svn commit: r767 - trunk/mapbender/http/print
astrid_emde at osgeo.org
Thu Sep 7 06:17:44 EDT 2006
Author: astrid_emde
Date: 2006-09-07 10:17:44+0000
New Revision: 767
trunk/mapbender/http/print/mod_printPDF.php
trunk/mapbender/http/print/mod_printPDF_pdf.php
trunk/mapbender/http/print/printPDF.conf
trunk/mapbender/http/print/printPDF_b.conf
pdf-print is extended to format A2 (thanks to Frank Haertel and Horst Becker)
Modified: trunk/mapbender/http/print/mod_printPDF.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/print/mod_printPDF.php?view=diff&rev=767&p1=trunk/mapbender/http/print/mod_printPDF.php&p2=trunk/mapbender/http/print/mod_printPDF.php&r1=766&r2=767
--- trunk/mapbender/http/print/mod_printPDF.php (original)
+++ trunk/mapbender/http/print/mod_printPDF.php 2006-09-07 10:17:44+0000
@@ -206,6 +206,14 @@
if(size == "A3" && format == "landscape"){
map_width = <?php echo $a3l_map_width; ?>;
map_height = <?php echo $a3l_map_height; ?>;
+ if(size == "A2" && format == "portrait"){
+ map_width = <?php echo $a2p_map_width; ?>;
+ map_height = <?php echo $a2p_map_height; ?>;
+ if(size == "A2" && format == "landscape"){
+ map_width = <?php echo $a2l_map_width; ?>;
+ map_height = <?php echo $a2l_map_height; ?>;
var pos = pt.makeClickPos2RealWorldPos(target, map_width , map_height);
pt.mb_mapObj[ind].extent = coord[0] + "," + pos[1] + "," + pos[0] + "," + coord[3];
@@ -301,6 +309,9 @@
if($a3 == true){
echo "<option value='A3'>".$label_format_a3."</option>";
+ if($a2 == true){
+ echo "<option value='A2'>".$label_format_a2."</option>";
</select>
</td>
Modified: trunk/mapbender/http/print/mod_printPDF_pdf.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/print/mod_printPDF_pdf.php?view=diff&rev=767&p1=trunk/mapbender/http/print/mod_printPDF_pdf.php&p2=trunk/mapbender/http/print/mod_printPDF_pdf.php&r1=766&r2=767
--- trunk/mapbender/http/print/mod_printPDF_pdf.php (original)
+++ trunk/mapbender/http/print/mod_printPDF_pdf.php 2006-09-07 10:17:44+0000
@@ -182,6 +182,12 @@
}elseif ($size == "A3" && $format == "landscape"){
$overview_left = $a3l_overviewOffset_left;
$overview_bottom = $a3l_overviewOffset_bottom;
+}elseif ($size == "A2" && $format == "portrait"){
+ $overview_left = $a2p_overviewOffset_left;
+ $overview_bottom =$a2p_overviewOffset_bottom;
+}elseif ($size == "A2" && $format == "landscape"){
+ $overview_left = $a2l_overviewOffset_left;
+ $overview_bottom = $a2l_overviewOffset_bottom;
$o_extent = $o_url->get("BBOX");
@@ -216,6 +222,12 @@
$northarrow_left = $a3l_northarrow_left;
$northarrow_bottom = $a3l_northarrow_bottom;
+ $northarrow_left = $a2p_northarrow_left;
+ $northarrow_bottom = $a2p_northarrow_bottom;
+ $northarrow_left = $a2l_northarrow_left;
+ $northarrow_bottom = $a2l_northarrow_bottom;
@@ -233,6 +245,12 @@
$specialImage_left = $a3l_special_left;
$specialImage_bottom = $a3l_special_bottom;
