svn commit: r956 - trunk/mapbender/http/php/mod_layerMetadata.php
christoph at osgeo.org
Thu Nov 23 10:03:04 EST 2006
Author: christoph
Date: 2006-11-23 15:03:04+0000
New Revision: 956
Added:
new version from Geoportal-RLP
Added: trunk/mapbender/http/php/mod_layerMetadata.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_layerMetadata.php?view=auto&rev=956
--- (empty file)
+++ trunk/mapbender/http/php/mod_layerMetadata.php 2006-11-23 15:03:04+0000
@@ -0,0 +1,196 @@
+<?php
+# $Id: mod_layerMetadata.php 235 2006-05-11 08:34:48Z uli $
+# http://www.mapbender.org/index.php/Administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once("../../conf/mapbender.conf");
+$con = db_connect(DBSERVER,OWNER,PW);
+db_select_db(DB,$con);
+function display_text($string) {
+ $string = eregi_replace("[[:alpha:]]+://[^<>[:space:]]+[[:alnum:]/]", "<a href=\"\\0\" target=_blank>\\0</a>", $string);
+ $string = eregi_replace("^[_a-z0-9-]+(\.[_a-z0-9-]+)*@([0-9a-z](-?[0-9a-z])*\.)+[a-z]{2}([zmuvtg]|fo|me)?$", "<a href=\"mailto:\\0\" target=_blank>\\0</a>", $string);
+ $string = eregi_replace("\n", "<br>", $string);
+ return $string;
+function getEpsgByLayerId ($layer_id) { // from merge_layer.php
+ $epsg_list = "";
+ $sql = "SELECT DISTINCT epsg FROM layer_epsg WHERE fkey_layer_id = $1";
+ $v = array($layer_id);
+ $t = array('i');
+ $res = db_prep_query($sql, $v, $t);
+ while($row = db_fetch_array($res)){
+ $epsg_list .= $row['epsg'] . " ";
+ return trim($epsg_list);
+<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="de">
+ <head>
+ <title>GeoPortal Rheinland-Pfalz - Metadaten</title>
+ <meta name="description" content="Metadaten" xml:lang="de" />
+ <meta name="keywords" content="Metadaten" xml:lang="de" />
+ <meta http-equiv="cache-control" content="no-cache">
+ <meta http-equiv="pragma" content="no-cache">
+ <meta http-equiv="expires" content="0">
+ <meta http-equiv="content-language" content="de" />
+ <meta http-equiv="content-style-type" content="text/css" />
+<?php
+ echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+ <link rel="stylesheet" type="text/css" href="../../../portal/fileadmin/design/css/screen.css" media="screen" />
+ <link rel="stylesheet" type="text/css" href="../../../portal/fileadmin/design/css/print.css" media="print" />
+ </head>
+ <body id="top" class="popup">
+ <div id="header_gray">
+ <a href="javascript:window.print()">Drucken <img src="../../../portal/fileadmin/design/images/icon_print.gif" width="14" height="14" alt="" /></a>
+ <a href="javascript:window.close()">Fenster schließen <img src="../../../portal/fileadmin/design/images/icon_close.gif" width="14" height="14" alt="" /></a>
+ </div>
+ <div id="header_redbottom"></div>
+ <div id="header_red"></div>
+ <div class="content">
+<?php
+ $layer_id = $_GET['id'];
+ $wms_getmap = urldecode($_GET['wms']);
+ $layer_name = urldecode($_GET['name']);
+ if ($layer_id) {
+ $sql = "SELECT ";
+ $sql .= "layer.layer_id, layer.layer_title, layer.layer_abstract, layer.layer_pos, layer.layer_parent, layer.layer_minscale, layer.layer_maxscale, ";
+ $sql .= "wms.wms_title, wms.wms_abstract, wms.wms_id, wms.fees, wms.accessconstraints, wms.contactperson, ";
+ $sql .= "wms.contactposition, wms.contactorganization, wms.address, wms.city, wms_timestamp, wms_owner, ";
+ $sql .= "wms.stateorprovince, wms.postcode, wms.contactvoicetelephone, wms.contactfacsimiletelephone, ";
+ $sql .= "wms.contactelectronicmailaddress, wms.country ";
+ $sql .= "FROM layer, wms WHERE layer.layer_id = $1 AND layer.fkey_wms_id = wms.wms_id LIMIT 1";
+ $t = array('i');
+ else if ($wms_getmap && $layer_name) {
+ $sql = "SELECT ";
+ $sql .= "FROM layer, wms WHERE layer.layer_pos <> 0 AND layer.layer_name = $1 AND layer.fkey_wms_id = wms.wms_id AND wms.wms_getmap LIKE $2 LIMIT 1";
