svn commit: r771 - trunk/mapbender/http/php/mod_loadCapabilitiesList.php
    uli at osgeo.org
    uli at osgeo.org
    Tue Sep 26 10:26:15 EDT 2006
Author: uli
Date: 2006-09-26 14:26:14+0000
New Revision: 771
highlight own and external services
Modified: trunk/mapbender/http/php/mod_loadCapabilitiesList.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_loadCapabilitiesList.php?view=diff&rev=771&p1=trunk/mapbender/http/php/mod_loadCapabilitiesList.php&p2=trunk/mapbender/http/php/mod_loadCapabilitiesList.php&r1=770&r2=771
--- trunk/mapbender/http/php/mod_loadCapabilitiesList.php	(original)
+++ trunk/mapbender/http/php/mod_loadCapabilitiesList.php	2006-09-26 14:26:14+0000
@@ -18,11 +18,11 @@
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 session_start();
-include("../../conf/mapbender.conf");
+include(dirname(__FILE__)."/../../conf/mapbender.conf");
 $con = db_connect(DBSERVER,OWNER,PW);
 db_select_db(DB,$con);
-include("../php/mb_validateSession.php");
+include(dirname(__FILE__)."/../php/mb_validateSession.php");
 import_request_variables("PG");
@@ -119,7 +119,7 @@
 <?php
-require_once("../classes/class_administration.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
 $admin = new administration();
 $ownguis = $admin->getGuisByOwner($_SESSION["mb_user_id"]);
@@ -127,42 +127,47 @@
 ###INSERT
 if(isset($wmsID) && isset($guiID)){
+	$sql_pos = "SELECT MAX(gui_wms_position) AS my_gui_wms_position FROM gui_wms WHERE fkey_gui_id = $1";
+	$v = array($guiList);
+	$t = array('s');
+	$res_pos = db_prep_query($sql_pos,$v,$t);
+	if(db_result($res_pos,0,"my_gui_wms_position") > -1){
+		$gui_wms_position = db_result($res_pos,0,"my_gui_wms_position") + 1;
+	else{
+		$gui_wms_position = 0;
-   $sql_pos = "SELECT MAX(gui_wms_position) AS my_gui_wms_position FROM gui_wms WHERE fkey_gui_id = '".$guiList."'";
-   $res_pos = db_query($sql_pos);
-   if(db_result($res_pos,0,"my_gui_wms_position") > -1){
-      $gui_wms_position = db_result($res_pos,0,"my_gui_wms_position") + 1;
-   else{
-      $gui_wms_position = 0;
-#echo $gui_wms_position."<br>";
-   $sql = "SELECT * FROM gui_wms WHERE fkey_gui_id = '".$guiID."' AND fkey_wms_id = ".$wmsID;
-   $res = db_query($sql);
-   $cnt = 0;
-   while($row = db_fetch_array($res)){
-      $sql_ins = "INSERT INTO gui_wms (fkey_gui_id,fkey_wms_id,gui_wms_position,gui_wms_mapformat,gui_wms_featureinfoformat,gui_wms_exceptionformat,gui_wms_epsg,gui_wms_visible) ";
-      $sql_ins .= "VALUES ('".$guiList."',".$wmsID.",".$gui_wms_position.",'".$row["gui_wms_mapformat"]."','".$row["gui_wms_featureinfoformat"]."','".$row["gui_wms_exceptionformat"]."','".$row["gui_wms_epsg"]."',".$row["gui_wms_visible"].")";
-      #echo $sql_ins."<br>";
-      db_query($sql_ins);
-      $cnt++;
+	$sql = "SELECT * FROM gui_wms WHERE fkey_gui_id = $1 AND fkey_wms_id = $2";
+	$v = array($guiID,$wmsID);
+	$t = array('s','i');
+	$res = db_query($sql,$v,$t);
+	$cnt = 0;
+	while($row = db_fetch_array($res)){
+		$sql_ins = "INSERT INTO gui_wms (fkey_gui_id,fkey_wms_id,gui_wms_position,gui_wms_mapformat,";
+		$sql_ins .= "gui_wms_featureinfoformat,gui_wms_exceptionformat,gui_wms_epsg,gui_wms_visible) ";
+		$sql_ins .= "VALUES ($1,$2,$3,$4,$5,$6,$7,$8)";