+ $specialImage_left = $a2p_special_left;
+ $specialImage_bottom = $a2p_special_bottom;
+ $specialImage_left = $a2l_special_left;
+ $specialImage_bottom = $a2l_special_bottom;
if($log == true){
@@ -454,6 +472,12 @@
$scalebar_left = $a3l_scalebar_left;
$scalebar_bottom = $a3l_scalebar_bottom;
+ }elseif ($size == "A2" && $format == "portrait"){
+ $scalebar_left = $a2p_scalebar_left;
+ $scalebar_bottom = $a2p_scalebar_bottom;
+ }elseif ($size == "A2" && $format == "landscape"){
+ $scalebar_left = $a2l_scalebar_left;
+ $scalebar_bottom = $a2l_scalebar_bottom;
$array_scalebar = setscalebar($map_scale);
Modified: trunk/mapbender/http/print/printPDF.conf
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/print/printPDF.conf?view=diff&rev=767&p1=trunk/mapbender/http/print/printPDF.conf&p2=trunk/mapbender/http/print/printPDF.conf&r1=766&r2=767
--- trunk/mapbender/http/print/printPDF.conf (original)
+++ trunk/mapbender/http/print/printPDF.conf 2006-09-07 10:17:44+0000
@@ -1,233 +1,286 @@
-<?php
-include_once("../../conf/mapbender.conf");
-# filename for temporary imagefiles
-$filename = TMPDIR."/map_".substr(md5(uniqid(rand())),0,7).".png";
-* DOWNLOAD
-$download = false;
-$downloadFile = TMPDIR."/map_".substr(md5(uniqid(rand())),0,7).".pdf";
-$downloadText = "Download: Karte als PDF...";
-*run print as iframe or window
-$type = 'iframe';
-* Legend
-$legend=true;
-$label_legend = 'print legend';
-$legendFilename = TMPDIR."/legend_".substr(md5(uniqid(rand())),0,7).".png";
-$legendText = "Legende";
-$legendFooter = "powered by Mapbender";
-$legendImage = "./img/mapbender_logo.png";
-$legendImage_width = 90;
-$legendImage_height = 13;
-# log requests, class 'class_log.php' required
-$log = false;
-# delete images:
-$unlink = true;
-# labeling
-$text1 = "Druckansicht";
-$text2 = "- Mapbender2 -";
-$text3 = "";
-$text4 = "Maßstab 1 : " . $_REQUEST["map_scale"];
-$text5 = "Datum: " . date("d.m.Y",strtotime("now"));;
-$text6 = "Notizen:";
-$text7 = "";
-$text8 = $_REQUEST["comment1"];
-$text9 = $_REQUEST["comment2"];
-$text10 = "";
-$text11 = "Der Auszug ist maschinell erzeugt, er ist ohne Unterschrift gültig.";
-$text12 = "Dieser Auszug ist gesetzlich geschützt (§ 3 Abs. 1 VermKatG NW). Vervielfältigungen, Umarbeitungen, Veröffentlichungen oder die Weitergabe an Dritte nur mit Zustimmung des";
-$text13 = "Herausgebers, ausgenommen Vervielfältigungen und Umarbeitungen zur innerdienstlichen Verwendung bei Behörden oder zum eigenen Gebrauch.";
-$text14 = "Dieser Auszug ist gesetzlich geschützt (§ 3 Abs. 1 VermKatG NW). Vervielfältigungen,";
-$text15 = "Umarbeitungen, Veröffentlichungen oder die Weitergabe an Dritte nur mit Zustimmung";
-$text16 = "des Herausgebers, ausgenommen Vervielfältigungen und Umarbeitungen zur inner-";
-$text17 = "dienstlichen Verwendung bei Behörden oder zum eigenen Gebrauch.";
-* Labeling for buttons, textfields ...
