svn commit: r928 - trunk/mapbender/http: classes html javascripts
christoph at osgeo.org
Tue Nov 21 10:33:51 EST 2006
Author: christoph
Date: 2006-11-21 15:33:51+0000
New Revision: 928
trunk/mapbender/http/classes/class_wmc.php
trunk/mapbender/http/classes/class_wms.php
trunk/mapbender/http/html/mod_treefolder.php
trunk/mapbender/http/javascripts/map_obj.js
trunk/mapbender/http/javascripts/mod_savewmc.php
added uid to layer object
(uid contains database id of layer)
Modified: trunk/mapbender/http/classes/class_wmc.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_wmc.php?view=diff&rev=928&p1=trunk/mapbender/http/classes/class_wmc.php&p2=trunk/mapbender/http/classes/class_wmc.php&r1=927&r2=928
--- trunk/mapbender/http/classes/class_wmc.php (original)
+++ trunk/mapbender/http/classes/class_wmc.php 2006-11-21 15:33:51+0000
@@ -1,5 +1,5 @@
<?php
-# $Id: class_wmc.php 505 2006-11-20 10:53:10Z christoph $
+# $Id: class_wmc.php 519 2006-11-21 15:33:24Z christoph $
# http://www.mapbender.org/index.php/class_wmc.php
# Copyright (C) 2002 CCGIS
@@ -27,6 +27,11 @@
if(CHARSET=="UTF-8") return utf8_decode($str);
return $str;
+function sepNameSpace($s){
+ $c = strpos($s,":");
+ if($c>0)return substr($s,$c+1);
+ return $s;
class wmc {
var $wmc_id;
@@ -66,8 +71,10 @@
var $wmc_wms_title = array();
var $wmc_layer_queryable = array();
var $wmc_layer_hidden = array();
+ var $wmc_wms_id = array();
var $wmc_wms_service = array();
var $wmc_wms_version = array();
+ var $wmc_layer_id = array();
var $wmc_layer_title = array();
var $wmc_layer_name = array();
var $wmc_layer_abstract = array();
@@ -156,15 +163,17 @@
$request = NULL;
$layer_style = array();
$cnt_styles = -1;
+ $extension = false;
$general = false;
$layerlist = false;
$layer = false;
foreach ($values as $element) {
+ $verbose .= ".";
if(strtoupper($element[tag]) == "VIEWCONTEXT" && $element[type] == "open"){
- $this->wmc_id = $element[attributes]["id"];
- $this->wmc_version = $element[attributes]["version"];
+ $this->wmc_id = $element[attributes]["id"];
+ $this->wmc_version = $element[attributes]["version"];
if(strtoupper($element[tag]) == "GENERAL" && $element[type] == "open"){
$general = true;
@@ -173,127 +182,128 @@
$layerlist = true;
if ($general) {
- if(strtoupper($element[tag]) == "WINDOW"){
- $this->wmc_windowWidth = $element[attributes]["width"];
- $this->wmc_windowHeight = $element[attributes]["height"];
- if(strtoupper($element[tag]) == "BOUNDINGBOX"){
- $this->wmc_bBox_SRS = $element[attributes]["SRS"];
- $this->wmc_bBox_minx = $element[attributes]["minx"];
- $this->wmc_bBox_miny = $element[attributes]["miny"];
- $this->wmc_bBox_maxx = $element[attributes]["maxx"];
- $this->wmc_bBox_maxy = $element[attributes]["maxy"];
- if(strtoupper($element[tag]) == "NAME"){
- $this->wmc_name = mb_utf8_decode($element[value]);
- if(strtoupper($element[tag]) == "TITLE"){
- $this->wmc_title = mb_utf8_decode($element[value]);
- if(strtoupper($element[tag]) == "ABSTRACT"){
- $this->wmc_abstract = mb_utf8_decode($element[value]);
- if(strtoupper($element[tag]) == "CONTACTINFORMATION" && $element['type'] == "open"){
- $contactinformation = true;
- if ($contactinformation) {
- if(strtoupper($element[tag]) == "CONTACTPOSITION"){
- $this->wmc_contactposition = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "WINDOW"){
+ $this->wmc_windowWidth = $element[attributes]["width"];
+ $this->wmc_windowHeight = $element[attributes]["height"];
+ if(strtoupper($element[tag]) == "BOUNDINGBOX"){
+ $this->wmc_bBox_SRS = $element[attributes]["SRS"];
+ $this->wmc_bBox_minx = $element[attributes]["minx"];
+ $this->wmc_bBox_miny = $element[attributes]["miny"];
+ $this->wmc_bBox_maxx = $element[attributes]["maxx"];
+ $this->wmc_bBox_maxy = $element[attributes]["maxy"];
- if(strtoupper($element[tag]) == "CONTACTVOICETELEPHONE"){
- $this->wmc_contactvoicetelephone = $element[value];
+ if(strtoupper($element[tag]) == "NAME"){
+ $this->wmc_name = mb_utf8_decode($element[value]);
- if(strtoupper($element[tag]) == "CONTACTFACSIMILETELEPHONE"){
- $this->wmc_contactfacsimiletelephone = $element[value];
+ if(strtoupper($element[tag]) == "TITLE"){
+ $this->wmc_title = mb_utf8_decode($element[value]);
- if(strtoupper($element[tag]) == "CONTACTELECTRONICMAILADDRESS"){
- $this->wmc_contactemail = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "ABSTRACT"){
+ $this->wmc_abstract = mb_utf8_decode($element[value]);
- if(strtoupper($element[tag]) == "CONTACTPERSONPRIMARY" && $element['type'] == "open"){
- $contactpersonprimary = true;
+ if(strtoupper($element[tag]) == "CONTACTINFORMATION" && $element['type'] == "open"){
+ $contactinformation = true;
- if ($contactpersonprimary) {
- if(strtoupper($element[tag]) == "CONTACTPERSON"){
- $this->wmc_contactperson = mb_utf8_decode($element[value]);
+ if ($contactinformation) {
+ if(strtoupper($element[tag]) == "CONTACTPOSITION"){
+ $this->wmc_contactposition = mb_utf8_decode($element[value]);
- if(strtoupper($element[tag]) == "CONTACTORGANIZATION"){
- $this->wmc_contactorganization = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "CONTACTVOICETELEPHONE"){
+ $this->wmc_contactvoicetelephone = $element[value];
- if(strtoupper($element[tag]) == "CONTACTPERSONPRIMARY" && $element['type'] == "close"){
- $contactpersonprimary = false;
+ if(strtoupper($element[tag]) == "CONTACTFACSIMILETELEPHONE"){
+ $this->wmc_contactfacsimiletelephone = $element[value];
- if(strtoupper($element[tag]) == "CONTACTADDRESS" && $element['type'] == "open"){
- $contactaddress = true;
- if ($contactaddress) {
- if(strtoupper($element[tag]) == "ADDRESSTYPE"){
- $this->wmc_contactaddresstype = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "CONTACTELECTRONICMAILADDRESS"){
+ $this->wmc_contactemail = mb_utf8_decode($element[value]);
- if(strtoupper($element[tag]) == "ADDRESS"){
- $this->wmc_contactaddress = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "CONTACTPERSONPRIMARY" && $element['type'] == "open"){
+ $contactpersonprimary = true;
- if(strtoupper($element[tag]) == "CITY"){
- $this->wmc_contactcity = mb_utf8_decode($element[value]);
+ if ($contactpersonprimary) {
+ if(strtoupper($element[tag]) == "CONTACTPERSON"){
+ $this->wmc_contactperson = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "CONTACTORGANIZATION"){
+ $this->wmc_contactorganization = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "CONTACTPERSONPRIMARY" && $element['type'] == "close"){
+ $contactpersonprimary = false;
- if(strtoupper($element[tag]) == "STATEORPROVINCE"){
- $this->wmc_contactstateorprovince = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "CONTACTADDRESS" && $element['type'] == "open"){
+ $contactaddress = true;
- if(strtoupper($element[tag]) == "POSTCODE"){
- $this->wmc_contactpostcode = $element[value];
+ if ($contactaddress) {
+ if(strtoupper($element[tag]) == "ADDRESSTYPE"){
+ $this->wmc_contactaddresstype = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "ADDRESS"){
+ $this->wmc_contactaddress = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "CITY"){
+ $this->wmc_contactcity = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "STATEORPROVINCE"){
+ $this->wmc_contactstateorprovince = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "POSTCODE"){
+ $this->wmc_contactpostcode = $element[value];
+ if(strtoupper($element[tag]) == "COUNTRY"){
+ $this->wmc_contactcountry = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "CONTACTADDRESS" && $element['type'] == "close"){
+ $contactaddress = false;
- if(strtoupper($element[tag]) == "COUNTRY"){
- $this->wmc_contactcountry = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "LOGOURL" && $element['type'] == "open"){
+ $logourl = true;
+ $this->wmc_logourl_width = $element[attributes]["width"];
+ $this->wmc_logourl_height = $element[attributes]["height"];
+ $this->wmc_logourl_format = $element[attributes]["format"];
+ if ($logourl) {
+ if(strtoupper($element[tag]) == "LOGOURL" && $element['type'] == "close"){
+ $logourl = false;
- if(strtoupper($element[tag]) == "CONTACTADDRESS" && $element['type'] == "close"){
- $contactaddress = false;
+ if(strtoupper($element[tag]) == "ONLINERESOURCE"){
+ $this->wmc_logourl_type = $element[attributes]["xlink:type"];
