[Mapbender-commits] r1069 - trunk/mapbender/resources/db/postgresql/utf8
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jan 26 11:51:22 EST 2007
Author: astrid_emde
Date: 2007-01-26 11:51:21 -0500 (Fri, 26 Jan 2007)
New Revision: 1069
   trunk/mapbender/resources/db/postgresql/utf8/pgsql_data.sql
new data for 2.4.1
Modified: trunk/mapbender/resources/db/postgresql/utf8/pgsql_data.sql
--- trunk/mapbender/resources/db/postgresql/utf8/pgsql_data.sql	2007-01-26 16:42:56 UTC (rev 1068)
+++ trunk/mapbender/resources/db/postgresql/utf8/pgsql_data.sql	2007-01-26 16:51:21 UTC (rev 1069)
@@ -1,15 +1,141 @@
 -- postgresql data utf8
--- Mapbender (Version: 2.4)
--- 2006-07-25
+-- Mapbender (Version: 2.4.1 c1)
+-- 2007-01-26
 UPDATE pg_catalog.pg_class SET reltriggers = 0;
+-- Started on 2007-01-26 12:20:29 Westeuropäische Normalzeit
+SET client_encoding = 'UTF8';
+SET check_function_bodies = false;
+SET client_min_messages = warning;
+SET search_path = public, pg_catalog;
--- TOC entry 1756 (class 0 OID 39047292)
--- Dependencies: 1231
+-- TOC entry 1814 (class 0 OID 0)
+-- Dependencies: 1244
+-- Name: gui_treegde_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('gui_treegde', 'id'), 99, true);
+-- TOC entry 1815 (class 0 OID 0)
+-- Dependencies: 1276
+-- Name: keyword_keyword_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('keyword', 'keyword_id'), 29, true);
+-- TOC entry 1816 (class 0 OID 0)
+-- Dependencies: 1248
+-- Name: layer_layer_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('layer', 'layer_id'), 19175, true);
+-- TOC entry 1817 (class 0 OID 0)
+-- Dependencies: 1252
+-- Name: mb_group_mb_group_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('mb_group', 'mb_group_id'), 20, true);
+-- TOC entry 1818 (class 0 OID 0)
+-- Dependencies: 1254
+-- Name: mb_log_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('mb_log', 'id'), 1, false);
+-- TOC entry 1819 (class 0 OID 0)
+-- Dependencies: 1257
+-- Name: mb_user_mb_user_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('mb_user', 'mb_user_id'), 1, true);
+-- TOC entry 1820 (class 0 OID 0)
+-- Dependencies: 1279
+-- Name: md_topic_category_md_topic_category_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('md_topic_category', 'md_topic_category_id'), 19, true);
+-- TOC entry 1821 (class 0 OID 0)
+-- Dependencies: 1265
+-- Name: wfs_conf_element_wfs_conf_element_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs_conf_element', 'wfs_conf_element_id'), 29, true);
+-- TOC entry 1822 (class 0 OID 0)
+-- Dependencies: 1263
+-- Name: wfs_conf_wfs_conf_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs_conf', 'wfs_conf_id'), 4, true);
+-- TOC entry 1823 (class 0 OID 0)
+-- Dependencies: 1267
+-- Name: wfs_element_element_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs_element', 'element_id'), 175, true);
+-- TOC entry 1824 (class 0 OID 0)
+-- Dependencies: 1269
+-- Name: wfs_featuretype_featuretype_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs_featuretype', 'featuretype_id'), 23, true);
+-- TOC entry 1825 (class 0 OID 0)
+-- Dependencies: 1261
+-- Name: wfs_wfs_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs', 'wfs_id'), 2, true);
+-- TOC entry 1826 (class 0 OID 0)
+-- Dependencies: 1272
+-- Name: wms_wms_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wms', 'wms_id'), 909, true);
+-- TOC entry 1782 (class 0 OID 47913121)
+-- Dependencies: 1238
 -- Data for Name: gui; Type: TABLE DATA; Schema: public; Owner: admin
@@ -26,109 +152,34 @@
 INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_north_america', 'wms_north_america', 'Container for north America data', 1);
 INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_worldwide', 'wms_worldwide', 'Container for world wide data', 1);
 INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('gui2', 'gui2', 'client element collection', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('gui_digitize', 'gui_digitize', 'new gui for digitizing', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('gui_digitize', 'gui_digitize', 'client element collection', 1);
--- TOC entry 1757 (class 0 OID 39047298)
--- Dependencies: 1232
+-- TOC entry 1783 (class 0 OID 47913127)
+-- Dependencies: 1239
 -- Data for Name: gui_element; Type: TABLE DATA; Schema: public; Owner: admin
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'metadata', 2, 1, 'shows informations about the wms and the requests of the gui', 'img', '../img/button_blink_red/metadata_off.png', 'onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_blink_red/metadata_over.png"'' onmouseout=''this.src="../img/button_blink_red/metadata_off.png"'' title="Show WMS infos"', 710, 60, 24, 24, 1, '', '', '', 'mod_displayObj.js', '', '', '', 'http://www.mapbender.org/index.php/Metadata');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'loadData', 2, 1, 'IFRAME, um Daten zu laden', 'iframe', '../html/mod_blank.html', 'frameborder = "0" ', 0, 0, 1, 1, 0, 'visibility:visible', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'loadwmc', 2, 0, 'load workspace from WMC', 'img', '../img/button_wmc/wmc_load.png', 'onclick=''mod_loadwmc()'' onmouseover=''mod_loadwmc_init(this)''
-title=''Load a web map context document''', 760, 10, 24, 24, 1, '', '', '', 'mod_loadwmc.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/LoadWMC');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'logo', 2, 1, 'Logo', 'img', '../img/mapbender_logo.png', '', 20, 20, 180, 26, 5, '', '', '', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'imprint', 2, 1, 'Information about the owner of the gui', 'iframe', '../html/tab_imprint.html', 'frameborder = "0" ', 1, 1, 1, 1, 5, 'visibility:hidden;', '', 'iframe', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'keyHandler', 2, 1, 'onkeydownevent (only IE)', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_key.php', '', 'mapframe1', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''
-onmouseover=''this.src="../img/button_gray/logout_over.png"''
-onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 660, 10, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/Logout');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'mapbender', 2, 1, 'Mapbender-Logo', 'div', '', 'onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"', 81, -19, 1, 1, 30, 'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;', '<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr>
-<script language="javascript">
-mb_registerSubFunctions("mod_mapbender()");
-function mod_mapbender(){
-document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90;
-document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1;
-</script>', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'mapframe1', 2, 1, 'frame for a map', 'iframe', '../php/mod_map1.php?sessionID', 'scrolling="no" frameborder=''0'' ', 230, 55, 500, 450, 2, '', '', 'iframe', '', '', '', '', 'http://www.mapbender.org/index.php/Mapframe');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'metadata', 2, 1, 'shows informations about the wms and the requests of the gui', 'img', '../img/button_gray/metadata_off.png', 'onClick="window.location.href=''javascript:mod_displayObj()''"
-border=''0''
-onmouseover=''this.src="../img/button_gray/metadata_over.png"''
-onmouseout=''this.src="../img/button_gray/metadata_off.png"'' title="Show service metadata"', 580, 10, 24, 24, 1, '', '', '', 'mod_displayObj.js', '', '', '', 'http://www.mapbender.org/index.php/Metadata');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'navFrame', 2, 1, 'navigation mapborder', 'div', '', '', 0, 0, 0, 0, 0, 'font-size:1px;', '<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div>
-<div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div>
-<div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div>
-<div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div>
-<div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div>
-<div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div>
-<div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div>
-<div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>
-', 'div', 'mod_navFrame.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/NavFrame');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'overview', 2, 1, 'OverviewFrame', 'iframe', '../php/mod_mapOV.php?wms=0&sessionID', 'scrolling="no" frameborder=''0'' ', 30, 65, 150, 130, 100, '', '', 'iframe', '', 'mod_box1.js', 'mapframe1', '', 'http://www.mapbender.org/index.php/Overview');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'pan1', 2, 1, 'pan', 'img', '../img/button_gray/pan_off.png', 'onmouseover = "mb_regButton(''init_mod_pan'')" title="Pan"', 270, 10, 24, 24, 1, '', '', '', 'mod_pan.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Pan');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'loadData', 2, 1, 'IFRAME, um Daten zu laden', 'iframe', '../html/mod_blank.html', 'frameborder = "0" ', 0, 0, 1, 1, 0, 'visibility:visible', '', 'iframe', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'printPDF', 2, 1, 'pdf print', 'iframe', '../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf', 'frameborder = "0" ', 1, 1, 2, 2, 5, 'visibility:hidden', '', 'iframe', '', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Print');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'rubberExt', 3, 1, 'deletes temporary (digitized) objects', 'div', '', ' title="Rubber"', 0, 0, 0, 0, 0, '', '', 'div', 'mod_rubberExt.js', '', 'mapframe1', 'setExtRequest', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'sandclock', 2, 1, 'displays a sand clock while waiting for requests', 'div', '', '', 80, 0, 0, 0, 0, '', '', 'div', 'mod_sandclock.php', '', 'mapframe1', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'sandclock', 2, 1, 'displays a sand clock while waiting for requests', 'div', '', '', 80, 0, 0, 0, 0, '', '', 'div', 'mod_sandclock.php', '', 'mapframe1', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'setBBOX', 2, 0, 'set extent for mapframe and overviewframe', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_setBBOX1.php', '', 'mapframe1', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'savewmc', 2, 0, 'save workspace as WMC', 'img', '../img/button_wmc/wmc_save.png', 'onclick=''mod_savewmc()'' onmouseover=''mod_savewmc_init(this)''
-title=''Save workspace as web map context document''', 730, 10, 24, 24, 1, '', '', '', 'mod_savewmc.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/SaveWMC');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'layout_linie2', 3, 0, 'layout', 'div', '', '', 1, 35, 830, 1, 1, 'background-color:#799FEB;font-size:1px;', '', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'legend', 2, 1, 'legend', 'iframe', '../javascripts/mod_legend.php?sessionID&e_id_css=legend', 'frameborder=''0''', 1, 1, 1, 1, 3, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'scaleSelect', 2, 0, 'Scale-Selectbox', 'select', '', 'onchange=''mod_scaleSelect(this)''', 555, 25, 100, 20, 1, '', '<option value = ''''>Scale</option>
-<option value=''100''>1 : 100</option>
-<option value=''250''>1 : 250</option>
-<option value=''500''>1 : 500</option>
-<option value=''1000''>1 : 1000</option>
-<option value=''2500''>1 : 2500</option>
-<option value=''5000''>1 : 5000</option>
-<option value=''10000''>1 : 10000</option>
-<option value=''25000''>1 : 25000</option>
-<option value=''30000''>1 : 30000</option>
-<option value=''50000''>1 : 50000</option>
-<option value=''75000''>1 : 75000</option>
-<option value=''100000''>1 : 100000</option>
-<option value=''200000''>1 : 200000</option>
-<option value=''300000''>1 : 300000</option>
-<option value=''400000''>1 : 400000</option>
-<option value=''500000''>1 : 500000</option>
-<option value=''600000''>1 : 600000</option>
-<option value=''700000''>1 : 700000</option>
-<option value=''800000''>1 : 800000</option>
-<option value=''900000''>1 : 900000</option>
-<option value=''1000000''>1 : 1000000</option>', 'select', 'mod_scaleSel.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'selArea1', 2, 1, 'zoombox', 'img', '../img/button_gray/selArea_off.png', 'onmouseover = "mb_regButton(''init_selArea1'')" title="Zoom by rectangle"', 295, 10, 24, 24, 1, '', '', '', 'mod_selArea1.php', 'mod_box1.js', 'mapframe1', '', 'http://www.mapbender.org/index.php/SelArea1');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'setBackground', 2, 1, 'switch background-wms', 'form', '', '', 30, 210, NULL, NULL, 1, '', '<select style=''font-family: Arial, sans-serif; font-size:12''
-name=''mod_setBackground_list''
-onchange=''mod_setBackground_change(this)'' ><option
-value=''0''></option></select>', 'form', 'mod_setBackground.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'setBBOX', 2, 0, 'set extent for mapframe and overviewframe', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_setBBOX1.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'setSpatialRequest', 2, 1, 'Spatial Request', 'div', '', '', 1, 1, 1, 1, 1, 'visibility:hidden;', '', 'div', '../javascripts/mod_wfs_SpatialRequest.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'showCoords_div', 2, 1, 'displays coodinates by onmouseover', 'img', '../img/button_gray/coords_off.png', 'onmouseover = "mb_regButton(''init_mod_showCoords_div'')" title="Coordinates" ', 450, 10, 24, 24, 1, 'background-color:white; font-family: Arial, Helvetica, sans-serif;font-size:10px;', '', '', 'mod_coords_div.php', '', 'mapframe1', 'dependendDiv', 'http://www.mapbender.org/index.php/ShowCoords_div');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'tabs', 2, 1, 'vertical tabs to handle iframes', 'div', '', '', 10, 240, 200, 20, 2, 'font-family: Arial,Helvetica;font-weight:bold;', '', 'div', 'mod_tab.php', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'treeGDE', 2, 1, 'dircetory structure, checkbox for visible, checkbox for querylayer', 'iframe', '../html/mod_sync_treefolder.php?sessionID&e_id_css=treeGDE', 'frameborder = "0" ', 1, 1, 1, 1, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/TreeGde');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'wfs', 2, 1, 'wfs request and result handling', 'div', '', '', 1, 1, 1, 1, 0, 'visibility:hidden', '', 'div', 'wfs.js', '../extensions/wz_jsgraphics.js', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'showLoggedUser', 2, 1, 'displays the logged admin', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, NULL, '', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'meetingPoint', 2, 1, 'create a meeting point', 'iframe', '../php/mod_meetingPoint.php?sessionID', 'frameborder = "0" ', 0, 0, NULL, NULL, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'treeGDE', 2, 1, 'dircetory structure, checkbox for visible, checkbox for querylayer', 'iframe', '../html/mod_sync_treefolder.php?sessionID&e_id_css=treeGDE', 'frameborder = "0" ', 1, 1, 1, 1, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'wfs_conf', 2, 1, 'get all wfs_conf-params', 'iframe', '../php/mod_wfs.php', 'frameborder = "0"', 1, 1, 1, 1, 0, 'visibility:hidden', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'wfsresult', 2, 1, 'display the list of wfs results', 'iframe', '../html/mod_blank.html', 'frameborder = "0"', 10, 730, 200, 150, 4, '', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'WMS_preferences', 2, 1, 'configures the preferences of each loaded wms', 'img', '../img/button_gray/preferences_off.png', 'onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''
-onmouseover=''this.src = this.src.replace(/_off/,"_over");''
-onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="WMS preferences"', 540, 10, 24, 24, 1, '', '', '', '', '', 'mapframe1,treeGDE', '', 'http://www.mapbender.org/index.php/WMS_preferences');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'Gazetteer_mbUser', 2, 1, 'a gazetteer for rivers of germany', 'iframe', '../php/mod_wfs_gazetteer.php?sessionID&wfs_conf=1&target=mapframe1,overview&resultFrame=wfsresult', 'frameborder = "0"', 10, 600, 300, 150, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1,overview', 'wz-graphics', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'zoomFull', 2, 1, 'zoom to full extent button', 'img', '../img/button_gray/zoomFull_off.png', 'onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"  title="Display complete map"', 320, 10, 24, 24, 2, '', '', 'img', 'mod_zoomFull.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomFull');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'zoomIn1', 2, 1, 'zoomIn button', 'img', '../img/button_gray/zoomIn2_off.png', 'onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' title="Zoom in"', 220, 10, 24, 24, 1, '', '', '', 'mod_zoomIn1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomIn');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'zoomOut1', 2, 1, 'zoomOut button', 'img', '../img/button_gray/zoomOut2_off.png', 'onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' title="Zoom out"', 245, 10, 24, 24, 1, '', '', '', 'mod_zoomOut1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomOut');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'body', 1, 1, 'body
 (obligatory)', 'body', '', 'onload="init()"', NULL, NULL, NULL, NULL, NULL, 'background-image:url(../img/background_yellow.jpg);background-repeat:repeat-x;', '', '', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'rubber', 3, 1, 'deletes temporary (digitized) objects', 'div', '', 'title="Rubber"', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_rubber.js', '', 'mapframe1', 'measure', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'zoomIn1', 2, 1, 'zoomIn button', 'img', '../img/button_blink_red/zoomIn2_off.png', 'onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' title=''Zoom in''', 210, 60, 24, 24, 1, '', '', '', 'mod_zoomIn1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomIn');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'closePolygon', 3, 1, 'close Polygon ', 'div', '', 'title="Close Polygon"', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_closePolygon.js', '', 'mapframe1', 'measure', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'getArea', 3, 1, 'Calculation of area, Postgis required', 'div', '', 'title="Get Area"', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_getArea.php', '', 'mapframe1', 'measure', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'owsproxy', 2, 1, 'secure services', 'a', '', 'href=\\"../php/mod_owsproxy_conf.php?sessionID\\"\\'' target=\\"AdminFrame\\"', 10, 910, 200, 20, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'OWSPROXY', 'a', '', '', '', 'AdminFrame', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'owsproxy', 2, 1, 'secure services', 'a', '', E'href=\\"../php/mod_owsproxy_conf.php?sessionID\\"\\'' target=\\"AdminFrame\\"', 10, 910, 200, 20, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'OWSPROXY', 'a', '', '', '', 'AdminFrame', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'delete_filteredGui', 2, 1, 'GUI l&ouml;schen', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 110, 240, 80, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI l&ouml;schen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'logout', 2, 1, 'Logout', 'img', '../img/button_blue/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blue/logout_over.png"'' onmouseout=''this.src="../img/button_blue/logout_off.png"''', 798, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/Logout');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'gui_owner', 2, 1, 'set owner', 'a', '', 'href = "../php/mod_gui_owner.php?sessionID&e_id_css=gui_owner" target = "AdminFrame" ', 10, 830, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI -> OWNER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
@@ -137,7 +188,6 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'repaint', 2, 1, 'refresh a mapobject', 'img', '../img/button_blue/repaint_off.png', 'onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)'' title="Redraw"', 358, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_repaint.php', '', 'mapframe1', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'wfs_conf', 2, 1, 'create and edit a gazetteer module', 'a', '', 'href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"', 10, 870, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'WFS CONF', 'a', '', '', '', 'AdminFrame', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'changeEPSG', 2, 1, 'change EPSG, Postgres required, overview is targed for full extent', 'iframe', '../php/mod_changeEPSG.php?sessionID', 'scrolling="no" frameborder=''0'' ', 432, 25, 107, 24, 1, '', '', 'iframe', '', '', 'overview', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'resizeMapsize', 2, 1, 'dynamically resize the mapframe in relation to the browsersize', 'div', '', 'onload=''adjustDimension()''', -10, 10, 1, 1, 1, '', '', 'div', 'mod_resize_mapsize.php', '', 'mapframe1', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_africa', 'body', 1, 1, 'obligatory body', 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_gdi_de', 'body', 1, 1, 'obligatory body', 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_germany', 'body', 1, 1, 'obligatory body', 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '', NULL);
@@ -146,7 +196,7 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'tabs', 2, 1, 'vertical tabs to handle iframes', 'div', '', '', 9, 245, 184, 25, 2, 'font-family: Arial,Helvetica;font-weight:bold;', '', 'div', 'mod_tab.php', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_worldwide', 'body', 1, 1, 'obligatory body', 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'loadWFS', 2, 1, 'load capabilities in a gui', 'a', '', 'href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"', 10, 850, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'LOAD WFS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/WFS_Konfiguration');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_africa', 'content', 2, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=\\''javascript:history.back()\\''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Beh&auml;lter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfl&auml;che. Verwenden Sie diesen (<a href=\\''javascript:history.back()\\''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuw&auml;hlen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_africa', 'content', 2, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', E'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=\\''javascript:history.back()\\''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Beh&auml;lter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfl&auml;che. Verwenden Sie diesen (<a href=\\''javascript:history.back()\\''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuw&auml;hlen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'addWMS', 2, 1, 'add a WMS to the running application', 'img', '../img/button_blue/add_off.png', 'onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS"', 580, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_addWMS.php', '', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/AddWMS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'back', 2, 1, 'History.back()', 'img', '../img/button_blue/back_off_disabled.png', 'onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" title="Back"', 398, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_back.php', '', 'mapframe1,overview0', '', 'http://www.mapbender.org/index.php/Back');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'copyright', 2, 1, 'a Copyright in the map', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_copyright.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Copyright');
@@ -204,7 +254,6 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'updateWMSs', 2, 1, 'edit the elements of the gui', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 10, 70, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'UPDATE WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/UpdateWMS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_europe', 'content', 2, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'rename_copy_Gui', 2, 1, 'rename and copy gui', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 10, 470, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'RENAME COPY GUI', 'a', '', '', '', 'AdminFrame', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'showLoggedUser', 2, 1, 'displays the logged admin', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 10, 2, 200, 30, 0, '', '', 'iframe', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_gdi_de', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''onmouseover=''this.src="../img/button_gray/logout_over.png"''onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'user_filteredGroup', 2, 1, 'allocate user to groups where this admin is owner', 'a', '', 'href = "../php/mod_user_filteredGroup.php?sessionID&e_id_css=user_filteredGroup" target = "AdminFrame" ', 10, 450, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'USER -> myGROUP', 'a', '', '', '', 'AdminFrame', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'user_filteredGui', 2, 1, 'allocate guis of this admin to user', 'a', '', 'href = "../php/mod_user_filteredGui.php?sessionID&e_id_css=user_filteredGui" target = "AdminFrame" ', 10, 390, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'USER-> myGUI', 'a', '', '', '', 'AdminFrame', NULL);
@@ -275,7 +324,6 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'mapframe1', 2, 1, 'frame for a map', 'iframe', '../php/mod_map1.php?sessionID', 'scrolling="no" frameborder=''0'' ', 230, 55, 500, 450, 2, '', '', 'iframe', '', '', '', '', 'http://www.mapbender.org/index.php/Mapframe');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_north_america', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''onmouseover=''this.src="../img/button_gray/logout_over.png"''onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'setBBOX', 2, 0, 'set extent for mapframe and overviewframe', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_setBBOX1.php', '', 'mapframe1', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'tabs', 2, 1, 'vertical tabs to handle iframes', 'div', '', '', 10, 240, 200, 20, 2, 'font-family: Arial,Helvetica;font-weight:bold;', '', 'div', 'mod_tab.php', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'addWMS', 2, 1, 'add a WMS to the running application', 'img', '../img/button_blink_red/add_off.png', 'onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS"', 645, 60, 24, 24, 1, '', '', '', 'mod_addWMS.php', '', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/AddWMS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'back', 2, 1, 'History.back()', 'img', '../img/button_blink_red/back_off_disabled.png', 'onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" title="Back"', 400, 60, 24, 24, 1, '', '', '', 'mod_back.php', '', 'mapframe1,overview', '', 'http://www.mapbender.org/index.php/Back');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'copyright', 2, 1, 'a Copyright in the map', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_copyright.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Copyright');
@@ -292,6 +340,7 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_worldwide', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''onmouseover=''this.src="../img/button_gray/logout_over.png"''onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'loadData', 2, 1, 'IFRAME to load data', 'iframe', '../html/mod_blank.html', 'frameborder = "0" ', 0, 0, 1, 1, 0, 'visibility:visible', '', 'iframe', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'help', 2, 1, 'button help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')" title="help"', 210, 2, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', 'http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'tabs', 2, 1, 'vertical tabs to handle iframes', 'div', '', '', 10, 240, 200, 20, 2, 'font-family: Arial,Helvetica;font-weight:bold;', '', 'div', 'mod_tab.php', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'mapbender', 2, 1, 'Mapbender-Logo', 'div', '', 'onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"', -59, 1, 1, 1, 30, 'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;', '<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>', 'div', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'print1', 2, 0, 'start print GUI', 'img', '../img/button_blink_red/print_off.png', 'onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID","printWin","width=300, height=400, resizable=yes ")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Print"', 555, 60, 24, 24, 1, '', '', '', '', '', 'mapframe1', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'repaint', 2, 1, 'refresh a mapobject', 'img', '../img/button_blink_red/repaint_off.png', 'onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)'' title="Redraw"', 360, 60, 24, 24, 1, '', '', '', 'mod_repaint.php', '', 'mapframe1', '', NULL);
@@ -313,7 +362,6 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'zoomCoords', 2, 1, 'zoom to coordinate', 'iframe', '../php/mod_zoomCoords_en.php?sessionID', 'frameborder = "0" ', 205, 7, 220, 45, 0, '', '', 'iframe', '', '', 'mapframe1,overview', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'selArea1', 2, 1, 'zoombox', 'img', '../img/button_blink_red/selArea_off.png', 'onmouseover = "mb_regButton(''init_selArea1'')" title="Zoom by rectangle"', 285, 60, 24, 24, 1, '', '', '', 'mod_selArea1.php', 'mod_box1.js', 'mapframe1', '', 'http://www.mapbender.org/index.php/SelArea1');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'showCoords_div', 2, 1, 'displays coordinates by onmouseover', 'img', '../img/button_blink_red/coords_off.png', 'onmouseover = "mb_regButton(''init_mod_showCoords_div'')"  title="Coordinates"', 490, 60, 24, 24, 1, 'background-color:white; font-family: Arial, Helvetica, sans-serif;font-size:10px;', '', '', 'mod_coords_div.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ShowCoords_div');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'treeGDE', 2, 1, 'directory tree, checkbox for visible, checkbox for querylayer,', 'iframe', '../html/mod_sync_treefolder.php?sessionID&e_id_css=treeGDE', 'frameborder = "0" ', 10, 220, 200, 300, NULL, 'visibility:visible', '', 'iframe', '', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/TreeGde');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'WMS_preferences', 2, 1, 'configure the preferences of each loaded wms', 'img', '../img/button_blink_red/preferences_off.png', 'onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="WMS preferences"', 670, 60, 24, 24, 1, '', '', '', '', '', 'mapframe1,treeGDE', '', 'http://www.mapbender.org/index.php/WMS_preferences');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'CreateTreeGDE', 2, 1, 'create a foldertree for a individual geodataexplorer', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 10, 810, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'CREATE TREE_GDE', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/ConfTreeGde');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'CreateTreeGDE', 2, 1, 'Ordnerbaum konfigurieren', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 10, 280, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Ordnerbaum konfigurieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/ConfTreeGde');
@@ -363,6 +411,7 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'deleteGui', 2, 1, 'delete gui', 'a', '', 'href = "../php/mod_deleteGUI.php?sessionID" target = "AdminFrame" ', 10, 150, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'DELETE GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'deleteWMS', 2, 1, 'delete wms', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 10, 110, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'DELETE WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWMS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'deleteWMS', 2, 1, '!Vollst&auml;ndig l&ouml;schen!', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 10, 100, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', '!Vollst&auml;ndig l&ouml;schen!', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'highlightPOI', 2, 1, 'highlight 1 to n pois in your gui with a Symbol and a special text', 'div', '', '', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_highlightPOI.php', '', 'mapframe1', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'deleteWMS', 2, 1, '!Delete completely!', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 10, 100, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', '!Delete completely!', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWMS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'delete_filteredGui', 2, 1, 'delete guis of this admin', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 10, 790, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'DELETE myGUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'layout_linie', 3, 0, 'layout', 'div', '', '', 1, 70, 830, 1, 1, 'background-color:#799FEB;font-size:1px;', '', 'div', '', '', '', '', '');
@@ -382,64 +431,68 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'loadWMS', 2, 1, 'load capabilities in a gui', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 10, 30, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'LOAD WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'loadWMS', 2, 1, 'Capabilities hochladen', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 10, 60, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Capabilities hochladen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'loadWMS', 2, 1, 'Load Capabilities', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 10, 60, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Load Capabilities', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_africa', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick=\\"window.location.href=\\''../php/mod_logout.php?sessionID\\''\\" border=\\''0\\''onmouseover=\\''this.src=\\"../img/button_gray/logout_over.png\\"\\''onmouseout=\\''this.src=\\"../img/button_gray/logout_off.png\\"\\'' title=\\"Logout\\"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_africa', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', E'onClick=\\"window.location.href=\\''../php/mod_logout.php?sessionID\\''\\" border=\\''0\\''onmouseover=\\''this.src=\\"../img/button_gray/logout_over.png\\"\\''onmouseout=\\''this.src=\\"../img/button_gray/logout_off.png\\"\\'' title=\\"Logout\\"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 180, 2, 24, 24, 1, '', '', 'img', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 180, 2, 24, 24, 2, '', '', 'img', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 180, 2, 24, 24, 2, '', '', 'img', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'logout', 2, 1, 'Logout', 'img', '../img/button_blink_red/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blink_red/logout_over.png"'' onmouseout=''this.src="../img/button_blink_red/logout_off.png"'' title="Logout"', 830, 60, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/Logout');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'addWMS', 2, 1, 'add a WMS to the running application', 'img', '../img/button_gray/add_off.png', 'onclick=''mod_addWMS()''
-onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS"', 515, 10, 24, 24, 1, '', '', '', 'mod_addWMS.php', '', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/AddWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'addWMSfromfilteredList', 2, 1, 'add a WMS to the running application from a filtered list', 'img', '../img/button_gray/add_filtered_list_off.png', 'onclick=''window.open("../javascripts/mod_addWMSfromfilteredList.php?sessionID","printWin","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''
-onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"', 490, 10, 24, 24, 1, '', '', '', '', 'mod_addWMSgeneralFunctions.js', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 660, 10, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/Logout');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'legend', 2, 1, 'legend', 'iframe', '../javascripts/mod_legend.php?sessionID&wms_legend = yes', 'frameborder=''0''', -59, 200, 180, 600, 3, '', '', 'iframe', '', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'back', 2, 1, 'History.back()', 'img', '../img/button_gray/back_off_disabled.png', 'onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" title="Back"', 360, 10, 24, 24, 1, '', '', '', 'mod_back.php', '', 'mapframe1,overview0', '', 'http://www.mapbender.org/index.php/Back');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'body', 1, 1, 'body (obligatory)', 'body', '', 'onload="init()"', 0, 0, 0, 0, 0, '', '', '', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'legend', 2, 1, 'legend', 'iframe', '../javascripts/mod_legend.php?sessionID&e_id_css=legend', 'frameborder=''0''', 1, 1, 1, 1, 3, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'closePolygonExt', 3, 0, 'close Polygon ', 'div', '', ' title="Close Polygon"', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_closePolygonExt.js', '', 'mapframe1', 'setExtRequest', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'copyright', 2, 1, 'a Copyright in the map', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_copyright.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Copyright');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'loadwmc', 2, 1, 'load workspace from WMC', 'img', '../img/button_blink_red/wmc_load_off.png', 'onclick=''mod_loadwmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");''
 onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Load a web map context document"', 895, 60, 24, 24, 1, '', '', '', 'mod_loadwmc.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/LoadWMC');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'dependentDiv', 2, 1, 'displays infos in a sticky div-tag', 'div', '', '', 81, -19, 1, 1, 0, 'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;', '', 'div', 'mod_dependentDiv.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/DependentDiv');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'digitize', 2, 1, 'Digitize tool.', 'iframe', '../javascripts/mod_digitize_tab.php?sessionID', 'frameborder = "0" ', 1, 1, 1, 1, 5, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'dragMapSize', 2, 1, 'drag & drop Mapsize', 'div', '', '', 81, -19, 0, 0, 2, 'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;', '', 'div', 'mod_dragMapSize.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'featureInfo1', 2, 0, 'FeatureInfoRequest', 'img', '../img/button_gray/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfo1'')"', 140, 40, 24, 24, 1, '', '', '', 'mod_featureInfo.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/FeatureInfo');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'FeatureInfoRedirect', 2, 1, 'redirect featureInfoRequests in an iframe for each wms', 'iframe', '../html/mod_blank.html', 'frameborder="0"', 83, -17, 1, 1, 0, '', '', 'iframe', 'mod_featureInfoRedirect.php', '', '', '', 'http://www.mapbender.org/index.php/FeatureInfoRedirect');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'AdminFrame', 2, 1, 'the frame for administration modules', 'iframe', '', 'frameborder = \\"0\\"', 220, 20, 800, 800, NULL, '', '', 'iframe', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'featureInfoTunnel', 2, 1, 'FeatureInfoRequest with local path', 'img', '../img/button_gray/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfoTunnel'')" title="Query"', 425, 10, 24, 24, 1, '', '', '', 'mod_featureInfoTunnel.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/FeatureInfoTunnel');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'forward', 2, 1, 'History.forward()', 'img', '../img/button_gray/forward_off_disabled.png', 'onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" title="Forward"', 385, 10, 24, 24, 1, '', '', '', 'mod_forward.php', '', 'mapframe1,overview0', '', 'http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'AdminFrame', 2, 1, 'the frame for administration modules', 'iframe', '', E'frameborder = \\"0\\"', 220, 20, 800, 800, NULL, '', '', 'iframe', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'addWMS', 2, 1, 'add a WMS to the running application', 'img', '../img/button_gray/add_off.png', 'onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS"', 515, 10, 24, 24, 1, '', '', '', 'mod_addWMS.php', '', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/AddWMS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'back', 2, 1, 'History.back()', 'img', '../img/button_gray/back_off_disabled.png', 'onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" title="Back"', 360, 10, 24, 24, 1, '', '', '', 'mod_back.php', '', 'mapframe1,overview0', '', 'http://www.mapbender.org/index.php/Back');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'copyright', 2, 1, 'a Copyright in the map', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_copyright.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Copyright');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'Gazetteer_mbUser', 2, 1, 'a gazetteer for user in the mapbender user map', 'iframe', '../php/mod_wfs_gazetteer.php?sessionID&wfs_conf=1&target=mapframe1,overview&resultFrame=wfsresult', 'frameborder = "0"', 10, 600, 300, 150, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1,overview', 'wz-graphics', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'dependentDiv', 2, 1, 'displays infos in a sticky div-tag', 'div', '', '', 81, -19, 1, 1, 0, 'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;', '', 'div', 'mod_dependentDiv.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/DependentDiv');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'featureInfo1', 2, 0, 'FeatureInfoRequest', 'img', '../img/button_gray/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfo1'')"', 140, 40, 24, 24, 1, '', '', '', 'mod_featureInfo.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/FeatureInfo');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'FeatureInfoRedirect', 2, 1, 'redirect featureInfoRequests in an iframe for each wms', 'iframe', '../html/mod_blank.html', 'frameborder="0"', 83, -17, 1, 1, 0, '', '', 'iframe', 'mod_featureInfoRedirect.php', '', '', '', 'http://www.mapbender.org/index.php/FeatureInfoRedirect');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'featureInfoTunnel', 2, 1, 'FeatureInfoRequest with local path', 'img', '../img/button_gray/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfoTunnel'')" title="Query"', 425, 10, 24, 24, 1, '', '', '', 'mod_featureInfoTunnel.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/FeatureInfoTunnel');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'forward', 2, 1, 'History.forward()', 'img', '../img/button_gray/forward_off_disabled.png', 'onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" title="Forward"', 385, 10, 24, 24, 1, '', '', '', 'mod_forward.php', '', 'mapframe1,overview0', '', 'http://www.mapbender.org/index.php/Forward');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'help', 2, 1, 'button help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')" title="help"', 620, 10, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', 'http://www.mapbender.org');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'metadata', 2, 1, 'shows informations about the wms and the requests of the gui', 'img', '../img/button_gray/metadata_off.png', 'onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_gray/metadata_over.png"'' onmouseout=''this.src="../img/button_gray/metadata_off.png"'' title="Show service metadata"', 580, 10, 24, 24, 1, '', '', '', 'mod_displayObj.js', '', '', '', 'http://www.mapbender.org/index.php/Metadata');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'imprint', 2, 1, 'Information about the owner of the gui', 'iframe', '../html/tab_imprint.html', 'frameborder = "0" ', 1, 1, 1, 1, 5, 'visibility:hidden;', '', 'iframe', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'navFrame', 2, 1, 'navigation mapborder', 'div', '', '', 0, 0, 0, 0, 0, 'font-size:1px;', '<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ', 'div', 'mod_navFrame.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/NavFrame');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'overview', 2, 1, 'OverviewFrame', 'iframe', '../php/mod_mapOV.php?wms=0&sessionID', 'scrolling="no" frameborder=''0'' ', 30, 65, 150, 130, 100, '', '', 'iframe', '', 'mod_box1.js', 'mapframe1', '', 'http://www.mapbender.org/index.php/Overview');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'pan1', 2, 1, 'pan', 'img', '../img/button_gray/pan_off.png', 'onmouseover = "mb_regButton(''init_mod_pan'')" title="Pan"', 270, 10, 24, 24, 1, '', '', '', 'mod_pan.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Pan');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'savewmc', 2, 1, 'save workspace as WMC', 'img', '../img/button_blink_red/wmc_save_off.png', 'onclick=''mod_savewmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Save workspace as web map context document"', 870, 60, 24, 24, 1, '', '', '', 'mod_savewmc.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/SaveWMC');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'printPDF', 2, 1, 'pdf print', 'iframe', '../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf', 'frameborder = "0" ', 1, 1, 2, 2, 5, 'visibility:hidden', '', 'iframe', '', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Print');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'selArea1', 2, 1, 'zoombox', 'img', '../img/button_gray/selArea_off.png', 'onmouseover = "mb_regButton(''init_selArea1'')" title="Zoom by rectangle"', 295, 10, 24, 24, 1, '', '', '', 'mod_selArea1.php', 'mod_box1.js', 'mapframe1', '', 'http://www.mapbender.org/index.php/SelArea1');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'initWmc', 2, 1, 'initialise client with wmc', 'div', '', '', 1, 1, 1, 1, NULL, 'visibility:hidden', '', 'div', 'mod_initWmc.php', '', 'mapframe1,overview', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'help', 2, 1, 'button help', 'img', '../img/button_blink_red/help_off.png', 'onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")'' title="Help"', 790, 60, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'highlightPOI', 2, 1, 'highlight 1 to n pois in your gui with a Symbol and a special text', 'div', '', '', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_highlightPOI.php', '', 'mapframe1', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'treeGDE', 2, 1, 'dircetory structure, checkbox for visible, checkbox for querylayer', 'iframe', '../html/mod_sync_treefolder.php?sessionID&e_id_css=treeGDE', 'frameborder = "0" ', 1, 1, 1, 1, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/TreeGde');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'WMS_preferences', 2, 1, 'configures the preferences of each loaded wms', 'img', '../img/button_gray/preferences_off.png', 'onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="WMS preferences"', 540, 10, 24, 24, 1, '', '', '', '', '', 'mapframe1,treeGDE', '', 'http://www.mapbender.org/index.php/WMS_preferences');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'zoomFull', 2, 1, 'zoom to full extent button', 'img', '../img/button_gray/zoomFull_off.png', 'onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"  title="Display complete map"', 320, 10, 24, 24, 2, '', '', 'img', 'mod_zoomFull.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomFull');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'keyHandler', 2, 1, 'onkeydownevent (only IE)', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_key.php', '', 'mapframe1', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'zoomOut1', 2, 1, 'zoomOut button', 'img', '../img/button_gray/zoomOut2_off.png', 'onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' title="Zoom out"', 245, 10, 24, 24, 1, '', '', '', 'mod_zoomOut1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomOut');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'Gazetteer_mbUser', 2, 1, 'a gazetteer for rivers of germany', 'iframe', '../php/mod_wfs_gazetteer.php?sessionID&wfs_conf=1&target=mapframe1,overview&resultFrame=wfsresult', 'frameborder = "0"', 10, 600, 300, 150, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1,overview', 'wz-graphics', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'dragMapSize', 2, 1, 'drag & drop Mapsize', 'div', '', '', 81, -19, NULL, NULL, 2, 'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;', '', 'div', 'mod_dragMapSize.php', '', 'mapframe1', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'setBackground', 2, 1, 'switch background-wms', 'form', '', '', 30, 210, NULL, NULL, 1, '', '<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>', 'form', 'mod_setBackground.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'zoomIn1', 2, 1, 'zoomIn button', 'img', '../img/button_gray/zoomIn2_off.png', 'onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' title=''Zoom in''', 220, 10, 24, 24, 1, '', '', '', 'mod_zoomIn1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'orphanWMS', 2, 1, 'display orphaned WMS', 'a', '', 'href = "../php/mod_orphanWMS.php?sessionID&&elementID=orphanWMS" target = "AdminFrame"', 10, 930, 200, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'ORPHAN WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'resizeMapsize', 2, 1, 'resize_mapsize', 'img', '../img/button_blink_red/resizemapsize_off.png', 'onclick = "adjustDimension()"
+onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Kartenfenstergröße optimieren"', 838, 40, 24, 24, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_resize_mapsize.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'treeGDE', 2, 1, 'directory tree, checkbox for visible, checkbox for querylayer,', 'iframe', '../html/mod_treefolder2.php?sessionID', E'frameborder = \\"0\\" ', 10, 220, 200, 300, NULL, 'visibility:visible', '', 'iframe', '', '', 'mapframe1', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'setPOI2Scale', 2, 1, 'zoom to a poi (get-parameter)', 'div', '', '', 1, 1, 1, 1, NULL, 'visibility:hidden', '', 'div', 'mod_setPOI2Scale.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Mod_setPoi2Scale');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'zoomFull', 2, 1, 'zoom to full extent button', 'img', '../img/button_gray/zoomFull_off.png', 'onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"  title="Display complete map"', 320, 10, 24, 24, 2, '', '', 'img', 'mod_zoomFull.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'body', 1, 1, 'body (obligatory)', 'body', '', 'onload="init()"', NULL, NULL, NULL, NULL, NULL, '', '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'addWMS', 2, 1, 'add a WMS to the running application', 'img', '../img/button_gray/add_off.png', 'onclick=''mod_addWMS()''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS"', 515, 10, 24, 24, 1, '', '', '', 'mod_addWMS.php', '', 'treeGDE,mapframe1', 'loadData', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'addWMSfromfilteredList', 2, 1, 'add a WMS to the running application from a filtered list', 'img', '../img/button_gray/add_filtered_list_off.png', 'onclick=''window.open("../javascripts/mod_addWMSfromfilteredList.php?sessionID","printWin","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"', 490, 10, 24, 24, 1, '', '', '', '', 'mod_addWMSgeneralFunctions.js', 'treeGDE,mapframe1', 'loadData', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'back', 2, 1, 'History.back()', 'img', '../img/button_gray/back_off_disabled.png', 'onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" title="Back"', 360, 10, 24, 24, 1, '', '', '', 'mod_back.php', '', 'mapframe1,overview0', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'closePolygonExt', 3, 0, 'close Polygon ', 'div', '', ' title="Close Polygon"', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_closePolygonExt.js', '', 'mapframe1', 'setExtRequest', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'copyright', 2, 1, 'a Copyright in the map', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_copyright.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'dependentDiv', 2, 1, 'displays infos in a sticky div-tag', 'div', '', '', 81, -19, 1, 1, 0, 'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;', '', 'div', 'mod_dependentDiv.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'dragMapSize', 2, 1, 'drag & drop Mapsize', 'div', '', '', 81, -19, 0, 0, 2, 'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;', '', 'div', 'mod_dragMapSize.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'featureInfo1', 2, 0, 'FeatureInfoRequest', 'img', '../img/button_gray/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfo1'')"', 140, 40, 24, 24, 1, '', '', '', 'mod_featureInfo.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'FeatureInfoRedirect', 2, 1, 'redirect featureInfoRequests in an iframe for each wms', 'iframe', '../html/mod_blank.html', 'frameborder="0"', 83, -17, 1, 1, 0, '', '', 'iframe', 'mod_featureInfoRedirect.php', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'featureInfoTunnel', 2, 1, 'FeatureInfoRequest with local path', 'img', '../img/button_gray/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfoTunnel'')" title="Query"', 425, 10, 24, 24, 1, '', '', '', 'mod_featureInfoTunnel.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'forward', 2, 1, 'History.forward()', 'img', '../img/button_gray/forward_off_disabled.png', 'onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" title="Forward"', 385, 10, 24, 24, 1, '', '', '', 'mod_forward.php', '', 'mapframe1,overview0', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'help', 2, 1, 'button help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')" title="help"', 620, 10, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'imprint', 2, 1, 'Information about the owner of the gui', 'iframe', '../html/tab_imprint.html', 'frameborder = "0" ', 1, 1, 1, 1, 5, 'visibility:hidden;', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'keyHandler', 2, 1, 'onkeydownevent (only IE)', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_key.php', '', 'mapframe1', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_back', 3, 1, 'layout, background for buttons', 'div', '', '', 360, 10, 51, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'zoomIn1', 2, 1, 'zoomIn button', 'img', '../img/button_gray/zoomIn2_off.png', 'onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' title=''Zoom in''', 220, 10, 24, 24, 1, '', '', '', 'mod_zoomIn1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomIn');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_featureInfo', 3, 1, 'layout, background for FeatureInfo', 'div', '', '', 425, 10, 51, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_help', 3, 1, 'layout, background for Help-button', 'div', '', '', 620, 10, 26, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_logout', 3, 1, 'layout, background for Logout-button', 'div', '', '', 660, 10, 26, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
@@ -447,49 +500,100 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_wms', 3, 1, 'layout, background for wms', 'div', '', '', 490, 10, 76, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_zoom', 3, 1, 'layout, background for Zoom-button', 'div', '', '', 220, 10, 126, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'legend', 2, 1, 'legend', 'iframe', '../javascripts/mod_legend.php?sessionID&e_id_css=legend', 'frameborder=''0''', 1, 1, 1, 1, 3, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'loadData', 2, 1, 'IFRAME, um Daten zu laden', 'iframe', '../html/mod_blank.html', 'frameborder = "0" ', 0, 0, 1, 1, 0, 'visibility:visible', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'loadwmc', 2, 0, 'load workspace from WMC', 'img', '../img/button_wmc/wmc_load.png', 'onclick=''mod_loadwmc()'' onmouseover=''mod_loadwmc_init(this)''
+title=''Load a web map context document''', 760, 10, 24, 24, 1, '', '', '', 'mod_loadwmc.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'logo', 2, 1, 'Logo', 'img', '../img/mapbender_logo.png', '', 20, 20, 180, 26, 5, '', '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''
+onmouseover=''this.src="../img/button_gray/logout_over.png"''
+onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 660, 10, 24, 24, 1, '', '', '', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'mapbender', 2, 1, 'Mapbender-Logo', 'div', '', 'onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"', 81, -19, 1, 1, 30, 'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;', '<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr>
+<script language="javascript">
+mb_registerSubFunctions("mod_mapbender()");
+function mod_mapbender(){
+document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90;
+document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1;
+</script>', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'mapframe1', 2, 1, 'frame for a map', 'iframe', '../php/mod_map1.php?sessionID', 'scrolling="no" frameborder=''0'' ', 230, 55, 500, 450, 2, '', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'metadata', 2, 1, 'shows informations about the wms and the requests of the gui', 'img', '../img/button_gray/metadata_off.png', 'onClick="window.location.href=''javascript:mod_displayObj()''"
+border=''0''
+onmouseover=''this.src="../img/button_gray/metadata_over.png"''
+onmouseout=''this.src="../img/button_gray/metadata_off.png"'' title="Show service metadata"', 580, 10, 24, 24, 1, '', '', '', 'mod_displayObj.js', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'navFrame', 2, 1, 'navigation mapborder', 'div', '', '', 0, 0, 0, 0, 0, 'font-size:1px;', '<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div>
+<div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div>
+<div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div>
+<div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div>
+<div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div>
+<div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div>
+<div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div>
+<div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>
+', 'div', 'mod_navFrame.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'overview', 2, 1, 'OverviewFrame', 'iframe', '../php/mod_mapOV.php?wms=0&sessionID', 'scrolling="no" frameborder=''0'' ', 30, 65, 150, 130, 100, '', '', 'iframe', '', 'mod_box1.js', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'pan1', 2, 1, 'pan', 'img', '../img/button_gray/pan_off.png', 'onmouseover = "mb_regButton(''init_mod_pan'')" title="Pan"', 270, 10, 24, 24, 1, '', '', '', 'mod_pan.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'printPDF', 2, 1, 'pdf print', 'iframe', '../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf', 'frameborder = "0" ', 1, 1, 2, 2, 5, 'visibility:hidden', '', 'iframe', '', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'rubberExt', 3, 1, 'deletes temporary (digitized) objects', 'div', '', ' title="Rubber"', 0, 0, 0, 0, 0, '', '', 'div', 'mod_rubberExt.js', '', 'mapframe1', 'setExtRequest', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'sandclock', 2, 1, 'displays a sand clock while waiting for requests', 'div', '', '', 80, 0, 0, 0, 0, '', '', 'div', 'mod_sandclock.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'savewmc', 2, 0, 'save workspace as WMC', 'img', '../img/button_wmc/wmc_save.png', 'onclick=''mod_savewmc()'' onmouseover=''mod_savewmc_init(this)''
+title=''Save workspace as web map context document''', 730, 10, 24, 24, 1, '', '', '', 'mod_savewmc.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'scaleSelect', 2, 0, 'Scale-Selectbox', 'select', '', 'onchange=''mod_scaleSelect(this)''', 555, 25, 100, 20, 1, '', '<option value = ''''>Scale</option>
+<option value=''100''>1 : 100</option>
+<option value=''250''>1 : 250</option>
+<option value=''500''>1 : 500</option>
+<option value=''1000''>1 : 1000</option>
+<option value=''2500''>1 : 2500</option>
+<option value=''5000''>1 : 5000</option>
+<option value=''10000''>1 : 10000</option>
+<option value=''25000''>1 : 25000</option>
+<option value=''30000''>1 : 30000</option>
+<option value=''50000''>1 : 50000</option>
+<option value=''75000''>1 : 75000</option>
+<option value=''100000''>1 : 100000</option>
+<option value=''200000''>1 : 200000</option>
+<option value=''300000''>1 : 300000</option>
+<option value=''400000''>1 : 400000</option>
+<option value=''500000''>1 : 500000</option>
+<option value=''600000''>1 : 600000</option>
+<option value=''700000''>1 : 700000</option>
+<option value=''800000''>1 : 800000</option>
+<option value=''900000''>1 : 900000</option>
+<option value=''1000000''>1 : 1000000</option>', 'select', 'mod_scaleSel.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'selArea1', 2, 1, 'zoombox', 'img', '../img/button_gray/selArea_off.png', 'onmouseover = "mb_regButton(''init_selArea1'')" title="Zoom by rectangle"', 295, 10, 24, 24, 1, '', '', '', 'mod_selArea1.php', 'mod_box1.js', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'setBackground', 2, 1, 'switch background-wms', 'form', '', '', 30, 210, NULL, NULL, 1, '', '<select style=''font-family: Arial, sans-serif; font-size:12''
+name=''mod_setBackground_list''
+onchange=''mod_setBackground_change(this)'' ><option
+value=''0''></option></select>', 'form', 'mod_setBackground.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'setBBOX', 2, 0, 'set extent for mapframe and overviewframe', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_setBBOX1.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'showCoords_div', 2, 1, 'displays coodinates by onmouseover', 'img', '../img/button_gray/coords_off.png', 'onmouseover = "mb_regButton(''init_mod_showCoords_div'')" title="Coordinates" ', 450, 10, 24, 24, 1, 'background-color:white; font-family: Arial, Helvetica, sans-serif;font-size:10px;', '', '', 'mod_coords_div.php', '', 'mapframe1', 'dependendDiv', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'treeGDE', 2, 1, 'dircetory structure, checkbox for visible, checkbox for querylayer', 'iframe', '../html/mod_sync_treefolder.php?sessionID&e_id_css=treeGDE', 'frameborder = "0" ', 1, 1, 1, 1, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'wfs_conf', 2, 1, 'get all wfs_conf-params', 'iframe', '../php/mod_wfs.php', 'frameborder = "0"', 1, 1, 1, 1, 0, 'visibility:hidden', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'wfsresult', 2, 1, 'display the list of wfs results', 'iframe', '../html/mod_blank.html', 'frameborder = "0"', 10, 730, 200, 150, 4, '', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'zoomIn1', 2, 1, 'zoomIn button', 'img', '../img/button_gray/zoomIn2_off.png', 'onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' title="Zoom in"', 220, 10, 24, 24, 1, '', '', '', 'mod_zoomIn1.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'zoomOut1', 2, 1, 'zoomOut button', 'img', '../img/button_gray/zoomOut2_off.png', 'onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' title="Zoom out"', 245, 10, 24, 24, 1, '', '', '', 'mod_zoomOut1.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'initWmc', 2, 0, 'initialise client with wmc', 'div', '', '', 1, 1, 1, 1, NULL, 'visibility:hidden', '', 'div', 'mod_initWmc.php', '', 'mapframe1,overview', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'WMS_preferences', 2, 1, 'configures the preferences of each loaded wms', 'img', '../img/button_gray/preferences_off.png', 'onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="WMS preferences"', 540, 10, 24, 24, 1, '', '', '', '', '', 'mapframe1,treeGDE', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'geometry', 1, 1, 'geometry library', 'div', '', '', 1, 1, 1, 1, NULL, 'visibility:hidden', '', 'div', 'geometry.js', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'digitize', 2, 1, 'Digitize tool.', 'iframe', '../javascripts/mod_digitize_tab.php?sessionID', 'frameborder = "0" ', 1, 1, 1, 1, 5, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'setSpatialRequest', 2, 1, 'Spatial Request', 'div', '', '', 1, 1, 1, 1, 1, 'visibility:hidden;', '', 'div', '../javascripts/mod_wfs_SpatialRequest.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'wfs', 2, 1, 'wfs request and result handling', 'div', '', '', 1, 1, 1, 1, NULL, 'visibility:hidden', '', 'div', 'wfs.js', '../extensions/wz_jsgraphics.js', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'ajax', 6, 1, 'ajax module', 'iframe', '../frames/jquery.html', '', 1, 1, 1, 1, 1, 'visibility:hidden', '', 'iframe', '../javascripts/mb_ajaxWrapper_jQuery.js', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'tabs', 1, 1, 'vertical tabs to handle iframes', 'div', '', '', 10, 240, 200, 20, 2, 'font-family: Arial,Helvetica;font-weight:bold;', '', 'div', 'mod_tab.php', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'showLoggedUser', 2, 0, 'Displays current user', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, 1, 'background-color:lightgrey;', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'EditWMSMetadata', 2, 1, 'edit the metadata of wms', 'a', '', 'href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"', 10, 950, 250, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT WMS-METADATA', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_1', 3, 0, 'Warning notice', 'div', '', '', 150, 250, 300, 16, 100, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none;', 'Development Version - Work in Progress!', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'wfs_gazetteer', 2, 1, 'a gazetteer for user in the mapbender user map', 'iframe', '../php/mod_wfs_gazetteer.php?sessionID&wfs_conf=1,4,3,2&target=mapframe1,overview&resultFrame=wfsresult', 'frameborder = "0"', 10, 600, 300, 150, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1,overview', 'wz-graphics', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'Gazetteer_mbUser', 2, 0, 'a gazetteer for user in the mapbender user map', 'iframe', '../php/mod_wfs_gazetteer.php?sessionID&wfs_conf=1&target=mapframe1,overview&resultFrame=wfsresult', 'frameborder = "0"', 10, 600, 300, 150, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1,overview', 'wz-graphics', '');
--- TOC entry 1758 (class 0 OID 39047306)
--- Dependencies: 1233
+-- TOC entry 1784 (class 0 OID 47913135)
+-- Dependencies: 1240
 -- Data for Name: gui_element_vars; Type: TABLE DATA; Schema: public; Owner: admin
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'switchwms', 'true', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_on[3]', '1', 'if this is "0", the button will not be available (default "1")
-', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_on[4]', '1', 'if this is "0", the button will not be available (default "1")
-', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_src[0]', 'select_rectangle_off.png', 'the reference (path and filename) to the image that will be displayed if the i-th button is not pressed (must be named *_off.png, other images *_on.png and *_over.png)', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_src[1]', 'select_polygon_off.png', 'the reference (path and filename) to the image that will be displayed if the i-th button is not pressed (must be named *_off.png, other images *_on.png and *_over.png)', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_src[2]', 'select_point_off.png', 'the reference (path and filename) to the image that will be displayed if the i-th button is not pressed (must be named *_off.png, other images *_on.png and *_over.png)', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_src[3]', 'select_extent_off.png', 'the reference (path and filename) to the image that will be displayed if the i-th button is not pressed (must be named *_off.png, other images *_on.png and *_over.png)', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_src[4]', 'select_choose_off.png', 'the reference (path and filename) to the image that will be displayed if the i-th button is not pressed (must be named *_off.png, other images *_on.png and *_over.png)', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_title_off[0]', 'select by rectangle', 'the tooltip that will be displayed if the i-th button is not pressed.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_title_off[1]', 'select by polygon', 'the tooltip that will be displayed if the i-th button is not pressed.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_title_off[2]', 'select by point', 'the tooltip that will be displayed if the i-th button is not pressed.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_title_off[3]', 'select by extent', 'the tooltip that will be displayed if the i-th button is not pressed.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_title_off[4]', 'select', 'the tooltip that will be displayed if the i-th button is not pressed.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_title_on[0]', 'select by rectangle', 'the tooltip that will be displayed if the i-th button is pressed.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_title_on[1]', 'select by polygon', 'the tooltip that will be displayed if the i-th button is pressed.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_title_on[2]', 'select by point', 'the tooltip that will be displayed if the i-th button is pressed.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_title_on[3]', 'select by extent', 'the tooltip that will be displayed if the i-th button is pressed.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_title_on[4]', 'select', 'the tooltip that will be displayed if the i-th button is pressed.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_x[0]', '750', 'the x-position of the i-th button', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_x[1]', '780', 'the x-position of the i-th button
-', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_x[2]', '810', 'the x-position of the i-th button
-', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_x[3]', '840', 'the x-position of the i-th button
-', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_x[4]', '870', 'the x-position of the i-th button
-', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_y[0]', '10', 'the y-position of the i-th button
-', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_y[1]', '10', 'the y-position of the i-th button
-', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'css_file_legend', '../css/legend.css', '', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'legendlink', 'false', '', 'var');
@@ -499,16 +603,6 @@
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'stickylegend', 'true', 'parameter to decide wether the legend should stick on the mapframe1', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_y[2]', '10', 'the y-position of the i-th button
-', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_y[3]', '10', 'the y-position of the i-th button
-', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_y[4]', '10', 'the y-position of the i-th button
-', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'legendlink', 'false', '', 'var');
@@ -516,24 +610,14 @@
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'closePolygon_title', 'after inserting at least three points, click the first one to close the polygon.', 'the tooltip that appears over a basepoint of a polygon.', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'imagedir', '../img/tree_gray', 'image directory', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'ficheckbox', 'false', 'checkbox for featureInfo requests', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[5]', '250', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'useUsemap', '0', '"1" adds a usemap to each geometry; the geometry will be highlighted onMouseOver. Every other value will skip the usemap.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_id[0]', 'Point', 'the id for a div-tag that will be created to contain the i-th button image', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_id[1]', 'Line', 'the id for a div-tag that will be created to contain the i-th button image', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_id[2]', 'Polygon', 'the id for a div-tag that will be created to contain the i-th button image', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_id[3]', 'dragBasePoint', 'the id for a div-tag that will be created to contain the i-th button image', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_id[4]', 'setBasePoint', 'the id for a div-tag that will be created to contain the i-th button image', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_id[5]', 'delBasePoint', 'the id for a div-tag that will be created to contain the i-th button image', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_imgdir', '../img/button_digitize/', 'the path to the digitize button images.', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_Gui', 'file css', '../css/administration_alloc.css', 'file', 'file/css');
@@ -554,7 +638,6 @@
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'gui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'User_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
@@ -582,29 +665,8 @@
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[1]', 'legend', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[2]', 'printPDF', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[3]', 'Gazetteer_mbUser', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[4]', 'imprint', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_prefix', '  ', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[0]', 'Maps', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[1]', 'Legend', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[2]', 'Print', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[3]', 'WFS Search', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[4]', 'Imprint', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'cssfile', '../css/treeGDE.css', 'global stylesheets', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'imagedir', '../img/tree', 'image directory', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;padding-left:8px;', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_on[0]', '1', 'if this is "0", the button will not be available for digitizing (default "1").', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
@@ -614,10 +676,7 @@
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'legendlink', 'false', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'logout', 'logout_location', 'http://www.mapbender.org/', 'webside to show after logout', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'cssfile', '../css/treeGDE.css', 'global stylesheets', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'imagedir', '../img/tree', 'image directory', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('wms_gdi_de', 'body', 'file css', '../css/mapbender.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
@@ -629,7 +688,6 @@
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_class_bg', 'body{background-color: #FEF8D4;}', 'to define the color of the body', 'text/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_on[1]', '1', 'if this is "0", the button will not be available for digitizing (default "1").', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
@@ -643,33 +701,90 @@
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[2]', 'printPDF', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[3]', 'Gazetteer_mbUser', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[4]', 'imprint', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_on[2]', '1', 'if this is "0", the button will not be available for digitizing (default "1").', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_on[3]', '1', 'if this is "0", the button will not be available for digitizing (default "1").', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[0]', 'Maps', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[1]', 'Legend', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[2]', 'Print', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[3]', 'WFS Search', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[4]', 'Imprint', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'cssfile', '../css/treeGDE.css', 'global stylesheets', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_on[4]', '1', 'if this is "0", the button will not be available for digitizing (default "1").', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'switchwms', 'true', 'enable/disable all layers of a wms', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_on[5]', '1', 'if this is "0", the button will not be available for digitizing (default "1").', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_src[0]', 'point_off.png', 'the reference (path and filename) to the image that will be displayed if the i-th button is not pressed (must be named *_off.png, other images *_on.png and *_over.png).
-# buttonDig_imgdir: the path to the digitize images. ', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'imagedir', '../img/tree_blue', 'image directory', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_src[1]', 'line_off.png', 'the reference (path and filename) to the image that will be displayed if the i-th button is not pressed (must be named *_off.png, other images *_on.png and *_over.png).
-', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_prefix', '&nbsp;&nbsp;', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_src[2]', 'polygon_off.png', 'the reference (path and filename) to the image that will be displayed if the i-th button is not pressed (must be named *_off.png, other images *_on.png and *_over.png).
-', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid #FDCC1A;font-size:12;color:#FFFFFF;background-color:#799FEB;cursor:pointer;margin-top:-4px; padding-top:5px;padding-left:8px;', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_ccs_file', '../css/meetingPoint.css', '', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_format', 'prompt', 'decide which format to choose (email, prompt)', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_subject', 'Ein Treffpunkt wurde erzeugt. Folgen Sie dem Link!', 'if you choose format email, define the text for the subject', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_height', '20', 'height of the meetingPoint_icon', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_icon', '../img/redball.gif', 'path to meetingPoint image', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_max_characters', '70', 'define the maximum length of the text', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_please_click', 'Please click in  the map to define the meeting point position!', 'text to show if no clickposition is set', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_style', 'background-color:white;font-weight: bold;color:red;font-family:Arial;', 'style to display the meetingPoint text', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_width', '20', 'width of the meetingPoint_icon', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[1]', 'legend', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[2]', 'printPDF', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[3]', 'Gazetteer_mbUser', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[4]', 'imprint', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_prefix', '  ', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[0]', 'Maps', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[1]', 'Legend', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[2]', 'Print', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[3]', 'WFS Search', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[4]', 'Imprint', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[5]', 'meetingPoint', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[5]', 'Meeting Point', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[5]', '160', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_height', '25', 'height of the poi_image', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_width', '25', 'width of the poi_image', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_height', '25', 'height of the poi_image', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_width', '25', 'width of the poi_image', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_height', '-35', 'to adjust the height of the mapframe on the bottom of the window', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_width', '-45', 'to adjust the width of the mapframe on the right side of the window', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'resize_option', 'button', 'auto (autoresize on load), button (resize by button)', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'menu', '', 'context menu elements', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'setPOI2Scale', 'mod_setPOI2Scale_defScale', '5000', 'default scale', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'linepointColor', '#ffff00', 'var', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'mod_digitize_elName', 'digitize', 'var', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'cssfile', '../css/treeGDE.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'imagedir', '../img/tree', 'image directory', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'switchwms', 'true', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'cssUrl', '../css/digitize.css', 'url to the style sheet of the mapframe', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'text css', ' body{
  font-size : 12px;
@@ -684,40 +799,6 @@
 ', 'text css', 'text/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'wfsCssUrl', '../css/mapbender.css', 'var', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'legendlink', 'false', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'open_tab', '5', 'define which tab should be opened when a gui is opened', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[1]', 'legend', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[2]', 'printPDF', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[3]', 'Gazetteer_mbUser', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[4]', 'imprint', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[5]', 'digitize', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_prefix', '  ', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[0]', 'Maps', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[1]', 'Legend', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[2]', 'Print', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[3]', 'WFS Search', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[4]', 'Imprint', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[5]', 'Digitize', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'cssfile', '../css/treeGDE.css', 'global stylesheets', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'imagedir', '../img/tree', 'image directory', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_id[0]', 'rectangle', 'the id for a div-tag that will be created to contain the i-th button image', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_id[1]', 'polygon', 'the id for a div-tag that will be created to contain the i-th button image', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_id[2]', 'point', 'the id for a div-tag that will be created to contain the i-th button image', 'var');
@@ -729,77 +810,82 @@
 ', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_on[2]', '1', 'if this is "0", the button will not be available (default "1")
 ', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_src[3]', 'move_node_off.png', 'the reference (path and filename) to the image that will be displayed if the i-th button is not pressed (must be named *_off.png, other images *_on.png and *_over.png).
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_on[3]', '1', 'if this is "0", the button will not be available (default "1")
 ', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_src[4]', 'new_node_off.png', 'the reference (path and filename) to the image that will be displayed if the i-th button is not pressed (must be named *_off.png, other images *_on.png and *_over.png).
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_on[4]', '1', 'if this is "0", the button will not be available (default "1")
 ', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_src[5]', 'delete_node_off.png', 'the reference (path and filename) to the image that will be displayed if the i-th button is not pressed (must be named *_off.png, other images *_on.png and *_over.png).
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_src[0]', 'select_rectangle_off.png', 'the reference (path and filename) to the image that will be displayed if the i-th button is not pressed (must be named *_off.png, other images *_on.png and *_over.png)', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_src[1]', 'select_polygon_off.png', 'the reference (path and filename) to the image that will be displayed if the i-th button is not pressed (must be named *_off.png, other images *_on.png and *_over.png)', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_src[2]', 'select_point_off.png', 'the reference (path and filename) to the image that will be displayed if the i-th button is not pressed (must be named *_off.png, other images *_on.png and *_over.png)', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_src[3]', 'select_extent_off.png', 'the reference (path and filename) to the image that will be displayed if the i-th button is not pressed (must be named *_off.png, other images *_on.png and *_over.png)', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_src[4]', 'select_choose_off.png', 'the reference (path and filename) to the image that will be displayed if the i-th button is not pressed (must be named *_off.png, other images *_on.png and *_over.png)', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_title_off[0]', 'select by rectangle', 'the tooltip that will be displayed if the i-th button is not pressed.', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_title_off[1]', 'select by polygon', 'the tooltip that will be displayed if the i-th button is not pressed.', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_title_off[2]', 'select by point', 'the tooltip that will be displayed if the i-th button is not pressed.', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_title_off[3]', 'select by extent', 'the tooltip that will be displayed if the i-th button is not pressed.', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_title_off[4]', 'select', 'the tooltip that will be displayed if the i-th button is not pressed.', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_title_on[0]', 'select by rectangle', 'the tooltip that will be displayed if the i-th button is pressed.', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_title_on[1]', 'select by polygon', 'the tooltip that will be displayed if the i-th button is pressed.', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_title_on[2]', 'select by point', 'the tooltip that will be displayed if the i-th button is pressed.', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_title_on[3]', 'select by extent', 'the tooltip that will be displayed if the i-th button is pressed.', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_title_on[4]', 'select', 'the tooltip that will be displayed if the i-th button is pressed.', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_toDigitize_src', '../img/wfs_digitize.png', 'var', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_toDigitize_title
+', 'edit this geometry', 'var', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_x[0]', '750', 'the x-position of the i-th button', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_x[1]', '780', 'the x-position of the i-th button
 ', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_title_off[0]', 'add point', 'the tooltip that will be displayed if the i-th button is not pressed.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_title_off[1]', 'add line', 'the tooltip that will be displayed if the i-th button is not pressed.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_title_off[2]', 'add polygon', 'the tooltip that will be displayed if the i-th button is not pressed.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_title_off[3]', 'move basepoint', 'the tooltip that will be displayed if the i-th button is not pressed.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_title_off[4]', 'insert basepoint', 'the tooltip that will be displayed if the i-th button is not pressed.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_title_off[5]', 'delete basepoint', 'the tooltip that will be displayed if the i-th button is not pressed.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_title_on[0]', 'finish editing', 'the tooltip that will be displayed if the i-th button is pressed.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_title_on[1]', 'finish editing', 'the tooltip that will be displayed if the i-th button is pressed.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_title_on[2]', 'close polygon', 'the tooltip that will be displayed if the i-th button is pressed.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_title_on[3]', 'move basepoint', 'the tooltip that will be displayed if the i-th button is pressed.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_title_on[4]', 'insert basepoint', 'the tooltip that will be displayed if the i-th button is pressed.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_title_on[5]', 'delete basepoint', 'the tooltip that will be displayed if the i-th button is pressed.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_x[0]', '0', 'the x-position of the i-th button within the digitizing iframe.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_x[1]', '30', 'the x-position of the i-th button within the digitizing iframe.
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_x[2]', '810', 'the x-position of the i-th button
 ', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_x[2]', '60', 'the x-position of the i-th button within the digitizing iframe.
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_x[3]', '840', 'the x-position of the i-th button
 ', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_x[3]', '100', 'the x-position of the i-th button within the digitizing iframe.
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_x[4]', '870', 'the x-position of the i-th button
 ', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_x[4]', '130', 'the x-position of the i-th button within the digitizing iframe.
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_y[0]', '10', 'the y-position of the i-th button
 ', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_x[5]', '160', 'the x-position of the i-th button within the digitizing iframe.
-', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_y[0]', '0', 'the y-position of the i-th button within the digitizing iframe.
-', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_y[1]', '0', 'the y-position of the i-th button within the digitizing iframe.
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_y[1]', '10', 'the y-position of the i-th button
 ', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_y[2]', '0', 'the y-position of the i-th button within the digitizing iframe.
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_y[2]', '10', 'the y-position of the i-th button
 ', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_y[3]', '0', 'the y-position of the i-th button within the digitizing iframe.
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_y[3]', '10', 'the y-position of the i-th button
 ', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_y[4]', '0', 'the y-position of the i-th button within the digitizing iframe.
