[Mapbender-commits] r1176 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Fri Mar 2 13:06:26 EST 2007
Author: christoph
Date: 2007-03-02 13:06:26 -0500 (Fri, 02 Mar 2007)
New Revision: 1176
trunk/mapbender/http/javascripts/map.php
some refactoring
Modified: trunk/mapbender/http/javascripts/map.php
--- trunk/mapbender/http/javascripts/map.php 2007-03-02 18:04:46 UTC (rev 1175)
+++ trunk/mapbender/http/javascripts/map.php 2007-03-02 18:06:26 UTC (rev 1176)
@@ -78,7 +78,7 @@
mb_ajaxWrap_post('../php/mb_js_exception.php', {text:message});
catch(e) {
- alert(e);
+ alert(message);
@@ -1270,7 +1270,7 @@
function DivTag (aTagName, aFrameName, aStyle) {
this.exists = function () {
- return (rootNode.getElementById(tagName))?true:false;
+ return (rootNode.getElementById(tagName)) ? true : false;
var determineRootNode = function () {
@@ -1282,7 +1282,7 @@
return node;
- var reformatJavaStyle = function(aString) {
+ var toCamelCase = function(aString) {
var newString = "";
for (var i = 0; i < aString.length; i++) {
if (aString.substr(i,1) != "-") {
@@ -1303,7 +1303,7 @@
for (var attr in tagStyle) {
if (typeof(tagStyle[attr] != "function") && typeof(tagStyle[attr] != "object")) {
- var evalString = "node.style."+reformatJavaStyle(attr)+" = \"" + tagStyle[attr] + "\";";
+ var evalString = "node.style."+toCamelCase(attr)+" = \"" + tagStyle[attr] + "\";";
eval(evalString);
More information about the Mapbender_commits
