svn commit: r850 - trunk/mapbender/http/classes
christoph at osgeo.org
Mon Nov 20 08:55:33 EST 2006
Author: christoph
Date: 2006-11-20 13:55:32+0000
New Revision: 850
trunk/mapbender/http/classes/class_connector.php
trunk/mapbender/http/classes/class_database.php
trunk/mapbender/http/classes/class_database_table.php
include via dirname(__FILE__)
Modified: trunk/mapbender/http/classes/class_connector.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_connector.php?view=diff&rev=850&p1=trunk/mapbender/http/classes/class_connector.php&p2=trunk/mapbender/http/classes/class_connector.php&r1=849&r2=850
--- trunk/mapbender/http/classes/class_connector.php (original)
+++ trunk/mapbender/http/classes/class_connector.php 2006-11-20 13:55:32+0000
@@ -1,3 +1,4 @@
<?php
# $Id$
# http://www.mapbender.org/index.php/class_connector
@@ -17,7 +18,7 @@
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once("../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
class connector{
var $file;
Modified: trunk/mapbender/http/classes/class_database.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_database.php?view=diff&rev=850&p1=trunk/mapbender/http/classes/class_database.php&p2=trunk/mapbender/http/classes/class_database.php&r1=849&r2=850
--- trunk/mapbender/http/classes/class_database.php (original)
+++ trunk/mapbender/http/classes/class_database.php 2006-11-20 13:55:32+0000
@@ -24,7 +24,7 @@
contact christoph.baudson at ccgis.de for help
-require_once("class_database_table.php");
+require_once(dirname(__FILE__)."/class_database_table.php");
class database{
Modified: trunk/mapbender/http/classes/class_database_table.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_database_table.php?view=diff&rev=850&p1=trunk/mapbender/http/classes/class_database_table.php&p2=trunk/mapbender/http/classes/class_database_table.php&r1=849&r2=850
--- trunk/mapbender/http/classes/class_database_table.php (original)
+++ trunk/mapbender/http/classes/class_database_table.php 2006-11-20 13:55:32+0000
@@ -17,9 +17,9 @@
-require_once("class_database_table_column.php");
-require_once("class_database_table_key.php");
-require_once("class_database_table_constraint.php");
+require_once(dirname(__FILE__)."/class_database_table_column.php");
+require_once(dirname(__FILE__)."/class_database_table_key.php");
+require_once(dirname(__FILE__)."/class_database_table_constraint.php");
class database_table{
More information about the Mapbender_commits