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_y[4]', '10', 'the y-position of the i-th button
 ', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_y[5]', '0', 'the y-position of the i-th button within the digitizing iframe.
-', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'cssUrl', '../css/digitize.css', 'url to the style sheet of the mapframe', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'dotDistance', '7', 'the distance between two dots that are part of a dash.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'geomList_x', '20', 'x-position of the geometry list', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'geomList_y', '50', 'y-position of the geometry list
-', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'snappingTolerance', '12', 'the radius of a circular area around each basepoint, that must not contain another basepoint.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'snappingColor', '#ff0000', 'the colour of a circular area around each basepoint, that must not contain another basepoint.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_remove_title', 'remove from workspace', 'button for geometry removal. tooltip.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_wfs_title
-', 'save / update / delete', 'button for wfs save/update/delete. tooltip', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_remove_src', 'geomRemove.png', 'button for geometry removal. filename.', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_toDigitize_src', '../img/wfs_digitize.png', 'var', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_toDigitize_title
-', 'edit this geometry', 'var', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'buttonDig_wfs_src', 'geomInfo.png', 'button for wfs save/update/delete. filename.
-', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'useUsemap', '0', '"1" adds a usemap to each geometry; the geometry will be highlighted onMouseOver. Every other value will skip the usemap.', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'buttonWfs_toDigitize_on', '1', '"1" transfers all geometries from the wfs query to the digitize module. For every other value, a list with the result of the wfs query will be displayed.', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'wfs', 'displayWfsResultList', '1', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'open_tab', '5', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[5]', '250', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[1]', 'legend', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[2]', 'printPDF', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[4]', 'imprint', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[5]', 'digitize', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_prefix', '  ', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;padding-left:8px;', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[0]', 'Maps', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[1]', 'Legend', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[2]', 'Print', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[3]', 'WFS Search', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[4]', 'Imprint', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[5]', 'Digitize', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'digitize_conf_filename', 'digitize_default.conf', '', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[3]', 'wfs_gazetteer', '', 'var');
--- TOC entry 1759 (class 0 OID 39047314)
--- Dependencies: 1234
+-- TOC entry 1785 (class 0 OID 47913143)
+-- Dependencies: 1241
 -- Data for Name: gui_layer; Type: TABLE DATA; Schema: public; Owner: admin
@@ -832,9 +918,8 @@
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19135, 903, 1, 1, 1, 0, 0, 1000, 50000, 10, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19136, 903, 1, 1, 1, 0, 0, 1000, 50000, 11, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19137, 903, 1, 1, 1, 0, 0, 1000, 50000, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19106, 901, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 15337, 407, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14190, 778, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 15337, 407, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14197, 779, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14198, 779, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14199, 779, 1, 1, 1, 0, 0, 1000000, 0, 2, '', NULL);
@@ -878,12 +963,12 @@
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 10107, 634, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 10108, 634, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 10109, 634, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 15338, 407, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 10110, 634, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13667, 739, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13668, 739, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13669, 739, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13670, 739, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 15338, 407, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13671, 739, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13672, 739, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13673, 739, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
@@ -2136,9 +2221,6 @@
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15008, 844, 1, 1, 1, 1, 1, 0, 0, 57, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15009, 844, 1, 1, 1, 1, 1, 0, 0, 58, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15010, 844, 1, 1, 1, 1, 1, 0, 0, 59, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 15337, 407, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 15338, 407, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 15339, 407, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18119, 866, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18120, 866, 1, 1, 1, 1, 1, 200, 749888, 1, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18121, 866, 1, 1, 1, 1, 1, 200, 749888, 2, NULL, NULL);
@@ -2279,45 +2361,6 @@
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18272, 885, 1, 1, 1, 0, 0, 0, 0, 26, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18274, 887, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18275, 887, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19006, 893, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19007, 893, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19008, 893, 1, 1, 1, 0, 0, 749999, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19009, 893, 1, 1, 1, 0, 0, 749999, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19010, 893, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19011, 893, 1, 1, 1, 1, 1, 0, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19012, 893, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19013, 893, 1, 1, 1, 0, 0, 0, 1250001, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19014, 893, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19015, 893, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19016, 893, 1, 1, 1, 0, 0, 0, 350000, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19017, 893, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19018, 893, 1, 1, 1, 0, 0, 1000000, 0, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19006, 893, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19007, 893, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19008, 893, 1, 1, 1, 0, 0, 749999, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19009, 893, 1, 1, 1, 0, 0, 749999, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19010, 893, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19011, 893, 1, 1, 1, 1, 1, 0, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19012, 893, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19013, 893, 1, 1, 1, 0, 0, 0, 1250001, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19014, 893, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19015, 893, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19016, 893, 1, 1, 1, 0, 0, 0, 350000, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19017, 893, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19018, 893, 1, 1, 1, 0, 0, 1000000, 0, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19006, 893, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19007, 893, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19008, 893, 1, 1, 1, 0, 0, 749999, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19009, 893, 1, 1, 1, 0, 0, 749999, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19010, 893, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19011, 893, 1, 1, 1, 1, 1, 0, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19012, 893, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19013, 893, 1, 1, 1, 0, 0, 0, 1250001, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19014, 893, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19015, 893, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19016, 893, 1, 1, 1, 0, 0, 0, 350000, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19017, 893, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19018, 893, 1, 1, 1, 0, 0, 1000000, 0, 12, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 11629, 717, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 11630, 717, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10028, 624, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
@@ -2373,24 +2416,7 @@
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19146, 904, 1, 1, 1, 0, 0, 200000, 1000000, 8, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19147, 904, 1, 1, 1, 0, 0, 200000, 0, 9, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19148, 904, 1, 1, 1, 0, 0, 1000000, 0, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 15339, 407, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10179, 640, 1, 1, 0, 0, 0, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 15337, 407, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 15338, 407, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 15339, 407, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19006, 893, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19007, 893, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19008, 893, 1, 1, 1, 0, 0, 749999, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19009, 893, 1, 1, 1, 0, 0, 749999, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19010, 893, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19011, 893, 1, 1, 1, 1, 1, 0, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19012, 893, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19013, 893, 1, 1, 1, 0, 0, 0, 1250001, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19014, 893, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19015, 893, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19016, 893, 1, 1, 1, 0, 0, 0, 350000, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19017, 893, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19018, 893, 1, 1, 1, 0, 0, 1000000, 0, 12, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19149, 905, 1, 1, 1, 0, 0, 50000, 0, 0, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19150, 905, 1, 1, 1, 1, 1, 50000, 0, 1, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19151, 905, 1, 1, 1, 1, 1, 50000, 0, 2, NULL, NULL);
@@ -2424,6 +2450,77 @@
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19103, 900, 1, 1, 1, 0, 0, 0, 0, 13, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19104, 900, 1, 1, 1, 0, 0, 0, 0, 14, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19105, 900, 1, 1, 1, 0, 0, 0, 0, 15, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19008, 893, 1, 1, 1, 0, 0, 750000, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19008, 893, 1, 1, 1, 0, 0, 750000, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19008, 893, 1, 1, 1, 0, 0, 750000, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19008, 893, 1, 1, 1, 0, 0, 750000, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19008, 893, 1, 1, 1, 0, 0, 750000, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19009, 893, 1, 1, 1, 0, 0, 750000, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19009, 893, 1, 1, 1, 0, 0, 750000, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19009, 893, 1, 1, 1, 0, 0, 750000, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19009, 893, 1, 1, 1, 0, 0, 750000, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19009, 893, 1, 1, 1, 0, 0, 750000, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19010, 893, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19010, 893, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19010, 893, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19010, 893, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19010, 893, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19011, 893, 1, 1, 1, 1, 1, 0, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19011, 893, 1, 1, 1, 1, 1, 0, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19011, 893, 1, 1, 1, 1, 1, 0, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19011, 893, 1, 1, 1, 1, 1, 0, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19011, 893, 1, 1, 1, 1, 1, 0, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19012, 893, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19012, 893, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19012, 893, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19012, 893, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19012, 893, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19013, 893, 1, 1, 1, 0, 0, 0, 1250000, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19013, 893, 1, 1, 1, 0, 0, 0, 1250000, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19013, 893, 1, 1, 1, 0, 0, 0, 1250000, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19013, 893, 1, 1, 1, 0, 0, 0, 1250000, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19013, 893, 1, 1, 1, 0, 0, 0, 1250000, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19014, 893, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19014, 893, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19014, 893, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19014, 893, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19014, 893, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19015, 893, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19110, 902, 1, 1, 1, 0, 0, 25001, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19111, 902, 1, 1, 1, 1, 1, 25001, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19112, 902, 1, 1, 1, 0, 0, 25001, 150000, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19113, 902, 1, 1, 1, 0, 0, 25001, 2000000, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19114, 902, 1, 1, 1, 0, 0, 25001, 600000, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19115, 902, 1, 1, 1, 0, 0, 25001, 200000, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19116, 902, 1, 1, 1, 0, 0, 25001, 150000, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19117, 902, 1, 1, 1, 0, 0, 25001, 250001, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19118, 902, 1, 1, 1, 0, 0, 25001, 250001, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19015, 893, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19015, 893, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19015, 893, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19006, 893, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19006, 893, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19119, 902, 1, 1, 1, 0, 0, 25001, 100000, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19120, 902, 1, 1, 1, 0, 0, 25001, 250001, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19121, 902, 1, 1, 1, 0, 0, 25001, 749999, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19122, 902, 1, 1, 1, 0, 0, 25001, 0, 12, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19123, 902, 1, 1, 1, 0, 0, 25001, 100000, 13, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19124, 902, 1, 1, 1, 0, 0, 2000000, 0, 14, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19155, 906, 1, 1, 1, 0, 0, 50000, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19156, 906, 1, 1, 1, 0, 0, 50000, 1000000, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19157, 906, 1, 1, 1, 1, 1, 50000, 1000000, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19158, 906, 1, 1, 1, 1, 1, 50000, 1000000, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19159, 906, 1, 1, 1, 1, 1, 50000, 1000000, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19160, 906, 1, 1, 1, 1, 1, 50000, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19161, 906, 1, 1, 1, 1, 1, 50000, 0, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19162, 906, 1, 1, 1, 0, 0, 50000, 0, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19163, 906, 1, 1, 1, 0, 0, 50000, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19164, 906, 1, 1, 1, 0, 0, 50000, 0, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19165, 906, 1, 1, 1, 0, 0, 50000, 0, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19166, 906, 1, 1, 1, 0, 0, 50000, 0, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19167, 906, 1, 1, 1, 0, 0, 50000, 0, 12, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19170, 908, 1, 1, 1, 0, 0, 0, 140316, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19171, 908, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2712, 250, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2713, 250, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2714, 250, 1, 1, 1, 1, 0, 0, 0, 2, NULL, NULL);
@@ -2460,55 +2557,46 @@
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10177, 640, 1, 1, 0, 0, 0, 0, 0, 12, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10178, 640, 1, 1, 0, 0, 0, 0, 0, 13, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10179, 640, 1, 1, 0, 0, 0, 0, 0, 14, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19172, 909, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19006, 893, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19006, 893, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19006, 893, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19173, 909, 1, 1, 1, 1, 1, 0, 0, 1, NULL, '2');
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19174, 909, 1, 1, 1, 1, 1, 0, 0, 2, NULL, '3');
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19007, 893, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19175, 909, 1, 1, 1, 1, 1, 0, 0, 3, NULL, '4');
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19007, 893, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19007, 893, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19007, 893, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19007, 893, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19008, 893, 1, 1, 1, 0, 0, 749999, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19009, 893, 1, 1, 1, 0, 0, 749999, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19010, 893, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19011, 893, 1, 1, 1, 1, 1, 0, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19012, 893, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19013, 893, 1, 1, 1, 0, 0, 0, 1250001, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19014, 893, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19015, 893, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19016, 893, 1, 1, 1, 0, 0, 0, 350000, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19016, 893, 1, 1, 1, 0, 0, 0, 350000, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19016, 893, 1, 1, 1, 0, 0, 0, 350000, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19016, 893, 1, 1, 1, 0, 0, 0, 350000, 10, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19016, 893, 1, 1, 1, 0, 0, 0, 350000, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19017, 893, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19017, 893, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19017, 893, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19017, 893, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19017, 893, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19018, 893, 1, 1, 1, 0, 0, 1000000, 0, 12, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19018, 893, 1, 1, 1, 0, 0, 1000000, 0, 12, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19018, 893, 1, 1, 1, 0, 0, 1000000, 0, 12, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19018, 893, 1, 1, 1, 0, 0, 1000000, 0, 12, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19018, 893, 1, 1, 1, 0, 0, 1000000, 0, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19107, 901, 1, 1, 1, 1, 1, 0, 0, 1, NULL, '2');
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19110, 902, 1, 1, 1, 0, 0, 25001, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19111, 902, 1, 1, 1, 1, 1, 25001, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19112, 902, 1, 1, 1, 0, 0, 25001, 150000, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19113, 902, 1, 1, 1, 0, 0, 25001, 2000000, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19114, 902, 1, 1, 1, 0, 0, 25001, 600000, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19115, 902, 1, 1, 1, 0, 0, 25001, 200000, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19116, 902, 1, 1, 1, 0, 0, 25001, 150000, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19117, 902, 1, 1, 1, 0, 0, 25001, 250001, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19118, 902, 1, 1, 1, 0, 0, 25001, 250001, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19108, 901, 1, 1, 1, 1, 1, 0, 0, 2, NULL, '3');
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19109, 901, 1, 1, 1, 1, 1, 0, 0, 3, NULL, '4');
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19119, 902, 1, 1, 1, 0, 0, 25001, 100000, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19120, 902, 1, 1, 1, 0, 0, 25001, 250001, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19121, 902, 1, 1, 1, 0, 0, 25001, 749999, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19122, 902, 1, 1, 1, 0, 0, 25001, 0, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19123, 902, 1, 1, 1, 0, 0, 25001, 100000, 13, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19124, 902, 1, 1, 1, 0, 0, 2000000, 0, 14, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19155, 906, 1, 1, 1, 0, 0, 50000, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19156, 906, 1, 1, 1, 0, 0, 50000, 1000000, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19157, 906, 1, 1, 1, 1, 1, 50000, 1000000, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19158, 906, 1, 1, 1, 1, 1, 50000, 1000000, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19159, 906, 1, 1, 1, 1, 1, 50000, 1000000, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19160, 906, 1, 1, 1, 1, 1, 50000, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19161, 906, 1, 1, 1, 1, 1, 50000, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19162, 906, 1, 1, 1, 0, 0, 50000, 0, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19163, 906, 1, 1, 1, 0, 0, 50000, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19164, 906, 1, 1, 1, 0, 0, 50000, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19165, 906, 1, 1, 1, 0, 0, 50000, 0, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19166, 906, 1, 1, 1, 0, 0, 50000, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19167, 906, 1, 1, 1, 0, 0, 50000, 0, 12, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 15337, 407, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 15337, 407, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 15338, 407, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 15338, 407, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 15339, 407, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 15339, 407, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 15339, 407, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
--- TOC entry 1760 (class 0 OID 39047326)
--- Dependencies: 1235
+-- TOC entry 1786 (class 0 OID 47913155)
+-- Dependencies: 1242
 -- Data for Name: gui_mb_group; Type: TABLE DATA; Schema: public; Owner: admin
@@ -2524,12 +2612,11 @@
 INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('wms_north_america', 20, '');
 INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('wms_worldwide', 20, '');
 INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('gui2', 20, '');
-INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('gui_digitize', 20, '');
--- TOC entry 1761 (class 0 OID 39047331)
--- Dependencies: 1236
+-- TOC entry 1787 (class 0 OID 47913160)
+-- Dependencies: 1243
 -- Data for Name: gui_mb_user; Type: TABLE DATA; Schema: public; Owner: admin
@@ -2550,8 +2637,8 @@
--- TOC entry 1762 (class 0 OID 39047337)
--- Dependencies: 1238
+-- TOC entry 1788 (class 0 OID 47913166)
+-- Dependencies: 1245
 -- Data for Name: gui_treegde; Type: TABLE DATA; Schema: public; Owner: admin
@@ -2568,19 +2655,18 @@
--- TOC entry 1763 (class 0 OID 39047346)
--- Dependencies: 1239
+-- TOC entry 1789 (class 0 OID 47913175)
+-- Dependencies: 1246
 -- Data for Name: gui_wfs; Type: TABLE DATA; Schema: public; Owner: admin
 INSERT INTO gui_wfs (fkey_gui_id, fkey_wfs_id) VALUES ('gui', 1);
 INSERT INTO gui_wfs (fkey_gui_id, fkey_wfs_id) VALUES ('gui2', 1);
-INSERT INTO gui_wfs (fkey_gui_id, fkey_wfs_id) VALUES ('gui_digitize', 2);
--- TOC entry 1764 (class 0 OID 39047350)
--- Dependencies: 1240
+-- TOC entry 1790 (class 0 OID 47913179)
+-- Dependencies: 1247
 -- Data for Name: gui_wms; Type: TABLE DATA; Schema: public; Owner: admin
@@ -2657,10 +2743,6 @@
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_africa', 779, 2, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_africa', 899, 3, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_africa', 900, 4, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui_digitize', 250, 0, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 0);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui_digitize', 640, 1, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 0);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui_digitize', 893, 2, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31467', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui_digitize', 901, 3, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 786, 10, 'IMAGE/PNG', 'text/plain', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:31468', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 787, 11, 'IMAGE/PNG', '', 'application/vnd.ogc.se_xml', 'EPSG:31464', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 789, 12, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
@@ -2673,1514 +2755,1535 @@
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 903, 18, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:25833', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 905, 20, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:25833', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 906, 21, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:25833', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 908, 22, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui_digitize', 250, 0, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 0);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui_digitize', 640, 1, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 0);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui_digitize', 893, 2, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31467', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui_digitize', 909, 3, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
--- TOC entry 1765 (class 0 OID 39047362)
--- Dependencies: 1242
+-- TOC entry 1809 (class 0 OID 48558625)
+-- Dependencies: 1277
+-- Data for Name: keyword; Type: TABLE DATA; Schema: public; Owner: admin
+INSERT INTO keyword (keyword_id, keyword) VALUES (1, 'Germany');
+INSERT INTO keyword (keyword_id, keyword) VALUES (2, ' Deutschland');
+INSERT INTO keyword (keyword_id, keyword) VALUES (3, 'WebGIS');
+INSERT INTO keyword (keyword_id, keyword) VALUES (4, 'WMS');
+INSERT INTO keyword (keyword_id, keyword) VALUES (5, 'WFS');
+INSERT INTO keyword (keyword_id, keyword) VALUES (6, 'WhereGroup');
+INSERT INTO keyword (keyword_id, keyword) VALUES (7, 'Mapbender');
+INSERT INTO keyword (keyword_id, keyword) VALUES (8, 'Laender');
+INSERT INTO keyword (keyword_id, keyword) VALUES (9, 'land');
+INSERT INTO keyword (keyword_id, keyword) VALUES (10, 'city');
+INSERT INTO keyword (keyword_id, keyword) VALUES (11, 'Ort');
+INSERT INTO keyword (keyword_id, keyword) VALUES (12, ' Staedte');
+INSERT INTO keyword (keyword_id, keyword) VALUES (13, 'Stadt');
+INSERT INTO keyword (keyword_id, keyword) VALUES (14, 'Postleitzahl');
+INSERT INTO keyword (keyword_id, keyword) VALUES (15, 'PLZ');
+INSERT INTO keyword (keyword_id, keyword) VALUES (16, 'postcode');
+INSERT INTO keyword (keyword_id, keyword) VALUES (17, 'railroad');
+INSERT INTO keyword (keyword_id, keyword) VALUES (18, 'Bahn');
+INSERT INTO keyword (keyword_id, keyword) VALUES (19, 'DB');
+INSERT INTO keyword (keyword_id, keyword) VALUES (20, 'river');
+INSERT INTO keyword (keyword_id, keyword) VALUES (21, 'Fluss');
+INSERT INTO keyword (keyword_id, keyword) VALUES (22, 'water');
+INSERT INTO keyword (keyword_id, keyword) VALUES (23, 'Wasser');
+INSERT INTO keyword (keyword_id, keyword) VALUES (24, 'road');
+INSERT INTO keyword (keyword_id, keyword) VALUES (25, 'Strasse');
+INSERT INTO keyword (keyword_id, keyword) VALUES (26, 'Infrastruktur');
+INSERT INTO keyword (keyword_id, keyword) VALUES (27, 'Staedte');
+INSERT INTO keyword (keyword_id, keyword) VALUES (28, 'Bundesland');
+INSERT INTO keyword (keyword_id, keyword) VALUES (29, 'Land');
+-- TOC entry 1791 (class 0 OID 47913191)
+-- Dependencies: 1249
 -- Data for Name: layer; Type: TABLE DATA; Schema: public; Owner: admin
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2712, 250, 0, '', '', 'Demis World Map', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2713, 250, 1, '0', 'Bathymetry', 'Bathymetry', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2714, 250, 2, '0', 'Countries', 'Countries', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2715, 250, 3, '0', 'Topography', 'Topography', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2716, 250, 4, '0', 'Hillshading', 'Hillshading', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2717, 250, 5, '0', 'Builtup areas', 'Builtup areas', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2718, 250, 6, '0', 'Coastlines', 'Coastlines', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2719, 250, 7, '0', 'Waterbodies', 'Waterbodies', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2720, 250, 8, '0', 'Inundated', 'Inundated', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2721, 250, 9, '0', 'Rivers', 'Rivers', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2722, 250, 10, '0', 'Streams', 'Streams', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2723, 250, 11, '0', 'Railroads', 'Railroads', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2724, 250, 12, '0', 'Highways', 'Highways', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2725, 250, 13, '0', 'Roads', 'Roads', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2726, 250, 14, '0', 'Trails', 'Trails', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2727, 250, 15, '0', 'Borders', 'Borders', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2728, 250, 16, '0', 'Cities', 'Cities', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2729, 250, 17, '0', 'Settlements', 'Settlements', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2730, 250, 18, '0', 'Spot elevations', 'Spot elevations', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2731, 250, 19, '0', 'Airports', 'Airports', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (2732, 250, 20, '0', 'Ocean features', 'Ocean features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3384, 328, 0, '', '', 'SW!ACE: Layers des Smallworld GIS', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3385, 328, 1, '0', 'Autobahn', 'Autobahn', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3386, 328, 2, '0', 'Bundesstr.', 'Bundesstr.', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3387, 328, 3, '0', 'Landesstr.', 'Landesstr.', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3388, 328, 4, '0', 'Kreisstr.', 'Kreisstr.', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3389, 328, 5, '0', 'AS Nr.', 'AS Nr.', 1, 0, 100220, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3390, 328, 6, '0', 'AS Name', 'AS Name', 1, 0, 53451, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3391, 328, 7, '0', 'Bauwerke', 'Bauwerke', 1, 0, 24720, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3392, 328, 8, '0', 'BW-Nr.', 'BW-Nr.', 1, 0, 24720, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3393, 328, 9, '0', 'Aeste', 'Aeste', 1, 0, 233847, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3394, 328, 10, '0', 'Netzkn.', 'Netzkn.', 1, 0, 53451, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3395, 328, 11, '0', 'Nullpkt.', 'Nullpkt.', 1, 0, 24720, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3396, 328, 12, '0', 'Str. Bez.', 'Str. Bez.', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3397, 328, 13, '0', 'Abs.Nr.', 'Abs.Nr.', 1, 0, 53451, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3398, 328, 14, '0', 'Durchlaesse', 'Durchlaesse', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3399, 328, 15, '0', 'Kreuzungen', 'Kreuzungen', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3400, 328, 16, '0', 'DGK 5', 'DGK 5', 0, 0, 24720, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3401, 329, 0, '', 'MUENSTER', 'Geobasisdaten Muenster', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3402, 329, 1, '0', 'splan', 'Stadtplan', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3403, 329, 2, '0', 'luftb', 'Luftbilder', 0, 1, 50000, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3404, 329, 3, '0', 'dgk5dbr', 'DGK5', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3405, 329, 4, '0', 'Stadtgrundkarte', 'Stadtgrundkarte', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3406, 329, 5, '4', 'flst', 'Flurstuecke', 0, 1, 2500, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3407, 329, 6, '4', 'gebaeude', 'Gebaeude', 0, 1, 2500, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3408, 329, 7, '4', 'linien', 'Topographie', 0, 1, 2500, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3409, 329, 8, '4', 'texte', 'Beschriftung', 0, 1, 2500, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3470, 336, 0, '', '', 'DTK10', 0, 138, 27683, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3471, 336, 1, '0', 'DTK10:Gesamt', 'Gesamt', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (3472, 336, 2, '0', 'DTK10:GesamtRS', 'GesamtRS', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (5575, 486, 0, '', 'PLZ_441', 'PLZ_441', 0, 1, 1000000000, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (5576, 486, 1, '0', 'Nationalborder', 'National Border', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (5577, 486, 2, '0', 'Postcodeareas', 'Post Code Areas', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (5578, 486, 3, '0', 'Postcodelabels', 'Post Code Labels', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7255, 525, 0, '', 'Middle_America', 'Middle America', 0, 0, 119999880, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7256, 525, 1, '0', 'North_and_South_American_States', 'America', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7257, 525, 2, '0', 'Middle_American_States_AREA', 'State Area', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7258, 525, 3, '0', 'Middle_America_DEM_surface', 'Elevation Model', 0, 0, 11999988, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7259, 525, 4, '0', 'National_borders', 'Borders', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7260, 525, 5, '0', 'Lakes_and_temporary_inundated_areas', 'Lakes', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7261, 525, 6, '0', 'Temporary_and_permanent_rivers_and_streams', 'Rivers', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7262, 525, 7, '0', 'Larger_cities_polygon', 'Cities', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7263, 525, 8, '0', 'Roads', 'Roads', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7264, 525, 9, '0', 'Railway_systems', 'Rails', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7265, 525, 10, '0', 'Smaller_cities_and_villages_point', 'Places', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7266, 525, 11, '0', 'Archaeological_maya_sites', 'Maya Sites', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7267, 525, 12, '0', 'Archaeological_maya_records', 'Maya Records', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7491, 583, 0, '', 'canada_base', 'Atlas of Canada WMS', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7492, 583, 1, '0', 'roc_2m', 'Regions outside Canada (1:2 000 000)', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7493, 583, 2, '0', 'roc_7.5m', 'Regions outside Canada (1:7 500 000)', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7494, 583, 3, '0', 'roc_15m', 'Regions outside Canada (1:15 000 000)', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7495, 583, 4, '0', 'wa_2m', 'Water areas (1:2 000 000)', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7496, 583, 5, '0', 'wa_7.5m', 'Water areas (1:7 500 000)', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7497, 583, 6, '0', 'wa_15m', 'Water areas (1:15 000 000)', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7498, 583, 7, '0', 'wa_60m', 'Water areas (1:60 000 000)', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7499, 583, 8, '0', 'drain_2m', 'Drainage (1:2 000 000)', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7500, 583, 9, '0', 'drain_7.5m', 'Drainage (1:7 500 000)', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7501, 583, 10, '0', 'drain_15m', 'Drainage (1:15 000 000)', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7502, 583, 11, '0', 'drain_60m', 'Drainage (1:60 000 000)', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7503, 583, 12, '0', 'roads_2m', 'Road network (1:2 000 000)', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7504, 583, 13, '0', 'roads_7.5m', 'Road network (1:7 500 000)', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7505, 583, 14, '0', 'roads_15m', 'Road network (1:15 000 000)', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7506, 583, 15, '0', 'nat_bounds', 'Provincial and Territorial Boundaries', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7507, 583, 16, '0', 'int_bounds', 'Boundaries', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7508, 583, 17, '0', 'can_7.5m', 'Landmass outline (1:7 500 000)', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7509, 583, 18, '0', 'places_symb_2m', 'Populated Places (symbols 1:2M)', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7510, 583, 19, '0', 'places_labels_2m', 'Populated Places (labels 1:2M)', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7511, 583, 20, '0', 'places_symb_7.5m', 'Populated Places (symbols 1:7.5M)', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7512, 583, 21, '0', 'places_labels_7.5m', 'Populated Places (labels 1:7.5M)', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7513, 583, 22, '0', 'places_symb_15m', 'Populated Places (symbols 1:15M)', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7514, 583, 23, '0', 'places_labels_15m', 'Populated Places (labels 1:15M)', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7515, 583, 24, '0', 'cap_symb_e', 'Capitals (symbols)', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7516, 583, 25, '0', 'cap_labels', 'Capitals (Canada)', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7517, 584, 0, '', 'BSC_WMS', 'Bird Studies Canada WMS/WFS Server', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7518, 584, 1, '0', 'IBA', 'Canadian Important Bird Areas', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7519, 584, 2, '0', 'CBC_PT', 'Canadian Christmas Bird Count Locations', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7520, 584, 3, '0', 'CBC_PY', 'Canadian Christmas Bird Count Locations', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7521, 584, 4, '0', 'MMP', 'Marsh Monitoring Program Route Locations', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7522, 584, 5, '0', 'CLLS', 'Canadian Lakes Loon Survey Locations', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7523, 584, 6, '0', 'OBBA_SQUARE', 'Ontario Breeding Bird Atlas 10 km Squares', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7524, 584, 7, '0', 'OBBA_REGION', 'Ontario Breeding Bird Atlas Administrative Regions', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7525, 584, 8, '0', 'OBBA_BLOCK', 'Ontario Breeding Bird Atlas 100 km Blocks', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7526, 584, 9, '0', 'OWLS', 'Nocturnal Owl Survey Locations', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (7527, 584, 10, '0', 'BBS_PT', 'Breeding Bird Survey Route Start Points', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9663, 612, 0, '', '', 'European Space Agency', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9664, 612, 1, '0', '', 'European Space Agency', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9665, 612, 2, '1', '', 'BOUNDARIES', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9666, 612, 3, '2', 'BARRIERL_1M:MapAdmin', 'Barrier Line Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9667, 612, 4, '2', 'BNDTXT_1M:MapAdmin', 'Boundaries Coverage Text', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9668, 612, 5, '2', 'COASTL_1M:MapAdmin', 'Coastlines', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9669, 612, 6, '2', 'DEPTHL_1M:MapAdmin', 'Depth Contours', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9670, 612, 7, '2', 'OCEANSEA_1M:MapAdmin', 'Oceans/Seas', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9671, 612, 8, '2', 'POLBNDA_1M:MapAdmin', 'Administrative Areas', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9672, 612, 9, '2', 'POLBNDL_1M:MapAdmin', 'Political Boundaries', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9673, 612, 10, '2', 'POLBNDP_1M:MapAdmin', 'Political Boundary Point Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9674, 612, 11, '1', '', 'BURNSCARS', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9675, 612, 12, '11', 'GLOBSCAR012002:MapAdmin', 'GLOBSCAR012002', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9676, 612, 13, '11', 'GLOBSCAR022002:MapAdmin', 'GLOBSCAR022002', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9677, 612, 14, '11', 'GLOBSCAR032002:MapAdmin', 'GLOBSCAR032002', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9678, 612, 15, '11', 'GLOBSCAR042002:MapAdmin', 'GLOBSCAR042002', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9679, 612, 16, '11', 'GLOBSCAR052002:MapAdmin', 'GLOBSCAR052002', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9680, 612, 17, '11', 'GLOBSCAR062002:MapAdmin', 'GLOBSCAR062002', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9681, 612, 18, '11', 'GLOBSCAR072002:MapAdmin', 'GLOBSCAR072002', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9682, 612, 19, '11', 'GLOBSCAR082002:MapAdmin', 'GLOBSCAR082002', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9683, 612, 20, '11', 'GLOBSCAR092002:MapAdmin', 'GLOBSCAR092002', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9684, 612, 21, '11', 'GLOBSCAR102002:MapAdmin', 'GLOBSCAR102002', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9685, 612, 22, '11', 'GLOBSCAR112002:MapAdmin', 'GLOBSCAR112002', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9686, 612, 23, '11', 'GLOBSCAR122002:MapAdmin', 'GLOBSCAR122002', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9687, 612, 24, '1', '', 'DATA QUALITY', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9688, 612, 25, '24', 'DQLINE_TRANS_1M:MapAdmin', 'Data Quality Line Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9689, 612, 26, '24', 'DQLINE_UTIL_1M:MapAdmin', 'Data Quality Line Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9690, 612, 27, '1', '', 'DIGITAL TERRAIN', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9691, 612, 28, '27', 'ETOPO5:MapAdmin', 'Global 5 Minute Elevations', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9692, 612, 29, '27', 'GTOPO30:MapAdmin', 'Global 30 Second Elevations', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9693, 612, 30, '1', '', 'ELEVATION', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9694, 612, 31, '30', 'CONTOURL_1M:MapAdmin', 'Elevation Contours', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9695, 612, 32, '30', 'ELEVP_1M:MapAdmin', 'Spot Elevations', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9696, 612, 33, '1', '', 'ENVISAT', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9697, 612, 34, '33', 'AATSR:MapAdmin', 'AATSR', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9698, 612, 35, '33', 'ASAR:MapAdmin', 'ASAR', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9699, 612, 36, '33', 'ASAR_WSM:MapAdmin', 'ASAR_WSM', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9700, 612, 37, '33', 'MERIS_RR:MapAdmin', 'MERIS_RR', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9701, 612, 38, '1', '', 'EO_MAPS', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9702, 612, 39, '38', 'WORLD_DMSP_NIGHT:MapAdmin', 'WORLD_DMSP_NIGHT', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9703, 612, 40, '38', 'WORLD_MODIS_1KM:MapAdmin', 'WORLD_MODIS_1KM', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9704, 612, 41, '38', 'WORLD_MODIS_5KM:MapAdmin', 'WORLD_MODIS_5KM', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9705, 612, 42, '1', '', 'GISD', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9706, 612, 43, '42', 'GISD_ROI:MapAdmin', 'GISD_ROI', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9707, 612, 44, '1', '', 'HYDROGRAPHY', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9708, 612, 45, '44', 'AQUECANL_1M:MapAdmin', 'Aqueducts/Canals/Flumes/Penstocks', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9709, 612, 46, '44', 'DANGERP_1M:MapAdmin', 'Danger Point Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9710, 612, 47, '44', 'HYDROTXT_1M:MapAdmin', 'Hydrography Coverage Text', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9711, 612, 48, '44', 'INWATERA_1M:MapAdmin', 'Inland Water Areas', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9712, 612, 49, '44', 'MISCL_1M:MapAdmin', 'Miscellaneous Line Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9713, 612, 50, '44', 'MISCP_1M:MapAdmin', 'Miscellaneous Point Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9714, 612, 51, '44', 'WATRCRSL_1M:MapAdmin', 'Water Courses', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9715, 612, 52, '1', '', 'INDUSTRY', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9716, 612, 53, '52', 'EXTRACTA_1M:MapAdmin', 'Extraction Areas', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9717, 612, 54, '52', 'EXTRACTP_1M:MapAdmin', 'Extraction Point Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9718, 612, 55, '52', 'FISHINDA_1M:MapAdmin', 'Fish Hatcheries/Fish Farms', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9719, 612, 56, '52', 'INDTXT_1M:MapAdmin', 'Industry Coverage Text', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9720, 612, 57, '52', 'MISINDP_1M:MapAdmin', 'Miscellaneous Industry Point Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9721, 612, 58, '52', 'STORAGEP_1M:MapAdmin', 'Storage Point Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9722, 612, 59, '1', '', 'PHYSIOGRAPHY', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9723, 612, 60, '59', 'GROUNDA_1M:MapAdmin', 'Ground Surface Areas', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9724, 612, 61, '59', 'LANDICEA_1M:MapAdmin', 'Snow/Ice Fields and Glaciers', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9725, 612, 62, '59', 'LNDFRML_1M:MapAdmin', 'Landform Line Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9726, 612, 63, '59', 'PHYSTXT_1M:MapAdmin', 'Physiography Coverage Text', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9727, 612, 64, '59', 'SEAICEA_1M:MapAdmin', 'Sea Ice Areas', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9728, 612, 65, '1', '', 'POPULATION', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9729, 612, 66, '65', 'BUILTUPA_1M:MapAdmin', 'Built-Up Areas', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9730, 612, 67, '65', 'BUILTUPP_1M:MapAdmin', 'Built-Up Area Points', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9731, 612, 68, '65', 'MISPOPA_1M:MapAdmin', 'Miscellaneous Population Areas', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9732, 612, 69, '65', 'MISPOPP_1M:MapAdmin', 'Miscellaneous Population Points', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9733, 612, 70, '65', 'POPTXT_1M:MapAdmin', 'Population Coverage Text', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9734, 612, 71, '1', '', 'TRANSPORTATION', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9735, 612, 72, '71', 'AEROFACP_1M:MapAdmin', 'Airport Facilities Points', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9736, 612, 73, '71', 'DQLINE_TRANS_1M:MapAdmin', 'Data Quality Line Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9737, 612, 74, '71', 'MISTRANL_1M:MapAdmin', 'Miscellaneous Transportation Line Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9738, 612, 75, '71', 'RAILRDL_1M:MapAdmin', 'Railroads', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9739, 612, 76, '71', 'ROADL_1M:MapAdmin', 'Roads', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9740, 612, 77, '71', 'RRYARDP_1M:MapAdmin', 'Railroad Yard Points', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9741, 612, 78, '71', 'TRAILL_1M:MapAdmin', 'Trails and Tracks', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9742, 612, 79, '71', 'TRANSTRC_1M:MapAdmin', 'Transportation Structures Points', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9743, 612, 80, '71', 'TRANSTRL_1M:MapAdmin', 'Transportation Structures Lines', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9744, 612, 81, '71', 'TRANSTXT_1M:MapAdmin', 'Transportation Coverage Text', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9745, 612, 82, '1', '', 'UTILITIES', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9746, 612, 83, '82', 'DQLINE_UTIL_1M:MapAdmin', 'Data Quality Line Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9747, 612, 84, '82', 'PIPEL_1M:MapAdmin', 'Pipelines', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9748, 612, 85, '82', 'UTILL_1M:MapAdmin', 'Power Transmission/Telephone/Telegraph Lines', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9749, 612, 86, '82', 'UTILP_1M:MapAdmin', 'Utility Point Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9750, 612, 87, '82', 'UTILTXT_1M:MapAdmin', 'Utilities Coverage Text', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9751, 612, 88, '1', '', 'VEGETATION', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9752, 612, 89, '88', 'CROPA_1M:MapAdmin', 'Croplands', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9753, 612, 90, '88', 'GRASSA_1M:MapAdmin', 'Grasslands', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9754, 612, 91, '88', 'SWAMPA_1M:MapAdmin', 'Marshs/Swamps', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9755, 612, 92, '88', 'TREESA_1M:MapAdmin', 'Trees', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9756, 612, 93, '88', 'TUNDRAA_1M:MapAdmin', 'Tundra', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9757, 612, 94, '0', '', 'CubeWerx Inc.', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9758, 612, 95, '94', '', 'CubeWerx Inc.', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9759, 612, 96, '95', '', 'Boundaries', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9760, 612, 97, '96', 'BARRIERL_1M:Foundation:CubeWerx', 'Barrier Line Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9761, 612, 98, '96', 'BNDTXT_1M:Foundation:CubeWerx', 'Boundaries Coverage Text', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9762, 612, 99, '96', 'COASTL_1M:Foundation:CubeWerx', 'Coastlines', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9763, 612, 100, '96', 'DEPTHL_1M:Foundation:CubeWerx', 'Depth Contours', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9764, 612, 101, '96', 'OCEANSEA_1M:Foundation:CubeWerx', 'Oceans/Seas', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9765, 612, 102, '96', 'POLBNDA_1M:Foundation:CubeWerx', 'Administrative Areas', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9766, 612, 103, '96', 'POLBNDL_1M:Foundation:CubeWerx', 'Political Boundaries', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9767, 612, 104, '96', 'POLBNDP_1M:Foundation:CubeWerx', 'Political Boundary Point Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9768, 612, 105, '95', '', 'Data Quality', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9769, 612, 106, '105', 'DQLINE_TRANS_1M:Foundation:CubeWerx', 'Data Quality Line Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9770, 612, 107, '105', 'DQLINE_UTIL_1M:Foundation:CubeWerx', 'Data Quality Line Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9771, 612, 108, '95', '', 'Digital Terrain', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9772, 612, 109, '108', 'ETOPO2:Foundation:CubeWerx', 'Global 2 Minute Elevations', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9773, 612, 110, '108', 'GTOPO30:Foundation:CubeWerx', 'Global 30 Second Elevations', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9774, 612, 111, '108', 'RELIEF:Foundation:CubeWerx', 'Two Minute Shaded Relief', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9775, 612, 112, '95', '', 'Elevation', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9776, 612, 113, '112', 'CONTOURL_1M:Foundation:CubeWerx', 'Elevation Contours', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9777, 612, 114, '112', 'ELEVP_1M:Foundation:CubeWerx', 'Spot Elevations', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9778, 612, 115, '95', '', 'Hydrography', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9779, 612, 116, '115', 'AQUECANL_1M:Foundation:CubeWerx', 'Aqueducts/Canals/Flumes/Penstocks', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9780, 612, 117, '115', 'DANGERP_1M:Foundation:CubeWerx', 'Danger Point Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9781, 612, 118, '115', 'HYDROTXT_1M:Foundation:CubeWerx', 'Hydrography Coverage Text', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9782, 612, 119, '115', 'INWATERA_1M:Foundation:CubeWerx', 'Inland Water Areas', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9783, 612, 120, '115', 'MISCL_1M:Foundation:CubeWerx', 'Miscellaneous Line Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9784, 612, 121, '115', 'MISCP_1M:Foundation:CubeWerx', 'Miscellaneous Point Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9785, 612, 122, '115', 'WATRCRSL_1M:Foundation:CubeWerx', 'Water Courses', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9786, 612, 123, '95', '', 'Industry', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9787, 612, 124, '123', 'EXTRACTA_1M:Foundation:CubeWerx', 'Extraction Areas', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9788, 612, 125, '123', 'EXTRACTP_1M:Foundation:CubeWerx', 'Extraction Point Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9789, 612, 126, '123', 'FISHINDA_1M:Foundation:CubeWerx', 'Fish Hatcheries/Fish Farms', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9790, 612, 127, '123', 'INDTXT_1M:Foundation:CubeWerx', 'Industry Coverage Text', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9791, 612, 128, '123', 'MISINDP_1M:Foundation:CubeWerx', 'Miscellaneous Industry Point Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9792, 612, 129, '123', 'STORAGEP_1M:Foundation:CubeWerx', 'Storage Point Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9793, 612, 130, '95', '', 'Physiography', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9794, 612, 131, '130', 'GROUNDA_1M:Foundation:CubeWerx', 'Ground Surface Areas', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9795, 612, 132, '130', 'LANDICEA_1M:Foundation:CubeWerx', 'Snow/Ice Fields and Glaciers', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9796, 612, 133, '130', 'LNDFRML_1M:Foundation:CubeWerx', 'Landform Line Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9797, 612, 134, '130', 'PHYSTXT_1M:Foundation:CubeWerx', 'Physiography Coverage Text', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9798, 612, 135, '130', 'SEAICEA_1M:Foundation:CubeWerx', 'Sea Ice Areas', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9799, 612, 136, '95', '', 'Population', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9800, 612, 137, '136', 'BUILTUPA_1M:Foundation:CubeWerx', 'Built-Up Areas', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9801, 612, 138, '136', 'BUILTUPP_1M:Foundation:CubeWerx', 'Built-Up Area Points', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9802, 612, 139, '136', 'MISPOPA_1M:Foundation:CubeWerx', 'Miscellaneous Population Areas', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9803, 612, 140, '136', 'MISPOPP_1M:Foundation:CubeWerx', 'Miscellaneous Population Points', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9804, 612, 141, '136', 'POPTXT_1M:Foundation:CubeWerx', 'Population Coverage Text', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9805, 612, 142, '95', '', 'Transportation', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9806, 612, 143, '142', 'AEROFACP_1M:Foundation:CubeWerx', 'Airport Facilities Points', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9807, 612, 144, '142', 'DQLINE_TRANS_1M:Foundation:CubeWerx', 'Data Quality Line Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9808, 612, 145, '142', 'MISTRANL_1M:Foundation:CubeWerx', 'Miscellaneous Transportation Line Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9809, 612, 146, '142', 'RAILRDL_1M:Foundation:CubeWerx', 'Railroads', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9810, 612, 147, '142', 'ROADL_1M:Foundation:CubeWerx', 'Roads', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9811, 612, 148, '142', 'RRYARDP_1M:Foundation:CubeWerx', 'Railroad Yard Points', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9812, 612, 149, '142', 'TRAILL_1M:Foundation:CubeWerx', 'Trails and Tracks', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9813, 612, 150, '142', 'TRANSTRC_1M:Foundation:CubeWerx', 'Transportation Structures Points', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9814, 612, 151, '142', 'TRANSTRL_1M:Foundation:CubeWerx', 'Transportation Structures Lines', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9815, 612, 152, '142', 'TRANSTXT_1M:Foundation:CubeWerx', 'Transportation Coverage Text', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9816, 612, 153, '95', '', 'Utilities', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9817, 612, 154, '153', 'DQLINE_UTIL_1M:Foundation:CubeWerx', 'Data Quality Line Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9818, 612, 155, '153', 'PIPEL_1M:Foundation:CubeWerx', 'Pipelines', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9819, 612, 156, '153', 'UTILL_1M:Foundation:CubeWerx', 'Power Transmission/Telephone/Telegraph Lines', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9820, 612, 157, '153', 'UTILP_1M:Foundation:CubeWerx', 'Utility Point Features', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9821, 612, 158, '153', 'UTILTXT_1M:Foundation:CubeWerx', 'Utilities Coverage Text', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9822, 612, 159, '95', '', 'Vegetation', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9823, 612, 160, '159', 'CROPA_1M:Foundation:CubeWerx', 'Croplands', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9824, 612, 161, '159', 'GRASSA_1M:Foundation:CubeWerx', 'Grasslands', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9825, 612, 162, '159', 'SWAMPA_1M:Foundation:CubeWerx', 'Marshs/Swamps', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9826, 612, 163, '159', 'TREESA_1M:Foundation:CubeWerx', 'Trees', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9827, 612, 164, '159', 'TUNDRAA_1M:Foundation:CubeWerx', 'Tundra', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9828, 612, 165, '94', '', 'CubeWerx Inc.', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9829, 612, 166, '165', '', 'Shuttle Rader Topography Mission Data', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9830, 612, 167, '166', 'ONEARCSEC:SRTM:CubeWerx', 'One Arc Second SRTM', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9831, 612, 168, '166', 'THREEARCSEC:SRTM:CubeWerx', 'Three Arc Second SRTM', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9832, 612, 169, '94', '', 'CubeWerx Inc.', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9833, 612, 170, '169', '', 'Canadian Geology', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9834, 612, 171, '170', 'AGE_ROCK_TYPE_CA:GSC:CubeWerx', 'Canadian Age Rock Type', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9835, 612, 172, '170', 'FAULTS_CA:GSC:CubeWerx', 'Canadian Fault Lines', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9836, 612, 173, '169', '', 'World Geology', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9837, 612, 174, '173', 'AGE_ROCK_TYPE:GSC:CubeWerx', 'World Age Rock Type', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9838, 612, 175, '173', 'FAULTS:GSC:CubeWerx', 'World Fault Lines', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9839, 612, 176, '173', 'FELSIC_MAGMATIC:GSC:CubeWerx', 'Felsic Magmatic', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9840, 612, 177, '173', 'MAFIC_MAGMATIC:GSC:CubeWerx', 'Mafic Magmatic', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9841, 612, 178, '173', 'PRECAMBRIAN:GSC:CubeWerx', 'Precambrian', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9842, 612, 179, '0', '', 'World Map', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9843, 612, 180, '179', 'Bathymetry:DEMIS', 'Bathymetry', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9844, 612, 181, '179', 'Countries:DEMIS', 'Countries', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9845, 612, 182, '179', 'Topography:DEMIS', 'Topography', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9846, 612, 183, '179', 'Hillshading:DEMIS', 'Hillshading', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9847, 612, 184, '179', 'Builtup areas:DEMIS', 'Builtup areas', 1, 0, 2147483647, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9848, 612, 185, '179', 'Coastlines:DEMIS', 'Coastlines', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9849, 612, 186, '179', 'Waterbodies:DEMIS', 'Waterbodies', 1, 0, 2147483647, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9850, 612, 187, '179', 'Inundated:DEMIS', 'Inundated', 1, 0, 2147483647, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9851, 612, 188, '179', 'Rivers:DEMIS', 'Rivers', 1, 0, 2147483647, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9852, 612, 189, '179', 'Streams:DEMIS', 'Streams', 1, 0, 2147483647, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9853, 612, 190, '179', 'Railroads:DEMIS', 'Railroads', 1, 0, 2147483647, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9854, 612, 191, '179', 'Highways:DEMIS', 'Highways', 1, 0, 2147483647, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9855, 612, 192, '179', 'Roads:DEMIS', 'Roads', 1, 0, 2147483647, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9856, 612, 193, '179', 'Trails:DEMIS', 'Trails', 1, 0, 2147483647, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9857, 612, 194, '179', 'Borders:DEMIS', 'Borders', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9858, 612, 195, '179', 'Cities:DEMIS', 'Cities', 1, 0, 2147483647, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9859, 612, 196, '179', 'Settlements:DEMIS', 'Settlements', 1, 0, 2147483647, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9860, 612, 197, '179', 'Spot elevations:DEMIS', 'Spot elevations', 0, 0, 2147483647, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9861, 612, 198, '179', 'Airports:DEMIS', 'Airports', 1, 0, 2147483647, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9862, 612, 199, '179', 'Ocean features:DEMIS', 'Ocean features', 1, 0, 2147483647, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9863, 612, 200, '0', '', 'Spacemetric Image Server', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9864, 612, 201, '200', '', 'GLCF Satellite Images', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9865, 612, 202, '201', '', 'Landsat ETM Scenes', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9866, 612, 203, '202', 'LANDSAT_TM_GLCF_432:TEST', 'Landsat ETM Band 432 Scenes', 1, 2147483647, 2147483647, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9867, 612, 204, '202', 'LANDSAT_TM_GLCF_432_STRETCH:TEST', 'Landsat ETM Band 432 Scenes, Stretched', 1, 2147483647, 2147483647, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9868, 612, 205, '202', 'LANDSAT_TM_GLCF_742:TEST', 'Landsat ETM Band 742 Scenes', 1, 2147483647, 2147483647, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9869, 612, 206, '200', '', 'DMC Scenes', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9870, 612, 207, '206', 'DMC_QL:TEST', 'DMC Quicklooks', 1, 2147483647, 2147483647, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9871, 612, 208, '0', '', 'TEST2 (X)', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9872, 612, 209, '0', '', 'map annotations', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9873, 612, 210, '209', 'graticule', 'Lat/Lon Graticule', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9874, 612, 211, '209', 'crosshairs', 'Crosshairs', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9875, 613, 0, '', '', 'ArcIMS MapService', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9876, 613, 1, '0', 'Shaded Relief Imagery', 'Shaded Relief Imagery', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9877, 614, 0, '', '', 'ArcIMS Map Server', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9878, 614, 1, '0', '250K Topo Map', '250K Topo Map', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9879, 614, 2, '0', '100K Topo Map', '100K Topo Map', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9880, 614, 3, '0', '24K Topo Map', '24K Topo Map', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9881, 614, 4, '0', 'General Topo Map', 'General Topo Map', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9882, 614, 5, '0', 'Road', 'Road', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9883, 614, 6, '0', '24K Quad', '24K Quad', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9884, 614, 7, '0', '100K Quad', '100K Quad', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9885, 614, 8, '0', '250K Quad', '250K Quad', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9886, 614, 9, '0', 'County', 'County', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9887, 614, 10, '0', 'State', 'State', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9888, 614, 11, '0', 'City', 'City', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9889, 614, 12, '0', 'Geographic Name', 'Geographic Name', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9890, 615, 0, '', '', 'ArcIMS Map Server', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9891, 615, 1, '0', 'Population', 'Population', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9892, 615, 2, '0', 'Landuse', 'Landuse', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9893, 615, 3, '0', 'Countries', 'Countries', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9894, 615, 4, '0', 'Landsat images', 'Landsat images', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9895, 615, 5, '0', 'Watersheds', 'Watersheds', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9896, 615, 6, '0', 'Rivers', 'Rivers', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9897, 615, 7, '0', 'Ramsar sites (Polygons)', 'Ramsar sites (Polygons)', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9898, 615, 8, '0', 'Ramsar sites', 'Ramsar sites', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9899, 615, 9, '0', 'Ramsar sites (Points)', 'Ramsar sites (Points)', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9900, 615, 10, '0', 'Cities', 'Cities', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9901, 616, 0, '', '', 'GeoNovaSDE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9902, 616, 1, '0', '10k_Drainage_polygons', '10k_Drainage Polygons', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9903, 616, 2, '0', 'ST_POINT', 'ST_POINT', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9904, 616, 3, '0', 'WA_POINT', 'WA_POINT', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9905, 616, 4, '0', 'ST_LINE', 'ST_LINE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9906, 616, 5, '0', 'LF_POINT', 'LF_POINT', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9907, 616, 6, '0', 'UT_LINE', 'UT_LINE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9908, 616, 7, '0', 'LF_LINE', 'LF_LINE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9909, 616, 8, '0', 'RR_POINT', 'RR_POINT', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9910, 616, 9, '0', 'RR_LINE', 'RR_LINE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9911, 616, 10, '0', 'DA_POINT', 'DA_POINT', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9912, 616, 11, '0', 'DL_LINE', 'DL_LINE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9913, 616, 12, '0', 'DA_POLY', 'DA_POLY', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9914, 616, 13, '0', 'DA_LINE', 'DA_LINE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9915, 616, 14, '0', 'LC_POINT', 'LC_POINT', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9916, 616, 15, '0', 'LC_LINE', 'LC_LINE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9917, 616, 16, '0', 'UT_POINT', 'UT_POINT', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9918, 616, 17, '0', 'WA_LINE', 'WA_LINE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9919, 616, 18, '0', 'COAST', 'COAST', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9920, 616, 19, '0', 'ROADS', 'ROADS', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9921, 617, 0, '', '', 'Geobase_NRN_NewfoundlandAndLabrador_I_Detail', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9922, 617, 1, '0', 'NewfoundlandLabrador', 'Provincial Boundary', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9923, 617, 2, '0', 'Water', 'Water', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9924, 617, 3, '0', 'Highways', 'Highways', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9925, 617, 4, '0', 'highwaysMjrRoads', 'Highways and Major Roads', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9926, 617, 5, '0', 'allroads', 'All Roads', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9927, 617, 6, '0', 'FerrySeg', 'FERRYSEG', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9928, 617, 7, '0', 'Junction', 'JUNCTION', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (9929, 617, 8, '0', 'BlkPassage', 'BLKPASSAGE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10028, 624, 0, '', '', 'gewstat', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10029, 624, 1, '0', 'Uebrige Gewaesser groesser 12 m Breite 3', 'Uebrige Gewaesser groesser 12 m Breite', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10030, 624, 2, '0', 'Uebrige Gewaesser kleiner 12 m Breite 2', 'Uebrige Gewaesser kleiner 12 m Breite', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10031, 624, 3, '0', 'Kanaele groesser 12 m Breite 2', 'Kanaele groesser 12 m Breite', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10032, 624, 4, '0', 'Kanaele kleiner 12m Breite', 'Kanaele kleiner 12 m Breite', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10033, 624, 5, '0', 'Unterirdisch verlaufende Gewaesser', 'Unterirdisch verlaufende Gewaesser', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10034, 624, 6, '0', 'Fliessgewaesser groesser 12 m Breite', 'Fliessgewaesser groesser 12 m Breite', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10035, 624, 7, '0', 'Fliessgewaesser kleiner 12 m Breite', 'Fliessgewaesser kleiner 12 m Breite', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10036, 624, 8, '0', 'St_Kanaele 1000 m', 'St_Kanaele 1000 m', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10037, 624, 9, '0', 'St_Rhein und Weser 1000 m', 'St_Rhein und Weser 1000 m', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10038, 624, 10, '0', 'St_Fliessgewaesser 1000 m', 'St_Fliessgewaesser 1000 m', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10039, 624, 11, '0', 'St_Kanaele 500 m', 'St_Kanaele 500 m', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10040, 624, 12, '0', 'St_Rhein und Weser 500 m', 'St_Rhein und Weser 500 m', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10041, 624, 13, '0', 'St_Fliessgewaesser 500 m', 'St_Fliessgewaesser 500 m', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10042, 624, 14, '0', 'St_Kanaele 100 m', 'St_Kanaele 100 m', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10043, 624, 15, '0', 'St_Rhein und Weser 100 m', 'St_Rhein und Weser 100 m', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10044, 624, 16, '0', 'St_Fliessgewaesser 100 m', 'St_Fliessgewaesser 100 m', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10045, 624, 17, '0', 'Stationierungslinie', 'Stationierungslinie', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10046, 624, 18, '0', 'Fluesse', 'Fluesse', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10047, 625, 0, '', 'DEMO', 'GMap WMS Demo Server', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10048, 625, 1, '0', 'bathymetry', 'Elevation/Bathymetry', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10049, 625, 2, '0', 'land_fn', 'Foreign Lands', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10050, 625, 3, '0', 'park', 'Parks', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10051, 625, 4, '0', 'drain_fn', 'Water', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10052, 625, 5, '0', 'drainage', 'Drainage', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10053, 625, 6, '0', 'prov_bound', 'Province', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10054, 625, 7, '0', 'fedlimit', 'Federal Limit', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10055, 625, 8, '0', 'rail', 'Railroads', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10056, 625, 9, '0', 'road', 'Roads', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10057, 625, 10, '0', 'popplace', 'Cities', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10058, 625, 11, '0', 'grid', 'Grid', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10106, 634, 0, '', 'Location', 'Point locations', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10107, 634, 1, '0', 'city_austral', 'Australasian Cities', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10108, 634, 2, '0', 'capital_aus', 'Australian Capital Cities', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10109, 634, 3, '0', 'town_aus', '          Some Australian towns', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10110, 634, 4, '0', 'wastewet', '          Wastewater artificial wetlands listed as', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10153, 637, 0, '', 'Bathymetry', 'MapServer WMS Demo', 0, 50000, 149999900, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10154, 637, 1, '0', 'etopo2', 'etopo2', 0, 50000, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10155, 637, 2, '0', 'ecbathy', 'ecbathy', 0, 50000, 10000000, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10156, 637, 3, '0', 'gom', 'gom', 0, 50000, 2000000, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10157, 637, 4, '0', 'bbay', 'bbay', 0, 50000, 1000000, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10158, 637, 5, '0', 'gomctr', 'gomctr', 0, 50000, 749999, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10159, 637, 6, '0', 'world_line_simp', 'world_line_simp', 0, 4999990, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10160, 637, 7, '0', 'world_line', 'world_line', 0, 0, 4999990, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10165, 640, 0, '', '', 'OnEarth Web Map Server', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10166, 640, 1, '0', 'global_mosaic', 'WMS Global Mosaic, pan sharpened', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10167, 640, 2, '0', 'global_mosaic_base', 'WMS Global Mosaic, not pan sharpened', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10168, 640, 3, '0', 'us_landsat_wgs84', 'CONUS mosaic of 1990 MRLC dataset', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10169, 640, 4, '0', 'us_overlays', 'Progressive US overlay map, white background', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10170, 640, 5, '0', 'us90_overlays', 'MRLC US mosaic with progressive overlay map', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10171, 640, 6, '0', 'daily_terra', 'Daily composite of MODIS-TERRA images', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10172, 640, 7, '0', 'daily_aqua', 'Daily composite of MODIS-AQUA images', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10173, 640, 8, '0', 'modis', 'Blue Marble, Global MODIS derived image', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10174, 640, 9, '0', 'huemapped_srtm', 'SRTM derived global elevation, 3 arc-second, hue m', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10175, 640, 10, '0', 'srtmplus', 'Global 1km elevation, seamless SRTM land elevation', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10176, 640, 11, '0', 'worldwind_dem', 'SRTM derived global elevation, 3 arc-second', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10177, 640, 12, '0', 'us_ned', 'United States elevation, 30m', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10178, 640, 13, '0', 'us_elevation', 'Digital Elevation Map of the United States, DTED d', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10179, 640, 14, '0', 'us_colordem', 'Digital Elevation Map of the United States, DTED d', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10194, 645, 0, '', '', 'ArcIMS MapService', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10195, 645, 1, '0', 'HDM:LANDMASS', 'Land Areas', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10196, 645, 2, '0', 'HDM:DFIRM_BFE', 'DFIRM Base Flood Elevations', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10197, 645, 3, '0', 'HDM:DFIRM_XSECTION', 'DFIRM Cross Sections', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10198, 645, 4, '0', 'HDM:DFIRM_FLD_AR', 'DFIRM Flood Hazard Areas', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10199, 645, 5, '0', 'HDM:Q3_COUNTYMAP', 'Flood Data Availability', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10200, 645, 6, '0', 'HDM:Q3_FLOOD', 'Q3 Flood Hazards', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10369, 648, 0, '', '', 'hangneigung', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10370, 648, 1, '0', 'hangneigung', 'Hangneigung', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10371, 648, 2, '0', 'Fliessgewaesser', 'Fliessgewaesser', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10415, 655, 0, '', 'SEACOOS Remotely-Sensed Imagery', 'SEACOOS Remotely-Sensed Imagery', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10416, 655, 1, '0', 'modis_ergb_low', 'MODIS Enhanced RGB, courtesy USF Institute for Mar', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10417, 655, 2, '0', 'modis_rgb_composite_low', 'MODIS Low Resolution RGB Composite, courtesy USF I', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10418, 655, 3, '0', 'modis_rgb_low', 'MODIS Low Resolution RGB, courtesy USF Institute f', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10419, 655, 4, '0', 'modis_rgb_hi_chesapeake_bay', 'MODIS High Resolution RGB, courtesy USF Institute', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10420, 655, 5, '0', 'modis_rgb_hi_florida_bay', 'MODIS High Resolution RGB, courtesy USF Institute', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10421, 655, 6, '0', 'modis_rgb_hi_miss_plume', 'MODIS High Resolution RGB, courtesy USF Institute', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10422, 655, 7, '0', 'modis_rgb_hi_suwannee_river', 'MODIS High Resolution RGB, courtesy USF Institute', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10423, 655, 8, '0', 'modis_rgb_hi_tampa_bay', 'MODIS High Resolution RGB, courtesy USF Institute', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10424, 655, 9, '0', 'oi_sst', 'Optimally Interpolated SST, courtesy USF Ocean Cir', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10425, 655, 10, '0', 'modis_sst', 'MODIS SST, courtesy USF Institute for Marine Remot', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10426, 655, 11, '0', 'avhrr_sst', 'AVHRR SST, courtesy USF Institute for Marine Remot', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10427, 655, 12, '0', 'modis_chl', 'MODIS Chl-A, courtesy USF Institute for Marine Rem', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10428, 655, 13, '0', 'jpl_sea_surface_height_composite', 'TBA', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10429, 655, 14, '0', 'tamu_level_III', 'Texas Mesonet Radar, courtesy Texas A and M Univer', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10430, 655, 15, '0', 'tamu_usrad', 'Texas Mesonet Radar, courtesy Texas A and M Univer', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10431, 655, 16, '0', 'surface_currents_radar', 'Surface currents (Radar) (EXPERIMENTAL), courtesy', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10432, 655, 17, '0', 'depth_averaged_currents', 'Depth-averaged currents (EXPERIMENTAL), courtesy U', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10433, 655, 18, '0', 'sea_surface_elevation', 'Sea surface elevation (EXPERIMENTAL), courtesy Uni', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10434, 655, 19, '0', 'opaque_legend_background', 'Opaque legend background', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10435, 655, 20, '0', 'modis_chl_legend_full_range', 'MODIS Chl-A Legend, courtesy USF Institute for Mar', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10436, 655, 21, '0', 'sst_legend_full_range', 'SST Legend, courtesy USF Institute for Marine Remo', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10437, 655, 22, '0', 'tamu_level_III_legend_full_range', 'Texas Mesonet Radar Legend, courtesy Texas A and M', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10438, 655, 23, '0', 'current_velocity_legend', 'Current velocity legend', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10439, 655, 24, '0', 'water_level_legend', 'Elevation legend', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10987, 670, 0, '', '', 'waldtyp', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10988, 670, 1, '0', 'Waldtyp', 'Waldtyp', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10989, 670, 2, '0', 'Waldtyp_50', 'Waldtyp_50', 0, 37494, 187472, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10990, 670, 3, '0', 'Waldtyp_Real', 'Waldtyp_Real', 0, 37494, 187472, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10991, 671, 0, '', '', 'wsg', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10992, 671, 1, '0', 'Trinkwasser Zone 1 punktfoermig', 'Trinkwasser Zone 1 punktfoermig', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10993, 671, 2, '0', 'Trinkwasserschutzgebiete', 'Trinkwasserschutzgebiete', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10994, 671, 3, '0', 'Heilquellen Zone 1 punktfoermig', 'Heilquellen Zone 1 punktfoermig', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (10995, 671, 4, '0', 'Heilquellenschutzgebiete', 'Heilquellenschutzgebiete', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (11541, 706, 0, '', '', 'WA_Atlas_GN_WMS', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (11542, 706, 1, '0', 'Australia Base Map', 'Australia Base Map', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (11543, 706, 2, '0', 'WA Base Map', 'WA Base Map', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (11544, 706, 3, '0', 'WA Base Map - Detailed', 'WA Base Map - Detailed', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (11545, 706, 4, '0', 'Bathymetry - Above Chart Datum', 'Bathymetry - Above Chart Datum', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (11546, 706, 5, '0', 'State Geological Polygons', 'State Geological Polygons', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (11547, 706, 6, '0', 'Beards Vegetation', 'Beards Vegetation', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (11629, 717, 0, '', '', 'forstamtsgr', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (11630, 717, 1, '0', '0', 'Forstamtsgrenzen', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13667, 739, 0, '', '', 'Eusoils_Ex', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13668, 739, 1, '0', '55', 'ERODI. Soil erodibility class', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13669, 739, 2, '0', '70', 'TXEROD. Textural factor of soil erodibility', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13670, 739, 3, '0', '48', 'CRUSTING. Soil crusting class', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13671, 739, 4, '0', '64', 'PHYSCHIM.Physi-chemical factor of soil', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13672, 739, 5, '0', '71', 'TXTCRUST. Textural factor of soil crusting', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13673, 739, 6, '0', '41', 'ATC. Accumulated temperature class', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13674, 739, 7, '0', '72', 'USE. Regrouped land use', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13675, 739, 8, '0', '39', 'AGLIM2NNI. 2nd Limitation to agricultural use', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13676, 739, 9, '0', '38', 'AGLIM1NNI. Dom.Limitation to agricultural use', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13677, 739, 10, '0', '53', 'EAWC_SUB. Subsoil easily avail.water capac.', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13678, 739, 11, '0', '54', 'EAWC_TOP. Topsoil easily avail.water capac.', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13679, 739, 12, '0', '42', 'AWC_SUB. Subsoil avail.water capacity', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13680, 739, 13, '0', '43', 'AWC_TOP. Topsoil avail.water capacity', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13681, 739, 14, '0', '56', 'HG. Hydro-geological class', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13682, 739, 15, '0', '51', 'DIMP. Depth to an impermeable layer', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13683, 739, 16, '0', '49', 'DGH. Depth to a gleyed horizon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13684, 739, 17, '0', '65', 'PMH. Parent material hydro-geological', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13685, 739, 18, '0', '61', 'PD_SUB. Subsoil Packing Density', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13686, 739, 19, '0', '62', 'PD_TOP. Topsoil packing density', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13687, 739, 20, '0', '66', 'STR_SUB. Subsoil structure', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13688, 739, 21, '0', '67', 'STR_TOP. Topsoil structure', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13689, 739, 22, '0', '68', 'TD. Rule inferred subsoil texture', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13690, 739, 23, '0', '73', 'VS. Volume of stones', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13691, 739, 24, '0', '52', 'DR. Depth to rock', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13692, 739, 25, '0', '44', 'BS_SUB. Base Subsoil Saturation', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13693, 739, 26, '0', '45', 'BS_TOP. Base Topsoil Saturation', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13694, 739, 27, '0', '46', 'CEC_SUB. Subsoil Cation Exch.Capacity', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13695, 739, 28, '0', '47', 'CEC_TOP. Topsoil Cation Exch.Capacity', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13696, 739, 29, '0', '58', 'MIN_SUB. Subsoil Mineralogy', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13697, 739, 30, '0', '59', 'MIN_TOP. Topsoil Mineralogy', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13698, 739, 31, '0', '57', 'MIN. Profile Mineralogy', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13699, 739, 32, '0', '50', 'DIFF. Soil Profile Differentiation', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13700, 739, 33, '0', '40', 'ALT. Elevation', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13701, 739, 34, '0', '63', 'PEAT', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13702, 739, 35, '0', '60', 'OC_TOP. Topsoil Organic Carbon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13703, 739, 36, '0', '69', 'TEXT. Dominant Surface Textural', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13704, 739, 37, '0', '21', 'SLOPESE. Secondary Slope class', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13705, 739, 38, '0', '20', 'SLOPEDO. Dominant Slope Class', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13706, 739, 39, '0', '37', 'ZMIN. Minimun elevetaion above sea', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13707, 739, 40, '0', '36', 'ZMAX. Maximun elevetaion above sea', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13708, 739, 41, '0', '30', 'WM2. Type of Water Manag.System', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13709, 739, 42, '0', '29', 'WM1. Presence of Water Manag.System', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13710, 739, 43, '0', '31', 'WR. Annual average soil water regime', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13711, 739, 44, '0', '10', 'IL. Impermeable Layer', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13712, 739, 45, '0', '19', 'ROO. Depth Class of obstacle to roots', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13713, 739, 46, '0', '2', 'AGLIM2. Sec.limitation to agr.use', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13714, 739, 47, '0', '1', 'AGLIM1. Dom.limitation to agr.use', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13715, 739, 48, '0', '28', 'USESE. Secondary Land Use', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13716, 739, 49, '0', '27', 'USEDO. Dominant Land Use', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13717, 739, 50, '0', '6', 'FAO85LV3. 