[Mapbender-commits] r1914 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Dec 12 09:41:47 EST 2007
Author: verenadiewald
Date: 2007-12-12 09:41:46 -0500 (Wed, 12 Dec 2007)
New Revision: 1914
   trunk/mapbender/http/javascripts/mod_digitize_tab.php
registerInit getMessages below initialiseMeasure()
Modified: trunk/mapbender/http/javascripts/mod_digitize_tab.php
--- trunk/mapbender/http/javascripts/mod_digitize_tab.php	2007-12-12 14:38:28 UTC (rev 1913)
+++ trunk/mapbender/http/javascripts/mod_digitize_tab.php	2007-12-12 14:41:46 UTC (rev 1914)
@@ -1,1411 +1,1407 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mod_digitize_tab.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-session_start();
-import_request_variables("PG");
-require_once("../php/mb_validateSession.php");
-require_once("../../conf/mapbender.conf");
-$con = db_connect($DBSERVER,$OWNER,$PW);
-db_select_db(DB,$con);
-$gui_id = $_SESSION["mb_user_gui"];
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>Digitize</title>
-<?php
-$digitize_conf_filename = "digitize_default.conf";
-include '../include/dyn_css.php';
-$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'digitize' AND fkey_gui_id = $1";
-$v = array($gui_id);
-$t = array('s');
-$res = db_prep_query($sql, $v, $t);
-$cnt = 0;
-while($row = db_fetch_array($res)){
-	$e_src = $row["e_src"];
-	$e_target = explode(",",$row["e_target"]);
-	$cnt++;
-if($cnt > 1) echo "alert('digitize_button: ID not unique!');";
-echo "<script language='JavaScript'>";
-echo "var mod_digitize_target = '".$e_target[0]."';";
-echo "var mod_digitize_frame = '".$e_target[1]."';";
-include("../../conf/" . $digitize_conf_filename);
-var wfsWindow;
-var dwin = null;
-var wfsConf = [];
-var d = new parent.GeometryArray();
-var mod_digitize_width;
-var mod_digitize_height;
-var mod_digitizeEvent = false;
-var nonTransactionalHighlight;
-var button_point = "Point";
-var button_line = "Line";
-var button_polygon = "Polygon";
-var button_move = "dragBasePoint";
-var button_insert = "setBasePoint";
-var button_delete = "delBasePoint";
-var button_clear = "clear";
-var button_combine = "combine";
-var digitizeDivTag;
-var GeometryArray = parent.GeometryArray;
-var MultiGeometry = parent.MultiGeometry;
-var Geometry = parent.Geometry;
-var Point = parent.Point;
-var geomType = parent.geomType;
-var msgObj;
-var featureTypeElementFormId = "featureTypeElementForm";
-try {if(mod_digitize_elName){}}catch(e) {mod_digitize_elName = "digitize";}
- * Append geometries from KML when KML has been loaded
-function appendGeometryArrayFromKML () {
-	try {
-		parent.kmlHasLoaded.register(function(properties){
-			d = parent.geoJsonToGeometryArray(properties);
-			executeDigitizeSubFunctions();
-	catch (e) {
-		var exc = new parent.Mb_warning(e);
-// --- polygon, line, point insertion (begin) ----------------------------------------------------------------------------------------------
-function appendGeometryArray(obj) {
-	executeDigitizePreFunctions();
-	for (i=0; i<obj.count(); i++) {
-		d.addCopy(obj.get(i));
-function mod_digitize_go(e){
-	parent.mb_registerGML(mod_digitize_target,d);
-	// ie workaround
-	if (e == undefined) {
-		e = parent.frames[mod_digitize_target].event;
-	if (e) {
-		// track mouse position
-		parent.mb_getMousePos(e, mod_digitize_target);
-		var currentPos = new parent.Point(parent.clickX, parent.clickY);
-		s.check(currentPos);
-	else {
-//		s.clean();
-	var el = parent.frames[mod_digitize_target].document;
-	el.onmousedown = mod_digitize_start;
-function mod_digitize_timeout(){
-	el.onmousedown = null;
-	el.onmouseup = null;
-	el.onmousemove = null;
-function mod_digitize_start(e){
-	// check if a proper geometry is selected
-	if (d.getGeometry(-1,-1).isComplete() || d.count() == 0){
-		if (mod_digitizeEvent != false) {
-			alert(msgObj.errorMessageNoGeometrySelected);
-		return false;
-	var realWorldPos;
-	if (s.isSnapped()) {
-		realWorldPos = s.getSnappedPoint();
-		s.clean();
-	else {
-		parent.mb_getMousePos(e,mod_digitize_target);
-		realWorldPos = parent.mapToReal(mod_digitize_target,new parent.Point(parent.clickX,parent.clickY));
-	if (d.get(-1).geomType == parent.geomType.polygon && d.getGeometry(-1,-1).count() > 1 && d.getGeometry(-1,-1).get(0).equals(realWorldPos)) {
-		// close the polygon
-		d.close();
-		parent.mb_disableThisButton(button_polygon);
-		return true;
-	else if (d.get(-1).geomType == parent.geomType.line && d.getGeometry(-1,-1).count() > 1 && d.getGeometry(-1,-1).get(-1).equals(realWorldPos)) {
-		// close the line
-		d.close();
-		parent.mb_disableThisButton(button_line);
-		return true;
-	else {
-		// set the calculated real world position as point of the geometry
-		d.getGeometry(-1,-1).addPoint(realWorldPos);
-		if(d.get(-1).geomType == parent.geomType.point){
-			d.close();
-			parent.mb_disableThisButton(button_point);
-			return true;
-		// add first point of polygon to snapping list (if three points have been inserted).
-		else if (d.get(-1).geomType == parent.geomType.polygon && d.getGeometry(-1,-1).count() == 3) {
-			s.add(d.getPoint(-1, -1, 0));
-		// add last point of line to snapping list (if at least two points have been inserted).
-		else if (d.get(-1).geomType == parent.geomType.line && d.getGeometry(-1,-1).count() >= 2) {
-			if (mod_digitizeEvent != button_move) {
-				s.store(d);
-			s.add(d.getPoint(-1, -1, -1));
-	return true;
-// --- basepoint handling (begin) -----------------------------------------------------------------------------------------
-var basepointObject = false;
-var basepointMemberIndex = null;
-var basepointGeometryIndex = null;
-var basepointPointIndex = null;
-var basepointDragActive = false;
-function handleBasepoint(obj,memberIndex,geometryIndex,pointIndex){
-	if(!(mod_digitizeEvent == button_move || mod_digitizeEvent == button_insert || mod_digitizeEvent == button_delete)){ return false; }
-	basepointObject = obj;
-	basepointMemberIndex = memberIndex;
-	basepointGeometryIndex = geometryIndex;
-	basepointPointIndex = pointIndex;
-	if(mod_digitizeEvent == button_move){
-		mod_digitize_timeout();
-		basepointObject.style.cursor = 'move';
-		basepointObject.onmousedown = parent.window.frames[mod_digitize_elName].selectBasepoint;
-	if(mod_digitizeEvent == button_delete){
-		basepointObject.style.cursor = 'crosshair';
-		basepointObject.onmousedown = parent.window.frames[mod_digitize_elName].deleteBasepoint;
-function convertLinepointToBasepoint(obj, memberIndex, geomIndex, pointIndex){
-	if(!(mod_digitizeEvent == button_insert)){ return false; }
-	if(mod_digitizeEvent == button_insert){
-		obj.style.cursor = 'crosshair';
-		obj.onclick = insertBasepoint;
-		basepointGeometryIndex = geomIndex;
-function insertBasepoint(e){
-	var i = basepointMemberIndex;
-	var j = basepointGeometryIndex;
-	var k = basepointPointIndex;
-	var pos = parent.makeClickPos2RealWorldPos(mod_digitize_target,parent.clickX, parent.clickY);
-	var p = new parent.Point(pos[0], pos[1]);
-	d.getGeometry(i,j).addPointAtIndex(p, k);
-function deleteBasepoint(){
-	d.delAllPointsLike(d.getPoint(i,j,k));
-function selectBasepoint(e){
-	if(!basepointDragActive && mod_digitizeEvent == button_move){
-		basepointDragActive = true;
-		s.store(d, d.getPoint(basepointMemberIndex, basepointGeometryIndex, basepointPointIndex));
-		// replace basepoint by transparent blob
-		basepointObject.style.width = mod_digitize_width;
-		basepointObject.style.height = mod_digitize_height;
-		basepointObject.style.left = 0;
-		basepointObject.style.top = 0;
-		if (parent.ie) {
-			// ie cannot handle backgroundColor = 'transparent'
-			basepointObject.style.background = "url(../img/transparent.gif)";
-		else{
-			basepointObject.style.backgroundColor = 'transparent';
-		basepointObject.onmouseup = releaseBasepoint;
-		basepointObject.onmousemove = dragBasepoint;
-function dragBasepoint(e){
-	if(basepointDragActive){
-		var res = s.check(currentPos);
-function updateAllPointsOfNonTransactionalLike(oldP, newP){
-	for (var i = 0; i < d.count(); i++) {
-		if (isTransactional(d.get(i))) {
-			d.get(i).updateAllPointsLike(oldP, newP);
-function releaseBasepoint(e){
-	basepointDragActive = false;
-	var basepointDragEnd = new parent.Point(parent.clickX, parent.clickY);
-	basepointObject.onmousedown = null;
-	var p = parent.makeClickPos2RealWorldPos(mod_digitize_target, basepointDragEnd.x, basepointDragEnd.y);
-	var oldPoint = parent.cloneObject(d.getPoint(i,j,k));
-		var snappedPoint = parent.cloneObject(s.getSnappedPoint());
-		if (!nonTransactionalEditable) {
-			updateAllPointsOfNonTransactionalLike(oldPoint, snappedPoint);
-		else {
-			d.updateAllPointsLike(oldPoint, snappedPoint);
-		s.clean();
-	else {
-		var newPoint = new parent.Point(p[0],p[1]);
-			updateAllPointsOfNonTransactionalLike(oldPoint, newPoint);
-		else {
-			d.updateAllPointsLike(oldPoint, newPoint);
-	basepointMemberIndex = null;
-	basepointGeometryIndex = null;
-	basepointPointIndex = null;
-// --- basepoint handling (end) -----------------------------------------------------------------------------------------
-// --- registered functions (begin) ---------------------------------------------------------------------------------------
-function registerDigitizePreFunctions(stringFunction){
-	mod_digitizePreFunctions[mod_digitizePreFunctions.length] = stringFunction;
-function registerDigitizeSubFunctions(stringFunction){
-	mod_digitizeSubFunctions[mod_digitizeSubFunctions.length] = stringFunction;
-function executeDigitizeSubFunctions(){
-//	console.profile();
-	for(var i=0; i<mod_digitizeSubFunctions.length; i++){
-		eval(mod_digitizeSubFunctions[i]);
-//	console.profileEnd();
-function executeDigitizePreFunctions(){
-	for(var i=0; i<mod_digitizePreFunctions.length; i++){
-		eval(mod_digitizePreFunctions[i]);
-function registerFunctions(){
-	mod_digitizePreFunctions = [];
-	mod_digitizeSubFunctions = [];
-	registerDigitizePreFunctions("updateExtent()");
-	registerDigitizePreFunctions("drawDashedLine()");
-	registerDigitizeSubFunctions("updateListOfGeometries()");
-	registerDigitizeSubFunctions("drawDashedLine()");
-	registerDigitizeSubFunctions("updateMeasureTag()");
-	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].getMessages()");
-	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].setStyleForTargetFrame()");
-	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].checkDigitizeTag()");
-	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].initialiseSnapping()");
-	parent.mb_registerL10nFunctions("window.frames['"+ mod_digitize_elName + "'].getMessages()");
-	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].appendGeometryArrayFromKML()");
-		parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].initialiseHighlight()");
-	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].initialiseMeasure()");
-	parent.mb_registerSubFunctions("window.frames['" + mod_digitize_elName + "'].updateExtent()");
-	if(spatialRequestResultToDigitize==1){
