[Mapbender-commits] r1934 - in trunk/mapbender/http: frames javascripts php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Dec 19 06:29:25 EST 2007
Author: christoph
Date: 2007-12-19 06:29:25 -0500 (Wed, 19 Dec 2007)
New Revision: 1934
Added:
   trunk/mapbender/http/javascripts/core.js
   trunk/mapbender/http/javascripts/core.php
   trunk/mapbender/http/frames/index.php
   trunk/mapbender/http/javascripts/event.js
   trunk/mapbender/http/javascripts/map.js
   trunk/mapbender/http/javascripts/map.php
   trunk/mapbender/http/javascripts/mod_digitize_tab.php
   trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php
   trunk/mapbender/http/php/mod_createJSObjFromDB.php
   trunk/mapbender/http/php/mod_map1.php
   trunk/mapbender/http/php/mod_mapOV.php
optimization, see http://lists.osgeo.org/pipermail/mapbender_dev/2007-December/000950.html
Modified: trunk/mapbender/http/frames/index.php
--- trunk/mapbender/http/frames/index.php	2007-12-18 15:38:37 UTC (rev 1933)
+++ trunk/mapbender/http/frames/index.php	2007-12-19 11:29:25 UTC (rev 1934)
@@ -84,30 +84,12 @@
 </style>
-<script type='text/javascript' src="../extensions/jquery.js"></script>
-<script type='text/javascript' src="../extensions/jqjson.js"></script>
-<script type='text/javascript' src="../javascripts/point.js"></script>
-<script type='text/javascript' src="../javascripts/map_obj.js"></script>
-<script type='text/javascript' src="../javascripts/wfs_obj.js"></script>
 <?php
-//echo "<script type='text/javascript' src='../javascripts/map.php?gui_id=".$_REQUEST["gui_id"]."&zoomToLayer=".$_REQUEST["zoomToLayer"]."&portal_services=".$_REQUEST['portal_services']."&portal_services_wfs=".$_REQUEST['portal_services_wfs']."&layer_preview=".$_REQUEST['layer_preview']."&".strip_tags(SID)."&mb_myBBOX=".$_REQUEST["mb_myBBOX"]."'></script>";
-echo "<script type='text/javascript' src='../javascripts/map.php?gui_id=".$_REQUEST["gui_id"]."&".strip_tags(SID)."&mb_myBBOX=".$_REQUEST["mb_myBBOX"]."'></script>";
-echo "<script type='text/javascript' src='../php/mod_createJSObjFromDB.php?". strip_tags (SID)."'></script>";
 $frame = "";
-$sql = "SELECT DISTINCT e_mb_mod FROM gui_element WHERE e_public = 1 AND fkey_gui_id = $1";
-$v = array($_REQUEST["gui_id"]);
-$t = array('s');
-$res = db_prep_query($sql,$v,$t);
-$cnt = 0;
-while($row = db_fetch_array($res)){
-	if($row["e_mb_mod"] != ""){
-		echo "<script type='text/javascript' src='../javascripts/".trim($row["e_mb_mod"])."?gui_id=".$_REQUEST["gui_id"]."&". strip_tags (SID)."'></script> ";
-	$cnt++;
+echo "<script type='text/javascript' src='../javascripts/core.php'></script>";
 </head>
 <?php
@@ -175,5 +157,10 @@
 <form id='sendData' name='sendData' action='' method='POST' target='loadData' style='position:absolute;left:800px'>
 <input type='hidden' name='data'>
 </form>
+<?php
+#echo "<script type='text/javascript' src='../javascripts/map.php?gui_id=".$_REQUEST["gui_id"]."&zoomToLayer=".$_REQUEST["zoomToLayer"]."&portal_services=".$_REQUEST['portal_services']."&portal_services_wfs=".$_REQUEST['portal_services_wfs']."&layer_preview=".$_REQUEST['layer_preview']."&".strip_tags(SID)."&mb_myBBOX=".$_REQUEST["mb_myBBOX"]."'></script>";