-$label_format = "Format:";
-$label_format_a4 = "A4";
-$label_format_a3 = "A3";
-$label_orientation = "Orientation: ";
-$label_portrait = "portrait";
-$label_landscape = "landscape";
-$label_72dpi = "Quality: 72 dpi";
-$label_288dpi = "Quality: 288 dpi";
-$label_comment = "Comment (max. 30)";
-$comment_length = 30;
-$label_button = 'print';
-* default
-* url string matching and replacement
-$matching = false;
-$pattern = "192.168.2.113";
-$replacement = "192.168.2.5";
-* high quality printing 288dpi
-* highquality mapfiles will be supplemented with "_4"
-* example: germany.map -> germany_4.map
-$highquality = false;
-$highqualitymapfiles = array(
- "/data/umn/germany/germany.map",
- "/data/umn/germany/germany_demo.map"
-# Dots per cm (72 dpi):
-# 28.346456692913385826771653543307
-$DPC = 28.35;
-# available formats:
-$a4 = true;
-$a3 = true;
-# dimensions of the map:
-# A4 portrait
-$a4p_mapOffset_left = 3.3 * $DPC;
-$a4p_mapOffset_bottom = 3 * $DPC;
-$a4p_map_width = 15.7 * $DPC;
-$a4p_map_height = 22 * $DPC;
-$a4p_page_width = 21 * $DPC;
-$a4p_page_height = 29.7 * $DPC;
-$a4p_header_height = 2.6 * $DPC;
-$a4p_footer_height = 1.12 * $DPC;
-# A4 landscape
-$a4l_mapOffset_left = 2.3 * $DPC;
-$a4l_mapOffset_bottom = 1.8 * $DPC;
-$a4l_map_width = 25.2 * $DPC;
-$a4l_map_height = 16.4 * $DPC;
-$a4l_page_width = 29.7 * $DPC;
-$a4l_page_height = 21 * $DPC;
-$a4l_header_width = 8.5 * $DPC;
-$a4l_header_height = 6 * $DPC;
-# A3 protrait
-$a3p_mapOffset_left = 3.3 * $DPC;
-$a3p_mapOffset_bottom = 3 * $DPC;
-$a3p_map_width = 24.1 * $DPC;
-$a3p_map_height = 36.7 * $DPC;
-$a3p_page_width = 29.7 * $DPC;
-$a3p_page_height = 42 * $DPC;
-$a3p_header_width = 8.5 * $DPC;
-$a3p_header_height = 6 * $DPC;
-# A3 landscape
-$a3l_mapOffset_left = 2.3 * $DPC;
-$a3l_mapOffset_bottom = 1.8 * $DPC;
-$a3l_map_width = 37.4 * $DPC;
-$a3l_map_height = 25.4 * $DPC;
-$a3l_page_width = 42 * $DPC;
-$a3l_page_height = 29.7 * $DPC;
-$a3l_header_width = 8.5 * $DPC;
-$a3l_header_height = 6 * $DPC;
-* Overview
-$overview = true;
-$a4p_overviewOffset_left = $a4p_mapOffset_left;
-$a4p_overviewOffset_bottom = $a4p_mapOffset_bottom;
-$a4l_overviewOffset_left = $a4l_mapOffset_left;
-$a4l_overviewOffset_bottom = $a4l_mapOffset_bottom;
-$a3p_overviewOffset_left = $a3p_mapOffset_left;
-$a3p_overviewOffset_bottom = $a3p_mapOffset_bottom;
-$a3l_overviewOffset_left = $a3l_mapOffset_left;
-$a3l_overviewOffset_bottom = $a3l_mapOffset_bottom;
-* Northarrow
-$northarrow = true;
-$northarrowImage = "./img/northarrow.png";
-$a4p_northarrow_left = $a4p_mapOffset_left + 160;
-$a4p_northarrow_bottom = $a4p_mapOffset_bottom +2 ;
-$a4l_northarrow_left = $a4l_mapOffset_left + 5;
-$a4l_northarrow_bottom = $a4l_mapOffset_bottom + $a4l_map_height - 40;
-$a3p_northarrow_left = $a3p_mapOffset_left +5;
-$a3p_northarrow_bottom = $a3p_mapOffset_bottom + $a3p_map_height - 80;
-$a3l_northarrow_left = $a3l_mapOffset_left + 5;
-$a3l_northarrow_bottom = $a3l_mapOffset_bottom + $a3l_map_height - 40;
-$northarrowImage_width = 15;
-$northarrowImage_height = 35;
-* special image for the map-page
-$special = true;
-$specialImage = "./img/mapbender_logo.png";