-	parent.mb_registerWfsReadSubFunctions(function(geom){parent.tab_open(mod_digitize_elName);parent.window.frames[mod_digitize_elName].appendGeometryArray(geom);});
-	parent.mb_registerWfsWriteSubFunctions(function(){parent.zoom(mod_digitize_target, true, 0.999);});
-function checkDigitizeTag(){
-	var digitizeTagName = "digitize";
-	var digitizeTagStyle = {"position":"absolute", "top":"0px", "left":"0px", "z-index":digitizeTransactionalZIndex, "font-size":"10px"};
-	digitizeDivTag = new parent.DivTag(digitizeTagName, mod_digitize_target, digitizeTagStyle);
-	parent.mb_registerPanSubElement(digitizeTagName);
-	parent.mb_registerSubFunctions("window.frames['"+ mod_digitize_elName + "'].drawDashedLine()");
-function setStyleForTargetFrame(){
-	var cssLink = parent.window.frames[mod_digitize_target].document.createElement("link");
-	cssLink.setAttribute("href", cssUrl);
-	cssLink.setAttribute("type", "text/css");
-	cssLink.setAttribute("rel", "stylesheet");
-	var cssTmp = parent.window.frames[mod_digitize_target].document.getElementsByTagName("head")[0];
-	cssTmp.appendChild(cssLink);
-function initialiseSnapping(){
-	s = new parent.Snapping(mod_digitize_target, snappingTolerance, snappingColor, snappingHighlightZIndex);
-function initialiseHighlight(){
-	nonTransactionalHighlight = new parent.Highlight(new Array(mod_digitize_target), "nonTransactional", {"position":"absolute", "top":"0px", "left":"0px", "z-index":digitizeNonTransactionalZIndex}, nonTransactionalLineWidth);
-function initialiseMeasure(){
-	measureDivTag = new parent.DivTag(measureTagName, measureTagTarget, measureTagStyle);
-	parent.mb_registerSubFunctions("window.frames['"+ mod_digitize_elName + "'].updateMeasureTag()");
-// --- registered functions (end) -----------------------------------------------------------------------------------------
-function updateMeasureTag () {
-	if (d.count() > 0 ) {
-		if (d.get(-1).count() > 0) {
-			if (d.getGeometry(-1, -1).count() > 0) {
-				if (mod_digitizeEvent == button_line || mod_digitizeEvent == button_polygon) {
-					var measureString = "";
-					measureString += msgObj.measureTagLabelCurrent + d.getGeometry(-1, -1).getCurrentDist(measureNumberOfDigits) + "<br>";
-					measureString += msgObj.measureTagLabelTotal + d.getGeometry(-1, -1).getTotalDist(measureNumberOfDigits);
-					measureDivTag.write(measureString);
-					return true;
-	measureDivTag.clean();
-// --- button handling (begin) --------------------------------------------------------------------------------------------
-function displayButtons(){
-	for (var i = 0 ; i < buttonDig_id.length ; i ++) {
-		if (parseInt(buttonDig_on[i])==1) {
-			var divTag = document.createElement("div");
-			divTag.setAttribute("id", "div_" + buttonDig_id[i]);
-// FIREFOX
-			document.getElementById("digButtons").appendChild(divTag);
-//IE WORKAROUND, WORKS ALSO FOR FIREFOX
-			var tagContent = "<div style='position:absolute; top:"+buttonDig_y[i]+"px; left:"+buttonDig_x[i]+"px;'><img name=\""+buttonDig_id[i]+"\" onmouseover=\"parent.mb_regButton_frame('initDigButton', mod_digitize_elName, "+i+");\" id=\""+buttonDig_id[i]+"\" title=\""+buttonDig_title_off[i]+"\" src=\""+buttonDig_imgdir+buttonDig_src[i]+"\"></div>";
-			parent.writeTag(mod_digitize_elName,"div_" + buttonDig_id[i],tagContent);
-function initDigButton(ind, pos){
-	parent.mb_button[ind] = document.getElementById(buttonDig_id[pos]);
-	parent.mb_button[ind].img_over = buttonDig_imgdir + buttonDig_src[pos].replace(/_off/,"_over");
-	parent.mb_button[ind].img_on = buttonDig_imgdir + buttonDig_src[pos].replace(/_off/,"_on");
-	parent.mb_button[ind].img_off = buttonDig_imgdir + buttonDig_src[pos];
-	parent.mb_button[ind].title_on = buttonDig_title_on[pos];
-	parent.mb_button[ind].title_off = buttonDig_title_off[pos];
-	parent.mb_button[ind].status = 0;
-	parent.mb_button[ind].elName = buttonDig_id[pos];
-	parent.mb_button[ind].fName = "";
-	parent.mb_button[ind].go = new Function ("digitizeEnable(parent.mb_button["+ind+"])");
-	parent.mb_button[ind].stop = new Function ("digitizeDisable(parent.mb_button["+ind+"])");
-function digitizeEnable(obj) {
-	if (obj.id == button_move || obj.id == button_insert || obj.id == button_delete) {
-		mod_digitizeEvent = obj.id;
-	else if (obj.id == button_point || obj.id == button_line || obj.id == button_polygon || obj.id == button_clear || obj.id == button_combine){
-		el.onmousemove = mod_digitize_go;
-		if (mod_digitizeEvent == button_point || mod_digitizeEvent == button_line || mod_digitizeEvent == button_polygon || mod_digitizeEvent == button_insert ) {
-			s.store(d);
-		obj.title = obj.title_on;
-		if (obj.id == button_point) {
-			if (d.count() > 0 && d.get(-1).count() > 0 && !d.get(-1).get(-1).isComplete()) {
-				if (d.get(-1).geomType != parent.geomType.point) {
-					d.close();
-				else {
-			if (d.count() == 0 || (d.count() > 0 && d.get(-1).count() > 0 && d.get(-1).get(-1).isComplete())) {
-				d.addMember(parent.geomType.point);
-				d.get(-1).addGeometry();
-			else {
-// delete existing line or polygon
-				d.del(-1);
-		else if (obj.id == button_polygon) {
-				if (d.get(-1).geomType != parent.geomType.polygon) {
-					d.close();
-				else {
-				// new geometry
-				d.addMember(parent.geomType.polygon);
-			else {
-// continue a line as a polygon
-					var geometryTemplate = parent.cloneObject(d.get(-1));
-					d.del(-1);
-					for (var i = 0; i < geometryTemplate.count(); i++) {
-						for (var j = 0; j < geometryTemplate.get(i).count(); j++) {
-							d.get(-1).get(-1).addPoint(geometryTemplate.get(i).get(j));
-		else if (obj.id == button_line) {
-				if (d.get(-1).geomType != parent.geomType.line) {
-					d.close();
-				else {
-				d.addMember(parent.geomType.line);
-			else {
-// continue a polygon as a line
-					d.del(-1);
-		else if (obj.id == button_clear) {
-			var clear = confirm(msgObj.messageConfirmDeleteAllGeomFromList);
-			if (clear) {
-				d = new parent.GeometryArray();
-				parent.mb_disableThisButton(button_clear);
-		else if (obj.id == button_combine) {
-//			d.combineToMultiGeometry();
-//			prompt('', d.toJSONString());
-//			parent.mb_ajax_post("../php/jsonTest.php", {json:d.toJSONString()}, function(test, status) {
-//				alert(test);
-			parent.mb_disableThisButton(button_combine);
-function digitizeDisable(obj) {
-	if (obj.id == button_point || obj.id == button_line || obj.id == button_polygon){
-		obj.title = obj.title_off;
-		if (d.get(-1).get(-1).count() == 0) {
-			d.delGeometry(-1,-1);
-	mod_digitizeEvent = false;
-// --- button handling (end) ----------------------------------------------------------------------------------------------
-// --- display (begin) -----------------------------------------------------------------------------------------
-function updateExtent() {
-	var anInd = parent.getMapObjIndexByName(mod_digitize_target);
-	var change = false;
-	if (typeof(mod_digitize_width) == 'undefined' || mod_digitize_width != parent.mb_mapObj[anInd].width) {
-		mod_digitize_width = parent.mb_mapObj[anInd].width;
-		change = true;
-	if (typeof(mod_digitize_height) == 'undefined' || mod_digitize_height != parent.mb_mapObj[anInd].height) {
-		mod_digitize_height = parent.mb_mapObj[anInd].height;
-		change = true;
-	if (typeof(mod_digitize_epsg) == 'undefined' || mod_digitize_epsg != parent.mb_mapObj[anInd].epsg) {
-		mod_digitize_epsg = parent.mb_mapObj[anInd].epsg;
-		change = true;
-//	if (change) {
-//		drawDashedLine();
-function drawDashedLine(){
-		nonTransactionalHighlight.clean();
-	var smPArray = [];
-	smPArray[smPArray.length] = "<div class='t_img'>"
-			+ "<img src='"+parent.mb_trans.src+"' width='"+mod_digitize_width+"' height='0'></div>"
-			+ "<div class='t_img'>"
-			+ "<img src='"+parent.mb_trans.src+"' width='0' height='"+mod_digitize_height+"'></div>";
-	for(var i=0, lenGeomArray = d.count(); i < lenGeomArray; i++){
-		var currentGeomArray = d.get(i);
-		if (!nonTransactionalEditable && !isTransactional(currentGeomArray)) {
-			nonTransactionalHighlight.add(currentGeomArray, nonTransactionalColor);
-		else {
-			for(var j=0, lenGeom = currentGeomArray.count(); j < lenGeom ; j++){
-				var currentGeometry = d.getGeometry(i,j);
-				for(var k = 0, lenPoint = currentGeometry.count(); k < lenPoint; k++){
-					var currentPoint = d.getPoint(i,j,k);
-					var pos = parent.makeRealWorld2mapPos(mod_digitize_target, currentPoint.x, currentPoint.y);
-					if (!currentGeometry.isComplete() &&
-						( (k == 0 && currentGeomArray.geomType == parent.geomType.polygon) || (k == currentGeometry.count()-1 && currentGeomArray.geomType == parent.geomType.line))) {
-						smPArray[smPArray.length] = "<div class='bp' style='top:"+
-							(pos[1]-2)+"px;left:"+(pos[0]-2)+"px;z-index:"+
-							digitizeTransactionalZIndex+";background-color:"+linepointColor+"'";
-					else {
-						smPArray[smPArray.length] = "<div class='bp' style='top:"+(pos[1]-2)+"px;left:"+(pos[0]-2)+"px;z-index:"+digitizeTransactionalZIndex+";'";
-					if(j==0 && currentGeomArray.geomType == parent.geomType.polygon && !currentGeometry.isComplete()){
-						smPArray[smPArray.length] = " title='"+closePolygon_title+"' ";
-					if(mod_digitizeEvent == button_move || mod_digitizeEvent == button_insert || mod_digitizeEvent == button_delete) {
-						smPArray[smPArray.length] = " onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].handleBasepoint(this,"+i+","+j+","+k+")' ;";
-					smPArray[smPArray.length] = "></div>";
-				var mapObj = parent.mb_mapObj[parent.getMapObjIndexByName(mod_digitize_target)];
-				for(var k = 1; k < currentGeometry.count(); k++){
-					var p0 = parent.realToMap(mod_digitize_target, d.getPoint(i,j,k));
-					var p1 = parent.realToMap(mod_digitize_target, d.getPoint(i,j,k-1));
-					points = parent.calculateVisibleDash(p0, p1, mapObj.width, mapObj.height);
-					if (points != false) {
-						smPArray[smPArray.length] = evaluateDashes(points[0], points[1], i, j, k);
-		nonTransactionalHighlight.paint();
-	digitizeDivTag.write(smPArray.join(""));
-function evaluateDashes(start, end, memberIndex, geomIndex, pointIndex){
-	var strArray = [];
-	var delta = new parent.Point(end.x - start.x, end.y - start.y);
-	var lastGeomIsComplete = d.getGeometry(-1,-1).isComplete();
-	var vecLength = start.dist(end);
-	var n = Math.round(vecLength/dotDistance);
-	if (n > 0) {
-		var step = delta.dividedBy(n);
-	for(var i=1; i < n; i++){
-		var x = Math.round(start.x + i * step.x) - 2;
-		var y = Math.round(start.y + i * step.y) - 2;
-		if(x >= 0 && x <= mod_digitize_width && y >= 0 && y <= mod_digitize_height){
-			if (memberIndex == d.count()-1 && !lastGeomIsComplete) {
-				strArray[strArray.length] = "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:"+digitizeTransactionalZIndex+";background-color:"+linepointColor+"' ";
-			else {
-				strArray[strArray.length] = "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:"+digitizeTransactionalZIndex+";' ";
-			if(mod_digitizeEvent == button_insert) {