+echo "<script type='text/javascript' src='../javascripts/map.php?gui_id=".$_REQUEST["gui_id"]."&".strip_tags(SID)."&mb_myBBOX=".$_REQUEST["mb_myBBOX"]."'></script>";
+echo "<script type='text/javascript' src='../php/mod_createJSObjFromDB.php?". strip_tags (SID)."'></script>";
 </body>
 </html>
\ No newline at end of file
Added: trunk/mapbender/http/javascripts/core.js
--- trunk/mapbender/http/javascripts/core.js	                        (rev 0)
+++ trunk/mapbender/http/javascripts/core.js	2007-12-19 11:29:25 UTC (rev 1934)
@@ -0,0 +1,153 @@
+var currentWmcExtensionData = {};
+var restoredWmcExtensionData = {};
+//var mb_MapRequestSubFunctions = [];
+//var mb_MapRequestPreFunctions = [];
+//var mb_MapObjectSubFunctions = [];
+//var mb_GetScalePreFunctions = [];
+//var mb_FeatureInfoPreFunctions = [];
+//var mb_loadWmsSubFunctions = [];
+//var mb_InitFunctions = [];
+var mb_WfsReadSubFunctions = [];
+var mb_WfsWriteSubFunctions = [];
+var mb_l10nFunctions = [];
+ * Triggered after a map is requested.
+var eventAfterMapRequest = new MapbenderEvent();
+ * Triggered before a map is requested.
+var eventBeforeMapRequest = new MapbenderEvent();
+ * Triggered before the scale is calculated.
+var eventBeforeGetScale = new MapbenderEvent();
+ * Triggered before a feature info is requested.
+var eventBeforeFeatureInfo = new MapbenderEvent();
+ * Triggered after a WMS has been loaded.
+var eventAfterLoadWMS = new MapbenderEvent();
+ * Triggered when Mapbender is loaded and after the map object has been initialised.
+var eventInit = new MapbenderEvent();
+ * Initializes the map object. Triggered when Mapbender is loaded.
+var eventInitMap = new MapbenderEvent();
+ * Triggered after the map object has been created.
+var eventAfterMapObjectConstruction = new MapbenderEvent(); // possibly obsolete!
+ * deprecated wrapped function
+ * @deprecated
+function mb_registerInitFunctions(stringFunction){
+//	mb_InitFunctions[mb_InitFunctions.length] = stringFunction;
+	eventInit.register(stringFunction);
+ * @deprecated
+function mb_registerPreFunctions(stringFunction){
+//	mb_MapRequestPreFunctions[mb_MapRequestPreFunctions.length] = stringFunction;
+	eventBeforeMapRequest.register(stringFunction);
+ * @deprecated
+function mb_registerFeatureInfoPreFunctions(stringFunction){
+//	mb_FeatureInfoPreFunctions[mb_FeatureInfoPreFunctions.length] = stringFunction;
+	eventBeforeFeatureInfo.register(stringFunction);
+ * @deprecated
+function mb_registerSubFunctions(stringFunction){
+//	mb_MapRequestSubFunctions[mb_MapRequestSubFunctions.length] = stringFunction;
+	eventAfterMapRequest.register(stringFunction);
+ * @deprecated
+function mb_registerMapObjectSubFunctions(stringFunction){
+//	mb_MapObjectSubFunctions[mb_MapObjectSubFunctions.length] = stringFunction;
+	eventAfterMapObjectConstruction.register(stringFunction);
