svn commit: r926 - trunk/mapbender/http: javascripts php
christoph at osgeo.org christoph at osgeo.org
Tue Nov 21 07:49:21 EST 2006
Author: christoph
Date: 2006-11-21 12:49:21+0000
New Revision: 926
Added:
   trunk/mapbender/http/javascripts/mod_insertLayerPreviewIntoDb.php
   trunk/mapbender/http/javascripts/mod_saveLayerPreview.php
   trunk/mapbender/http/php/mod_editWMS_Metadata.php
   trunk/mapbender/http/php/mod_layerMetadata.php
files for layer preview
Added: trunk/mapbender/http/javascripts/mod_insertLayerPreviewIntoDb.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_insertLayerPreviewIntoDb.php?view=auto&rev=926
--- (empty file)
+++ trunk/mapbender/http/javascripts/mod_insertLayerPreviewIntoDb.php	2006-11-21 12:49:21+0000
@@ -0,0 +1,158 @@
+<?php
+#$Id: mod_insertWmcIntoDb.php 359 2006-10-09 16:41:18Z christoph $
+#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+session_start();
+include("../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+$gui_id = $_REQUEST["gui_id"];
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db(DB,$con);
+function escByteA($binData) {
+   * \134 = 92 = backslash, \000 = 00 = NULL, \047 = 39 = Single Quote
+   * str_replace() replaces the searches array in order.
+   * Therefore, we must
+   * process the 'backslash' character first. If we process it last, it'll
+   * replace all the escaped backslashes from the other searches that came
+   * before. tomATminnesota.com
+   $search = array();
+   $replace = array();
+   array_push($search, chr(92));
+   array_push($replace, '\\134');
+   array_push($search, chr(0));
+   array_push($replace, '\\000');
+   array_push($search, chr(39));
+   array_push($replace, '\\047');
+   array_push($search, chr(13));
+   array_push($replace, '\\015');
+   array_push($search, chr(10));
+   array_push($replace, '\\012');
+  $binData = str_replace($search, $replace, $binData);
+  return $binData;
+if ($_POST["data"]) {
+	$d = explode("____", $_POST["data"]);
+	$mapurl = $d[0];
+	$legendurl = $d[1];
+	$mapurl = eregi_replace("(&width=)[0-9]+($|[^0-9])", "\\1200\\2", $mapurl);
+	$mapurl = eregi_replace("(&height=)[0-9]+($|[^0-9])", "\\1200\\2", $mapurl);
+	$adm = new administration();
+	$layer_id = $_SESSION['layer_preview'];
+	if (!$layer_id) {
+		 echo "<script>alert('Could not find wms: ".$wms_getmap."');</script>";
+	else {
+		$map_img = file_get_contents($mapurl);
+		$legend_img = file_get_contents($legendurl);
+		$rlp_4326_box = array(6.10988942079081,48.987785376052,8.58790010810365,50.9273496139233);
+		$sql = "SELECT * FROM layer_epsg WHERE fkey_layer_id = $1 AND epsg = 'EPSG:4326'";
+		$v = array($layer_id);
+		$t = array('i');
+		$res = db_prep_query($sql, $v, $t);
+		$row = db_fetch_array($res);
+		if ($row['minx'] && $row['miny'] && $row['maxx'] && $row['maxy']) {
+			$extent_layer_id = $layer_id;
+			$layer_4326_box = array($row['minx'], $row['miny'], $row['maxx'], $row['maxy']);
+		else {
+			$sql = "SELECT * FROM (SELECT fkey_wms_id FROM layer WHERE layer_id = $1 LIMIT 1) AS w, layer_epsg AS e, layer AS l WHERE l.fkey_wms_id = w.fkey_wms_id AND l.layer_pos = 0 AND l.layer_id = e.fkey_layer_id AND e.epsg = 'EPSG:4326'";
+			$t = array('i');
+			if ($row['epsg'] && $row['minx'] && $row['miny'] && $row['maxx'] && $row['maxy']) {
+				$extent_layer_id = $row['layer_id'];
+			else {
+				$layer_4326_box = $rlp_4326_box;
+		if ($layer_4326_box[0] < $rlp_4326_box[0] || $layer_4326_box[2] > $rlp_4326_box[2]) {
+			if ($layer_4326_box[0] < $rlp_4326_box[0]) {
+				$rlp_4326_box[0] = $layer_4326_box[0];
