[Mapbender-commits] r1221 - trunk/mapbender/resources/db/postgresql/utf8
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Mar 12 08:12:32 EDT 2007
Author: astrid_emde
Date: 2007-03-12 08:12:29 -0400 (Mon, 12 Mar 2007)
New Revision: 1221
   trunk/mapbender/resources/db/postgresql/utf8/pgsql_data.sql
data dump f?\195?\188r mb 2.4.1 utf8
Modified: trunk/mapbender/resources/db/postgresql/utf8/pgsql_data.sql
--- trunk/mapbender/resources/db/postgresql/utf8/pgsql_data.sql	2007-03-12 11:37:06 UTC (rev 1220)
+++ trunk/mapbender/resources/db/postgresql/utf8/pgsql_data.sql	2007-03-12 12:12:29 UTC (rev 1221)
@@ -1,167 +1,40 @@
 -- postgresql data utf8
--- Mapbender (Version: 2.4.1 c1)
--- 2007-01-26
+-- Mapbender (Version: 2.4.1)
+-- 2007-03-12
 UPDATE pg_catalog.pg_class SET reltriggers = 0;
--- Started on 2007-01-26 12:20:29 Westeuropäische Normalzeit
-SET client_encoding = 'UTF8';
-SET check_function_bodies = false;
-SET client_min_messages = warning;
-SET search_path = public, pg_catalog;
--- TOC entry 1814 (class 0 OID 0)
--- Dependencies: 1244
--- Name: gui_treegde_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
-SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('gui_treegde', 'id'), 99, true);
--- TOC entry 1815 (class 0 OID 0)
--- Dependencies: 1276
--- Name: keyword_keyword_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
-SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('keyword', 'keyword_id'), 29, true);
--- TOC entry 1816 (class 0 OID 0)
--- Dependencies: 1248
--- Name: layer_layer_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
-SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('layer', 'layer_id'), 19175, true);
--- TOC entry 1817 (class 0 OID 0)
--- Dependencies: 1252
--- Name: mb_group_mb_group_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
-SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('mb_group', 'mb_group_id'), 20, true);
--- TOC entry 1818 (class 0 OID 0)
--- Dependencies: 1254
--- Name: mb_log_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
-SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('mb_log', 'id'), 1, false);
--- TOC entry 1819 (class 0 OID 0)
--- Dependencies: 1257
--- Name: mb_user_mb_user_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
-SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('mb_user', 'mb_user_id'), 1, true);
--- TOC entry 1820 (class 0 OID 0)
--- Dependencies: 1279
--- Name: md_topic_category_md_topic_category_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
-SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('md_topic_category', 'md_topic_category_id'), 19, true);
--- TOC entry 1821 (class 0 OID 0)
--- Dependencies: 1265
--- Name: wfs_conf_element_wfs_conf_element_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
-SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs_conf_element', 'wfs_conf_element_id'), 29, true);
--- TOC entry 1822 (class 0 OID 0)
--- Dependencies: 1263
--- Name: wfs_conf_wfs_conf_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
-SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs_conf', 'wfs_conf_id'), 4, true);
--- TOC entry 1823 (class 0 OID 0)
--- Dependencies: 1267
--- Name: wfs_element_element_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
-SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs_element', 'element_id'), 175, true);
--- TOC entry 1824 (class 0 OID 0)
--- Dependencies: 1269
--- Name: wfs_featuretype_featuretype_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
-SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs_featuretype', 'featuretype_id'), 23, true);
--- TOC entry 1825 (class 0 OID 0)
--- Dependencies: 1261
--- Name: wfs_wfs_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
-SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs', 'wfs_id'), 2, true);
--- TOC entry 1826 (class 0 OID 0)
--- Dependencies: 1272
--- Name: wms_wms_id_seq; Type: SEQUENCE SET; Schema: public; Owner: admin
-SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wms', 'wms_id'), 909, true);
--- TOC entry 1782 (class 0 OID 47913121)
--- Dependencies: 1238
--- Data for Name: gui; Type: TABLE DATA; Schema: public; Owner: admin
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin1', 'admin1', 'all administration modules', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin2_de', 'admin2_de', 'admin GUI in Deutsch', 1);
 INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin2_en', 'admin2_en', 'admin GUI in english', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('gui', 'gui', 'client element collection', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('gui1', 'gui1', 'client element collection', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_africa', 'wms_africa', 'Container for Africa data', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_australia', 'wms_australia', 'Container for Australia data', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_europe', 'wms_europe', 'container for europe data', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_gdi_de', 'wms_gdi_de', 'WMS Dienste Germany', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_germany', 'wms_germany', 'container for germany data', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_north_america', 'wms_north_america', 'Container for north America data', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_worldwide', 'wms_worldwide', 'Container for world wide data', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('gui2', 'gui2', 'client element collection', 1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('gui_digitize', 'gui_digitize', 'client element collection', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin2_de', 'admin2_de', 'admin GUI in deutscher Sprache', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin_de_services', 'admin_de_services', 'erweiterte admin GUI - WMS, WFS, Metadaten (deutsch)
+', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin_en_services', 'admin_en_services', 'extended admin GUI - WMS, WFS, metadata-handling (english)', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_germany', 'wms_germany', 'Container for german WMS', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_gdi_de', 'wms_gdi_de', 'Container for german WMS from GDI-DE', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('gui1', 'gui1', 'GUI combining most of the Mapbender functionality', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin1', 'admin1', 'admin GUI containing all adminstrative modules (use only as a template)', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('gui_digitize', 'gui_digitize', 'GUI with WFS search and digitizing using WFS-T', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('gui', 'gui', 'GUI with tab, search modules', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_europe', 'wms_europe', 'Container for european WMS', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_worldwide', 'wms_worldwide', 'Container for world wide WMS', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_north_america', 'wms_north_america', 'Container for north America WMS', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_australia', 'wms_australia', 'Container for Australia WMS', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('wms_africa', 'wms_africa', 'Container for Africa WMS', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('gui2', 'gui2', 'GUI with focus on layout', 1);
--- TOC entry 1783 (class 0 OID 47913127)
+-- TOC entry 1805 (class 0 OID 47913127)
 -- Dependencies: 1239
 -- Data for Name: gui_element; Type: TABLE DATA; Schema: public; Owner: admin
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'metadata', 2, 1, 'shows informations about the wms and the requests of the gui', 'img', '../img/button_blink_red/metadata_off.png', 'onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_blink_red/metadata_over.png"'' onmouseout=''this.src="../img/button_blink_red/metadata_off.png"'' title="Show WMS infos"', 710, 60, 24, 24, 1, '', '', '', 'mod_displayObj.js', '', '', '', 'http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredGui_filteredUser', 2, 1, 'Oberfläche mehreren Benutzer zuordnen ', 'a', '', 'href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ', 8, 535, 190, 25, 10, '', 'GUI mehreren Benutzern <br> zuordnen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'imprint', 2, 1, 'Information about the owner of the gui', 'iframe', '../html/tab_imprint.html', 'frameborder = "0" ', 1, 1, 1, 1, 5, 'visibility:hidden;', '', 'iframe', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'keyHandler', 2, 1, 'onkeydownevent (only IE)', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_key.php', '', 'mapframe1', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'loadData', 2, 1, 'IFRAME, um Daten zu laden', 'iframe', '../html/mod_blank.html', 'frameborder = "0" ', 0, 0, 1, 1, 0, 'visibility:visible', '', 'iframe', '', '', '', '', NULL);
@@ -171,8 +44,23 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'legend', 2, 1, 'legend', 'iframe', '../javascripts/mod_legend.php?sessionID&e_id_css=legend', 'frameborder=''0''', 1, 1, 1, 1, 3, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'showLoggedUser', 2, 1, 'displays the logged admin', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, NULL, '', '', 'iframe', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'meetingPoint', 2, 1, 'create a meeting point', 'iframe', '../php/mod_meetingPoint.php?sessionID', 'frameborder = "0" ', 0, 0, NULL, NULL, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredGui_filteredGroup', 2, 1, 'Einzelner Oberfläche mehrere Gruppen zuordnen', 'a', '', 'href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ', 8, 605, 190, 25, 10, '', 'Einzelner GUI mehrere<br> Gruppen zuordnen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'AdminFrame', 2, 1, 'Bereich für Administrationsmodule', 'iframe', '', 'frameborder = "0"', 210, 25, 800, 800, 12, '', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'CreateTreeGDE', 2, 1, 'Ordnerbaum konfigurieren', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 10, 516, 200, 20, 5, '', 'Ordnerbaum konfigurieren', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'EditWMSMetadata', 2, 1, 'edit the metadata of wms', 'a', '', 'href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"', 10, 275, 200, 20, 5, '', 'WMS Metadaten', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'body', 1, 1, 'Navigation', 'body', '', 'onload=''mod_adminNavigation_init()''', NULL, NULL, NULL, NULL, NULL, '', '', '', 'mod_adminNavigation.js', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'deleteWFS', 2, 1, 'WFS löschen', 'a', '', 'href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ', 10, 393, 200, 20, 5, '', 'WFS löschen', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'deleteWMS', 2, 1, '!Vollständig löschen!', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 10, 100, 200, 20, 5, '', 'WMS löschen!', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'delete_filteredGui', 2, 1, 'GUI löschen', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 10, 471, 200, 20, 5, '', 'GUI löschen', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'editElements', 2, 1, 'Oberflächenelemente editieren', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 10, 491, 200, 25, 5, '', 'GUI editieren', 'a', '', '', '', 'AdminFrame', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'treeGDE', 2, 1, 'dircetory structure, checkbox for visible, checkbox for querylayer', 'iframe', '../html/mod_sync_treefolder.php?sessionID&e_id_css=treeGDE', 'frameborder = "0" ', 1, 1, 1, 1, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'Gazetteer_mbUser', 2, 1, 'a gazetteer for rivers of germany', 'iframe', '../php/mod_wfs_gazetteer.php?sessionID&wfs_conf=1&target=mapframe1,overview&resultFrame=wfsresult', 'frameborder = "0"', 10, 600, 300, 150, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1,overview', 'wz-graphics', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'editGUI_WMS', 2, 1, 'WMS GUI Einstellungen', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 10, 218, 200, 20, 5, '', 'WMS Einstellungen ändern', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'exportGUI', 2, 1, 'GUI exportieren, SQL erzeugen', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 10, 536, 200, 25, 10, 'x', 'GUI exportieren (SQL)', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'filteredWms_layer_topic', 2, 1, 'allocate topics to layers of wms of this user', 'a', '', 'href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ', 10, 295, 200, 20, 5, '', 'Kategoriezuordnung', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'headline_Configure_WMS_Access', 3, 1, 'Hintergrund WMS Zuordnung', 'div', '', '', 1, 175, 210, 63, 2, '', 'WMS Zuordnung', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'headline_GUI_Management', 3, 1, 'Oberflächenverwaltung', 'div', '', '', 1, 428, 210, 153, 2, '', 'GUI Verwaltung', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'headline_Metadata', 3, 1, 'Metadateneditor Caption', 'div', '', '', 1, 252, 210, 63, 2, '', 'Metadaten', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'headline_WFS_Management', 3, 1, 'WFS Verwaltung', 'div', '', '', 1, 330, 210, 82, 2, '', 'WFS Verwaltung', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'body', 1, 1, 'body
 (obligatory)', 'body', '', 'onload="init()"', NULL, NULL, NULL, NULL, NULL, 'background-image:url(../img/background_yellow.jpg);background-repeat:repeat-x;', '', '', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'rubber', 3, 1, 'deletes temporary (digitized) objects', 'div', '', 'title="Rubber"', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_rubber.js', '', 'mapframe1', 'measure', '');
@@ -180,7 +68,13 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'closePolygon', 3, 1, 'close Polygon ', 'div', '', 'title="Close Polygon"', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_closePolygon.js', '', 'mapframe1', 'measure', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'getArea', 3, 1, 'Calculation of area, Postgis required', 'div', '', 'title="Get Area"', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_getArea.php', '', 'mapframe1', 'measure', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'owsproxy', 2, 1, 'secure services', 'a', '', E'href=\\"../php/mod_owsproxy_conf.php?sessionID\\"\\'' target=\\"AdminFrame\\"', 10, 910, 200, 20, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'OWSPROXY', 'a', '', '', '', 'AdminFrame', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'delete_filteredGui', 2, 1, 'GUI l&ouml;schen', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 110, 240, 80, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI l&ouml;schen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'headline_WMS_Management', 3, 1, 'Dienstverwaltung Beschriftung', 'div', '', '', 0, 37, 210, 123, 2, '', 'WMS Verwaltung', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'help', 2, 1, 'button help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')" title="help"', 210, 2, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', 'http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'loadWFS', 2, 1, 'WFS Capabilities in eine GUI laden', 'a', '', 'href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"', 10, 353, 200, 20, 5, '', 'WFS laden', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'loadWMS', 2, 1, 'Capabilities hochladen', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 10, 60, 200, 20, 5, '', 'WMS laden', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'loadWMSList', 2, 1, 'WMS in GUI einbinden', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 10, 198, 200, 20, 5, '', 'WMS einbinden', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 180, 2, 24, 24, 2, '', '', 'img', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredGroup_filteredGui', 2, 1, 'Einzelner Gruppe mehrere Oberflaechen zuordnen', 'a', '', 'href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ', 8, 570, 190, 25, 10, '', 'Einzelner Gruppe mehrere <br>GUIs zuordnen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'logout', 2, 1, 'Logout', 'img', '../img/button_blue/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blue/logout_over.png"'' onmouseout=''this.src="../img/button_blue/logout_off.png"''', 798, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/Logout');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'gui_owner', 2, 1, 'set owner', 'a', '', 'href = "../php/mod_gui_owner.php?sessionID&e_id_css=gui_owner" target = "AdminFrame" ', 10, 830, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI -> OWNER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'logo', 2, 1, 'Logo', 'img', '../img/mapbender_oo.png', '', 10, 35, 129, 32, 5, 'filter:Chroma(color=#C2CBCF);', '', '', '', '', '', '', NULL);
@@ -188,12 +82,13 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'repaint', 2, 1, 'refresh a mapobject', 'img', '../img/button_blue/repaint_off.png', 'onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)'' title="Redraw"', 358, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_repaint.php', '', 'mapframe1', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'wfs_conf', 2, 1, 'create and edit a gazetteer module', 'a', '', 'href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"', 10, 870, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'WFS CONF', 'a', '', '', '', 'AdminFrame', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'changeEPSG', 2, 1, 'change EPSG, Postgres required, overview is targed for full extent', 'iframe', '../php/mod_changeEPSG.php?sessionID', 'scrolling="no" frameborder=''0'' ', 432, 25, 107, 24, 1, '', '', 'iframe', '', '', 'overview', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'myGUIlist', 2, 1, 'Zurück zur eigenen GUI Liste', 'img', '../img/button_gray/home_off.png', 'onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zurück zur GUI Liste"', 150, 2, 24, 24, 2, '', '', 'img', 'mod_home.php', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_africa', 'body', 1, 1, 'obligatory body', 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_gdi_de', 'body', 1, 1, 'obligatory body', 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_germany', 'body', 1, 1, 'obligatory body', 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'setBackground', 2, 1, 'switch background-wms', 'form', '', '', 10, 218, NULL, NULL, 1, '', '<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>', 'form', 'mod_setBackground.php', '', 'mapframe1', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_north_america', 'body', 1, 1, 'obligatory body', 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'tabs', 2, 1, 'vertical tabs to handle iframes', 'div', '', '', 9, 245, 184, 25, 2, 'font-family: Arial,Helvetica;font-weight:bold;', '', 'div', 'mod_tab.php', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'newGui', 2, 1, 'GUI erzeugen', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 10, 451, 200, 20, 5, '', 'GUI erzeugen', 'a', '', '', '', 'AdminFrame', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_worldwide', 'body', 1, 1, 'obligatory body', 'body', '', '', 0, 0, 0, 0, 0, '', '', 'body', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'loadWFS', 2, 1, 'load capabilities in a gui', 'a', '', 'href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"', 10, 850, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'LOAD WFS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/WFS_Konfiguration');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_africa', 'content', 2, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', E'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=\\''javascript:history.back()\\''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Beh&auml;lter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfl&auml;che. Verwenden Sie diesen (<a href=\\''javascript:history.back()\\''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuw&auml;hlen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', NULL);
@@ -205,7 +100,7 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'featureInfo1', 2, 0, 'FeatureInfoRequest', 'img', '../img/button_blue/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfo1'')"', 140, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_featureInfo.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/FeatureInfo');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'featureInfoTunnel', 2, 1, 'FeatureInfoRequest with local path', 'img', '../img/button_blue/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfoTunnel'')" title="Query"', 461, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_featureInfoTunnel.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/FeatureInfoTunnel');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'forward', 2, 1, 'History.forward()', 'img', '../img/button_blue/forward_off_disabled.png', 'onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" title="Forward"', 423, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_forward.php', '', 'mapframe1,overview0', '', 'http://www.mapbender.org/index.php/Forward');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'gui_owner', 2, 1, 'GUI editieren Benutzer zuordnen', 'a', '', 'href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame" ', 10, 640, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI editieren Benutzer zuordnen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredUser_filteredGui', 2, 1, 'Allow one user to access several GUIs', 'a', '', 'href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ', 8, 500, 190, 25, 10, '', 'Allow one user to access <br> several GUIs', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'mapframe1', 2, 1, 'frame for a map', 'iframe', '../php/mod_map1.php?sessionID', 'scrolling="no" frameborder=''0'' ', 213, 90, 608, 467, 2, '', '', 'iframe', '', '', '', '', 'http://www.mapbender.org/index.php/Mapframe');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'metadata', 2, 1, 'shows informations about the wms and the requests of the gui', 'img', '../img/button_blue/metadata_off.png', 'onClick="window.location.href=''javascript:mod_displayObj()''" border=''0''
 onmouseover=''this.src="../img/button_blue/metadata_over.png"'' onmouseout=''this.src="../img/button_blue/metadata_off.png"''
@@ -228,10 +123,12 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'zoomIn1', 2, 1, 'zoomIn button', 'img', '../img/button_blue/zoomIn2_off.png', 'onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' title=''Zoom in''', 203, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_zoomIn1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomIn');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'zoomOut1', 2, 1, 'zoomOut button', 'img', '../img/button_blue/zoomOut2_off.png', 'onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' title="Zoom out"', 231, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_zoomOut1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomOut');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'deleteWFS', 2, 1, 'delete WFS', 'a', '', 'href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ', 10, 890, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'DELETE WFS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'gui_owner', 2, 1, 'Edit GUI assign to user', 'a', '', 'href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame"  ', 10, 640, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Edit GUI assign to user', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'orphanWMS', 2, 1, 'display orphaned WMS', 'a', '', 'href = "../php/mod_orphanWMS.php?sessionID"
+target = "AdminFrame"', 10, 120, 200, 20, 5, '', 'WMS ohne Zuordung löschen', 'a', '', '', '', 'AdminFrame', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'dragMapSize', 2, 1, 'drag & drop Mapsize', 'div', '', '', 81, -19, NULL, NULL, 2, 'background-color:#799FEB; font-size:1px; cursor:move; width:10; height:10;', '', 'div', 'mod_dragMapSize.php', '', 'mapframe1', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'loadwmc', 2, 1, 'load workspace from WMC', 'img', '../img/button_blue/wmc_load_off.png', 'onclick=''mod_loadwmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");''
 onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Load a web map context document"', 758, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_loadwmc.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/LoadWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'owsproxy', 2, 1, 'secure services', 'a', '', 'href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"', 10, 140, 200, 20, 10, '', 'OWSPROXY', 'a', '', '', '', 'AdminFrame', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'changePassword_button', 2, 1, 'button: change password of logged user', 'img', '../img/button_blue/change_password_off.png', 'onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');" border=''0''
 onmouseover=''this.src="../img/button_blue/change_password_over.png"'' onmouseout=''this.src="../img/button_blue/change_password_off.png"'' title="Change password"', 668, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/ChangePassword');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'measure', 2, 1, 'Measure', 'img', '../img/button_blue/measure_off.png', 'onmouseover = "mb_regButton(''init_mod_measure'')" title="Measure distance"', 513, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_measure.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Measure');
@@ -245,40 +142,42 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_australia', 'content', 2, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'showCoords_div', 2, 1, 'displays coodinates by onmouseover', 'img', '../img/button_gray/coords_off.png', 'onmouseover = "mb_regButton(''init_mod_showCoords_div'')" title="Coordinates" ', 450, 10, 24, 24, 1, '', '', '', 'mod_coords_div.php', '', 'mapframe1', 'dependendDiv', 'http://www.mapbender.org/index.php/ShowCoords_div');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_australia', 'body', 1, 1, 'obligatory body', 'body', '', '', 0, 0, NULL, NULL, NULL, '', '', 'body', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'updateWMSs', 2, 1, 'Hochgeladene aktualisieren', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 10, 80, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Hochgeladene aktualisieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredGui_filteredUser', 2, 1, 'Allow several users access to one GUI ', 'a', '', 'href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ', 8, 535, 190, 25, 10, '', 'Allow several users access to <br> one GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_europe', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''onmouseover=''this.src="../img/button_gray/logout_over.png"''onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'body', 1, 1, 'navigation', 'body', '', 'onload=''mod_adminNavigation_init()''', 0, 0, 0, 0, 0, '', '', '', 'mod_adminNavigation.js', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'updateWMSs', 2, 1, 'Update with Capabilities', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 10, 80, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Update Capabilities', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'rename_copy_Gui', 2, 1, 'GUI umbenennen/ kopieren', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 10, 561, 200, 20, 10, '', 'GUI umbenennen/kopieren', 'a', '', '', '', 'AdminFrame', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_europe', 'body', 1, 1, 'obligatory body', 'body', '', '', 0, 0, NULL, NULL, NULL, '', '', 'body', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'editGroup', 2, 1, 'edit group', 'a', '', 'href = "../php/mod_editGroup.php?sessionID" target = "AdminFrame" ', 10, 510, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT GROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'updateWMSs', 2, 1, 'edit the elements of the gui', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 10, 70, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'UPDATE WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/UpdateWMS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_europe', 'content', 2, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'rename_copy_Gui', 2, 1, 'rename and copy gui', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 10, 470, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'RENAME COPY GUI', 'a', '', '', '', 'AdminFrame', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredGroup_filteredGui', 2, 1, 'Allow one group access to several GUIs', 'a', '', 'href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ', 8, 570, 190, 25, 10, '', 'Allow one group access to <br> several GUIs', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_gdi_de', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''onmouseover=''this.src="../img/button_gray/logout_over.png"''onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'user_filteredGroup', 2, 1, 'allocate user to groups where this admin is owner', 'a', '', 'href = "../php/mod_user_filteredGroup.php?sessionID&e_id_css=user_filteredGroup" target = "AdminFrame" ', 10, 450, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'USER -> myGROUP', 'a', '', '', '', 'AdminFrame', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'user_filteredGui', 2, 1, 'allocate guis of this admin to user', 'a', '', 'href = "../php/mod_user_filteredGui.php?sessionID&e_id_css=user_filteredGui" target = "AdminFrame" ', 10, 390, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'USER-> myGUI', 'a', '', '', '', 'AdminFrame', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'newGui', 2, 1, 'GUI erzeugen', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 10, 240, 85, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;', 'GUI erzeugen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'showLoggedUser', 2, 1, 'Anzeige des eingeloggten Benutzers', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, 1, 'background-color:lightgrey;', '', 'iframe', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'user_gui', 2, 1, 'allocate guis to user', 'a', '', 'href = "../php/mod_user_gui.php?sessionID&e_id_css=user_gui" target = "AdminFrame" ', 10, 370, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'USER -> GUI ', 'a', '', '', '', 'AdminFrame', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'AdminFrame', 2, 1, 'Bereich f&uuml;r Administrationsmodule', 'iframe', '', 'frameborder = "0"', 200, 20, 800, 800, 0, '', '', 'iframe', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'body', 1, 1, 'Navigation', 'body', '', 'onload=''mod_adminNavigation_init()''', 0, 0, 180, 20, 0, '', '', '', 'mod_adminNavigation.js', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'newGui', 2, 1, 'create a new gui', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 10, 130, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;', 'NEW GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_gdi_de', 'content', 2, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_0', 3, 1, 'Hintergrund WMS Verwaltung Rahmen', 'div', '', '', 3, 35, 190, 90, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #008000;background-color:red;', '', 'div', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_1', 3, 1, 'Hintergrund WMS Management', 'div', '', '', 5, 37, 186, 86, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none; color: #000080;background-color:white;', ' WMS Verwaltung', 'div', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_1a', 3, 1, 'Hintergrund WMS Zuordnung Rahmen', 'div', '', '', 3, 135, 190, 70, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #008000;background-color:red;', '', 'div', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_1b', 3, 1, 'Hintergrund WMS Zuordnung', 'div', '', '', 5, 137, 186, 66, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none; color: #000080;background-color:white;', ' WMS Zuordnung', 'div', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_1c', 3, 1, 'Hintergrund Oberfl&auml;chenverwaltung Rahmen', 'div', '', '', 3, 215, 190, 130, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #008000;background-color:red;', '', 'div', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_1d', 3, 1, 'Hintergrund Oberfl&auml;chenverwaltung', 'div', '', '', 5, 217, 186, 126, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none; color: #000080;background-color:white;', ' Oberfl&auml;chenverwaltung', 'div', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_2', 3, 1, 'Hintergrund Benutzerverwaltung Rahmen', 'div', '', '', 3, 355, 190, 110, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #008000;background-color:red;', '', 'div', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_3', 3, 1, 'Hintergrund Benutzerverwaltung', 'div', '', '', 5, 357, 186, 106, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none; color: #000080;background-color:white;', ' Benutzerverwaltung', 'div', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_4', 3, 1, 'Hintergrund Benutzerzugriff erteilen Rahmen', 'div', '', '', 3, 475, 190, 200, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #008000;background-color:red;', '', 'div', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_5', 3, 1, 'Hintergrund Benutzerzugriff erteilen', 'div', '', '', 5, 477, 186, 196, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none; color: #000080;background-color:white;', ' Benutzerzugriff erteilen', 'div', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'rename_copy_Gui', 2, 1, 'GUI umbenennen/ kopieren', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 10, 320, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI umbenennen/kopieren', 'a', '', '', '', 'AdminFrame', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'updateWMSs', 2, 1, 'Hochgeladene aktualisieren', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 10, 80, 200, 20, 5, '', 'WMS aktualisieren', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'wfs_conf', 2, 1, 'WFS konfigurieren', 'a', '', 'href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"', 10, 373, 200, 20, 5, '', 'WFS konfigurieren', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'AdminFrame', 2, 1, 'administration frame', 'iframe', '', 'frameborder = "0"', 210, 25, 1000, 800, 12, '', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'CreateTreeGDE', 2, 1, 'Configure TreeGDE', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 10, 513, 200, 20, 5, '', 'Configure TreeGDE', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'EditWMSMetadata', 2, 1, 'edit the metadata of wms', 'a', '', 'href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"', 10, 275, 200, 20, 5, '', 'WMS Metadata', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'body', 1, 1, 'Navigation', 'body', '', 'onload=''mod_adminNavigation_init()''', NULL, NULL, NULL, NULL, NULL, '', '', '', 'mod_adminNavigation.js', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'deleteWFS', 2, 1, 'Delete WFS', 'a', '', 'href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ', 10, 393, 200, 20, 5, '', 'Delete WFS', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'deleteWMS', 2, 1, '!Delete completely!', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 10, 100, 200, 20, 5, '', '!Delete completely!', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'delete_filteredGui', 2, 1, 'Delete GUI', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 10, 471, 200, 20, 5, '', 'Delete GUI', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredGui_filteredGroup', 2, 1, 'Allow several groups access to one GUI', 'a', '', 'href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ', 8, 605, 190, 25, 10, '', 'Allow several groups access <br> to one GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'editElements', 2, 1, 'Edit GUI Elements', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 10, 491, 200, 20, 5, '', 'Edit GUI Elements', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'editGUI_WMS', 2, 1, 'WMS GUI settings', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 10, 218, 200, 20, 5, '', 'WMS GUI settings', 'a', '', '', '', 'AdminFrame', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'showLoggedUser', 2, 1, 'Anzeige des eingeloggten Benutzers', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, 1, 'background-color:lightgrey;', '', 'iframe', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'printPDF', 2, 1, 'pdf print', 'iframe', '../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf', 'frameborder = "0" ', 1, 1, 2, 2, 5, 'visibility:hidden', '', 'iframe', '', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Print');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'AdminFrame', 2, 1, 'the frame for administration modules', 'iframe', '', 'frameborder = "0"', 200, 20, 800, 800, 0, '', '', 'iframe', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'body', 1, 1, 'navigation', 'body', '', 'onload=''mod_adminNavigation_init()''', 0, 0, 0, 0, 0, '', '', '', 'mod_adminNavigation.js', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'newGui', 2, 1, 'Create new GUI', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 10, 240, 90, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;', 'Create new GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'exportGUI', 2, 1, 'Export GUI (SQL), create SQL', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 10, 533, 200, 20, 10, 'x', 'Export GUI (SQL)', 'a', '', '', '', 'AdminFrame', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_germany', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''onmouseover=''this.src="../img/button_gray/logout_over.png"''onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'addWMSfromfilteredList', 2, 1, 'add a WMS to the running application from a filtered list', 'img', '../img/button_blue/add_filtered_list_off.png', 'onclick=''window.open("../javascripts/mod_addWMSfromfilteredList.php?sessionID","printWin","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"', 553, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', '', 'mod_addWMSgeneralFunctions.js', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'changePassword_button', 2, 1, 'button: change password of logged user', 'img', '../img/button_blink_red/change_password_off.png', 'onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');" border=''0'' onmouseover=''this.src="../img/button_blink_red/change_password_over.png"'' onmouseout=''this.src="../img/button_blink_red/change_password_off.png"'' title="Change password"', 750, 60, 24, 24, 1, 'cursor:hand', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/ChangePassword');
@@ -287,21 +186,23 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'help', 2, 1, 'button help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')" title="help"', 210, 2, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', 'http://www.mapbender.org');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'help', 2, 1, 'button help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')" title="help"', 620, 10, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', 'http://www.mapbender.org');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'help', 2, 1, 'button help', 'img', '../img/button_blue/help_off.png', 'onmouseover = "mb_regButton(''init_help'')" title="help"', 693, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', 'http://www.mapbender.org');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'layout_0', 3, 1, 'WMS Management border', 'div', '', '', 3, 35, 190, 90, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #008000;background-color:red;', '', 'div', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'layout_1', 3, 1, 'WMS Management caption', 'div', '', '', 5, 37, 186, 86, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none; color: #000080;background-color:white;', ' WMS Management', 'div', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'layout_1a', 3, 1, 'Configure WMS Access border', 'div', '', '', 3, 135, 190, 70, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #008000;background-color:red;', '', 'div', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'layout_1b', 3, 1, 'Configure WMS Access', 'div', '', '', 5, 137, 186, 66, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none; color: #000080;background-color:white;', ' Configure WMS Access', 'div', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'layout_1c', 3, 1, 'GUI Management border', 'div', '', '', 3, 215, 190, 130, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #008000;background-color:red;', '', 'div', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'layout_1d', 3, 1, 'GUI Management caption', 'div', '', '', 5, 217, 186, 126, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none; color: #000080;background-color:white;', ' GUI Management ', 'div', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'layout_2', 3, 1, 'User Management border', 'div', '', '', 3, 355, 190, 110, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #008000;background-color:red;', '', 'div', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'layout_3', 3, 1, 'User Management caption', 'div', '', '', 5, 357, 186, 106, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none; color: #000080;background-color:white;', ' User Management ', 'div', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'layout_4', 3, 1, 'Authorization background', 'div', '', '', 3, 475, 190, 190, 1, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #008000;background-color:red;', '', 'div', '', '', '', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'layout_5', 3, 1, 'Authorization caption', 'div', '', '', 5, 477, 186, 186, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none; color: #000080;background-color:white;', ' Authorization', 'div', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'filteredWms_layer_topic', 2, 1, 'allocate topics to layers of wms of this user', 'a', '', 'href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ', 10, 295, 200, 20, 5, '', 'Allocate topics', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'headline_Configure_WMS_Access', 3, 1, 'WMS Assignment', 'div', '', '', 1, 175, 210, 63, 2, '', 'WMS Assignment', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'headline_GUI_Management', 3, 1, 'GUI Management', 'div', '', '', 1, 428, 210, 148, 2, '', 'GUI Management', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'headline_Metadata', 3, 1, 'Metadata', 'div', '', '', 1, 252, 210, 63, 2, '', 'Metadata', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'headline_WFS_Management', 3, 1, 'WFS Management', 'div', '', '', 1, 330, 210, 82, 2, '', 'WFS Management', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'headline_WMS_Management', 3, 1, 'WMS Management', 'div', '', '', 0, 37, 210, 123, 2, '', 'WMS Management', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'help', 2, 1, 'button help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')" title="help"', 210, 2, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', 'http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'loadWFS', 2, 1, 'Load WFS Capabilities into a GUI', 'a', '', 'href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"', 10, 353, 200, 20, 5, '', 'Load WFS', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'loadWMS', 2, 1, 'load Capabilities', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 10, 60, 200, 20, 5, '', 'Load Capabilities', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'loadWMSList', 2, 1, 'assign WMS to a GUI', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 10, 198, 200, 20, 5, '', 'Assign WMS to a GUI', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 180, 2, 24, 24, 2, '', '', 'img', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'myGUIlist', 2, 1, 'back to GUI list', 'img', '../img/button_gray/home_off.png', 'onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zurück zur GUI Liste"', 150, 2, 24, 24, 2, '', '', 'img', 'mod_home.php', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'forward', 2, 1, 'History.forward()', 'img', '../img/button_blink_red/forward_off_disabled.png', 'onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" title="Forward"', 425, 60, 24, 24, 1, '', '', '', 'mod_forward.php', '', 'mapframe1,overview', '', 'http://www.mapbender.org/index.php/Forward');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'navFrame', 2, 1, 'navigation mapborder', 'div', '', '', 0, 0, 0, 0, 10, 'font-size:1px;', '<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ', 'div', 'mod_navFrame.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/NavFrame');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'pan1', 2, 1, 'pan', 'img', '../img/button_blink_red/pan_off.png', 'onmouseover = "mb_regButton(''init_mod_pan'')" title="Pan"', 260, 60, 24, 24, 1, '', '', '', 'mod_pan.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Pan');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_germany', 'content', 2, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'rename_copy_Gui', 2, 1, 'Rename/ copy GUI', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 10, 320, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Rename / copy GUI', 'a', '', '', '', 'AdminFrame', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'newGui', 2, 1, 'New GUI', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 10, 451, 200, 20, 5, '', 'New GUI', 'a', '', '', '', 'AdminFrame', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'showLoggedUser', 2, 1, 'Logged User:', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, 1, 'background-color:lightgrey;', '', 'iframe', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'printPDF', 2, 1, 'start print GUI', 'img', '../img/button_blink_red/print_off.png', 'onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF_b.conf","printWin","width=180, height=200, resizable=yes ")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Print"', 555, 60, 24, 24, 1, '', '', '', '', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Print');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'zoomFull', 2, 1, 'zoom to full extent button', 'img', '../img/button_blink_red/zoomFull_off.png', 'onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"  title="Display complete map"', 335, 60, 24, 24, 2, '', '', 'img', 'mod_zoomFull.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomFull');
@@ -324,6 +225,7 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'mapframe1', 2, 1, 'frame for a map', 'iframe', '../php/mod_map1.php?sessionID', 'scrolling="no" frameborder=''0'' ', 230, 55, 500, 450, 2, '', '', 'iframe', '', '', '', '', 'http://www.mapbender.org/index.php/Mapframe');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_north_america', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''onmouseover=''this.src="../img/button_gray/logout_over.png"''onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'setBBOX', 2, 0, 'set extent for mapframe and overviewframe', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_setBBOX1.php', '', 'mapframe1', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'gazetteerWFS', 2, 1, 'a gazetteer for rivers of germany', 'iframe', '../php/mod_wfs_gazetteer.php?sessionID&wfs_conf=1&target=mapframe1,overview&resultFrame=wfsresult', 'frameborder = "0"', 10, 600, 300, 150, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1,overview', 'wz-graphics', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'addWMS', 2, 1, 'add a WMS to the running application', 'img', '../img/button_blink_red/add_off.png', 'onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS"', 645, 60, 24, 24, 1, '', '', '', 'mod_addWMS.php', '', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/AddWMS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'back', 2, 1, 'History.back()', 'img', '../img/button_blink_red/back_off_disabled.png', 'onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" title="Back"', 400, 60, 24, 24, 1, '', '', '', 'mod_back.php', '', 'mapframe1,overview', '', 'http://www.mapbender.org/index.php/Back');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'copyright', 2, 1, 'a Copyright in the map', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_copyright.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Copyright');
@@ -361,11 +263,13 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'wfs_gazetteer', 2, 0, 'gazetteer using wfs', 'iframe', '../php/mod_wfs_gazetteer.php?sessionID&color=255,0,255', 'frameborder = "0" ', -50, 490, 250, 300, 0, 'visibility:visible', '', 'iframe', '', '', 'mapframe1,overview', 'wfs', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'zoomCoords', 2, 1, 'zoom to coordinate', 'iframe', '../php/mod_zoomCoords_en.php?sessionID', 'frameborder = "0" ', 205, 7, 220, 45, 0, '', '', 'iframe', '', '', 'mapframe1,overview', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'selArea1', 2, 1, 'zoombox', 'img', '../img/button_blink_red/selArea_off.png', 'onmouseover = "mb_regButton(''init_selArea1'')" title="Zoom by rectangle"', 285, 60, 24, 24, 1, '', '', '', 'mod_selArea1.php', 'mod_box1.js', 'mapframe1', '', 'http://www.mapbender.org/index.php/SelArea1');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'showCoords_div', 2, 1, 'displays coordinates by onmouseover', 'img', '../img/button_blink_red/coords_off.png', 'onmouseover = "mb_regButton(''init_mod_showCoords_div'')"  title="Coordinates"', 490, 60, 24, 24, 1, 'background-color:white; font-family: Arial, Helvetica, sans-serif;font-size:10px;', '', '', 'mod_coords_div.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'gazetteerWFS', 2, 1, 'a gazetteer for user in the mapbender user map', 'iframe', '../php/mod_wfs_gazetteer.php?sessionID&wfs_conf=1,4,3,2&target=mapframe1,overview&resultFrame=wfsresult', 'frameborder = "0"', 10, 600, 300, 150, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1,overview', 'wz-graphics', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'orphanWMS', 2, 1, 'Delete orphaned WMS', 'a', '', 'href = "../php/mod_orphanWMS.php?sessionID"
+target = "AdminFrame"', 10, 120, 200, 20, 5, '', 'Delete orphaned WMS', 'a', '', '', '', 'AdminFrame', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'WMS_preferences', 2, 1, 'configure the preferences of each loaded wms', 'img', '../img/button_blink_red/preferences_off.png', 'onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="WMS preferences"', 670, 60, 24, 24, 1, '', '', '', '', '', 'mapframe1,treeGDE', '', 'http://www.mapbender.org/index.php/WMS_preferences');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'CreateTreeGDE', 2, 1, 'create a foldertree for a individual geodataexplorer', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 10, 810, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'CREATE TREE_GDE', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/ConfTreeGde');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'CreateTreeGDE', 2, 1, 'Ordnerbaum konfigurieren', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 10, 280, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Ordnerbaum konfigurieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/ConfTreeGde');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'CreateTreeGDE', 2, 1, 'TreeGDE set up', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 10, 280, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'TreeGDE set up', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'owsproxy', 2, 1, 'secure services', 'a', '', 'href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"', 10, 140, 200, 20, 10, '', 'OWSPROXY', 'a', '', '', '', 'AdminFrame', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'rename_copy_Gui', 2, 1, 'Rename / copy GUI', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 10, 556, 200, 20, 10, '', 'Rename / copy GUI', 'a', '', '', '', 'AdminFrame', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'Group_Gui', 2, 1, 'allocate groups to guis', 'a', '', 'href = "../php/mod_group_gui.php?sessionID&e_id_css=Group_Gui" target = "AdminFrame" ', 10, 610, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GROUP -> GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'Group_User', 2, 1, 'allocate groups to user', 'a', '', 'href = "../php/mod_group_user.php?sessionID&e_id_css=Group_User" target = "AdminFrame" ', 10, 550, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;', 'GROUP -> USER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'Group_filteredGui', 2, 1, 'allocate Groups to the guis of this admin', 'a', '', 'href = "../php/mod_group_filteredGui.php?sessionID&e_id_css=Group_filteredGui" target = "AdminFrame" ', 10, 710, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GROUP -> myGUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
@@ -374,83 +278,72 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'User_Group', 2, 1, 'allocat user to groups', 'a', '', 'href = "../php/mod_user_group.php?sessionID&e_id_css=User_Group" target = "AdminFrame" ', 10, 430, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'USER -> GROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'myGUIlist', 2, 1, 'Zurück zur eigenen GUI Liste', 'img', '../img/button_gray/home_off.png', 'onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zurück zur GUI Liste"', 150, 2, 24, 24, 2, '', '', 'img', 'mod_home.php', '', '', '', 'http://www.mapbender.org/index.php/MyGUIlist');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'editFilteredGroup', 2, 1, 'edit group of this admin', 'a', '', 'href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ', 10, 530, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT myGROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'editFilteredGroup', 2, 1, 'Gruppe anlegen und editieren', 'a', '', 'href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ', 10, 400, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Gruppe anlegen und editieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'editFilteredGroup', 2, 1, 'Create and edit group', 'a', '', 'href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ', 10, 400, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Create and edit group', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'showLoggedUser', 2, 1, 'show logged in user', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, 1, 'background-color:lightgrey;', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'updateWMSs', 2, 1, 'Update Capabilities', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 10, 80, 200, 20, 5, '', 'Update Capabilities', 'a', '', '', '', 'AdminFrame', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'editFilteredUser', 2, 1, 'save, edit, delete user where this admin is owner', 'a', '', 'href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"', 10, 350, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT myUSER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'editFilteredUser', 2, 1, 'Benutzer anlegen und editieren', 'a', '', 'href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"', 10, 380, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Benutzer anlegen und editieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'editFilteredUser', 2, 1, 'Create and edit user', 'a', '', 'href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"', 10, 380, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Create and edit user', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'wfs_conf', 2, 1, 'Configure WFS', 'a', '', 'href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"', 10, 373, 200, 20, 5, '', 'Configure WFS', 'a', '', '', '', 'AdminFrame', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'editUser', 2, 1, 'save, edit, delete user', 'a', '', 'href = "../php/mod_editUser.php?sessionID" target="AdminFrame"', 10, 330, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT USER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGoup_filteredUser', 2, 1, 'allocate the groups of this admin to user where the admin is owner', 'a', '', 'href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ', 10, 590, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGROUP -> myUSER ', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredGoup_filteredUser', 2, 1, 'Gruppe mit Benutzern best&uuml;cken', 'a', '', 'href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ', 10, 440, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Gruppe mit Benutzern best&uuml;cken ', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredGoup_filteredUser', 2, 1, 'Add several users to one group', 'a', '', 'href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ', 10, 440, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Add several users to one group ', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGroup_Gui', 2, 1, 'allocate groups of this admin to guis', 'a', '', 'href = "../php/mod_filteredGroup_Gui.php?sessionID&e_id_css=filteredGroup_Gui" target = "AdminFrame" ', 10, 750, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGROUP -> GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGroup_User', 2, 1, 'allocate groups of this admin to user', 'a', '', 'href = "../php/mod_filteredGroup_User.php?sessionID&e_id_css=filteredGroup_User" target = "AdminFrame" ', 10, 690, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGROUP -> USER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGroup_filteredGui', 2, 1, 'allocate groups of this admin to guis of this admin', 'a', '', 'href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ', 10, 730, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGROUP -> myGUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredGroup_filteredGui', 2, 1, 'Einzelner Gruppe mehrere Oberflaechen zuordnen', 'a', '', 'href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ', 10, 570, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Einzelner Gruppe mehrere <br>Oberfl&auml;chen zuordnen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredGroup_filteredGui', 2, 1, 'Allow one group access to several GUIs', 'a', '', 'href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ', 10, 570, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Allow one group access to <br> several GUIs', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGui_Group', 2, 1, 'allocate guis to groups', 'a', '', 'href = "../php/mod_filteredGui_group.php?sessionID&e_id_css=filteredGui_Group" target = "AdminFrame" ', 10, 270, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGUI -> GROUP ', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGui_filteredGroup', 2, 1, 'allocate guis of this admin to groups where this admin is owner', 'a', '', 'href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ', 10, 290, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGUI -> myGROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredGui_filteredGroup', 2, 1, 'Einzelner Oberfl&auml;che mehrere Gruppen zuordnen', 'a', '', 'href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ', 10, 605, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Einzelner Oberfl&auml;che mehrere<br> Gruppen zuordnen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredGui_filteredGroup', 2, 1, 'Allow several groups access to one GUI', 'a', '', 'href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ', 10, 605, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Allow several groups access <br> to one GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGui_filteredUser', 2, 1, 'allocate the user where the admin is owner to his guis ', 'a', '', 'href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ', 10, 230, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGUI -> myUSER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredGui_filteredUser', 2, 1, 'Oberfl&auml;che mehreren Benutzer zuordnen ', 'a', '', 'href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ', 10, 535, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Oberfl&auml;che mehreren Benutzern <br> zuordnen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredGui_filteredUser', 2, 1, 'Allow several users access to one GUI ', 'a', '', 'href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ', 10, 535, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Allow several users access to <br> one GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'FeatureInfoRedirect', 2, 0, 'redirect featureInfoRequests in an iframe for each wms', 'iframe', '../html/mod_blank.html', 'frameborder="0"', 83, -17, 1, 1, NULL, '', '', 'iframe', 'mod_featureInfoRedirect.php', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredGui_user', 2, 1, 'allocate the guis of this admin to a user', 'a', '', 'href = "../php/mod_filteredGui_User.php?sessionID&e_id_css=filteredGui_user" target = "AdminFrame" ', 10, 210, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myGUI -> USER ', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredUser_Group', 2, 1, 'allocate user of this admin to groups', 'a', '', 'href = "../php/mod_filteredUser_Group.php?sessionID&e_id_css=filteredUser_Group" target = "AdminFrame" ', 10, 670, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myUSER -> GROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredUser_Gui', 2, 1, 'allocate user of this admin to guis', 'a', '', 'href = "../php/mod_filteredUser_Gui.php?sessionID&e_id_css=filteredUser_Gui" target = "AdminFrame" ', 10, 770, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myUSER -> GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredUser_filteredGroup', 2, 1, 'allocate user where this admin is owner to groups where this admin is owner', 'a', '', 'href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ', 10, 490, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myUSER -> myGROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredUser_filteredGroup', 2, 1, 'Benutzer in Gruppen eintragen', 'a', '', 'href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ', 10, 420, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Benutzer in Gruppen eintragen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredUser_filteredGroup', 2, 1, 'Add one user to serveral groups', 'a', '', 'href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ', 10, 420, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Add one user to serveral groups', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'gazetteerWFS', 2, 1, 'a gazetteer for rivers of germany', 'iframe', '../php/mod_wfs_gazetteer.php?sessionID&wfs_conf=1&target=mapframe1,overview&resultFrame=wfsresult', 'frameborder = "0"', 10, 600, 300, 150, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1,overview', 'wz-graphics', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'filteredUser_filteredGui', 2, 1, 'allocate admins user to guis of this admin', 'a', '', 'href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ', 10, 410, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'myUSER -> myGUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredUser_filteredGui', 2, 1, 'Einem Nutzer Zugriff auf mehrere Oberfl&auml;chen erteilen', 'a', '', 'href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ', 10, 500, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Einem Nutzer Zugriff auf <br> mehrere Oberfl&auml;chen erteilen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredUser_filteredGui', 2, 1, 'Allow one user to access several GUIs', 'a', '', 'href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ', 10, 500, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Allow one user to access <br> several GUIs', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'group_filteredUser', 2, 1, 'allocate groups to user where this admin is owner', 'a', '', 'href = "../php/mod_group_filteredUser.php?sessionID&e_id_css=group_filteredUser" target = "AdminFrame" ', 10, 570, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GROUP -> myUSER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'gui_filteredGroup', 2, 1, 'allocate guis to groups of this admin', 'a', '', 'href = "../php/mod_gui_filteredGroup.php?sessionID&e_id_css=gui_filteredGroup" target = "AdminFrame" ', 10, 650, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI -> myGROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'gui_filteredUser', 2, 1, 'allocate guis to user of this admin', 'a', '', 'href = "../php/mod_gui_filteredUser.php?sessionID&e_id_css=gui_filteredUser" target = "AdminFrame" ', 10, 630, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI -> myUSER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'header_yellow', 2, 0, 'header', 'img', '../img/header_yellow.jpg', '', -1, -1, 833, 75, NULL, '', '', '', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'deleteGui', 2, 1, 'delete gui', 'a', '', 'href = "../php/mod_deleteGUI.php?sessionID" target = "AdminFrame" ', 10, 150, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'DELETE GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'deleteWMS', 2, 1, 'delete wms', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 10, 110, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'DELETE WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'deleteWMS', 2, 1, '!Vollst&auml;ndig l&ouml;schen!', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 10, 100, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', '!Vollst&auml;ndig l&ouml;schen!', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWMS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'highlightPOI', 2, 1, 'highlight 1 to n pois in your gui with a Symbol and a special text', 'div', '', '', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_highlightPOI.