+ * @deprecated
+function mb_registerGetScalePreFunctions(stringFunction){
+//	mb_GetScalePreFunctions[mb_GetScalePreFunctions.length] = stringFunction;
+	eventBeforeGetScale.register(stringFunction);
+ * @deprecated
+function mb_registerloadWmsSubFunctions(stringFunction){
+//	mb_loadWmsSubFunctions[mb_loadWmsSubFunctions.length] = stringFunction;
+	eventAfterLoadWMS.register(stringFunction);
+ * @deprecated
+function mb_registerWfsReadSubFunctions(stringFunction){
+	mb_WfsReadSubFunctions[mb_WfsReadSubFunctions.length] = stringFunction;
+ * @deprecated
+function mb_registerWfsWriteSubFunctions(stringFunction){
+	mb_WfsWriteSubFunctions[mb_WfsWriteSubFunctions.length] = stringFunction;
+ * @deprecated
+function mb_registerL10nFunctions(stringFunction) {
+	mb_l10nFunctions[mb_l10nFunctions.length] = stringFunction;
+ * deprecated function for writing content within a tag via innerHTML
+ * @deprecated
+function writeTag(frameName, elName, tagSource) {
+  if(frameName && frameName != ""){
+     window.frames[frameName].document.getElementById(elName).innerHTML = tagSource;
+  else if(!frameName || frameName == ""){
+       document.getElementById(elName).innerHTML = tagSource;
Added: trunk/mapbender/http/javascripts/core.php
--- trunk/mapbender/http/javascripts/core.php	                        (rev 0)
+++ trunk/mapbender/http/javascripts/core.php	2007-12-19 11:29:25 UTC (rev 1934)
@@ -0,0 +1,30 @@
+<?php
+# $Id: map.php 1915 2007-12-12 16:21:27Z christoph $
+# http://www.mapbender.org/index.php/Map.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+#if (substr_count($_SERVER['HTTP_ACCEPT_ENCODING'], 'gzip')) {
+#	ob_start("ob_gzhandler");
+#else {
+	ob_start();
+header('Content-type: application/x-javascript');
+require_once("../javascripts/event.js");
+require_once("../javascripts/core.js");
Modified: trunk/mapbender/http/javascripts/event.js
--- trunk/mapbender/http/javascripts/event.js	2007-12-18 15:38:37 UTC (rev 1933)
+++ trunk/mapbender/http/javascripts/event.js	2007-12-19 11:29:25 UTC (rev 1934)
@@ -1,41 +1,48 @@
  * An event. What happens, when the event occurs, depends on which functions have been
  * registered with the event.
+ * usage:
+ * // create a new Event
+ * var eventAfterMapRequest = new MapbenderEvent();
+ * // register a function with that event
+ * eventAfterMapRequest.register(function () {
+ * // trigger the event
+ * eventAfterMapRequest.trigger();
 var MapbenderEvent = function () {
-	// public
+	// public methods
 	 * A function that needs to be executed, when the event occurs, has to be
 	 * registered via this function.
-	this.register = function(aFunction, aPriority) {
-//		var e = new Mb_notice("MapbenderEvent: registering " + aFunction);
+	this.register = function(aFunction) {
-		var mpbnFunction = new MapbenderFunction(aFunction, aPriority, functionArray.length);
+		var mpbnFunction = new MapbenderFunction(aFunction);
 		functionArray.push(mpbnFunction);
-		// unfortunately, there is no way of using static variables in JS...
