[Mapbender-commits] r1269 - trunk/mapbender/owsproxy/http
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Apr 20 10:43:13 EDT 2007
Author: uli
Date: 2007-04-20 10:43:13 -0400 (Fri, 20 Apr 2007)
New Revision: 1269
   trunk/mapbender/owsproxy/http/index.php
bug fixed
empty style parameter (only one layer is activated whithout style) causes error in php-function key()
Modified: trunk/mapbender/owsproxy/http/index.php
--- trunk/mapbender/owsproxy/http/index.php	2007-04-17 14:46:37 UTC (rev 1268)
+++ trunk/mapbender/owsproxy/http/index.php	2007-04-20 14:43:13 UTC (rev 1269)
@@ -1,5 +1,5 @@
 <?php
-# $Id:$
+# $Id$
 # http://www.mapbender.org/index.php/Owsproxy
 # Module maintainer Uli
 # Copyright (C) 2002 CCGIS
@@ -20,19 +20,20 @@
 require("../../conf/mapbender.conf");
 require("../../http/classes/class_administration.php");
+require_once("../../http/classes/class_mb_exception.php");
 /***** conf *****/
 $imageformats = array("image/png","image/gif","image/jpeg", "image/jpg");
 $mbkeys = array("sid",strtolower(ini_get("session.name")),"wms");
 /***** conf *****/
-$owskey = array();
+$reqParams = array();
 $myKeys = array_keys($_REQUEST);
+// create an associative array with request parameters (get)
 for($i=0; $i<count($myKeys); $i++){
 	$tmp[$i] = removeQM(strtolower($myKeys[$i]));
 	$$tmp[$i]  = $_REQUEST[$myKeys[$i]];
 	if(!in_array(removeQM(strtolower($myKeys[$i])),$mbkeys)){
-		$owskey[removeQM(strtolower($myKeys[$i]))] = $_REQUEST[$myKeys[$i]];
+		$reqParams[removeQM(strtolower($myKeys[$i]))] = $_REQUEST[$myKeys[$i]];
@@ -89,7 +90,7 @@
 		break;
 	default:
 		$or = $n->checkURL($row["wms_getcapabilities"]);
-		$owskey["layers"] = checkLayerPermission($layers);
+		$reqParams["layers"] = checkLayerPermission($layers);
 		$or = completeURL($or);
 		getMap($or);
@@ -129,13 +130,11 @@
 	if($format == 'image/gif'){imagegif($im);}
 function completeURL($url){
-	global $owskey;
-	$c = 0;
-	while ($key = current($owskey)) {
-		if($c > 0){ $url .= "&"; }
-		$url .= key($owskey)."=".$key;
-		$c++;
-		next($owskey);
+	global $reqParams;
+	$mykeys = array_keys($reqParams);
+	for($i=0; $i<count($mykeys);$i++){
+		if($i > 0){ $url .= "&"; }
+		$url .= $mykeys[$i]."=".$reqParams[$mykeys[$i]];
 	return $url;
More information about the Mapbender_commits mailing list
