[Mapbender-commits] r1628 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Wed Aug 8 05:29:55 EDT 2007
Author: christoph
Date: 2007-08-08 05:29:55 -0400 (Wed, 08 Aug 2007)
New Revision: 1628
Added:
trunk/mapbender/http/classes/class_bbox.php
new classes representing a coordinate and a bounding box w/ epsg transformation routine
Added: trunk/mapbender/http/classes/class_bbox.php
--- trunk/mapbender/http/classes/class_bbox.php (rev 0)
+++ trunk/mapbender/http/classes/class_bbox.php 2007-08-08 09:29:55 UTC (rev 1628)
@@ -0,0 +1,210 @@
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/Mod_treefolder2.php
+# Copyright (C) 2007 Melchior Moos
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
+$con = db_connect(DBSERVER,OWNER,PW);
+db_select_db(DB,$con);
+ * A Mapbender_point is a 2-dimensional point with an EPSG.
+class Mapbender_point {
+ var $x;
+ var $y;
+ var $epsg;
+ * @constructor
+ function Mapbender_point($x, $y, $epsg) {
+ if ($x == null || $y == null || $epsg == null) {
+ $e = new mb_exception("Mapbender_point: constructor: some parameters are not set!");
+ $this->x = $x;
+ $this->y = $y;
+ $this->epsg = $epsg;
+ * computes a new point with the minimal coordinates of this point and $point
+ function min ($point) {
+ if ($this->epsg == $point->epsg) {
+ if ($this->isWestOf($point)) {
+ $minx = $this->x;
+ else {
+ $minx = $point->x;
+ if ($this->isSouthOf($point)) {
+ $miny = $this->y;
+ else {
+ $miny = $point->y;
+ return new Mapbender_point($minx, $miny, $this->epsg);
+ else {
+ $e = new mb_exception("Mapbender_point: cannot process min with different EPSG codes");
+ * computes a new point with the maximal coordinates of this point and $point
+ function max ($point) {
+ $maxx = $point->x;
+ else {
+ $maxx = $this->x;
+ $maxy = $point->y;
+ else {
+ $maxy = $this->y;
+ return new Mapbender_point($maxx, $maxy, $this->epsg);
+ else {
+ function isWestOf($point) {
+ if ($this->x < $point->x) {
+ return true;
+ function isSouthOf($point) {
+ if ($this->y < $point->y) {
+ return true;
+ * transforms this point to another EPSG
+ function transform($toEpsg) {
+ if(SYS_DBTYPE=='pgsql'){
+ $currentEpsg = preg_replace("/EPSG:/", "", $this->epsg);
+ $targetEpsg = preg_replace("/EPSG:/", "", $toEpsg);
+ $sql = "SELECT X(transform(GeometryFromText('POINT(".$this->x." ".$this->y.")',".$currentEpsg."),".$targetEpsg.")) as x, ";
+ $sql .= "Y(transform(GeometryFromText('POINT(".$this->x." ".$this->y.")',".$currentEpsg."),".$targetEpsg.")) as y";
+ $res = db_query($sql);
+ $point = new Mapbender_point(db_result($res,0,"x"), db_result($res,0,"y"), $toEpsg);
+ $this->x = $point->x;
+ $this->y = $point->y;
+ $this->epsg = $point->epsg;
+ else {
+ $e = new mb_exception("transformCoordinates needs PostgreSQL");
+ function toString() {
+ return "(" . $this->x . "," . $this->y . "," . $this->epsg . ")";
+ * A bounding box consisting of an lower left and an upper right point, and an EPSG.
+class Mapbender_bbox {
+ var $min;
+ var $max;
+ var $epsg;
+ * @constructor
+ function Mapbender_bbox($min, $max, $epsg) {
+ if ($min->isWestOf($max) && $min->isSouthOf($max)) {
+ if ($min->epsg == $max->epsg && $min->epsg == $epsg) {
+ $this->min = $min;
+ $this->max = $max;
+ else {
+ $e = new mb_exception("Mapbender_bbox: EPSG mismatch!");
+ else {
+ $e = new mb_exception("Mapbender_bbox: min is not southwest of max!");
+ * Computes a new bounding box, this bbox UNION $bbox
+ function union ($bbox) {
+ if ($this->isValid()) {
+ if ($bbox != null && $bbox->isValid()) {
+ if ($this->epsg == $bbox->epsg) {
+ return new Mapbender_bbox($this->min->min($bbox->min), $this->max->max($bbox->max), $this->epsg);
+ else {
+ $e = new mb_exception("mapbender_bbox: cannot process union with different EPSG codes");
+ else {
+ $e = new mb_notice("mapbender_bbox: union: second parameter not a bbox, returning first bbox");
+ return new Mapbender_bbox($this->min, $this->max, $this->epsg);
+ $e = new mb_notice("mapbender_bbox: union: first parameter not a bbox, returning second bbox");
+ return $bbox;
+ return null;
+ * transforms this bbox in another EPSG
+ $this->epsg = $toEpsg;
+ $this->min->transform($toEpsg);
+ $this->max->transform($toEpsg);
+ return true;
+ return false;
+ * checks if lower left and upper right coordinate are set, as well as EPSG
+ function isValid() {
+ if ($this->min != null && $this->max != null && $this->epsg != null) {
+ return true;
+ $e = new mb_exception("Mapbender_bbox: this is not a valid bbox!");
+ return false;
+ return "[" . $this->min->toString() . $this->max->toString() . " " . $this->epsg . "]";
\ No newline at end of file
Property changes on: trunk/mapbender/http/classes/class_bbox.php
___________________________________________________________________
+ Id
More information about the Mapbender_commits