-		sortFunction = mpbnFunction.getSortFunction();
 	 * Exclude a previously registered function from the event
 	this.unregister = function(aFunction) {
-		var e = new Mb_notice("functions (before del): " + functionArray.join(","));
 		for (var i = 0, len = functionArray.length; i < len; i++) {
 			if (functionArray[i].getFunction() === aFunction) {
 				for (var j = i + 1; j < len; j++) {
 					functionArray[j-1] = functionArray[j];
-					functionArray[j-1].setArrayPosition(j-1);
 				delete functionArray[len - 1];
 				len = len - 1;
 		functionArray.length = len;
-		var e = new Mb_notice("functions (after del): " + functionArray.join(","));
@@ -68,18 +75,18 @@
 				booleanOperator = properties;
 			else {
-				var e = new Mb_exception("MapbenderEvent.trigger: invalid properties: %s", properties);
+//				var e = new Mb_exception("MapbenderEvent.trigger: invalid properties: %s", properties);
 		// booleanOperator
 		if (typeof(booleanOperator) == "string") {
 			if (booleanOperator != "AND" && booleanOperator != "OR") {
-				var e = new Mb_exception("MapbenderEvent.trigger: invalid booleanOperator: %s", booleanOperator);
+//				var e = new Mb_exception("MapbenderEvent.trigger: invalid booleanOperator: %s", booleanOperator);
 		else if (typeof(booleanOperator) != "undefined") {
-			var e = new Mb_exception("MapbenderEvent.trigger: invalid booleanOperator, must be a string, but is %s", typeof(booleanOperator));
+//			var e = new Mb_exception("MapbenderEvent.trigger: invalid booleanOperator, must be a string, but is %s", typeof(booleanOperator));
 		var result;
@@ -98,8 +105,6 @@
 				break;
-		// sort the function array by priority
-		functionArray.sort(sortFunction);
 		if (log) {
 			var e = new Mb_notice("functions (after sort): " + functionArray.join(","));
@@ -132,20 +137,14 @@
 	var functionArray = [];
-	 * the functionArray will be sorted using this function
-	var sortFunction;
 	var propertiesObj;
 	var log = false;
-	// constructor
  * A MapbenderFunction is a function with a priority.
-var MapbenderFunction = function (aFunction, aPriority, posInArray) {
+var MapbenderFunction = function (aFunction) {
 	// public
@@ -156,34 +155,15 @@
-	 * Returns the functions priority
-	this.getPriority = function () {
-		return priority;
-	 *  Returns the array position
-	this.getArrayPosition = function () {
-		return posInArray;
-	this.setArrayPosition = function (i) {
-		posInArray = i;
 	 * Executes the function
 	this.execute = function (argumentObj) {
-//		var e = new Mb_notice("MapbenderFunction: executing " + this);
 		if (typeof(aFunction) == "function") {
 			return func(argumentObj);
+		// this branch is for backwards compatibility with the
+		// pre-2.5 event system that is based on strings.
 		else {
 			var argumentNames = [];
 			var argumentValues = [];
@@ -203,46 +183,10 @@
 			str += "}";
 			str += "(" + argumentValues.join(", ") + "));";
 			var returnValue = eval(str);
-//			console.log("%s: %s", aFunction, returnValue);
 			return returnValue;
-	 * Returns a sort function for Mapbender functions. Sorted by priority.
-	this.getSortFunction = function () {
-		var mapbenderFunctionSort = function (functionA, functionB) {
-			var diff = functionA.getPriority() - functionB.getPriority();
-			if (diff === 0) {
-				// I assumed that if the return value of the sort function was 0, then no switch
-				// would occur. But this is not the case. A random looking output is what I get.
-				// So I had to use the array position as well.
-				return functionA.getArrayPosition() - functionB.getArrayPosition();
-			return diff;
-		return mapbenderFunctionSort;
 	// private
 	var func = aFunction;
-	// constructor
-	 * priority is a number, lower number means higher priority.
-	 * Maybe use 0-9, then 5 could be a default.
-	if (typeof(aPriority) != "number") {
-		var priority = 5;
-	else {
-		var priority = aPriority;
-	// the array position is needed for the sort function, if the priorities are equal.
