[Mapbender-commits] r1257 - trunk/mapbender/http/frames
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Apr 12 04:43:46 EDT 2007
Author: christoph
Date: 2007-04-12 04:43:46 -0400 (Thu, 12 Apr 2007)
New Revision: 1257
   trunk/mapbender/http/frames/index.php
added json library
added parameter e_target for modules in iframes
Modified: trunk/mapbender/http/frames/index.php
--- trunk/mapbender/http/frames/index.php	2007-04-12 07:57:14 UTC (rev 1256)
+++ trunk/mapbender/http/frames/index.php	2007-04-12 08:43:46 UTC (rev 1257)
@@ -70,9 +70,7 @@
 </style>
 <script type='text/javascript' src="../extensions/json.js"></script>
 <script type='text/javascript' src="../javascripts/point.js"></script>
 <script type='text/javascript' src="../javascripts/map_obj.js"></script>
 <script type='text/javascript' src="../javascripts/wfs_obj.js"></script>
@@ -121,7 +119,7 @@
 				else {
 	      			echo "?";
-      			echo "e_id_css=".db_result($res,$i,"e_id")."&e_id=".db_result($res,$i,"e_id")."'";
+      			echo "e_id_css=".db_result($res,$i,"e_id")."&e_id=".db_result($res,$i,"e_id")."&e_target=".db_result($res,$i,"e_target")."'";
 		else{
 			echo " src = '".preg_replace($pattern,$replacement,db_result($res,$i,"e_src"))."'";
More information about the Mapbender_commits mailing list
