[Mapbender-commits] r1193 - trunk/mapbender/http/extensions
svn_mapbender at osgeo.org
Tue Mar 6 03:57:15 EST 2007
Author: christoph
Date: 2007-03-06 03:57:15 -0500 (Tue, 06 Mar 2007)
New Revision: 1193
Added:
trunk/mapbender/http/extensions/JSON.php
trunk/mapbender/http/extensions/json.js
json for js/php
Added: trunk/mapbender/http/extensions/JSON.php
--- trunk/mapbender/http/extensions/JSON.php (rev 0)
+++ trunk/mapbender/http/extensions/JSON.php 2007-03-06 08:57:15 UTC (rev 1193)
@@ -0,0 +1,806 @@
+<?php
+/* vim: set expandtab tabstop=4 shiftwidth=4 softtabstop=4: */
+ * Converts to and from JSON format.
+ * JSON (JavaScript Object Notation) is a lightweight data-interchange
+ * format. It is easy for humans to read and write. It is easy for machines
+ * to parse and generate. It is based on a subset of the JavaScript
+ * Programming Language, Standard ECMA-262 3rd Edition - December 1999.
+ * This feature can also be found in Python. JSON is a text format that is
+ * completely language independent but uses conventions that are familiar
+ * to programmers of the C-family of languages, including C, C++, C#, Java,
+ * JavaScript, Perl, TCL, and many others. These properties make JSON an
+ * ideal data-interchange language.
+ * This package provides a simple encoder and decoder for JSON notation. It
+ * is intended for use with client-side Javascript applications that make
+ * use of HTTPRequest to perform server communication functions - data can
+ * be encoded into JSON notation for use in a client-side javascript, or
+ * decoded from incoming Javascript requests. JSON format is native to
+ * Javascript, and can be directly eval()'ed with no further parsing
+ * overhead
+ * All strings should be in ASCII or UTF-8 format!
+ * LICENSE: Redistribution and use in source and binary forms, with or
+ * without modification, are permitted provided that the following
+ * conditions are met: Redistributions of source code must retain the
+ * above copyright notice, this list of conditions and the following
+ * disclaimer. Redistributions in binary form must reproduce the above
+ * copyright notice, this list of conditions and the following disclaimer
+ * in the documentation and/or other materials provided with the
+ * distribution.
+ * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN
+ * NO EVENT SHALL CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
+ * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR
+ * TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE
+ * USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH
+ * DAMAGE.
+ * @category
+ * @package Services_JSON
+ * @author Michal Migurski <mike-json at teczno.com>
+ * @author Matt Knapp <mdknapp[at]gmail[dot]com>
+ * @author Brett Stimmerman <brettstimmerman[at]gmail[dot]com>
+ * @copyright 2005 Michal Migurski
+ * @version CVS: $Id: JSON.php,v 1.31 2006/06/28 05:54:17 migurski Exp $
+ * @license http://www.opensource.org/licenses/bsd-license.php
+ * @link http://pear.php.net/pepr/pepr-proposal-show.php?id=198
+ * Marker constant for Services_JSON::decode(), used to flag stack state
+define('SERVICES_JSON_SLICE', 1);
+define('SERVICES_JSON_IN_STR', 2);
+define('SERVICES_JSON_IN_ARR', 3);
+define('SERVICES_JSON_IN_OBJ', 4);
+define('SERVICES_JSON_IN_CMT', 5);
+ * Behavior switch for Services_JSON::decode()
+define('SERVICES_JSON_LOOSE_TYPE', 16);
+define('SERVICES_JSON_SUPPRESS_ERRORS', 32);
+ * Brief example of use:
+ * <code>
+ * // create a new instance of Services_JSON
+ * $json = new Services_JSON();
+ * // convert a complexe value to JSON notation, and send it to the browser
+ * $value = array('foo', 'bar', array(1, 2, 'baz'), array(3, array(4)));
+ * $output = $json->encode($value);
+ * print($output);
+ * // prints: ["foo","bar",[1,2,"baz"],[3,[4]]]
+ * // accept incoming POST data, assumed to be in JSON notation
+ * $input = file_get_contents('php://input', 1000000);
+ * $value = $json->decode($input);
+ * </code>
+class Services_JSON
+ * constructs a new JSON instance
+ * @param int $use object behavior flags; combine with boolean-OR
+ * possible values:
+ * - SERVICES_JSON_LOOSE_TYPE: loose typing.
