[Mapbender-commits] r1544 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Fri Jul 27 04:22:36 EDT 2007
Author: astrid_emde
Date: 2007-07-27 04:22:36 -0400 (Fri, 27 Jul 2007)
New Revision: 1544
trunk/mapbender/http/javascripts/mod_navFrame.php
new element var mod_navFrame_ext to define the navFrame width
Modified: trunk/mapbender/http/javascripts/mod_navFrame.php
--- trunk/mapbender/http/javascripts/mod_navFrame.php 2007-07-27 07:26:46 UTC (rev 1543)
+++ trunk/mapbender/http/javascripts/mod_navFrame.php 2007-07-27 08:22:36 UTC (rev 1544)
@@ -20,6 +20,7 @@
$gui_id = $_REQUEST["gui_id"];
require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+include '../include/dyn_js.php';
$con = db_connect($DBSERVER,$OWNER,$PW);
db_select_db(DB,$con);
$sql = "SELECT e_target,e_src FROM gui_element WHERE e_id = 'navFrame' AND fkey_gui_id = $1";
@@ -37,7 +38,14 @@
echo "var mod_navFrame_src = '".db_result($res,0,"e_src")."';";
-var mod_navFrame_ext = 10;
+try{
+ if (mod_navFrame_ext){}
+catch(e){
+ mod_navFrame_ext = 10;
mb_registerSubFunctions("mod_navFrame_arrange()");
function mod_navFrame_arrange(){
@@ -47,6 +55,7 @@
var myTop = parseInt(el.top);
var myWidth = parseInt(el.width);
var myHeight = parseInt(el.height);
//left,top,width,height
mod_navFrame_pos("mbN",(myLeft),(myTop - ext),(myWidth),(ext));
document.getElementById("arrow_n").style.left = myWidth/2 - document.getElementById("arrow_n").width/2;
More information about the Mapbender_commits
