[Mapbender-commits] r1472 - trunk/mapbender/http/print
    svn_mapbender at osgeo.org
    Mon Jul  9 03:07:26 EDT 2007
Author: astrid_emde
Date: 2007-07-09 03:07:26 -0400 (Mon, 09 Jul 2007)
New Revision: 1472
   trunk/mapbender/http/print/printPDF.conf
only A4-A2 , error fixed
Modified: trunk/mapbender/http/print/printPDF.conf
--- trunk/mapbender/http/print/printPDF.conf	2007-07-09 07:06:43 UTC (rev 1471)
+++ trunk/mapbender/http/print/printPDF.conf	2007-07-09 07:07:26 UTC (rev 1472)
@@ -383,389 +383,3 @@
-<?php
-include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-# filename for temporary imagefiles
-$filename = TMPDIR."/map_".substr(md5(uniqid(rand())),0,7).".png";
-* DOWNLOAD
-$download = false;
-$downloadFile = TMPDIR."/map_".substr(md5(uniqid(rand())),0,7).".pdf";
-$downloadText = "Download: Karte als PDF...";
-*run print as iframe or window
-$type = 'iframe';
-* Legend
-$legend=true;
-$label_legend = 'print legend';
-$legendFilename = TMPDIR."/legend_".substr(md5(uniqid(rand())),0,7).".png";
-$legendFilenameUserPolygon = TMPDIR."/legend_".substr(md5(uniqid(rand())),0,7).".png";
-$legendText = "Legende";
-$legendFooter = "powered by Mapbender";
-$legendImage = "./img/mapbender_logo.png";
-$legendImage_width = 90;
-$legendImage_height = 13;
-# log requests, class 'class_log.php' required
-$log = true;
-# delete images:
-$unlink = false;
-# labeling
-if(CHARSET=="UTF-8"){
-	$new_comment1 = utf8_decode($_REQUEST["comment1"]);
-	$new_comment2 = utf8_decode($_REQUEST["comment2"]);
-else{
-	$new_comment1 = $_REQUEST["comment1"];
-	$new_comment2 = $_REQUEST["comment2"];
-$text1 = "Druckansicht";
-$text2 = "- Mapbender -";
-$text3 = "";
-$text4 = "Maßstab 1 : " . $_REQUEST["map_scale"];
-$text5 = "Datum: " . date("d.m.Y",strtotime("now"));;
-$text6 = "Notizen:";
-$text7 = "";
-$text8 = $new_comment1;
-$text9 = $new_comment2;
-$text10 = "";
-$text11 = "Der Auszug ist maschinell erzeugt, er ist ohne Unterschrift gültig.";
-$text12 = "Dieser Auszug ist gesetzlich geschützt (§ 3 Abs. 1 VermKatG NW). Vervielfältigungen, Umarbeitungen, Veröffentlichungen oder die Weitergabe an Dritte nur mit Zustimmung des";
-$text13 = "Herausgebers, ausgenommen Vervielfältigungen und Umarbeitungen zur innerdienstlichen Verwendung bei Behörden oder zum eigenen Gebrauch.";
-$text14 = "Dieser Auszug ist gesetzlich geschützt (§ 3 Abs. 1 VermKatG NW). Vervielfältigungen,";
-$text15 = "Umarbeitungen, Veröffentlichungen oder die Weitergabe an Dritte nur mit Zustimmung";
-$text16 = "des Herausgebers, ausgenommen Vervielfältigungen und Umarbeitungen zur inner-";
-$text17 = "dienstlichen Verwendung bei Behörden oder zum eigenen Gebrauch.";
-* Labeling for buttons, textfields ...