+			if ($layer_4326_box[2] > $rlp_4326_box[2]) {
+				$rlp_4326_box[2] = $layer_4326_box[2];
+			$d_x = $rlp_4326_box[2] - $rlp_4326_box[0];
+			$new_minx = $rlp_4326_box[0] - 0.1*($d_x);
+			$new_maxx = $rlp_4326_box[2] + 0.1*($d_x);
+			if ($new_minx < -180) $rlp_4326_box[0] = -180; else $rlp_4326_box[0] = $new_minx;
+			if ($new_maxx > 180) $rlp_4326_box[2] = 180; else $rlp_4326_box[2] = $new_maxx;
+		if ($layer_4326_box[1] < $rlp_4326_box[1] || $layer_4326_box[3] > $rlp_4326_box[3]) {
+			if ($layer_4326_box[1] < $rlp_4326_box[1]) {
+				$rlp_4326_box[1] = $layer_4326_box[1];
+			if ($layer_4326_box[3] > $rlp_4326_box[3]) {
+				$rlp_4326_box[3] = $layer_4326_box[3];
+			$d_y = $rlp_4326_box[3] - $rlp_4326_box[1];
+			$new_miny = $rlp_4326_box[1] - 0.1*($d_y);
+			$new_maxy = $rlp_4326_box[3] + 0.1*($d_y);
+			if ($new_miny < -90) $rlp_4326_box[1] = -90; else $rlp_4326_box[1] = $new_miny;
+			if ($new_maxy > 90) $rlp_4326_box[3] = 90; else $rlp_4326_box[3] = $new_maxy;
+		$extent_img = file_get_contents("http://212.79.172.107/cgi-bin/mapserv?map=/data/umn/service_layer.map&VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=rlp,ows_layer&STYLES=&SRS=EPSG:4326&BBOX=".$rlp_4326_box[0].",".$rlp_4326_box[1].",".$rlp_4326_box[2].",".$rlp_4326_box[3]."&WIDTH=120&HEIGHT=120&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage&layer_id=".$extent_layer_id);
+		$sql = "SELECT * FROM layer_preview WHERE fkey_layer_id = $1";
+		$t = array('i');
+		if ($row['fkey_layer_id'] == $layer_id) {
+			$sql = "UPDATE layer_preview SET layer_map_preview = $1, layer_extent_preview = $2, layer_legend_preview = $3 WHERE fkey_layer_id = $4";
+			$v = array( escByteA($map_img),  escByteA($extent_img), escByteA($legend_img), $layer_id);
+			$t = array('s', 's', 's', 'i');
+		else {
+			$sql = "INSERT INTO layer_preview (fkey_layer_id, layer_map_preview, layer_extent_preview, layer_legend_preview) VALUES ($1, $2, $3, $4)";
+			$v = array($layer_id, escByteA($map_img), escByteA($extent_img), escByteA($legend_img));
+			$t = array('i', 's', 's', 's');
+		if (db_error()) {
+			 echo "<script>alert(\"Error while saving layer preview: ".addslashes(db_error())."\");</script>";
+		else {
+			 echo "<script>try{parent.opener.document.getElementById('".$layer_id."_dp').style.display='';}catch(e){};alert(\"Layer preview has been saved!\")</script>";
+</body>
+<html>
Added: trunk/mapbender/http/javascripts/mod_saveLayerPreview.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_saveLayerPreview.php?view=auto&rev=926
--- (empty file)
+++ trunk/mapbender/http/javascripts/mod_saveLayerPreview.php	2006-11-21 12:49:21+0000
@@ -0,0 +1,53 @@
+<?php
+# $Id: mod_savewmc.php 264 2006-05-12 11:07:19Z vera_schulze
+# http://www.mapbender.org/index.php/mod_savewmc.php
+require_once("../../conf/mapbender.conf");
+$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'savewmc' AND fkey_gui_id = $1";
+$v = array($gui_id);
+$t = array('s');
+$res = db_prep_query($sql, $v, $t);
+$cnt = 0;
+while($row = db_fetch_array($res)){
+	$e_src = $row["e_src"];
+	$e_target = $row["e_target"];
+	$cnt++;
+if($cnt > 1){
+	echo "alert('savewmc: ID not unique!');";
+$e_id_css = "saveLayerPreview";
+include("../include/dyn_js.php");
+echo "mod_savewmc_target = '".$e_target."';";
+var mod_saveLayerPreview_img = new Image(); mod_saveLayerPreview_img.src = "<?php  echo $e_src;  ?>";
+function mod_saveLayerPreview(){
+//	document.sendData.target = "_blank";
+	document.sendData.action = "../javascripts/mod_insertLayerPreviewIntoDb.php";