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'deleteWMS', 2, 1, '!Delete completely!', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 10, 100, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', '!Delete completely!', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'exportGUI', 2, 1, 'Oberfläche (GUI) exportieren, SQL erzeugen', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 8, 300, 190, 20, 10, '', 'GUI exportieren (SQL)', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'delete_filteredGui', 2, 1, 'delete guis of this admin', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 10, 790, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'DELETE myGUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'layout_linie', 3, 0, 'layout', 'div', '', '', 1, 70, 830, 1, 1, 'background-color:#799FEB;font-size:1px;', '', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'editElements', 2, 1, 'edit gui elements', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 10, 170, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;', 'EDIT GUI-ELEMENTS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_Elements');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'editElements', 2, 1, 'Oberfl&auml;chenelemente editieren', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 10, 260, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;', 'Oberfl&auml;chenelemente editieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_Elements');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'editElements', 2, 1, 'Edit GUI elements', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 10, 260, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;', 'Edit GUI elements', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_Elements');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'editGUI_WMS', 2, 1, 'edit the elements of the gui', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 10, 90, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT GUI-WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_WMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'editGUI_WMS', 2, 1, 'WMS GUI Einstellungen', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 10, 180, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'WMS GUI Einstellungen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_WMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'editGUI_WMS', 2, 1, 'WMS GUI settings', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 10, 180, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'WMS GUI settings', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_WMS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'exportGUI', 2, 1, 'export gui, create SQLL', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 10, 310, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EXPORT GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'exportGUI', 2, 1, 'Oberfl&auml;che (GUI) exportieren, SQL erzeugen', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 10, 300, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Oberfl&auml;che exportieren (SQL)', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'exportGUI', 2, 1, 'export GUI, create SQL', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 10, 300, 180, 20, 10, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Export GUI (SQL)', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'delete_filteredGui', 2, 1, 'Delete GUI', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 110, 240, 80, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Delete GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'loadWMSList', 2, 1, 'load wms from a list', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 10, 50, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'LOAD myWMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'loadWMSList', 2, 1, 'WMS in GUI einbinden', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 10, 160, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'WMS in GUI einbinden', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'loadWMSList', 2, 1, 'Link WMS into GUI', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 10, 160, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Link WMS into GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'loadWMS', 2, 1, 'load capabilities in a gui', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 10, 30, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'LOAD WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'loadWMS', 2, 1, 'Capabilities hochladen', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 10, 60, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Capabilities hochladen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'loadWMS', 2, 1, 'Load Capabilities', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 10, 60, 180, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'Load Capabilities', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_africa', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', E'onClick=\\"window.location.href=\\''../php/mod_logout.php?sessionID\\''\\" border=\\''0\\''onmouseover=\\''this.src=\\"../img/button_gray/logout_over.png\\"\\''onmouseout=\\''this.src=\\"../img/button_gray/logout_off.png\\"\\'' title=\\"Logout\\"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 180, 2, 24, 24, 1, '', '', 'img', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 180, 2, 24, 24, 2, '', '', 'img', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 180, 2, 24, 24, 2, '', '', 'img', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'logout', 2, 1, 'Logout', 'img', '../img/button_blink_red/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blink_red/logout_over.png"'' onmouseout=''this.src="../img/button_blink_red/logout_off.png"'' title="Logout"', 830, 60, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'treeGDE', 2, 1, 'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2', 'iframe', '../html/mod_treefolder2.php?sessionID', E'frameborder = \\"0\\" ', 10, 220, 200, 300, NULL, 'visibility:visible', '', 'iframe', '', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'editElements', 2, 1, 'Oberflächenelemente editieren', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 8, 260, 190, 20, 5, '', 'GUI-Elemente editieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_Elements');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 660, 10, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/Logout');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'legend', 2, 1, 'legend', 'iframe', '../javascripts/mod_legend.php?sessionID&wms_legend = yes', 'frameborder=''0''', -59, 200, 180, 600, 3, '', '', 'iframe', '', '', 'mapframe1', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'legend', 2, 1, 'legend', 'iframe', '../javascripts/mod_legend.php?sessionID&e_id_css=legend', 'frameborder=''0''', 1, 1, 1, 1, 3, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'gui_owner', 2, 1, 'Edit GUI assign to user', 'a', '', 'href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame"  ', 8, 640, 190, 20, 10, '', 'Edit GUI assign to user', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'updateWMSs', 2, 1, 'Update with Capabilities', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 8, 80, 190, 20, 5, '', 'Update Capabilities', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/UpdateWMS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'loadwmc', 2, 1, 'load workspace from WMC', 'img', '../img/button_blink_red/wmc_load_off.png', 'onclick=''mod_loadwmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");''
 onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Load a web map context document"', 895, 60, 24, 24, 1, '', '', '', 'mod_loadwmc.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/LoadWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'rename_copy_Gui', 2, 1, 'Rename/ copy GUI', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 8, 320, 190, 20, 10, '', 'Rename / copy GUI', 'a', '', '', '', 'AdminFrame', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'editFilteredUser', 2, 1, 'Create and edit user', 'a', '', 'href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"', 8, 380, 190, 20, 10, '', 'Create and edit user', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredGoup_filteredUser', 2, 1, 'Add several users to one group', 'a', '', 'href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ', 8, 440, 190, 20, 10, '', 'Add several users to one group ', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'AdminFrame', 2, 1, 'the frame for administration modules', 'iframe', '', E'frameborder = \\"0\\"', 220, 20, 800, 800, NULL, '', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'showCoords_div', 2, 1, 'displays coordinates by onmouseover', 'img', '../img/button_blink_red/coords_off.png', E'onmouseover = \\"mb_regButton(\\''init_mod_showCoords_div\\'')\\"  title=\\"Coordinates\\"', 490, 60, 24, 24, 1, '', '', '', 'mod_coords_div.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ShowCoords_div');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'addWMS', 2, 1, 'add a WMS to the running application', 'img', '../img/button_gray/add_off.png', 'onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS"', 515, 10, 24, 24, 1, '', '', '', 'mod_addWMS.php', '', 'treeGDE,mapframe1', 'loadData', 'http://www.mapbender.org/index.php/AddWMS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'back', 2, 1, 'History.back()', 'img', '../img/button_gray/back_off_disabled.png', 'onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" title="Back"', 360, 10, 24, 24, 1, '', '', '', 'mod_back.php', '', 'mapframe1,overview0', '', 'http://www.mapbender.org/index.php/Back');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'copyright', 2, 1, 'a Copyright in the map', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_copyright.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredUser_filteredGroup', 2, 1, 'Add one user to serveral groups', 'a', '', 'href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ', 8, 420, 190, 20, 10, '', 'Add one user to serveral groups', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'dependentDiv', 2, 1, 'displays infos in a sticky div-tag', 'div', '', '', 81, -19, 1, 1, 0, 'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;', '', 'div', 'mod_dependentDiv.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/DependentDiv');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'featureInfo1', 2, 0, 'FeatureInfoRequest', 'img', '../img/button_gray/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfo1'')"', 140, 40, 24, 24, 1, '', '', '', 'mod_featureInfo.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/FeatureInfo');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'FeatureInfoRedirect', 2, 1, 'redirect featureInfoRequests in an iframe for each wms', 'iframe', '../html/mod_blank.html', 'frameborder="0"', 83, -17, 1, 1, 0, '', '', 'iframe', 'mod_featureInfoRedirect.php', '', '', '', 'http://www.mapbender.org/index.php/FeatureInfoRedirect');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'featureInfoTunnel', 2, 1, 'FeatureInfoRequest with local path', 'img', '../img/button_gray/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfoTunnel'')" title="Query"', 425, 10, 24, 24, 1, '', '', '', 'mod_featureInfoTunnel.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/FeatureInfoTunnel');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'forward', 2, 1, 'History.forward()', 'img', '../img/button_gray/forward_off_disabled.png', 'onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" title="Forward"', 385, 10, 24, 24, 1, '', '', '', 'mod_forward.php', '', 'mapframe1,overview0', '', 'http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'tabs', 2, 1, 'vertical tabs to handle iframes', 'div', '', '', 2, 245, 191, 22, 2, 'font-family: Arial,Helvetica;font-weight:bold;', '', 'div', 'mod_tab.php', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'metadata', 2, 1, 'shows informations about the wms and the requests of the gui', 'img', '../img/button_gray/metadata_off.png', 'onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_gray/metadata_over.png"'' onmouseout=''this.src="../img/button_gray/metadata_off.png"'' title="Show service metadata"', 580, 10, 24, 24, 1, '', '', '', 'mod_displayObj.js', '', '', '', 'http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'deleteWMS', 2, 1, '!Delete completely!', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 8, 100, 190, 20, 5, '', '!Delete completely!', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWMS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'navFrame', 2, 1, 'navigation mapborder', 'div', '', '', 0, 0, 0, 0, 0, 'font-size:1px;', '<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ', 'div', 'mod_navFrame.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/NavFrame');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'overview', 2, 1, 'OverviewFrame', 'iframe', '../php/mod_mapOV.php?wms=0&sessionID', 'scrolling="no" frameborder=''0'' ', 30, 65, 150, 130, 100, '', '', 'iframe', '', 'mod_box1.js', 'mapframe1', '', 'http://www.mapbender.org/index.php/Overview');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'pan1', 2, 1, 'pan', 'img', '../img/button_gray/pan_off.png', 'onmouseover = "mb_regButton(''init_mod_pan'')" title="Pan"', 270, 10, 24, 24, 1, '', '', '', 'mod_pan.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Pan');
@@ -462,15 +355,29 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'treeGDE', 2, 1, 'dircetory structure, checkbox for visible, checkbox for querylayer', 'iframe', '../html/mod_sync_treefolder.php?sessionID&e_id_css=treeGDE', 'frameborder = "0" ', 1, 1, 1, 1, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/TreeGde');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'WMS_preferences', 2, 1, 'configures the preferences of each loaded wms', 'img', '../img/button_gray/preferences_off.png', 'onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="WMS preferences"', 540, 10, 24, 24, 1, '', '', '', '', '', 'mapframe1,treeGDE', '', 'http://www.mapbender.org/index.php/WMS_preferences');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'zoomFull', 2, 1, 'zoom to full extent button', 'img', '../img/button_gray/zoomFull_off.png', 'onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"  title="Display complete map"', 320, 10, 24, 24, 2, '', '', 'img', 'mod_zoomFull.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'showCoords_div', 2, 1, 'displays coodinates by onmouseover', 'img', '../img/button_gray/coords_off.png', E'onmouseover = \\"mb_regButton(\\''init_mod_showCoords_div\\'')\\" title=\\"Coordinates\\" ', 450, 10, 24, 24, 1, '', '', '', 'mod_coords_div.php', '', 'mapframe1', 'dependendDiv', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'zoomOut1', 2, 1, 'zoomOut button', 'img', '../img/button_gray/zoomOut2_off.png', 'onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' title="Zoom out"', 245, 10, 24, 24, 1, '', '', '', 'mod_zoomOut1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomOut');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'Gazetteer_mbUser', 2, 1, 'a gazetteer for rivers of germany', 'iframe', '../php/mod_wfs_gazetteer.php?sessionID&wfs_conf=1&target=mapframe1,overview&resultFrame=wfsresult', 'frameborder = "0"', 10, 600, 300, 150, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1,overview', 'wz-graphics', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'dragMapSize', 2, 1, 'drag & drop Mapsize', 'div', '', '', 81, -19, NULL, NULL, 2, 'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;', '', 'div', 'mod_dragMapSize.php', '', 'mapframe1', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'setBackground', 2, 1, 'switch background-wms', 'form', '', '', 30, 210, NULL, NULL, 1, '', '<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>', 'form', 'mod_setBackground.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'editElements', 2, 1, 'Edit GUI elements', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 8, 260, 190, 20, 5, '', 'Edit GUI elements', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_Elements');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'zoomIn1', 2, 1, 'zoomIn button', 'img', '../img/button_gray/zoomIn2_off.png', 'onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' title=''Zoom in''', 220, 10, 24, 24, 1, '', '', '', 'mod_zoomIn1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'editGUI_WMS', 2, 1, 'WMS GUI settings', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 8, 180, 190, 20, 5, '', 'WMS GUI settings', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'exportGUI', 2, 1, 'export GUI, create SQL', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 8, 300, 190, 20, 10, '', 'Export GUI (SQL)', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'loadWMSList', 2, 1, 'Link WMS into GUI', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 8, 160, 190, 20, 5, '', 'Link WMS into GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'loadWMS', 2, 1, 'Load Capabilities', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 8, 60, 190, 20, 5, '', 'Load Capabilities', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'CreateTreeGDE', 2, 1, 'TreeGDE set up', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 8, 280, 190, 20, 5, '', 'TreeGDE set up', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'editFilteredGroup', 2, 1, 'Create and edit group', 'a', '', 'href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ', 8, 400, 190, 20, 10, '', 'Create and edit group', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_1d', 3, 1, 'Hintergrund Oberflächenverwaltung', 'div', '', '', 5, 217, 193, 126, 2, '', ' GUI-Verwaltung', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'orphanWMS', 2, 1, 'display orphaned WMS', 'a', '', 'href = "../php/mod_orphanWMS.php?sessionID&&elementID=orphanWMS" target = "AdminFrame"', 10, 930, 200, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'ORPHAN WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/OrphanWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'resizeMapsize', 2, 1, 'resize_mapsize', 'img', '../img/button_blink_red/resizemapsize_off.png', 'onclick = "adjustDimension()"
-onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Kartenfenstergröße optimieren"', 838, 40, 24, 24, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_resize_mapsize.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'treeGDE', 2, 1, 'directory tree, checkbox for visible, checkbox for querylayer,', 'iframe', '../html/mod_treefolder2.php?sessionID', E'frameborder = \\"0\\" ', 10, 220, 200, 300, NULL, 'visibility:visible', '', 'iframe', '', '', 'mapframe1', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'layout_0', 3, 1, 'WMS Management border', 'div', '', '', 3, 35, 193, 90, 1, '', '', 'div', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'layout_1', 3, 1, 'WMS Management caption', 'div', '', '', 5, 37, 193, 86, 2, '', ' WMS Management', 'div', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'layout_1a', 3, 1, 'Configure WMS Access border', 'div', '', '', 3, 135, 193, 70, 1, '', '', 'div', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'layout_1b', 3, 1, 'Configure WMS Access', 'div', '', '', 5, 137, 193, 66, 2, '', ' Configure WMS Access', 'div', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'layout_1c', 3, 1, 'GUI Management border', 'div', '', '', 3, 215, 193, 130, 1, '', '', 'div', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'layout_1d', 3, 1, 'GUI Management caption', 'div', '', '', 5, 217, 193, 126, 2, '', ' GUI Management ', 'div', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'layout_2', 3, 1, 'User Management border', 'div', '', '', 3, 355, 193, 110, 1, '', '', 'div', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'layout_3', 3, 1, 'User Management caption', 'div', '', '', 5, 357, 193, 106, 2, '', ' User Management ', 'div', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'layout_4', 3, 1, 'Authorization background', 'div', '', '', 3, 475, 193, 190, 1, '', '', 'div', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'setPOI2Scale', 2, 1, 'zoom to a poi (get-parameter)', 'div', '', '', 1, 1, 1, 1, NULL, 'visibility:hidden', '', 'div', 'mod_setPOI2Scale.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Mod_setPoi2Scale');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'zoomFull', 2, 1, 'zoom to full extent button', 'img', '../img/button_gray/zoomFull_off.png', 'onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"  title="Display complete map"', 320, 10, 24, 24, 2, '', '', 'img', 'mod_zoomFull.php', '', 'mapframe1', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'body', 1, 1, 'body (obligatory)', 'body', '', 'onload="init()"', NULL, NULL, NULL, NULL, NULL, '', '', '', '', '', '', '', '');
@@ -486,11 +393,13 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'dependentDiv', 2, 1, 'displays infos in a sticky div-tag', 'div', '', '', 81, -19, 1, 1, 0, 'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;', '', 'div', 'mod_dependentDiv.php', '', 'mapframe1', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'dragMapSize', 2, 1, 'drag & drop Mapsize', 'div', '', '', 81, -19, 0, 0, 2, 'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;', '', 'div', 'mod_dragMapSize.php', '', 'mapframe1', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'featureInfo1', 2, 0, 'FeatureInfoRequest', 'img', '../img/button_gray/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfo1'')"', 140, 40, 24, 24, 1, '', '', '', 'mod_featureInfo.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'FeatureInfoRedirect', 2, 1, 'redirect featureInfoRequests in an iframe for each wms', 'iframe', '../html/mod_blank.html', 'frameborder="0"', 83, -17, 1, 1, 0, '', '', 'iframe', 'mod_featureInfoRedirect.php', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'ajax', 6, 1, 'ajax module', 'iframe', '../frames/jquery.html', '', 1, 1, 1, 1, 1, 'visibility:hidden', '', 'iframe', '../javascripts/mb_ajaxWrapper_jQuery.js', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'featureInfoTunnel', 2, 1, 'FeatureInfoRequest with local path', 'img', '../img/button_gray/query_off.png', 'onmouseover = "mb_regButton(''init_featureInfoTunnel'')" title="Query"', 425, 10, 24, 24, 1, '', '', '', 'mod_featureInfoTunnel.php', '', 'mapframe1', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'forward', 2, 1, 'History.forward()', 'img', '../img/button_gray/forward_off_disabled.png', 'onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" title="Forward"', 385, 10, 24, 24, 1, '', '', '', 'mod_forward.php', '', 'mapframe1,overview0', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'layout_5', 3, 1, 'Authorization caption', 'div', '', '', 5, 477, 193, 186, 2, '', ' Authorization', 'div', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'help', 2, 1, 'button help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')" title="help"', 620, 10, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'imprint', 2, 1, 'Information about the owner of the gui', 'iframe', '../html/tab_imprint.html', 'frameborder = "0" ', 1, 1, 1, 1, 5, 'visibility:hidden;', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'delete_filteredGui', 2, 1, 'GUI l&ouml;schen', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 110, 240, 80, 20, 5, '', 'GUI l&ouml;schen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'keyHandler', 2, 1, 'onkeydownevent (only IE)', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_key.php', '', 'mapframe1', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_back', 3, 1, 'layout, background for buttons', 'div', '', '', 360, 10, 51, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_featureInfo', 3, 1, 'layout, background for FeatureInfo', 'div', '', '', 425, 10, 51, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', '');
@@ -564,7 +473,8 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'setBBOX', 2, 0, 'set extent for mapframe and overviewframe', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_setBBOX1.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'showCoords_div', 2, 1, 'displays coodinates by onmouseover', 'img', '../img/button_gray/coords_off.png', 'onmouseover = "mb_regButton(''init_mod_showCoords_div'')" title="Coordinates" ', 450, 10, 24, 24, 1, 'background-color:white; font-family: Arial, Helvetica, sans-serif;font-size:10px;', '', '', 'mod_coords_div.php', '', 'mapframe1', 'dependendDiv', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'resizeMapsize', 2, 1, 'resize mapsize to browser window size', 'img', '../img/button_blink_red/resizemapsize_off.png', E'onclick = \\"adjustDimension()\\"
+onmouseover=\\''this.src = this.src.replace(/_off/,\\"_over\\");\\'' onmouseout=\\''this.src = this.src.replace(/_over/, \\"_off\\");\\'' title=\\"optimize mapsize to browser window\\"', 838, 40, 24, 24, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_resize_mapsize.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ResizeMapsize');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'treeGDE', 2, 1, 'dircetory structure, checkbox for visible, checkbox for querylayer', 'iframe', '../html/mod_sync_treefolder.php?sessionID&e_id_css=treeGDE', 'frameborder = "0" ', 1, 1, 1, 1, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'wfs_conf', 2, 1, 'get all wfs_conf-params', 'iframe', '../php/mod_wfs.php', 'frameborder = "0"', 1, 1, 1, 1, 0, 'visibility:hidden', '', 'iframe', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'wfsresult', 2, 1, 'display the list of wfs results', 'iframe', '../html/mod_blank.html', 'frameborder = "0"', 10, 730, 200, 150, 4, '', '', 'iframe', '', '', '', '', '');
@@ -581,19 +491,47 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'ajax', 6, 1, 'ajax module', 'iframe', '../frames/jquery.html', '', 1, 1, 1, 1, 1, 'visibility:hidden', '', 'iframe', '../javascripts/mb_ajaxWrapper_jQuery.js', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'tabs', 1, 1, 'vertical tabs to handle iframes', 'div', '', '', 10, 240, 200, 20, 2, 'font-family: Arial,Helvetica;font-weight:bold;', '', 'div', 'mod_tab.php', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'showLoggedUser', 2, 0, 'Displays current user', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, 1, 'background-color:lightgrey;', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'gazetteerMetadata', 2, 1, 'gazetteer for metadata', 'iframe', '../php/mod_gazetteerMetadata.php?sessionID&target=mapframe1,overview', 'frameborder = "0"', 1, 1, 1, 1, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1,overview', 'wz-graphics', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'EditWMSMetadata', 2, 1, 'edit the metadata of wms', 'a', '', 'href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"', 10, 950, 250, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT WMS-METADATA', 'a', '', '', '', 'AdminFrame', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'layout_1', 3, 0, 'Warning notice', 'div', '', '', 150, 250, 300, 16, 100, 'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none;', 'Development Version - Work in Progress!', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'wfs_gazetteer', 2, 1, 'a gazetteer for user in the mapbender user map', 'iframe', '../php/mod_wfs_gazetteer.php?sessionID&wfs_conf=1,4,3,2&target=mapframe1,overview&resultFrame=wfsresult', 'frameborder = "0"', 10, 600, 300, 150, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1,overview', 'wz-graphics', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui_digitize', 'Gazetteer_mbUser', 2, 0, 'a gazetteer for user in the mapbender user map', 'iframe', '../php/mod_wfs_gazetteer.php?sessionID&wfs_conf=1&target=mapframe1,overview&resultFrame=wfsresult', 'frameborder = "0"', 10, 600, 300, 150, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1,overview', 'wz-graphics', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'delete_filteredGui', 2, 1, 'Delete GUI', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 120, 240, 80, 20, 5, '', 'Delete GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'ajax', 6, 1, 'ajax module', 'iframe', '../frames/jquery.html', '', 1, 1, 1, 1, 1, 'visibility:hidden', '', 'iframe', '../javascripts/mb_ajaxWrapper_jQuery.js', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'newGui', 2, 1, 'GUI erzeugen', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 8, 240, 85, 20, 5, '', 'GUI erzeugen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'gui_owner', 2, 1, 'GUI editieren Benutzer zuordnen', 'a', '', 'href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame" ', 8, 640, 190, 20, 10, '', 'GUI editieren Benutzer zuordnen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'updateWMSs', 2, 1, 'Hochgeladene aktualisieren', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 8, 80, 190, 20, 5, '', 'Hochgeladene aktualisieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'rename_copy_Gui', 2, 1, 'GUI umbenennen/ kopieren', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 8, 320, 190, 20, 10, '', 'GUI umbenennen/kopieren', 'a', '', '', '', 'AdminFrame', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'CreateTreeGDE', 2, 1, 'Ordnerbaum konfigurieren', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 8, 280, 190, 20, 5, '', 'Ordnerbaum konfigurieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'editFilteredGroup', 2, 1, 'Gruppe anlegen und editieren', 'a', '', 'href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ', 8, 400, 190, 20, 10, '', 'Gruppe anlegen und editieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'editFilteredUser', 2, 1, 'Benutzer anlegen und editieren', 'a', '', 'href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"', 8, 380, 190, 20, 10, '', 'Benutzer anlegen und editieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredGoup_filteredUser', 2, 1, 'Gruppe mit Benutzern best&uuml;cken', 'a', '', 'href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ', 8, 440, 190, 20, 10, '', 'Gruppe mit Benutzern best&uuml;cken ', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'deleteWMS', 2, 1, '!Vollst&auml;ndig l&ouml;schen!', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 8, 100, 190, 20, 5, '', '!Vollst&auml;ndig l&ouml;schen!', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredUser_filteredGroup', 2, 1, 'Benutzer in Gruppen eintragen', 'a', '', 'href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ', 8, 420, 190, 20, 10, '', 'Benutzer in Gruppen eintragen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'editGUI_WMS', 2, 1, 'WMS GUI Einstellungen', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 8, 180, 190, 20, 5, '', 'WMS GUI Einstellungen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'loadWMSList', 2, 1, 'WMS in GUI einbinden', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 8, 160, 190, 20, 5, '', 'WMS in GUI einbinden', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'loadWMS', 2, 1, 'Capabilities hochladen', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 8, 60, 190, 20, 5, '', 'Capabilities hochladen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredUser_filteredGui', 2, 1, 'Einem Nutzer Zugriff auf mehrere Oberflächen erteilen', 'a', '', 'href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ', 8, 500, 190, 25, 10, '', 'Einem Nutzer Zugriff auf <br> mehrere GUIs erteilen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_0', 3, 1, 'Hintergrund WMS Verwaltung Rahmen', 'div', '', '', 3, 35, 193, 90, 1, '', '', 'div', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_1', 3, 1, 'Hintergrund WMS Management', 'div', '', '', 5, 37, 193, 86, 2, '', ' WMS Verwaltung', 'div', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_1a', 3, 1, 'Hintergrund WMS Zuordnung Rahmen', 'div', '', '', 3, 135, 193, 70, 1, '', '', 'div', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_1b', 3, 1, 'Hintergrund WMS Zuordnung', 'div', '', '', 5, 137, 193, 66, 2, '', ' WMS Zuordnung', 'div', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_1c', 3, 1, 'Hintergrund Oberfl&auml;chenverwaltung Rahmen', 'div', '', '', 3, 215, 193, 130, 1, '', '', 'div', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_2', 3, 1, 'Hintergrund Benutzerverwaltung Rahmen', 'div', '', '', 3, 355, 193, 110, 1, '', '', 'div', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_3', 3, 1, 'Hintergrund Benutzerverwaltung', 'div', '', '', 5, 357, 193, 106, 2, '', ' Benutzerverwaltung', 'div', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_4', 3, 1, 'Hintergrund Benutzerzugriff erteilen Rahmen', 'div', '', '', 3, 475, 193, 200, 1, '', '', 'div', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_5', 3, 1, 'Hintergrund Benutzerzugriff erteilen', 'div', '', '', 5, 477, 193, 196, 2, '', ' Benutzerzugriff erteilen', 'div', '', '', '', '', NULL);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'newGui', 2, 1, 'Create new GUI', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 8, 240, 110, 20, 5, '', 'Create new GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
--- TOC entry 1784 (class 0 OID 47913135)
+-- TOC entry 1806 (class 0 OID 47913135)
 -- Dependencies: 1240
 -- Data for Name: gui_element_vars; Type: TABLE DATA; Schema: public; Owner: admin
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'body', 'body_css_file', '../css/admin.css', 'css-file to define the style fo the admin-gui', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'body', 'body_css_file', '../css/admin.css', 'css-file to define the style fo the admin-gui', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'css_file_legend', '../css/legend.css', '', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'legendlink', 'false', '', 'var');
@@ -612,12 +550,22 @@
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'imagedir', '../img/tree_gray', 'image directory', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'ficheckbox', 'false', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'metadatalink', 'false', 'link for layer-metadata', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[6]', '280', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid #FDCC1A;font-size:12;color:#FFFFFF;background-color:#799FEB;cursor:pointer;margin-top:-3px; padding-top:3px;padding-left:4px;', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_Gui', 'file css', '../css/administration_alloc.css', 'file', 'file/css');
@@ -638,23 +586,28 @@
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'gui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'User_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[1]', 'legend', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[2]', 'printPDF', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[4]', 'imprint', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGoup_filteredUser', 'css_file_filteredGroup_filterdUser', '../css/administration_alloc.css', 'file/css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[0]', 'Maps', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[1]', 'Legend', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[2]', 'Print', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[3]', 'WFS Search', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[4]', 'Imprint', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_prefix', '&nbsp;&nbsp;', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[6]', 'gazetteerMetadata', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGroup', 'css_filteredUser_filteredGroup', '../css/administration_alloc.css', 'file/css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'body', 'body_file_css', '../css/admin_service.css', 'file/css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
@@ -665,8 +618,29 @@
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'menu', '', 'context menu elements', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showwmstitle', 'true', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'filteredWms_layer_topic', 'file css', '../css/administration_alloc_4.css', 'css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'filteredWms_layer_topic', 'language', 'de', '', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'cssfile', '../css/treeGDE.css', 'global stylesheets', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'body', 'body_file_css', '../css/admin_service.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'filteredWms_layer_topic', 'file css', '../css/administration_alloc_4.css', 'css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'filteredWms_layer_topic', 'language', 'de', '', 'php_var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
@@ -676,7 +650,9 @@
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'legendlink', 'false', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'logout', 'logout_location', 'http://www.mapbender.org/', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('wms_gdi_de', 'body', 'file css', '../css/mapbender.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
@@ -687,32 +663,24 @@
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_class_bg', 'body{background-color: #FEF8D4;}', 'to define the color of the body', 'text/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[1]', 'legend', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[2]', 'printPDF', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[3]', 'Gazetteer_mbUser', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[4]', 'imprint', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[0]', 'Maps', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[1]', 'Legend', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[2]', 'Print', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[3]', 'WFS Search', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[4]', 'Imprint', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showlayertitle', 'true', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'cssfile', '../css/treeGDE.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[6]', 'Metadata search', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'switchwms', 'true', 'enable/disable all layers of a wms', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'imagedir', '../img/tree_blue', 'image directory', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_prefix', '&nbsp;&nbsp;', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid #FDCC1A;font-size:12;color:#FFFFFF;background-color:#799FEB;cursor:pointer;margin-top:-4px; padding-top:5px;padding-left:8px;', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_height', '-35', 'to adjust the height of the mapframe on the bottom of the window', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_width', '-45', 'to adjust the width of the mapframe on the right side of the window', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'resize_option', 'button', 'auto (autoresize on load), button (resize by button)', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_class_bg', 'body{background-color: #FEF8D4;}', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_ccs_file', '../css/meetingPoint.css', '', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_format', 'prompt', 'decide which format to choose (email, prompt)', 'var');
@@ -732,7 +700,6 @@
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[1]', 'legend', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[2]', 'printPDF', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[3]', 'Gazetteer_mbUser', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[4]', 'imprint', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_prefix', '  ', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;', '', 'var');
@@ -752,19 +719,9 @@
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_width', '25', 'width of the poi_image', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_height', '-35', 'to adjust the height of the mapframe on the bottom of the window', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_width', '-45', 'to adjust the width of the mapframe on the right side of the window', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'resize_option', 'button', 'auto (autoresize on load), button (resize by button)', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'menu', '', 'context menu elements', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'setPOI2Scale', 'mod_setPOI2Scale_defScale', '5000', 'default scale', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
@@ -773,8 +730,6 @@
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'legendlink', 'false', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'cssfile', '../css/treeGDE.css', 'global stylesheets', 'file/css');
@@ -879,18 +834,28 @@
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[4]', 'Imprint', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[5]', 'Digitize', '', 'var');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
 INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'digitize_conf_filename', 'digitize_default.conf', '', 'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[3]', 'wfs_gazetteer', '', 'var');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'var');
--- TOC entry 1785 (class 0 OID 47913143)
+-- TOC entry 1807 (class 0 OID 47913143)
 -- Dependencies: 1241
 -- Data for Name: gui_layer; Type: TABLE DATA; Schema: public; Owner: admin
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9890, 615, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14111, 767, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18218, 882, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19178, 615, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10173, 640, 1, 1, 1, 0, 0, 1002199, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14173, 776, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13775, 101, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13776, 101, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13777, 101, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9891, 615, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 15337, 407, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14190, 778, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9892, 615, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9893, 615, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9894, 615, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
@@ -900,274 +865,132 @@
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9898, 615, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9899, 615, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 9900, 615, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19125, 903, 1, 1, 1, 0, 0, 100, 50000, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19126, 903, 1, 1, 1, 0, 0, 100, 50000, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19127, 903, 1, 1, 1, 1, 1, 1000, 50000, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19128, 903, 1, 1, 1, 0, 0, 1000, 50000, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19129, 903, 1, 1, 1, 0, 0, 1000, 50000, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19130, 903, 1, 1, 1, 0, 0, 1000, 50000, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14173, 776, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19131, 903, 1, 1, 1, 0, 0, 1000, 50000, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19132, 903, 1, 1, 1, 0, 0, 1000, 50000, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19133, 903, 1, 1, 1, 0, 0, 1000, 29999, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14177, 777, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14178, 777, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14179, 777, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14180, 777, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19134, 903, 1, 1, 1, 0, 0, 1000, 50000, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19135, 903, 1, 1, 1, 0, 0, 1000, 50000, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19136, 903, 1, 1, 1, 0, 0, 1000, 50000, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19137, 903, 1, 1, 1, 0, 0, 1000, 50000, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 15337, 407, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14190, 778, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14197, 779, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14198, 779, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14199, 779, 1, 1, 1, 0, 0, 1000000, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14200, 779, 1, 1, 1, 0, 0, 1000000, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14201, 779, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14202, 779, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14203, 779, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14204, 779, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14205, 779, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14206, 779, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14207, 779, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14208, 779, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14209, 779, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14210, 779, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14211, 779, 1, 1, 1, 0, 0, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14212, 779, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14213, 779, 1, 1, 1, 0, 0, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14214, 779, 1, 1, 1, 0, 0, 0, 0, 17, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14215, 779, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14216, 779, 1, 1, 1, 0, 0, 0, 0, 19, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14217, 779, 1, 1, 1, 0, 0, 0, 0, 20, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14218, 779, 1, 1, 1, 0, 0, 0, 0, 21, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14219, 779, 1, 1, 1, 0, 0, 0, 0, 22, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14220, 779, 1, 1, 1, 0, 0, 0, 0, 23, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14221, 779, 1, 1, 1, 0, 0, 0, 0, 24, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14222, 779, 1, 1, 1, 0, 0, 0, 0, 25, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14223, 779, 1, 1, 1, 0, 0, 0, 0, 26, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14224, 779, 1, 1, 1, 0, 0, 0, 0, 27, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14225, 779, 1, 1, 1, 0, 0, 0, 0, 28, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14226, 779, 1, 1, 1, 0, 0, 0, 0, 29, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14227, 779, 1, 1, 1, 0, 0, 0, 0, 30, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 14228, 779, 1, 1, 1, 0, 0, 0, 0, 31, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11541, 706, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11542, 706, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11543, 706, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11544, 706, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11545, 706, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11546, 706, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11547, 706, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 10106, 634, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 10107, 634, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 10108, 634, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 10109, 634, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 10110, 634, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13667, 739, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13668, 739, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13669, 739, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13670, 739, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19209, 785, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14252, 785, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14253, 785, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14254, 785, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 19251, 832, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19272, 867, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18155, 869, 1, 1, 1, 1, 1, 0, 150214, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18142, 867, 1, 1, 1, 1, 1, 22497, 0, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14928, 842, 1, 1, 1, 1, 1, 0, 0, 34, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14929, 842, 1, 1, 1, 1, 1, 0, 0, 35, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14930, 842, 1, 1, 1, 1, 1, 0, 0, 36, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14931, 842, 1, 1, 1, 0, 0, 0, 0, 37, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14932, 842, 1, 1, 1, 1, 1, 0, 0, 38, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14933, 842, 1, 1, 1, 1, 1, 0, 0, 39, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19306, 841, 1, 1, 1, 0, 0, 0, 0, 66, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19307, 841, 1, 1, 1, 0, 0, 0, 0, 67, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19355, 824, 1, 1, 1, 0, 0, 0, 0, 47, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 15338, 407, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13671, 739, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13672, 739, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13673, 739, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13674, 739, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13675, 739, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13676, 739, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13677, 739, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13678, 739, 1, 1, 1, 1, 1, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13679, 739, 1, 1, 1, 1, 1, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13680, 739, 1, 1, 1, 1, 1, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13681, 739, 1, 1, 1, 1, 1, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13682, 739, 1, 1, 1, 1, 1, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13683, 739, 1, 1, 1, 1, 1, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13684, 739, 1, 1, 1, 1, 1, 0, 0, 17, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13685, 739, 1, 1, 1, 1, 1, 0, 0, 18, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13686, 739, 1, 1, 1, 1, 1, 0, 0, 19, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13687, 739, 1, 1, 1, 1, 1, 0, 0, 20, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13688, 739, 1, 1, 1, 1, 1, 0, 0, 21, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13689, 739, 1, 1, 1, 1, 1, 0, 0, 22, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13690, 739, 1, 1, 1, 1, 1, 0, 0, 23, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13691, 739, 1, 1, 1, 1, 1, 0, 0, 24, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13692, 739, 1, 1, 1, 1, 1, 0, 0, 25, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13693, 739, 1, 1, 1, 1, 1, 0, 0, 26, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13694, 739, 1, 1, 1, 1, 1, 0, 0, 27, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13695, 739, 1, 1, 1, 1, 1, 0, 0, 28, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13696, 739, 1, 1, 1, 1, 1, 0, 0, 29, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13697, 739, 1, 1, 1, 1, 1, 0, 0, 30, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13698, 739, 1, 1, 1, 1, 1, 0, 0, 31, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13699, 739, 1, 1, 1, 1, 1, 0, 0, 32, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13700, 739, 1, 1, 1, 1, 1, 0, 0, 33, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13701, 739, 1, 1, 1, 1, 1, 0, 0, 34, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13702, 739, 1, 1, 1, 1, 1, 0, 0, 35, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13703, 739, 1, 1, 1, 1, 1, 0, 0, 36, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13704, 739, 1, 1, 1, 1, 1, 0, 0, 37, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13705, 739, 1, 1, 1, 1, 1, 0, 0, 38, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13706, 739, 1, 1, 1, 1, 1, 0, 0, 39, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13707, 739, 1, 1, 1, 1, 1, 0, 0, 40, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13708, 739, 1, 1, 1, 1, 1, 0, 0, 41, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13709, 739, 1, 1, 1, 1, 1, 0, 0, 42, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13710, 739, 1, 1, 1, 1, 1, 0, 0, 43, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13711, 739, 1, 1, 1, 1, 1, 0, 0, 44, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13712, 739, 1, 1, 1, 1, 1, 0, 0, 45, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13713, 739, 1, 1, 1, 1, 1, 0, 0, 46, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13714, 739, 1, 1, 1, 1, 1, 0, 0, 47, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13715, 739, 1, 1, 1, 1, 1, 0, 0, 48, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13716, 739, 1, 1, 1, 1, 1, 0, 0, 49, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13717, 739, 1, 1, 1, 1, 1, 0, 0, 50, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13718, 739, 1, 1, 1, 1, 1, 0, 0, 51, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13719, 739, 1, 1, 1, 1, 1, 0, 0, 52, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13720, 739, 1, 1, 1, 1, 1, 0, 0, 53, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13721, 739, 1, 1, 1, 1, 1, 0, 0, 54, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13722, 739, 1, 1, 1, 1, 1, 0, 0, 55, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13723, 739, 1, 1, 1, 1, 1, 0, 0, 56, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13724, 739, 1, 1, 1, 1, 1, 0, 0, 57, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13725, 739, 1, 1, 1, 1, 1, 0, 0, 58, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13726, 739, 1, 1, 1, 1, 1, 0, 0, 59, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13727, 739, 1, 1, 1, 1, 1, 0, 0, 60, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13728, 739, 1, 1, 1, 1, 1, 0, 0, 61, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13729, 739, 1, 1, 1, 1, 1, 0, 0, 62, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13730, 739, 1, 1, 1, 1, 1, 0, 0, 63, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13731, 739, 1, 1, 1, 1, 1, 0, 0, 64, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13732, 739, 1, 1, 1, 1, 1, 0, 0, 65, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13733, 739, 1, 1, 1, 1, 1, 0, 0, 66, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13734, 739, 1, 1, 1, 1, 1, 0, 0, 67, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13735, 739, 1, 1, 1, 1, 1, 0, 0, 68, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13736, 739, 1, 1, 1, 1, 1, 0, 0, 69, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13737, 739, 1, 1, 1, 1, 1, 0, 0, 70, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13738, 739, 1, 1, 1, 1, 1, 0, 0, 71, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13739, 739, 1, 1, 1, 1, 1, 0, 0, 72, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13740, 739, 1, 1, 1, 1, 1, 0, 0, 73, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13741, 739, 1, 1, 1, 1, 1, 0, 0, 74, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13742, 739, 1, 1, 1, 1, 1, 0, 0, 75, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13743, 739, 1, 1, 1, 1, 1, 0, 0, 76, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 13744, 739, 1, 1, 1, 1, 1, 0, 0, 77, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 11629, 717, 1, 1, 1, 1, 1, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19176, 250, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19176, 250, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19176, 250, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19176, 250, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2713, 250, 1, 1, 1, 1, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2713, 250, 1, 1, 1, 1, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2714, 250, 1, 1, 1, 1, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2715, 250, 1, 1, 1, 1, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2715, 250, 1, 1, 1, 1, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2716, 250, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2716, 250, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2717, 250, 1, 1, 1, 1, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2717, 250, 1, 1, 1, 1, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2718, 250, 1, 1, 1, 1, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2718, 250, 1, 1, 1, 1, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2719, 250, 1, 1, 1, 1, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2719, 250, 1, 1, 1, 1, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2720, 250, 1, 1, 1, 1, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2720, 250, 1, 1, 1, 1, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2721, 250, 1, 1, 1, 1, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2721, 250, 1, 1, 1, 1, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2722, 250, 1, 1, 1, 1, 0, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2722, 250, 1, 1, 1, 1, 0, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2723, 250, 1, 1, 1, 1, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2723, 250, 1, 1, 1, 1, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2723, 250, 1, 1, 1, 1, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2724, 250, 1, 1, 1, 1, 0, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2724, 250, 1, 1, 1, 1, 0, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2724, 250, 1, 1, 1, 1, 0, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2725, 250, 1, 1, 1, 1, 0, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2725, 250, 1, 1, 1, 1, 0, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2725, 250, 1, 1, 1, 1, 0, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2726, 250, 1, 1, 1, 1, 0, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2726, 250, 1, 1, 1, 1, 0, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2726, 250, 1, 1, 1, 1, 0, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2727, 250, 1, 1, 1, 1, 0, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2727, 250, 1, 1, 1, 1, 0, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2727, 250, 1, 1, 1, 1, 0, 0, 0, 15, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2727, 250, 1, 1, 1, 1, 0, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2728, 250, 1, 1, 1, 1, 0, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2728, 250, 1, 1, 1, 1, 0, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2728, 250, 1, 1, 1, 1, 0, 0, 0, 16, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2728, 250, 1, 1, 1, 1, 0, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2729, 250, 1, 1, 1, 1, 0, 0, 0, 17, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2729, 250, 1, 1, 1, 1, 0, 0, 0, 17, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2729, 250, 1, 1, 1, 1, 0, 0, 0, 17, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2729, 250, 1, 1, 1, 1, 0, 0, 0, 17, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2730, 250, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2730, 250, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2730, 250, 1, 1, 1, 0, 0, 0, 0, 18, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2730, 250, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2731, 250, 1, 1, 1, 1, 0, 0, 0, 19, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2731, 250, 1, 1, 1, 1, 0, 0, 0, 19, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2731, 250, 1, 1, 1, 1, 0, 0, 0, 19, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2731, 250, 1, 1, 1, 1, 0, 0, 0, 19, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2732, 250, 1, 1, 1, 1, 0, 0, 0, 20, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2732, 250, 1, 1, 1, 1, 0, 0, 0, 20, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2732, 250, 1, 1, 1, 1, 0, 0, 0, 20, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2732, 250, 1, 1, 1, 1, 0, 0, 0, 20, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19208, 717, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19208, 717, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 11630, 717, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3401, 329, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3402, 329, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3403, 329, 1, 1, 1, 0, 0, 1, 50000, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3404, 329, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3405, 329, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3406, 329, 1, 1, 1, 0, 0, 1, 2500, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3407, 329, 1, 1, 1, 0, 0, 1, 2500, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3408, 329, 1, 1, 1, 0, 0, 1, 2500, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3409, 329, 1, 1, 1, 0, 0, 1, 2500, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10028, 624, 1, 1, 1, 1, 1, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10029, 624, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10030, 624, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10031, 624, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10032, 624, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10033, 624, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10034, 624, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10035, 624, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10036, 624, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10037, 624, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10038, 624, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10039, 624, 1, 1, 1, 1, 1, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10040, 624, 1, 1, 1, 1, 1, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10041, 624, 1, 1, 1, 1, 1, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10042, 624, 1, 1, 1, 1, 1, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10043, 624, 1, 1, 1, 1, 1, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10044, 624, 1, 1, 1, 1, 1, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10045, 624, 1, 1, 1, 1, 1, 0, 0, 17, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10046, 624, 1, 1, 1, 1, 1, 0, 0, 18, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10369, 648, 1, 1, 1, 1, 1, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10370, 648, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10371, 648, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 19253, 836, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 19274, 837, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14870, 841, 1, 1, 1, 0, 0, 0, 0, 19, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14871, 841, 1, 1, 1, 0, 0, 0, 0, 20, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14872, 841, 1, 1, 1, 0, 0, 0, 0, 21, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14873, 841, 1, 1, 1, 0, 0, 0, 0, 22, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14874, 841, 1, 1, 1, 0, 0, 0, 0, 23, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14875, 841, 1, 1, 1, 0, 0, 0, 0, 24, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14876, 841, 1, 1, 1, 0, 0, 0, 0, 25, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19294, 841, 1, 1, 1, 0, 0, 0, 0, 39, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14877, 841, 1, 1, 1, 0, 0, 0, 0, 26, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14878, 841, 1, 1, 1, 0, 0, 0, 0, 27, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19298, 841, 1, 1, 1, 0, 0, 0, 0, 45, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19299, 841, 1, 1, 1, 0, 0, 0, 0, 46, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3470, 336, 1, 1, 1, 0, 0, 138, 27683, 0, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3471, 336, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3472, 336, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3384, 328, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3385, 328, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3386, 328, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3387, 328, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3388, 328, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3389, 328, 1, 1, 1, 1, 1, 0, 100220, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3390, 328, 1, 1, 1, 1, 1, 0, 53451, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3391, 328, 1, 1, 1, 1, 1, 0, 24720, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3392, 328, 1, 1, 1, 1, 1, 0, 24720, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3393, 328, 1, 1, 1, 1, 1, 0, 233847, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3394, 328, 1, 1, 1, 1, 1, 0, 53451, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3395, 328, 1, 1, 1, 1, 1, 0, 24720, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3396, 328, 1, 1, 1, 1, 1, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3397, 328, 1, 1, 1, 1, 1, 0, 53451, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3398, 328, 1, 1, 1, 1, 1, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3399, 328, 1, 1, 1, 1, 1, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3400, 328, 1, 1, 1, 0, 0, 0, 24720, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 5575, 486, 1, 1, 1, 0, 0, 1, 1000000000, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 5576, 486, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 5577, 486, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 5578, 486, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14104, 767, 1, 1, 1, 0, 0, 500, 250001, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14105, 767, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14106, 767, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14107, 767, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14108, 767, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14109, 767, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14110, 767, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14111, 767, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14112, 767, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14113, 767, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14114, 767, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14115, 767, 1, 1, 1, 1, 1, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10987, 670, 1, 1, 1, 1, 1, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10988, 670, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10989, 670, 1, 1, 1, 0, 0, 37494, 187472, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10990, 670, 1, 1, 1, 0, 0, 37494, 187472, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10991, 671, 1, 1, 1, 1, 1, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10992, 671, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10993, 671, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10994, 671, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10995, 671, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14029, 760, 1, 1, 1, 1, 1, 25001, 0, 1, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14034, 760, 1, 1, 1, 0, 0, 25001, 150000, 6, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14037, 760, 1, 1, 1, 0, 0, 25001, 100000, 9, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14038, 760, 1, 1, 1, 0, 0, 25001, 250001, 10, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14039, 760, 1, 1, 1, 0, 0, 25001, 749999, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2712, 250, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14059, 762, 1, 1, 1, 0, 0, 100, 50000, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2713, 250, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14061, 762, 1, 1, 1, 0, 0, 1000, 50000, 3, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14062, 762, 1, 1, 1, 0, 0, 1000, 50000, 4, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14063, 762, 1, 1, 1, 0, 0, 1000, 50000, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2714, 250, 1, 1, 1, 1, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2715, 250, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14066, 762, 1, 1, 1, 0, 0, 1000, 50000, 8, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14067, 762, 1, 1, 1, 0, 0, 1000, 20000, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2716, 250, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2717, 250, 1, 1, 1, 1, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2718, 250, 1, 1, 1, 1, 0, 0, 0, 6, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14007, 758, 1, 1, 1, 1, 1, 200000, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2719, 250, 1, 1, 1, 1, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2720, 250, 1, 1, 1, 1, 0, 0, 0, 8, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14010, 758, 1, 1, 1, 0, 0, 200000, 749999, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2721, 250, 1, 1, 1, 1, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2722, 250, 1, 1, 1, 1, 0, 0, 0, 10, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14013, 758, 1, 1, 1, 0, 0, 200000, 400000, 7, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14014, 758, 1, 1, 1, 0, 0, 200000, 1000000, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2723, 250, 1, 1, 1, 1, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2724, 250, 1, 1, 1, 1, 0, 0, 0, 12, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14082, 764, 1, 1, 1, 0, 0, 50000, 0, 0, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14083, 764, 1, 1, 1, 1, 1, 50000, 0, 1, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14084, 764, 1, 1, 1, 1, 1, 50000, 0, 2, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14085, 764, 1, 1, 1, 1, 1, 50000, 0, 3, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14086, 764, 1, 1, 1, 1, 1, 50000, 0, 4, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14087, 764, 1, 1, 1, 1, 1, 50000, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2725, 250, 1, 1, 1, 1, 0, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2726, 250, 1, 1, 1, 1, 0, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2727, 250, 1, 1, 1, 1, 0, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2728, 250, 1, 1, 1, 1, 0, 0, 0, 16, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14092, 765, 1, 1, 1, 1, 1, 50000, 1000000, 4, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14093, 765, 1, 1, 1, 1, 1, 50000, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2729, 250, 1, 1, 1, 1, 0, 0, 0, 17, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2730, 250, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2731, 250, 1, 1, 1, 1, 0, 0, 0, 19, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2732, 250, 1, 1, 1, 1, 0, 0, 0, 20, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10165, 640, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14099, 765, 1, 1, 1, 0, 0, 50000, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10166, 640, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7491, 583, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7492, 583, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7493, 583, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
@@ -1194,43 +1017,7 @@
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7514, 583, 1, 1, 1, 1, 1, 0, 0, 23, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7515, 583, 1, 1, 1, 1, 1, 0, 0, 24, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7516, 583, 1, 1, 1, 1, 1, 0, 0, 25, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7517, 584, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7518, 584, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7519, 584, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7520, 584, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7521, 584, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7522, 584, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7523, 584, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7524, 584, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7525, 584, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7526, 584, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7527, 584, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10415, 655, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10416, 655, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10417, 655, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10418, 655, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10419, 655, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10420, 655, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10421, 655, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10422, 655, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10423, 655, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10424, 655, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10167, 640, 1, 1, 0, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10425, 655, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10426, 655, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10427, 655, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10428, 655, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10429, 655, 1, 1, 1, 0, 0, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10430, 655, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10431, 655, 1, 1, 1, 0, 0, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10432, 655, 1, 1, 1, 0, 0, 0, 0, 17, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10433, 655, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10434, 655, 1, 1, 1, 0, 0, 0, 0, 19, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10435, 655, 1, 1, 1, 0, 0, 0, 0, 20, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10436, 655, 1, 1, 1, 0, 0, 0, 0, 21, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10437, 655, 1, 1, 1, 0, 0, 0, 0, 22, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10438, 655, 1, 1, 1, 0, 0, 0, 0, 23, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10439, 655, 1, 1, 1, 0, 0, 0, 0, 24, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 2714, 250, 1, 1, 1, 1, 0, 0, 0, 2, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9877, 614, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9878, 614, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9879, 614, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
@@ -1244,47 +1031,35 @@
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9887, 614, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9888, 614, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9889, 614, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9901, 616, 1, 1, 1, 1, 1, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9902, 616, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9903, 616, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9904, 616, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9905, 616, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9906, 616, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9907, 616, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9908, 616, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9909, 616, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9910, 616, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9911, 616, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9912, 616, 1, 1, 1, 1, 1, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9913, 616, 1, 1, 1, 1, 1, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9914, 616, 1, 1, 1, 1, 1, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9915, 616, 1, 1, 1, 1, 1, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9916, 616, 1, 1, 1, 1, 1, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9917, 616, 1, 1, 1, 1, 1, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9918, 616, 1, 1, 1, 1, 1, 0, 0, 17, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9919, 616, 1, 1, 1, 1, 1, 0, 0, 18, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9920, 616, 1, 1, 1, 1, 1, 0, 0, 19, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9921, 617, 1, 1, 1, 1, 1, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9922, 617, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9923, 617, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9924, 617, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9925, 617, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9926, 617, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9927, 617, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9928, 617, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 9929, 617, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13751, 86, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13752, 86, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13753, 86, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13754, 86, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13755, 86, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10047, 625, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10048, 625, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10049, 625, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10048, 625, 1, 1, 1, 1, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10049, 625, 1, 1, 1, 1, 0, 0, 0, 2, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10050, 625, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10051, 625, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10052, 625, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10053, 625, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10054, 625, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10055, 625, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10056, 625, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10051, 625, 1, 1, 1, 1, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10052, 625, 1, 1, 1, 1, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14104, 767, 1, 1, 1, 0, 0, 500, 62500, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19213, 767, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10053, 625, 1, 1, 1, 1, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10054, 625, 1, 1, 1, 1, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14105, 767, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10055, 625, 1, 1, 1, 1, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10056, 625, 1, 1, 1, 1, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14106, 767, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10057, 625, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10058, 625, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14107, 767, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10058, 625, 1, 1, 1, 1, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14108, 767, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14109, 767, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14110, 767, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14112, 767, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14113, 767, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14114, 767, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14115, 767, 1, 1, 1, 1, 1, 0, 0, 11, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10194, 645, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10195, 645, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10196, 645, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
@@ -1292,10 +1067,14 @@
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10198, 645, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10199, 645, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10200, 645, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7255, 525, 1, 1, 1, 0, 0, 0, 119999880, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7256, 525, 0, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7257, 525, 0, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7258, 525, 1, 1, 1, 0, 0, 0, 11999988, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 5575, 486, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7255, 525, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 5576, 486, 1, 1, 1, 0, 0, 750000, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7256, 525, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 5577, 486, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7257, 525, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 5578, 486, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7258, 525, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7259, 525, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7260, 525, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7261, 525, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
@@ -1305,304 +1084,117 @@
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7265, 525, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7266, 525, 1, 1, 1, 1, 1, 0, 0, 11, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7267, 525, 1, 1, 1, 1, 1, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9663, 612, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9664, 612, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9665, 612, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9666, 612, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9667, 612, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9668, 612, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9669, 612, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9670, 612, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9671, 612, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9672, 612, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9673, 612, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9674, 612, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9675, 612, 1, 1, 1, 1, 1, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9676, 612, 1, 1, 1, 1, 1, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9677, 612, 1, 1, 1, 1, 1, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9678, 612, 1, 1, 1, 1, 1, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9679, 612, 1, 1, 1, 1, 1, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9680, 612, 1, 1, 1, 1, 1, 0, 0, 17, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9681, 612, 1, 1, 1, 1, 1, 0, 0, 18, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9682, 612, 1, 1, 1, 1, 1, 0, 0, 19, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9683, 612, 1, 1, 1, 1, 1, 0, 0, 20, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9684, 612, 1, 1, 1, 1, 1, 0, 0, 21, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9685, 612, 1, 1, 1, 1, 1, 0, 0, 22, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9686, 612, 1, 1, 1, 1, 1, 0, 0, 23, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9687, 612, 1, 1, 1, 0, 0, 0, 0, 24, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9688, 612, 1, 1, 1, 1, 1, 0, 0, 25, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9689, 612, 1, 1, 1, 1, 1, 0, 0, 26, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9690, 612, 1, 1, 1, 0, 0, 0, 0, 27, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9691, 612, 1, 1, 1, 1, 1, 0, 0, 28, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9692, 612, 1, 1, 1, 1, 1, 0, 0, 29, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9693, 612, 1, 1, 1, 0, 0, 0, 0, 30, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9694, 612, 1, 1, 1, 1, 1, 0, 0, 31, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9695, 612, 1, 1, 1, 1, 1, 0, 0, 32, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9696, 612, 1, 1, 1, 0, 0, 0, 0, 33, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9697, 612, 1, 1, 1, 1, 1, 0, 0, 34, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9698, 612, 1, 1, 1, 1, 1, 0, 0, 35, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9699, 612, 1, 1, 1, 1, 1, 0, 0, 36, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9700, 612, 1, 1, 1, 1, 1, 0, 0, 37, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9701, 612, 1, 1, 1, 0, 0, 0, 0, 38, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9702, 612, 1, 1, 1, 1, 1, 0, 0, 39, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9703, 612, 1, 1, 1, 1, 1, 0, 0, 40, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9704, 612, 1, 1, 1, 1, 1, 0, 0, 41, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9705, 612, 1, 1, 1, 0, 0, 0, 0, 42, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9706, 612, 1, 1, 1, 1, 1, 0, 0, 43, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9707, 612, 1, 1, 1, 0, 0, 0, 0, 44, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9708, 612, 1, 1, 1, 1, 1, 0, 0, 45, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9709, 612, 1, 1, 1, 1, 1, 0, 0, 46, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9710, 612, 1, 1, 1, 1, 1, 0, 0, 47, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9711, 612, 1, 1, 1, 1, 1, 0, 0, 48, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9712, 612, 1, 1, 1, 1, 1, 0, 0, 49, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9713, 612, 1, 1, 1, 1, 1, 0, 0, 50, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9714, 612, 1, 1, 1, 1, 1, 0, 0, 51, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9715, 612, 1, 1, 1, 0, 0, 0, 0, 52, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9716, 612, 1, 1, 1, 1, 1, 0, 0, 53, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9717, 612, 1, 1, 1, 1, 1, 0, 0, 54, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9718, 612, 1, 1, 1, 1, 1, 0, 0, 55, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9719, 612, 1, 1, 1, 1, 1, 0, 0, 56, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9720, 612, 1, 1, 1, 1, 1, 0, 0, 57, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9721, 612, 1, 1, 1, 1, 1, 0, 0, 58, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9722, 612, 1, 1, 1, 0, 0, 0, 0, 59, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9723, 612, 1, 1, 1, 1, 1, 0, 0, 60, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9724, 612, 1, 1, 1, 1, 1, 0, 0, 61, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9725, 612, 1, 1, 1, 1, 1, 0, 0, 62, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9726, 612, 1, 1, 1, 1, 1, 0, 0, 63, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9727, 612, 1, 1, 1, 1, 1, 0, 0, 64, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9728, 612, 1, 1, 1, 0, 0, 0, 0, 65, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9729, 612, 1, 1, 1, 1, 1, 0, 0, 66, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9730, 612, 1, 1, 1, 1, 1, 0, 0, 67, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9731, 612, 1, 1, 1, 1, 1, 0, 0, 68, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9732, 612, 1, 1, 1, 1, 1, 0, 0, 69, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9733, 612, 1, 1, 1, 1, 1, 0, 0, 70, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9734, 612, 1, 1, 1, 0, 0, 0, 0, 71, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9735, 612, 1, 1, 1, 1, 1, 0, 0, 72, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9736, 612, 1, 1, 1, 1, 1, 0, 0, 73, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9737, 612, 1, 1, 1, 1, 1, 0, 0, 74, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9738, 612, 1, 1, 1, 1, 1, 0, 0, 75, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9739, 612, 1, 1, 1, 1, 1, 0, 0, 76, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9740, 612, 1, 1, 1, 1, 1, 0, 0, 77, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9741, 612, 1, 1, 1, 1, 1, 0, 0, 78, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9742, 612, 1, 1, 1, 1, 1, 0, 0, 79, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9743, 612, 1, 1, 1, 1, 1, 0, 0, 80, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9744, 612, 1, 1, 1, 1, 1, 0, 0, 81, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9745, 612, 1, 1, 1, 0, 0, 0, 0, 82, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9746, 612, 1, 1, 1, 1, 1, 0, 0, 83, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9747, 612, 1, 1, 1, 1, 1, 0, 0, 84, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9748, 612, 1, 1, 1, 1, 1, 0, 0, 85, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9749, 612, 1, 1, 1, 1, 1, 0, 0, 86, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9750, 612, 1, 1, 1, 1, 1, 0, 0, 87, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9751, 612, 1, 1, 1, 0, 0, 0, 0, 88, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9752, 612, 1, 1, 1, 1, 1, 0, 0, 89, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9753, 612, 1, 1, 1, 1, 1, 0, 0, 90, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9754, 612, 1, 1, 1, 1, 1, 0, 0, 91, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9755, 612, 1, 1, 1, 1, 1, 0, 0, 92, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9756, 612, 1, 1, 1, 1, 1, 0, 0, 93, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9757, 612, 1, 1, 1, 0, 0, 0, 0, 94, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9758, 612, 1, 1, 1, 0, 0, 0, 0, 95, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9759, 612, 1, 1, 1, 0, 0, 0, 0, 96, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9760, 612, 1, 1, 1, 1, 1, 0, 0, 97, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9761, 612, 1, 1, 1, 1, 1, 0, 0, 98, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9762, 612, 1, 1, 1, 1, 1, 0, 0, 99, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9763, 612, 1, 1, 1, 1, 1, 0, 0, 100, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9764, 612, 1, 1, 1, 1, 1, 0, 0, 101, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9765, 612, 1, 1, 1, 1, 1, 0, 0, 102, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9766, 612, 1, 1, 1, 1, 1, 0, 0, 103, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9767, 612, 1, 1, 1, 1, 1, 0, 0, 104, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9768, 612, 1, 1, 1, 0, 0, 0, 0, 105, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9769, 612, 1, 1, 1, 1, 1, 0, 0, 106, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9770, 612, 1, 1, 1, 1, 1, 0, 0, 107, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9771, 612, 1, 1, 1, 0, 0, 0, 0, 108, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9772, 612, 1, 1, 1, 1, 1, 0, 0, 109, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9773, 612, 1, 1, 1, 1, 1, 0, 0, 110, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9774, 612, 1, 1, 1, 1, 1, 0, 0, 111, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9775, 612, 1, 1, 1, 0, 0, 0, 0, 112, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9776, 612, 1, 1, 1, 1, 1, 0, 0, 113, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9777, 612, 1, 1, 1, 1, 1, 0, 0, 114, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9778, 612, 1, 1, 1, 0, 0, 0, 0, 115, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9779, 612, 1, 1, 1, 1, 1, 0, 0, 116, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9780, 612, 1, 1, 1, 1, 1, 0, 0, 117, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9781, 612, 1, 1, 1, 1, 1, 0, 0, 118, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9782, 612, 1, 1, 1, 1, 1, 0, 0, 119, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9783, 612, 1, 1, 1, 1, 1, 0, 0, 120, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9784, 612, 1, 1, 1, 1, 1, 0, 0, 121, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9785, 612, 1, 1, 1, 1, 1, 0, 0, 122, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9786, 612, 1, 1, 1, 0, 0, 0, 0, 123, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9787, 612, 1, 1, 1, 1, 1, 0, 0, 124, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9788, 612, 1, 1, 1, 1, 1, 0, 0, 125, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9789, 612, 1, 1, 1, 1, 1, 0, 0, 126, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9790, 612, 1, 1, 1, 1, 1, 0, 0, 127, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9791, 612, 1, 1, 1, 1, 1, 0, 0, 128, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9792, 612, 1, 1, 1, 1, 1, 0, 0, 129, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9793, 612, 1, 1, 1, 0, 0, 0, 0, 130, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9794, 612, 1, 1, 1, 1, 1, 0, 0, 131, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9795, 612, 1, 1, 1, 1, 1, 0, 0, 132, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9796, 612, 1, 1, 1, 1, 1, 0, 0, 133, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9797, 612, 1, 1, 1, 1, 1, 0, 0, 134, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9798, 612, 1, 1, 1, 1, 1, 0, 0, 135, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9799, 612, 1, 1, 1, 0, 0, 0, 0, 136, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9800, 612, 1, 1, 1, 1, 1, 0, 0, 137, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9801, 612, 1, 1, 1, 1, 1, 0, 0, 138, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9802, 612, 1, 1, 1, 1, 1, 0, 0, 139, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9803, 612, 1, 1, 1, 1, 1, 0, 0, 140, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9804, 612, 1, 1, 1, 1, 1, 0, 0, 141, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9805, 612, 1, 1, 1, 0, 0, 0, 0, 142, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9806, 612, 1, 1, 1, 1, 1, 0, 0, 143, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9807, 612, 1, 1, 1, 1, 1, 0, 0, 144, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9808, 612, 1, 1, 1, 1, 1, 0, 0, 145, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9809, 612, 1, 1, 1, 1, 1, 0, 0, 146, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9810, 612, 1, 1, 1, 1, 1, 0, 0, 147, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9811, 612, 1, 1, 1, 1, 1, 0, 0, 148, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9812, 612, 1, 1, 1, 1, 1, 0, 0, 149, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9813, 612, 1, 1, 1, 1, 1, 0, 0, 150, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9814, 612, 1, 1, 1, 1, 1, 0, 0, 151, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9815, 612, 1, 1, 1, 1, 1, 0, 0, 152, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9816, 612, 1, 1, 1, 0, 0, 0, 0, 153, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9817, 612, 1, 1, 1, 1, 1, 0, 0, 154, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9818, 612, 1, 1, 1, 1, 1, 0, 0, 155, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9819, 612, 1, 1, 1, 1, 1, 0, 0, 156, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9820, 612, 1, 1, 1, 1, 1, 0, 0, 157, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9821, 612, 1, 1, 1, 1, 1, 0, 0, 158, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9822, 612, 1, 1, 1, 0, 0, 0, 0, 159, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9823, 612, 1, 1, 1, 1, 1, 0, 0, 160, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9824, 612, 1, 1, 1, 1, 1, 0, 0, 161, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9825, 612, 1, 1, 1, 1, 1, 0, 0, 162, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9826, 612, 1, 1, 1, 1, 1, 0, 0, 163, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9827, 612, 1, 1, 1, 1, 1, 0, 0, 164, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9828, 612, 1, 1, 1, 0, 0, 0, 0, 165, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9829, 612, 1, 1, 1, 0, 0, 0, 0, 166, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9830, 612, 1, 1, 1, 1, 1, 0, 0, 167, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9831, 612, 1, 1, 1, 1, 1, 0, 0, 168, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9832, 612, 1, 1, 1, 0, 0, 0, 0, 169, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9833, 612, 1, 1, 1, 0, 0, 0, 0, 170, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9834, 612, 1, 1, 1, 1, 1, 0, 0, 171, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9835, 612, 1, 1, 1, 1, 1, 0, 0, 172, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9836, 612, 1, 1, 1, 0, 0, 0, 0, 173, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9837, 612, 1, 1, 1, 1, 1, 0, 0, 174, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9838, 612, 1, 1, 1, 1, 1, 0, 0, 175, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9839, 612, 1, 1, 1, 1, 1, 0, 0, 176, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9840, 612, 1, 1, 1, 1, 1, 0, 0, 177, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9841, 612, 1, 1, 1, 1, 1, 0, 0, 178, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9842, 612, 1, 1, 1, 0, 0, 0, 0, 179, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9843, 612, 1, 1, 1, 1, 1, 0, 0, 180, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9844, 612, 1, 1, 1, 1, 1, 0, 0, 181, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9845, 612, 1, 1, 1, 1, 1, 0, 0, 182, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9846, 612, 1, 1, 1, 0, 0, 0, 0, 183, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9847, 612, 1, 1, 1, 1, 1, 0, 2147483647, 184, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9848, 612, 1, 1, 1, 1, 1, 0, 0, 185, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9849, 612, 1, 1, 1, 1, 1, 0, 2147483647, 186, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9850, 612, 1, 1, 1, 1, 1, 0, 2147483647, 187, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9851, 612, 1, 1, 1, 1, 1, 0, 2147483647, 188, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9852, 612, 1, 1, 1, 1, 1, 0, 2147483647, 189, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9853, 612, 1, 1, 1, 1, 1, 0, 2147483647, 190, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9854, 612, 1, 1, 1, 1, 1, 0, 2147483647, 191, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9855, 612, 1, 1, 1, 1, 1, 0, 2147483647, 192, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9856, 612, 1, 1, 1, 1, 1, 0, 2147483647, 193, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9857, 612, 1, 1, 1, 1, 1, 0, 0, 194, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9858, 612, 1, 1, 1, 1, 1, 0, 2147483647, 195, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9859, 612, 1, 1, 1, 1, 1, 0, 2147483647, 196, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9860, 612, 1, 1, 1, 0, 0, 0, 2147483647, 197, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9861, 612, 1, 1, 1, 1, 1, 0, 2147483647, 198, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9862, 612, 1, 1, 1, 1, 1, 0, 2147483647, 199, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9863, 612, 1, 1, 1, 0, 0, 0, 0, 200, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9864, 612, 1, 1, 1, 0, 0, 0, 0, 201, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9865, 612, 1, 1, 1, 0, 0, 0, 0, 202, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9866, 612, 1, 1, 1, 1, 1, 2147483647, 2147483647, 203, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9867, 612, 1, 1, 1, 1, 1, 2147483647, 2147483647, 204, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9868, 612, 1, 1, 1, 1, 1, 2147483647, 2147483647, 205, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9869, 612, 1, 1, 1, 0, 0, 0, 0, 206, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9870, 612, 1, 1, 1, 1, 1, 2147483647, 2147483647, 207, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9871, 612, 1, 1, 1, 0, 0, 0, 0, 208, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9872, 612, 1, 1, 1, 0, 0, 0, 0, 209, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9873, 612, 1, 1, 1, 0, 0, 0, 0, 210, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9874, 612, 1, 1, 1, 0, 0, 0, 0, 211, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9875, 613, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 9876, 613, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10165, 640, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10166, 640, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10167, 640, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10168, 640, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10169, 640, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10170, 640, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10171, 640, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10172, 640, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10173, 640, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10174, 640, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10175, 640, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10176, 640, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10177, 640, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10178, 640, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10179, 640, 1, 1, 1, 0, 0, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10153, 637, 0, 0, 0, 0, 0, 50000, 149999900, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10154, 637, 1, 1, 1, 0, 0, 50000, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10155, 637, 1, 1, 1, 0, 0, 50000, 10000000, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10156, 637, 1, 1, 1, 0, 0, 50000, 2000000, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10157, 637, 1, 1, 1, 0, 0, 50000, 1000000, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10158, 637, 1, 1, 1, 0, 0, 50000, 749999, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10159, 637, 1, 1, 1, 0, 0, 4999990, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10160, 637, 1, 1, 1, 0, 0, 0, 4999990, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13775, 101, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13776, 101, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13777, 101, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2712, 250, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2713, 250, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2714, 250, 1, 1, 1, 1, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2715, 250, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2716, 250, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2717, 250, 1, 1, 1, 1, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2718, 250, 1, 1, 1, 1, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2719, 250, 1, 1, 1, 1, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2720, 250, 1, 1, 1, 1, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2721, 250, 1, 1, 1, 1, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2722, 250, 1, 1, 1, 1, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2723, 250, 1, 1, 1, 1, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2724, 250, 1, 1, 1, 1, 0, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2725, 250, 1, 1, 1, 1, 0, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2726, 250, 1, 1, 1, 1, 0, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2727, 250, 1, 1, 1, 1, 0, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2728, 250, 1, 1, 1, 1, 0, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2729, 250, 1, 1, 1, 1, 0, 0, 0, 17, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2730, 250, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2731, 250, 1, 1, 1, 1, 0, 0, 0, 19, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 2732, 250, 1, 1, 1, 1, 0, 0, 0, 20, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13751, 86, 1, 1, 1, 0, 0, 1, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13752, 86, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13753, 86, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13754, 86, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 13755, 86, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14251, 785, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14252, 785, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14253, 785, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14254, 785, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 19212, 800, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14365, 800, 1, 1, 1, 0, 0, 802, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14364, 800, 1, 1, 1, 0, 0, 802, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14366, 800, 1, 1, 1, 0, 0, 241, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 19222, 800, 1, 1, 1, 0, 0, 481, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 19224, 800, 1, 1, 1, 0, 0, 481, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10415, 655, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 19258, 655, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 19259, 655, 1, 1, 1, 0, 0, 0, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10416, 655, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10417, 655, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10418, 655, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10419, 655, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10420, 655, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10421, 655, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10422, 655, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10423, 655, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10424, 655, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10425, 655, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10426, 655, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10427, 655, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10428, 655, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10429, 655, 1, 1, 1, 0, 0, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10430, 655, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10431, 655, 1, 1, 1, 0, 0, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10432, 655, 1, 1, 1, 0, 0, 0, 0, 17, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10433, 655, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10434, 655, 1, 1, 1, 0, 0, 0, 0, 19, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10435, 655, 1, 1, 1, 0, 0, 0, 0, 20, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10436, 655, 1, 1, 1, 0, 0, 0, 0, 21, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10437, 655, 1, 1, 1, 0, 0, 0, 0, 22, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10438, 655, 1, 1, 1, 0, 0, 0, 0, 23, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14255, 786, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14256, 786, 1, 1, 1, 0, 0, 1, 125000, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14257, 787, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14258, 787, 1, 1, 1, 0, 0, 20, 400880, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14259, 787, 1, 1, 1, 0, 0, 20, 80176, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14260, 787, 1, 1, 1, 0, 0, 20, 801759, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14261, 788, 1, 1, 1, 0, 0, 10000, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14262, 788, 1, 1, 1, 0, 0, 50000, 2000000, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14263, 788, 1, 1, 1, 0, 0, 10000, 50000, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14264, 789, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14265, 789, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14266, 789, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14267, 789, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14268, 789, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14269, 789, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14270, 789, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14271, 789, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14272, 789, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14273, 789, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14274, 789, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14275, 789, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14276, 789, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14277, 790, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14278, 790, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14279, 790, 1, 1, 1, 0, 0, 0, 847059, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14280, 790, 1, 1, 1, 0, 0, 0, 795580, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14281, 790, 1, 1, 1, 0, 0, 0, 423530, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14287, 792, 1, 1, 1, 0, 0, 200, 200440, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19214, 786, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14256, 786, 1, 1, 1, 0, 0, 1, 20000, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19215, 786, 1, 1, 1, 0, 0, 1, 9999, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19216, 786, 1, 1, 1, 0, 0, 1, 20000, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19217, 786, 1, 1, 1, 0, 0, 0, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19220, 786, 1, 1, 1, 0, 0, 1, 9999, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19221, 786, 1, 1, 1, 0, 0, 0, 0, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19223, 786, 1, 1, 1, 0, 0, 1, 20000, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19225, 786, 1, 1, 1, 0, 0, 9999, 1000000, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19227, 786, 1, 1, 1, 0, 0, 1, 9999, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19260, 840, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19276, 844, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15004, 844, 1, 1, 1, 1, 1, 0, 0, 53, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14965, 844, 1, 1, 1, 1, 1, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14967, 844, 1, 1, 1, 1, 1, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14971, 844, 1, 1, 1, 1, 1, 0, 0, 20, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15005, 844, 1, 1, 1, 1, 1, 0, 0, 54, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14998, 844, 1, 1, 1, 1, 1, 0, 0, 47, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19285, 844, 1, 1, 1, 1, 1, 0, 0, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14968, 844, 1, 1, 1, 1, 1, 0, 0, 17, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14993, 844, 1, 1, 1, 1, 1, 0, 0, 42, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15002, 844, 1, 1, 1, 1, 1, 0, 0, 51, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19288, 844, 1, 1, 1, 1, 1, 0, 0, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19290, 844, 1, 1, 1, 1, 1, 0, 0, 12, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19292, 844, 1, 1, 1, 1, 1, 0, 0, 13, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14981, 844, 1, 1, 1, 1, 1, 0, 0, 30, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14903, 842, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14964, 844, 1, 1, 1, 1, 1, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14904, 842, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14995, 844, 1, 1, 1, 1, 1, 0, 0, 44, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14905, 842, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14988, 844, 1, 1, 1, 1, 1, 0, 0, 37, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14906, 842, 1, 1, 1, 1, 1, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14984, 844, 1, 1, 1, 1, 1, 0, 0, 33, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14907, 842, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19293, 844, 1, 1, 1, 1, 1, 0, 0, 19, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14908, 842, 1, 1, 1, 1, 1, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14973, 844, 1, 1, 1, 1, 1, 0, 0, 22, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14972, 844, 1, 1, 1, 1, 1, 0, 0, 21, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14909, 842, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14994, 844, 1, 1, 1, 1, 1, 0, 0, 43, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14910, 842, 1, 1, 1, 1, 1, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14969, 844, 1, 1, 1, 1, 1, 0, 0, 18, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14911, 842, 1, 1, 1, 1, 1, 0, 0, 17, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14997, 844, 1, 1, 1, 1, 1, 0, 0, 46, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14980, 844, 1, 1, 1, 1, 1, 0, 0, 29, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14912, 842, 1, 1, 1, 1, 1, 0, 0, 18, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15010, 844, 1, 1, 1, 1, 1, 0, 0, 59, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14913, 842, 1, 1, 1, 0, 0, 0, 0, 19, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14976, 844, 1, 1, 1, 1, 1, 0, 0, 25, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14914, 842, 1, 1, 1, 1, 1, 0, 0, 20, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14983, 844, 1, 1, 1, 1, 1, 0, 0, 32, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14915, 842, 1, 1, 1, 0, 0, 0, 0, 21, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14916, 842, 1, 1, 1, 0, 0, 0, 0, 22, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14977, 844, 1, 1, 1, 1, 1, 0, 0, 26, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14917, 842, 1, 1, 1, 0, 0, 0, 0, 23, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19295, 844, 1, 1, 1, 1, 1, 0, 0, 30, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19296, 844, 1, 1, 1, 1, 1, 0, 0, 31, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14918, 842, 1, 1, 1, 0, 0, 0, 0, 24, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19297, 844, 1, 1, 1, 1, 1, 0, 0, 32, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14919, 842, 1, 1, 1, 0, 0, 0, 0, 25, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14920, 842, 1, 1, 1, 1, 1, 0, 0, 26, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14974, 844, 1, 1, 1, 1, 1, 0, 0, 23, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14921, 842, 1, 1, 1, 1, 1, 0, 0, 27, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14922, 842, 1, 1, 1, 1, 1, 0, 0, 28, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15006, 844, 1, 1, 1, 1, 1, 0, 0, 55, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15001, 844, 1, 1, 1, 1, 1, 0, 0, 50, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14923, 842, 1, 1, 1, 1, 1, 0, 0, 29, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14966, 844, 1, 1, 1, 1, 1, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14924, 842, 1, 1, 1, 1, 1, 0, 0, 30, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14970, 844, 1, 1, 1, 1, 1, 0, 0, 19, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14925, 842, 1, 1, 1, 1, 1, 0, 0, 31, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14978, 844, 1, 1, 1, 1, 1, 0, 0, 27, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14926, 842, 1, 1, 1, 1, 1, 0, 0, 32, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14927, 842, 1, 1, 1, 1, 1, 0, 0, 33, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14990, 844, 1, 1, 1, 1, 1, 0, 0, 39, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19177, 613, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19218, 792, 1, 1, 1, 0, 0, 200, 200440, 0, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14288, 792, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14289, 792, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14290, 792, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
@@ -1612,10 +1204,89 @@
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14294, 792, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14295, 792, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14296, 792, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14297, 793, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14298, 793, 1, 1, 1, 0, 0, 601, 50110, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14299, 793, 1, 1, 1, 0, 0, 1203, 150330, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14300, 793, 1, 1, 1, 0, 0, 40088, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19261, 883, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18236, 883, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18237, 883, 1, 1, 1, 0, 0, 0, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18238, 883, 1, 1, 1, 0, 0, 0, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18239, 883, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18240, 883, 1, 1, 1, 0, 0, 0, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 10439, 655, 1, 1, 1, 0, 0, 0, 0, 24, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18219, 882, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18220, 882, 1, 1, 1, 0, 0, 135001, 300000, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18221, 882, 1, 1, 1, 0, 0, 20001, 135000, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18222, 882, 1, 1, 1, 0, 0, 12001, 20000, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18223, 882, 1, 1, 1, 0, 0, 2751, 12000, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18224, 882, 1, 1, 1, 0, 0, 0, 2750, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18225, 882, 1, 1, 1, 0, 0, 300000, 1000000, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18226, 882, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18227, 882, 1, 1, 1, 0, 0, 0, 300000, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18228, 882, 1, 1, 1, 0, 0, 0, 300000, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18229, 882, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18230, 882, 1, 1, 1, 0, 0, 0, 300000, 12, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18231, 882, 1, 1, 1, 0, 0, 0, 300000, 13, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18232, 882, 1, 1, 1, 0, 0, 0, 0, 14, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18233, 882, 1, 1, 1, 0, 0, 0, 300000, 15, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18234, 882, 1, 1, 1, 0, 0, 0, 300000, 16, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14982, 844, 1, 1, 1, 1, 1, 0, 0, 31, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19308, 824, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19309, 824, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19310, 824, 1, 1, 1, 0, 0, 0, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19311, 824, 1, 1, 1, 0, 0, 0, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19312, 824, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19313, 824, 1, 1, 1, 0, 0, 0, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19314, 824, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19315, 824, 1, 1, 1, 0, 0, 0, 0, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19316, 824, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19317, 824, 1, 1, 1, 0, 0, 0, 0, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19318, 824, 1, 1, 1, 0, 0, 0, 0, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19319, 824, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19320, 824, 1, 1, 1, 0, 0, 0, 0, 12, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19321, 824, 1, 1, 1, 0, 0, 0, 0, 13, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19322, 824, 1, 1, 1, 0, 0, 0, 0, 14, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19323, 824, 1, 1, 1, 0, 0, 0, 0, 15, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19324, 824, 1, 1, 1, 0, 0, 0, 0, 16, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19325, 824, 1, 1, 1, 0, 0, 0, 0, 17, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19326, 824, 1, 1, 1, 0, 0, 0, 0, 18, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19327, 824, 1, 1, 1, 0, 0, 0, 0, 19, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19328, 824, 1, 1, 1, 0, 0, 0, 0, 20, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19329, 824, 1, 1, 1, 0, 0, 0, 0, 21, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19330, 824, 1, 1, 1, 0, 0, 0, 0, 22, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19331, 824, 1, 1, 1, 0, 0, 0, 0, 23, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19332, 824, 1, 1, 1, 0, 0, 0, 0, 24, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19333, 824, 1, 1, 1, 0, 0, 0, 0, 25, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19334, 824, 1, 1, 1, 0, 0, 0, 0, 26, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19335, 824, 1, 1, 1, 0, 0, 0, 0, 27, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19336, 824, 1, 1, 1, 0, 0, 0, 0, 28, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19337, 824, 1, 1, 1, 0, 0, 0, 0, 29, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19338, 824, 1, 1, 1, 0, 0, 0, 0, 30, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19339, 824, 1, 1, 1, 0, 0, 0, 0, 31, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19340, 824, 1, 1, 1, 0, 0, 0, 0, 32, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19341, 824, 1, 1, 1, 0, 0, 0, 0, 33, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19342, 824, 1, 1, 1, 0, 0, 0, 0, 34, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19343, 824, 1, 1, 1, 0, 0, 0, 0, 35, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19344, 824, 1, 1, 1, 0, 0, 0, 0, 36, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19345, 824, 1, 1, 1, 0, 0, 0, 0, 37, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19346, 824, 1, 1, 1, 0, 0, 0, 0, 38, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19347, 824, 1, 1, 1, 0, 0, 0, 0, 39, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19348, 824, 1, 1, 1, 0, 0, 0, 0, 40, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19349, 824, 1, 1, 1, 0, 0, 0, 0, 41, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19350, 824, 1, 1, 1, 0, 0, 0, 0, 42, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19351, 824, 1, 1, 1, 0, 0, 0, 0, 43, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19352, 824, 1, 1, 1, 0, 0, 0, 0, 44, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19353, 824, 1, 1, 1, 0, 0, 0, 0, 45, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19354, 824, 1, 1, 1, 0, 0, 0, 0, 46, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14261, 788, 1, 1, 1, 0, 0, 10000, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14262, 788, 1, 1, 1, 0, 0, 50000, 2000000, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14263, 788, 1, 1, 1, 0, 0, 10000, 50000, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2713, 250, 1, 1, 1, 1, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2714, 250, 1, 1, 1, 1, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2715, 250, 1, 1, 1, 1, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2716, 250, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2717, 250, 1, 1, 1, 1, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2718, 250, 1, 1, 1, 1, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2719, 250, 1, 1, 1, 1, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2720, 250, 1, 1, 1, 1, 0, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2721, 250, 1, 1, 1, 1, 0, 0, 0, 9, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14302, 794, 1, 1, 1, 1, 1, 25001, 0, 1, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14307, 794, 1, 1, 1, 0, 0, 25001, 150000, 6, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14310, 794, 1, 1, 1, 0, 0, 25001, 100000, 9, '', NULL);
@@ -1633,462 +1304,189 @@