+ * "{...}" syntax creates associative arrays
+ * instead of objects in decode().
+ * - SERVICES_JSON_SUPPRESS_ERRORS: error suppression.
+ * Values which can't be encoded (e.g. resources)
+ * appear as NULL instead of throwing errors.
+ * By default, a deeply-nested resource will
+ * bubble up with an error, so all return values
+ * from encode() should be checked with isError()
+ function Services_JSON($use = 0)
+ $this->use = $use;
+ * convert a string from one UTF-16 char to one UTF-8 char
+ * Normally should be handled by mb_convert_encoding, but
+ * provides a slower PHP-only method for installations
+ * that lack the multibye string extension.
+ * @param string $utf16 UTF-16 character
+ * @return string UTF-8 character
+ * @access private
+ function utf162utf8($utf16)
+ // oh please oh please oh please oh please oh please
+ if(function_exists('mb_convert_encoding')) {
+ return mb_convert_encoding($utf16, 'UTF-8', 'UTF-16');
+ $bytes = (ord($utf16{0}) << 8) | ord($utf16{1});
+ switch(true) {
+ case ((0x7F & $bytes) == $bytes):
+ // this case should never be reached, because we are in ASCII range
+ // see: http://www.cl.cam.ac.uk/~mgk25/unicode.html#utf-8
+ return chr(0x7F & $bytes);
+ case (0x07FF & $bytes) == $bytes:
+ // return a 2-byte UTF-8 character
+ return chr(0xC0 | (($bytes >> 6) & 0x1F))
+ . chr(0x80 | ($bytes & 0x3F));
+ case (0xFFFF & $bytes) == $bytes:
+ // return a 3-byte UTF-8 character
+ return chr(0xE0 | (($bytes >> 12) & 0x0F))
+ . chr(0x80 | (($bytes >> 6) & 0x3F))
+ // ignoring UTF-32 for now, sorry
+ return '';
+ * convert a string from one UTF-8 char to one UTF-16 char
+ * @param string $utf8 UTF-8 character
+ * @return string UTF-16 character
+ * @access private
+ function utf82utf16($utf8)
+ return mb_convert_encoding($utf8, 'UTF-16', 'UTF-8');
+ switch(strlen($utf8)) {
+ case 1:
+ return $utf8;
+ case 2:
+ // return a UTF-16 character from a 2-byte UTF-8 char
+ return chr(0x07 & (ord($utf8{0}) >> 2))
+ . chr((0xC0 & (ord($utf8{0}) << 6))
+ | (0x3F & ord($utf8{1})));
+ case 3:
+ // return a UTF-16 character from a 3-byte UTF-8 char
+ return chr((0xF0 & (ord($utf8{0}) << 4))
+ | (0x0F & (ord($utf8{1}) >> 2)))
+ . chr((0xC0 & (ord($utf8{1}) << 6))
+ | (0x7F & ord($utf8{2})));
+ return '';
+ * encodes an arbitrary variable into JSON format
+ * @param mixed $var any number, boolean, string, array, or object to be encoded.
+ * see argument 1 to Services_JSON() above for array-parsing behavior.
+ * if var is a strng, note that encode() always expects it
+ * to be in ASCII or UTF-8 format!