+	document.sendData.data.value = mb_mapObj[0].mapURL[0] + "____" + wms[0].wms_getlegendurl;
+	document.sendData.submit();
Added: trunk/mapbender/http/php/mod_editWMS_Metadata.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_editWMS_Metadata.php?view=auto&rev=926
--- (empty file)
+++ trunk/mapbender/http/php/mod_editWMS_Metadata.php	2006-11-21 12:49:21+0000
@@ -0,0 +1,472 @@
+<?php
+# $Id: mod_editWMS_Metadata.php 11 2006-09-06 12:15:35Z wieth�lter/strotmann $
+session_start();
+include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/mb_validatePermission.php");
+$secParams = SID."&guiID=".$_REQUEST["guiID"]."&elementID=".$_REQUEST["elementID"];
+$self = $PHP_SELF."?".$secParams;
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<title>Edit WMS Metadata</title>
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+include_once '../include/dyn_css.php';
+#Error reporting
+error_reporting(E_ALL);
+ini_set('display_errors', TRUE);
+$con = db_connect(DBSERVER,OWNER,PW);
+$adm = new administration();
+<script language="JavaScript">
+var dTarget;
+function save()
+   document.forms[0].update_content.value=1;
+   document.forms[0].submit();
+function deletepreview(layer_id)
+	var url = String(document.location);
+	url = url.substr(0, url.indexOf('?'));
+	window.open(url+"?<?php echo strip_tags(SID);?>&guiID=<?php echo $_REQUEST["guiID"]?>&elementID=<?php echo $_REQUEST["elementID"];?>&delete_preview=1&layer_id="+layer_id,'delete preview', 'height=50, width=150, dependent=yes');
+	document.getElementById(layer_id+"_dp").style.display="none";
+function pick_the_date(obj)
+    dTarget = obj;
+    var dp =
+window.open('../tools/datepicker/datepicker.php?m=Jan_Feb_Mrz_Apr_Mai_Jun_Jul_Aug_Sep_Okt_Nov_Dez&d=Mo_Di_Mi_Do_Fr_Sa_So&t=heute','dp','left=200,top=200,width=230,height=210,toolbar=0,location=0,directories=0,status=0,menubar=0,scrollbars=0');
+    dp.focus();
+    return false
+</script>
+</head>
+<body>
+<?php
+function guessTimestamp($timestr)
+     if (strstr($timestr, '.'))
+        list($day, $month, $year) = explode(".", $timestr);
+     elseif (strstr($timestr, '/'))
+        list($month, $day, $year) = explode("/", $timestr);
+     elseif (strstr($timestr, '-'))
+        list($year, $month, $day) = explode("-", $timestr);
+     else
+     	$year = 0;
+        $month = 0;
+        $day = 0;
+     return mktime(0, 0, 0, $month, $day, intval($year));
+#Update handling
+if(isset($_REQUEST['update_content']) && $_REQUEST['update_content'] == true)
+            $update_wms_sql = "UPDATE wms SET " .
+                      "wms_title = '".$_REQUEST['wms_title_box']."', " .
+                      "wms_abstract = '".$_REQUEST['wms_abstract_box']."', " .
+                      "fees = '".$_REQUEST['fees_box']."', " .
+                      "accessconstraints = '".$_REQUEST['accessconstraints_box']."', " .
+                      "contactperson = '".$_REQUEST['contactperson_box']."', " .
+                      "contactposition = '".$_REQUEST['contactposition_box']."', " .
+                      "contactorganization = '".$_REQUEST['contactorganization_box']."', " .
+                      "address = '".$_REQUEST['address_box']."', " .
+                      "city = '".$_REQUEST['city_box']."', " .
+                      "stateorprovince = '".$_REQUEST['stateorprovince_box']."', " .
+                      "postcode = '".$_REQUEST['postcode_box']."', " .
+                      "country = '".$_REQUEST['country_box']."', " .
+                      "contactvoicetelephone = '".$_REQUEST['contactvoicetelephone_box']."', " .