+ $this->wmc_logourl = $element[attributes]["xlink:href"];
- if(strtoupper($element[tag]) == "LOGOURL" && $element['type'] == "open"){
- $logourl = true;
- $this->wmc_logourl_width = $element[attributes]["width"];
- $this->wmc_logourl_height = $element[attributes]["height"];
- $this->wmc_logourl_format = $element[attributes]["format"];
- if ($logourl) {
- if(strtoupper($element[tag]) == "LOGOURL" && $element['type'] == "close"){
- $logourl = false;
- if(strtoupper($element[tag]) == "ONLINERESOURCE"){
- $this->wmc_logourl_type = $element[attributes]["xlink:type"];
- $this->wmc_logourl = $element[attributes]["xlink:href"];
+ if(strtoupper($element[tag]) == "DESCRIPTIONURL" && $element['type'] == "open"){
+ $descriptionurl = true;
+ $this->wmc_descriptionurl_format = $element[attributes]["format"];
- if(strtoupper($element[tag]) == "DESCRIPTIONURL" && $element['type'] == "open"){
- $descriptionurl = true;
- $this->wmc_descriptionurl_format = $element[attributes]["format"];
- if ($descriptionurl) {
- if(strtoupper($element[tag]) == "DESCRIPTIONURL" && $element['type'] == "close"){
- $descriptionurl = false;
- $this->wmc_descriptionurl_type = $element[attributes]["xlink:type"];
- $this->wmc_descriptionurl = $element[attributes]["xlink:href"];
+ if ($descriptionurl) {
+ if(strtoupper($element[tag]) == "DESCRIPTIONURL" && $element['type'] == "close"){
+ $descriptionurl = false;
+ $this->wmc_descriptionurl_type = $element[attributes]["xlink:type"];
+ $this->wmc_descriptionurl = $element[attributes]["xlink:href"];
- if(strtoupper($element[tag]) == "KEYWORDLIST" && $element['type'] == "open"){
- $keywordlist = true;
- if ($keywordlist) {
- if(strtoupper($element[tag]) == "KEYWORDLIST" && $element['type'] == "close"){
- $keywordlist = false;
- $cnt_keyword = -1;
- if(strtoupper($element[tag]) == "KEYWORD"){
- $cnt_keyword++;
- $this->wmc_keyword[$cnt_keyword] = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "KEYWORDLIST" && $element['type'] == "open"){
+ $keywordlist = true;
- if(strtoupper($element[tag]) == "GENERAL" && $element['type'] == "close"){
- $general = false;
+ if ($keywordlist) {
+ if(strtoupper($element[tag]) == "KEYWORDLIST" && $element['type'] == "close"){
+ $keywordlist = false;
+ $cnt_keyword = -1;
+ if(strtoupper($element[tag]) == "KEYWORD"){
+ $cnt_keyword++;
+ $this->wmc_keyword[$cnt_keyword] = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "GENERAL" && $element['type'] == "close"){
+ $general = false;
if ($layerlist) {
if(strtoupper($element[tag]) == "LAYERLIST" && $element['type'] == "close"){
@@ -308,7 +318,7 @@
if ($layer) {
if(strtoupper($element[tag]) == "LAYER" && $element[type] == "close"){
- $layer = false;
+ $layer = false;
if ($formatlist) {
if(strtoupper($element[tag]) == "FORMAT"){
@@ -421,10 +431,22 @@
$cnt_epsg++;
- if(strtoupper($element[tag]) == "SCALEHINT"){
+ if (strtoupper($element[tag]) == "EXTENSION" && $element[type] == "open") {
+ $extension = true;
+ if (strtoupper($element[tag]) == "EXTENSION" && $element[type] == "close") {
+ if($extension == true && strtoupper(sepNameSpace($element[tag])) == "SCALEHINT"){
$this->wmc_layer_minscale[$cnt_layer] = $element[attributes]["min"];
$this->wmc_layer_maxscale[$cnt_layer] = $element[attributes]["max"];
+ if($extension == true && strtoupper(sepNameSpace($element[tag])) == "LAYER_ID"){
+ $this->wmc_layer_id[$cnt_layer] = $element[value];
+ if($extension == true && strtoupper(sepNameSpace($element[tag])) == "WMS_ID"){
+ $this->wmc_wms_id[$cnt_layer] = $element[value];
if(strtoupper($element[tag]) == "METADATAURL" && $element[type] == "open"){
$metadataurl = true;
@@ -444,6 +466,7 @@
return true;
+ //return $verbose;
function createJsObjFromWMC($target, $mapObj, $action){
@@ -547,7 +570,7 @@
$wmc_string .= "if (!wms_exists) {\n\t";
// add parent layer
- $wmc_string .= $target . "wms_add_layer('','','". $this->wmc_wms_title[$i] ."','','0','0','0','0','','".$id."','1','1','1','0','0','0','0');\n";
+ $wmc_string .= $target . "wms_add_layer('','".$this->wmc_layer_id[$i]."','','". $this->wmc_wms_title[$i] ."','','0','0','0','0','','".$id."','1','1','1','0','0','0','0');\n";
if ($action == "merge") {
$wmc_string .= "}\n";
@@ -584,6 +607,7 @@
// add layer
$wmc_string .= "\t" . $target . "wms_add_layer('0','".
+ $this->wmc_layer_id[$ii] . "','".
$this->wmc_layer_name[$ii] . "','".
$this->wmc_layer_title[$ii] ."','".
$this->wmc_layer_dataurl[$ii] . "','".
Modified: trunk/mapbender/http/classes/class_wms.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_wms.php?view=diff&rev=928&p1=trunk/mapbender/http/classes/class_wms.php&p2=trunk/mapbender/http/classes/class_wms.php&r1=927&r2=928
--- trunk/mapbender/http/classes/class_wms.php (original)
+++ trunk/mapbender/http/classes/class_wms.php 2006-11-21 15:33:51+0000
@@ -651,8 +651,8 @@
echo "parent.";
print ("wms_add_layer('".
- #$this->objLayer[$i]->layer_id ."','".
$this->objLayer[$i]->layer_parent ."','".
+ $this->objLayer[$i]->layer_uid ."','".
$this->objLayer[$i]->layer_name . "','".
$this->objLayer[$i]->layer_title ."','".
$this->objLayer[$i]->layer_dataurl_href ."','".
@@ -1345,6 +1345,7 @@
while($row2 = db_fetch_array($res_layer)){
$this->addLayer($row2["layer_pos"],$row2["layer_parent"]);
$layer_cnt=count($this->objLayer)-1;
+ $this->objLayer[$layer_cnt]->layer_uid = $layer_id;
$this->objLayer[$layer_cnt]->layer_name =$row2["layer_name"];
$this->objLayer[$layer_cnt]->layer_title =$row2["layer_title"];
$this->objLayer[$layer_cnt]->layer_dataurl_href =$row2["layer_dataurl"];
@@ -1356,6 +1357,7 @@
$this->objLayer[$layer_cnt]->layer_maxscale = $row2["layer_maxscale"];
$count_layer++;
$this->objLayer[$layer_cnt]->gui_layer_wms_id = $row["gui_layer_wms_id"];
$this->objLayer[$layer_cnt]->gui_layer_selectable = $row["gui_layer_selectable"];
$this->objLayer[$layer_cnt]->gui_layer_visible = $row["gui_layer_visible"];
Modified: trunk/mapbender/http/html/mod_treefolder.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/html/mod_treefolder.php?view=diff&rev=928&p1=trunk/mapbender/http/html/mod_treefolder.php&p2=trunk/mapbender/http/html/mod_treefolder.php&r1=927&r2=928
--- trunk/mapbender/http/html/mod_treefolder.php (original)
+++ trunk/mapbender/http/html/mod_treefolder.php 2006-11-21 15:33:51+0000
@@ -1,666 +1,671 @@
-<?php
-session_start();
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-$con = db_connect(DBSERVER,OWNER,PW);
-db_select_db(DB,$con);
-$gui_id = $_SESSION["mb_user_gui"];
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN">
-<HTML>
-<HEAD>
-<META NAME="Generator" CONTENT="Cosmo Create 1.0.3">
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<TITLE>Treefolder</TITLE>
-<?php
- include '../include/dyn_css.php';
-<script language='JavaScript'>
-function pop_up(name, einstellungen)
- window.open ('',name,einstellungen);
-</script>
-<?php
-echo "<script language='JavaScript'>";
- $sql = "SELECT e_target FROM gui_element WHERE e_id = $1 AND fkey_gui_id = $2";
- $v = array($_REQUEST['e_id_css'],$_SESSION["mb_user_gui"]);
- $t = array('s','s');
- $res = db_prep_query($sql,$v,$t);
- $e_target = db_result($res,0,"e_target");
- echo "mod_treeGDE_map = '".$e_target."';";
-echo "</script>";
- <SCRIPT language="JavaScript1.2">
- * sitemap.js 1.31 05/02/2000
- * - Opera 5
- * sitemap.js 1.3 27/11/2000
- * - Netscape 6
- * sitemap.js 1.2 20/05/2000
- * - split array tree into arrays for each element old tree
- * - no mory type flag, an folder is an entry which has sons
- * - a folder can have an link
- * - while initing an default layers is shown
- * sitemap.js 1.1 20/10/1999
- * - showTree only updates and init layers new which have been really changed
- * - add deep to knot entry
- * - substitute knotDeep[ id ] w/ tree[ id2treeIndex[ id ] ].deep
- * - add alignment to img and a at the beginning of eyery line
- * - add a fake img for bookmarks on top panel
- * sitemap.js 1.02 14/10/1999
- * - fix bug in initStyles
- * sitemap.js 1.01 06/10/1999
- * - fix bug in knotDeep for Netscape 4.00-4.0.5
- * sitemap.js 1.0 20/09/1999
- * Javascript function for displaying hierarchic directory structures with
- * the ability to collapse and expand directories.