-				strArray[strArray.length] = "onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].convertLinepointToBasepoint(this,"+memberIndex+","+geomIndex+","+pointIndex+")'";
-			strArray[strArray.length] = "></div>";
-	return strArray.join("");
-function isTransactional(geom) {
-//	alert(typeof(geom.wfs_conf) + " " + geom.wfs_conf + " " + wfsConf.length);
-	if (typeof(geom.wfs_conf) == 'number') {
-		if (geom.wfs_conf >= 0 && geom.wfs_conf < wfsConf.length) {
-			var isTransactionalGeom = (wfsConf[geom.wfs_conf]['wfs_transaction'] != "" && wfsConf[geom.wfs_conf]['fkey_featuretype_id'] != "");
-			if (isTransactionalGeom) {
-				return true;
-			else{
-				return false;
-	else if (typeof(geom.wfs_conf) == 'undefined') {
-		return true;
-function isValidWfsConfIndex (wfsConf, wfsConfIndex) {
-	return (typeof(wfsConfIndex) == "number" && wfsConfIndex >=0 && wfsConfIndex < wfsConf.length);
-function getName (geom) {
-	wfsConfId = geom.wfs_conf;
-	wfsConf = parent.get_complete_wfs_conf();
-	if (isValidWfsConfIndex(wfsConf, wfsConfId)) {
-		var resultName = "";
-		for (var i = 0 ; i < wfsConf[wfsConfId]['element'].length ; i++) {
-			if (wfsConf[wfsConfId]['element'][i]['f_show'] == 1) {
-				resultName += geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']) + " ";
-		if (resultName == "") {
-			resultName = wfsConf[wfsConfId]['g_label'];
-		return resultName;
-	else if (geom.e.getElementValueByName("name")) {
-		return geom.e.getElementValueByName("name");
-	else {
-		return msgObj.digitizeDefaultGeometryName;
-function updateListOfGeometries(){
-	var listOfGeom = "<table id='geometryTable' style='position:absolute; top:"+geomList_y+"px; left:"+geomList_x+"px;'>\n";
-	if (d.count() > 0) {
-		for (var i = 0 ; i < d.count(); i ++) {
-			if (d.get(i).get(-1).isComplete() && (nonTransactionalEditable || isTransactional(d.get(i)))) {
-				// for the geometries from a kml, there is another save dialogue
-				if (d.get(i).isFromKml()) {
-					// if the kml is in the db (id = id in database)
-					if (d.get(i).e.getElementValueByName("Mapbender:id")) {
-						// button: geometry information, update kml
-						listOfGeom += "\t<tr>\n\t\t<td>\n";
-						listOfGeom += "\t\t\t<img src = '"+buttonDig_imgdir+buttonDig_wfs_src+"' title='"+msgObj.buttonDig_wfs_title+"' onclick='showWfsKml("+i+")'>\n";
-				else {
-					// button: geometry information, save, update, delete
-					if (wfsExistsForGeom(d.get(i), wfsConf)) {
-						listOfGeom += "\t\t\t<img src = '"+buttonDig_imgdir+buttonDig_wfs_src+"' title='"+msgObj.buttonDig_wfs_title+"' onclick='showWfs("+i+")'>\n";
-					listOfGeom += "\t\t</td>\n\t\t<td>\n";
-					// button: remove this geometry
-					listOfGeom += "\t\t\t<img src = '"+buttonDig_imgdir+buttonDig_remove_src+"' title='"+msgObj.buttonDig_remove_title+"' onclick='parent.mb_disableThisButton(mod_digitizeEvent);d.del("+i+");executeDigitizeSubFunctions();'>\n";
-				// button: remove geometry from database
-				if (isValidWfsConfIndex(wfsConf, d.get(i).wfs_conf)) {
-					listOfGeom += "\t\t\t<img src = '"+buttonDig_imgdir+buttonDig_removeDb_src+"' title='"+msgObj.buttonDig_removeDb_title+"' onclick=\"var deltrans = confirm('"+msgObj.messageConfirmDeleteGeomFromDb+"');if (deltrans) dbGeom('delete', "+i+")\">\n";
-				listOfGeom += "\t\t</td>\n\t\t<td style = 'color:blue;font-size:12px'>\n";
-				listOfGeom += "\t\t\t<div onmouseover='parent.mb_wfs_perform(\"over\",d.get("+i+"));' ";
-				listOfGeom += " onmouseout='parent.mb_wfs_perform(\"out\",d.get("+i+"))' ";
-				listOfGeom += " onclick='parent.mb_wfs_perform(\"click\",d.get("+i+"));' ";
-				var geomName = getName(d.get(i));
-				if (d.get(i).geomType == parent.geomType.polygon) {geomName += " ("+msgObj.messageDescriptionPolygon+")";}
-				else if (d.get(i).geomType == parent.geomType.line) {geomName += " ("+msgObj.messageDescriptionLine+")";}
-				else if (d.get(i).geomType == parent.geomType.point) {geomName += " ("+msgObj.messageDescriptionPoint+")";}
-				listOfGeom += ">" + geomName +"</div>\t\t</td>\n\t</tr>\n";
-	listOfGeom += "</table>\n";
-	parent.writeTag(mod_digitize_elName,"listOfGeometries",listOfGeom);
-// --- display (end) -----------------------------------------------------------------------------------------
-// --- wfs window (begin) -----------------------------------------------------------------------------------------
-// --- wfs window form check (begin) -----------------------------------------------------------------------------------------
-function formCorrect(doc, formId) {
-	var isCorrect = true;
-	var errorMessage = "";
-	var result;
-	var form = doc.getElementById(formId);
-	result = mandatoryFieldsNotEmpty(doc, form);
-	isCorrect = isCorrect && result.isCorrect;
-	errorMessage += result.errorMessage;
-	result = validBoxEntrySelected(form);
-	result = dataTypeIsCorrect(doc, form);
-	return {"isCorrect":isCorrect, "errorMessage":errorMessage};
-function validBoxEntrySelected(form){
-	for (var i = 0; i < form.childNodes.length && isCorrect; i++) {
-		if (form.childNodes[i].nodeName.toUpperCase() == "SELECT") {
-			if (parseInt(form.childNodes[i].selectedIndex) == 0) {
-				return {"isCorrect":false, "errorMessage":errorMessage};
-		else if (form.childNodes[i].hasChildNodes()) {
-			isCorrect = validBoxEntrySelected(form.childNodes[i]).isCorrect;
-	if (!isCorrect) {
-		errorMessage = msgObj.messageSelectAnOption + "\n";
-function mandatoryFieldsNotEmpty(doc, node){
-	nodeArray = doc.getElementsByName("mandatory");
-	for (var i = 0; i < nodeArray.length && isCorrect; i++) {
-		if (nodeArray[i].nodeName.toUpperCase() == "INPUT" && nodeArray[i].type == "hidden" && nodeArray[i].id.substr(0,10) == "mandatory_") {
-			var nodeId = nodeArray[i].id.substr(10);
-			if (nodeArray[i].value == "true") {
-				if (doc.getElementById(nodeId).value == "") {
-					isCorrect = false;
-					errorMessage += "'"+ doc.getElementById(nodeId).name +"': "+ msgObj.messageErrorFieldIsEmpty +"\n";
-function isInteger(str) {
-	if (str.match(/^\d*$/)) {
-		return true;
-	return false;
-function isFloat(str) {
-	if (isInteger(str)) {
-		return true;
-	if (str.match(/^\d+\.\d+$/)) {
-		return true;
-	return false;
-function replaceCommaByDecimalPoint(str) {
-	var patternString = ",";
-	var pattern = new RegExp(patternString);
-	while (str.match(pattern)) {
-		str = str.replace(pattern, ".");
-	return str;
-function dataTypeIsCorrect(doc, node){
-	nodeArray = doc.getElementsByName("datatype");
-	for (var i = 0; i < nodeArray.length ; i++) {
-		if (nodeArray[i].nodeName.toUpperCase() == "INPUT" && nodeArray[i].type == "hidden" && nodeArray[i].id.substr(0,9) == "datatype_") {
-			var nodeId = nodeArray[i].id.substr(9);
-			var nodeValue = doc.getElementById(nodeId).value;
-			if (nodeArray[i].value == "int") {
-				if (!isInteger(nodeValue)) {
-					errorMessage += "'"+doc.getElementById(nodeId).name+"': "+ msgObj.messageErrorNotAnInteger + "\n";
-			else if (nodeArray[i].value == "double") {
-				nodeValue = replaceCommaByDecimalPoint(nodeValue);
-				if (!isFloat(nodeValue)) {
-					errorMessage += "'"+doc.getElementById(nodeId).name+"': "+ msgObj.messageErrorNotAFloat + "\n";
-				else {
-					doc.getElementById(nodeId).value = nodeValue;
-// --- wfs window form check (end) -----------------------------------------------------------------------------------------
-function getAvailableWfsForGeom(geom, wfsConf) {
-	var wfsConfIndices = [];
-	for (var attr in wfsConf) {
-		var isTrans = (wfsConf[attr]['wfs_transaction'] != "");
-		if (!isTrans) {
-			continue;
-		if (isValidWfsConfIndex(wfsConf, parseInt(geom.wfs_conf))) {
-			if (parseInt(geom.wfs_conf) == parseInt(attr)) {
-				wfsConfIndices.push(attr);
-		else {
-			for (var elementIndex = 0; elementIndex < wfsConf[attr]['element'].length ; elementIndex++) {
-				var isGeomColumn = (parseInt(wfsConf[attr]['element'][elementIndex]['f_geom']) == 1);
-				if (isGeomColumn) {
-					var isMultiPolygon = (geom.geomType == parent.geomType.polygon && wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiPolygonPropertyType');
-					var isPolygon = (geom.geomType == parent.geomType.polygon && geom.count() == 1 && wfsConf[attr]['element'][elementIndex]['element_type'] == 'PolygonPropertyType');
-					var isMultiLine = (geom.geomType == parent.geomType.line && wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiLineStringPropertyType');
-					var isLine = (geom.geomType == parent.geomType.line && geom.count() == 1 && wfsConf[attr]['element'][elementIndex]['element_type'] == 'LineStringPropertyType');
-					var isPoint = (geom.geomType == parent.geomType.point && wfsConf[attr]['element'][elementIndex]['element_type'] == 'PointPropertyType');
-//					alert(isMultiPolygon + " " + isPolygon + " " + isMultiLine + " " + isLine + " " + isPoint);
-					if (isMultiPolygon || isPolygon || isMultiLine || isLine || isPoint || wfsConf[attr]['element'][elementIndex]['element_type'] == 'GeometryAssociationType') {
-	return wfsConfIndices;
-function wfsExistsForGeom(geom, wfsConf) {
-	wfsConfIndices = getAvailableWfsForGeom(geom, wfsConf);
-//	alert(wfsConfIndices.join(","));
-	if (wfsConfIndices.length > 0) {
-		return true;
-	return false;
-function showWfsKml (geometryIndex) {
-	wfsKmlWindow = open("", "wfsattributes", "width="+wfsWindowWidth+", height="+wfsWindowHeight+", resizable, dependent=yes, scrollbars=yes");
-	wfsKmlWindow.document.open("text/html");
-	wfsKmlWindow.document.writeln("<html><head></head><body><div id='linkToKml'></div><div id='elementForm'></div></body></html>");
-	wfsKmlWindow.document.close();
-	str = "<form id = 'wmsKmlForm' onsubmit='return false;'><table>";
-	var properties = d.get(geometryIndex).e;
-	var propertyCount = properties.count();
-	for (var i = 0; i < propertyCount; i++) {
-		var key = properties.getName(i);
-		var value = properties.getValue(i);
-		var expr = /Mapbender:/;
-		if (!key.match(expr)) {
-			str += "\t\t<tr>\n";
-			str += "\t\t\t<td>\n\t\t\t\t<div>" + key + "</div>\n\t\t\t</td>\n";
-			str += "\t\t\t<td>\n";
-			str += "\t\t\t\t<input id = 'wmskml_" + i + "' name='" + key + "' type='text' size=20 value = '" + value + "'>\n";
-			str += "\t\t\t</td>\n\t\t</tr>\n";
-	var updateOnClickText = "this.disabled=true;window.opener.updateKmlInDb("+geometryIndex+", 'update');";
-	var deleteOnClickText = "var deltrans = confirm('This geometry will be removed from the KML.');";
-	deleteOnClickText += "if (deltrans){";
-	deleteOnClickText += "this.disabled=true;window.opener.updateKmlInDb("+geometryIndex+", 'delete')}";
-	str += "\t\t\t<td><input type='button' name='updateButton' value='Update' onclick=\""+updateOnClickText+"\"/></td>\n";
-// delete button not yet implemented
-//	str += "\t\t\t<td><input type='button' name='deleteButton' value='Delete' onclick=\""+deleteOnClickText+"\"/></td>\n";
-	str += "\t\t\t<td><input type='button' name='abortButton' value='Abort' onclick=\"window.close();\" /></td>\n";
-	str += "\t\t</tr>\n";
-	str += "\t</table>\n";
