svn commit: r354 - trunk/mapbender/http/javascripts
christoph at osgeo.org
Mon May 29 06:42:49 EDT 2006
Author: christoph
Date: 2006-05-29 10:42:49+0000
New Revision: 354
Added:
trunk/mapbender/http/javascripts/mod_geometryArray.js
trunk/mapbender/http/javascripts/point.js
trunk/mapbender/http/javascripts/wfs_usemap.js
new geometry classes
Added: trunk/mapbender/http/javascripts/mod_geometryArray.js
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_geometryArray.js?view=auto&rev=354
--- (empty file)
+++ trunk/mapbender/http/javascripts/mod_geometryArray.js 2006-05-29 10:42:49+0000
@@ -0,0 +1,537 @@
+// http://www.mapbender.org/index.php/GeometryArray.js
+<?php
+require_once('point.js');
+var geomTypePolygon = "polygon";
+var geomTypeLine = "line";
+var geomTypePoint = "point";
+var nameGeometryArray = "GeometryArray";
+var nameMultiGeometry = "MultiGeometry";
+var nameGeometry = "Geometry";
+// ----------- class: geometry array ------------------
+function GeometryArray(){
+ this.count = function(){
+ return this.m.length;
+ this.get = function(i){
+ i = this.getIndex(i);
+ if (i != null) return this.m[i];
+ return false;
+ this.getGeometry = function(i,j){
+ return this.get(i).get(j);
+ this.getPoint = function(i,j,k){
+ return this.get(i).get(j).get(k);
+ this.addMember = function(geomtype){
+ this.m[this.m.length] = new MultiGeometry(geomtype, -1);
+ this.appendMember = function(aMember){
+ this.m[this.m.length] = cloneObject(aMember);
+ this.del = function(i){
+ for(var z = i; z < this.m.length - 1; z++){
+ this.m[z] = this.m[z+1];
+ this.m.length -= 1;
+ this.delGeometry = function(i,j){
+ var res = this.get(i).del(j);
+ if (res == false) this.del(i);
+ this.delPoint = function (i,j,k){
+ var res = this.get(i).delPoint(j,k);
+ this.close = function(){
+ this.get(-1).get(-1).close();
+ if (this.get(-1).get(-1).count() == 0) {this.get(-1).del(-1);}
+ if (this.get(-1).count() == 0) {this.del(-1);}
+ this.delAllPointsLike = function(point){
+ var finished = false;
+ while (finished==false){
+ finished = true;
+ for (var i = 0 ; finished == true && i < this.count() ; i++){
+ for (var j = 0 ; finished == true && j < this.get(i).count() ; j++){
+ for (var k = 0 ; finished == true && k < this.get(i).get(j).count() ; k++){
+ if (this.getPoint(i,j,k).equals(point)){
+ this.delPoint(i,j,k);
+ finished = false;
+ this.updateAllPointsLike = function(oldP, newP){
+ for (var i = 0; i < this.count(); i++){
+ this.get(i).updateAllPointsLike(oldP, newP);
+ this.toString = function(){
+ var str = "";
+ for (var i =0 ; i < this.count() ; i++){
+ str += this.get(i).toString();
+ return str;
+ this.getIndex = function(i){ //private
+ if ((i >= 0 && i < this.m.length) || (i*(-1)>0 && i*(-1) <=this.m.length)){
+ if (i >= 0) return i; else return this.m.length+i;
+ else {
+ alert("exception: member index " + i + " is not valid");
+ return null;
+ this.name = nameGeometryArray;
+ this.m = new Array();
+// ----------- class: multigeometry -----------
+function MultiGeometry(geomtype, wfs_conf){
+ return this.g.length;
+ if (i != null){
+ return this.g[i];
