svn commit: r898 - trunk/mapbender/http/javascripts/mod_savewmc.php
christoph at osgeo.org
Tue Nov 21 03:44:14 EST 2006
Author: christoph
Date: 2006-11-21 08:44:13+0000
New Revision: 898
* added js function htmlspecialchars
* added keywords (for a start 'Mapbender' and 'WMC')
* added scalehints (TODO: change to 'Extensions')
* changed epsg from mb_mapObj[ind].epsg to mb_mapObj[ind].wms[i].gui_wms_epsg
* added correct data format
* removed obsolete function mod_savewmc_init
Modified: trunk/mapbender/http/javascripts/mod_savewmc.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_savewmc.php?view=diff&rev=898&p1=trunk/mapbender/http/javascripts/mod_savewmc.php&p2=trunk/mapbender/http/javascripts/mod_savewmc.php&r1=897&r2=898
--- trunk/mapbender/http/javascripts/mod_savewmc.php (original)
+++ trunk/mapbender/http/javascripts/mod_savewmc.php 2006-11-21 08:44:13+0000
@@ -45,13 +45,7 @@
document.getElementsByTagName('body')[0].setAttribute("onUnload", "mod_savewmc('session');");
-try {
- if (saveInSession) {}
-catch(e) {
- saveInSession = 0;
+try {if (saveInSession) {}}catch(e) {saveInSession = 0;}
if (saveInSession == '1') {
mb_registerInitFunctions('setOnUnload()');
@@ -60,19 +54,34 @@
var mod_savewmc_img = new Image(); mod_savewmc_img.src = "<?php echo $e_src; ?>";
//var mod_savewmc_img_over = new Image(); mod_savewmc_img_over.src = "<?php echo preg_replace("/_off/","_over",$e_src); ?>";
+//0 = Keine Anführungszeichen umwandeln
+//1 = Nur einfache Anführungszeichen umwandeln
+//2 = Nur doppelte Anführungszeichen umwandeln (Standardeinstellung)
+//3 = Beide Arten (einfache und doppelte Anführungszeichen) umwandeln
+function htmlspecialchars(str,typ) {
+ if(typeof str=="undefined") str="";
+ if(typeof typ!="number") typ=2;
+ typ=Math.max(0,Math.min(3,parseInt(typ)));
+ var html=new Array();
+ html[38]="&"; html[60]="&#60;"; html[62]="&#62;";
+ if(typ==1 || typ==3) html[39]="&#39;";
+ if(typ==2 || typ==3) html[34]="&#34;";
+ for(var i in html) eval("str=str.replace(/"+String.fromCharCode(i)+"/g,\""+html[i]+"\");");
+ return str;
function mod_savewmc(title){
var user = "<?php echo $_SESSION["mb_user_id"]; ?>";
var ind = getMapObjIndexByName(mod_savewmc_target);
var session = 0;
if (title) {
- var generalTitle = title;
+ var generalTitle = htmlspecialchars(title,0);
title_alert = 0;
if (title == 'session') {
session = 1;
else {
- var generalTitle = prompt("Save WMC as...");
+ var generalTitle = htmlspecialchars(prompt("Save WMC as..."),0);
title_alert = 1;
if (generalTitle != null){
@@ -137,7 +146,7 @@
// Missing: Extension
//ViewContext
- wmc += "<?xml version=\"1.0\" encoding=\"<?php echo CHARSET; ?>\" ?>\n";
+ wmc += "<?xml version=\"1.0\" encoding=\"<?php echo CHARSET; ?>\"?>";
// wmc += "<!ENTITY amp \"&#38;#38;\">\n";
wmc += "<ViewContext version=\"" + version + "\" ";
wmc += "id = \"" + id + "\" ";
@@ -241,15 +250,15 @@
// BEGIN: new code
- // in the end, this array contains all epsg´s of this wms
+ // in the end, this array contains all epsgs of this wms
var wms_epsg = new Array();
- // the gui_wms_epsg is always the first epsg in this layer´s epsg list
- wms_epsg[0] = mb_mapObj[ind].wms[i].gui_wms_epsg;
+ // the gui_wms_epsg is always the first epsg in this layers epsg list
+ wms_epsg[0] = mb_mapObj[ind].epsg;
// the epsg of the mapObj has to be in this list
if (mb_mapObj[ind].wms[i].gui_wms_epsg != mb_mapObj[ind].epsg){
- wms_epsg[1] = mb_mapObj[ind].epsg;
+ wms_epsg[1] = mb_mapObj[ind].wms[i].gui_wms_epsg;
// add all gui_epsg if not already in the array