+ * @return mixed JSON string representation of input var or an error if a problem occurs
+ * @access public
+ function encode($var)
+ switch (gettype($var)) {
+ case 'boolean':
+ return $var ? 'true' : 'false';
+ case 'NULL':
+ return 'null';
+ case 'integer':
+ return (int) $var;
+ case 'double':
+ case 'float':
+ return (float) $var;
+ case 'string':
+ // STRINGS ARE EXPECTED TO BE IN ASCII OR UTF-8 FORMAT
+ $ascii = '';
+ $strlen_var = strlen($var);
+ * Iterate over every character in the string,
+ * escaping with a slash or encoding to UTF-8 where necessary
+ for ($c = 0; $c < $strlen_var; ++$c) {
+ $ord_var_c = ord($var{$c});
+ switch (true) {
+ case $ord_var_c == 0x08:
+ $ascii .= '\b';
+ break;
+ case $ord_var_c == 0x09:
+ $ascii .= '\t';
+ break;
+ case $ord_var_c == 0x0A:
+ $ascii .= '\n';
+ break;
+ case $ord_var_c == 0x0C:
+ $ascii .= '\f';
+ break;
+ case $ord_var_c == 0x0D:
+ $ascii .= '\r';
+ break;
+ case $ord_var_c == 0x22:
+ case $ord_var_c == 0x2F:
+ case $ord_var_c == 0x5C:
+ // double quote, slash, slosh
+ $ascii .= '\\'.$var{$c};
+ break;
+ case (($ord_var_c >= 0x20) && ($ord_var_c <= 0x7F)):
+ // characters U-00000000 - U-0000007F (same as ASCII)
+ $ascii .= $var{$c};
+ break;
+ case (($ord_var_c & 0xE0) == 0xC0):
+ // characters U-00000080 - U-000007FF, mask 110XXXXX
+ // see http://www.cl.cam.ac.uk/~mgk25/unicode.html#utf-8
+ $char = pack('C*', $ord_var_c, ord($var{$c + 1}));
+ $c += 1;
+ $utf16 = $this->utf82utf16($char);
+ $ascii .= sprintf('\u%04s', bin2hex($utf16));
+ break;
+ case (($ord_var_c & 0xF0) == 0xE0):
+ // characters U-00000800 - U-0000FFFF, mask 1110XXXX
+ ord($var{$c + 1}),
+ ord($var{$c + 2}));
+ $c += 2;
+ break;
+ case (($ord_var_c & 0xF8) == 0xF0):
+ // characters U-00010000 - U-001FFFFF, mask 11110XXX
+ ord($var{$c + 2}),
+ ord($var{$c + 3}));
+ $c += 3;
+ break;
+ case (($ord_var_c & 0xFC) == 0xF8):
+ // characters U-00200000 - U-03FFFFFF, mask 111110XX
+ ord($var{$c + 3}),
+ ord($var{$c + 4}));
+ $c += 4;
+ break;
+ case (($ord_var_c & 0xFE) == 0xFC):
+ // characters U-04000000 - U-7FFFFFFF, mask 1111110X
+ ord($var{$c + 4}),
+ ord($var{$c + 5}));
+ $c += 5;
+ break;
+ return '"'.$ascii.'"';
+ case 'array':
+ * As per JSON spec if any array key is not an integer
+ * we must treat the the whole array as an object. We
+ * also try to catch a sparsely populated associative
+ * array with numeric keys here because some JS engines
+ * will create an array with empty indexes up to
+ * max_index which can cause memory issues and because
+ * the keys, which may be relevant, will be remapped
+ * otherwise.
+ * As per the ECMA and JSON specification an object may
+ * have any string as a property. Unfortunately due to
+ * a hole in the ECMA specification if the key is a
+ * ECMA reserved word or starts with a digit the
+ * parameter is only accessible using ECMAScript's
+ * bracket notation.