+ return false;
+ this.getPoint = function(j,k){
+ return this.get(j).get(k);
+ this.addGeometry = function(){
+ this.g[this.g.length] = new Geometry(this.geomtype);
+ if (i != null){
+ var tmpLength = this.count() - 1;
+ for (var z = i; z < tmpLength ; z ++){
+ this.g[z] = this.g[z+1];
+ this.e[z] = this.e[z+1];
+ this.g.length -= 1;
+ if (this.g.length == 0){
+ return false;
+ return true;
+ this.delPoint = function(i,j){
+ if (res == false) {return this.del(i);}
+ return true;
+ this.emptyMember = function(){
+ this.g = new Array();
+ this.getBBox = function(){
+ var q = this.get(0).get(0);
+ var min = cloneObject(q);
+ var max = cloneObject(q);
+ for(var i=0; i<this.count();i++){
+ var pos = this.get(i).getBBox();
+ if (pos[0].x < min.x) {min.x = pos[0].x;}
+ if (pos[1].x > max.x) {max.x = pos[1].x;}
+ if (pos[1].y > min.y) {min.y = pos[1].y;}
+ if (pos[0].y < max.y) {max.y = pos[0].y;}
+ return new Array(min, max);
+ this.getCenter = function(){
+ var tmp = this.getBBox();
+ var x = parseFloat(tmp[0].x) + parseFloat((tmp[1].x - tmp[0].x)/2);
+ var y = parseFloat(tmp[0].y) + parseFloat((tmp[1].y - tmp[0].y)/2);
+ return new Point(x,y);
+ this.getTotalPointCount = function(){
+ var c = 0;
+ for (var i = 0 ; i < this.count(); i++){
+ c += this.get(i).count();
+ return c;
+ var str = "";
+ return str;
+ if ((i >= 0 && i < this.g.length) || (i*(-1)>0 && i*(-1) <=this.g.length)){
+ if (i >= 0) {return i;} else {return this.g.length+i;}
+ else {
+ alert("exception: geometry index is not valid");
+ return null;
+ this.e = new Wfs_element();
+ this.geomtype = geomtype;
+ this.name = nameMultiGeometry;
+ this.wfs_conf = wfs_conf;
+// ----------- class: geometry ------------------------
+function Geometry(aGeomtype){
+ return this.v.length;
+ if (i != null){return this.v[i];}
+ return false;
+ var q = this.get(0);
+ for (var j=0; j<this.count(); j++){
+ var pos = this.get(j);
+ if (pos.x < min.x) {min.x = pos.x;}
+ else if (pos.x > max.x) {max.x = pos.x;}
+ if (pos.y < min.y) {min.y = pos.y;}
+ else if (pos.y > max.y) {max.y = pos.y;}
+ this.complete = true;
+ if (this.geomtype == geomTypePolygon){
+ if (this.count() > 0){this.addPoint(this.get(0));}
+ this.addPointByCoordinates = function(x,y){
+ this.v[this.v.length] = new Point(x,y);
+// this.updateDist();
+ this.addPoint = function(aPoint){
+ this.v[this.v.length] = new Point(aPoint.x, aPoint.y);
+ this.addPointAtIndex = function(p,i){
+ if (i != null){
+ for(var z = this.v.length; z > i; z--){
+ this.v[z] = this.v[z-1];
+ this.v[i] = new Point(p.x, p.y);
+ if (i != null) {
+ var tmpLength = this.count()-1;
+ this.v[z] = this.v[z+1];
+ this.v.length -= 1;
+ if (i == tmpLength) {this.v[0] = this.v[tmpLength-1];}
+ else if (i == 0) {this.v[tmpLength-1] = this.v[0];}
+ if (this.v.length == 1){return false;}
+ if(this.v.length == 0) {return false;}
+ return true;
+ return false;
+ this.updateGeometry = function(p, i){
+ if ((i == 0 || i == this.count()-1) && this.geomtype == geomTypePolygon){
+ this.v[0] = p;
+ this.v[this.count()-1] = p;
+ else {this.v[i] = p;}
+ var len = this.count();
+ for (var i = 0; i < len ; i++){