-$label_format = "Format:";
-$label_format_a4 = "A4";
-$label_format_a3 = "A3";
-$label_format_a2 = "A2";
-$label_format_a1 = "A1";
-$label_format_a0 = "A0";
-$label_orientation = "Orientation: ";
-$label_portrait = "portrait";
-$label_landscape = "landscape";
-$label_72dpi = "Quality: 72 dpi";
-$label_288dpi = "Quality: 288 dpi";
-$label_comment = "Comment (max. 30)";
-$comment_length = 30;
-$label_button = 'drucken';
-* default
-* url string matching and replacement
-$matching = false;
-$pattern =  "192.168.2.113";
-$replacement = "192.168.2.5";
-* high quality printing 288dpi
-* highquality mapfiles will be supplemented with "_4"
-* example: germany.map -> germany_4.map
-$highquality = true;
-$highqualitymapfiles = array(
-	"/data/umn/germany/germany_demo.map",
-	"/data/umn/mapbender_user/mapbender_user.map"
-# Dots per cm (72 dpi):
-# 28.346456692913385826771653543307
-$DPC = 28.35;
-# available formats:
-$a4 = true;
-$a3 = true;
-$a2 = true;
-$a1 = true;
-$a0 = true;
-# dimensions of the map:
-# A4 portrait
-$a4p_mapOffset_left = 3.3 * $DPC;
-$a4p_mapOffset_bottom = 3 * $DPC;
-$a4p_map_width = 15.7 * $DPC;
-$a4p_map_height = 22 * $DPC;
-$a4p_page_width = 21 * $DPC;
-$a4p_page_height = 29.7 * $DPC;
-$a4p_header_height = 2.6 * $DPC;
-$a4p_footer_height = 1.12 * $DPC;
-# A4 landscape
-$a4l_mapOffset_left = 2.3 * $DPC;
-$a4l_mapOffset_bottom = 1.8 * $DPC;
-$a4l_map_width = 25.2 * $DPC;
-$a4l_map_height = 16.4 * $DPC;
-$a4l_page_width = 29.7 * $DPC;
-$a4l_page_height = 21 * $DPC;
-$a4l_header_width = 8.5 * $DPC;
-$a4l_header_height = 6 * $DPC;
-# A3 protrait
-$a3p_mapOffset_left = 3.3 * $DPC;
-$a3p_mapOffset_bottom = 3 * $DPC;
-$a3p_map_width = 24.1 * $DPC;
-$a3p_map_height = 36.7 * $DPC;
-$a3p_page_width = 29.7 * $DPC;
-$a3p_page_height = 42 * $DPC;
-$a3p_header_width =  8.5 * $DPC;
-$a3p_header_height = 6 * $DPC;
-# A3 landscape
-$a3l_mapOffset_left = 2.3 * $DPC;
-$a3l_mapOffset_bottom = 1.8 * $DPC;
-$a3l_map_width = 37.4 * $DPC;
-$a3l_map_height = 25.4 * $DPC;
-$a3l_page_width = 42 * $DPC;
-$a3l_page_height = 29.7 * $DPC;
-$a3l_header_width =  8.5 * $DPC;
-$a3l_header_height = 6 * $DPC;
-# a2 protrait
-$a2p_mapOffset_left = 3.2 * $DPC;
-$a2p_mapOffset_bottom = 2.3 * $DPC;
-$a2p_map_width = 37.3 * $DPC;
-$a2p_map_height = 54.8 * $DPC;
-$a2p_page_width = 42 * $DPC;
-$a2p_page_height = 59.4 * $DPC;
-$a2p_header_width =  8.5 * $DPC;
-$a2p_header_height = 6 * $DPC;
-# a2 landscape
-$a2l_mapOffset_left = 3.2 * $DPC;
-$a2l_mapOffset_bottom = 2.3 * $DPC;
-$a2l_map_width = 54.1 * $DPC;
-$a2l_map_height = 37.3 * $DPC;
-$a2l_page_width = 59.4 * $DPC;
-$a2l_page_height = 42 * $DPC;
-$a2l_header_width =  8.5 * $DPC;
-$a2l_header_height = 6 * $DPC;
-# a1 portrait
-$a1p_mapOffset_left = 3.2 * $DPC;
-$a1p_mapOffset_bottom = 2.3 * $DPC;
-$a1p_map_width = 54.5 * $DPC;
-$a1p_map_height = 79.5 * $DPC;
-$a1p_page_width = 59.4 * $DPC;
-$a1p_page_height = 84 * $DPC;
-$a1p_header_width =  8.5 * $DPC;
-$a1p_header_height = 6 * $DPC;
-# a1 landscape
-$a1l_mapOffset_left = 3.2 * $DPC;
-$a1l_mapOffset_bottom = 2.3 * $DPC;
-$a1l_map_width = 79.5 * $DPC;