+ // treat as a JSON object
+ if (is_array($var) && count($var) && (array_keys($var) !== range(0, sizeof($var) - 1))) {
+ $properties = array_map(array($this, 'name_value'),
+ array_keys($var),
+ array_values($var));
+ foreach($properties as $property) {
+ if(Services_JSON::isError($property)) {
+ return $property;
+ return '{' . join(',', $properties) . '}';
+ // treat it like a regular array
+ $elements = array_map(array($this, 'encode'), $var);
+ foreach($elements as $element) {
+ if(Services_JSON::isError($element)) {
+ return $element;
+ return '[' . join(',', $elements) . ']';
+ case 'object':
+ $vars = get_object_vars($var);
+ array_keys($vars),
+ array_values($vars));
+ return $property;
+ default:
+ return ($this->use & SERVICES_JSON_SUPPRESS_ERRORS)
+ ? 'null'
+ : new Services_JSON_Error(gettype($var)." can not be encoded as JSON string");
+ * array-walking function for use in generating JSON-formatted name-value pairs
+ * @param string $name name of key to use
+ * @param mixed $value reference to an array element to be encoded
+ * @return string JSON-formatted name-value pair, like '"name":value'
+ * @access private
+ function name_value($name, $value)
+ $encoded_value = $this->encode($value);
+ if(Services_JSON::isError($encoded_value)) {
+ return $encoded_value;
+ return $this->encode(strval($name)) . ':' . $encoded_value;
+ * reduce a string by removing leading and trailing comments and whitespace
+ * @param $str string string value to strip of comments and whitespace
+ * @return string string value stripped of comments and whitespace
+ * @access private
+ function reduce_string($str)
+ $str = preg_replace(array(
+ // eliminate single line comments in '// ...' form
+ '#^\s*//(.+)$#m',
+ // eliminate multi-line comments in '/* ... */' form, at start of string
+ '#^\s*/\*(.+)\*/#Us',
+ // eliminate multi-line comments in '/* ... */' form, at end of string
+ '#/\*(.+)\*/\s*$#Us'
+ ), '', $str);
+ // eliminate extraneous space
+ return trim($str);
+ * decodes a JSON string into appropriate variable
+ * @param string $str JSON-formatted string
+ * @return mixed number, boolean, string, array, or object
+ * corresponding to given JSON input string.
+ * See argument 1 to Services_JSON() above for object-output behavior.
+ * Note that decode() always returns strings
+ * in ASCII or UTF-8 format!
+ * @access public
+ function decode($str)
+ $str = $this->reduce_string($str);
+ switch (strtolower($str)) {
+ case 'true':
+ return true;
+ case 'false':
+ return false;
+ case 'null':
+ return null;
+ default:
+ $m = array();
+ if (is_numeric($str)) {
+ // Lookie-loo, it's a number
+ // This would work on its own, but I'm trying to be
+ // good about returning integers where appropriate:
+ // return (float)$str;
+ // Return float or int, as appropriate
+ return ((float)$str == (integer)$str)
+ ? (integer)$str
+ : (float)$str;
+ } elseif (preg_match('/^("|\').*(\1)$/s', $str, $m) && $m[1] == $m[2]) {
+ // STRINGS RETURNED IN UTF-8 FORMAT
+ $delim = substr($str, 0, 1);
+ $chrs = substr($str, 1, -1);
+ $utf8 = '';
+ $strlen_chrs = strlen($chrs);
+ for ($c = 0; $c < $strlen_chrs; ++$c) {
+ $substr_chrs_c_2 = substr($chrs, $c, 2);
+ $ord_chrs_c = ord($chrs{$c});
+ switch (true) {
+ case $substr_chrs_c_2 == '\b':
+ $utf8 .= chr(0x08);
+ ++$c;
+ break;
+ case $substr_chrs_c_2 == '\t':
+ $utf8 .= chr(0x09);
+ ++$c;
+ break;
+ case $substr_chrs_c_2 == '\n':