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14360, 799, 1, 1, 1, 0, 0, 10000, 0, 0, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14361, 799, 1, 1, 1, 0, 0, 50000, 2000000, 1, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14362, 799, 1, 1, 1, 0, 0, 10000, 50000, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2712, 250, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2713, 250, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2714, 250, 1, 1, 1, 1, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2715, 250, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2716, 250, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2717, 250, 1, 1, 1, 1, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2718, 250, 1, 1, 1, 1, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2719, 250, 1, 1, 1, 1, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2720, 250, 1, 1, 1, 1, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2721, 250, 1, 1, 1, 1, 0, 0, 0, 9, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2722, 250, 1, 1, 1, 1, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2723, 250, 1, 1, 1, 1, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2724, 250, 1, 1, 1, 1, 0, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2725, 250, 1, 1, 1, 1, 0, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2726, 250, 1, 1, 1, 1, 0, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2727, 250, 1, 1, 1, 1, 0, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2728, 250, 1, 1, 1, 1, 0, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2729, 250, 1, 1, 1, 1, 0, 0, 0, 17, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2730, 250, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2731, 250, 1, 1, 1, 1, 0, 0, 0, 19, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 2732, 250, 1, 1, 1, 1, 0, 0, 0, 20, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14363, 800, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14364, 800, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14365, 800, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14366, 800, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10165, 640, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10166, 640, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10167, 640, 1, 1, 0, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10168, 640, 1, 1, 0, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10169, 640, 1, 1, 0, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10170, 640, 1, 1, 0, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10171, 640, 1, 1, 0, 0, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10172, 640, 1, 1, 0, 0, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10173, 640, 1, 1, 0, 0, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10174, 640, 1, 1, 0, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10175, 640, 1, 1, 0, 0, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10176, 640, 1, 1, 0, 0, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10177, 640, 1, 1, 0, 0, 0, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10178, 640, 1, 1, 0, 0, 0, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10179, 640, 1, 1, 0, 0, 0, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14370, 824, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14371, 824, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14372, 824, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14373, 824, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14374, 824, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14375, 824, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14376, 824, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14377, 824, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14378, 824, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14379, 824, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14380, 824, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14381, 824, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14382, 824, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14383, 824, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14384, 824, 1, 1, 1, 0, 0, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14385, 824, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14386, 824, 1, 1, 1, 0, 0, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14387, 824, 1, 1, 1, 0, 0, 0, 0, 17, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14388, 824, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14389, 824, 1, 1, 1, 0, 0, 0, 0, 19, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14390, 824, 1, 1, 1, 0, 0, 0, 0, 20, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14391, 824, 1, 1, 1, 0, 0, 0, 0, 21, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14392, 824, 1, 1, 1, 0, 0, 0, 0, 22, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14393, 824, 1, 1, 1, 0, 0, 0, 0, 23, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14394, 824, 1, 1, 1, 0, 0, 0, 0, 24, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14395, 824, 1, 1, 1, 0, 0, 0, 0, 25, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14396, 824, 1, 1, 1, 0, 0, 0, 0, 26, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14397, 824, 1, 1, 1, 0, 0, 0, 0, 27, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14398, 824, 1, 1, 1, 0, 0, 0, 0, 28, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14399, 824, 1, 1, 1, 0, 0, 0, 0, 29, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14400, 824, 1, 1, 1, 0, 0, 0, 0, 30, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14401, 824, 1, 1, 1, 0, 0, 0, 0, 31, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14402, 824, 1, 1, 1, 0, 0, 0, 0, 32, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14403, 824, 1, 1, 1, 0, 0, 0, 0, 33, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14404, 824, 1, 1, 1, 0, 0, 0, 0, 34, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14405, 824, 1, 1, 1, 0, 0, 0, 0, 35, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14406, 824, 1, 1, 1, 0, 0, 0, 0, 36, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14407, 824, 1, 1, 1, 0, 0, 0, 0, 37, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14408, 824, 1, 1, 1, 0, 0, 0, 0, 38, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14409, 824, 1, 1, 1, 0, 0, 0, 0, 39, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14410, 824, 1, 1, 1, 0, 0, 0, 0, 40, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14411, 824, 1, 1, 1, 0, 0, 0, 0, 41, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14412, 824, 1, 1, 1, 0, 0, 0, 0, 42, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14413, 824, 1, 1, 1, 0, 0, 0, 0, 43, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14414, 824, 1, 1, 1, 0, 0, 0, 0, 44, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14415, 824, 1, 1, 1, 0, 0, 0, 0, 45, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14416, 824, 1, 1, 1, 0, 0, 0, 0, 46, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14417, 824, 1, 1, 1, 0, 0, 0, 0, 47, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14418, 824, 1, 1, 1, 0, 0, 0, 0, 48, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14419, 824, 1, 1, 1, 0, 0, 0, 0, 49, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14420, 824, 1, 1, 1, 0, 0, 0, 0, 50, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14421, 824, 1, 1, 1, 0, 0, 0, 0, 51, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14422, 824, 1, 1, 1, 0, 0, 0, 0, 52, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14423, 824, 1, 1, 1, 0, 0, 0, 0, 53, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14424, 824, 1, 1, 1, 0, 0, 0, 0, 54, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14425, 824, 1, 1, 1, 0, 0, 0, 0, 55, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14426, 824, 1, 1, 1, 0, 0, 0, 0, 56, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14427, 824, 1, 1, 1, 0, 0, 0, 0, 57, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14428, 824, 1, 1, 1, 0, 0, 0, 0, 58, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14429, 824, 1, 1, 1, 0, 0, 0, 0, 59, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14430, 824, 1, 1, 1, 0, 0, 0, 0, 60, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14431, 824, 1, 1, 1, 0, 0, 0, 0, 61, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14432, 824, 1, 1, 1, 0, 0, 0, 0, 62, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14433, 824, 1, 1, 1, 0, 0, 0, 0, 63, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14434, 824, 1, 1, 1, 0, 0, 0, 0, 64, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14435, 824, 1, 1, 1, 0, 0, 0, 0, 65, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14436, 824, 1, 1, 1, 0, 0, 0, 0, 66, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14437, 824, 1, 1, 1, 0, 0, 0, 0, 67, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14438, 824, 1, 1, 1, 0, 0, 0, 0, 68, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14439, 824, 1, 1, 1, 0, 0, 0, 0, 69, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14440, 824, 1, 1, 1, 0, 0, 0, 0, 70, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14441, 824, 1, 1, 1, 0, 0, 0, 0, 71, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14442, 824, 1, 1, 1, 0, 0, 0, 0, 72, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14443, 824, 1, 1, 1, 0, 0, 0, 0, 73, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14444, 824, 1, 1, 1, 0, 0, 0, 0, 74, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14445, 824, 1, 1, 1, 0, 0, 0, 0, 75, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14446, 824, 1, 1, 1, 0, 0, 0, 0, 76, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14447, 824, 1, 1, 1, 0, 0, 0, 0, 77, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14448, 824, 1, 1, 1, 0, 0, 0, 0, 78, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14449, 824, 1, 1, 1, 0, 0, 0, 0, 79, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14450, 824, 1, 1, 1, 0, 0, 0, 0, 80, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14451, 824, 1, 1, 1, 0, 0, 0, 0, 81, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14452, 824, 1, 1, 1, 0, 0, 0, 0, 82, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14453, 824, 1, 1, 1, 0, 0, 0, 0, 83, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14454, 824, 1, 1, 1, 0, 0, 0, 0, 84, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14455, 824, 1, 1, 1, 0, 0, 0, 0, 85, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14456, 824, 1, 1, 1, 0, 0, 0, 0, 86, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14457, 824, 1, 1, 1, 0, 0, 0, 0, 87, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14458, 824, 1, 1, 1, 0, 0, 0, 0, 88, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14459, 824, 1, 1, 1, 0, 0, 0, 0, 89, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14460, 824, 1, 1, 1, 0, 0, 0, 0, 90, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14461, 824, 1, 1, 1, 0, 0, 0, 0, 91, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14462, 824, 1, 1, 1, 0, 0, 0, 0, 92, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14463, 824, 1, 1, 1, 0, 0, 0, 0, 93, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14464, 824, 1, 1, 1, 0, 0, 0, 0, 94, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14465, 824, 1, 1, 1, 0, 0, 0, 0, 95, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14466, 824, 1, 1, 1, 0, 0, 0, 0, 96, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14467, 824, 1, 1, 1, 0, 0, 0, 0, 97, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14468, 824, 1, 1, 1, 0, 0, 0, 0, 98, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14469, 824, 1, 1, 1, 0, 0, 0, 0, 99, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14470, 824, 1, 1, 1, 0, 0, 0, 0, 100, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14471, 824, 1, 1, 1, 0, 0, 0, 0, 101, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14472, 824, 1, 1, 1, 0, 0, 0, 0, 102, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14473, 824, 1, 1, 1, 0, 0, 0, 0, 103, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14474, 824, 1, 1, 1, 0, 0, 0, 0, 104, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14475, 824, 1, 1, 1, 0, 0, 0, 0, 105, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14476, 824, 1, 1, 1, 0, 0, 0, 0, 106, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14477, 824, 1, 1, 1, 0, 0, 0, 0, 107, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14478, 824, 1, 1, 1, 0, 0, 0, 0, 108, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14479, 824, 1, 1, 1, 0, 0, 0, 0, 109, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14480, 824, 1, 1, 1, 0, 0, 0, 0, 110, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14481, 824, 1, 1, 1, 0, 0, 0, 0, 111, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14482, 824, 1, 1, 1, 0, 0, 0, 0, 112, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14483, 824, 1, 1, 1, 0, 0, 0, 0, 113, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14484, 824, 1, 1, 1, 0, 0, 0, 0, 114, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14485, 824, 1, 1, 1, 0, 0, 0, 0, 115, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14486, 824, 1, 1, 1, 0, 0, 0, 0, 116, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14487, 824, 1, 1, 1, 0, 0, 0, 0, 117, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14488, 824, 1, 1, 1, 0, 0, 0, 0, 118, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14489, 824, 1, 1, 1, 0, 0, 0, 0, 119, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14490, 824, 1, 1, 1, 0, 0, 0, 0, 120, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14491, 824, 1, 1, 1, 0, 0, 0, 0, 121, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14492, 824, 1, 1, 1, 0, 0, 0, 0, 122, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14493, 824, 1, 1, 1, 0, 0, 0, 0, 123, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14494, 824, 1, 1, 1, 0, 0, 0, 0, 124, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14495, 824, 1, 1, 1, 0, 0, 0, 0, 125, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14496, 824, 1, 1, 1, 0, 0, 0, 0, 126, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14497, 824, 1, 1, 1, 0, 0, 0, 0, 127, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14498, 824, 1, 1, 1, 0, 0, 0, 0, 128, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14499, 824, 1, 1, 1, 0, 0, 0, 0, 129, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14500, 824, 1, 1, 1, 0, 0, 0, 0, 130, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14501, 824, 1, 1, 1, 0, 0, 0, 0, 131, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14502, 824, 1, 1, 1, 0, 0, 0, 0, 132, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14503, 824, 1, 1, 1, 0, 0, 0, 0, 133, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14504, 824, 1, 1, 1, 0, 0, 0, 0, 134, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14505, 824, 1, 1, 1, 0, 0, 0, 0, 135, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14506, 824, 1, 1, 1, 0, 0, 0, 0, 136, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14507, 824, 1, 1, 1, 0, 0, 0, 0, 137, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14508, 824, 1, 1, 1, 0, 0, 0, 0, 138, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14509, 824, 1, 1, 1, 0, 0, 0, 0, 139, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14510, 824, 1, 1, 1, 0, 0, 0, 0, 140, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14511, 824, 1, 1, 1, 0, 0, 0, 0, 141, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14512, 824, 1, 1, 1, 0, 0, 0, 0, 142, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14513, 824, 1, 1, 1, 0, 0, 0, 0, 143, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14514, 824, 1, 1, 1, 0, 0, 0, 0, 144, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14515, 824, 1, 1, 1, 0, 0, 0, 0, 145, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14516, 824, 1, 1, 1, 0, 0, 0, 0, 146, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14517, 824, 1, 1, 1, 0, 0, 0, 0, 147, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14518, 824, 1, 1, 1, 0, 0, 0, 0, 148, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14519, 824, 1, 1, 1, 0, 0, 0, 0, 149, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14520, 824, 1, 1, 1, 0, 0, 0, 0, 150, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 14525, 827, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 14526, 827, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14527, 828, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14528, 828, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14529, 828, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14530, 828, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14531, 828, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14532, 828, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14533, 828, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14534, 829, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 14535, 829, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14550, 831, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14551, 831, 1, 1, 1, 0, 0, 0, 125000, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14552, 831, 1, 1, 1, 0, 0, 0, 30000, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14553, 831, 1, 1, 1, 0, 0, 0, 499999, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14554, 831, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14555, 831, 1, 1, 1, 0, 0, 0, 100000, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14556, 831, 1, 1, 1, 0, 0, 0, 100000, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14557, 832, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19179, 624, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19179, 624, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19180, 624, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19180, 624, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19181, 624, 1, 1, 1, 1, 1, 0, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19181, 624, 1, 1, 1, 1, 1, 0, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19182, 624, 1, 1, 1, 1, 1, 524922, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19182, 624, 1, 1, 1, 1, 1, 524922, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19183, 624, 1, 1, 1, 1, 1, 200, 524922, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19183, 624, 1, 1, 1, 1, 1, 200, 524922, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19184, 624, 1, 1, 1, 1, 1, 200, 89987, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19184, 624, 1, 1, 1, 1, 1, 200, 89987, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19185, 624, 1, 1, 1, 1, 1, 200, 74989, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19185, 624, 1, 1, 1, 1, 1, 200, 74989, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19186, 624, 1, 1, 1, 1, 1, 200, 74989, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19186, 624, 1, 1, 1, 1, 1, 200, 74989, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19187, 624, 1, 1, 1, 1, 1, 0, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19187, 624, 1, 1, 1, 1, 1, 0, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19188, 624, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19188, 624, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19189, 624, 1, 1, 1, 1, 1, 0, 0, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19189, 624, 1, 1, 1, 1, 1, 0, 0, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19226, 789, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14265, 789, 1, 1, 1, 0, 0, 117283, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14266, 789, 1, 1, 1, 0, 0, 23457, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14268, 789, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14270, 789, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14271, 789, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14269, 789, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14267, 789, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14272, 789, 1, 1, 1, 0, 0, 9382, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14273, 789, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14275, 789, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14276, 789, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14274, 789, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19235, 789, 1, 1, 1, 0, 0, 4691, 9382, 13, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19236, 789, 1, 1, 1, 0, 0, 0, 0, 14, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19237, 789, 1, 1, 1, 0, 0, 0, 0, 15, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19238, 789, 1, 1, 1, 0, 0, 0, 0, 16, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19239, 789, 1, 1, 1, 0, 0, 0, 0, 17, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19241, 789, 1, 1, 1, 0, 0, 94, 4691, 18, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19242, 789, 1, 1, 1, 0, 0, 0, 0, 19, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19243, 789, 1, 1, 1, 0, 0, 0, 0, 20, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19244, 789, 1, 1, 1, 0, 0, 0, 0, 21, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19245, 789, 1, 1, 1, 0, 0, 0, 0, 22, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14558, 832, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14559, 832, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14560, 832, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14561, 833, 1, 1, 1, 1, 1, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14562, 833, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14563, 833, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14564, 833, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14565, 833, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14566, 833, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14567, 833, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14568, 833, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14569, 833, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14570, 833, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14571, 833, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14572, 833, 1, 1, 1, 1, 1, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14573, 833, 1, 1, 1, 1, 1, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14574, 833, 1, 1, 1, 1, 1, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14575, 833, 1, 1, 1, 1, 1, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14576, 833, 1, 1, 1, 1, 1, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14577, 833, 1, 1, 1, 1, 1, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14578, 833, 1, 1, 1, 1, 1, 0, 0, 17, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14579, 833, 1, 1, 1, 1, 1, 0, 0, 18, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14580, 833, 1, 1, 1, 1, 1, 0, 0, 19, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14581, 833, 1, 1, 1, 1, 1, 0, 0, 20, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14582, 833, 1, 1, 1, 1, 1, 0, 0, 21, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14583, 833, 1, 1, 1, 1, 1, 0, 0, 22, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14584, 833, 1, 1, 1, 1, 1, 0, 0, 23, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14585, 833, 1, 1, 1, 1, 1, 0, 0, 24, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14586, 833, 1, 1, 1, 1, 1, 0, 0, 25, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14587, 833, 1, 1, 1, 1, 1, 0, 0, 26, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14588, 833, 1, 1, 1, 1, 1, 0, 0, 27, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14589, 833, 1, 1, 1, 1, 1, 0, 0, 28, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14590, 833, 1, 1, 1, 1, 1, 0, 0, 29, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14591, 833, 1, 1, 1, 1, 1, 0, 0, 30, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14592, 833, 1, 1, 1, 1, 1, 0, 0, 31, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14593, 833, 1, 1, 1, 1, 1, 0, 0, 32, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14594, 833, 1, 1, 1, 1, 1, 0, 0, 33, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14595, 833, 1, 1, 1, 1, 1, 0, 0, 34, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14596, 833, 1, 1, 1, 1, 1, 0, 0, 35, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14597, 833, 1, 1, 1, 1, 1, 0, 0, 36, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14598, 833, 1, 1, 1, 1, 1, 0, 0, 37, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14599, 833, 1, 1, 1, 1, 1, 0, 0, 38, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14600, 833, 1, 1, 1, 1, 1, 0, 0, 39, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14601, 833, 1, 1, 1, 1, 1, 0, 0, 40, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14602, 833, 1, 1, 1, 1, 1, 0, 0, 41, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14603, 833, 1, 1, 1, 1, 1, 0, 0, 42, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14604, 833, 1, 1, 1, 1, 1, 0, 0, 43, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14605, 833, 1, 1, 1, 1, 1, 0, 0, 44, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14606, 833, 1, 1, 1, 1, 1, 0, 0, 45, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14607, 833, 1, 1, 1, 1, 1, 0, 0, 46, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14608, 833, 1, 1, 1, 1, 1, 0, 0, 47, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14609, 833, 1, 1, 1, 1, 1, 0, 0, 48, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14610, 833, 1, 1, 1, 1, 1, 0, 0, 49, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14611, 833, 1, 1, 1, 1, 1, 0, 0, 50, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14612, 833, 1, 1, 1, 1, 1, 0, 0, 51, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14613, 833, 1, 1, 1, 1, 1, 0, 0, 52, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14614, 833, 1, 1, 1, 1, 1, 0, 0, 53, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14615, 833, 1, 1, 1, 1, 1, 0, 0, 54, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14616, 833, 1, 1, 1, 1, 1, 0, 0, 55, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14617, 833, 1, 1, 1, 1, 1, 0, 0, 56, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14618, 833, 1, 1, 1, 1, 1, 0, 0, 57, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14619, 833, 1, 1, 1, 1, 1, 0, 0, 58, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14620, 833, 1, 1, 1, 1, 1, 0, 0, 59, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14621, 833, 1, 1, 1, 1, 1, 0, 0, 60, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14622, 833, 1, 1, 1, 1, 1, 0, 0, 61, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14623, 833, 1, 1, 1, 1, 1, 0, 0, 62, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14624, 833, 1, 1, 1, 1, 1, 0, 0, 63, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14625, 833, 1, 1, 1, 1, 1, 0, 0, 64, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14626, 833, 1, 1, 1, 1, 1, 0, 0, 65, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14627, 833, 1, 1, 1, 1, 1, 0, 0, 66, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14628, 833, 1, 1, 1, 1, 1, 0, 0, 67, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14629, 833, 1, 1, 1, 1, 1, 0, 0, 68, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14630, 833, 1, 1, 1, 1, 1, 0, 0, 69, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14631, 833, 1, 1, 1, 1, 1, 0, 0, 70, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14632, 833, 1, 1, 1, 1, 1, 0, 0, 71, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14633, 833, 1, 1, 1, 1, 1, 0, 0, 72, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14634, 833, 1, 1, 1, 1, 1, 0, 0, 73, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14635, 833, 1, 1, 1, 1, 1, 0, 0, 74, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14636, 833, 1, 1, 1, 1, 1, 0, 0, 75, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14637, 833, 1, 1, 1, 1, 1, 0, 0, 76, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14638, 833, 1, 1, 1, 1, 1, 0, 0, 77, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14639, 833, 1, 1, 1, 1, 1, 0, 0, 78, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14640, 833, 1, 1, 1, 1, 1, 0, 0, 79, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14641, 833, 1, 1, 1, 1, 1, 0, 0, 80, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14642, 833, 1, 1, 1, 1, 1, 0, 0, 81, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14643, 833, 1, 1, 1, 1, 1, 0, 0, 82, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14644, 833, 1, 1, 1, 1, 1, 0, 0, 83, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14645, 833, 1, 1, 1, 1, 1, 0, 0, 84, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14646, 833, 1, 1, 1, 1, 1, 0, 0, 85, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14647, 833, 1, 1, 1, 1, 1, 0, 0, 86, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14648, 833, 1, 1, 1, 1, 1, 0, 0, 87, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14649, 833, 1, 1, 1, 1, 1, 0, 0, 88, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14650, 833, 1, 1, 1, 1, 1, 0, 0, 89, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14651, 833, 1, 1, 1, 1, 1, 0, 0, 90, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14652, 833, 1, 1, 1, 1, 1, 0, 0, 91, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14653, 833, 1, 1, 1, 1, 1, 0, 0, 92, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14654, 833, 1, 1, 1, 1, 1, 0, 0, 93, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14655, 833, 1, 1, 1, 1, 1, 0, 0, 94, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14656, 833, 1, 1, 1, 1, 1, 0, 0, 95, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14657, 833, 1, 1, 1, 1, 1, 0, 0, 96, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14658, 833, 1, 1, 1, 1, 1, 0, 0, 97, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14659, 833, 1, 1, 1, 1, 1, 0, 0, 98, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14660, 833, 1, 1, 1, 1, 1, 0, 0, 99, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14661, 833, 1, 1, 1, 1, 1, 0, 0, 100, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14662, 833, 1, 1, 1, 1, 1, 0, 0, 101, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14663, 833, 1, 1, 1, 1, 1, 0, 0, 102, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14664, 833, 1, 1, 1, 1, 1, 0, 0, 103, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14665, 833, 1, 1, 1, 1, 1, 0, 0, 104, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14666, 833, 1, 1, 1, 1, 1, 0, 0, 105, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14667, 833, 1, 1, 1, 1, 1, 0, 0, 106, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14668, 833, 1, 1, 1, 1, 1, 0, 0, 107, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14669, 833, 1, 1, 1, 1, 1, 0, 0, 108, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14670, 833, 1, 1, 1, 1, 1, 0, 0, 109, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14671, 833, 1, 1, 1, 1, 1, 0, 0, 110, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14672, 833, 1, 1, 1, 1, 1, 0, 0, 111, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14673, 833, 1, 1, 1, 1, 1, 0, 0, 112, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14674, 833, 1, 1, 1, 1, 1, 0, 0, 113, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14675, 833, 1, 1, 1, 1, 1, 0, 0, 114, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14676, 833, 1, 1, 1, 1, 1, 0, 0, 115, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14677, 833, 1, 1, 1, 1, 1, 0, 0, 116, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14678, 833, 1, 1, 1, 1, 1, 0, 0, 117, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14679, 833, 1, 1, 1, 1, 1, 0, 0, 118, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14680, 833, 1, 1, 1, 1, 1, 0, 0, 119, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14681, 833, 1, 1, 1, 1, 1, 0, 0, 120, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14682, 833, 1, 1, 1, 1, 1, 0, 0, 121, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14683, 833, 1, 1, 1, 1, 1, 0, 0, 122, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14684, 833, 1, 1, 1, 1, 1, 0, 0, 123, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14685, 833, 1, 1, 1, 1, 1, 0, 0, 124, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14686, 833, 1, 1, 1, 1, 1, 0, 0, 125, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14687, 833, 1, 1, 1, 1, 1, 0, 0, 126, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14688, 833, 1, 1, 1, 1, 1, 0, 0, 127, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14689, 833, 1, 1, 1, 1, 1, 0, 0, 128, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14690, 833, 1, 1, 1, 1, 1, 0, 0, 129, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14691, 833, 1, 1, 1, 1, 1, 0, 0, 130, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14692, 833, 1, 1, 1, 1, 1, 0, 0, 131, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14693, 833, 1, 1, 1, 1, 1, 0, 0, 132, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14694, 833, 1, 1, 1, 1, 1, 0, 0, 133, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14695, 833, 1, 1, 1, 1, 1, 0, 0, 134, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14696, 833, 1, 1, 1, 1, 1, 0, 0, 135, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14697, 833, 1, 1, 1, 1, 1, 0, 0, 136, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14698, 833, 1, 1, 1, 1, 1, 0, 0, 137, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14699, 833, 1, 1, 1, 1, 1, 0, 0, 138, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14700, 833, 1, 1, 1, 1, 1, 0, 0, 139, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14701, 833, 1, 1, 1, 1, 1, 0, 0, 140, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14702, 833, 1, 1, 1, 1, 1, 0, 0, 141, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14703, 833, 1, 1, 1, 1, 1, 0, 0, 142, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14704, 833, 1, 1, 1, 1, 1, 0, 0, 143, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14705, 833, 1, 1, 1, 1, 1, 0, 0, 144, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14706, 833, 1, 1, 1, 1, 1, 0, 0, 145, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14707, 833, 1, 1, 1, 1, 1, 0, 0, 146, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14708, 833, 1, 1, 1, 1, 1, 0, 0, 147, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14709, 833, 1, 1, 1, 1, 1, 0, 0, 148, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14710, 833, 1, 1, 1, 1, 1, 0, 0, 149, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14711, 833, 1, 1, 1, 1, 1, 0, 0, 150, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14712, 833, 1, 1, 1, 1, 1, 0, 0, 151, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14713, 833, 1, 1, 1, 1, 1, 0, 0, 152, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14714, 833, 1, 1, 1, 1, 1, 0, 0, 153, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14715, 833, 1, 1, 1, 1, 1, 0, 0, 154, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14716, 833, 1, 1, 1, 1, 1, 0, 0, 155, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14717, 833, 1, 1, 1, 1, 1, 0, 0, 156, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14718, 833, 1, 1, 1, 1, 1, 0, 0, 157, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14719, 833, 1, 1, 1, 1, 1, 0, 0, 158, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14720, 833, 1, 1, 1, 1, 1, 0, 0, 159, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14721, 833, 1, 1, 1, 1, 1, 0, 0, 160, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14722, 833, 1, 1, 1, 1, 1, 0, 0, 161, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14723, 833, 1, 1, 1, 1, 1, 0, 0, 162, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14724, 833, 1, 1, 1, 1, 1, 0, 0, 163, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14725, 833, 1, 1, 1, 1, 1, 0, 0, 164, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14726, 833, 1, 1, 1, 1, 1, 0, 0, 165, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14727, 833, 1, 1, 1, 1, 1, 0, 0, 166, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14728, 833, 1, 1, 1, 1, 1, 0, 0, 167, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14729, 833, 1, 1, 1, 1, 1, 0, 0, 168, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14730, 833, 1, 1, 1, 1, 1, 0, 0, 169, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14731, 833, 1, 1, 1, 1, 1, 0, 0, 170, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14732, 833, 1, 1, 1, 1, 1, 0, 0, 171, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14733, 833, 1, 1, 1, 1, 1, 0, 0, 172, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14734, 833, 1, 1, 1, 1, 1, 0, 0, 173, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14735, 833, 1, 1, 1, 1, 1, 0, 0, 174, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14736, 833, 1, 1, 1, 1, 1, 0, 0, 175, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14737, 833, 1, 1, 1, 1, 1, 0, 0, 176, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14738, 833, 1, 1, 1, 1, 1, 0, 0, 177, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14739, 833, 1, 1, 1, 1, 1, 0, 0, 178, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14740, 833, 1, 1, 1, 1, 1, 0, 0, 179, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14741, 833, 1, 1, 1, 1, 1, 0, 0, 180, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14742, 833, 1, 1, 1, 1, 1, 0, 0, 181, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14743, 833, 1, 1, 1, 1, 1, 0, 0, 182, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14744, 833, 1, 1, 1, 1, 1, 0, 0, 183, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14745, 833, 1, 1, 1, 1, 1, 0, 0, 184, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14746, 833, 1, 1, 1, 1, 1, 0, 0, 185, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14747, 833, 1, 1, 1, 1, 1, 0, 0, 186, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14748, 833, 1, 1, 1, 1, 1, 0, 0, 187, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14749, 833, 1, 1, 1, 1, 1, 0, 0, 188, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14750, 833, 1, 1, 1, 1, 1, 0, 0, 189, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14751, 833, 1, 1, 1, 1, 1, 0, 0, 190, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14752, 833, 1, 1, 1, 1, 1, 0, 0, 191, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14753, 833, 1, 1, 1, 1, 1, 0, 0, 192, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14754, 833, 1, 1, 1, 1, 1, 0, 0, 193, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14755, 833, 1, 1, 1, 1, 1, 0, 0, 194, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14756, 833, 1, 1, 1, 1, 1, 0, 0, 195, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14757, 833, 1, 1, 1, 1, 1, 0, 0, 196, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14758, 834, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19262, 841, 1, 1, 1, 0, 0, 0, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19264, 841, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19265, 841, 1, 1, 1, 0, 0, 0, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19266, 841, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19267, 841, 1, 1, 1, 0, 0, 0, 0, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19268, 841, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19269, 841, 1, 1, 1, 0, 0, 0, 0, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14860, 841, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14861, 841, 1, 1, 1, 0, 0, 20000000, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14862, 841, 1, 1, 1, 0, 0, 1700000, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14863, 841, 1, 1, 1, 0, 0, 0, 1699999, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14864, 841, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14865, 841, 1, 1, 1, 0, 0, 20000000, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14866, 841, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19275, 841, 1, 1, 1, 0, 0, 0, 0, 17, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19277, 841, 1, 1, 1, 0, 0, 0, 0, 18, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19278, 841, 1, 1, 1, 0, 0, 0, 0, 19, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19279, 841, 1, 1, 1, 0, 0, 1999999, 0, 20, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19280, 841, 1, 1, 1, 0, 0, 0, 1999999, 21, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19281, 841, 1, 1, 1, 0, 0, 0, 0, 22, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19282, 841, 1, 1, 1, 0, 0, 0, 0, 23, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14894, 842, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19284, 841, 1, 1, 1, 0, 0, 0, 0, 24, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14895, 842, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19286, 841, 1, 1, 1, 0, 0, 1999999, 0, 25, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19287, 841, 1, 1, 1, 0, 0, 0, 1999999, 26, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14896, 842, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14897, 842, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14867, 841, 1, 1, 1, 0, 0, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14898, 842, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14868, 841, 1, 1, 1, 0, 0, 11999988, 0, 17, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14899, 842, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14869, 841, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14900, 842, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19289, 841, 1, 1, 1, 0, 0, 0, 0, 30, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14901, 842, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19291, 841, 1, 1, 1, 0, 0, 0, 0, 31, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14902, 842, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19190, 328, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3385, 328, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3386, 328, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3387, 328, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3388, 328, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3393, 328, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19191, 328, 1, 1, 1, 1, 1, 0, 68150, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19192, 328, 1, 1, 1, 1, 1, 0, 50110, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19193, 328, 1, 1, 1, 1, 1, 0, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19194, 328, 1, 1, 1, 1, 1, 0, 68150, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19195, 328, 1, 1, 1, 1, 1, 0, 0, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19196, 328, 1, 1, 1, 1, 1, 0, 0, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3391, 328, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19197, 328, 1, 1, 1, 1, 1, 0, 50110, 13, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19198, 328, 1, 1, 1, 1, 1, 0, 50110, 14, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19199, 328, 1, 1, 1, 1, 1, 0, 0, 15, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19200, 328, 1, 1, 1, 1, 1, 0, 0, 16, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19201, 328, 1, 1, 1, 1, 1, 0, 0, 17, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19202, 328, 1, 1, 1, 1, 1, 0, 0, 18, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19203, 328, 1, 1, 1, 1, 1, 0, 0, 19, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19204, 328, 1, 1, 1, 0, 0, 0, 0, 20, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19205, 328, 1, 1, 1, 0, 0, 0, 0, 21, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19219, 640, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19219, 640, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19219, 640, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19219, 640, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10166, 640, 1, 1, 1, 0, 0, 20044, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10166, 640, 1, 1, 1, 0, 0, 20044, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10166, 640, 1, 1, 1, 0, 0, 20044, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10166, 640, 1, 1, 1, 0, 0, 20044, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10167, 640, 1, 1, 1, 0, 0, 20044, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10167, 640, 1, 1, 1, 0, 0, 20044, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10167, 640, 1, 1, 1, 0, 0, 20044, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10167, 640, 1, 1, 1, 0, 0, 20044, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10168, 640, 1, 1, 1, 0, 0, 40088, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10168, 640, 1, 1, 1, 0, 0, 40088, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10168, 640, 1, 1, 1, 0, 0, 40088, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19229, 640, 1, 1, 1, 0, 0, 20044, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19229, 640, 1, 1, 1, 0, 0, 20044, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19229, 640, 1, 1, 1, 0, 0, 20044, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19229, 640, 1, 1, 1, 0, 0, 20044, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19230, 640, 1, 1, 1, 0, 0, 250550, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19230, 640, 1, 1, 1, 0, 0, 250550, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19230, 640, 1, 1, 1, 0, 0, 250550, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19230, 640, 1, 1, 1, 0, 0, 250550, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19231, 640, 1, 1, 1, 0, 0, 250550, 0, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19231, 640, 1, 1, 1, 0, 0, 250550, 0, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19231, 640, 1, 1, 1, 0, 0, 250550, 0, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19231, 640, 1, 1, 1, 0, 0, 250550, 0, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19232, 640, 1, 1, 1, 0, 0, 250550, 0, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19232, 640, 1, 1, 1, 0, 0, 250550, 0, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19232, 640, 1, 1, 1, 0, 0, 250550, 0, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19232, 640, 1, 1, 1, 0, 0, 250550, 0, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19234, 640, 1, 1, 1, 0, 0, 250550, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19234, 640, 1, 1, 1, 0, 0, 250550, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19234, 640, 1, 1, 1, 0, 0, 250550, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19234, 640, 1, 1, 1, 0, 0, 250550, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10171, 640, 1, 1, 1, 0, 0, 250550, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10171, 640, 1, 1, 1, 0, 0, 250550, 0, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10171, 640, 1, 1, 1, 0, 0, 250550, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10172, 640, 1, 1, 1, 0, 0, 250550, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10172, 640, 1, 1, 1, 0, 0, 250550, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10172, 640, 1, 1, 1, 0, 0, 250550, 0, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10172, 640, 1, 1, 1, 0, 0, 250550, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19240, 640, 1, 1, 1, 0, 0, 501099, 0, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19240, 640, 1, 1, 1, 0, 0, 501099, 0, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10370, 648, 1, 1, 1, 1, 1, 200, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10371, 648, 1, 1, 1, 1, 1, 200, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 19228, 834, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14759, 834, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14800, 836, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14801, 836, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14802, 836, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14803, 837, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14804, 837, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14805, 837, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14806, 837, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14842, 840, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14843, 840, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14844, 840, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14851, 841, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14845, 840, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14852, 841, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14846, 840, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14856, 841, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14847, 840, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14848, 840, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14849, 840, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14850, 840, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14851, 841, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14852, 841, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19263, 887, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18275, 887, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14804, 837, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14944, 843, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14945, 843, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14946, 843, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14947, 843, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14948, 843, 1, 1, 1, 0, 0, 0, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14805, 837, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14949, 843, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14950, 843, 1, 1, 1, 0, 0, 0, 0, 16, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 14806, 837, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14853, 841, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14854, 841, 1, 1, 1, 0, 0, 44999930, 0, 3, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14855, 841, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14856, 841, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14857, 841, 1, 1, 1, 0, 0, 9000006, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14858, 841, 1, 1, 1, 0, 0, 3000002, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14859, 841, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14860, 841, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14861, 841, 1, 1, 1, 0, 0, 20000000, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14862, 841, 1, 1, 1, 0, 0, 1700000, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14863, 841, 1, 1, 1, 0, 0, 0, 1700000, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14864, 841, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14865, 841, 1, 1, 1, 0, 0, 20000000, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14866, 841, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14867, 841, 1, 1, 1, 0, 0, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14868, 841, 1, 1, 1, 0, 0, 11999988, 0, 17, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14869, 841, 1, 1, 1, 0, 0, 0, 0, 18, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14870, 841, 1, 1, 1, 0, 0, 0, 0, 19, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14871, 841, 1, 1, 1, 0, 0, 0, 0, 20, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14872, 841, 1, 1, 1, 0, 0, 0, 0, 21, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14873, 841, 1, 1, 1, 0, 0, 0, 0, 22, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14874, 841, 1, 1, 1, 0, 0, 0, 0, 23, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14875, 841, 1, 1, 1, 0, 0, 0, 0, 24, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14876, 841, 1, 1, 1, 0, 0, 0, 0, 25, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14877, 841, 1, 1, 1, 0, 0, 0, 0, 26, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14878, 841, 1, 1, 1, 0, 0, 0, 0, 27, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14879, 841, 1, 1, 1, 0, 0, 0, 0, 28, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14880, 841, 1, 1, 1, 0, 0, 0, 0, 29, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14881, 841, 1, 1, 1, 0, 0, 0, 0, 30, '', NULL);
@@ -2104,234 +1502,60 @@
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14891, 841, 1, 1, 1, 0, 0, 0, 0, 40, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14892, 841, 1, 1, 1, 0, 0, 0, 0, 41, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14893, 841, 1, 1, 1, 0, 0, 0, 0, 42, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14894, 842, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14895, 842, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14896, 842, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14897, 842, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14898, 842, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14899, 842, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14900, 842, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14901, 842, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14902, 842, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14903, 842, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14904, 842, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14905, 842, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14906, 842, 1, 1, 1, 1, 1, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14907, 842, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14908, 842, 1, 1, 1, 1, 1, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14909, 842, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14910, 842, 1, 1, 1, 1, 1, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14911, 842, 1, 1, 1, 1, 1, 0, 0, 17, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14912, 842, 1, 1, 1, 1, 1, 0, 0, 18, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14913, 842, 1, 1, 1, 0, 0, 0, 0, 19, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14914, 842, 1, 1, 1, 1, 1, 0, 0, 20, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14915, 842, 1, 1, 1, 0, 0, 0, 0, 21, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14916, 842, 1, 1, 1, 0, 0, 0, 0, 22, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14917, 842, 1, 1, 1, 0, 0, 0, 0, 23, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14918, 842, 1, 1, 1, 0, 0, 0, 0, 24, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14919, 842, 1, 1, 1, 0, 0, 0, 0, 25, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14920, 842, 1, 1, 1, 1, 1, 0, 0, 26, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14921, 842, 1, 1, 1, 1, 1, 0, 0, 27, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14922, 842, 1, 1, 1, 1, 1, 0, 0, 28, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14923, 842, 1, 1, 1, 1, 1, 0, 0, 29, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14924, 842, 1, 1, 1, 1, 1, 0, 0, 30, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14925, 842, 1, 1, 1, 1, 1, 0, 0, 31, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14926, 842, 1, 1, 1, 1, 1, 0, 0, 32, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14927, 842, 1, 1, 1, 1, 1, 0, 0, 33, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14928, 842, 1, 1, 1, 1, 1, 0, 0, 34, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14929, 842, 1, 1, 1, 1, 1, 0, 0, 35, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14930, 842, 1, 1, 1, 1, 1, 0, 0, 36, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14931, 842, 1, 1, 1, 0, 0, 0, 0, 37, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14932, 842, 1, 1, 1, 1, 1, 0, 0, 38, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14933, 842, 1, 1, 1, 1, 1, 0, 0, 39, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14934, 843, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14935, 843, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14936, 843, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14937, 843, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14938, 843, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14939, 843, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14940, 843, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14941, 843, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14942, 843, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14943, 843, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14944, 843, 1, 1, 1, 0, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14945, 843, 1, 1, 1, 0, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14946, 843, 1, 1, 1, 0, 0, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14947, 843, 1, 1, 1, 0, 0, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14948, 843, 1, 1, 1, 0, 0, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14949, 843, 1, 1, 1, 0, 0, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14950, 843, 1, 1, 1, 0, 0, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14951, 844, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14952, 844, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14953, 844, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14954, 844, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14955, 844, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14956, 844, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14957, 844, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14958, 844, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14959, 844, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14960, 844, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14961, 844, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14962, 844, 1, 1, 1, 1, 1, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14963, 844, 1, 1, 1, 1, 1, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14964, 844, 1, 1, 1, 1, 1, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14965, 844, 1, 1, 1, 1, 1, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14966, 844, 1, 1, 1, 1, 1, 0, 0, 15, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14967, 844, 1, 1, 1, 1, 1, 0, 0, 16, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14968, 844, 1, 1, 1, 1, 1, 0, 0, 17, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14969, 844, 1, 1, 1, 1, 1, 0, 0, 18, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14970, 844, 1, 1, 1, 1, 1, 0, 0, 19, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14971, 844, 1, 1, 1, 1, 1, 0, 0, 20, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14972, 844, 1, 1, 1, 1, 1, 0, 0, 21, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14973, 844, 1, 1, 1, 1, 1, 0, 0, 22, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14974, 844, 1, 1, 1, 1, 1, 0, 0, 23, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14975, 844, 1, 1, 1, 1, 1, 0, 0, 24, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14976, 844, 1, 1, 1, 1, 1, 0, 0, 25, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14977, 844, 1, 1, 1, 1, 1, 0, 0, 26, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14978, 844, 1, 1, 1, 1, 1, 0, 0, 27, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14979, 844, 1, 1, 1, 1, 1, 0, 0, 28, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14980, 844, 1, 1, 1, 1, 1, 0, 0, 29, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14981, 844, 1, 1, 1, 1, 1, 0, 0, 30, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14982, 844, 1, 1, 1, 1, 1, 0, 0, 31, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14983, 844, 1, 1, 1, 1, 1, 0, 0, 32, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14984, 844, 1, 1, 1, 1, 1, 0, 0, 33, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14985, 844, 1, 1, 1, 1, 1, 0, 0, 34, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14986, 844, 1, 1, 1, 1, 1, 0, 0, 35, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14987, 844, 1, 1, 1, 1, 1, 0, 0, 36, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14988, 844, 1, 1, 1, 1, 1, 0, 0, 37, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14989, 844, 1, 1, 1, 1, 1, 0, 0, 38, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14990, 844, 1, 1, 1, 1, 1, 0, 0, 39, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14991, 844, 1, 1, 1, 1, 1, 0, 0, 40, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14992, 844, 1, 1, 1, 1, 1, 0, 0, 41, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14993, 844, 1, 1, 1, 1, 1, 0, 0, 42, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14994, 844, 1, 1, 1, 1, 1, 0, 0, 43, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14995, 844, 1, 1, 1, 1, 1, 0, 0, 44, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14996, 844, 1, 1, 1, 1, 1, 0, 0, 45, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14997, 844, 1, 1, 1, 1, 1, 0, 0, 46, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14998, 844, 1, 1, 1, 1, 1, 0, 0, 47, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14999, 844, 1, 1, 1, 1, 1, 0, 0, 48, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15000, 844, 1, 1, 1, 1, 1, 0, 0, 49, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15001, 844, 1, 1, 1, 1, 1, 0, 0, 50, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15002, 844, 1, 1, 1, 1, 1, 0, 0, 51, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15003, 844, 1, 1, 1, 1, 1, 0, 0, 52, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15004, 844, 1, 1, 1, 1, 1, 0, 0, 53, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15005, 844, 1, 1, 1, 1, 1, 0, 0, 54, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15006, 844, 1, 1, 1, 1, 1, 0, 0, 55, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15007, 844, 1, 1, 1, 1, 1, 0, 0, 56, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15008, 844, 1, 1, 1, 1, 1, 0, 0, 57, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15009, 844, 1, 1, 1, 1, 1, 0, 0, 58, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15010, 844, 1, 1, 1, 1, 1, 0, 0, 59, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18119, 866, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18120, 866, 1, 1, 1, 1, 1, 200, 749888, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18121, 866, 1, 1, 1, 1, 1, 200, 749888, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18122, 866, 1, 1, 1, 1, 1, 200, 749888, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18123, 866, 1, 1, 1, 1, 1, 200, 749888, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18124, 866, 1, 1, 1, 1, 1, 200, 749888, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18125, 866, 1, 1, 1, 1, 1, 200, 749888, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18126, 866, 1, 1, 1, 1, 1, 200, 374944, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18127, 866, 1, 1, 1, 1, 1, 200, 374944, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18128, 866, 1, 1, 1, 1, 1, 200, 374944, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18129, 866, 1, 1, 1, 1, 1, 200, 374944, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18130, 866, 1, 1, 1, 1, 1, 200, 374944, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18131, 866, 1, 1, 1, 1, 1, 200, 374944, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18132, 867, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18133, 867, 1, 1, 1, 1, 1, 22497, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18134, 867, 1, 1, 1, 1, 1, 22497, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18135, 867, 1, 1, 1, 1, 1, 22497, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18136, 867, 1, 1, 1, 1, 1, 22497, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18137, 867, 1, 1, 1, 1, 1, 22497, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18138, 867, 1, 1, 1, 1, 1, 22497, 74989, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18139, 867, 1, 1, 1, 1, 1, 22497, 0, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18140, 867, 1, 1, 1, 1, 1, 22497, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18141, 867, 1, 1, 1, 1, 1, 22497, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18142, 867, 1, 1, 1, 1, 1, 22497, 0, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19302, 841, 1, 1, 1, 0, 0, 0, 0, 62, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19303, 841, 1, 1, 1, 0, 0, 0, 0, 63, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19304, 841, 1, 1, 1, 0, 0, 0, 0, 64, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19305, 841, 1, 1, 1, 0, 0, 0, 0, 65, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7517, 584, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7518, 584, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18143, 868, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18144, 868, 1, 1, 1, 0, 0, 26075, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18145, 869, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18159, 871, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18160, 871, 1, 1, 1, 0, 0, 2400, 2000000, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18161, 871, 1, 1, 1, 0, 0, 375, 3900, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18162, 871, 1, 1, 1, 0, 0, 1, 3900, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18163, 871, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18164, 871, 1, 1, 1, 0, 0, 1, 2500, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18165, 871, 1, 1, 1, 0, 0, 1, 2500, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18166, 871, 1, 1, 1, 0, 0, 1, 2500, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18167, 871, 1, 1, 1, 0, 0, 1, 2500, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10153, 637, 1, 1, 1, 0, 0, 50000, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10154, 637, 1, 1, 1, 0, 0, 50000, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10155, 637, 1, 1, 1, 0, 0, 50000, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10156, 637, 1, 1, 1, 0, 0, 50000, 2000000, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10157, 637, 1, 1, 1, 0, 0, 50000, 1000000, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10158, 637, 1, 1, 1, 0, 0, 50000, 749999, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10159, 637, 1, 1, 1, 0, 0, 4999990, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10160, 637, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19211, 637, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19270, 869, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18146, 869, 1, 1, 1, 1, 1, 0, 150214, 1, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18147, 869, 1, 1, 1, 1, 1, 0, 150214, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18133, 867, 1, 1, 1, 1, 1, 22497, 0, 1, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18148, 869, 1, 1, 1, 1, 1, 0, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18134, 867, 1, 1, 1, 1, 1, 22497, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18135, 867, 1, 1, 1, 1, 1, 22497, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18121, 866, 1, 1, 1, 1, 1, 200, 749888, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18122, 866, 1, 1, 1, 1, 1, 200, 749888, 3, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18149, 869, 1, 1, 1, 1, 1, 0, 150214, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18136, 867, 1, 1, 1, 1, 1, 22497, 0, 4, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18150, 869, 1, 1, 1, 1, 1, 0, 150214, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18137, 867, 1, 1, 1, 1, 1, 22497, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18123, 866, 1, 1, 1, 1, 1, 200, 749888, 4, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18151, 869, 1, 1, 1, 1, 1, 0, 150214, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18138, 867, 1, 1, 1, 1, 1, 22497, 74989, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18124, 866, 1, 1, 1, 1, 1, 200, 749888, 5, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18152, 869, 1, 1, 1, 1, 1, 0, 150214, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18139, 867, 1, 1, 1, 1, 1, 22497, 0, 7, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18153, 869, 1, 1, 1, 1, 1, 0, 150214, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18125, 866, 1, 1, 1, 1, 1, 200, 749888, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18140, 867, 1, 1, 1, 1, 1, 22497, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18126, 866, 1, 1, 1, 1, 1, 200, 374944, 7, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18154, 869, 1, 1, 1, 1, 1, 0, 150214, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18155, 869, 1, 1, 1, 1, 1, 0, 150214, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18159, 871, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18160, 871, 1, 1, 1, 0, 0, 2400, 2000000, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18161, 871, 1, 1, 1, 0, 0, 375, 3900, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18162, 871, 1, 1, 1, 0, 0, 1, 3900, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18163, 871, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18164, 871, 1, 1, 1, 0, 0, 1, 2500, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18165, 871, 1, 1, 1, 0, 0, 1, 2500, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18166, 871, 1, 1, 1, 0, 0, 1, 2500, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18167, 871, 1, 1, 1, 0, 0, 1, 2500, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18168, 872, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18169, 872, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18170, 872, 1, 1, 1, 0, 0, 0, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18171, 872, 1, 1, 1, 0, 0, 0, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18172, 872, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18173, 872, 1, 1, 1, 0, 0, 0, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18174, 872, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18175, 872, 1, 1, 1, 0, 0, 0, 0, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18176, 872, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18177, 872, 1, 1, 1, 0, 0, 0, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18178, 872, 1, 1, 1, 0, 0, 0, 0, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18179, 872, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18180, 872, 1, 1, 1, 0, 0, 0, 0, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18181, 872, 1, 1, 1, 0, 0, 0, 0, 13, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18182, 872, 1, 1, 1, 0, 0, 0, 0, 14, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18183, 872, 1, 1, 1, 0, 0, 0, 0, 15, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18184, 872, 1, 1, 1, 0, 0, 0, 0, 16, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18185, 872, 1, 1, 1, 0, 0, 0, 0, 17, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18186, 872, 1, 1, 1, 0, 0, 0, 0, 18, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18187, 872, 1, 1, 1, 0, 0, 0, 0, 19, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18188, 872, 1, 1, 1, 0, 0, 0, 0, 20, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18189, 872, 1, 1, 1, 0, 0, 0, 0, 21, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18190, 872, 1, 1, 1, 0, 0, 0, 0, 22, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18191, 872, 1, 1, 1, 0, 0, 0, 0, 23, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18192, 872, 1, 1, 1, 0, 0, 0, 0, 24, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18193, 872, 1, 1, 1, 0, 0, 0, 0, 25, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18194, 872, 1, 1, 1, 0, 0, 0, 0, 26, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18195, 872, 1, 1, 1, 0, 0, 0, 0, 27, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18196, 872, 1, 1, 1, 0, 0, 0, 0, 28, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18205, 881, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18206, 881, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18207, 881, 1, 1, 1, 0, 0, 0, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18208, 881, 1, 1, 1, 0, 0, 0, 300000, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18209, 881, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18210, 881, 1, 1, 1, 0, 0, 0, 300000, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18211, 881, 1, 1, 1, 0, 0, 0, 300000, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18212, 881, 1, 1, 1, 0, 0, 0, 0, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18213, 881, 1, 1, 1, 0, 0, 0, 300000, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18214, 881, 1, 1, 1, 0, 0, 0, 300000, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18215, 881, 1, 1, 1, 0, 0, 0, 0, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18216, 881, 1, 1, 1, 0, 0, 0, 100000, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18217, 881, 1, 1, 1, 0, 0, 0, 100000, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18218, 882, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18219, 882, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18220, 882, 1, 1, 1, 0, 0, 135001, 300000, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18221, 882, 1, 1, 1, 0, 0, 20001, 135000, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18222, 882, 1, 1, 1, 0, 0, 12001, 20000, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18223, 882, 1, 1, 1, 0, 0, 2751, 12000, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18224, 882, 1, 1, 1, 0, 0, 0, 2750, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18225, 882, 1, 1, 1, 0, 0, 300000, 1000000, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18226, 882, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18227, 882, 1, 1, 1, 0, 0, 0, 300000, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18228, 882, 1, 1, 1, 0, 0, 0, 300000, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18229, 882, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18230, 882, 1, 1, 1, 0, 0, 0, 300000, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18231, 882, 1, 1, 1, 0, 0, 0, 300000, 13, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18232, 882, 1, 1, 1, 0, 0, 0, 0, 14, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18233, 882, 1, 1, 1, 0, 0, 0, 300000, 15, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18234, 882, 1, 1, 1, 0, 0, 0, 300000, 16, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18235, 883, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18236, 883, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18237, 883, 1, 1, 1, 0, 0, 0, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18238, 883, 1, 1, 1, 0, 0, 0, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18239, 883, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18240, 883, 1, 1, 1, 0, 0, 0, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19117, 902, 1, 1, 1, 0, 0, 25001, 250001, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18127, 866, 1, 1, 1, 1, 1, 200, 374944, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18141, 867, 1, 1, 1, 1, 1, 22497, 0, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19206, 670, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18246, 885, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18247, 885, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18248, 885, 1, 1, 1, 0, 0, 0, 0, 2, NULL, NULL);
@@ -2359,106 +1583,83 @@
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18270, 885, 1, 1, 1, 0, 0, 0, 0, 24, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18271, 885, 1, 1, 1, 0, 0, 0, 0, 25, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18272, 885, 1, 1, 1, 0, 0, 0, 0, 26, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18274, 887, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18275, 887, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 11629, 717, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 11630, 717, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10028, 624, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10029, 624, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10030, 624, 1, 1, 1, 1, 1, 0, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10031, 624, 1, 1, 1, 1, 1, 0, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10032, 624, 1, 1, 1, 1, 1, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10033, 624, 1, 1, 1, 1, 1, 0, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10034, 624, 1, 1, 1, 1, 1, 0, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10035, 624, 1, 1, 1, 1, 1, 0, 0, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10036, 624, 1, 1, 1, 1, 1, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10037, 624, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10038, 624, 1, 1, 1, 1, 1, 0, 0, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10039, 624, 1, 1, 1, 1, 1, 0, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10040, 624, 1, 1, 1, 1, 1, 0, 0, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10041, 624, 1, 1, 1, 1, 1, 0, 0, 13, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10042, 624, 1, 1, 1, 1, 1, 0, 0, 14, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10043, 624, 1, 1, 1, 1, 1, 0, 0, 15, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10044, 624, 1, 1, 1, 1, 1, 0, 0, 16, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10045, 624, 1, 1, 1, 1, 1, 0, 0, 17, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10046, 624, 1, 1, 1, 1, 1, 0, 0, 18, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10369, 648, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10370, 648, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10371, 648, 1, 1, 1, 1, 1, 0, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10987, 670, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10988, 670, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19206, 670, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10989, 670, 1, 1, 1, 0, 0, 37494, 187472, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10990, 670, 1, 1, 1, 0, 0, 37494, 187472, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19240, 640, 1, 1, 1, 0, 0, 501099, 0, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19240, 640, 1, 1, 1, 0, 0, 501099, 0, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10173, 640, 1, 1, 1, 0, 0, 1002199, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10173, 640, 1, 1, 1, 0, 0, 1002199, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10173, 640, 1, 1, 1, 0, 0, 1002199, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10174, 640, 1, 1, 1, 0, 0, 90198, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10174, 640, 1, 1, 1, 0, 0, 90198, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10174, 640, 1, 1, 1, 0, 0, 90198, 0, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10174, 640, 1, 1, 1, 0, 0, 90198, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10175, 640, 1, 1, 1, 0, 0, 1002199, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10175, 640, 1, 1, 1, 0, 0, 1002199, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10175, 640, 1, 1, 1, 0, 0, 1002199, 0, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10175, 640, 1, 1, 1, 0, 0, 1002199, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10176, 640, 1, 1, 1, 0, 0, 90198, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10370, 648, 1, 1, 1, 1, 1, 200, 0, 1, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10989, 670, 1, 1, 1, 0, 0, 37494, 187472, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19207, 671, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19207, 671, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10990, 670, 1, 1, 1, 0, 0, 37494, 187472, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10991, 671, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10371, 648, 1, 1, 1, 1, 1, 200, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10992, 671, 1, 1, 1, 1, 1, 0, 0, 1, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10992, 671, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10993, 671, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10993, 671, 1, 1, 1, 1, 1, 0, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10994, 671, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10994, 671, 1, 1, 1, 1, 1, 0, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 11630, 717, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 10995, 671, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 10995, 671, 1, 1, 1, 1, 1, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10168, 640, 1, 1, 0, 0, 0, 0, 0, 3, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10169, 640, 1, 1, 0, 0, 0, 0, 0, 4, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10170, 640, 1, 1, 0, 0, 0, 0, 0, 5, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10171, 640, 1, 1, 0, 0, 0, 0, 0, 6, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10172, 640, 1, 1, 0, 0, 0, 0, 0, 7, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10173, 640, 1, 1, 0, 0, 0, 0, 0, 8, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10174, 640, 1, 1, 0, 0, 0, 0, 0, 9, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10175, 640, 1, 1, 0, 0, 0, 0, 0, 10, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10176, 640, 1, 1, 0, 0, 0, 0, 0, 11, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10177, 640, 1, 1, 0, 0, 0, 0, 0, 12, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10178, 640, 1, 1, 0, 0, 0, 0, 0, 13, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19138, 904, 1, 1, 1, 0, 0, 25001, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19139, 904, 1, 1, 1, 1, 1, 200000, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19140, 904, 1, 1, 1, 0, 0, 200000, 1000000, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19141, 904, 1, 1, 1, 0, 0, 200000, 749999, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19142, 904, 1, 1, 1, 0, 0, 200000, 749999, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19143, 904, 1, 1, 1, 0, 0, 200000, 749999, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19144, 904, 1, 1, 1, 0, 0, 200000, 749999, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19145, 904, 1, 1, 1, 0, 0, 200000, 400000, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19146, 904, 1, 1, 1, 0, 0, 200000, 1000000, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19147, 904, 1, 1, 1, 0, 0, 200000, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19148, 904, 1, 1, 1, 0, 0, 1000000, 0, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10179, 640, 1, 1, 0, 0, 0, 0, 0, 14, '', NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19149, 905, 1, 1, 1, 0, 0, 50000, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19150, 905, 1, 1, 1, 1, 1, 50000, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19151, 905, 1, 1, 1, 1, 1, 50000, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19152, 905, 1, 1, 1, 1, 1, 50000, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19153, 905, 1, 1, 1, 1, 1, 50000, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19154, 905, 1, 1, 1, 1, 1, 50000, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19079, 899, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19080, 899, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19081, 899, 1, 1, 1, 0, 0, 0, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19082, 899, 1, 1, 1, 0, 0, 0, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19083, 899, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19084, 899, 1, 1, 1, 0, 0, 0, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19085, 899, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19086, 899, 1, 1, 1, 0, 0, 0, 0, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19087, 899, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19088, 899, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19089, 899, 1, 1, 1, 1, 1, 0, 0, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19090, 900, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19091, 900, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19092, 900, 1, 1, 1, 0, 0, 0, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19093, 900, 1, 1, 1, 0, 0, 0, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19094, 900, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19095, 900, 1, 1, 1, 0, 0, 0, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19096, 900, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19097, 900, 1, 1, 1, 0, 0, 0, 0, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19098, 900, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19099, 900, 1, 1, 1, 0, 0, 0, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19100, 900, 1, 1, 1, 0, 0, 0, 0, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19101, 900, 1, 1, 1, 0, 0, 0, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19102, 900, 1, 1, 1, 0, 0, 0, 0, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19103, 900, 1, 1, 1, 0, 0, 0, 0, 13, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19104, 900, 1, 1, 1, 0, 0, 0, 0, 14, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_africa', 19105, 900, 1, 1, 1, 0, 0, 0, 0, 15, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10168, 640, 1, 1, 1, 0, 0, 40088, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10171, 640, 1, 1, 1, 0, 0, 250550, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7519, 584, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7520, 584, 1, 1, 1, 1, 1, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7521, 584, 1, 1, 1, 1, 1, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7522, 584, 1, 1, 1, 1, 1, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7523, 584, 1, 1, 1, 1, 1, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7524, 584, 1, 1, 1, 1, 1, 0, 0, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7525, 584, 1, 1, 1, 1, 1, 0, 0, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7526, 584, 1, 1, 1, 1, 1, 0, 0, 9, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_north_america', 7527, 584, 1, 1, 1, 1, 1, 0, 0, 10, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19246, 828, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19247, 828, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19248, 828, 1, 1, 1, 1, 1, 0, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19249, 828, 1, 1, 1, 1, 1, 0, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19250, 828, 1, 1, 1, 1, 1, 0, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19252, 828, 1, 1, 1, 1, 1, 0, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19254, 828, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19255, 828, 1, 1, 1, 1, 1, 0, 0, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19256, 828, 1, 1, 1, 1, 1, 0, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19257, 828, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19273, 843, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14935, 843, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14936, 843, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14937, 843, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19110, 902, 1, 1, 1, 0, 0, 25001, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14938, 843, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19008, 893, 1, 1, 1, 0, 0, 750000, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14939, 843, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19008, 893, 1, 1, 1, 0, 0, 750000, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19111, 902, 1, 1, 1, 1, 1, 25001, 0, 1, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19008, 893, 1, 1, 1, 0, 0, 750000, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14940, 843, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19008, 893, 1, 1, 1, 0, 0, 750000, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19112, 902, 1, 1, 1, 0, 0, 25001, 150000, 2, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19008, 893, 1, 1, 1, 0, 0, 750000, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14941, 843, 1, 1, 1, 0, 0, 0, 0, 7, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19009, 893, 1, 1, 1, 0, 0, 750000, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19113, 902, 1, 1, 1, 0, 0, 25001, 2000000, 3, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19009, 893, 1, 1, 1, 0, 0, 750000, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19114, 902, 1, 1, 1, 0, 0, 25001, 600000, 4, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19009, 893, 1, 1, 1, 0, 0, 750000, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14942, 843, 1, 1, 1, 0, 0, 0, 0, 8, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19009, 893, 1, 1, 1, 0, 0, 750000, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14943, 843, 1, 1, 1, 0, 0, 0, 0, 9, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19009, 893, 1, 1, 1, 0, 0, 750000, 0, 3, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19010, 893, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19010, 893, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
@@ -2475,8 +1676,11 @@
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19012, 893, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19012, 893, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19012, 893, 1, 1, 1, 0, 0, 0, 0, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19115, 902, 1, 1, 1, 0, 0, 25001, 200000, 5, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19013, 893, 1, 1, 1, 0, 0, 0, 1250000, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19283, 843, 1, 1, 1, 0, 0, 0, 0, 10, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19013, 893, 1, 1, 1, 0, 0, 0, 1250000, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19116, 902, 1, 1, 1, 0, 0, 25001, 150000, 6, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19013, 893, 1, 1, 1, 0, 0, 0, 1250000, 7, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19013, 893, 1, 1, 1, 0, 0, 0, 1250000, 7, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19013, 893, 1, 1, 1, 0, 0, 0, 1250000, 7, NULL, NULL);
@@ -2486,89 +1690,39 @@
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19014, 893, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19014, 893, 1, 1, 1, 0, 0, 0, 0, 8, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19015, 893, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19110, 902, 1, 1, 1, 0, 0, 25001, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19111, 902, 1, 1, 1, 1, 1, 25001, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19112, 902, 1, 1, 1, 0, 0, 25001, 150000, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19113, 902, 1, 1, 1, 0, 0, 25001, 2000000, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19114, 902, 1, 1, 1, 0, 0, 25001, 600000, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19115, 902, 1, 1, 1, 0, 0, 25001, 200000, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19116, 902, 1, 1, 1, 0, 0, 25001, 150000, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19117, 902, 1, 1, 1, 0, 0, 25001, 250001, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19118, 902, 1, 1, 1, 0, 0, 25001, 250001, 8, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19015, 893, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19015, 893, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19015, 893, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19006, 893, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19006, 893, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19119, 902, 1, 1, 1, 0, 0, 25001, 100000, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19120, 902, 1, 1, 1, 0, 0, 25001, 250001, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19121, 902, 1, 1, 1, 0, 0, 25001, 749999, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19122, 902, 1, 1, 1, 0, 0, 25001, 0, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19123, 902, 1, 1, 1, 0, 0, 25001, 100000, 13, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19124, 902, 1, 1, 1, 0, 0, 2000000, 0, 14, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19155, 906, 1, 1, 1, 0, 0, 50000, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19156, 906, 1, 1, 1, 0, 0, 50000, 1000000, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19157, 906, 1, 1, 1, 1, 1, 50000, 1000000, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19158, 906, 1, 1, 1, 1, 1, 50000, 1000000, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19159, 906, 1, 1, 1, 1, 1, 50000, 1000000, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19160, 906, 1, 1, 1, 1, 1, 50000, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19161, 906, 1, 1, 1, 1, 1, 50000, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19162, 906, 1, 1, 1, 0, 0, 50000, 0, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19163, 906, 1, 1, 1, 0, 0, 50000, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19164, 906, 1, 1, 1, 0, 0, 50000, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19165, 906, 1, 1, 1, 0, 0, 50000, 0, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19166, 906, 1, 1, 1, 0, 0, 50000, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19167, 906, 1, 1, 1, 0, 0, 50000, 0, 12, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19170, 908, 1, 1, 1, 0, 0, 0, 140316, 0, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19171, 908, 1, 1, 1, 1, 1, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2712, 250, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2713, 250, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2713, 250, 1, 1, 1, 1, 0, 0, 0, 1, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2714, 250, 1, 1, 1, 1, 0, 0, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2715, 250, 1, 1, 1, 0, 0, 0, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2715, 250, 1, 1, 1, 1, 0, 0, 0, 3, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2716, 250, 1, 1, 1, 0, 0, 0, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19172, 909, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19173, 909, 1, 1, 1, 1, 1, 0, 0, 1, NULL, '2');
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19174, 909, 1, 1, 1, 1, 1, 0, 0, 2, NULL, '3');
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19175, 909, 1, 1, 1, 1, 1, 0, 0, 3, NULL, '4');
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2717, 250, 1, 1, 1, 1, 0, 0, 0, 5, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2718, 250, 1, 1, 1, 1, 0, 0, 0, 6, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2719, 250, 1, 1, 1, 1, 0, 0, 0, 7, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2720, 250, 1, 1, 1, 1, 0, 0, 0, 8, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2721, 250, 1, 1, 1, 1, 0, 0, 0, 9, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2722, 250, 1, 1, 1, 1, 0, 0, 0, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2723, 250, 1, 1, 1, 1, 0, 0, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2724, 250, 1, 1, 1, 1, 0, 0, 0, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2725, 250, 1, 1, 1, 1, 0, 0, 0, 13, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2726, 250, 1, 1, 1, 1, 0, 0, 0, 14, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2727, 250, 1, 1, 1, 1, 0, 0, 0, 15, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2728, 250, 1, 1, 1, 1, 0, 0, 0, 16, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2729, 250, 1, 1, 1, 1, 0, 0, 0, 17, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2730, 250, 1, 1, 1, 0, 0, 0, 0, 18, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2731, 250, 1, 1, 1, 1, 0, 0, 0, 19, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2732, 250, 1, 1, 1, 1, 0, 0, 0, 20, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10165, 640, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10166, 640, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10167, 640, 1, 1, 0, 0, 0, 0, 0, 2, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10168, 640, 1, 1, 0, 0, 0, 0, 0, 3, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10169, 640, 1, 1, 0, 0, 0, 0, 0, 4, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10170, 640, 1, 1, 0, 0, 0, 0, 0, 5, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10171, 640, 1, 1, 0, 0, 0, 0, 0, 6, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10172, 640, 1, 1, 0, 0, 0, 0, 0, 7, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10173, 640, 1, 1, 0, 0, 0, 0, 0, 8, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10174, 640, 1, 1, 0, 0, 0, 0, 0, 9, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10175, 640, 1, 1, 0, 0, 0, 0, 0, 10, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10176, 640, 1, 1, 0, 0, 0, 0, 0, 11, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10177, 640, 1, 1, 0, 0, 0, 0, 0, 12, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10178, 640, 1, 1, 0, 0, 0, 0, 0, 13, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10179, 640, 1, 1, 0, 0, 0, 0, 0, 14, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19172, 909, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19006, 893, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19006, 893, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19006, 893, 1, 1, 1, 0, 0, 1, 0, 0, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19173, 909, 1, 1, 1, 1, 1, 0, 0, 1, NULL, '2');
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19174, 909, 1, 1, 1, 1, 1, 0, 0, 2, NULL, '3');
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2723, 250, 1, 1, 1, 1, 0, 0, 0, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2724, 250, 1, 1, 1, 1, 0, 0, 0, 12, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19007, 893, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
-INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19175, 909, 1, 1, 1, 1, 1, 0, 0, 3, NULL, '4');
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2725, 250, 1, 1, 1, 1, 0, 0, 0, 13, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19007, 893, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19007, 893, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 19007, 893, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19007, 893, 1, 1, 1, 0, 0, 0, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 2726, 250, 1, 1, 1, 1, 0, 0, 0, 14, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 19015, 893, 1, 1, 1, 1, 1, 0, 0, 9, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 19016, 893, 1, 1, 1, 0, 0, 0, 350000, 10, NULL, NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 19016, 893, 1, 1, 1, 0, 0, 0, 350000, 10, NULL, NULL);
@@ -2592,10 +1746,862 @@
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui1', 15339, 407, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 15339, 407, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
 INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 15339, 407, 1, 1, 1, 1, 1, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19210, 787, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14258, 787, 1, 1, 1, 0, 0, 20, 400880, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14259, 787, 1, 1, 1, 0, 0, 20, 80176, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 14260, 787, 1, 1, 1, 0, 0, 20, 801759, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10176, 640, 1, 1, 1, 0, 0, 90198, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10176, 640, 1, 1, 1, 0, 0, 90198, 0, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10176, 640, 1, 1, 1, 0, 0, 90198, 0, 11, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10177, 640, 1, 1, 1, 0, 0, 40088, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10177, 640, 1, 1, 1, 0, 0, 40088, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10177, 640, 1, 1, 1, 0, 0, 40088, 0, 12, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10177, 640, 1, 1, 1, 0, 0, 40088, 0, 12, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10178, 640, 1, 1, 1, 0, 0, 90198, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10178, 640, 1, 1, 1, 0, 0, 90198, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10178, 640, 1, 1, 1, 0, 0, 90198, 0, 13, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10178, 640, 1, 1, 1, 0, 0, 90198, 0, 13, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui', 10179, 640, 1, 1, 1, 0, 0, 90198, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui2', 10179, 640, 1, 1, 1, 0, 0, 90198, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('gui_digitize', 10179, 640, 1, 1, 1, 0, 0, 90198, 0, 14, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 10179, 640, 1, 1, 1, 0, 0, 90198, 0, 14, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 19271, 866, 1, 1, 1, 1, 1, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18120, 866, 1, 1, 1, 1, 1, 200, 749888, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19118, 902, 1, 1, 1, 0, 0, 25001, 250001, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18128, 866, 1, 1, 1, 1, 1, 200, 374944, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19119, 902, 1, 1, 1, 0, 0, 25001, 100000, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18129, 866, 1, 1, 1, 1, 1, 200, 374944, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19120, 902, 1, 1, 1, 0, 0, 25001, 250001, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18130, 866, 1, 1, 1, 1, 1, 200, 374944, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19121, 902, 1, 1, 1, 0, 0, 25001, 749999, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19122, 902, 1, 1, 1, 0, 0, 25001, 0, 12, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_gdi_de', 18131, 866, 1, 1, 1, 1, 1, 200, 374944, 12, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19123, 902, 1, 1, 1, 0, 0, 25001, 100000, 13, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19124, 902, 1, 1, 1, 0, 0, 2000000, 0, 14, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14999, 844, 1, 1, 1, 1, 1, 0, 0, 48, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14986, 844, 1, 1, 1, 1, 1, 0, 0, 35, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15000, 844, 1, 1, 1, 1, 1, 0, 0, 49, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14985, 844, 1, 1, 1, 1, 1, 0, 0, 34, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14987, 844, 1, 1, 1, 1, 1, 0, 0, 36, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14975, 844, 1, 1, 1, 1, 1, 0, 0, 24, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14989, 844, 1, 1, 1, 1, 1, 0, 0, 38, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15003, 844, 1, 1, 1, 1, 1, 0, 0, 52, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14992, 844, 1, 1, 1, 1, 1, 0, 0, 41, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14979, 844, 1, 1, 1, 1, 1, 0, 0, 28, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19300, 844, 1, 1, 1, 1, 1, 0, 0, 50, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 19301, 844, 1, 1, 1, 1, 1, 0, 0, 51, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 14996, 844, 1, 1, 1, 1, 1, 0, 0, 45, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15007, 844, 1, 1, 1, 1, 1, 0, 0, 56, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_worldwide', 15009, 844, 1, 1, 1, 1, 1, 0, 0, 58, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19356, 824, 1, 1, 1, 0, 0, 0, 0, 48, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19357, 824, 1, 1, 1, 0, 0, 0, 0, 49, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19358, 824, 1, 1, 1, 0, 0, 0, 0, 50, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19359, 824, 1, 1, 1, 0, 0, 0, 0, 51, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19360, 824, 1, 1, 1, 0, 0, 0, 0, 52, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19361, 824, 1, 1, 1, 0, 0, 0, 0, 53, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19362, 824, 1, 1, 1, 0, 0, 0, 0, 54, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19363, 824, 1, 1, 1, 0, 0, 0, 0, 55, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19364, 824, 1, 1, 1, 0, 0, 0, 0, 56, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19365, 824, 1, 1, 1, 0, 0, 0, 0, 57, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19366, 824, 1, 1, 1, 0, 0, 0, 0, 58, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19367, 824, 1, 1, 1, 0, 0, 0, 0, 59, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19368, 824, 1, 1, 1, 0, 0, 0, 0, 60, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19369, 824, 1, 1, 1, 0, 0, 0, 0, 61, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19370, 824, 1, 1, 1, 0, 0, 0, 0, 62, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19371, 824, 1, 1, 1, 0, 0, 0, 0, 63, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19372, 824, 1, 1, 1, 0, 0, 0, 0, 64, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19373, 824, 1, 1, 1, 0, 0, 0, 0, 65, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19374, 824, 1, 1, 1, 0, 0, 0, 0, 66, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19375, 824, 1, 1, 1, 0, 0, 0, 0, 67, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19376, 824, 1, 1, 1, 0, 0, 0, 0, 68, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19377, 824, 1, 1, 1, 0, 0, 0, 0, 69, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19378, 824, 1, 1, 1, 0, 0, 0, 0, 70, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19379, 824, 1, 1, 1, 0, 0, 0, 0, 71, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19380, 824, 1, 1, 1, 0, 0, 0, 0, 72, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19381, 824, 1, 1, 1, 0, 0, 0, 0, 73, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19382, 824, 1, 1, 1, 0, 0, 0, 0, 74, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19383, 824, 1, 1, 1, 0, 0, 0, 0, 75, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19384, 824, 1, 1, 1, 0, 0, 0, 0, 76, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19385, 824, 1, 1, 1, 0, 0, 0, 0, 77, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19386, 824, 1, 1, 1, 0, 0, 0, 0, 78, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19387, 824, 1, 1, 1, 0, 0, 0, 0, 79, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19388, 824, 1, 1, 1, 0, 0, 0, 0, 80, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19389, 824, 1, 1, 1, 0, 0, 0, 0, 81, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19390, 824, 1, 1, 1, 0, 0, 0, 0, 82, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19391, 824, 1, 1, 1, 0, 0, 0, 0, 83, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19392, 824, 1, 1, 1, 0, 0, 0, 0, 84, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19393, 824, 1, 1, 1, 0, 0, 0, 0, 85, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19394, 824, 1, 1, 1, 0, 0, 0, 0, 86, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19395, 824, 1, 1, 1, 0, 0, 0, 0, 87, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19396, 824, 1, 1, 1, 0, 0, 0, 0, 88, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19397, 824, 1, 1, 1, 0, 0, 0, 0, 89, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19398, 824, 1, 1, 1, 0, 0, 0, 0, 90, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19399, 824, 1, 1, 1, 0, 0, 0, 0, 91, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19400, 824, 1, 1, 1, 0, 0, 0, 0, 92, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19401, 824, 1, 1, 1, 0, 0, 0, 0, 93, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19402, 824, 1, 1, 1, 0, 0, 0, 0, 94, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19403, 824, 1, 1, 1, 0, 0, 0, 0, 95, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19404, 824, 1, 1, 1, 0, 0, 0, 0, 96, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19405, 824, 1, 1, 1, 0, 0, 0, 0, 97, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19406, 824, 1, 1, 1, 0, 0, 0, 0, 98, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19407, 824, 1, 1, 1, 0, 0, 0, 0, 99, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19408, 824, 1, 1, 1, 0, 0, 0, 0, 100, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19409, 824, 1, 1, 1, 0, 0, 0, 0, 101, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19410, 824, 1, 1, 1, 0, 0, 0, 0, 102, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19411, 824, 1, 1, 1, 0, 0, 0, 0, 103, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19412, 824, 1, 1, 1, 0, 0, 0, 0, 104, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19413, 824, 1, 1, 1, 0, 0, 0, 0, 105, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19414, 824, 1, 1, 1, 0, 0, 0, 0, 106, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19415, 824, 1, 1, 1, 0, 0, 0, 0, 107, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19416, 824, 1, 1, 1, 0, 0, 0, 0, 108, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19417, 824, 1, 1, 1, 0, 0, 0, 0, 109, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19418, 824, 1, 1, 1, 0, 0, 0, 0, 110, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19419, 824, 1, 1, 1, 0, 0, 0, 0, 111, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19420, 824, 1, 1, 1, 0, 0, 0, 0, 112, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19421, 824, 1, 1, 1, 0, 0, 0, 0, 113, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19422, 824, 1, 1, 1, 0, 0, 0, 0, 114, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19423, 824, 1, 1, 1, 0, 0, 0, 0, 115, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19424, 824, 1, 1, 1, 0, 0, 0, 0, 116, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19425, 824, 1, 1, 1, 0, 0, 0, 0, 117, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19426, 824, 1, 1, 1, 0, 0, 0, 0, 118, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19427, 824, 1, 1, 1, 0, 0, 0, 0, 119, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19428, 824, 1, 1, 1, 0, 0, 0, 0, 120, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19429, 824, 1, 1, 1, 0, 0, 0, 0, 121, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19430, 824, 1, 1, 1, 0, 0, 0, 0, 122, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19431, 824, 1, 1, 1, 0, 0, 0, 0, 123, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19432, 824, 1, 1, 1, 0, 0, 0, 0, 124, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19433, 824, 1, 1, 1, 0, 0, 0, 0, 125, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19434, 824, 1, 1, 1, 0, 0, 0, 0, 126, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19435, 824, 1, 1, 1, 0, 0, 0, 0, 127, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19436, 824, 1, 1, 1, 0, 0, 0, 0, 128, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19437, 824, 1, 1, 1, 0, 0, 0, 0, 129, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19438, 824, 1, 1, 1, 0, 0, 0, 0, 130, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19439, 824, 1, 1, 1, 0, 0, 0, 0, 131, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19440, 824, 1, 1, 1, 0, 0, 0, 0, 132, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19441, 824, 1, 1, 1, 0, 0, 0, 0, 133, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19442, 824, 1, 1, 1, 0, 0, 0, 0, 134, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19443, 824, 1, 1, 1, 0, 0, 0, 0, 135, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19444, 824, 1, 1, 1, 0, 0, 0, 0, 136, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19445, 824, 1, 1, 1, 0, 0, 0, 0, 137, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19446, 824, 1, 1, 1, 0, 0, 0, 0, 138, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19447, 824, 1, 1, 1, 0, 0, 0, 0, 139, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19448, 824, 1, 1, 1, 0, 0, 0, 0, 140, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19449, 824, 1, 1, 1, 0, 0, 0, 0, 141, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19450, 824, 1, 1, 1, 0, 0, 0, 0, 142, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19451, 824, 1, 1, 1, 0, 0, 0, 0, 143, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19452, 824, 1, 1, 1, 0, 0, 0, 0, 144, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19453, 824, 1, 1, 1, 0, 0, 0, 0, 145, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19454, 824, 1, 1, 1, 0, 0, 0, 0, 146, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19455, 824, 1, 1, 1, 0, 0, 0, 0, 147, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19456, 824, 1, 1, 1, 0, 0, 0, 0, 148, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19457, 824, 1, 1, 1, 0, 0, 0, 0, 149, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19458, 824, 1, 1, 1, 0, 0, 0, 0, 150, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19459, 824, 1, 1, 1, 0, 0, 0, 0, 151, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19460, 824, 1, 1, 1, 0, 0, 0, 0, 152, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19461, 824, 1, 1, 1, 0, 0, 0, 0, 153, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19462, 824, 1, 1, 1, 0, 0, 0, 0, 154, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19463, 824, 1, 1, 1, 0, 0, 0, 0, 155, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19464, 824, 1, 1, 1, 0, 0, 0, 0, 156, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19465, 824, 1, 1, 1, 0, 0, 0, 0, 157, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19466, 824, 1, 1, 1, 0, 0, 0, 0, 158, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19467, 824, 1, 1, 1, 0, 0, 0, 0, 159, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19468, 824, 1, 1, 1, 0, 0, 0, 0, 160, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19469, 824, 1, 1, 1, 0, 0, 0, 0, 161, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19470, 824, 1, 1, 1, 0, 0, 0, 0, 162, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19471, 824, 1, 1, 1, 0, 0, 0, 0, 163, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19472, 824, 1, 1, 1, 0, 0, 0, 0, 164, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19473, 824, 1, 1, 1, 0, 0, 0, 0, 165, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19474, 824, 1, 1, 1, 0, 0, 0, 0, 166, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19475, 824, 1, 1, 1, 0, 0, 0, 0, 167, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19476, 824, 1, 1, 1, 0, 0, 0, 0, 168, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19477, 824, 1, 1, 1, 0, 0, 0, 0, 169, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19478, 824, 1, 1, 1, 0, 0, 0, 0, 170, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19479, 824, 1, 1, 1, 0, 0, 0, 0, 171, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19480, 824, 1, 1, 1, 0, 0, 0, 0, 172, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19481, 824, 1, 1, 1, 0, 0, 0, 0, 173, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19482, 824, 1, 1, 1, 0, 0, 0, 0, 174, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19483, 824, 1, 1, 1, 0, 0, 0, 0, 175, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19484, 824, 1, 1, 1, 0, 0, 0, 0, 176, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19485, 824, 1, 1, 1, 0, 0, 0, 0, 177, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19486, 824, 1, 1, 1, 0, 0, 0, 0, 178, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19487, 824, 1, 1, 1, 0, 0, 0, 0, 179, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19488, 824, 1, 1, 1, 0, 0, 0, 0, 180, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19489, 824, 1, 1, 1, 0, 0, 0, 0, 181, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19490, 824, 1, 1, 1, 0, 0, 0, 0, 182, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19491, 824, 1, 1, 1, 0, 0, 0, 0, 183, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19492, 824, 1, 1, 1, 0, 0, 0, 0, 184, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19493, 824, 1, 1, 1, 0, 0, 0, 0, 185, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19494, 824, 1, 1, 1, 0, 0, 0, 0, 186, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19495, 824, 1, 1, 1, 0, 0, 0, 0, 187, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19496, 824, 1, 1, 1, 0, 0, 0, 0, 188, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19497, 824, 1, 1, 1, 0, 0, 0, 0, 189, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19498, 824, 1, 1, 1, 0, 0, 0, 0, 190, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19499, 824, 1, 1, 1, 0, 0, 0, 0, 191, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19500, 824, 1, 1, 1, 0, 0, 0, 0, 192, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19501, 824, 1, 1, 1, 0, 0, 0, 0, 193, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19502, 824, 1, 1, 1, 0, 0, 0, 0, 194, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19503, 824, 1, 1, 1, 0, 0, 0, 0, 195, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19504, 824, 1, 1, 1, 0, 0, 0, 0, 196, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19505, 824, 1, 1, 1, 0, 0, 0, 0, 197, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19506, 824, 1, 1, 1, 0, 0, 0, 0, 198, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19507, 824, 1, 1, 1, 0, 0, 0, 0, 199, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19508, 824, 1, 1, 1, 0, 0, 0, 0, 200, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19509, 824, 1, 1, 1, 0, 0, 0, 0, 201, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19510, 824, 1, 1, 1, 0, 0, 0, 0, 202, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19511, 824, 1, 1, 1, 0, 0, 0, 0, 203, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19512, 824, 1, 1, 1, 0, 0, 0, 0, 204, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19513, 824, 1, 1, 1, 0, 0, 0, 0, 205, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19514, 824, 1, 1, 1, 0, 0, 0, 0, 206, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19515, 824, 1, 1, 1, 0, 0, 0, 0, 207, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19516, 824, 1, 1, 1, 0, 0, 0, 0, 208, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19517, 824, 1, 1, 1, 0, 0, 0, 0, 209, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19518, 824, 1, 1, 1, 0, 0, 0, 0, 210, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19519, 824, 1, 1, 1, 0, 0, 0, 0, 211, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19520, 824, 1, 1, 1, 0, 0, 0, 0, 212, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19521, 824, 1, 1, 1, 0, 0, 0, 0, 213, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19522, 824, 1, 1, 1, 0, 0, 0, 0, 214, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19523, 824, 1, 1, 1, 0, 0, 0, 0, 215, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19524, 824, 1, 1, 1, 0, 0, 0, 0, 216, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19525, 824, 1, 1, 1, 0, 0, 0, 0, 217, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19526, 824, 1, 1, 1, 0, 0, 0, 0, 218, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19527, 824, 1, 1, 1, 0, 0, 0, 0, 219, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19528, 824, 1, 1, 1, 0, 0, 0, 0, 220, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19529, 824, 1, 1, 1, 0, 0, 0, 0, 221, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19530, 824, 1, 1, 1, 0, 0, 0, 0, 222, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19531, 824, 1, 1, 1, 0, 0, 0, 0, 223, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19532, 824, 1, 1, 1, 0, 0, 0, 0, 224, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19533, 824, 1, 1, 1, 0, 0, 0, 0, 225, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19534, 824, 1, 1, 1, 0, 0, 0, 0, 226, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19535, 824, 1, 1, 1, 0, 0, 0, 0, 227, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19536, 824, 1, 1, 1, 0, 0, 0, 0, 228, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19537, 824, 1, 1, 1, 0, 0, 0, 0, 229, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19538, 824, 1, 1, 1, 0, 0, 0, 0, 230, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19539, 824, 1, 1, 1, 0, 0, 0, 0, 231, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19540, 824, 1, 1, 1, 0, 0, 0, 0, 232, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19541, 824, 1, 1, 1, 0, 0, 0, 0, 233, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19542, 824, 1, 1, 1, 0, 0, 0, 0, 234, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19543, 824, 1, 1, 1, 0, 0, 0, 0, 235, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19544, 824, 1, 1, 1, 0, 0, 0, 0, 236, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19545, 824, 1, 1, 1, 0, 0, 0, 0, 237, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19546, 824, 1, 1, 1, 0, 0, 0, 0, 238, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19547, 824, 1, 1, 1, 0, 0, 0, 0, 239, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19548, 824, 1, 1, 1, 0, 0, 0, 0, 240, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19549, 824, 1, 1, 1, 0, 0, 0, 0, 241, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19550, 824, 1, 1, 1, 0, 0, 0, 0, 242, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19551, 824, 1, 1, 1, 0, 0, 0, 0, 243, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19552, 824, 1, 1, 1, 0, 0, 0, 0, 244, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19553, 824, 1, 1, 1, 0, 0, 0, 0, 245, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19554, 824, 1, 1, 1, 0, 0, 0, 0, 246, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19555, 824, 1, 1, 1, 0, 0, 0, 0, 247, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19556, 824, 1, 1, 1, 0, 0, 0, 0, 248, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19557, 824, 1, 1, 1, 0, 0, 0, 0, 249, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19558, 824, 1, 1, 1, 0, 0, 0, 0, 250, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19559, 824, 1, 1, 1, 0, 0, 0, 0, 251, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19560, 824, 1, 1, 1, 0, 0, 0, 0, 252, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19561, 824, 1, 1, 1, 0, 0, 0, 0, 253, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19562, 824, 1, 1, 1, 0, 0, 0, 0, 254, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19563, 824, 1, 1, 1, 0, 0, 0, 0, 255, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19564, 824, 1, 1, 1, 0, 0, 0, 0, 256, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19565, 824, 1, 1, 1, 0, 0, 0, 0, 257, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19566, 824, 1, 1, 1, 0, 0, 0, 0, 258, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19567, 824, 1, 1, 1, 0, 0, 0, 0, 259, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19568, 824, 1, 1, 1, 0, 0, 0, 0, 260, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19569, 824, 1, 1, 1, 0, 0, 0, 0, 261, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19570, 824, 1, 1, 1, 0, 0, 0, 0, 262, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19571, 824, 1, 1, 1, 0, 0, 0, 0, 263, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19572, 824, 1, 1, 1, 0, 0, 0, 0, 264, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19573, 824, 1, 1, 1, 0, 0, 0, 0, 265, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19574, 824, 1, 1, 1, 0, 0, 0, 0, 266, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19575, 824, 1, 1, 1, 0, 0, 0, 0, 267, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19576, 824, 1, 1, 1, 0, 0, 0, 0, 268, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19577, 824, 1, 1, 1, 0, 0, 0, 0, 269, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19578, 824, 1, 1, 1, 0, 0, 0, 0, 270, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19579, 824, 1, 1, 1, 0, 0, 0, 0, 271, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19580, 824, 1, 1, 1, 0, 0, 0, 0, 272, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19581, 824, 1, 1, 1, 0, 0, 0, 0, 273, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19582, 824, 1, 1, 1, 0, 0, 0, 0, 274, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19583, 824, 1, 1, 1, 0, 0, 0, 0, 275, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19584, 824, 1, 1, 1, 0, 0, 0, 0, 276, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19585, 824, 1, 1, 1, 0, 0, 0, 0, 277, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19586, 824, 1, 1, 1, 0, 0, 0, 0, 278, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19587, 824, 1, 1, 1, 0, 0, 0, 0, 279, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19588, 824, 1, 1, 1, 0, 0, 0, 0, 280, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19589, 824, 1, 1, 1, 0, 0, 0, 0, 281, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19590, 824, 1, 1, 1, 0, 0, 0, 0, 282, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19591, 824, 1, 1, 1, 0, 0, 0, 0, 283, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19592, 824, 1, 1, 1, 0, 0, 0, 0, 284, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19593, 824, 1, 1, 1, 0, 0, 0, 0, 285, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19594, 824, 1, 1, 1, 0, 0, 0, 0, 286, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19595, 824, 1, 1, 1, 0, 0, 0, 0, 287, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19596, 824, 1, 1, 1, 0, 0, 0, 0, 288, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19597, 824, 1, 1, 1, 0, 0, 0, 0, 289, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19598, 824, 1, 1, 1, 0, 0, 0, 0, 290, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19599, 824, 1, 1, 1, 0, 0, 0, 0, 291, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19600, 824, 1, 1, 1, 0, 0, 0, 0, 292, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19601, 824, 1, 1, 1, 0, 0, 0, 0, 293, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19602, 824, 1, 1, 1, 0, 0, 0, 0, 294, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19603, 824, 1, 1, 1, 0, 0, 0, 0, 295, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19604, 824, 1, 1, 1, 0, 0, 0, 0, 296, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19605, 824, 1, 1, 1, 0, 0, 0, 0, 297, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19606, 824, 1, 1, 1, 0, 0, 0, 0, 298, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19607, 824, 1, 1, 1, 0, 0, 0, 0, 299, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19608, 824, 1, 1, 1, 0, 0, 0, 0, 300, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19609, 824, 1, 1, 1, 0, 0, 0, 0, 301, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19610, 824, 1, 1, 1, 0, 0, 0, 0, 302, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19611, 824, 1, 1, 1, 0, 0, 0, 0, 303, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19612, 824, 1, 1, 1, 0, 0, 0, 0, 304, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19613, 824, 1, 1, 1, 0, 0, 0, 0, 305, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19614, 824, 1, 1, 1, 0, 0, 0, 0, 306, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19615, 824, 1, 1, 1, 0, 0, 0, 0, 307, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19616, 824, 1, 1, 1, 0, 0, 0, 0, 308, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19617, 824, 1, 1, 1, 0, 0, 0, 0, 309, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19618, 824, 1, 1, 1, 0, 0, 0, 0, 310, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19619, 824, 1, 1, 1, 0, 0, 0, 0, 311, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19620, 824, 1, 1, 1, 0, 0, 0, 0, 312, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19621, 824, 1, 1, 1, 0, 0, 0, 0, 313, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19622, 824, 1, 1, 1, 0, 0, 0, 0, 314, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19623, 824, 1, 1, 1, 0, 0, 0, 0, 315, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19624, 824, 1, 1, 1, 0, 0, 0, 0, 316, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19625, 824, 1, 1, 1, 0, 0, 0, 0, 317, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19626, 824, 1, 1, 1, 0, 0, 0, 0, 318, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19627, 824, 1, 1, 1, 0, 0, 0, 0, 319, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19628, 824, 1, 1, 1, 0, 0, 0, 0, 320, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19629, 824, 1, 1, 1, 0, 0, 0, 0, 321, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19630, 824, 1, 1, 1, 0, 0, 0, 0, 322, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19631, 824, 1, 1, 1, 0, 0, 0, 0, 323, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19632, 824, 1, 1, 1, 0, 0, 0, 0, 324, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19633, 824, 1, 1, 1, 0, 0, 0, 0, 325, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19634, 824, 1, 1, 1, 0, 0, 0, 0, 326, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19635, 824, 1, 1, 1, 0, 0, 0, 0, 327, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19636, 824, 1, 1, 1, 0, 0, 0, 0, 328, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19637, 824, 1, 1, 1, 0, 0, 0, 0, 329, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19638, 824, 1, 1, 1, 0, 0, 0, 0, 330, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19639, 824, 1, 1, 1, 0, 0, 0, 0, 331, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19640, 824, 1, 1, 1, 0, 0, 0, 0, 332, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19641, 824, 1, 1, 1, 0, 0, 0, 0, 333, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19642, 824, 1, 1, 1, 0, 0, 0, 0, 334, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19643, 824, 1, 1, 1, 0, 0, 0, 0, 335, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19644, 824, 1, 1, 1, 0, 0, 0, 0, 336, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19645, 824, 1, 1, 1, 0, 0, 0, 0, 337, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19646, 824, 1, 1, 1, 0, 0, 0, 0, 338, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19647, 824, 1, 1, 1, 0, 0, 0, 0, 339, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19648, 824, 1, 1, 1, 0, 0, 0, 0, 340, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19649, 824, 1, 1, 1, 0, 0, 0, 0, 341, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19650, 824, 1, 1, 1, 0, 0, 0, 0, 342, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19651, 824, 1, 1, 1, 0, 0, 0, 0, 343, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19652, 824, 1, 1, 1, 0, 0, 0, 0, 344, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19653, 824, 1, 1, 1, 0, 0, 0, 0, 345, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19654, 824, 1, 1, 1, 0, 0, 0, 0, 346, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19655, 824, 1, 1, 1, 0, 0, 0, 0, 347, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19656, 824, 1, 1, 1, 0, 0, 0, 0, 348, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19657, 824, 1, 1, 1, 0, 0, 0, 0, 349, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19658, 824, 1, 1, 1, 0, 0, 0, 0, 350, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19659, 824, 1, 1, 1, 0, 0, 0, 0, 351, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19660, 824, 1, 1, 1, 0, 0, 0, 0, 352, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19661, 824, 1, 1, 1, 0, 0, 0, 0, 353, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19662, 824, 1, 1, 1, 0, 0, 0, 0, 354, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19663, 824, 1, 1, 1, 0, 0, 0, 0, 355, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19664, 824, 1, 1, 1, 0, 0, 0, 0, 356, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19665, 824, 1, 1, 1, 0, 0, 0, 0, 357, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19666, 824, 1, 1, 1, 0, 0, 0, 0, 358, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19667, 824, 1, 1, 1, 0, 0, 0, 0, 359, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19668, 824, 1, 1, 1, 0, 0, 0, 0, 360, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19669, 824, 1, 1, 1, 0, 0, 0, 0, 361, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19670, 824, 1, 1, 1, 0, 0, 0, 0, 362, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19671, 824, 1, 1, 1, 0, 0, 0, 0, 363, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19672, 824, 1, 1, 1, 0, 0, 0, 0, 364, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19673, 824, 1, 1, 1, 0, 0, 0, 0, 365, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19674, 824, 1, 1, 1, 0, 0, 0, 0, 366, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19675, 824, 1, 1, 1, 0, 0, 0, 0, 367, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19676, 824, 1, 1, 1, 0, 0, 0, 0, 368, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19677, 824, 1, 1, 1, 0, 0, 0, 0, 369, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19678, 824, 1, 1, 1, 0, 0, 0, 0, 370, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19679, 824, 1, 1, 1, 0, 0, 0, 0, 371, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19680, 824, 1, 1, 1, 0, 0, 0, 0, 372, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19681, 824, 1, 1, 1, 0, 0, 0, 0, 373, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19682, 824, 1, 1, 1, 0, 0, 0, 0, 374, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19683, 824, 1, 1, 1, 0, 0, 0, 0, 375, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19684, 824, 1, 1, 1, 0, 0, 0, 0, 376, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19685, 824, 1, 1, 1, 0, 0, 0, 0, 377, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19686, 824, 1, 1, 1, 0, 0, 0, 0, 378, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19687, 824, 1, 1, 1, 0, 0, 0, 0, 379, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19688, 824, 1, 1, 1, 0, 0, 0, 0, 380, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19689, 824, 1, 1, 1, 0, 0, 0, 0, 381, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19690, 824, 1, 1, 1, 0, 0, 0, 0, 382, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19691, 824, 1, 1, 1, 0, 0, 0, 0, 383, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19692, 824, 1, 1, 1, 0, 0, 0, 0, 384, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19693, 824, 1, 1, 1, 0, 0, 0, 0, 385, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19694, 824, 1, 1, 1, 0, 0, 0, 0, 386, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19695, 824, 1, 1, 1, 0, 0, 0, 0, 387, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19696, 824, 1, 1, 1, 0, 0, 0, 0, 388, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19697, 824, 1, 1, 1, 0, 0, 0, 0, 389, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19698, 824, 1, 1, 1, 0, 0, 0, 0, 390, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19699, 824, 1, 1, 1, 0, 0, 0, 0, 391, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19700, 824, 1, 1, 1, 0, 0, 0, 0, 392, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19701, 824, 1, 1, 1, 0, 0, 0, 0, 393, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19702, 824, 1, 1, 1, 0, 0, 0, 0, 394, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19703, 824, 1, 1, 1, 0, 0, 0, 0, 395, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19704, 824, 1, 1, 1, 0, 0, 0, 0, 396, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19705, 824, 1, 1, 1, 0, 0, 0, 0, 397, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19706, 824, 1, 1, 1, 0, 0, 0, 0, 398, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19707, 824, 1, 1, 1, 0, 0, 0, 0, 399, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19708, 824, 1, 1, 1, 0, 0, 0, 0, 400, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19709, 824, 1, 1, 1, 0, 0, 0, 0, 401, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19710, 824, 1, 1, 1, 0, 0, 0, 0, 402, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19711, 824, 1, 1, 1, 0, 0, 0, 0, 403, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19712, 824, 1, 1, 1, 0, 0, 0, 0, 404, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19713, 824, 1, 1, 1, 0, 0, 0, 0, 405, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19714, 824, 1, 1, 1, 0, 0, 0, 0, 406, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19715, 824, 1, 1, 1, 0, 0, 0, 0, 407, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19716, 824, 1, 1, 1, 0, 0, 0, 0, 408, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19717, 824, 1, 1, 1, 0, 0, 0, 0, 409, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19718, 824, 1, 1, 1, 0, 0, 0, 0, 410, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19719, 824, 1, 1, 1, 0, 0, 0, 0, 411, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19720, 824, 1, 1, 1, 0, 0, 0, 0, 412, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19721, 824, 1, 1, 1, 0, 0, 0, 0, 413, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19722, 824, 1, 1, 1, 0, 0, 0, 0, 414, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19723, 824, 1, 1, 1, 0, 0, 0, 0, 415, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19724, 824, 1, 1, 1, 0, 0, 0, 0, 416, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19725, 824, 1, 1, 1, 0, 0, 0, 0, 417, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19726, 824, 1, 1, 1, 0, 0, 0, 0, 418, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19727, 824, 1, 1, 1, 0, 0, 0, 0, 419, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19728, 824, 1, 1, 1, 0, 0, 0, 0, 420, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19729, 824, 1, 1, 1, 0, 0, 0, 0, 421, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19730, 824, 1, 1, 1, 0, 0, 0, 0, 422, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19731, 824, 1, 1, 1, 0, 0, 0, 0, 423, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19732, 824, 1, 1, 1, 0, 0, 0, 0, 424, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19733, 824, 1, 1, 1, 0, 0, 0, 0, 425, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19734, 824, 1, 1, 1, 0, 0, 0, 0, 426, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19735, 824, 1, 1, 1, 0, 0, 0, 0, 427, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19736, 824, 1, 1, 1, 0, 0, 0, 0, 428, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19737, 824, 1, 1, 1, 0, 0, 0, 0, 429, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19738, 824, 1, 1, 1, 0, 0, 0, 0, 430, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19739, 824, 1, 1, 1, 0, 0, 0, 0, 431, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19740, 824, 1, 1, 1, 0, 0, 0, 0, 432, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19741, 824, 1, 1, 1, 0, 0, 0, 0, 433, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19742, 824, 1, 1, 1, 0, 0, 0, 0, 434, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19743, 824, 1, 1, 1, 0, 0, 0, 0, 435, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19744, 824, 1, 1, 1, 0, 0, 0, 0, 436, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19745, 824, 1, 1, 1, 0, 0, 0, 0, 437, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19746, 824, 1, 1, 1, 0, 0, 0, 0, 438, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19747, 824, 1, 1, 1, 0, 0, 0, 0, 439, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19748, 824, 1, 1, 1, 0, 0, 0, 0, 440, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19749, 824, 1, 1, 1, 0, 0, 0, 0, 441, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19750, 824, 1, 1, 1, 0, 0, 0, 0, 442, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19751, 824, 1, 1, 1, 0, 0, 0, 0, 443, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19752, 824, 1, 1, 1, 0, 0, 0, 0, 444, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19753, 824, 1, 1, 1, 0, 0, 0, 0, 445, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19754, 824, 1, 1, 1, 0, 0, 0, 0, 446, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19755, 824, 1, 1, 1, 0, 0, 0, 0, 447, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19756, 824, 1, 1, 1, 0, 0, 0, 0, 448, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19757, 824, 1, 1, 1, 0, 0, 0, 0, 449, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19758, 824, 1, 1, 1, 0, 0, 0, 0, 450, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19759, 824, 1, 1, 1, 0, 0, 0, 0, 451, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19760, 824, 1, 1, 1, 0, 0, 0, 0, 452, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19761, 824, 1, 1, 1, 0, 0, 0, 0, 453, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19762, 824, 1, 1, 1, 0, 0, 0, 0, 454, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19763, 824, 1, 1, 1, 0, 0, 0, 0, 455, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19764, 824, 1, 1, 1, 0, 0, 0, 0, 456, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19765, 824, 1, 1, 1, 0, 0, 0, 0, 457, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19766, 824, 1, 1, 1, 0, 0, 0, 0, 458, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19767, 824, 1, 1, 1, 0, 0, 0, 0, 459, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19768, 824, 1, 1, 1, 0, 0, 0, 0, 460, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19769, 824, 1, 1, 1, 0, 0, 0, 0, 461, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19770, 824, 1, 1, 1, 0, 0, 0, 0, 462, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19771, 824, 1, 1, 1, 0, 0, 0, 0, 463, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19772, 824, 1, 1, 1, 0, 0, 0, 0, 464, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19773, 824, 1, 1, 1, 0, 0, 0, 0, 465, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19774, 824, 1, 1, 1, 0, 0, 0, 0, 466, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19775, 824, 1, 1, 1, 0, 0, 0, 0, 467, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19776, 824, 1, 1, 1, 0, 0, 0, 0, 468, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19777, 824, 1, 1, 1, 0, 0, 0, 0, 469, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19778, 824, 1, 1, 1, 0, 0, 0, 0, 470, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19779, 824, 1, 1, 1, 0, 0, 0, 0, 471, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19780, 824, 1, 1, 1, 0, 0, 0, 0, 472, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19781, 824, 1, 1, 1, 0, 0, 0, 0, 473, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19782, 824, 1, 1, 1, 0, 0, 0, 0, 474, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19783, 824, 1, 1, 1, 0, 0, 0, 0, 475, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19784, 824, 1, 1, 1, 0, 0, 0, 0, 476, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19785, 824, 1, 1, 1, 0, 0, 0, 0, 477, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19786, 824, 1, 1, 1, 0, 0, 0, 0, 478, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19787, 824, 1, 1, 1, 0, 0, 0, 0, 479, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19788, 824, 1, 1, 1, 0, 0, 0, 0, 480, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19789, 824, 1, 1, 1, 0, 0, 0, 0, 481, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19790, 824, 1, 1, 1, 0, 0, 0, 0, 482, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19791, 824, 1, 1, 1, 0, 0, 0, 0, 483, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19792, 824, 1, 1, 1, 0, 0, 0, 0, 484, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19793, 824, 1, 1, 1, 0, 0, 0, 0, 485, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19794, 824, 1, 1, 1, 0, 0, 0, 0, 486, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19795, 824, 1, 1, 1, 0, 0, 0, 0, 487, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19796, 824, 1, 1, 1, 0, 0, 0, 0, 488, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19797, 824, 1, 1, 1, 0, 0, 0, 0, 489, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19798, 824, 1, 1, 1, 0, 0, 0, 0, 490, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19799, 824, 1, 1, 1, 0, 0, 0, 0, 491, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19800, 824, 1, 1, 1, 0, 0, 0, 0, 492, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19801, 824, 1, 1, 1, 0, 0, 0, 0, 493, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19802, 824, 1, 1, 1, 0, 0, 0, 0, 494, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19803, 824, 1, 1, 1, 0, 0, 0, 0, 495, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19804, 824, 1, 1, 1, 0, 0, 0, 0, 496, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19805, 824, 1, 1, 1, 0, 0, 0, 0, 497, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19806, 824, 1, 1, 1, 0, 0, 0, 0, 498, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19807, 824, 1, 1, 1, 0, 0, 0, 0, 499, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19808, 824, 1, 1, 1, 0, 0, 0, 0, 500, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19809, 824, 1, 1, 1, 0, 0, 0, 0, 501, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19810, 824, 1, 1, 1, 0, 0, 0, 0, 502, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19811, 824, 1, 1, 1, 0, 0, 0, 0, 503, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19812, 824, 1, 1, 1, 0, 0, 0, 0, 504, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19813, 824, 1, 1, 1, 0, 0, 0, 0, 505, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19814, 824, 1, 1, 1, 0, 0, 0, 0, 506, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19815, 824, 1, 1, 1, 0, 0, 0, 0, 507, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19816, 824, 1, 1, 1, 0, 0, 0, 0, 508, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19817, 824, 1, 1, 1, 0, 0, 0, 0, 509, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19818, 824, 1, 1, 1, 0, 0, 0, 0, 510, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19819, 824, 1, 1, 1, 0, 0, 0, 0, 511, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19820, 824, 1, 1, 1, 0, 0, 0, 0, 512, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19821, 824, 1, 1, 1, 0, 0, 0, 0, 513, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19822, 824, 1, 1, 1, 0, 0, 0, 0, 514, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19823, 824, 1, 1, 1, 0, 0, 0, 0, 515, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19824, 824, 1, 1, 1, 0, 0, 0, 0, 516, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19825, 824, 1, 1, 1, 0, 0, 0, 0, 517, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19826, 824, 1, 1, 1, 0, 0, 0, 0, 518, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19827, 824, 1, 1, 1, 0, 0, 0, 0, 519, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19828, 824, 1, 1, 1, 0, 0, 0, 0, 520, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19829, 824, 1, 1, 1, 0, 0, 0, 0, 521, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19830, 824, 1, 1, 1, 0, 0, 0, 0, 522, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19831, 824, 1, 1, 1, 0, 0, 0, 0, 523, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19832, 824, 1, 1, 1, 0, 0, 0, 0, 524, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19833, 824, 1, 1, 1, 0, 0, 0, 0, 525, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19834, 824, 1, 1, 1, 0, 0, 0, 0, 526, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19835, 824, 1, 1, 1, 0, 0, 0, 0, 527, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19836, 824, 1, 1, 1, 0, 0, 0, 0, 528, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19837, 824, 1, 1, 1, 0, 0, 0, 0, 529, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19838, 824, 1, 1, 1, 0, 0, 0, 0, 530, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19839, 824, 1, 1, 1, 0, 0, 0, 0, 531, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19840, 824, 1, 1, 1, 0, 0, 0, 0, 532, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19841, 824, 1, 1, 1, 0, 0, 0, 0, 533, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19842, 824, 1, 1, 1, 0, 0, 0, 0, 534, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19843, 824, 1, 1, 1, 0, 0, 0, 0, 535, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19844, 824, 1, 1, 1, 0, 0, 0, 0, 536, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19845, 824, 1, 1, 1, 0, 0, 0, 0, 537, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19846, 824, 1, 1, 1, 0, 0, 0, 0, 538, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19847, 824, 1, 1, 1, 0, 0, 0, 0, 539, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19848, 824, 1, 1, 1, 0, 0, 0, 0, 540, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19849, 824, 1, 1, 1, 0, 0, 0, 0, 541, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19850, 824, 1, 1, 1, 0, 0, 0, 0, 542, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19851, 824, 1, 1, 1, 0, 0, 0, 0, 543, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19852, 824, 1, 1, 1, 0, 0, 0, 0, 544, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19853, 824, 1, 1, 1, 0, 0, 0, 0, 545, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19854, 824, 1, 1, 1, 0, 0, 0, 0, 546, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19855, 824, 1, 1, 1, 0, 0, 0, 0, 547, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19856, 824, 1, 1, 1, 0, 0, 0, 0, 548, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19857, 824, 1, 1, 1, 0, 0, 0, 0, 549, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19858, 824, 1, 1, 1, 0, 0, 0, 0, 550, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19859, 824, 1, 1, 1, 0, 0, 0, 0, 551, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19860, 824, 1, 1, 1, 0, 0, 0, 0, 552, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19861, 824, 1, 1, 1, 0, 0, 0, 0, 553, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19862, 824, 1, 1, 1, 0, 0, 0, 0, 554, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19863, 824, 1, 1, 1, 0, 0, 0, 0, 555, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19864, 824, 1, 1, 1, 0, 0, 0, 0, 556, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19865, 824, 1, 1, 1, 0, 0, 0, 0, 557, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19866, 824, 1, 1, 1, 0, 0, 0, 0, 558, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19867, 824, 1, 1, 1, 0, 0, 0, 0, 559, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19868, 824, 1, 1, 1, 0, 0, 0, 0, 560, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19869, 824, 1, 1, 1, 0, 0, 0, 0, 561, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19870, 824, 1, 1, 1, 0, 0, 0, 0, 562, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19871, 824, 1, 1, 1, 0, 0, 0, 0, 563, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19872, 824, 1, 1, 1, 0, 0, 0, 0, 564, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19873, 824, 1, 1, 1, 0, 0, 0, 0, 565, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19874, 824, 1, 1, 1, 0, 0, 0, 0, 566, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19875, 824, 1, 1, 1, 0, 0, 0, 0, 567, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19876, 824, 1, 1, 1, 0, 0, 0, 0, 568, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19877, 824, 1, 1, 1, 0, 0, 0, 0, 569, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19878, 824, 1, 1, 1, 0, 0, 0, 0, 570, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19879, 824, 1, 1, 1, 0, 0, 0, 0, 571, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19880, 824, 1, 1, 1, 0, 0, 0, 0, 572, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19881, 824, 1, 1, 1, 0, 0, 0, 0, 573, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19882, 824, 1, 1, 1, 0, 0, 0, 0, 574, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19883, 824, 1, 1, 1, 0, 0, 0, 0, 575, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19884, 824, 1, 1, 1, 0, 0, 0, 0, 576, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19885, 824, 1, 1, 1, 0, 0, 0, 0, 577, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19886, 824, 1, 1, 1, 0, 0, 0, 0, 578, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19887, 824, 1, 1, 1, 0, 0, 0, 0, 579, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19888, 824, 1, 1, 1, 0, 0, 0, 0, 580, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19889, 824, 1, 1, 1, 0, 0, 0, 0, 581, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19890, 824, 1, 1, 1, 0, 0, 0, 0, 582, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19891, 824, 1, 1, 1, 0, 0, 0, 0, 583, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19892, 824, 1, 1, 1, 0, 0, 0, 0, 584, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19893, 824, 1, 1, 1, 0, 0, 0, 0, 585, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19894, 824, 1, 1, 1, 0, 0, 0, 0, 586, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19895, 824, 1, 1, 1, 0, 0, 0, 0, 587, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19896, 824, 1, 1, 1, 0, 0, 0, 0, 588, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19897, 824, 1, 1, 1, 0, 0, 0, 0, 589, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19898, 824, 1, 1, 1, 0, 0, 0, 0, 590, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19899, 824, 1, 1, 1, 0, 0, 0, 0, 591, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19900, 824, 1, 1, 1, 0, 0, 0, 0, 592, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19901, 824, 1, 1, 1, 0, 0, 0, 0, 593, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19902, 824, 1, 1, 1, 0, 0, 0, 0, 594, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19903, 824, 1, 1, 1, 0, 0, 0, 0, 595, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19904, 824, 1, 1, 1, 0, 0, 0, 0, 596, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19905, 824, 1, 1, 1, 0, 0, 0, 0, 597, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19906, 824, 1, 1, 1, 0, 0, 0, 0, 598, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19907, 824, 1, 1, 1, 0, 0, 0, 0, 599, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19908, 824, 1, 1, 1, 0, 0, 0, 0, 600, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19909, 824, 1, 1, 1, 0, 0, 0, 0, 601, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19910, 824, 1, 1, 1, 0, 0, 0, 0, 602, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19911, 824, 1, 1, 1, 0, 0, 0, 0, 603, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19912, 824, 1, 1, 1, 0, 0, 0, 0, 604, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19913, 824, 1, 1, 1, 0, 0, 0, 0, 605, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19914, 824, 1, 1, 1, 0, 0, 0, 0, 606, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19915, 824, 1, 1, 1, 0, 0, 0, 0, 607, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19916, 824, 1, 1, 1, 0, 0, 0, 0, 608, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19917, 824, 1, 1, 1, 0, 0, 0, 0, 609, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19918, 824, 1, 1, 1, 0, 0, 0, 0, 610, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19919, 824, 1, 1, 1, 0, 0, 0, 0, 611, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19920, 824, 1, 1, 1, 0, 0, 0, 0, 612, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19921, 824, 1, 1, 1, 0, 0, 0, 0, 613, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19922, 824, 1, 1, 1, 0, 0, 0, 0, 614, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19923, 824, 1, 1, 1, 0, 0, 0, 0, 615, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19924, 824, 1, 1, 1, 0, 0, 0, 0, 616, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19925, 824, 1, 1, 1, 0, 0, 0, 0, 617, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19926, 824, 1, 1, 1, 0, 0, 0, 0, 618, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19927, 824, 1, 1, 1, 0, 0, 0, 0, 619, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19928, 824, 1, 1, 1, 0, 0, 0, 0, 620, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19929, 824, 1, 1, 1, 0, 0, 0, 0, 621, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19930, 824, 1, 1, 1, 0, 0, 0, 0, 622, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19931, 824, 1, 1, 1, 0, 0, 0, 0, 623, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19932, 824, 1, 1, 1, 0, 0, 0, 0, 624, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19933, 824, 1, 1, 1, 0, 0, 0, 0, 625, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19934, 824, 1, 1, 1, 0, 0, 0, 0, 626, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19935, 824, 1, 1, 1, 0, 0, 0, 0, 627, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19936, 824, 1, 1, 1, 0, 0, 0, 0, 628, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19937, 824, 1, 1, 1, 0, 0, 0, 0, 629, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19938, 824, 1, 1, 1, 0, 0, 0, 0, 630, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19939, 824, 1, 1, 1, 0, 0, 0, 0, 631, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19940, 824, 1, 1, 1, 0, 0, 0, 0, 632, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19941, 824, 1, 1, 1, 0, 0, 0, 0, 633, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19942, 824, 1, 1, 1, 0, 0, 0, 0, 634, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19943, 824, 1, 1, 1, 0, 0, 0, 0, 635, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19944, 824, 1, 1, 1, 0, 0, 0, 0, 636, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19945, 824, 1, 1, 1, 0, 0, 0, 0, 637, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19946, 824, 1, 1, 1, 0, 0, 0, 0, 638, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19947, 824, 1, 1, 1, 0, 0, 0, 0, 639, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19948, 824, 1, 1, 1, 0, 0, 0, 0, 640, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19949, 824, 1, 1, 1, 0, 0, 0, 0, 641, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19950, 824, 1, 1, 1, 0, 0, 0, 0, 642, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19951, 824, 1, 1, 1, 0, 0, 0, 0, 643, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19952, 824, 1, 1, 1, 0, 0, 0, 0, 644, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19953, 824, 1, 1, 1, 0, 0, 0, 0, 645, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19954, 824, 1, 1, 1, 0, 0, 0, 0, 646, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19955, 824, 1, 1, 1, 0, 0, 0, 0, 647, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19956, 824, 1, 1, 1, 0, 0, 0, 0, 648, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19957, 824, 1, 1, 1, 0, 0, 0, 0, 649, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19958, 824, 1, 1, 1, 0, 0, 0, 0, 650, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19959, 824, 1, 1, 1, 0, 0, 0, 0, 651, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19960, 824, 1, 1, 1, 0, 0, 0, 0, 652, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19961, 824, 1, 1, 1, 0, 0, 0, 0, 653, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19962, 824, 1, 1, 1, 0, 0, 0, 0, 654, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19963, 824, 1, 1, 1, 0, 0, 0, 0, 655, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19964, 824, 1, 1, 1, 0, 0, 0, 0, 656, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19965, 824, 1, 1, 1, 0, 0, 0, 0, 657, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19966, 824, 1, 1, 1, 0, 0, 0, 0, 658, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19967, 824, 1, 1, 1, 0, 0, 0, 0, 659, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19968, 824, 1, 1, 1, 0, 0, 0, 0, 660, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19969, 824, 1, 1, 1, 0, 0, 0, 0, 661, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19970, 824, 1, 1, 1, 0, 0, 0, 0, 662, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19971, 824, 1, 1, 1, 0, 0, 0, 0, 663, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19972, 824, 1, 1, 1, 0, 0, 0, 0, 664, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19973, 824, 1, 1, 1, 0, 0, 0, 0, 665, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19974, 824, 1, 1, 1, 0, 0, 0, 0, 666, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19975, 824, 1, 1, 1, 0, 0, 0, 0, 667, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19976, 824, 1, 1, 1, 0, 0, 0, 0, 668, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19977, 824, 1, 1, 1, 0, 0, 0, 0, 669, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19978, 824, 1, 1, 1, 0, 0, 0, 0, 670, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19979, 824, 1, 1, 1, 0, 0, 0, 0, 671, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19980, 824, 1, 1, 1, 0, 0, 0, 0, 672, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19981, 824, 1, 1, 1, 0, 0, 0, 0, 673, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19982, 824, 1, 1, 1, 0, 0, 0, 0, 674, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19983, 824, 1, 1, 1, 0, 0, 0, 0, 675, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19984, 824, 1, 1, 1, 0, 0, 0, 0, 676, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19985, 824, 1, 1, 1, 0, 0, 0, 0, 677, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19986, 824, 1, 1, 1, 0, 0, 0, 0, 678, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19987, 824, 1, 1, 1, 0, 0, 0, 0, 679, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19988, 824, 1, 1, 1, 0, 0, 0, 0, 680, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19989, 824, 1, 1, 1, 0, 0, 0, 0, 681, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19990, 824, 1, 1, 1, 0, 0, 0, 0, 682, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19991, 824, 1, 1, 1, 0, 0, 0, 0, 683, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19992, 824, 1, 1, 1, 0, 0, 0, 0, 684, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19993, 824, 1, 1, 1, 0, 0, 0, 0, 685, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19994, 824, 1, 1, 1, 0, 0, 0, 0, 686, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19995, 824, 1, 1, 1, 0, 0, 0, 0, 687, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19996, 824, 1, 1, 1, 0, 0, 0, 0, 688, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19997, 824, 1, 1, 1, 0, 0, 0, 0, 689, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19998, 824, 1, 1, 1, 0, 0, 0, 0, 690, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 19999, 824, 1, 1, 1, 0, 0, 0, 0, 691, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20000, 824, 1, 1, 1, 0, 0, 0, 0, 692, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20001, 824, 1, 1, 1, 0, 0, 0, 0, 693, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20002, 824, 1, 1, 1, 0, 0, 0, 0, 694, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20003, 824, 1, 1, 1, 0, 0, 0, 0, 695, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20004, 824, 1, 1, 1, 0, 0, 0, 0, 696, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20005, 824, 1, 1, 1, 0, 0, 0, 0, 697, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20006, 824, 1, 1, 1, 0, 0, 0, 0, 698, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20007, 824, 1, 1, 1, 0, 0, 0, 0, 699, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20008, 824, 1, 1, 1, 0, 0, 0, 0, 700, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20009, 824, 1, 1, 1, 0, 0, 0, 0, 701, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20010, 824, 1, 1, 1, 0, 0, 0, 0, 702, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20011, 824, 1, 1, 1, 0, 0, 0, 0, 703, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20012, 824, 1, 1, 1, 0, 0, 0, 0, 704, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20013, 824, 1, 1, 1, 0, 0, 0, 0, 705, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20014, 824, 1, 1, 1, 0, 0, 0, 0, 706, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20015, 824, 1, 1, 1, 0, 0, 0, 0, 707, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20016, 824, 1, 1, 1, 0, 0, 0, 0, 708, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20017, 824, 1, 1, 1, 0, 0, 0, 0, 709, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20018, 824, 1, 1, 1, 0, 0, 0, 0, 710, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20019, 824, 1, 1, 1, 0, 0, 0, 0, 711, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20020, 824, 1, 1, 1, 0, 0, 0, 0, 712, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20021, 824, 1, 1, 1, 0, 0, 0, 0, 713, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20022, 824, 1, 1, 1, 0, 0, 0, 0, 714, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20023, 824, 1, 1, 1, 0, 0, 0, 0, 715, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20024, 824, 1, 1, 1, 0, 0, 0, 0, 716, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20025, 824, 1, 1, 1, 0, 0, 0, 0, 717, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20026, 824, 1, 1, 1, 0, 0, 0, 0, 718, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20027, 824, 1, 1, 1, 0, 0, 0, 0, 719, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20028, 824, 1, 1, 1, 0, 0, 0, 0, 720, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20029, 824, 1, 1, 1, 0, 0, 0, 0, 721, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20030, 824, 1, 1, 1, 0, 0, 0, 0, 722, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20031, 824, 1, 1, 1, 0, 0, 0, 0, 723, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20032, 824, 1, 1, 1, 0, 0, 0, 0, 724, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20033, 824, 1, 1, 1, 0, 0, 0, 0, 725, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20034, 824, 1, 1, 1, 0, 0, 0, 0, 726, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20035, 824, 1, 1, 1, 0, 0, 0, 0, 727, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20036, 824, 1, 1, 1, 0, 0, 0, 0, 728, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20037, 824, 1, 1, 1, 0, 0, 0, 0, 729, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20038, 824, 1, 1, 1, 0, 0, 0, 0, 730, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20039, 824, 1, 1, 1, 0, 0, 0, 0, 731, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20040, 824, 1, 1, 1, 0, 0, 0, 0, 732, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20041, 824, 1, 1, 1, 0, 0, 0, 0, 733, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20042, 824, 1, 1, 1, 0, 0, 0, 0, 734, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20043, 824, 1, 1, 1, 0, 0, 0, 0, 735, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20044, 824, 1, 1, 1, 0, 0, 0, 0, 736, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20045, 824, 1, 1, 1, 0, 0, 0, 0, 737, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20046, 824, 1, 1, 1, 0, 0, 0, 0, 738, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20047, 824, 1, 1, 1, 0, 0, 0, 0, 739, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20048, 824, 1, 1, 1, 0, 0, 0, 0, 740, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20049, 824, 1, 1, 1, 0, 0, 0, 0, 741, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20050, 824, 1, 1, 1, 0, 0, 0, 0, 742, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20051, 824, 1, 1, 1, 0, 0, 0, 0, 743, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20052, 824, 1, 1, 1, 0, 0, 0, 0, 744, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20053, 824, 1, 1, 1, 0, 0, 0, 0, 745, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20054, 824, 1, 1, 1, 0, 0, 0, 0, 746, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20055, 824, 1, 1, 1, 0, 0, 0, 0, 747, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20056, 824, 1, 1, 1, 0, 0, 0, 0, 748, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20057, 824, 1, 1, 1, 0, 0, 0, 0, 749, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20058, 824, 1, 1, 1, 0, 0, 0, 0, 750, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20059, 824, 1, 1, 1, 0, 0, 0, 0, 751, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20060, 824, 1, 1, 1, 0, 0, 0, 0, 752, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20061, 824, 1, 1, 1, 0, 0, 0, 0, 753, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20062, 824, 1, 1, 1, 0, 0, 0, 0, 754, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20063, 824, 1, 1, 1, 0, 0, 0, 0, 755, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20064, 824, 1, 1, 1, 0, 0, 0, 0, 756, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20065, 824, 1, 1, 1, 0, 0, 0, 0, 757, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20066, 824, 1, 1, 1, 0, 0, 0, 0, 758, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20067, 824, 1, 1, 1, 0, 0, 0, 0, 759, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20068, 824, 1, 1, 1, 0, 0, 0, 0, 760, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20069, 824, 1, 1, 1, 0, 0, 0, 0, 761, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20070, 824, 1, 1, 1, 0, 0, 0, 0, 762, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20071, 824, 1, 1, 1, 0, 0, 0, 0, 763, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20072, 824, 1, 1, 1, 0, 0, 0, 0, 764, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20073, 824, 1, 1, 1, 0, 0, 0, 0, 765, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20074, 824, 1, 1, 1, 0, 0, 0, 0, 766, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20075, 824, 1, 1, 1, 0, 0, 0, 0, 767, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20076, 824, 1, 1, 1, 0, 0, 0, 0, 768, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20077, 824, 1, 1, 1, 0, 0, 0, 0, 769, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20078, 824, 1, 1, 1, 0, 0, 0, 0, 770, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20079, 824, 1, 1, 1, 0, 0, 0, 0, 771, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20080, 824, 1, 1, 1, 0, 0, 0, 0, 772, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20081, 824, 1, 1, 1, 0, 0, 0, 0, 773, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20082, 824, 1, 1, 1, 0, 0, 0, 0, 774, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20083, 824, 1, 1, 1, 0, 0, 0, 0, 775, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20084, 824, 1, 1, 1, 0, 0, 0, 0, 776, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20085, 824, 1, 1, 1, 0, 0, 0, 0, 777, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20086, 824, 1, 1, 1, 0, 0, 0, 0, 778, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20087, 824, 1, 1, 1, 0, 0, 0, 0, 779, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20088, 824, 1, 1, 1, 0, 0, 0, 0, 780, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20089, 824, 1, 1, 1, 0, 0, 0, 0, 781, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20090, 824, 1, 1, 1, 0, 0, 0, 0, 782, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20091, 824, 1, 1, 1, 0, 0, 0, 0, 783, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20092, 824, 1, 1, 1, 0, 0, 0, 0, 784, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20093, 824, 1, 1, 1, 0, 0, 0, 0, 785, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20094, 824, 1, 1, 1, 0, 0, 0, 0, 786, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20095, 824, 1, 1, 1, 0, 0, 0, 0, 787, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20096, 824, 1, 1, 1, 0, 0, 0, 0, 788, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20097, 824, 1, 1, 1, 0, 0, 0, 0, 789, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20098, 824, 1, 1, 1, 0, 0, 0, 0, 790, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20099, 824, 1, 1, 1, 0, 0, 0, 0, 791, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20100, 824, 1, 1, 1, 0, 0, 0, 0, 792, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_europe', 20101, 824, 1, 1, 1, 0, 0, 0, 0, 793, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19149, 905, 1, 1, 1, 0, 0, 50000, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19150, 905, 1, 1, 1, 1, 1, 50000, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19151, 905, 1, 1, 1, 1, 1, 50000, 0, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19152, 905, 1, 1, 1, 1, 1, 50000, 0, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19153, 905, 1, 1, 1, 1, 1, 50000, 0, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19154, 905, 1, 1, 1, 1, 1, 50000, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3401, 329, 1, 1, 1, 0, 0, 0, 0, 0, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19138, 904, 1, 1, 1, 0, 0, 25001, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3402, 329, 1, 1, 1, 0, 0, 2400, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19139, 904, 1, 1, 1, 1, 1, 200000, 0, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19140, 904, 1, 1, 1, 0, 0, 200000, 1000000, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3403, 329, 1, 1, 1, 0, 0, 375, 3900, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19141, 904, 1, 1, 1, 0, 0, 200000, 749999, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3404, 329, 1, 1, 1, 0, 0, 1, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19142, 904, 1, 1, 1, 0, 0, 200000, 749999, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3405, 329, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19143, 904, 1, 1, 1, 0, 0, 200000, 749999, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3406, 329, 1, 1, 1, 0, 0, 1, 2500, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19144, 904, 1, 1, 1, 0, 0, 200000, 749999, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19155, 906, 1, 1, 1, 0, 0, 50000, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3407, 329, 1, 1, 1, 0, 0, 1, 2500, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19145, 904, 1, 1, 1, 0, 0, 200000, 400000, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3408, 329, 1, 1, 1, 0, 0, 1, 2500, 7, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19156, 906, 1, 1, 1, 0, 0, 50000, 1000000, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19146, 904, 1, 1, 1, 0, 0, 200000, 1000000, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19157, 906, 1, 1, 1, 1, 1, 50000, 1000000, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 3409, 329, 1, 1, 1, 0, 0, 1, 2500, 8, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19147, 904, 1, 1, 1, 0, 0, 200000, 0, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19158, 906, 1, 1, 1, 1, 1, 50000, 1000000, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19148, 904, 1, 1, 1, 0, 0, 1000000, 0, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19159, 906, 1, 1, 1, 1, 1, 50000, 1000000, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19160, 906, 1, 1, 1, 1, 1, 50000, 0, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19161, 906, 1, 1, 1, 1, 1, 50000, 0, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19162, 906, 1, 1, 1, 0, 0, 50000, 0, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19163, 906, 1, 1, 1, 0, 0, 50000, 0, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19164, 906, 1, 1, 1, 0, 0, 50000, 0, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19165, 906, 1, 1, 1, 0, 0, 50000, 0, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19166, 906, 1, 1, 1, 0, 0, 50000, 0, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19167, 906, 1, 1, 1, 0, 0, 50000, 0, 12, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 19233, 706, 1, 1, 1, 0, 0, 0, 0, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11542, 706, 1, 1, 1, 0, 0, 0, 0, 1, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11543, 706, 1, 1, 1, 0, 0, 0, 0, 2, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11544, 706, 1, 1, 1, 0, 0, 0, 0, 3, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11545, 706, 1, 1, 1, 0, 0, 0, 0, 4, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11546, 706, 1, 1, 1, 0, 0, 0, 0, 5, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_australia', 11547, 706, 1, 1, 1, 0, 0, 0, 0, 6, '', NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19125, 903, 1, 1, 1, 0, 0, 100, 50000, 0, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19126, 903, 1, 1, 1, 0, 0, 100, 50000, 1, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19127, 903, 1, 1, 1, 1, 1, 1000, 50000, 2, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19128, 903, 1, 1, 1, 0, 0, 1000, 50000, 3, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19129, 903, 1, 1, 1, 0, 0, 1000, 50000, 4, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19130, 903, 1, 1, 1, 0, 0, 1000, 50000, 5, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19131, 903, 1, 1, 1, 0, 0, 1000, 50000, 6, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19132, 903, 1, 1, 1, 0, 0, 1000, 50000, 7, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19133, 903, 1, 1, 1, 0, 0, 1000, 29999, 8, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19134, 903, 1, 1, 1, 0, 0, 1000, 50000, 9, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19135, 903, 1, 1, 1, 0, 0, 1000, 50000, 10, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19136, 903, 1, 1, 1, 0, 0, 1000, 50000, 11, NULL, NULL);
+INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) VALUES ('wms_germany', 19137, 903, 1, 1, 1, 0, 0, 1000, 50000, 12, NULL, NULL);
--- TOC entry 1786 (class 0 OID 47913155)
+-- TOC entry 1808 (class 0 OID 47913155)
 -- Dependencies: 1242
 -- Data for Name: gui_mb_group; Type: TABLE DATA; Schema: public; Owner: admin
@@ -2615,7 +2621,7 @@
--- TOC entry 1787 (class 0 OID 47913160)
+-- TOC entry 1809 (class 0 OID 47913160)
 -- Dependencies: 1243
 -- Data for Name: gui_mb_user; Type: TABLE DATA; Schema: public; Owner: admin
@@ -2633,11 +2639,13 @@
 INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('wms_north_america', 1, 'owner');
 INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('wms_worldwide', 1, 'owner');
 INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('gui2', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin_en_services', 1, 'owner');
 INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('gui_digitize', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin_de_services', 1, 'owner');
--- TOC entry 1788 (class 0 OID 47913166)
+-- TOC entry 1810 (class 0 OID 47913166)
 -- Dependencies: 1245
 -- Data for Name: gui_treegde; Type: TABLE DATA; Schema: public; Owner: admin
@@ -2655,7 +2663,7 @@
--- TOC entry 1789 (class 0 OID 47913175)
+-- TOC entry 1811 (class 0 OID 47913175)
 -- Dependencies: 1246
 -- Data for Name: gui_wfs; Type: TABLE DATA; Schema: public; Owner: admin
@@ -2665,52 +2673,26 @@
--- TOC entry 1790 (class 0 OID 47913179)
+-- TOC entry 1812 (class 0 OID 47913179)
 -- Dependencies: 1247
 -- Data for Name: gui_wms; Type: TABLE DATA; Schema: public; Owner: admin
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui', 250, 0, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 0);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui', 640, 1, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 0);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui1', 407, 1, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_africa', 615, 0, 'PNG', 'mime', 'INIMAGE', 'EPSG:4326', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui', 407, 3, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_australia', 706, 0, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_australia', 634, 1, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:26915', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_australia', 827, 2, 'png', '', 'inimage', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_europe', 739, 0, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_europe', 824, 1, 'image/png', '', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_europe', 828, 2, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:23030', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_europe', 829, 3, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31297', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui', 640, 1, 'image/png', '', 'application/vnd.ogc.se_xml', 'EPSG:4326', 0);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui2', 640, 1, 'image/png', '', 'application/vnd.ogc.se_xml', 'EPSG:4326', 0);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 329, 2, 'IMAGE/PNG', 'text/plain', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:31467', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 583, 0, 'image/gif', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 584, 1, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 655, 2, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 614, 3, 'PNG', 'mime', 'INIMAGE', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 616, 4, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:26920', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 617, 5, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 625, 6, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:42304', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 645, 7, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 525, 8, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 800, 9, 'image/jpeg', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 831, 10, 'image/png', 'text/plain', 'application/vnd.ogc.se_inimage', 'EPSG:26915', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 832, 11, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 833, 12, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 834, 13, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:102257', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 612, 0, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', '', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 613, 1, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 640, 2, 'IMAGE/PNG', '', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 637, 3, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 101, 4, 'image/gif', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 250, 5, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 0);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 86, 6, 'image/gif', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 840, 7, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:27700', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 841, 8, 'image/png', 'text/plain', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 842, 9, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 843, 10, 'png', 'mime', 'inimage', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 844, 11, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui1', 893, 0, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31467', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 717, 1, 'image/jpeg', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31492', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 329, 2, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:31467', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 624, 3, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 648, 4, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 328, 5, 'IMAGE/PNG', 'application/vnd.ogc.gml', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:31466', 1);
@@ -2719,7 +2701,6 @@
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 670, 8, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 671, 9, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui2', 250, 0, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 0);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui2', 640, 1, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 0);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui2', 893, 2, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31467', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 893, 0, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31467', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui', 893, 2, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31467', 1);
@@ -2727,43 +2708,54 @@
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 866, 0, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 867, 1, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 869, 2, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 872, 3, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 881, 4, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31467', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 882, 5, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31467', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 883, 6, 'png', 'mime', 'WMS_XML', 'EPSG:31467', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 887, 7, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31492', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 717, 8, 'image/jpeg', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31492', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 624, 9, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 648, 10, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 670, 11, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 671, 12, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 836, 14, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 837, 15, 'image/jpeg', '', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_africa', 777, 1, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_africa', 779, 2, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_africa', 899, 3, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_africa', 900, 4, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 787, 11, 'IMAGE/PNG', '', 'application/vnd.ogc.se_xml', 'EPSG:31464', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui_digitize', 640, 1, 'image/png', '', 'application/vnd.ogc.se_xml', 'EPSG:4326', 0);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 640, 1, 'IMAGE/PNG', '', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 792, 13, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:31468', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 786, 10, 'IMAGE/PNG', 'text/plain', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:31468', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 787, 11, 'IMAGE/PNG', '', 'application/vnd.ogc.se_xml', 'EPSG:31464', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 789, 12, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 790, 13, 'IMAGE/PNG', '', 'application/vnd.ogc.se_xml', 'EPSG:31467', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 792, 14, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:31468', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 793, 15, 'IMAGE/PNG', '', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:31467', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 785, 16, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 902, 17, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:25833', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 904, 19, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:25833', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 903, 18, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:25833', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 905, 20, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:25833', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 906, 21, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:25833', 1);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 908, 22, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui_digitize', 250, 0, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 0);
-INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui_digitize', 640, 1, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 0);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui_digitize', 893, 2, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31467', 1);
 INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('gui_digitize', 909, 3, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 613, 0, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 637, 2, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 101, 3, 'image/gif', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 250, 4, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 0);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 86, 5, 'image/gif', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 840, 6, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:27700', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 841, 7, 'image/png', 'text/plain', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 842, 8, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 843, 9, 'png', 'mime', 'inimage', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_worldwide', 844, 10, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 800, 7, 'image/jpeg', '', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 836, 10, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', '', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 837, 11, 'image/jpeg', '', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_europe', 824, 0, 'image/png', '', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 625, 4, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:42304', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 645, 5, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 525, 6, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_europe', 828, 1, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:23030', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 785, 14, 'IMAGE/PNG', 'text/html', 'APPLICATION/VND.OGC.SE_INIMAGE', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 902, 15, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:25833', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 904, 17, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:25833', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 903, 16, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:25833', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 905, 18, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:25833', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 906, 19, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:25833', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_germany', 908, 20, 'image/png', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 832, 8, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:4326', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_north_america', 834, 9, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:102257', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 882, 3, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31467', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 883, 4, 'png', 'mime', 'WMS_XML', 'EPSG:31467', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 887, 5, 'image/png', 'text/html', 'application/vnd.ogc.se_inimage', 'EPSG:31492', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 717, 6, 'image/jpeg', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31492', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 624, 7, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 648, 8, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 670, 9, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
+INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) VALUES ('wms_gdi_de', 671, 10, 'IMAGE/PNG', 'text/html', 'application/vnd.ogc.se_xml', 'EPSG:31466', 1);
--- TOC entry 1809 (class 0 OID 48558625)
+-- TOC entry 1831 (class 0 OID 48558625)
 -- Dependencies: 1277
 -- Data for Name: keyword; Type: TABLE DATA; Schema: public; Owner: admin
@@ -2797,81 +2789,193 @@
 INSERT INTO keyword (keyword_id, keyword) VALUES (27, 'Staedte');
 INSERT INTO keyword (keyword_id, keyword) VALUES (28, 'Bundesland');
 INSERT INTO keyword (keyword_id, keyword) VALUES (29, 'Land');
+INSERT INTO keyword (keyword_id, keyword) VALUES (30, 'digitize');
+INSERT INTO keyword (keyword_id, keyword) VALUES (31, 'polygon');
+INSERT INTO keyword (keyword_id, keyword) VALUES (32, 'Linie');
+INSERT INTO keyword (keyword_id, keyword) VALUES (33, 'line');
+INSERT INTO keyword (keyword_id, keyword) VALUES (34, 'point');
+INSERT INTO keyword (keyword_id, keyword) VALUES (35, 'Punkt');
+INSERT INTO keyword (keyword_id, keyword) VALUES (36, 'poi');
+INSERT INTO keyword (keyword_id, keyword) VALUES (37, 'ArcIMS');
+INSERT INTO keyword (keyword_id, keyword) VALUES (38, 'ESRI');
+INSERT INTO keyword (keyword_id, keyword) VALUES (39, 'OGC Map Service');
+INSERT INTO keyword (keyword_id, keyword) VALUES (40, 'Web Mapping');
+INSERT INTO keyword (keyword_id, keyword) VALUES (41, 'GIS');
+INSERT INTO keyword (keyword_id, keyword) VALUES (42, 'GDI NRW');
+INSERT INTO keyword (keyword_id, keyword) VALUES (43, 'NWSIB');
+INSERT INTO keyword (keyword_id, keyword) VALUES (44, 'klassifiziertes Straßennetz');
+INSERT INTO keyword (keyword_id, keyword) VALUES (45, 'Anweisung Straßeninformationsbank ASB');
+INSERT INTO keyword (keyword_id, keyword) VALUES (46, 'Netzknoten-Stationierungssystem');
+INSERT INTO keyword (keyword_id, keyword) VALUES (47, 'birds');
