[Mapbender-commits] r1159 - trunk/mapbender
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Mar 1 12:23:33 EST 2007
Author: verenadiewald
Date: 2007-03-01 12:23:30 -0500 (Thu, 01 Mar 2007)
New Revision: 1159
   trunk/mapbender/Install.txt
test
Modified: trunk/mapbender/Install.txt
--- trunk/mapbender/Install.txt	2007-03-01 17:13:15 UTC (rev 1158)
+++ trunk/mapbender/Install.txt	2007-03-01 17:23:30 UTC (rev 1159)
@@ -2,6 +2,7 @@
 http://www.mapbender.org/index.php/Installation
 Every Mapbender User is invited to let the Mapbender Wiki grow.
 If you want an account to edit any of these Wiki pages please write an email to info at mapbender.org and request for an ID and password.
 You need a valid email address to be able to edit this Wiki.
@@ -61,7 +62,7 @@
 2. pgsql_data.sql	(loads data)
 3. pgsql_serial_set_sequences_7x.sql or pgsql_serial_set_sequences.sql
 (depending on wich postgresql version you use, sets the values for the sequences)
-- Zählerstand der Sequenz für Serial-Felder (Autowerte)
+- Z�hlerstand der Sequenz f�r Serial-Felder (Autowerte)
 -- How to load the sqls in PostgreSQL:
More information about the Mapbender_commits mailing list