+ $utf8 .= chr(0x0A);
+ ++$c;
+ break;
+ case $substr_chrs_c_2 == '\f':
+ $utf8 .= chr(0x0C);
+ ++$c;
+ break;
+ case $substr_chrs_c_2 == '\r':
+ $utf8 .= chr(0x0D);
+ ++$c;
+ break;
+ case $substr_chrs_c_2 == '\\"':
+ case $substr_chrs_c_2 == '\\\'':
+ case $substr_chrs_c_2 == '\\\\':
+ case $substr_chrs_c_2 == '\\/':
+ if (($delim == '"' && $substr_chrs_c_2 != '\\\'') ||
+ ($delim == "'" && $substr_chrs_c_2 != '\\"')) {
+ $utf8 .= $chrs{++$c};
+ break;
+ case preg_match('/\\\u[0-9A-F]{4}/i', substr($chrs, $c, 6)):
+ // single, escaped unicode character
+ $utf16 = chr(hexdec(substr($chrs, ($c + 2), 2)))
+ . chr(hexdec(substr($chrs, ($c + 4), 2)));
+ $utf8 .= $this->utf162utf8($utf16);
+ $c += 5;
+ break;
+ case ($ord_chrs_c >= 0x20) && ($ord_chrs_c <= 0x7F):
+ $utf8 .= $chrs{$c};
+ break;
+ case ($ord_chrs_c & 0xE0) == 0xC0:
+ //see http://www.cl.cam.ac.uk/~mgk25/unicode.html#utf-8
+ $utf8 .= substr($chrs, $c, 2);
+ ++$c;
+ break;
+ case ($ord_chrs_c & 0xF0) == 0xE0:
+ $utf8 .= substr($chrs, $c, 3);
+ $c += 2;
+ break;
+ case ($ord_chrs_c & 0xF8) == 0xF0:
+ $utf8 .= substr($chrs, $c, 4);
+ $c += 3;
+ break;
+ case ($ord_chrs_c & 0xFC) == 0xF8:
+ $utf8 .= substr($chrs, $c, 5);
+ $c += 4;
+ break;
+ case ($ord_chrs_c & 0xFE) == 0xFC:
+ $utf8 .= substr($chrs, $c, 6);
+ $c += 5;
+ break;
+ return $utf8;
+ } elseif (preg_match('/^\[.*\]$/s', $str) || preg_match('/^\{.*\}$/s', $str)) {
+ // array, or object notation
+ if ($str{0} == '[') {
+ $stk = array(SERVICES_JSON_IN_ARR);
+ $arr = array();
+ } else {
+ if ($this->use & SERVICES_JSON_LOOSE_TYPE) {
+ $stk = array(SERVICES_JSON_IN_OBJ);
+ $obj = array();
+ } else {
+ $obj = new stdClass();
+ array_push($stk, array('what' => SERVICES_JSON_SLICE,
+ 'where' => 0,
+ 'delim' => false));
+ $chrs = $this->reduce_string($chrs);
+ if ($chrs == '') {
+ if (reset($stk) == SERVICES_JSON_IN_ARR) {
+ return $arr;
+ } else {
+ return $obj;
+ //print("\nparsing {$chrs}\n");
+ for ($c = 0; $c <= $strlen_chrs; ++$c) {
+ $top = end($stk);
+ if (($c == $strlen_chrs) || (($chrs{$c} == ',') && ($top['what'] == SERVICES_JSON_SLICE))) {
+ // found a comma that is not inside a string, array, etc.,
+ // OR we've reached the end of the character list
+ $slice = substr($chrs, $top['where'], ($c - $top['where']));
+ array_push($stk, array('what' => SERVICES_JSON_SLICE, 'where' => ($c + 1), 'delim' => false));
+ //print("Found split at {$c}: ".substr($chrs, $top['where'], (1 + $c - $top['where']))."\n");
+ // we are in an array, so just push an element onto the stack
+ array_push($arr, $this->decode($slice));
+ } elseif (reset($stk) == SERVICES_JSON_IN_OBJ) {
+ // we are in an object, so figure
+ // out the property name and set an
+ // element in an associative array,
+ // for now
+ $parts = array();
+ if (preg_match('/^\s*(["\'].*[^\\\]["\'])\s*:\s*(\S.*),?$/Uis', $slice, $parts)) {
+ // "name":value pair
+ $key = $this->decode($parts[1]);
+ $val = $this->decode($parts[2]);
+ $obj[$key] = $val;
+ } else {
+ $obj->$key = $val;
+ } elseif (preg_match('/^\s*(\w+)\s*:\s*(\S.*),?$/Uis', $slice, $parts)) {
+ // name:value pair, where name is unquoted
+ $key = $parts[1];
+ } else {
+ } elseif ((($chrs{$c} == '"') || ($chrs{$c} == "'")) && ($top['what'] != SERVICES_JSON_IN_STR)) {
+ // found a quote, and we are not inside a string
+ array_push($stk, array('what' => SERVICES_JSON_IN_STR, 'where' => $c, 'delim' => $chrs{$c}));