+INSERT INTO keyword (keyword_id, keyword) VALUES (48, 'distribution');
+INSERT INTO keyword (keyword_id, keyword) VALUES (49, 'abundance');
+INSERT INTO keyword (keyword_id, keyword) VALUES (50, 'conservation');
+INSERT INTO keyword (keyword_id, keyword) VALUES (51, 'sites');
+INSERT INTO keyword (keyword_id, keyword) VALUES (52, 'monitoring');
+INSERT INTO keyword (keyword_id, keyword) VALUES (53, 'populations');
+INSERT INTO keyword (keyword_id, keyword) VALUES (54, 'canada');
+INSERT INTO keyword (keyword_id, keyword) VALUES (55, 'iba');
+INSERT INTO keyword (keyword_id, keyword) VALUES (56, 'birdlife');
+INSERT INTO keyword (keyword_id, keyword) VALUES (57, 'winter');
+INSERT INTO keyword (keyword_id, keyword) VALUES (58, 'survey');
+INSERT INTO keyword (keyword_id, keyword) VALUES (59, 'population');
+INSERT INTO keyword (keyword_id, keyword) VALUES (60, 'volunteers');
+INSERT INTO keyword (keyword_id, keyword) VALUES (61, 'cbc');
+INSERT INTO keyword (keyword_id, keyword) VALUES (62, 'christmas');
+INSERT INTO keyword (keyword_id, keyword) VALUES (63, 'Słubfurt');
+INSERT INTO keyword (keyword_id, keyword) VALUES (64, ' Słubice');
+INSERT INTO keyword (keyword_id, keyword) VALUES (65, ' Frankfurt (Oder)');
+INSERT INTO keyword (keyword_id, keyword) VALUES (66, ' topophilia');
+INSERT INTO keyword (keyword_id, keyword) VALUES (67, ' mental maps');
+INSERT INTO keyword (keyword_id, keyword) VALUES (68, 'geopgraphy');
+INSERT INTO keyword (keyword_id, keyword) VALUES (69, 'spatial perception');
+INSERT INTO keyword (keyword_id, keyword) VALUES (71, 'sense of place and identity');
+INSERT INTO keyword (keyword_id, keyword) VALUES (70, 'waterbirds');
+INSERT INTO keyword (keyword_id, keyword) VALUES (72, 'amphibians');
+INSERT INTO keyword (keyword_id, keyword) VALUES (73, 'cognitive map');
+INSERT INTO keyword (keyword_id, keyword) VALUES (74, 'marsh');
+INSERT INTO keyword (keyword_id, keyword) VALUES (75, 'spatial cognition');
+INSERT INTO keyword (keyword_id, keyword) VALUES (76, 'wetland');
+INSERT INTO keyword (keyword_id, keyword) VALUES (77, 'cognitive psychology');
+INSERT INTO keyword (keyword_id, keyword) VALUES (78, 'cognitive science');
+INSERT INTO keyword (keyword_id, keyword) VALUES (79, 'urban design');
+INSERT INTO keyword (keyword_id, keyword) VALUES (80, 'united states');
+INSERT INTO keyword (keyword_id, keyword) VALUES (81, 'great lakes');
+INSERT INTO keyword (keyword_id, keyword) VALUES (82, 'spatial orientation');
+INSERT INTO keyword (keyword_id, keyword) VALUES (83, 'AOC');
+INSERT INTO keyword (keyword_id, keyword) VALUES (84, 'identity of place');
+INSERT INTO keyword (keyword_id, keyword) VALUES (85, ' borders');
+INSERT INTO keyword (keyword_id, keyword) VALUES (86, 'national landscapes');
+INSERT INTO keyword (keyword_id, keyword) VALUES (87, 'Gavia immer');
+INSERT INTO keyword (keyword_id, keyword) VALUES (88, 'loons');
+INSERT INTO keyword (keyword_id, keyword) VALUES (89, 'lakes');
+INSERT INTO keyword (keyword_id, keyword) VALUES (90, 'acid rain');
+INSERT INTO keyword (keyword_id, keyword) VALUES (91, 'disturbance');
+INSERT INTO keyword (keyword_id, keyword) VALUES (92, 'ecosystem health');
+INSERT INTO keyword (keyword_id, keyword) VALUES (93, 'breeding range');
+INSERT INTO keyword (keyword_id, keyword) VALUES (94, 'Ontario');
+INSERT INTO keyword (keyword_id, keyword) VALUES (95, 'deegree');
+INSERT INTO keyword (keyword_id, keyword) VALUES (96, 'wms');
+INSERT INTO keyword (keyword_id, keyword) VALUES (97, 'ImageryBaseMapsEarthCover');
+INSERT INTO keyword (keyword_id, keyword) VALUES (98, 'Imagery');
+INSERT INTO keyword (keyword_id, keyword) VALUES (99, 'BaseMaps');
+INSERT INTO keyword (keyword_id, keyword) VALUES (100, 'EarthCover');
+INSERT INTO keyword (keyword_id, keyword) VALUES (101, 'JPL');
+INSERT INTO keyword (keyword_id, keyword) VALUES (102, 'Jet Propulsion Laboratory');
+INSERT INTO keyword (keyword_id, keyword) VALUES (103, 'Landsat');
+INSERT INTO keyword (keyword_id, keyword) VALUES (104, 'none');
+INSERT INTO keyword (keyword_id, keyword) VALUES (105, 'SLD');
+INSERT INTO keyword (keyword_id, keyword) VALUES (106, 'owls');
+INSERT INTO keyword (keyword_id, keyword) VALUES (107, 'Global');
+INSERT INTO keyword (keyword_id, keyword) VALUES (108, 'broadcast');
+INSERT INTO keyword (keyword_id, keyword) VALUES (109, 'breeding');
+INSERT INTO keyword (keyword_id, keyword) VALUES (110, 'roadside');
+INSERT INTO keyword (keyword_id, keyword) VALUES (111, 'Delaware');
+INSERT INTO keyword (keyword_id, keyword) VALUES (112, 'DataMIL');
+INSERT INTO keyword (keyword_id, keyword) VALUES (113, 'The National Map');
+INSERT INTO keyword (keyword_id, keyword) VALUES (114, 'framework');
+INSERT INTO keyword (keyword_id, keyword) VALUES (115, 'orthoimagery');
+INSERT INTO keyword (keyword_id, keyword) VALUES (116, 'orthophotography');
+INSERT INTO keyword (keyword_id, keyword) VALUES (117, 'aerial imagery');
+INSERT INTO keyword (keyword_id, keyword) VALUES (118, 'imagery');
+INSERT INTO keyword (keyword_id, keyword) VALUES (119, 'OGC');
+INSERT INTO keyword (keyword_id, keyword) VALUES (120, ' La Rioja');
+INSERT INTO keyword (keyword_id, keyword) VALUES (121, 'Cartografia');
+INSERT INTO keyword (keyword_id, keyword) VALUES (122, ' Mapas ');
+INSERT INTO keyword (keyword_id, keyword) VALUES (123, 'TAT');
+INSERT INTO keyword (keyword_id, keyword) VALUES (124, 'Critical Habitat');
+INSERT INTO keyword (keyword_id, keyword) VALUES (125, 'NWI');
+INSERT INTO keyword (keyword_id, keyword) VALUES (126, 'seacoos');
+INSERT INTO keyword (keyword_id, keyword) VALUES (127, ' near real-time ocean data');
+INSERT INTO keyword (keyword_id, keyword) VALUES (128, ' merged observational data');
+INSERT INTO keyword (keyword_id, keyword) VALUES (129, ' merged models');
+INSERT INTO keyword (keyword_id, keyword) VALUES (130, ' southeastern united states');
+INSERT INTO keyword (keyword_id, keyword) VALUES (131, ' in-situ moored sensing');
+INSERT INTO keyword (keyword_id, keyword) VALUES (132, ' in-situ drifting sensing');
+INSERT INTO keyword (keyword_id, keyword) VALUES (133, ' coastal');
+INSERT INTO keyword (keyword_id, keyword) VALUES (134, ' offshore');
+INSERT INTO keyword (keyword_id, keyword) VALUES (135, ' remote sensing');
+INSERT INTO keyword (keyword_id, keyword) VALUES (136, ' satellites');
+INSERT INTO keyword (keyword_id, keyword) VALUES (137, ' aircraft');
+INSERT INTO keyword (keyword_id, keyword) VALUES (138, ' current');
+INSERT INTO keyword (keyword_id, keyword) VALUES (139, ' sea surface temperature');
+INSERT INTO keyword (keyword_id, keyword) VALUES (140, ' SST');
+INSERT INTO keyword (keyword_id, keyword) VALUES (141, ' wind speed and direction');
+INSERT INTO keyword (keyword_id, keyword) VALUES (142, ' RGB');
+INSERT INTO keyword (keyword_id, keyword) VALUES (143, ' true color');
+INSERT INTO keyword (keyword_id, keyword) VALUES (144, 'TBA');
+INSERT INTO keyword (keyword_id, keyword) VALUES (145, 'enhanced true color image');
+INSERT INTO keyword (keyword_id, keyword) VALUES (146, ' upper ocean waters');
+INSERT INTO keyword (keyword_id, keyword) VALUES (171, 'Testing');
+INSERT INTO keyword (keyword_id, keyword) VALUES (147, ' coastal zones');
+INSERT INTO keyword (keyword_id, keyword) VALUES (148, ' ocean color');
+INSERT INTO keyword (keyword_id, keyword) VALUES (149, ' MODerate Resolution Imaging Spectroradiometers');
+INSERT INTO keyword (keyword_id, keyword) VALUES (150, ' MODIS');
+INSERT INTO keyword (keyword_id, keyword) VALUES (151, ' NASA polar orbiting Terra and Aqua satellites');
+INSERT INTO keyword (keyword_id, keyword) VALUES (152, ' USF Institute for Marine Remote Sensing');
+INSERT INTO keyword (keyword_id, keyword) VALUES (153, ' imars');
+INSERT INTO keyword (keyword_id, keyword) VALUES (154, 'approximate true color');
+INSERT INTO keyword (keyword_id, keyword) VALUES (155, ' land areas');
+INSERT INTO keyword (keyword_id, keyword) VALUES (156, ' chesapeake bay');
+INSERT INTO keyword (keyword_id, keyword) VALUES (157, ' florida bay');
+INSERT INTO keyword (keyword_id, keyword) VALUES (158, ' miss plume');
+INSERT INTO keyword (keyword_id, keyword) VALUES (159, ' suwannee river');
+INSERT INTO keyword (keyword_id, keyword) VALUES (160, ' tampa bay');
+INSERT INTO keyword (keyword_id, keyword) VALUES (161, 'operational');
+INSERT INTO keyword (keyword_id, keyword) VALUES (162, ' cloud free');
+INSERT INTO keyword (keyword_id, keyword) VALUES (163, ' satellite SST');
+INSERT INTO keyword (keyword_id, keyword) VALUES (164, ' Optimal Interpolation');
+INSERT INTO keyword (keyword_id, keyword) VALUES (165, ' NOAA and NASA satellites');
+INSERT INTO keyword (keyword_id, keyword) VALUES (166, ' USF Ocean Circulation Group');
+INSERT INTO keyword (keyword_id, keyword) VALUES (167, 'SST');
+INSERT INTO keyword (keyword_id, keyword) VALUES (168, ' AVHRR');
+INSERT INTO keyword (keyword_id, keyword) VALUES (169, ' Advanced Very High Resolution Radiometer');
+INSERT INTO keyword (keyword_id, keyword) VALUES (170, ' NOAA satellites');
+INSERT INTO keyword (keyword_id, keyword) VALUES (172, 'ICEDS');
+INSERT INTO keyword (keyword_id, keyword) VALUES (173, 'Texas');
+INSERT INTO keyword (keyword_id, keyword) VALUES (174, 'LANDSAT');
+INSERT INTO keyword (keyword_id, keyword) VALUES (175, ' Mesonet');
+INSERT INTO keyword (keyword_id, keyword) VALUES (176, 'SRTM');
+INSERT INTO keyword (keyword_id, keyword) VALUES (177, ' radar');
+INSERT INTO keyword (keyword_id, keyword) VALUES (178, 'GRID');
+INSERT INTO keyword (keyword_id, keyword) VALUES (179, 'LANDSAT 5');
+INSERT INTO keyword (keyword_id, keyword) VALUES (180, 'SRTM3');
+INSERT INTO keyword (keyword_id, keyword) VALUES (181, 'GSHHS');
+INSERT INTO keyword (keyword_id, keyword) VALUES (182, 'SRTM30');
+INSERT INTO keyword (keyword_id, keyword) VALUES (183, 'GTOPO30');
+INSERT INTO keyword (keyword_id, keyword) VALUES (184, 'USGS');
+INSERT INTO keyword (keyword_id, keyword) VALUES (185, 'DOQ');
+INSERT INTO keyword (keyword_id, keyword) VALUES (186, 'DRG');
+INSERT INTO keyword (keyword_id, keyword) VALUES (187, 'DNM');
+INSERT INTO keyword (keyword_id, keyword) VALUES (188, 'Topographic');
+INSERT INTO keyword (keyword_id, keyword) VALUES (189, 'GDI');
+INSERT INTO keyword (keyword_id, keyword) VALUES (190, 'UrbanArea');
+INSERT INTO keyword (keyword_id, keyword) VALUES (191, 'Urban Areas');
+INSERT INTO keyword (keyword_id, keyword) VALUES (192, 'Navigation');
+INSERT INTO keyword (keyword_id, keyword) VALUES (193, 'Brandenburg');
+INSERT INTO keyword (keyword_id, keyword) VALUES (194, 'Weather Maps');
+INSERT INTO keyword (keyword_id, keyword) VALUES (199, 'MODIS');
+INSERT INTO keyword (keyword_id, keyword) VALUES (200, 'BLUE MARBLE');
+INSERT INTO keyword (keyword_id, keyword) VALUES (201, 'DMSP');
+INSERT INTO keyword (keyword_id, keyword) VALUES (202, 'NOAA');
+INSERT INTO keyword (keyword_id, keyword) VALUES (203, 'night lights');
+INSERT INTO keyword (keyword_id, keyword) VALUES (204, 'ASTER DEM footprints');
+INSERT INTO keyword (keyword_id, keyword) VALUES (205, ' water bodies');
+INSERT INTO keyword (keyword_id, keyword) VALUES (206, 'ASTER');
+INSERT INTO keyword (keyword_id, keyword) VALUES (207, 'Three Gorges');
+INSERT INTO keyword (keyword_id, keyword) VALUES (208, 'ECW');
+INSERT INTO keyword (keyword_id, keyword) VALUES (209, 'JPEG 2000');
--- TOC entry 1791 (class 0 OID 47913191)
+-- TOC entry 1813 (class 0 OID 47913191)
 -- Dependencies: 1249
 -- Data for Name: layer; Type: TABLE DATA; Schema: public; Owner: admin
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2712, 250, 0, '', '', 'Demis World Map', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2713, 250, 1, '0', 'Bathymetry', 'Bathymetry', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2714, 250, 2, '0', 'Countries', 'Countries', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2715, 250, 3, '0', 'Topography', 'Topography', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2716, 250, 4, '0', 'Hillshading', 'Hillshading', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2717, 250, 5, '0', 'Builtup areas', 'Builtup areas', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2718, 250, 6, '0', 'Coastlines', 'Coastlines', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2719, 250, 7, '0', 'Waterbodies', 'Waterbodies', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2720, 250, 8, '0', 'Inundated', 'Inundated', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2721, 250, 9, '0', 'Rivers', 'Rivers', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2722, 250, 10, '0', 'Streams', 'Streams', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2723, 250, 11, '0', 'Railroads', 'Railroads', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2724, 250, 12, '0', 'Highways', 'Highways', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2725, 250, 13, '0', 'Roads', 'Roads', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2726, 250, 14, '0', 'Trails', 'Trails', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2727, 250, 15, '0', 'Borders', 'Borders', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2728, 250, 16, '0', 'Cities', 'Cities', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2729, 250, 17, '0', 'Settlements', 'Settlements', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2730, 250, 18, '0', 'Spot elevations', 'Spot elevations', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2731, 250, 19, '0', 'Airports', 'Airports', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2732, 250, 20, '0', 'Ocean features', 'Ocean features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3384, 328, 0, '', '', 'SW!ACE: Layers des Smallworld GIS', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3385, 328, 1, '0', 'Autobahn', 'Autobahn', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3386, 328, 2, '0', 'Bundesstr.', 'Bundesstr.', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3387, 328, 3, '0', 'Landesstr.', 'Landesstr.', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3388, 328, 4, '0', 'Kreisstr.', 'Kreisstr.', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3389, 328, 5, '0', 'AS Nr.', 'AS Nr.', 1, 0, 100220, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3390, 328, 6, '0', 'AS Name', 'AS Name', 1, 0, 53451, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3391, 328, 7, '0', 'Bauwerke', 'Bauwerke', 1, 0, 24720, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3392, 328, 8, '0', 'BW-Nr.', 'BW-Nr.', 1, 0, 24720, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3393, 328, 9, '0', 'Aeste', 'Aeste', 1, 0, 233847, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3394, 328, 10, '0', 'Netzkn.', 'Netzkn.', 1, 0, 53451, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3395, 328, 11, '0', 'Nullpkt.', 'Nullpkt.', 1, 0, 24720, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3396, 328, 12, '0', 'Str. Bez.', 'Str. Bez.', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3397, 328, 13, '0', 'Abs.Nr.', 'Abs.Nr.', 1, 0, 53451, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3398, 328, 14, '0', 'Durchlaesse', 'Durchlaesse', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3399, 328, 15, '0', 'Kreuzungen', 'Kreuzungen', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3400, 328, 16, '0', 'DGK 5', 'DGK 5', 0, 0, 24720, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3401, 329, 0, '', 'MUENSTER', 'Geobasisdaten Muenster', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3402, 329, 1, '0', 'splan', 'Stadtplan', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3403, 329, 2, '0', 'luftb', 'Luftbilder', 0, 1, 50000, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3404, 329, 3, '0', 'dgk5dbr', 'DGK5', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3405, 329, 4, '0', 'Stadtgrundkarte', 'Stadtgrundkarte', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3406, 329, 5, '4', 'flst', 'Flurstuecke', 0, 1, 2500, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3407, 329, 6, '4', 'gebaeude', 'Gebaeude', 0, 1, 2500, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3408, 329, 7, '4', 'linien', 'Topographie', 0, 1, 2500, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3409, 329, 8, '4', 'texte', 'Beschriftung', 0, 1, 2500, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3470, 336, 0, '', '', 'DTK10', 0, 138, 27683, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3471, 336, 1, '0', 'DTK10:Gesamt', 'Gesamt', 1, 0, 0, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3472, 336, 2, '0', 'DTK10:GesamtRS', 'GesamtRS', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (5575, 486, 0, '', 'PLZ_441', 'PLZ_441', 0, 1, 1000000000, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (5576, 486, 1, '0', 'Nationalborder', 'National Border', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (5577, 486, 2, '0', 'Postcodeareas', 'Post Code Areas', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (5578, 486, 3, '0', 'Postcodelabels', 'Post Code Labels', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7255, 525, 0, '', 'Middle_America', 'Middle America', 0, 0, 119999880, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7256, 525, 1, '0', 'North_and_South_American_States', 'America', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7257, 525, 2, '0', 'Middle_American_States_AREA', 'State Area', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7258, 525, 3, '0', 'Middle_America_DEM_surface', 'Elevation Model', 0, 0, 11999988, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7259, 525, 4, '0', 'National_borders', 'Borders', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7260, 525, 5, '0', 'Lakes_and_temporary_inundated_areas', 'Lakes', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7261, 525, 6, '0', 'Temporary_and_permanent_rivers_and_streams', 'Rivers', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7262, 525, 7, '0', 'Larger_cities_polygon', 'Cities', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7263, 525, 8, '0', 'Roads', 'Roads', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7264, 525, 9, '0', 'Railway_systems', 'Rails', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7265, 525, 10, '0', 'Smaller_cities_and_villages_point', 'Places', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7266, 525, 11, '0', 'Archaeological_maya_sites', 'Maya Sites', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7267, 525, 12, '0', 'Archaeological_maya_records', 'Maya Records', 1, 0, 0, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7491, 583, 0, '', 'canada_base', 'Atlas of Canada WMS', 0, 0, 0, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7492, 583, 1, '0', 'roc_2m', 'Regions outside Canada (1:2 000 000)', 0, 0, 0, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7493, 583, 2, '0', 'roc_7.5m', 'Regions outside Canada (1:7 500 000)', 0, 0, 0, '', NULL, NULL);
@@ -2898,231 +3002,60 @@
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7514, 583, 23, '0', 'places_labels_15m', 'Populated Places (labels 1:15M)', 1, 0, 0, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7515, 583, 24, '0', 'cap_symb_e', 'Capitals (symbols)', 1, 0, 0, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7516, 583, 25, '0', 'cap_labels', 'Capitals (Canada)', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7517, 584, 0, '', 'BSC_WMS', 'Bird Studies Canada WMS/WFS Server', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7518, 584, 1, '0', 'IBA', 'Canadian Important Bird Areas', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7519, 584, 2, '0', 'CBC_PT', 'Canadian Christmas Bird Count Locations', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7520, 584, 3, '0', 'CBC_PY', 'Canadian Christmas Bird Count Locations', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7521, 584, 4, '0', 'MMP', 'Marsh Monitoring Program Route Locations', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7522, 584, 5, '0', 'CLLS', 'Canadian Lakes Loon Survey Locations', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7523, 584, 6, '0', 'OBBA_SQUARE', 'Ontario Breeding Bird Atlas 10 km Squares', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7524, 584, 7, '0', 'OBBA_REGION', 'Ontario Breeding Bird Atlas Administrative Regions', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7525, 584, 8, '0', 'OBBA_BLOCK', 'Ontario Breeding Bird Atlas 100 km Blocks', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7526, 584, 9, '0', 'OWLS', 'Nocturnal Owl Survey Locations', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7527, 584, 10, '0', 'BBS_PT', 'Breeding Bird Survey Route Start Points', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9663, 612, 0, '', '', 'European Space Agency', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9664, 612, 1, '0', '', 'European Space Agency', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9665, 612, 2, '1', '', 'BOUNDARIES', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9666, 612, 3, '2', 'BARRIERL_1M:MapAdmin', 'Barrier Line Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9667, 612, 4, '2', 'BNDTXT_1M:MapAdmin', 'Boundaries Coverage Text', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9668, 612, 5, '2', 'COASTL_1M:MapAdmin', 'Coastlines', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9669, 612, 6, '2', 'DEPTHL_1M:MapAdmin', 'Depth Contours', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9670, 612, 7, '2', 'OCEANSEA_1M:MapAdmin', 'Oceans/Seas', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9671, 612, 8, '2', 'POLBNDA_1M:MapAdmin', 'Administrative Areas', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9672, 612, 9, '2', 'POLBNDL_1M:MapAdmin', 'Political Boundaries', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9673, 612, 10, '2', 'POLBNDP_1M:MapAdmin', 'Political Boundary Point Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9674, 612, 11, '1', '', 'BURNSCARS', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9675, 612, 12, '11', 'GLOBSCAR012002:MapAdmin', 'GLOBSCAR012002', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9676, 612, 13, '11', 'GLOBSCAR022002:MapAdmin', 'GLOBSCAR022002', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9677, 612, 14, '11', 'GLOBSCAR032002:MapAdmin', 'GLOBSCAR032002', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9678, 612, 15, '11', 'GLOBSCAR042002:MapAdmin', 'GLOBSCAR042002', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9679, 612, 16, '11', 'GLOBSCAR052002:MapAdmin', 'GLOBSCAR052002', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9680, 612, 17, '11', 'GLOBSCAR062002:MapAdmin', 'GLOBSCAR062002', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9681, 612, 18, '11', 'GLOBSCAR072002:MapAdmin', 'GLOBSCAR072002', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9682, 612, 19, '11', 'GLOBSCAR082002:MapAdmin', 'GLOBSCAR082002', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9683, 612, 20, '11', 'GLOBSCAR092002:MapAdmin', 'GLOBSCAR092002', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9684, 612, 21, '11', 'GLOBSCAR102002:MapAdmin', 'GLOBSCAR102002', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9685, 612, 22, '11', 'GLOBSCAR112002:MapAdmin', 'GLOBSCAR112002', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9686, 612, 23, '11', 'GLOBSCAR122002:MapAdmin', 'GLOBSCAR122002', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9687, 612, 24, '1', '', 'DATA QUALITY', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9688, 612, 25, '24', 'DQLINE_TRANS_1M:MapAdmin', 'Data Quality Line Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9689, 612, 26, '24', 'DQLINE_UTIL_1M:MapAdmin', 'Data Quality Line Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9690, 612, 27, '1', '', 'DIGITAL TERRAIN', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9691, 612, 28, '27', 'ETOPO5:MapAdmin', 'Global 5 Minute Elevations', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9692, 612, 29, '27', 'GTOPO30:MapAdmin', 'Global 30 Second Elevations', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9693, 612, 30, '1', '', 'ELEVATION', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9694, 612, 31, '30', 'CONTOURL_1M:MapAdmin', 'Elevation Contours', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9695, 612, 32, '30', 'ELEVP_1M:MapAdmin', 'Spot Elevations', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9696, 612, 33, '1', '', 'ENVISAT', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9697, 612, 34, '33', 'AATSR:MapAdmin', 'AATSR', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9698, 612, 35, '33', 'ASAR:MapAdmin', 'ASAR', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9699, 612, 36, '33', 'ASAR_WSM:MapAdmin', 'ASAR_WSM', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9700, 612, 37, '33', 'MERIS_RR:MapAdmin', 'MERIS_RR', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9701, 612, 38, '1', '', 'EO_MAPS', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9702, 612, 39, '38', 'WORLD_DMSP_NIGHT:MapAdmin', 'WORLD_DMSP_NIGHT', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9703, 612, 40, '38', 'WORLD_MODIS_1KM:MapAdmin', 'WORLD_MODIS_1KM', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9704, 612, 41, '38', 'WORLD_MODIS_5KM:MapAdmin', 'WORLD_MODIS_5KM', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9705, 612, 42, '1', '', 'GISD', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9706, 612, 43, '42', 'GISD_ROI:MapAdmin', 'GISD_ROI', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9707, 612, 44, '1', '', 'HYDROGRAPHY', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9708, 612, 45, '44', 'AQUECANL_1M:MapAdmin', 'Aqueducts/Canals/Flumes/Penstocks', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9709, 612, 46, '44', 'DANGERP_1M:MapAdmin', 'Danger Point Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9710, 612, 47, '44', 'HYDROTXT_1M:MapAdmin', 'Hydrography Coverage Text', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9711, 612, 48, '44', 'INWATERA_1M:MapAdmin', 'Inland Water Areas', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9712, 612, 49, '44', 'MISCL_1M:MapAdmin', 'Miscellaneous Line Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9713, 612, 50, '44', 'MISCP_1M:MapAdmin', 'Miscellaneous Point Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9714, 612, 51, '44', 'WATRCRSL_1M:MapAdmin', 'Water Courses', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9715, 612, 52, '1', '', 'INDUSTRY', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9716, 612, 53, '52', 'EXTRACTA_1M:MapAdmin', 'Extraction Areas', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9717, 612, 54, '52', 'EXTRACTP_1M:MapAdmin', 'Extraction Point Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9718, 612, 55, '52', 'FISHINDA_1M:MapAdmin', 'Fish Hatcheries/Fish Farms', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9719, 612, 56, '52', 'INDTXT_1M:MapAdmin', 'Industry Coverage Text', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9720, 612, 57, '52', 'MISINDP_1M:MapAdmin', 'Miscellaneous Industry Point Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9721, 612, 58, '52', 'STORAGEP_1M:MapAdmin', 'Storage Point Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9722, 612, 59, '1', '', 'PHYSIOGRAPHY', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9723, 612, 60, '59', 'GROUNDA_1M:MapAdmin', 'Ground Surface Areas', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9724, 612, 61, '59', 'LANDICEA_1M:MapAdmin', 'Snow/Ice Fields and Glaciers', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9725, 612, 62, '59', 'LNDFRML_1M:MapAdmin', 'Landform Line Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9726, 612, 63, '59', 'PHYSTXT_1M:MapAdmin', 'Physiography Coverage Text', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9727, 612, 64, '59', 'SEAICEA_1M:MapAdmin', 'Sea Ice Areas', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9728, 612, 65, '1', '', 'POPULATION', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9729, 612, 66, '65', 'BUILTUPA_1M:MapAdmin', 'Built-Up Areas', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9730, 612, 67, '65', 'BUILTUPP_1M:MapAdmin', 'Built-Up Area Points', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9731, 612, 68, '65', 'MISPOPA_1M:MapAdmin', 'Miscellaneous Population Areas', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9732, 612, 69, '65', 'MISPOPP_1M:MapAdmin', 'Miscellaneous Population Points', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9733, 612, 70, '65', 'POPTXT_1M:MapAdmin', 'Population Coverage Text', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9734, 612, 71, '1', '', 'TRANSPORTATION', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9735, 612, 72, '71', 'AEROFACP_1M:MapAdmin', 'Airport Facilities Points', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9736, 612, 73, '71', 'DQLINE_TRANS_1M:MapAdmin', 'Data Quality Line Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9737, 612, 74, '71', 'MISTRANL_1M:MapAdmin', 'Miscellaneous Transportation Line Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9738, 612, 75, '71', 'RAILRDL_1M:MapAdmin', 'Railroads', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9739, 612, 76, '71', 'ROADL_1M:MapAdmin', 'Roads', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9740, 612, 77, '71', 'RRYARDP_1M:MapAdmin', 'Railroad Yard Points', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9741, 612, 78, '71', 'TRAILL_1M:MapAdmin', 'Trails and Tracks', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9742, 612, 79, '71', 'TRANSTRC_1M:MapAdmin', 'Transportation Structures Points', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9743, 612, 80, '71', 'TRANSTRL_1M:MapAdmin', 'Transportation Structures Lines', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9744, 612, 81, '71', 'TRANSTXT_1M:MapAdmin', 'Transportation Coverage Text', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9745, 612, 82, '1', '', 'UTILITIES', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9746, 612, 83, '82', 'DQLINE_UTIL_1M:MapAdmin', 'Data Quality Line Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9747, 612, 84, '82', 'PIPEL_1M:MapAdmin', 'Pipelines', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9748, 612, 85, '82', 'UTILL_1M:MapAdmin', 'Power Transmission/Telephone/Telegraph Lines', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9749, 612, 86, '82', 'UTILP_1M:MapAdmin', 'Utility Point Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9750, 612, 87, '82', 'UTILTXT_1M:MapAdmin', 'Utilities Coverage Text', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9751, 612, 88, '1', '', 'VEGETATION', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9752, 612, 89, '88', 'CROPA_1M:MapAdmin', 'Croplands', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9753, 612, 90, '88', 'GRASSA_1M:MapAdmin', 'Grasslands', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9754, 612, 91, '88', 'SWAMPA_1M:MapAdmin', 'Marshs/Swamps', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9755, 612, 92, '88', 'TREESA_1M:MapAdmin', 'Trees', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9756, 612, 93, '88', 'TUNDRAA_1M:MapAdmin', 'Tundra', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9757, 612, 94, '0', '', 'CubeWerx Inc.', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9758, 612, 95, '94', '', 'CubeWerx Inc.', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9759, 612, 96, '95', '', 'Boundaries', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9760, 612, 97, '96', 'BARRIERL_1M:Foundation:CubeWerx', 'Barrier Line Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9761, 612, 98, '96', 'BNDTXT_1M:Foundation:CubeWerx', 'Boundaries Coverage Text', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9762, 612, 99, '96', 'COASTL_1M:Foundation:CubeWerx', 'Coastlines', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9763, 612, 100, '96', 'DEPTHL_1M:Foundation:CubeWerx', 'Depth Contours', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9764, 612, 101, '96', 'OCEANSEA_1M:Foundation:CubeWerx', 'Oceans/Seas', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9765, 612, 102, '96', 'POLBNDA_1M:Foundation:CubeWerx', 'Administrative Areas', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9766, 612, 103, '96', 'POLBNDL_1M:Foundation:CubeWerx', 'Political Boundaries', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9767, 612, 104, '96', 'POLBNDP_1M:Foundation:CubeWerx', 'Political Boundary Point Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9768, 612, 105, '95', '', 'Data Quality', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9769, 612, 106, '105', 'DQLINE_TRANS_1M:Foundation:CubeWerx', 'Data Quality Line Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9770, 612, 107, '105', 'DQLINE_UTIL_1M:Foundation:CubeWerx', 'Data Quality Line Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9771, 612, 108, '95', '', 'Digital Terrain', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9772, 612, 109, '108', 'ETOPO2:Foundation:CubeWerx', 'Global 2 Minute Elevations', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9773, 612, 110, '108', 'GTOPO30:Foundation:CubeWerx', 'Global 30 Second Elevations', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9774, 612, 111, '108', 'RELIEF:Foundation:CubeWerx', 'Two Minute Shaded Relief', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9775, 612, 112, '95', '', 'Elevation', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9776, 612, 113, '112', 'CONTOURL_1M:Foundation:CubeWerx', 'Elevation Contours', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9777, 612, 114, '112', 'ELEVP_1M:Foundation:CubeWerx', 'Spot Elevations', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9778, 612, 115, '95', '', 'Hydrography', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9779, 612, 116, '115', 'AQUECANL_1M:Foundation:CubeWerx', 'Aqueducts/Canals/Flumes/Penstocks', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9780, 612, 117, '115', 'DANGERP_1M:Foundation:CubeWerx', 'Danger Point Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9781, 612, 118, '115', 'HYDROTXT_1M:Foundation:CubeWerx', 'Hydrography Coverage Text', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9782, 612, 119, '115', 'INWATERA_1M:Foundation:CubeWerx', 'Inland Water Areas', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9783, 612, 120, '115', 'MISCL_1M:Foundation:CubeWerx', 'Miscellaneous Line Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9784, 612, 121, '115', 'MISCP_1M:Foundation:CubeWerx', 'Miscellaneous Point Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9785, 612, 122, '115', 'WATRCRSL_1M:Foundation:CubeWerx', 'Water Courses', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9786, 612, 123, '95', '', 'Industry', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9787, 612, 124, '123', 'EXTRACTA_1M:Foundation:CubeWerx', 'Extraction Areas', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9788, 612, 125, '123', 'EXTRACTP_1M:Foundation:CubeWerx', 'Extraction Point Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9789, 612, 126, '123', 'FISHINDA_1M:Foundation:CubeWerx', 'Fish Hatcheries/Fish Farms', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9790, 612, 127, '123', 'INDTXT_1M:Foundation:CubeWerx', 'Industry Coverage Text', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9791, 612, 128, '123', 'MISINDP_1M:Foundation:CubeWerx', 'Miscellaneous Industry Point Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9792, 612, 129, '123', 'STORAGEP_1M:Foundation:CubeWerx', 'Storage Point Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9793, 612, 130, '95', '', 'Physiography', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9794, 612, 131, '130', 'GROUNDA_1M:Foundation:CubeWerx', 'Ground Surface Areas', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9795, 612, 132, '130', 'LANDICEA_1M:Foundation:CubeWerx', 'Snow/Ice Fields and Glaciers', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9796, 612, 133, '130', 'LNDFRML_1M:Foundation:CubeWerx', 'Landform Line Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9797, 612, 134, '130', 'PHYSTXT_1M:Foundation:CubeWerx', 'Physiography Coverage Text', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9798, 612, 135, '130', 'SEAICEA_1M:Foundation:CubeWerx', 'Sea Ice Areas', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9799, 612, 136, '95', '', 'Population', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9800, 612, 137, '136', 'BUILTUPA_1M:Foundation:CubeWerx', 'Built-Up Areas', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9801, 612, 138, '136', 'BUILTUPP_1M:Foundation:CubeWerx', 'Built-Up Area Points', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9802, 612, 139, '136', 'MISPOPA_1M:Foundation:CubeWerx', 'Miscellaneous Population Areas', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9803, 612, 140, '136', 'MISPOPP_1M:Foundation:CubeWerx', 'Miscellaneous Population Points', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9804, 612, 141, '136', 'POPTXT_1M:Foundation:CubeWerx', 'Population Coverage Text', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9805, 612, 142, '95', '', 'Transportation', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9806, 612, 143, '142', 'AEROFACP_1M:Foundation:CubeWerx', 'Airport Facilities Points', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9807, 612, 144, '142', 'DQLINE_TRANS_1M:Foundation:CubeWerx', 'Data Quality Line Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9808, 612, 145, '142', 'MISTRANL_1M:Foundation:CubeWerx', 'Miscellaneous Transportation Line Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9809, 612, 146, '142', 'RAILRDL_1M:Foundation:CubeWerx', 'Railroads', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9810, 612, 147, '142', 'ROADL_1M:Foundation:CubeWerx', 'Roads', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9811, 612, 148, '142', 'RRYARDP_1M:Foundation:CubeWerx', 'Railroad Yard Points', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9812, 612, 149, '142', 'TRAILL_1M:Foundation:CubeWerx', 'Trails and Tracks', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9813, 612, 150, '142', 'TRANSTRC_1M:Foundation:CubeWerx', 'Transportation Structures Points', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9814, 612, 151, '142', 'TRANSTRL_1M:Foundation:CubeWerx', 'Transportation Structures Lines', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9815, 612, 152, '142', 'TRANSTXT_1M:Foundation:CubeWerx', 'Transportation Coverage Text', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9816, 612, 153, '95', '', 'Utilities', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9817, 612, 154, '153', 'DQLINE_UTIL_1M:Foundation:CubeWerx', 'Data Quality Line Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9818, 612, 155, '153', 'PIPEL_1M:Foundation:CubeWerx', 'Pipelines', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9819, 612, 156, '153', 'UTILL_1M:Foundation:CubeWerx', 'Power Transmission/Telephone/Telegraph Lines', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9820, 612, 157, '153', 'UTILP_1M:Foundation:CubeWerx', 'Utility Point Features', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9821, 612, 158, '153', 'UTILTXT_1M:Foundation:CubeWerx', 'Utilities Coverage Text', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9822, 612, 159, '95', '', 'Vegetation', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9823, 612, 160, '159', 'CROPA_1M:Foundation:CubeWerx', 'Croplands', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9824, 612, 161, '159', 'GRASSA_1M:Foundation:CubeWerx', 'Grasslands', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9825, 612, 162, '159', 'SWAMPA_1M:Foundation:CubeWerx', 'Marshs/Swamps', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9826, 612, 163, '159', 'TREESA_1M:Foundation:CubeWerx', 'Trees', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9827, 612, 164, '159', 'TUNDRAA_1M:Foundation:CubeWerx', 'Tundra', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9828, 612, 165, '94', '', 'CubeWerx Inc.', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9829, 612, 166, '165', '', 'Shuttle Rader Topography Mission Data', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9830, 612, 167, '166', 'ONEARCSEC:SRTM:CubeWerx', 'One Arc Second SRTM', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9831, 612, 168, '166', 'THREEARCSEC:SRTM:CubeWerx', 'Three Arc Second SRTM', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9832, 612, 169, '94', '', 'CubeWerx Inc.', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9833, 612, 170, '169', '', 'Canadian Geology', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9834, 612, 171, '170', 'AGE_ROCK_TYPE_CA:GSC:CubeWerx', 'Canadian Age Rock Type', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9835, 612, 172, '170', 'FAULTS_CA:GSC:CubeWerx', 'Canadian Fault Lines', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9836, 612, 173, '169', '', 'World Geology', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9837, 612, 174, '173', 'AGE_ROCK_TYPE:GSC:CubeWerx', 'World Age Rock Type', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9838, 612, 175, '173', 'FAULTS:GSC:CubeWerx', 'World Fault Lines', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9839, 612, 176, '173', 'FELSIC_MAGMATIC:GSC:CubeWerx', 'Felsic Magmatic', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9840, 612, 177, '173', 'MAFIC_MAGMATIC:GSC:CubeWerx', 'Mafic Magmatic', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9841, 612, 178, '173', 'PRECAMBRIAN:GSC:CubeWerx', 'Precambrian', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9842, 612, 179, '0', '', 'World Map', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9843, 612, 180, '179', 'Bathymetry:DEMIS', 'Bathymetry', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9844, 612, 181, '179', 'Countries:DEMIS', 'Countries', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9845, 612, 182, '179', 'Topography:DEMIS', 'Topography', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9846, 612, 183, '179', 'Hillshading:DEMIS', 'Hillshading', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9847, 612, 184, '179', 'Builtup areas:DEMIS', 'Builtup areas', 1, 0, 2147483647, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9848, 612, 185, '179', 'Coastlines:DEMIS', 'Coastlines', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9849, 612, 186, '179', 'Waterbodies:DEMIS', 'Waterbodies', 1, 0, 2147483647, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9850, 612, 187, '179', 'Inundated:DEMIS', 'Inundated', 1, 0, 2147483647, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9851, 612, 188, '179', 'Rivers:DEMIS', 'Rivers', 1, 0, 2147483647, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9852, 612, 189, '179', 'Streams:DEMIS', 'Streams', 1, 0, 2147483647, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9853, 612, 190, '179', 'Railroads:DEMIS', 'Railroads', 1, 0, 2147483647, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9854, 612, 191, '179', 'Highways:DEMIS', 'Highways', 1, 0, 2147483647, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9855, 612, 192, '179', 'Roads:DEMIS', 'Roads', 1, 0, 2147483647, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9856, 612, 193, '179', 'Trails:DEMIS', 'Trails', 1, 0, 2147483647, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9857, 612, 194, '179', 'Borders:DEMIS', 'Borders', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9858, 612, 195, '179', 'Cities:DEMIS', 'Cities', 1, 0, 2147483647, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9859, 612, 196, '179', 'Settlements:DEMIS', 'Settlements', 1, 0, 2147483647, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9860, 612, 197, '179', 'Spot elevations:DEMIS', 'Spot elevations', 0, 0, 2147483647, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9861, 612, 198, '179', 'Airports:DEMIS', 'Airports', 1, 0, 2147483647, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9862, 612, 199, '179', 'Ocean features:DEMIS', 'Ocean features', 1, 0, 2147483647, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9863, 612, 200, '0', '', 'Spacemetric Image Server', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9864, 612, 201, '200', '', 'GLCF Satellite Images', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9865, 612, 202, '201', '', 'Landsat ETM Scenes', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9866, 612, 203, '202', 'LANDSAT_TM_GLCF_432:TEST', 'Landsat ETM Band 432 Scenes', 1, 2147483647, 2147483647, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9867, 612, 204, '202', 'LANDSAT_TM_GLCF_432_STRETCH:TEST', 'Landsat ETM Band 432 Scenes, Stretched', 1, 2147483647, 2147483647, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9868, 612, 205, '202', 'LANDSAT_TM_GLCF_742:TEST', 'Landsat ETM Band 742 Scenes', 1, 2147483647, 2147483647, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9869, 612, 206, '200', '', 'DMC Scenes', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9870, 612, 207, '206', 'DMC_QL:TEST', 'DMC Quicklooks', 1, 2147483647, 2147483647, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9871, 612, 208, '0', '', 'TEST2 (X)', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9872, 612, 209, '0', '', 'map annotations', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9873, 612, 210, '209', 'graticule', 'Lat/Lon Graticule', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9874, 612, 211, '209', 'crosshairs', 'Crosshairs', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9875, 613, 0, '', '', 'ArcIMS MapService', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9876, 613, 1, '0', 'Shaded Relief Imagery', 'Shaded Relief Imagery', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7517, 584, 0, '', 'BSC_WMS', 'Data provided by Bird Studies Canada', 0, 0, 0, '', '', 'Bird Studies Canada WMS/WFS Server for bird distribution and abundance data, and related information.  Bird Studies Canada gratefully acknowledges the support of Environment Canada - Canadian Information System for the Environment in developing this service.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7518, 584, 1, '0', 'IBA', 'Canadian Important Bird Areas', 1, 0, 0, '', 'http://www.bsc-eoc.org/website/metadata/caniba_poly.xml', 'This layer represents *generalized* boundaries of Important Bird Areas (IBA) in Canada.  IBAs, in Canada and elsewhere, are evaluated and designated on the basis of internationally criteria.  The polygons contained in the dataset meet these criteria and are therefore deemed significant at the national, continental, or global level.  In Canada, IBAs are not legally recognized entities and therefore do not have any regulatory status.  Nevertheless, they are extremely useful for conservation planning for birds.  Polygon boundaries were digitized on-screen in ArcView GIS 3.2 by using NTDB 1:50K or 1:250K digital layers for reference.  If NTDB coverage was not available (e.g., far north), the Digital Chart of the World (1:1M) was used.  The boundaries of IBAs in this dataset are intentionally generalized to reflect the importance of the surrounding ecosystem on the values present within IBAs.  For example, small islands supporting colonies of seabirds might be buffered by 1 or 2 km to form an IBA.  Boundaries for a very small minority of IBAs were available in paper form as part of IBA conservation plans that had been developed previously.  In such cases, we visually estimated their boundaries against the NTDB or other base layers.  Many IBAs are already recognized as other types of protected areas, e.g., National Wildlife Areas, National and Provincial Parks, Migratory Bird Sanctuaries, conservation reserves, and so on.  In these cases, we used digital boundaries from other sources (e.g., WWF Canada''s Designated Areas Database, Environment Canada''s Canadian Conservation Areas Database) as reference points when digitizing IBA boundaries.  Please cite as follows:  Bird Studies Canada and Nature Canada.  2004.  Important Bird Areas of Canada Database.  Port Rowan, Ontario:  Bird Studies Canada.  To access the Canadian IBA directory: http://www.bsc-eoc.org/iba/ibasites.html.  Full metadata for this layer:  http://www.bsc-eoc.org/website/metadata/caniba_poly.xml');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19208, 717, 0, '', 'forstamtsgr', 'forstamtsgr', 1, 0, 0, '', '', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19253, 836, 0, '', 'NDOP', 'NDOP', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19209, 785, 0, '', 'dtk200_500_1000_a10_gk3_wms', 'dtk200_500_1000_a10_gk3_wms', 0, 0, 0, '', '', 'WMS Map Server');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14114, 767, 11, '0', 'HotSpots-2', 'HotSpots-2', 1, 0, 0, '', '', 'Slubfurter Mental Map Survey 2000 - 2002: Nearest Neighbor Hierarchical Clustering - Second Order; For each identified cluster a Standard Deviational Ellipse is calculated. Typically, one standard deviation will cover more than 50% of the cases, one and a half standard deviations will cover more than 90% of the cases, and two standard deviations will cover more than 99% of the cases, although the exact percentage will depend on the distribution (Levine, 2002).');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14115, 767, 12, '0', 'SDE-W', 'SDE-W', 1, 0, 0, '', '', 'Slubfurter Mental Map Survey 2000 - 2002; Standard Deviational Ellipse - Weighted: A standard deviational ellipse is centered around the mean center of the data set. The ellipse is an indicator of spatial concentration and dispertion with a directional bias. The deviation along the major axis will be the direction of maximum spread of the points and the minor axis will be the direction of minimum spread of the points.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10172, 640, 10, '0', 'daily_aqua', 'Daily composite of MODIS-AQUA images', 0, 250550, 0, '', '', ' 	Daily generated mosaic of the AQUA images released by the MODIS Rapid Response System. 	Updates every day, at about 1200Z, with images taken during the previous day. 	Maximum resolution is 8 arcseconds per pixel. The WMS "time" dimension can be used to retrieve past data.       ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19240, 640, 11, '0', 'BMNG', 'Blue Marble Next Generation, Global MODIS derived image', 0, 501099, 0, '', '', '         A set of twelve images built from MODIS data, one for each month of 2004. The native resolution is 15 arcseconds. This is the version with land and ocean bottom hillshading.       ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10173, 640, 12, '0', 'modis', 'Blue Marble, Global MODIS derived image', 0, 1002199, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10174, 640, 13, '0', 'huemapped_srtm', 'SRTM derived global elevation, 3 arc-second, hue mapped', 0, 90198, 0, '', '', ' An SRTM derived elevation dataset, where elevation is mapped to hue, resulting a color image');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10175, 640, 14, '0', 'srtmplus', 'Global 1km elevation, seamless SRTM land elevation and ocean depth', 0, 1002199, 0, '', '', ' 	The SRTM30 Plus dataset, a 30 arc-second seamless combination of GTOPO30, SRTM derived land elevation and UCSD Sandwell bathymetry data.  The default style is scaled to 8 bit, non-linear.  It is possible to request the elevation data in meters by the short_int tyle and requesting PNG format.  The resulting PNG file will be a unsigned 16 bit per pixel image. The values are then the elevation in meters.  Values are signed 16 bit integers, but PNG will present them as unsigned, any values larger than 32767 should be interpreted as negative numbers.  For elevation values in feet, request PNG format with the style feet_short_int.       ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10176, 640, 15, '0', 'worldwind_dem', 'SRTM derived global elevation, 3 arc-second', 0, 90198, 0, '', '', ' 	A global elevation model, prepared from the 3 arc-second SRTM dataset by filling some of the problem areas. Prepared by the NASA Learning Technologies. 	The default style is scaled to 8 bit, non-linear. 	It is possible to request the elevation data in meters by the short_int tyle and requesting PNG format. The resulting PNG file will be a unsigned 16 bit per pixel image. The values are then the elevation in meters. 	Values are signed 16 bit integers, but PNG will present them as unsigned, leading to a few areas with very large values (65000+) 	For elevation values in feet, request PNG format with the style feet_short_int.       ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19255, 828, 7, '0', 'Puntos_geodésicos', 'Puntos_geodésicos', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19176, 250, 0, '', 'Demis World Map', 'Demis World Map', 0, 0, 0, '', '', 'None');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2713, 250, 1, '0', 'Bathymetry', 'Bathymetry', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2714, 250, 2, '0', 'Countries', 'Countries', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2715, 250, 3, '0', 'Topography', 'Topography', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2716, 250, 4, '0', 'Hillshading', 'Hillshading', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2717, 250, 5, '0', 'Builtup areas', 'Builtup areas', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2718, 250, 6, '0', 'Coastlines', 'Coastlines', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2719, 250, 7, '0', 'Waterbodies', 'Waterbodies', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2720, 250, 8, '0', 'Inundated', 'Inundated', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2721, 250, 9, '0', 'Rivers', 'Rivers', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2722, 250, 10, '0', 'Streams', 'Streams', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2723, 250, 11, '0', 'Railroads', 'Railroads', 1, 0, 1683694, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2724, 250, 12, '0', 'Highways', 'Highways', 1, 0, 1403078, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2725, 250, 13, '0', 'Roads', 'Roads', 1, 0, 841847, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2726, 250, 14, '0', 'Trails', 'Trails', 1, 0, 561231, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2727, 250, 15, '0', 'Borders', 'Borders', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2728, 250, 16, '0', 'Cities', 'Cities', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2729, 250, 17, '0', 'Settlements', 'Settlements', 1, 0, 1122463, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2730, 250, 18, '0', 'Spot elevations', 'Spot elevations', 0, 0, 561231, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2731, 250, 19, '0', 'Airports', 'Airports', 1, 0, 1122463, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2732, 250, 20, '0', 'Ocean features', 'Ocean features', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7520, 584, 3, '0', 'CBC_PY', 'Canadian Christmas Bird Count Locations', 1, 0, 0, '', '', 'A winter survey of bird populations conducted during the Christmas period - December 14 to January 5th inclusive.  More than 1800 counts are conducted each year across Canada, the United States and Latin America.  On a selected day within the count period, local birders count as many birds as possible within a 24 km (15 mile) diameter circle.  The Christmas Bird Count had long been organized on the continental scale by the New York-based National Audubon Society. In 2000, Audubon finalized an agreement with Bird Studies Canada that would see BSC partner with Audubon to coordinate CBCs in Canada.  This layer represents the 24 km circles surveyed as part of each Christmas Bird Count conducted in Canada.  An accompanying layer (CBC_PT) contains the centre point of the circles.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7521, 584, 4, '0', 'MMP', 'Marsh Monitoring Program Route Locations', 1, 0, 0, '', '', 'A Spring survey of birds and amphibians carried out primarily within the Great Lakes region of North America.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7522, 584, 5, '0', 'CLLS', 'Canadian Lakes Loon Survey Locations', 1, 0, 0, '', '', 'A volunteer-based program that monitors the effects of acid rain and other human disturbance on loon breeding and presence on Canada''s cottage lakes and other waterbodies.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19244, 789, 21, '18', 'tk10v', 'TK 10 - Vegetation', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK10VEG');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (5575, 486, 0, '', 'PLZ_441', 'PLZ_441', 0, 1, 0, '', '', 'PLZ (post code areas Germany) served with UMN MapServer 4.4.1');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (5576, 486, 1, '0', 'Nationalborder', 'National Border', 0, 750000, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (5577, 486, 2, '0', 'Postcodeareas', 'Post Code Areas', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (5578, 486, 3, '0', 'Postcodelabels', 'Post Code Labels', 0, 0, 350000, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9891, 615, 1, '0', 'Population', 'Population', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9892, 615, 2, '0', 'Landuse', 'Landuse', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9893, 615, 3, '0', 'Countries', 'Countries', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9894, 615, 4, '0', 'Landsat images', 'Landsat images', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9895, 615, 5, '0', 'Watersheds', 'Watersheds', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9896, 615, 6, '0', 'Rivers', 'Rivers', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9897, 615, 7, '0', 'Ramsar sites (Polygons)', 'Ramsar sites (Polygons)', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9898, 615, 8, '0', 'Ramsar sites', 'Ramsar sites', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19210, 787, 0, '', 'OGC-Dienst der Bayerischen Vermessungsverwaltung', 'OGC-Dienst der Bayerischen Vermessungsverwaltung', 0, 0, 0, '', '', 'Saemtliche Rechte an den ueber diesen Dienst verfuegbaren Geobasisdaten liegen beim Landesamt fuer Vermessung und Geoinformation (LVG Bayern). Fuer ihre Nutzung durch Vervielfaeltigung, Verbreitung und Veroeffentlichung beachten Sie bitte die Nutzungsbedingungen unter http://www.geodaten.bayern.de/ogc/Nutzungsbedingungen.htm. Kostenfrei gestattet ist die Vervielfaeltigung zum privaten Gebrauch sowie die Veroeffentlichung von Geobasisdaten auf der eigenen Website im Umfang eines Bildes von maximal 1024 x 768 Pixel. Die Quellenangabe ist in der Form "(c) LVG Bayern" anzubringen und als Link auf http://www.lvg.bayern.de auszufuehren. Fuer jede andere Nutzung ist eine Nutzungsvereinbarung mit dem LVG Bayern erforderlich.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10166, 640, 1, '0', 'global_mosaic', 'WMS Global Mosaic, pan sharpened', 0, 20044, 0, '', 'http://onearth.jpl.nasa.gov/WAF/WMS_GM.xml', ' 	Release 2 of the WMS Global Mosaic, a seamless mosaic of Landsat7 scenes. 	Spatial resolution is 0.5 second for the pan band, 1 second for the visual and near-IR bands and 2 second for the thermal bands 	Use this layer to request individual grayscale bands. The default styles may have gamma, sharpening and saturation filters applied. 	The grayscale styles have no extra processing applied, and will return the image data as stored on the server. 	The source dataset is part of the NASA Scientific Data Purchase, and contains scenes acquired in 1999-2003.         This layer provides pan-sharpened images, where the pan band is used for the image brightness regardless of the color combination requested.       ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19245, 789, 22, '18', 'tk10g', 'TK 10 - Grundriss', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK10GRU');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9877, 614, 0, '', '', 'ArcIMS Map Server', 0, 0, 0, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9878, 614, 1, '0', '250K Topo Map', '250K Topo Map', 0, 0, 0, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9879, 614, 2, '0', '100K Topo Map', '100K Topo Map', 0, 0, 0, '', NULL, NULL);
@@ -3136,105 +3069,18 @@