-$a1l_map_height = 55.5 * $DPC;
-$a1l_page_width = 84 * $DPC;
-$a1l_page_height = 59.4 * $DPC;
-$a1l_header_width =  8.5 * $DPC;
-$a1l_header_height = 6 * $DPC;
-# a0 portrait
-$a0p_mapOffset_left = 3.2 * $DPC;
-$a0p_mapOffset_bottom = 2.3 * $DPC;
-$a0p_map_width = 79 * $DPC;
-$a0p_map_height = 115 * $DPC;
-$a0p_page_width = 84 * $DPC;
-$a0p_page_height = 118.8 * $DPC;
-$a0p_header_width =  8.5 * $DPC;
-$a0p_header_height = 6 * $DPC;
-# a0 landscape
-$a0l_mapOffset_left = 3.2 * $DPC;
-$a0l_mapOffset_bottom = 2.3 * $DPC;
-$a0l_map_width = 113 * $DPC;
-$a0l_map_height = 80.5 * $DPC;
-$a0l_page_width = 118.8 * $DPC;
-$a0l_page_height = 84 * $DPC;
-$a0l_header_width =  8.5 * $DPC;
-$a0l_header_height = 6 * $DPC;
-* Overview
-$overview = true;
-$a4p_overviewOffset_left = $a4p_mapOffset_left;
-$a4p_overviewOffset_bottom = $a4p_mapOffset_bottom;
-$a4l_overviewOffset_left = $a4l_mapOffset_left;
-$a4l_overviewOffset_bottom = $a4l_mapOffset_bottom;
-$a3p_overviewOffset_left = $a3p_mapOffset_left;
-$a3p_overviewOffset_bottom = $a3p_mapOffset_bottom;
-$a3l_overviewOffset_left = $a3l_mapOffset_left;
-$a3l_overviewOffset_bottom = $a3l_mapOffset_bottom;
-$a2p_overviewOffset_left = $a2p_mapOffset_left;
-$a2p_overviewOffset_bottom = $a2p_mapOffset_bottom;
-$a2l_overviewOffset_left = $a2l_mapOffset_left;
-$a2l_overviewOffset_bottom = $a2l_mapOffset_bottom;
-$a1p_overviewOffset_left = $a1p_mapOffset_left;
-$a1p_overviewOffset_bottom = $a1p_mapOffset_bottom;
-$a1l_overviewOffset_left = $a1l_mapOffset_left;
-$a1l_overviewOffset_bottom = $a1l_mapOffset_bottom;
-$a0p_overviewOffset_left = $a0p_mapOffset_left;
-$a0p_overviewOffset_bottom = $a0p_mapOffset_bottom;
-$a0l_overviewOffset_left = $a0l_mapOffset_left;
-$a0l_overviewOffset_bottom = $a0l_mapOffset_bottom;
-* Northarrow
-$northarrow = true;
-$northarrowImage = "./img/northarrow.png";
-$a4p_northarrow_left = $a4p_mapOffset_left + 160;
-$a4p_northarrow_bottom = $a4p_mapOffset_bottom +2 ;
-$a4l_northarrow_left = $a4l_mapOffset_left + 5;
-$a4l_northarrow_bottom = $a4l_mapOffset_bottom + $a4l_map_height - 40;
-$a3p_northarrow_left = $a3p_mapOffset_left +5;
-$a3p_northarrow_bottom = $a3p_mapOffset_bottom + $a3p_map_height - 80;
-$a3l_northarrow_left = $a3l_mapOffset_left + 5;
-$a3l_northarrow_bottom = $a3l_mapOffset_bottom + $a3l_map_height - 40;
-$a2p_northarrow_left = $a2p_mapOffset_left +5;
-$a2p_northarrow_bottom = $a2p_mapOffset_bottom + $a2p_map_height - 80;
-$a2l_northarrow_left = $a2l_mapOffset_left + 5;
-$a2l_northarrow_bottom = $a2l_mapOffset_bottom + $a2l_map_height - 80;
-$a1p_northarrow_left = $a1p_mapOffset_left +5;
-$a1p_northarrow_bottom = $a1p_mapOffset_bottom + $a1p_map_height - 80;
-$a1l_northarrow_left = $a1l_mapOffset_left + 5;
-$a1l_northarrow_bottom = $a1l_mapOffset_bottom + $a1l_map_height - 160;
-$a0p_northarrow_left = $a0p_mapOffset_left +5;
-$a0p_northarrow_bottom = $a0p_mapOffset_bottom + $a0p_map_height - 80;
-$a0l_northarrow_left = $a0l_mapOffset_left + 5;
-$a0l_northarrow_bottom = $a0l_mapOffset_bottom + $a0l_map_height - 160;
-$northarrowImage_width = 15;
