[Mapbender-commits] r1900 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Thu Dec 6 08:51:15 EST 2007
Author: christoph
Date: 2007-12-06 08:51:15 -0500 (Thu, 06 Dec 2007)
New Revision: 1900
Added:
trunk/mapbender/http/javascripts/mod_loadKML.php
load KML
Added: trunk/mapbender/http/javascripts/mod_loadKML.php
--- trunk/mapbender/http/javascripts/mod_loadKML.php (rev 0)
+++ trunk/mapbender/http/javascripts/mod_loadKML.php 2007-12-06 13:51:15 UTC (rev 1900)
@@ -0,0 +1,53 @@
+<?php
+# $Id: mod_loadwmc.php 1769 2007-10-29 12:43:58Z christoph $
+# http://www.mapbender.org/index.php/mod_loadwmc.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../classes/class_kml.php");
+$gui_id = $_REQUEST["gui_id"];
+echo "var loadKmlTarget = '".$e_target."';\n";
+var kmlHasLoaded = new MapbenderEvent();
+var loadKmlImg = new Image();
+loadKmlImg.src = "<?php echo $e_src; ?>";
+var loadKmlImgOver = new Image();
+loadKmlImgOver.src = "<?php echo preg_replace("/_off/","_over",$e_src); ?>";
+var mpbn_loadKml = function () {
+ windowKml = window.open("../php/mb_listKMLs.php?<?php echo SID;?>","displayKml","width=500, height=600, scrollbars=yes, dependent=yes");
+var mpbn_loadKmlInit = function (obj) {
+ obj.src = loadKmlImgOver.src;
+ obj.onmouseover = new Function("mpbn_loadKmlOver(this)");
+ obj.onmouseout = new Function("mpbn_loadKmlOut(this)")
+var mpbn_loadKmlOver = function (obj) {
+var mpbn_loadKmlOut = function (obj) {
+ obj.src = loadKmlImg.src;
\ No newline at end of file
More information about the Mapbender_commits