3rd Level Soil Code 1974 FAO', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13718, 739, 51, '0', '5', 'FAO85LV2. 2nd Level Soil Code 1974 FAO', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13719, 739, 52, '0', '4', 'FAO85LV1. Soil Major Group 1974 FAO', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13720, 739, 53, '0', '3', 'FAO85FU. Full Soil Code 1974 FAO', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13721, 739, 54, '0', '9', 'FAO90LV2. 2nd level Soil Code 1990 FAO', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13722, 739, 55, '0', '8', 'FAO90LV1. Soil Major Group 1990 FAO', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13723, 739, 56, '0', '7', 'FAO90FU. Full Soil Code 1990 FAO', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13724, 739, 57, '0', '18', 'PARMASE3. 3rd level Sec.Par.Material', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13725, 739, 58, '0', '17', 'PARMASE2. 2nd level Sec.Par.Material', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13726, 739, 59, '0', '16', 'PARMASE1. Major Group Sec.Par.Material', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13727, 739, 60, '0', '15', 'PARMASE. Secondary Parent Material', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13728, 739, 61, '0', '14', 'PARMADO3. 3rd level Dom.Par.Material', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13729, 739, 62, '0', '13', 'PARMADO2. 2nd level Dom.Par.Material', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13730, 739, 63, '0', '12', 'PARMADO1. Major Group Dom.Par.Material', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13731, 739, 64, '0', '11', 'PARMADO. Dominant Parent Material', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13732, 739, 65, '0', '26', 'TXSUBSE. Sec.Sub-surface text.class', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13733, 739, 66, '0', '25', 'TXSUBDO. Dom.Sub-surface text.class', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13734, 739, 67, '0', '22', 'TXDEPCHG. Depth class to a text.change', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13735, 739, 68, '0', '24', 'TXSRFSE. Sec.surface text.class', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13736, 739, 69, '0', '23', 'TXSRFDO. Dom.surface text.class', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13737, 739, 70, '0', '33', 'WRBADJ2. 2nd Soil Adjective Code', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13738, 739, 71, '0', '32', 'WRBADJ1. First Soil Adjective Code', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13739, 739, 72, '0', '35', 'WRBLV1. Soil reference group', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13740, 739, 73, '0', '34', 'WRBFU. Full soil Code', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13741, 739, 74, '0', '97', 'Eurasia Lakes-Inland Waters', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13742, 739, 75, '0', '98', 'European Cities', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13743, 739, 76, '0', '0', 'Country Boundaries', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13744, 739, 77, '0', '99', 'Soil Polygon Outlines', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13751, 86, 0, '', 'World_map', 'World Map', 0, 1, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13752, 86, 1, '0', 'Countries', 'Countries', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13753, 86, 2, '0', 'Countrynames', 'Countrynames', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13754, 86, 3, '0', 'Citypoints', 'Citypoints', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13755, 86, 4, '0', 'City', 'Citynames', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13775, 101, 0, '', 'UMN_Mapserver', 'UMN Mapserver', 0, 1, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13776, 101, 1, '0', 'UMN_USER', 'UMN User', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (13777, 101, 2, '0', 'UMN_USER_NAMES', 'UMN Info', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19110, 902, 0, '', 'Brandenburg', 'DNM 100/2', 0, 25001, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19111, 902, 1, '0', 'kreis', 'Landkreise und kreisfreie Städte', 1, 25001, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19090, 900, 0, '', 'benin2', 'Pendjari National Parc', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19091, 900, 1, '0', 'zoneseri', 'Zone Seri', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19092, 900, 2, '0', 'zoneest', 'Zone Est', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19093, 900, 3, '0', 'zonepnp', 'Zone Pnp', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19094, 900, 4, '0', 'zonezck', 'Zone Zck', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19095, 900, 5, '0', 'zonezcp', 'Zone Zcp', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19096, 900, 6, '0', 'ldcpendjari', 'Limite du Complexe pendjari', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19097, 900, 7, '0', 'maresextension', 'Mares Extension', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19098, 900, 8, '0', 'piste1', 'Piste 1', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19099, 900, 9, '0', 'pistepodiega', 'Piste podiéga', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19100, 900, 10, '0', 'agglom', 'Agglomeration Areas', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14083, 764, 1, '0', 'flur', 'Flur', 1, 50000, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14084, 764, 2, '0', 'gema', 'Gemarkung', 1, 50000, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14085, 764, 3, '0', 'geme', 'Gemeinde', 1, 50000, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14087, 764, 5, '0', 'kreis', 'Landkreise', 1, 50000, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19101, 900, 11, '0', 'coursdeauperm', 'Cours deau permanent', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19102, 900, 12, '0', 'cCoursdeau2003', 'Cours d eau 2003', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19103, 900, 13, '0', 'coursdeautemp', 'Cours d eau temporaire', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19104, 900, 14, '0', 'escarpement', 'Escarpements', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19105, 900, 15, '0', 'mar', 'Mares', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19112, 902, 2, '0', 'wald', 'Wald', 0, 25001, 150000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19113, 902, 3, '0', 'ozen', 'Oberzentren', 0, 25001, 2000000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19114, 902, 4, '0', 'mzen', 'Mittelzentren', 0, 25001, 600000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19115, 902, 5, '0', 'uzen', 'Unterzentren', 0, 25001, 200000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19116, 902, 6, '0', 'lwas', 'Flüsse und Kanäle', 0, 25001, 150000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14104, 767, 0, '', 'SLUBFURT', 'SLUBFURT', 0, 500, 250001, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14105, 767, 1, '0', 'Mentalscape', 'Mentalscape', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14106, 767, 2, '0', 'Districts', 'Districts', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14107, 767, 3, '0', 'Odra', 'Odra', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14108, 767, 4, '0', 'Paths', 'Paths', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14109, 767, 5, '0', 'Edges', 'Edges', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14110, 767, 6, '0', 'Nodes', 'Nodes', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14111, 767, 7, '0', 'Landmarks', 'Landmarks', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14112, 767, 8, '0', 'CityWall', 'CityWall', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14113, 767, 9, '0', 'HotSpots', 'HotSpots', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14114, 767, 10, '0', 'HotSpots-2', 'HotSpots-2', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14115, 767, 11, '0', 'SDE-W', 'SDE-W', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19117, 902, 7, '0', 'fwas', 'Seen', 0, 25001, 250001, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19118, 902, 8, '0', 'ebahn', 'Eisenbahnen', 0, 25001, 250001, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19119, 902, 9, '0', 'kstr', 'Kreisstraßen', 0, 25001, 100000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19120, 902, 10, '0', 'lstr', 'Landesstraßen', 0, 25001, 250001, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19121, 902, 11, '0', 'bstr', 'Bundesstraßen', 0, 25001, 749999, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19122, 902, 12, '0', 'astr', 'Autobahnen', 0, 25001, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19123, 902, 13, '0', 'nfwas', 'Namen der Seen', 0, 25001, 100000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19124, 902, 14, '0', 'kfz', 'Kfz-Zeichen', 0, 2000000, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19130, 903, 5, '0', 'lwas', 'Flüsse und Kanäle', 0, 1000, 50000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14177, 777, 0, '', 'Africa', 'Lieu / Locations', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14178, 777, 1, '0', 'adminareas', 'Pays / Countries', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14179, 777, 2, '0', 'provinceboundaries', 'D&#233;part./ Provinces', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14180, 777, 3, '0', 'populateplace', 'Villes / Towns', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19131, 903, 6, '0', 'fwas', 'Seen, Teiche', 0, 1000, 50000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19132, 903, 7, '0', 'kgrnz', 'Kreisgrenze', 0, 1000, 50000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19133, 903, 8, '0', 'flug', 'Internationale Flughäfen', 0, 1000, 29999, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19134, 903, 9, '0', 'ebahn', 'Eisenbahnverbindungen', 0, 1000, 50000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19135, 903, 10, '0', 'str', 'Straßen', 0, 1000, 50000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19136, 903, 11, '0', 'haus', 'Gebäude', 0, 1000, 50000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19137, 903, 12, '0', 'nfwas', 'Namen der Seen, Teiche', 0, 1000, 50000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19138, 904, 0, '', 'Brandenburg', 'DNM 250/2', 0, 25001, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19139, 904, 1, '0', 'kreis', 'Landkreise und kreisfreie Städte', 1, 200000, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19140, 904, 2, '0', 'orte', 'Zentren', 0, 200000, 1000000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19141, 904, 3, '0', 'korte', 'Orte', 0, 200000, 749999, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19142, 904, 4, '0', 'lwas', 'Flüsse und Kanäle', 0, 200000, 749999, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19143, 904, 5, '0', 'fwas', 'Seen', 0, 200000, 749999, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19144, 904, 6, '0', 'ebahn', 'Eisenbahnen', 0, 200000, 749999, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19145, 904, 7, '0', 'lstr', 'Landesstraßen', 0, 200000, 400000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14197, 779, 0, '', 'Ruanda24', 'Ruanda', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14198, 779, 1, '0', 'Countries', 'Countries', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14199, 779, 2, '1', 'Countries', 'Country Names', 0, 1000000, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14200, 779, 3, '0', 'Country', 'Country Names', 0, 1000000, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14201, 779, 4, '0', 'Cities', 'Cities', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14202, 779, 5, '4', 'Cities', 'Cities', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14203, 779, 6, '0', 'City', 'City Names', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14204, 779, 7, '0', 'Landsat', 'Sat-Image', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14205, 779, 8, '0', 'Dry Savannah', 'Dry Savannah', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14206, 779, 9, '8', 'Dry Savannah', 'Ruanda2', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14207, 779, 10, '0', 'Swamps', 'Swamps', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14208, 779, 11, '10', 'Swamps', 'Ruanda2', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14209, 779, 12, '0', 'Lakes', 'Lakes', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14210, 779, 13, '12', 'Lakes', 'Lakes', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14211, 779, 14, '0', 'Lake Names', 'Lake Names', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14212, 779, 15, '0', 'Dry Swamp', 'Dry Swamp', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14213, 779, 16, '15', 'Dry Swamp', 'Ruanda2', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14214, 779, 17, '0', 'Forests', 'Forests', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14215, 779, 18, '17', 'Forests', 'Ruanda2', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14216, 779, 19, '0', 'Islands', 'Islands', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14217, 779, 20, '19', 'Islands', 'Ruanda2', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14218, 779, 21, '0', 'Valleys', 'Valleys', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14219, 779, 22, '21', 'Valleys', 'Ruanda2', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14220, 779, 23, '0', 'Vegetation.shp', 'Vegetation', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14221, 779, 24, '0', 'Akagera-river', 'Akagera-river', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14222, 779, 25, '24', 'Akagera-river', 'Ruanda2', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14223, 779, 26, '0', 'Parc Limit', 'Parc Limit', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14224, 779, 27, '26', 'Parc Limit', 'Parc Limit', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14225, 779, 28, '0', 'Lanes', 'Lanes', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14226, 779, 29, '28', 'Lanes', 'Ruanda2', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14227, 779, 30, '0', 'Infrastructure', 'Infrastructure', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14228, 779, 31, '0', 'Places', 'Places', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14251, 785, 0, '', '', 'dtk200_500_1000_a10_gk3_wms', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14252, 785, 1, '0', 'DTK200-V', 'Digitale Topographische Karte 1:200.000', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14253, 785, 2, '0', 'DTK500-V', 'Digitale Topographische Karte 1:500.000', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14254, 785, 3, '0', 'DTK1000', 'Digitale Topographische Karte 1:1.000.000', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14255, 786, 0, '', 'MS', 'Luftbild', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14256, 786, 1, '0', 'ortho', 'Luftbild', 0, 1, 125000, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14257, 787, 0, '', '', 'OGC-Dienst der Bayerischen Vermessungsverwaltung', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14258, 787, 1, '0', 'DOP', 'DOP', 0, 20, 400880, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14259, 787, 2, '0', 'TK50', 'TK50', 0, 20, 80176, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14260, 787, 3, '0', 'UK500', 'UK500', 0, 20, 801759, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14261, 788, 0, '', 'DOP', 'Digitale Orthophotos mit einer reduzierten Bodenau', 0, 10000, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14262, 788, 1, '0', 'dop25', 'DOP 25m', 0, 50000, 2000000, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14263, 788, 2, '0', 'dop5', 'DOP 5m', 0, 10000, 50000, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14264, 789, 0, '', '', 'Rasterdaten_tk100_tk50', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14265, 789, 1, '0', 'UEB', 'Uebersicht Sachsen', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14266, 789, 2, '0', 'tk100', 'Topog. Karte 1:100000', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14267, 789, 3, '2', 'tk100s', 'tk100-Schriften', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14268, 789, 4, '2', 'tk100w', 'tk100-Gewaesser', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14269, 789, 5, '2', 'tk100g', 'tk100-Grundriss', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14270, 789, 6, '2', 'tk100i', 'tk100-Hoehenlinien', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14271, 789, 7, '2', 'tk100v', 'tk100-Vegetation', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14272, 789, 8, '0', 'tk50', 'Topog. Karte 1:50000', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14273, 789, 9, '8', 'tk50w', 'tk50-Gewaesser', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14274, 789, 10, '8', 'tk50g', 'tk50-Grundriss', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14275, 789, 11, '8', 'tk50i', 'tk50-Hoehenlinien', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14276, 789, 12, '8', 'tk50v', 'tk50-Vegetation', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14277, 790, 0, '', '', 'LGN - WMS', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14278, 790, 1, '0', 'DUEKN5000', 'Uebersichtskarte 1:5000000', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14279, 790, 2, '0', 'DUEKN1000', 'Uebersichtskarte 1:1000000', 0, 0, 847059, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14280, 790, 3, '0', 'DUEKN500', 'Uebersichtskarte 1:500000', 0, 0, 795580, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14281, 790, 4, '0', 'TK100', 'Topographische Karte 1:100000', 0, 0, 423530, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14287, 792, 0, '', '', 'TKVV', 0, 200, 200440, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14288, 792, 1, '0', 'Thueringer_Orthofotos', 'Thueringer_Orthofotos', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14289, 792, 2, '1', 'Orthophotos_TH-2m', 'Orthophotos_TH-2m', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14290, 792, 3, '0', 'TK50', 'TK50', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14291, 792, 4, '3', 'Top.Karte_50_gesamt', 'Top.Karte_50_gesamt', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14292, 792, 5, '3', 'Grundriss', 'Grundriss', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14293, 792, 6, '3', 'Gewaesser', 'Gewaesser', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14294, 792, 7, '3', 'Hoehenschichten', 'Hoehenschichten', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14295, 792, 8, '3', 'Strassen', 'Strassen', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14296, 792, 9, '3', 'Wald', 'Wald', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14297, 793, 0, '', '', 'OGC-Dienst des Hessischen Landesvermessungsamtes', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14298, 793, 1, '0', 'ATKIS50', 'ATKIS50', 0, 601, 50110, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14299, 793, 2, '0', 'ATKIS100', 'ATKIS100', 0, 1203, 150330, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14300, 793, 3, '0', 'DOP2SW', 'DOP2SW', 0, 40088, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14342, 797, 1, '0', 'flur', 'Flur', 1, 50000, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14343, 797, 2, '0', 'gema', 'Gemarkung', 1, 50000, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14344, 797, 3, '0', 'geme', 'Gemeinde', 1, 50000, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14346, 797, 5, '0', 'kreis', 'Landkreise', 1, 50000, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14360, 799, 0, '', 'DOP', 'Digitale Orthophotos mit einer reduzierten Bodenau', 0, 10000, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14361, 799, 1, '0', 'dop25', 'DOP 25m', 0, 50000, 2000000, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14362, 799, 2, '0', 'dop5', 'DOP 5m', 0, 10000, 50000, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14363, 800, 0, '', '', 'WMS', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14364, 800, 1, '0', 'doq', '1991 doq', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14365, 800, 2, '0', 'fsa', '2003 fsa', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14366, 800, 3, '0', 'metro', '2004 NGA', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14370, 824, 0, '', '', 'ECW Images', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14371, 824, 1, '0', '/l7ecw_stretched/orthol7_20123xs190600.ecw', 'orthol7_20123xs190600.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14372, 824, 2, '0', '/l7ecw_stretched/orthol7_20124xs190600.ecw', 'orthol7_20124xs190600.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14373, 824, 3, '0', '/l7ecw_stretched/orthol7_20125xs190600.ecw', 'orthol7_20125xs190600.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14374, 824, 4, '0', '/l7ecw_stretched/orthol7_20222xs120501.ecw', 'orthol7_20222xs120501.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14375, 824, 5, '0', '/l7ecw_stretched/orthol7_20223xs120501.ecw', 'orthol7_20223xs120501.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14376, 824, 6, '0', '/l7ecw_stretched/orthol7_20224xs120501.ecw', 'orthol7_20224xs120501.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14377, 824, 7, '0', '/l7ecw_stretched/orthol7_20225xs120501.ecw', 'orthol7_20225xs120501.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14378, 824, 8, '0', '/l7ecw_stretched/orthol7_20323xs170600.ecw', 'orthol7_20323xs170600.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14379, 824, 9, '0', '/l7ecw_stretched/orthol7_20324xs170600.ecw', 'orthol7_20324xs170600.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14380, 824, 10, '0', '/l7ecw_stretched/orthol7_20325xs300400.ecw', 'orthol7_20325xs300400.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14381, 824, 11, '0', '/l7ecw_stretched/orthol7_20421xs070500.ecw', 'orthol7_20421xs070500.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14382, 824, 12, '0', '/l7ecw_stretched/orthol7_20422xs070500.ecw', 'orthol7_20422xs070500.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14383, 824, 13, '0', '/l7ecw_stretched/orthol7_20423xs100999.ecw', 'orthol7_20423xs100999.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14384, 824, 14, '0', '/l7ecw_stretched/orthol7_20424xs240799.ecw', 'orthol7_20424xs240799.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14385, 824, 15, '0', '/l7ecw_stretched/orthol7_20425xs240799.ecw', 'orthol7_20425xs240799.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14386, 824, 16, '0', '/l7ecw_stretched/orthol7_20520xs170700.ecw', 'orthol7_20520xs170700.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14387, 824, 17, '0', '/l7ecw_stretched/orthol7_20521xs170700.ecw', 'orthol7_20521xs170700.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14388, 824, 18, '0', '/l7ecw_stretched/orthol7_20522xs170700.ecw', 'orthol7_20522xs170700.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14389, 824, 19, '0', '/l7ecw_stretched/orthol7_20619xs180300.ecw', 'orthol7_20619xs180300.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14390, 824, 20, '0', '/l7ecw_stretched/orthol7_20620xs050500.ecw', 'orthol7_20620xs050500.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14391, 824, 21, '0', '/l7ecw_stretched/orthol7_20621xs250800.ecw', 'orthol7_20621xs250800.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14392, 824, 22, '0', '/l7ecw_stretched/orthol7_20622xs240501.ecw', 'orthol7_20622xs240501.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14393, 824, 23, '0', '/l7ecw_stretched/orthol7_20719xs290799.ecw', 'orthol7_20719xs290799.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14394, 824, 24, '0', '/l7ecw_stretched/orthol7_20720xs120500.ecw', 'orthol7_20720xs120500.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14395, 824, 25, '0', '/landmap/ls5/stif/ecw/ortholandsat5_201_23.ecw', 'ortholandsat5_201_23.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14396, 824, 26, '0', '/landmap/ls5/stif/ecw/ortholandsat5_201_24.ecw', 'ortholandsat5_201_24.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14397, 824, 27, '0', '/landmap/ls5/stif/ecw/ortholandsat5_202_22.ecw', 'ortholandsat5_202_22.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14398, 824, 28, '0', '/landmap/ls5/stif/ecw/ortholandsat5_202_23.ecw', 'ortholandsat5_202_23.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14399, 824, 29, '0', '/landmap/ls5/stif/ecw/ortholandsat5_202_24.ecw', 'ortholandsat5_202_24.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14400, 824, 30, '0', '/landmap/ls5/stif/ecw/ortholandsat5_202_25.ecw', 'ortholandsat5_202_25.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14401, 824, 31, '0', '/landmap/ls5/stif/ecw/ortholandsat5_203_22.ecw', 'ortholandsat5_203_22.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14402, 824, 32, '0', '/landmap/ls5/stif/ecw/ortholandsat5_203_23.ecw', 'ortholandsat5_203_23.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14403, 824, 33, '0', '/landmap/ls5/stif/ecw/ortholandsat5_203_24.ecw', 'ortholandsat5_203_24.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14404, 824, 34, '0', '/landmap/ls5/stif/ecw/ortholandsat5_203_25.ecw', 'ortholandsat5_203_25.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14405, 824, 35, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_20q1.ecw', 'ortholandsat5_204_20q1.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14406, 824, 36, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_20q3.ecw', 'ortholandsat5_204_20q3.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14407, 824, 37, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_21.ecw', 'ortholandsat5_204_21.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14408, 824, 38, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_22.ecw', 'ortholandsat5_204_22.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14409, 824, 39, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_23.ecw', 'ortholandsat5_204_23.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14410, 824, 40, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_24.ecw', 'ortholandsat5_204_24.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14411, 824, 41, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_25.ecw', 'ortholandsat5_204_25.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14412, 824, 42, '0', '/landmap/ls5/stif/ecw/ortholandsat5_205_18q1.ecw', 'ortholandsat5_205_18q1.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14413, 824, 43, '0', '/landmap/ls5/stif/ecw/ortholandsat5_205_18q2.ecw', 'ortholandsat5_205_18q2.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14414, 824, 44, '0', '/landmap/ls5/stif/ecw/ortholandsat5_205_20.ecw', 'ortholandsat5_205_20.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14415, 824, 45, '0', '/landmap/ls5/stif/ecw/ortholandsat5_205_21.ecw', 'ortholandsat5_205_21.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14416, 824, 46, '0', '/landmap/ls5/stif/ecw/ortholandsat5_205_22.ecw', 'ortholandsat5_205_22.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14417, 824, 47, '0', '/landmap/ls5/stif/ecw/ortholandsat5_206_18.ecw', 'ortholandsat5_206_18.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14418, 824, 48, '0', '/landmap/ls5/stif/ecw/ortholandsat5_206_19.ecw', 'ortholandsat5_206_19.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14419, 824, 49, '0', '/landmap/ls5/stif/ecw/ortholandsat5_206_20.ecw', 'ortholandsat5_206_20.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14420, 824, 50, '0', '/landmap/ls5/stif/ecw/ortholandsat5_206_21.ecw', 'ortholandsat5_206_21.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14421, 824, 51, '0', '/landmap/ls5/stif/ecw/ortholandsat5_206_22.ecw', 'ortholandsat5_206_22.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14422, 824, 52, '0', '/landmap/ls5/stif/ecw/ortholandsat5_207_20.ecw', 'ortholandsat5_207_20.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14423, 824, 53, '0', '/landmap/ls5/stif/ecw/ortholandsat5_207_21.ecw', 'ortholandsat5_207_21.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14424, 824, 54, '0', '/landmap/ls5/stif/ecw/ortholandsat5_207_22.ecw', 'ortholandsat5_207_22.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14425, 824, 55, '0', '/landmap/ls5/stif/ecw/ortholandsat5_208_19.ecw', 'ortholandsat5_208_19.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14426, 824, 56, '0', '/landmap/ls5/stif/ecw/ortholandsat5_208_20.ecw', 'ortholandsat5_208_20.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14427, 824, 57, '0', '/landmap/mosaics/landsat/hs.ecw', 'hs.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14428, 824, 58, '0', '/landmap/mosaics/landsat/hs2.ecw', 'hs2.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14429, 824, 59, '0', '/landmap/mosaics/landsat/hs3.ecw', 'hs3.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14430, 824, 60, '0', '/landmap/mosaics/landsat/l5mosaic.ecw', 'l5mosaic.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14431, 824, 61, '0', '/landmap/mosaics/landsat/l5mosaicb742.ecw', 'l5mosaicb742.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14432, 824, 62, '0', '/landmap/mosaics/landsat/l5mosaic_geodetic.ecw', 'l5mosaic_geodetic.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14433, 824, 63, '0', '/landmap/mosaics/landsat/l5mosaic_geodetic1.ecw', 'l5mosaic_geodetic1.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14434, 824, 64, '0', '/landmap/mosaics/landsat/l5mosaic_UTM.ecw', 'l5mosaic_UTM.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14435, 824, 65, '0', '/landmap/mosaics/landsat/l7b123.ecw', 'l7b123.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14436, 824, 66, '0', '/landmap/mosaics/landsat/l7bpan.ecw', 'l7bpan.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14437, 824, 67, '0', '/landmap/mosaics/landsat/l7bpan_s.ecw', 'l7bpan_s.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14438, 824, 68, '0', '/landmap/mosaics/landsat/l7bpan_s_geo.becw.ecw', 'l7bpan_s_geo.becw.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14439, 824, 69, '0', '/landmap/mosaics/landsat/l7bpan_s_geo.ecw', 'l7bpan_s_geo.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14440, 824, 70, '0', '/landmap/mosaics/landsat/landsat7m25.ecw', 'landsat7m25.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14441, 824, 71, '0', '/landmap/mosaics/landsat/landsat7m25r.ecw', 'landsat7m25r.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14442, 824, 72, '0', '/landmap/mosaics/landsat/landsat7m25_123.ecw', 'landsat7m25_123.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14443, 824, 73, '0', '/landmap/mosaics/landsat/landsat_mosaic_15m.ecw', 'landsat_mosaic_15m.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14444, 824, 74, '0', '/landmap/mosaics/spot/orthospot13_231.ecw', 'orthospot13_231.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14445, 824, 75, '0', '/landmap/mosaics/spot/orthospot13_232.ecw', 'orthospot13_232.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14446, 824, 76, '0', '/landmap/mosaics/spot/orthospot13_233.ecw', 'orthospot13_233.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14447, 824, 77, '0', '/landmap/mosaics/spot/orthospot13_234.ecw', 'orthospot13_234.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14448, 824, 78, '0', '/landmap/mosaics/spot/orthospot13_235.ecw', 'orthospot13_235.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14449, 824, 79, '0', '/landmap/mosaics/spot/orthospot14_230.ecw', 'orthospot14_230.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14450, 824, 80, '0', '/landmap/mosaics/spot/orthospot14_231.ecw', 'orthospot14_231.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14451, 824, 81, '0', '/landmap/mosaics/spot/orthospot14_232.ecw', 'orthospot14_232.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14452, 824, 82, '0', '/landmap/mosaics/spot/orthospot14_232_ecw.ecw', 'orthospot14_232_ecw.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14453, 824, 83, '0', '/landmap/mosaics/spot/orthospot14_233.ecw', 'orthospot14_233.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14454, 824, 84, '0', '/landmap/mosaics/spot/orthospot14_234.ecw', 'orthospot14_234.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14455, 824, 85, '0', '/landmap/mosaics/spot/orthospot14_235.ecw', 'orthospot14_235.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14456, 824, 86, '0', '/landmap/mosaics/spot/orthospot14_236.ecw', 'orthospot14_236.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14457, 824, 87, '0', '/landmap/mosaics/spot/orthospot17_230.ecw', 'orthospot17_230.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14458, 824, 88, '0', '/landmap/mosaics/spot/orthospot17_231.ecw', 'orthospot17_231.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14459, 824, 89, '0', '/landmap/mosaics/spot/orthospot17_232.ecw', 'orthospot17_232.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14460, 824, 90, '0', '/landmap/mosaics/spot/orthospot17_233.ecw', 'orthospot17_233.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14461, 824, 91, '0', '/landmap/mosaics/spot/orthospot17_234.ecw', 'orthospot17_234.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14462, 824, 92, '0', '/landmap/mosaics/spot/orthospot17_235.ecw', 'orthospot17_235.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14463, 824, 93, '0', '/landmap/mosaics/spot/orthospot17_236.ecw', 'orthospot17_236.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14464, 824, 94, '0', '/landmap/mosaics/spot/orthospot17_237.ecw', 'orthospot17_237.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14465, 824, 95, '0', '/landmap/mosaics/spot/orthospot17_238.ecw', 'orthospot17_238.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14466, 824, 96, '0', '/landmap/mosaics/spot/orthospot17_239.ecw', 'orthospot17_239.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14467, 824, 97, '0', '/landmap/mosaics/spot/orthospot17_240.ecw', 'orthospot17_240.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14468, 824, 98, '0', '/landmap/mosaics/spot/orthospot18_229.ecw', 'orthospot18_229.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14469, 824, 99, '0', '/landmap/mosaics/spot/orthospot18_231.ecw', 'orthospot18_231.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14470, 824, 100, '0', '/landmap/mosaics/spot/orthospot18_232.ecw', 'orthospot18_232.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14471, 824, 101, '0', '/landmap/mosaics/spot/orthospot18_233.ecw', 'orthospot18_233.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14472, 824, 102, '0', '/landmap/mosaics/spot/orthospot18_234.ecw', 'orthospot18_234.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14473, 824, 103, '0', '/landmap/mosaics/spot/orthospot18_235.ecw', 'orthospot18_235.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14474, 824, 104, '0', '/landmap/mosaics/spot/orthospot18_236.ecw', 'orthospot18_236.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14475, 824, 105, '0', '/landmap/mosaics/spot/orthospot18_237.ecw', 'orthospot18_237.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14476, 824, 106, '0', '/landmap/mosaics/spot/orthospot18_238.ecw', 'orthospot18_238.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14477, 824, 107, '0', '/landmap/mosaics/spot/orthospot25_237.ecw', 'orthospot25_237.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14478, 824, 108, '0', '/landmap/mosaics/spot/orthospot25_238.ecw', 'orthospot25_238.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14479, 824, 109, '0', '/landmap/mosaics/spot/orthospot25_241.ecw', 'orthospot25_241.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14480, 824, 110, '0', '/landmap/mosaics/spot/orthospot25_242.ecw', 'orthospot25_242.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14481, 824, 111, '0', '/landmap/mosaics/spot/orthospot25_243.ecw', 'orthospot25_243.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14482, 824, 112, '0', '/landmap/mosaics/spot/orthospot25_244.ecw', 'orthospot25_244.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14483, 824, 113, '0', '/landmap/mosaics/spot/orthospot25_245.ecw', 'orthospot25_245.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14484, 824, 114, '0', '/landmap/mosaics/spot/orthospot25_247.ecw', 'orthospot25_247.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14485, 824, 115, '0', '/landmap/mosaics/spot/orthospot25_248.ecw', 'orthospot25_248.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14486, 824, 116, '0', '/landmap/mosaics/spot/orthospot26_239.ecw', 'orthospot26_239.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14487, 824, 117, '0', '/landmap/mosaics/spot/orthospot26_240.ecw', 'orthospot26_240.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14488, 824, 118, '0', '/landmap/mosaics/spot/orthospot26_241.ecw', 'orthospot26_241.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14489, 824, 119, '0', '/landmap/mosaics/spot/orthospot26_242.ecw', 'orthospot26_242.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14490, 824, 120, '0', '/landmap/mosaics/spot/orthospot26_243.ecw', 'orthospot26_243.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14491, 824, 121, '0', '/landmap/mosaics/spot/orthospot26_244.ecw', 'orthospot26_244.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14492, 824, 122, '0', '/landmap/mosaics/spot/orthospot26_245.ecw', 'orthospot26_245.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14493, 824, 123, '0', '/landmap/mosaics/spot/orthospot26_246.ecw', 'orthospot26_246.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14494, 824, 124, '0', '/landmap/mosaics/spot/orthospot26_247.ecw', 'orthospot26_247.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14495, 824, 125, '0', '/landmap/mosaics/spot/orthospot26_248.ecw', 'orthospot26_248.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14496, 824, 126, '0', '/landmap/mosaics/spot/orthospot28_246.ecw', 'orthospot28_246.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14497, 824, 127, '0', '/landmap/mosaics/spot/orthospot28_247.ecw', 'orthospot28_247.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14498, 824, 128, '0', '/landmap/mosaics/spot/orthospot29_239.ecw', 'orthospot29_239.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14499, 824, 129, '0', '/landmap/mosaics/spot/orthospot29_240.ecw', 'orthospot29_240.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14500, 824, 130, '0', '/landmap/mosaics/spot/orthospot29_241.ecw', 'orthospot29_241.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14501, 824, 131, '0', '/landmap/mosaics/spot/orthospot29_242.ecw', 'orthospot29_242.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14502, 824, 132, '0', '/landmap/mosaics/spot/orthospot29_243.ecw', 'orthospot29_243.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14503, 824, 133, '0', '/landmap/mosaics/spot/orthospot29_244.ecw', 'orthospot29_244.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14504, 824, 134, '0', '/landmap/mosaics/spot/orthospot29_245.ecw', 'orthospot29_245.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14505, 824, 135, '0', '/landmap/mosaics/spot/orthospot30_242.ecw', 'orthospot30_242.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14506, 824, 136, '0', '/landmap/mosaics/spot/orthospot30_243.ecw', 'orthospot30_243.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14507, 824, 137, '0', '/landmap/mosaics/spot/orthospot30_245.ecw', 'orthospot30_245.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14508, 824, 138, '0', '/landmap/mosaics/spot/orthospot30_246.ecw', 'orthospot30_246.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14509, 824, 139, '0', '/landmap/mosaics/spot/orthospot30_247.ecw', 'orthospot30_247.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14510, 824, 140, '0', '/landmap/mosaics/spot/orthospot32_246.ecw', 'orthospot32_246.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14511, 824, 141, '0', '/landmap/mosaics/spot/orthospot32_247.ecw', 'orthospot32_247.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14512, 824, 142, '0', '/landmap/mosaics/spot/orthospot33_243.ecw', 'orthospot33_243.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14513, 824, 143, '0', '/landmap/mosaics/spot/orthospot33_244.ecw', 'orthospot33_244.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14514, 824, 144, '0', '/landmap/mosaics/spot/orthospot33_245.ecw', 'orthospot33_245.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14515, 824, 145, '0', '/landmap/mosaics/spot/orthospot34_243.ecw', 'orthospot34_243.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14516, 824, 146, '0', '/landmap/mosaics/spot/orthospot34_244.ecw', 'orthospot34_244.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14517, 824, 147, '0', '/landmap/mosaics/spot/orthospot34_245.ecw', 'orthospot34_245.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14518, 824, 148, '0', '/landmap/mosaics/spot/orthospot34_246.ecw', 'orthospot34_246.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14519, 824, 149, '0', '/landmap/mosaics/spot/orthospot34_247.ecw', 'orthospot34_247.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14520, 824, 150, '0', '/landmap/orthospot/UK_Orthospot/mosaics.ecw', 'mosaics.ecw', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14525, 827, 0, '', '', 'Test Imagery', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14526, 827, 1, '0', 'dlwc_landsat_2000_mosaic', 'NSW Landsat 2000 Mosaic', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14527, 828, 0, '', '', 'IDERIOJA', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14528, 828, 1, '0', 'ortofoto', 'Ortofoto', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14529, 828, 2, '0', 'Cuadricula', 'Cuadricula 5k', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14530, 828, 3, '0', 'Nucleos', 'Nucleos Urbanos', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14531, 828, 4, '0', 'Rios', 'Rios', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14532, 828, 5, '0', 'municipios', 'Terminos Municipales', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14533, 828, 6, '0', 'Carreteras', 'Carreteras', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14534, 829, 0, '', '', 'at_etm7_lambert', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14535, 829, 1, '0', '0', 'etm7_lambert', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14550, 831, 0, '', 'DELI', 'MNDNR Data Deli WMS Server', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14551, 831, 1, '0', 'L380000020906', '1:100k Digital Raster Graphic - Collars Removed', 0, 0, 125000, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14552, 831, 2, '0', 'L380000030906', '1:24k Digital Raster Graphic - Collars Removed', 0, 0, 30000, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14553, 831, 3, '0', 'L380000010906', '1:250k Digital Raster Graphic - Collars Removed', 0, 0, 499999, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14554, 831, 4, '0', 'L390002440906', 'GAP Land Cover - Image', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14555, 831, 5, '0', 'L390002400906', 'Public Waters Inventory Maps', 0, 0, 100000, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14556, 831, 6, '0', 'L370000050906', 'USGS Digital Orthophoto Quad (DOQ) - 3 meter', 0, 0, 100000, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14557, 832, 0, '', '', 'ArcIMS MapService', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14558, 832, 1, '0', 'overview', 'Wetland Overview', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14559, 832, 2, '0', 'wetlands_low', 'Wetlands Low Res', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14560, 832, 3, '0', 'wetlands', 'Wetlands High Res', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14561, 833, 0, '', '', 'encdirect', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14562, 833, 1, '0', '4', 'ENCNAMES_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14563, 833, 2, '0', 'LAND', 'LAND', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14564, 833, 3, '0', 'QUALITY OF DATA(M_QUAL)', 'QUALITY OF DATA', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14565, 833, 4, '0', 'NAVIGATIONAL SYSTEM OF MARKS(M_NSYS)', 'NAVIGATIONAL SYSTEM OF MARKS', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14566, 833, 5, '0', 'HORIZONTAL DATUM OF DATA(M_SDAT)', 'HORIZONTAL DATUM OF DATA', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14567, 833, 6, '0', 'NAUTICAL PUBLICATION INFORMATION(M_NPUB)', 'NAUTICAL PUBLICATION INFORMATION', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14568, 833, 7, '0', 'COMPLIATION OF SCALE DATA(M_CSCL)', 'COMPLIATION OF SCALE DATA', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14569, 833, 8, '0', 'COVERAGE(M_COVR)', 'COVERAGE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14570, 833, 9, '0', 'ACCURACY(M_ACCY)', 'ACCURACY', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14571, 833, 10, '0', 'LAND AREA(LNDARE)', 'LAND AREA_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14572, 833, 11, '0', 'DEPTH AREA(DEPARE)', 'DEPTH AREA_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14573, 833, 12, '0', 'ICE AREA(ICEARE)', 'ICE AREA', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14574, 833, 13, '0', 'HARBOR FACILITY_POLYGON(HRBFAC)', 'HARBOR FACILITY_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14575, 833, 14, '0', 'SEA AREA(SEAARE)', 'SEA AREA_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14576, 833, 15, '0', 'PYLONS_polygon(PYLONS)', 'PYLONS_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14577, 833, 16, '0', 'SEABED AREA_polygon(SBDARE)', 'SEABED AREA_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14578, 833, 17, '0', 'PONTOON(PONTON)', 'PONTOON_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14579, 833, 18, '0', 'WEED, KELP(WEDKLP)', 'WEED, KELP_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14580, 833, 19, '0', 'OFFSHORE PRODUCTION AREA(OSPARE)', 'OFFSHORE PRODUCTION AREA', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14581, 833, 20, '0', 'VEGATATION(VEGATN)', 'VEGATATION_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14582, 833, 21, '0', 'TWO_WAY ROUTE PART(TWRTPT)', 'TWO_WAY ROUTE PART', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14583, 833, 22, '0', 'SWEPTH AREA(SWPARE)', 'SWEPTH AREA', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14584, 833, 23, '0', 'SEA PLANE LANDING AREA(SLPARE)', 'SEA PLANE LANDING AREA_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14585, 833, 24, '0', 'WATER TURBULENCE(WATTUR)', 'WATER TURBULENCE_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14586, 833, 25, '0', 'SLOPING GROUND(SLOGRD)', 'SLOPING GROUND_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14587, 833, 26, '0', 'PRODUCTION AREA(PRDARE)', 'PRODUCTION AREA_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14588, 833, 27, '0', 'RUNWAY(RUNWAY)', 'RUNWAY_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14589, 833, 28, '0', 'RECOMMENDED TRACK(RECTRC)', 'RECOMMENDED TRACK_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14590, 833, 29, '0', 'RAPIDS(RAPIDS)', 'RAPIDS_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14591, 833, 30, '0', 'MILITARY PRACTICE AREA(MIPARE)', 'MILITARY PRACTICE AREA_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14592, 833, 31, '0', 'PRECAUTIONARY AREA_polygon(PRCARE)', 'PRECAUTIONARY AREA_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14593, 833, 32, '0', 'PILOT BOARDING AREA(PILBOP)', 'PILOT BOARDING AREA_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14594, 833, 33, '0', 'OFFSHORE PLATFORM(OFSPLF)', 'OFFSHORE PLATFORM_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14595, 833, 34, '0', 'LOCAL MAGNETIC ANOMALY(LOCMAG)', 'LOCAL MAGNETIC ANOMALY_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14596, 833, 35, '0', 'LOCK BASIN(LOKBSN)', 'LOCK BASIN', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14597, 833, 36, '0', 'MOORING FACILITY(MORFAC)', 'MOORING FACILITY_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14598, 833, 37, '0', 'GATE(GATCON)', 'GATE_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14599, 833, 38, '0', 'HARBOR AREA(HRBARE)', 'HARBOR AREA', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14600, 833, 39, '0', 'GRIDIRON(GRIDRN)', 'GRIDIRON_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14601, 833, 40, '0', 'LOG POND(LOGPON)', 'LOG POND_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14602, 833, 41, '0', 'LANDMARK(LNDMRK)', 'LANDMARK_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14603, 833, 42, '0', 'FERRY ROUTE(FERYRT)', 'FERRY ROUTE_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14604, 833, 43, '0', 'HULK_polygon(HULKES)', 'HULK_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14605, 833, 44, '0', 'FISH FACILITY(FSHFAC)', 'FISH FACILITY_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14606, 833, 45, '0', 'FLOATING DOCK_polygon(FLODOC)', 'FLOATING DOCK_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14607, 833, 46, '0', 'RIVERS(RIVERS)', 'RIVERS_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14608, 833, 47, '0', 'UNSURVEYED AREA(UNSARE)', 'UNSURVEYED AREA', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14609, 833, 48, '0', 'LAKE(LAKARE)', 'LAKE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14610, 833, 49, '0', 'SHORELINE CONSTRUCTION(SLCONS)', 'SHORELINE CONSTRUCTION_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14611, 833, 50, '0', 'TRAFFIC SEPARATION ZONE(TSEZNE)', 'TRAFFIC SEPARATION ZONE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14612, 833, 51, '0', 'OBSTRUCTION(OBSTRN)', 'OBSTRUCTION_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14613, 833, 52, '0', 'TRAFFIC SEPARATION SCHEME LANE PART(TSSLPT)', 'TRAFFIC SEPARATION SCHEME LANE PART', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14614, 833, 53, '0', 'LAND REGION(LNDRGN)', 'LAND REGION_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14615, 833, 54, '0', 'WRECKS_polygon(WRECKS)', 'WRECKS_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14616, 833, 55, '0', 'MARINE FARM, CULTURE(MARCUL)', 'MARINE FARM, CULTURE_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14617, 833, 56, '0', 'INSHORE TRAFFIC ZONE(ISTZNE)', 'INSHORE TRAFFIC ZONE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14618, 833, 57, '0', 'DEEP WATER ROUTE PART(DWRTPT)', 'DEEP WATER ROUTE PART', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14619, 833, 58, '0', 'DREDGED AREA(DRGARE)', 'DREDGED AREA', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14620, 833, 59, '0', 'DUMPING GROUND(DMPGRD)', 'DUMPING GROUND_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14621, 833, 60, '0', 'FAIRWAY_polygon(FAIRWY)', 'FAIRWAY', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14622, 833, 61, '0', 'ANCHOR BERTH(ACHBRT)', 'ANCHOR BERTH_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14623, 833, 62, '0', 'DRY DOCK(DRYDOC)', 'DRY DOCK', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14624, 833, 63, '0', 'RESTRICTED AREA(RESARE)', 'RESTRICTED AREA', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14625, 833, 64, '0', 'DOCK AREA(DOCARE)', 'DOCK AREA', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14626, 833, 65, '0', 'DIKE(DYKON)', 'DIKE_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14627, 833, 66, '0', 'BERTHS(BERTHS)', 'BERTHS_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14628, 833, 67, '0', 'DAM(DAMCON)', 'DAM_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14629, 833, 68, '0', 'ANCHORAGE AREA(ACHARE)', 'ANCHORAGE AREA_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14630, 833, 69, '0', 'CANALS(CANALS)', 'CANALS_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14631, 833, 70, '0', 'CAUSEWAY(CAUSWY)', 'CAUSEWAY_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14632, 833, 71, '0', 'CABLE AREA(CBLARE)', 'CABLE AREA', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14633, 833, 72, '0', 'BUILT-UP AREA(BUAARE)', 'BUILT-UP AREA_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14634, 833, 73, '0', 'SILO, TANK(SILTNK)', 'SILO, TANK_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14635, 833, 74, '0', 'FORTIFIED STRUCTURE(FORSTC)', 'FORTIFIED STRUCTURE_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14636, 833, 75, '0', 'TUNNEL(TUNNEL)', 'TUNNEL_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14637, 833, 76, '0', 'CONVEYOR(CONVYR)', 'CONVEYOR_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14638, 833, 77, '0', 'BUILDING(BUISGL)', 'BUILDING_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14639, 833, 78, '0', 'CRANES(CRANES)', 'CRANES_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14640, 833, 79, '0', 'ADMINISTRATION AREA_polygon(ADMARE)', 'ADMINISTRATION AREA', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14641, 833, 80, '0', 'AIRARE(AIRARE)', 'AIRPORT_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14642, 833, 81, '0', 'TRAFFIC SEPARATION SCHEME BOUNDARY(TSSBND)', 'TRAFFIC SEPARATION SCHEME BOUNDARY', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14643, 833, 82, '0', 'CAUTION AREA(CTNARE)', 'CAUTION AREA_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14644, 833, 83, '0', 'BRIDGE_polygon(BRIDGE)', 'BRIDGE_polygon', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14645, 833, 84, '0', 'SLOPE_TOPLINE(SLOTOP', 'SLOPE TOPLINE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14646, 833, 85, '0', 'WATER FALL_line(WATFAL)', 'WATER FALL_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14647, 833, 86, '0', 'SHORELINE CONSTRUCTION_line(SLCONS)', 'SHORELINE CONSTRUCTION_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14648, 833, 87, '0', 'RIVERS_line(RIVERS)', 'RIVERS_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14649, 833, 88, '0', 'SUBMARINE_ON LAND PIPELINE_line(PIPSOL)', 'SUBMARINE_ON LAND PIPELINE_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14650, 833, 89, '0', 'OVERHEAD PIPELINE(PIPOHD)', 'OVERHEAD PIPELINE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14651, 833, 90, '0', 'OBSTRUCTION_line(OBSTRN)', 'OBSTRUCTION_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14652, 833, 91, '0', 'NAVIGATION LINE(NAVLNE)', 'NAVIGATION LINE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14653, 833, 92, '0', 'LAND ELEVATION_line(LNDELV)', 'LAND ELEVATION_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14654, 833, 93, '0', 'ROAD_line(ROADWY)', 'ROAD_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14655, 833, 94, '0', 'FENCE LINE_line(FNCLNE)', 'FENCE LINE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14656, 833, 95, '0', 'OIL BARRIER_line(OILBAR)', 'OIL BARRIER', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14657, 833, 96, '0', 'FERRY ROUTE_line(FERYRT)', 'FERRY ROUTE_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14658, 833, 97, '0', 'DIKE_line(DYKCON)', 'DIKE_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14659, 833, 98, '0', 'SAND WAVES_line(SNDWAV)', 'SAND WAVES_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14660, 833, 99, '0', 'RECOMMENDED TRACK_line(RECTRC)', 'RECOMMENDED TRACK_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14661, 833, 100, '0', 'DEPTH AREA_line(DEPARE)', 'DEPTH AREA_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14662, 833, 101, '0', '1', 'WATER TURBULENCE_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14663, 833, 102, '0', 'DEPTH CONTOUR(DEPCNT)', 'DEPTH CONTOUR', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14664, 833, 103, '0', 'CONVEYOR_line(CONVYR)', 'CONVEYOR_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14665, 833, 104, '0', 'DAM_line(DAMCON)', 'DAM_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14666, 833, 105, '0', 'COASTLINE(COALNE)', 'COASTLINE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14667, 833, 106, '0', 'LAND AREA_line(LNDAARE)', 'LAND AREA_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14668, 833, 107, '0', 'FISH FACILITY_line(FSHFAC)', 'FISH FACILITY_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14669, 833, 108, '0', 'MOORING FACILITY_line(MORFAC)', 'MOORING FACILITY_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14670, 833, 109, '0', 'GATE_line(GATCON)', 'GATE_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14671, 833, 110, '0', 'TUNNEL_line(TUNNEL)', 'TUNNEL_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14672, 833, 111, '0', 'SUBMARINE CABLE(CLBSUB)', 'SUBMARINE CABLE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14673, 833, 112, '0', 'SLOPE TOPLINE_line(SLOTOP)', 'SLOPE TOPLINE_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14674, 833, 113, '0', 'RAILWAY_line(RAILWY)', 'RAILWAY', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14675, 833, 114, '0', 'TRAFFIC SEPARATION LINE(TSELNE)', 'TRAFFIC SEPARATION LINE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14676, 833, 115, '0', 'VEGATATION_line(VEGATN)', 'VEGATATION_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14677, 833, 116, '0', 'OVERHEAD CABLE(CBLOHD)', 'OVERHEAD CABLE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14678, 833, 117, '0', 'PONTOON_line(PONTON)', 'PONTOON_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14679, 833, 118, '0', 'CANALS_line(CANALS)', 'CANALS_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14680, 833, 119, '0', 'RECOMMENDED ROUTE CENTERLINE_line(RCRTCL)', 'RECOMMENDED ROUTE CENTERLINE_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14681, 833, 120, '0', 'BRIDGE_line(BRIDGE)', 'BRIDGE_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14682, 833, 121, '0', 'WRECKS_point(WRECKS)', 'WRECKS_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14683, 833, 122, '0', 'WEED, KELP_point(WEDKLP)', 'WEED, KELP_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14684, 833, 123, '0', 'WATER TURBULENCE_point(WATTUR)', 'WATER TURBULENCE_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14685, 833, 124, '0', 'ROCK AWASH, UNDERWATER_POINT(UWTROC)', 'ROCK AWASH, UNDERWATER', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14686, 833, 125, '0', 'TOPMARK_point(TOPMAR)', 'TOPMARK', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14687, 833, 126, '0', 'SHORELINE CONSTRUCTION_point(SLCONS)', 'SHORELINE CONSTRUCTION_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14688, 833, 127, '0', 'SILO, TANK_point(SILTNK)', 'SILO, TANK_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14689, 833, 128, '0', 'SEA AREA_point(SEAARE)', 'SEA AREA_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14690, 833, 129, '0', 'SEABED AREA_point(SBDARE)', 'SEABED AREA_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14691, 833, 130, '0', 'RADAR TRANSPONDER BEACON_POINT(RTPBCN)', 'RADAR TRANSPONDER BEACON', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14692, 833, 131, '0', 'RESCUE STATION_POINT(RCSTA)', 'RESCUE STATION', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14693, 833, 132, '0', 'PYLONS_point(PYLONS)', 'PYLONS_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14694, 833, 133, '0', 'PILE_point(PILPNT)', 'PILE', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14695, 833, 134, '0', 'OFFSHORE PLATFORM_point(OFSPLF_point)', 'OFFSHORE PLATFORM_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14696, 833, 135, '0', 'MOORING FACILITY_point(MORFAC_point)', 'MOORING FACILITY_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14697, 833, 136, '0', 'LAND REGION_point(LNDRGN_point)', 'LAND REGION_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14698, 833, 137, '0', 'LANDMARK_point(LNDMARK)', 'LANDMARK_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14699, 833, 138, '0', 'LAND AREA_point(LNDARE)', 'LAND AREA_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14700, 833, 139, '0', 'FOGSIG_point(FOGSIG)', 'FOG SIGNAL', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14701, 833, 140, '0', 'DAYMARK_point(DAYMAR)', 'DAYMARK', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14702, 833, 141, '0', 'CAUTION AREA_point(CNTARE)', 'CAUTION AREA_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14703, 833, 142, '0', 'COASTGUARD STATION_point(CGUSTA)', 'COASTGUARD STATION', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14704, 833, 143, '0', 'BUILDING_point(BUISGL)', 'BUILDING_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14705, 833, 144, '0', 'BUILT-UP AREA_point(BUAARE)', 'BUILT-UP AREA_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14706, 833, 145, '0', 'INSTALLATION(BOYINB)', 'INSTALLATION BUOY', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14707, 833, 146, '0', 'SPECIAL PURPOSE BUOY_point(BOYSPP)', 'SPECIAL PURPOSE BUOY', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14708, 833, 147, '0', 'SAFE WATER BUOY(BOYSAW)', 'SAFE WATER BUOY', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14709, 833, 148, '0', 'LATERAL BUOY_point(BOYLAT)', 'LATERAL BUOY', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14710, 833, 149, '0', 'SPECIAL PURPOSE BEACON_point(BCNSPP)', 'SPECIAL PURPOSE BEACON', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14711, 833, 150, '0', 'SAFE WATER BEACON_point(BCNSAW)', 'SAFE WATER BEACON', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14712, 833, 151, '0', 'LATERAL BEACON_point(BCNLAT)', 'LATERAL BEACON', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14713, 833, 152, '0', 'LAND ELEVATION_point(LNDELV)', 'LAND ELEVATION_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14714, 833, 153, '0', 'ANCHOR BERTH_point(ACHBRT)', 'ANCHOR BERTH_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14715, 833, 154, '0', 'ANCHORAGE AREA_point(ANCARE)', 'ANCHORAGE AREA_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14716, 833, 155, '0', 'AIRPORT_point(AIRARE)', 'AIRPORT_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14717, 833, 156, '0', 'ISOLATED DANGER BEACON(BCNISD)', 'ISOLATED DANGER BEACON', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14718, 833, 157, '0', 'BERTHS_point(BERTHS)', 'BERTHS_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14719, 833, 158, '0', 'CARDINAL BUOY_point(BOYCAR)', 'CARDINAL BUOY', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14720, 833, 159, '0', 'ISOLATED DANGER BUOY_point(BOYISD)', 'ISOLATED DANGER BUOY', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14721, 833, 160, '0', 'CRANES_point(CRANES)', 'CRANES_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14722, 833, 161, '0', 'CONTROL POINT(CTRPNT)', 'CONTROL POINT', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14723, 833, 162, '0', 'CURRENT_point(CURENT)', 'CURRENT', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14724, 833, 163, '0', 'DAM_point(DAMCON)', 'DAM_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14725, 833, 164, '0', 'DISTANCE MARK_point(DISMAR)', 'DISTANCE MARK', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14726, 833, 165, '0', 'DUMPING GROUND_point(DMPGRD)', 'DUMPING GROUND_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14727, 833, 166, '0', 'FORTIFIED STRUCTURE_point(FORSTC)', 'FORTIFIED STRUCTURE_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14728, 833, 167, '0', 'FISH FACILITY_point(FSHFAC)', 'FISH FACILITY_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14729, 833, 168, '0', 'GATE_point(GATCON)', 'GATE_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14730, 833, 169, '0', 'HARBOR FACILITY_point(HRBFAC)', 'HARBOR FACILITY_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14731, 833, 170, '0', 'LOCAL MAGNETIC ANOMALY_point(LOCMAG)', 'LOCAL MAGNETIC ANOMALY_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14732, 833, 171, '0', 'LOG POND_point(LOGPON)', 'LOG POND_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14733, 833, 172, '0', 'MAGNETIC VARIATION_point(MAGVAR)', 'MAGNETIC VARIATION_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14734, 833, 173, '0', 'PILOT BOARDING POINT_point(PILBOP)', 'PILOT BOARDING POINT_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14735, 833, 174, '0', 'SUBMARINE_ON LAND PIPELINE_point(PISOL)', 'SUBMARINE_ON LAND PIPELINE_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14736, 833, 175, '0', 'PRODUCTION AREA_point(PRDARE)', 'PRODUCTION AREA_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14737, 833, 176, '0', 'RADIO CALLING IN POINT_point(RDOCAL)', 'RADIO CALLING IN POINT_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14738, 833, 177, '0', 'RETRO REFLECTOR_point(RETRFL)', 'RETRO REFLECTOR', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14739, 833, 178, '0', 'WARNING SIGNAL STATION_point(SISTAW)', 'WARNING SIGNAL STATION', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14740, 833, 179, '0', 'TRAFFIC SIGNAL STATION_point(SISTAT)', 'TRAFFIC SIGNAL STATION', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14741, 833, 180, '0', 'SLOPING GROUND_point(SLOGRD)', 'SLOPING GROUND_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14742, 833, 181, '0', 'SMALL CRAFT FACILITY_point(SMCFAC)', 'SMALL CRAFT FACILITY_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14743, 833, 182, '0', 'SAND WAVES_point(SNDWAV)', 'SAND WAVES_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14744, 833, 183, '0', 'SEA PLANE LANDING AREA_point(SPLARE)', 'SEA PLANE LANDING AREA_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14745, 833, 184, '0', 'SPRING_point(SPRING)', 'SPRING', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14746, 833, 185, '0', 'TIDAL STREAM_point(TS_FEB)', 'TIDAL STREAM_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14747, 833, 186, '0', 'SEABED AREA_line(SBDARE)', 'SEABED AREA_line', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14748, 833, 187, '0', 'TUNNEL_point(TUNNEL)', 'TUNNEL_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14749, 833, 188, '0', 'VEGATATION_point(VEGATN)', 'VEGATATION_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14750, 833, 189, '0', 'WATER FALL', 'WATER FALL_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14751, 833, 190, '0', 'RADIO STATION(RDOSTA)', 'RADIO STATION', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14752, 833, 191, '0', 'OBSTRUCTION_point(OBSTRN)', 'OBSTRUCTION_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14753, 833, 192, '0', 'LIGHTS_point(LIGHTS)', 'LIGHTS', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14754, 833, 193, '0', 'LIGHT FLOAT_point(LITFLT)', 'LIGHT FLOAT', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14755, 833, 194, '0', 'HULK_point(HULKES)', 'HULKES_point', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14756, 833, 195, '0', 'SOUNDINGS', 'SOUNDINGS', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14757, 833, 196, '0', '0', 'ENC INDEX', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14758, 834, 0, '', '', 'DE_aerial02', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14759, 834, 1, '0', 'ortho2002', '2002 Aerial Imagery', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14800, 836, 0, '', '', 'NDOP', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14801, 836, 1, '0', 'States', 'State Boundaries', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14802, 836, 2, '0', 'Projects', 'NDOP Projects', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14803, 837, 0, '', '', 'U.S. Geological Survey', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14804, 837, 1, '0', 'DOQ', 'USGS Digital Ortho-Quadrangles', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14805, 837, 2, '0', 'DRG', 'USGS Raster Graphics (Topo Maps)', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14806, 837, 3, '0', 'UrbanArea', 'USGS Urban Areas Ortho-Imagery', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14842, 840, 0, '', '', 'World', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14843, 840, 1, '0', 'GLOBEImage', 'GlobeImage', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14844, 840, 2, '0', 'ADMIN', 'Admin', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14845, 840, 3, '0', 'COUNTRY', ' Country', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14846, 840, 4, '0', 'Lakes', ' Lakes', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14847, 840, 5, '0', 'RAILWAY', ' Railway', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14848, 840, 6, '0', 'WorldGridLines', ' World Grid Lines', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14849, 840, 7, '0', 'OCEAN_TEXT', ' Ocean Label', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14850, 840, 8, '0', 'CAPITALS', ' Capitals', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14851, 841, 0, '', 'ICEDSWMS', 'ICEDS (Integrated CEOS European Data Server) WMS', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14852, 841, 1, '0', 'GRID', 'MAPDRESSING GRID', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14853, 841, 2, '0', 'lights', 'DMSP/NOAA human settlements night lights of the wo', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14854, 841, 3, '2', 'lights_1', 'DMSP/NOAA human settlements night lights (300 arcs', 0, 44999930, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14855, 841, 4, '2', 'lights_2', 'DMSP/NOAA human settlements night lights (30 arcse', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14856, 841, 5, '0', 'landsat5', 'LANDSAT 5 mosaic for Africa and Europe', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14857, 841, 6, '5', 'landsat_1', 'LANDSAT 5 mosaic for Africa and Europe (100 arscse', 0, 9000006, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14858, 841, 7, '5', 'landsat_2', 'LANDSAT 5 mosaic for Africa and Europe (10 arscsec', 0, 3000002, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14859, 841, 8, '5', 'landsat_3', 'LANDSAT 5 mosaic for Africa and Europe (1 arscsec.', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14860, 841, 9, '0', 'srtm', 'Hillshaded SRTM3 mosaic', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14861, 841, 10, '9', 'srtm3_1', 'Hillshaded SRTM3 mosaic (180 arscsec. level)', 0, 20000000, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14862, 841, 11, '9', 'srtm3_2', 'Hillshaded SRTM3 mosaic (30 arscsec. level)', 0, 1700000, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14863, 841, 12, '9', 'srtm3_3', 'Hillshaded SRTM3 mosaic (3 arscsec. level)', 0, 0, 1700000, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14864, 841, 13, '0', 'srtm30', 'Hillshaded SRTM30 mosaic', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14865, 841, 14, '13', 'srtm30_1', 'Hillshaded SRTM30 mosaic (300 arscsec. level)', 0, 20000000, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14866, 841, 15, '13', 'srtm30_2', 'Hillshaded SRTM30 mosaic (30 arscsec. level)', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14867, 841, 16, '0', 'bluemarble', 'Global MODIS Blue Marble', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14868, 841, 17, '16', 'bluemarble_1', 'Global MODIS Blue Marble (300 arcsec. level)', 0, 11999988, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14869, 841, 18, '16', 'bluemarble_2', 'Global MODIS Blue Marble (30 arcsec. level)', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14870, 841, 19, '0', 'globe', 'Cascaded data from GLOBE', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14871, 841, 20, '19', 'rivers', 'Cascaded Rivers from GLOBE', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14872, 841, 21, '19', 'coastlines', 'Cascaded Coastlines from GLOBE', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14873, 841, 22, '0', 'demis', 'Cascaded data from Demis', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14874, 841, 23, '22', 'bathymetry', 'Cascaded Bathymetry from Demis', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14875, 841, 24, '0', 'onearth', 'Cascaded data from OnEarth', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14876, 841, 25, '24', 'landsat7', 'Cascaded Landsat7 from OnEarth', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14877, 841, 26, '24', 'terra', 'Cascaded daily MODIS Terra from OnEarth', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14878, 841, 27, '24', 'aqua', 'Cascaded daily MODIS Aqua from OnEarth', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14879, 841, 28, '0', 'metarweather', 'Cascaded World Hourly METAR Weather Reports from C', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14880, 841, 29, '0', 'noaa', 'Cascaded NOAA World Natural Hazards data', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14881, 841, 30, '29', 'earthquakes', 'Cascaded NOAA Significant Earthquakes', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14882, 841, 31, '29', 'tsunamievents', 'Cascaded NOAA Tsunami Events', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14883, 841, 32, '29', 'volcanoes', 'Cascaded NOAA Volcanoes', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14884, 841, 33, '29', 'plateboundaries', 'Cascaded NOAA Plate Boundaries', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14885, 841, 34, '29', 'countries', 'Cascaded NOAA Countries', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14886, 841, 35, '29', 'cities', 'Cascaded NOAA Cities', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14887, 841, 36, '0', 'sigafrique', 'Cascaded SIGAFRIQUE data', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14888, 841, 37, '36', 'geofault10', 'Cascaded geologic faults 10 m', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14889, 841, 38, '36', 'geoform10', 'Cascaded geologic formations 10 m', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14890, 841, 39, '36', 'towns', 'Cascaded towns', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14891, 841, 40, '36', 'mainrivers', 'Cascaded main water courses and inland water bodie', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14892, 841, 41, '36', 'water', 'Cascaded water courses', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14893, 841, 42, '36', 'railway', 'Cascaded railway network', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14894, 842, 0, '', 'Tsunami_Disaster_Map', 'Tsunami_Diasaster_Data', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14895, 842, 1, '0', 'Satellite_Imagery', 'Satellite_Imagery', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14896, 842, 2, '1', 'GAEL_WORLD_MARCH', 'ENVISAT MERIS mosaic', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14897, 842, 3, '1', 'srtm_tiles', 'SRTM 90m DEM - unclassified', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14898, 842, 4, '1', 'thai-LandsatTrue', 'Landsat Mosaic of Thailand', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14899, 842, 5, '1', 'sri_landsat', 'Landsat Mosaic of Sri Lanka', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14900, 842, 6, '0', 'Physical_Geography', 'Physical_Geography', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14901, 842, 7, '6', 'GTOPO30:Foundation', 'Global 30 Second Elevations', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14902, 842, 8, '6', 'RELIEF:Foundation', 'Two Minute Shaded Relief', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14903, 842, 9, '6', 'Bathymetry', 'Bathymetry', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14904, 842, 10, '6', 'Topography', 'Topography', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14905, 842, 11, '6', 'Hillshading', 'Hillshading', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14906, 842, 12, '6', 'CONTOURL_ELEV_1M:Foundation', 'Elevation Contours', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14907, 842, 13, '0', 'Disaster_Info', 'Disaster_Info', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14908, 842, 14, '13', 'locations', 'Disaster Point Locations', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14909, 842, 15, '13', 'faults', 'Fault Lines', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14910, 842, 16, '13', 'Wave_Heights', 'Wave Heights', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14911, 842, 17, '13', 'earthquakes', 'Recent Earthquakes', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14912, 842, 18, '13', 'epicenter', 'Epicenter of the Earthquake', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14913, 842, 19, '0', 'Political', 'Political', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14914, 842, 20, '19', 'World_WMS-WorldGen', 'World Countries', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14915, 842, 21, '19', 'Coastlines', 'Coastlines', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14916, 842, 22, '19', 'Borders', 'Borders', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14917, 842, 23, '19', 'oceans', 'World Oceans Labels', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14918, 842, 24, '19', 'Cities', 'World Cities', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14919, 842, 25, '0', 'Affected_Country_Statistics', 'Affected_Country_Statistics', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14920, 842, 26, '25', 'gdp', 'Gross Domestic Product (GDP)', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14921, 842, 27, '25', 'gdpper', 'Gross Domestic Product (GDP) per capita', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14922, 842, 28, '25', 'extdebt', 'External Debt', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14923, 842, 29, '25', 'density', 'Population Density (per sq. km)', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14924, 842, 30, '25', 'population', '2004 Population', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14925, 842, 31, '25', 'deaths', 'Total Deaths Per Country', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14926, 842, 32, '25', 'SriLanka_deaths', 'Sri Lanka Total Deaths by Region', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14927, 842, 33, '25', 'SriLanka_injured', 'Sri Lanka Total injuries by Region', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14928, 842, 34, '25', 'SriLanka_missing', 'Sri Lanka Total missing persons by Region', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14929, 842, 35, '25', 'SriLanka_displaced', 'Sri Lanka Total Displaced Population by Region', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14930, 842, 36, '25', 'SriLanka_camps', 'Sri Lanka Total camps by Region', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14931, 842, 37, '0', 'Infrastructure', 'Infrastructure', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14932, 842, 38, '37', 'BUILTUPA_POP_1M:Foundation', 'Built-Up Areas', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14933, 842, 39, '37', 'ROADL_TRANS_1M:Foundation', 'Roads', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14934, 843, 0, '', '', 'hazards', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14935, 843, 1, '0', 'Ambient Population 2002 (per 30 arc seconds)', 'Ambient Population 2002 (per 30 arc seconds)', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14936, 843, 2, '0', 'Elevation/Bathymetry', 'Elevation/Bathymetry', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14937, 843, 3, '0', 'Continents', 'Continents', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14938, 843, 4, '0', 'Lakes', 'Lakes', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14939, 843, 5, '0', 'Rivers', 'Rivers', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14940, 843, 6, '0', 'Countries', 'Countries', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14941, 843, 7, '0', 'States', 'States', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14942, 843, 8, '0', 'Cities', 'Cities', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14943, 843, 9, '0', 'Plate Boundaries', 'Plate Boundaries', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14944, 843, 10, '0', 'Volcanoes', 'Volcanoes', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14945, 843, 11, '0', 'Tsunami Events with runups', 'Tsunami Events with runups', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14946, 843, 12, '0', 'Tsunami Events with slides', 'Tsunami Events with slides', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14947, 843, 13, '0', 'Tsunami Events', 'Tsunami Events', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14948, 843, 14, '0', 'Tsunami Runups', 'Tsunami Runups', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14949, 843, 15, '0', 'Significant Earthquakes with slides', 'Significant Earthquakes with slides', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14950, 843, 16, '0', 'Significant Earthquakes', 'Significant Earthquakes', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14951, 844, 0, '', '', 'CustomWeather Map Server', 0, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14952, 844, 1, '0', 'cite:BasicPolygons', 'cite:BasicPolygons', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14953, 844, 2, '0', 'cite:Bridges', 'cite:Bridges', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14954, 844, 3, '0', 'cite:BuildingCenters', 'cite:BuildingCenters', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14955, 844, 4, '0', 'cite:Buildings', 'cite:Buildings', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14956, 844, 5, '0', 'cite:DividedRoutes', 'cite:DividedRoutes', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14957, 844, 6, '0', 'cite:Forests', 'cite:Forests', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14958, 844, 7, '0', 'cite:Lakes', 'cite:Lakes', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14959, 844, 8, '0', 'cite:MapNeatline', 'cite:MapNeatline', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14960, 844, 9, '0', 'cite:NamedPlaces', 'cite:NamedPlaces', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14961, 844, 10, '0', 'cite:Ponds', 'cite:Ponds', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14962, 844, 11, '0', 'cite:RoadSegments', 'cite:RoadSegments', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14963, 844, 12, '0', 'cite:Streams', 'cite:Streams', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14964, 844, 13, '0', 'airport_delay', 'airport_delay', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14965, 844, 14, '0', 'anim', 'anim', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14966, 844, 15, '0', 'au_radar', 'au_radar', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14967, 844, 16, '0', 'au_radar_stations', 'au_radar_stations', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14968, 844, 17, '0', 'base', 'base', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14969, 844, 18, '0', 'borders', 'borders', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14970, 844, 19, '0', 'coasts', 'coasts', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14971, 844, 20, '0', 'conditions', 'conditions', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14972, 844, 21, '0', 'contour_fire_danger', 'contour_fire_danger', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14973, 844, 22, '0', 'contour_high', 'contour_high', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14974, 844, 23, '0', 'contour_jet_stream', 'contour_jet_stream', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14975, 844, 24, '0', 'contour_low', 'contour_low', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14976, 844, 25, '0', 'contour_precip', 'contour_precip', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14977, 844, 26, '0', 'contour_pressure', 'contour_pressure', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14978, 844, 27, '0', 'contour_syn_precip', 'contour_syn_precip', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14979, 844, 28, '0', 'conus_ir_satellite_4km', 'conus_ir_satellite_4km', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14980, 844, 29, '0', 'counties', 'counties', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14981, 844, 30, '0', 'earthquakes', 'earthquakes', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14982, 844, 31, '0', 'eqc', 'eqc', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14983, 844, 32, '0', 'forecasts', 'forecasts', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14984, 844, 33, '0', 'frontlines', 'frontlines', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14985, 844, 34, '0', 'future_lightning', 'future_lightning', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14986, 844, 35, '0', 'gazetteer', 'gazetteer', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14987, 844, 36, '0', 'geom', 'geom', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14988, 844, 37, '0', 'global_ir_satellite_10km', 'global_ir_satellite_10km', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14989, 844, 38, '0', 'hurricanes', 'hurricanes', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14990, 844, 39, '0', 'interstates', 'interstates', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14991, 844, 40, '0', 'jetstream', 'jetstream', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14992, 844, 41, '0', 'label', 'label', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14993, 844, 42, '0', 'land_sea_mask', 'land_sea_mask', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14994, 844, 43, '0', 'legend', 'legend', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14995, 844, 44, '0', 'lightning', 'lightning', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14996, 844, 45, '0', 'maple', 'maple', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14997, 844, 46, '0', 'maple_raster', 'maple_raster', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14998, 844, 47, '0', 'marine_zones', 'marine_zones', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (14999, 844, 48, '0', 'pacus_ir_satellite_4km', 'pacus_ir_satellite_4km', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15000, 844, 49, '0', 'post_borders', 'post_borders', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15001, 844, 50, '0', 'radar', 'radar', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15002, 844, 51, '0', 'radar_mask', 'radar_mask', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15003, 844, 52, '0', 'rivers', 'rivers', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15004, 844, 53, '0', 'severe_warnings', 'severe_warnings', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15005, 844, 54, '0', 'severe_watches', 'severe_watches', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15006, 844, 55, '0', 'state_borders', 'state_borders', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15007, 844, 56, '0', 'storm_track', 'storm_track', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15008, 844, 57, '0', 'template', 'template', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15009, 844, 58, '0', 'wide_conus_ir_satellite_4km', 'wide_conus_ir_satellite_4km', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15010, 844, 59, '0', 'zones', 'zones', 1, 0, 0, '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15337, 407, 0, '', 'Mapbender', 'Mapbender User', 0, 1, 0, '', 'http://wms1.ccgis.de/mapbender22/metadata/metadata.php?layer=Schulen');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15338, 407, 1, '0', 'Mapbender_User', 'Mapbender User', 0, 0, 0, '', 'http://wms1.ccgis.de/mapbender22/metadata/metadata.php?layer=Rathaus');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15339, 407, 2, '0', 'Mapbender_Names', 'Mapbender Info', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15735, 854, 0, '', 'wesseling_stadtkarte', 'Stadtkarte', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15736, 854, 1, '0', 'Nutzung', 'Nutzung', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15737, 854, 2, '1', 'wes_dsk_patch1', 'wes_dsk_patch1', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15738, 854, 3, '1', 'atkis_wes_1_umn_pl', 'atkis_wes_1_umn_pl', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15739, 854, 4, '1', 'atkis_wes_1_umn_l', 'atkis_wes_1_umn_l', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15740, 854, 5, '1', 'atkis_wes_3_layer1_pl', 'atkis_wes_3_layer1_pl', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15741, 854, 6, '1', 'atkis_wes_3_layer2_pl', 'atkis_wes_3_layer2_pl', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15742, 854, 7, '1', 'atkis_wes_3_layer3_pl', 'atkis_wes_3_layer3_pl', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15743, 854, 8, '1', 'atkis_wes_3_layer4_pl', 'atkis_wes_3_layer4_pl', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15744, 854, 9, '1', 'atkis_wes_3_layer5_pl', 'atkis_wes_3_layer5_pl', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15745, 854, 10, '1', 'atkis_wes_3_layer6_l', 'atkis_wes_3_layer6_l', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15747, 854, 12, '0', 'Strassen', 'Strassen', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15749, 854, 14, '12', 'WES_DSK_umring', 'WES_DSK_umring', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15751, 854, 16, '0', 'Stadtgrenze', 'Stadtgrenze', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15752, 854, 17, '0', 'Strassennamen', 'Strassennamen', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15753, 854, 18, '17', 'wes_dsk_strnamen_umn_1_t', 'wes_dsk_strnamen_umn_1_t', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15754, 854, 19, '17', 'wes_dsk_strnamen_umn_2_t', 'wes_dsk_strnamen_umn_2_t', 0, 0, 4000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15755, 854, 20, '0', 'wes_dsk_patch', 'wes_dsk_patch', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15798, 855, 0, '', '', 'World Map', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15799, 855, 1, '0', 'Bathymetry', 'Bathymetry', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15800, 855, 2, '0', 'Countries', 'Countries', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15801, 855, 3, '0', 'Topography', 'Topography', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15802, 855, 4, '0', 'Hillshading', 'Hillshading', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15803, 855, 5, '0', 'Builtup areas', 'Builtup areas', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15804, 855, 6, '0', 'Coastlines', 'Coastlines', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15805, 855, 7, '0', 'Waterbodies', 'Waterbodies', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15806, 855, 8, '0', 'Inundated', 'Inundated', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15807, 855, 9, '0', 'Rivers', 'Rivers', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15808, 855, 10, '0', 'Streams', 'Streams', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15809, 855, 11, '0', 'Railroads', 'Railroads', 1, 0, 1683694, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15810, 855, 12, '0', 'Highways', 'Highways', 1, 0, 1403078, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15811, 855, 13, '0', 'Roads', 'Roads', 1, 0, 841847, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15812, 855, 14, '0', 'Trails', 'Trails', 1, 0, 561231, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15813, 855, 15, '0', 'Borders', 'Borders', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15814, 855, 16, '0', 'Cities', 'Cities', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15815, 855, 17, '0', 'Settlements', 'Settlements', 1, 0, 1122463, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15816, 855, 18, '0', 'Spot elevations', 'Spot elevations', 0, 0, 561231, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15817, 855, 19, '0', 'Airports', 'Airports', 1, 0, 1122463, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (15818, 855, 20, '0', 'Ocean features', 'Ocean features', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18068, 859, 0, '', '', 'Geobasisdaten', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18069, 859, 1, '0', '1', 'Digitale Orthophotos', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18119, 866, 0, '', '', 'hochwasser', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18120, 866, 1, '0', '8', 'rhein-hq100-odeich', 1, 200, 749888, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18121, 866, 2, '0', '9', 'rhein-hq100-mdeich', 1, 200, 749888, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18122, 866, 3, '0', '6', 'rhein-hq200-odeich', 1, 200, 749888, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18123, 866, 4, '0', '7', 'rhein-hq200-mdeich', 1, 200, 749888, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18124, 866, 5, '0', '4', 'rhein-hq500-odeich', 1, 200, 749888, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18125, 866, 6, '0', '5', 'rhein-hq500-mdeich', 1, 200, 749888, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18126, 866, 7, '0', '0', 'vereinf_Verfahren', 1, 200, 374944, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18127, 866, 8, '0', '1', 'Sonstige_UESG', 1, 200, 374944, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18128, 866, 9, '0', '2', 'Historische_UESG', 1, 200, 374944, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18129, 866, 10, '0', '3', 'neuere_Berechnungsverfahren', 1, 200, 374944, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18130, 866, 11, '0', '18', 'Seen', 1, 200, 374944, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18131, 866, 12, '0', '19', 'Talsperre', 1, 200, 374944, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18132, 867, 0, '', '', 'stobo', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18133, 867, 1, '0', 'Bleibelastung der Ackerboeden in mg pro kg', 'Bleibelastung der Ackerboeden in mg pro kg', 1, 22497, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18134, 867, 2, '0', 'Cadmiumbelastung der Ackerboeden in mg pro kg', 'Cadmiumbelastung der Ackerboeden in mg pro kg', 1, 22497, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18135, 867, 3, '0', 'Zinkbelastung der Ackerboeden in mg pro kg', 'Zinkbelastung der Ackerboeden in mg pro kg', 1, 22497, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18136, 867, 4, '0', 'Bleibelastung der Gartenboeden in mg pro kg', 'Bleibelastung der Gartenboeden in mg pro kg', 1, 22497, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18137, 867, 5, '0', 'Cadmiumbelastung der Gartenboeden in mg pro kg', 'Cadmiumbelastung der Gartenboeden in mg pro kg', 1, 22497, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18138, 867, 6, '0', 'Zinkbelastung der Gartenboeden in mg pro kg', 'Zinkbelastung der Gartenboeden in mg pro kg', 1, 22497, 74989, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18139, 867, 7, '0', 'Bleibelastung der Gruenlandboeden in mg pro kg', 'Bleibelastung der Gruenlandboeden in mg pro kg', 1, 22497, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18140, 867, 8, '0', 'Cadmiumbelastung der Gruenlandboeden in mg pro kg', 'Cadmiumbelastung der Gruenlandboeden in mg pro kg', 1, 22497, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18141, 867, 9, '0', 'Zinkbelastung der Gruenlandboeden in mg pro kg', 'Zinkbelastung der Gruenlandboeden in mg pro kg', 1, 22497, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18142, 867, 10, '0', 'Probenahmenstandorte in NRW differenziert nach Nutzungen', 'Probenahmenstandorte in NRW differenziert nach Nutzungen', 1, 22497, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18143, 868, 0, '', '', 'Gelaendemodell', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18144, 868, 1, '0', 'DGM50', 'DGM50', 0, 26075, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18145, 869, 0, '', '', 'linfos', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18146, 869, 1, '0', '51', 'Vegetationstypen', 1, 0, 150214, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18147, 869, 2, '0', '49', 'Vegetationsaufnahmen', 1, 0, 150214, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18148, 869, 3, '0', '45', 'Naturraeumliche Haupteinheiten', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18149, 869, 4, '0', '43', 'Landschaftsschutzgebiete', 1, 0, 150214, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18150, 869, 5, '0', '42', 'Stand der Landschaftsplanung', 1, 0, 150214, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18151, 869, 6, '0', '32', 'FFH-Gebiete', 1, 0, 150214, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18152, 869, 7, '0', '31', 'Vogelschutzgebiete', 1, 0, 150214, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18153, 869, 8, '0', '28', 'Biotoptypen', 1, 0, 150214, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18154, 869, 9, '0', '3', 'Biotopkataster', 1, 0, 150214, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18155, 869, 10, '0', '1', 'Naturschutzgebiete', 1, 0, 150214, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18159, 871, 0, '', 'MUENSTER', 'Geobasisdaten Muenster', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18160, 871, 1, '0', 'splan', 'Stadtplan', 0, 2400, 2000000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18161, 871, 2, '0', 'luftb', 'Luftbilder', 0, 375, 3900, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18162, 871, 3, '0', 'dgk5dbr', 'DGK5', 0, 1, 3900, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18163, 871, 4, '0', 'Stadtgrundkarte', 'Stadtgrundkarte', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18164, 871, 5, '4', 'flst', 'Flurstuecke', 0, 1, 2500, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18165, 871, 6, '4', 'gebaeude', 'Gebaeude', 0, 1, 2500, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18166, 871, 7, '4', 'linien', 'Topographie', 0, 1, 2500, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18167, 871, 8, '4', 'texte', 'Beschriftung', 0, 1, 2500, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18168, 872, 0, '', '', 'WV_WMS', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18169, 872, 1, '0', 'rheinplus', 'rheinplus', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18170, 872, 2, '0', 'uesgobwup', 'uesgobwup', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18171, 872, 3, '0', 'uesgmorsbach', 'uesgmorsbach', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18172, 872, 4, '0', 'klaerwerkseinzugsgebiete', 'klaerwerkseinzugsgebiete', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18173, 872, 5, '0', 'entwaesserungssystem', 'entwaesserungssystem', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18174, 872, 6, '0', 'gezgross', 'gezgross', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18175, 872, 7, '0', 'gezklein', 'gezklein', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18176, 872, 8, '0', 'ueberleitungsgebiete', 'ueberleitungsgebiete', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18177, 872, 9, '0', 'verbandsgebiet', 'verbandsgebiet', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18178, 872, 10, '0', 'gsg5', 'gsg5', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18179, 872, 11, '0', 'gsg3', 'gsg3', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18180, 872, 12, '0', 'gsg1', 'gsg1', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18181, 872, 13, '0', 'gewaesser', 'gewaesser', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18182, 872, 14, '0', 'verrohrungen', 'verrohrungen', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18183, 872, 15, '0', 'verlaufaenderungen', 'verlaufaenderungen', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18184, 872, 16, '0', 'gewaesserbeschriftung', 'gewaesserbeschriftung', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18185, 872, 17, '0', 'talsperren', 'talsperren', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18186, 872, 18, '0', 'sammler', 'sammler', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18187, 872, 19, '0', 'stationierung', 'stationierung', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18188, 872, 20, '0', 'fotos_am_gewaesser', 'fotos_am_gewaesser', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18189, 872, 21, '0', 'limnologie', 'limnologie', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18190, 872, 22, '0', 'niederschlagsstationen', 'niederschlagsstationen', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18191, 872, 23, '0', 'pegel', 'pegel', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18192, 872, 24, '0', 'wehre', 'wehre', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18193, 872, 25, '0', 'fischaufstiege', 'fischaufstiege', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18194, 872, 26, '0', 'hrb', 'hrb', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18195, 872, 27, '0', 'regenbeckenwv', 'regenbeckenwv', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18196, 872, 28, '0', 'klaerwerke', 'klaerwerke', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18205, 881, 0, '', 'Gebietsgliederung', 'Gebietsgliederung', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18206, 881, 1, '0', 'Stadtbezirke', 'Stadtbezirke', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18207, 881, 2, '1', 'stadtbezirke_pl', 'stadtbezirke_pl', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18208, 881, 3, '1', 'stadtbezirke_t', 'stadtbezirke_t', 0, 0, 300000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18209, 881, 4, '0', 'Statistische_Bezirke', 'Statistische_Bezirke', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18210, 881, 5, '4', 'statist_bez_pl', 'statist_bez_pl', 0, 0, 300000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18211, 881, 6, '4', 'statist_bez_t', 'statist_bez_t', 0, 0, 300000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18212, 881, 7, '0', 'Verkehrszellen', 'Verkehrszellen', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18213, 881, 8, '7', 'verkehrszellen_pl', 'verkehrszellen_pl', 0, 0, 300000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18214, 881, 9, '7', 'verkehrszellen_t', 'verkehrszellen_t', 0, 0, 300000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18215, 881, 10, '0', 'Baubloecke', 'Baubloecke', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18216, 881, 11, '10', 'baubloecke_pl', 'baubloecke_pl', 0, 0, 100000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18217, 881, 12, '10', 'baubloecke_t', 'baubloecke_t', 0, 0, 100000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18218, 882, 0, '', 'Wahlen', 'Wahlen', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18219, 882, 1, '0', 'HINTERGRUNDKARTE', 'HINTERGRUNDKARTE', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18220, 882, 2, '1', 'stadtplan_grau_zoomst_1', 'stadtplan_grau_zoomst_1', 0, 135001, 300000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18221, 882, 3, '1', 'stadtplan_zoom3_01', '02_stadtplan', 0, 20001, 135000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18222, 882, 4, '1', 'stadtplan_zoom3_02', '03_stadtplan', 0, 12001, 20000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18223, 882, 5, '1', 'stadtplan_zoom3_03', '04_stadtplan', 0, 2751, 12000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18224, 882, 6, '1', 'dgk5_liste', 'Deutsche Grundkarte', 0, 0, 2750, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18225, 882, 7, '0', 'stadtplan_72dpi', 'stadtplan_uebersicht', 0, 300000, 1000000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18226, 882, 8, '0', 'Stadtbezirke', 'Stadtbezirke', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18227, 882, 9, '8', 'stadtbezirke_pl', 'stadtbezirke_pl', 0, 0, 300000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18228, 882, 10, '8', 'stadtbezirke_t', 'stadtbezirke_t', 0, 0, 300000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18229, 882, 11, '0', 'Wahlbezirke', 'Wahlbezirke', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18230, 882, 12, '11', 'wahlbezirke_pl', 'wahlbezirke_pl', 0, 0, 300000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18231, 882, 13, '11', 'wahlbezirke_t', 'wahlbezirke_t', 0, 0, 300000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18232, 882, 14, '0', 'Stimmbezirke', 'Stimmbezirke', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18233, 882, 15, '14', 'stimmbezirke_pl', 'stimmbezirke_pl', 0, 0, 300000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18234, 882, 16, '14', 'stimmbezirke_t', 'stimmbezirke_t', 0, 0, 300000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18235, 883, 0, '', '', 'Luftbilder', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18236, 883, 1, '0', '1', '$_nav_uebersicht', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18237, 883, 2, '0', '2', 'Stadtplan', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18238, 883, 3, '0', '5', 'Luftbilder 1999', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18239, 883, 4, '0', '8', 'Flurstuecksstruktur', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18240, 883, 5, '0', '9', 'Texte', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18248, 885, 2, '1', 'Autobahnen', 'Autobahnen', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18253, 885, 7, '6', 'NKAutobahnen', 'Netzknoten, Autobahnen', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18258, 885, 12, '11', 'NPAutobahnen', 'Nullpunkte, Autobahnen', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18262, 885, 16, '0', 'TKBlaetter', 'TK-Blattschnitte', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18264, 885, 18, '17', 'mZstBereichAutobahnen', 'Zst-Bereiche Autobahnen', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18269, 885, 23, '22', 'mZstOrtAutobahnen', 'Zst-Orte Autobahnen', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18270, 885, 24, '22', 'mZstOrtBundesstrassen', 'Zst-Orte Bundesstrassen', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18271, 885, 25, '22', 'mZstOrtLandesstrassen', 'Zst-Orte Landesstrassen', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18272, 885, 26, '22', 'mZstOrtKreisstrassen', 'Zst-Orte Kreisstrassen', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18274, 887, 0, '', '', 'BK50', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (18275, 887, 1, '0', 'bk50', 'bk50', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19006, 893, 0, '', 'Germany', 'Germany', 0, 1, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19007, 893, 1, '0', 'Topographie', 'topography', 0, 0, 0, 'http://www.ccgis.de', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19008, 893, 2, '0', 'Grenze', 'border', 0, 749999, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19009, 893, 3, '0', 'Bundeslaender', 'federal states', 0, 749999, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19010, 893, 4, '0', 'Staedte', 'places', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19011, 893, 5, '0', 'Postleitzahlbereiche', 'postcode areas', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19012, 893, 6, '0', 'Bahnlinien', 'railroad lines', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19013, 893, 7, '0', 'Fluesse', 'rivers', 0, 0, 1250001, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19014, 893, 8, '0', 'Strassen', 'roads', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19015, 893, 9, '0', 'Staedtepunkte', 'places as point', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19016, 893, 10, '0', 'Postleitzahlbereichname', 'postcode areas (names)', 0, 0, 350000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19017, 893, 11, '0', 'Staedtenamen', 'places (names)', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19018, 893, 12, '0', 'Bundeslaendernamen', 'federal states (names)', 0, 1000000, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19168, 907, 0, '', 'NRW', 'NRW', 0, 0, 140316, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19125, 903, 0, '', 'Brandenburg', 'DNM 25', 0, 100, 50000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19169, 907, 1, '0', 'Raster:TK100_KMF:Farbkombination', 'Farbkombination', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19126, 903, 1, '0', 'land', 'Landkreise und kreisfreie Städte', 0, 100, 50000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19127, 903, 2, '0', 'ort', 'Ortschaften', 1, 1000, 50000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19106, 901, 0, '', 'germany_wfs_myedit', 'MyEdit Elements', 0, 1, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19107, 901, 1, '0', 'my_polygons', 'my polygons', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19108, 901, 2, '0', 'my_lines', 'my lines', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19109, 901, 3, '0', 'my_points', 'my points', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19079, 899, 0, '', 'infoprix', 'Infoprix', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19080, 899, 1, '0', 'Ajouter_un_Marche', 'Ajouter_un_Marche', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19081, 899, 2, '0', 'Weltlaender', 'Etats', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19082, 899, 3, '0', 'Departmt', 'Departements', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19083, 899, 4, '0', 'Sousprefneu', 'Sous Prefectures', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19084, 899, 5, '0', 'rivlc', 'Rivieres et lacs', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19085, 899, 6, '0', 'Route2', 'Voies de communication', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19086, 899, 7, '0', 'localits', 'Localités', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19087, 899, 8, '0', 'Villes', 'Villes', 0, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19088, 899, 9, '0', 'Maerkte1', 'Marches', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19089, 899, 10, '0', 'Nouveaux-Marches', 'Nouveaux-Marches', 1, 0, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19128, 903, 3, '0', 'wald', 'Waldflächen', 0, 1000, 50000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19129, 903, 4, '0', 'gruen', 'Grünflächen', 0, 1000, 50000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19146, 904, 8, '0', 'bstr', 'Bundesstraßen', 0, 200000, 1000000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19147, 904, 9, '0', 'astr', 'Autobahnen', 0, 200000, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19148, 904, 10, '0', 'kfz', 'Kfz-Zeichen', 0, 1000000, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19149, 905, 0, '', 'Brandenburg', 'DNM FÜK', 0, 50000, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19150, 905, 1, '0', 'flur', 'Flur', 1, 50000, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19151, 905, 2, '0', 'gema', 'Gemarkung', 1, 50000, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19152, 905, 3, '0', 'geme', 'Gemeinde', 1, 50000, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19153, 905, 4, '0', 'stadt', 'Kreisfreie Städte', 1, 50000, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19154, 905, 5, '0', 'kreis', 'Landkreise', 1, 50000, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19155, 906, 0, '', 'Brandenburg', 'DNM VG', 0, 50000, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19156, 906, 1, '0', 'berlin', 'Berliner Bezirke', 0, 50000, 1000000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19157, 906, 2, '0', 'geme', 'Gemeinde', 1, 50000, 1000000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19158, 906, 3, '0', 'kamt', 'Amtsfreie Gemeinde', 1, 50000, 1000000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19159, 906, 4, '0', 'amt', 'Ämter', 1, 50000, 1000000, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19160, 906, 5, '0', 'stadt', 'Kreisfreie Städte', 1, 50000, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19161, 906, 6, '0', 'kreis', 'Landkreise', 1, 50000, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19162, 906, 7, '0', 'land', 'Land', 0, 50000, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19163, 906, 8, '0', 'staat', 'Deutschland', 0, 50000, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19164, 906, 9, '0', 'ngeme', 'Namen der Gemeinden', 0, 50000, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19165, 906, 10, '0', 'nkamt', 'Namen der amtfreien Gemeinden', 0, 50000, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19166, 906, 11, '0', 'namt', 'Namen der Ämter', 0, 50000, 0, '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl) VALUES (19167, 906, 12, '0', 'nkreis', 'KFZ Kennzeichen der Kreise', 0, 50000, 0, '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2712, 250, 0, '', '', 'Demis World Map', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2713, 250, 1, '0', 'Bathymetry', 'Bathymetry', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2714, 250, 2, '0', 'Countries', 'Countries', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2715, 250, 3, '0', 'Topography', 'Topography', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2716, 250, 4, '0', 'Hillshading', 'Hillshading', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2717, 250, 5, '0', 'Builtup areas', 'Builtup areas', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2718, 250, 6, '0', 'Coastlines', 'Coastlines', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2719, 250, 7, '0', 'Waterbodies', 'Waterbodies', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2720, 250, 8, '0', 'Inundated', 'Inundated', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2721, 250, 9, '0', 'Rivers', 'Rivers', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2722, 250, 10, '0', 'Streams', 'Streams', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2723, 250, 11, '0', 'Railroads', 'Railroads', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2724, 250, 12, '0', 'Highways', 'Highways', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2725, 250, 13, '0', 'Roads', 'Roads', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2726, 250, 14, '0', 'Trails', 'Trails', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2727, 250, 15, '0', 'Borders', 'Borders', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2728, 250, 16, '0', 'Cities', 'Cities', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2729, 250, 17, '0', 'Settlements', 'Settlements', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2730, 250, 18, '0', 'Spot elevations', 'Spot elevations', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2731, 250, 19, '0', 'Airports', 'Airports', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2732, 250, 20, '0', 'Ocean features', 'Ocean features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3384, 328, 0, '', '', 'SW!ACE: Layers des Smallworld GIS', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3385, 328, 1, '0', 'Autobahn', 'Autobahn', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3386, 328, 2, '0', 'Bundesstr.', 'Bundesstr.', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3387, 328, 3, '0', 'Landesstr.', 'Landesstr.', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3388, 328, 4, '0', 'Kreisstr.', 'Kreisstr.', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3389, 328, 5, '0', 'AS Nr.', 'AS Nr.', 1, 0, 100220, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3390, 328, 6, '0', 'AS Name', 'AS Name', 1, 0, 53451, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3391, 328, 7, '0', 'Bauwerke', 'Bauwerke', 1, 0, 24720, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3392, 328, 8, '0', 'BW-Nr.', 'BW-Nr.', 1, 0, 24720, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3393, 328, 9, '0', 'Aeste', 'Aeste', 1, 0, 233847, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3394, 328, 10, '0', 'Netzkn.', 'Netzkn.', 1, 0, 53451, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3395, 328, 11, '0', 'Nullpkt.', 'Nullpkt.', 1, 0, 24720, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3396, 328, 12, '0', 'Str. Bez.', 'Str. Bez.', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3397, 328, 13, '0', 'Abs.Nr.', 'Abs.Nr.', 1, 0, 53451, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3398, 328, 14, '0', 'Durchlaesse', 'Durchlaesse', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3399, 328, 15, '0', 'Kreuzungen', 'Kreuzungen', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3400, 328, 16, '0', 'DGK 5', 'DGK 5', 0, 0, 24720, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3401, 329, 0, '', 'MUENSTER', 'Geobasisdaten Muenster', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3402, 329, 1, '0', 'splan', 'Stadtplan', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3403, 329, 2, '0', 'luftb', 'Luftbilder', 0, 1, 50000, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3404, 329, 3, '0', 'dgk5dbr', 'DGK5', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3405, 329, 4, '0', 'Stadtgrundkarte', 'Stadtgrundkarte', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3406, 329, 5, '4', 'flst', 'Flurstuecke', 0, 1, 2500, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3407, 329, 6, '4', 'gebaeude', 'Gebaeude', 0, 1, 2500, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3408, 329, 7, '4', 'linien', 'Topographie', 0, 1, 2500, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3409, 329, 8, '4', 'texte', 'Beschriftung', 0, 1, 2500, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3470, 336, 0, '', '', 'DTK10', 0, 138, 27683, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3471, 336, 1, '0', 'DTK10:Gesamt', 'Gesamt', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3472, 336, 2, '0', 'DTK10:GesamtRS', 'GesamtRS', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (5575, 486, 0, '', 'PLZ_441', 'PLZ_441', 0, 1, 1000000000, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (5576, 486, 1, '0', 'Nationalborder', 'National Border', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (5577, 486, 2, '0', 'Postcodeareas', 'Post Code Areas', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (5578, 486, 3, '0', 'Postcodelabels', 'Post Code Labels', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7255, 525, 0, '', 'Middle_America', 'Middle America', 0, 0, 119999880, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7256, 525, 1, '0', 'North_and_South_American_States', 'America', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7257, 525, 2, '0', 'Middle_American_States_AREA', 'State Area', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7258, 525, 3, '0', 'Middle_America_DEM_surface', 'Elevation Model', 0, 0, 11999988, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7259, 525, 4, '0', 'National_borders', 'Borders', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7260, 525, 5, '0', 'Lakes_and_temporary_inundated_areas', 'Lakes', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7261, 525, 6, '0', 'Temporary_and_permanent_rivers_and_streams', 'Rivers', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7262, 525, 7, '0', 'Larger_cities_polygon', 'Cities', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7263, 525, 8, '0', 'Roads', 'Roads', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7264, 525, 9, '0', 'Railway_systems', 'Rails', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7265, 525, 10, '0', 'Smaller_cities_and_villages_point', 'Places', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7266, 525, 11, '0', 'Archaeological_maya_sites', 'Maya Sites', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7267, 525, 12, '0', 'Archaeological_maya_records', 'Maya Records', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7491, 583, 0, '', 'canada_base', 'Atlas of Canada WMS', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7492, 583, 1, '0', 'roc_2m', 'Regions outside Canada (1:2 000 000)', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7493, 583, 2, '0', 'roc_7.5m', 'Regions outside Canada (1:7 500 000)', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7494, 583, 3, '0', 'roc_15m', 'Regions outside Canada (1:15 000 000)', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7495, 583, 4, '0', 'wa_2m', 'Water areas (1:2 000 000)', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7496, 583, 5, '0', 'wa_7.5m', 'Water areas (1:7 500 000)', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7497, 583, 6, '0', 'wa_15m', 'Water areas (1:15 000 000)', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7498, 583, 7, '0', 'wa_60m', 'Water areas (1:60 000 000)', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7499, 583, 8, '0', 'drain_2m', 'Drainage (1:2 000 000)', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7500, 583, 9, '0', 'drain_7.5m', 'Drainage (1:7 500 000)', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7501, 583, 10, '0', 'drain_15m', 'Drainage (1:15 000 000)', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7502, 583, 11, '0', 'drain_60m', 'Drainage (1:60 000 000)', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7503, 583, 12, '0', 'roads_2m', 'Road network (1:2 000 000)', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7504, 583, 13, '0', 'roads_7.5m', 'Road network (1:7 500 000)', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7505, 583, 14, '0', 'roads_15m', 'Road network (1:15 000 000)', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7506, 583, 15, '0', 'nat_bounds', 'Provincial and Territorial Boundaries', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7507, 583, 16, '0', 'int_bounds', 'Boundaries', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7508, 583, 17, '0', 'can_7.5m', 'Landmass outline (1:7 500 000)', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7509, 583, 18, '0', 'places_symb_2m', 'Populated Places (symbols 1:2M)', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7510, 583, 19, '0', 'places_labels_2m', 'Populated Places (labels 1:2M)', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7511, 583, 20, '0', 'places_symb_7.5m', 'Populated Places (symbols 1:7.5M)', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7512, 583, 21, '0', 'places_labels_7.5m', 'Populated Places (labels 1:7.5M)', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7513, 583, 22, '0', 'places_symb_15m', 'Populated Places (symbols 1:15M)', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7514, 583, 23, '0', 'places_labels_15m', 'Populated Places (labels 1:15M)', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7515, 583, 24, '0', 'cap_symb_e', 'Capitals (symbols)', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7516, 583, 25, '0', 'cap_labels', 'Capitals (Canada)', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7517, 584, 0, '', 'BSC_WMS', 'Bird Studies Canada WMS/WFS Server', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7518, 584, 1, '0', 'IBA', 'Canadian Important Bird Areas', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7519, 584, 2, '0', 'CBC_PT', 'Canadian Christmas Bird Count Locations', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7520, 584, 3, '0', 'CBC_PY', 'Canadian Christmas Bird Count Locations', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7521, 584, 4, '0', 'MMP', 'Marsh Monitoring Program Route Locations', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7522, 584, 5, '0', 'CLLS', 'Canadian Lakes Loon Survey Locations', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7523, 584, 6, '0', 'OBBA_SQUARE', 'Ontario Breeding Bird Atlas 10 km Squares', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7524, 584, 7, '0', 'OBBA_REGION', 'Ontario Breeding Bird Atlas Administrative Regions', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7525, 584, 8, '0', 'OBBA_BLOCK', 'Ontario Breeding Bird Atlas 100 km Blocks', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7526, 584, 9, '0', 'OWLS', 'Nocturnal Owl Survey Locations', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7527, 584, 10, '0', 'BBS_PT', 'Breeding Bird Survey Route Start Points', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9663, 612, 0, '', '', 'European Space Agency', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9664, 612, 1, '0', '', 'European Space Agency', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9665, 612, 2, '1', '', 'BOUNDARIES', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9666, 612, 3, '2', 'BARRIERL_1M:MapAdmin', 'Barrier Line Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9667, 612, 4, '2', 'BNDTXT_1M:MapAdmin', 'Boundaries Coverage Text', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9668, 612, 5, '2', 'COASTL_1M:MapAdmin', 'Coastlines', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9669, 612, 6, '2', 'DEPTHL_1M:MapAdmin', 'Depth Contours', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9670, 612, 7, '2', 'OCEANSEA_1M:MapAdmin', 'Oceans/Seas', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9671, 612, 8, '2', 'POLBNDA_1M:MapAdmin', 'Administrative Areas', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9672, 612, 9, '2', 'POLBNDL_1M:MapAdmin', 'Political Boundaries', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9673, 612, 10, '2', 'POLBNDP_1M:MapAdmin', 'Political Boundary Point Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9674, 612, 11, '1', '', 'BURNSCARS', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9675, 612, 12, '11', 'GLOBSCAR012002:MapAdmin', 'GLOBSCAR012002', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9676, 612, 13, '11', 'GLOBSCAR022002:MapAdmin', 'GLOBSCAR022002', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9677, 612, 14, '11', 'GLOBSCAR032002:MapAdmin', 'GLOBSCAR032002', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9678, 612, 15, '11', 'GLOBSCAR042002:MapAdmin', 'GLOBSCAR042002', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9679, 612, 16, '11', 'GLOBSCAR052002:MapAdmin', 'GLOBSCAR052002', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9680, 612, 17, '11', 'GLOBSCAR062002:MapAdmin', 'GLOBSCAR062002', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9681, 612, 18, '11', 'GLOBSCAR072002:MapAdmin', 'GLOBSCAR072002', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9682, 612, 19, '11', 'GLOBSCAR082002:MapAdmin', 'GLOBSCAR082002', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9683, 612, 20, '11', 'GLOBSCAR092002:MapAdmin', 'GLOBSCAR092002', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9684, 612, 21, '11', 'GLOBSCAR102002:MapAdmin', 'GLOBSCAR102002', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9685, 612, 22, '11', 'GLOBSCAR112002:MapAdmin', 'GLOBSCAR112002', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9686, 612, 23, '11', 'GLOBSCAR122002:MapAdmin', 'GLOBSCAR122002', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9687, 612, 24, '1', '', 'DATA QUALITY', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9688, 612, 25, '24', 'DQLINE_TRANS_1M:MapAdmin', 'Data Quality Line Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9689, 612, 26, '24', 'DQLINE_UTIL_1M:MapAdmin', 'Data Quality Line Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9690, 612, 27, '1', '', 'DIGITAL TERRAIN', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9691, 612, 28, '27', 'ETOPO5:MapAdmin', 'Global 5 Minute Elevations', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9692, 612, 29, '27', 'GTOPO30:MapAdmin', 'Global 30 Second Elevations', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9693, 612, 30, '1', '', 'ELEVATION', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9694, 612, 31, '30', 'CONTOURL_1M:MapAdmin', 'Elevation Contours', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9695, 612, 32, '30', 'ELEVP_1M:MapAdmin', 'Spot Elevations', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9696, 612, 33, '1', '', 'ENVISAT', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9697, 612, 34, '33', 'AATSR:MapAdmin', 'AATSR', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9698, 612, 35, '33', 'ASAR:MapAdmin', 'ASAR', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9699, 612, 36, '33', 'ASAR_WSM:MapAdmin', 'ASAR_WSM', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9700, 612, 37, '33', 'MERIS_RR:MapAdmin', 'MERIS_RR', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9701, 612, 38, '1', '', 'EO_MAPS', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9702, 612, 39, '38', 'WORLD_DMSP_NIGHT:MapAdmin', 'WORLD_DMSP_NIGHT', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9703, 612, 40, '38', 'WORLD_MODIS_1KM:MapAdmin', 'WORLD_MODIS_1KM', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9704, 612, 41, '38', 'WORLD_MODIS_5KM:MapAdmin', 'WORLD_MODIS_5KM', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9705, 612, 42, '1', '', 'GISD', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9706, 612, 43, '42', 'GISD_ROI:MapAdmin', 'GISD_ROI', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9707, 612, 44, '1', '', 'HYDROGRAPHY', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9708, 612, 45, '44', 'AQUECANL_1M:MapAdmin', 'Aqueducts/Canals/Flumes/Penstocks', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9709, 612, 46, '44', 'DANGERP_1M:MapAdmin', 'Danger Point Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9710, 612, 47, '44', 'HYDROTXT_1M:MapAdmin', 'Hydrography Coverage Text', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9711, 612, 48, '44', 'INWATERA_1M:MapAdmin', 'Inland Water Areas', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9712, 612, 49, '44', 'MISCL_1M:MapAdmin', 'Miscellaneous Line Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9713, 612, 50, '44', 'MISCP_1M:MapAdmin', 'Miscellaneous Point Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9714, 612, 51, '44', 'WATRCRSL_1M:MapAdmin', 'Water Courses', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9715, 612, 52, '1', '', 'INDUSTRY', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9716, 612, 53, '52', 'EXTRACTA_1M:MapAdmin', 'Extraction Areas', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9717, 612, 54, '52', 'EXTRACTP_1M:MapAdmin', 'Extraction Point Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9718, 612, 55, '52', 'FISHINDA_1M:MapAdmin', 'Fish Hatcheries/Fish Farms', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9719, 612, 56, '52', 'INDTXT_1M:MapAdmin', 'Industry Coverage Text', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9720, 612, 57, '52', 'MISINDP_1M:MapAdmin', 'Miscellaneous Industry Point Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9721, 612, 58, '52', 'STORAGEP_1M:MapAdmin', 'Storage Point Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9722, 612, 59, '1', '', 'PHYSIOGRAPHY', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9723, 612, 60, '59', 'GROUNDA_1M:MapAdmin', 'Ground Surface Areas', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9724, 612, 61, '59', 'LANDICEA_1M:MapAdmin', 'Snow/Ice Fields and Glaciers', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9725, 612, 62, '59', 'LNDFRML_1M:MapAdmin', 'Landform Line Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9726, 612, 63, '59', 'PHYSTXT_1M:MapAdmin', 'Physiography Coverage Text', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9727, 612, 64, '59', 'SEAICEA_1M:MapAdmin', 'Sea Ice Areas', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9728, 612, 65, '1', '', 'POPULATION', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9729, 612, 66, '65', 'BUILTUPA_1M:MapAdmin', 'Built-Up Areas', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9730, 612, 67, '65', 'BUILTUPP_1M:MapAdmin', 'Built-Up Area Points', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9731, 612, 68, '65', 'MISPOPA_1M:MapAdmin', 'Miscellaneous Population Areas', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9732, 612, 69, '65', 'MISPOPP_1M:MapAdmin', 'Miscellaneous Population Points', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9733, 612, 70, '65', 'POPTXT_1M:MapAdmin', 'Population Coverage Text', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9734, 612, 71, '1', '', 'TRANSPORTATION', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9735, 612, 72, '71', 'AEROFACP_1M:MapAdmin', 'Airport Facilities Points', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9736, 612, 73, '71', 'DQLINE_TRANS_1M:MapAdmin', 'Data Quality Line Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9737, 612, 74, '71', 'MISTRANL_1M:MapAdmin', 'Miscellaneous Transportation Line Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9738, 612, 75, '71', 'RAILRDL_1M:MapAdmin', 'Railroads', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9739, 612, 76, '71', 'ROADL_1M:MapAdmin', 'Roads', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9740, 612, 77, '71', 'RRYARDP_1M:MapAdmin', 'Railroad Yard Points', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9741, 612, 78, '71', 'TRAILL_1M:MapAdmin', 'Trails and Tracks', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9742, 612, 79, '71', 'TRANSTRC_1M:MapAdmin', 'Transportation Structures Points', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9743, 612, 80, '71', 'TRANSTRL_1M:MapAdmin', 'Transportation Structures Lines', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9744, 612, 81, '71', 'TRANSTXT_1M:MapAdmin', 'Transportation Coverage Text', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9745, 612, 82, '1', '', 'UTILITIES', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9746, 612, 83, '82', 'DQLINE_UTIL_1M:MapAdmin', 'Data Quality Line Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9747, 612, 84, '82', 'PIPEL_1M:MapAdmin', 'Pipelines', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9748, 612, 85, '82', 'UTILL_1M:MapAdmin', 'Power Transmission/Telephone/Telegraph Lines', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9749, 612, 86, '82', 'UTILP_1M:MapAdmin', 'Utility Point Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9750, 612, 87, '82', 'UTILTXT_1M:MapAdmin', 'Utilities Coverage Text', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9751, 612, 88, '1', '', 'VEGETATION', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9752, 612, 89, '88', 'CROPA_1M:MapAdmin', 'Croplands', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9753, 612, 90, '88', 'GRASSA_1M:MapAdmin', 'Grasslands', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9754, 612, 91, '88', 'SWAMPA_1M:MapAdmin', 'Marshs/Swamps', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9755, 612, 92, '88', 'TREESA_1M:MapAdmin', 'Trees', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9756, 612, 93, '88', 'TUNDRAA_1M:MapAdmin', 'Tundra', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9757, 612, 94, '0', '', 'CubeWerx Inc.', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9758, 612, 95, '94', '', 'CubeWerx Inc.', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9759, 612, 96, '95', '', 'Boundaries', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9760, 612, 97, '96', 'BARRIERL_1M:Foundation:CubeWerx', 'Barrier Line Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9761, 612, 98, '96', 'BNDTXT_1M:Foundation:CubeWerx', 'Boundaries Coverage Text', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9762, 612, 99, '96', 'COASTL_1M:Foundation:CubeWerx', 'Coastlines', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9763, 612, 100, '96', 'DEPTHL_1M:Foundation:CubeWerx', 'Depth Contours', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9764, 612, 101, '96', 'OCEANSEA_1M:Foundation:CubeWerx', 'Oceans/Seas', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9765, 612, 102, '96', 'POLBNDA_1M:Foundation:CubeWerx', 'Administrative Areas', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9766, 612, 103, '96', 'POLBNDL_1M:Foundation:CubeWerx', 'Political Boundaries', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9767, 612, 104, '96', 'POLBNDP_1M:Foundation:CubeWerx', 'Political Boundary Point Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9768, 612, 105, '95', '', 'Data Quality', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9769, 612, 106, '105', 'DQLINE_TRANS_1M:Foundation:CubeWerx', 'Data Quality Line Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9770, 612, 107, '105', 'DQLINE_UTIL_1M:Foundation:CubeWerx', 'Data Quality Line Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9771, 612, 108, '95', '', 'Digital Terrain', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9772, 612, 109, '108', 'ETOPO2:Foundation:CubeWerx', 'Global 2 Minute Elevations', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9773, 612, 110, '108', 'GTOPO30:Foundation:CubeWerx', 'Global 30 Second Elevations', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9774, 612, 111, '108', 'RELIEF:Foundation:CubeWerx', 'Two Minute Shaded Relief', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9775, 612, 112, '95', '', 'Elevation', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9776, 612, 113, '112', 'CONTOURL_1M:Foundation:CubeWerx', 'Elevation Contours', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9777, 612, 114, '112', 'ELEVP_1M:Foundation:CubeWerx', 'Spot Elevations', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9778, 612, 115, '95', '', 'Hydrography', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9779, 612, 116, '115', 'AQUECANL_1M:Foundation:CubeWerx', 'Aqueducts/Canals/Flumes/Penstocks', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9780, 612, 117, '115', 'DANGERP_1M:Foundation:CubeWerx', 'Danger Point Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9781, 612, 118, '115', 'HYDROTXT_1M:Foundation:CubeWerx', 'Hydrography Coverage Text', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9782, 612, 119, '115', 'INWATERA_1M:Foundation:CubeWerx', 'Inland Water Areas', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9783, 612, 120, '115', 'MISCL_1M:Foundation:CubeWerx', 'Miscellaneous Line Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9784, 612, 121, '115', 'MISCP_1M:Foundation:CubeWerx', 'Miscellaneous Point Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9785, 612, 122, '115', 'WATRCRSL_1M:Foundation:CubeWerx', 'Water Courses', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9786, 612, 123, '95', '', 'Industry', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9787, 612, 124, '123', 'EXTRACTA_1M:Foundation:CubeWerx', 'Extraction Areas', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9788, 612, 125, '123', 'EXTRACTP_1M:Foundation:CubeWerx', 'Extraction Point Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9789, 612, 126, '123', 'FISHINDA_1M:Foundation:CubeWerx', 'Fish Hatcheries/Fish Farms', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9790, 612, 127, '123', 'INDTXT_1M:Foundation:CubeWerx', 'Industry Coverage Text', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9791, 612, 128, '123', 'MISINDP_1M:Foundation:CubeWerx', 'Miscellaneous Industry Point Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9792, 612, 129, '123', 'STORAGEP_1M:Foundation:CubeWerx', 'Storage Point Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9793, 612, 130, '95', '', 'Physiography', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9794, 612, 131, '130', 'GROUNDA_1M:Foundation:CubeWerx', 'Ground Surface Areas', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9795, 612, 132, '130', 'LANDICEA_1M:Foundation:CubeWerx', 'Snow/Ice Fields and Glaciers', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9796, 612, 133, '130', 'LNDFRML_1M:Foundation:CubeWerx', 'Landform Line Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9797, 612, 134, '130', 'PHYSTXT_1M:Foundation:CubeWerx', 'Physiography Coverage Text', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9798, 612, 135, '130', 'SEAICEA_1M:Foundation:CubeWerx', 'Sea Ice Areas', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9799, 612, 136, '95', '', 'Population', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9800, 612, 137, '136', 'BUILTUPA_1M:Foundation:CubeWerx', 'Built-Up Areas', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9801, 612, 138, '136', 'BUILTUPP_1M:Foundation:CubeWerx', 'Built-Up Area Points', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9802, 612, 139, '136', 'MISPOPA_1M:Foundation:CubeWerx', 'Miscellaneous Population Areas', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9803, 612, 140, '136', 'MISPOPP_1M:Foundation:CubeWerx', 'Miscellaneous Population Points', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9804, 612, 141, '136', 'POPTXT_1M:Foundation:CubeWerx', 'Population Coverage Text', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9805, 612, 142, '95', '', 'Transportation', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9806, 612, 143, '142', 'AEROFACP_1M:Foundation:CubeWerx', 'Airport Facilities Points', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9807, 612, 144, '142', 'DQLINE_TRANS_1M:Foundation:CubeWerx', 'Data Quality Line Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9808, 612, 145, '142', 'MISTRANL_1M:Foundation:CubeWerx', 'Miscellaneous Transportation Line Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9809, 612, 146, '142', 'RAILRDL_1M:Foundation:CubeWerx', 'Railroads', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9810, 612, 147, '142', 'ROADL_1M:Foundation:CubeWerx', 'Roads', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9811, 612, 148, '142', 'RRYARDP_1M:Foundation:CubeWerx', 'Railroad Yard Points', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9812, 612, 149, '142', 'TRAILL_1M:Foundation:CubeWerx', 'Trails and Tracks', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9813, 612, 150, '142', 'TRANSTRC_1M:Foundation:CubeWerx', 'Transportation Structures Points', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9814, 612, 151, '142', 'TRANSTRL_1M:Foundation:CubeWerx', 'Transportation Structures Lines', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9815, 612, 152, '142', 'TRANSTXT_1M:Foundation:CubeWerx', 'Transportation Coverage Text', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9816, 612, 153, '95', '', 'Utilities', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9817, 612, 154, '153', 'DQLINE_UTIL_1M:Foundation:CubeWerx', 'Data Quality Line Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9818, 612, 155, '153', 'PIPEL_1M:Foundation:CubeWerx', 'Pipelines', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9819, 612, 156, '153', 'UTILL_1M:Foundation:CubeWerx', 'Power Transmission/Telephone/Telegraph Lines', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9820, 612, 157, '153', 'UTILP_1M:Foundation:CubeWerx', 'Utility Point Features', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9821, 612, 158, '153', 'UTILTXT_1M:Foundation:CubeWerx', 'Utilities Coverage Text', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9822, 612, 159, '95', '', 'Vegetation', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9823, 612, 160, '159', 'CROPA_1M:Foundation:CubeWerx', 'Croplands', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9824, 612, 161, '159', 'GRASSA_1M:Foundation:CubeWerx', 'Grasslands', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9825, 612, 162, '159', 'SWAMPA_1M:Foundation:CubeWerx', 'Marshs/Swamps', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9826, 612, 163, '159', 'TREESA_1M:Foundation:CubeWerx', 'Trees', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9827, 612, 164, '159', 'TUNDRAA_1M:Foundation:CubeWerx', 'Tundra', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9828, 612, 165, '94', '', 'CubeWerx Inc.', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9829, 612, 166, '165', '', 'Shuttle Rader Topography Mission Data', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9830, 612, 167, '166', 'ONEARCSEC:SRTM:CubeWerx', 'One Arc Second SRTM', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9831, 612, 168, '166', 'THREEARCSEC:SRTM:CubeWerx', 'Three Arc Second SRTM', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9832, 612, 169, '94', '', 'CubeWerx Inc.', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9833, 612, 170, '169', '', 'Canadian Geology', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9834, 612, 171, '170', 'AGE_ROCK_TYPE_CA:GSC:CubeWerx', 'Canadian Age Rock Type', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9835, 612, 172, '170', 'FAULTS_CA:GSC:CubeWerx', 'Canadian Fault Lines', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9836, 612, 173, '169', '', 'World Geology', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9837, 612, 174, '173', 'AGE_ROCK_TYPE:GSC:CubeWerx', 'World Age Rock Type', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9838, 612, 175, '173', 'FAULTS:GSC:CubeWerx', 'World Fault Lines', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9839, 612, 176, '173', 'FELSIC_MAGMATIC:GSC:CubeWerx', 'Felsic Magmatic', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9840, 612, 177, '173', 'MAFIC_MAGMATIC:GSC:CubeWerx', 'Mafic Magmatic', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9841, 612, 178, '173', 'PRECAMBRIAN:GSC:CubeWerx', 'Precambrian', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9842, 612, 179, '0', '', 'World Map', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9843, 612, 180, '179', 'Bathymetry:DEMIS', 'Bathymetry', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9844, 612, 181, '179', 'Countries:DEMIS', 'Countries', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9845, 612, 182, '179', 'Topography:DEMIS', 'Topography', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9846, 612, 183, '179', 'Hillshading:DEMIS', 'Hillshading', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9847, 612, 184, '179', 'Builtup areas:DEMIS', 'Builtup areas', 1, 0, 2147483647, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9848, 612, 185, '179', 'Coastlines:DEMIS', 'Coastlines', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9849, 612, 186, '179', 'Waterbodies:DEMIS', 'Waterbodies', 1, 0, 2147483647, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9850, 612, 187, '179', 'Inundated:DEMIS', 'Inundated', 1, 0, 2147483647, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9851, 612, 188, '179', 'Rivers:DEMIS', 'Rivers', 1, 0, 2147483647, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9852, 612, 189, '179', 'Streams:DEMIS', 'Streams', 1, 0, 2147483647, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9853, 612, 190, '179', 'Railroads:DEMIS', 'Railroads', 1, 0, 2147483647, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9854, 612, 191, '179', 'Highways:DEMIS', 'Highways', 1, 0, 2147483647, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9855, 612, 192, '179', 'Roads:DEMIS', 'Roads', 1, 0, 2147483647, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9856, 612, 193, '179', 'Trails:DEMIS', 'Trails', 1, 0, 2147483647, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9857, 612, 194, '179', 'Borders:DEMIS', 'Borders', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9858, 612, 195, '179', 'Cities:DEMIS', 'Cities', 1, 0, 2147483647, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9859, 612, 196, '179', 'Settlements:DEMIS', 'Settlements', 1, 0, 2147483647, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9860, 612, 197, '179', 'Spot elevations:DEMIS', 'Spot elevations', 0, 0, 2147483647, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9861, 612, 198, '179', 'Airports:DEMIS', 'Airports', 1, 0, 2147483647, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9862, 612, 199, '179', 'Ocean features:DEMIS', 'Ocean features', 1, 0, 2147483647, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9863, 612, 200, '0', '', 'Spacemetric Image Server', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9864, 612, 201, '200', '', 'GLCF Satellite Images', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9865, 612, 202, '201', '', 'Landsat ETM Scenes', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9866, 612, 203, '202', 'LANDSAT_TM_GLCF_432:TEST', 'Landsat ETM Band 432 Scenes', 1, 2147483647, 2147483647, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9867, 612, 204, '202', 'LANDSAT_TM_GLCF_432_STRETCH:TEST', 'Landsat ETM Band 432 Scenes, Stretched', 1, 2147483647, 2147483647, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9868, 612, 205, '202', 'LANDSAT_TM_GLCF_742:TEST', 'Landsat ETM Band 742 Scenes', 1, 2147483647, 2147483647, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9869, 612, 206, '200', '', 'DMC Scenes', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9870, 612, 207, '206', 'DMC_QL:TEST', 'DMC Quicklooks', 1, 2147483647, 2147483647, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9871, 612, 208, '0', '', 'TEST2 (X)', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9872, 612, 209, '0', '', 'map annotations', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9873, 612, 210, '209', 'graticule', 'Lat/Lon Graticule', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9874, 612, 211, '209', 'crosshairs', 'Crosshairs', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9875, 613, 0, '', '', 'ArcIMS MapService', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9876, 613, 1, '0', 'Shaded Relief Imagery', 'Shaded Relief Imagery', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9877, 614, 0, '', '', 'ArcIMS Map Server', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9878, 614, 1, '0', '250K Topo Map', '250K Topo Map', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9879, 614, 2, '0', '100K Topo Map', '100K Topo Map', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9880, 614, 3, '0', '24K Topo Map', '24K Topo Map', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9881, 614, 4, '0', 'General Topo Map', 'General Topo Map', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9882, 614, 5, '0', 'Road', 'Road', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9883, 614, 6, '0', '24K Quad', '24K Quad', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9884, 614, 7, '0', '100K Quad', '100K Quad', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9885, 614, 8, '0', '250K Quad', '250K Quad', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9886, 614, 9, '0', 'County', 'County', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9887, 614, 10, '0', 'State', 'State', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9888, 614, 11, '0', 'City', 'City', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9889, 614, 12, '0', 'Geographic Name', 'Geographic Name', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9890, 615, 0, '', '', 'ArcIMS Map Server', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9891, 615, 1, '0', 'Population', 'Population', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9892, 615, 2, '0', 'Landuse', 'Landuse', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9893, 615, 3, '0', 'Countries', 'Countries', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9894, 615, 4, '0', 'Landsat images', 'Landsat images', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9895, 615, 5, '0', 'Watersheds', 'Watersheds', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9896, 615, 6, '0', 'Rivers', 'Rivers', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9897, 615, 7, '0', 'Ramsar sites (Polygons)', 'Ramsar sites (Polygons)', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9898, 615, 8, '0', 'Ramsar sites', 'Ramsar sites', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9899, 615, 9, '0', 'Ramsar sites (Points)', 'Ramsar sites (Points)', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9900, 615, 10, '0', 'Cities', 'Cities', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9901, 616, 0, '', '', 'GeoNovaSDE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9902, 616, 1, '0', '10k_Drainage_polygons', '10k_Drainage Polygons', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9903, 616, 2, '0', 'ST_POINT', 'ST_POINT', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9904, 616, 3, '0', 'WA_POINT', 'WA_POINT', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9905, 616, 4, '0', 'ST_LINE', 'ST_LINE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9906, 616, 5, '0', 'LF_POINT', 'LF_POINT', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9907, 616, 6, '0', 'UT_LINE', 'UT_LINE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9908, 616, 7, '0', 'LF_LINE', 'LF_LINE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9909, 616, 8, '0', 'RR_POINT', 'RR_POINT', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9910, 616, 9, '0', 'RR_LINE', 'RR_LINE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9911, 616, 10, '0', 'DA_POINT', 'DA_POINT', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9912, 616, 11, '0', 'DL_LINE', 'DL_LINE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9913, 616, 12, '0', 'DA_POLY', 'DA_POLY', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9914, 616, 13, '0', 'DA_LINE', 'DA_LINE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9915, 616, 14, '0', 'LC_POINT', 'LC_POINT', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9916, 616, 15, '0', 'LC_LINE', 'LC_LINE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9917, 616, 16, '0', 'UT_POINT', 'UT_POINT', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9918, 616, 17, '0', 'WA_LINE', 'WA_LINE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9919, 616, 18, '0', 'COAST', 'COAST', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9920, 616, 19, '0', 'ROADS', 'ROADS', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9921, 617, 0, '', '', 'Geobase_NRN_NewfoundlandAndLabrador_I_Detail', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9922, 617, 1, '0', 'NewfoundlandLabrador', 'Provincial Boundary', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9923, 617, 2, '0', 'Water', 'Water', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9924, 617, 3, '0', 'Highways', 'Highways', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9925, 617, 4, '0', 'highwaysMjrRoads', 'Highways and Major Roads', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9926, 617, 5, '0', 'allroads', 'All Roads', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9927, 617, 6, '0', 'FerrySeg', 'FERRYSEG', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9928, 617, 7, '0', 'Junction', 'JUNCTION', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9929, 617, 8, '0', 'BlkPassage', 'BLKPASSAGE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10028, 624, 0, '', '', 'gewstat', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10029, 624, 1, '0', 'Uebrige Gewaesser groesser 12 m Breite 3', 'Uebrige Gewaesser groesser 12 m Breite', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10030, 624, 2, '0', 'Uebrige Gewaesser kleiner 12 m Breite 2', 'Uebrige Gewaesser kleiner 12 m Breite', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10031, 624, 3, '0', 'Kanaele groesser 12 m Breite 2', 'Kanaele groesser 12 m Breite', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10032, 624, 4, '0', 'Kanaele kleiner 12m Breite', 'Kanaele kleiner 12 m Breite', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10033, 624, 5, '0', 'Unterirdisch verlaufende Gewaesser', 'Unterirdisch verlaufende Gewaesser', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10034, 624, 6, '0', 'Fliessgewaesser groesser 12 m Breite', 'Fliessgewaesser groesser 12 m Breite', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10035, 624, 7, '0', 'Fliessgewaesser kleiner 12 m Breite', 'Fliessgewaesser kleiner 12 m Breite', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10036, 624, 8, '0', 'St_Kanaele 1000 m', 'St_Kanaele 1000 m', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10037, 624, 9, '0', 'St_Rhein und Weser 1000 m', 'St_Rhein und Weser 1000 m', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10038, 624, 10, '0', 'St_Fliessgewaesser 1000 m', 'St_Fliessgewaesser 1000 m', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10039, 624, 11, '0', 'St_Kanaele 500 m', 'St_Kanaele 500 m', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10040, 624, 12, '0', 'St_Rhein und Weser 500 m', 'St_Rhein und Weser 500 m', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10041, 624, 13, '0', 'St_Fliessgewaesser 500 m', 'St_Fliessgewaesser 500 m', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10042, 624, 14, '0', 'St_Kanaele 100 m', 'St_Kanaele 100 m', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10043, 624, 15, '0', 'St_Rhein und Weser 100 m', 'St_Rhein und Weser 100 m', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10044, 624, 16, '0', 'St_Fliessgewaesser 100 m', 'St_Fliessgewaesser 100 m', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10045, 624, 17, '0', 'Stationierungslinie', 'Stationierungslinie', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10046, 624, 18, '0', 'Fluesse', 'Fluesse', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10047, 625, 0, '', 'DEMO', 'GMap WMS Demo Server', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10048, 625, 1, '0', 'bathymetry', 'Elevation/Bathymetry', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10049, 625, 2, '0', 'land_fn', 'Foreign Lands', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10050, 625, 3, '0', 'park', 'Parks', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10051, 625, 4, '0', 'drain_fn', 'Water', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10052, 625, 5, '0', 'drainage', 'Drainage', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10053, 625, 6, '0', 'prov_bound', 'Province', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10054, 625, 7, '0', 'fedlimit', 'Federal Limit', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10055, 625, 8, '0', 'rail', 'Railroads', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10056, 625, 9, '0', 'road', 'Roads', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10057, 625, 10, '0', 'popplace', 'Cities', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10058, 625, 11, '0', 'grid', 'Grid', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10106, 634, 0, '', 'Location', 'Point locations', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10107, 634, 1, '0', 'city_austral', 'Australasian Cities', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10108, 634, 2, '0', 'capital_aus', 'Australian Capital Cities', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10109, 634, 3, '0', 'town_aus', '          Some Australian towns', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10110, 634, 4, '0', 'wastewet', '          Wastewater artificial wetlands listed as', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10153, 637, 0, '', 'Bathymetry', 'MapServer WMS Demo', 0, 50000, 149999900, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10154, 637, 1, '0', 'etopo2', 'etopo2', 0, 50000, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10155, 637, 2, '0', 'ecbathy', 'ecbathy', 0, 50000, 10000000, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10156, 637, 3, '0', 'gom', 'gom', 0, 50000, 2000000, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10157, 637, 4, '0', 'bbay', 'bbay', 0, 50000, 1000000, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10158, 637, 5, '0', 'gomctr', 'gomctr', 0, 50000, 749999, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10159, 637, 6, '0', 'world_line_simp', 'world_line_simp', 0, 4999990, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10160, 637, 7, '0', 'world_line', 'world_line', 0, 0, 4999990, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10165, 640, 0, '', '', 'OnEarth Web Map Server', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10166, 640, 1, '0', 'global_mosaic', 'WMS Global Mosaic, pan sharpened', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10167, 640, 2, '0', 'global_mosaic_base', 'WMS Global Mosaic, not pan sharpened', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10168, 640, 3, '0', 'us_landsat_wgs84', 'CONUS mosaic of 1990 MRLC dataset', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10169, 640, 4, '0', 'us_overlays', 'Progressive US overlay map, white background', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10170, 640, 5, '0', 'us90_overlays', 'MRLC US mosaic with progressive overlay map', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10171, 640, 6, '0', 'daily_terra', 'Daily composite of MODIS-TERRA images', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10172, 640, 7, '0', 'daily_aqua', 'Daily composite of MODIS-AQUA images', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10173, 640, 8, '0', 'modis', 'Blue Marble, Global MODIS derived image', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10174, 640, 9, '0', 'huemapped_srtm', 'SRTM derived global elevation, 3 arc-second, hue m', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10175, 640, 10, '0', 'srtmplus', 'Global 1km elevation, seamless SRTM land elevation', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10176, 640, 11, '0', 'worldwind_dem', 'SRTM derived global elevation, 3 arc-second', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10177, 640, 12, '0', 'us_ned', 'United States elevation, 30m', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10178, 640, 13, '0', 'us_elevation', 'Digital Elevation Map of the United States, DTED d', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10179, 640, 14, '0', 'us_colordem', 'Digital Elevation Map of the United States, DTED d', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10194, 645, 0, '', '', 'ArcIMS MapService', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10195, 645, 1, '0', 'HDM:LANDMASS', 'Land Areas', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10196, 645, 2, '0', 'HDM:DFIRM_BFE', 'DFIRM Base Flood Elevations', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10197, 645, 3, '0', 'HDM:DFIRM_XSECTION', 'DFIRM Cross Sections', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10198, 645, 4, '0', 'HDM:DFIRM_FLD_AR', 'DFIRM Flood Hazard Areas', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10199, 645, 5, '0', 'HDM:Q3_COUNTYMAP', 'Flood Data Availability', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10200, 645, 6, '0', 'HDM:Q3_FLOOD', 'Q3 Flood Hazards', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10369, 648, 0, '', '', 'hangneigung', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10370, 648, 1, '0', 'hangneigung', 'Hangneigung', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10371, 648, 2, '0', 'Fliessgewaesser', 'Fliessgewaesser', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10415, 655, 0, '', 'SEACOOS Remotely-Sensed Imagery', 'SEACOOS Remotely-Sensed Imagery', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10416, 655, 1, '0', 'modis_ergb_low', 'MODIS Enhanced RGB, courtesy USF Institute for Mar', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10417, 655, 2, '0', 'modis_rgb_composite_low', 'MODIS Low Resolution RGB Composite, courtesy USF I', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10418, 655, 3, '0', 'modis_rgb_low', 'MODIS Low Resolution RGB, courtesy USF Institute f', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10419, 655, 4, '0', 'modis_rgb_hi_chesapeake_bay', 'MODIS High Resolution RGB, courtesy USF Institute', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10420, 655, 5, '0', 'modis_rgb_hi_florida_bay', 'MODIS High Resolution RGB, courtesy USF Institute', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10421, 655, 6, '0', 'modis_rgb_hi_miss_plume', 'MODIS High Resolution RGB, courtesy USF Institute', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10422, 655, 7, '0', 'modis_rgb_hi_suwannee_river', 'MODIS High Resolution RGB, courtesy USF Institute', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10423, 655, 8, '0', 'modis_rgb_hi_tampa_bay', 'MODIS High Resolution RGB, courtesy USF Institute', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10424, 655, 9, '0', 'oi_sst', 'Optimally Interpolated SST, courtesy USF Ocean Cir', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10425, 655, 10, '0', 'modis_sst', 'MODIS SST, courtesy USF Institute for Marine Remot', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10426, 655, 11, '0', 'avhrr_sst', 'AVHRR SST, courtesy USF Institute for Marine Remot', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10427, 655, 12, '0', 'modis_chl', 'MODIS Chl-A, courtesy USF Institute for Marine Rem', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10428, 655, 13, '0', 'jpl_sea_surface_height_composite', 'TBA', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10429, 655, 14, '0', 'tamu_level_III', 'Texas Mesonet Radar, courtesy Texas A and M Univer', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10430, 655, 15, '0', 'tamu_usrad', 'Texas Mesonet Radar, courtesy Texas A and M Univer', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10431, 655, 16, '0', 'surface_currents_radar', 'Surface currents (Radar) (EXPERIMENTAL), courtesy', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10432, 655, 17, '0', 'depth_averaged_currents', 'Depth-averaged currents (EXPERIMENTAL), courtesy U', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10433, 655, 18, '0', 'sea_surface_elevation', 'Sea surface elevation (EXPERIMENTAL), courtesy Uni', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10434, 655, 19, '0', 'opaque_legend_background', 'Opaque legend background', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10435, 655, 20, '0', 'modis_chl_legend_full_range', 'MODIS Chl-A Legend, courtesy USF Institute for Mar', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10436, 655, 21, '0', 'sst_legend_full_range', 'SST Legend, courtesy USF Institute for Marine Remo', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10437, 655, 22, '0', 'tamu_level_III_legend_full_range', 'Texas Mesonet Radar Legend, courtesy Texas A and M', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10438, 655, 23, '0', 'current_velocity_legend', 'Current velocity legend', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10439, 655, 24, '0', 'water_level_legend', 'Elevation legend', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10987, 670, 0, '', '', 'waldtyp', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10988, 670, 1, '0', 'Waldtyp', 'Waldtyp', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10989, 670, 2, '0', 'Waldtyp_50', 'Waldtyp_50', 0, 37494, 187472, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10990, 670, 3, '0', 'Waldtyp_Real', 'Waldtyp_Real', 0, 37494, 187472, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10991, 671, 0, '', '', 'wsg', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10992, 671, 1, '0', 'Trinkwasser Zone 1 punktfoermig', 'Trinkwasser Zone 1 punktfoermig', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10993, 671, 2, '0', 'Trinkwasserschutzgebiete', 'Trinkwasserschutzgebiete', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10994, 671, 3, '0', 'Heilquellen Zone 1 punktfoermig', 'Heilquellen Zone 1 punktfoermig', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10995, 671, 4, '0', 'Heilquellenschutzgebiete', 'Heilquellenschutzgebiete', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11541, 706, 0, '', '', 'WA_Atlas_GN_WMS', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11542, 706, 1, '0', 'Australia Base Map', 'Australia Base Map', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11543, 706, 2, '0', 'WA Base Map', 'WA Base Map', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11544, 706, 3, '0', 'WA Base Map - Detailed', 'WA Base Map - Detailed', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11545, 706, 4, '0', 'Bathymetry - Above Chart Datum', 'Bathymetry - Above Chart Datum', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11546, 706, 5, '0', 'State Geological Polygons', 'State Geological Polygons', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11547, 706, 6, '0', 'Beards Vegetation', 'Beards Vegetation', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11629, 717, 0, '', '', 'forstamtsgr', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11630, 717, 1, '0', '0', 'Forstamtsgrenzen', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13667, 739, 0, '', '', 'Eusoils_Ex', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13668, 739, 1, '0', '55', 'ERODI. Soil erodibility class', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13669, 739, 2, '0', '70', 'TXEROD. Textural factor of soil erodibility', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13670, 739, 3, '0', '48', 'CRUSTING. Soil crusting class', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13671, 739, 4, '0', '64', 'PHYSCHIM.Physi-chemical factor of soil', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13672, 739, 5, '0', '71', 'TXTCRUST. Textural factor of soil crusting', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13673, 739, 6, '0', '41', 'ATC. Accumulated temperature class', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13674, 739, 7, '0', '72', 'USE. Regrouped land use', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13675, 739, 8, '0', '39', 'AGLIM2NNI. 2nd Limitation to agricultural use', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13676, 739, 9, '0', '38', 'AGLIM1NNI. Dom.Limitation to agricultural use', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13677, 739, 10, '0', '53', 'EAWC_SUB. Subsoil easily avail.water capac.', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13678, 739, 11, '0', '54', 'EAWC_TOP. Topsoil easily avail.water capac.', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13679, 739, 12, '0', '42', 'AWC_SUB. Subsoil avail.water capacity', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13680, 739, 13, '0', '43', 'AWC_TOP. Topsoil avail.water capacity', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13681, 739, 14, '0', '56', 'HG. Hydro-geological class', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13682, 739, 15, '0', '51', 'DIMP. Depth to an impermeable layer', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13683, 739, 16, '0', '49', 'DGH. Depth to a gleyed horizon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13684, 739, 17, '0', '65', 'PMH. Parent material hydro-geological', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13685, 739, 18, '0', '61', 'PD_SUB. Subsoil Packing Density', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13686, 739, 19, '0', '62', 'PD_TOP. Topsoil packing density', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13687, 739, 20, '0', '66', 'STR_SUB. Subsoil structure', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13688, 739, 21, '0', '67', 'STR_TOP. Topsoil structure', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13689, 739, 22, '0', '68', 'TD. Rule inferred subsoil texture', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13690, 739, 23, '0', '73', 'VS. Volume of stones', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13691, 739, 24, '0', '52', 'DR. Depth to rock', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13692, 739, 25, '0', '44', 'BS_SUB. Base Subsoil Saturation', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13693, 739, 26, '0', '45', 'BS_TOP. Base Topsoil Saturation', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13694, 739, 27, '0', '46', 'CEC_SUB. Subsoil Cation Exch.Capacity', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13695, 739, 28, '0', '47', 'CEC_TOP. Topsoil Cation Exch.Capacity', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13696, 739, 29, '0', '58', 'MIN_SUB. Subsoil Mineralogy', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13697, 739, 30, '0', '59', 'MIN_TOP. Topsoil Mineralogy', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13698, 739, 31, '0', '57', 'MIN. Profile Mineralogy', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13699, 739, 32, '0', '50', 'DIFF. Soil Profile Differentiation', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13700, 739, 33, '0', '40', 'ALT. Elevation', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13701, 739, 34, '0', '63', 'PEAT', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13702, 739, 35, '0', '60', 'OC_TOP. Topsoil Organic Carbon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13703, 739, 36, '0', '69', 'TEXT. Dominant Surface Textural', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13704, 739, 37, '0', '21', 'SLOPESE. Secondary Slope class', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13705, 739, 38, '0', '20', 'SLOPEDO. Dominant Slope Class', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13706, 739, 39, '0', '37', 'ZMIN. Minimun elevetaion above sea', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13707, 739, 40, '0', '36', 'ZMAX. Maximun elevetaion above sea', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13708, 739, 41, '0', '30', 'WM2. Type of Water Manag.System', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13709, 739, 42, '0', '29', 'WM1. Presence of Water Manag.System', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13710, 739, 43, '0', '31', 'WR. Annual average soil water regime', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13711, 739, 44, '0', '10', 'IL. Impermeable Layer', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13712, 739, 45, '0', '19', 'ROO. Depth Class of obstacle to roots', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13713, 739, 46, '0', '2', 'AGLIM2. Sec.limitation to agr.use', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13714, 739, 47, '0', '1', 'AGLIM1. Dom.limitation to agr.use', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13715, 739, 48, '0', '28', 'USESE. Secondary Land Use', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13716, 739, 49, '0', '27', 'USEDO. Dominant Land Use', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13717, 739, 50, '0', '6', 'FAO85LV3. 3rd Level Soil Code 1974 FAO', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13718, 739, 51, '0', '5', 'FAO85LV2. 2nd Level Soil Code 1974 FAO', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13719, 739, 52, '0', '4', 'FAO85LV1. Soil Major Group 1974 FAO', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13720, 739, 53, '0', '3', 'FAO85FU. Full Soil Code 1974 FAO', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13721, 739, 54, '0', '9', 'FAO90LV2. 2nd level Soil Code 1990 FAO', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13722, 739, 55, '0', '8', 'FAO90LV1. Soil Major Group 1990 FAO', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13723, 739, 56, '0', '7', 'FAO90FU. Full Soil Code 1990 FAO', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13724, 739, 57, '0', '18', 'PARMASE3. 3rd level Sec.Par.Material', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13725, 739, 58, '0', '17', 'PARMASE2. 2nd level Sec.Par.Material', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13726, 739, 59, '0', '16', 'PARMASE1. Major Group Sec.Par.Material', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13727, 739, 60, '0', '15', 'PARMASE. Secondary Parent Material', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13728, 739, 61, '0', '14', 'PARMADO3. 3rd level Dom.Par.Material', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13729, 739, 62, '0', '13', 'PARMADO2. 2nd level Dom.Par.Material', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13730, 739, 63, '0', '12', 'PARMADO1. Major Group Dom.Par.Material', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13731, 739, 64, '0', '11', 'PARMADO. Dominant Parent Material', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13732, 739, 65, '0', '26', 'TXSUBSE. Sec.Sub-surface text.class', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13733, 739, 66, '0', '25', 'TXSUBDO. Dom.Sub-surface text.class', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13734, 739, 67, '0', '22', 'TXDEPCHG. Depth class to a text.change', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13735, 739, 68, '0', '24', 'TXSRFSE. Sec.surface text.class', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13736, 739, 69, '0', '23', 'TXSRFDO. Dom.surface text.class', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13737, 739, 70, '0', '33', 'WRBADJ2. 2nd Soil Adjective Code', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13738, 739, 71, '0', '32', 'WRBADJ1. First Soil Adjective Code', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13739, 739, 72, '0', '35', 'WRBLV1. Soil reference group', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13740, 739, 73, '0', '34', 'WRBFU. Full soil Code', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13741, 739, 74, '0', '97', 'Eurasia Lakes-Inland Waters', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13742, 739, 75, '0', '98', 'European Cities', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13743, 739, 76, '0', '0', 'Country Boundaries', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13744, 739, 77, '0', '99', 'Soil Polygon Outlines', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13751, 86, 0, '', 'World_map', 'World Map', 0, 1, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13752, 86, 1, '0', 'Countries', 'Countries', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13753, 86, 2, '0', 'Countrynames', 'Countrynames', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13754, 86, 3, '0', 'Citypoints', 'Citypoints', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13755, 86, 4, '0', 'City', 'Citynames', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13775, 101, 0, '', 'UMN_Mapserver', 'UMN Mapserver', 0, 1, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13776, 101, 1, '0', 'UMN_USER', 'UMN User', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13777, 101, 2, '0', 'UMN_USER_NAMES', 'UMN Info', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19110, 902, 0, '', 'Brandenburg', 'DNM 100/2', 0, 25001, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19111, 902, 1, '0', 'kreis', 'Landkreise und kreisfreie Städte', 1, 25001, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19090, 900, 0, '', 'benin2', 'Pendjari National Parc', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19091, 900, 1, '0', 'zoneseri', 'Zone Seri', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19092, 900, 2, '0', 'zoneest', 'Zone Est', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19093, 900, 3, '0', 'zonepnp', 'Zone Pnp', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19094, 900, 4, '0', 'zonezck', 'Zone Zck', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19095, 900, 5, '0', 'zonezcp', 'Zone Zcp', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19096, 900, 6, '0', 'ldcpendjari', 'Limite du Complexe pendjari', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19097, 900, 7, '0', 'maresextension', 'Mares Extension', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19098, 900, 8, '0', 'piste1', 'Piste 1', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19099, 900, 9, '0', 'pistepodiega', 'Piste podiéga', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19100, 900, 10, '0', 'agglom', 'Agglomeration Areas', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14083, 764, 1, '0', 'flur', 'Flur', 1, 50000, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14084, 764, 2, '0', 'gema', 'Gemarkung', 1, 50000, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14085, 764, 3, '0', 'geme', 'Gemeinde', 1, 50000, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14087, 764, 5, '0', 'kreis', 'Landkreise', 1, 50000, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19101, 900, 11, '0', 'coursdeauperm', 'Cours deau permanent', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19102, 900, 12, '0', 'cCoursdeau2003', 'Cours d eau 2003', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19103, 900, 13, '0', 'coursdeautemp', 'Cours d eau temporaire', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19104, 900, 14, '0', 'escarpement', 'Escarpements', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19105, 900, 15, '0', 'mar', 'Mares', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19112, 902, 2, '0', 'wald', 'Wald', 0, 25001, 150000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19113, 902, 3, '0', 'ozen', 'Oberzentren', 0, 25001, 2000000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19114, 902, 4, '0', 'mzen', 'Mittelzentren', 0, 25001, 600000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19115, 902, 5, '0', 'uzen', 'Unterzentren', 0, 25001, 200000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19116, 902, 6, '0', 'lwas', 'Flüsse und Kanäle', 0, 25001, 150000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14104, 767, 0, '', 'SLUBFURT', 'SLUBFURT', 0, 500, 250001, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14105, 767, 1, '0', 'Mentalscape', 'Mentalscape', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14106, 767, 2, '0', 'Districts', 'Districts', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14107, 767, 3, '0', 'Odra', 'Odra', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14108, 767, 4, '0', 'Paths', 'Paths', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14109, 767, 5, '0', 'Edges', 'Edges', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14110, 767, 6, '0', 'Nodes', 'Nodes', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14111, 767, 7, '0', 'Landmarks', 'Landmarks', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14112, 767, 8, '0', 'CityWall', 'CityWall', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14113, 767, 9, '0', 'HotSpots', 'HotSpots', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14114, 767, 10, '0', 'HotSpots-2', 'HotSpots-2', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14115, 767, 11, '0', 'SDE-W', 'SDE-W', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19117, 902, 7, '0', 'fwas', 'Seen', 0, 25001, 250001, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19118, 902, 8, '0', 'ebahn', 'Eisenbahnen', 0, 25001, 250001, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19119, 902, 9, '0', 'kstr', 'Kreisstraßen', 0, 25001, 100000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19120, 902, 10, '0', 'lstr', 'Landesstraßen', 0, 25001, 250001, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19121, 902, 11, '0', 'bstr', 'Bundesstraßen', 0, 25001, 749999, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19122, 902, 12, '0', 'astr', 'Autobahnen', 0, 25001, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19123, 902, 13, '0', 'nfwas', 'Namen der Seen', 0, 25001, 100000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19124, 902, 14, '0', 'kfz', 'Kfz-Zeichen', 0, 2000000, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19130, 903, 5, '0', 'lwas', 'Flüsse und Kanäle', 0, 1000, 50000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14177, 777, 0, '', 'Africa', 'Lieu / Locations', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14178, 777, 1, '0', 'adminareas', 'Pays / Countries', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14179, 777, 2, '0', 'provinceboundaries', 'D&#233;part./ Provinces', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14180, 777, 3, '0', 'populateplace', 'Villes / Towns', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19131, 903, 6, '0', 'fwas', 'Seen, Teiche', 0, 1000, 50000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19132, 903, 7, '0', 'kgrnz', 'Kreisgrenze', 0, 1000, 50000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19133, 903, 8, '0', 'flug', 'Internationale Flughäfen', 0, 1000, 29999, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19134, 903, 9, '0', 'ebahn', 'Eisenbahnverbindungen', 0, 1000, 50000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19135, 903, 10, '0', 'str', 'Straßen', 0, 1000, 50000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19136, 903, 11, '0', 'haus', 'Gebäude', 0, 1000, 50000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19137, 903, 12, '0', 'nfwas', 'Namen der Seen, Teiche', 0, 1000, 50000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19138, 904, 0, '', 'Brandenburg', 'DNM 250/2', 0, 25001, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19139, 904, 1, '0', 'kreis', 'Landkreise und kreisfreie Städte', 1, 200000, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19140, 904, 2, '0', 'orte', 'Zentren', 0, 200000, 1000000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19141, 904, 3, '0', 'korte', 'Orte', 0, 200000, 749999, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19142, 904, 4, '0', 'lwas', 'Flüsse und Kanäle', 0, 200000, 749999, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19143, 904, 5, '0', 'fwas', 'Seen', 0, 200000, 749999, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19144, 904, 6, '0', 'ebahn', 'Eisenbahnen', 0, 200000, 749999, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19145, 904, 7, '0', 'lstr', 'Landesstraßen', 0, 200000, 400000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14197, 779, 0, '', 'Ruanda24', 'Ruanda', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14198, 779, 1, '0', 'Countries', 'Countries', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14199, 779, 2, '1', 'Countries', 'Country Names', 0, 1000000, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14200, 779, 3, '0', 'Country', 'Country Names', 0, 1000000, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14201, 779, 4, '0', 'Cities', 'Cities', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14202, 779, 5, '4', 'Cities', 'Cities', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14203, 779, 6, '0', 'City', 'City Names', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14204, 779, 7, '0', 'Landsat', 'Sat-Image', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14205, 779, 8, '0', 'Dry Savannah', 'Dry Savannah', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14206, 779, 9, '8', 'Dry Savannah', 'Ruanda2', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14207, 779, 10, '0', 'Swamps', 'Swamps', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14208, 779, 11, '10', 'Swamps', 'Ruanda2', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14209, 779, 12, '0', 'Lakes', 'Lakes', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14210, 779, 13, '12', 'Lakes', 'Lakes', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14211, 779, 14, '0', 'Lake Names', 'Lake Names', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14212, 779, 15, '0', 'Dry Swamp', 'Dry Swamp', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14213, 779, 16, '15', 'Dry Swamp', 'Ruanda2', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14214, 779, 17, '0', 'Forests', 'Forests', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14215, 779, 18, '17', 'Forests', 'Ruanda2', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14216, 779, 19, '0', 'Islands', 'Islands', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14217, 779, 20, '19', 'Islands', 'Ruanda2', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14218, 779, 21, '0', 'Valleys', 'Valleys', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14219, 779, 22, '21', 'Valleys', 'Ruanda2', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14220, 779, 23, '0', 'Vegetation.shp', 'Vegetation', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14221, 779, 24, '0', 'Akagera-river', 'Akagera-river', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14222, 779, 25, '24', 'Akagera-river', 'Ruanda2', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14223, 779, 26, '0', 'Parc Limit', 'Parc Limit', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14224, 779, 27, '26', 'Parc Limit', 'Parc Limit', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14225, 779, 28, '0', 'Lanes', 'Lanes', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14226, 779, 29, '28', 'Lanes', 'Ruanda2', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14227, 779, 30, '0', 'Infrastructure', 'Infrastructure', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14228, 779, 31, '0', 'Places', 'Places', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14251, 785, 0, '', '', 'dtk200_500_1000_a10_gk3_wms', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14252, 785, 1, '0', 'DTK200-V', 'Digitale Topographische Karte 1:200.000', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14253, 785, 2, '0', 'DTK500-V', 'Digitale Topographische Karte 1:500.000', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14254, 785, 3, '0', 'DTK1000', 'Digitale Topographische Karte 1:1.000.000', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14255, 786, 0, '', 'MS', 'Luftbild', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14256, 786, 1, '0', 'ortho', 'Luftbild', 0, 1, 125000, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14257, 787, 0, '', '', 'OGC-Dienst der Bayerischen Vermessungsverwaltung', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14258, 787, 1, '0', 'DOP', 'DOP', 0, 20, 400880, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14259, 787, 2, '0', 'TK50', 'TK50', 0, 20, 80176, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14260, 787, 3, '0', 'UK500', 'UK500', 0, 20, 801759, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14261, 788, 0, '', 'DOP', 'Digitale Orthophotos mit einer reduzierten Bodenau', 0, 10000, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14262, 788, 1, '0', 'dop25', 'DOP 25m', 0, 50000, 2000000, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14263, 788, 2, '0', 'dop5', 'DOP 5m', 0, 10000, 50000, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14264, 789, 0, '', '', 'Rasterdaten_tk100_tk50', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14265, 789, 1, '0', 'UEB', 'Uebersicht Sachsen', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14266, 789, 2, '0', 'tk100', 'Topog. Karte 1:100000', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14267, 789, 3, '2', 'tk100s', 'tk100-Schriften', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14268, 789, 4, '2', 'tk100w', 'tk100-Gewaesser', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14269, 789, 5, '2', 'tk100g', 'tk100-Grundriss', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14270, 789, 6, '2', 'tk100i', 'tk100-Hoehenlinien', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14271, 789, 7, '2', 'tk100v', 'tk100-Vegetation', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14272, 789, 8, '0', 'tk50', 'Topog. Karte 1:50000', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14273, 789, 9, '8', 'tk50w', 'tk50-Gewaesser', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14274, 789, 10, '8', 'tk50g', 'tk50-Grundriss', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14275, 789, 11, '8', 'tk50i', 'tk50-Hoehenlinien', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14276, 789, 12, '8', 'tk50v', 'tk50-Vegetation', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14277, 790, 0, '', '', 'LGN - WMS', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14278, 790, 1, '0', 'DUEKN5000', 'Uebersichtskarte 1:5000000', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14279, 790, 2, '0', 'DUEKN1000', 'Uebersichtskarte 1:1000000', 0, 0, 847059, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14280, 790, 3, '0', 'DUEKN500', 'Uebersichtskarte 1:500000', 0, 0, 795580, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14281, 790, 4, '0', 'TK100', 'Topographische Karte 1:100000', 0, 0, 423530, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14287, 792, 0, '', '', 'TKVV', 0, 200, 200440, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14288, 792, 1, '0', 'Thueringer_Orthofotos', 'Thueringer_Orthofotos', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14289, 792, 2, '1', 'Orthophotos_TH-2m', 'Orthophotos_TH-2m', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14290, 792, 3, '0', 'TK50', 'TK50', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14291, 792, 4, '3', 'Top.Karte_50_gesamt', 'Top.Karte_50_gesamt', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14292, 792, 5, '3', 'Grundriss', 'Grundriss', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14293, 792, 6, '3', 'Gewaesser', 'Gewaesser', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14294, 792, 7, '3', 'Hoehenschichten', 'Hoehenschichten', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14295, 792, 8, '3', 'Strassen', 'Strassen', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14296, 792, 9, '3', 'Wald', 'Wald', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14297, 793, 0, '', '', 'OGC-Dienst des Hessischen Landesvermessungsamtes', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14298, 793, 1, '0', 'ATKIS50', 'ATKIS50', 0, 601, 50110, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14299, 793, 2, '0', 'ATKIS100', 'ATKIS100', 0, 1203, 150330, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14300, 793, 3, '0', 'DOP2SW', 'DOP2SW', 0, 40088, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14342, 797, 1, '0', 'flur', 'Flur', 1, 50000, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14343, 797, 2, '0', 'gema', 'Gemarkung', 1, 50000, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14344, 797, 3, '0', 'geme', 'Gemeinde', 1, 50000, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14346, 797, 5, '0', 'kreis', 'Landkreise', 1, 50000, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14360, 799, 0, '', 'DOP', 'Digitale Orthophotos mit einer reduzierten Bodenau', 0, 10000, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14361, 799, 1, '0', 'dop25', 'DOP 25m', 0, 50000, 2000000, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14362, 799, 2, '0', 'dop5', 'DOP 5m', 0, 10000, 50000, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14363, 800, 0, '', '', 'WMS', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14364, 800, 1, '0', 'doq', '1991 doq', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14365, 800, 2, '0', 'fsa', '2003 fsa', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14366, 800, 3, '0', 'metro', '2004 NGA', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14370, 824, 0, '', '', 'ECW Images', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14371, 824, 1, '0', '/l7ecw_stretched/orthol7_20123xs190600.ecw', 'orthol7_20123xs190600.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14372, 824, 2, '0', '/l7ecw_stretched/orthol7_20124xs190600.ecw', 'orthol7_20124xs190600.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14373, 824, 3, '0', '/l7ecw_stretched/orthol7_20125xs190600.ecw', 'orthol7_20125xs190600.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14374, 824, 4, '0', '/l7ecw_stretched/orthol7_20222xs120501.ecw', 'orthol7_20222xs120501.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14375, 824, 5, '0', '/l7ecw_stretched/orthol7_20223xs120501.ecw', 'orthol7_20223xs120501.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14376, 824, 6, '0', '/l7ecw_stretched/orthol7_20224xs120501.ecw', 'orthol7_20224xs120501.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14377, 824, 7, '0', '/l7ecw_stretched/orthol7_20225xs120501.ecw', 'orthol7_20225xs120501.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14378, 824, 8, '0', '/l7ecw_stretched/orthol7_20323xs170600.ecw', 'orthol7_20323xs170600.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14379, 824, 9, '0', '/l7ecw_stretched/orthol7_20324xs170600.ecw', 'orthol7_20324xs170600.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14380, 824, 10, '0', '/l7ecw_stretched/orthol7_20325xs300400.ecw', 'orthol7_20325xs300400.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14381, 824, 11, '0', '/l7ecw_stretched/orthol7_20421xs070500.ecw', 'orthol7_20421xs070500.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14382, 824, 12, '0', '/l7ecw_stretched/orthol7_20422xs070500.ecw', 'orthol7_20422xs070500.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14383, 824, 13, '0', '/l7ecw_stretched/orthol7_20423xs100999.ecw', 'orthol7_20423xs100999.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14384, 824, 14, '0', '/l7ecw_stretched/orthol7_20424xs240799.ecw', 'orthol7_20424xs240799.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14385, 824, 15, '0', '/l7ecw_stretched/orthol7_20425xs240799.ecw', 'orthol7_20425xs240799.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14386, 824, 16, '0', '/l7ecw_stretched/orthol7_20520xs170700.ecw', 'orthol7_20520xs170700.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14387, 824, 17, '0', '/l7ecw_stretched/orthol7_20521xs170700.ecw', 'orthol7_20521xs170700.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14388, 824, 18, '0', '/l7ecw_stretched/orthol7_20522xs170700.ecw', 'orthol7_20522xs170700.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14389, 824, 19, '0', '/l7ecw_stretched/orthol7_20619xs180300.ecw', 'orthol7_20619xs180300.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14390, 824, 20, '0', '/l7ecw_stretched/orthol7_20620xs050500.ecw', 'orthol7_20620xs050500.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14391, 824, 21, '0', '/l7ecw_stretched/orthol7_20621xs250800.ecw', 'orthol7_20621xs250800.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14392, 824, 22, '0', '/l7ecw_stretched/orthol7_20622xs240501.ecw', 'orthol7_20622xs240501.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14393, 824, 23, '0', '/l7ecw_stretched/orthol7_20719xs290799.ecw', 'orthol7_20719xs290799.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14394, 824, 24, '0', '/l7ecw_stretched/orthol7_20720xs120500.ecw', 'orthol7_20720xs120500.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14395, 824, 25, '0', '/landmap/ls5/stif/ecw/ortholandsat5_201_23.ecw', 'ortholandsat5_201_23.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14396, 824, 26, '0', '/landmap/ls5/stif/ecw/ortholandsat5_201_24.ecw', 'ortholandsat5_201_24.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14397, 824, 27, '0', '/landmap/ls5/stif/ecw/ortholandsat5_202_22.ecw', 'ortholandsat5_202_22.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14398, 824, 28, '0', '/landmap/ls5/stif/ecw/ortholandsat5_202_23.ecw', 'ortholandsat5_202_23.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14399, 824, 29, '0', '/landmap/ls5/stif/ecw/ortholandsat5_202_24.ecw', 'ortholandsat5_202_24.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14400, 824, 30, '0', '/landmap/ls5/stif/ecw/ortholandsat5_202_25.ecw', 'ortholandsat5_202_25.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14401, 824, 31, '0', '/landmap/ls5/stif/ecw/ortholandsat5_203_22.ecw', 'ortholandsat5_203_22.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14402, 824, 32, '0', '/landmap/ls5/stif/ecw/ortholandsat5_203_23.ecw', 'ortholandsat5_203_23.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14403, 824, 33, '0', '/landmap/ls5/stif/ecw/ortholandsat5_203_24.ecw', 'ortholandsat5_203_24.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14404, 824, 34, '0', '/landmap/ls5/stif/ecw/ortholandsat5_203_25.ecw', 'ortholandsat5_203_25.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14405, 824, 35, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_20q1.ecw', 'ortholandsat5_204_20q1.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14406, 824, 36, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_20q3.ecw', 'ortholandsat5_204_20q3.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14407, 824, 37, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_21.ecw', 'ortholandsat5_204_21.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14408, 824, 38, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_22.ecw', 'ortholandsat5_204_22.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14409, 824, 39, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_23.ecw', 'ortholandsat5_204_23.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14410, 824, 40, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_24.ecw', 'ortholandsat5_204_24.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14411, 824, 41, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_25.ecw', 'ortholandsat5_204_25.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14412, 824, 42, '0', '/landmap/ls5/stif/ecw/ortholandsat5_205_18q1.ecw', 'ortholandsat5_205_18q1.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14413, 824, 43, '0', '/landmap/ls5/stif/ecw/ortholandsat5_205_18q2.ecw', 'ortholandsat5_205_18q2.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14414, 824, 44, '0', '/landmap/ls5/stif/ecw/ortholandsat5_205_20.ecw', 'ortholandsat5_205_20.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14415, 824, 45, '0', '/landmap/ls5/stif/ecw/ortholandsat5_205_21.ecw', 'ortholandsat5_205_21.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14416, 824, 46, '0', '/landmap/ls5/stif/ecw/ortholandsat5_205_22.ecw', 'ortholandsat5_205_22.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14417, 824, 47, '0', '/landmap/ls5/stif/ecw/ortholandsat5_206_18.ecw', 'ortholandsat5_206_18.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14418, 824, 48, '0', '/landmap/ls5/stif/ecw/ortholandsat5_206_19.ecw', 'ortholandsat5_206_19.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14419, 824, 49, '0', '/landmap/ls5/stif/ecw/ortholandsat5_206_20.ecw', 'ortholandsat5_206_20.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14420, 824, 50, '0', '/landmap/ls5/stif/ecw/ortholandsat5_206_21.ecw', 'ortholandsat5_206_21.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14421, 824, 51, '0', '/landmap/ls5/stif/ecw/ortholandsat5_206_22.ecw', 'ortholandsat5_206_22.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14422, 824, 52, '0', '/landmap/ls5/stif/ecw/ortholandsat5_207_20.ecw', 'ortholandsat5_207_20.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14423, 824, 53, '0', '/landmap/ls5/stif/ecw/ortholandsat5_207_21.ecw', 'ortholandsat5_207_21.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14424, 824, 54, '0', '/landmap/ls5/stif/ecw/ortholandsat5_207_22.ecw', 'ortholandsat5_207_22.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14425, 824, 55, '0', '/landmap/ls5/stif/ecw/ortholandsat5_208_19.ecw', 'ortholandsat5_208_19.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14426, 824, 56, '0', '/landmap/ls5/stif/ecw/ortholandsat5_208_20.ecw', 'ortholandsat5_208_20.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14427, 824, 57, '0', '/landmap/mosaics/landsat/hs.ecw', 'hs.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14428, 824, 58, '0', '/landmap/mosaics/landsat/hs2.ecw', 'hs2.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14429, 824, 59, '0', '/landmap/mosaics/landsat/hs3.ecw', 'hs3.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14430, 824, 60, '0', '/landmap/mosaics/landsat/l5mosaic.ecw', 'l5mosaic.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14431, 824, 61, '0', '/landmap/mosaics/landsat/l5mosaicb742.ecw', 'l5mosaicb742.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14432, 824, 62, '0', '/landmap/mosaics/landsat/l5mosaic_geodetic.ecw', 'l5mosaic_geodetic.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14433, 824, 63, '0', '/landmap/mosaics/landsat/l5mosaic_geodetic1.ecw', 'l5mosaic_geodetic1.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14434, 824, 64, '0', '/landmap/mosaics/landsat/l5mosaic_UTM.ecw', 'l5mosaic_UTM.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14435, 824, 65, '0', '/landmap/mosaics/landsat/l7b123.ecw', 'l7b123.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14436, 824, 66, '0', '/landmap/mosaics/landsat/l7bpan.ecw', 'l7bpan.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14437, 824, 67, '0', '/landmap/mosaics/landsat/l7bpan_s.ecw', 'l7bpan_s.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14438, 824, 68, '0', '/landmap/mosaics/landsat/l7bpan_s_geo.becw.ecw', 'l7bpan_s_geo.becw.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14439, 824, 69, '0', '/landmap/mosaics/landsat/l7bpan_s_geo.ecw', 'l7bpan_s_geo.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14440, 824, 70, '0', '/landmap/mosaics/landsat/landsat7m25.ecw', 'landsat7m25.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14441, 824, 71, '0', '/landmap/mosaics/landsat/landsat7m25r.ecw', 'landsat7m25r.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14442, 824, 72, '0', '/landmap/mosaics/landsat/landsat7m25_123.ecw', 'landsat7m25_123.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14443, 824, 73, '0', '/landmap/mosaics/landsat/landsat_mosaic_15m.ecw', 'landsat_mosaic_15m.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14444, 824, 74, '0', '/landmap/mosaics/spot/orthospot13_231.ecw', 'orthospot13_231.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14445, 824, 75, '0', '/landmap/mosaics/spot/orthospot13_232.ecw', 'orthospot13_232.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14446, 824, 76, '0', '/landmap/mosaics/spot/orthospot13_233.ecw', 'orthospot13_233.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14447, 824, 77, '0', '/landmap/mosaics/spot/orthospot13_234.ecw', 'orthospot13_234.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14448, 824, 78, '0', '/landmap/mosaics/spot/orthospot13_235.ecw', 'orthospot13_235.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14449, 824, 79, '0', '/landmap/mosaics/spot/orthospot14_230.ecw', 'orthospot14_230.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14450, 824, 80, '0', '/landmap/mosaics/spot/orthospot14_231.ecw', 'orthospot14_231.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14451, 824, 81, '0', '/landmap/mosaics/spot/orthospot14_232.ecw', 'orthospot14_232.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14452, 824, 82, '0', '/landmap/mosaics/spot/orthospot14_232_ecw.ecw', 'orthospot14_232_ecw.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14453, 824, 83, '0', '/landmap/mosaics/spot/orthospot14_233.ecw', 'orthospot14_233.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14454, 824, 84, '0', '/landmap/mosaics/spot/orthospot14_234.ecw', 'orthospot14_234.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14455, 824, 85, '0', '/landmap/mosaics/spot/orthospot14_235.ecw', 'orthospot14_235.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14456, 824, 86, '0', '/landmap/mosaics/spot/orthospot14_236.ecw', 'orthospot14_236.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14457, 824, 87, '0', '/landmap/mosaics/spot/orthospot17_230.ecw', 'orthospot17_230.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14458, 824, 88, '0', '/landmap/mosaics/spot/orthospot17_231.ecw', 'orthospot17_231.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14459, 824, 89, '0', '/landmap/mosaics/spot/orthospot17_232.ecw', 'orthospot17_232.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14460, 824, 90, '0', '/landmap/mosaics/spot/orthospot17_233.ecw', 'orthospot17_233.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14461, 824, 91, '0', '/landmap/mosaics/spot/orthospot17_234.ecw', 'orthospot17_234.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14462, 824, 92, '0', '/landmap/mosaics/spot/orthospot17_235.ecw', 'orthospot17_235.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14463, 824, 93, '0', '/landmap/mosaics/spot/orthospot17_236.ecw', 'orthospot17_236.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14464, 824, 94, '0', '/landmap/mosaics/spot/orthospot17_237.ecw', 'orthospot17_237.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14465, 824, 95, '0', '/landmap/mosaics/spot/orthospot17_238.ecw', 'orthospot17_238.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14466, 824, 96, '0', '/landmap/mosaics/spot/orthospot17_239.ecw', 'orthospot17_239.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14467, 824, 97, '0', '/landmap/mosaics/spot/orthospot17_240.ecw', 'orthospot17_240.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14468, 824, 98, '0', '/landmap/mosaics/spot/orthospot18_229.ecw', 'orthospot18_229.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14469, 824, 99, '0', '/landmap/mosaics/spot/orthospot18_231.ecw', 'orthospot18_231.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14470, 824, 100, '0', '/landmap/mosaics/spot/orthospot18_232.ecw', 'orthospot18_232.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14471, 824, 101, '0', '/landmap/mosaics/spot/orthospot18_233.ecw', 'orthospot18_233.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14472, 824, 102, '0', '/landmap/mosaics/spot/orthospot18_234.ecw', 'orthospot18_234.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14473, 824, 103, '0', '/landmap/mosaics/spot/orthospot18_235.ecw', 'orthospot18_235.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14474, 824, 104, '0', '/landmap/mosaics/spot/orthospot18_236.ecw', 'orthospot18_236.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14475, 824, 105, '0', '/landmap/mosaics/spot/orthospot18_237.ecw', 'orthospot18_237.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14476, 824, 106, '0', '/landmap/mosaics/spot/orthospot18_238.ecw', 'orthospot18_238.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14477, 824, 107, '0', '/landmap/mosaics/spot/orthospot25_237.ecw', 'orthospot25_237.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14478, 824, 108, '0', '/landmap/mosaics/spot/orthospot25_238.ecw', 'orthospot25_238.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14479, 824, 109, '0', '/landmap/mosaics/spot/orthospot25_241.ecw', 'orthospot25_241.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14480, 824, 110, '0', '/landmap/mosaics/spot/orthospot25_242.ecw', 'orthospot25_242.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14481, 824, 111, '0', '/landmap/mosaics/spot/orthospot25_243.ecw', 'orthospot25_243.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14482, 824, 112, '0', '/landmap/mosaics/spot/orthospot25_244.ecw', 'orthospot25_244.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14483, 824, 113, '0', '/landmap/mosaics/spot/orthospot25_245.ecw', 'orthospot25_245.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14484, 824, 114, '0', '/landmap/mosaics/spot/orthospot25_247.ecw', 'orthospot25_247.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14485, 824, 115, '0', '/landmap/mosaics/spot/orthospot25_248.ecw', 'orthospot25_248.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14486, 824, 116, '0', '/landmap/mosaics/spot/orthospot26_239.ecw', 'orthospot26_239.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14487, 824, 117, '0', '/landmap/mosaics/spot/orthospot26_240.ecw', 'orthospot26_240.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14488, 824, 118, '0', '/landmap/mosaics/spot/orthospot26_241.ecw', 'orthospot26_241.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14489, 824, 119, '0', '/landmap/mosaics/spot/orthospot26_242.ecw', 'orthospot26_242.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14490, 824, 120, '0', '/landmap/mosaics/spot/orthospot26_243.ecw', 'orthospot26_243.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14491, 824, 121, '0', '/landmap/mosaics/spot/orthospot26_244.ecw', 'orthospot26_244.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14492, 824, 122, '0', '/landmap/mosaics/spot/orthospot26_245.ecw', 'orthospot26_245.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14493, 824, 123, '0', '/landmap/mosaics/spot/orthospot26_246.ecw', 'orthospot26_246.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14494, 824, 124, '0', '/landmap/mosaics/spot/orthospot26_247.ecw', 'orthospot26_247.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14495, 824, 125, '0', '/landmap/mosaics/spot/orthospot26_248.ecw', 'orthospot26_248.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14496, 824, 126, '0', '/landmap/mosaics/spot/orthospot28_246.ecw', 'orthospot28_246.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14497, 824, 127, '0', '/landmap/mosaics/spot/orthospot28_247.ecw', 'orthospot28_247.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14498, 824, 128, '0', '/landmap/mosaics/spot/orthospot29_239.ecw', 'orthospot29_239.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14499, 824, 129, '0', '/landmap/mosaics/spot/orthospot29_240.ecw', 'orthospot29_240.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14500, 824, 130, '0', '/landmap/mosaics/spot/orthospot29_241.ecw', 'orthospot29_241.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14501, 824, 131, '0', '/landmap/mosaics/spot/orthospot29_242.ecw', 'orthospot29_242.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14502, 824, 132, '0', '/landmap/mosaics/spot/orthospot29_243.ecw', 'orthospot29_243.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14503, 824, 133, '0', '/landmap/mosaics/spot/orthospot29_244.ecw', 'orthospot29_244.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14504, 824, 134, '0', '/landmap/mosaics/spot/orthospot29_245.ecw', 'orthospot29_245.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14505, 824, 135, '0', '/landmap/mosaics/spot/orthospot30_242.ecw', 'orthospot30_242.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14506, 824, 136, '0', '/landmap/mosaics/spot/orthospot30_243.ecw', 'orthospot30_243.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14507, 824, 137, '0', '/landmap/mosaics/spot/orthospot30_245.ecw', 'orthospot30_245.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14508, 824, 138, '0', '/landmap/mosaics/spot/orthospot30_246.ecw', 'orthospot30_246.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14509, 824, 139, '0', '/landmap/mosaics/spot/orthospot30_247.ecw', 'orthospot30_247.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14510, 824, 140, '0', '/landmap/mosaics/spot/orthospot32_246.ecw', 'orthospot32_246.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14511, 824, 141, '0', '/landmap/mosaics/spot/orthospot32_247.ecw', 'orthospot32_247.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14512, 824, 142, '0', '/landmap/mosaics/spot/orthospot33_243.ecw', 'orthospot33_243.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14513, 824, 143, '0', '/landmap/mosaics/spot/orthospot33_244.ecw', 'orthospot33_244.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14514, 824, 144, '0', '/landmap/mosaics/spot/orthospot33_245.ecw', 'orthospot33_245.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14515, 824, 145, '0', '/landmap/mosaics/spot/orthospot34_243.ecw', 'orthospot34_243.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14516, 824, 146, '0', '/landmap/mosaics/spot/orthospot34_244.ecw', 'orthospot34_244.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14517, 824, 147, '0', '/landmap/mosaics/spot/orthospot34_245.ecw', 'orthospot34_245.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14518, 824, 148, '0', '/landmap/mosaics/spot/orthospot34_246.ecw', 'orthospot34_246.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14519, 824, 149, '0', '/landmap/mosaics/spot/orthospot34_247.ecw', 'orthospot34_247.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14520, 824, 150, '0', '/landmap/orthospot/UK_Orthospot/mosaics.ecw', 'mosaics.ecw', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14525, 827, 0, '', '', 'Test Imagery', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14526, 827, 1, '0', 'dlwc_landsat_2000_mosaic', 'NSW Landsat 2000 Mosaic', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14527, 828, 0, '', '', 'IDERIOJA', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14528, 828, 1, '0', 'ortofoto', 'Ortofoto', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14529, 828, 2, '0', 'Cuadricula', 'Cuadricula 5k', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14530, 828, 3, '0', 'Nucleos', 'Nucleos Urbanos', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14531, 828, 4, '0', 'Rios', 'Rios', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14532, 828, 5, '0', 'municipios', 'Terminos Municipales', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14533, 828, 6, '0', 'Carreteras', 'Carreteras', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14534, 829, 0, '', '', 'at_etm7_lambert', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14535, 829, 1, '0', '0', 'etm7_lambert', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14550, 831, 0, '', 'DELI', 'MNDNR Data Deli WMS Server', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14551, 831, 1, '0', 'L380000020906', '1:100k Digital Raster Graphic - Collars Removed', 0, 0, 125000, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14552, 831, 2, '0', 'L380000030906', '1:24k Digital Raster Graphic - Collars Removed', 0, 0, 30000, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14553, 831, 3, '0', 'L380000010906', '1:250k Digital Raster Graphic - Collars Removed', 0, 0, 499999, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14554, 831, 4, '0', 'L390002440906', 'GAP Land Cover - Image', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14555, 831, 5, '0', 'L390002400906', 'Public Waters Inventory Maps', 0, 0, 100000, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14556, 831, 6, '0', 'L370000050906', 'USGS Digital Orthophoto Quad (DOQ) - 3 meter', 0, 0, 100000, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14557, 832, 0, '', '', 'ArcIMS MapService', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14558, 832, 1, '0', 'overview', 'Wetland Overview', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14559, 832, 2, '0', 'wetlands_low', 'Wetlands Low Res', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14560, 832, 3, '0', 'wetlands', 'Wetlands High Res', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14561, 833, 0, '', '', 'encdirect', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14562, 833, 1, '0', '4', 'ENCNAMES_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14563, 833, 2, '0', 'LAND', 'LAND', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14564, 833, 3, '0', 'QUALITY OF DATA(M_QUAL)', 'QUALITY OF DATA', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14565, 833, 4, '0', 'NAVIGATIONAL SYSTEM OF MARKS(M_NSYS)', 'NAVIGATIONAL SYSTEM OF MARKS', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14566, 833, 5, '0', 'HORIZONTAL DATUM OF DATA(M_SDAT)', 'HORIZONTAL DATUM OF DATA', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14567, 833, 6, '0', 'NAUTICAL PUBLICATION INFORMATION(M_NPUB)', 'NAUTICAL PUBLICATION INFORMATION', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14568, 833, 7, '0', 'COMPLIATION OF SCALE DATA(M_CSCL)', 'COMPLIATION OF SCALE DATA', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14569, 833, 8, '0', 'COVERAGE(M_COVR)', 'COVERAGE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14570, 833, 9, '0', 'ACCURACY(M_ACCY)', 'ACCURACY', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14571, 833, 10, '0', 'LAND AREA(LNDARE)', 'LAND AREA_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14572, 833, 11, '0', 'DEPTH AREA(DEPARE)', 'DEPTH AREA_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14573, 833, 12, '0', 'ICE AREA(ICEARE)', 'ICE AREA', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14574, 833, 13, '0', 'HARBOR FACILITY_POLYGON(HRBFAC)', 'HARBOR FACILITY_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14575, 833, 14, '0', 'SEA AREA(SEAARE)', 'SEA AREA_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14576, 833, 15, '0', 'PYLONS_polygon(PYLONS)', 'PYLONS_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14577, 833, 16, '0', 'SEABED AREA_polygon(SBDARE)', 'SEABED AREA_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14578, 833, 17, '0', 'PONTOON(PONTON)', 'PONTOON_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14579, 833, 18, '0', 'WEED, KELP(WEDKLP)', 'WEED, KELP_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14580, 833, 19, '0', 'OFFSHORE PRODUCTION AREA(OSPARE)', 'OFFSHORE PRODUCTION AREA', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14581, 833, 20, '0', 'VEGATATION(VEGATN)', 'VEGATATION_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14582, 833, 21, '0', 'TWO_WAY ROUTE PART(TWRTPT)', 'TWO_WAY ROUTE PART', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14583, 833, 22, '0', 'SWEPTH AREA(SWPARE)', 'SWEPTH AREA', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14584, 833, 23, '0', 'SEA PLANE LANDING AREA(SLPARE)', 'SEA PLANE LANDING AREA_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14585, 833, 24, '0', 'WATER TURBULENCE(WATTUR)', 'WATER TURBULENCE_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14586, 833, 25, '0', 'SLOPING GROUND(SLOGRD)', 'SLOPING GROUND_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14587, 833, 26, '0', 'PRODUCTION AREA(PRDARE)', 'PRODUCTION AREA_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14588, 833, 27, '0', 'RUNWAY(RUNWAY)', 'RUNWAY_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14589, 833, 28, '0', 'RECOMMENDED TRACK(RECTRC)', 'RECOMMENDED TRACK_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14590, 833, 29, '0', 'RAPIDS(RAPIDS)', 'RAPIDS_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14591, 833, 30, '0', 'MILITARY PRACTICE AREA(MIPARE)', 'MILITARY PRACTICE AREA_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14592, 833, 31, '0', 'PRECAUTIONARY AREA_polygon(PRCARE)', 'PRECAUTIONARY AREA_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14593, 833, 32, '0', 'PILOT BOARDING AREA(PILBOP)', 'PILOT BOARDING AREA_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14594, 833, 33, '0', 'OFFSHORE PLATFORM(OFSPLF)', 'OFFSHORE PLATFORM_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14595, 833, 34, '0', 'LOCAL MAGNETIC ANOMALY(LOCMAG)', 'LOCAL MAGNETIC ANOMALY_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14596, 833, 35, '0', 'LOCK BASIN(LOKBSN)', 'LOCK BASIN', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14597, 833, 36, '0', 'MOORING FACILITY(MORFAC)', 'MOORING FACILITY_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14598, 833, 37, '0', 'GATE(GATCON)', 'GATE_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14599, 833, 38, '0', 'HARBOR AREA(HRBARE)', 'HARBOR AREA', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14600, 833, 39, '0', 'GRIDIRON(GRIDRN)', 'GRIDIRON_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14601, 833, 40, '0', 'LOG POND(LOGPON)', 'LOG POND_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14602, 833, 41, '0', 'LANDMARK(LNDMRK)', 'LANDMARK_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14603, 833, 42, '0', 'FERRY ROUTE(FERYRT)', 'FERRY ROUTE_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14604, 833, 43, '0', 'HULK_polygon(HULKES)', 'HULK_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14605, 833, 44, '0', 'FISH FACILITY(FSHFAC)', 'FISH FACILITY_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14606, 833, 45, '0', 'FLOATING DOCK_polygon(FLODOC)', 'FLOATING DOCK_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14607, 833, 46, '0', 'RIVERS(RIVERS)', 'RIVERS_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14608, 833, 47, '0', 'UNSURVEYED AREA(UNSARE)', 'UNSURVEYED AREA', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14609, 833, 48, '0', 'LAKE(LAKARE)', 'LAKE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14610, 833, 49, '0', 'SHORELINE CONSTRUCTION(SLCONS)', 'SHORELINE CONSTRUCTION_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14611, 833, 50, '0', 'TRAFFIC SEPARATION ZONE(TSEZNE)', 'TRAFFIC SEPARATION ZONE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14612, 833, 51, '0', 'OBSTRUCTION(OBSTRN)', 'OBSTRUCTION_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14613, 833, 52, '0', 'TRAFFIC SEPARATION SCHEME LANE PART(TSSLPT)', 'TRAFFIC SEPARATION SCHEME LANE PART', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14614, 833, 53, '0', 'LAND REGION(LNDRGN)', 'LAND REGION_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14615, 833, 54, '0', 'WRECKS_polygon(WRECKS)', 'WRECKS_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14616, 833, 55, '0', 'MARINE FARM, CULTURE(MARCUL)', 'MARINE FARM, CULTURE_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14617, 833, 56, '0', 'INSHORE TRAFFIC ZONE(ISTZNE)', 'INSHORE TRAFFIC ZONE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14618, 833, 57, '0', 'DEEP WATER ROUTE PART(DWRTPT)', 'DEEP WATER ROUTE PART', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14619, 833, 58, '0', 'DREDGED AREA(DRGARE)', 'DREDGED AREA', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14620, 833, 59, '0', 'DUMPING GROUND(DMPGRD)', 'DUMPING GROUND_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14621, 833, 60, '0', 'FAIRWAY_polygon(FAIRWY)', 'FAIRWAY', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14622, 833, 61, '0', 'ANCHOR BERTH(ACHBRT)', 'ANCHOR BERTH_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14623, 833, 62, '0', 'DRY DOCK(DRYDOC)', 'DRY DOCK', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14624, 833, 63, '0', 'RESTRICTED AREA(RESARE)', 'RESTRICTED AREA', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14625, 833, 64, '0', 'DOCK AREA(DOCARE)', 'DOCK AREA', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14626, 833, 65, '0', 'DIKE(DYKON)', 'DIKE_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14627, 833, 66, '0', 'BERTHS(BERTHS)', 'BERTHS_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14628, 833, 67, '0', 'DAM(DAMCON)', 'DAM_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14629, 833, 68, '0', 'ANCHORAGE AREA(ACHARE)', 'ANCHORAGE AREA_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14630, 833, 69, '0', 'CANALS(CANALS)', 'CANALS_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14631, 833, 70, '0', 'CAUSEWAY(CAUSWY)', 'CAUSEWAY_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14632, 833, 71, '0', 'CABLE AREA(CBLARE)', 'CABLE AREA', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14633, 833, 72, '0', 'BUILT-UP AREA(BUAARE)', 'BUILT-UP AREA_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14634, 833, 73, '0', 'SILO, TANK(SILTNK)', 'SILO, TANK_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14635, 833, 74, '0', 'FORTIFIED STRUCTURE(FORSTC)', 'FORTIFIED STRUCTURE_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14636, 833, 75, '0', 'TUNNEL(TUNNEL)', 'TUNNEL_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14637, 833, 76, '0', 'CONVEYOR(CONVYR)', 'CONVEYOR_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14638, 833, 77, '0', 'BUILDING(BUISGL)', 'BUILDING_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14639, 833, 78, '0', 'CRANES(CRANES)', 'CRANES_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14640, 833, 79, '0', 'ADMINISTRATION AREA_polygon(ADMARE)', 'ADMINISTRATION AREA', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14641, 833, 80, '0', 'AIRARE(AIRARE)', 'AIRPORT_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14642, 833, 81, '0', 'TRAFFIC SEPARATION SCHEME BOUNDARY(TSSBND)', 'TRAFFIC SEPARATION SCHEME BOUNDARY', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14643, 833, 82, '0', 'CAUTION AREA(CTNARE)', 'CAUTION AREA_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14644, 833, 83, '0', 'BRIDGE_polygon(BRIDGE)', 'BRIDGE_polygon', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14645, 833, 84, '0', 'SLOPE_TOPLINE(SLOTOP', 'SLOPE TOPLINE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14646, 833, 85, '0', 'WATER FALL_line(WATFAL)', 'WATER FALL_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14647, 833, 86, '0', 'SHORELINE CONSTRUCTION_line(SLCONS)', 'SHORELINE CONSTRUCTION_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14648, 833, 87, '0', 'RIVERS_line(RIVERS)', 'RIVERS_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14649, 833, 88, '0', 'SUBMARINE_ON LAND PIPELINE_line(PIPSOL)', 'SUBMARINE_ON LAND PIPELINE_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14650, 833, 89, '0', 'OVERHEAD PIPELINE(PIPOHD)', 'OVERHEAD PIPELINE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14651, 833, 90, '0', 'OBSTRUCTION_line(OBSTRN)', 'OBSTRUCTION_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14652, 833, 91, '0', 'NAVIGATION LINE(NAVLNE)', 'NAVIGATION LINE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14653, 833, 92, '0', 'LAND ELEVATION_line(LNDELV)', 'LAND ELEVATION_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14654, 833, 93, '0', 'ROAD_line(ROADWY)', 'ROAD_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14655, 833, 94, '0', 'FENCE LINE_line(FNCLNE)', 'FENCE LINE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14656, 833, 95, '0', 'OIL BARRIER_line(OILBAR)', 'OIL BARRIER', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14657, 833, 96, '0', 'FERRY ROUTE_line(FERYRT)', 'FERRY ROUTE_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14658, 833, 97, '0', 'DIKE_line(DYKCON)', 'DIKE_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14659, 833, 98, '0', 'SAND WAVES_line(SNDWAV)', 'SAND WAVES_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14660, 833, 99, '0', 'RECOMMENDED TRACK_line(RECTRC)', 'RECOMMENDED TRACK_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14661, 833, 100, '0', 'DEPTH AREA_line(DEPARE)', 'DEPTH AREA_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14662, 833, 101, '0', '1', 'WATER TURBULENCE_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14663, 833, 102, '0', 'DEPTH CONTOUR(DEPCNT)', 'DEPTH CONTOUR', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14664, 833, 103, '0', 'CONVEYOR_line(CONVYR)', 'CONVEYOR_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14665, 833, 104, '0', 'DAM_line(DAMCON)', 'DAM_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14666, 833, 105, '0', 'COASTLINE(COALNE)', 'COASTLINE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14667, 833, 106, '0', 'LAND AREA_line(LNDAARE)', 'LAND AREA_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14668, 833, 107, '0', 'FISH FACILITY_line(FSHFAC)', 'FISH FACILITY_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14669, 833, 108, '0', 'MOORING FACILITY_line(MORFAC)', 'MOORING FACILITY_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14670, 833, 109, '0', 'GATE_line(GATCON)', 'GATE_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14671, 833, 110, '0', 'TUNNEL_line(TUNNEL)', 'TUNNEL_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14672, 833, 111, '0', 'SUBMARINE CABLE(CLBSUB)', 'SUBMARINE CABLE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14673, 833, 112, '0', 'SLOPE TOPLINE_line(SLOTOP)', 'SLOPE TOPLINE_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14674, 833, 113, '0', 'RAILWAY_line(RAILWY)', 'RAILWAY', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14675, 833, 114, '0', 'TRAFFIC SEPARATION LINE(TSELNE)', 'TRAFFIC SEPARATION LINE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14676, 833, 115, '0', 'VEGATATION_line(VEGATN)', 'VEGATATION_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14677, 833, 116, '0', 'OVERHEAD CABLE(CBLOHD)', 'OVERHEAD CABLE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14678, 833, 117, '0', 'PONTOON_line(PONTON)', 'PONTOON_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14679, 833, 118, '0', 'CANALS_line(CANALS)', 'CANALS_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14680, 833, 119, '0', 'RECOMMENDED ROUTE CENTERLINE_line(RCRTCL)', 'RECOMMENDED ROUTE CENTERLINE_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14681, 833, 120, '0', 'BRIDGE_line(BRIDGE)', 'BRIDGE_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14682, 833, 121, '0', 'WRECKS_point(WRECKS)', 'WRECKS_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14683, 833, 122, '0', 'WEED, KELP_point(WEDKLP)', 'WEED, KELP_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14684, 833, 123, '0', 'WATER TURBULENCE_point(WATTUR)', 'WATER TURBULENCE_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14685, 833, 124, '0', 'ROCK AWASH, UNDERWATER_POINT(UWTROC)', 'ROCK AWASH, UNDERWATER', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14686, 833, 125, '0', 'TOPMARK_point(TOPMAR)', 'TOPMARK', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14687, 833, 126, '0', 'SHORELINE CONSTRUCTION_point(SLCONS)', 'SHORELINE CONSTRUCTION_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14688, 833, 127, '0', 'SILO, TANK_point(SILTNK)', 'SILO, TANK_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14689, 833, 128, '0', 'SEA AREA_point(SEAARE)', 'SEA AREA_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14690, 833, 129, '0', 'SEABED AREA_point(SBDARE)', 'SEABED AREA_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14691, 833, 130, '0', 'RADAR TRANSPONDER BEACON_POINT(RTPBCN)', 'RADAR TRANSPONDER BEACON', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14692, 833, 131, '0', 'RESCUE STATION_POINT(RCSTA)', 'RESCUE STATION', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14693, 833, 132, '0', 'PYLONS_point(PYLONS)', 'PYLONS_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14694, 833, 133, '0', 'PILE_point(PILPNT)', 'PILE', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14695, 833, 134, '0', 'OFFSHORE PLATFORM_point(OFSPLF_point)', 'OFFSHORE PLATFORM_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14696, 833, 135, '0', 'MOORING FACILITY_point(MORFAC_point)', 'MOORING FACILITY_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14697, 833, 136, '0', 'LAND REGION_point(LNDRGN_point)', 'LAND REGION_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14698, 833, 137, '0', 'LANDMARK_point(LNDMARK)', 'LANDMARK_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14699, 833, 138, '0', 'LAND AREA_point(LNDARE)', 'LAND AREA_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14700, 833, 139, '0', 'FOGSIG_point(FOGSIG)', 'FOG SIGNAL', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14701, 833, 140, '0', 'DAYMARK_point(DAYMAR)', 'DAYMARK', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14702, 833, 141, '0', 'CAUTION AREA_point(CNTARE)', 'CAUTION AREA_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14703, 833, 142, '0', 'COASTGUARD STATION_point(CGUSTA)', 'COASTGUARD STATION', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14704, 833, 143, '0', 'BUILDING_point(BUISGL)', 'BUILDING_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14705, 833, 144, '0', 'BUILT-UP AREA_point(BUAARE)', 'BUILT-UP AREA_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14706, 833, 145, '0', 'INSTALLATION(BOYINB)', 'INSTALLATION BUOY', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14707, 833, 146, '0', 'SPECIAL PURPOSE BUOY_point(BOYSPP)', 'SPECIAL PURPOSE BUOY', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14708, 833, 147, '0', 'SAFE WATER BUOY(BOYSAW)', 'SAFE WATER BUOY', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14709, 833, 148, '0', 'LATERAL BUOY_point(BOYLAT)', 'LATERAL BUOY', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14710, 833, 149, '0', 'SPECIAL PURPOSE BEACON_point(BCNSPP)', 'SPECIAL PURPOSE BEACON', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14711, 833, 150, '0', 'SAFE WATER BEACON_point(BCNSAW)', 'SAFE WATER BEACON', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14712, 833, 151, '0', 'LATERAL BEACON_point(BCNLAT)', 'LATERAL BEACON', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14713, 833, 152, '0', 'LAND ELEVATION_point(LNDELV)', 'LAND ELEVATION_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14714, 833, 153, '0', 'ANCHOR BERTH_point(ACHBRT)', 'ANCHOR BERTH_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14715, 833, 154, '0', 'ANCHORAGE AREA_point(ANCARE)', 'ANCHORAGE AREA_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14716, 833, 155, '0', 'AIRPORT_point(AIRARE)', 'AIRPORT_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14717, 833, 156, '0', 'ISOLATED DANGER BEACON(BCNISD)', 'ISOLATED DANGER BEACON', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14718, 833, 157, '0', 'BERTHS_point(BERTHS)', 'BERTHS_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14719, 833, 158, '0', 'CARDINAL BUOY_point(BOYCAR)', 'CARDINAL BUOY', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14720, 833, 159, '0', 'ISOLATED DANGER BUOY_point(BOYISD)', 'ISOLATED DANGER BUOY', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14721, 833, 160, '0', 'CRANES_point(CRANES)', 'CRANES_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14722, 833, 161, '0', 'CONTROL POINT(CTRPNT)', 'CONTROL POINT', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14723, 833, 162, '0', 'CURRENT_point(CURENT)', 'CURRENT', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14724, 833, 163, '0', 'DAM_point(DAMCON)', 'DAM_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14725, 833, 164, '0', 'DISTANCE MARK_point(DISMAR)', 'DISTANCE MARK', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14726, 833, 165, '0', 'DUMPING GROUND_point(DMPGRD)', 'DUMPING GROUND_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14727, 833, 166, '0', 'FORTIFIED STRUCTURE_point(FORSTC)', 'FORTIFIED STRUCTURE_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14728, 833, 167, '0', 'FISH FACILITY_point(FSHFAC)', 'FISH FACILITY_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14729, 833, 168, '0', 'GATE_point(GATCON)', 'GATE_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14730, 833, 169, '0', 'HARBOR FACILITY_point(HRBFAC)', 'HARBOR FACILITY_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14731, 833, 170, '0', 'LOCAL MAGNETIC ANOMALY_point(LOCMAG)', 'LOCAL MAGNETIC ANOMALY_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14732, 833, 171, '0', 'LOG POND_point(LOGPON)', 'LOG POND_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14733, 833, 172, '0', 'MAGNETIC VARIATION_point(MAGVAR)', 'MAGNETIC VARIATION_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14734, 833, 173, '0', 'PILOT BOARDING POINT_point(PILBOP)', 'PILOT BOARDING POINT_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14735, 833, 174, '0', 'SUBMARINE_ON LAND PIPELINE_point(PISOL)', 'SUBMARINE_ON LAND PIPELINE_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14736, 833, 175, '0', 'PRODUCTION AREA_point(PRDARE)', 'PRODUCTION AREA_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14737, 833, 176, '0', 'RADIO CALLING IN POINT_point(RDOCAL)', 'RADIO CALLING IN POINT_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14738, 833, 177, '0', 'RETRO REFLECTOR_point(RETRFL)', 'RETRO REFLECTOR', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14739, 833, 178, '0', 'WARNING SIGNAL STATION_point(SISTAW)', 'WARNING SIGNAL STATION', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14740, 