+ if (oldP.equals(this.get(i))){
+ if (i>0 && newP.equals(this.get(i-1))){
+ this.del(i);
+ len--;
+ i--;
+ else this.updateGeometry(newP, i);
+ this.isComplete = function() {
+ return this.complete;
+ var str = "";
+ return str;
+ if ((i >= 0 && i < this.v.length) || (i*(-1)>0 && i*(-1) <=this.v.length)){
+ if (i >= 0) {return i;} else {return this.v.length+i;}
+ else {
+ alert("exception: point index is not valid");
+ return null;
+ this.updateDist = function(){ //private
+ this.dist[0] = 0;
+ this.totaldist[0] = 0;
+ for (var i = 1 ; i < this.count(); i++){
+ this.dist[i] = this.get(i-1).dist(this.get(i));
+ this.totaldist[i] = this.totaldist[i-1] + this.dist[i];
+ this.geomtype = aGeomtype;
+ this.complete = false;
+ this.v = new Array();
+ this.dist = new Array();
+ this.totaldist = new Array();
+ this.name = nameGeometry;
+// ----------- class: Wfs_element ---------------------
+function Wfs_element(){
+ return this.name.length;
+ this.getElementValueByName = function(elementName){
+ var i = this.getElementIndexByName(elementName);
+ if (i == -1) {return false;}
+ return this.value[i];
+ this.getName = function(i){
+ if (this.isValidElementIndex(i)) {return this.name[i];}
+ return false;
+ this.getValue = function(i){
+ if (this.isValidElementIndex(i)) {return this.value[i];}
+ return false;
+ this.setElement = function(aName, aValue){
+ var i = this.getElementIndexByName(aName);
+ if (i == -1){
+ i = this.name.length;
+ this.name[i] = aName;
+ this.value[i] = aValue;
+ return true;
+ this.getElementIndexByName = function(elementName){ // private
+ var arrayLength = this.name.length;
+ for (var j = 0 ; j < arrayLength ; j++){
+ if (this.name[j] == elementName) {return j;}
+ return -1;
+ this.isValidElementIndex = function(i){ //private
+ if (i>=0 && i<this.name.length) {return true;}
+ alert("exception: illegal element index");
+ return false;
+ this.name = new Array();
+ this.value = new Array();
+// ----------- class: Snapping --------------------------
+function Snapping(aTarget, tolerance, color, isInFrame){
+ this.isSnapped = function(){
+ if (this.min_i != -1) {return true;}
+ return false;
+ this.getSnappedPoint = function(geom){
+ var point;
+ var i = this.coord[this.min_i]['member'];
+ var j = this.coord[this.min_i]['geometry'];
+ var k = this.coord[this.min_i]['point'];
+ if (geom.name == nameGeometryArray) {point = geom.getPoint(i,j,k);}
+ else if (geom.name == nameMultiGeometry) {point = geom.getPoint(j,k);}
+ else if (geom.name == nameGeometry) {point = geom.get(k);}
+ return point;
+ this.check = function(currPoint){
+ var minDist = false;
+ for (var i = 0 ; i < this.coord.length ; i++) {
+ var aDist = currPoint.dist(this.coord[i]['coord']);
+ if (minDist == false || aDist < minDist) {
+ minDist = aDist;
+ if (minDist < this.tolerance) {this.min_i = i;}
+ if (this.coord.length>0 && minDist > this.tolerance) {this.min_i = -1;}
+ this.clean();
+ if (this.min_i != -1){
+ this.draw(this.coord[this.min_i]['coord'], this.tolerance, 3);
+ this.add = function(geom, k, j, i){
+ var cnt = this.coord.length;