+                      "contactfacsimiletelephone = '".$_REQUEST['contactfacsimiletelephone_box']."', " .
+                      "contactelectronicmailaddress = '".$_REQUEST['contactelectronicmailaddress_box']."'";
+                      if (isset($_REQUEST['wms_timestamp_box']) && $_REQUEST['wms_timestamp_box'] <> "")
+                            $update_wms_sql .= ", " . "wms_timestamp = " .
+                            "'".guessTimestamp($_REQUEST['wms_timestamp_box'])."' ";
+   $update_wms_sql .= "WHERE wms_id = '".$_REQUEST['wms_id']."'";
+    $res_update_wms_sql = db_query($update_wms_sql);
+     while(list($key,$val) = each($_REQUEST))
+        if(preg_match("/___/", $key))
+            $myKey = explode("___", $key);
+            $layer_id = str_replace("L_","",$myKey[0]);
+            if($myKey[1]=="layer_abstract")
+                $layer_sql = "UPDATE layer SET layer_abstract = '$val' " .
+                             "WHERE layer_id = $layer_id AND fkey_wms_id = '".$_REQUEST['wms_id']."'";
+                $res_keyword_sql = db_query($layer_sql);
+            if($myKey[1]=="layer_keywords")
+                #Get all keywords depending on the given layer after user modification
+                $keywords  = explode(",",$val);
+                #delete all blanks from the keywords list
+                for($j = 0; $j < count($keywords); $j++)
+                    $word = $keywords[$j];
+                    $word = trim($word);
+                    $keywords[$j] = $word;
+                #echo "1: Keywords eines Layers: id des Layers: ", $layer_id, ", �bergebener String: ", $val, ";<br>";
+                #Get all keywords depending on this layer from database
+                $keyword_sql = "SELECT keyword_id, keyword FROM keyword, layer_keyword, layer " .
+                               "WHERE keyword.keyword_id = layer_keyword.fkey_keyword_id " .
+                               "AND layer_keyword.fkey_layer_id = layer.layer_id " .
+                               "AND layer.fkey_wms_id = '".$_REQUEST['wms_id']."'" .
+                               "AND layer.layer_id = $layer_id";
+                $res_keyword_sql = db_query($keyword_sql);
+                while($keyword_row = db_fetch_array($res_keyword_sql))
+                    $keyword = $keyword_row['keyword'];
+                    $keyword_id = $keyword_row['keyword_id'];
+                    #keyword has been deleted or has been modified
+                    #keyword exists in database but not in user data
+                    $index = -1;
+                    #echo "1a: Abfrage ob DB Keywords in User Liste: Keyword: ", $keyword, ";<br>";
+                    if(in_array($keyword, $keywords) == false)
+                        #echo "1c: Keyword nicht in User Liste: Keyword: ", $keyword, ";<br>";
+                        #Deleting reference to the keyword from the layer_keyword table.
+                        $keyword_sql = "DELETE FROM layer_keyword " .
+                                       "WHERE fkey_layer_id = $layer_id " .
+                                       "AND fkey_keyword_id = $keyword_id";
+                        db_query($keyword_sql);
+                        #Checking, if the keyword is in use by any layer
+                        $layer_sql = "SELECT * FROM layer_keyword " .
+                                       "WHERE fkey_keyword_id = $keyword_id";
+                        $res_layer_sql = db_query($layer_sql);
+                        if(!($row = db_fetch_array($res_layer_sql)))
+                            #If keyword will not longer be in use, delete it from keyword table
+                            $keyword_sql = "DELETE FROM keyword " .
+                                           "WHERE keyword_id = $keyword_id";
+                    #Keyword exists in the database and in the user data
+                    else
+                        #echo "1d: Keyword ist in User Liste: Keyword: ", $keyword, ";<br>";
+                        for($i = 0; $i < count($keywords); $i++)
+                            #Delete keyword from the user data list, because the data
+                            #have not to be updated within the database
+                            if($keywords[$i] == $keyword)
+                                $keywords[$i] = null;
+                #Inserting keyword, that are not existing in the database
+                    #echo "2: Alle Eintr�ge des Keyword arrays: Keyword: ", $keywords[$i], "; Index: ", $i, ";<br>";
+                    if($keywords[$i] != null)
+                        #echo "3: Eintr�ge ungleich null: Keyword: ", $keywords[$i], "; Index: ", $i, ";<nr>";
+                        $keyword = $keywords[$i];
+                        #Check, if the keyword is exsiting in the database
+                        $keyword_sql = "SELECT keyword_id FROM keyword " .