833, 179, '0', 'TRAFFIC SIGNAL STATION_point(SISTAT)', 'TRAFFIC SIGNAL STATION', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14741, 833, 180, '0', 'SLOPING GROUND_point(SLOGRD)', 'SLOPING GROUND_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14742, 833, 181, '0', 'SMALL CRAFT FACILITY_point(SMCFAC)', 'SMALL CRAFT FACILITY_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14743, 833, 182, '0', 'SAND WAVES_point(SNDWAV)', 'SAND WAVES_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14744, 833, 183, '0', 'SEA PLANE LANDING AREA_point(SPLARE)', 'SEA PLANE LANDING AREA_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14745, 833, 184, '0', 'SPRING_point(SPRING)', 'SPRING', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14746, 833, 185, '0', 'TIDAL STREAM_point(TS_FEB)', 'TIDAL STREAM_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14747, 833, 186, '0', 'SEABED AREA_line(SBDARE)', 'SEABED AREA_line', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14748, 833, 187, '0', 'TUNNEL_point(TUNNEL)', 'TUNNEL_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14749, 833, 188, '0', 'VEGATATION_point(VEGATN)', 'VEGATATION_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14750, 833, 189, '0', 'WATER FALL', 'WATER FALL_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14751, 833, 190, '0', 'RADIO STATION(RDOSTA)', 'RADIO STATION', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14752, 833, 191, '0', 'OBSTRUCTION_point(OBSTRN)', 'OBSTRUCTION_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14753, 833, 192, '0', 'LIGHTS_point(LIGHTS)', 'LIGHTS', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14754, 833, 193, '0', 'LIGHT FLOAT_point(LITFLT)', 'LIGHT FLOAT', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14755, 833, 194, '0', 'HULK_point(HULKES)', 'HULKES_point', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14756, 833, 195, '0', 'SOUNDINGS', 'SOUNDINGS', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14757, 833, 196, '0', '0', 'ENC INDEX', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14758, 834, 0, '', '', 'DE_aerial02', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14759, 834, 1, '0', 'ortho2002', '2002 Aerial Imagery', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14800, 836, 0, '', '', 'NDOP', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14801, 836, 1, '0', 'States', 'State Boundaries', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14802, 836, 2, '0', 'Projects', 'NDOP Projects', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14803, 837, 0, '', '', 'U.S. Geological Survey', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14804, 837, 1, '0', 'DOQ', 'USGS Digital Ortho-Quadrangles', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14805, 837, 2, '0', 'DRG', 'USGS Raster Graphics (Topo Maps)', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14806, 837, 3, '0', 'UrbanArea', 'USGS Urban Areas Ortho-Imagery', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14842, 840, 0, '', '', 'World', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14843, 840, 1, '0', 'GLOBEImage', 'GlobeImage', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14844, 840, 2, '0', 'ADMIN', 'Admin', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14845, 840, 3, '0', 'COUNTRY', ' Country', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14846, 840, 4, '0', 'Lakes', ' Lakes', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14847, 840, 5, '0', 'RAILWAY', ' Railway', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14848, 840, 6, '0', 'WorldGridLines', ' World Grid Lines', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14849, 840, 7, '0', 'OCEAN_TEXT', ' Ocean Label', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14850, 840, 8, '0', 'CAPITALS', ' Capitals', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14851, 841, 0, '', 'ICEDSWMS', 'ICEDS (Integrated CEOS European Data Server) WMS', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14852, 841, 1, '0', 'GRID', 'MAPDRESSING GRID', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14853, 841, 2, '0', 'lights', 'DMSP/NOAA human settlements night lights of the wo', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14854, 841, 3, '2', 'lights_1', 'DMSP/NOAA human settlements night lights (300 arcs', 0, 44999930, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14855, 841, 4, '2', 'lights_2', 'DMSP/NOAA human settlements night lights (30 arcse', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14856, 841, 5, '0', 'landsat5', 'LANDSAT 5 mosaic for Africa and Europe', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14857, 841, 6, '5', 'landsat_1', 'LANDSAT 5 mosaic for Africa and Europe (100 arscse', 0, 9000006, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14858, 841, 7, '5', 'landsat_2', 'LANDSAT 5 mosaic for Africa and Europe (10 arscsec', 0, 3000002, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14859, 841, 8, '5', 'landsat_3', 'LANDSAT 5 mosaic for Africa and Europe (1 arscsec.', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14860, 841, 9, '0', 'srtm', 'Hillshaded SRTM3 mosaic', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14861, 841, 10, '9', 'srtm3_1', 'Hillshaded SRTM3 mosaic (180 arscsec. level)', 0, 20000000, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14862, 841, 11, '9', 'srtm3_2', 'Hillshaded SRTM3 mosaic (30 arscsec. level)', 0, 1700000, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14863, 841, 12, '9', 'srtm3_3', 'Hillshaded SRTM3 mosaic (3 arscsec. level)', 0, 0, 1700000, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14864, 841, 13, '0', 'srtm30', 'Hillshaded SRTM30 mosaic', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14865, 841, 14, '13', 'srtm30_1', 'Hillshaded SRTM30 mosaic (300 arscsec. level)', 0, 20000000, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14866, 841, 15, '13', 'srtm30_2', 'Hillshaded SRTM30 mosaic (30 arscsec. level)', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14867, 841, 16, '0', 'bluemarble', 'Global MODIS Blue Marble', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14868, 841, 17, '16', 'bluemarble_1', 'Global MODIS Blue Marble (300 arcsec. level)', 0, 11999988, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14869, 841, 18, '16', 'bluemarble_2', 'Global MODIS Blue Marble (30 arcsec. level)', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14870, 841, 19, '0', 'globe', 'Cascaded data from GLOBE', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14871, 841, 20, '19', 'rivers', 'Cascaded Rivers from GLOBE', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14872, 841, 21, '19', 'coastlines', 'Cascaded Coastlines from GLOBE', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14873, 841, 22, '0', 'demis', 'Cascaded data from Demis', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14874, 841, 23, '22', 'bathymetry', 'Cascaded Bathymetry from Demis', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14875, 841, 24, '0', 'onearth', 'Cascaded data from OnEarth', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14876, 841, 25, '24', 'landsat7', 'Cascaded Landsat7 from OnEarth', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14877, 841, 26, '24', 'terra', 'Cascaded daily MODIS Terra from OnEarth', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14878, 841, 27, '24', 'aqua', 'Cascaded daily MODIS Aqua from OnEarth', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14879, 841, 28, '0', 'metarweather', 'Cascaded World Hourly METAR Weather Reports from C', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14880, 841, 29, '0', 'noaa', 'Cascaded NOAA World Natural Hazards data', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14881, 841, 30, '29', 'earthquakes', 'Cascaded NOAA Significant Earthquakes', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14882, 841, 31, '29', 'tsunamievents', 'Cascaded NOAA Tsunami Events', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14883, 841, 32, '29', 'volcanoes', 'Cascaded NOAA Volcanoes', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14884, 841, 33, '29', 'plateboundaries', 'Cascaded NOAA Plate Boundaries', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14885, 841, 34, '29', 'countries', 'Cascaded NOAA Countries', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14886, 841, 35, '29', 'cities', 'Cascaded NOAA Cities', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14887, 841, 36, '0', 'sigafrique', 'Cascaded SIGAFRIQUE data', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14888, 841, 37, '36', 'geofault10', 'Cascaded geologic faults 10 m', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14889, 841, 38, '36', 'geoform10', 'Cascaded geologic formations 10 m', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14890, 841, 39, '36', 'towns', 'Cascaded towns', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14891, 841, 40, '36', 'mainrivers', 'Cascaded main water courses and inland water bodie', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14892, 841, 41, '36', 'water', 'Cascaded water courses', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14893, 841, 42, '36', 'railway', 'Cascaded railway network', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14894, 842, 0, '', 'Tsunami_Disaster_Map', 'Tsunami_Diasaster_Data', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14895, 842, 1, '0', 'Satellite_Imagery', 'Satellite_Imagery', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14896, 842, 2, '1', 'GAEL_WORLD_MARCH', 'ENVISAT MERIS mosaic', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14897, 842, 3, '1', 'srtm_tiles', 'SRTM 90m DEM - unclassified', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14898, 842, 4, '1', 'thai-LandsatTrue', 'Landsat Mosaic of Thailand', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14899, 842, 5, '1', 'sri_landsat', 'Landsat Mosaic of Sri Lanka', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14900, 842, 6, '0', 'Physical_Geography', 'Physical_Geography', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14901, 842, 7, '6', 'GTOPO30:Foundation', 'Global 30 Second Elevations', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14902, 842, 8, '6', 'RELIEF:Foundation', 'Two Minute Shaded Relief', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14903, 842, 9, '6', 'Bathymetry', 'Bathymetry', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14904, 842, 10, '6', 'Topography', 'Topography', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14905, 842, 11, '6', 'Hillshading', 'Hillshading', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14906, 842, 12, '6', 'CONTOURL_ELEV_1M:Foundation', 'Elevation Contours', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14907, 842, 13, '0', 'Disaster_Info', 'Disaster_Info', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14908, 842, 14, '13', 'locations', 'Disaster Point Locations', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14909, 842, 15, '13', 'faults', 'Fault Lines', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14910, 842, 16, '13', 'Wave_Heights', 'Wave Heights', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14911, 842, 17, '13', 'earthquakes', 'Recent Earthquakes', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14912, 842, 18, '13', 'epicenter', 'Epicenter of the Earthquake', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14913, 842, 19, '0', 'Political', 'Political', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14914, 842, 20, '19', 'World_WMS-WorldGen', 'World Countries', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14915, 842, 21, '19', 'Coastlines', 'Coastlines', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14916, 842, 22, '19', 'Borders', 'Borders', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14917, 842, 23, '19', 'oceans', 'World Oceans Labels', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14918, 842, 24, '19', 'Cities', 'World Cities', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14919, 842, 25, '0', 'Affected_Country_Statistics', 'Affected_Country_Statistics', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14920, 842, 26, '25', 'gdp', 'Gross Domestic Product (GDP)', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14921, 842, 27, '25', 'gdpper', 'Gross Domestic Product (GDP) per capita', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14922, 842, 28, '25', 'extdebt', 'External Debt', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14923, 842, 29, '25', 'density', 'Population Density (per sq. km)', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14924, 842, 30, '25', 'population', '2004 Population', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14925, 842, 31, '25', 'deaths', 'Total Deaths Per Country', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14926, 842, 32, '25', 'SriLanka_deaths', 'Sri Lanka Total Deaths by Region', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14927, 842, 33, '25', 'SriLanka_injured', 'Sri Lanka Total injuries by Region', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14928, 842, 34, '25', 'SriLanka_missing', 'Sri Lanka Total missing persons by Region', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14929, 842, 35, '25', 'SriLanka_displaced', 'Sri Lanka Total Displaced Population by Region', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14930, 842, 36, '25', 'SriLanka_camps', 'Sri Lanka Total camps by Region', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14931, 842, 37, '0', 'Infrastructure', 'Infrastructure', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14932, 842, 38, '37', 'BUILTUPA_POP_1M:Foundation', 'Built-Up Areas', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14933, 842, 39, '37', 'ROADL_TRANS_1M:Foundation', 'Roads', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14934, 843, 0, '', '', 'hazards', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14935, 843, 1, '0', 'Ambient Population 2002 (per 30 arc seconds)', 'Ambient Population 2002 (per 30 arc seconds)', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14936, 843, 2, '0', 'Elevation/Bathymetry', 'Elevation/Bathymetry', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14937, 843, 3, '0', 'Continents', 'Continents', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14938, 843, 4, '0', 'Lakes', 'Lakes', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14939, 843, 5, '0', 'Rivers', 'Rivers', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14940, 843, 6, '0', 'Countries', 'Countries', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14941, 843, 7, '0', 'States', 'States', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14942, 843, 8, '0', 'Cities', 'Cities', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14943, 843, 9, '0', 'Plate Boundaries', 'Plate Boundaries', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14944, 843, 10, '0', 'Volcanoes', 'Volcanoes', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14945, 843, 11, '0', 'Tsunami Events with runups', 'Tsunami Events with runups', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14946, 843, 12, '0', 'Tsunami Events with slides', 'Tsunami Events with slides', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14947, 843, 13, '0', 'Tsunami Events', 'Tsunami Events', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14948, 843, 14, '0', 'Tsunami Runups', 'Tsunami Runups', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14949, 843, 15, '0', 'Significant Earthquakes with slides', 'Significant Earthquakes with slides', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14950, 843, 16, '0', 'Significant Earthquakes', 'Significant Earthquakes', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14951, 844, 0, '', '', 'CustomWeather Map Server', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14952, 844, 1, '0', 'cite:BasicPolygons', 'cite:BasicPolygons', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14953, 844, 2, '0', 'cite:Bridges', 'cite:Bridges', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14954, 844, 3, '0', 'cite:BuildingCenters', 'cite:BuildingCenters', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14955, 844, 4, '0', 'cite:Buildings', 'cite:Buildings', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14956, 844, 5, '0', 'cite:DividedRoutes', 'cite:DividedRoutes', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14957, 844, 6, '0', 'cite:Forests', 'cite:Forests', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14958, 844, 7, '0', 'cite:Lakes', 'cite:Lakes', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14959, 844, 8, '0', 'cite:MapNeatline', 'cite:MapNeatline', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14960, 844, 9, '0', 'cite:NamedPlaces', 'cite:NamedPlaces', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14961, 844, 10, '0', 'cite:Ponds', 'cite:Ponds', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14962, 844, 11, '0', 'cite:RoadSegments', 'cite:RoadSegments', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14963, 844, 12, '0', 'cite:Streams', 'cite:Streams', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14964, 844, 13, '0', 'airport_delay', 'airport_delay', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14965, 844, 14, '0', 'anim', 'anim', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14966, 844, 15, '0', 'au_radar', 'au_radar', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14967, 844, 16, '0', 'au_radar_stations', 'au_radar_stations', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14968, 844, 17, '0', 'base', 'base', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14969, 844, 18, '0', 'borders', 'borders', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14970, 844, 19, '0', 'coasts', 'coasts', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14971, 844, 20, '0', 'conditions', 'conditions', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14972, 844, 21, '0', 'contour_fire_danger', 'contour_fire_danger', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14973, 844, 22, '0', 'contour_high', 'contour_high', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14974, 844, 23, '0', 'contour_jet_stream', 'contour_jet_stream', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14975, 844, 24, '0', 'contour_low', 'contour_low', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14976, 844, 25, '0', 'contour_precip', 'contour_precip', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14977, 844, 26, '0', 'contour_pressure', 'contour_pressure', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14978, 844, 27, '0', 'contour_syn_precip', 'contour_syn_precip', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14979, 844, 28, '0', 'conus_ir_satellite_4km', 'conus_ir_satellite_4km', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14980, 844, 29, '0', 'counties', 'counties', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14981, 844, 30, '0', 'earthquakes', 'earthquakes', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14982, 844, 31, '0', 'eqc', 'eqc', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14983, 844, 32, '0', 'forecasts', 'forecasts', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14984, 844, 33, '0', 'frontlines', 'frontlines', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14985, 844, 34, '0', 'future_lightning', 'future_lightning', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14986, 844, 35, '0', 'gazetteer', 'gazetteer', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14987, 844, 36, '0', 'geom', 'geom', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14988, 844, 37, '0', 'global_ir_satellite_10km', 'global_ir_satellite_10km', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14989, 844, 38, '0', 'hurricanes', 'hurricanes', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14990, 844, 39, '0', 'interstates', 'interstates', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14991, 844, 40, '0', 'jetstream', 'jetstream', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14992, 844, 41, '0', 'label', 'label', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14993, 844, 42, '0', 'land_sea_mask', 'land_sea_mask', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14994, 844, 43, '0', 'legend', 'legend', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14995, 844, 44, '0', 'lightning', 'lightning', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14996, 844, 45, '0', 'maple', 'maple', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14997, 844, 46, '0', 'maple_raster', 'maple_raster', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14998, 844, 47, '0', 'marine_zones', 'marine_zones', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14999, 844, 48, '0', 'pacus_ir_satellite_4km', 'pacus_ir_satellite_4km', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15000, 844, 49, '0', 'post_borders', 'post_borders', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15001, 844, 50, '0', 'radar', 'radar', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15002, 844, 51, '0', 'radar_mask', 'radar_mask', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15003, 844, 52, '0', 'rivers', 'rivers', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15004, 844, 53, '0', 'severe_warnings', 'severe_warnings', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15005, 844, 54, '0', 'severe_watches', 'severe_watches', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15006, 844, 55, '0', 'state_borders', 'state_borders', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15007, 844, 56, '0', 'storm_track', 'storm_track', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15008, 844, 57, '0', 'template', 'template', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15009, 844, 58, '0', 'wide_conus_ir_satellite_4km', 'wide_conus_ir_satellite_4km', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15010, 844, 59, '0', 'zones', 'zones', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15735, 854, 0, '', 'wesseling_stadtkarte', 'Stadtkarte', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15736, 854, 1, '0', 'Nutzung', 'Nutzung', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15737, 854, 2, '1', 'wes_dsk_patch1', 'wes_dsk_patch1', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15738, 854, 3, '1', 'atkis_wes_1_umn_pl', 'atkis_wes_1_umn_pl', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15739, 854, 4, '1', 'atkis_wes_1_umn_l', 'atkis_wes_1_umn_l', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15740, 854, 5, '1', 'atkis_wes_3_layer1_pl', 'atkis_wes_3_layer1_pl', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15741, 854, 6, '1', 'atkis_wes_3_layer2_pl', 'atkis_wes_3_layer2_pl', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15742, 854, 7, '1', 'atkis_wes_3_layer3_pl', 'atkis_wes_3_layer3_pl', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15743, 854, 8, '1', 'atkis_wes_3_layer4_pl', 'atkis_wes_3_layer4_pl', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15744, 854, 9, '1', 'atkis_wes_3_layer5_pl', 'atkis_wes_3_layer5_pl', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15745, 854, 10, '1', 'atkis_wes_3_layer6_l', 'atkis_wes_3_layer6_l', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15747, 854, 12, '0', 'Strassen', 'Strassen', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15749, 854, 14, '12', 'WES_DSK_umring', 'WES_DSK_umring', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15751, 854, 16, '0', 'Stadtgrenze', 'Stadtgrenze', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15752, 854, 17, '0', 'Strassennamen', 'Strassennamen', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15753, 854, 18, '17', 'wes_dsk_strnamen_umn_1_t', 'wes_dsk_strnamen_umn_1_t', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15754, 854, 19, '17', 'wes_dsk_strnamen_umn_2_t', 'wes_dsk_strnamen_umn_2_t', 0, 0, 4000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15755, 854, 20, '0', 'wes_dsk_patch', 'wes_dsk_patch', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19172, 909, 0, '', 'germany_wfs_myedit', 'MyEdit Elements', 0, 1, 0, '', '', 'germany_wfs_places');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19173, 909, 1, '0', 'my_polygons', 'my polygons', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19174, 909, 2, '0', 'my_lines', 'my lines', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19175, 909, 3, '0', 'my_points', 'my points', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15337, 407, 0, '', 'Mapbender', 'Mapbender User', 0, 1, 0, '', '', 'Mapbender User Overview (Mapbender User/Postgis)');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15338, 407, 1, '0', 'Mapbender_User', 'Mapbender User', 0, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Mapbender');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15339, 407, 2, '0', 'Mapbender_Names', 'Mapbender Info', 1, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Mapbender');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18068, 859, 0, '', '', 'Geobasisdaten', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18069, 859, 1, '0', '1', 'Digitale Orthophotos', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18119, 866, 0, '', '', 'hochwasser', 1, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18120, 866, 1, '0', '8', 'rhein-hq100-odeich', 1, 200, 749888, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18121, 866, 2, '0', '9', 'rhein-hq100-mdeich', 1, 200, 749888, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18122, 866, 3, '0', '6', 'rhein-hq200-odeich', 1, 200, 749888, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18123, 866, 4, '0', '7', 'rhein-hq200-mdeich', 1, 200, 749888, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18124, 866, 5, '0', '4', 'rhein-hq500-odeich', 1, 200, 749888, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18125, 866, 6, '0', '5', 'rhein-hq500-mdeich', 1, 200, 749888, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18126, 866, 7, '0', '0', 'vereinf_Verfahren', 1, 200, 374944, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18127, 866, 8, '0', '1', 'Sonstige_UESG', 1, 200, 374944, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18128, 866, 9, '0', '2', 'Historische_UESG', 1, 200, 374944, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18129, 866, 10, '0', '3', 'neuere_Berechnungsverfahren', 1, 200, 374944, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18130, 866, 11, '0', '18', 'Seen', 1, 200, 374944, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18131, 866, 12, '0', '19', 'Talsperre', 1, 200, 374944, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18132, 867, 0, '', '', 'stobo', 1, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18133, 867, 1, '0', 'Bleibelastung der Ackerboeden in mg pro kg', 'Bleibelastung der Ackerboeden in mg pro kg', 1, 22497, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18134, 867, 2, '0', 'Cadmiumbelastung der Ackerboeden in mg pro kg', 'Cadmiumbelastung der Ackerboeden in mg pro kg', 1, 22497, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18135, 867, 3, '0', 'Zinkbelastung der Ackerboeden in mg pro kg', 'Zinkbelastung der Ackerboeden in mg pro kg', 1, 22497, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18136, 867, 4, '0', 'Bleibelastung der Gartenboeden in mg pro kg', 'Bleibelastung der Gartenboeden in mg pro kg', 1, 22497, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18137, 867, 5, '0', 'Cadmiumbelastung der Gartenboeden in mg pro kg', 'Cadmiumbelastung der Gartenboeden in mg pro kg', 1, 22497, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18138, 867, 6, '0', 'Zinkbelastung der Gartenboeden in mg pro kg', 'Zinkbelastung der Gartenboeden in mg pro kg', 1, 22497, 74989, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18139, 867, 7, '0', 'Bleibelastung der Gruenlandboeden in mg pro kg', 'Bleibelastung der Gruenlandboeden in mg pro kg', 1, 22497, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18140, 867, 8, '0', 'Cadmiumbelastung der Gruenlandboeden in mg pro kg', 'Cadmiumbelastung der Gruenlandboeden in mg pro kg', 1, 22497, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18141, 867, 9, '0', 'Zinkbelastung der Gruenlandboeden in mg pro kg', 'Zinkbelastung der Gruenlandboeden in mg pro kg', 1, 22497, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18142, 867, 10, '0', 'Probenahmenstandorte in NRW differenziert nach Nutzungen', 'Probenahmenstandorte in NRW differenziert nach Nutzungen', 1, 22497, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18143, 868, 0, '', '', 'Gelaendemodell', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18144, 868, 1, '0', 'DGM50', 'DGM50', 0, 26075, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18145, 869, 0, '', '', 'linfos', 1, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18146, 869, 1, '0', '51', 'Vegetationstypen', 1, 0, 150214, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18147, 869, 2, '0', '49', 'Vegetationsaufnahmen', 1, 0, 150214, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18148, 869, 3, '0', '45', 'Naturraeumliche Haupteinheiten', 1, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18149, 869, 4, '0', '43', 'Landschaftsschutzgebiete', 1, 0, 150214, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18150, 869, 5, '0', '42', 'Stand der Landschaftsplanung', 1, 0, 150214, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18151, 869, 6, '0', '32', 'FFH-Gebiete', 1, 0, 150214, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18152, 869, 7, '0', '31', 'Vogelschutzgebiete', 1, 0, 150214, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18153, 869, 8, '0', '28', 'Biotoptypen', 1, 0, 150214, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18154, 869, 9, '0', '3', 'Biotopkataster', 1, 0, 150214, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18155, 869, 10, '0', '1', 'Naturschutzgebiete', 1, 0, 150214, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18159, 871, 0, '', 'MUENSTER', 'Geobasisdaten Muenster', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18160, 871, 1, '0', 'splan', 'Stadtplan', 0, 2400, 2000000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18161, 871, 2, '0', 'luftb', 'Luftbilder', 0, 375, 3900, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18162, 871, 3, '0', 'dgk5dbr', 'DGK5', 0, 1, 3900, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18163, 871, 4, '0', 'Stadtgrundkarte', 'Stadtgrundkarte', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18164, 871, 5, '4', 'flst', 'Flurstuecke', 0, 1, 2500, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18165, 871, 6, '4', 'gebaeude', 'Gebaeude', 0, 1, 2500, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18166, 871, 7, '4', 'linien', 'Topographie', 0, 1, 2500, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18167, 871, 8, '4', 'texte', 'Beschriftung', 0, 1, 2500, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18168, 872, 0, '', '', 'WV_WMS', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18169, 872, 1, '0', 'rheinplus', 'rheinplus', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18170, 872, 2, '0', 'uesgobwup', 'uesgobwup', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18171, 872, 3, '0', 'uesgmorsbach', 'uesgmorsbach', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18172, 872, 4, '0', 'klaerwerkseinzugsgebiete', 'klaerwerkseinzugsgebiete', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18173, 872, 5, '0', 'entwaesserungssystem', 'entwaesserungssystem', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18174, 872, 6, '0', 'gezgross', 'gezgross', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18175, 872, 7, '0', 'gezklein', 'gezklein', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18176, 872, 8, '0', 'ueberleitungsgebiete', 'ueberleitungsgebiete', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18177, 872, 9, '0', 'verbandsgebiet', 'verbandsgebiet', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18178, 872, 10, '0', 'gsg5', 'gsg5', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18179, 872, 11, '0', 'gsg3', 'gsg3', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18180, 872, 12, '0', 'gsg1', 'gsg1', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18181, 872, 13, '0', 'gewaesser', 'gewaesser', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18182, 872, 14, '0', 'verrohrungen', 'verrohrungen', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18183, 872, 15, '0', 'verlaufaenderungen', 'verlaufaenderungen', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18184, 872, 16, '0', 'gewaesserbeschriftung', 'gewaesserbeschriftung', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18185, 872, 17, '0', 'talsperren', 'talsperren', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18186, 872, 18, '0', 'sammler', 'sammler', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18187, 872, 19, '0', 'stationierung', 'stationierung', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18188, 872, 20, '0', 'fotos_am_gewaesser', 'fotos_am_gewaesser', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18189, 872, 21, '0', 'limnologie', 'limnologie', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18190, 872, 22, '0', 'niederschlagsstationen', 'niederschlagsstationen', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18191, 872, 23, '0', 'pegel', 'pegel', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18192, 872, 24, '0', 'wehre', 'wehre', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18193, 872, 25, '0', 'fischaufstiege', 'fischaufstiege', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18194, 872, 26, '0', 'hrb', 'hrb', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18195, 872, 27, '0', 'regenbeckenwv', 'regenbeckenwv', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18196, 872, 28, '0', 'klaerwerke', 'klaerwerke', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18205, 881, 0, '', 'Gebietsgliederung', 'Gebietsgliederung', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18206, 881, 1, '0', 'Stadtbezirke', 'Stadtbezirke', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18207, 881, 2, '1', 'stadtbezirke_pl', 'stadtbezirke_pl', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18208, 881, 3, '1', 'stadtbezirke_t', 'stadtbezirke_t', 0, 0, 300000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18209, 881, 4, '0', 'Statistische_Bezirke', 'Statistische_Bezirke', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18210, 881, 5, '4', 'statist_bez_pl', 'statist_bez_pl', 0, 0, 300000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18211, 881, 6, '4', 'statist_bez_t', 'statist_bez_t', 0, 0, 300000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18212, 881, 7, '0', 'Verkehrszellen', 'Verkehrszellen', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18213, 881, 8, '7', 'verkehrszellen_pl', 'verkehrszellen_pl', 0, 0, 300000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18214, 881, 9, '7', 'verkehrszellen_t', 'verkehrszellen_t', 0, 0, 300000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18215, 881, 10, '0', 'Baubloecke', 'Baubloecke', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18216, 881, 11, '10', 'baubloecke_pl', 'baubloecke_pl', 0, 0, 100000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18217, 881, 12, '10', 'baubloecke_t', 'baubloecke_t', 0, 0, 100000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18218, 882, 0, '', 'Wahlen', 'Wahlen', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18219, 882, 1, '0', 'HINTERGRUNDKARTE', 'HINTERGRUNDKARTE', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18220, 882, 2, '1', 'stadtplan_grau_zoomst_1', 'stadtplan_grau_zoomst_1', 0, 135001, 300000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18221, 882, 3, '1', 'stadtplan_zoom3_01', '02_stadtplan', 0, 20001, 135000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18222, 882, 4, '1', 'stadtplan_zoom3_02', '03_stadtplan', 0, 12001, 20000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18223, 882, 5, '1', 'stadtplan_zoom3_03', '04_stadtplan', 0, 2751, 12000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18224, 882, 6, '1', 'dgk5_liste', 'Deutsche Grundkarte', 0, 0, 2750, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18225, 882, 7, '0', 'stadtplan_72dpi', 'stadtplan_uebersicht', 0, 300000, 1000000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18226, 882, 8, '0', 'Stadtbezirke', 'Stadtbezirke', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18227, 882, 9, '8', 'stadtbezirke_pl', 'stadtbezirke_pl', 0, 0, 300000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18228, 882, 10, '8', 'stadtbezirke_t', 'stadtbezirke_t', 0, 0, 300000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18229, 882, 11, '0', 'Wahlbezirke', 'Wahlbezirke', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18230, 882, 12, '11', 'wahlbezirke_pl', 'wahlbezirke_pl', 0, 0, 300000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18231, 882, 13, '11', 'wahlbezirke_t', 'wahlbezirke_t', 0, 0, 300000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18232, 882, 14, '0', 'Stimmbezirke', 'Stimmbezirke', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18233, 882, 15, '14', 'stimmbezirke_pl', 'stimmbezirke_pl', 0, 0, 300000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18234, 882, 16, '14', 'stimmbezirke_t', 'stimmbezirke_t', 0, 0, 300000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18235, 883, 0, '', '', 'Luftbilder', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18236, 883, 1, '0', '1', '$_nav_uebersicht', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18237, 883, 2, '0', '2', 'Stadtplan', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18238, 883, 3, '0', '5', 'Luftbilder 1999', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18239, 883, 4, '0', '8', 'Flurstuecksstruktur', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18240, 883, 5, '0', '9', 'Texte', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18248, 885, 2, '1', 'Autobahnen', 'Autobahnen', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18253, 885, 7, '6', 'NKAutobahnen', 'Netzknoten, Autobahnen', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18258, 885, 12, '11', 'NPAutobahnen', 'Nullpunkte, Autobahnen', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18262, 885, 16, '0', 'TKBlaetter', 'TK-Blattschnitte', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18264, 885, 18, '17', 'mZstBereichAutobahnen', 'Zst-Bereiche Autobahnen', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18269, 885, 23, '22', 'mZstOrtAutobahnen', 'Zst-Orte Autobahnen', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18270, 885, 24, '22', 'mZstOrtBundesstrassen', 'Zst-Orte Bundesstrassen', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18271, 885, 25, '22', 'mZstOrtLandesstrassen', 'Zst-Orte Landesstrassen', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18272, 885, 26, '22', 'mZstOrtKreisstrassen', 'Zst-Orte Kreisstrassen', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18274, 887, 0, '', '', 'BK50', 1, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18275, 887, 1, '0', 'bk50', 'bk50', 1, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19125, 903, 0, '', 'Brandenburg', 'DNM 25', 0, 100, 50000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19006, 893, 0, '', 'Germany', 'Germany', 0, 1, 0, '', '', 'Germany');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19126, 903, 1, '0', 'land', 'Landkreise und kreisfreie Städte', 0, 100, 50000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19127, 903, 2, '0', 'ort', 'Ortschaften', 1, 1000, 50000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19007, 893, 1, '0', 'Topographie', 'topography', 0, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Topographie,Landschaft');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19079, 899, 0, '', 'infoprix', 'Infoprix', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19080, 899, 1, '0', 'Ajouter_un_Marche', 'Ajouter_un_Marche', 1, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19081, 899, 2, '0', 'Weltlaender', 'Etats', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19082, 899, 3, '0', 'Departmt', 'Departements', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19083, 899, 4, '0', 'Sousprefneu', 'Sous Prefectures', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19084, 899, 5, '0', 'rivlc', 'Rivieres et lacs', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19085, 899, 6, '0', 'Route2', 'Voies de communication', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19086, 899, 7, '0', 'localits', 'Localités', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19087, 899, 8, '0', 'Villes', 'Villes', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19088, 899, 9, '0', 'Maerkte1', 'Marches', 1, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19089, 899, 10, '0', 'Nouveaux-Marches', 'Nouveaux-Marches', 1, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19128, 903, 3, '0', 'wald', 'Waldflächen', 0, 1000, 50000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19129, 903, 4, '0', 'gruen', 'Grünflächen', 0, 1000, 50000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19146, 904, 8, '0', 'bstr', 'Bundesstraßen', 0, 200000, 1000000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19147, 904, 9, '0', 'astr', 'Autobahnen', 0, 200000, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19148, 904, 10, '0', 'kfz', 'Kfz-Zeichen', 0, 1000000, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19149, 905, 0, '', 'Brandenburg', 'DNM FÜK', 0, 50000, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19150, 905, 1, '0', 'flur', 'Flur', 1, 50000, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19151, 905, 2, '0', 'gema', 'Gemarkung', 1, 50000, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19152, 905, 3, '0', 'geme', 'Gemeinde', 1, 50000, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19153, 905, 4, '0', 'stadt', 'Kreisfreie Städte', 1, 50000, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19154, 905, 5, '0', 'kreis', 'Landkreise', 1, 50000, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19155, 906, 0, '', 'Brandenburg', 'DNM VG', 0, 50000, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19156, 906, 1, '0', 'berlin', 'Berliner Bezirke', 0, 50000, 1000000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19157, 906, 2, '0', 'geme', 'Gemeinde', 1, 50000, 1000000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19158, 906, 3, '0', 'kamt', 'Amtsfreie Gemeinde', 1, 50000, 1000000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19159, 906, 4, '0', 'amt', 'Ämter', 1, 50000, 1000000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19160, 906, 5, '0', 'stadt', 'Kreisfreie Städte', 1, 50000, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19161, 906, 6, '0', 'kreis', 'Landkreise', 1, 50000, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19162, 906, 7, '0', 'land', 'Land', 0, 50000, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19163, 906, 8, '0', 'staat', 'Deutschland', 0, 50000, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19164, 906, 9, '0', 'ngeme', 'Namen der Gemeinden', 0, 50000, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19165, 906, 10, '0', 'nkamt', 'Namen der amtfreien Gemeinden', 0, 50000, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19166, 906, 11, '0', 'namt', 'Namen der Ämter', 0, 50000, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19167, 906, 12, '0', 'nkreis', 'KFZ Kennzeichen der Kreise', 0, 50000, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19170, 908, 0, '', 'NRW', 'NRW', 0, 0, 140316, '', '', 'Nutzungsbedingungen: Sämtliche Rechte an diesem Produkt liegen beim Landesvermessungsamt NRW. Die Nutzung ist bis auf Widerruf kostenfrei. Der Nutzer muss sich vor jeder Nutzung beim Landesvermessungsamt NRW identifizieren und seine spezielle Nutzung mit Angabe des Verwendungszwecks und Umfang der Nutzung anmelden (Kontaktmöglichkeiten zum Landesvermessungsamt NRW siehe unten). Die Nutzung ist ausschließlich für Testzwecke und im Rahmen von GDI-Projekten zulässig; die Nutzung für kommerzielle Anwendungen ist ausdrücklich ausgeschlossen. Die mittelbare oder unmittelbare Weitergabe der Daten an Dritte ist auch in Verbindung mit weiteren Daten ohne ausdrückliche Genehmigung durch das Landesvermessungsamt NRW nicht zulässig. Der Nutzer ist verpflichtet, einen deutlichen Copyright-Hinweis auf das Landesvermessungsamt NRW als Dateneigentümer bei Visualisierungen jeder Art anzubringen.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19171, 908, 1, '0', 'Raster:TK100_KMF:Farbkombination', 'Farbkombination', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19008, 893, 2, '0', 'Grenze', 'border', 0, 750000, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Grenzen, border');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19009, 893, 3, '0', 'Bundeslaender', 'federal states', 0, 750000, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Laender');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19010, 893, 4, '0', 'Staedte', 'places', 0, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Staedte in der BRD');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19011, 893, 5, '0', 'Postleitzahlbereiche', 'postcode areas', 1, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Postleitzahl,PLZ,postcode');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19012, 893, 6, '0', 'Bahnlinien', 'railroad lines', 0, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'railroad,Bahn,DB');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19013, 893, 7, '0', 'Fluesse', 'rivers', 0, 0, 1250000, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'river');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19014, 893, 8, '0', 'Strassen', 'roads', 0, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'road');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19015, 893, 9, '0', 'Staedtepunkte', 'places as point', 1, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Stadt');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19016, 893, 10, '0', 'Postleitzahlbereichname', 'postcode areas (names)', 0, 0, 350000, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'PLZ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19017, 893, 11, '0', 'Staedtenamen', 'places (names)', 0, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'city');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19018, 893, 12, '0', 'Bundeslaendernamen', 'federal states (names)', 0, 1000000, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Bundesland');
--- TOC entry 1766 (class 0 OID 39047376)
--- Dependencies: 1243
+-- TOC entry 1792 (class 0 OID 47913205)
+-- Dependencies: 1250
 -- Data for Name: layer_epsg; Type: TABLE DATA; Schema: public; Owner: admin
@@ -6008,12 +6111,6 @@
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15008, 'EPSG:4326', -180, -90, 180, 90);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15009, 'EPSG:4326', -180, -90, 180, 90);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15010, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15337, 'EPSG:4326', 7, 42, 12, 59);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15338, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15339, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15735, 'EPSG:4326', 6.9261499999999998, 50.787700000000001, 7.0339900000000002, 50.856000000000002);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15735, 'EPSG:31466', 2565300, 5628400, 2572800, 5635900);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15737, 'EPSG:4326', -3.6927599999999998, 45.2759, 18.497900000000001, 55.417200000000001);
@@ -6050,28 +6147,10 @@
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15754, 'EPSG:31466', -25000000, -25000000, 25000000, 25000000);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15755, 'EPSG:4326', 6.7854400000000004, 50.7166, 7.1661400000000004, 50.937899999999999);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15755, 'EPSG:31466', 2555460, 5620630, 2581960, 5644900);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15798, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15798, 'EPSG:4326', -184, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15799, 'EPSG:4326', -180, -90, 180, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15800, 'EPSG:4326', -184, -90, 180, 85);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15801, 'EPSG:4326', -180, -59.999999999979998, 179.999999999984, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15802, 'EPSG:4326', -180, -59.999999999979998, 179.999999999984, 90);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15803, 'EPSG:4326', -180, -55, 180, 75);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15804, 'EPSG:4326', -184, -90, 180, 85);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15805, 'EPSG:4326', -184, -75, 180, 85);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15806, 'EPSG:4326', -180, -50, 180, 80);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15807, 'EPSG:4326', -180, -55, 180, 85);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15808, 'EPSG:4326', -180, -55, 180, 85);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15809, 'EPSG:4326', -170, -55, 180, 80);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15810, 'EPSG:4326', -175, -55, 180, 75);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15811, 'EPSG:4326', -184, -55, 180, 75);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15812, 'EPSG:4326', -184, -50, 180, 80);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15813, 'EPSG:4326', -184, -60, 176, 75);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15814, 'EPSG:4326', -180, -55, 180, 75);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15815, 'EPSG:4326', -180, -55, 180, 85);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15816, 'EPSG:4326', -179.98309326171901, -89.83837890625, 179.99143981933599, 83.520408630371094);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15817, 'EPSG:4326', -184, -55, 180, 80);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15818, 'EPSG:4326', -180, -62.923179626464801, 179.99942016601599, 68.690658569335895);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19172, 'EPSG:4326', 5.8799999999999999, 46.621299999999998, 15, 55.718699999999998);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19173, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19174, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19175, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18068, 'EPSG:4326', 7.46, 47.490000000000002, 10.57, 49.810000000000002);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18068, 'EPSG:31467', 3383722, 5262500, 3616277, 5521500);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (18069, 'EPSG:4326', 7.46, 47.490000000000002, 10.57, 49.810000000000002);
@@ -6392,37 +6471,11 @@
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19006, 'EPSG:4326', 5.6007499999999997, 47.244100000000003, 15.425000000000001, 55.031700000000001);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19006, 'EPSG:31467', 3282450, 5248260, 3912240, 6100130);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19007, 'EPSG:4326', 5.8656300000000003, 47.275799999999997, 15, 55.055599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19007, 'EPSG:4326', 5.8656300000000003, 47.275799999999997, 15, 55.055599999999998);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19008, 'EPSG:4326', 5.8656300000000003, 47.275799999999997, 15, 55.055599999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19008, 'EPSG:4326', 5.8656300000000003, 47.275799999999997, 15, 55.055599999999998);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19009, 'EPSG:4326', 5.8641699999999997, 47.274700000000003, 15.0389, 55.056699999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19009, 'EPSG:4326', 5.8641699999999997, 47.274700000000003, 15.0389, 55.056699999999999);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19010, 'EPSG:4326', 6.0522299999999998, 47.482500000000002, 14.998100000000001, 54.9405);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19010, 'EPSG:4326', 6.0522299999999998, 47.482500000000002, 14.998100000000001, 54.9405);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19011, 'EPSG:4326', 5.8662900000000002, 47.273600000000002, 15.0486, 55.058300000000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19011, 'EPSG:4326', 5.8662900000000002, 47.273600000000002, 15.0486, 55.058300000000003);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19012, 'EPSG:4326', 5.9825900000000001, 47.406399999999998, 15, 54.904499999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19012, 'EPSG:4326', 5.9825900000000001, 47.406399999999998, 15, 54.904499999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19013, 'EPSG:4326', 5.9519200000000003, 47.2864, 14.975899999999999, 54.910699999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19014, 'EPSG:4326', 5.9050799999999999, 47.313600000000001, 14.998100000000001, 55.015700000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19015, 'EPSG:4326', 6.0166700000000004, 47.399999999999999, 15, 54.899999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19016, 'EPSG:4326', 5.8662900000000002, 47.273600000000002, 15.0486, 55.058300000000003);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19017, 'EPSG:4326', 6.0166700000000004, 47.399999999999999, 15, 54.899999999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19018, 'EPSG:4326', 5.8641699999999997, 47.274700000000003, 15.0389, 55.056699999999999);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19168, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19168, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19168, 'EPSG:31462', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19168, 'EPSG:31492', 2476553, 5540279, 2779499, 5856970);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19168, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19168, 'EPSG:25831', 691515.46999999997, 5541873.3499999996, 981462.09999999998, 5870966.6200000001);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19168, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19168, 'EPSG:25833', -167984.51000000001, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19079, 'EPSG:4326', 0.36599999999999999, 5.9089999999999998, 4.423, 12.911);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19080, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
@@ -6445,14 +6498,12 @@
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19088, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19089, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19106, 'EPSG:4326', 5.8799999999999999, 46.621299999999998, 15, 55.718699999999998);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19107, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19108, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
-INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19109, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19013, 'EPSG:4326', 5.9519200000000003, 47.2864, 14.975899999999999, 54.910699999999999);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19014, 'EPSG:4326', 5.9050799999999999, 47.313600000000001, 14.998100000000001, 55.015700000000002);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19015, 'EPSG:4326', 6.0166700000000004, 47.399999999999999, 15, 54.899999999999999);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19016, 'EPSG:4326', 5.8662900000000002, 47.273600000000002, 15.0486, 55.058300000000003);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19017, 'EPSG:4326', 6.0166700000000004, 47.399999999999999, 15, 54.899999999999999);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19018, 'EPSG:4326', 5.8641699999999997, 47.274700000000003, 15.0389, 55.056699999999999);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19110, 'EPSG:4326', 10.859400000000001, 51.196599999999997, 15.0908, 53.662700000000001);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19110, 'EPSG:25833', 3226000, 5679000, 3506000, 5946000);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19111, 'EPSG:4326', 11.2317, 51.309899999999999, 14.765599999999999, 53.563899999999997);
@@ -6507,19 +6558,78 @@
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19166, 'EPSG:25833', 3250120, 5690390, 3483680, 5921730);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19167, 'EPSG:4326', 11.2317, 51.309899999999999, 14.765599999999999, 53.563899999999997);
 INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19167, 'EPSG:25833', 3250120, 5690390, 3483680, 5935030);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15337, 'EPSG:4326', 7, 42, 12, 59);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15338, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (15339, 'EPSG:4326', -25000000, -25000000, 25000000, 25000000);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19170, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19170, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19170, 'EPSG:31462', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19170, 'EPSG:31492', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19170, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19170, 'EPSG:25831', 691515.46999999997, 5541873.3499999996, 981462.09999999998, 5870966.6200000001);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19170, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19170, 'EPSG:25833', -167984.51000000001, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19171, 'EPSG:4326', 5.673, 49.994399999999999, 10.141999999999999, 52.769100000000002);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19171, 'EPSG:31466', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19171, 'EPSG:31462', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19171, 'EPSG:31492', 2476553, 5540279, 2779499, 5856970);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19171, 'EPSG:31467', 3261513.0499999998, 5545534.7300000004, 3577127.98, 5849530.1500000004);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19171, 'EPSG:25831', 691515.46999999997, 5541873.3499999996, 981462.09999999998, 5870966.6200000001);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19171, 'EPSG:25832', 261533.79000000001, 5543758.2400000002, 577026.19999999995, 5847631.2699999996);
+INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (19171, 'EPSG:25833', -167984.51000000001, 5580271.6100000003, 172362.07000000001, 5858091.8799999999);
--- TOC entry 1767 (class 0 OID 39047384)
--- Dependencies: 1244
+-- TOC entry 1810 (class 0 OID 48558633)
+-- Dependencies: 1278
+-- Data for Name: layer_keyword; Type: TABLE DATA; Schema: public; Owner: admin
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19006, 1);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19006, 2);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19006, 3);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19006, 4);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19006, 5);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19006, 6);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19007, 7);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19008, 7);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19009, 8);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19009, 9);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19010, 10);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19010, 11);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19010, 12);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19010, 13);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19011, 14);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19011, 15);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19011, 16);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19012, 17);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19012, 18);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19012, 19);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19013, 20);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19013, 21);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19013, 22);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19013, 23);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19014, 24);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19014, 25);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19014, 26);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19015, 13);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19015, 27);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19015, 10);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19016, 15);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19017, 10);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19018, 28);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (19018, 29);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (15337, 7);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (15337, 3);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (15337, 4);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (15337, 5);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (15338, 7);
+INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) VALUES (15339, 7);
+-- TOC entry 1793 (class 0 OID 47913213)
+-- Dependencies: 1251
 -- Data for Name: layer_style; Type: TABLE DATA; Schema: public; Owner: admin
@@ -6958,7 +7068,6 @@
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14929, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=SriLanka_displaced&format=image/png', '');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14930, 'default', 'default', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=SriLanka_camps&format=image/png', '');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14951, 'Simple', 'Simple Map Style', '', '');
-INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (15338, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Mapbender_User&format=image/png', '');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (15738, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=atkis_wes_1_umn_pl&format=image/png', 'image/png');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (15739, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=atkis_wes_1_umn_l&format=image/png', 'image/png');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (15740, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wesseling/wesseling_stadtkarte.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=atkis_wes_3_layer1_pl&format=image/png', 'image/png');
@@ -7041,15 +7150,6 @@
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18268, 'MitDTV', 'mit DTV-Wert', '', '');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18268, 'MitKennung+DTV', 'mit Kennung und DTV-Wert', '', '');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (18268, 'OhneBeschriftung', 'ohne Beschriftung', '', '');
-INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19007, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Topographie&format=image/png', 'image/png');
-INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19008, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Grenze&format=image/png', 'image/png');
-INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19009, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Bundeslaender&format=image/png', 'image/png');
-INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19010, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Staedte&format=image/png', 'image/png');
-INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19011, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Postleitzahlbereiche&format=image/png', 'image/png');
-INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19012, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Bahnlinien&format=image/png', 'image/png');
-INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19013, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Fluesse&format=image/png', 'image/png');
-INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19014, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Strassen&format=image/png', 'image/png');
-INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19015, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Staedtepunkte&format=image/png', 'image/png');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19080, 'default', 'default', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/infoprix.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Ajouter_un_Marche&format=image/png', 'image/png');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19081, 'default', 'default', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/infoprix.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Weltlaender&format=image/png', 'image/png');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19082, 'default', 'default', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/infoprix.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Departmt&format=image/png', 'image/png');
@@ -7062,14 +7162,24 @@
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19089, 'default', 'default', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/infoprix.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Nouveaux-Marches&format=image/png', 'image/png');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19096, 'default', 'default', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/pendjari.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=ldcpendjari&format=image/png', 'image/png');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19100, 'default', 'default', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/pendjari.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=agglom&format=image/png', 'image/png');
-INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19107, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=my_polygons&format=image/png', 'image/png');
-INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19108, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=my_lines&format=image/png', 'image/png');
-INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19109, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=my_points&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19007, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Topographie&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19008, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Grenze&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19009, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Bundeslaender&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19173, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=my_polygons&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19174, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=my_lines&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19175, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=my_points&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19010, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Staedte&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19011, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Postleitzahlbereiche&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19012, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Bahnlinien&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19013, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Fluesse&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19014, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Strassen&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19015, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Staedtepunkte&format=image/png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (15338, 'default', 'default', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Mapbender_User&format=image/png', 'image/png');
--- TOC entry 1768 (class 0 OID 39047391)
--- Dependencies: 1246
+-- TOC entry 1794 (class 0 OID 47913220)
+-- Dependencies: 1253
 -- Data for Name: mb_group; Type: TABLE DATA; Schema: public; Owner: admin
@@ -7077,24 +7187,24 @@
--- TOC entry 1769 (class 0 OID 39047398)
--- Dependencies: 1248
+-- TOC entry 1795 (class 0 OID 47913227)
+-- Dependencies: 1255
 -- Data for Name: mb_log; Type: TABLE DATA; Schema: public; Owner: admin
--- TOC entry 1782 (class 0 OID 42299424)
--- Dependencies: 1268
+-- TOC entry 1796 (class 0 OID 47913234)
+-- Dependencies: 1256
 -- Data for Name: mb_monitor; Type: TABLE DATA; Schema: public; Owner: admin
--- TOC entry 1770 (class 0 OID 39047407)
--- Dependencies: 1250
+-- TOC entry 1797 (class 0 OID 47913246)
+-- Dependencies: 1258
 -- Data for Name: mb_user; Type: TABLE DATA; Schema: public; Owner: admin
@@ -7102,8 +7212,8 @@
--- TOC entry 1771 (class 0 OID 39047418)
--- Dependencies: 1251
+-- TOC entry 1798 (class 0 OID 47913257)
+-- Dependencies: 1259
 -- Data for Name: mb_user_mb_group; Type: TABLE DATA; Schema: public; Owner: admin
@@ -7111,16 +7221,43 @@
--- TOC entry 1772 (class 0 OID 39047422)
--- Dependencies: 1252
+-- TOC entry 1799 (class 0 OID 47913261)
+-- Dependencies: 1260
 -- Data for Name: mb_user_wmc; Type: TABLE DATA; Schema: public; Owner: admin
--- TOC entry 1773 (class 0 OID 39047431)
--- Dependencies: 1254
+-- TOC entry 1811 (class 0 OID 48558647)
+-- Dependencies: 1280
+-- Data for Name: md_topic_category; Type: TABLE DATA; Schema: public; Owner: admin
+INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (1, 'farming', 'Landwirtschaft');
+INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (2, 'biota', 'Biotope');
+INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (3, 'boundaries', 'Grenzen');
+INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (4, 'climatologyMeteorologyAtmosphere', 'Wetterkunde');
+INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (5, 'economy', 'Wirtschaft');
+INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (6, 'elevation', 'Höhendaten');
+INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (7, 'environment', 'Umwelt');
+INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (8, 'geoscientificInformation', 'Geowissenschaft');
+INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (9, 'health', 'Gesundheit');
+INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (10, 'imageryBaseMapsEarthCover', 'Grundlagenkarten');
+INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (11, 'intelligenceMilitary', 'militärische Aufklärung');
+INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (12, 'inlandWaters', 'Binnengewässer');
+INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (13, 'location', 'Ortsinformationen');
+INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (14, 'oceans', 'Meereskunde');
+INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (15, 'planningCadastre', 'Landnutzung/Planung/Kataster');
+INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (16, 'society', 'Gesellschaft');
+INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (17, 'structure', 'Bauwerke');
+INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (18, 'transportation', 'Transportwesen');
+INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (19, 'utilitiesCommunication', 'Infrastruktur');
+-- TOC entry 1800 (class 0 OID 47913270)
+-- Dependencies: 1262
 -- Data for Name: wfs; Type: TABLE DATA; Schema: public; Owner: admin
@@ -7135,14 +7272,11 @@
--- TOC entry 1774 (class 0 OID 39047439)
--- Dependencies: 1256
+-- TOC entry 1801 (class 0 OID 47913278)
+-- Dependencies: 1264
 -- Data for Name: wfs_conf; Type: TABLE DATA; Schema: public; Owner: admin
-INSERT INTO wfs_conf (wfs_conf_id, wfs_conf_abstract, fkey_wfs_id, fkey_featuretype_id, g_label, g_label_id, g_button, g_button_id, g_style, g_buffer, g_res_style, g_use_wzgraphics) VALUES (2, 'myPolygons', 2, 8, 'Polygon:', '', '', '', '', 0.01, '', 1);
-INSERT INTO wfs_conf (wfs_conf_id, wfs_conf_abstract, fkey_wfs_id, fkey_featuretype_id, g_label, g_label_id, g_button, g_button_id, g_style, g_buffer, g_res_style, g_use_wzgraphics) VALUES (4, 'myPoints', 2, 16, 'Point:', '', '', '', '', 0.01, '', 1);
-INSERT INTO wfs_conf (wfs_conf_id, wfs_conf_abstract, fkey_wfs_id, fkey_featuretype_id, g_label, g_label_id, g_button, g_button_id, g_style, g_buffer, g_res_style, g_use_wzgraphics) VALUES (3, 'myLines', 2, 22, 'Line:', '', '', '', '', 0.01, '', 1);
 INSERT INTO wfs_conf (wfs_conf_id, wfs_conf_abstract, fkey_wfs_id, fkey_featuretype_id, g_label, g_label_id, g_button, g_button_id, g_style, g_buffer, g_res_style, g_use_wzgraphics) VALUES (1, 'Mapbender User', 1, 4, 'Mapbender User:', 'a', 'OK', 'b', 'body{
  font-family:Verdana,Arial,sans-serif;
  font-size: 12px;
@@ -7175,32 +7309,110 @@
  font-size: 11px;
 }', 0);
+INSERT INTO wfs_conf (wfs_conf_id, wfs_conf_abstract, fkey_wfs_id, fkey_featuretype_id, g_label, g_label_id, g_button, g_button_id, g_style, g_buffer, g_res_style, g_use_wzgraphics) VALUES (3, 'myLines', 2, 22, 'Line:', 'a', 'ok', 'b', 'body{
+ font-family:Verdana,Arial,sans-serif;
+ font-size: 12px;
+ line-height:2;
+.a{
+ font-weight:bold;
+.b{
+ font-size: 12px;
+ width:40px;
+.c{
+ position:absolute;
+ width:100px;
+ left:75px;
+ font-size: 12px;
+.d{
+ color:#808080;
+}', 0.01, '.even{
+ color:blue;
+ font-size: 11px;
+.uneven{
+ color:red;
+ font-size: 11px;
+}', 1);
+INSERT INTO wfs_conf (wfs_conf_id, wfs_conf_abstract, fkey_wfs_id, fkey_featuretype_id, g_label, g_label_id, g_button, g_button_id, g_style, g_buffer, g_res_style, g_use_wzgraphics) VALUES (4, 'myPoints', 2, 16, 'Point:', 'a', 'go', 'b', 'body{
+ font-size: 12px;
+ line-height:2;
+.a{
+ font-weight:bold;
+.b{
+ font-size: 12px;
+ width:40px;
+.c{
+ width:100px;
+ left:75px;
+ font-size: 12px;
+.d{
+ color:#808080;
+}', 0.01, '.even{
+ color:blue;
+ font-size: 11px;
+.uneven{
+ color:red;
+ font-size: 11px;
+}', 1);
+INSERT INTO wfs_conf (wfs_conf_id, wfs_conf_abstract, fkey_wfs_id, fkey_featuretype_id, g_label, g_label_id, g_button, g_button_id, g_style, g_buffer, g_res_style, g_use_wzgraphics) VALUES (2, 'myPolygons', 2, 8, 'Polygon:', 'a', 'go', 'b', 'body{
+ font-size: 12px;
+ line-height:2;
+.a{
+ font-weight:bold;
+.b{
+ font-size: 12px;
+ width:40px;
+.c{
+ width:100px;
+ left:75px;
+ font-size: 12px;
+.d{
+ color:#808080;
+}', 0.01, '.even{
+ color:aqua;
+ font-size: 11px;
+.uneven{
+ color:silver;
+ font-size: 11px;
+}', 1);
--- TOC entry 1775 (class 0 OID 39047451)
--- Dependencies: 1258
+-- TOC entry 1802 (class 0 OID 47913290)
+-- Dependencies: 1266
 -- Data for Name: wfs_conf_element; Type: TABLE DATA; Schema: public; Owner: admin
-INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (13, 2, 99, 0, 0, 0, 0, '0', 0, '', '0', 1, 1);
-INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (14, 2, 100, 0, 0, 0, 0, '0', 0, '', '0', 0, 0);
-INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (15, 2, 101, 0, 0, 0, 0, '0', 0, '', '0', 0, 0);
-INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (17, 2, 103, 0, 0, 0, 0, '0', 0, '', '0', 0, 0);
-INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (16, 2, 102, 1, 0, 0, 0, '0', 0, '', '0', 0, 0);
-INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (12, 2, 98, 0, 1, 0, 0, '0', 0, '', '0', 0, 0);
-INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (19, 3, 167, 0, 0, 0, 0, '0', 0, '', '0', 1, 1);
-INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (20, 3, 168, 0, 0, 0, 0, '0', 0, '', '0', 0, 0);
-INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (21, 3, 169, 0, 0, 0, 0, '0', 0, '', '0', 0, 0);
-INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (23, 3, 171, 0, 0, 0, 0, '0', 0, '', '0', 0, 0);
-INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (22, 3, 170, 1, 0, 0, 0, '0', 0, '', '0', 0, 0);
-INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (18, 3, 166, 0, 1, 0, 0, '0', 0, '', '0', 0, 0);
-INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (25, 4, 126, 0, 0, 0, 0, '0', 0, '', '0', 1, 1);
-INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (26, 4, 127, 0, 0, 0, 0, '0', 0, '', '0', 0, 0);
-INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (27, 4, 128, 0, 0, 0, 0, '0', 0, '', '0', 0, 0);
-INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (29, 4, 130, 0, 0, 0, 0, '0', 0, '', '0', 0, 0);
-INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (28, 4, 129, 1, 0, 0, 0, '0', 0, '', '0', 0, 0);
-INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (24, 4, 125, 0, 1, 0, 0, '0', 0, '', '0', 0, 0);
 INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (1, 1, 46, 0, 1, 0, 0, '', 0, '', '', 0, 0);
 INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (2, 1, 47, 0, 0, 1, 1, 'c', 0, 'Firstname:', 'd', 1, 2);
 INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (3, 1, 48, 0, 0, 1, 2, 'c', 0, 'Lastname:', 'd', 1, 1);
@@ -7212,11 +7424,29 @@
 INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (9, 1, 54, 0, 0, 0, 0, '', 0, '', '', 0, 0);
 INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (10, 1, 55, 0, 0, 0, 0, '', 0, '', '', 0, 0);
 INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (11, 1, 56, 1, 0, 0, 0, '', 0, '', '', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (18, 3, 166, 0, 1, 0, 0, '0', 0, '', '0', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (19, 3, 167, 0, 0, 1, 1, 'c', 0, '', 'd', 1, 1);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (20, 3, 168, 0, 0, 0, 0, '0', 0, '', '0', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (21, 3, 169, 0, 0, 0, 0, '0', 0, '', '0', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (22, 3, 170, 1, 0, 0, 0, '0', 0, '', '0', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (23, 3, 171, 0, 0, 0, 0, '0', 0, '', '0', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (24, 4, 125, 0, 1, 0, 0, '0', 0, '', '0', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (25, 4, 126, 0, 0, 1, 1, 'c', 0, '', 'd', 1, 1);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (26, 4, 127, 0, 0, 0, 0, '0', 0, '', '0', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (27, 4, 128, 0, 0, 0, 0, '0', 0, '', '0', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (28, 4, 129, 1, 0, 0, 0, '0', 0, '', '0', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (29, 4, 130, 0, 0, 0, 0, '0', 0, '', '0', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (12, 2, 98, 0, 1, 0, 0, '0', 0, '', '0', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (13, 2, 99, 0, 0, 1, 1, 'c', 0, '', 'd', 1, 1);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (14, 2, 100, 0, 0, 0, 0, '0', 0, '', '0', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (15, 2, 101, 0, 0, 0, 0, '0', 0, '', '0', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (16, 2, 102, 1, 0, 0, 0, '0', 0, '', '0', 0, 0);
+INSERT INTO wfs_conf_element (wfs_conf_element_id, fkey_wfs_conf_id, f_id, f_geom, f_gid, f_search, f_pos, f_style_id, f_toupper, f_label, f_label_id, f_show, f_respos) VALUES (17, 2, 103, 0, 0, 0, 0, '0', 0, '', '0', 0, 0);
--- TOC entry 1776 (class 0 OID 39047463)
--- Dependencies: 1260
+-- TOC entry 1803 (class 0 OID 47913302)
+-- Dependencies: 1268
 -- Data for Name: wfs_element; Type: TABLE DATA; Schema: public; Owner: admin
@@ -7398,8 +7628,8 @@
--- TOC entry 1777 (class 0 OID 39047469)
--- Dependencies: 1262
+-- TOC entry 1804 (class 0 OID 47913308)
+-- Dependencies: 1270
 -- Data for Name: wfs_featuretype; Type: TABLE DATA; Schema: public; Owner: admin
@@ -7429,8 +7659,8 @@
--- TOC entry 1781 (class 0 OID 39047651)
--- Dependencies: 1267
+-- TOC entry 1805 (class 0 OID 47913313)
+-- Dependencies: 1271
 -- Data for Name: wfs_featuretype_namespace; Type: TABLE DATA; Schema: public; Owner: admin
@@ -7491,12 +7721,12 @@
--- TOC entry 1778 (class 0 OID 39047476)
--- Dependencies: 1264
+-- TOC entry 1806 (class 0 OID 47913324)
+-- Dependencies: 1273
 -- Data for Name: wms; Type: TABLE DATA; Schema: public; Owner: admin
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (899, '1.1.1', 'Infoprix', 'daSFS GHDS JHDF FSSWQW', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/infoprix.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/infoprix.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/infoprix.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/infoprix.map&', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (899, '1.1.1', 'Infoprix', 'daSFS GHDS JHDF FSSWQW', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/infoprix.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/infoprix.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/infoprix.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/infoprix.map&', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
 <!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengeospatial.net/wms/1.1.1/WMS_MS_Capabilities.dtd"
  <!ELEMENT VendorSpecificCapabilities EMPTY>
@@ -7748,8 +7978,8 @@
   </Layer>
 </Capability>
 </WMT_MS_Capabilities>
-', NULL, 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/infoprix.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (905, '1.1.0', 'DNM FÜK', 'Digitales Navigationsmodell Flurübersichtskarte der Brandenburger Landesvermessung', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMFUEK.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMFUEK.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMFUEK.map&', '', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
+', NULL, 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/infoprix.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (905, '1.1.0', 'DNM FÜK', 'Digitales Navigationsmodell Flurübersichtskarte der Brandenburger Landesvermessung', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMFUEK.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMFUEK.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMFUEK.map&', '', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
 <!DOCTYPE WMT_MS_Capabilities SYSTEM "http://www.digitalearth.gov/wmt/xml/capabilities_1_1_0.dtd"