-$a4p_special_left = $a4p_mapOffset_left + $a4p_map_width/2 + 100;
-$a4p_special_bottom = $a4p_mapOffset_bottom + $a4p_map_height + 65;
-$a4l_special_left = $a4l_mapOffset_left + $a4l_map_width - $a4l_header_width + 0.8 * $DPC + 10 ;
-$a4l_special_bottom = $a4l_mapOffset_bottom + 54;
-$a3p_special_left = $a3p_mapOffset_left + $a3p_map_width - $a3p_header_width ;
-$a3p_special_bottom = $a3p_mapOffset_bottom + 30;
-$a3l_special_left = $a3l_mapOffset_left + $a3l_map_width - $a3l_header_width + 0.8 * $DPC + 10;
-$a3l_special_bottom = $a3l_mapOffset_bottom + 60;
-$specialImage_width = 90;
-$specialImage_height = 13;
-* dynamic scalebar
-$scalebar = true;
-$units = "Meter";
-$a4p_scalebar_left = $a4p_mapOffset_left + 2 * $a4p_map_width/3;
-$a4p_scalebar_bottom = $a4p_mapOffset_bottom + 0.5 * $DPC;
-$a4l_scalebar_left = $a4l_mapOffset_left + $a4l_map_width/4 ;
-$a4l_scalebar_bottom = $a4l_mapOffset_bottom + + 0.5 * $DPC;
-$a3p_scalebar_left = $a3p_mapOffset_left + $a3p_map_width/4 ;
-$a3p_scalebar_bottom = $a3p_mapOffset_bottom + 0.5 * $DPC;
-$a3l_scalebar_left = $a3l_mapOffset_left + $a3l_map_width/4 ;
-$a3l_scalebar_bottom = $a3l_mapOffset_bottom + + 0.5 * $DPC;
-$scalebar_width = 3 * $DPC;
-$scalebar_height = 0.18 * $DPC;
\ No newline at end of file
+<?php
+include_once("../../conf/mapbender.conf");
+# filename for temporary imagefiles
+$filename = TMPDIR."/map_".substr(md5(uniqid(rand())),0,7).".png";
+* DOWNLOAD
+$download = false;
+$downloadFile = TMPDIR."/map_".substr(md5(uniqid(rand())),0,7).".pdf";
+$downloadText = "Download: Karte als PDF...";
+*run print as iframe or window
+$type = 'iframe';
+* Legend
+$legend=true;
+$label_legend = 'print legend';
+$legendFilename = TMPDIR."/legend_".substr(md5(uniqid(rand())),0,7).".png";
+$legendText = "Legende";
+$legendFooter = "powered by Mapbender";
+$legendImage = "./img/mapbender_logo.png";
+$legendImage_width = 90;
+$legendImage_height = 13;
+# log requests, class 'class_log.php' required
+$log = false;
+# delete images:
+$unlink = true;
+# labeling
+$text1 = "Druckansicht";
+$text2 = "- Mapbender -";
+$text3 = "";
+$text4 = "Maßstab 1 : " . $_REQUEST["map_scale"];
+$text5 = "Datum: " . date("d.m.Y",strtotime("now"));;
+$text6 = "Notizen:";
+$text7 = "";
+$text8 = $_REQUEST["comment1"];
+$text9 = $_REQUEST["comment2"];
+$text10 = "";
+$text11 = "Der Auszug ist maschinell erzeugt, er ist ohne Unterschrift gültig.";
+$text12 = "Dieser Auszug ist gesetzlich geschützt (§ 3 Abs. 1 VermKatG NW). Vervielfältigungen, Umarbeitungen, Veröffentlichungen oder die Weitergabe an Dritte nur mit Zustimmung des";
+$text13 = "Herausgebers, ausgenommen Vervielfältigungen und Umarbeitungen zur innerdienstlichen Verwendung bei Behörden oder zum eigenen Gebrauch.";
+$text14 = "Dieser Auszug ist gesetzlich geschützt (§ 3 Abs. 1 VermKatG NW). Vervielfältigungen,";
+$text15 = "Umarbeitungen, Veröffentlichungen oder die Weitergabe an Dritte nur mit Zustimmung";
+$text16 = "des Herausgebers, ausgenommen Vervielfältigungen und Umarbeitungen zur inner-";
+$text17 = "dienstlichen Verwendung bei Behörden oder zum eigenen Gebrauch.";
+* Labeling for buttons, textfields ...
