svn commit: r340 - trunk/mapbender/http/php/mod_user_gui.php
uli at osgeo.org
uli at osgeo.org
Wed May 24 07:58:45 EDT 2006
Author: uli
Date: 2006-05-24 11:58:45+0000
New Revision: 340
validation of permissions
prepared statements included
Modified: trunk/mapbender/http/php/mod_user_gui.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_user_gui.php?view=diff&rev=340&p1=trunk/mapbender/http/php/mod_user_gui.php&p2=trunk/mapbender/http/php/mod_user_gui.php&r1=339&r2=340
--- trunk/mapbender/http/php/mod_user_gui.php (original)
+++ trunk/mapbender/http/php/mod_user_gui.php 2006-05-24 11:58:45+0000
@@ -19,11 +19,13 @@
import_request_variables("PG");
session_start();
$gui_id = $_SESSION["mb_user_gui"];
-//require_once("mb_validateInput.php");
require_once("../../conf/mapbender.conf");
-require_once("../classes/class_wms.php");
-$con = db_connect($DBSERVER,$OWNER,$PW);
+$con = db_connect(DBSERVER,OWNER,PW);
db_select_db(DB,$con);
+require_once("mb_validatePermission.php");
+require_once("../classes/class_wms.php");
+$self = $PHP_SELF . "?".SID."&guiID=".$_REQUEST["guiID"]."&elementID=".$_REQUEST["elementID"];
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
@@ -79,12 +81,16 @@
if(count($selected_gui)>0){
for($i=0; $i<count($selected_gui); $i++){
$exists = false;
- $sql_insert = "SELECT * from gui_mb_user where fkey_mb_user_id = '".$selected_user."' and fkey_gui_id = '".$selected_gui[$i]."'";
- $res_insert = db_query($sql_insert);
+ $sql_insert = "SELECT * from gui_mb_user where fkey_mb_user_id = $1 and fkey_gui_id = $2";
+ $v = array($selected_user,$selected_gui[$i]);
+ $t = array('i','s');
+ $res_insert = db_prep_query($sql_insert,$v,$t);
while($row = db_fetch_array($res_insert)){$exists = true;}
if($exists == false){
- $sql_insert = "INSERT INTO gui_mb_user(fkey_mb_user_id, fkey_gui_id) VALUES('$selected_user', '".$selected_gui[$i]."');";
+ $sql_insert = "INSERT INTO gui_mb_user(fkey_mb_user_id, fkey_gui_id) VALUES($1, $2)";
@@ -92,8 +98,10 @@
if($remove){
if(count($remove_gui)>0){
for($i=0; $i<count($remove_gui); $i++){
- $sql_remove = "DELETE FROM gui_mb_user WHERE fkey_gui_id = '".$remove_gui[$i]."' and fkey_mb_user_id = '$selected_user'";
- db_query($sql_remove);
+ $sql_remove = "DELETE FROM gui_mb_user WHERE fkey_gui_id = $1 and fkey_mb_user_id = $2";
+ $v = array($remove_gui[$i],$selected_user);
+ $t = array('s','i');
+ db_prep_query($sql_remove,$v,$t);
@@ -120,12 +128,13 @@
/*get all gui from selected_user******************************************************************************/
$sql_user_mb_gui = "SELECT gui.gui_id, gui.gui_name, gui_mb_user.fkey_mb_user_id FROM gui_mb_user ";
$sql_user_mb_gui .= "INNER JOIN gui ON gui_mb_user.fkey_gui_id = gui.gui_id ";
-$sql_user_mb_gui .= "WHERE gui_mb_user.fkey_mb_user_id=";
+$sql_user_mb_gui .= "WHERE gui_mb_user.fkey_mb_user_id = $1 ORDER BY gui.gui_name";
+if(!$selected_user){$v = array($user_id[0]);}
+if($selected_user){$v = array($selected_user);}
+$t = array('i');
-if(!$selected_user){$sql_user_mb_gui .= $user_id[0];}
-if($selected_user){$sql_user_mb_gui .= $selected_user;}
-$sql_user_mb_gui .= " ORDER BY gui.gui_name";
-$res_user_mb_gui = db_query($sql_user_mb_gui);
+$res_user_mb_gui = db_prep_query($sql_user_mb_gui,$v,$t);
while($row = db_fetch_array($res_user_mb_gui)){
$gui_id_user[$cnt_gui_user] = $row["gui_id"];
$gui_name_user[$cnt_gui_user] = $row["gui_name"];
@@ -133,7 +142,7 @@
/*INSERT HTML*/
-echo "<form name='form1' action='" . $PHP_SELF . "?".SID."&e_id_css=".$_REQUEST["e_id_css"]."' method='post'>";
+echo "<form name='form1' action='" . $self ."&e_id_css=".$_REQUEST["e_id_css"]."' method='post'>";
/*insert all user in selectbox*************************************************************************************/
echo "<div class='text1'>USER: </div>";
More information about the Mapbender_commits