-	str += "</form>\n";
-	wfsKmlWindow.document.getElementById("elementForm").innerHTML = str;
-// this method opens a new window and displays the attributes in wfs_conf
-function showWfs(geometryIndex) {
-	wfsWindow = open("", "wfsattributes", "width="+wfsWindowWidth+", height="+wfsWindowHeight+", resizable, dependent=yes, scrollbars=yes");
-	wfsWindow.document.open("text/html");
-	var str = "";
-	var strStyle = "";
-	var defaultIndex = -1;
-	str += "<form id='wfs'>\n";
-	// 1. add select box
-	var onChangeText = "document.getElementById('elementForm').innerHTML = ";
-	onChangeText += "window.opener.buildElementForm(this.value , " + geometryIndex + ");";
-	onChangeText += "window.opener.setWfsWindowStyle(this.value);";
-	str += "\t<select name='wfs' size='" + wfsConf.length + "'";
-	str += " onChange=\""+ onChangeText +"\"";
-	str += ">\n\t\t";
-	var wfsConfIndices = getAvailableWfsForGeom(d.get(geometryIndex), wfsConf);
-	var selected = false;
-	for (var i = 0; i < wfsConfIndices.length ; i++) {
-		str += "<option value='" + wfsConfIndices[i] + "'";
-		if (!selected) {
-			str += " selected";
-			selected = true;
-			defaultIndex = parseInt(wfsConfIndices[i]);
-		str += ">" + wfsConf[wfsConfIndices[i]]['wfs_conf_abstract'];
-		str += "</option>\n\t\t";
-	str += "</select>\n\t\t</form>\n\t";
-	str += "<div id='elementForm'>\n</div>";
-	if (defaultIndex != -1) {
-		wfsWindow.document.writeln("<html><head><style type='text/css'>"+wfsConf[defaultIndex]['g_style']+"</style></head><body></body></html>");
-		wfsWindow.document.write(str);
-		wfsWindow.document.close();
-		wfsWindow.document.getElementById("elementForm").innerHTML = buildElementForm(defaultIndex, geometryIndex);
-	else {
-		wfsWindow.document.writeln("<html><head><style type='text/css'></style></head><body></body></html>");
-function setWfsWindowStyle(wfsConfIndex) {
-	wfsWindow.document.getElementsByTagName("style")[0].innerHTML = wfsConf[wfsConfIndex]['g_style'];
-// returns a form with the elements of a selected wfs
-// (if the original wfs is the selected wfs, the values are set too)
-function buildElementForm(wfsConfIndex, memberIndex){
-	var featureTypeMismatch = false;
-	if (parseInt(d.get(memberIndex).wfs_conf) != parseInt(wfsConfIndex)) {featureTypeMismatch = true;}
-	var str = "";
-	var hasGeometryColumn = false;
-	var featureTypeArray = wfsConf[wfsConfIndex];
-	var memberElements;
-	var fid = false;
-	if (!featureTypeMismatch) {
-		memberElements = d.get(memberIndex).e;
-		fid = memberElements.getElementValueByName('fid');
-	if (typeof(featureTypeArray["element"]) !== "undefined") {
-		str += "<form id='"+featureTypeElementFormId+"'>\n\t<table>\n";
-		featureTypeElementArray = featureTypeArray["element"];
-		// 2. add rows to form
-		for (var i = 0 ; i < featureTypeElementArray.length ; i ++) {
-			var featureTypeElement = featureTypeElementArray[i];
-			var elementName = featureTypeElement['element_name'];
-			var elementType = featureTypeElement['element_type'];
-			var isEditable = (parseInt(featureTypeElement['f_edit']) == 1);
-			var isMandatory = (parseInt(featureTypeElement['f_mandatory']) == 1);
-			var isGeomColumn = (parseInt(featureTypeElement['f_geom']) == 1);
-			var elementLabelExists = (featureTypeElement['f_label'] != "");
-			var elementLabel = "";
-			if (elementLabelExists) {
-				elementLabel = featureTypeElement['f_label'];
-			var elementLabelStyle = featureTypeElement['f_label_id'];
-			if (!isGeomColumn) {
-				if (isEditable) {
-					str += "\t\t\t<td>\n\t\t\t\t<div class = '"+elementLabelStyle+"''>" + elementLabel + "</div>\n\t\t\t</td>\n";
-					var elementValue = "";
-						for (var j = 0 ; j < memberElements.count() ; j ++) {
-							if (memberElements.getName(j) == featureTypeElement['element_name']) {
-								elementValue = memberElements.getValue(j);
-					var formElementHtml = featureTypeElement['f_form_element_html'];
-					if (!formElementHtml || !formElementHtml.match(/<select/)) {
-						str += "\t\t\t\t<input id = 'datatype_" + elementName + "' name='datatype' type='hidden' value = '" + elementType + "'>\n";
-						str += "\t\t\t\t<input id = 'mandatory_" + elementName + "' name='mandatory' type='hidden' value = '" + isMandatory + "'>\n";
-						str += "\t\t\t\t<input id = '" + elementName + "' name='" + elementLabel + "' type='text' class = '"+featureTypeElement['f_style_id']+"' size=20 value = '" + elementValue + "'>\n";
-					else {
-							while (formElementHtml.match(/\\/)) {
-								formElementHtml = formElementHtml.replace(/\\/, "");
-//							alert(formElementHtml);
-							// preselect the correct entry of the box
-							var patternString = "option value='"+elementValue+"'";
-							formElementHtml = formElementHtml.replace(pattern, patternString+" selected");
-							str += formElementHtml;
-			else {
-				hasGeometryColumn = true;
-		// 3. add buttons "save", "update", "delete"
-		str += "</table><table>";
-		var isTransactional = (featureTypeArray['wfs_transaction']);
-		if (isTransactional) {
-			var options = ["save", "update", "delete", "abort"];
-			for (var i = 0 ; i < options.length ; i++) {
-				var onClickText = "this.disabled=true;var result = window.opener.formCorrect(document, '"+featureTypeElementFormId+"');";
-				onClickText += 	"if (result.isCorrect) {";
-				onClickText += 		"window.opener.dbGeom('"+options[i]+"', "+memberIndex+"); ";
-//				onClickText +=      "window.close();";
-				onClickText += 	"}";
-				onClickText += 	"else {";
-				onClickText += 		"alert(result.errorMessage);this.disabled=false;"
-				if (options[i] == "save" && hasGeometryColumn && (!fid || showSaveButtonForExistingGeometries)) {
-					str += "\t\t\t<td><input type='button' name='saveButton' value='"+msgObj.buttonLabelSaveGeometry+"' onclick=\""+onClickText+"\" /></td>\n";
-				if (!featureTypeMismatch && fid) {
-					if (options[i] == "update" && hasGeometryColumn) {
-						str += "\t\t\t<td><input type='button' name='updateButton' value='"+msgObj.buttonLabelUpdateGeometry+"' onclick=\""+onClickText+"\"/></td>\n";
-					if (options[i] == "delete"){
-						var deleteOnClickText = "var deltrans = confirm('"+msgObj.messageConfirmDeleteGeomFromDb+"');";
-						deleteOnClickText += onClickText + "}";
-						str += "\t\t\t<td><input type='button' name='deleteButton' value='"+msgObj.buttonLabelDeleteGeometry+"' onclick=\""+deleteOnClickText+"\"/></td>\n";
-				if (options[i] == "abort") {
-					str += "\t\t\t<td><input type='button' name='abortButton' value='"+msgObj.buttonLabelAbort+"' onclick=\"window.close();\" /></td>\n";
-		str += "<input type='hidden' id='fid' value='"+fid+"'>";
-//			str += "<input type='text' name='mb_wfs_conf'>";
-	return str;
-function dbGeom(type,m) {
-	if (typeof(wfsWindow) != 'undefined' && !wfsWindow.closed) {
-		d.get(m).wfs_conf = parseInt(wfsWindow.document.forms[0].wfs.options[wfsWindow.document.forms[0].wfs.selectedIndex].value);
-		d.get(m).e = new parent.Wfs_element();
-	else {
-	var myconf = wfsConf[d.get(m).wfs_conf];
-	var mapObjInd = parent.getMapObjIndexByName(mod_digitize_target);
-	if (myconf['featuretype_srs'] != parent.mb_mapObj[mapObjInd].epsg) {
-		alert(msgObj.errorMessageEpsgMismatch + parent.mb_mapObj[mapObjInd].epsg + " / "+ myconf['featuretype_srs']);
-	else {
-		var fid = false;
-			myform = wfsWindow.document.getElementById(featureTypeElementFormId);
-			for (var i=0; i<myform.length; i++){
-				if (myform.elements[i].id == "fid") {
-					fid = myform.elements[i].value;
-					d.get(m).e.setElement('fid', fid);
-				else if (myform.elements[i].type == 'text' ){
-					if (myform.elements[i].id) {
-						d.get(m).e.setElement(myform.elements[i].id, myform.elements[i].value);
-					else {
-						errorMessage = msgObj.messageErrorFormEvaluation;
-				// selectbox
-				else if (typeof(myform.elements[i].selectedIndex) == 'number') {
-						d.get(m).e.setElement(myform.elements[i].id, myform.elements[i].options[myform.elements[i].selectedIndex].value);
-					else {
-		else {
-			fid = d.get(m).e.getElementValueByName('fid');
-		str = parent.get_wfs_str(myconf, d, m, type, fid);
-		parent.mb_ajax_post("../extensions/geom2wfst.php", {'filter':str,'url':myconf['wfs_transaction'],'featuretype_name':myconf['featuretype_name'],'wfs_conf_id':wfsConf[d.get(m).wfs_conf]['wfs_conf_id']}, function(json,status){
-			var result = eval('('+json+')');
-			var response = result.response;
-			var fid = result.fid;
-			wfsSubWrite(m, type, status, response, fid);
-function wfsSubWrite(m, type, status, response, fid) {
-	if (type == 'save' && fid) {
-		d.get(m).e.setElement("fid", fid);
-	if (type == 'delete') {
-		parent.mb_disableThisButton(mod_digitizeEvent);
-		d.del(m);
-	parent.mb_execWfsWriteSubFunctions();
-	if (status == "success" && response == "success") {
-		var wfsWriteMessage = msgObj.messageSuccessWfsWrite;
-	else {
-		var wfsWriteMessage = msgObj.messageErrorWfsWrite;
-		wfsWindow.alert(wfsWriteMessage);
-		window.setTimeout("wfsWindow.close()",0);
-	else {
-		alert(wfsWriteMessage);
-function getMultiGeometryIdsByPlacemarkId (placemarkId) {
-	var multiGeometryIdArray = [];
-		var currentPlacemarkId = d.get(i).e.getElementValueByName("Mapbender:placemarkId");
-		if (currentPlacemarkId && currentPlacemarkId == placemarkId) {
-			multiGeometryIdArray.push(i);
-	return multiGeometryIdArray;
-function updateKmlInDb (geometryIndex, command) {
-	var placemarkId = properties.getElementValueByName("Mapbender:placemarkId");
-	var multiGeometryIdArray = getMultiGeometryIdsByPlacemarkId(placemarkId);
-	if (typeof(wfsKmlWindow) != 'undefined' && !wfsKmlWindow.closed) {
-		// update properties from form
-		myform = wfsKmlWindow.document.getElementById("wmsKmlForm");
-		for (var i=0; i < myform.length; i++){
-			if (myform.elements[i].type == 'text' ){
-					var key = myform.elements[i].name;
-					var value = myform.elements[i].value;
-					// update all geometries with the same placemark id
-					for (var j = 0; j < multiGeometryIdArray.length; j++) {
-						var currentProperties = d.get(j).e;
-						currentProperties.setElement(key, value);
-		var kmlId = properties.getElementValueByName("Mapbender:id");
-		parent.mb_ajax_post("../php/mod_updateKmlInDb.php", {command:command, kmlId:kmlId, placemarkId:placemarkId, geoJSON:d.placemarkToString(placemarkId)}, function(obj, status) {
-			if (obj === "1") {
-				wfsKmlWindow.alert("KML updated.");
-				var link = wfsKmlWindow.document.createElement("a");
-				link.href = "../php/mod_displayKML.php?kmlId=" + kmlId;
-				link.target = "_blank";
-				link.innerHTML = "KML";
-				wfsKmlWindow.document.getElementById('elementForm').innerHTML = "";
-				wfsKmlWindow.document.getElementById('linkToKml').appendChild(link);
-			else {
-				wfsKmlWindow.alert("Error, KML could not be updated. Check your error log.");
-function getMessages() {
-	parent.mb_ajax_json("../php/mod_digitize_messages.php", function(obj, status) {
-		msgObj = obj;
-		applyMessages();
-function applyMessages() {