@@ -276,17 +285,16 @@
layerHidden = 1;
layerQueryable = mb_mapObj[ind].wms[i].objLayer[j].layer_queryable;
- layerName = mb_mapObj[ind].wms[i].objLayer[j].layer_name;
- layerTitle = mb_mapObj[ind].wms[i].objLayer[j].layer_title;
+ layerName = htmlspecialchars(mb_mapObj[ind].wms[i].objLayer[j].layer_name,0);
+ layerTitle = htmlspecialchars(mb_mapObj[ind].wms[i].objLayer[j].layer_title, 0);
layerAbstract = mb_mapObj[ind].wms[i].wms_abstract; //To Do: insert actual abstract
layerDataUrl = mb_mapObj[ind].wms[i].objLayer[j].layer_dataurl_href;
- //layerDataUrl = mb_mapObj[ind].wms[i].objLayer[j].layer_dataurl_href;
- layerMetadataUrl = mb_mapObj[ind].wms[i].objLayer[j].layer_metadataurl;
- //layerMetadataUrl = mb_mapObj[ind].wms[i].objLayer[j].layer_metadataurl;
+ layerMetadataUrl = mb_mapObj[ind].wms[i].objLayer[j].layer_metadataurl;
+ layerMinscale = mb_mapObj[ind].wms[i].objLayer[j].layer_minscale;
+ layerMaxscale = mb_mapObj[ind].wms[i].objLayer[j].layer_maxscale;
wmsVersion = mb_mapObj[ind].wms[i].wms_version;
- wmsTitle = mb_mapObj[ind].wms[i].wms_title;
+ wmsTitle = htmlspecialchars(mb_mapObj[ind].wms[i].wms_title,0) ;
wmsOnlineResource = mb_mapObj[ind].wms[i].wms_getmap;
- //wmsOnlineResource = mb_mapObj[ind].wms[i].wms_getmap;
wmc += "\t\t<Layer queryable = \"" + layerQueryable + "\" hidden = \"" + layerHidden + "\">\n";
wmc += "\t\t\t<Server service = \"OGC:WMS\" version = \"" + wmsVersion + "\" title = \"" + wmsTitle + "\">\n";
@@ -321,26 +329,29 @@
wmc += "\t\t\t</MetadataURL>\n";
+ if (layerMinscale && layerMaxscale) {
+ wmc += "\t\t\t<ScaleHint min=\""+layerMinscale+"\" max=\""+layerMaxscale+"\"/>\n";
//layerFormat
wmc += "\t\t\t<FormatList>\n";
- for (var k = 0; k < 1; k++){
+ var data_format_current = false;
+ for (var k = 0; k < wms[i].data_format.length; k++){
- if (k == 0){
- layerFormat_current = 1; // To do: insert proper data
- else{
- layerFormat_current = 0; // To do: insert proper data
- layerFormat = mb_mapObj[ind].wms[i].gui_wms_mapformat;
- wmc += "\t\t\t\t<Format ";
- if (layerFormat_current == 1){
- wmc += "current = \"1\"";
+ if (wms[i].data_type[k] == 'map') {
+ layerFormat = mb_mapObj[ind].wms[i].data_format[k];
+ wmc += "\t\t\t\t<Format";
+ if (data_format_current == false && (
+ (mb_mapObj[ind].wms[i].data_format[k] == mb_mapObj[ind].wms[i].gui_wms_mapformat) ||
+ (k == wms[i].data_format.length-1)
+ wmc += " current = \"1\"";
+ data_format_current = true;
+ wmc += ">" + layerFormat + "</Format>\n";
- wmc += ">" + layerFormat + "</Format>\n";
wmc += "\t\t\t</FormatList>\n";
// LayerStyle
@@ -378,8 +389,6 @@
layerStyle_legendUrl_height = ""; // To Do: add proper data
layerStyle_legendUrl_format = ""; // To Do: add proper data
- //layerStyle_legendUrl = stripAmpersand(mb_mapObj[ind].wms[i].wms_getlegendurl);
if (layerStyle_current == 1){
@@ -404,7 +413,7 @@
wmc += "\t</LayerList>\n";
wmc += "</ViewContext>\n";
- if (session == true) {
+ if (session == 1) {
var wmc_win = window.open('about:blank', 'wmc_confirm', 'width=200,height=10,left='+Math.round(0.5*screen.width)+',top='+Math.round(0.5*screen.height));
document.sendData.target = 'wmc_confirm';
// document.sendData.target = '_blank';
@@ -415,12 +424,4 @@
document.sendData.submit();
return id;
-function mod_savewmc_init(obj){
- //document.getElementById("savewmc").src = mod_zoom1_img_over.src;
- //obj.onmouseover = new Function("mod_zoomIn1_over()");
- //obj.onmouseout = new Function("mod_zoomIn1_out()");
\ No newline at end of file
More information about the Mapbender_commits