-$northarrowImage_height = 35;
-* special image for the map-page
-$special = true;
-$specialImage = "../img/mapbender_oo.png";
-$a4p_special_left = $a4p_mapOffset_left + $a4p_map_width - 50 ;
-$a4p_special_bottom = $a4p_mapOffset_bottom + $a4p_map_height + 80;
-$a4l_special_left = $a4l_mapOffset_left + $a4l_map_width - $a4l_header_width + 0.8 * $DPC + 10 ;
-$a4l_special_bottom = $a4l_mapOffset_bottom + 54;
-$a3p_special_left = $a3p_mapOffset_left + $a3p_map_width - $a3p_header_width ;
-$a3p_special_bottom = $a3p_mapOffset_bottom + 30;
-$a3l_special_left = $a3l_mapOffset_left + $a3l_map_width - $a3l_header_width + 0.8 * $DPC + 10;
-$a3l_special_bottom = $a3l_mapOffset_bottom + 60;
-$a2p_special_left = $a2p_mapOffset_left + $a2p_map_width - $a2p_header_width + 0.1 *$DPC ;
-$a2p_special_bottom = $a2p_mapOffset_bottom + 110;
-$a2l_special_left = $a2l_mapOffset_left + $a2l_map_width - $a2l_header_width + 0.2 * $DPC ;
-$a2l_special_bottom = $a2l_mapOffset_bottom + 110;
-$a1p_special_left = $a1p_mapOffset_left + $a1p_map_width - $a1p_header_width + 0.1 *$DPC ;
-$a1p_special_bottom = $a1p_mapOffset_bottom + 110;
-$a1l_special_left = $a1l_mapOffset_left + $a1l_map_width - $a1l_header_width + 0.2 * $DPC ;
-$a1l_special_bottom = $a1l_mapOffset_bottom + 110;
-$a0p_special_left = $a0p_mapOffset_left + $a0p_map_width - $a0p_header_width + 0.1 *$DPC ;
-$a0p_special_bottom = $a0p_mapOffset_bottom + 110;
-$a0l_special_left = $a0l_mapOffset_left + $a0l_map_width - $a0l_header_width + 0.2 * $DPC ;
-$a0l_special_bottom = $a0l_mapOffset_bottom + 110;
-$specialImage_width = 65;
-$specialImage_height = 15;
-* dynamic scalebar
-$scalebar = true;
-$units = "Meter";
-$a4p_scalebar_left = $a4p_mapOffset_left + 2 * $a4p_map_width/3;
-$a4p_scalebar_bottom = $a4p_mapOffset_bottom  + 0.5 * $DPC;
-$a4l_scalebar_left = $a4l_mapOffset_left + $a4l_map_width/4 ;
-$a4l_scalebar_bottom = $a4l_mapOffset_bottom +  + 0.5 * $DPC;
-$a3p_scalebar_left = $a3p_mapOffset_left  + $a3p_map_width/4 ;
-$a3p_scalebar_bottom = $a3p_mapOffset_bottom + 0.5 * $DPC;
-$a3l_scalebar_left = $a3l_mapOffset_left  + $a3l_map_width/4 ;
-$a3l_scalebar_bottom = $a3l_mapOffset_bottom +  + 0.5 * $DPC;
-$a2p_scalebar_left = $a2p_mapOffset_left  + $a2p_map_width/4 ;
-$a2p_scalebar_bottom = $a2p_mapOffset_bottom + 0.5 * $DPC;
-$a2l_scalebar_left = $a2l_mapOffset_left  + $a2l_map_width/4 ;
-$a2l_scalebar_bottom = $a2l_mapOffset_bottom +  + 0.5 * $DPC;
-$a1p_scalebar_left = $a1p_mapOffset_left  + $a1p_map_width/4 ;
-$a1p_scalebar_bottom = $a1p_mapOffset_bottom + 0.5 * $DPC;
-$a1l_scalebar_left = $a1l_mapOffset_left  + $a1l_map_width/4 ;
-$a1l_scalebar_bottom = $a1l_mapOffset_bottom +  + 0.5 * $DPC;
-$a0p_scalebar_left = $a0p_mapOffset_left  + $a0p_map_width/4 ;
-$a0p_scalebar_bottom = $a0p_mapOffset_bottom + 0.5 * $DPC;
-$a0l_scalebar_left = $a0l_mapOffset_left  + $a0l_map_width/4 ;
-$a0l_scalebar_bottom = $a0l_mapOffset_bottom +  + 0.5 * $DPC;
-$scalebar_width = 3 * $DPC;
-$scalebar_height = 0.18 * $DPC;
\ No newline at end of file
More information about the Mapbender_commits