@@ -7874,49 +8104,47 @@
   </Layer>
 </Capability>
-', NULL, 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMFUEK.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (907, '1.1.0', 'NRW: TK100 Farbe', 'Nutzungsbedingungen: Sämtliche Rechte an diesem Produkt liegen beim Landesvermessungsamt NRW. Die Nutzung ist bis auf Widerruf kostenfrei. Der Nutzer muss sich vor jeder Nutzung beim Landesvermessungsamt NRW identifizieren und seine spezielle Nutzung mit Angabe des Verwendungszwecks und Umfang der Nutzung anmelden (Kontaktmöglichkeiten zum Landesvermessungsamt NRW siehe unten). Die Nutzung ist ausschließlich für Testzwecke und im Rahmen von GDI-Projekten zulässig; die Nutzung für kommerzielle Anwendungen ist ausdrücklich ausgeschlossen. Die mittelbare oder unmittelbare Weitergabe der Daten an Dritte ist auch in Verbindung mit weiteren Daten ohne ausdrückliche Genehmigung durch das Landesvermessungsamt NRW nicht zulässig. Der Nutzer ist verpflichtet, einen deutlichen Copyright-Hinweis auf das Landesvermessungsamt NRW als Dateneigentümer bei Visualisierungen jeder Art anzubringen.', 'http://www.geoserver.nrw.de:80/GeoOgcWms1.3/servlet/TK100', 'http://www.geoserver.nrw.de:80/GeoOgcWms1.3/servlet/TK100', 'http://www.geoserver.nrw.de:80/GeoOgcWms1.3/servlet/TK100', '', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
-<!-- The DTD (Document Type Definition) given here must correspond to the version number declared in the WMT_MS_Capabilities element below. -->
-<!DOCTYPE WMT_MS_Capabilities SYSTEM
-  "http://www.digitalearth.gov/wmt/xml/capabilities_1_1_0.dtd"
-  <!-- other vendor-specific elements defined here -->
-  <!ELEMENT VendorSpecificCapabilities EMPTY>
-  ]>  <!-- end of DOCTYPE declaration -->
+', NULL, 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMFUEK.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (407, '1.1.1', 'Mapbender User', 'Mapbender User Overview (Mapbender User/Postgis)', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&', '', '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
+<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengeospatial.net/wms/1.1.1/WMS_MS_Capabilities.dtd"
+ <!ELEMENT VendorSpecificCapabilities EMPTY>
+ ]>  <!-- end of DOCTYPE declaration -->
-<!-- The version number listed in the WMT_MS_Capabilities element here must correspond to the DTD declared above.  See the WMT specification document for how to respond when a client requests a version number not implemented by the server. -->
+<WMT_MS_Capabilities version="1.1.1">
-<WMT_MS_Capabilities version="1.1.0" updateSequence="0">
-<!-- Service Metadata -->
+<!-- MapServer version 4.8.4 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG -->
 <Service>
-  <!-- The WMT-defined name for this type of service -->
   <Name>OGC:WMS</Name>
-  <!-- Human-readable title for pick lists -->
-  <Title>NRW: TK100 Farbe</Title>
-  <!-- Narrative description providing additional information -->
-      <Abstract>Nutzungsbedingungen: Sämtliche Rechte an diesem Produkt liegen beim Landesvermessungsamt NRW. Die Nutzung ist bis auf Widerruf kostenfrei. Der Nutzer muss sich vor jeder Nutzung beim Landesvermessungsamt NRW identifizieren und seine spezielle Nutzung mit Angabe des Verwendungszwecks und Umfang der Nutzung anmelden (Kontaktmöglichkeiten zum Landesvermessungsamt NRW siehe unten). Die Nutzung ist ausschließlich für Testzwecke und im Rahmen von GDI-Projekten zulässig; die Nutzung für kommerzielle Anwendungen ist ausdrücklich ausgeschlossen. Die mittelbare oder unmittelbare Weitergabe der Daten an Dritte ist auch in Verbindung mit weiteren Daten ohne ausdrückliche Genehmigung durch das Landesvermessungsamt NRW nicht zulässig. Der Nutzer ist verpflichtet, einen deutlichen Copyright-Hinweis auf das Landesvermessungsamt NRW als Dateneigentümer bei Visualisierungen jeder Art anzubringen.</Abstract>
-      <!-- Top-level web address of service or service provider.  See also OnlineResource
-  elements under <DCPType>. -->
-      <!-- Contact information -->
-      <ContactInformation>
-         <ContactPersonPrimary>
-            <ContactPerson>Karin Landsberg</ContactPerson>
-            <ContactOrganization>Landesvermessungsamt NRW</ContactOrganization>
-         </ContactPersonPrimary>
-         <ContactPosition>Geodatenvertrieb</ContactPosition>
-         <ContactAddress>
-            <AddressType/>
-            <Address>Muffendorfer Str. 19-21</Address>
-            <City>Bonn</City>
-            <StateOrProvince>NRW</StateOrProvince>
-            <PostCode>53177</PostCode>
-            <Country>Germany</Country>
-         </ContactAddress>
-         <ContactVoiceTelephone>49 (228) 846 9320</ContactVoiceTelephone>
-         <ContactFacsimileTelephone>49 (228) 846 9002</ContactFacsimileTelephone>
-         <ContactElectronicMailAddress>landsberg at lverma.nrw.de</ContactElectronicMailAddress>
-      </ContactInformation>  <Fees>none</Fees>
+  <Title>Mapbender User</Title>
+  <Abstract>Mapbender User Overview (Mapbender User/Postgis)</Abstract>
+        <KeywordList>
+          <Keyword>Mapbender</Keyword>
+          <Keyword>WebGIS</Keyword>
+          <Keyword>WMS</Keyword>
+          <Keyword>WFS</Keyword>
+        </KeywordList>
+  <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&amp;"/>
+  <ContactInformation>
+    <ContactPersonPrimary>
+      <ContactPerson>A. Emde</ContactPerson>
+      <ContactOrganization>WhereGroup</ContactOrganization>
+    </ContactPersonPrimary>
+      <ContactPosition>WhereGroup</ContactPosition>
+    <ContactAddress>
+        <AddressType>postal</AddressType>
+        <Address>Siemensstrasse 8</Address>
+        <City>Bonn</City>
+        <StateOrProvince>NRW</StateOrProvince>
+        <PostCode>53121</PostCode>
+        <Country>Germany</Country>
+    </ContactAddress>
+      <ContactVoiceTelephone></ContactVoiceTelephone>
+      <ContactFacsimileTelephone>022190903819</ContactFacsimileTelephone>
+  <ContactElectronicMailAddress>astrid.emde at whergroup.com</ContactElectronicMailAddress>
+  </ContactInformation>
+  <Fees>none</Fees>
   <AccessConstraints>none</AccessConstraints>
 </Service>
@@ -7926,76 +8154,143 @@
       <Format>application/vnd.ogc.wms_xml</Format>
       <DCPType>
         <HTTP>
-          <Get>
-            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
-             xlink:href="http://www.geoserver.nrw.de:80/GeoOgcWms1.3/servlet/TK100"
-             xlink:type="simple" />
-          </Get>
-          <Post>
-          </Post>
+          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&amp;"/></Get>
+          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&amp;"/></Post>
         </HTTP>
       </DCPType>
     </GetCapabilities>
     <GetMap>
+      <Format>image/gif</Format>
       <Format>image/png</Format>
-      <Format>image/bmp</Format>
+      <Format>image/png; mode=24bit</Format>
       <Format>image/jpeg</Format>
+      <Format>image/wbmp</Format>
       <Format>image/tiff</Format>
       <DCPType>
         <HTTP>
-          <Get>
-          </Get>
         </HTTP>
       </DCPType>
     </GetMap>
     <GetFeatureInfo>
+      <Format>text/plain</Format>
       <Format>text/html</Format>
-      <Format>text/plain</Format>
+      <Format>application/vnd.ogc.gml</Format>
       <DCPType>
         <HTTP>
-          <Get>
-          </Get>
-          <Post>
-          </Post>
         </HTTP>
       </DCPType>
     </GetFeatureInfo>
+    <DescribeLayer>
+      <Format>text/xml</Format>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </DescribeLayer>
+    <GetLegendGraphic>
+      <Format>image/png</Format>
+      <Format>image/jpeg</Format>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </GetLegendGraphic>
   </Request>
   <Exception>
     <Format>application/vnd.ogc.se_xml</Format>
+    <Format>application/vnd.ogc.se_inimage</Format>
+    <Format>application/vnd.ogc.se_blank</Format>
   </Exception>
-    <Layer queryable="0" opaque="1">
-      <Title>NRW</Title>
-        <SRS>EPSG:31466 EPSG:31462 EPSG:31492 EPSG:31467 EPSG:25831 EPSG:25832 EPSG:25833</SRS>
-        <LatLonBoundingBox minx="5.673" miny="49.9944" maxx="10.142" maxy="52.7691"></LatLonBoundingBox>
-        <BoundingBox SRS="EPSG:31466" minx="2476553.0" miny="5540279.0" maxx="2779499.0" maxy="5856970.0"></BoundingBox>
-        <BoundingBox SRS="EPSG:31462" minx="2476553.0" miny="5540279.0" maxx="2779499.0" maxy="5856970.0"></BoundingBox>
-        <BoundingBox SRS="EPSG:31492" minx="2476553.0" miny="5540279.0" maxx="2779499.0" maxy="5856970.0"></BoundingBox>
-        <BoundingBox SRS="EPSG:31467" minx="3261513.05" miny="5545534.73" maxx="3577127.98" maxy="5849530.15"></BoundingBox>
-        <BoundingBox SRS="EPSG:25831" minx="691515.47" miny="5541873.35" maxx="981462.1" maxy="5870966.62"></BoundingBox>
-        <BoundingBox SRS="EPSG:25832" minx="261533.79" miny="5543758.24" maxx="577026.2" maxy="5847631.27"></BoundingBox>
-        <BoundingBox SRS="EPSG:25833" minx="-167984.51" miny="5580271.61" maxx="172362.07" maxy="5858091.88"></BoundingBox>
-          <ScaleHint min="0.0" max="70.004"></ScaleHint>
-          <Layer queryable="1" opaque="1">
-            <Name>Raster:TK100_KMF:Farbkombination</Name>
-            <Title>Farbkombination</Title>
-          </Layer>
-    </Layer></Capability>
+  <VendorSpecificCapabilities />
+  <UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0"/>
+  <Layer>
+    <Name>Mapbender</Name>
+    <SRS>epsg:4326</SRS>
+    <SRS>epsg:31467</SRS>
+    <SRS>epsg:31466</SRS>
+    <SRS>epsg:31468</SRS>
+    <SRS>epsg:31469</SRS>
+    <SRS>epsg:31492</SRS>
+    <SRS>epsg:31493</SRS>
+    <SRS>epsg:31494</SRS>
+    <SRS>epsg:31495</SRS>
+    <SRS>epsg:31462</SRS>
+    <SRS>epsg:31463</SRS>
+    <SRS>epsg:31464</SRS>
+    <SRS>epsg:31465</SRS>
+    <SRS>epsg:25832</SRS>
+    <SRS>epsg:25833</SRS>
+    <SRS>epsg:31297</SRS>
+    <SRS>epsg:2398</SRS>
+    <LatLonBoundingBox minx="7" miny="42" maxx="12" maxy="59" />
+    <BoundingBox SRS="EPSG:4326"
+                minx="7" miny="42" maxx="12" maxy="59" />
+    <ScaleHint min="0.000498902848429637" max="49890284842963.7" />
+    <Layer queryable="0" opaque="0" cascaded="0">
+        <Name>Mapbender_User</Name>
+        <Abstract>Mapbender</Abstract>
+        <KeywordList>
+        </KeywordList>
+        <LatLonBoundingBox minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07" />
+                    minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07" />
+        <MetadataURL type="TC211">
+          <Format>text/html</Format>
+          <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.mapbender.de/"/>
+        </MetadataURL>
+        <DataURL>
+        </DataURL>
+        <Style>
+          <Name>default</Name>
+          <Title>default</Title>
+          <LegendURL width="20" height="10">
+             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&amp;version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=Mapbender_User&amp;format=image/png"/>
+          </LegendURL>
+        </Style>
+    </Layer>
+    <Layer queryable="1" opaque="0" cascaded="0">
+        <Name>Mapbender_Names</Name>
+        <Title>Mapbender Info</Title>
+        <KeywordList>
+        </KeywordList>
+        </MetadataURL>
+        <DataURL>
+        </DataURL>
+    </Layer>
+  </Layer>
+</Capability>
-', NULL, 'http://www.geoserver.nrw.de/GeoOgcWms1.3/servlet/TK100?REQUEST=GetCapabilities&VERSION=1.1.0&SERVICE=WMS');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (900, '1.1.1', 'Pendjari National Parc', 'Pendjari', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/pendjari.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/pendjari.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/pendjari.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/pendjari.map&', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
+', NULL, 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1', 'none', 'none', 'A. Emde', 'WhereGroup', 'WhereGroup', 'Siemensstrasse 8', 'Bonn', 'NRW', '53121', 'Germany', '', '022190903819', 'astrid.emde at whergroup.com', NULL, 1, 1169808777);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (900, '1.1.1', 'Pendjari National Parc', 'Pendjari', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/pendjari.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/pendjari.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/pendjari.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/pendjari.map&', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
@@ -8223,212 +8518,49 @@
   </Layer>
 </Capability>
-', NULL, 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/pendjari.map&&VERSION=1.1.1&REQUEST=GetCapabilities&SERVICE=WMS');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (906, '1.1.0', 'DNM VG', 'Digitales Navigationsmodell Verwaltungsgrenzen als Basisnavigationsdaten der Brandenburger Landesvermessung', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMVG.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMVG.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMVG.map&', '', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
-<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://www.digitalearth.gov/wmt/xml/capabilities_1_1_0.dtd"
+', NULL, 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/webapps/benin/pendjari.map&&VERSION=1.1.1&REQUEST=GetCapabilities&SERVICE=WMS', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (893, '1.1.1', 'Germany', 'Germany', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
-<!-- MapServer version 4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
 <Service>
-  <Title>DNM VG</Title>
-  <Abstract>Digitales Navigationsmodell Verwaltungsgrenzen als Basisnavigationsdaten der Brandenburger Landesvermessung</Abstract>
-  <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&amp;map=wms/DNMVG.map&amp;"/>
+  <Title>Germany</Title>
+  <Abstract>Germany</Abstract>
         <KeywordList>
-          <Keyword>DNM</Keyword>
-          <Keyword>GDI</Keyword>
+          <Keyword>Germany</Keyword>
+          <Keyword> Deutschland</Keyword>
-          <Keyword>Navigation</Keyword>
-          <Keyword>Brandenburg</Keyword>
+          <Keyword>WhereGroup</Keyword>
         </KeywordList>
+  <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&amp;"/>
+    <ContactAddress>
+        <City>Bonn</City>
+    </ContactAddress>
   <Fees>none</Fees>
-</Service>
-<Capability>
-  <Request>
-    <GetCapabilities>
-      <Format>application/vnd.ogc.wms_xml</Format>
-      <DCPType>
-        <HTTP>
-          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&amp;map=wms/DNMVG.map&amp;"/></Get>
-          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&amp;map=wms/DNMVG.map&amp;"/></Post>
-        </HTTP>
-      </DCPType>
-    </GetCapabilities>
-    <GetMap>
-      <Format>image/png</Format>
-      <Format>image/jpeg</Format>
-      <Format>image/wbmp</Format>
-      <Format>text/html</Format>
-      <Format>application/x-pdf</Format>
-      <Format>image/tiff</Format>
-      <DCPType>
-        <HTTP>
-        </HTTP>
-      </DCPType>
-    </GetMap>
-    <GetFeatureInfo>
-      <Format>application/vnd.ogc.gml</Format>
-      <DCPType>
-        <HTTP>
-        </HTTP>
-      </DCPType>
-    </GetFeatureInfo>
-  </Request>
-  <Exception>
-    <Format>application/vnd.ogc.se_xml</Format>
-    <Format>application/vnd.ogc.se_inimage</Format>
-    <Format>application/vnd.ogc.se_blank</Format>
-  </Exception>
-  <VendorSpecificCapabilities />
-  <Layer>
-    <Name>Brandenburg</Name>
-    <SRS>EPSG:25833</SRS>
-    <LatLonBoundingBox minx="10.8594" miny="51.1966" maxx="15.0908" maxy="53.6627" />
-                minx="3.226e+06" miny="5.679e+06" maxx="3.506e+06" maxy="5.946e+06" />
-    <ScaleHint min="24.9451" max="1247.26" />
-    <Layer queryable="0" opaque="0" cascaded="0">
-        <Name>berlin</Name>
-        <Title>Berliner Bezirke</Title>
-        <LatLonBoundingBox minx="13.0773" miny="52.3311" maxx="13.7647" maxy="52.6794" />
-                    minx="3.36999e+06" miny="5.79958e+06" maxx="3.41584e+06" maxy="5.83733e+06" />
-        <ScaleHint min="24.9451" max="498.903" />
-    </Layer>
-    <Layer queryable="1" opaque="0" cascaded="0">
-        <Name>geme</Name>
-        <Title>Gemeinde</Title>
-        <Abstract>digitaliert aus DTK 1:100.000</Abstract>
-        <LatLonBoundingBox minx="11.2317" miny="51.3099" maxx="14.7656" maxy="53.5639" />
-                    minx="3.25012e+06" miny="5.69039e+06" maxx="3.48368e+06" maxy="5.93503e+06" />
-    </Layer>
-        <Name>kamt</Name>
-        <Title>Amtsfreie Gemeinde</Title>
-        <LatLonBoundingBox minx="11.5254" miny="51.3507" maxx="14.7581" maxy="53.5638" />
-                    minx="3.26964e+06" miny="5.69402e+06" maxx="3.48317e+06" maxy="5.93503e+06" />
-    </Layer>
-        <Name>amt</Name>
-        <Title>Ämter</Title>
-        <LatLonBoundingBox minx="11.2423" miny="51.3099" maxx="14.7656" maxy="53.4443" />
-                    minx="3.25012e+06" miny="5.69039e+06" maxx="3.48368e+06" maxy="5.92173e+06" />
-    </Layer>
-        <Name>stadt</Name>
-        <Title>Kreisfreie Städte</Title>
-        <LatLonBoundingBox minx="12.3551" miny="51.6655" maxx="14.607" maxy="52.5623" />
-                    minx="3.32061e+06" miny="5.72702e+06" maxx="3.47284e+06" maxy="5.82365e+06" />
-    </Layer>
-        <Name>kreis</Name>
-        <Title>Landkreise</Title>
-    </Layer>
-        <Name>land</Name>
-        <Title>Land</Title>
-    </Layer>
-        <Name>staat</Name>
-        <Title>Deutschland</Title>
-        <LatLonBoundingBox minx="14.1131" miny="51.5791" maxx="14.7644" maxy="53.3307" />
-                    minx="3.44093e+06" miny="5.71457e+06" maxx="3.48368e+06" maxy="5.90909e+06" />
-    </Layer>
-        <Name>ngeme</Name>
-        <Title>Namen der Gemeinden</Title>
-    </Layer>
-        <Name>nkamt</Name>
-        <Title>Namen der amtfreien Gemeinden</Title>
-    </Layer>
-        <Name>namt</Name>
-        <Title>Namen der Ämter</Title>
-    </Layer>
-        <Name>nkreis</Name>
-        <Title>KFZ Kennzeichen der Kreise</Title>
-    </Layer>
-  </Layer>
-</Capability>
-</WMT_MS_Capabilities>
-', NULL, 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMVG.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (893, '1.1.1', 'Germany', 'Germany', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&', NULL, '<?xml version="1.0" encoding="ISO-8859-1" standalone="no" ?>
-<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengeospatial.net/wms/1.1.1/WMS_MS_Capabilities.dtd"
-<WMT_MS_Capabilities version="1.1.1">
-<!-- MapServer version 4.4.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
-<Service>
-  <Name>OGC:WMS</Name>
-  <Title>Germany</Title>
-  <Abstract>Germany</Abstract>
-  <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&amp;"/>
 </Service>
@@ -8501,21 +8633,46 @@
   <Layer>
     <Name>Germany</Name>
-    <SRS>epsg:4326 epsg:31467 epsg:31466 epsg:31468 epsg:31469 epsg:31492 epsg:31493 epsg:31494 epsg:31495 epsg:31462 epsg:31463 epsg:31464 epsg:31465 epsg:25832 epsg:25833 epsg:31287 epsg:32633</SRS>
+    <SRS>epsg:31287</SRS>
+    <SRS>epsg:32633</SRS>
     <LatLonBoundingBox minx="5.60075" miny="47.2441" maxx="15.425" maxy="55.0317" />
                 minx="3.28245e+06" miny="5.24826e+06" maxx="3.91224e+06" maxy="6.10013e+06" />
-    <ScaleHint min="0.000498903" max="4.98903e+13" />
         <Name>Topographie</Name>
         <Title>topography</Title>
+        <Abstract>Topographie,Landschaft</Abstract>
+        <KeywordList>
+        </KeywordList>
         <LatLonBoundingBox minx="5.86563" miny="47.2758" maxx="15" maxy="55.0556" />
+        </MetadataURL>
         <DataURL>
-          <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.ccgis.de"/>
         </DataURL>
         <Style>
@@ -8529,10 +8686,22 @@
         <Name>Grenze</Name>
         <Title>border</Title>
+        <Abstract>Grenzen, border</Abstract>
+        <KeywordList>
+        </KeywordList>
+        </MetadataURL>
+        <DataURL>
+        </DataURL>
         <Style>
@@ -8541,15 +8710,28 @@
              <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&amp;version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=Grenze&amp;format=image/png"/>
           </LegendURL>
         </Style>
-        <ScaleHint min="374.177" max="4.98903e+13" />
+        <ScaleHint min="374.177136322228" max="49890284842963.7" />
     </Layer>
         <Name>Bundeslaender</Name>
         <Title>federal states</Title>
+        <Abstract>Laender</Abstract>
+        <KeywordList>
+          <Keyword>Laender</Keyword>
+          <Keyword>land</Keyword>
+        </KeywordList>
         <LatLonBoundingBox minx="5.86417" miny="47.2747" maxx="15.0389" maxy="55.0567" />
+        </MetadataURL>
+        <DataURL>
+        </DataURL>
         <Style>
@@ -8558,15 +8740,30 @@
              <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&amp;version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=Bundeslaender&amp;format=image/png"/>
           </LegendURL>
         </Style>
-        <ScaleHint min="374.177" max="449013" />
+        <ScaleHint min="374.177136322228" max="449012.563586673" />
     </Layer>
         <Name>Staedte</Name>
         <Title>places</Title>
+        <Abstract>Staedte in der BRD</Abstract>
+        <KeywordList>
+          <Keyword>city</Keyword>
+          <Keyword>Ort</Keyword>
+          <Keyword> Staedte</Keyword>
+          <Keyword>Stadt</Keyword>
+        </KeywordList>
         <LatLonBoundingBox minx="6.05223" miny="47.4825" maxx="14.9981" maxy="54.9405" />
+        </MetadataURL>
+        <DataURL>
+        </DataURL>
         <Style>
@@ -8575,15 +8772,29 @@
              <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&amp;version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=Staedte&amp;format=image/png"/>
           </LegendURL>
         </Style>
-        <ScaleHint min="0" max="4490.13" />
+        <ScaleHint min="0" max="4490.12563586673" />
     </Layer>
         <Name>Postleitzahlbereiche</Name>
         <Title>postcode areas</Title>
+        <Abstract>Postleitzahl,PLZ,postcode</Abstract>
+        <KeywordList>
+          <Keyword>Postleitzahl</Keyword>
+          <Keyword>PLZ</Keyword>
+          <Keyword>postcode</Keyword>
+        </KeywordList>
         <LatLonBoundingBox minx="5.86629" miny="47.2736" maxx="15.0486" maxy="55.0583" />
+        </MetadataURL>
+        <DataURL>
+        </DataURL>
         <Style>
@@ -8596,10 +8807,24 @@
         <Name>Bahnlinien</Name>
         <Title>railroad lines</Title>
+        <Abstract>railroad,Bahn,DB</Abstract>
+        <KeywordList>
+          <Keyword>railroad</Keyword>
+          <Keyword>Bahn</Keyword>
+          <Keyword>DB</Keyword>
+        </KeywordList>
         <LatLonBoundingBox minx="5.98259" miny="47.4064" maxx="15" maxy="54.9045" />
+        </MetadataURL>
+        <DataURL>
+        </DataURL>
         <Style>
@@ -8612,10 +8837,25 @@
         <Name>Fluesse</Name>
         <Title>rivers</Title>
+        <Abstract>river</Abstract>
+        <KeywordList>
+          <Keyword>river</Keyword>
+          <Keyword>Fluss</Keyword>
+          <Keyword>water</Keyword>
+          <Keyword>Wasser</Keyword>
+        </KeywordList>
         <LatLonBoundingBox minx="5.95192" miny="47.2864" maxx="14.9759" maxy="54.9107" />
+        </MetadataURL>
+        <DataURL>
+        </DataURL>
         <Style>
@@ -8624,15 +8864,29 @@
              <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&amp;version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=Fluesse&amp;format=image/png"/>
           </LegendURL>
         </Style>
-        <ScaleHint min="0" max="623.629" />
+        <ScaleHint min="0" max="623.628560537046" />
     </Layer>
         <Name>Strassen</Name>
         <Title>roads</Title>
+        <Abstract>road</Abstract>
+        <KeywordList>
+          <Keyword>road</Keyword>
+          <Keyword>Strasse</Keyword>
+          <Keyword>Infrastruktur</Keyword>
+        </KeywordList>
         <LatLonBoundingBox minx="5.90508" miny="47.3136" maxx="14.9981" maxy="55.0157" />
+        </MetadataURL>
+        <DataURL>
+        </DataURL>
         <Style>
@@ -8645,10 +8899,24 @@
         <Name>Staedtepunkte</Name>
         <Title>places as point</Title>
+        <Abstract>Stadt</Abstract>
+        <KeywordList>
+          <Keyword>Staedte</Keyword>
+        </KeywordList>
         <LatLonBoundingBox minx="6.01667" miny="47.4" maxx="15" maxy="54.9" />
+        </MetadataURL>
+        <DataURL>
+        </DataURL>
         <Style>
@@ -8661,49 +8929,94 @@
         <Name>Postleitzahlbereichname</Name>
         <Title>postcode areas (names)</Title>
+        <Abstract>PLZ</Abstract>
+        <KeywordList>
+        </KeywordList>
-        <ScaleHint min="0" max="174.616" />
+        </MetadataURL>
+        <DataURL>
+        </DataURL>
+        <ScaleHint min="0" max="174.615996950373" />
     </Layer>
         <Name>Staedtenamen</Name>
         <Title>places (names)</Title>
+        <Abstract>city</Abstract>
+        <KeywordList>
+        </KeywordList>
+        </MetadataURL>
+        <DataURL>
+        </DataURL>
     </Layer>
         <Name>Bundeslaendernamen</Name>
         <Title>federal states (names)</Title>
+        <Abstract>Bundesland</Abstract>
+        <KeywordList>
+          <Keyword>Bundesland</Keyword>
+          <Keyword>Land</Keyword>
+        </KeywordList>
-        <ScaleHint min="498.903" max="39912.2" />
+        </MetadataURL>
+        <DataURL>
+        </DataURL>
+        <ScaleHint min="498.902848429637" max="39912.227874371" />
     </Layer>
   </Layer>
 </Capability>
-', '', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (901, '1.1.1', 'MyEdit Elements', 'germany_wfs_places', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
+', '', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1', 'none', 'none', 'A. Emde', 'WhereGroup', 'WhereGroup', 'Siemensstrasse 8', 'Bonn', 'NRW', '53121', 'Germany', '', '022190903819', 'astrid.emde at whergroup.com', NULL, 1, 1169808745);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (906, '1.1.0', 'DNM VG', 'Digitales Navigationsmodell Verwaltungsgrenzen als Basisnavigationsdaten der Brandenburger Landesvermessung', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMVG.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMVG.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMVG.map&', '', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
+<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://www.digitalearth.gov/wmt/xml/capabilities_1_1_0.dtd"
+<WMT_MS_Capabilities version="1.1.0" updateSequence="0">
-<!-- MapServer version 4.8.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG -->
+<!-- MapServer version 4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
 <Service>
-  <Title>MyEdit Elements</Title>
-  <Abstract>germany_wfs_places</Abstract>
-  <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&amp;"/>
-  <AccessConstraints>none</AccessConstraints>
+  <Title>DNM VG</Title>
+  <Abstract>Digitales Navigationsmodell Verwaltungsgrenzen als Basisnavigationsdaten der Brandenburger Landesvermessung</Abstract>
+  <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&amp;map=wms/DNMVG.map&amp;"/>
+        <KeywordList>
+          <Keyword>DNM</Keyword>
+          <Keyword>GDI</Keyword>
+          <Keyword>Navigation</Keyword>
+          <Keyword>Brandenburg</Keyword>
+        </KeywordList>
+  <Fees>none</Fees>
 </Service>
 <Capability>
@@ -8712,22 +9025,22 @@
       <DCPType>
         <HTTP>
-          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&amp;"/></Get>
-          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&amp;"/></Post>
+          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&amp;map=wms/DNMVG.map&amp;"/></Get>
+          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&amp;map=wms/DNMVG.map&amp;"/></Post>
         </HTTP>
       </DCPType>
     </GetCapabilities>
     <GetMap>
-      <Format>image/gif</Format>
-      <Format>image/png; mode=24bit</Format>
+      <Format>application/x-pdf</Format>
       <DCPType>
         <HTTP>
         </HTTP>
       </DCPType>
     </GetMap>
@@ -8737,33 +9050,11 @@
       <DCPType>
         <HTTP>
         </HTTP>
       </DCPType>
     </GetFeatureInfo>
-    <DescribeLayer>
-      <Format>text/xml</Format>
-      <DCPType>
-        <HTTP>
-        </HTTP>
-      </DCPType>
-    </DescribeLayer>
-    <GetLegendGraphic>
-      <DCPType>
-        <HTTP>
-        </HTTP>
-      </DCPType>
-    </GetLegendGraphic>
   </Request>
   <Exception>
@@ -8771,79 +9062,135 @@
   </Exception>
-  <UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0"/>
   <Layer>
-    <Name>germany_wfs_myedit</Name>
-    <SRS>epsg:4326</SRS>
-    <SRS>epsg:31467</SRS>
-    <SRS>epsg:31466</SRS>
-    <SRS>epsg:31468</SRS>
-    <SRS>epsg:31469</SRS>
-    <LatLonBoundingBox minx="5.88" miny="46.6213" maxx="15" maxy="55.7187" />
-    <BoundingBox SRS="EPSG:4326"
-                minx="5.88" miny="46.6213" maxx="15" maxy="55.7187" />
-    <ScaleHint min="0.000498902848429637" max="498902.848429637" />
+    <Name>Brandenburg</Name>
+    <SRS>EPSG:25833</SRS>
+    <LatLonBoundingBox minx="10.8594" miny="51.1966" maxx="15.0908" maxy="53.6627" />
+    <BoundingBox SRS="EPSG:25833"
+                minx="3.226e+06" miny="5.679e+06" maxx="3.506e+06" maxy="5.946e+06" />
+    <ScaleHint min="24.9451" max="1247.26" />
+        <Name>berlin</Name>
+        <Title>Berliner Bezirke</Title>
+        <LatLonBoundingBox minx="13.0773" miny="52.3311" maxx="13.7647" maxy="52.6794" />
+                    minx="3.36999e+06" miny="5.79958e+06" maxx="3.41584e+06" maxy="5.83733e+06" />
+        <ScaleHint min="24.9451" max="498.903" />
+    </Layer>
-        <Name>my_polygons</Name>
-        <Title>my polygons</Title>
-        <LatLonBoundingBox minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07" />
-                    minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07" />
-        <Style>
-          <Name>default</Name>
-          <Title>default</Title>
-          <LegendURL width="16" height="10">
-             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&amp;version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=my_polygons&amp;format=image/png"/>
-          </LegendURL>
-        </Style>
+        <Name>geme</Name>
+        <Title>Gemeinde</Title>
+        <Abstract>digitaliert aus DTK 1:100.000</Abstract>
+        <LatLonBoundingBox minx="11.2317" miny="51.3099" maxx="14.7656" maxy="53.5639" />
+                    minx="3.25012e+06" miny="5.69039e+06" maxx="3.48368e+06" maxy="5.93503e+06" />
     </Layer>
-        <Name>my_lines</Name>
-        <Title>my lines</Title>
-        <Style>
-             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&amp;version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=my_lines&amp;format=image/png"/>
-          </LegendURL>
-        </Style>
+        <Name>kamt</Name>
+        <Title>Amtsfreie Gemeinde</Title>
+        <LatLonBoundingBox minx="11.5254" miny="51.3507" maxx="14.7581" maxy="53.5638" />
+                    minx="3.26964e+06" miny="5.69402e+06" maxx="3.48317e+06" maxy="5.93503e+06" />
     </Layer>
-        <Name>my_points</Name>
-        <Title>my points</Title>
-        <Style>
-             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&amp;version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=my_points&amp;format=image/png"/>
-          </LegendURL>
-        </Style>
+        <Name>amt</Name>
+        <Title>Ämter</Title>
+        <LatLonBoundingBox minx="11.2423" miny="51.3099" maxx="14.7656" maxy="53.4443" />
+                    minx="3.25012e+06" miny="5.69039e+06" maxx="3.48368e+06" maxy="5.92173e+06" />
     </Layer>
+        <Name>stadt</Name>
+        <Title>Kreisfreie Städte</Title>
+        <LatLonBoundingBox minx="12.3551" miny="51.6655" maxx="14.607" maxy="52.5623" />
+                    minx="3.32061e+06" miny="5.72702e+06" maxx="3.47284e+06" maxy="5.82365e+06" />
+    </Layer>
+        <Name>kreis</Name>
+        <Title>Landkreise</Title>
+    </Layer>
+        <Name>land</Name>
+        <Title>Land</Title>
+    </Layer>
+        <Name>staat</Name>
+        <Title>Deutschland</Title>
+        <LatLonBoundingBox minx="14.1131" miny="51.5791" maxx="14.7644" maxy="53.3307" />
+                    minx="3.44093e+06" miny="5.71457e+06" maxx="3.48368e+06" maxy="5.90909e+06" />
+    </Layer>
+        <Name>ngeme</Name>
+        <Title>Namen der Gemeinden</Title>
+    </Layer>
+        <Name>nkamt</Name>
+        <Title>Namen der amtfreien Gemeinden</Title>
+    </Layer>
+        <Name>namt</Name>
+        <Title>Namen der Ämter</Title>
+    </Layer>
+        <Name>nkreis</Name>
+        <Title>KFZ Kennzeichen der Kreise</Title>
+    </Layer>
   </Layer>
 </Capability>
-', NULL, 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&VERSION=1.1.1&REQUEST=GetCapabilities&SERVICE=WMS');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (824, '1.1.1', 'Image Web Server', 'WMS Version 1.1.1', 'http://camber.mc.man.ac.uk/ecwp/ecw_wms.dll', 'http://camber.mc.man.ac.uk/ecwp/ecw_wms.dll', '', '', '', '', NULL, 'http://camber.mc.man.ac.uk/ecwp/ecw_wms.dll');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (250, '1.1.1', 'Demis World Map', 'Demis World Map', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&', '', '', '', NULL, 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (86, '1.1.1', 'World Map', 'World Map in WGS84 Reference System', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/world/world_map.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/world/world_map.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/world/world_map.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/world/world_map.map&', '', '', NULL, 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/world/world_map.map&');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (101, '1.1.1', 'UMN Mapserver', 'UMN User Overview (UMN MapServer/Postgis)', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/umn_user.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/umn_user.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/umn_user.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/umn_user.map&', '', '', NULL, 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/umn_user.map&');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (328, '1.1.0', 'OSIRIS-WMS, GIS Consult GmbH', 'Web Map Service auf Basis des Smallworld GIS', 'http://services.gis-consult.de/NWSIB-online/GCGisService', 'http://services.gis-consult.de/NWSIB-online/GCGisService', 'http://services.gis-consult.de/NWSIB-online/GCGisService', '', '', '', NULL, 'http://services.gis-consult.de/NWSIB-online/GCGisService');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (329, '1.1.0', 'Geobasisdaten Muenster', 'Geobasisdaten Muenster', 'http://geo.stadt-muenster.de/cgi-bin/geobasis?', 'http://geo.stadt-muenster.de/cgi-bin/geobasis?', 'http://geo.stadt-muenster.de/cgi-bin/geobasis?', '', '', '', NULL, 'http://geo.stadt-muenster.de/cgi-bin/geobasis?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (407, '1.1.1', 'Mapbender User', 'Mapbender User Overview (Mapbender User/Postgis)', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&', '', '', NULL, 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (867, '1.1.0', 'FIS Stobo NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/stobo?', 'http://www.gis2.nrw.de/wmsconnector/wms/stobo?', 'http://www.gis2.nrw.de/wmsconnector/wms/stobo?', '', NULL, '<?xml version="1.0" encoding="UTF-8"?>
+', NULL, 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMVG.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (777, '1.1.1', 'Lieu / Locations', 'Boundaries and Cities of Africa', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/resimao/resimao.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/resimao/resimao.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/resimao/resimao.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/resimao/resimao.map&', '', '', NULL, 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/resimao/resimao.map&', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (824, '1.1.1', 'Image Web Server', 'WMS Version 1.1.1', 'http://camber.mc.man.ac.uk/ecwp/ecw_wms.dll', 'http://camber.mc.man.ac.uk/ecwp/ecw_wms.dll', '', '', '', '', NULL, 'http://camber.mc.man.ac.uk/ecwp/ecw_wms.dll', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (250, '1.1.1', 'Demis World Map', 'Demis World Map', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&', '', '', '', NULL, 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (86, '1.1.1', 'World Map', 'World Map in WGS84 Reference System', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/world/world_map.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/world/world_map.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/world/world_map.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/world/world_map.map&', '', '', NULL, 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/world/world_map.map&', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (101, '1.1.1', 'UMN Mapserver', 'UMN User Overview (UMN MapServer/Postgis)', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/umn_user.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/umn_user.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/umn_user.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/umn_user.map&', '', '', NULL, 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/umn_user.map&', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (328, '1.1.0', 'OSIRIS-WMS, GIS Consult GmbH', 'Web Map Service auf Basis des Smallworld GIS', 'http://services.gis-consult.de/NWSIB-online/GCGisService', 'http://services.gis-consult.de/NWSIB-online/GCGisService', 'http://services.gis-consult.de/NWSIB-online/GCGisService', '', '', '', NULL, 'http://services.gis-consult.de/NWSIB-online/GCGisService', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (329, '1.1.0', 'Geobasisdaten Muenster', 'Geobasisdaten Muenster', 'http://geo.stadt-muenster.de/cgi-bin/geobasis?', 'http://geo.stadt-muenster.de/cgi-bin/geobasis?', 'http://geo.stadt-muenster.de/cgi-bin/geobasis?', '', '', '', NULL, 'http://geo.stadt-muenster.de/cgi-bin/geobasis?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (867, '1.1.0', 'FIS Stobo NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/stobo?', 'http://www.gis2.nrw.de/wmsconnector/wms/stobo?', 'http://www.gis2.nrw.de/wmsconnector/wms/stobo?', '', NULL, '<?xml version="1.0" encoding="UTF-8"?>
   SYSTEM "http://www.gis2.nrw.de/wmsconnector/schema/wms/1.1.0/capabilities_1_1_0.dtd">
 <WMT_MS_Capabilities updateSequence="0" version="1.1.0">
@@ -9130,31 +9477,31 @@
 			</Layer>
 		</Layer>
 	</Capability>
-</WMT_MS_Capabilities>', NULL, 'http://www.gis2.nrw.de/wmsconnector/wms/stobo?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (486, '1.1.1', 'PLZ_441', 'PLZ (post code areas Germany) served with UMN MapServer 4.4.1', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany_demo/PLZ_441.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany_demo/PLZ_441.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany_demo/PLZ_441.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany_demo/PLZ_441.map&', '', '', NULL, 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany_demo/PLZ_441.map&');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (525, '1.1.1', 'Middle America', 'Middle_America', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/middle_america/middle_america.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/middle_america/middle_america.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/middle_america/middle_america.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/middle_america/middle_america.map&', '', '', NULL, 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/middle_america/middle_america.map&');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (583, '1.1.0', 'Atlas of Canada WMS', 'The Atlas of Canadas Web Mapping Service (WMS) is an Internet-based service designed to provide developers of on-line mapping tools access to the Atlas of Canadas base layers.   By using this service, developers gain access to our most current and accurat', 'http://atlas.gc.ca:80/cgi-bin/atlaswms_en?', 'http://atlas.gc.ca:80/cgi-bin/atlaswms_en?', 'http://atlas.gc.ca:80/cgi-bin/atlaswms_en?', '', '', '', NULL, 'http://atlas.gc.ca:80/cgi-bin/atlaswms_en?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (584, '1.1.1', 'Bird Studies Canada WMS/WFS Server', 'Bird Studies Canada WMS/WFS Server for bird distribution and abundance data, and related information.  Bird Studies Canada gratefully acknowledges the support of Environment Canada - Canadian Information System for the Environment in developing this servi', 'http://www.bsc-eoc.org/cgi-bin/bsc_ows.asp?', 'http://www.bsc-eoc.org/cgi-bin/bsc_ows.asp?', 'http://www.bsc-eoc.org/cgi-bin/bsc_ows.asp?', 'http://www.bsc-eoc.org/cgi-bin/bsc_ows.asp?', '', '', NULL, 'http://www.bsc-eoc.org/cgi-bin/bsc_ows.asp?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (612, '1.1.2', 'ESA CubeSERV', 'European Space Agency CubeSERV map server.', 'http://mapserv2.esrin.esa.it/cubestor/cubeserv/cubeserv.cgi?', 'http://mapserv2.esrin.esa.it/cubestor/cubeserv/cubeserv.cgi?', 'http://mapserv2.esrin.esa.it/cubestor/cubeserv/cubeserv.cgi?', 'http://mapserv2.esrin.esa.it/cubestor/cubeserv/cubeserv.cgi?', '', '', NULL, 'http://mapserv2.esrin.esa.it/cubestor/cubeserv/cubeserv.cgi?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (613, '1.1.1', 'ESRI Co. Map Server', 'OGC - Web Map Server.', 'http://www.geographynetwork.com/ogc/com.esri.ogc.wms.WMSServlet?', 'http://www.geographynetwork.com/ogc/com.esri.ogc.wms.WMSServlet?', 'http://www.geographynetwork.com/ogc/com.esri.ogc.wms.WMSServlet?', '', '', '', NULL, 'http://www.geographynetwork.com/ogc/com.esri.ogc.wms.WMSServlet?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (614, '1.0.0', 'ESRI Inc. Map Server', 'WMT Map Server maintained by ESRI Inc.', 'http://inside3.uidaho.edu:80/servlet/com.esri.wms.Esrimap?servicename=WMS_WebMapCAP', 'http://inside3.uidaho.edu:80/servlet/com.esri.wms.Esrimap?servicename=WMS_WebMapCAP', 'http://inside3.uidaho.edu:80/servlet/com.esri.wms.Esrimap?servicename=WMS_WebMapCAP', '', '', '', NULL, 'http://inside3.uidaho.edu:80/servlet/com.esri.wms.Esrimap?servicename=WMS_WebMapCAP');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (615, '1.0.0', 'ESRI Inc. Map Server', 'WMT Map Server maintained by ESRI Inc.', 'http://maps.ciesin.org:80/servlet/com.esri.wms.Esrimap?', 'http://maps.ciesin.org:80/servlet/com.esri.wms.Esrimap?', 'http://maps.ciesin.org:80/servlet/com.esri.wms.Esrimap?', '', '', '', NULL, 'http://maps.ciesin.org:80/servlet/com.esri.wms.Esrimap?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (616, '1.1.1', 'ESRI Web Map Service', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://142.176.62.108/wmsconnector/com.esri.wsit.WMSServlet/GeoNovaSDE?', 'http://142.176.62.108/wmsconnector/com.esri.wsit.WMSServlet/GeoNovaSDE?', 'http://142.176.62.108/wmsconnector/com.esri.wsit.WMSServlet/GeoNovaSDE?', '', '', '', NULL, 'http://142.176.62.108/wmsconnector/com.esri.wsit.WMSServlet/GeoNovaSDE?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (617, '1.1.1', 'ESRI Web Map Service', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.geographynetwork.ca/wmsconnector/com.esri.wsit.WMSServlet/Geobase_NRN_NewfoundlandAndLabrador_I_Detail?', 'http://www.geographynetwork.ca/wmsconnector/com.esri.wsit.WMSServlet/Geobase_NRN_NewfoundlandAndLabrador_I_Detail?', 'http://www.geographynetwork.ca/wmsconnector/com.esri.wsit.WMSServlet/Geobase_NRN_NewfoundlandAndLabrador_I_Detail?', '', '', '', NULL, 'http://www.geographynetwork.ca/wmsconnector/com.esri.wsit.WMSServlet/Geobase_NRN_NewfoundlandAndLabrador_I_Detail?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (624, '1.1.0', 'Gewaesserstationierungskarte des Landes NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/gewstat?', 'http://www.gis2.nrw.de/wmsconnector/wms/gewstat?', 'http://www.gis2.nrw.de/wmsconnector/wms/gewstat?', '', '', '', NULL, 'http://www.gis2.nrw.de/wmsconnector/wms/gewstat?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (625, '1.1.1', 'GMap WMS Demo Server', 'This demonstration server was setup by DM Solutions Group (http://www.dmsolutions.ca/) and is powered by the UMN MapServer (http://mapserver.gis.umn.edu/).  This server uses Canadian source data (c)2000, Government of Canada with permission from Natural R', 'http://dev1.dmsolutions.ca/cgi-bin/mswms_gmap?', 'http://dev1.dmsolutions.ca/cgi-bin/mswms_gmap?', 'http://dev1.dmsolutions.ca/cgi-bin/mswms_gmap?', 'http://dev1.dmsolutions.ca/cgi-bin/mswms_gmap?', '', '', NULL, 'http://dev1.dmsolutions.ca/cgi-bin/mswms_gmap?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (634, '1.1.0', 'Location mapserver', 'This service provides approximate point locations for various    themes.', 'http://www.indexgeo.com.au/cgi-bin/wms-location', 'http://www.indexgeo.com.au/cgi-bin/wms-location', 'http://www.indexgeo.com.au/cgi-bin/wms-location', '', '', '', NULL, 'http://www.indexgeo.com.au/cgi-bin/wms-location');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (637, '1.1.1', 'MapServer WMS Demo', 'This is a UMN WMS MapServer demonstration application for global elevation data.', 'http://cooa.whoi.edu/cw/etopo2_wms?', 'http://cooa.whoi.edu/cw/etopo2_wms?', 'http://cooa.whoi.edu/cw/etopo2_wms?', '', '', '', NULL, 'http://cooa.whoi.edu/cw/etopo2_wms?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (640, '1.1.1', 'JPL World Map Service', 'WMS Server maintained by JPL, worldwide satellite imagery.', 'http://wms.jpl.nasa.gov/wms.cgi?', 'http://wms.jpl.nasa.gov/wms.cgi?', '', '', '', '', NULL, 'http://wms.jpl.nasa.gov/wms.cgi?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (645, '1.1.1', 'Multi-Hazard Mapping Initiative WMS Map Server (HDM)', 'This map server is provided by the Multi-Hazard Mapping Initiative and hosted by Harvard Design & Mapping Co., Inc.', 'http://www.hazardmaps.gov/ogc/wms?', 'http://www.hazardmaps.gov/ogc/wms?', 'http://www.hazardmaps.gov/ogc/wms?', '', '', '', NULL, 'http://www.hazardmaps.gov/ogc/wms?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (648, '1.1.0', 'Neigungsklassen zur Gelaendebefahrbarkeit', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/hangneigung?', 'http://www.gis2.nrw.de/wmsconnector/wms/hangneigung?', 'http://www.gis2.nrw.de/wmsconnector/wms/hangneigung?', '', '', '', NULL, 'http://www.gis2.nrw.de/wmsconnector/wms/hangneigung?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (655, '1.1.1', 'SEACOOS Remotely-Sensed Imagery', 'The SouthEast Atlantic Coastal Ocean Observing System (SEACOOS) is a regional partnership that has initiated an integrated coastal ocean observing system for a four-state region of the southeast U.S.  SEACOOS brings together many organizations witha veste', 'http://nautilus.baruch.sc.edu/wms/seacoos_rs?', 'http://nautilus.baruch.sc.edu/wms/seacoos_rs?', 'http://nautilus.baruch.sc.edu/wms/seacoos_rs?', 'http://nautilus.baruch.sc.edu/wms/seacoos_rs?', '', '', NULL, 'http://nautilus.baruch.sc.edu/wms/seacoos_rs?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (670, '1.1.0', 'Waldtypenkarte NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/waldtyp?', 'http://www.gis2.nrw.de/wmsconnector/wms/waldtyp?', 'http://www.gis2.nrw.de/wmsconnector/wms/waldtyp?', '', '', '', NULL, 'http://www.gis2.nrw.de/wmsconnector/wms/waldtyp?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (671, '1.1.0', 'Wasserschutzgebiete NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/wsg?', 'http://www.gis2.nrw.de/wmsconnector/wms/wsg?', 'http://www.gis2.nrw.de/wmsconnector/wms/wsg?', '', '', '', NULL, 'http://www.gis2.nrw.de/wmsconnector/wms/wsg?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (706, '1.1.0', 'WMS Map Server Australien', 'WMS Map Server Australien', 'http://atlas.walis.wa.gov.au:80/servlet/com.esri.wms.Esrimap?', 'http://atlas.walis.wa.gov.au:80/servlet/com.esri.wms.Esrimap?', 'http://atlas.walis.wa.gov.au:80/servlet/com.esri.wms.Esrimap?', '', '', '', NULL, 'http://atlas.walis.wa.gov.au:80/servlet/com.esri.wms.Esrimap?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (717, '1.1.0', 'Forstliche Verwaltungsgrenzen NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/forstamtsgr?', 'http://www.gis2.nrw.de/wmsconnector/wms/forstamtsgr?', 'http://www.gis2.nrw.de/wmsconnector/wms/forstamtsgr?', '', '', '', NULL, 'http://www.gis2.nrw.de/wmsconnector/wms/forstamtsgr?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (739, '1.1.1', 'Web Map Service Eusoils_Ex', 'ArcIMS 9.0 SP2 - Eusoils_Ex Web Map Service', 'http://eusoils.jrc.it:80/wmsconnector/com.esri.wms.Esrimap/Eusoils_Ex?', 'http://eusoils.jrc.it:80/wmsconnector/com.esri.wms.Esrimap/Eusoils_Ex?', 'http://eusoils.jrc.it:80/wmsconnector/com.esri.wms.Esrimap/Eusoils_Ex?', '', '', '', NULL, 'http://eusoils.jrc.it:80/wmsconnector/com.esri.wms.Esrimap/Eusoils_Ex?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (902, '1.1.0', 'DNM 100/2', '2. Generation des Digitalen Navigationsmodells 1:100.000 als topographische Basisnavigationsdaten der Brandenburger Landesvermessung', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM100n.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM100n.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM100n.map&', '', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
+</WMT_MS_Capabilities>', NULL, 'http://www.gis2.nrw.de/wmsconnector/wms/stobo?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (486, '1.1.1', 'PLZ_441', 'PLZ (post code areas Germany) served with UMN MapServer 4.4.1', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany_demo/PLZ_441.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany_demo/PLZ_441.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany_demo/PLZ_441.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany_demo/PLZ_441.map&', '', '', NULL, 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany_demo/PLZ_441.map&', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (525, '1.1.1', 'Middle America', 'Middle_America', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/middle_america/middle_america.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/middle_america/middle_america.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/middle_america/middle_america.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/middle_america/middle_america.map&', '', '', NULL, 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/middle_america/middle_america.map&', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (583, '1.1.0', 'Atlas of Canada WMS', 'The Atlas of Canadas Web Mapping Service (WMS) is an Internet-based service designed to provide developers of on-line mapping tools access to the Atlas of Canadas base layers.   By using this service, developers gain access to our most current and accurat', 'http://atlas.gc.ca:80/cgi-bin/atlaswms_en?', 'http://atlas.gc.ca:80/cgi-bin/atlaswms_en?', 'http://atlas.gc.ca:80/cgi-bin/atlaswms_en?', '', '', '', NULL, 'http://atlas.gc.ca:80/cgi-bin/atlaswms_en?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (584, '1.1.1', 'Bird Studies Canada WMS/WFS Server', 'Bird Studies Canada WMS/WFS Server for bird distribution and abundance data, and related information.  Bird Studies Canada gratefully acknowledges the support of Environment Canada - Canadian Information System for the Environment in developing this servi', 'http://www.bsc-eoc.org/cgi-bin/bsc_ows.asp?', 'http://www.bsc-eoc.org/cgi-bin/bsc_ows.asp?', 'http://www.bsc-eoc.org/cgi-bin/bsc_ows.asp?', 'http://www.bsc-eoc.org/cgi-bin/bsc_ows.asp?', '', '', NULL, 'http://www.bsc-eoc.org/cgi-bin/bsc_ows.asp?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (612, '1.1.2', 'ESA CubeSERV', 'European Space Agency CubeSERV map server.', 'http://mapserv2.esrin.esa.it/cubestor/cubeserv/cubeserv.cgi?', 'http://mapserv2.esrin.esa.it/cubestor/cubeserv/cubeserv.cgi?', 'http://mapserv2.esrin.esa.it/cubestor/cubeserv/cubeserv.cgi?', 'http://mapserv2.esrin.esa.it/cubestor/cubeserv/cubeserv.cgi?', '', '', NULL, 'http://mapserv2.esrin.esa.it/cubestor/cubeserv/cubeserv.cgi?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (613, '1.1.1', 'ESRI Co. Map Server', 'OGC - Web Map Server.', 'http://www.geographynetwork.com/ogc/com.esri.ogc.wms.WMSServlet?', 'http://www.geographynetwork.com/ogc/com.esri.ogc.wms.WMSServlet?', 'http://www.geographynetwork.com/ogc/com.esri.ogc.wms.WMSServlet?', '', '', '', NULL, 'http://www.geographynetwork.com/ogc/com.esri.ogc.wms.WMSServlet?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (614, '1.0.0', 'ESRI Inc. Map Server', 'WMT Map Server maintained by ESRI Inc.', 'http://inside3.uidaho.edu:80/servlet/com.esri.wms.Esrimap?servicename=WMS_WebMapCAP', 'http://inside3.uidaho.edu:80/servlet/com.esri.wms.Esrimap?servicename=WMS_WebMapCAP', 'http://inside3.uidaho.edu:80/servlet/com.esri.wms.Esrimap?servicename=WMS_WebMapCAP', '', '', '', NULL, 'http://inside3.uidaho.edu:80/servlet/com.esri.wms.Esrimap?servicename=WMS_WebMapCAP', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (615, '1.0.0', 'ESRI Inc. Map Server', 'WMT Map Server maintained by ESRI Inc.', 'http://maps.ciesin.org:80/servlet/com.esri.wms.Esrimap?', 'http://maps.ciesin.org:80/servlet/com.esri.wms.Esrimap?', 'http://maps.ciesin.org:80/servlet/com.esri.wms.Esrimap?', '', '', '', NULL, 'http://maps.ciesin.org:80/servlet/com.esri.wms.Esrimap?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (616, '1.1.1', 'ESRI Web Map Service', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://142.176.62.108/wmsconnector/com.esri.wsit.WMSServlet/GeoNovaSDE?', 'http://142.176.62.108/wmsconnector/com.esri.wsit.WMSServlet/GeoNovaSDE?', 'http://142.176.62.108/wmsconnector/com.esri.wsit.WMSServlet/GeoNovaSDE?', '', '', '', NULL, 'http://142.176.62.108/wmsconnector/com.esri.wsit.WMSServlet/GeoNovaSDE?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (617, '1.1.1', 'ESRI Web Map Service', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.geographynetwork.ca/wmsconnector/com.esri.wsit.WMSServlet/Geobase_NRN_NewfoundlandAndLabrador_I_Detail?', 'http://www.geographynetwork.ca/wmsconnector/com.esri.wsit.WMSServlet/Geobase_NRN_NewfoundlandAndLabrador_I_Detail?', 'http://www.geographynetwork.ca/wmsconnector/com.esri.wsit.WMSServlet/Geobase_NRN_NewfoundlandAndLabrador_I_Detail?', '', '', '', NULL, 'http://www.geographynetwork.ca/wmsconnector/com.esri.wsit.WMSServlet/Geobase_NRN_NewfoundlandAndLabrador_I_Detail?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (624, '1.1.0', 'Gewaesserstationierungskarte des Landes NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/gewstat?', 'http://www.gis2.nrw.de/wmsconnector/wms/gewstat?', 'http://www.gis2.nrw.de/wmsconnector/wms/gewstat?', '', '', '', NULL, 'http://www.gis2.nrw.de/wmsconnector/wms/gewstat?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (625, '1.1.1', 'GMap WMS Demo Server', 'This demonstration server was setup by DM Solutions Group (http://www.dmsolutions.ca/) and is powered by the UMN MapServer (http://mapserver.gis.umn.edu/).  This server uses Canadian source data (c)2000, Government of Canada with permission from Natural R', 'http://dev1.dmsolutions.ca/cgi-bin/mswms_gmap?', 'http://dev1.dmsolutions.ca/cgi-bin/mswms_gmap?', 'http://dev1.dmsolutions.ca/cgi-bin/mswms_gmap?', 'http://dev1.dmsolutions.ca/cgi-bin/mswms_gmap?', '', '', NULL, 'http://dev1.dmsolutions.ca/cgi-bin/mswms_gmap?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (634, '1.1.0', 'Location mapserver', 'This service provides approximate point locations for various    themes.', 'http://www.indexgeo.com.au/cgi-bin/wms-location', 'http://www.indexgeo.com.au/cgi-bin/wms-location', 'http://www.indexgeo.com.au/cgi-bin/wms-location', '', '', '', NULL, 'http://www.indexgeo.com.au/cgi-bin/wms-location', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (637, '1.1.1', 'MapServer WMS Demo', 'This is a UMN WMS MapServer demonstration application for global elevation data.', 'http://cooa.whoi.edu/cw/etopo2_wms?', 'http://cooa.whoi.edu/cw/etopo2_wms?', 'http://cooa.whoi.edu/cw/etopo2_wms?', '', '', '', NULL, 'http://cooa.whoi.edu/cw/etopo2_wms?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (640, '1.1.1', 'JPL World Map Service', 'WMS Server maintained by JPL, worldwide satellite imagery.', 'http://wms.jpl.nasa.gov/wms.cgi?', 'http://wms.jpl.nasa.gov/wms.cgi?', '', '', '', '', NULL, 'http://wms.jpl.nasa.gov/wms.cgi?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (645, '1.1.1', 'Multi-Hazard Mapping Initiative WMS Map Server (HDM)', 'This map server is provided by the Multi-Hazard Mapping Initiative and hosted by Harvard Design & Mapping Co., Inc.', 'http://www.hazardmaps.gov/ogc/wms?', 'http://www.hazardmaps.gov/ogc/wms?', 'http://www.hazardmaps.gov/ogc/wms?', '', '', '', NULL, 'http://www.hazardmaps.gov/ogc/wms?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (648, '1.1.0', 'Neigungsklassen zur Gelaendebefahrbarkeit', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/hangneigung?', 'http://www.gis2.nrw.de/wmsconnector/wms/hangneigung?', 'http://www.gis2.nrw.de/wmsconnector/wms/hangneigung?', '', '', '', NULL, 'http://www.gis2.nrw.de/wmsconnector/wms/hangneigung?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (655, '1.1.1', 'SEACOOS Remotely-Sensed Imagery', 'The SouthEast Atlantic Coastal Ocean Observing System (SEACOOS) is a regional partnership that has initiated an integrated coastal ocean observing system for a four-state region of the southeast U.S.  SEACOOS brings together many organizations witha veste', 'http://nautilus.baruch.sc.edu/wms/seacoos_rs?', 'http://nautilus.baruch.sc.edu/wms/seacoos_rs?', 'http://nautilus.baruch.sc.edu/wms/seacoos_rs?', 'http://nautilus.baruch.sc.edu/wms/seacoos_rs?', '', '', NULL, 'http://nautilus.baruch.sc.edu/wms/seacoos_rs?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (670, '1.1.0', 'Waldtypenkarte NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/waldtyp?', 'http://www.gis2.nrw.de/wmsconnector/wms/waldtyp?', 'http://www.gis2.nrw.de/wmsconnector/wms/waldtyp?', '', '', '', NULL, 'http://www.gis2.nrw.de/wmsconnector/wms/waldtyp?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (671, '1.1.0', 'Wasserschutzgebiete NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/wsg?', 'http://www.gis2.nrw.de/wmsconnector/wms/wsg?', 'http://www.gis2.nrw.de/wmsconnector/wms/wsg?', '', '', '', NULL, 'http://www.gis2.nrw.de/wmsconnector/wms/wsg?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (706, '1.1.0', 'WMS Map Server Australien', 'WMS Map Server Australien', 'http://atlas.walis.wa.gov.au:80/servlet/com.esri.wms.Esrimap?', 'http://atlas.walis.wa.gov.au:80/servlet/com.esri.wms.Esrimap?', 'http://atlas.walis.wa.gov.au:80/servlet/com.esri.wms.Esrimap?', '', '', '', NULL, 'http://atlas.walis.wa.gov.au:80/servlet/com.esri.wms.Esrimap?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (717, '1.1.0', 'Forstliche Verwaltungsgrenzen NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/forstamtsgr?', 'http://www.gis2.nrw.de/wmsconnector/wms/forstamtsgr?', 'http://www.gis2.nrw.de/wmsconnector/wms/forstamtsgr?', '', '', '', NULL, 'http://www.gis2.nrw.de/wmsconnector/wms/forstamtsgr?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (739, '1.1.1', 'Web Map Service Eusoils_Ex', 'ArcIMS 9.0 SP2 - Eusoils_Ex Web Map Service', 'http://eusoils.jrc.it:80/wmsconnector/com.esri.wms.Esrimap/Eusoils_Ex?', 'http://eusoils.jrc.it:80/wmsconnector/com.esri.wms.Esrimap/Eusoils_Ex?', 'http://eusoils.jrc.it:80/wmsconnector/com.esri.wms.Esrimap/Eusoils_Ex?', '', '', '', NULL, 'http://eusoils.jrc.it:80/wmsconnector/com.esri.wms.Esrimap/Eusoils_Ex?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (902, '1.1.0', 'DNM 100/2', '2. Generation des Digitalen Navigationsmodells 1:100.000 als topographische Basisnavigationsdaten der Brandenburger Landesvermessung', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM100n.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM100n.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM100n.map&', '', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
  <!ELEMENT VendorSpecificCapabilities EMPTY>
@@ -9374,34 +9721,32 @@
   </Layer>
 </Capability>
-', NULL, 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM100n.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (767, '1.1.1', 'SLUBFURT', 'Slubfurter Mental Map Survey 2000 - 2002: Border regions pose a challenge to spatial planning policies and practices. Many border regions are experiencing social and cultural convergence and fragmentation as well as a growing concern for the natural envir', 'http://odragis.org/cgi-bin/slubfurtwms?', 'http://odragis.org/cgi-bin/slubfurtwms?', 'http://odragis.org/cgi-bin/slubfurtwms?', 'http://odragis.org/cgi-bin/slubfurtwms?', '', '', NULL, 'http://odragis.org/cgi-bin/slubfurtwms?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (777, '1.1.1', 'Lieu / Locations', 'Boundaries and Cities of Africa', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/resimao/resimao.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/resimao/resimao.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/resimao/resimao.map&', 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/resimao/resimao.map&', '', '', NULL, 'http://212.79.172.184/cgi-bin/mapserv?map=/var/data/resimao/resimao.map&');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (779, '1.1.0', 'Ruanda', '', 'http://www.terrestris.de/cgi-bin/mapserv?map=/var/www/html/ruanda/Ruanda1.map&', 'http://www.terrestris.de/cgi-bin/mapserv?map=/var/www/html/ruanda/Ruanda1.map&', 'http://www.terrestris.de/cgi-bin/mapserv?map=/var/www/html/ruanda/Ruanda1.map&', '', '', '', NULL, 'http://www.terrestris.de/cgi-bin/mapserv?map=/var/www/html/ruanda/Ruanda1.map&');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (785, '1.1.0', 'WMS Map Server', 'WMS Map Server', 'http://gdz1.leipzig.ifag.de:80/servlet/com.esri.wms.Esrimap?servicename=dtk200_500_1000_a10_gk3_wms', 'http://gdz1.leipzig.ifag.de:80/servlet/com.esri.wms.Esrimap?servicename=dtk200_500_1000_a10_gk3_wms', 'http://gdz1.leipzig.ifag.de:80/servlet/com.esri.wms.Esrimap?servicename=dtk200_500_1000_a10_gk3_wms', '', '', '', NULL, 'http://gdz1.leipzig.ifag.de:80/servlet/com.esri.wms.Esrimap?servicename=dtk200_500_1000_a10_gk3_wms');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (786, '1.1.0', 'Luftbild', '', 'http://www.landesvermessung.sachsen.de/ias/basiskarte/service/SRVDOPFREE/WMSFREE_TK/WMSFREE_TK/wmsservice?', 'http://www.landesvermessung.sachsen.de/ias/basiskarte/service/SRVDOPFREE/WMSFREE_TK/WMSFREE_TK/wmsservice?', 'http://www.landesvermessung.sachsen.de/ias/basiskarte/service/SRVDOPFREE/WMSFREE_TK/WMSFREE_TK/wmsservice?', 'http://www.landesvermessung.sachsen.de/ias/basiskarte/service/SRVDOPFREE/WMSFREE_TK/WMSFREE_TK/wmsservice?', '', '', NULL, 'http://www.landesvermessung.sachsen.de/ias/basiskarte/service/SRVDOPFREE/WMSFREE_TK/WMSFREE_TK/wmsservice?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (787, '1.1.1', 'Bavarian WMS MAP Server', 'Bavarian WMS MAP Server', 'http://deutschlandviewer.bayern.de/ogc/getogc.cgi?', 'http://deutschlandviewer.bayern.de/ogc/getogc.cgi?', '', '', '', '', NULL, 'http://deutschlandviewer.bayern.de/ogc/getogc.cgi?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (789, '1.1.0', 'TopKarten100_TopKarten50', 'SICAD Internet Suite V6.0A05 at www.landesvermessung.sachsen.de/sims/sicad-', 'http://www.landesvermessung.sachsen.de/sims/sicad/GetCapabilities.pl?datasource=freetk:de:', 'http://www.landesvermessung.sachsen.de/sims/sicad/ShowMap.pl?datasource=freetk:de:', 'http://www.landesvermessung.sachsen.de/sims/sicad/ShowOnlineAlpha.pl?datasource=freetk:de:', '', '', '', NULL, 'http://www.landesvermessung.sachsen.de/sims/sicad/GetCapabilities.pl?datasource=freetk:de:');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (790, '1.1.1', 'Mapserver Niedersachsen  4.7.4', '', 'http://www.lgn21.niedersachsen.de/freezoneogc/mapserverogc?', 'http://www.lgn21.niedersachsen.de/freezoneogc/mapserverogc?', '', '', '', '', NULL, 'http://www.lgn21.niedersachsen.de/freezoneogc/mapserverogc?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (792, '1.1.1', 'WMS-Thueringen', 'wms reference implementation', 'http://www.webmap-test.thueringen.de/deegreewms/wms?', 'http://www.webmap-test.thueringen.de/deegreewms/wms?', 'http://www.webmap-test.thueringen.de/deegreewms/wms?', '', '', '', NULL, 'http://www.webmap-test.thueringen.de/deegreewms/wms?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (793, '1.1.0', 'WMS Hessen', 'WMT Map Server, Copyright (c) Hessisches Landesvermessungsamt', 'http://wmssrv.geo.hessen.de/ias/cgi-bin/siscgi.exe?', 'http://wmssrv.geo.hessen.de/ias/cgi-bin/siscgi.exe?', '', '', '', '', NULL, 'http://wmssrv.geo.hessen.de/ias/cgi-bin/siscgi.exe?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (800, '1.1.1', 'OGCConnector v0.3', '', 'http://geoint.lmic.state.mn.us/cgi-bin/wms', 'http://geoint.lmic.state.mn.us/cgi-bin/wms', 'http://geoint.lmic.state.mn.us/cgi-bin/wms', '', '', '', NULL, 'http://geoint.lmic.state.mn.us/cgi-bin/wms');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (827, '1.0.0', 'NSW DIPNR Image Server', 'NSW DIPNR Image Server Web Map Service interface used to serve large raster images (up to 100 Gigabytes per image). It is currently used to serve the NSW Landsat 2000 Mosaic, and can also serve scanned maps and aerial photography.', 'http://atlas.canri.nsw.gov.au/proxy/wms?', 'http://atlas.canri.nsw.gov.au/proxy/wms?', '', '', '', '', NULL, 'http://atlas.canri.nsw.gov.au/proxy/wms?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (828, '1.1.1', 'IDERIOJA', 'IDE Gobierno de La Rioja', 'http://wms.larioja.org/request.asp', 'http://wms.larioja.org/request.asp', 'http://wms.larioja.org/request.asp', '', '', '', NULL, 'http://wms.larioja.org/request.asp');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (829, '1.1.1', 'WMS Geography Salzburgat_etm7_lambert', 'Dep. Geography - University Salzburg, Austria: at_etm7_lambert Web Map Service', 'http://maps.geo.sbg.ac.at:80/wmsconnector/com.esri.wms.Esrimap/at_etm7_lambert?', 'http://maps.geo.sbg.ac.at:80/wmsconnector/com.esri.wms.Esrimap/at_etm7_lambert?', 'http://maps.geo.sbg.ac.at:80/wmsconnector/com.esri.wms.Esrimap/at_etm7_lambert?', '', '', '', NULL, 'http://maps.geo.sbg.ac.at:80/wmsconnector/com.esri.wms.Esrimap/at_etm7_lambert?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (831, '1.1.1', 'MNDNR Data Deli WMS Server', '', 'http://maps.dnr.state.mn.us/cgi-bin/wms?map=DELI_WMS_MAPFILE&', 'http://maps.dnr.state.mn.us/cgi-bin/wms?map=DELI_WMS_MAPFILE&', 'http://maps.dnr.state.mn.us/cgi-bin/wms?map=DELI_WMS_MAPFILE&', 'http://maps.dnr.state.mn.us/cgi-bin/wms?map=DELI_WMS_MAPFILE&', '', '', NULL, 'http://maps.dnr.state.mn.us/cgi-bin/wms?map=DELI_WMS_MAPFILE&');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (832, '1.1.0', 'Technology Applications Team Wms Service', 'This is an OGC compliant MapService served by the USGS Technology Applications Team (TAT) from the USGSs Fort Collins Science Center', 'http://mapper.tat.fws.gov/ogcwms/WmsServlet?SERVICENAME=nwi_wms&', 'http://mapper.tat.fws.gov/ogcwms/WmsServlet?SERVICENAME=nwi_wms&', 'http://mapper.tat.fws.gov/ogcwms/WmsServlet?SERVICENAME=nwi_wms&', '', '', '', NULL, 'http://mapper.tat.fws.gov/ogcwms/WmsServlet?SERVICENAME=nwi_wms&');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (833, '1.1.1', 'ESRI Web Map Service', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://ocs-spatial.ncd.noaa.gov/wmsconnector/com.esri.wsit.WMSServlet/encdirect?', 'http://ocs-spatial.ncd.noaa.gov/wmsconnector/com.esri.wsit.WMSServlet/encdirect?', 'http://ocs-spatial.ncd.noaa.gov/wmsconnector/com.esri.wsit.WMSServlet/encdirect?', '', '', '', NULL, 'http://ocs-spatial.ncd.noaa.gov/wmsconnector/com.esri.wsit.WMSServlet/encdirect?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (834, '1.1.1', 'Delaware 2002 Aerial Imagery WMS Service', 'The Delaware 2002 Aerial Imagery Map Service serves statewide orthophotography as captured in 2002. The State of Delaware contracted with EarthData International to develop 0.25-meter resolution color infrared digital ortho-photos for the entire state. Ma', 'http://datamil.delaware.gov:80/wmsconnector/com.esri.wms.Esrimap/DE_aerial02?', 'http://datamil.delaware.gov:80/wmsconnector/com.esri.wms.Esrimap/DE_aerial02?', 'http://datamil.delaware.gov:80/wmsconnector/com.esri.wms.Esrimap/DE_aerial02?', '', '', '', NULL, 'http://datamil.delaware.gov:80/wmsconnector/com.esri.wms.Esrimap/DE_aerial02?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (836, '1.1.1', 'NDOP (OGCConnector v1.2)', '', 'http://mcmcwebmap.usgs.gov:80/OGCConnector/servlet/OGCConnector?ServiceName=NDOP', 'http://mcmcwebmap.usgs.gov:80/OGCConnector/servlet/OGCConnector?ServiceName=NDOP', 'http://mcmcwebmap.usgs.gov:80/OGCConnector/servlet/OGCConnector?ServiceName=NDOP', 'http://mcmcwebmap.usgs.gov:80/OGCConnector/servlet/OGCConnector?ServiceName=NDOP', '', '', NULL, 'http://mcmcwebmap.usgs.gov:80/OGCConnector/servlet/OGCConnector?ServiceName=NDOP');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (837, '1.1.1', 'Microsoft TerraServer Map Server', 'WMT Map Server maintained by Microsoft Corporation.  Data returned provided by US Geological Survey.  Contact: tbarclay at microsoft.com or gylee at usgs.gov.', 'http://terraservice.net/ogccapabilities.ashx', 'http://terraservice.net/ogcmap.ashx', '', '', '', '', NULL, 'http://terraservice.net/ogccapabilities.ashx');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (840, '1.1.1', 'Intergraph World Map', '', 'http://maps1.intergraph.com/wms/world/request.asp', 'http://maps1.intergraph.com/wms/world/request.asp', 'http://maps1.intergraph.com/wms/world/request.asp', 'http://maps1.intergraph.com/wms/world/request.asp', '', '', NULL, 'http://maps1.intergraph.com/wms/world/request.asp');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (841, '1.1.1', 'ICEDS (Integrated CEOS European Data Server) WMS', 'Integrated CEOS European Data Server (ICEDS) Web Map Service, maintained by the Geomatic Engineering Dept at UCL', 'http://iceds.ge.ucl.ac.uk/cgi-bin/icedswms?', 'http://iceds.ge.ucl.ac.uk/cgi-bin/icedswms?', 'http://iceds.ge.ucl.ac.uk/cgi-bin/icedswms?', 'http://iceds.ge.ucl.ac.uk/cgi-bin/icedswms?', '', '', NULL, 'http://iceds.ge.ucl.ac.uk/cgi-bin/icedswms?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (842, '1.1.1', 'Tsunami_Diasaster_Data', 'This WMS server contains data used in http://www.mapsherpa.com/tsunami/. Much of the reference data is cascaded from other WMS servers.  Before using this data in your live application, please consult the metadata url for each layer to check to see if you', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?', '', '', NULL, 'http://www.mapsherpa.com/cgi-bin/wms_iodra?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (843, '1.0.0', 'WMS Map Server', 'WMS Map Server', 'http://map.ngdc.noaa.gov:80/servlet/com.esri.wms.Esrimap?servicename=hazards', 'http://map.ngdc.noaa.gov:80/servlet/com.esri.wms.Esrimap?servicename=hazards', 'http://map.ngdc.noaa.gov:80/servlet/com.esri.wms.Esrimap?servicename=hazards', '', '', '', NULL, 'http://map.ngdc.noaa.gov:80/servlet/com.esri.wms.Esrimap?servicename=hazards');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (844, '1.1.1', 'CustomWeather Map Server', 'CustomWeather WMT Map Server.  Contact: info at customweather.com. Doppler, Satellite, Severe Watches and Warnings, Hurricanes, Frontlines, ContourMaps, and More.', 'http://maps.customweather.com/image?', 'http://maps.customweather.com/image?', 'http://maps.customweather.com/image?', '', '', '', NULL, 'http://maps.customweather.com/image?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (855, '1.1.1', 'World Map', 'None', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&', '', NULL, '<?xml version="1.0"?><!DOCTYPE WMT_MS_Capabilities SYSTEM "http://www2.demis.nl/wms/capabilities_1_1_1.dtd" [ <!-- Vendor-specific elements are defined here if needed. --> <!-- If not needed, just leave this EMPTY declaration.  Do not  delete the declaration entirely. --> <!ELEMENT VendorSpecificCapabilities EMPTY> ]><WMT_MS_Capabilities version="1.1.1">	<!-- Service Metadata -->	<Service>		<!-- The WMT-defined name for this type of service -->		<Name>OGC:WMS</Name>		<!-- Human-readable title for pick lists -->		<Title>World Map</Title>		<!-- Narrative description providing additional information -->		<Abstract>None</Abstract>		<!-- Top-level web address of service or service provider.  See also OnlineResource  elements under <DCPType>. -->		<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www2.demis.nl"/>		<!-- Contact information -->		<ContactInformation>			<ContactPersonPrimary>				<ContactPerson></ContactPerson>				<ContactOrganization></ContactOrganization>			</ContactPersonPrimary>			<ContactElectronicMailAddress></ContactElectronicMailAddress>		</ContactInformation>		<!-- Fees or access constraints imposed. -->		<Fees>none</Fees>		<AccessConstraints>none</AccessConstraints>	</Service>	<Capability>		<Request>			<GetCapabilities>				<Format>application/vnd.ogc.wms_xml</Format>				<DCPType>					<HTTP>						<Get>							<!-- The URL here for invoking GetCapabilities using HTTP GET            is only a prefix to which a query string is appended. -->							<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www2.demis.nl/wms/wms.asp?wms=WorldMap&amp;"/>						</Get>					</HTTP>				</DCPType>			</GetCapabilities>			<GetMap>				<Format>image/png</Format>				<Format>image/jpeg</Format>				<Format>image/gif</Format>				<Format>image/bmp</Format>				<Format>image/swf</Format>				<DCPType>					<HTTP>						<Get>							<!-- The URL here for invoking GetCapabilities using HTTP GET            is only a prefix to which a query string is appended. -->							<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www2.demis.nl/wms/wms.asp?wms=WorldMap&amp;"/>						</Get>					</HTTP>				</DCPType>			</GetMap>			<GetFeatureInfo>				<Format>text/xml</Format>				<Format>text/plain</Format>				<Format>text/html</Format>				<Format>text/swf</Format>				<Format>application/vnd.ogc.gml</Format>				<DCPType>					<HTTP>						<Get>							<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www2.demis.nl/wms/wms.asp?wms=WorldMap&amp;"/>						</Get>					</HTTP>				</DCPType>			</GetFeatureInfo>		</Request>		<Exception>			<Format>application/vnd.ogc.se_inimage</Format>			<Format>application/vnd.ogc.se_blank</Format>			<Format>application/vnd.ogc.se_xml</Format>			<Format>text/xml</Format>			<Format>text/plain</Format>		</Exception>		<VendorSpecificCapabilities/>		<Layer>			<Title>World Map</Title>			<SRS>EPSG:4326</SRS>			<LatLonBoundingBox minx="-180" miny="-90" maxx="180" maxy="90"/>			<BoundingBox SRS="EPSG:4326" minx="-184" miny="-90" maxx="180" maxy="90"/>			<Layer queryable="1" opaque="1">				<Name>Bathymetry</Name>				<Title>Bathymetry</Title>				<BoundingBox SRS="EPSG:4326" minx="-180" miny="-90" maxx="180" maxy="90"/>			</Layer>			<Layer queryable="1" opaque="0">				<Name>Countries</Name>				<Title>Countries</Title>				<BoundingBox SRS="EPSG:4326" minx="-184" miny="-90" maxx="180" maxy="85"/>			</Layer>			<Layer queryable="1" opaque="1">				<Name>Topography</Name>				<Title>Topography</Title>				<BoundingBox SRS="EPSG:4326" minx="-180" miny="-59.99999999998" maxx="179.999999999984" maxy="90"/>			</Layer>			<Layer queryable="0" opaque="1">				<Name>Hillshading</Name>				<Title>Hillshading</Title>				<BoundingBox SRS="EPSG:4326" minx="-180" miny="-59.99999999998" maxx="179.999999999984" maxy="90"/>			</Layer>			<Layer queryable="1" opaque="0">				<Name>Builtup areas</Name>				<Title>Builtup areas</Title>				<BoundingBox SRS="EPSG:4326" minx="-180" miny="-55" maxx="180" maxy="75"/>				<ScaleHint min="0" max="1400"/>			</Layer>			<Layer queryable="1" opaque="0">				<Name>Coastlines</Name>				<Title>Coastlines</Title>				<BoundingBox SRS="EPSG:4326" minx="-184" miny="-90" maxx="180" maxy="85"/>			</Layer>			<Layer queryable="1" opaque="0">				<Name>Waterbodies</Name>				<Title>Waterbodies</Title>				<BoundingBox SRS="EPSG:4326" minx="-184" miny="-75" maxx="180" maxy="85"/>				<ScaleHint min="0" max="5600"/>			</Layer>			<Layer queryable="1" opaque="0">				<Name>Inundated</Name>				<Title>Inundated</Title>				<BoundingBox SRS="EPSG:4326" minx="-180" miny="-50" maxx="180" maxy="80"/>				<ScaleHint min="0" max="1400"/>			</Layer>			<Layer queryable="1" opaque="0">				<Name>Rivers</Name>				<Title>Rivers</Title>				<BoundingBox SRS="EPSG:4326" minx="-180" miny="-55" maxx="180" maxy="85"/>				<ScaleHint min="0" max="11200"/>			</Layer>			<Layer queryable="1" opaque="0">				<Name>Streams</Name>				<Title>Streams</Title>				<BoundingBox SRS="EPSG:4326" minx="-180" miny="-55" maxx="180" maxy="85"/>				<ScaleHint min="0" max="5600"/>			</Layer>			<Layer queryable="1" opaque="0">				<Name>Railroads</Name>				<Title>Railroads</Title>				<BoundingBox SRS="EPSG:4326" minx="-170" miny="-55" maxx="180" maxy="80"/>				<ScaleHint min="0" max="840"/>			</Layer>			<Layer queryable="1" opaque="0">				<Name>Highways</Name>				<Title>Highways</Title>				<BoundingBox SRS="EPSG:4326" minx="-175" miny="-55" maxx="180" maxy="75"/>				<ScaleHint min="0" max="700"/>			</Layer>			<Layer queryable="1" opaque="0">				<Name>Roads</Name>				<Title>Roads</Title>				<BoundingBox SRS="EPSG:4326" minx="-184" miny="-55" maxx="180" maxy="75"/>				<ScaleHint min="0" max="420"/>			</Layer>			<Layer queryable="1" opaque="0">				<Name>Trails</Name>				<Title>Trails</Title>				<BoundingBox SRS="EPSG:4326" minx="-184" miny="-50" maxx="180" maxy="80"/>				<ScaleHint min="0" max="280"/>			</Layer>			<Layer queryable="1" opaque="0">				<Name>Borders</Name>				<Title>Borders</Title>				<BoundingBox SRS="EPSG:4326" minx="-184" miny="-60" maxx="176" maxy="75"/>			</Layer>			<Layer queryable="1" opaque="0">				<Name>Cities</Name>				<Title>Cities</Title>				<BoundingBox SRS="EPSG:4326" minx="-180" miny="-55" maxx="180" maxy="75"/>				<ScaleHint min="0" max="28000"/>			</Layer>			<Layer queryable="1" opaque="0">				<Name>Settlements</Name>				<Title>Settlements</Title>				<BoundingBox SRS="EPSG:4326" minx="-180" miny="-55" maxx="180" maxy="85"/>				<ScaleHint min="0" max="560"/>			</Layer>			<Layer queryable="0" opaque="0">				<Name>Spot elevations</Name>				<Title>Spot elevations</Title>				<BoundingBox SRS="EPSG:4326" minx="-179.983093261719" miny="-89.83837890625" maxx="179.991439819336" maxy="83.5204086303711"/>				<ScaleHint min="0" max="280"/>			</Layer>			<Layer queryable="1" opaque="0">				<Name>Airports</Name>				<Title>Airports</Title>				<BoundingBox SRS="EPSG:4326" minx="-184" miny="-55" maxx="180" maxy="80"/>				<ScaleHint min="0" max="560"/>			</Layer>			<Layer queryable="1" opaque="0">				<Name>Ocean features</Name>				<Title>Ocean features</Title>				<BoundingBox SRS="EPSG:4326" minx="-180" miny="-62.9231796264648" maxx="179.999420166016" maxy="68.6906585693359"/>				<ScaleHint min="0" max="2800"/>			</Layer>		</Layer>	</Capability></WMT_MS_Capabilities>', NULL, 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (866, '1.1.0', 'Digitale Karte der hochwassergefaehrdeten Bereiche NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/hochwasser?', 'http://www.gis2.nrw.de/wmsconnector/wms/hochwasser?', 'http://www.gis2.nrw.de/wmsconnector/wms/hochwasser?', '', NULL, '<?xml version="1.0" encoding="UTF-8"?>