-	var posInArray = posInArray;
-MapbenderFunction.prototype.toString = function () {
-	return this.getFunction() + " (pos: "+this.getArrayPosition()+")";
Modified: trunk/mapbender/http/javascripts/map.js
--- trunk/mapbender/http/javascripts/map.js	2007-12-18 15:38:37 UTC (rev 1933)
+++ trunk/mapbender/http/javascripts/map.js	2007-12-19 11:29:25 UTC (rev 1934)
@@ -19,71 +19,7 @@
 var mb_offset_bottom = 0;
 var mb_offset_left = 0;
 var mb_log = null;
-var currentWmcExtensionData = {};
-var restoredWmcExtensionData = {};
- *   register functions
-//var mb_MapRequestSubFunctions = [];
-//var mb_MapRequestPreFunctions = [];
-//var mb_MapObjectSubFunctions = [];
-//var mb_GetScalePreFunctions = [];
-//var mb_FeatureInfoPreFunctions = [];
-//var mb_loadWmsSubFunctions = [];
-//var mb_InitFunctions = [];
-var mb_WfsReadSubFunctions = [];
-var mb_WfsWriteSubFunctions = [];
-var mb_l10nFunctions = [];
-var eventAfterMapRequest = new MapbenderEvent();
-var eventBeforeMapRequest = new MapbenderEvent();
-var eventBeforeGetScale = new MapbenderEvent();
-var eventBeforeFeatureInfo = new MapbenderEvent();
-var eventAfterLoadWMS = new MapbenderEvent();
-var eventInit = new MapbenderEvent();
-var eventAfterMapObjectConstruction = new MapbenderEvent(); // possibly obsolete!
-function mb_registerInitFunctions(stringFunction){
-//	mb_InitFunctions[mb_InitFunctions.length] = stringFunction;
-	eventInit.register(stringFunction);
-function mb_registerPreFunctions(stringFunction){
-//	mb_MapRequestPreFunctions[mb_MapRequestPreFunctions.length] = stringFunction;
-	eventBeforeMapRequest.register(stringFunction);
-function mb_registerFeatureInfoPreFunctions(stringFunction){
-//	mb_FeatureInfoPreFunctions[mb_FeatureInfoPreFunctions.length] = stringFunction;
-	eventBeforeFeatureInfo.register(stringFunction);
-function mb_registerSubFunctions(stringFunction){
-//	mb_MapRequestSubFunctions[mb_MapRequestSubFunctions.length] = stringFunction;
-	eventAfterMapRequest.register(stringFunction);
-function mb_registerMapObjectSubFunctions(stringFunction){
-//	mb_MapObjectSubFunctions[mb_MapObjectSubFunctions.length] = stringFunction;
-	eventAfterMapObjectConstruction.register(stringFunction);
-function mb_registerGetScalePreFunctions(stringFunction){
-//	mb_GetScalePreFunctions[mb_GetScalePreFunctions.length] = stringFunction;
-	eventBeforeGetScale.register(stringFunction);
-function mb_registerloadWmsSubFunctions(stringFunction){
-//	mb_loadWmsSubFunctions[mb_loadWmsSubFunctions.length] = stringFunction;
-	eventAfterLoadWMS.register(stringFunction);
-function mb_registerWfsReadSubFunctions(stringFunction){
-	mb_WfsReadSubFunctions[mb_WfsReadSubFunctions.length] = stringFunction;
-function mb_registerWfsWriteSubFunctions(stringFunction){
-	mb_WfsWriteSubFunctions[mb_WfsWriteSubFunctions.length] = stringFunction;
-function mb_registerL10nFunctions(stringFunction) {
-	mb_l10nFunctions[mb_l10nFunctions.length] = stringFunction;
 function mb_removeFunctionFromArray(arrayname,stringFunction){
 	var length = eval(arrayname+".length");
 	for(var i=0; i<length; i++){
@@ -97,7 +33,6 @@
 function localize() {
 	for(var i=0; i<mb_l10nFunctions.length; i++){
 		eval(mb_l10nFunctions[i]);
@@ -160,7 +95,8 @@
 /*END OF GLOBALS*/
-function init(){
+function init() {
+	eventInitMap.trigger();
 	eventInit.trigger();
 	for(var i=0; i<mb_InitFunctions.length; i++){
@@ -1101,14 +1037,7 @@