+                                       "WHERE keyword = '$keyword'";
+                        $keyword_row = db_fetch_array($res_keyword_sql);
+                        if($keyword_row != null)
+                            $keyword_id = $keyword_row[0];
+                            #echo "4: Keyword in Datenbank vorhanden: id des Keywords: ", $keyword_id, ";<br>";
+                        #Keyword does not exist in the database
+                        else
+                            $keyword_sql = "INSERT INTO keyword (keyword) VALUES ('$keyword')";
+                            $keyword_sql = "SELECT keyword_id FROM keyword WHERE keyword = '$keyword'";
+                                #echo "4: Keyword in der Datenbank nicht vorhanden: id des Keywords: ", $keyword_id, ";<br>";
+                        #Inserting the reference between layer and keyword in the layer_keyword table
+                        $keyword_sql = "INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) " .
+                                       "VALUES ('$layer_id', '$keyword_id')";
+                #Delete all elements from array
+                unset($keywords);
+unset($update_content);
+#delete preview
+if(isset($_REQUEST['delete_preview']) && $_REQUEST['delete_preview']=='1'
+	&& isset($_REQUEST['layer_id']))
+    $preview_sql = "DELETE FROM layer_preview WHERE fkey_layer_id = ".$_REQUEST['layer_id']."";
+    $res_preview_sql = db_query($preview_sql);
+    die("Preview has been deleted!</body></html>");
+<form name='form1' action='<?php  $self ?>' method='post'>
+<table>
+<td WIDTH="300">
+<B><FONT FACE="Arial">WMS Metadaten<FONT/><B/>
+<td/>
+<td WIDTH="200">
+<input type='button' style='width:100px;height:40px;' value='save' onclick='save()'>
+<td/>
+</table>
+<?php
+#Use select box to select a wms
+if (isset($_REQUEST['show_wms_list']) && $_REQUEST['show_wms_list'] == true)
+    #Querying information from wms data table
+    $wms_sql = "SELECT wms_id, wms_title FROM wms WHERE wms_owner = ".$_SESSION["mb_user_id"];
+    $res_wms_sql = db_query($wms_sql);
+    #wms-selection
+    <br/>
+    <select size='4' name='wmsList' style='width:200px' onchange='submit()'>
+    <?php
+    while($row = db_fetch_array($res_wms_sql))
+        if ($adm->getWmsPermission($row["wms_id"], $_SESSION['mb_user_id'])) {
+	        echo "<option value='".$row["wms_id"]."' ";
+	        if(isset($_REQUEST['wmsList']) && $_REQUEST['wmsList'] == $row["wms_id"])
+	            echo "selected";
+	            $count_wms = 0;
+	        echo "> ".$row["wms_title"]."</option>";
+    $count_wms++;
+    </select>
+    <?php
+    if(isset($_REQUEST['wmsList']) == true && $_REQUEST['wmsList'] <>0)
+    editWMSByWMSID ($_REQUEST['wmsList']);
+$wms_id;
+function editWMSByWMSID($param_wms_id)
+    global $wms_id;
+    $wms_id = $param_wms_id;
+if(isset($wms_id) == true && $wms_id <>0)
+	$selected_wms_sql = "SELECT * FROM wms WHERE wms_id = '".$wms_id."'";
+    $res_selected_wms_sql = db_query($selected_wms_sql);
+    $selected_row = db_fetch_array($res_selected_wms_sql);
+    <br/>
+    <br/>
+    <table cellpadding='3' cellspacing='3' border='0' class='table_top'>
+    <tr>
+    <td>WMS-Titel:<td><td/>
+    <input type='text' name='wms_title_box' value='<?php echo $selected_row["wms_title"];?>' /><td/>
+    <td>WMS- Abstract:<td><td/>
+    <input type='text' name='wms_abstract_box' value='<?php echo $selected_row["wms_abstract"];?>' /><td/>
+    <td>Fees:<td><td/>
+    <input type='text' name='fees_box' value='<?php echo $selected_row["fees"]?>'/><td/>
+    <tr/>
+    <tr>
+    <td>Access Constraints:<td><td/>
+    <input type='text' name='accessconstraints_box' value='<?php echo $selected_row["accessconstraints"]?>'/><td/>
+    <td>Contact Person:<td><td/>