+		$v = array($guiList,$wmsID,$gui_wms_position,$row["gui_wms_mapformat"],$row["gui_wms_featureinfoformat"],
+		$row["gui_wms_exceptionformat"],$row["gui_wms_epsg"],$row["gui_wms_visible"]);
+		$t = array('s','i','i','s','s','s','s','i');
+		db_prep_query($sql_ins,$v,$t);
+		$cnt++;
-   $sql = "SELECT * FROM gui_layer WHERE fkey_gui_id = '".$guiID."' AND gui_layer_wms_id = ".$wmsID;
-   $cnt = 0;
-      $sql_ins = "INSERT INTO gui_layer (fkey_gui_id,fkey_layer_id,gui_layer_wms_id,gui_layer_status,gui_layer_selectable,";
-      $sql_ins .= "gui_layer_visible,gui_layer_queryable,gui_layer_querylayer,gui_layer_minscale,gui_layer_maxscale,gui_layer_priority) ";
-      $sql_ins .= "VALUES ('".$guiList."',".$row["fkey_layer_id"].",".$wmsID.",".$row["gui_layer_status"];
-      $sql_ins .= ",".$row["gui_layer_selectable"].",".$row["gui_layer_visible"];
-      $sql_ins .= ",".$row["gui_layer_queryable"].",".$row["gui_layer_querylayer"];
-      $sql_ins .= ",".$row["gui_layer_minscale"].",".$row["gui_layer_maxscale"].",".$row["gui_layer_priority"].")";
-      $cnt++;
-   }    #die;
+	$sql = "SELECT * FROM gui_layer WHERE fkey_gui_id = '".$guiID."' AND gui_layer_wms_id = ".$wmsID;
+	$res = db_query($sql);
+	$cnt = 0;
+		$sql_ins = "INSERT INTO gui_layer (fkey_gui_id,fkey_layer_id,gui_layer_wms_id,gui_layer_status,gui_layer_selectable,";
+		$sql_ins .= "gui_layer_visible,gui_layer_queryable,gui_layer_querylayer,gui_layer_minscale,gui_layer_maxscale,gui_layer_priority) ";
+		$sql_ins .= "VALUES ($1,$2,$3,$4,$5,$6,$7,$8,$9,10,$11)";
+		$v = array($guiList,$row["fkey_layer_id"],$wmsID,$row["gui_layer_status"],$row["gui_layer_selectable"],
+		$row["gui_layer_visible"],$row["gui_layer_queryable"],$row["gui_layer_querylayer"],$row["gui_layer_minscale"],
+		$row["gui_layer_maxscale"],$row["gui_layer_priority"]);
+		$t = array('s','i','i','i','i','i','i','i','i','i','i');
+		$cnt++;
 echo "<form name='form1' action='" . $PHP_SELF . "?".SID."' method='post'>";
@@ -173,16 +178,13 @@
 if (count($ownguis)>0){
 	echo"GUI";
 	echo"<br>";
-	#$sql = "SELECT * from gui_mb_user, gui WHERE gui.gui_id=gui_mb_user.fkey_gui_id AND gui.gui_public=1 AND gui_mb_user.fkey_mb_user_id=".$_SESSION["mb_user_id"]."  Order BY fkey_gui_id ;";
 	$sql = "SELECT * FROM gui WHERE gui_id IN (";
-	 for($i=0; $i<count($ownguis); $i++){
+	for($i=0; $i<count($ownguis); $i++){
 		if($i>0){ $sql .= ",";}
 		$sql .= "'".$ownguis[$i]."'";
-	$sql .= ") ORDER BY gui_name";
+	$sql .= ") ORDER BY gui_name";
 	$count=0;
 	echo"<select size='8' name='guiList' style='width:200px' onClick='submit()'>";
@@ -192,79 +194,84 @@
 		$gui_description[$count]=$row["gui_description"];
 		$count++;
 		echo "<option value='".$row["gui_id"]."' ";
-		   if($guiList && $guiList == $row["gui_name"]){
-	         echo "selected";
-	      echo ">".$row["gui_name"]."</option>";
+		if($guiList && $guiList == $row["gui_name"]){
+			echo "selected";
+		echo ">".$row["gui_name"]."</option>";
-	  $arrayGUIs=$_SESSION["mb_user_guis"];
-	  echo count($arrayGUIs);
+	$arrayGUIs=$_SESSION["mb_user_guis"];
+	echo count($arrayGUIs);
 	echo "</select><br><br>";
 	echo "</td>";
 	echo "<td>";
 	echo"WMS";
 	echo"<br>";
-	If (isset($guiList) && $guiList!=""){