+$label_format = "Format:";
+$label_format_a4 = "A4";
+$label_format_a3 = "A3";
+$label_format_a2 = "A2";
+$label_orientation = "Orientation: ";
+$label_portrait = "portrait";
+$label_landscape = "landscape";
+$label_72dpi = "Quality: 72 dpi";
+$label_288dpi = "Quality: 288 dpi";
+$label_comment = "Comment (max. 30)";
+$comment_length = 30;
+$label_button = 'print';
+* default
+* url string matching and replacement
+$matching = false;
+$pattern = "192.168.2.113";
+$replacement = "192.168.2.5";
+* high quality printing 288dpi
+* highquality mapfiles will be supplemented with "_4"
+* example: germany.map -> germany_4.map
+$highquality = true;
+$highqualitymapfiles = array(
+ "/opt/umn/remscheid/liegenschaftskarte/liegenschaftskarte.map",
+ "/data/umn/germany/germany_demo.map"
+# Dots per cm (72 dpi):
+# 28.346456692913385826771653543307
+$DPC = 28.35;
+# available formats:
+$a4 = true;
+$a3 = true;
+$a2 = true;
+# dimensions of the map:
+# A4 portrait
+$a4p_mapOffset_left = 3.3 * $DPC;
+$a4p_mapOffset_bottom = 3 * $DPC;
+$a4p_map_width = 15.7 * $DPC;
+$a4p_map_height = 22 * $DPC;
+$a4p_page_width = 21 * $DPC;
+$a4p_page_height = 29.7 * $DPC;
+$a4p_header_height = 2.6 * $DPC;
+$a4p_footer_height = 1.12 * $DPC;
+# A4 landscape
+$a4l_mapOffset_left = 2.3 * $DPC;
+$a4l_mapOffset_bottom = 1.8 * $DPC;
+$a4l_map_width = 25.2 * $DPC;
+$a4l_map_height = 16.4 * $DPC;
+$a4l_page_width = 29.7 * $DPC;
+$a4l_page_height = 21 * $DPC;
+$a4l_header_width = 8.5 * $DPC;
+$a4l_header_height = 6 * $DPC;
+# A3 protrait
+$a3p_mapOffset_left = 3.3 * $DPC;
+$a3p_mapOffset_bottom = 3 * $DPC;
+$a3p_map_width = 24.1 * $DPC;
+$a3p_map_height = 36.7 * $DPC;
+$a3p_page_width = 29.7 * $DPC;
+$a3p_page_height = 42 * $DPC;
+$a3p_header_width = 8.5 * $DPC;
+$a3p_header_height = 6 * $DPC;
+# A3 landscape
+$a3l_mapOffset_left = 2.3 * $DPC;
+$a3l_mapOffset_bottom = 1.8 * $DPC;
+$a3l_map_width = 37.4 * $DPC;
+$a3l_map_height = 25.4 * $DPC;
+$a3l_page_width = 42 * $DPC;
+$a3l_page_height = 29.7 * $DPC;
+$a3l_header_width = 8.5 * $DPC;
+$a3l_header_height = 6 * $DPC;
+# a2 protrait
+$a2p_mapOffset_left = 3.2 * $DPC;
+$a2p_mapOffset_bottom = 2.3 * $DPC;
+$a2p_map_width = 37.3 * $DPC;
+$a2p_map_height = 54.8 * $DPC;
+$a2p_page_width = 42 * $DPC;
+$a2p_page_height = 59.4 * $DPC;
+$a2p_header_width = 8.5 * $DPC;
+$a2p_header_height = 6 * $DPC;