+ this.coord[cnt] = new Array();
+ if (typeof(j) != 'undefined'){
+ if (typeof(i) != 'undefined'){
+ this.coord[cnt]['coord'] = parent.realToMap(this.target, geom.getPoint(i,j,k));
+ else this.coord[cnt]['coord'] = parent.realToMap(this.target, geom.getPoint(j,k));
+ else this.coord[cnt]['coord'] = parent.realToMap(this.target, geom.get(k));
+ this.coord[cnt]['member'] = i;
+ this.coord[cnt]['geometry'] = j;
+ this.coord[cnt]['point'] = k;
+ this.store = function(geom, event, point){
+ this.coord = new Array();
+ this.min_i = -1;
+ for (var i = 0 ; i < geom.count(); i++){
+ if (geom.name == nameGeometryArray || geom.name == nameMultiGeometry){
+ for (var j = 0 ; j < geom.get(i).count() ; j++){
+ if (geom.get(i).name == nameMultiGeometry){
+ for (var k = 0 ; k < geom.get(i).get(j).count() ; k++){
+ if ((event != button_move && geom.get(i).get(j).isComplete() == true) || (typeof(point) != 'undefined' && !geom.get(i).get(j).get(k).equals(point))){
+ this.add(geom, k, j, i);
+ else {
+ this.add(geom, j, i);
+ else {
+ this.add(geom, i);
+ this.draw = function(center,radius,size){ //private
+ this.canvas.setColor(this.color);
+ this.canvas.drawEllipse(-2+center.x-(size/2)*radius,-2+center.y-(size/2)*radius,size*radius,size*radius);
+ this.canvas.paint();
+ this.clean = function(){ // private
+ var el = parent.window.frames[this.target].document.getElementById(this.divtag);
+ if (el) el.innerHTML = "";
+ this.tolerance = (typeof(tolerance) == 'undefined') ? 10 : tolerance;
+ this.color = (typeof(color) == 'undefined') ? "#ff0000" : color;
+ this.target = aTarget;
+ this.coord = new Array(); // private
+ this.canvas; // private
+ this.divtag = "snapping"+Math.random()*Math.pow(10,10); //private
+ this.min_i = -1; //private
+ var attributes = new Array();
+ attributes[0] = new Array();
+ attributes[0][0] = "style";
+ attributes[0][1] = "position:absolute;top:0px;left:0px;width:0px;height:0px;z-index:500";
+ if (isInFrame == true){
+ node = parent.mb_checkTag(this.target, "div", this.divtag, "body", attributes);
+ this.canvas = new parent.jsGraphics(this.divtag, parent.window.frames[this.target]);
+ else{
+ node = mb_checkTag(this.target, "div", this.divtag, "body", attributes);
+ this.canvas = new jsGraphics(this.divtag, window.frames[this.target]);
+ this.canvas.setStroke(3);
+ if (node == false) {alert("Fatal error: Element id is already taken!");}
Added: trunk/mapbender/http/javascripts/point.js
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/point.js?view=auto&rev=354
--- (empty file)
+++ trunk/mapbender/http/javascripts/point.js 2006-05-29 10:42:49+0000
@@ -0,0 +1,87 @@
+//http://www.mapbender.org/index.php/point.js
+function Point(x, y){
+ this.dist = function(p){
+ return Math.sqrt(Math.pow(this.y-p.y,2) + Math.pow(this.x-p.x,2)) ;
+ this.equals = function(p){
+ if (this.x == p.x && this.y == p.y) {return true;}
+ return false;
+ this.minus = function(p){
+ return new Point(this.x-p.x, this.y-p.y);
+ this.plus = function(p){
+ return new Point(this.x+p.x, this.y+p.y);
+ this.dividedBy = function(c){
+ if (c != 0) {return new Point(this.x/c, this.y/c);}