- * Copyright (c) 1999 Polzin GmbH, Duesseldorf. All Rights Reserved.
- * Author: Lutz Eymers <ixtab at polzin.com>
- * Download: http://www.polzin.com/inet/fset_inet.phtml?w=goodies
- * Permission to use, copy, modify, and distribute this software
- * and its documentation for any purposes and without fee
- * is hereby granted provided that this copyright notice
- * appears in all copies.
- * Of course, this software is provided "as is" without express or implied
- * warranty of any kind.
-// some defaults
-try{if (switchwms){}}catch(e){switchwms = 'false';}
-try{if (ficheckbox){}}catch(e){ficheckbox = 'true';}
-try{if (metadatalink){}}catch(e){metadatalink = 'false';}
- parent.mb_registerSubFunctions("window.frames['treeGDE'].mod_treeGDE();");
- parent.mb_registerloadWmsSubFunctions("window.frames['treeGDE'].deleteInputTags();");
- parent.mb_registerloadWmsSubFunctions("window.frames['treeGDE'].document.location.reload();");
-function deleteInputTags() {
- var max = document.getElementsByTagName("input").length;
- for (var i=0; i<max; i++) {
- var aNode = document.getElementsByTagName("input")[0];
- var aNodeParent = aNode.parentNode;
- aNodeParent.removeChild(aNode);
-function handleSelectedLayer(mapObj,wms_id,layername,type,status){
- var mywms = new Array();
- mywms[0] = wms_id;
- var mylayername = new Array();
- mylayername[0] = layername;
- parent.handleSelectedLayer_array(mapObj, mywms, mylayername, type, status);
-function switchWMS(w,s){
- for(var i=0; i<parent.mb_mapObj.length; i++){
- if(parent.mb_mapObj[i].frameName == mod_treeGDE_map){
- for(var ii=0; ii<parent.mb_mapObj[i].wms.length; ii++){
- if(parent.mb_mapObj[i].wms[ii].wms_id == w){
- for(var iii=1; iii<parent.mb_mapObj[i].wms[ii].objLayer.length; iii++){
- if(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_selectable == '1'){
- parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_visible = s;
- if(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_queryable == '1'){
- //parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_querylayer = s;
- parent.mb_restateLayers(mod_treeGDE_map,w);
- parent.setSingleMapRequest(mod_treeGDE_map,w);
-function mod_treeGDE(){
- var ind = parent.getMapObjIndexByName(mod_treeGDE_map);
- //if(ind == false){ alert("error, no mapobject specified");}
- for(var i=0; i<document.getElementsByTagName("input").length; i++){
- //layer_shortname,wms_id,{visible | querylayer}
- var myID = document.getElementsByTagName("input")[i].id;
- var arrayID = document.getElementsByTagName("input")[i].id.split("###");
- var wms_ind = parent.getWMSIndexById(mod_treeGDE_map,arrayID[1]);
- if(arrayID[2] == "visible" && typeof(wms_ind) != "undefined"){
- var arrayLayer = parent.mb_mapObj[ind].layers[wms_ind].split(",");
- var isOn = false;
- for(var ii=0; ii<arrayLayer.length; ii++){
- if(arrayID[0] == arrayLayer[ii]){
- isOn = true;
- if(isOn == true){ document.getElementById(myID).checked = true;}
- if(isOn == false){ document.getElementById(myID).checked = false;}
- if(arrayID[2] == "querylayer" && typeof(wms_ind) != "undefined"){
- var arrayLayer = parent.mb_mapObj[ind].querylayers[wms_ind].split(",");
- var isOn = false;
- isOn = true;
- /*consider scalhints*/
- var scale = parseInt(parent.mb_getScale(mod_treeGDE_map));
- if(document.getElementById(parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_name+"_"+parent.mb_mapObj[i].wms[ii].wms_id)){
- if(scale < parseInt(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_minscale) && parseInt(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_minscale) != 0){
- document.getElementById(parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_name+"_"+parent.mb_mapObj[i].wms[ii].wms_id).style.color = '#999999';
- else if(scale > parseInt(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_maxscale) && parseInt(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_maxscale) != 0){
- else{
- document.getElementById(parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_name+"_"+parent.mb_mapObj[i].wms[ii].wms_id).style.color = '#000000';
- window.onError=null;
- var idx=0
- var treeId = new Array();
- var treeP_id = new Array();
- var treeIsOn = new Array();
- var treeTyp = new Array();
- var treeName = new Array();
- var treeUrl = new Array();
- var treeWasOn = new Array();
- var treeDeep = new Array();
- var treeLastY = new Array();
- var treeIsShown = new Array();
- var treeSelectable = new Array();
- var treeVisible = new Array();
- var treeQueryable = new Array();
- var treeQuerylayer = new Array();
- var treeWMS = new Array();
- var treeShortname = new Array();
- function Note( id,p_id,name,url,selectable,visible,queryable,querylayer,wms,shortname) {
- treeId[ idx ] = id
- treeP_id[ idx ] = p_id
- treeIsOn[ idx ] = false
- treeTyp[ idx ] = 'f'
- treeName[ idx ] = name
- treeUrl[ idx ] = url
- treeWasOn[ idx ] = false
- treeDeep[ idx ] = 0
- treeLastY[ idx ] = 0
- treeIsShown[ idx ] = false
- treeSelectable[ idx ] = selectable
- treeVisible[ idx ] = visible
- treeQueryable[ idx ] = queryable
- treeQuerylayer[ idx ] = querylayer
- treeWMS[ idx ] = wms
- treeShortname[ idx ] = shortname
- idx++
- function openwindow(Adresse) {
- Fenster1 = window.open(Adresse, "Informationen", "width=500,height=500,left=100,top=100,scrollbars=yes,resizable=no");
- Fenster1.focus();
- function initDiv ( )
- if ( isDOM || isDomIE )
- divPrefix='<DIV CLASS="sitemap" style="position:absolute; left:0; top:0; visibility:hidden;" ID="sitemap'
- divInfo='<DIV CLASS="sitemap" style="position:absolute; visibility:visible" ID="sitemap'
- else
- divPrefix='<DIV CLASS="sitemap" ID="sitemap'
- divInfo='<DIV CLASS="sitemap" ID="sitemap'
- document.writeln( divInfo + 'info">Bitte haben Sie etwas Geduld.<BR> <BR>Es werden die Einträge aus<BR> <BR>der Datenbank initialisiert.</DIV> ' );
- for ( var i=1; i<idx; i++ )
- // linked Name ?
- if ( treeUrl[i] != '' ){
- linkedName = "<input id='"+treeShortname[i]+"###"+treeWMS[i]+"###visible###' type='checkbox' ";
- if(treeVisible[i] == '1'){ linkedName += "checked ";}
- if(treeSelectable[i] != '1'){
- linkedName += "disabled ";
- linkedName += "onClick = 'if(this.checked){handleSelectedLayer(\""+mod_treeGDE_map+"\",\""+treeWMS[i]+"\",\""+treeShortname[i]+"\",\"visible\",1);";
- if(ficheckbox == 'false'){
- linkedName += "handleSelectedLayer(\""+mod_treeGDE_map+"\",\""+treeWMS[i]+"\",\""+treeShortname[i]+"\",\"querylayer\",1);";
- linkedName += "}";
- linkedName += "else{handleSelectedLayer(\""+mod_treeGDE_map+"\",\""+treeWMS[i]+"\",\""+treeShortname[i]+"\",\"visible\",0);";
- linkedName += "handleSelectedLayer(\""+mod_treeGDE_map+"\",\""+treeWMS[i]+"\",\""+treeShortname[i]+"\",\"querylayer\",0);";
- linkedName += "}'";
- linkedName += '>';
- if (ficheckbox == 'true'){
- linkedName += "<input id='"+treeShortname[i]+"###"+treeWMS[i]+"###querylayer' type='checkbox' ";
- if(treeQuerylayer[i] == '1'){ linkedName += "checked ";}
- if(treeQueryable[i] != '1'){ linkedName += "disabled ";}
- linkedName += "onClick = 'if(this.checked){handleSelectedLayer(\""+mod_treeGDE_map+"\",\""+treeWMS[i]+"\",\""+treeShortname[i]+"\",\"querylayer\",1);}";
- linkedName += "else{handleSelectedLayer(\""+mod_treeGDE_map+"\",\""+treeWMS[i]+"\",\""+treeShortname[i]+"\",\"querylayer\",0);}'";
- //linkedName += '<A id="'+treeWMS[i]+'_'+treeShortname[i]+'" HREF="' + treeUrl[i] + '" TARGET="' + defaultTarget + '"><IMG SRC="'+imagedir+'/1w.gif" BORDER="0" WIDTH="3">' + treeName[i] + '</A>';
- linkedName += '<A id="'+treeShortname[i]+'_'+treeWMS[i];
- if (metadatalink == 'true'){
- linkedName += '" HREF="' + treeUrl[i];
-// linkedName += '" HREF="../php/mod_layerMetadata.php?id=' + ;
- linkedName +='" TARGET="' + defaultTarget + '" onclick="openwindow(this.href); return false"><IMG SRC="'+imagedir+'/1w.gif" BORDER="0" WIDTH="3">' + treeName[i] + '</A>';
- else{
- linkedName = '<IMG SRC="'+imagedir+'/1w.gif" BORDER="0" WIDTH="3">';
- if(switchwms == 'true'){
- linkedName += '<input type="checkbox" onclick="if(this.checked){switchWMS(\''+treeWMS[i]+'\',1)}else{switchWMS(\''+treeWMS[i]+'\',0)}">';
- linkedName += treeName[i];
- // don't link folder icon if node has no sons
- if ( i == idx-1 || treeP_id[i+1] != treeId[i] ) {
- if ( treeDeep[ i ] == 0 )
- folderImg = '<IMG ALIGN="BOTTOM" SRC="'+imagedir+'/file_empty.gif" BORDER="0" HEIGHT="16" WIDTH="1" HSPACE="0">'
- else
- folderImg = ''
- } else {
- folderImg = '<A HREF="javascript:sitemapClick(' + treeId[i] + ')"><IMG ALIGN="BOTTOM" SRC="'+imagedir+'/folder_off.gif" BORDER="0" NAME="folder' + treeId[i] + '" HEIGHT="16" WIDTH="30" HSPACE="0"></A>'
- // which type of file icon should be displayed?