+# a2 landscape
+$a2l_mapOffset_left = 3.2 * $DPC;
+$a2l_mapOffset_bottom = 2.3 * $DPC;
+$a2l_map_width = 54.1 * $DPC;
+$a2l_map_height = 37.3 * $DPC;
+$a2l_page_width = 59.4 * $DPC;
+$a2l_page_height = 42 * $DPC;
+$a2l_header_width = 8.5 * $DPC;
+$a2l_header_height = 6 * $DPC;
+* Overview
+$overview = true;
+$a4p_overviewOffset_left = $a4p_mapOffset_left;
+$a4p_overviewOffset_bottom = $a4p_mapOffset_bottom;
+$a4l_overviewOffset_left = $a4l_mapOffset_left;
+$a4l_overviewOffset_bottom = $a4l_mapOffset_bottom;
+$a3p_overviewOffset_left = $a3p_mapOffset_left;
+$a3p_overviewOffset_bottom = $a3p_mapOffset_bottom;
+$a3l_overviewOffset_left = $a3l_mapOffset_left;
+$a3l_overviewOffset_bottom = $a3l_mapOffset_bottom;
+$a2p_overviewOffset_left = $a2p_mapOffset_left;
+$a2p_overviewOffset_bottom = $a2p_mapOffset_bottom;
+$a2l_overviewOffset_left = $a2l_mapOffset_left;
+$a2l_overviewOffset_bottom = $a2l_mapOffset_bottom;
+* Northarrow
+$northarrow = true;
+$northarrowImage = "./img/northarrow.png";
+$a4p_northarrow_left = $a4p_mapOffset_left + 160;
+$a4p_northarrow_bottom = $a4p_mapOffset_bottom +2 ;
+$a4l_northarrow_left = $a4l_mapOffset_left + 5;
+$a4l_northarrow_bottom = $a4l_mapOffset_bottom + $a4l_map_height - 40;
+$a3p_northarrow_left = $a3p_mapOffset_left +5;
+$a3p_northarrow_bottom = $a3p_mapOffset_bottom + $a3p_map_height - 80;
+$a3l_northarrow_left = $a3l_mapOffset_left + 5;
+$a3l_northarrow_bottom = $a3l_mapOffset_bottom + $a3l_map_height - 40;
+$a2p_northarrow_left = $a2p_mapOffset_left +5;
+$a2p_northarrow_bottom = $a2p_mapOffset_bottom + $a2p_map_height - 80;
+$a2l_northarrow_left = $a2l_mapOffset_left + 5;
+$a2l_northarrow_bottom = $a2l_mapOffset_bottom + $a2l_map_height - 80;
+$northarrowImage_width = 15;
+$northarrowImage_height = 35;
+* special image for the map-page
+$special = true;
+$specialImage = "./img/mapbender_logo.png";
+$a4p_special_left = $a4p_mapOffset_left + $a4p_map_width/2 + 100;
+$a4p_special_bottom = $a4p_mapOffset_bottom + $a4p_map_height + 65;
+$a4l_special_left = $a4l_mapOffset_left + $a4l_map_width - $a4l_header_width + 0.8 * $DPC + 10 ;
+$a4l_special_bottom = $a4l_mapOffset_bottom + 54;
+$a3p_special_left = $a3p_mapOffset_left + $a3p_map_width - $a3p_header_width ;
+$a3p_special_bottom = $a3p_mapOffset_bottom + 30;