-	updateMeasureTag();
-	updateListOfGeometries();
-	</script>
-	</head>
-	<body onload="registerFunctions();displayButtons();">
-		<table cellpadding='0' cellspacing='0' align = center><tr><td><div id='digButtons'></div></td></tr></table>
-		<div id = 'listOfGeometries'></div>
-	</body>
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/mod_digitize_tab.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+session_start();
+import_request_variables("PG");
+require_once("../php/mb_validateSession.php");
+require_once("../../conf/mapbender.conf");
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db(DB,$con);
+$gui_id = $_SESSION["mb_user_gui"];
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>Digitize</title>
+<?php
+$digitize_conf_filename = "digitize_default.conf";
+include '../include/dyn_css.php';
+$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'digitize' AND fkey_gui_id = $1";
+$v = array($gui_id);
+$t = array('s');
+$res = db_prep_query($sql, $v, $t);
+$cnt = 0;
+while($row = db_fetch_array($res)){
+	$e_src = $row["e_src"];
+	$e_target = explode(",",$row["e_target"]);
+	$cnt++;
+if($cnt > 1) echo "alert('digitize_button: ID not unique!');";
+echo "<script language='JavaScript'>";
+echo "var mod_digitize_target = '".$e_target[0]."';";
+echo "var mod_digitize_frame = '".$e_target[1]."';";
+include("../../conf/" . $digitize_conf_filename);
+var wfsWindow;
+var dwin = null;
+var wfsConf = [];
+var d = new parent.GeometryArray();
+var mod_digitize_width;
+var mod_digitize_height;
+var mod_digitizeEvent = false;
+var nonTransactionalHighlight;
+var button_point = "Point";
+var button_line = "Line";
+var button_polygon = "Polygon";
+var button_move = "dragBasePoint";
+var button_insert = "setBasePoint";
+var button_delete = "delBasePoint";
+var button_clear = "clear";
+var button_combine = "combine";
+var digitizeDivTag;
+var GeometryArray = parent.GeometryArray;
+var MultiGeometry = parent.MultiGeometry;
+var Geometry = parent.Geometry;
+var Point = parent.Point;
+var geomType = parent.geomType;
+var msgObj;
+var featureTypeElementFormId = "featureTypeElementForm";
+try {if(mod_digitize_elName){}}catch(e) {mod_digitize_elName = "digitize";}
+ * Append geometries from KML when KML has been loaded
+function appendGeometryArrayFromKML () {
+	try {
+		parent.kmlHasLoaded.register(function(properties){
+			d = parent.geoJsonToGeometryArray(properties);
+			executeDigitizeSubFunctions();
+	catch (e) {
+		var exc = new parent.Mb_warning(e);
+// --- polygon, line, point insertion (begin) ----------------------------------------------------------------------------------------------
+function appendGeometryArray(obj) {
+	executeDigitizePreFunctions();
+	for (i=0; i<obj.count(); i++) {
+		d.addCopy(obj.get(i));
+function mod_digitize_go(e){
+	parent.mb_registerGML(mod_digitize_target,d);
+	// ie workaround
+	if (e == undefined) {
+		e = parent.frames[mod_digitize_target].event;
+	if (e) {
+		// track mouse position
+		parent.mb_getMousePos(e, mod_digitize_target);
+		var currentPos = new parent.Point(parent.clickX, parent.clickY);
+		s.check(currentPos);
+	else {
+//		s.clean();
+	var el = parent.frames[mod_digitize_target].document;
+	el.onmousedown = mod_digitize_start;
+function mod_digitize_timeout(){
+	el.onmousedown = null;
+	el.onmouseup = null;
+	el.onmousemove = null;
+function mod_digitize_start(e){
+	// check if a proper geometry is selected
+	if (d.getGeometry(-1,-1).isComplete() || d.count() == 0){
+		if (mod_digitizeEvent != false) {
+			alert(msgObj.errorMessageNoGeometrySelected);
+		return false;
+	var realWorldPos;
+	if (s.isSnapped()) {
+		realWorldPos = s.getSnappedPoint();
+		s.clean();
+	else {
+		parent.mb_getMousePos(e,mod_digitize_target);
+		realWorldPos = parent.mapToReal(mod_digitize_target,new parent.Point(parent.clickX,parent.clickY));
+	if (d.get(-1).geomType == parent.geomType.polygon && d.getGeometry(-1,-1).count() > 1 && d.getGeometry(-1,-1).get(0).equals(realWorldPos)) {
+		// close the polygon
+		d.close();
+		parent.mb_disableThisButton(button_polygon);
+		return true;
+	else if (d.get(-1).geomType == parent.geomType.line && d.getGeometry(-1,-1).count() > 1 && d.getGeometry(-1,-1).get(-1).equals(realWorldPos)) {
+		// close the line
+		d.close();
+		parent.mb_disableThisButton(button_line);
+		return true;
+	else {
+		// set the calculated real world position as point of the geometry
+		d.getGeometry(-1,-1).addPoint(realWorldPos);
+		if(d.get(-1).geomType == parent.geomType.point){
+			d.close();
+			parent.mb_disableThisButton(button_point);
+			return true;
+		// add first point of polygon to snapping list (if three points have been inserted).
+		else if (d.get(-1).geomType == parent.geomType.polygon && d.getGeometry(-1,-1).count() == 3) {
+			s.add(d.getPoint(-1, -1, 0));
+		// add last point of line to snapping list (if at least two points have been inserted).
+		else if (d.get(-1).geomType == parent.geomType.line && d.getGeometry(-1,-1).count() >= 2) {
+			if (mod_digitizeEvent != button_move) {
+				s.store(d);
+			s.add(d.getPoint(-1, -1, -1));
+	return true;
+// --- basepoint handling (begin) -----------------------------------------------------------------------------------------
+var basepointObject = false;
+var basepointMemberIndex = null;
+var basepointGeometryIndex = null;
+var basepointPointIndex = null;
+var basepointDragActive = false;
+function handleBasepoint(obj,memberIndex,geometryIndex,pointIndex){
+	if(!(mod_digitizeEvent == button_move || mod_digitizeEvent == button_insert || mod_digitizeEvent == button_delete)){ return false; }
+	basepointObject = obj;
+	basepointMemberIndex = memberIndex;
+	basepointGeometryIndex = geometryIndex;
+	basepointPointIndex = pointIndex;
+	if(mod_digitizeEvent == button_move){
+		mod_digitize_timeout();
+		basepointObject.style.cursor = 'move';
+		basepointObject.onmousedown = parent.window.frames[mod_digitize_elName].selectBasepoint;
+	if(mod_digitizeEvent == button_delete){
+		basepointObject.style.cursor = 'crosshair';
+		basepointObject.onmousedown = parent.window.frames[mod_digitize_elName].deleteBasepoint;
+function convertLinepointToBasepoint(obj, memberIndex, geomIndex, pointIndex){
+	if(!(mod_digitizeEvent == button_insert)){ return false; }
+	if(mod_digitizeEvent == button_insert){
+		obj.style.cursor = 'crosshair';
+		obj.onclick = insertBasepoint;
+		basepointGeometryIndex = geomIndex;
+function insertBasepoint(e){
+	var i = basepointMemberIndex;
+	var j = basepointGeometryIndex;
+	var k = basepointPointIndex;
+	var pos = parent.makeClickPos2RealWorldPos(mod_digitize_target,parent.clickX, parent.clickY);
+	var p = new parent.Point(pos[0], pos[1]);
+	d.getGeometry(i,j).addPointAtIndex(p, k);
+function deleteBasepoint(){
+	d.delAllPointsLike(d.getPoint(i,j,k));
+function selectBasepoint(e){
+	if(!basepointDragActive && mod_digitizeEvent == button_move){
+		basepointDragActive = true;
+		s.store(d, d.getPoint(basepointMemberIndex, basepointGeometryIndex, basepointPointIndex));
+		// replace basepoint by transparent blob
+		basepointObject.style.width = mod_digitize_width;
+		basepointObject.style.height = mod_digitize_height;
+		basepointObject.style.left = 0;
+		basepointObject.style.top = 0;
+		if (parent.ie) {
+			// ie cannot handle backgroundColor = 'transparent'
+			basepointObject.style.background = "url(../img/transparent.gif)";
+		else{
+			basepointObject.style.backgroundColor = 'transparent';
+		basepointObject.onmouseup = releaseBasepoint;
+		basepointObject.onmousemove = dragBasepoint;
+function dragBasepoint(e){
+	if(basepointDragActive){
+		var res = s.check(currentPos);
+function updateAllPointsOfNonTransactionalLike(oldP, newP){
+	for (var i = 0; i < d.count(); i++) {
+		if (isTransactional(d.get(i))) {
+			d.get(i).updateAllPointsLike(oldP, newP);
+function releaseBasepoint(e){
+	basepointDragActive = false;
+	var basepointDragEnd = new parent.Point(parent.clickX, parent.clickY);
+	basepointObject.onmousedown = null;
+	var p = parent.makeClickPos2RealWorldPos(mod_digitize_target, basepointDragEnd.x, basepointDragEnd.y);
+	var oldPoint = parent.cloneObject(d.getPoint(i,j,k));
+		var snappedPoint = parent.cloneObject(s.getSnappedPoint());
+		if (!nonTransactionalEditable) {
+			updateAllPointsOfNonTransactionalLike(oldPoint, snappedPoint);
+		else {
+			d.updateAllPointsLike(oldPoint, snappedPoint);
+		s.clean();
+	else {
+		var newPoint = new parent.Point(p[0],p[1]);
+			updateAllPointsOfNonTransactionalLike(oldPoint, newPoint);
+		else {
+			d.updateAllPointsLike(oldPoint, newPoint);
+	basepointMemberIndex = null;
+	basepointGeometryIndex = null;
+	basepointPointIndex = null;
+// --- basepoint handling (end) -----------------------------------------------------------------------------------------
+// --- registered functions (begin) ---------------------------------------------------------------------------------------
+function registerDigitizePreFunctions(stringFunction){
+	mod_digitizePreFunctions[mod_digitizePreFunctions.length] = stringFunction;
+function registerDigitizeSubFunctions(stringFunction){
+	mod_digitizeSubFunctions[mod_digitizeSubFunctions.length] = stringFunction;
+function executeDigitizeSubFunctions(){
+//	console.profile();
+	for(var i=0; i<mod_digitizeSubFunctions.length; i++){
+		eval(mod_digitizeSubFunctions[i]);
+//	console.profileEnd();
+function executeDigitizePreFunctions(){
+	for(var i=0; i<mod_digitizePreFunctions.length; i++){
+		eval(mod_digitizePreFunctions[i]);
+function registerFunctions(){
+	mod_digitizePreFunctions = [];
+	mod_digitizeSubFunctions = [];
+	registerDigitizePreFunctions("updateExtent()");
+	registerDigitizePreFunctions("drawDashedLine()");
+	registerDigitizeSubFunctions("updateListOfGeometries()");
+	registerDigitizeSubFunctions("drawDashedLine()");
+	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].setStyleForTargetFrame()");
+	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].checkDigitizeTag()");
+	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].initialiseSnapping()");
+	parent.mb_registerL10nFunctions("window.frames['"+ mod_digitize_elName + "'].getMessages()");
+//	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].appendGeometryArrayFromKML()");
+		parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].initialiseHighlight()");
+	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].initialiseMeasure()");
+	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].getMessages()");
+	parent.mb_registerSubFunctions("window.frames['" + mod_digitize_elName + "'].updateExtent()");
+	if(spatialRequestResultToDigitize==1){
+	parent.mb_registerWfsReadSubFunctions(function(geom){parent.tab_open(mod_digitize_elName);parent.window.frames[mod_digitize_elName].appendGeometryArray(geom);});
+	parent.mb_registerWfsWriteSubFunctions(function(){parent.zoom(mod_digitize_target, true, 0.999);});
+function checkDigitizeTag(){
+	var digitizeTagName = "digitize";