- if ( treeP_id[i] != 0 )
- if ( lastEntryInFolder( treeId[i] ) )
- fileImg = '<IMG ALIGN="BOTTOM" SRC="'+imagedir+'/file_last.gif" BORDER="0" NAME="file'
- + treeId[i] + '" HEIGHT="16" WIDTH="30" HSPACE="0">'
- else
- fileImg = '<IMG ALIGN="BOTTOM" SRC="'+imagedir+'/file.gif" BORDER="0" NAME="file'
- else
- fileImg = ''
- // traverse parents up to root and show vertical lines if parent
- // is not the last entry on this layer
- verticales = ''
- for( var act_id=treeId[i] ; treeDeep[ id2treeIndex[ act_id ] ] > 1; )
- act_id = treeP_id[ id2treeIndex[ act_id ]]
- if ( lastEntryInFolder( act_id ) )
- verticales = '<IMG ALIGN="BOTTOM" SRC="'+imagedir+'/file_empty.gif" BORDER="0" HEIGHT="16" WIDTH="30" HSPACE="0">' + verticales
- else
- verticales = '<IMG ALIGN="BOTTOM" SRC="'+imagedir+'/file_vert.gif" BORDER="0" HEIGHT="16" WIDTH="30" HSPACE="0">' + verticales
- document.writeln( divPrefix + treeId[i] + '"><NOBR> ' + verticales + fileImg + folderImg + linkedName + '</NOBR></DIV>'
- function initStyles ( )
- document.writeln( '<STYLE TYPE="text/css">' + "\n" + '<!--' )
- for ( var i=1,y=y0; i<idx; i++ )
- document.writeln( '#sitemap' + treeId[i] + ' {POSITION: absolute; VISIBILITY: hidden;}' )
- if ( treeIsOn[ id2treeIndex[ treeP_id[i] ] ] )
- y += deltaY
- document.writeln( '#sitemapinfo {POSITION: absolute; VISIBILITY: visible;}' )
- document.writeln( '//-->' + "\n" + '</STYLE>' )
- function sitemapClick( id )
- var i = id2treeIndex[ id ]
- if ( treeIsOn[ i ] )
- // close directory
- // mark node as invisible
- treeIsOn[ i ]=false
- // mark all sons as invisible
- actDeep = treeDeep[ i ]
- for( var j=i+1; j<idx && treeDeep[j] > actDeep; j++ )
- treeWasOn[ j ] = treeIsOn[ j ]
- treeIsOn[ j ]=false
- gif_off( id )
- else
- // open directory
- treeIsOn[ i ]=true
- // remember and restore old status
- treeIsOn[ j ] = treeWasOn[ j ]
- gif_on( id )
- showTree()
- function knotDeep( id )
- var deep=0
- while ( true )
- if ( treeP_id[ id2treeIndex[id] ] == 0 )
- return deep
- else
- ++deep
- id = treeP_id[ id2treeIndex[id] ]
- return deep
- function initTree( id )
- treeIsOn[ id2treeIndex[id] ] = true
- if ( treeTyp[ id2treeIndex[id] ] != 'b' )
- gif_on( id )
- while ( treeP_id[ id2treeIndex[id] ] != 0 )
- gif_on( id )
- function lastEntryInFolder( id )
- var i = id2treeIndex[id]
- if ( i == idx-1 )
- return true
- if ( treeTyp[i] == 'b' )
- if ( treeP_id[i+1] != treeP_id[i] )
- return true
- else
- return false
- else
- var actDeep = treeDeep[i]
- for( var j=i+1; j<idx && treeDeep[j] > actDeep ; j++ )
- if ( j<idx && treeDeep[j] == actDeep )
- return false
- else
- return true
- function showTree()
- for( var i=1, y=y0, x=x0; i<idx; i++ )
- // show current node
- if ( !(y == treeLastY[i] && treeIsShown[i] ) )
- showLayer( "sitemap"+ treeId[i] )
- setyLayer( "sitemap"+ treeId[i], y )
- treeIsShown[i] = true
- treeLastY[i] = y
- y += deltaY
- else
- // hide current node and all sons
- if ( treeIsShown[ i ] )
- hideLayer( "sitemap"+ treeId[i] )
- treeIsShown[i] = false
- function initIndex() {
- for( var i=0; i<idx; i++ )
- id2treeIndex[ treeId[i] ] = i
- function gif_name (name, width, height) {
- this.on = new Image (width, height);
- this.on.src = imagedir+ "/" +name + "_on.gif"
- this.off = new Image (width, height);
- this.off.src = imagedir+ "/"+name + "_off.gif"
- function load_gif (name, width, height) {
- gif_name [name] = new gif_name (name,width,height);
- function load_all () {
- load_gif ('folder',30,16)
- file_last = new Image( 30,16 )
- file_last.src = imagedir+ "/file_last.gif"
- file_middle = new Image( 30,16 )
- file_middle.src = imagedir+ "/file.gif"
- file_vert = new Image( 30,16 )
- file_vert.src = imagedir+ "/file_vert.gif"
- file_empty = new Image( 30,16 )
- file_empty = imagedir+ "/file_empty.gif"
- function gif_on ( id ) {
- eval("document['folder" + id + "'].src = gif_name['folder'].on.src")
- function gif_off ( id ) {
- eval("document['folder" + id + "'].src = gif_name['folder'].off.src")
- // global configuration
- var deltaX = 30
- var deltaY = 16
- var x0 = 5
- var y0 = 5
- var defaultTarget = '_blank'
- var browserName = navigator.appName;
- var browserVersion = parseInt(navigator.appVersion);
- var isIE = false;
- var isNN = false;
- var isDOM = false;
- var isDomIE = false;
- var isDomNN = false;
- var layerok = false;
- var isIE = browserName.indexOf("Microsoft Internet Explorer" )==-1?false:true;
- var isNN = browserName.indexOf("Netscape")==-1?false:true;
- var isOpera = browserName.indexOf("Opera")==-1?false:true;
- var isDOM = document.getElementById?true:false;
- var isDomNN = document.layers?true:false;
- var isDomIE = document.all?true:false;
- if ( isNN && browserVersion>=4 ) layerok=true;
- if ( isIE && browserVersion>=4 ) layerok=true;
- if ( isOpera && browserVersion>=5 ) layerok=true;
- function hideLayer(layerName) {
- if (isDOM)
- document.getElementById(layerName).style.visibility="hidden"
- else if (isDomIE)
- document.all[layerName].style.visibility="hidden";
- else if (isDomNN)
- document.layers[layerName].visibility="hidden";
- function showLayer(layerName) {
- if (isDOM)
- document.getElementById(layerName).style.visibility="visible"
- else if (isDomIE)
- document.all[layerName].style.visibility="visible";
- else if (isDomNN)
- document.layers[layerName].visibility="visible";
- function setyLayer(layerName, y) {
- if (isDOM)
- document.getElementById(layerName).style.top=y
- else if (isDomIE)
- document.all[layerName].style.top=y;
- else if (isDomNN)
- document.layers[layerName].top=y;
- var id2treeIndex = new Array()
- // the structure is easy to understand with a simple example
- // p_id is the id of the parent
- // E0 ( id=0,p_id=-1 )
- // E11 ( id=1,p_id=0)
- // E111 ( id=2,p_id=1 )
- // E112 ( id=3,p_id=1 )
- // E12 ( id=4,p_id=0 )
- // E121 ( id=5,p_id=4 )
- // E13 ( id=6,p_id=0 )
- // E131 ( id=7,p_id=6 )
- // E1311 ( id=8,p_id=7 )
- // E132 ( id=9,p_id=6 )
- // this is a multinary tree structure which is easy to
- // populate with database data :)
-function initArray(){
- var parentObj = 0;
- if(parent.mb_mapObj.length == 0){ window.setTimeout("initArray()",100); }