+$a3l_special_left = $a3l_mapOffset_left + $a3l_map_width - $a3l_header_width + 0.8 * $DPC + 10;
+$a3l_special_bottom = $a3l_mapOffset_bottom + 60;
+$a2p_special_left = $a2p_mapOffset_left + $a2p_map_width - $a2p_header_width + 0.1 *$DPC ;
+$a2p_special_bottom = $a2p_mapOffset_bottom + 110;
+$a2l_special_left = $a2l_mapOffset_left + $a2l_map_width - $a2l_header_width + 0.2 * $DPC ;
+$a2l_special_bottom = $a2l_mapOffset_bottom + 110;
+$specialImage_width = 90;
+$specialImage_height = 13;
+* dynamic scalebar
+$scalebar = true;
+$units = "Meter";
+$a4p_scalebar_left = $a4p_mapOffset_left + 2 * $a4p_map_width/3;
+$a4p_scalebar_bottom = $a4p_mapOffset_bottom + 0.5 * $DPC;
+$a4l_scalebar_left = $a4l_mapOffset_left + $a4l_map_width/4 ;
+$a4l_scalebar_bottom = $a4l_mapOffset_bottom + + 0.5 * $DPC;
+$a3p_scalebar_left = $a3p_mapOffset_left + $a3p_map_width/4 ;
+$a3p_scalebar_bottom = $a3p_mapOffset_bottom + 0.5 * $DPC;
+$a3l_scalebar_left = $a3l_mapOffset_left + $a3l_map_width/4 ;
+$a3l_scalebar_bottom = $a3l_mapOffset_bottom + + 0.5 * $DPC;
+$a2p_scalebar_left = $a2p_mapOffset_left + $a2p_map_width/4 ;
+$a2p_scalebar_bottom = $a2p_mapOffset_bottom + 0.5 * $DPC;
+$a2l_scalebar_left = $a2l_mapOffset_left + $a2l_map_width/4 ;
+$a2l_scalebar_bottom = $a2l_mapOffset_bottom + + 0.5 * $DPC;
+$scalebar_width = 3 * $DPC;
+$scalebar_height = 0.18 * $DPC;
Modified: trunk/mapbender/http/print/printPDF_b.conf
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/print/printPDF_b.conf?view=diff&rev=767&p1=trunk/mapbender/http/print/printPDF_b.conf&p2=trunk/mapbender/http/print/printPDF_b.conf&r1=766&r2=767
--- trunk/mapbender/http/print/printPDF_b.conf (original)
+++ trunk/mapbender/http/print/printPDF_b.conf 2006-09-07 10:17:44+0000
@@ -4,16 +4,15 @@
* DOWNLOAD
-$download = true;
+$download = false;
-* run print as iframe or window
$type = 'window';
@@ -32,7 +31,6 @@
$log = false;
@@ -41,7 +39,7 @@
# labeling
$text3 = "";
@@ -52,6 +50,7 @@
$text10 = "";
@@ -68,6 +67,7 @@
@@ -81,8 +81,6 @@
* default
@@ -97,9 +95,10 @@
@@ -110,6 +109,7 @@
$a4 = true;
$a3 = true;
+$a2 = true;
@@ -134,7 +134,7 @@
-# A3 portrait
+# A3 protrait
@@ -154,6 +154,27 @@
+# a2 protrait
+# a2 landscape
* Overview
@@ -170,6 +191,14 @@
* Northarrow
@@ -188,6 +217,12 @@
@@ -196,6 +231,7 @@
$special = true;
@@ -208,8 +244,15 @@
@@ -230,7 +273,14 @@
More information about the Mapbender_commits