+	var digitizeTagStyle = {"position":"absolute", "top":"0px", "left":"0px", "z-index":digitizeTransactionalZIndex, "font-size":"10px"};
+	digitizeDivTag = new parent.DivTag(digitizeTagName, mod_digitize_target, digitizeTagStyle);
+	parent.mb_registerPanSubElement(digitizeTagName);
+	parent.mb_registerSubFunctions("window.frames['"+ mod_digitize_elName + "'].drawDashedLine()");
+function setStyleForTargetFrame(){
+	var cssLink = parent.window.frames[mod_digitize_target].document.createElement("link");
+	cssLink.setAttribute("href", cssUrl);
+	cssLink.setAttribute("type", "text/css");
+	cssLink.setAttribute("rel", "stylesheet");
+	var cssTmp = parent.window.frames[mod_digitize_target].document.getElementsByTagName("head")[0];
+	cssTmp.appendChild(cssLink);
+function initialiseSnapping(){
+	s = new parent.Snapping(mod_digitize_target, snappingTolerance, snappingColor, snappingHighlightZIndex);
+function initialiseHighlight(){
+	nonTransactionalHighlight = new parent.Highlight(new Array(mod_digitize_target), "nonTransactional", {"position":"absolute", "top":"0px", "left":"0px", "z-index":digitizeNonTransactionalZIndex}, nonTransactionalLineWidth);
+function initialiseMeasure(){
+	measureDivTag = new parent.DivTag(measureTagName, measureTagTarget, measureTagStyle);
+	parent.mb_registerSubFunctions("window.frames['"+ mod_digitize_elName + "'].updateMeasureTag()");
+// --- registered functions (end) -----------------------------------------------------------------------------------------
+function updateMeasureTag () {
+	if (d.count() > 0 ) {
+		if (d.get(-1).count() > 0) {
+			if (d.getGeometry(-1, -1).count() > 0) {
+				if (mod_digitizeEvent == button_line || mod_digitizeEvent == button_polygon) {
+					var measureString = "";
+					measureString += msgObj.measureTagLabelCurrent + d.getGeometry(-1, -1).getCurrentDist(measureNumberOfDigits) + "<br>";
+					measureString += msgObj.measureTagLabelTotal + d.getGeometry(-1, -1).getTotalDist(measureNumberOfDigits);
+					measureDivTag.write(measureString);
+					return true;
+	measureDivTag.clean();
+// --- button handling (begin) --------------------------------------------------------------------------------------------
+function displayButtons(){
+	for (var i = 0 ; i < buttonDig_id.length ; i ++) {
+		if (parseInt(buttonDig_on[i])==1) {
+			var divTag = document.createElement("div");
+			divTag.setAttribute("id", "div_" + buttonDig_id[i]);
+// FIREFOX
+			document.getElementById("digButtons").appendChild(divTag);
+//IE WORKAROUND, WORKS ALSO FOR FIREFOX
+			var tagContent = "<div style='position:absolute; top:"+buttonDig_y[i]+"px; left:"+buttonDig_x[i]+"px;'><img name=\""+buttonDig_id[i]+"\" onmouseover=\"parent.mb_regButton_frame('initDigButton', mod_digitize_elName, "+i+");\" id=\""+buttonDig_id[i]+"\" title=\""+buttonDig_title_off[i]+"\" src=\""+buttonDig_imgdir+buttonDig_src[i]+"\"></div>";
+			parent.writeTag(mod_digitize_elName,"div_" + buttonDig_id[i],tagContent);
+function initDigButton(ind, pos){
+	parent.mb_button[ind] = document.getElementById(buttonDig_id[pos]);
+	parent.mb_button[ind].img_over = buttonDig_imgdir + buttonDig_src[pos].replace(/_off/,"_over");
+	parent.mb_button[ind].img_on = buttonDig_imgdir + buttonDig_src[pos].replace(/_off/,"_on");
+	parent.mb_button[ind].img_off = buttonDig_imgdir + buttonDig_src[pos];
+	parent.mb_button[ind].title_on = buttonDig_title_on[pos];
+	parent.mb_button[ind].title_off = buttonDig_title_off[pos];
+	parent.mb_button[ind].status = 0;
+	parent.mb_button[ind].elName = buttonDig_id[pos];
+	parent.mb_button[ind].fName = "";
+	parent.mb_button[ind].go = new Function ("digitizeEnable(parent.mb_button["+ind+"])");
+	parent.mb_button[ind].stop = new Function ("digitizeDisable(parent.mb_button["+ind+"])");
+function digitizeEnable(obj) {
+	if (obj.id == button_move || obj.id == button_insert || obj.id == button_delete) {
+		mod_digitizeEvent = obj.id;
+	else if (obj.id == button_point || obj.id == button_line || obj.id == button_polygon || obj.id == button_clear || obj.id == button_combine){
+		el.onmousemove = mod_digitize_go;
+		if (mod_digitizeEvent == button_point || mod_digitizeEvent == button_line || mod_digitizeEvent == button_polygon || mod_digitizeEvent == button_insert ) {
+			s.store(d);
+		obj.title = obj.title_on;
+		if (obj.id == button_point) {
+			if (d.count() > 0 && d.get(-1).count() > 0 && !d.get(-1).get(-1).isComplete()) {
+				if (d.get(-1).geomType != parent.geomType.point) {
+					d.close();
+				else {
+			if (d.count() == 0 || (d.count() > 0 && d.get(-1).count() > 0 && d.get(-1).get(-1).isComplete())) {
+				d.addMember(parent.geomType.point);
+				d.get(-1).addGeometry();
+			else {
+// delete existing line or polygon
+				d.del(-1);
+		else if (obj.id == button_polygon) {
+				if (d.get(-1).geomType != parent.geomType.polygon) {
+					d.close();
+				else {
+				// new geometry
+				d.addMember(parent.geomType.polygon);
+			else {
+// continue a line as a polygon
+					var geometryTemplate = parent.cloneObject(d.get(-1));
+					d.del(-1);
+					for (var i = 0; i < geometryTemplate.count(); i++) {
+						for (var j = 0; j < geometryTemplate.get(i).count(); j++) {
+							d.get(-1).get(-1).addPoint(geometryTemplate.get(i).get(j));
+		else if (obj.id == button_line) {
+				if (d.get(-1).geomType != parent.geomType.line) {
+					d.close();
+				else {
+				d.addMember(parent.geomType.line);
+			else {
+// continue a polygon as a line
+					d.del(-1);
+		else if (obj.id == button_clear) {
+			var clear = confirm(msgObj.messageConfirmDeleteAllGeomFromList);
+			if (clear) {
+				d = new parent.GeometryArray();
+				parent.mb_disableThisButton(button_clear);
+		else if (obj.id == button_combine) {
+//			d.combineToMultiGeometry();
+//			prompt('', d.toJSONString());
+//			parent.mb_ajax_post("../php/jsonTest.php", {json:d.toJSONString()}, function(test, status) {
+//				alert(test);
+			parent.mb_disableThisButton(button_combine);
+function digitizeDisable(obj) {
+	if (obj.id == button_point || obj.id == button_line || obj.id == button_polygon){
+		obj.title = obj.title_off;
+		if (d.get(-1).get(-1).count() == 0) {
+			d.delGeometry(-1,-1);
+	mod_digitizeEvent = false;
+// --- button handling (end) ----------------------------------------------------------------------------------------------
+// --- display (begin) -----------------------------------------------------------------------------------------
+function updateExtent() {
+	var anInd = parent.getMapObjIndexByName(mod_digitize_target);
+	var change = false;
+	if (typeof(mod_digitize_width) == 'undefined' || mod_digitize_width != parent.mb_mapObj[anInd].width) {
+		mod_digitize_width = parent.mb_mapObj[anInd].width;
+		change = true;
+	if (typeof(mod_digitize_height) == 'undefined' || mod_digitize_height != parent.mb_mapObj[anInd].height) {
+		mod_digitize_height = parent.mb_mapObj[anInd].height;
+		change = true;
+	if (typeof(mod_digitize_epsg) == 'undefined' || mod_digitize_epsg != parent.mb_mapObj[anInd].epsg) {
+		mod_digitize_epsg = parent.mb_mapObj[anInd].epsg;
+		change = true;
+//	if (change) {
+//		drawDashedLine();
+function drawDashedLine(){
+		nonTransactionalHighlight.clean();
+	var smPArray = [];
+	smPArray[smPArray.length] = "<div class='t_img'>"
+			+ "<img src='"+parent.mb_trans.src+"' width='"+mod_digitize_width+"' height='0'></div>"
+			+ "<div class='t_img'>"
+			+ "<img src='"+parent.mb_trans.src+"' width='0' height='"+mod_digitize_height+"'></div>";
+	for(var i=0, lenGeomArray = d.count(); i < lenGeomArray; i++){
+		var currentGeomArray = d.get(i);
+		if (!nonTransactionalEditable && !isTransactional(currentGeomArray)) {
+			nonTransactionalHighlight.add(currentGeomArray, nonTransactionalColor);
+		else {
+			for(var j=0, lenGeom = currentGeomArray.count(); j < lenGeom ; j++){
+				var currentGeometry = d.getGeometry(i,j);
+				for(var k = 0, lenPoint = currentGeometry.count(); k < lenPoint; k++){
+					var currentPoint = d.getPoint(i,j,k);
+					var pos = parent.makeRealWorld2mapPos(mod_digitize_target, currentPoint.x, currentPoint.y);
+					if (!currentGeometry.isComplete() &&
+						( (k == 0 && currentGeomArray.geomType == parent.geomType.polygon) || (k == currentGeometry.count()-1 && currentGeomArray.geomType == parent.geomType.line))) {
+						smPArray[smPArray.length] = "<div class='bp' style='top:"+
+							(pos[1]-2)+"px;left:"+(pos[0]-2)+"px;z-index:"+
+							digitizeTransactionalZIndex+";background-color:"+linepointColor+"'";
+					else {
+						smPArray[smPArray.length] = "<div class='bp' style='top:"+(pos[1]-2)+"px;left:"+(pos[0]-2)+"px;z-index:"+digitizeTransactionalZIndex+";'";
+					if(j==0 && currentGeomArray.geomType == parent.geomType.polygon && !currentGeometry.isComplete()){
+						smPArray[smPArray.length] = " title='"+closePolygon_title+"' ";
+					if(mod_digitizeEvent == button_move || mod_digitizeEvent == button_insert || mod_digitizeEvent == button_delete) {
+						smPArray[smPArray.length] = " onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].handleBasepoint(this,"+i+","+j+","+k+")' ;";
+					smPArray[smPArray.length] = "></div>";
+				var mapObj = parent.mb_mapObj[parent.getMapObjIndexByName(mod_digitize_target)];
+				for(var k = 1; k < currentGeometry.count(); k++){
+					var p0 = parent.realToMap(mod_digitize_target, d.getPoint(i,j,k));
+					var p1 = parent.realToMap(mod_digitize_target, d.getPoint(i,j,k-1));
+					points = parent.calculateVisibleDash(p0, p1, mapObj.width, mapObj.height);
+					if (points != false) {
+						smPArray[smPArray.length] = evaluateDashes(points[0], points[1], i, j, k);
+	digitizeDivTag.write(smPArray.join(""));
+function evaluateDashes(start, end, memberIndex, geomIndex, pointIndex){
+	var strArray = [];
+	var delta = new parent.Point(end.x - start.x, end.y - start.y);
+	var lastGeomIsComplete = d.getGeometry(-1,-1).isComplete();
+	var vecLength = start.dist(end);
+	var n = Math.round(vecLength/dotDistance);
+	if (n > 0) {
+		var step = delta.dividedBy(n);
+	for(var i=1; i < n; i++){
+		var x = Math.round(start.x + i * step.x) - 2;
+		var y = Math.round(start.y + i * step.y) - 2;
+		if(x >= 0 && x <= mod_digitize_width && y >= 0 && y <= mod_digitize_height){
+			if (memberIndex == d.count()-1 && !lastGeomIsComplete) {
+				strArray[strArray.length] = "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:"+digitizeTransactionalZIndex+";background-color:"+linepointColor+"' ";
+			else {
+				strArray[strArray.length] = "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:"+digitizeTransactionalZIndex+";' ";
+			if(mod_digitizeEvent == button_insert) {
+				strArray[strArray.length] = "onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].convertLinepointToBasepoint(this,"+memberIndex+","+geomIndex+","+pointIndex+")'";
+			strArray[strArray.length] = "></div>";
+	return strArray.join("");
+function isTransactional(geom) {
+//	alert(typeof(geom.wfs_conf) + " " + geom.wfs_conf + " " + wfsConf.length);
+	if (typeof(geom.wfs_conf) == 'number') {