+    <input type='text' name='contactperson_box' value='<?php echo $selected_row["contactperson"]?>'/><td/>
+    <td>Contact Position:<td><td/>
+    <input type='text' name='contactposition_box' value='<?php echo $selected_row["contactposition"]?>'/><td/>
+    <tr/>
+    <tr>
+    <td>Contact Organization:<td><td/>
+    <input type='text' name='contactorganization_box' value='<?php echo $selected_row["contactorganization"]?>'/><td/>
+    <td>Address:<td><td/>
+    <input type='text' name='address_box' value='<?php echo $selected_row["address"]?>'/><td/>
+    <td>City:<td><td/>
+    <input type='text' name='city_box' value='<?php echo $selected_row["city"]?>'/><td/>
+    <tr/>
+    <tr>
+    <td>State or Province:<td><td/>
+    <input type='text' name='stateorprovince_box' value='<?php echo $selected_row["stateorprovince"]?>'/><td/>
+    <td>Postcode:<td><td/>
+    <input type='text' name='postcode_box' value='<?php echo $selected_row["postcode"]?>'/><td/>
+    <td>Country:<td><td/>
+    <input type='text' name='country_box' value='<?php echo $selected_row["country"]?>'/><td/>
+    <tr/>
+    <tr>
+    <td>Telephone:<td><td/>
+    <input type='text' name='contactvoicetelephone_box'
+        value='<?php echo $selected_row["contactvoicetelephone"]?>'/><td/>
+    <td>Fax:<td><td/>
+    <input type='text' name='contactfacsimiletelephone_box' value='<?php echo $selected_row["contactfacsimiletelephone"]?>'/><td/>
+    <td>E-Mail:<td><td/>
+    <input type='text' name='contactelectronicmailaddress_box' value='<?php echo $selected_row["contactelectronicmailaddress"]?>'/><td/>
+    <tr/>
+    <tr>
+    <?php
+  if (isset($selected_row["wms_timestamp"]) && $selected_row["wms_timestamp"] <> "")
+    $datum = date("d.m.Y",$selected_row["wms_timestamp"]);
+  else $datum = ""
+    <td>Date:<td><td/>
+    <input type='text' name='wms_timestamp_box' value='<?php echo $datum?>' onClick='pick_the_date(document.form1.wms_timestamp_box)'/><td/>
+    <tr/>
+    <table border='1' cellpadding='1'>
+    <tr><td>Nr.</td><td>Title</td><td>Abstract</td><td>Keywords</td><td></td></tr>
+<?php
+    $layer_sql = "SELECT * FROM layer WHERE layer.fkey_wms_id = '".$wms_id."'" .
+                 " ORDER BY layer_pos";
+    while($layer_row = db_fetch_array($res_layer_sql))
+        <tr align='center'>
+        <td><input type='text' size='1' name='L_<?php echo $layer_row['layer_id']?>___layer_nr'
+            value='<?php echo $layer_row['layer_pos']?>' readonly></td>
+        <td><input type='text' size='15' name='L_<?php echo $layer_row['layer_id']?>___layer_title'
+            value='<?php echo $layer_row['layer_title']?>' readonly></td>
+        <td><input type='text' size='42' name='L_<?php echo $layer_row['layer_id']?>___layer_abstract'
+            value='<?php echo $layer_row['layer_abstract']?>'>
+    <?php
+        $keyword_sql = "SELECT keyword FROM keyword, layer_keyword, layer " .
+                       "AND layer.fkey_wms_id = '".$wms_id."' " .
+                       "AND layer.layer_id = ".$layer_row['layer_id']."";
+        $keywordList = "";
+        $seperator = "";
+            if($keywordList != "")
+                $seperator = ",";
+            $keywordList .= $seperator.$keyword_row["keyword"];
+        <td><input type='text' size='42' name='L_<?php echo $layer_row['layer_id']?>___layer_keywords'
+             value='<?php echo $keywordList?>'>
+        </td>
+        <td><input type="button" value='preview' onclick="window.open('../frames/index.php?&gui_id=layer_preview&layer_preview=1&portal_services=<?php echo $layer_row['layer_id'];?>', 'mini_mapbender', 'height=370, width=370, dependent=yes');"></td>
+        <td>
+<?php
+    $preview_sql = "SELECT * FROM layer_preview " .
