[Mapbender-commits] r1896 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Thu Dec 6 08:46:41 EST 2007
Author: christoph
Date: 2007-12-06 08:46:35 -0500 (Thu, 06 Dec 2007)
New Revision: 1896
trunk/mapbender/http/javascripts/geometry.js
allows to display an icon as a point highlight
Modified: trunk/mapbender/http/javascripts/geometry.js
--- trunk/mapbender/http/javascripts/geometry.js 2007-12-06 12:21:39 UTC (rev 1895)
+++ trunk/mapbender/http/javascripts/geometry.js 2007-12-06 13:46:35 UTC (rev 1896)
@@ -1033,7 +1033,14 @@
var p = realToMap(mapframe,g.get(i).get(0));
if (p.x + diameter < mb_mapObj[mapObjInd].width && p.x - diameter > 0 &&
p.y + diameter < mb_mapObj[mapObjInd].height && p.y - diameter > 0) {
- drawCircle(p.x-1, p.y-1, diameter,col);
+ // if the point contains a link to an icon, display the icon
+ g.e.setElement("Mapbender:icon", "../img/indicator_wheel.gif");
+ if (g.e.getElementValueByName("Mapbender:icon")) {
+ displayIcon(g.e.getElementValueByName("Mapbender:icon"), p.x, p.y);
+ else {
+ drawCircle(p.x-1, p.y-1, diameter,col);
else if(t==geomType.line || t==geomType.polygon) {
@@ -1105,6 +1112,25 @@
+ * Displays an icon in the mapframe
+ * @private
+ * @param {String} url link to the image
+ * @param {Float} x x coordinate within the map frame
+ * @param {Float} y y coordinate within the map frame
+ var displayIcon = function (url, x, y) {
+ var newImg = document.createElement("img");
+ newImg.src = url;
+ newImg.style.position = "absolute";
+ // center the image at x, y
+ newImg.style.top = y - Math.round(newImg.height/2);
+ newImg.style.left = x - Math.round(newImg.width/2);
+ that.canvasDivTag.getTag().appendChild(newImg);
* This is the {@link DivTag} that contains the output by {@link jsGraphics}.
* @type DivTag
More information about the Mapbender_commits