+		if (geom.wfs_conf >= 0 && geom.wfs_conf < wfsConf.length) {
+			var isTransactionalGeom = (wfsConf[geom.wfs_conf]['wfs_transaction'] != "" && wfsConf[geom.wfs_conf]['fkey_featuretype_id'] != "");
+			if (isTransactionalGeom) {
+				return true;
+			else{
+				return false;
+	else if (typeof(geom.wfs_conf) == 'undefined') {
+		return true;
+function isValidWfsConfIndex (wfsConf, wfsConfIndex) {
+	return (typeof(wfsConfIndex) == "number" && wfsConfIndex >=0 && wfsConfIndex < wfsConf.length);
+function getName (geom) {
+	wfsConfId = geom.wfs_conf;
+	wfsConf = parent.get_complete_wfs_conf();
+	if (isValidWfsConfIndex(wfsConf, wfsConfId)) {
+		var resultName = "";
+		for (var i = 0 ; i < wfsConf[wfsConfId]['element'].length ; i++) {
+			if (wfsConf[wfsConfId]['element'][i]['f_show'] == 1) {
+				resultName += geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']) + " ";
+		if (resultName == "") {
+			resultName = wfsConf[wfsConfId]['g_label'];
+		return resultName;
+	else if (geom.e.getElementValueByName("name")) {
+		return geom.e.getElementValueByName("name");
+	else {
+		return msgObj.digitizeDefaultGeometryName;
+function updateListOfGeometries(){
+	var listOfGeom = "<table id='geometryTable' style='position:absolute; top:"+geomList_y+"px; left:"+geomList_x+"px;'>\n";
+	if (d.count() > 0) {
+		for (var i = 0 ; i < d.count(); i ++) {
+			if (d.get(i).get(-1).isComplete() && (nonTransactionalEditable || isTransactional(d.get(i)))) {
+				// for the geometries from a kml, there is another save dialogue
+				if (d.get(i).isFromKml()) {
+					// if the kml is in the db (id = id in database)
+					if (d.get(i).e.getElementValueByName("Mapbender:id")) {
+						// button: geometry information, update kml
+						listOfGeom += "\t<tr>\n\t\t<td>\n";
+						listOfGeom += "\t\t\t<img src = '"+buttonDig_imgdir+buttonDig_wfs_src+"' title='"+msgObj.buttonDig_wfs_title+"' onclick='showWfsKml("+i+")'>\n";
+				else {
+					// button: geometry information, save, update, delete
+					if (wfsExistsForGeom(d.get(i), wfsConf)) {
+						listOfGeom += "\t\t\t<img src = '"+buttonDig_imgdir+buttonDig_wfs_src+"' title='"+msgObj.buttonDig_wfs_title+"' onclick='showWfs("+i+")'>\n";
+					listOfGeom += "\t\t</td>\n\t\t<td>\n";
+					// button: remove this geometry
+					listOfGeom += "\t\t\t<img src = '"+buttonDig_imgdir+buttonDig_remove_src+"' title='"+msgObj.buttonDig_remove_title+"' onclick='parent.mb_disableThisButton(mod_digitizeEvent);d.del("+i+");executeDigitizeSubFunctions();'>\n";
+				// button: remove geometry from database
+				if (isValidWfsConfIndex(wfsConf, d.get(i).wfs_conf)) {
+					listOfGeom += "\t\t\t<img src = '"+buttonDig_imgdir+buttonDig_removeDb_src+"' title='"+msgObj.buttonDig_removeDb_title+"' onclick=\"var deltrans = confirm('"+msgObj.messageConfirmDeleteGeomFromDb+"');if (deltrans) dbGeom('delete', "+i+")\">\n";
+				listOfGeom += "\t\t</td>\n\t\t<td style = 'color:blue;font-size:12px'>\n";
+				listOfGeom += "\t\t\t<div onmouseover='parent.mb_wfs_perform(\"over\",d.get("+i+"));' ";
+				listOfGeom += " onmouseout='parent.mb_wfs_perform(\"out\",d.get("+i+"))' ";
+				listOfGeom += " onclick='parent.mb_wfs_perform(\"click\",d.get("+i+"));' ";
+				var geomName = getName(d.get(i));
+				if (d.get(i).geomType == parent.geomType.polygon) {geomName += " ("+msgObj.messageDescriptionPolygon+")";}
+				else if (d.get(i).geomType == parent.geomType.line) {geomName += " ("+msgObj.messageDescriptionLine+")";}
+				else if (d.get(i).geomType == parent.geomType.point) {geomName += " ("+msgObj.messageDescriptionPoint+")";}
+				listOfGeom += ">" + geomName +"</div>\t\t</td>\n\t</tr>\n";
+	listOfGeom += "</table>\n";
+	parent.writeTag(mod_digitize_elName,"listOfGeometries",listOfGeom);
+// --- display (end) -----------------------------------------------------------------------------------------
+// --- wfs window (begin) -----------------------------------------------------------------------------------------
+// --- wfs window form check (begin) -----------------------------------------------------------------------------------------
+function formCorrect(doc, formId) {
+	var isCorrect = true;
+	var errorMessage = "";
+	var result;
+	var form = doc.getElementById(formId);
+	result = mandatoryFieldsNotEmpty(doc, form);
+	isCorrect = isCorrect && result.isCorrect;
+	errorMessage += result.errorMessage;
+	result = validBoxEntrySelected(form);
+	result = dataTypeIsCorrect(doc, form);
+	return {"isCorrect":isCorrect, "errorMessage":errorMessage};
+function validBoxEntrySelected(form){
+	for (var i = 0; i < form.childNodes.length && isCorrect; i++) {
+		if (form.childNodes[i].nodeName.toUpperCase() == "SELECT") {
+			if (parseInt(form.childNodes[i].selectedIndex) == 0) {
+				return {"isCorrect":false, "errorMessage":errorMessage};
+		else if (form.childNodes[i].hasChildNodes()) {
+			isCorrect = validBoxEntrySelected(form.childNodes[i]).isCorrect;
+	if (!isCorrect) {
+		errorMessage = msgObj.messageSelectAnOption + "\n";
+function mandatoryFieldsNotEmpty(doc, node){
+	nodeArray = doc.getElementsByName("mandatory");
+	for (var i = 0; i < nodeArray.length && isCorrect; i++) {
+		if (nodeArray[i].nodeName.toUpperCase() == "INPUT" && nodeArray[i].type == "hidden" && nodeArray[i].id.substr(0,10) == "mandatory_") {
+			var nodeId = nodeArray[i].id.substr(10);
+			if (nodeArray[i].value == "true") {
+				if (doc.getElementById(nodeId).value == "") {
+					isCorrect = false;
+					errorMessage += "'"+ doc.getElementById(nodeId).name +"': "+ msgObj.messageErrorFieldIsEmpty +"\n";
+function isInteger(str) {
+	if (str.match(/^\d*$/)) {
+		return true;
+	return false;
+function isFloat(str) {
+	if (isInteger(str)) {
+		return true;
+	if (str.match(/^\d+\.\d+$/)) {
+		return true;
+	return false;
+function replaceCommaByDecimalPoint(str) {
+	var patternString = ",";
+	var pattern = new RegExp(patternString);
+	while (str.match(pattern)) {
+		str = str.replace(pattern, ".");
+	return str;
+function dataTypeIsCorrect(doc, node){
+	nodeArray = doc.getElementsByName("datatype");
+	for (var i = 0; i < nodeArray.length ; i++) {
+		if (nodeArray[i].nodeName.toUpperCase() == "INPUT" && nodeArray[i].type == "hidden" && nodeArray[i].id.substr(0,9) == "datatype_") {
+			var nodeId = nodeArray[i].id.substr(9);
+			var nodeValue = doc.getElementById(nodeId).value;
+			if (nodeArray[i].value == "int") {
+				if (!isInteger(nodeValue)) {
+					errorMessage += "'"+doc.getElementById(nodeId).name+"': "+ msgObj.messageErrorNotAnInteger + "\n";
+			else if (nodeArray[i].value == "double") {
+				nodeValue = replaceCommaByDecimalPoint(nodeValue);
+				if (!isFloat(nodeValue)) {
+					errorMessage += "'"+doc.getElementById(nodeId).name+"': "+ msgObj.messageErrorNotAFloat + "\n";
+				else {
+					doc.getElementById(nodeId).value = nodeValue;
+// --- wfs window form check (end) -----------------------------------------------------------------------------------------
+function getAvailableWfsForGeom(geom, wfsConf) {
+	var wfsConfIndices = [];
+	for (var attr in wfsConf) {
+		var isTrans = (wfsConf[attr]['wfs_transaction'] != "");
+		if (!isTrans) {
+			continue;
+		if (isValidWfsConfIndex(wfsConf, parseInt(geom.wfs_conf))) {
+			if (parseInt(geom.wfs_conf) == parseInt(attr)) {
+				wfsConfIndices.push(attr);
+		else {
+			for (var elementIndex = 0; elementIndex < wfsConf[attr]['element'].length ; elementIndex++) {
+				var isGeomColumn = (parseInt(wfsConf[attr]['element'][elementIndex]['f_geom']) == 1);
+				if (isGeomColumn) {
+					var isMultiPolygon = (geom.geomType == parent.geomType.polygon && wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiPolygonPropertyType');
+					var isPolygon = (geom.geomType == parent.geomType.polygon && geom.count() == 1 && wfsConf[attr]['element'][elementIndex]['element_type'] == 'PolygonPropertyType');
+					var isMultiLine = (geom.geomType == parent.geomType.line && wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiLineStringPropertyType');
+					var isLine = (geom.geomType == parent.geomType.line && geom.count() == 1 && wfsConf[attr]['element'][elementIndex]['element_type'] == 'LineStringPropertyType');
+					var isPoint = (geom.geomType == parent.geomType.point && wfsConf[attr]['element'][elementIndex]['element_type'] == 'PointPropertyType');
+//					alert(isMultiPolygon + " " + isPolygon + " " + isMultiLine + " " + isLine + " " + isPoint);
+					if (isMultiPolygon || isPolygon || isMultiLine || isLine || isPoint || wfsConf[attr]['element'][elementIndex]['element_type'] == 'GeometryAssociationType') {
+	return wfsConfIndices;
+function wfsExistsForGeom(geom, wfsConf) {
+	wfsConfIndices = getAvailableWfsForGeom(geom, wfsConf);
+//	alert(wfsConfIndices.join(","));
+	if (wfsConfIndices.length > 0) {
+		return true;
+	return false;
+function showWfsKml (geometryIndex) {
+	wfsKmlWindow = open("", "wfsattributes", "width="+wfsWindowWidth+", height="+wfsWindowHeight+", resizable, dependent=yes, scrollbars=yes");
+	wfsKmlWindow.document.open("text/html");
+	wfsKmlWindow.document.writeln("<html><head></head><body><div id='linkToKml'></div><div id='elementForm'></div></body></html>");
+	wfsKmlWindow.document.close();
+	str = "<form id = 'wmsKmlForm' onsubmit='return false;'><table>";
+	var properties = d.get(geometryIndex).e;
+	var propertyCount = properties.count();
+	for (var i = 0; i < propertyCount; i++) {
+		var key = properties.getName(i);
+		var value = properties.getValue(i);
+		var expr = /Mapbender:/;
+		if (!key.match(expr)) {
+			str += "\t\t<tr>\n";
+			str += "\t\t\t<td>\n\t\t\t\t<div>" + key + "</div>\n\t\t\t</td>\n";
+			str += "\t\t\t<td>\n";
+			str += "\t\t\t\t<input id = 'wmskml_" + i + "' name='" + key + "' type='text' size=20 value = '" + value + "'>\n";
+			str += "\t\t\t</td>\n\t\t</tr>\n";
+	var updateOnClickText = "this.disabled=true;window.opener.updateKmlInDb("+geometryIndex+", 'update');";
+	var deleteOnClickText = "var deltrans = confirm('This geometry will be removed from the KML.');";
+	deleteOnClickText += "if (deltrans){";
+	deleteOnClickText += "this.disabled=true;window.opener.updateKmlInDb("+geometryIndex+", 'delete')}";
+	str += "\t\t\t<td><input type='button' name='updateButton' value='Update' onclick=\""+updateOnClickText+"\"/></td>\n";
+// delete button not yet implemented
+//	str += "\t\t\t<td><input type='button' name='deleteButton' value='Delete' onclick=\""+deleteOnClickText+"\"/></td>\n";
+	str += "\t\t\t<td><input type='button' name='abortButton' value='Abort' onclick=\"window.close();\" /></td>\n";
+	str += "\t\t</tr>\n";
+	str += "\t</table>\n";
+	str += "</form>\n";
+	wfsKmlWindow.document.getElementById("elementForm").innerHTML = str;
+// this method opens a new window and displays the attributes in wfs_conf
+function showWfs(geometryIndex) {
+	wfsWindow = open("", "wfsattributes", "width="+wfsWindowWidth+", height="+wfsWindowHeight+", resizable, dependent=yes, scrollbars=yes");
+	wfsWindow.document.open("text/html");