- else if(parent.mb_mapObj.length > 0){
- Note(0,-1,'','');
- if(parent.mb_mapObj[i].wms[ii].gui_wms_visible == '1' || parent.mb_mapObj[i].wms[ii].gui_wms_visible == 1){
- for(var iii=0; iii<parent.mb_mapObj[i].wms[ii].objLayer.length; iii++){
- var temp = parent.mb_mapObj[i].wms[ii].objLayer[iii];
- if(parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_parent == ""){
- //alert((parseInt(temp.layer_id)+1) + " , " +0 + " , " +temp.layer_title + " , " +" , "+temp.layer_metadataurl);
- Note((parseInt(temp.layer_id)+1),0,temp.layer_title,'','','','','',parent.mb_mapObj[i].wms[ii].wms_id,'');
- parentObj = temp.layer_id+1;
- if(parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_parent == "0"){
- //alert((parseInt(temp.layer_id)+1) + " , " +parentObj + " , " +temp.layer_title + " , " +temp.layer_metadataurl);
- if(temp.gui_layer_selectable == '1' || temp.gui_layer_queryable == '1'){
- //alert((parseInt(temp.layer_id)+1) + " , " +parentObj + " , " +temp.layer_title + " , " +temp.layer_metadataurl + " , " +temp.gui_layer_selectable + " , " +temp.gui_layer_visible + " , " +temp.gui_layer_queryable + " , " +temp.gui_layer_querylayer);
- Note((parseInt(temp.layer_id)+1),parentObj,temp.layer_title,'../php/mod_layerMetadata.php?wms='+encodeURIComponent(parent.mb_mapObj[i].wms[ii].wms_getmap)+'&name='+encodeURIComponent(temp.layer_name),temp.gui_layer_selectable,temp.gui_layer_visible,temp.gui_layer_queryable,temp.gui_layer_querylayer,parent.mb_mapObj[i].wms[ii].wms_id,temp.layer_name);
- if(temp.layer_metadataurl!=''){
- Note((parseInt(temp.layer_id)+1),parentObj,temp.layer_title,temp.layer_metadataurl,temp.gui_layer_selectable,temp.gui_layer_visible,temp.gui_layer_queryable,temp.gui_layer_querylayer,parent.mb_mapObj[i].wms[ii].wms_id,temp.layer_name);
- }else{
- Note((parseInt(temp.layer_id)+1),parentObj,temp.layer_title,'../metadata/'+temp.layer_name+".html",temp.gui_layer_selectable,temp.gui_layer_visible,temp.gui_layer_queryable,temp.gui_layer_querylayer,parent.mb_mapObj[i].wms[ii].wms_id,temp.layer_name);
- treeTyp[0] = 'f'
- treeIsOn[0] = true
- treeWasOn[0] = true
- function initArray_()
- Note(0,-1,'','')
- Note(1,0,'Tutorials','')
- Note(8,1,'HTML','')
- Note(10,8,'SelfHtml','http://www.teamone.de/selfaktuell/')
- Note(9,1,'willi','')
- Note(100,9,'SelfHtml','http://www.teamone.de/selfaktuell/')
- Note(3,1,'JavaScript','')
- Note(4,3, 'Netscape Guide 1.3','http://developer.netscape.com/docs/manuals/js/client/jsguide/index.htm')
- Note(7,3, 'Introduction to Javascript','http://rummelplatz.uni-mannheim.de/~skoch/js/script.htm')
- Note(12,1, 'Perl','')
- Note(14,12, 'Perl Tutorial','http://www.awu.id.ethz.ch/~didi/perl/perl_start.html')
- Note(13,1,'SQL','')
- Note(15,13, 'Introduction to SQL','http://w3.one.net/~jhoffman/sqltut.htm')
- Note(111,1, 'Introduction to SQL','http://w3.one.net/~jhoffman/sqltut.htm')
- Note(2,0, 'Reference Manuals','')
- Note(11,2, 'HTML Version 3.2 Referenz','http://www.cls-online.de/htmlref/index.htm')
- Note(6,2,'Netscape Reference 1.3','http://developer.netscape.com/docs/manuals/js/client/jsref/index.htm')
- Note(17,2,'PHP Manual','http://www.php.net/manual/html/')
- treeTyp[0] = 'f'
- var idx=0
- initArray()
- initIndex()
- load_all()
- for( i=1; i<idx; i++ )
- treeDeep[i] = knotDeep( treeId[i] )
- if ( treeDeep[i] == 0 )
- if ( isDomNN )
- initStyles();
- </SCRIPT>
-</HEAD>
-<BODY VLINK="#000000" ALINK="#000000" LINK="#000000" BGCOLOR="#ffffff" TEXT="#000000"
- onLoad="if (layerok) showTree();mod_treeGDE();"
- MARGINHEIGHT="0" MARGINWIDTH="0" LEFTMARGIN="0" TOPMARGIN="0">
-<SCRIPT language="JavaScript1.2">
- initDiv()
- hideLayer("sitemapinfo")
-</SCRIPT>
-</BODY>
-</HTML>
+<?php
+session_start();
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+$con = db_connect(DBSERVER,OWNER,PW);
+db_select_db(DB,$con);
+$gui_id = $_SESSION["mb_user_gui"];
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN">
+<HTML>
+<HEAD>
+<META NAME="Generator" CONTENT="Cosmo Create 1.0.3">
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<TITLE>Treefolder</TITLE>
+<?php
+ include '../include/dyn_css.php';
+<script language='JavaScript'>
+function pop_up(name, einstellungen)
+ window.open ('',name,einstellungen);
+</script>
+<?php
+echo "<script language='JavaScript'>";
+ $sql = "SELECT e_target FROM gui_element WHERE e_id = $1 AND fkey_gui_id = $2";
+ $v = array($_REQUEST['e_id_css'],$_SESSION["mb_user_gui"]);
+ $t = array('s','s');
+ $res = db_prep_query($sql,$v,$t);
+ $e_target = db_result($res,0,"e_target");
+ echo "mod_treeGDE_map = '".$e_target."';";
+echo "</script>";
+ <SCRIPT language="JavaScript1.2">
+ * sitemap.js 1.31 05/02/2000
+ * - Opera 5
+ * sitemap.js 1.3 27/11/2000
+ * - Netscape 6
+ * sitemap.js 1.2 20/05/2000
+ * - split array tree into arrays for each element old tree
+ * - no mory type flag, an folder is an entry which has sons
+ * - a folder can have an link
+ * - while initing an default layers is shown
+ * sitemap.js 1.1 20/10/1999
+ * - showTree only updates and init layers new which have been really changed
+ * - add deep to knot entry
+ * - substitute knotDeep[ id ] w/ tree[ id2treeIndex[ id ] ].deep
+ * - add alignment to img and a at the beginning of eyery line
+ * - add a fake img for bookmarks on top panel
+ * sitemap.js 1.02 14/10/1999
+ * - fix bug in initStyles
+ * sitemap.js 1.01 06/10/1999
+ * - fix bug in knotDeep for Netscape 4.00-4.0.5
+ * sitemap.js 1.0 20/09/1999
+ * Javascript function for displaying hierarchic directory structures with
+ * the ability to collapse and expand directories.
+ * Copyright (c) 1999 Polzin GmbH, Duesseldorf. All Rights Reserved.
+ * Author: Lutz Eymers <ixtab at polzin.com>
+ * Download: http://www.polzin.com/inet/fset_inet.phtml?w=goodies
+ * Permission to use, copy, modify, and distribute this software
+ * and its documentation for any purposes and without fee
+ * is hereby granted provided that this copyright notice
+ * appears in all copies.
+ * Of course, this software is provided "as is" without express or implied
+ * warranty of any kind.
