[Mapbender-commits] r1664 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Tue Aug 28 17:27:56 EDT 2007
Author: marcjansen
Date: 2007-08-28 17:27:56 -0400 (Tue, 28 Aug 2007)
New Revision: 1664
trunk/mapbender/http/classes/class_administration.php
PHPdoc comments added
Modified: trunk/mapbender/http/classes/class_administration.php
--- trunk/mapbender/http/classes/class_administration.php 2007-08-21 08:39:47 UTC (rev 1663)
+++ trunk/mapbender/http/classes/class_administration.php 2007-08-28 21:27:56 UTC (rev 1664)
@@ -529,7 +529,7 @@
- * resets the loin count of a given user to 0
+ * resets the login count of a given user to 0
* @param <integer> the user id
* @return <boolean> could the login count be reseted?
@@ -548,6 +548,12 @@
+ * returns the user id for a given username
+ * @param <string> the username of which the id shall be returned
+ * @return <string|boolean> the userid or false if the operation fails
function getUserIdByUserName($username){
$sql = "SELECT mb_user_id FROM mb_user ";
$sql .= "WHERE mb_user_name = $1 GROUP BY mb_user_id";
@@ -555,9 +561,21 @@
$t = array('s');
$res = db_prep_query($sql,$v,$t);
$row = db_fetch_array($res);
- if ($row) return $row["mb_user_id"]; else return false;
+ if ($row) {
+ return $row["mb_user_id"];
+ else {
+ return false;
+ * sets the given user_id as owner for the passed gui_id
+ * @param <string> the gui_id to change ownership of
+ * @param <integer> the user_id of the intended new owner
+ * @return <boolean> Could the owner be updated?
function setUserAsGuiOwner($guiId, $userId) {
$sql = "UPDATE gui_mb_user SET mb_user_type = 'owner' ";
$sql .= "WHERE fkey_gui_id = $1 AND fkey_mb_user_id = $2 ";
@@ -573,8 +591,16 @@
+ * gets and returns gui_ids identified by the passed over gui_name
+ * @param <string> name of the gui
+ * @return <array|boolean> an array of gui_ids or false when something went wrong
function getGuiIdByGuiName($guiTitle){
- $sql = "SELECT gui_id FROM gui ";
+ //TODO: check whether the passed variable should be renamed, guiTitle is misleading
+ //TODO: check whether the function should be renamed to "getGuiIdsByGuiName" since it usually returns an array
+ $sql = "SELECT gui_id FROM gui ";
$sql .= "WHERE gui_name = $1 GROUP BY gui_id";
$v = array($guiTitle);
$t = array('s');
@@ -593,15 +619,23 @@
- function getGuisByOwner($user_id,$ignore_public)
- $sql_guis = "SELECT gui.gui_id FROM gui,gui_mb_user ";
+ * returns gui_ids owned by the user with the passed user_id
+ * @param <integer> user_id of the owner
+ * @param <boolean> shall only public guis be returned? sort of optional... see todo
+ * @return <array> array of gui_ids owned by the user
+ function getGuisByOwner($user_id,$ignore_public) {
+ //TODO: isn't the name of the second parameter misleading?
+ $sql_guis = "SELECT gui.gui_id FROM gui,gui_mb_user ";
$sql_guis .= "WHERE (gui.gui_id = gui_mb_user.fkey_gui_id AND gui_mb_user.fkey_mb_user_id = $1) ";
- if (!isset($ignore_public) OR $ignore_public == false){
+ //TODO: when using !isset() below should IMO be replaced with a true otional second parameter via a default value
+ if (!isset($ignore_public) OR $ignore_public == false){
$sql_guis .= " AND gui.gui_public = 1 ";
$sql_guis .= " AND gui_mb_user.mb_user_type = 'owner' GROUP BY gui.gui_id";
- $sql_guis .= " ORDER by gui.gui_id";
+ $sql_guis .= " ORDER BY gui.gui_id";
$v = array($user_id);
$t = array('i');
$res_guis = db_prep_query($sql_guis,$v,$t);
@@ -611,9 +645,16 @@
$arrayGuis[$count_g] = $row["gui_id"];
$count_g++;
+ //TODO: check: why do we always return an array, when most other comparable functions would return false? This is IMO at least inconsistent.
return $arrayGuis;
+ * returns wmc_ids owned by the user with the passed user_id
+ * @return <array> array of wmc_ids owned by the user
function getWmcByOwner($user_id){
$sql_wmc = "SELECT wmc_id FROM mb_user_wmc ";
$sql_wmc .= "WHERE fkey_user_id = $1 GROUP BY wmc_id";
@@ -626,6 +667,7 @@
$arrayWmc[$count_g] = $row["wmc_id"];
$count_g++;
return $arrayWmc;
@@ -680,7 +722,7 @@
if(count($array_gui_ids)>0){
$v = array();
$t = array();
- $sql = "SELECT fkey_wms_id from gui_wms WHERE gui_wms.fkey_gui_id IN(";
+ $sql = "SELECT fkey_wms_id FROM gui_wms WHERE gui_wms.fkey_gui_id IN(";
for($i=0; $i<count($array_gui_ids); $i++){
if($i>0){ $sql .= ",";}
$sql .= "$".strval($i+1);
@@ -839,6 +881,7 @@
if($row = db_fetch_array($res)){
return true;
+ //TODO: next three lines should be removable...
else{
return false;
@@ -934,15 +977,15 @@
|\xF4[\x80-\x8F][\x80-\xBF]{2} # plane 16
)+%xs', $string);
function is_utf8_xml($xml) {
return preg_match('/<\?xml[^>]+encoding="utf-8"[^>]*\?>/is', $xml);
function is_utf8 ($data) {
return ($this->is_utf8_xml($data) || $this->is_utf8_string($data));
function char_encode($data) {
if (CHARSET == "UTF-8") {
if (!$this->is_utf8($data)) {
@@ -970,12 +1013,12 @@
$e = new mb_notice("no conversion: is " . CHARSET);
return $data;
* identifies the Featureservices where the current user is owner
* @param integer userid the user-ID of the current user
- * @returen integer[] the IDs of the featureservices
+ * @return array an array of the IDs as integers of the featureservices
function getWfsByOwner($userid){
$sql = "SELECT wfs_id FROM wfs WHERE wfs_owner = $1";
More information about the Mapbender_commits