-	  $sql="SELECT Distinct wms.wms_title, gui_wms_position from gui_wms JOIN gui ON gui_wms.fkey_gui_id=gui.gui_id JOIN wms ON gui_wms.fkey_wms_id=wms.wms_id and gui_wms.fkey_gui_id=gui.gui_id where gui.gui_name='".$guiList."' order by gui_wms_position";
-	  $count=0;
-	  echo"<select size='8' name='wmsList' style='width:200px'>";
+	if(isset($guiList) && $guiList!=""){
+		$sql = "SELECT DISTINCT wms.wms_title, gui_wms_position FROM gui_wms ";
+		$sql .= "JOIN gui ON gui_wms.fkey_gui_id = gui.gui_id JOIN wms ON gui_wms.fkey_wms_id=wms.wms_id ";
+		$sql .= "AND gui_wms.fkey_gui_id=gui.gui_id WHERE gui.gui_name = $1 ORDER BY gui_wms_position";
+		$t = array('s');
+		$res = db_prep_query($sql,$v,$t);
+		$count=0;
+		echo"<select size='8' name='wmsList' style='width:200px'>";
-	  	if ($row["wms_title"]!=""){
-		echo "<option value='' ";
-	    echo ">".$row["wms_title"]."</option>";
+			if ($row["wms_title"]!=""){
+				echo "<option value='' ";
+				echo ">".$row["wms_title"]."</option>";
+			$count++;
-		$count++;
-	    echo "</select><br><br>";
+		echo "</select><br><br>";
 	}else{
-	  echo"<select size='8' name='wmsList' style='width:200px' on Click='submit()'>";
+		echo"<select size='8' name='wmsList' style='width:200px' on Click='submit()'>";
 	echo "</td>";
 	echo "<tr></table><br>";
 	echo"<div class='text1'>Load WMS</div>";
-	$sql = "SELECT DISTINCT wms.wms_id,wms.wms_title,wms.wms_abstract FROM gui_wms JOIN wms ON wms.wms_id = gui_wms.fkey_wms_id WHERE gui_wms.fkey_gui_id IN(";
+	$sql = "SELECT DISTINCT wms.wms_id,wms.wms_title,wms.wms_abstract,wms.wms_owner FROM gui_wms JOIN wms ON ";
+	$sql .= "wms.wms_id = gui_wms.fkey_wms_id WHERE gui_wms.fkey_gui_id IN(";
 	for($i=0; $i<count($arrayGUIs); $i++){
-	   if($i>0){$sql .= ",";}
-	   $sql .= "'".$arrayGUIs[$i]."'";
+		if($i>0){$sql .= ",";}
+		$sql .= "'".$arrayGUIs[$i]."'";
 	$sql .= ") ORDER BY wms.wms_title";
-	//echo $sql;
 	echo "<select class='select1' name='wmsID' size='20' onchange='submit()'>";
 	$cnt = 0;
-	   echo "<option value='".$row["wms_id"]."' ";
-	   if(isset($wmsID) && $wmsID == $row["wms_id"]){
-	      echo "selected";
-	      $wms_getcapabilities = $row["wms_getcapabilities"];
-	   $cnt++;
+		echo "<option value='".$row["wms_id"]."' ";
+		if($row["wms_owner"] == $_SESSION["mb_user_id"]){
+			echo "style='color:green' ";
+		else{
+			echo "style='color:red' ";
+		if(isset($wmsID) && $wmsID == $row["wms_id"]){
+			echo "selected";
+			$wms_getcapabilities = $row["wms_getcapabilities"];
+		$cnt++;
 	echo "</select>";
 	if(isset($wmsID)){
-	   echo "<div class='text2'>FROM:</div>";
-	   $sql = "SELECT * from gui_wms WHERE fkey_wms_id ='".$wmsID."' ORDER BY fkey_gui_id";
-	   echo "<select class='select2' name='guiID' size='20' onchange='load()'>";
-	   $cnt = 0;
-	      echo "<option value='".$row["fkey_gui_id"]."' ";
-	      echo ">".$row["fkey_gui_id"]."</option>";
-	      $cnt++;
+		echo "<div class='text2'>FROM:</div>";
+		$sql = "SELECT * from gui_wms WHERE fkey_wms_id ='".$wmsID."' ORDER BY fkey_gui_id";
+		echo "<select class='select2' name='guiID' size='20' onchange='load()'>";
+		$cnt = 0;
+			echo "<option value='".$row["fkey_gui_id"]."' ";
+			echo ">".$row["fkey_gui_id"]."</option>";
+			$cnt++;
 	echo "</select>";
 echo "</form>";
More information about the Mapbender_commits