+ $v = array($layer_name, $wms_getmap."%");
+ $t = array('s', 's');
+ else die();
+ $res = db_prep_query($sql,$v,$t);
+ echo db_error();
+ $layer = array();
+ $row = db_fetch_array($res);
+ $layer_id = $row['layer_id'];
+ $sql_p = "SELECT * FROM layer_preview WHERE fkey_layer_id = $1 LIMIT 1";
+ $v_p = array($layer_id);
+ $t_p = array('i');
+ $res_p = db_prep_query($sql_p, $v_p, $t_p);
+ $row_p = db_fetch_array($res_p);
+ if ($row_p['layer_map_preview'] != "") {
+ $layer['Voransicht'] = "<img src = 'mod_displayImage.php?id=".$layer_id."&col=layer_map_preview'>";
+ if ($row_p['layer_legend_preview'] != "") $layer['Voransicht'] .= "<img src = 'mod_displayImage.php?id=".$layer_id."&col=layer_legend_preview'>";
+ $sql_dep = "SELECT mb_user_department FROM mb_user WHERE mb_user_id = $1 LIMIT 1";
+ $v_dep = array($row['wms_owner']);
+ $t_dep = array('i');
+ $res_dep = db_prep_query($sql_dep, $v_dep, $t_dep);
+ $row_dep = db_fetch_array($res_dep);
+ //$layer['ID'] = $row['layer_id'];
+ $layer['Titel'] = $row['layer_title'];
+ $layer['Zusammenfassung'] = $row['layer_abstract'];
+ if ($row['layer_pos'] || $row['layer_parent']) {
+ $layer['Minscale'] = $row['layer_minscale'];
+ $layer['Maxscale'] = $row['layer_maxscale'];
+ $layer['Projektionssysteme'] = str_replace(" ", ", ", getEpsgByLayerId($row['layer_id']));
+ $layer['Capabilities-Dokument'] = "<a href = '../x_geoportal/getCapabilities_document.php?wms_request=".$row['wms_id']."&layer_request=".$row['layer_pos']."' target=_blank>Capabilities-Dokument</a>";
+ if ($row['wms_timestamp']) {
+ $layer['Datum der Registrierung'] = date("d.m.Y",$row['wms_timestamp']);
+ else {
+ $layer['Datum der Registrierung'] = "Keine Angabe";
+ $layer['Registrierende Stelle'] = $row_dep['mb_user_department'];
+ $layer['WMS Titel'] = $row['wms_title'];
+ $layer['WMS Zusammenfassung'] = $row['wms_abstract'];
+ $layer['Gebühren'] = $row['fees'];
+ $layer['Zugriffsbeschränkung'] = $row['accessconstraints'];
+ $layer['Ansprechpartner'] = $row['contactperson'];
+ $layer['Organisation'] = $row['contactorganization'];
+ $layer['Adresse'] = $row['address'];
+ $layer['Stadt'] = $row['city'];
+ $layer['Bundesland'] = $row['stateorprovince'];
+ $layer['PLZ'] = $row['postcode'];
+ $layer['Telefon'] = $row['contactvoicetelephone'];
+ $layer['Fax'] = $row['contactfacsimiletelephone'];
+ $layer['E-Mail'] = $row['contactelectronicmailaddress'];
+ $layer['Land'] = $row['country'];
+ $sql_p = "SELECT layer_extent_preview FROM layer_preview WHERE fkey_layer_id = $1 LIMIT 1";
+ if ($row_p['layer_extent_preview'] != "") $layer['Ausdehnung'] = "<img src = 'mod_displayImage.php?id=".$layer_id."&col=layer_extent_preview'>";
+ echo "<table class='contenttable-0-wide'>\n";
+ $t_a = "\t<tr>\n\t\t<th>\n\t\t\t";
+ $t_b = "\n\t\t</th>\n\t\t<td>\n\t\t\t";
+ $t_c = "\n\t\t</td>\n\t</tr>\n";
+ $keys = array_keys($layer);
+ for ($j=0; $j<count($layer); $j++) {
+ echo $t_a . utf8_encode($keys[$j]) . $t_b . display_text($layer[$keys[$j]]) . $t_c;
+ if (!$row['layer_pos'] && !$row['layer_parent']) {
+ $wms_id = $row['wms_id'];
+ $sql = "SELECT layer.layer_title, layer.layer_id FROM layer WHERE fkey_wms_id = $1 AND layer_pos <> 0";
+ $v = array($wms_id);
+ $t = array('i');
+ $i=0;
+ $layer = array();
+ while ($row = db_fetch_array($res)) {
+ $layer[$i] = array();
+ $layer[$i]['Titel'] = $row['layer_title'];
+ $layer[$i]['id'] = $row['layer_id'];
+ $i++;
+ echo "<tr><th>Ebenen</th><td>";
+ for ($i=0; $i<count($layer); $i++) {
+ if ($i >0) echo ", ";
+ echo "<a href='mod_layerMetadata.php?id=".$layer[$i]['id']."'>" . $layer[$i]['Titel'] . "</a>";
+ echo "</td></tr></table>\n";
+ </div>
+ <div id="footer_red"></div>
+ </body>
+</html>
More information about the Mapbender_commits