    	if(cnt_fi == 0){alert(unescape("Please select a layer! \n Bitte waehlen Sie eine Ebene zur Abfrage aus!"));}
-function writeTag(frameName, elName, tagSource) {
-  if(frameName && frameName != ""){
-     window.frames[frameName].document.getElementById(elName).innerHTML = tagSource;
-  else if(!frameName || frameName == ""){
-       document.getElementById(elName).innerHTML = tagSource;
  * global function to zoom a mapobject
@@ -1798,7 +1727,8 @@
 function mb_ajax_get(url, param, callback) {
 	try {
-		mb_ajaxWrap_get(url, param, callback);
+//		$.ajaxSetup({async:false});
+		$.get(url, param, callback);
 	catch(e) {
 		var error = new Mb_exception('map.php: mb_ajax_get:'+e);
@@ -1814,7 +1744,8 @@
 function mb_ajax_post(url, param, callback) {
 	try {
-		mb_ajaxWrap_post(url, param, callback);
+		$.post(url, param, callback);
 	catch(e) {
 		var error = new Mb_exception('map.php: mb_ajax_post:'+e);
@@ -1830,13 +1761,14 @@
 function mb_ajax_json(url, param, callback) {
 	try {
-		mb_ajaxWrap_json(url, param, callback);
+//		window.frames['ajax'].$.ajaxSetup({async:false}); //TODO: find out why async doesn't work sometimes
+		$.getJSON(url, param, callback);
 	catch(e) {
 		var error = new Mb_exception('map.php: mb_ajax_json:'+e);
  *   button handling
Modified: trunk/mapbender/http/javascripts/map.php
--- trunk/mapbender/http/javascripts/map.php	2007-12-18 15:38:37 UTC (rev 1933)
+++ trunk/mapbender/http/javascripts/map.php	2007-12-19 11:29:25 UTC (rev 1934)
@@ -17,11 +17,15 @@
+session_start();
-include(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
 require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
-session_start();
+// see http://trac.osgeo.org/mapbender/ticket/79
+ini_set('session.bug_compat_42',0);
+ini_set('session.bug_compat_warn',0);
 $con = db_connect(DBSERVER,OWNER,PW);
 db_select_db(DB,$con);
@@ -51,6 +55,9 @@
 ob_start();
+// Define global variables (TODO: move to mapbender object later on)
 echo "var mb_nr = '".session_id()."';";
 echo "var mb_myLogin = '".$_SESSION["mb_login"]."';";
 echo "var mb_styleID = '".md5($_SESSION["mb_user_name"])."';";
@@ -63,16 +70,34 @@
 echo "var global_mb_log_level = '".LOG_LEVEL."';";
 echo "var global_log_levels = '".LOG_LEVEL_LIST."';";
-include("event.js");
-include("map.js");
+// Load JavaScript libraries
+require_once("../javascripts/map.js");
+require_once("../javascripts/point.js");
+require_once("../javascripts/map_obj.js");
+require_once("../javascripts/wfs_obj.js");
+require_once("../extensions/jquery.js");
+require_once("../extensions/jqjson.js");
-// see http://trac.osgeo.org/mapbender/ticket/79
-ini_set('session.bug_compat_42',0);
-ini_set('session.bug_compat_warn',0);
+// Load JavaScript modules of GUI elements
+$sql = "SELECT DISTINCT e_mb_mod FROM gui_element WHERE e_public = 1 AND fkey_gui_id = $1";
+$v = array($_REQUEST["gui_id"]);
+$t = array('s');
+$res = db_prep_query($sql,$v,$t);
+$cnt = 0;
+while($row = db_fetch_array($res)){
+	if($row["e_mb_mod"] != ""){
+		require_once("../javascripts/" . trim($row["e_mb_mod"]));
+	$cnt++;
-$con = db_connect(DBSERVER,OWNER,PW);
-db_select_db(DB,$con);
+// Load JavaScript files of GUI elements
 $mb_sql = "SELECT DISTINCT e_js_file, e_id, e_src, e_target, e_pos FROM gui_element WHERE e_public = 1 AND fkey_gui_id = $1 ORDER BY e_pos";
 $mb_v = array($_REQUEST["gui_id"]);
 $mb_t = array("s");
