[Mapbender-commits] r1921 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Dec 14 05:28:00 EST 2007
Author: verenadiewald
Date: 2007-12-14 05:27:59 -0500 (Fri, 14 Dec 2007)
New Revision: 1921
   trunk/mapbender/http/classes/class_wfs.php
replaced mysql_result with db_result in line 410
Modified: trunk/mapbender/http/classes/class_wfs.php
--- trunk/mapbender/http/classes/class_wfs.php	2007-12-13 11:06:56 UTC (rev 1920)
+++ trunk/mapbender/http/classes/class_wfs.php	2007-12-14 10:27:59 UTC (rev 1921)
@@ -407,7 +407,7 @@
 			if(!$found){
 				$sql = "DELETE FROM wfs_element WHERE element_id = $1 AND fkey_featuretype_id = $2";
-				$v = array(mysql_result($res_el, $cnt, "element_id"), $this->wfs_featuretype[$i]->featuretype_id);
+				$v = array(db_result($res_el, $cnt, "element_id"), $this->wfs_featuretype[$i]->featuretype_id);
 				$t = array('i','i');
 				//echo $sql."<br />";
 				$res = db_prep_query($sql,$v,$t);
More information about the Mapbender_commits mailing list