+ //print("Found start of string at {$c}\n");
+ } elseif (($chrs{$c} == $top['delim']) &&
+ ($top['what'] == SERVICES_JSON_IN_STR) &&
+ ((strlen(substr($chrs, 0, $c)) - strlen(rtrim(substr($chrs, 0, $c), '\\'))) % 2 != 1)) {
+ // found a quote, we're in a string, and it's not escaped
+ // we know that it's not escaped becase there is _not_ an
+ // odd number of backslashes at the end of the string so far
+ array_pop($stk);
+ //print("Found end of string at {$c}: ".substr($chrs, $top['where'], (1 + 1 + $c - $top['where']))."\n");
+ } elseif (($chrs{$c} == '[') &&
+ in_array($top['what'], array(SERVICES_JSON_SLICE, SERVICES_JSON_IN_ARR, SERVICES_JSON_IN_OBJ))) {
+ // found a left-bracket, and we are in an array, object, or slice
+ array_push($stk, array('what' => SERVICES_JSON_IN_ARR, 'where' => $c, 'delim' => false));
+ //print("Found start of array at {$c}\n");
+ } elseif (($chrs{$c} == ']') && ($top['what'] == SERVICES_JSON_IN_ARR)) {
+ // found a right-bracket, and we're in an array
+ array_pop($stk);
+ //print("Found end of array at {$c}: ".substr($chrs, $top['where'], (1 + $c - $top['where']))."\n");
+ } elseif (($chrs{$c} == '{') &&
+ // found a left-brace, and we are in an array, object, or slice
+ array_push($stk, array('what' => SERVICES_JSON_IN_OBJ, 'where' => $c, 'delim' => false));
+ //print("Found start of object at {$c}\n");
+ } elseif (($chrs{$c} == '}') && ($top['what'] == SERVICES_JSON_IN_OBJ)) {
+ // found a right-brace, and we're in an object
+ array_pop($stk);
+ //print("Found end of object at {$c}: ".substr($chrs, $top['where'], (1 + $c - $top['where']))."\n");
+ } elseif (($substr_chrs_c_2 == '/*') &&
+ // found a comment start, and we are in an array, object, or slice
+ array_push($stk, array('what' => SERVICES_JSON_IN_CMT, 'where' => $c, 'delim' => false));
+ $c++;
+ //print("Found start of comment at {$c}\n");
+ } elseif (($substr_chrs_c_2 == '*/') && ($top['what'] == SERVICES_JSON_IN_CMT)) {
+ // found a comment end, and we're in one now
+ array_pop($stk);
+ $c++;
+ for ($i = $top['where']; $i <= $c; ++$i)
+ $chrs = substr_replace($chrs, ' ', $i, 1);
+ //print("Found end of comment at {$c}: ".substr($chrs, $top['where'], (1 + $c - $top['where']))."\n");
+ return $arr;
+ return $obj;
+ * @todo Ultimately, this should just call PEAR::isError()
+ function isError($data, $code = null)
+ if (class_exists('pear')) {
+ return PEAR::isError($data, $code);
+ } elseif (is_object($data) && (get_class($data) == 'services_json_error' ||
+ is_subclass_of($data, 'services_json_error'))) {
+ return true;
+ return false;
+if (class_exists('PEAR_Error')) {
+ class Services_JSON_Error extends PEAR_Error
+ function Services_JSON_Error($message = 'unknown error', $code = null,
+ $mode = null, $options = null, $userinfo = null)
+ parent::PEAR_Error($message, $code, $mode, $options, $userinfo);
+} else {
+ * @todo Ultimately, this class shall be descended from PEAR_Error
Added: trunk/mapbender/http/extensions/json.js
--- trunk/mapbender/http/extensions/json.js (rev 0)
+++ trunk/mapbender/http/extensions/json.js 2007-03-06 08:57:15 UTC (rev 1193)
@@ -0,0 +1,193 @@
+ json.js
+ 2007-01-10
+ This file adds these methods to JavaScript:
+ array.toJSONString()
+ boolean.toJSONString()
+ date.toJSONString()
+ number.toJSONString()
+ object.toJSONString()
+ string.toJSONString()
+ These methods produce a JSON text from a JavaScript value.