+// some defaults
+try{if (switchwms){}}catch(e){switchwms = 'false';}
+try{if (ficheckbox){}}catch(e){ficheckbox = 'true';}
+try{if (metadatalink){}}catch(e){metadatalink = 'false';}
+ parent.mb_registerSubFunctions("window.frames['treeGDE'].mod_treeGDE();");
+ parent.mb_registerloadWmsSubFunctions("window.frames['treeGDE'].deleteInputTags();");
+ parent.mb_registerloadWmsSubFunctions("window.frames['treeGDE'].document.location.reload();");
+function deleteInputTags() {
+ var max = document.getElementsByTagName("input").length;
+ for (var i=0; i<max; i++) {
+ var aNode = document.getElementsByTagName("input")[0];
+ var aNodeParent = aNode.parentNode;
+ aNodeParent.removeChild(aNode);
+function handleSelectedLayer(mapObj,wms_id,layername,type,status){
+ var mywms = new Array();
+ mywms[0] = wms_id;
+ var mylayername = new Array();
+ mylayername[0] = layername;
+ parent.handleSelectedLayer_array(mapObj, mywms, mylayername, type, status);
+function switchWMS(w,s){
+ for(var i=0; i<parent.mb_mapObj.length; i++){
+ if(parent.mb_mapObj[i].frameName == mod_treeGDE_map){
+ for(var ii=0; ii<parent.mb_mapObj[i].wms.length; ii++){
+ if(parent.mb_mapObj[i].wms[ii].wms_id == w){
+ for(var iii=1; iii<parent.mb_mapObj[i].wms[ii].objLayer.length; iii++){
+ if(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_selectable == '1'){
+ parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_visible = s;
+ if(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_queryable == '1'){
+ //parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_querylayer = s;
+ parent.mb_restateLayers(mod_treeGDE_map,w);
+ parent.setSingleMapRequest(mod_treeGDE_map,w);
+function mod_treeGDE(){
+ var ind = parent.getMapObjIndexByName(mod_treeGDE_map);
+ //if(ind == false){ alert("error, no mapobject specified");}
+ for(var i=0; i<document.getElementsByTagName("input").length; i++){
+ //layer_shortname,wms_id,{visible | querylayer}
+ var myID = document.getElementsByTagName("input")[i].id;
+ var arrayID = document.getElementsByTagName("input")[i].id.split("###");
+ var wms_ind = parent.getWMSIndexById(mod_treeGDE_map,arrayID[1]);
+ if(arrayID[2] == "visible" && typeof(wms_ind) != "undefined"){
+ var arrayLayer = parent.mb_mapObj[ind].layers[wms_ind].split(",");
+ var isOn = false;
+ for(var ii=0; ii<arrayLayer.length; ii++){
+ if(arrayID[0] == arrayLayer[ii]){
+ isOn = true;
+ if(isOn == true){ document.getElementById(myID).checked = true;}
+ if(isOn == false){ document.getElementById(myID).checked = false;}
+ if(arrayID[2] == "querylayer" && typeof(wms_ind) != "undefined"){
+ var arrayLayer = parent.mb_mapObj[ind].querylayers[wms_ind].split(",");
+ var isOn = false;
+ isOn = true;
+ /*consider scalhints*/
+ var scale = parseInt(parent.mb_getScale(mod_treeGDE_map));
+ if(document.getElementById(parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_name+"_"+parent.mb_mapObj[i].wms[ii].wms_id)){
+ if(scale < parseInt(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_minscale) && parseInt(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_minscale) != 0){
+ document.getElementById(parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_name+"_"+parent.mb_mapObj[i].wms[ii].wms_id).style.color = '#999999';
+ else if(scale > parseInt(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_maxscale) && parseInt(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_maxscale) != 0){
+ else{
+ document.getElementById(parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_name+"_"+parent.mb_mapObj[i].wms[ii].wms_id).style.color = '#000000';
+ window.onError=null;
+ var idx=0
+ var treeId = new Array();
+ var treeP_id = new Array();
+ var treeIsOn = new Array();
+ var treeTyp = new Array();
+ var treeName = new Array();
+ var treeUrl = new Array();
+ var treeWasOn = new Array();
+ var treeDeep = new Array();
+ var treeLastY = new Array();
+ var treeIsShown = new Array();
+ var treeSelectable = new Array();
+ var treeVisible = new Array();
+ var treeQueryable = new Array();
+ var treeQuerylayer = new Array();
+ var treeWMS = new Array();
+ var treeShortname = new Array();
+ function Note( id,p_id,name,url,selectable,visible,queryable,querylayer,wms,shortname) {
+ treeId[ idx ] = id
+ treeP_id[ idx ] = p_id
+ treeIsOn[ idx ] = false
+ treeTyp[ idx ] = 'f'
+ treeName[ idx ] = name
+ treeUrl[ idx ] = url
+ treeWasOn[ idx ] = false
+ treeDeep[ idx ] = 0
+ treeLastY[ idx ] = 0
+ treeIsShown[ idx ] = false
+ treeSelectable[ idx ] = selectable
+ treeVisible[ idx ] = visible
+ treeQueryable[ idx ] = queryable
+ treeQuerylayer[ idx ] = querylayer
+ treeWMS[ idx ] = wms
+ treeShortname[ idx ] = shortname
+ idx++
+ function openwindow(Adresse) {
+ Fenster1 = window.open(Adresse, "Informationen", "width=500,height=500,left=100,top=100,scrollbars=yes,resizable=no");
+ Fenster1.focus();
+ function initDiv ( )
+ if ( isDOM || isDomIE )
+ divPrefix='<DIV CLASS="sitemap" style="position:absolute; left:0; top:0; visibility:hidden;" ID="sitemap'
+ divInfo='<DIV CLASS="sitemap" style="position:absolute; visibility:visible" ID="sitemap'
+ else
+ divPrefix='<DIV CLASS="sitemap" ID="sitemap'
+ divInfo='<DIV CLASS="sitemap" ID="sitemap'
+ document.writeln( divInfo + 'info">Bitte haben Sie etwas Geduld.<BR> <BR>Es werden die Einträge aus<BR> <BR>der Datenbank initialisiert.</DIV> ' );
+ for ( var i=1; i<idx; i++ )
+ // linked Name ?
+ if ( treeUrl[i] != '' ){
+ linkedName = "<input id='"+treeShortname[i]+"###"+treeWMS[i]+"###visible###' type='checkbox' ";
+ if(treeVisible[i] == '1'){ linkedName += "checked ";}
+ if(treeSelectable[i] != '1'){
+ linkedName += "disabled ";
+ linkedName += "onClick = 'if(this.checked){handleSelectedLayer(\""+mod_treeGDE_map+"\",\""+treeWMS[i]+"\",\""+treeShortname[i]+"\",\"visible\",1);";
+ if(ficheckbox == 'false'){
+ linkedName += "handleSelectedLayer(\""+mod_treeGDE_map+"\",\""+treeWMS[i]+"\",\""+treeShortname[i]+"\",\"querylayer\",1);";
+ linkedName += "}";
+ linkedName += "else{handleSelectedLayer(\""+mod_treeGDE_map+"\",\""+treeWMS[i]+"\",\""+treeShortname[i]+"\",\"visible\",0);";
+ linkedName += "handleSelectedLayer(\""+mod_treeGDE_map+"\",\""+treeWMS[i]+"\",\""+treeShortname[i]+"\",\"querylayer\",0);";
+ linkedName += "}'";
+ linkedName += '>';
+ if (ficheckbox == 'true'){
+ linkedName += "<input id='"+treeShortname[i]+"###"+treeWMS[i]+"###querylayer' type='checkbox' ";
+ if(treeQuerylayer[i] == '1'){ linkedName += "checked ";}
+ if(treeQueryable[i] != '1'){ linkedName += "disabled ";}
+ linkedName += "onClick = 'if(this.checked){handleSelectedLayer(\""+mod_treeGDE_map+"\",\""+treeWMS[i]+"\",\""+treeShortname[i]+"\",\"querylayer\",1);}";
+ linkedName += "else{handleSelectedLayer(\""+mod_treeGDE_map+"\",\""+treeWMS[i]+"\",\""+treeShortname[i]+"\",\"querylayer\",0);}'";
+ //linkedName += '<A id="'+treeWMS[i]+'_'+treeShortname[i]+'" HREF="' + treeUrl[i] + '" TARGET="' + defaultTarget + '"><IMG SRC="'+imagedir+'/1w.gif" BORDER="0" WIDTH="3">' + treeName[i] + '</A>';
+ linkedName += '<A id="'+treeShortname[i]+'_'+treeWMS[i];
+ if (metadatalink == 'true'){
+ linkedName += '" HREF="' + treeUrl[i];
+// linkedName += '" HREF="../php/mod_layerMetadata.php?id=' + ;
+ linkedName +='" TARGET="' + defaultTarget + '" onclick="openwindow(this.href); return false"><IMG SRC="'+imagedir+'/1w.gif" BORDER="0" WIDTH="3">' + treeName[i] + '</A>';
+ else{
+ linkedName = '<IMG SRC="'+imagedir+'/1w.gif" BORDER="0" WIDTH="3">';
+ if(switchwms == 'true'){
+ linkedName += '<input type="checkbox" onclick="if(this.checked){switchWMS(\''+treeWMS[i]+'\',1)}else{switchWMS(\''+treeWMS[i]+'\',0)}">';
+ linkedName += treeName[i];
+ // don't link folder icon if node has no sons
+ if ( i == idx-1 || treeP_id[i+1] != treeId[i] ) {
+ if ( treeDeep[ i ] == 0 )
+ folderImg = '<IMG ALIGN="BOTTOM" SRC="'+imagedir+'/file_empty.gif" BORDER="0" HEIGHT="16" WIDTH="1" HSPACE="0">'
+ else
+ folderImg = ''
+ } else {
+ folderImg = '<A HREF="javascript:sitemapClick(' + treeId[i] + ')"><IMG ALIGN="BOTTOM" SRC="'+imagedir+'/folder_off.gif" BORDER="0" NAME="folder' + treeId[i] + '" HEIGHT="16" WIDTH="30" HSPACE="0"></A>'
+ // which type of file icon should be displayed?
