[Mapbender-commits] r1928 -
branches/mapbender_sld/resources/db/postgresql
svn_mapbender at osgeo.org
Tue Dec 18 08:58:15 EST 2007
Author: mschulz
Date: 2007-12-18 08:58:15 -0500 (Tue, 18 Dec 2007)
New Revision: 1928
branches/mapbender_sld/resources/db/postgresql/pgsql_schema.sql
merge: added missing sld table definition
Modified: branches/mapbender_sld/resources/db/postgresql/pgsql_schema.sql
--- branches/mapbender_sld/resources/db/postgresql/pgsql_schema.sql 2007-12-18 13:43:06 UTC (rev 1927)
+++ branches/mapbender_sld/resources/db/postgresql/pgsql_schema.sql 2007-12-18 13:58:15 UTC (rev 1928)
@@ -356,6 +356,19 @@
+-- SLD Editor data table
+CREATE TABLE sld_user_layer (
+ sld_user_layer_id serial NOT NULL,
+ fkey_mb_user_id integer NOT NULL,
+ fkey_layer_id integer NOT NULL,
+ fkey_gui_id character varying,
+ sld_xml text,
+ use_sld smallint
-- new table translation: new table for translations
@@ -516,7 +529,11 @@
contactelectronicmailaddress character varying(255),
wms_mb_getcapabilies_doc text,
wms_owner integer,
- wms_timestamp integer
+ wms_timestamp integer,
+ wms_supportsld boolean,
+ wms_userlayer boolean,
+ wms_userstyle boolean,
+ wms_remotewfs boolean
@@ -967,6 +984,30 @@
+-- Name: sld_user_layer_ibfk_1; Type: FK CONSTRAINT; Schema: public; Owner: admin
+ALTER TABLE ONLY sld_user_layer
+ ADD CONSTRAINT sld_user_layer_ibfk_1 FOREIGN KEY (fkey_mb_user_id) REFERENCES mb_user(mb_user_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- Name: sld_user_layer_ibfk_2; Type: FK CONSTRAINT; Schema: public; Owner: admin
+ ADD CONSTRAINT sld_user_layer_ibfk_2 FOREIGN KEY (fkey_layer_id) REFERENCES layer(layer_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- Name: sld_user_layer_ibfk_3; Type: FK CONSTRAINT; Schema: public; Owner: admin
+ ADD CONSTRAINT sld_user_layer_ibfk_3 FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
-- TOC entry 1771 (class 2606 OID 47913469)
-- Dependencies: 1735 1264 1266
-- Name: wfs_conf_element_ibfk_1; Type: FK CONSTRAINT; Schema: public; Owner: admin
@@ -1092,7 +1133,9 @@
ALTER TABLE mb_log ADD CONSTRAINT pk_mb_log PRIMARY KEY (id);
+ALTER TABLE sld_user_layer ADD CONSTRAINT pk_sld_user_layer PRIMARY KEY (sld_user_layer_id);
-- new function gettext for easy translations
More information about the Mapbender_commits