+                   "WHERE fkey_layer_id = ".$layer_row['layer_id']."";
+	if(db_numrows($res_preview_sql)>0){?>
+        <input id="<?php echo $layer_row['layer_id'];?>_dp" type="button" value='delete preview' onclick="deletepreview('<?php echo $layer_row['layer_id'];?>');">
+<?php }else{?>
+        <input id="<?php echo $layer_row['layer_id'];?>_dp" type="button" value='delete preview' style="display:none;" onclick="deletepreview('<?php echo $layer_row['layer_id'];?>');">
+<?php }?>
+        </td>
+        </tr>
+    <?php
+    #editWMSByWMSID(961);
+    </table>
+    <input type='hidden' name='update_content' value=''/>
+    <input type='hidden' name='wms_id' value='<?php echo $wms_id ?>'/>
+    <input type="hidden" value='' name='delete_preview'>
+    <input type="hidden" value='' name='layer_id'>
+    </form>
+    </body>
+    </html>
+<?php
Added: trunk/mapbender/http/php/mod_layerMetadata.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_layerMetadata.php?view=auto&rev=926
--- (empty file)
+++ trunk/mapbender/http/php/mod_layerMetadata.php	2006-11-21 12:49:21+0000
@@ -0,0 +1,165 @@
+<?php
+# $Id: mod_layerMetadata.php 235 2006-05-11 08:34:48Z uli $
+# http://www.mapbender.org/index.php/Administration
+function display_text($string) {
+    $string = eregi_replace("[[:alpha:]]+://[^<>[:space:]]+[[:alnum:]/]", "<a href=\"\\0\" target=_blank>\\0</a>", $string);
+    $string = eregi_replace("^[_a-z0-9-]+(\.[_a-z0-9-]+)*@([0-9a-z](-?[0-9a-z])*\.)+[a-z]{2}([zmuvtg]|fo|me)?$", "<a href=\"mailto:\\0\" target=_blank>\\0</a>", $string);
+    $string = eregi_replace("\n", "<br>", $string);
+    return $string;
+<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="de">
+	<head>
+		<title>GeoPortal Rheinland-Pfalz - Metadaten</title>
+		<meta name="description" content="Metadaten" xml:lang="de" />
+		<meta name="keywords" content="Metadaten" xml:lang="de" />
+		<meta http-equiv="cache-control" content="no-cache">
+		<meta http-equiv="pragma" content="no-cache">
+		<meta http-equiv="expires" content="0">
+		<meta http-equiv="content-language" content="de" />
+		<meta http-equiv="content-style-type" content="text/css" />
+<?php
+	echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+		<link rel="stylesheet" type="text/css" href="../../../portal/fileadmin/design/css/screen.css" media="screen" />
+		<link rel="stylesheet" type="text/css" href="../../../portal/fileadmin/design/css/print.css" media="print" />
+	</head>
+	<body id="top" class="popup">
+	<div id="header_graybottom"></div>
+	<div id="header_gray"><a href="javascript:window.close()"><?php echo utf8_encode('Fenster schließen');?></a></div>
+	<div id="header_redbottom"></div>
+	<div id="header_red"></div>
+	<div class="content">
+<?php
+	$layer_id = $_GET['id'];
+	$wms_getmap = urldecode($_GET['wms']);
+	$layer_name = urldecode($_GET['name']);
+	if ($layer_id) {
+		$sql = "SELECT ";
+		$sql .= "layer.layer_id, layer.layer_title, layer.layer_abstract, layer.layer_pos, layer.layer_parent, layer.layer_minscale, layer.layer_maxscale, ";
+		$sql .= "wms.wms_title, wms.wms_abstract, wms.wms_id, wms.fees, wms.accessconstraints, wms.contactperson, ";
+		$sql .= "wms.contactposition, wms.contactorganization, wms.address, wms.city, ";
+		$sql .= "wms.stateorprovince, wms.postcode, wms.contactvoicetelephone, wms.contactfacsimiletelephone, ";
