[Mapbender-commits] r1613 - trunk/mapbender/conf
svn_mapbender at osgeo.org
Mon Aug 6 06:04:17 EDT 2007
Author: christoph
Date: 2007-08-06 06:04:17 -0400 (Mon, 06 Aug 2007)
New Revision: 1613
trunk/mapbender/conf/wfs_default.conf
i18nized
Modified: trunk/mapbender/conf/wfs_default.conf
--- trunk/mapbender/conf/wfs_default.conf 2007-08-06 10:00:54 UTC (rev 1612)
+++ trunk/mapbender/conf/wfs_default.conf 2007-08-06 10:04:17 UTC (rev 1613)
@@ -1,68 +1,17 @@
-var language = (function () {
- function constructorFunction(){
- this.de = "de";
- this.en = "en";
- return new constructorFunction();
-var selectedLanguage = language.en;
+var buttonRectangle = {"status":1, "x":750, "y":10, "img":"select_rectangle_off.png"};
+var buttonPolygon = {"status":1, "x":780, "y":10, "img":"select_polygon_off.png"};
+var buttonPoint = {"status":1, "x":810, "y":10, "img":"select_point_off.png"};
+var buttonExtent = {"status":1, "x":840, "y":10, "img":"select_extent_off.png"};
+var buttonDialogue = {"status":1, "x":870, "y":10, "img":"select_choose_off.png"};
-function addButtonWfs(id, isOn, src, titleOff, titleOn, x, y) {
- buttonWfs_id.push(id);
- buttonWfs_on.push(isOn);
- buttonWfs_src.push(src);
- buttonWfs_title_off.push(titleOff);
- buttonWfs_title_on.push(titleOn);
- buttonWfs_x.push(x);
- buttonWfs_y.push(y);
var buttonWfs_imgdir = "../img/button_gray/";
var buttonWfs_zIndex = 10;
-var buttonWfs_id = [];
-var buttonWfs_on = [];
-var buttonWfs_src = [];
-var buttonWfs_title_off = [];
-var buttonWfs_title_on = [];
-var buttonWfs_x = [];
-var buttonWfs_y = [];
-var buttonLabelRectangle = [];
-buttonLabelRectangle[language.de] = "Rechteckauswahl";
-buttonLabelRectangle[language.en] = "select by rectangle";
-var buttonLabelPolygon = [];
-buttonLabelPolygon[language.de] = "Polygonauswahl";
-buttonLabelPolygon[language.en] = "select by polygon";
-var buttonLabelPoint = [];
-buttonLabelPoint[language.de] = "Punktauswahl";
-buttonLabelPoint[language.en] = "select by point";
-var buttonLabelExtent = [];
-buttonLabelExtent[language.de] = "Universalauswahl";
-buttonLabelExtent[language.en] = "select by extent";
-var buttonLabelDialogue = [];
-buttonLabelDialogue[language.de] = "Auswahlfenster öffnen";
-buttonLabelDialogue[language.en] = "open dialogue form";
-addButtonWfs("rectangle", 1, "select_rectangle_off.png", buttonLabelRectangle[selectedLanguage], buttonLabelRectangle[selectedLanguage], 750, 10);
-addButtonWfs("polygon", 1, "select_polygon_off.png", buttonLabelPolygon[selectedLanguage], buttonLabelPolygon[selectedLanguage], 780, 10);
-addButtonWfs("point", 1, "select_point_off.png", buttonLabelPoint[selectedLanguage], buttonLabelPoint[selectedLanguage], 810, 10);
-addButtonWfs("extent", 1, "select_extent_off.png", buttonLabelExtent[selectedLanguage], buttonLabelExtent[selectedLanguage], 840, 10);
-addButtonWfs("dialogue", 1, "select_choose_off.png", buttonLabelDialogue[selectedLanguage], buttonLabelDialogue[selectedLanguage], 870, 10);
var buttonWfs_toDigitize_on = 1;
var buttonWfs_toDigitize_src = "../img/wfs_digitize.png";
var generalHighlightZIndex = 90;
var generalHighlightLineWidth = 2;
-var errorMessageInvalidExtent = [];
-errorMessageInvalidExtent[selectedLanguage] = "Ausschnitt ungültig!";
-errorMessageInvalidExtent[selectedLanguage] = "Invalid box!";
var wfsResultModulePath = "php/";
var wfsResultModuleFilename = "mod_wfs_result.php";
\ No newline at end of file
More information about the Mapbender_commits