+ if ( treeP_id[i] != 0 )
+ if ( lastEntryInFolder( treeId[i] ) )
+ fileImg = '<IMG ALIGN="BOTTOM" SRC="'+imagedir+'/file_last.gif" BORDER="0" NAME="file'
+ + treeId[i] + '" HEIGHT="16" WIDTH="30" HSPACE="0">'
+ else
+ fileImg = '<IMG ALIGN="BOTTOM" SRC="'+imagedir+'/file.gif" BORDER="0" NAME="file'
+ else
+ fileImg = ''
+ // traverse parents up to root and show vertical lines if parent
+ // is not the last entry on this layer
+ verticales = ''
+ for( var act_id=treeId[i] ; treeDeep[ id2treeIndex[ act_id ] ] > 1; )
+ act_id = treeP_id[ id2treeIndex[ act_id ]]
+ if ( lastEntryInFolder( act_id ) )
+ verticales = '<IMG ALIGN="BOTTOM" SRC="'+imagedir+'/file_empty.gif" BORDER="0" HEIGHT="16" WIDTH="30" HSPACE="0">' + verticales
+ else
+ verticales = '<IMG ALIGN="BOTTOM" SRC="'+imagedir+'/file_vert.gif" BORDER="0" HEIGHT="16" WIDTH="30" HSPACE="0">' + verticales
+ document.writeln( divPrefix + treeId[i] + '"><NOBR> ' + verticales + fileImg + folderImg + linkedName + '</NOBR></DIV>'
+ function initStyles ( )
+ document.writeln( '<STYLE TYPE="text/css">' + "\n" + '<!--' )
+ for ( var i=1,y=y0; i<idx; i++ )
+ document.writeln( '#sitemap' + treeId[i] + ' {POSITION: absolute; VISIBILITY: hidden;}' )
+ if ( treeIsOn[ id2treeIndex[ treeP_id[i] ] ] )
+ y += deltaY
+ document.writeln( '#sitemapinfo {POSITION: absolute; VISIBILITY: visible;}' )
+ document.writeln( '//-->' + "\n" + '</STYLE>' )
+ function sitemapClick( id )
+ var i = id2treeIndex[ id ]
+ if ( treeIsOn[ i ] )
+ // close directory
+ // mark node as invisible
+ treeIsOn[ i ]=false
+ // mark all sons as invisible
+ actDeep = treeDeep[ i ]
+ for( var j=i+1; j<idx && treeDeep[j] > actDeep; j++ )
+ treeWasOn[ j ] = treeIsOn[ j ]
+ treeIsOn[ j ]=false
+ gif_off( id )
+ else
+ // open directory
+ treeIsOn[ i ]=true
+ // remember and restore old status
+ treeIsOn[ j ] = treeWasOn[ j ]
+ gif_on( id )
+ showTree()
+ function knotDeep( id )
+ var deep=0
+ while ( true )
+ if ( treeP_id[ id2treeIndex[id] ] == 0 )
+ return deep
+ else
+ ++deep
+ id = treeP_id[ id2treeIndex[id] ]
+ return deep
+ function initTree( id )
+ treeIsOn[ id2treeIndex[id] ] = true
+ if ( treeTyp[ id2treeIndex[id] ] != 'b' )
+ gif_on( id )
+ while ( treeP_id[ id2treeIndex[id] ] != 0 )
+ gif_on( id )
+ function lastEntryInFolder( id )
+ var i = id2treeIndex[id]
+ if ( i == idx-1 )
+ return true
+ if ( treeTyp[i] == 'b' )
+ if ( treeP_id[i+1] != treeP_id[i] )
+ return true
+ else
+ return false
+ else
+ var actDeep = treeDeep[i]
+ for( var j=i+1; j<idx && treeDeep[j] > actDeep ; j++ )
+ if ( j<idx && treeDeep[j] == actDeep )
+ return false
+ else
+ return true
+ function showTree()
+ for( var i=1, y=y0, x=x0; i<idx; i++ )
+ // show current node
+ if ( !(y == treeLastY[i] && treeIsShown[i] ) )
+ showLayer( "sitemap"+ treeId[i] )
+ setyLayer( "sitemap"+ treeId[i], y )
+ treeIsShown[i] = true
+ treeLastY[i] = y
+ y += deltaY
+ else
+ // hide current node and all sons
+ if ( treeIsShown[ i ] )
+ hideLayer( "sitemap"+ treeId[i] )
+ treeIsShown[i] = false
+ function initIndex() {
+ for( var i=0; i<idx; i++ )
+ id2treeIndex[ treeId[i] ] = i
+ function gif_name (name, width, height) {
+ this.on = new Image (width, height);
+ this.on.src = imagedir+ "/" +name + "_on.gif"
+ this.off = new Image (width, height);
+ this.off.src = imagedir+ "/"+name + "_off.gif"
+ function load_gif (name, width, height) {
+ gif_name [name] = new gif_name (name,width,height);
+ function load_all () {
+ load_gif ('folder',30,16)
+ file_last = new Image( 30,16 )
+ file_last.src = imagedir+ "/file_last.gif"
+ file_middle = new Image( 30,16 )
+ file_middle.src = imagedir+ "/file.gif"
+ file_vert = new Image( 30,16 )
+ file_vert.src = imagedir+ "/file_vert.gif"
+ file_empty = new Image( 30,16 )
+ file_empty = imagedir+ "/file_empty.gif"
+ function gif_on ( id ) {
+ eval("document['folder" + id + "'].src = gif_name['folder'].on.src")
+ function gif_off ( id ) {
+ eval("document['folder" + id + "'].src = gif_name['folder'].off.src")
+ // global configuration
+ var deltaX = 30
+ var deltaY = 16
+ var x0 = 5
+ var y0 = 5
+ var defaultTarget = '_blank'
+ var browserName = navigator.appName;
+ var browserVersion = parseInt(navigator.appVersion);
+ var isIE = false;
+ var isNN = false;
+ var isDOM = false;
+ var isDomIE = false;
+ var isDomNN = false;
+ var layerok = false;
+ var isIE = browserName.indexOf("Microsoft Internet Explorer" )==-1?false:true;
+ var isNN = browserName.indexOf("Netscape")==-1?false:true;
+ var isOpera = browserName.indexOf("Opera")==-1?false:true;
+ var isDOM = document.getElementById?true:false;
+ var isDomNN = document.layers?true:false;
+ var isDomIE = document.all?true:false;
+ if ( isNN && browserVersion>=4 ) layerok=true;
+ if ( isIE && browserVersion>=4 ) layerok=true;
+ if ( isOpera && browserVersion>=5 ) layerok=true;
+ function hideLayer(layerName) {
+ if (isDOM)
+ document.getElementById(layerName).style.visibility="hidden"
+ else if (isDomIE)
+ document.all[layerName].style.visibility="hidden";
+ else if (isDomNN)
+ document.layers[layerName].visibility="hidden";
+ function showLayer(layerName) {
+ if (isDOM)
+ document.getElementById(layerName).style.visibility="visible"
+ else if (isDomIE)
+ document.all[layerName].style.visibility="visible";
+ else if (isDomNN)
+ document.layers[layerName].visibility="visible";
+ function setyLayer(layerName, y) {
+ if (isDOM)
+ document.getElementById(layerName).style.top=y
+ else if (isDomIE)
+ document.all[layerName].style.top=y;
+ else if (isDomNN)
+ document.layers[layerName].top=y;
+ var id2treeIndex = new Array()
+ // the structure is easy to understand with a simple example
+ // p_id is the id of the parent
+ // E0 ( id=0,p_id=-1 )
+ // E11 ( id=1,p_id=0)
+ // E111 ( id=2,p_id=1 )
+ // E112 ( id=3,p_id=1 )
+ // E12 ( id=4,p_id=0 )
+ // E121 ( id=5,p_id=4 )
+ // E13 ( id=6,p_id=0 )
+ // E131 ( id=7,p_id=6 )
+ // E1311 ( id=8,p_id=7 )
+ // E132 ( id=9,p_id=6 )
+ // this is a multinary tree structure which is easy to
+ // populate with database data :)
+function initArray(){
+ var parentObj = 0;
+ if(parent.mb_mapObj.length == 0){ window.setTimeout("initArray()",100); }
+ else if(parent.mb_mapObj.length > 0){
+ Note(0,-1,'','');
+ if(parent.mb_mapObj[i].wms[ii].gui_wms_visible == '1' || parent.mb_mapObj[i].wms[ii].gui_wms_visible == 1){
+ for(var iii=0; iii<parent.mb_mapObj[i].wms[ii].objLayer.length; iii++){
+ var temp = parent.mb_mapObj[i].wms[ii].objLayer[iii];
+ if(parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_parent == ""){
+ //alert((parseInt(temp.layer_id)+1) + " , " +0 + " , " +temp.layer_title + " , " +" , "+temp.layer_metadataurl);
+ Note((parseInt(temp.layer_id)+1),0,temp.layer_title,'','','','','',parent.mb_mapObj[i].wms[ii].wms_id,'');
+ parentObj = temp.layer_id+1;
+ if(parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_parent == "0"){
+ //alert((parseInt(temp.layer_id)+1) + " , " +parentObj + " , " +temp.layer_title + " , " +temp.layer_metadataurl);
+ if(temp.gui_layer_selectable == '1' || temp.gui_layer_queryable == '1'){