+	var str = "";
+	var strStyle = "";
+	var defaultIndex = -1;
+	str += "<form id='wfs'>\n";
+	// 1. add select box
+	var onChangeText = "document.getElementById('elementForm').innerHTML = ";
+	onChangeText += "window.opener.buildElementForm(this.value , " + geometryIndex + ");";
+	onChangeText += "window.opener.setWfsWindowStyle(this.value);";
+	str += "\t<select name='wfs' size='" + wfsConf.length + "'";
+	str += " onChange=\""+ onChangeText +"\"";
+	str += ">\n\t\t";
+	var wfsConfIndices = getAvailableWfsForGeom(d.get(geometryIndex), wfsConf);
+	var selected = false;
+	for (var i = 0; i < wfsConfIndices.length ; i++) {
+		str += "<option value='" + wfsConfIndices[i] + "'";
+		if (!selected) {
+			str += " selected";
+			selected = true;
+			defaultIndex = parseInt(wfsConfIndices[i]);
+		str += ">" + wfsConf[wfsConfIndices[i]]['wfs_conf_abstract'];
+		str += "</option>\n\t\t";
+	str += "</select>\n\t\t</form>\n\t";
+	str += "<div id='elementForm'>\n</div>";
+	if (defaultIndex != -1) {
+		wfsWindow.document.writeln("<html><head><style type='text/css'>"+wfsConf[defaultIndex]['g_style']+"</style></head><body></body></html>");
+		wfsWindow.document.write(str);
+		wfsWindow.document.close();
+		wfsWindow.document.getElementById("elementForm").innerHTML = buildElementForm(defaultIndex, geometryIndex);
+	else {
+		wfsWindow.document.writeln("<html><head><style type='text/css'></style></head><body></body></html>");
+function setWfsWindowStyle(wfsConfIndex) {
+	wfsWindow.document.getElementsByTagName("style")[0].innerHTML = wfsConf[wfsConfIndex]['g_style'];
+// returns a form with the elements of a selected wfs
+// (if the original wfs is the selected wfs, the values are set too)
+function buildElementForm(wfsConfIndex, memberIndex){
+	var featureTypeMismatch = false;
+	if (parseInt(d.get(memberIndex).wfs_conf) != parseInt(wfsConfIndex)) {featureTypeMismatch = true;}
+	var str = "";
+	var hasGeometryColumn = false;
+	var featureTypeArray = wfsConf[wfsConfIndex];
+	var memberElements;
+	var fid = false;
+	if (!featureTypeMismatch) {
+		memberElements = d.get(memberIndex).e;
+		fid = memberElements.getElementValueByName('fid');
+	if (typeof(featureTypeArray["element"]) !== "undefined") {
+		str += "<form id='"+featureTypeElementFormId+"'>\n\t<table>\n";
+		featureTypeElementArray = featureTypeArray["element"];
+		// 2. add rows to form
+		for (var i = 0 ; i < featureTypeElementArray.length ; i ++) {
+			var featureTypeElement = featureTypeElementArray[i];
+			var elementName = featureTypeElement['element_name'];
+			var elementType = featureTypeElement['element_type'];
+			var isEditable = (parseInt(featureTypeElement['f_edit']) == 1);
+			var isMandatory = (parseInt(featureTypeElement['f_mandatory']) == 1);
+			var isGeomColumn = (parseInt(featureTypeElement['f_geom']) == 1);
+			var elementLabelExists = (featureTypeElement['f_label'] != "");
+			var elementLabel = "";
+			if (elementLabelExists) {
+				elementLabel = featureTypeElement['f_label'];
+			var elementLabelStyle = featureTypeElement['f_label_id'];
+			if (!isGeomColumn) {
+				if (isEditable) {
+					str += "\t\t\t<td>\n\t\t\t\t<div class = '"+elementLabelStyle+"''>" + elementLabel + "</div>\n\t\t\t</td>\n";
+					var elementValue = "";
+						for (var j = 0 ; j < memberElements.count() ; j ++) {
+							if (memberElements.getName(j) == featureTypeElement['element_name']) {
+								elementValue = memberElements.getValue(j);
+					var formElementHtml = featureTypeElement['f_form_element_html'];
+					if (!formElementHtml || !formElementHtml.match(/<select/)) {
+						str += "\t\t\t\t<input id = 'datatype_" + elementName + "' name='datatype' type='hidden' value = '" + elementType + "'>\n";
+						str += "\t\t\t\t<input id = 'mandatory_" + elementName + "' name='mandatory' type='hidden' value = '" + isMandatory + "'>\n";
+						str += "\t\t\t\t<input id = '" + elementName + "' name='" + elementLabel + "' type='text' class = '"+featureTypeElement['f_style_id']+"' size=20 value = '" + elementValue + "'>\n";
+					else {
+							while (formElementHtml.match(/\\/)) {
+								formElementHtml = formElementHtml.replace(/\\/, "");
+//							alert(formElementHtml);
+							// preselect the correct entry of the box
+							var patternString = "option value='"+elementValue+"'";
+							formElementHtml = formElementHtml.replace(pattern, patternString+" selected");
+							str += formElementHtml;
+			else {
+				hasGeometryColumn = true;
+		// 3. add buttons "save", "update", "delete"
+		str += "</table><table>";
+		var isTransactional = (featureTypeArray['wfs_transaction']);
+		if (isTransactional) {
+			var options = ["save", "update", "delete", "abort"];
+			for (var i = 0 ; i < options.length ; i++) {
+				var onClickText = "this.disabled=true;var result = window.opener.formCorrect(document, '"+featureTypeElementFormId+"');";
+				onClickText += 	"if (result.isCorrect) {";
+				onClickText += 		"window.opener.dbGeom('"+options[i]+"', "+memberIndex+"); ";
+//				onClickText +=      "window.close();";
+				onClickText += 	"}";
+				onClickText += 	"else {";
+				onClickText += 		"alert(result.errorMessage);this.disabled=false;"
+				if (options[i] == "save" && hasGeometryColumn && (!fid || showSaveButtonForExistingGeometries)) {
+					str += "\t\t\t<td><input type='button' name='saveButton' value='"+msgObj.buttonLabelSaveGeometry+"' onclick=\""+onClickText+"\" /></td>\n";
+				if (!featureTypeMismatch && fid) {
+					if (options[i] == "update" && hasGeometryColumn) {
+						str += "\t\t\t<td><input type='button' name='updateButton' value='"+msgObj.buttonLabelUpdateGeometry+"' onclick=\""+onClickText+"\"/></td>\n";
+					if (options[i] == "delete"){
+						var deleteOnClickText = "var deltrans = confirm('"+msgObj.messageConfirmDeleteGeomFromDb+"');";
+						deleteOnClickText += onClickText + "}";
+						str += "\t\t\t<td><input type='button' name='deleteButton' value='"+msgObj.buttonLabelDeleteGeometry+"' onclick=\""+deleteOnClickText+"\"/></td>\n";
+				if (options[i] == "abort") {
+					str += "\t\t\t<td><input type='button' name='abortButton' value='"+msgObj.buttonLabelAbort+"' onclick=\"window.close();\" /></td>\n";
+		str += "<input type='hidden' id='fid' value='"+fid+"'>";
+//			str += "<input type='text' name='mb_wfs_conf'>";
+	return str;
+function dbGeom(type,m) {
+	if (typeof(wfsWindow) != 'undefined' && !wfsWindow.closed) {
+		d.get(m).wfs_conf = parseInt(wfsWindow.document.forms[0].wfs.options[wfsWindow.document.forms[0].wfs.selectedIndex].value);
+		d.get(m).e = new parent.Wfs_element();
+	else {
+	var myconf = wfsConf[d.get(m).wfs_conf];
+	var mapObjInd = parent.getMapObjIndexByName(mod_digitize_target);
+	if (myconf['featuretype_srs'] != parent.mb_mapObj[mapObjInd].epsg) {
+		alert(msgObj.errorMessageEpsgMismatch + parent.mb_mapObj[mapObjInd].epsg + " / "+ myconf['featuretype_srs']);
+	else {
+		var fid = false;
+			myform = wfsWindow.document.getElementById(featureTypeElementFormId);
+			for (var i=0; i<myform.length; i++){
+				if (myform.elements[i].id == "fid") {
+					fid = myform.elements[i].value;
+					d.get(m).e.setElement('fid', fid);
+				else if (myform.elements[i].type == 'text' ){
+					if (myform.elements[i].id) {
+						d.get(m).e.setElement(myform.elements[i].id, myform.elements[i].value);
+					else {
+						errorMessage = msgObj.messageErrorFormEvaluation;
+				// selectbox
+				else if (typeof(myform.elements[i].selectedIndex) == 'number') {
+						d.get(m).e.setElement(myform.elements[i].id, myform.elements[i].options[myform.elements[i].selectedIndex].value);
+					else {
+		else {
+			fid = d.get(m).e.getElementValueByName('fid');
+		str = parent.get_wfs_str(myconf, d, m, type, fid);
+		parent.mb_ajax_post("../extensions/geom2wfst.php", {'filter':str,'url':myconf['wfs_transaction'],'featuretype_name':myconf['featuretype_name'],'wfs_conf_id':wfsConf[d.get(m).wfs_conf]['wfs_conf_id']}, function(json,status){
+			var result = eval('('+json+')');
+			var response = result.response;
+			var fid = result.fid;
+			wfsSubWrite(m, type, status, response, fid);
+function wfsSubWrite(m, type, status, response, fid) {
+	if (type == 'save' && fid) {
+		d.get(m).e.setElement("fid", fid);
+	if (type == 'delete') {
+		parent.mb_disableThisButton(mod_digitizeEvent);
+		d.del(m);
+	parent.mb_execWfsWriteSubFunctions();
+	if (status == "success" && response == "success") {
+		var wfsWriteMessage = msgObj.messageSuccessWfsWrite;
+	else {
+		var wfsWriteMessage = msgObj.messageErrorWfsWrite;
+		wfsWindow.alert(wfsWriteMessage);
+		window.setTimeout("wfsWindow.close()",0);
+	else {
+		alert(wfsWriteMessage);
+function getMultiGeometryIdsByPlacemarkId (placemarkId) {
+	var multiGeometryIdArray = [];
+		var currentPlacemarkId = d.get(i).e.getElementValueByName("Mapbender:placemarkId");
+		if (currentPlacemarkId && currentPlacemarkId == placemarkId) {
+			multiGeometryIdArray.push(i);
+	return multiGeometryIdArray;
+function updateKmlInDb (geometryIndex, command) {
+	var placemarkId = properties.getElementValueByName("Mapbender:placemarkId");
+	var multiGeometryIdArray = getMultiGeometryIdsByPlacemarkId(placemarkId);
+	if (typeof(wfsKmlWindow) != 'undefined' && !wfsKmlWindow.closed) {
+		// update properties from form
+		myform = wfsKmlWindow.document.getElementById("wmsKmlForm");
+		for (var i=0; i < myform.length; i++){
+			if (myform.elements[i].type == 'text' ){
+					var key = myform.elements[i].name;
+					var value = myform.elements[i].value;
+					// update all geometries with the same placemark id
+					for (var j = 0; j < multiGeometryIdArray.length; j++) {
+						var currentProperties = d.get(j).e;
+						currentProperties.setElement(key, value);
+		var kmlId = properties.getElementValueByName("Mapbender:id");
+		parent.mb_ajax_post("../php/mod_updateKmlInDb.php", {command:command, kmlId:kmlId, placemarkId:placemarkId, geoJSON:d.placemarkToString(placemarkId)}, function(obj, status) {
+			if (obj === "1") {
+				wfsKmlWindow.alert("KML updated.");
+				var link = wfsKmlWindow.document.createElement("a");
+				link.href = "../php/mod_displayKML.php?kmlId=" + kmlId;
+				link.target = "_blank";
+				link.innerHTML = "KML";
+				wfsKmlWindow.document.getElementById('elementForm').innerHTML = "";
+				wfsKmlWindow.document.getElementById('linkToKml').appendChild(link);
+			else {
+				wfsKmlWindow.alert("Error, KML could not be updated. Check your error log.");
+function getMessages() {
+	parent.mb_ajax_json("../php/mod_digitize_messages.php", function(obj, status) {
+		msgObj = obj;
+		applyMessages();
+function applyMessages() {
+	updateMeasureTag();
+	updateListOfGeometries();
+	</script>
+	</head>
+	<body onload="registerFunctions();displayButtons();">
+		<table cellpadding='0' cellspacing='0' align = center><tr><td><div id='digButtons'></div></td></tr></table>
+		<div id = 'listOfGeometries'></div>
+	</body>
 </html>
\ No newline at end of file
More information about the Mapbender_commits mailing list