@@ -84,7 +109,7 @@
 		$e_id_css = $row_js["e_id"];
 		$e_src = $row_js["e_src"];
 		$e_target = $row_js["e_target"];
-		include($row_js["e_js_file"]);
+		require_once($row_js["e_js_file"]);
Modified: trunk/mapbender/http/javascripts/mod_digitize_tab.php
--- trunk/mapbender/http/javascripts/mod_digitize_tab.php	2007-12-18 15:38:37 UTC (rev 1933)
+++ trunk/mapbender/http/javascripts/mod_digitize_tab.php	2007-12-19 11:29:25 UTC (rev 1934)
@@ -64,7 +64,7 @@
 var wfsWindow;
 var dwin = null;
 var wfsConf = [];
-var d = new parent.GeometryArray();
+var d;
 var mod_digitize_width;
 var mod_digitize_height;
 var mod_digitizeEvent = false;
@@ -81,17 +81,24 @@
 var digitizeDivTag;
-var GeometryArray = parent.GeometryArray;
+var GeometryArray;
 var MultiGeometry = parent.MultiGeometry;
-var Geometry = parent.Geometry;
-var Point = parent.Point;
-var geomType = parent.geomType;
+var Geometry;
+var Point;
+var geomType;
 var msgObj;
 var featureTypeElementFormId = "featureTypeElementForm";
 try {if(mod_digitize_elName){}}catch(e) {mod_digitize_elName = "digitize";}
+function initializeDigitize () {
+	d = new parent.GeometryArray();
+	GeometryArray = parent.GeometryArray;
+	Geometry = parent.Geometry;
+	Point = parent.Point;
+	geomType = parent.geomType;
  * Append geometries from KML when KML has been loaded
@@ -391,6 +398,7 @@
 	registerDigitizePreFunctions("drawDashedLine()");
 	registerDigitizeSubFunctions("updateListOfGeometries()");
 	registerDigitizeSubFunctions("drawDashedLine()");
+	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].initializeDigitize()");
 	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].setStyleForTargetFrame()");
 	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].checkDigitizeTag()");
 	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].initialiseSnapping()");
Modified: trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php
--- trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php	2007-12-18 15:38:37 UTC (rev 1933)
+++ trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php	2007-12-19 11:29:25 UTC (rev 1934)
@@ -50,13 +50,13 @@
 		maxHighlightedPoints = Number(maxHighlightedPoints);
 		if (isNaN(maxHighlightedPoints)) {
-			var e = new parent.Mb_warning("mod_wfs_gazetteer_client.php: Element var maxHighlightedPoints must be a number.");
+//			var e = new parent.Mb_warning("mod_wfs_gazetteer_client.php: Element var maxHighlightedPoints must be a number.");
 catch(e){
 	maxHighlightedPoints = 0;
-	var e = new parent.Mb_warning("mod_wfs_gazetteer_client.php: Element var maxHighlightedPoints is not set, see 'edit element vars'.");
+//	var e = new parent.Mb_warning("mod_wfs_gazetteer_client.php: Element var maxHighlightedPoints is not set, see 'edit element vars'.");
 var targetArray = targetString.split(",");
Modified: trunk/mapbender/http/php/mod_createJSObjFromDB.php
--- trunk/mapbender/http/php/mod_createJSObjFromDB.php	2007-12-18 15:38:37 UTC (rev 1933)
+++ trunk/mapbender/http/php/mod_createJSObjFromDB.php	2007-12-19 11:29:25 UTC (rev 1934)
@@ -17,6 +17,7 @@
+ob_start();
 require_once(dirname(__FILE__)."/mb_validateSession.php");
 require_once(dirname(__FILE__)."/../classes/class_wms.php");
Modified: trunk/mapbender/http/php/mod_map1.php
--- trunk/mapbender/http/php/mod_map1.php	2007-12-18 15:38:37 UTC (rev 1933)
+++ trunk/mapbender/http/php/mod_map1.php	2007-12-19 11:29:25 UTC (rev 1934)