+ //alert((parseInt(temp.layer_id)+1) + " , " +parentObj + " , " +temp.layer_title + " , " +temp.layer_metadataurl + " , " +temp.gui_layer_selectable + " , " +temp.gui_layer_visible + " , " +temp.gui_layer_queryable + " , " +temp.gui_layer_querylayer);
+ if (temp.layer_uid) {
+ Note((parseInt(temp.layer_id)+1),parentObj,temp.layer_title,'../php/mod_layerMetadata.php?id='+temp.layer_uid,temp.gui_layer_selectable,temp.gui_layer_visible,temp.gui_layer_queryable,temp.gui_layer_querylayer,parent.mb_mapObj[i].wms[ii].wms_id,temp.layer_name);
+ else {
+ Note((parseInt(temp.layer_id)+1),parentObj,temp.layer_title,'',temp.gui_layer_selectable,temp.gui_layer_visible,temp.gui_layer_queryable,temp.gui_layer_querylayer,parent.mb_mapObj[i].wms[ii].wms_id,temp.layer_name);
+ if(temp.layer_metadataurl!=''){
+ Note((parseInt(temp.layer_id)+1),parentObj,temp.layer_title,temp.layer_metadataurl,temp.gui_layer_selectable,temp.gui_layer_visible,temp.gui_layer_queryable,temp.gui_layer_querylayer,parent.mb_mapObj[i].wms[ii].wms_id,temp.layer_name);
+ }else{
+ Note((parseInt(temp.layer_id)+1),parentObj,temp.layer_title,'../metadata/'+temp.layer_name+".html",temp.gui_layer_selectable,temp.gui_layer_visible,temp.gui_layer_queryable,temp.gui_layer_querylayer,parent.mb_mapObj[i].wms[ii].wms_id,temp.layer_name);
+ treeTyp[0] = 'f'
+ treeIsOn[0] = true
+ treeWasOn[0] = true
+ function initArray_()
+ Note(0,-1,'','')
+ Note(1,0,'Tutorials','')
+ Note(8,1,'HTML','')
+ Note(10,8,'SelfHtml','http://www.teamone.de/selfaktuell/')
+ Note(9,1,'willi','')
+ Note(100,9,'SelfHtml','http://www.teamone.de/selfaktuell/')
+ Note(3,1,'JavaScript','')
+ Note(4,3, 'Netscape Guide 1.3','http://developer.netscape.com/docs/manuals/js/client/jsguide/index.htm')
+ Note(7,3, 'Introduction to Javascript','http://rummelplatz.uni-mannheim.de/~skoch/js/script.htm')
+ Note(12,1, 'Perl','')
+ Note(14,12, 'Perl Tutorial','http://www.awu.id.ethz.ch/~didi/perl/perl_start.html')
+ Note(13,1,'SQL','')
+ Note(15,13, 'Introduction to SQL','http://w3.one.net/~jhoffman/sqltut.htm')
+ Note(111,1, 'Introduction to SQL','http://w3.one.net/~jhoffman/sqltut.htm')
+ Note(2,0, 'Reference Manuals','')
+ Note(11,2, 'HTML Version 3.2 Referenz','http://www.cls-online.de/htmlref/index.htm')
+ Note(6,2,'Netscape Reference 1.3','http://developer.netscape.com/docs/manuals/js/client/jsref/index.htm')
+ Note(17,2,'PHP Manual','http://www.php.net/manual/html/')
+ treeTyp[0] = 'f'
+ var idx=0
+ initArray()
+ initIndex()
+ load_all()
+ for( i=1; i<idx; i++ )
+ treeDeep[i] = knotDeep( treeId[i] )
+ if ( treeDeep[i] == 0 )
+ if ( isDomNN )
+ initStyles();
+ </SCRIPT>
+</HEAD>
+<BODY VLINK="#000000" ALINK="#000000" LINK="#000000" BGCOLOR="#ffffff" TEXT="#000000"
+ onLoad="if (layerok) showTree();mod_treeGDE();"
+ MARGINHEIGHT="0" MARGINWIDTH="0" LEFTMARGIN="0" TOPMARGIN="0">
+<SCRIPT language="JavaScript1.2">
+ initDiv()
+ hideLayer("sitemapinfo")
+</SCRIPT>
+</BODY>
+</HTML>
Modified: trunk/mapbender/http/javascripts/map_obj.js
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/map_obj.js?view=diff&rev=928&p1=trunk/mapbender/http/javascripts/map_obj.js&p2=trunk/mapbender/http/javascripts/map_obj.js&r1=927&r2=928
--- trunk/mapbender/http/javascripts/map_obj.js (original)
+++ trunk/mapbender/http/javascripts/map_obj.js 2006-11-21 15:33:51+0000
@@ -120,6 +120,7 @@
//layer
function wms_add_layer(
layer_parent,
+ layer_uid,
layer_name,
layer_title,
layer_dataurl_href,
@@ -140,6 +141,7 @@
wms[wms.length-1].objLayer[wms[wms.length-1].objLayer.length] = new wms_layer(
layer_parent,
+ layer_uid,
layer_name,
layer_title,
layer_dataurl_href,
@@ -160,6 +162,7 @@
function wms_layer(
layer_parent,
+ wms_layer_uid,
layer_name,
layer_title,
layer_dataurl_href,
@@ -178,6 +181,7 @@
gui_layer_maxscale,
gui_layer_wfs_featuretype){
this.layer_id = wms_layer_count;
+ this.layer_uid = wms_layer_uid;
this.layer_parent = layer_parent;
this.layer_name = layer_name;
this.layer_title = layer_title;
Modified: trunk/mapbender/http/javascripts/mod_savewmc.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_savewmc.php?view=diff&rev=928&p1=trunk/mapbender/http/javascripts/mod_savewmc.php&p2=trunk/mapbender/http/javascripts/mod_savewmc.php&r1=927&r2=928
--- trunk/mapbender/http/javascripts/mod_savewmc.php (original)
+++ trunk/mapbender/http/javascripts/mod_savewmc.php 2006-11-21 15:33:51+0000
@@ -124,7 +124,7 @@
var generalContactFacsimileTelephone = "";
var generalContactElectronicMailAddress = "";
- // Missing: Extension
+ var extension_namespace = "mapbender";
// LayerList variables
var layerHidden = "";
@@ -150,7 +150,7 @@
// wmc += "<!ENTITY amp \"&#38;#38;\">\n";
wmc += "<ViewContext version=\"" + version + "\" ";
wmc += "id = \"" + id + "\" ";
- wmc += "xmlns=\"http://www.opengis.net/context\" xmlns:xlink=\"http://www.w3.org/1999/xlink\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:SchemaLocation=\"http://schemas.opengis.net/context/1.0.0/context.xsd\" ";
+ wmc += "xmlns=\"http://www.opengis.net/context\" xmlns:xlink=\"http://www.w3.org/1999/xlink\" xmlns:mapbender=\"http://www.mapbender.org\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:SchemaLocation=\"http://schemas.opengis.net/context/1.0.0/context.xsd\" ";
wmc += ">\n";
//General
@@ -248,20 +248,13 @@
wmc += "\t<LayerList>\n";
for (var i = 0; i < mb_mapObj[ind].wms.length; i++){
- // BEGIN: new code
+ wmsId = mb_mapObj[ind].wms[i].wms_id;
- // in the end, this array contains all epsgs of this wms
var wms_epsg = new Array();
- // the gui_wms_epsg is always the first epsg in this layers epsg list
wms_epsg[0] = mb_mapObj[ind].epsg;
- // the epsg of the mapObj has to be in this list
if (mb_mapObj[ind].wms[i].gui_wms_epsg != mb_mapObj[ind].epsg){
wms_epsg[1] = mb_mapObj[ind].wms[i].gui_wms_epsg;
- // add all gui_epsg if not already in the array
for (q = 0; q < mb_mapObj[ind].wms[i].gui_epsg.length ; q ++){
var isInArray = false;
for (r = 0 ; r < wms_epsg.length ; r ++){
@@ -273,8 +266,6 @@
wms_epsg[wms_epsg.length] = mb_mapObj[ind].wms[i].gui_epsg[q];
- // END: new code
for (var j = 0; j < mb_mapObj[ind].wms[i].objLayer.length; j++){
if (mb_mapObj[ind].wms[i].objLayer[j].layer_parent != ''){
@@ -285,6 +276,7 @@
layerHidden = 1;
layerQueryable = mb_mapObj[ind].wms[i].objLayer[j].layer_queryable;
+ layerId = mb_mapObj[ind].wms[i].objLayer[j].layer_uid;
layerName = htmlspecialchars(mb_mapObj[ind].wms[i].objLayer[j].layer_name,0);
layerTitle = htmlspecialchars(mb_mapObj[ind].wms[i].objLayer[j].layer_title, 0);
layerAbstract = mb_mapObj[ind].wms[i].wms_abstract; //To Do: insert actual abstract
@@ -329,9 +321,13 @@
wmc += "\t\t\t</MetadataURL>\n";
+ wmc += "\t\t\t<Extension>\n";
if (layerMinscale && layerMaxscale) {
- wmc += "\t\t\t<ScaleHint min=\""+layerMinscale+"\" max=\""+layerMaxscale+"\"/>\n";
+ wmc += "\t\t\t\t<"+extension_namespace+":ScaleHint min=\""+layerMinscale+"\" max=\""+layerMaxscale+"\"/>\n";
+ wmc += "\t\t\t\t<"+extension_namespace+":layer_id>"+layerId+"</"+extension_namespace+":layer_id>\n";
+ wmc += "\t\t\t\t<"+extension_namespace+":wms_id>"+wmsId+"</"+extension_namespace+":wms_id>\n";
+ wmc += "\t\t\t</Extension>\n";
//layerFormat
wmc += "\t\t\t<FormatList>\n";
More information about the Mapbender_commits
