svn commit: r763 - trunk/mapbender/http/php/mod_editSelf.php
uli at osgeo.org
uli at osgeo.org
Fri Sep 1 06:08:01 EDT 2006
Author: uli
Date: 2006-09-01 10:08:01+0000
New Revision: 763
some bugs:
- use passwd instead of password
- owner_name is not required
- owner_id is user_id to edit this data
Modified: trunk/mapbender/http/php/mod_editSelf.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_editSelf.php?view=diff&rev=763&p1=trunk/mapbender/http/php/mod_editSelf.php&p2=trunk/mapbender/http/php/mod_editSelf.php&r1=762&r2=763
--- trunk/mapbender/http/php/mod_editSelf.php (original)
+++ trunk/mapbender/http/php/mod_editSelf.php 2006-09-01 10:08:01+0000
@@ -16,6 +16,7 @@
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
require_once("../../conf/mapbender.conf");
require_once("../php/mb_validateSession.php");
import_request_variables("PG");
@@ -121,7 +122,7 @@
</head>
<body>
<?php
-$con = db_connect($DBSERVER,$OWNER,$PW);
+$con = db_connect(DBSERVER,OWNER,PW);
db_select_db(DB,$con);
#delete
@@ -149,7 +150,7 @@
$sql = "Insert INTO mb_user (mb_user_name, mb_user_password,mb_user_owner, mb_user_description,";
$sql .= " mb_user_email, mb_user_phone, mb_user_department, mb_user_resolution) VALUES ";
$sql.= "($1, $2, $3, $4, $5, $6, $7, $8)";
- $v = array($name,md5($password),$owner_id,$description,$email,$phone,$department,$resolution);
+ $v = array($name,md5($passw),$owner_id,$description,$email,$phone,$department,$resolution);
$t = array('s','s','i','s','s','s','s','i');
$res = db_prep_query($sql,$t,$v);
$selected_user = db_insert_id();
@@ -166,6 +167,19 @@
echo "<script language='JavaScript'>alert('Username must be unique!');</script>";
else{
+ if($passw == ""){
+ $sql = "SELECT mb_user_password FROM mb_user WHERE mb_user_name = $1 AND mb_user_id = $2";
+ $v = array($name,$selected_user);
+ $t = array('s','i');
+ $res = db_prep_query($sql,$v,$t);
+ if($row = db_fetch_row($res)){
+ $p = $row["mb_user_password"];
+ else{
+ $p = md5($passw);
+ $password = true;
$sql = "UPDATE mb_user SET mb_user_name = $1";
$sql .= ", mb_user_password = $2";
$sql .=", mb_user_description = $3";
@@ -175,7 +189,7 @@
$sql .=", mb_user_department = $7";
$sql .=", mb_user_resolution = $8";
$sql .=" where mb_user_id = $9";
- $v = array($name,md5($password),$description,$login_count,$email,$phone,$department,$resolution,$selected_user);
+ $v = array($name,$p,$description,$login_count,$email,$phone,$department,$resolution,$selected_user);
$t = array('s','s','s','i','s','s','s','i','i');
if($password && $res){
@@ -209,17 +223,17 @@
$v = array($_SESSION["mb_user_id"]);
$t = array('i');
- if(db_fetch_row($res)){
- $name = db_result($res,0,"mb_user_name");
- $password = db_result($res,0,"mb_user_password");
- $owner_id = db_result($res,0,"mb_user_owner");
- $description = db_result($res,0,"mb_user_description");
- $login_count = db_result($res,0,"mb_user_login_count");
- $email = db_result($res,0,"mb_user_email");
- $phone = db_result($res,0,"mb_user_phone");
- $department = db_result($res,0,"mb_user_department");
- $resolution = db_result($res,0,"mb_user_resolution");
- $owner_name = $_SESSION["mb_user_id"];
+ if($row = db_fetch_array($res)){
+ $name = $row["mb_user_name"];
+ $password = $row["mb_user_password"];
+ $owner_id = $row["mb_user_owner"];
+ $description = $row["mb_user_description"];
+ $login_count = $row["mb_user_login_count"];
+ $email = $row["mb_user_email"];
+ $phone = $row["mb_user_phone"];
+ $department = $row["mb_user_department"];
+ $resolution = $row["mb_user_resolution"];
+ $owner_id = $_SESSION["mb_user_id"];
$edit = true;
else {
@@ -231,8 +245,8 @@
if ($edit) {
#name
echo "<tr>";
- echo "<td>Name:</td>";
- echo "<td>";
+ echo "<td>Name:</td>";
+ echo "<td>";
echo "<input type='text' size='30' name='name' value='".$name."'>";
echo "</td>";
echo "</tr>";
More information about the Mapbender_commits