@@ -54,15 +54,19 @@
 <script type="text/javascript">
-function init_mod_map1(){
-   parent.mb_registerMapObj('mapframe1', 'maps', null,mod_map1_width, mod_map1_height);
-   document.getElementById("maps").style.width = mod_map1_width;
-   document.getElementById("maps").style.height = mod_map1_height;
+function init () {
+	parent.eventInitMap.register(function init_mod_map1(){
+		parent.mb_registerMapObj('mapframe1', 'maps', null,mod_map1_width, mod_map1_height);
+		document.getElementById("maps").style.width = mod_map1_width;
+		document.getElementById("maps").style.height = mod_map1_height;
 </script>
 </head>
-<body leftmargin='0' topmargin='0' onload="init_mod_map1()" bgcolor='#ffffff'>
+<body leftmargin='0' topmargin='0' onload="init()" bgcolor='#ffffff'>
 <div id='markResult' name='maps' style ='position: absolute; left: 0px; top: 0px; width: 0px; height: 0px; z-index:26'> </div>
 <div id='maps' name='maps' style ='position: absolute; left: 0px; top: 0px; width: 0px; height: 0px; z-index:2;'> </div>
Modified: trunk/mapbender/http/php/mod_mapOV.php
--- trunk/mapbender/http/php/mod_mapOV.php	2007-12-18 15:38:37 UTC (rev 1933)
+++ trunk/mapbender/http/php/mod_mapOV.php	2007-12-19 11:29:25 UTC (rev 1934)
@@ -61,18 +61,21 @@
-function init_mod_mapOV(){
-	parent.mb_registerMapObj('overview', 'maps', mod_overview_rank, mod_overview_width, mod_overview_height);
-	document.onmouseover = mod_ov_setHandler;
-	document.onmousedown = parent.mod_box_start;
-	document.onmouseup = mod_ov_getExtent;
-	document.onmousemove = parent.mod_box_run;
-	document.getElementById("maps").style.width = mod_overview_width;
-	document.getElementById("maps").style.height = mod_overview_height;
-	var ind = parent.getMapObjIndexByName('overview');
-	var ov_extent = parent.mb_mapObj[ind].getExtentInfos();
-	parent.mb_setWmcExtensionData({"ov_minx":ov_extent.minx,"ov_miny":ov_extent.miny,"ov_maxx":ov_extent.maxx,"ov_maxy":ov_extent.maxy});
+function init () {
+	parent.eventInitMap.register(function init_mod_mapOV(){
+		parent.mb_registerMapObj('overview', 'maps', mod_overview_rank, mod_overview_width, mod_overview_height);
+		document.onmouseover = mod_ov_setHandler;
+		document.onmousedown = parent.mod_box_start;
+		document.onmouseup = mod_ov_getExtent;
+		document.onmousemove = parent.mod_box_run;
+		document.getElementById("maps").style.width = mod_overview_width;
+		document.getElementById("maps").style.height = mod_overview_height;
+		var ind = parent.getMapObjIndexByName('overview');
+		var ov_extent = parent.mb_mapObj[ind].getExtentInfos();
+		parent.mb_setWmcExtensionData({"ov_minx":ov_extent.minx,"ov_miny":ov_extent.miny,"ov_maxx":ov_extent.maxx,"ov_maxy":ov_extent.maxy});
 function mod_ov_setHandler(e){
    parent.mb_isBF = "overview";
@@ -135,7 +138,7 @@
 </script>
 </head>
-<body leftmargin='0' topmargin='0' onload="init_mod_mapOV()"  bgcolor='#ffffff'>
 <div id='maps' name='maps' style =' position:absolute;left:0px;top:0px;width:0px;height:0px;' ></div>
 <div id='l_top' name='l_top' style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:11;visibility:hidden;background-color:red;cursor: crosshair;"></div>
 <div id='l_right' name='l_right' style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:12;visibility:hidden;background-color:red;cursor: crosshair;"></div>
More information about the Mapbender_commits mailing list