+ alert("Exception: Division by zero");
+ return false;
+ this.times = function(c){
+ return new Point(this.x*c, this.y*c);
+ this.round = function(numOfDigits){
+ var tmpX = Math.round(this.x*Math.pow(10, parseInt(numOfDigits)))/Math.pow(10, parseInt(numOfDigits));
+ var tmpY = Math.round(this.y*Math.pow(10, parseInt(numOfDigits)))/Math.pow(10, parseInt(numOfDigits));
+ return new Point(tmpX, tmpY);
+ return "(" + this.x + ", " + this.y + ")";
+ this.x = x;
+ this.y = y;
+// possible improvement: point has flag: map OR real. additional functions: toReal, toMap
+function mapToReal(frameName, aPoint) {
+ var v = makeClickPos2RealWorldPos(frameName, aPoint.x, aPoint.y);
+ return new Point(v[0], v[1]);
+function realToMap(frameName, aPoint) {
+ var v = makeRealWorld2mapPos(frameName, aPoint.x, aPoint.y);
+ return new Point(Math.round(v[0]), Math.round(v[1]));
+function mb_calcExtent(frameName, min, max) {
+ var ind = getMapObjIndexByName(frameName);
+ var extent = max.minus(min);
+ var center = extent.dividedBy(2).plus(min);
+ var relation_px_x = mb_mapObj[ind].width / mb_mapObj[ind].height;
+ var relation_px_y = mb_mapObj[ind].height / mb_mapObj[ind].width;
+ var relation_bbox_x = extent.x / extent.y;
+ if(relation_bbox_x <= relation_px_x){
+ min = new Point(center.x - relation_px_x * extent.y / 2, min.y);
+ max = new Point(center.x + relation_px_x * extent.y / 2, max.y);
+ else if(relation_bbox_x > relation_px_x){
+ min = new Point(min.x, center.y - relation_px_y * extent.x / 2);
+ max = new Point(max.x, center.y + relation_px_y * extent.x / 2);
+ mb_mapObj[ind].extent = min.x +","+ min.y +","+ max.x +","+ max.y;
+function cloneObject(a){
+ var z = new Array();
+ for (attr in a) {
+ var b = a[attr];
+ if (typeof(b) == "object") {z[attr] = cloneObject(b);}
+ else z[attr] = b;
+ return z;
\ No newline at end of file
Added: trunk/mapbender/http/javascripts/wfs_usemap.js
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/wfs_usemap.js?view=auto&rev=354
--- (empty file)
+++ trunk/mapbender/http/javascripts/wfs_usemap.js 2006-05-29 10:42:49+0000
@@ -0,0 +1,179 @@
+// --- usemap (begin) --------------------------------------------------------------------------------------------
+function mod_usemap (wfs_name) {
+ if (wfs_name == "") {
+ usemap = "";
+ var ind = getMapObjIndexByName(mb_wfs_targets[0]);
+ var myImg = window.frames[mb_wfs_targets[0]].document.getElementById("um_img").style;
+ myImg.width = mb_mapObj[ind].width;
+ myImg.height = mb_mapObj[ind].height;
+ for (var i = 0 ; i < mb_wfs_fetch.length ; i ++) {
+ if (mb_wfs_fetch[i]['wfs_conf'] == wfs_name || wfs_name == "") {
+ if (mb_wfs_fetch[i]['geomtype'] == geomTypePolygon) {
+ usemap += mod_usemap_polygon(i);
+ else if (mb_wfs_fetch[i]['geomtype'] == geomTypePoint) {
+ usemap += mod_usemap_circle(i);
+ else if (mb_wfs_fetch[i]['geomtype'] == geomTypeLine) {
+ usemap += mod_usemap_line(i);
+ writeUsemap(usemap);
+function mod_usemap_circle(ind){
+ var str = "";
+ var coord = "";
+ for (var i = 0 ; i < mb_wfs_fetch[ind]['geometry'].length ; i ++) {
+ var xArray = mb_wfs_fetch[ind]['geometry'][i]['x'];