+		$sql .= "wms.contactelectronicmailaddress, wms.country ";
+		$sql .= "FROM layer, wms WHERE layer.layer_id = $1 AND layer.fkey_wms_id = wms.wms_id LIMIT 1";
+		$t = array('i');
+	else if ($wms_getmap && $layer_name) {
+		$sql = "SELECT ";
+		$sql .= "FROM layer, wms WHERE layer.layer_pos <> 0 AND layer.layer_name = $1 AND layer.fkey_wms_id = wms.wms_id AND wms.wms_getmap LIKE $2 LIMIT 1";
+		$v = array($layer_name, $wms_getmap."%");
+		$t = array('s', 's');
+	else die();
+	$res = db_prep_query($sql,$v,$t);
+	echo db_error();
+	$layer = array();
+	$layer_id = $row['layer_id'];
+	$sql_p = "SELECT * FROM layer_preview WHERE fkey_layer_id = $1 LIMIT 1";
+	$v_p = array($layer_id);
+	$t_p = array('i');
+	$res_p = db_prep_query($sql_p, $v_p, $t_p);
+	$row_p = db_fetch_array($res_p);
+	if ($row_p['layer_map_preview'] != "") {
+		$layer['Voransicht'] = "<img src = 'mod_displayImage.php?id=".$layer_id."&col=layer_map_preview'>";
+		if ($row_p['layer_legend_preview'] != "") $layer['Voransicht'] .= "<img src = 'mod_displayImage.php?id=".$layer_id."&col=layer_legend_preview'>";
+	$layer['ID'] = $row['layer_id'];
+	$layer['Titel'] = $row['layer_title'];
+	$layer['Zusammenfassung'] = $row['layer_abstract'];
+	if ($row['layer_pos'] || $row['layer_parent']) {
+		$layer['Minscale'] = $row['layer_minscale'];
+		$layer['Maxscale'] = $row['layer_maxscale'];
+	$layer['WMS Titel'] = $row['wms_title'];
+	$layer['WMS Zusammenfassung'] = $row['wms_abstract'];
+	$layer['Gebühren'] = $row['fees'];
+	$layer['Zugriffsbeschränkung'] = $row['accessconstraints'];
+	$layer['Ansprechpartner'] = $row['contactperson'];
+	$layer['Organisation'] = $row['contactorganization'];
+	$layer['Adresse'] = $row['address'];
+	$layer['Stadt'] = $row['city'];
+	$layer['Bundesland'] = $row['stateorprovince'];
+	$layer['PLZ'] = $row['postcode'];
+	$layer['Telefon'] = $row['contactvoicetelephone'];
+	$layer['Fax'] = $row['contactfacsimiletelephone'];
+	$layer['E-Mail'] = $row['contactelectronicmailaddress'];
+	$layer['Land'] = $row['country'];
+	$sql_p = "SELECT layer_extent_preview FROM layer_preview WHERE fkey_layer_id = $1 LIMIT 1";
+	if ($row_p['layer_extent_preview'] != "") $layer['Ausdehnung'] = "<img src = 'mod_displayImage.php?id=".$layer_id."&col=layer_extent_preview'>";
+	echo "<table class='contenttable-0-wide'>\n";
+	$t_a = "\t<tr>\n\t\t<th>\n\t\t\t";
+	$t_b = "\n\t\t</th>\n\t\t<td>\n\t\t\t";
+	$t_c = "\n\t\t</td>\n\t</tr>\n";
+	$keys = array_keys($layer);
+	for ($j=0; $j<count($layer); $j++) {
+		echo $t_a . utf8_encode($keys[$j]) . $t_b . display_text($layer[$keys[$j]]) . $t_c;
+	if (!$row['layer_pos'] && !$row['layer_parent']) {
+		$wms_id = $row['wms_id'];
+		$sql = "SELECT layer.layer_title, layer.layer_id FROM layer WHERE fkey_wms_id = $1 AND layer_pos <> 0";
+		$v = array($wms_id);
+		$t = array('i');
+		$i=0;
+		$layer = array();
+		while ($row = db_fetch_array($res)) {
+			$layer[$i] = array();
+			$layer[$i]['Titel'] = $row['layer_title'];
+			$layer[$i]['id'] = $row['layer_id'];
+			$i++;
+		echo "<tr><th>Ebenen</th><td>";
+		for ($i=0; $i<count($layer); $i++) {
+			if ($i >0) echo ", ";
+			echo "<a href='mod_layerMetadata.php?id=".$layer[$i]['id']."'>" . $layer[$i]['Titel'] . "</a>";
+	echo "</td></tr></table>\n";
+	</div>
+	<div id="footer_red"></div>
+	</body>
+</html>
More information about the Mapbender_commits mailing list