+ It must not contain any cyclical references. Illegal values
+ will be excluded.
+ The default conversion for dates is to an ISO string. You can
+ add a toJSONString method to any date object to get a different
+ representation.
+ string.parseJSON(filter)
+ This method parses a JSON text to produce an object or
+ array. It can throw a SyntaxError exception.
+ The optional filter parameter is a function which can filter and
+ transform the results. It receives each of the keys and values, and
+ its return value is used instead of the original value. If it
+ returns what it received, then structure is not modified. If it
+ returns undefined then the member is deleted.
+ Example:
+ // Parse the text. If a key contains the string 'date' then
+ // convert the value to a date.
+ myData = text.parseJSON(function (key, value) {
+ return key.indexOf('date') >= 0 ? new Date(value) : value;
+ It is expected that these methods will formally become part of the
+ JavaScript Programming Language in the Fourth Edition of the
+ ECMAScript standard in 2007.
+if (!Object.prototype.toJSONString) {
+ Array.prototype.toJSONString = function () {
+ var a = ['['], b, i, l = this.length, v;
+ function p(s) {
+ if (b) {
+ a.push(',');
+ a.push(s);
+ b = true;
+ for (i = 0; i < l; i += 1) {
+ v = this[i];
+ switch (typeof v) {
+ case 'undefined':
+ case 'function':
+ case 'unknown':
+ break;
+ case 'object':
+ if (v) {
+ if (typeof v.toJSONString === 'function') {
+ p(v.toJSONString());
+ } else {
+ p("null");
+ break;
+ default:
+ a.push(']');
+ return a.join('');
+ Boolean.prototype.toJSONString = function () {
+ return String(this);
+ Date.prototype.toJSONString = function () {
+ function f(n) {
+ return n < 10 ? '0' + n : n;
+ return '"' + this.getFullYear() + '-' +
+ f(this.getMonth() + 1) + '-' +
+ f(this.getDate()) + 'T' +
+ f(this.getHours()) + ':' +
+ f(this.getMinutes()) + ':' +
+ f(this.getSeconds()) + '"';
+ Number.prototype.toJSONString = function () {
+ return isFinite(this) ? String(this) : "null";
+ Object.prototype.toJSONString = function () {
+ var a = ['{'], b, i, v;
+ function p(s) {
+ if (b) {
+ a.push(',');
+ a.push(i.toJSONString(), ':', s);
+ b = true;
+ for (i in this) {
+ if (this.hasOwnProperty(i)) {
+ v = this[i];
+ case 'undefined':
+ case 'function':
+ case 'unknown':
+ break;
+ case 'object':
+ if (v) {
+ } else {
+ p("null");
+ break;
+ default:
+ a.push('}');
+ (function (s) {
+ var m = {
+ '\b': '\\b',
+ '\t': '\\t',
+ '\n': '\\n',
+ '\f': '\\f',
+ '\r': '\\r',
+ s.parseJSON = function (filter) {
+ try {
+ if (/^("(\\.|[^"\\\n\r])*?"|[,:{}\[\]0-9.\-+Eaeflnr-u \n\r\t])+?$/.
+ test(this)) {
+ var j = eval('(' + this + ')');
+ if (typeof filter === 'function') {
+ function walk(k, v) {
+ if (v && typeof v === 'object') {
+ for (var i in v) {
+ if (v.hasOwnProperty(i)) {
+ v[i] = walk(i, v[i]);
+ return filter(k, v);
+ return walk('', j);
+ return j;
+ } catch (e) {
+ throw new SyntaxError("parseJSON");
+ s.toJSONString = function () {
+ if (/["\\\x00-\x1f]/.test(this)) {
+ return '"' + this.replace(/([\x00-\x1f\\"])/g, function(a, b) {
+ var c = m[b];
+ if (c) {
+ return c;
+ c = b.charCodeAt();
+ return '\\u00' +
+ Math.floor(c / 16).toString(16) +
+ (c % 16).toString(16);
+ return '"' + this + '"';
+ })(String.prototype);
\ No newline at end of file
More information about the Mapbender_commits