+ var yArray = mb_wfs_fetch[ind]['geometry'][i]['y'];
+ var title = getElementValueByName(mb_wfs_fetch, ind, "name") + " (Pt)";
+ var pos = makeRealWorld2mapPos(mb_wfs_targets[0],xArray[0],yArray[0]);
+ coord += pos[0] + ", " + pos[1];
+ str += "<AREA onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch["+ind+"])' ";
+ str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch["+ind+"])' shape='circle' coords='";
+ str += coord + ", " + mod_usemap_radius + "' href='#'>";
+ return str;
+function mod_usemap_line_calculate (xArray, yArray, j, orientation, cnt) {
+ var coord = "";
+ var p1 = makeRealWorld2mapPos(mb_wfs_targets[0],xArray[j],yArray[j]);
+ var p2 = makeRealWorld2mapPos(mb_wfs_targets[0],xArray[j+orientation],yArray[j+orientation]);
+ var vec = new Array();
+ vec[0] = p2[0] - p1[0];
+ vec[1] = p2[1] - p1[1];
+ if (vec[0] != 0 || vec[1] != 0) {
+ n_vec = new Array();
+ if (vec[0] != 0) {
+ if (vec[0] > 0) {
+ n_vec[0] = (-vec[1])/vec[0];
+ n_vec[1] = -1;
+ else {
+ n_vec[0] = (vec[1])/vec[0];
+ n_vec[1] = 1;
+ else {
+ if (vec[1] > 0) {
+ n_vec[0] = 1;
+ n_vec[1] = 0;
+ else {
+ n_vec[0] = -1;
+ n_vec[1] = 0;
+ n_vec_length = Math.sqrt(Math.pow(n_vec[0], 2) + Math.pow(n_vec[1], 2));
+ n_vec[0] = (n_vec[0]*mod_usemap_line_tolerance)/n_vec_length;
+ n_vec[1] = (n_vec[1]*mod_usemap_line_tolerance)/n_vec_length;
+ lp = new Array();
+ lp[0] = p1[0] + n_vec[0];
+ lp[1] = p1[1] - n_vec[1];
+ if (cnt > 0) {
+ coord += ", ";
+ coord += parseInt(lp[0]) + ", " + parseInt(lp[1]);
+ coord += ", " + parseInt(lp[0]+vec[0]) + ", " + parseInt(lp[1]+vec[1]);
+ return coord;
+function mod_usemap_line(ind){
+ var str = "";
+ var coord = "";
+ var cnt = 0;
+ xArray = new Array();
+ xArray = mb_wfs_fetch[ind]['geometry'][i]['x'];
+ yArray = new Array();
+ yArray = mb_wfs_fetch[ind]['geometry'][i]['y'];
+ for (var j = 0 ; j < xArray.length - 1 ; j ++) {
+ var result = mod_usemap_line_calculate(xArray, yArray, j, 1, cnt);
+ if (result != "") {
+ coord += result;
+ cnt++;
+ for (var j = (xArray.length - 1) ; j > 0 ; j--) {
+ var result = mod_usemap_line_calculate(xArray, yArray, j, -1, cnt);
+ coord += result;
+ cnt++;
+ if (coord != "") {
+ str += "<AREA ";
+ str += "onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch["+ind+"])' ";
+ str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch["+ind+"])' ";
+ str += "shape='poly' coords='";
+ str += coord + "' href='#'>";
+ else {
+ //display circle
+ return str;
+function mod_usemap_polygon(ind){
+ var str = "";
+ var coord = "";
+ var title = getElementValueByName(mb_wfs_fetch, ind, "name") + " (Py)";
+ for (var j = 1 ; j < xArray.length ; j ++) {
+ pos = makeRealWorld2mapPos(mb_wfs_targets[0],xArray[j],yArray[j]);
+ coord += ", " + pos[0] + ", " + pos[1];
+ str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch["+ind+"])' shape='poly' coords='";
+ return str;
+function writeUsemap(str) {
+ writeTag(mb_wfs_targets[0], 'um', str);
+// --- usemap (end) ----------------------------------------------------------------------------------------------
More information about the Mapbender_commits
