svn commit: r808 - trunk/mapbender/http/php/mod_meetingPoint.php
astrid_emde at osgeo.org
Fri Oct 27 09:02:50 EDT 2006
Author: astrid_emde
Date: 2006-10-27 13:02:50+0000
New Revision: 808
when a meetingPoint is set, the clickpos and text are displayed in the style which is defined in the gui
Modified: trunk/mapbender/http/php/mod_meetingPoint.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_meetingPoint.php?view=diff&rev=808&p1=trunk/mapbender/http/php/mod_meetingPoint.php&p2=trunk/mapbender/http/php/mod_meetingPoint.php&r1=807&r2=808
--- trunk/mapbender/http/php/mod_meetingPoint.php (original)
+++ trunk/mapbender/http/php/mod_meetingPoint.php 2006-10-27 13:02:50+0000
@@ -93,6 +93,36 @@
meetingPoint_image = "../img/button_digitize/point_off.png";
+try{
+ if (meetingPoint_icon){}
+catch(e){
+ meetingPoint_icon = '../img/redball.gif';
+try{
+ if (meetingPoint_width){}
+catch(e){
+ meetingPoint_width = 20;
+try{
+ if (meetingPoint_height){}
+catch(e){
+ meetingPoint_height = 20;
+try{
+ if (meetingPoint_style){}
+catch(e){
+ meetingPoint_style = 'background-color:white;font-weight: bold;color:black;font-family:Arial;';
+parent.mb_registerSubFunctions("window.frames['meetingPoint'].mod_meetingPoint_draw()");
var ie = document.all?1:0;
var mod_meetingPoint_win = null;
var mod_meetingPoint_elName = "meetingPoint";
@@ -118,9 +148,7 @@
function mod_meetingPoint_run(){
parent.frames[mod_meetingPoint_target].document.onclick = mod_meetingPoint_click;
-function mod_meetingPoint_disable(){
- parent.frames[mod_meetingPoint_target].document.onclick = null;
function mod_meetingPoint_click(e){
if(ie){
clickX = parent.frames[mod_meetingPoint_target].event.clientX;
@@ -134,26 +162,35 @@
var pos = parent.makeClickPos2RealWorldPos(mod_meetingPoint_target, clickX, clickY);
mod_meetingPoint_write(pos[0],pos[1]);
- mod_meetingPoint_disable();
-function mod_meetingPoint_display(e){
- if(ie){
- clickX = parent.frames[mod_meetingPoint_target].event.clientX;
- clickY = parent.frames[mod_meetingPoint_target].event.clientY;
- else{
- clickX = e.pageX;
- clickY = e.pageY;
- var pos = makeClickPos2RealWorldPos(mod_meetingPoint_target, clickX, clickY);
+ mod_meetingPoint_draw();
function mod_meetingPoint_write(x,y){
document.forms[0].x.value =x;
document.forms[0].y.value =y;
+function mod_meetingPoint_hide(){
+ var ind = parent.getMapObjIndexByName(mod_meetingPoint_target);
+ parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.visibility = 'hidden';
+function mod_meetingPoint_draw(){
+ //alert(document.forms[0].x.value +" -- "+ document.forms[0].y.value + " - " + parent.mb_mapObj[ind].width +" iii: "+ ind);
+ parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.width = parent.mb_mapObj[ind].width;
+ parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.height = parent.mb_mapObj[ind].height;
+ parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.top = 0;
+ parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.left = 0;
+ parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.visibility = 'visible';
+ var tagSource = "";
+ var pos = parent.makeRealWorld2mapPos(mod_meetingPoint_target,document.forms[0].x.value, document.forms[0].y.value);
+ tagSource += "<div style='position:absolute;left:"+(pos[0]- meetingPoint_width)+"px;top:"+(pos[1]-meetingPoint_height)+"px'>";
+ tagSource += "<img src='"+meetingPoint_icon+"'>";
+ tagSource += "<span style='"+meetingPoint_style+"'>"+document.forms[0].mytext.value+"<span>";
+ tagSource += "</div>";
+ parent.writeTag(mod_meetingPoint_target, "permanent", tagSource);
</script>
@@ -216,6 +253,7 @@
document.forms[0].mytext.value ='';
document.forms[0].x.value ='';
document.forms[0].y.value = '';
+ mod_meetingPoint_hide();
function createEmail (url,subject) {
@@ -254,15 +292,15 @@
<input class='strinput' type="hidden" name='myuser' value='<?php echo $_SESSION["mb_user_name"]; ?>'>
<input class='strinput' type="hidden" name='mypw' value='<?php echo $_SESSION["mb_user_password"]; ?>'>
-Text :<br>
+<br>
<!--<input class='strinput' type="textarea" size=2 name='mytext' value='' "maxlength=70" title="max. 70 Zeichen">-->
-<textarea rows="3" name='mytext' value='huhu' title="max. 70 Zeichen"></textarea>
+<textarea rows="3" name='mytext' title="max. 70 Zeichen"></textarea>
<br>
<input class="okbutton" name="Send" type="button" value="ok" onclick="validate();">
<input class="ibutton" type="button" value="cancel" onClick="emptyfields();">
<br>
-<input class="coord" type="hidden" name='x' value='' readonly>
-<input class="coord" type="hidden" name='y' value='' readonly>
+<input class="coord" type="text" name='x' value='' readonly>
+<input class="coord" type="text" name='y' value='' readonly>
<br>
</form>
</body>
More information about the Mapbender_commits
