svn commit: r911 - trunk/mapbender/http/frames/login.php
christoph at osgeo.org
Tue Nov 21 05:44:26 EST 2006
Author: christoph
Date: 2006-11-21 10:44:26+0000
New Revision: 911
include via dirname(__FILE__)
Modified: trunk/mapbender/http/frames/login.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/frames/login.php?view=diff&rev=911&p1=trunk/mapbender/http/frames/login.php&p2=trunk/mapbender/http/frames/login.php&r1=910&r2=911
--- trunk/mapbender/http/frames/login.php (original)
+++ trunk/mapbender/http/frames/login.php 2006-11-21 10:44:26+0000
@@ -1,5 +1,5 @@
<?php
-# $Id$
+# $Id: login.php 76 2006-08-15 12:25:34Z heuser $
# Copyright (C) 2002 CCGIS
# This program is free software; you can redistribute it and/or modify
@@ -17,7 +17,7 @@
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
ob_start();
-include_once("../../conf/mapbender.conf");
+include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
$con = db_connect(DBSERVER,OWNER,PW);
db_select_db(DB,$con);
@@ -148,13 +148,13 @@
// if given user data is found in database, set session data (db_fetch_array returns false if no row is found)
if($row){
setSession();
- include("../../conf/session.conf");
+ include(dirname(__FILE__)."/../../conf/session.conf");
if($_SESSION["mb_user_id"]){
if($row["mb_user_login_count"] < $loginMax){
$sql_del_cnt = "UPDATE mb_user SET mb_user_login_count = 0 WHERE mb_user_id = " . $_SESSION['mb_user_id'];
db_query($sql_del_cnt);
- require_once("../php/mb_getGUIs.php");
+ require_once(dirname(__FILE__)."/../php/mb_getGUIs.php");
$arrayGUIs = mb_getGUIs($row["mb_user_id"]);
$_SESSION["mb_user_guis"] = $arrayGUIs;
$_SESSION["mb_login"] = $login;
@@ -176,7 +176,7 @@
# list all guis of this user and his groups
else{
- require_once("../php/mb_listGUIs.php");
+ require_once(dirname(__FILE__)."/../php/mb_listGUIs.php");
mb_listGUIs($arrayGUIs);
More information about the Mapbender_commits
