svn commit: r865 - trunk/mapbender/http/php
christoph at osgeo.org
Mon Nov 20 09:25:12 EST 2006
Author: christoph
Date: 2006-11-20 14:25:12+0000
New Revision: 865
trunk/mapbender/http/php/mod_newGui.php
trunk/mapbender/http/php/mod_printView1.php
trunk/mapbender/http/php/mod_renameGUI.php
include via dirname(__FILE__)
Modified: trunk/mapbender/http/php/mod_newGui.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_newGui.php?view=diff&rev=865&p1=trunk/mapbender/http/php/mod_newGui.php&p2=trunk/mapbender/http/php/mod_newGui.php&r1=864&r2=865
--- trunk/mapbender/http/php/mod_newGui.php (original)
+++ trunk/mapbender/http/php/mod_newGui.php 2006-11-20 14:25:12+0000
@@ -18,10 +18,10 @@
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
import_request_variables("PG");
-require_once("../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
$con = db_connect(DBSERVER,OWNER,PW);
db_select_db(DB,$con);
-require_once("../php/mb_validatePermission.php");
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
$self = $PHP_SELF . "?".SID."&guiID=".$_REQUEST["guiID"]."&elementID=".$_REQUEST["elementID"];
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
@@ -58,7 +58,7 @@
$v = array($newGui,$_SESSION["mb_user_id"], 'owner');
$t = array('s','i','s');
$res = db_prep_query($sql,$v,$t);
- require_once("mb_getGUIs.php");
+ require_once(dirname(__FILE__)."/mb_getGUIs.php");
$arrayGUIs = mb_getGUIs( $_SESSION["mb_user_id"]);
$_SESSION["mb_user_guis"] = $arrayGUIs;
$guiCreated=true;
Modified: trunk/mapbender/http/php/mod_printView1.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_printView1.php?view=diff&rev=865&p1=trunk/mapbender/http/php/mod_printView1.php&p2=trunk/mapbender/http/php/mod_printView1.php&r1=864&r2=865
--- trunk/mapbender/http/php/mod_printView1.php (original)
+++ trunk/mapbender/http/php/mod_printView1.php 2006-11-20 14:25:12+0000
@@ -22,7 +22,7 @@
$_SESSION["mb_print_url"] = $map_url;
$_SESSION["mb_print_resolution"] = $quality;
-include("../../conf/print.conf");
+include(dirname(__FILE__)."/../../conf/print.conf");
Modified: trunk/mapbender/http/php/mod_renameGUI.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_renameGUI.php?view=diff&rev=865&p1=trunk/mapbender/http/php/mod_renameGUI.php&p2=trunk/mapbender/http/php/mod_renameGUI.php&r1=864&r2=865
--- trunk/mapbender/http/php/mod_renameGUI.php (original)
+++ trunk/mapbender/http/php/mod_renameGUI.php 2006-11-20 14:25:12+0000
@@ -18,11 +18,11 @@
session_start();
-require_once("../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
@@ -153,8 +153,8 @@
<body onLoad='document.form1.newGuiName.focus()'>
<?php
-require_once("../classes/class_administration.php");
-require_once("../classes/class_gui.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+require_once(dirname(__FILE__)."/../classes/class_gui.php");
###rename
if($rename || $copy){
@@ -173,7 +173,7 @@
$admin = new administration();
-$ownguis = $admin->getGuisByOwner($_SESSION["mb_user_id"]);
+$ownguis = $admin->getGuisByOwner($_SESSION["mb_user_id"],true);
echo "<form name='form1' action='" . $self ."' method='post'>";
if(count($ownguis)>0){
More information about the Mapbender_commits