+', NULL, 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM100n.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (767, '1.1.1', 'SLUBFURT', 'Slubfurter Mental Map Survey 2000 - 2002: Border regions pose a challenge to spatial planning policies and practices. Many border regions are experiencing social and cultural convergence and fragmentation as well as a growing concern for the natural envir', 'http://odragis.org/cgi-bin/slubfurtwms?', 'http://odragis.org/cgi-bin/slubfurtwms?', 'http://odragis.org/cgi-bin/slubfurtwms?', 'http://odragis.org/cgi-bin/slubfurtwms?', '', '', NULL, 'http://odragis.org/cgi-bin/slubfurtwms?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (779, '1.1.0', 'Ruanda', '', 'http://www.terrestris.de/cgi-bin/mapserv?map=/var/www/html/ruanda/Ruanda1.map&', 'http://www.terrestris.de/cgi-bin/mapserv?map=/var/www/html/ruanda/Ruanda1.map&', 'http://www.terrestris.de/cgi-bin/mapserv?map=/var/www/html/ruanda/Ruanda1.map&', '', '', '', NULL, 'http://www.terrestris.de/cgi-bin/mapserv?map=/var/www/html/ruanda/Ruanda1.map&', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (785, '1.1.0', 'WMS Map Server', 'WMS Map Server', 'http://gdz1.leipzig.ifag.de:80/servlet/com.esri.wms.Esrimap?servicename=dtk200_500_1000_a10_gk3_wms', 'http://gdz1.leipzig.ifag.de:80/servlet/com.esri.wms.Esrimap?servicename=dtk200_500_1000_a10_gk3_wms', 'http://gdz1.leipzig.ifag.de:80/servlet/com.esri.wms.Esrimap?servicename=dtk200_500_1000_a10_gk3_wms', '', '', '', NULL, 'http://gdz1.leipzig.ifag.de:80/servlet/com.esri.wms.Esrimap?servicename=dtk200_500_1000_a10_gk3_wms', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (786, '1.1.0', 'Luftbild', '', 'http://www.landesvermessung.sachsen.de/ias/basiskarte/service/SRVDOPFREE/WMSFREE_TK/WMSFREE_TK/wmsservice?', 'http://www.landesvermessung.sachsen.de/ias/basiskarte/service/SRVDOPFREE/WMSFREE_TK/WMSFREE_TK/wmsservice?', 'http://www.landesvermessung.sachsen.de/ias/basiskarte/service/SRVDOPFREE/WMSFREE_TK/WMSFREE_TK/wmsservice?', 'http://www.landesvermessung.sachsen.de/ias/basiskarte/service/SRVDOPFREE/WMSFREE_TK/WMSFREE_TK/wmsservice?', '', '', NULL, 'http://www.landesvermessung.sachsen.de/ias/basiskarte/service/SRVDOPFREE/WMSFREE_TK/WMSFREE_TK/wmsservice?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (787, '1.1.1', 'Bavarian WMS MAP Server', 'Bavarian WMS MAP Server', 'http://deutschlandviewer.bayern.de/ogc/getogc.cgi?', 'http://deutschlandviewer.bayern.de/ogc/getogc.cgi?', '', '', '', '', NULL, 'http://deutschlandviewer.bayern.de/ogc/getogc.cgi?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (789, '1.1.0', 'TopKarten100_TopKarten50', 'SICAD Internet Suite V6.0A05 at www.landesvermessung.sachsen.de/sims/sicad-', 'http://www.landesvermessung.sachsen.de/sims/sicad/GetCapabilities.pl?datasource=freetk:de:', 'http://www.landesvermessung.sachsen.de/sims/sicad/ShowMap.pl?datasource=freetk:de:', 'http://www.landesvermessung.sachsen.de/sims/sicad/ShowOnlineAlpha.pl?datasource=freetk:de:', '', '', '', NULL, 'http://www.landesvermessung.sachsen.de/sims/sicad/GetCapabilities.pl?datasource=freetk:de:', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (790, '1.1.1', 'Mapserver Niedersachsen  4.7.4', '', 'http://www.lgn21.niedersachsen.de/freezoneogc/mapserverogc?', 'http://www.lgn21.niedersachsen.de/freezoneogc/mapserverogc?', '', '', '', '', NULL, 'http://www.lgn21.niedersachsen.de/freezoneogc/mapserverogc?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (792, '1.1.1', 'WMS-Thueringen', 'wms reference implementation', 'http://www.webmap-test.thueringen.de/deegreewms/wms?', 'http://www.webmap-test.thueringen.de/deegreewms/wms?', 'http://www.webmap-test.thueringen.de/deegreewms/wms?', '', '', '', NULL, 'http://www.webmap-test.thueringen.de/deegreewms/wms?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (793, '1.1.0', 'WMS Hessen', 'WMT Map Server, Copyright (c) Hessisches Landesvermessungsamt', 'http://wmssrv.geo.hessen.de/ias/cgi-bin/siscgi.exe?', 'http://wmssrv.geo.hessen.de/ias/cgi-bin/siscgi.exe?', '', '', '', '', NULL, 'http://wmssrv.geo.hessen.de/ias/cgi-bin/siscgi.exe?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (800, '1.1.1', 'OGCConnector v0.3', '', 'http://geoint.lmic.state.mn.us/cgi-bin/wms', 'http://geoint.lmic.state.mn.us/cgi-bin/wms', 'http://geoint.lmic.state.mn.us/cgi-bin/wms', '', '', '', NULL, 'http://geoint.lmic.state.mn.us/cgi-bin/wms', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (827, '1.0.0', 'NSW DIPNR Image Server', 'NSW DIPNR Image Server Web Map Service interface used to serve large raster images (up to 100 Gigabytes per image). It is currently used to serve the NSW Landsat 2000 Mosaic, and can also serve scanned maps and aerial photography.', 'http://atlas.canri.nsw.gov.au/proxy/wms?', 'http://atlas.canri.nsw.gov.au/proxy/wms?', '', '', '', '', NULL, 'http://atlas.canri.nsw.gov.au/proxy/wms?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (828, '1.1.1', 'IDERIOJA', 'IDE Gobierno de La Rioja', 'http://wms.larioja.org/request.asp', 'http://wms.larioja.org/request.asp', 'http://wms.larioja.org/request.asp', '', '', '', NULL, 'http://wms.larioja.org/request.asp', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (829, '1.1.1', 'WMS Geography Salzburgat_etm7_lambert', 'Dep. Geography - University Salzburg, Austria: at_etm7_lambert Web Map Service', 'http://maps.geo.sbg.ac.at:80/wmsconnector/com.esri.wms.Esrimap/at_etm7_lambert?', 'http://maps.geo.sbg.ac.at:80/wmsconnector/com.esri.wms.Esrimap/at_etm7_lambert?', 'http://maps.geo.sbg.ac.at:80/wmsconnector/com.esri.wms.Esrimap/at_etm7_lambert?', '', '', '', NULL, 'http://maps.geo.sbg.ac.at:80/wmsconnector/com.esri.wms.Esrimap/at_etm7_lambert?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (831, '1.1.1', 'MNDNR Data Deli WMS Server', '', 'http://maps.dnr.state.mn.us/cgi-bin/wms?map=DELI_WMS_MAPFILE&', 'http://maps.dnr.state.mn.us/cgi-bin/wms?map=DELI_WMS_MAPFILE&', 'http://maps.dnr.state.mn.us/cgi-bin/wms?map=DELI_WMS_MAPFILE&', 'http://maps.dnr.state.mn.us/cgi-bin/wms?map=DELI_WMS_MAPFILE&', '', '', NULL, 'http://maps.dnr.state.mn.us/cgi-bin/wms?map=DELI_WMS_MAPFILE&', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (832, '1.1.0', 'Technology Applications Team Wms Service', 'This is an OGC compliant MapService served by the USGS Technology Applications Team (TAT) from the USGSs Fort Collins Science Center', 'http://mapper.tat.fws.gov/ogcwms/WmsServlet?SERVICENAME=nwi_wms&', 'http://mapper.tat.fws.gov/ogcwms/WmsServlet?SERVICENAME=nwi_wms&', 'http://mapper.tat.fws.gov/ogcwms/WmsServlet?SERVICENAME=nwi_wms&', '', '', '', NULL, 'http://mapper.tat.fws.gov/ogcwms/WmsServlet?SERVICENAME=nwi_wms&', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (833, '1.1.1', 'ESRI Web Map Service', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://ocs-spatial.ncd.noaa.gov/wmsconnector/com.esri.wsit.WMSServlet/encdirect?', 'http://ocs-spatial.ncd.noaa.gov/wmsconnector/com.esri.wsit.WMSServlet/encdirect?', 'http://ocs-spatial.ncd.noaa.gov/wmsconnector/com.esri.wsit.WMSServlet/encdirect?', '', '', '', NULL, 'http://ocs-spatial.ncd.noaa.gov/wmsconnector/com.esri.wsit.WMSServlet/encdirect?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (834, '1.1.1', 'Delaware 2002 Aerial Imagery WMS Service', 'The Delaware 2002 Aerial Imagery Map Service serves statewide orthophotography as captured in 2002. The State of Delaware contracted with EarthData International to develop 0.25-meter resolution color infrared digital ortho-photos for the entire state. Ma', 'http://datamil.delaware.gov:80/wmsconnector/com.esri.wms.Esrimap/DE_aerial02?', 'http://datamil.delaware.gov:80/wmsconnector/com.esri.wms.Esrimap/DE_aerial02?', 'http://datamil.delaware.gov:80/wmsconnector/com.esri.wms.Esrimap/DE_aerial02?', '', '', '', NULL, 'http://datamil.delaware.gov:80/wmsconnector/com.esri.wms.Esrimap/DE_aerial02?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (836, '1.1.1', 'NDOP (OGCConnector v1.2)', '', 'http://mcmcwebmap.usgs.gov:80/OGCConnector/servlet/OGCConnector?ServiceName=NDOP', 'http://mcmcwebmap.usgs.gov:80/OGCConnector/servlet/OGCConnector?ServiceName=NDOP', 'http://mcmcwebmap.usgs.gov:80/OGCConnector/servlet/OGCConnector?ServiceName=NDOP', 'http://mcmcwebmap.usgs.gov:80/OGCConnector/servlet/OGCConnector?ServiceName=NDOP', '', '', NULL, 'http://mcmcwebmap.usgs.gov:80/OGCConnector/servlet/OGCConnector?ServiceName=NDOP', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (837, '1.1.1', 'Microsoft TerraServer Map Server', 'WMT Map Server maintained by Microsoft Corporation.  Data returned provided by US Geological Survey.  Contact: tbarclay at microsoft.com or gylee at usgs.gov.', 'http://terraservice.net/ogccapabilities.ashx', 'http://terraservice.net/ogcmap.ashx', '', '', '', '', NULL, 'http://terraservice.net/ogccapabilities.ashx', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (840, '1.1.1', 'Intergraph World Map', '', 'http://maps1.intergraph.com/wms/world/request.asp', 'http://maps1.intergraph.com/wms/world/request.asp', 'http://maps1.intergraph.com/wms/world/request.asp', 'http://maps1.intergraph.com/wms/world/request.asp', '', '', NULL, 'http://maps1.intergraph.com/wms/world/request.asp', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (841, '1.1.1', 'ICEDS (Integrated CEOS European Data Server) WMS', 'Integrated CEOS European Data Server (ICEDS) Web Map Service, maintained by the Geomatic Engineering Dept at UCL', 'http://iceds.ge.ucl.ac.uk/cgi-bin/icedswms?', 'http://iceds.ge.ucl.ac.uk/cgi-bin/icedswms?', 'http://iceds.ge.ucl.ac.uk/cgi-bin/icedswms?', 'http://iceds.ge.ucl.ac.uk/cgi-bin/icedswms?', '', '', NULL, 'http://iceds.ge.ucl.ac.uk/cgi-bin/icedswms?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (842, '1.1.1', 'Tsunami_Diasaster_Data', 'This WMS server contains data used in http://www.mapsherpa.com/tsunami/. Much of the reference data is cascaded from other WMS servers.  Before using this data in your live application, please consult the metadata url for each layer to check to see if you', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?', 'http://www.mapsherpa.com/cgi-bin/wms_iodra?', '', '', NULL, 'http://www.mapsherpa.com/cgi-bin/wms_iodra?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (843, '1.0.0', 'WMS Map Server', 'WMS Map Server', 'http://map.ngdc.noaa.gov:80/servlet/com.esri.wms.Esrimap?servicename=hazards', 'http://map.ngdc.noaa.gov:80/servlet/com.esri.wms.Esrimap?servicename=hazards', 'http://map.ngdc.noaa.gov:80/servlet/com.esri.wms.Esrimap?servicename=hazards', '', '', '', NULL, 'http://map.ngdc.noaa.gov:80/servlet/com.esri.wms.Esrimap?servicename=hazards', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (844, '1.1.1', 'CustomWeather Map Server', 'CustomWeather WMT Map Server.  Contact: info at customweather.com. Doppler, Satellite, Severe Watches and Warnings, Hurricanes, Frontlines, ContourMaps, and More.', 'http://maps.customweather.com/image?', 'http://maps.customweather.com/image?', 'http://maps.customweather.com/image?', '', '', '', NULL, 'http://maps.customweather.com/image?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (866, '1.1.0', 'Digitale Karte der hochwassergefaehrdeten Bereiche NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/hochwasser?', 'http://www.gis2.nrw.de/wmsconnector/wms/hochwasser?', 'http://www.gis2.nrw.de/wmsconnector/wms/hochwasser?', '', NULL, '<?xml version="1.0" encoding="UTF-8"?>
   SYSTEM "http://www.gis2.nrw.de/wmsconnector/schema/wms/1.1.0/capabilities_1_1_0.dtd">
 <WMT_MS_Capabilities updateSequence="0" version="1.1.0">
@@ -9726,8 +10071,8 @@
 			</Layer>
 		</Layer>
 	</Capability>
-</WMT_MS_Capabilities>', NULL, 'http://www.gis2.nrw.de/wmsconnector/wms/hochwasser?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (869, '1.1.0', 'LINFOS NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/linfos?', 'http://www.gis2.nrw.de/wmsconnector/wms/linfos?', 'http://www.gis2.nrw.de/wmsconnector/linfos?', '', NULL, '<?xml version="1.0" encoding="UTF-8"?>
+</WMT_MS_Capabilities>', NULL, 'http://www.gis2.nrw.de/wmsconnector/wms/hochwasser?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (869, '1.1.0', 'LINFOS NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/linfos?', 'http://www.gis2.nrw.de/wmsconnector/wms/linfos?', 'http://www.gis2.nrw.de/wmsconnector/linfos?', '', NULL, '<?xml version="1.0" encoding="UTF-8"?>
@@ -10016,14 +10361,14 @@
 			</Layer>
 		</Layer>
 	</Capability>
-</WMT_MS_Capabilities>', NULL, 'http://www.gis2.nrw.de/wmsconnector/wms/linfos?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (872, '1.1.0', 'WMS Map Server', 'WMS Map Server', 'http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?', 'http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?', 'http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?', '', NULL, '<?xml version="1.0" encoding="UTF-8" standalone="yes" ?><!DOCTYPE WMT_MS_Capabilities SYSTEM "http://www.digitalearth.gov/wmt/xml/capabilities_1_1_0.dtd"
+</WMT_MS_Capabilities>', NULL, 'http://www.gis2.nrw.de/wmsconnector/wms/linfos?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (872, '1.1.0', 'WMS Map Server', 'WMS Map Server', 'http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?', 'http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?', 'http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?', '', NULL, '<?xml version="1.0" encoding="UTF-8" standalone="yes" ?><!DOCTYPE WMT_MS_Capabilities SYSTEM "http://www.digitalearth.gov/wmt/xml/capabilities_1_1_0.dtd"
 <!-- This document is compliant to WMT_MS_Capabilities DTD version 1.1 --><!-- Generated on Fri Nov 04 14:22:58 CET 2005 -->
-<WMT_MS_Capabilities version="1.1.0" updateSequence="0"><Service><Name>OGC:WMS</Name><Title>WMS Map Server</Title><Abstract>WMS Map Server</Abstract><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?"/><Fees></Fees><AccessConstraints></AccessConstraints></Service><Capability><Request><GetCapabilities><Format>application/vnd.ogc.wms_xml</Format><DCPType><HTTP><Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?"/></Get></HTTP></DCPType></GetCapabilities><GetMap><Format>image/jpeg</Format><Format>image/gif</Format><Format>image/png</Format><DCPType><HTTP><Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?"/></Get></HTTP></DCPType></GetMap><GetFeatureInfo><Format>application/vnd.ogc.wms_xml</Format><Format>text/plain</Format><Format>text/html</Format><DCPType><HTTP><Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?"/></Get></HTTP></DCPType></GetFeatureInfo></Request><Exception><Format>application/vnd.ogc.se_xml</Format><Format>application/vnd.ogc.se_inimage</Format><Format>application/vnd.ogc.se_blank</Format></Exception><Layer><Title>WV_WMS</Title><SRS>EPSG:4326</SRS><Layer><Name>rheinplus</Name><Title>rheinplus</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2546442.5" miny="5629738.5" maxx="2574239.0" maxy="5690679.0"/></Layer><Layer><Name>uesgobwup</Name><Title>uesgobwup</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2593889.2" miny="5662005.5" maxx="2609059.0" maxy="5669772.0"/></Layer><Layer><Name>uesgmorsbach</Name><Title>uesgmorsbach</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2579495.5" miny="5670734.5" maxx="2586469.8" maxy="5679051.5"/></Layer><Layer><Name>klaerwerkseinzugsgebiete</Name><Title>klaerwerkseinzugsgebiete</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2563368.2" miny="5652735.5" maxx="2612351.5" maxy="5687238.5"/></Layer><Layer><Name>entwaesserungssystem</Name><Title>entwaesserungssystem</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2563368.2" miny="5652735.5" maxx="2612351.5" maxy="5687238.5"/></Layer><Layer><Name>gezgross</Name><Title>gezgross</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2566194.5" miny="5650761.0" maxx="2612288.8" maxy="5687441.5"/></Layer><Layer><Name>gezklein</Name><Title>gezklein</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2566194.5" miny="5650761.0" maxx="2612288.8" maxy="5687441.5"/></Layer><Layer><Name>ueberleitungsgebiete</Name><Title>ueberleitungsgebiete</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2563139.2" miny="5653338.0" maxx="2598613.0" maxy="5687438.5"/></Layer><Layer><Name>verbandsgebiet</Name><Title>verbandsgebiet</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2566194.0" miny="5650736.5" maxx="2612255.8" maxy="5687418.5"/></Layer><Layer><Name>gsg5</Name><Title>gsg5</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2566094.0" miny="5650929.5" maxx="2611978.2" maxy="5687202.5"/></Layer><Layer><Name>gsg3</Name><Title>gsg3</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2566094.0" miny="5650892.0" maxx="2612015.5" maxy="5687211.0"/></Layer><Layer><Name>gsg1</Name><Title>gsg1</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2566094.0" miny="5650866.0" maxx="2612040.5" maxy="5687229.5"/></Layer><Layer><Name>gewaesser</Name><Title>gewaesser</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2565684.0" miny="5650966.5" maxx="2611954.8" maxy="5687197.0"/></Layer><Layer><Name>verrohrungen</Name><Title>verrohrungen</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2568289.8" miny="5650979.5" maxx="2611939.5" maxy="5687154.0"/></Layer><Layer><Name>verlaufaenderungen</Name><Title>verlaufaenderungen</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2567540.2" miny="5651123.5" maxx="2610584.0" maxy="5686884.5"/></Layer><Layer><Name>gewaesserbeschriftung</Name><Title>gewaesserbeschriftung</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2565684.0" miny="5650966.5" maxx="2611954.8" maxy="5687197.0"/></Layer><Layer><Name>talsperren</Name><Title>talsperren</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2574368.5" miny="5657951.5" maxx="2609796.2" maxy="5680451.5"/></Layer><Layer><Name>sammler</Name><Title>sammler</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2568024.0" miny="5657404.5" maxx="2610590.5" maxy="5676478.5"/></Layer><Layer><Name>stationierung</Name><Title>stationierung</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2566160.2" miny="5650970.5" maxx="2611941.8" maxy="5687151.0"/></Layer><Layer><Name>fotos_am_gewaesser</Name><Title>fotos_am_gewaesser</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2566094.0" miny="5650970.5" maxx="2611941.0" maxy="5687106.5"/></Layer><Layer><Name>limnologie</Name><Title>limnologie</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2568246.5" miny="5655120.5" maxx="2610520.0" maxy="5682874.5"/></Layer><Layer><Name>niederschlagsstationen</Name><Title>niederschlagsstationen</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2568200.5" miny="5655310.0" maxx="2609614.8" maxy="5684705.0"/></Layer><Layer><Name>pegel</Name><Title>pegel</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2569725.2" miny="5652906.5" maxx="2610202.8" maxy="5683943.5"/></Layer><Layer><Name>wehre</Name><Title>wehre</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2567619.8" miny="5655330.5" maxx="2610201.8" maxy="5682797.0"/></Layer><Layer><Name>fischaufstiege</Name><Title>fischaufstiege</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2567619.8" miny="5655330.5" maxx="2607229.8" maxy="5682797.0"/></Layer><Layer><Name>hrb</Name><Title>hrb</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2574521.2" miny="5654207.5" maxx="2598042.2" maxy="5685821.0"/></Layer><Layer><Name>regenbeckenwv</Name><Title>regenbeckenwv</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2571850.8" miny="5655250.0" maxx="2610579.0" maxy="5684825.0"/></Layer><Layer><Name>klaerwerke</Name><Title>klaerwerke</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2568205.8" miny="5655293.0" maxx="2606643.5" maxy="5684697.0"/></Layer></Layer></Capability></WMT_MS_Capabilities>', NULL, 'http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (881, '1.1.0', 'Gebietsgliederung', '', 'http://212.8.208.50/umn/wms_gebgli.asp?', 'http://212.8.208.50/umn/wms_gebgli.asp?', 'http://212.8.208.50/umn/wms_gebgli.asp?', 'http://212.8.208.50/umn/wms_gebgli.asp?', NULL, '<?xml version="1.0" encoding="ISO-8859-1" standalone="no" ?><!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengeospatial.net/wms/1.1.0/capabilities_1_1_0.dtd" [ <!ELEMENT VendorSpecificCapabilities EMPTY> ]>  <!-- end of DOCTYPE declaration --><WMT_MS_Capabilities version="1.1.0"><!-- MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG --><Service>  <Name>OGC:WMS</Name>  <Title>Gebietsgliederung</Title>  <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Service><Capability>  <Request>    <GetCapabilities>      <Format>application/vnd.ogc.wms_xml</Format>      <DCPType>        <HTTP>          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Get>          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Post>        </HTTP>      </DCPType>    </GetCapabilities>    <GetMap>      <Format>image/gif</Format>      <Format>image/png</Format>      <Format>image/jpeg</Format>      <Format>image/tiff</Format>      <DCPType>        <HTTP>          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Get>          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Post>        </HTTP>      </DCPType>    </GetMap>    <GetFeatureInfo>      <Format>text/plain</Format>      <Format>text/html</Format>      <Format>application/vnd.ogc.gml</Format>      <DCPType>        <HTTP>          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Get>          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Post>        </HTTP>      </DCPType>    </GetFeatureInfo>    <DescribeLayer>      <Format>text/xml</Format>      <DCPType>        <HTTP>          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Get>          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Post>        </HTTP>      </DCPType>    </DescribeLayer>    <GetLegendGraphic>      <Format>image/gif</Format>      <Format>image/png</Format>      <Format>image/jpeg</Format>      <DCPType>        <HTTP>          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Get>          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Post>        </HTTP>      </DCPType>    </GetLegendGraphic>  </Request>  <Exception>    <Format>application/vnd.ogc.se_xml</Format>    <Format>application/vnd.ogc.se_inimage</Format>    <Format>application/vnd.ogc.se_blank</Format>  </Exception>  <VendorSpecificCapabilities />  <UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0"/>  <Layer>    <Name>Gebietsgliederung</Name>    <Title>Gebietsgliederung</Title>    <SRS>epsg:31467</SRS>    <LatLonBoundingBox minx="8.37676" miny="51.9156" maxx="8.68781" maxy="52.1168" />    <BoundingBox SRS="EPSG:31467"                minx="3.45731e+006" miny="5.75355e+006" maxx="3.47852e+006" maxy="5.77579e+006" />    <Layer>      <Name>Stadtbezirke</Name>      <Title>Stadtbezirke</Title>      <Abstract>Stadtbezirke</Abstract>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>stadtbezirke_pl</Name>        <Title>stadtbezirke_pl</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=stadtbezirke_pl&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="4989.03" />      </Layer>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>stadtbezirke_t</Name>        <Title>stadtbezirke_t</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=stadtbezirke_t&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="149.671" />      </Layer>    </Layer>    <Layer>      <Name>Statistische_Bezirke</Name>      <Title>Statistische_Bezirke</Title>      <Abstract>Statistische_Bezirke</Abstract>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>statist_bez_pl</Name>        <Title>statist_bez_pl</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=statist_bez_pl&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="149.671" />      </Layer>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>statist_bez_t</Name>        <Title>statist_bez_t</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=statist_bez_t&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="149.671" />      </Layer>    </Layer>    <Layer>      <Name>Verkehrszellen</Name>      <Title>Verkehrszellen</Title>      <Abstract>Verkehrszellen</Abstract>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>verkehrszellen_pl</Name>        <Title>verkehrszellen_pl</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=verkehrszellen_pl&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="149.671" />      </Layer>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>verkehrszellen_t</Name>        <Title>verkehrszellen_t</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=verkehrszellen_t&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="149.671" />      </Layer>    </Layer>    <Layer>      <Name>Baubloecke</Name>      <Title>Baubloecke</Title>      <Abstract>Baubloecke</Abstract>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>baubloecke_pl</Name>        <Title>baubloecke_pl</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=baubloecke_pl&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="49.8903" />      </Layer>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>baubloecke_t</Name>        <Title>baubloecke_t</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=baubloecke_t&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="49.8903" />      </Layer>    </Layer>  </Layer></Capability></WMT_MS_Capabilities>', NULL, 'http://212.8.208.50/umn/wms_gebgli.asp?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (882, '1.1.0', 'Wahlen', '', 'http://212.8.208.50/umn/wms_wahlen.asp?', 'http://212.8.208.50/umn/wms_wahlen.asp?', 'http://212.8.208.50/umn/wms_wahlen.asp?', 'http://212.8.208.50/umn/wms_wahlen.asp?', NULL, '<?xml version="1.0" encoding="ISO-8859-1" standalone="no" ?><!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengeospatial.net/wms/1.1.0/capabilities_1_1_0.dtd" [ <!ELEMENT VendorSpecificCapabilities EMPTY> ]>  <!-- end of DOCTYPE declaration --><WMT_MS_Capabilities version="1.1.0"><!-- MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG --><Service>  <Name>OGC:WMS</Name>  <Title>Wahlen</Title>  <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Service><Capability>  <Request>    <GetCapabilities>      <Format>application/vnd.ogc.wms_xml</Format>      <DCPType>        <HTTP>          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Get>          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Post>        </HTTP>      </DCPType>    </GetCapabilities>    <GetMap>      <Format>image/gif</Format>      <Format>image/png</Format>      <Format>image/jpeg</Format>      <Format>image/tiff</Format>      <DCPType>        <HTTP>          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Get>          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Post>        </HTTP>      </DCPType>    </GetMap>    <GetFeatureInfo>      <Format>text/plain</Format>      <Format>text/html</Format>      <Format>application/vnd.ogc.gml</Format>      <DCPType>        <HTTP>          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Get>          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Post>        </HTTP>      </DCPType>    </GetFeatureInfo>    <DescribeLayer>      <Format>text/xml</Format>      <DCPType>        <HTTP>          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Get>          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Post>        </HTTP>      </DCPType>    </DescribeLayer>    <GetLegendGraphic>      <Format>image/gif</Format>      <Format>image/png</Format>      <Format>image/jpeg</Format>      <DCPType>        <HTTP>          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Get>          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Post>        </HTTP>      </DCPType>    </GetLegendGraphic>  </Request>  <Exception>    <Format>application/vnd.ogc.se_xml</Format>    <Format>application/vnd.ogc.se_inimage</Format>    <Format>application/vnd.ogc.se_blank</Format>  </Exception>  <VendorSpecificCapabilities />  <UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0"/>  <Layer>    <Name>Wahlen</Name>    <Title>Wahlen</Title>    <SRS>epsg:31467</SRS>    <LatLonBoundingBox minx="8.37676" miny="51.9156" maxx="8.68781" maxy="52.1168" />    <BoundingBox SRS="EPSG:31467"                minx="3.45731e+006" miny="5.75355e+006" maxx="3.47852e+006" maxy="5.77579e+006" />    <Layer>      <Name>HINTERGRUNDKARTE</Name>      <Title>HINTERGRUNDKARTE</Title>      <Abstract>HINTERGRUNDKARTE</Abstract>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>stadtplan_grau_zoomst_1</Name>        <Title>stadtplan_grau_zoomst_1</Title>        <SRS>EPSG:31467</SRS>        <ScaleHint min="67.3524" max="149.671" />      </Layer>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>stadtplan_zoom3_01</Name>        <Title>02_stadtplan</Title>        <SRS>EPSG:31467</SRS>        <ScaleHint min="9.97856" max="67.3519" />      </Layer>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>stadtplan_zoom3_02</Name>        <Title>03_stadtplan</Title>        <SRS>EPSG:31467</SRS>        <ScaleHint min="5.98733" max="9.97806" />      </Layer>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>stadtplan_zoom3_03</Name>        <Title>04_stadtplan</Title>        <SRS>EPSG:31467</SRS>        <ScaleHint min="1.37248" max="5.98683" />      </Layer>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>dgk5_liste</Name>        <Title>Deutsche Grundkarte</Title>        <SRS>EPSG:31467</SRS>        <ScaleHint min="0" max="1.37198" />      </Layer>    </Layer>    <Layer queryable="0" opaque="0" cascaded="0">        <Name>stadtplan_72dpi</Name>        <Title>stadtplan_uebersicht</Title>        <SRS>EPSG:31467</SRS>        <ScaleHint min="149.671" max="498.903" />    </Layer>    <Layer>      <Name>Stadtbezirke</Name>      <Title>Stadtbezirke</Title>      <Abstract>Stadtbezirke</Abstract>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>stadtbezirke_pl</Name>        <Title>stadtbezirke_pl</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=stadtbezirke_pl&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="149.671" />      </Layer>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>stadtbezirke_t</Name>        <Title>stadtbezirke_t</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=stadtbezirke_t&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="149.671" />      </Layer>    </Layer>    <Layer>      <Name>Wahlbezirke</Name>      <Title>Wahlbezirke</Title>      <Abstract>Wahlbezirke</Abstract>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>wahlbezirke_pl</Name>        <Title>wahlbezirke_pl</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=wahlbezirke_pl&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="149.671" />      </Layer>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>wahlbezirke_t</Name>        <Title>wahlbezirke_t</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=wahlbezirke_t&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="149.671" />      </Layer>    </Layer>    <Layer>      <Name>Stimmbezirke</Name>      <Title>Stimmbezirke</Title>      <Abstract>Stimmbezirke</Abstract>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>stimmbezirke_pl</Name>        <Title>stimmbezirke_pl</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=stimmbezirke_pl&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="149.671" />      </Layer>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>stimmbezirke_t</Name>        <Title>stimmbezirke_t</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=stimmbezirke_t&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="149.671" />      </Layer>    </Layer>  </Layer></Capability></WMT_MS_Capabilities>', NULL, 'http://212.8.208.50/umn/wms_wahlen.asp?');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (883, '1.0.0', 'SICAD/SD-IMS V5.1-Luftbilder', 'SICAD/SD Internet Map Services V5.1 at http://192.168.252.12:80-Luftbilder', 'http://212.8.208.50/mapserver/isserver/sdims/bin/wms/getCapabilities.pl?dataSource=Luftbilder', 'http://212.8.208.50/mapserver/isserver/sdims/bin/wms/getMap.pl?dataSource=Luftbilder', 'http://212.8.208.50/mapserver/isserver/sdims/bin/wms/getFeatureInfo.pl?dataSource=Luftbilder', '', NULL, '<?xml version="1.0" encoding="ISO-8859-1" standalone="no"?>
+<WMT_MS_Capabilities version="1.1.0" updateSequence="0"><Service><Name>OGC:WMS</Name><Title>WMS Map Server</Title><Abstract>WMS Map Server</Abstract><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?"/><Fees></Fees><AccessConstraints></AccessConstraints></Service><Capability><Request><GetCapabilities><Format>application/vnd.ogc.wms_xml</Format><DCPType><HTTP><Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?"/></Get></HTTP></DCPType></GetCapabilities><GetMap><Format>image/jpeg</Format><Format>image/gif</Format><Format>image/png</Format><DCPType><HTTP><Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?"/></Get></HTTP></DCPType></GetMap><GetFeatureInfo><Format>application/vnd.ogc.wms_xml</Format><Format>text/plain</Format><Format>text/html</Format><DCPType><HTTP><Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?"/></Get></HTTP></DCPType></GetFeatureInfo></Request><Exception><Format>application/vnd.ogc.se_xml</Format><Format>application/vnd.ogc.se_inimage</Format><Format>application/vnd.ogc.se_blank</Format></Exception><Layer><Title>WV_WMS</Title><SRS>EPSG:4326</SRS><Layer><Name>rheinplus</Name><Title>rheinplus</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2546442.5" miny="5629738.5" maxx="2574239.0" maxy="5690679.0"/></Layer><Layer><Name>uesgobwup</Name><Title>uesgobwup</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2593889.2" miny="5662005.5" maxx="2609059.0" maxy="5669772.0"/></Layer><Layer><Name>uesgmorsbach</Name><Title>uesgmorsbach</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2579495.5" miny="5670734.5" maxx="2586469.8" maxy="5679051.5"/></Layer><Layer><Name>klaerwerkseinzugsgebiete</Name><Title>klaerwerkseinzugsgebiete</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2563368.2" miny="5652735.5" maxx="2612351.5" maxy="5687238.5"/></Layer><Layer><Name>entwaesserungssystem</Name><Title>entwaesserungssystem</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2563368.2" miny="5652735.5" maxx="2612351.5" maxy="5687238.5"/></Layer><Layer><Name>gezgross</Name><Title>gezgross</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2566194.5" miny="5650761.0" maxx="2612288.8" maxy="5687441.5"/></Layer><Layer><Name>gezklein</Name><Title>gezklein</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2566194.5" miny="5650761.0" maxx="2612288.8" maxy="5687441.5"/></Layer><Layer><Name>ueberleitungsgebiete</Name><Title>ueberleitungsgebiete</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2563139.2" miny="5653338.0" maxx="2598613.0" maxy="5687438.5"/></Layer><Layer><Name>verbandsgebiet</Name><Title>verbandsgebiet</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2566194.0" miny="5650736.5" maxx="2612255.8" maxy="5687418.5"/></Layer><Layer><Name>gsg5</Name><Title>gsg5</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2566094.0" miny="5650929.5" maxx="2611978.2" maxy="5687202.5"/></Layer><Layer><Name>gsg3</Name><Title>gsg3</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2566094.0" miny="5650892.0" maxx="2612015.5" maxy="5687211.0"/></Layer><Layer><Name>gsg1</Name><Title>gsg1</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2566094.0" miny="5650866.0" maxx="2612040.5" maxy="5687229.5"/></Layer><Layer><Name>gewaesser</Name><Title>gewaesser</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2565684.0" miny="5650966.5" maxx="2611954.8" maxy="5687197.0"/></Layer><Layer><Name>verrohrungen</Name><Title>verrohrungen</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2568289.8" miny="5650979.5" maxx="2611939.5" maxy="5687154.0"/></Layer><Layer><Name>verlaufaenderungen</Name><Title>verlaufaenderungen</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2567540.2" miny="5651123.5" maxx="2610584.0" maxy="5686884.5"/></Layer><Layer><Name>gewaesserbeschriftung</Name><Title>gewaesserbeschriftung</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2565684.0" miny="5650966.5" maxx="2611954.8" maxy="5687197.0"/></Layer><Layer><Name>talsperren</Name><Title>talsperren</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2574368.5" miny="5657951.5" maxx="2609796.2" maxy="5680451.5"/></Layer><Layer><Name>sammler</Name><Title>sammler</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2568024.0" miny="5657404.5" maxx="2610590.5" maxy="5676478.5"/></Layer><Layer><Name>stationierung</Name><Title>stationierung</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2566160.2" miny="5650970.5" maxx="2611941.8" maxy="5687151.0"/></Layer><Layer><Name>fotos_am_gewaesser</Name><Title>fotos_am_gewaesser</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2566094.0" miny="5650970.5" maxx="2611941.0" maxy="5687106.5"/></Layer><Layer><Name>limnologie</Name><Title>limnologie</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2568246.5" miny="5655120.5" maxx="2610520.0" maxy="5682874.5"/></Layer><Layer><Name>niederschlagsstationen</Name><Title>niederschlagsstationen</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2568200.5" miny="5655310.0" maxx="2609614.8" maxy="5684705.0"/></Layer><Layer><Name>pegel</Name><Title>pegel</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2569725.2" miny="5652906.5" maxx="2610202.8" maxy="5683943.5"/></Layer><Layer><Name>wehre</Name><Title>wehre</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2567619.8" miny="5655330.5" maxx="2610201.8" maxy="5682797.0"/></Layer><Layer><Name>fischaufstiege</Name><Title>fischaufstiege</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2567619.8" miny="5655330.5" maxx="2607229.8" maxy="5682797.0"/></Layer><Layer><Name>hrb</Name><Title>hrb</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2574521.2" miny="5654207.5" maxx="2598042.2" maxy="5685821.0"/></Layer><Layer><Name>regenbeckenwv</Name><Title>regenbeckenwv</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2571850.8" miny="5655250.0" maxx="2610579.0" maxy="5684825.0"/></Layer><Layer><Name>klaerwerke</Name><Title>klaerwerke</Title><SRS>EPSG:4326</SRS><LatLonBoundingBox minx="2568205.8" miny="5655293.0" maxx="2606643.5" maxy="5684697.0"/></Layer></Layer></Capability></WMT_MS_Capabilities>', NULL, 'http://fluggs.wupperverband.de:80/servlet/com.esri.wms.Esrimap?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (881, '1.1.0', 'Gebietsgliederung', '', 'http://212.8.208.50/umn/wms_gebgli.asp?', 'http://212.8.208.50/umn/wms_gebgli.asp?', 'http://212.8.208.50/umn/wms_gebgli.asp?', 'http://212.8.208.50/umn/wms_gebgli.asp?', NULL, '<?xml version="1.0" encoding="ISO-8859-1" standalone="no" ?><!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengeospatial.net/wms/1.1.0/capabilities_1_1_0.dtd" [ <!ELEMENT VendorSpecificCapabilities EMPTY> ]>  <!-- end of DOCTYPE declaration --><WMT_MS_Capabilities version="1.1.0"><!-- MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG --><Service>  <Name>OGC:WMS</Name>  <Title>Gebietsgliederung</Title>  <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Service><Capability>  <Request>    <GetCapabilities>      <Format>application/vnd.ogc.wms_xml</Format>      <DCPType>        <HTTP>          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Get>          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Post>        </HTTP>      </DCPType>    </GetCapabilities>    <GetMap>      <Format>image/gif</Format>      <Format>image/png</Format>      <Format>image/jpeg</Format>      <Format>image/tiff</Format>      <DCPType>        <HTTP>          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Get>          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Post>        </HTTP>      </DCPType>    </GetMap>    <GetFeatureInfo>      <Format>text/plain</Format>      <Format>text/html</Format>      <Format>application/vnd.ogc.gml</Format>      <DCPType>        <HTTP>          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Get>          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Post>        </HTTP>      </DCPType>    </GetFeatureInfo>    <DescribeLayer>      <Format>text/xml</Format>      <DCPType>        <HTTP>          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Get>          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Post>        </HTTP>      </DCPType>    </DescribeLayer>    <GetLegendGraphic>      <Format>image/gif</Format>      <Format>image/png</Format>      <Format>image/jpeg</Format>      <DCPType>        <HTTP>          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Get>          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?"/></Post>        </HTTP>      </DCPType>    </GetLegendGraphic>  </Request>  <Exception>    <Format>application/vnd.ogc.se_xml</Format>    <Format>application/vnd.ogc.se_inimage</Format>    <Format>application/vnd.ogc.se_blank</Format>  </Exception>  <VendorSpecificCapabilities />  <UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0"/>  <Layer>    <Name>Gebietsgliederung</Name>    <Title>Gebietsgliederung</Title>    <SRS>epsg:31467</SRS>    <LatLonBoundingBox minx="8.37676" miny="51.9156" maxx="8.68781" maxy="52.1168" />    <BoundingBox SRS="EPSG:31467"                minx="3.45731e+006" miny="5.75355e+006" maxx="3.47852e+006" maxy="5.77579e+006" />    <Layer>      <Name>Stadtbezirke</Name>      <Title>Stadtbezirke</Title>      <Abstract>Stadtbezirke</Abstract>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>stadtbezirke_pl</Name>        <Title>stadtbezirke_pl</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=stadtbezirke_pl&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="4989.03" />      </Layer>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>stadtbezirke_t</Name>        <Title>stadtbezirke_t</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=stadtbezirke_t&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="149.671" />      </Layer>    </Layer>    <Layer>      <Name>Statistische_Bezirke</Name>      <Title>Statistische_Bezirke</Title>      <Abstract>Statistische_Bezirke</Abstract>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>statist_bez_pl</Name>        <Title>statist_bez_pl</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=statist_bez_pl&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="149.671" />      </Layer>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>statist_bez_t</Name>        <Title>statist_bez_t</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=statist_bez_t&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="149.671" />      </Layer>    </Layer>    <Layer>      <Name>Verkehrszellen</Name>      <Title>Verkehrszellen</Title>      <Abstract>Verkehrszellen</Abstract>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>verkehrszellen_pl</Name>        <Title>verkehrszellen_pl</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=verkehrszellen_pl&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="149.671" />      </Layer>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>verkehrszellen_t</Name>        <Title>verkehrszellen_t</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=verkehrszellen_t&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="149.671" />      </Layer>    </Layer>    <Layer>      <Name>Baubloecke</Name>      <Title>Baubloecke</Title>      <Abstract>Baubloecke</Abstract>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>baubloecke_pl</Name>        <Title>baubloecke_pl</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=baubloecke_pl&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="49.8903" />      </Layer>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>baubloecke_t</Name>        <Title>baubloecke_t</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_gebgli.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=baubloecke_t&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="49.8903" />      </Layer>    </Layer>  </Layer></Capability></WMT_MS_Capabilities>', NULL, 'http://212.8.208.50/umn/wms_gebgli.asp?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (882, '1.1.0', 'Wahlen', '', 'http://212.8.208.50/umn/wms_wahlen.asp?', 'http://212.8.208.50/umn/wms_wahlen.asp?', 'http://212.8.208.50/umn/wms_wahlen.asp?', 'http://212.8.208.50/umn/wms_wahlen.asp?', NULL, '<?xml version="1.0" encoding="ISO-8859-1" standalone="no" ?><!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengeospatial.net/wms/1.1.0/capabilities_1_1_0.dtd" [ <!ELEMENT VendorSpecificCapabilities EMPTY> ]>  <!-- end of DOCTYPE declaration --><WMT_MS_Capabilities version="1.1.0"><!-- MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG --><Service>  <Name>OGC:WMS</Name>  <Title>Wahlen</Title>  <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Service><Capability>  <Request>    <GetCapabilities>      <Format>application/vnd.ogc.wms_xml</Format>      <DCPType>        <HTTP>          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Get>          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Post>        </HTTP>      </DCPType>    </GetCapabilities>    <GetMap>      <Format>image/gif</Format>      <Format>image/png</Format>      <Format>image/jpeg</Format>      <Format>image/tiff</Format>      <DCPType>        <HTTP>          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Get>          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Post>        </HTTP>      </DCPType>    </GetMap>    <GetFeatureInfo>      <Format>text/plain</Format>      <Format>text/html</Format>      <Format>application/vnd.ogc.gml</Format>      <DCPType>        <HTTP>          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Get>          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Post>        </HTTP>      </DCPType>    </GetFeatureInfo>    <DescribeLayer>      <Format>text/xml</Format>      <DCPType>        <HTTP>          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Get>          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Post>        </HTTP>      </DCPType>    </DescribeLayer>    <GetLegendGraphic>      <Format>image/gif</Format>      <Format>image/png</Format>      <Format>image/jpeg</Format>      <DCPType>        <HTTP>          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Get>          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?"/></Post>        </HTTP>      </DCPType>    </GetLegendGraphic>  </Request>  <Exception>    <Format>application/vnd.ogc.se_xml</Format>    <Format>application/vnd.ogc.se_inimage</Format>    <Format>application/vnd.ogc.se_blank</Format>  </Exception>  <VendorSpecificCapabilities />  <UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0"/>  <Layer>    <Name>Wahlen</Name>    <Title>Wahlen</Title>    <SRS>epsg:31467</SRS>    <LatLonBoundingBox minx="8.37676" miny="51.9156" maxx="8.68781" maxy="52.1168" />    <BoundingBox SRS="EPSG:31467"                minx="3.45731e+006" miny="5.75355e+006" maxx="3.47852e+006" maxy="5.77579e+006" />    <Layer>      <Name>HINTERGRUNDKARTE</Name>      <Title>HINTERGRUNDKARTE</Title>      <Abstract>HINTERGRUNDKARTE</Abstract>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>stadtplan_grau_zoomst_1</Name>        <Title>stadtplan_grau_zoomst_1</Title>        <SRS>EPSG:31467</SRS>        <ScaleHint min="67.3524" max="149.671" />      </Layer>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>stadtplan_zoom3_01</Name>        <Title>02_stadtplan</Title>        <SRS>EPSG:31467</SRS>        <ScaleHint min="9.97856" max="67.3519" />      </Layer>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>stadtplan_zoom3_02</Name>        <Title>03_stadtplan</Title>        <SRS>EPSG:31467</SRS>        <ScaleHint min="5.98733" max="9.97806" />      </Layer>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>stadtplan_zoom3_03</Name>        <Title>04_stadtplan</Title>        <SRS>EPSG:31467</SRS>        <ScaleHint min="1.37248" max="5.98683" />      </Layer>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>dgk5_liste</Name>        <Title>Deutsche Grundkarte</Title>        <SRS>EPSG:31467</SRS>        <ScaleHint min="0" max="1.37198" />      </Layer>    </Layer>    <Layer queryable="0" opaque="0" cascaded="0">        <Name>stadtplan_72dpi</Name>        <Title>stadtplan_uebersicht</Title>        <SRS>EPSG:31467</SRS>        <ScaleHint min="149.671" max="498.903" />    </Layer>    <Layer>      <Name>Stadtbezirke</Name>      <Title>Stadtbezirke</Title>      <Abstract>Stadtbezirke</Abstract>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>stadtbezirke_pl</Name>        <Title>stadtbezirke_pl</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=stadtbezirke_pl&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="149.671" />      </Layer>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>stadtbezirke_t</Name>        <Title>stadtbezirke_t</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=stadtbezirke_t&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="149.671" />      </Layer>    </Layer>    <Layer>      <Name>Wahlbezirke</Name>      <Title>Wahlbezirke</Title>      <Abstract>Wahlbezirke</Abstract>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>wahlbezirke_pl</Name>        <Title>wahlbezirke_pl</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=wahlbezirke_pl&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="149.671" />      </Layer>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>wahlbezirke_t</Name>        <Title>wahlbezirke_t</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=wahlbezirke_t&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="149.671" />      </Layer>    </Layer>    <Layer>      <Name>Stimmbezirke</Name>      <Title>Stimmbezirke</Title>      <Abstract>Stimmbezirke</Abstract>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>stimmbezirke_pl</Name>        <Title>stimmbezirke_pl</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=stimmbezirke_pl&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="149.671" />      </Layer>      <Layer queryable="0" opaque="0" cascaded="0">        <Name>stimmbezirke_t</Name>        <Title>stimmbezirke_t</Title>        <SRS>EPSG:31467</SRS>        <LatLonBoundingBox minx="-180" miny="-4.52677e+032" maxx="176.991" maxy="4.52677e+032" />        <BoundingBox SRS="EPSG:31467"                    minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007" maxy="2.5e+007" />        <Style>          <Name>default</Name>          <Title>default</Title>          <LegendURL width="18" height="12">             <Format>image/png</Format>             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://212.8.208.50/umn/wms_wahlen.asp?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=stimmbezirke_t&amp;format=image/png"/>          </LegendURL>        </Style>        <ScaleHint min="0" max="149.671" />      </Layer>    </Layer>  </Layer></Capability></WMT_MS_Capabilities>', NULL, 'http://212.8.208.50/umn/wms_wahlen.asp?', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (883, '1.0.0', 'SICAD/SD-IMS V5.1-Luftbilder', 'SICAD/SD Internet Map Services V5.1 at http://192.168.252.12:80-Luftbilder', 'http://212.8.208.50/mapserver/isserver/sdims/bin/wms/getCapabilities.pl?dataSource=Luftbilder', 'http://212.8.208.50/mapserver/isserver/sdims/bin/wms/getMap.pl?dataSource=Luftbilder', 'http://212.8.208.50/mapserver/isserver/sdims/bin/wms/getFeatureInfo.pl?dataSource=Luftbilder', '', NULL, '<?xml version="1.0" encoding="ISO-8859-1" standalone="no"?>
 <!DOCTYPE WMT_MS_Capabilities SYSTEM "http://212.8.208.50/mapserver/isserver/sdims/bin/wms/capabilities1.0.0.dtd" >
 <WMT_MS_Capabilities version="1.0.0" updateSequence="1">
 	<Service>
@@ -10149,9 +10494,9 @@
 			<Abstract>9</Abstract>
 			</Style>
 	</Layer>
-</Layer></Capability></WMT_MS_Capabilities>', NULL, 'http://212.8.208.50/mapserver/isserver/sdims/bin/wms/getCapabilities.pl?dataSource=Luftbilder');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (887, '1.1.0', 'NRW: Bodenkarte BK50', 'WMS Map Server', 'http://www.gis.nrw.de:80/wms/BK50', 'http://www.gis.nrw.de:80/wms/BK50', 'http://www.gis.nrw.de:80/wms/BK50', '', NULL, '<?xml version="1.0" encoding="UTF-8" standalone="yes" ?><!DOCTYPE WMT_MS_Capabilities SYSTEM "http://www.digitalearth.gov/wmt/xml/capabilities_1_1_0.dtd" ><WMT_MS_Capabilities version="1.1.0" updateSequence="0"><Service><Name>OGC:WMS</Name><Title>NRW: Bodenkarte BK50</Title><Abstract>WMS Map Server</Abstract><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.gis.nrw.de:80/wms/BK50?"/><Fees></Fees><AccessConstraints></AccessConstraints></Service><Capability><Request><GetCapabilities><Format>application/vnd.ogc.wms_xml</Format><DCPType><HTTP><Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.gis.nrw.de:80/wms/BK50"/></Get></HTTP></DCPType></GetCapabilities><GetMap><Format>image/jpeg</Format><Format>image/png</Format><DCPType><HTTP><Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.gis.nrw.de:80/wms/BK50"/></Get></HTTP></DCPType></GetMap><GetFeatureInfo><Format>application/vnd.ogc.wms_xml</Format><Format>text/plain</Format><Format>text/html</Format><DCPType><HTTP><Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.gis.nrw.de:80/wms/BK50"/></Get></HTTP></DCPType></GetFeatureInfo></Request><Exception><Format>application/vnd.ogc.se_xml</Format><Format>application/vnd.ogc.se_inimage</Format><Format>application/vnd.ogc.se_blank</Format></Exception><Layer queryable="1"><Title>BK50</Title><SRS>EPSG:31492</SRS>  <LatLonBoundingBox maxx="8.6519" maxy="52.5054" minx="5.8682" miny="50.3189" />   <BoundingBox SRS="EPSG:31492" minx="2476553.0" miny="5540279.0" maxx="2779499.0" maxy="5856970.0" /><Layer queryable="1"><Name>bk50</Name><Title>bk50</Title><SRS>EPSG:31492</SRS><LatLonBoundingBox minx="2738496.0" miny="77673.0" maxx="5821724.0" maxy="625065.0"/></Layer></Layer></Capability></WMT_MS_Capabilities>', NULL, 'http://www.gis.nrw.de:80/wms/BK50');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (903, '1.1.0', 'DNM 25', 'Digitales Navigationsmodell 1:25.000 als Basisnavigationsdaten der Brandenburger Landesvermessung', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM25.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM25.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM25.map&', '', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
+</Layer></Capability></WMT_MS_Capabilities>', NULL, 'http://212.8.208.50/mapserver/isserver/sdims/bin/wms/getCapabilities.pl?dataSource=Luftbilder', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (887, '1.1.0', 'NRW: Bodenkarte BK50', 'WMS Map Server', 'http://www.gis.nrw.de:80/wms/BK50', 'http://www.gis.nrw.de:80/wms/BK50', 'http://www.gis.nrw.de:80/wms/BK50', '', NULL, '<?xml version="1.0" encoding="UTF-8" standalone="yes" ?><!DOCTYPE WMT_MS_Capabilities SYSTEM "http://www.digitalearth.gov/wmt/xml/capabilities_1_1_0.dtd" ><WMT_MS_Capabilities version="1.1.0" updateSequence="0"><Service><Name>OGC:WMS</Name><Title>NRW: Bodenkarte BK50</Title><Abstract>WMS Map Server</Abstract><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.gis.nrw.de:80/wms/BK50?"/><Fees></Fees><AccessConstraints></AccessConstraints></Service><Capability><Request><GetCapabilities><Format>application/vnd.ogc.wms_xml</Format><DCPType><HTTP><Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.gis.nrw.de:80/wms/BK50"/></Get></HTTP></DCPType></GetCapabilities><GetMap><Format>image/jpeg</Format><Format>image/png</Format><DCPType><HTTP><Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.gis.nrw.de:80/wms/BK50"/></Get></HTTP></DCPType></GetMap><GetFeatureInfo><Format>application/vnd.ogc.wms_xml</Format><Format>text/plain</Format><Format>text/html</Format><DCPType><HTTP><Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.gis.nrw.de:80/wms/BK50"/></Get></HTTP></DCPType></GetFeatureInfo></Request><Exception><Format>application/vnd.ogc.se_xml</Format><Format>application/vnd.ogc.se_inimage</Format><Format>application/vnd.ogc.se_blank</Format></Exception><Layer queryable="1"><Title>BK50</Title><SRS>EPSG:31492</SRS>  <LatLonBoundingBox maxx="8.6519" maxy="52.5054" minx="5.8682" miny="50.3189" />   <BoundingBox SRS="EPSG:31492" minx="2476553.0" miny="5540279.0" maxx="2779499.0" maxy="5856970.0" /><Layer queryable="1"><Name>bk50</Name><Title>bk50</Title><SRS>EPSG:31492</SRS><LatLonBoundingBox minx="2738496.0" miny="77673.0" maxx="5821724.0" maxy="625065.0"/></Layer></Layer></Capability></WMT_MS_Capabilities>', NULL, 'http://www.gis.nrw.de:80/wms/BK50', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (903, '1.1.0', 'DNM 25', 'Digitales Navigationsmodell 1:25.000 als Basisnavigationsdaten der Brandenburger Landesvermessung', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM25.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM25.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM25.map&', '', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
@@ -10351,8 +10696,8 @@
   </Layer>
 </Capability>
-', NULL, 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM25.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1');
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url) VALUES (904, '1.1.0', 'DNM 250/2', '2. Generation des Digitalen Navigationsmodells 1:250.000 als topographische Basisnavigationsdaten der Brandenburger Landesvermessung', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM250n.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM250n.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM250n.map&', '', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
+', NULL, 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM25.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (904, '1.1.0', 'DNM 250/2', '2. Generation des Digitalen Navigationsmodells 1:250.000 als topographische Basisnavigationsdaten der Brandenburger Landesvermessung', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM250n.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM250n.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM250n.map&', '', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
@@ -10532,12 +10877,280 @@
   </Layer>
 </Capability>
-', NULL, 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM250n.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1');
+', NULL, 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNM250n.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 1, NULL);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (908, '1.1.0', 'NRW: TK100 Farbe', 'Nutzungsbedingungen: Sämtliche Rechte an diesem Produkt liegen beim Landesvermessungsamt NRW. Die Nutzung ist bis auf Widerruf kostenfrei. Der Nutzer muss sich vor jeder Nutzung beim Landesvermessungsamt NRW identifizieren und seine spezielle Nutzung mit Angabe des Verwendungszwecks und Umfang der Nutzung anmelden (Kontaktmöglichkeiten zum Landesvermessungsamt NRW siehe unten). Die Nutzung ist ausschließlich für Testzwecke und im Rahmen von GDI-Projekten zulässig; die Nutzung für kommerzielle Anwendungen ist ausdrücklich ausgeschlossen. Die mittelbare oder unmittelbare Weitergabe der Daten an Dritte ist auch in Verbindung mit weiteren Daten ohne ausdrückliche Genehmigung durch das Landesvermessungsamt NRW nicht zulässig. Der Nutzer ist verpflichtet, einen deutlichen Copyright-Hinweis auf das Landesvermessungsamt NRW als Dateneigentümer bei Visualisierungen jeder Art anzubringen.', 'http://www.geoserver.nrw.de:80/GeoOgcWms1.3/servlet/TK100', 'http://www.geoserver.nrw.de:80/GeoOgcWms1.3/servlet/TK100', 'http://www.geoserver.nrw.de:80/GeoOgcWms1.3/servlet/TK100', '', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
+<!-- The DTD (Document Type Definition) given here must correspond to the version number declared in the WMT_MS_Capabilities element below. -->
+<!DOCTYPE WMT_MS_Capabilities SYSTEM
+  "http://www.geoserver.nrw.de/wmt/xml/capabilities_1_1_0.dtd"
+  <!-- other vendor-specific elements defined here -->
+  <!ELEMENT VendorSpecificCapabilities EMPTY>
+  ]>  <!-- end of DOCTYPE declaration -->
+<!-- The version number listed in the WMT_MS_Capabilities element here must correspond to the DTD declared above.  See the WMT specification document for how to respond when a client requests a version number not implemented by the server. -->
+<!-- Service Metadata -->
+<Service>
+  <!-- The WMT-defined name for this type of service -->
+  <Name>OGC:WMS</Name>
+  <!-- Human-readable title for pick lists -->
+  <Title>NRW: TK100 Farbe</Title>
+  <!-- Narrative description providing additional information -->
+      <Abstract>Nutzungsbedingungen: Sämtliche Rechte an diesem Produkt liegen beim Landesvermessungsamt NRW. Die Nutzung ist bis auf Widerruf kostenfrei. Der Nutzer muss sich vor jeder Nutzung beim Landesvermessungsamt NRW identifizieren und seine spezielle Nutzung mit Angabe des Verwendungszwecks und Umfang der Nutzung anmelden (Kontaktmöglichkeiten zum Landesvermessungsamt NRW siehe unten). Die Nutzung ist ausschließlich für Testzwecke und im Rahmen von GDI-Projekten zulässig; die Nutzung für kommerzielle Anwendungen ist ausdrücklich ausgeschlossen. Die mittelbare oder unmittelbare Weitergabe der Daten an Dritte ist auch in Verbindung mit weiteren Daten ohne ausdrückliche Genehmigung durch das Landesvermessungsamt NRW nicht zulässig. Der Nutzer ist verpflichtet, einen deutlichen Copyright-Hinweis auf das Landesvermessungsamt NRW als Dateneigentümer bei Visualisierungen jeder Art anzubringen.</Abstract>
+      <!-- Top-level web address of service or service provider.  See also OnlineResource
+  elements under <DCPType>. -->
+      <!-- Contact information -->
+      <ContactInformation>
+         <ContactPersonPrimary>
+            <ContactPerson>Karin Landsberg</ContactPerson>
+            <ContactOrganization>Landesvermessungsamt NRW</ContactOrganization>
+         </ContactPersonPrimary>
+         <ContactPosition>Geodatenvertrieb</ContactPosition>
+         <ContactAddress>
+            <AddressType/>
+            <Address>Muffendorfer Str. 19-21</Address>
+            <City>Bonn</City>
+            <StateOrProvince>NRW</StateOrProvince>
+            <PostCode>53177</PostCode>
+            <Country>Germany</Country>
+         </ContactAddress>
+         <ContactVoiceTelephone>49 (228) 846 9320</ContactVoiceTelephone>
+         <ContactFacsimileTelephone>49 (228) 846 9002</ContactFacsimileTelephone>
+         <ContactElectronicMailAddress>landsberg at lverma.nrw.de</ContactElectronicMailAddress>
+      </ContactInformation>  <Fees>none</Fees>
+  <AccessConstraints>none</AccessConstraints>
+</Service>
+<Capability>
+  <Request>
+    <GetCapabilities>
+      <Format>application/vnd.ogc.wms_xml</Format>
+      <DCPType>
+        <HTTP>
+          <Get>
+            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
+             xlink:href="http://www.geoserver.nrw.de:80/GeoOgcWms1.3/servlet/TK100"
+             xlink:type="simple" />
+          </Get>
+          <Post>
+          </Post>
+        </HTTP>
+      </DCPType>
+    </GetCapabilities>
+    <GetMap>
+      <Format>image/png</Format>
+      <Format>image/bmp</Format>
+      <Format>image/jpeg</Format>
+      <Format>image/tiff</Format>
+      <DCPType>
+        <HTTP>
+          <Get>
+          </Get>
+        </HTTP>
+      </DCPType>
+    </GetMap>
+    <GetFeatureInfo>
+      <Format>text/html</Format>
+      <Format>text/plain</Format>
+      <DCPType>
+        <HTTP>
+          <Get>
+          </Get>
+          <Post>
+          </Post>
+        </HTTP>
+      </DCPType>
+    </GetFeatureInfo>
+  </Request>
+  <Exception>
+    <Format>application/vnd.ogc.se_xml</Format>
+  </Exception>
+    <Layer queryable="0" opaque="1">
+      <Title>NRW</Title>
+        <SRS>EPSG:31466 EPSG:31462 EPSG:31492 EPSG:31467 EPSG:25831 EPSG:25832 EPSG:25833</SRS>
+        <LatLonBoundingBox minx="5.673" miny="49.9944" maxx="10.142" maxy="52.7691"></LatLonBoundingBox>
+        <BoundingBox SRS="EPSG:31466" minx="2476553.0" miny="5540279.0" maxx="2779499.0" maxy="5856970.0"></BoundingBox>
+        <BoundingBox SRS="EPSG:31462" minx="2476553.0" miny="5540279.0" maxx="2779499.0" maxy="5856970.0"></BoundingBox>
+        <BoundingBox SRS="EPSG:31492" minx="2476553.0" miny="5540279.0" maxx="2779499.0" maxy="5856970.0"></BoundingBox>
+        <BoundingBox SRS="EPSG:31467" minx="3261513.05" miny="5545534.73" maxx="3577127.98" maxy="5849530.15"></BoundingBox>
+        <BoundingBox SRS="EPSG:25831" minx="691515.47" miny="5541873.35" maxx="981462.1" maxy="5870966.62"></BoundingBox>
+        <BoundingBox SRS="EPSG:25832" minx="261533.79" miny="5543758.24" maxx="577026.2" maxy="5847631.27"></BoundingBox>
+        <BoundingBox SRS="EPSG:25833" minx="-167984.51" miny="5580271.61" maxx="172362.07" maxy="5858091.88"></BoundingBox>
+          <ScaleHint min="0.0" max="70.004"></ScaleHint>
+          <Layer queryable="1" opaque="1">
+            <Name>Raster:TK100_KMF:Farbkombination</Name>
+            <Title>Farbkombination</Title>
+          </Layer>
+    </Layer></Capability>
+</WMT_MS_Capabilities>
+', NULL, 'http://www.geoserver.nrw.de:80/GeoOgcWms1.3/servlet/TK100?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1', 'none', 'none', 'Karin Landsberg', 'Geodatenvertrieb', 'Landesvermessungsamt NRW', 'Muffendorfer Str. 19-21', 'Bonn', 'NRW', '53177', 'Germany', '49 (228) 846 9320', '49 (228) 846 9002', 'landsberg at lverma.nrw.de', NULL, 1, 1169032046);
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (909, '1.1.1', 'MyEdit Elements', 'germany_wfs_places', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
+<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengeospatial.net/wms/1.1.1/WMS_MS_Capabilities.dtd"
+<WMT_MS_Capabilities version="1.1.1">
+<!-- MapServer version 4.8.4 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG -->
+<Service>
+  <Title>MyEdit Elements</Title>
+  <Abstract>germany_wfs_places</Abstract>
+  <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&amp;"/>
+</Service>
+<Capability>
+  <Request>
+    <GetCapabilities>
+      <DCPType>
+        <HTTP>
+          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&amp;"/></Get>
+          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&amp;"/></Post>
+        </HTTP>
+      </DCPType>
+    <GetMap>
+      <Format>image/gif</Format>
+      <Format>image/png; mode=24bit</Format>
+      <Format>image/wbmp</Format>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </GetMap>
+    <GetFeatureInfo>
+      <Format>application/vnd.ogc.gml</Format>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </GetFeatureInfo>
+    <DescribeLayer>
+      <Format>text/xml</Format>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </DescribeLayer>
+    <GetLegendGraphic>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </GetLegendGraphic>
+  </Request>
+  <Exception>
+    <Format>application/vnd.ogc.se_inimage</Format>
+    <Format>application/vnd.ogc.se_blank</Format>
+  </Exception>
+  <VendorSpecificCapabilities />
+  <UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0"/>
+  <Layer>
+    <Name>germany_wfs_myedit</Name>
+    <SRS>epsg:4326</SRS>
+    <SRS>epsg:31467</SRS>
+    <SRS>epsg:31466</SRS>
+    <SRS>epsg:31468</SRS>
+    <SRS>epsg:31469</SRS>
+    <LatLonBoundingBox minx="5.88" miny="46.6213" maxx="15" maxy="55.7187" />
+    <BoundingBox SRS="EPSG:4326"
+                minx="5.88" miny="46.6213" maxx="15" maxy="55.7187" />
+    <ScaleHint min="0.000498902848429637" max="498902.848429637" />
+    <Layer queryable="1" opaque="0" cascaded="0">
+        <Name>my_polygons</Name>
+        <Title>my polygons</Title>
+        <LatLonBoundingBox minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07" />
+                    minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07" />
+        <Style>
+          <Name>default</Name>
+          <Title>default</Title>
+          <LegendURL width="16" height="10">
+             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&amp;version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=my_polygons&amp;format=image/png"/>
+          </LegendURL>
+        </Style>
+    </Layer>
+        <Name>my_lines</Name>
+        <Title>my lines</Title>
+        <Style>
+             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&amp;version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=my_lines&amp;format=image/png"/>
+          </LegendURL>
+        </Style>
+    </Layer>
+        <Name>my_points</Name>
+        <Title>my points</Title>
+        <Style>
+             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&amp;version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=my_points&amp;format=image/png"/>
+          </LegendURL>
+        </Style>
+    </Layer>
+  </Layer>
+</Capability>
+', NULL, 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/wfs/germany_wfs_myedit_4326.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1', '', 'none', '', '', '', '', '', '', '', '', '', '', '', NULL, 1, 1169737820);
--- TOC entry 1779 (class 0 OID 39047487)
--- Dependencies: 1265
+-- TOC entry 1807 (class 0 OID 47913335)
+-- Dependencies: 1274
 -- Data for Name: wms_format; Type: TABLE DATA; Schema: public; Owner: admin
@@ -10838,8 +11451,8 @@
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (900, 'exception', 'application/vnd.ogc.se_xml');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (900, 'exception', 'application/vnd.ogc.se_inimage');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (900, 'exception', 'application/vnd.ogc.se_blank');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (907, 'map', 'image/png');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (907, 'map', 'image/bmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (909, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (909, 'map', 'image/gif');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (764, 'map', 'image/png');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (764, 'map', 'image/jpeg');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (764, 'map', 'image/wbmp');
@@ -10852,11 +11465,11 @@
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (764, 'exception', 'application/vnd.ogc.se_xml');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (764, 'exception', 'application/vnd.ogc.se_inimage');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (764, 'exception', 'application/vnd.ogc.se_blank');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (907, 'map', 'image/jpeg');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (907, 'map', 'image/tiff');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (907, 'featureinfo', 'text/html');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (907, 'featureinfo', 'text/plain');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (907, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (909, 'map', 'image/png; mode=24bit');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (909, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (909, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (909, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (909, 'featureinfo', 'text/plain');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (767, 'map', 'image/gif');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (767, 'map', 'image/png');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (767, 'map', 'image/png; mode=24bit');
@@ -11110,18 +11723,6 @@
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (844, 'featureinfo', 'text/plain');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (844, 'featureinfo', 'text/html');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (844, 'exception', 'application/vnd.ogc.se_xml');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'map', 'image/gif');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'map', 'image/png');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'map', 'image/png; mode=24bit');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'map', 'image/jpeg');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'map', 'image/wbmp');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'map', 'image/tiff');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'featureinfo', 'text/plain');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'featureinfo', 'text/html');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'featureinfo', 'application/vnd.ogc.gml');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'exception', 'application/vnd.ogc.se_xml');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'exception', 'application/vnd.ogc.se_inimage');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'exception', 'application/vnd.ogc.se_blank');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (854, 'map', 'image/gif');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (854, 'map', 'image/png');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (854, 'map', 'image/png; mode=24bit');
@@ -11133,21 +11734,21 @@
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (854, 'exception', 'application/vnd.ogc.se_xml');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (854, 'exception', 'application/vnd.ogc.se_inimage');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (854, 'exception', 'application/vnd.ogc.se_blank');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'map', 'image/png');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'map', 'image/jpeg');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'map', 'image/gif');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'map', 'image/bmp');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'map', 'image/swf');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'featureinfo', 'text/xml');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'featureinfo', 'text/plain');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'featureinfo', 'text/html');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'featureinfo', 'text/swf');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'featureinfo', 'application/vnd.ogc.gml');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'exception', 'application/vnd.ogc.se_inimage');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'exception', 'application/vnd.ogc.se_blank');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'exception', 'application/vnd.ogc.se_xml');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'exception', 'text/xml');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (855, 'exception', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (909, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (909, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (909, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (909, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (909, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'map', 'image/png; mode=24bit');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'exception', 'application/vnd.ogc.se_xml');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (859, 'map', 'image/png');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (859, 'map', 'image/jpeg');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (859, 'featureinfo', 'application/vnd.ogc.wms_xml');
@@ -11244,18 +11845,6 @@
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (887, 'exception', 'application/vnd.ogc.se_xml');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (887, 'exception', 'application/vnd.ogc.se_inimage');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (887, 'exception', 'application/vnd.ogc.se_blank');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'map', 'image/png');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'map', 'image/gif');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'map', 'image/png; mode=24bit');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'map', 'image/jpeg');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'map', 'image/wbmp');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'map', 'image/tiff');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'featureinfo', 'text/plain');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'featureinfo', 'text/html');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'featureinfo', 'application/vnd.ogc.gml');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'exception', 'application/vnd.ogc.se_xml');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'exception', 'application/vnd.ogc.se_inimage');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'exception', 'application/vnd.ogc.se_blank');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (902, 'exception', 'application/vnd.ogc.se_blank');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (905, 'map', 'image/png');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (905, 'map', 'image/jpeg');
@@ -11269,18 +11858,8 @@
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (905, 'exception', 'application/vnd.ogc.se_xml');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (905, 'exception', 'application/vnd.ogc.se_inimage');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (905, 'exception', 'application/vnd.ogc.se_blank');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (901, 'map', 'image/png');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (901, 'map', 'image/gif');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (901, 'map', 'image/png; mode=24bit');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (901, 'map', 'image/jpeg');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (901, 'map', 'image/wbmp');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (901, 'map', 'image/tiff');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (901, 'featureinfo', 'text/plain');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (901, 'featureinfo', 'text/html');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (901, 'featureinfo', 'application/vnd.ogc.gml');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (901, 'exception', 'application/vnd.ogc.se_xml');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (901, 'exception', 'application/vnd.ogc.se_inimage');
-INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (901, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (407, 'exception', 'application/vnd.ogc.se_blank');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (899, 'map', 'image/gif');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (899, 'map', 'image/png');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (899, 'map', 'image/jpeg');
@@ -11316,16 +11895,43 @@
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (906, 'exception', 'application/vnd.ogc.se_xml');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (906, 'exception', 'application/vnd.ogc.se_inimage');
 INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (906, 'exception', 'application/vnd.ogc.se_blank');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (908, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (908, 'map', 'image/bmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (908, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (908, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (908, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (908, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (908, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'map', 'image/png');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'map', 'image/gif');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'map', 'image/png; mode=24bit');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'map', 'image/jpeg');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'map', 'image/wbmp');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'map', 'image/tiff');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'featureinfo', 'text/plain');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'featureinfo', 'text/html');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'featureinfo', 'application/vnd.ogc.gml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'exception', 'application/vnd.ogc.se_xml');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'exception', 'application/vnd.ogc.se_inimage');
+INSERT INTO wms_format (fkey_wms_id, data_type, data_format) VALUES (893, 'exception', 'application/vnd.ogc.se_blank');
--- TOC entry 1780 (class 0 OID 39047492)
--- Dependencies: 1266
+-- TOC entry 1812 (class 0 OID 48558674)
+-- Dependencies: 1281
+-- Data for Name: wms_md_topic_category; Type: TABLE DATA; Schema: public; Owner: admin
+-- TOC entry 1808 (class 0 OID 47913340)
+-- Dependencies: 1275
 -- Data for Name: wms_srs; Type: TABLE DATA; Schema: public; Owner: admin
 INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (854, 'EPSG:31466');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (855, 'EPSG:4326');
+INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (909, 'EPSG:31469');
 INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (859, 'EPSG:NONE');
 INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (859, 'EPSG:4326');
 INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (866, 'EPSG:4326');
@@ -11362,40 +11968,30 @@
 INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (885, 'EPSG:25832');
 INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (885, 'EPSG:25833');
 INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (887, 'EPSG:31492');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (893, 'EPSG:4326');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (893, 'EPSG:31467');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (893, 'EPSG:31466');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (893, 'EPSG:31468');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (893, 'EPSG:31469');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (893, 'EPSG:31492');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (893, 'EPSG:31493');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (893, 'EPSG:31494');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (893, 'EPSG:31495');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (893, 'EPSG:31462');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (893, 'EPSG:31463');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (893, 'EPSG:31464');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (893, 'EPSG:31465');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (893, 'EPSG:25832');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (893, 'EPSG:25833');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (893, 'EPSG:31287');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (893, 'EPSG:32633');
 INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (902, 'EPSG:25833');
 INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (903, 'EPSG:25833');
 INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (904, 'EPSG:25833');
 INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (905, 'EPSG:25833');
 INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (906, 'EPSG:25833');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (907, 'EPSG:31466');
+INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (893, 'EPSG:2398');
 INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (899, 'EPSG:4326');
 INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (900, 'EPSG:4326');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (907, 'EPSG:31462');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (907, 'EPSG:31492');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (907, 'EPSG:31467');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (907, 'EPSG:25831');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (907, 'EPSG:25832');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (907, 'EPSG:25833');
-INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (901, 'EPSG:31469');
+INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (407, 'EPSG:2398');
+INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (908, 'EPSG:31466');
+INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (908, 'EPSG:31462');
+INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (908, 'EPSG:31492');
+INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (908, 'EPSG:31467');
+INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (908, 'EPSG:25831');
+INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (908, 'EPSG:25832');
+INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (908, 'EPSG:25833');
+-- Completed on 2007-01-26 12:20:32 Westeuropäische Normalzeit
+-- PostgreSQL database dump complete
 UPDATE pg_catalog.pg_class SET reltriggers = (SELECT pg_catalog.count(*) FROM pg_catalog.pg_trigger where pg_class.oid = tgrelid) ;
More information about the Mapbender_commits mailing list