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9887, 614, 10, '0', 'State', 'State', 0, 0, 0, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9888, 614, 11, '0', 'City', 'City', 0, 0, 0, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9889, 614, 12, '0', 'Geographic Name', 'Geographic Name', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9890, 615, 0, '', '', 'ArcIMS Map Server', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9891, 615, 1, '0', 'Population', 'Population', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9892, 615, 2, '0', 'Landuse', 'Landuse', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9893, 615, 3, '0', 'Countries', 'Countries', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9894, 615, 4, '0', 'Landsat images', 'Landsat images', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9895, 615, 5, '0', 'Watersheds', 'Watersheds', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9896, 615, 6, '0', 'Rivers', 'Rivers', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9897, 615, 7, '0', 'Ramsar sites (Polygons)', 'Ramsar sites (Polygons)', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9898, 615, 8, '0', 'Ramsar sites', 'Ramsar sites', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9899, 615, 9, '0', 'Ramsar sites (Points)', 'Ramsar sites (Points)', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9900, 615, 10, '0', 'Cities', 'Cities', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9901, 616, 0, '', '', 'GeoNovaSDE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9902, 616, 1, '0', '10k_Drainage_polygons', '10k_Drainage Polygons', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9903, 616, 2, '0', 'ST_POINT', 'ST_POINT', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9904, 616, 3, '0', 'WA_POINT', 'WA_POINT', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9905, 616, 4, '0', 'ST_LINE', 'ST_LINE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9906, 616, 5, '0', 'LF_POINT', 'LF_POINT', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9907, 616, 6, '0', 'UT_LINE', 'UT_LINE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9908, 616, 7, '0', 'LF_LINE', 'LF_LINE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9909, 616, 8, '0', 'RR_POINT', 'RR_POINT', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9910, 616, 9, '0', 'RR_LINE', 'RR_LINE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9911, 616, 10, '0', 'DA_POINT', 'DA_POINT', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9912, 616, 11, '0', 'DL_LINE', 'DL_LINE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9913, 616, 12, '0', 'DA_POLY', 'DA_POLY', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9914, 616, 13, '0', 'DA_LINE', 'DA_LINE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9915, 616, 14, '0', 'LC_POINT', 'LC_POINT', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9916, 616, 15, '0', 'LC_LINE', 'LC_LINE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9917, 616, 16, '0', 'UT_POINT', 'UT_POINT', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9918, 616, 17, '0', 'WA_LINE', 'WA_LINE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9919, 616, 18, '0', 'COAST', 'COAST', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9920, 616, 19, '0', 'ROADS', 'ROADS', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9921, 617, 0, '', '', 'Geobase_NRN_NewfoundlandAndLabrador_I_Detail', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9922, 617, 1, '0', 'NewfoundlandLabrador', 'Provincial Boundary', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9923, 617, 2, '0', 'Water', 'Water', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9924, 617, 3, '0', 'Highways', 'Highways', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9925, 617, 4, '0', 'highwaysMjrRoads', 'Highways and Major Roads', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9926, 617, 5, '0', 'allroads', 'All Roads', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9927, 617, 6, '0', 'FerrySeg', 'FERRYSEG', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9928, 617, 7, '0', 'Junction', 'JUNCTION', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9929, 617, 8, '0', 'BlkPassage', 'BLKPASSAGE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10028, 624, 0, '', '', 'gewstat', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10029, 624, 1, '0', 'Uebrige Gewaesser groesser 12 m Breite 3', 'Uebrige Gewaesser groesser 12 m Breite', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10030, 624, 2, '0', 'Uebrige Gewaesser kleiner 12 m Breite 2', 'Uebrige Gewaesser kleiner 12 m Breite', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10031, 624, 3, '0', 'Kanaele groesser 12 m Breite 2', 'Kanaele groesser 12 m Breite', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10032, 624, 4, '0', 'Kanaele kleiner 12m Breite', 'Kanaele kleiner 12 m Breite', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10033, 624, 5, '0', 'Unterirdisch verlaufende Gewaesser', 'Unterirdisch verlaufende Gewaesser', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10034, 624, 6, '0', 'Fliessgewaesser groesser 12 m Breite', 'Fliessgewaesser groesser 12 m Breite', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10035, 624, 7, '0', 'Fliessgewaesser kleiner 12 m Breite', 'Fliessgewaesser kleiner 12 m Breite', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10036, 624, 8, '0', 'St_Kanaele 1000 m', 'St_Kanaele 1000 m', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10037, 624, 9, '0', 'St_Rhein und Weser 1000 m', 'St_Rhein und Weser 1000 m', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10038, 624, 10, '0', 'St_Fliessgewaesser 1000 m', 'St_Fliessgewaesser 1000 m', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10039, 624, 11, '0', 'St_Kanaele 500 m', 'St_Kanaele 500 m', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10040, 624, 12, '0', 'St_Rhein und Weser 500 m', 'St_Rhein und Weser 500 m', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10041, 624, 13, '0', 'St_Fliessgewaesser 500 m', 'St_Fliessgewaesser 500 m', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10042, 624, 14, '0', 'St_Kanaele 100 m', 'St_Kanaele 100 m', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10043, 624, 15, '0', 'St_Rhein und Weser 100 m', 'St_Rhein und Weser 100 m', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10044, 624, 16, '0', 'St_Fliessgewaesser 100 m', 'St_Fliessgewaesser 100 m', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10045, 624, 17, '0', 'Stationierungslinie', 'Stationierungslinie', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10046, 624, 18, '0', 'Fluesse', 'Fluesse', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10047, 625, 0, '', 'DEMO', 'GMap WMS Demo Server', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10048, 625, 1, '0', 'bathymetry', 'Elevation/Bathymetry', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10049, 625, 2, '0', 'land_fn', 'Foreign Lands', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10050, 625, 3, '0', 'park', 'Parks', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10051, 625, 4, '0', 'drain_fn', 'Water', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10052, 625, 5, '0', 'drainage', 'Drainage', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10053, 625, 6, '0', 'prov_bound', 'Province', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10054, 625, 7, '0', 'fedlimit', 'Federal Limit', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10055, 625, 8, '0', 'rail', 'Railroads', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10056, 625, 9, '0', 'road', 'Roads', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10057, 625, 10, '0', 'popplace', 'Cities', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10058, 625, 11, '0', 'grid', 'Grid', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10106, 634, 0, '', 'Location', 'Point locations', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10107, 634, 1, '0', 'city_austral', 'Australasian Cities', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10108, 634, 2, '0', 'capital_aus', 'Australian Capital Cities', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10109, 634, 3, '0', 'town_aus', '          Some Australian towns', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10110, 634, 4, '0', 'wastewet', '          Wastewater artificial wetlands listed as', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10153, 637, 0, '', 'Bathymetry', 'MapServer WMS Demo', 0, 50000, 149999900, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10154, 637, 1, '0', 'etopo2', 'etopo2', 0, 50000, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10155, 637, 2, '0', 'ecbathy', 'ecbathy', 0, 50000, 10000000, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10156, 637, 3, '0', 'gom', 'gom', 0, 50000, 2000000, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10157, 637, 4, '0', 'bbay', 'bbay', 0, 50000, 1000000, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10158, 637, 5, '0', 'gomctr', 'gomctr', 0, 50000, 749999, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10159, 637, 6, '0', 'world_line_simp', 'world_line_simp', 0, 4999990, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10160, 637, 7, '0', 'world_line', 'world_line', 0, 0, 4999990, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10165, 640, 0, '', '', 'OnEarth Web Map Server', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10166, 640, 1, '0', 'global_mosaic', 'WMS Global Mosaic, pan sharpened', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10167, 640, 2, '0', 'global_mosaic_base', 'WMS Global Mosaic, not pan sharpened', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10168, 640, 3, '0', 'us_landsat_wgs84', 'CONUS mosaic of 1990 MRLC dataset', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10169, 640, 4, '0', 'us_overlays', 'Progressive US overlay map, white background', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10170, 640, 5, '0', 'us90_overlays', 'MRLC US mosaic with progressive overlay map', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10171, 640, 6, '0', 'daily_terra', 'Daily composite of MODIS-TERRA images', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10172, 640, 7, '0', 'daily_aqua', 'Daily composite of MODIS-AQUA images', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10173, 640, 8, '0', 'modis', 'Blue Marble, Global MODIS derived image', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10174, 640, 9, '0', 'huemapped_srtm', 'SRTM derived global elevation, 3 arc-second, hue m', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10175, 640, 10, '0', 'srtmplus', 'Global 1km elevation, seamless SRTM land elevation', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10176, 640, 11, '0', 'worldwind_dem', 'SRTM derived global elevation, 3 arc-second', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10177, 640, 12, '0', 'us_ned', 'United States elevation, 30m', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10178, 640, 13, '0', 'us_elevation', 'Digital Elevation Map of the United States, DTED d', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10179, 640, 14, '0', 'us_colordem', 'Digital Elevation Map of the United States, DTED d', 0, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7255, 525, 0, '', 'Middle_America', 'Middle America', 0, 0, 0, '', '', 'Middle_America');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7256, 525, 1, '0', 'North_and_South_American_States', 'America', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7257, 525, 2, '0', 'Middle_American_States_AREA', 'State Area', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7258, 525, 3, '0', 'Middle_America_DEM_surface', 'Elevation Model', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7259, 525, 4, '0', 'National_borders', 'Borders', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7260, 525, 5, '0', 'Lakes_and_temporary_inundated_areas', 'Lakes', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7261, 525, 6, '0', 'Temporary_and_permanent_rivers_and_streams', 'Rivers', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7262, 525, 7, '0', 'Larger_cities_polygon', 'Cities', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7263, 525, 8, '0', 'Roads', 'Roads', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7264, 525, 9, '0', 'Railway_systems', 'Rails', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7265, 525, 10, '0', 'Smaller_cities_and_villages_point', 'Places', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7266, 525, 11, '0', 'Archaeological_maya_sites', 'Maya Sites', 1, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10194, 645, 0, '', '', 'ArcIMS MapService', 0, 0, 0, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10195, 645, 1, '0', 'HDM:LANDMASS', 'Land Areas', 1, 0, 0, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10196, 645, 2, '0', 'HDM:DFIRM_BFE', 'DFIRM Base Flood Elevations', 1, 0, 0, '', NULL, NULL);
@@ -3242,282 +3088,69 @@
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10198, 645, 4, '0', 'HDM:DFIRM_FLD_AR', 'DFIRM Flood Hazard Areas', 1, 0, 0, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10199, 645, 5, '0', 'HDM:Q3_COUNTYMAP', 'Flood Data Availability', 1, 0, 0, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10200, 645, 6, '0', 'HDM:Q3_FLOOD', 'Q3 Flood Hazards', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10369, 648, 0, '', '', 'hangneigung', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10370, 648, 1, '0', 'hangneigung', 'Hangneigung', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10371, 648, 2, '0', 'Fliessgewaesser', 'Fliessgewaesser', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10415, 655, 0, '', 'SEACOOS Remotely-Sensed Imagery', 'SEACOOS Remotely-Sensed Imagery', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10416, 655, 1, '0', 'modis_ergb_low', 'MODIS Enhanced RGB, courtesy USF Institute for Mar', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10417, 655, 2, '0', 'modis_rgb_composite_low', 'MODIS Low Resolution RGB Composite, courtesy USF I', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10418, 655, 3, '0', 'modis_rgb_low', 'MODIS Low Resolution RGB, courtesy USF Institute f', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10419, 655, 4, '0', 'modis_rgb_hi_chesapeake_bay', 'MODIS High Resolution RGB, courtesy USF Institute', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10420, 655, 5, '0', 'modis_rgb_hi_florida_bay', 'MODIS High Resolution RGB, courtesy USF Institute', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10421, 655, 6, '0', 'modis_rgb_hi_miss_plume', 'MODIS High Resolution RGB, courtesy USF Institute', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10422, 655, 7, '0', 'modis_rgb_hi_suwannee_river', 'MODIS High Resolution RGB, courtesy USF Institute', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10423, 655, 8, '0', 'modis_rgb_hi_tampa_bay', 'MODIS High Resolution RGB, courtesy USF Institute', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10424, 655, 9, '0', 'oi_sst', 'Optimally Interpolated SST, courtesy USF Ocean Cir', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10425, 655, 10, '0', 'modis_sst', 'MODIS SST, courtesy USF Institute for Marine Remot', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10426, 655, 11, '0', 'avhrr_sst', 'AVHRR SST, courtesy USF Institute for Marine Remot', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10427, 655, 12, '0', 'modis_chl', 'MODIS Chl-A, courtesy USF Institute for Marine Rem', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10428, 655, 13, '0', 'jpl_sea_surface_height_composite', 'TBA', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10429, 655, 14, '0', 'tamu_level_III', 'Texas Mesonet Radar, courtesy Texas A and M Univer', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10430, 655, 15, '0', 'tamu_usrad', 'Texas Mesonet Radar, courtesy Texas A and M Univer', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10431, 655, 16, '0', 'surface_currents_radar', 'Surface currents (Radar) (EXPERIMENTAL), courtesy', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10432, 655, 17, '0', 'depth_averaged_currents', 'Depth-averaged currents (EXPERIMENTAL), courtesy U', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10433, 655, 18, '0', 'sea_surface_elevation', 'Sea surface elevation (EXPERIMENTAL), courtesy Uni', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10434, 655, 19, '0', 'opaque_legend_background', 'Opaque legend background', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10435, 655, 20, '0', 'modis_chl_legend_full_range', 'MODIS Chl-A Legend, courtesy USF Institute for Mar', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10436, 655, 21, '0', 'sst_legend_full_range', 'SST Legend, courtesy USF Institute for Marine Remo', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10437, 655, 22, '0', 'tamu_level_III_legend_full_range', 'Texas Mesonet Radar Legend, courtesy Texas A and M', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10438, 655, 23, '0', 'current_velocity_legend', 'Current velocity legend', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10439, 655, 24, '0', 'water_level_legend', 'Elevation legend', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10987, 670, 0, '', '', 'waldtyp', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10988, 670, 1, '0', 'Waldtyp', 'Waldtyp', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10989, 670, 2, '0', 'Waldtyp_50', 'Waldtyp_50', 0, 37494, 187472, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10990, 670, 3, '0', 'Waldtyp_Real', 'Waldtyp_Real', 0, 37494, 187472, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10991, 671, 0, '', '', 'wsg', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10992, 671, 1, '0', 'Trinkwasser Zone 1 punktfoermig', 'Trinkwasser Zone 1 punktfoermig', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10993, 671, 2, '0', 'Trinkwasserschutzgebiete', 'Trinkwasserschutzgebiete', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10994, 671, 3, '0', 'Heilquellen Zone 1 punktfoermig', 'Heilquellen Zone 1 punktfoermig', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10995, 671, 4, '0', 'Heilquellenschutzgebiete', 'Heilquellenschutzgebiete', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11541, 706, 0, '', '', 'WA_Atlas_GN_WMS', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11542, 706, 1, '0', 'Australia Base Map', 'Australia Base Map', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11543, 706, 2, '0', 'WA Base Map', 'WA Base Map', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11544, 706, 3, '0', 'WA Base Map - Detailed', 'WA Base Map - Detailed', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11545, 706, 4, '0', 'Bathymetry - Above Chart Datum', 'Bathymetry - Above Chart Datum', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11546, 706, 5, '0', 'State Geological Polygons', 'State Geological Polygons', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11547, 706, 6, '0', 'Beards Vegetation', 'Beards Vegetation', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11629, 717, 0, '', '', 'forstamtsgr', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11630, 717, 1, '0', '0', 'Forstamtsgrenzen', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13667, 739, 0, '', '', 'Eusoils_Ex', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13668, 739, 1, '0', '55', 'ERODI. Soil erodibility class', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13669, 739, 2, '0', '70', 'TXEROD. Textural factor of soil erodibility', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13670, 739, 3, '0', '48', 'CRUSTING. Soil crusting class', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13671, 739, 4, '0', '64', 'PHYSCHIM.Physi-chemical factor of soil', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13672, 739, 5, '0', '71', 'TXTCRUST. Textural factor of soil crusting', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13673, 739, 6, '0', '41', 'ATC. Accumulated temperature class', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13674, 739, 7, '0', '72', 'USE. Regrouped land use', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13675, 739, 8, '0', '39', 'AGLIM2NNI. 2nd Limitation to agricultural use', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13676, 739, 9, '0', '38', 'AGLIM1NNI. Dom.Limitation to agricultural use', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13677, 739, 10, '0', '53', 'EAWC_SUB. Subsoil easily avail.water capac.', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13678, 739, 11, '0', '54', 'EAWC_TOP. Topsoil easily avail.water capac.', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13679, 739, 12, '0', '42', 'AWC_SUB. Subsoil avail.water capacity', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13680, 739, 13, '0', '43', 'AWC_TOP. Topsoil avail.water capacity', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13681, 739, 14, '0', '56', 'HG. Hydro-geological class', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13682, 739, 15, '0', '51', 'DIMP. Depth to an impermeable layer', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13683, 739, 16, '0', '49', 'DGH. Depth to a gleyed horizon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13684, 739, 17, '0', '65', 'PMH. Parent material hydro-geological', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13685, 739, 18, '0', '61', 'PD_SUB. Subsoil Packing Density', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13686, 739, 19, '0', '62', 'PD_TOP. Topsoil packing density', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13687, 739, 20, '0', '66', 'STR_SUB. Subsoil structure', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13688, 739, 21, '0', '67', 'STR_TOP. Topsoil structure', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13689, 739, 22, '0', '68', 'TD. Rule inferred subsoil texture', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13690, 739, 23, '0', '73', 'VS. Volume of stones', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13691, 739, 24, '0', '52', 'DR. Depth to rock', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13692, 739, 25, '0', '44', 'BS_SUB. Base Subsoil Saturation', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13693, 739, 26, '0', '45', 'BS_TOP. Base Topsoil Saturation', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13694, 739, 27, '0', '46', 'CEC_SUB. Subsoil Cation Exch.Capacity', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13695, 739, 28, '0', '47', 'CEC_TOP. Topsoil Cation Exch.Capacity', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13696, 739, 29, '0', '58', 'MIN_SUB. Subsoil Mineralogy', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13697, 739, 30, '0', '59', 'MIN_TOP. Topsoil Mineralogy', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13698, 739, 31, '0', '57', 'MIN. Profile Mineralogy', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13699, 739, 32, '0', '50', 'DIFF. Soil Profile Differentiation', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13700, 739, 33, '0', '40', 'ALT. Elevation', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13701, 739, 34, '0', '63', 'PEAT', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13702, 739, 35, '0', '60', 'OC_TOP. Topsoil Organic Carbon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13703, 739, 36, '0', '69', 'TEXT. Dominant Surface Textural', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13704, 739, 37, '0', '21', 'SLOPESE. Secondary Slope class', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13705, 739, 38, '0', '20', 'SLOPEDO. Dominant Slope Class', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13706, 739, 39, '0', '37', 'ZMIN. Minimun elevetaion above sea', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13707, 739, 40, '0', '36', 'ZMAX. Maximun elevetaion above sea', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13708, 739, 41, '0', '30', 'WM2. Type of Water Manag.System', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13709, 739, 42, '0', '29', 'WM1. Presence of Water Manag.System', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13710, 739, 43, '0', '31', 'WR. Annual average soil water regime', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13711, 739, 44, '0', '10', 'IL. Impermeable Layer', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13712, 739, 45, '0', '19', 'ROO. Depth Class of obstacle to roots', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13713, 739, 46, '0', '2', 'AGLIM2. Sec.limitation to agr.use', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13714, 739, 47, '0', '1', 'AGLIM1. Dom.limitation to agr.use', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13715, 739, 48, '0', '28', 'USESE. Secondary Land Use', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13716, 739, 49, '0', '27', 'USEDO. Dominant Land Use', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13717, 739, 50, '0', '6', 'FAO85LV3. 3rd Level Soil Code 1974 FAO', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13718, 739, 51, '0', '5', 'FAO85LV2. 2nd Level Soil Code 1974 FAO', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13719, 739, 52, '0', '4', 'FAO85LV1. Soil Major Group 1974 FAO', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13720, 739, 53, '0', '3', 'FAO85FU. Full Soil Code 1974 FAO', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13721, 739, 54, '0', '9', 'FAO90LV2. 2nd level Soil Code 1990 FAO', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13722, 739, 55, '0', '8', 'FAO90LV1. Soil Major Group 1990 FAO', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13723, 739, 56, '0', '7', 'FAO90FU. Full Soil Code 1990 FAO', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13724, 739, 57, '0', '18', 'PARMASE3. 3rd level Sec.Par.Material', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13725, 739, 58, '0', '17', 'PARMASE2. 2nd level Sec.Par.Material', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13726, 739, 59, '0', '16', 'PARMASE1. Major Group Sec.Par.Material', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13727, 739, 60, '0', '15', 'PARMASE. Secondary Parent Material', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13728, 739, 61, '0', '14', 'PARMADO3. 3rd level Dom.Par.Material', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13729, 739, 62, '0', '13', 'PARMADO2. 2nd level Dom.Par.Material', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13730, 739, 63, '0', '12', 'PARMADO1. Major Group Dom.Par.Material', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13731, 739, 64, '0', '11', 'PARMADO. Dominant Parent Material', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13732, 739, 65, '0', '26', 'TXSUBSE. Sec.Sub-surface text.class', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13733, 739, 66, '0', '25', 'TXSUBDO. Dom.Sub-surface text.class', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13734, 739, 67, '0', '22', 'TXDEPCHG. Depth class to a text.change', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13735, 739, 68, '0', '24', 'TXSRFSE. Sec.surface text.class', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13736, 739, 69, '0', '23', 'TXSRFDO. Dom.surface text.class', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13737, 739, 70, '0', '33', 'WRBADJ2. 2nd Soil Adjective Code', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13738, 739, 71, '0', '32', 'WRBADJ1. First Soil Adjective Code', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13739, 739, 72, '0', '35', 'WRBLV1. Soil reference group', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13740, 739, 73, '0', '34', 'WRBFU. Full soil Code', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13741, 739, 74, '0', '97', 'Eurasia Lakes-Inland Waters', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13742, 739, 75, '0', '98', 'European Cities', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13743, 739, 76, '0', '0', 'Country Boundaries', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13744, 739, 77, '0', '99', 'Soil Polygon Outlines', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13751, 86, 0, '', 'World_map', 'World Map', 0, 1, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13752, 86, 1, '0', 'Countries', 'Countries', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13753, 86, 2, '0', 'Countrynames', 'Countrynames', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13754, 86, 3, '0', 'Citypoints', 'Citypoints', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13755, 86, 4, '0', 'City', 'Citynames', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13775, 101, 0, '', 'UMN_Mapserver', 'UMN Mapserver', 0, 1, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13776, 101, 1, '0', 'UMN_USER', 'UMN User', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13777, 101, 2, '0', 'UMN_USER_NAMES', 'UMN Info', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19110, 902, 0, '', 'Brandenburg', 'DNM 100/2', 0, 25001, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19111, 902, 1, '0', 'kreis', 'Landkreise und kreisfreie Städte', 1, 25001, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19090, 900, 0, '', 'benin2', 'Pendjari National Parc', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19091, 900, 1, '0', 'zoneseri', 'Zone Seri', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19092, 900, 2, '0', 'zoneest', 'Zone Est', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19093, 900, 3, '0', 'zonepnp', 'Zone Pnp', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19094, 900, 4, '0', 'zonezck', 'Zone Zck', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19095, 900, 5, '0', 'zonezcp', 'Zone Zcp', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19096, 900, 6, '0', 'ldcpendjari', 'Limite du Complexe pendjari', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19097, 900, 7, '0', 'maresextension', 'Mares Extension', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19098, 900, 8, '0', 'piste1', 'Piste 1', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19099, 900, 9, '0', 'pistepodiega', 'Piste podiéga', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19100, 900, 10, '0', 'agglom', 'Agglomeration Areas', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7267, 525, 12, '0', 'Archaeological_maya_records', 'Maya Records', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10047, 625, 0, '', 'DEMO', 'DM Solutions'' WMS Demo Server', 0, 0, 0, '', '', 'This demonstration server was setup by DM Solutions Group (http://www.dmsolutions.ca/) and is powered by MapServer (http://mapserver.gis.umn.edu/).  This server uses Canadian source data (c)2000, Government of Canada with permission from Natural Resources Canada from NRCan''s GeoGratis web site (http://geogratis.cgdi.gc.ca/).');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10048, 625, 1, '0', 'bathymetry', 'Elevation/Bathymetry', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10994, 671, 3, '0', 'Heilquellen Zone 1 punktfoermig', 'Heilquellen Zone 1 punktfoermig', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10049, 625, 2, '0', 'land_fn', 'US Land', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10995, 671, 4, '0', 'Heilquellenschutzgebiete', 'Heilquellenschutzgebiete', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11630, 717, 1, '0', '0', 'Forstamtsgrenzen', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10050, 625, 3, '0', 'park', 'Parks', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10051, 625, 4, '0', 'drain_fn', 'US Lakes', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10052, 625, 5, '0', 'drainage', 'Lakes', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10053, 625, 6, '0', 'prov_bound', 'Provincial Borders', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10054, 625, 7, '0', 'fedlimit', 'Federal Limit', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10055, 625, 8, '0', 'rail', 'Railroads', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10056, 625, 9, '0', 'road', 'Roads', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10057, 625, 10, '0', 'popplace', 'Cities', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10058, 625, 11, '0', 'grid', 'Grid', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10167, 640, 2, '0', 'global_mosaic_base', 'WMS Global Mosaic, not pan sharpened', 0, 20044, 0, '', '', ' 	Release 2 of the WMS Global Mosaic, a seamless mosaic of Landsat7 scenes. 	Spatial resolution is 0.5 second for the pan band, 1 second for the visual and near-IR bands and 2 second for the thermal bands 	Use this layer to request individual grayscale bands. The default styles may have gamma, sharpening and saturation filters applied. 	The source dataset is part of the NASA Scientific Data Purchase, and contains scenes acquired in 1999-2003. 	Release 2.       ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10168, 640, 3, '0', 'us_landsat_wgs84', 'CONUS mosaic of 1990 MRLC dataset', 0, 40088, 0, '', '', ' 	CONUS seamless mosaic of Landsat5 scenes. Maximum resolution is 1 arc-second. 	The default styles may have gamma, sharpening and saturation filters applied. 	The source dataset is part of the MRLC 1990 dataset. 	This layer is not precisely geo-referenced!       ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13775, 101, 0, '', 'UMN_Mapserver', 'UMN Mapserver', 0, 1, 0, '', '', 'UMN User Overview (UMN MapServer/Postgis)');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13776, 101, 1, '0', 'UMN_USER', 'UMN MapServer User', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13777, 101, 2, '0', 'UMN_USER_NAMES', 'UMN Info', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13751, 86, 0, '', 'World_map', 'World Map', 0, 1, 0, '', '', 'World Map in WGS84 Reference System');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13752, 86, 1, '0', 'Countries', 'Countries', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13753, 86, 2, '0', 'Countrynames', 'Countrynames', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13754, 86, 3, '0', 'Citypoints', 'Citypoints', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (13755, 86, 4, '0', 'City', 'Citynames', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19177, 613, 0, '', 'ArcIMS MapService', 'ArcIMS MapService', 0, 0, 0, '', '', 'OGC - Web Map Server.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14104, 767, 0, '', 'SLUBFURT', 'Słubfurt', 0, 125, 62500, '', '', 'Słubfurter Mental Map Survey 2000 - 2002.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19212, 800, 0, '', 'LMIC WMS server (aerial photography)', 'LMIC WMS server (aerial photography)', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14105, 767, 2, '0', 'Mentalscape', 'Mentalscape', 0, 0, 0, '', '', 'Słubfurter Mental Map Survey 2000 - 2002: mentalscape');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14365, 800, 1, '0', 'fsa', '2003 color FSA', 0, 802, 0, '', 'http://www.lmic.state.mn.us/chouse/metadata/naip03.html', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14106, 767, 3, '0', 'Districts', 'Districts', 1, 0, 0, '', '', 'Slubfurter Mental Map Survey 2000 - 2002: Districts are the medium to large sections of the city, conceived of as having two dimensional extent, which the observer enters  - inside of -, and which are recognizable as having some common identifying cha  racter (eg. city center, central business district, shopping zone, neighborhoods, villages, large city parks or wooded areas ...).(Lynch 1960: The Image of the City)');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14083, 764, 1, '0', 'flur', 'Flur', 1, 50000, 0, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14084, 764, 2, '0', 'gema', 'Gemarkung', 1, 50000, 0, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14085, 764, 3, '0', 'geme', 'Gemeinde', 1, 50000, 0, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14087, 764, 5, '0', 'kreis', 'Landkreise', 1, 50000, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19101, 900, 11, '0', 'coursdeauperm', 'Cours deau permanent', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19102, 900, 12, '0', 'cCoursdeau2003', 'Cours d eau 2003', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19103, 900, 13, '0', 'coursdeautemp', 'Cours d eau temporaire', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19104, 900, 14, '0', 'escarpement', 'Escarpements', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19105, 900, 15, '0', 'mar', 'Mares', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19112, 902, 2, '0', 'wald', 'Wald', 0, 25001, 150000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19113, 902, 3, '0', 'ozen', 'Oberzentren', 0, 25001, 2000000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19114, 902, 4, '0', 'mzen', 'Mittelzentren', 0, 25001, 600000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19115, 902, 5, '0', 'uzen', 'Unterzentren', 0, 25001, 200000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19116, 902, 6, '0', 'lwas', 'Flüsse und Kanäle', 0, 25001, 150000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14104, 767, 0, '', 'SLUBFURT', 'SLUBFURT', 0, 500, 250001, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14105, 767, 1, '0', 'Mentalscape', 'Mentalscape', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14106, 767, 2, '0', 'Districts', 'Districts', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14107, 767, 3, '0', 'Odra', 'Odra', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14108, 767, 4, '0', 'Paths', 'Paths', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14109, 767, 5, '0', 'Edges', 'Edges', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14110, 767, 6, '0', 'Nodes', 'Nodes', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14111, 767, 7, '0', 'Landmarks', 'Landmarks', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14112, 767, 8, '0', 'CityWall', 'CityWall', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14113, 767, 9, '0', 'HotSpots', 'HotSpots', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14114, 767, 10, '0', 'HotSpots-2', 'HotSpots-2', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14115, 767, 11, '0', 'SDE-W', 'SDE-W', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19117, 902, 7, '0', 'fwas', 'Seen', 0, 25001, 250001, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19118, 902, 8, '0', 'ebahn', 'Eisenbahnen', 0, 25001, 250001, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19119, 902, 9, '0', 'kstr', 'Kreisstraßen', 0, 25001, 100000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19120, 902, 10, '0', 'lstr', 'Landesstraßen', 0, 25001, 250001, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19121, 902, 11, '0', 'bstr', 'Bundesstraßen', 0, 25001, 749999, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19122, 902, 12, '0', 'astr', 'Autobahnen', 0, 25001, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19123, 902, 13, '0', 'nfwas', 'Namen der Seen', 0, 25001, 100000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19124, 902, 14, '0', 'kfz', 'Kfz-Zeichen', 0, 2000000, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19130, 903, 5, '0', 'lwas', 'Flüsse und Kanäle', 0, 1000, 50000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14177, 777, 0, '', 'Africa', 'Lieu / Locations', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14178, 777, 1, '0', 'adminareas', 'Pays / Countries', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14179, 777, 2, '0', 'provinceboundaries', 'D&#233;part./ Provinces', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14180, 777, 3, '0', 'populateplace', 'Villes / Towns', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19131, 903, 6, '0', 'fwas', 'Seen, Teiche', 0, 1000, 50000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19132, 903, 7, '0', 'kgrnz', 'Kreisgrenze', 0, 1000, 50000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19133, 903, 8, '0', 'flug', 'Internationale Flughäfen', 0, 1000, 29999, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19134, 903, 9, '0', 'ebahn', 'Eisenbahnverbindungen', 0, 1000, 50000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19135, 903, 10, '0', 'str', 'Straßen', 0, 1000, 50000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19136, 903, 11, '0', 'haus', 'Gebäude', 0, 1000, 50000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19137, 903, 12, '0', 'nfwas', 'Namen der Seen, Teiche', 0, 1000, 50000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19138, 904, 0, '', 'Brandenburg', 'DNM 250/2', 0, 25001, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19139, 904, 1, '0', 'kreis', 'Landkreise und kreisfreie Städte', 1, 200000, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19140, 904, 2, '0', 'orte', 'Zentren', 0, 200000, 1000000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19141, 904, 3, '0', 'korte', 'Orte', 0, 200000, 749999, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19142, 904, 4, '0', 'lwas', 'Flüsse und Kanäle', 0, 200000, 749999, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19143, 904, 5, '0', 'fwas', 'Seen', 0, 200000, 749999, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19144, 904, 6, '0', 'ebahn', 'Eisenbahnen', 0, 200000, 749999, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19145, 904, 7, '0', 'lstr', 'Landesstraßen', 0, 200000, 400000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14197, 779, 0, '', 'Ruanda24', 'Ruanda', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14198, 779, 1, '0', 'Countries', 'Countries', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14199, 779, 2, '1', 'Countries', 'Country Names', 0, 1000000, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14200, 779, 3, '0', 'Country', 'Country Names', 0, 1000000, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14201, 779, 4, '0', 'Cities', 'Cities', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14202, 779, 5, '4', 'Cities', 'Cities', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14203, 779, 6, '0', 'City', 'City Names', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14204, 779, 7, '0', 'Landsat', 'Sat-Image', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14205, 779, 8, '0', 'Dry Savannah', 'Dry Savannah', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14206, 779, 9, '8', 'Dry Savannah', 'Ruanda2', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14207, 779, 10, '0', 'Swamps', 'Swamps', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14208, 779, 11, '10', 'Swamps', 'Ruanda2', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14209, 779, 12, '0', 'Lakes', 'Lakes', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14210, 779, 13, '12', 'Lakes', 'Lakes', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14211, 779, 14, '0', 'Lake Names', 'Lake Names', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14212, 779, 15, '0', 'Dry Swamp', 'Dry Swamp', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14213, 779, 16, '15', 'Dry Swamp', 'Ruanda2', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14214, 779, 17, '0', 'Forests', 'Forests', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14215, 779, 18, '17', 'Forests', 'Ruanda2', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14216, 779, 19, '0', 'Islands', 'Islands', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14217, 779, 20, '19', 'Islands', 'Ruanda2', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14218, 779, 21, '0', 'Valleys', 'Valleys', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14219, 779, 22, '21', 'Valleys', 'Ruanda2', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14220, 779, 23, '0', 'Vegetation.shp', 'Vegetation', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14221, 779, 24, '0', 'Akagera-river', 'Akagera-river', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14222, 779, 25, '24', 'Akagera-river', 'Ruanda2', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14223, 779, 26, '0', 'Parc Limit', 'Parc Limit', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14224, 779, 27, '26', 'Parc Limit', 'Parc Limit', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14225, 779, 28, '0', 'Lanes', 'Lanes', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14226, 779, 29, '28', 'Lanes', 'Ruanda2', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14227, 779, 30, '0', 'Infrastructure', 'Infrastructure', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14228, 779, 31, '0', 'Places', 'Places', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14251, 785, 0, '', '', 'dtk200_500_1000_a10_gk3_wms', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14252, 785, 1, '0', 'DTK200-V', 'Digitale Topographische Karte 1:200.000', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14253, 785, 2, '0', 'DTK500-V', 'Digitale Topographische Karte 1:500.000', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14254, 785, 3, '0', 'DTK1000', 'Digitale Topographische Karte 1:1.000.000', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14255, 786, 0, '', 'MS', 'Luftbild', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14256, 786, 1, '0', 'ortho', 'Luftbild', 0, 1, 125000, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14257, 787, 0, '', '', 'OGC-Dienst der Bayerischen Vermessungsverwaltung', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14258, 787, 1, '0', 'DOP', 'DOP', 0, 20, 400880, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14259, 787, 2, '0', 'TK50', 'TK50', 0, 20, 80176, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14260, 787, 3, '0', 'UK500', 'UK500', 0, 20, 801759, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19178, 615, 0, '', 'ArcIMS Map Server', 'ArcIMS Map Server', 0, 0, 0, '', '', 'WMT Map Server maintained by ESRI Inc.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9899, 615, 9, '0', 'Ramsar sites (Points)', 'Ramsar sites (Points)', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (9900, 615, 10, '0', 'Cities', 'Cities', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14258, 787, 1, '0', 'DOP', 'DOP', 0, 20, 400880, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14252, 785, 1, '0', 'DTK200-V', 'Digitale Topographische Karte 1:200.000', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14259, 787, 2, '0', 'TK50', 'TK50', 0, 20, 80176, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14253, 785, 2, '0', 'DTK500-V', 'Digitale Topographische Karte 1:500.000', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14260, 787, 3, '0', 'UK500', 'UK500', 0, 20, 801759, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14254, 785, 3, '0', 'DTK1000', 'Digitale Topographische Karte 1:1.000.000', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19213, 767, 1, '0', 'slubfurtmap', 'Słubfurt City Map', 0, 0, 0, '', '', 'Słubfurter City Map');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14255, 786, 0, '', 'MS', 'Luftbilder', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14256, 786, 2, '1', 'ortho', 'Sachsen 1999-2004', 0, 1, 20000, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14107, 767, 4, '0', 'Odra', 'Odra', 1, 0, 0, '', '', 'Odralandia - Odra');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14108, 767, 5, '0', 'Paths', 'Paths', 1, 0, 0, '', '', 'Slubfurter Mental Map Survey 2000 - 2002: Paths are the channels along which the observer customarily, occasionally, or potentially moves (e.g. walkways, streets, roads, alleys, rivers, railway lines). (Lynch 1960: The Image of the City)');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14265, 789, 1, '0', 'UEB', 'Uebersicht', 0, 117283, 0, '', '', 'FREETK:MS:FREETK:RASTER UEB');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14261, 788, 0, '', 'DOP', 'Digitale Orthophotos mit einer reduzierten Bodenau', 0, 10000, 0, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14262, 788, 1, '0', 'dop25', 'DOP 25m', 0, 50000, 2000000, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14263, 788, 2, '0', 'dop5', 'DOP 5m', 0, 10000, 50000, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14264, 789, 0, '', '', 'Rasterdaten_tk100_tk50', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14265, 789, 1, '0', 'UEB', 'Uebersicht Sachsen', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14266, 789, 2, '0', 'tk100', 'Topog. Karte 1:100000', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14267, 789, 3, '2', 'tk100s', 'tk100-Schriften', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14268, 789, 4, '2', 'tk100w', 'tk100-Gewaesser', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14269, 789, 5, '2', 'tk100g', 'tk100-Grundriss', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14270, 789, 6, '2', 'tk100i', 'tk100-Hoehenlinien', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14271, 789, 7, '2', 'tk100v', 'tk100-Vegetation', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14272, 789, 8, '0', 'tk50', 'Topog. Karte 1:50000', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14273, 789, 9, '8', 'tk50w', 'tk50-Gewaesser', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14274, 789, 10, '8', 'tk50g', 'tk50-Grundriss', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14275, 789, 11, '8', 'tk50i', 'tk50-Hoehenlinien', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14276, 789, 12, '8', 'tk50v', 'tk50-Vegetation', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14277, 790, 0, '', '', 'LGN - WMS', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14278, 790, 1, '0', 'DUEKN5000', 'Uebersichtskarte 1:5000000', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14279, 790, 2, '0', 'DUEKN1000', 'Uebersichtskarte 1:1000000', 0, 0, 847059, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14280, 790, 3, '0', 'DUEKN500', 'Uebersichtskarte 1:500000', 0, 0, 795580, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14281, 790, 4, '0', 'TK100', 'Topographische Karte 1:100000', 0, 0, 423530, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14287, 792, 0, '', '', 'TKVV', 0, 200, 200440, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14288, 792, 1, '0', 'Thueringer_Orthofotos', 'Thueringer_Orthofotos', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14289, 792, 2, '1', 'Orthophotos_TH-2m', 'Orthophotos_TH-2m', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14290, 792, 3, '0', 'TK50', 'TK50', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14291, 792, 4, '3', 'Top.Karte_50_gesamt', 'Top.Karte_50_gesamt', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14292, 792, 5, '3', 'Grundriss', 'Grundriss', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14293, 792, 6, '3', 'Gewaesser', 'Gewaesser', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14294, 792, 7, '3', 'Hoehenschichten', 'Hoehenschichten', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14295, 792, 8, '3', 'Strassen', 'Strassen', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14296, 792, 9, '3', 'Wald', 'Wald', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14297, 793, 0, '', '', 'OGC-Dienst des Hessischen Landesvermessungsamtes', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14298, 793, 1, '0', 'ATKIS50', 'ATKIS50', 0, 601, 50110, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14299, 793, 2, '0', 'ATKIS100', 'ATKIS100', 0, 1203, 150330, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14300, 793, 3, '0', 'DOP2SW', 'DOP2SW', 0, 40088, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19179, 624, 0, '', 'gewstat', 'gewstat', 1, 0, 0, '', '', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19180, 624, 1, '0', '2', 'Einzugsgebiete', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19181, 624, 2, '0', '12', 'Kanal', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19182, 624, 3, '0', '14', 'groessere Fliessgewaesser (generalisiert)', 1, 524922, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19183, 624, 4, '0', '9', 'Fliessgewaesser', 1, 200, 524922, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19184, 624, 5, '0', '16', 'Gewaesserflaeche', 1, 200, 89987, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19185, 624, 6, '0', '15', 'Stationierungslinie', 1, 200, 74989, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19186, 624, 7, '0', '6', 'Stationierung', 1, 200, 74989, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19187, 624, 8, '0', '17', 'Beschriftung Kanal', 1, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14342, 797, 1, '0', 'flur', 'Flur', 1, 50000, 0, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14343, 797, 2, '0', 'gema', 'Gemarkung', 1, 50000, 0, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14344, 797, 3, '0', 'geme', 'Gemeinde', 1, 50000, 0, '', NULL, NULL);
@@ -3525,558 +3158,98 @@
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14360, 799, 0, '', 'DOP', 'Digitale Orthophotos mit einer reduzierten Bodenau', 0, 10000, 0, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14361, 799, 1, '0', 'dop25', 'DOP 25m', 0, 50000, 2000000, '', NULL, NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14362, 799, 2, '0', 'dop5', 'DOP 5m', 0, 10000, 50000, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14363, 800, 0, '', '', 'WMS', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14364, 800, 1, '0', 'doq', '1991 doq', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14365, 800, 2, '0', 'fsa', '2003 fsa', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14366, 800, 3, '0', 'metro', '2004 NGA', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14370, 824, 0, '', '', 'ECW Images', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14371, 824, 1, '0', '/l7ecw_stretched/orthol7_20123xs190600.ecw', 'orthol7_20123xs190600.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14372, 824, 2, '0', '/l7ecw_stretched/orthol7_20124xs190600.ecw', 'orthol7_20124xs190600.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14373, 824, 3, '0', '/l7ecw_stretched/orthol7_20125xs190600.ecw', 'orthol7_20125xs190600.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14374, 824, 4, '0', '/l7ecw_stretched/orthol7_20222xs120501.ecw', 'orthol7_20222xs120501.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14375, 824, 5, '0', '/l7ecw_stretched/orthol7_20223xs120501.ecw', 'orthol7_20223xs120501.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14376, 824, 6, '0', '/l7ecw_stretched/orthol7_20224xs120501.ecw', 'orthol7_20224xs120501.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14377, 824, 7, '0', '/l7ecw_stretched/orthol7_20225xs120501.ecw', 'orthol7_20225xs120501.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14378, 824, 8, '0', '/l7ecw_stretched/orthol7_20323xs170600.ecw', 'orthol7_20323xs170600.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14379, 824, 9, '0', '/l7ecw_stretched/orthol7_20324xs170600.ecw', 'orthol7_20324xs170600.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14380, 824, 10, '0', '/l7ecw_stretched/orthol7_20325xs300400.ecw', 'orthol7_20325xs300400.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14381, 824, 11, '0', '/l7ecw_stretched/orthol7_20421xs070500.ecw', 'orthol7_20421xs070500.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14382, 824, 12, '0', '/l7ecw_stretched/orthol7_20422xs070500.ecw', 'orthol7_20422xs070500.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14383, 824, 13, '0', '/l7ecw_stretched/orthol7_20423xs100999.ecw', 'orthol7_20423xs100999.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14384, 824, 14, '0', '/l7ecw_stretched/orthol7_20424xs240799.ecw', 'orthol7_20424xs240799.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14385, 824, 15, '0', '/l7ecw_stretched/orthol7_20425xs240799.ecw', 'orthol7_20425xs240799.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14386, 824, 16, '0', '/l7ecw_stretched/orthol7_20520xs170700.ecw', 'orthol7_20520xs170700.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14387, 824, 17, '0', '/l7ecw_stretched/orthol7_20521xs170700.ecw', 'orthol7_20521xs170700.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14388, 824, 18, '0', '/l7ecw_stretched/orthol7_20522xs170700.ecw', 'orthol7_20522xs170700.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14389, 824, 19, '0', '/l7ecw_stretched/orthol7_20619xs180300.ecw', 'orthol7_20619xs180300.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14390, 824, 20, '0', '/l7ecw_stretched/orthol7_20620xs050500.ecw', 'orthol7_20620xs050500.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14391, 824, 21, '0', '/l7ecw_stretched/orthol7_20621xs250800.ecw', 'orthol7_20621xs250800.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14392, 824, 22, '0', '/l7ecw_stretched/orthol7_20622xs240501.ecw', 'orthol7_20622xs240501.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14393, 824, 23, '0', '/l7ecw_stretched/orthol7_20719xs290799.ecw', 'orthol7_20719xs290799.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14394, 824, 24, '0', '/l7ecw_stretched/orthol7_20720xs120500.ecw', 'orthol7_20720xs120500.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14395, 824, 25, '0', '/landmap/ls5/stif/ecw/ortholandsat5_201_23.ecw', 'ortholandsat5_201_23.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14396, 824, 26, '0', '/landmap/ls5/stif/ecw/ortholandsat5_201_24.ecw', 'ortholandsat5_201_24.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14397, 824, 27, '0', '/landmap/ls5/stif/ecw/ortholandsat5_202_22.ecw', 'ortholandsat5_202_22.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14398, 824, 28, '0', '/landmap/ls5/stif/ecw/ortholandsat5_202_23.ecw', 'ortholandsat5_202_23.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14399, 824, 29, '0', '/landmap/ls5/stif/ecw/ortholandsat5_202_24.ecw', 'ortholandsat5_202_24.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14400, 824, 30, '0', '/landmap/ls5/stif/ecw/ortholandsat5_202_25.ecw', 'ortholandsat5_202_25.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14401, 824, 31, '0', '/landmap/ls5/stif/ecw/ortholandsat5_203_22.ecw', 'ortholandsat5_203_22.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14402, 824, 32, '0', '/landmap/ls5/stif/ecw/ortholandsat5_203_23.ecw', 'ortholandsat5_203_23.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14403, 824, 33, '0', '/landmap/ls5/stif/ecw/ortholandsat5_203_24.ecw', 'ortholandsat5_203_24.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14404, 824, 34, '0', '/landmap/ls5/stif/ecw/ortholandsat5_203_25.ecw', 'ortholandsat5_203_25.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14405, 824, 35, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_20q1.ecw', 'ortholandsat5_204_20q1.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14406, 824, 36, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_20q3.ecw', 'ortholandsat5_204_20q3.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14407, 824, 37, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_21.ecw', 'ortholandsat5_204_21.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14408, 824, 38, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_22.ecw', 'ortholandsat5_204_22.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14409, 824, 39, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_23.ecw', 'ortholandsat5_204_23.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14410, 824, 40, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_24.ecw', 'ortholandsat5_204_24.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14411, 824, 41, '0', '/landmap/ls5/stif/ecw/ortholandsat5_204_25.ecw', 'ortholandsat5_204_25.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14412, 824, 42, '0', '/landmap/ls5/stif/ecw/ortholandsat5_205_18q1.ecw', 'ortholandsat5_205_18q1.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14413, 824, 43, '0', '/landmap/ls5/stif/ecw/ortholandsat5_205_18q2.ecw', 'ortholandsat5_205_18q2.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14414, 824, 44, '0', '/landmap/ls5/stif/ecw/ortholandsat5_205_20.ecw', 'ortholandsat5_205_20.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14415, 824, 45, '0', '/landmap/ls5/stif/ecw/ortholandsat5_205_21.ecw', 'ortholandsat5_205_21.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14416, 824, 46, '0', '/landmap/ls5/stif/ecw/ortholandsat5_205_22.ecw', 'ortholandsat5_205_22.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14417, 824, 47, '0', '/landmap/ls5/stif/ecw/ortholandsat5_206_18.ecw', 'ortholandsat5_206_18.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14418, 824, 48, '0', '/landmap/ls5/stif/ecw/ortholandsat5_206_19.ecw', 'ortholandsat5_206_19.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14419, 824, 49, '0', '/landmap/ls5/stif/ecw/ortholandsat5_206_20.ecw', 'ortholandsat5_206_20.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14420, 824, 50, '0', '/landmap/ls5/stif/ecw/ortholandsat5_206_21.ecw', 'ortholandsat5_206_21.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14421, 824, 51, '0', '/landmap/ls5/stif/ecw/ortholandsat5_206_22.ecw', 'ortholandsat5_206_22.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14422, 824, 52, '0', '/landmap/ls5/stif/ecw/ortholandsat5_207_20.ecw', 'ortholandsat5_207_20.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14423, 824, 53, '0', '/landmap/ls5/stif/ecw/ortholandsat5_207_21.ecw', 'ortholandsat5_207_21.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14424, 824, 54, '0', '/landmap/ls5/stif/ecw/ortholandsat5_207_22.ecw', 'ortholandsat5_207_22.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14425, 824, 55, '0', '/landmap/ls5/stif/ecw/ortholandsat5_208_19.ecw', 'ortholandsat5_208_19.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14426, 824, 56, '0', '/landmap/ls5/stif/ecw/ortholandsat5_208_20.ecw', 'ortholandsat5_208_20.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14427, 824, 57, '0', '/landmap/mosaics/landsat/hs.ecw', 'hs.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14428, 824, 58, '0', '/landmap/mosaics/landsat/hs2.ecw', 'hs2.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14429, 824, 59, '0', '/landmap/mosaics/landsat/hs3.ecw', 'hs3.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14430, 824, 60, '0', '/landmap/mosaics/landsat/l5mosaic.ecw', 'l5mosaic.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14431, 824, 61, '0', '/landmap/mosaics/landsat/l5mosaicb742.ecw', 'l5mosaicb742.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14432, 824, 62, '0', '/landmap/mosaics/landsat/l5mosaic_geodetic.ecw', 'l5mosaic_geodetic.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14433, 824, 63, '0', '/landmap/mosaics/landsat/l5mosaic_geodetic1.ecw', 'l5mosaic_geodetic1.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14434, 824, 64, '0', '/landmap/mosaics/landsat/l5mosaic_UTM.ecw', 'l5mosaic_UTM.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14435, 824, 65, '0', '/landmap/mosaics/landsat/l7b123.ecw', 'l7b123.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14436, 824, 66, '0', '/landmap/mosaics/landsat/l7bpan.ecw', 'l7bpan.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14437, 824, 67, '0', '/landmap/mosaics/landsat/l7bpan_s.ecw', 'l7bpan_s.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14438, 824, 68, '0', '/landmap/mosaics/landsat/l7bpan_s_geo.becw.ecw', 'l7bpan_s_geo.becw.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14439, 824, 69, '0', '/landmap/mosaics/landsat/l7bpan_s_geo.ecw', 'l7bpan_s_geo.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14440, 824, 70, '0', '/landmap/mosaics/landsat/landsat7m25.ecw', 'landsat7m25.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14441, 824, 71, '0', '/landmap/mosaics/landsat/landsat7m25r.ecw', 'landsat7m25r.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14442, 824, 72, '0', '/landmap/mosaics/landsat/landsat7m25_123.ecw', 'landsat7m25_123.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14443, 824, 73, '0', '/landmap/mosaics/landsat/landsat_mosaic_15m.ecw', 'landsat_mosaic_15m.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14444, 824, 74, '0', '/landmap/mosaics/spot/orthospot13_231.ecw', 'orthospot13_231.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14445, 824, 75, '0', '/landmap/mosaics/spot/orthospot13_232.ecw', 'orthospot13_232.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14446, 824, 76, '0', '/landmap/mosaics/spot/orthospot13_233.ecw', 'orthospot13_233.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14447, 824, 77, '0', '/landmap/mosaics/spot/orthospot13_234.ecw', 'orthospot13_234.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14448, 824, 78, '0', '/landmap/mosaics/spot/orthospot13_235.ecw', 'orthospot13_235.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14449, 824, 79, '0', '/landmap/mosaics/spot/orthospot14_230.ecw', 'orthospot14_230.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14450, 824, 80, '0', '/landmap/mosaics/spot/orthospot14_231.ecw', 'orthospot14_231.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14451, 824, 81, '0', '/landmap/mosaics/spot/orthospot14_232.ecw', 'orthospot14_232.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14452, 824, 82, '0', '/landmap/mosaics/spot/orthospot14_232_ecw.ecw', 'orthospot14_232_ecw.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14453, 824, 83, '0', '/landmap/mosaics/spot/orthospot14_233.ecw', 'orthospot14_233.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14454, 824, 84, '0', '/landmap/mosaics/spot/orthospot14_234.ecw', 'orthospot14_234.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14455, 824, 85, '0', '/landmap/mosaics/spot/orthospot14_235.ecw', 'orthospot14_235.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14456, 824, 86, '0', '/landmap/mosaics/spot/orthospot14_236.ecw', 'orthospot14_236.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14457, 824, 87, '0', '/landmap/mosaics/spot/orthospot17_230.ecw', 'orthospot17_230.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14458, 824, 88, '0', '/landmap/mosaics/spot/orthospot17_231.ecw', 'orthospot17_231.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14459, 824, 89, '0', '/landmap/mosaics/spot/orthospot17_232.ecw', 'orthospot17_232.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14460, 824, 90, '0', '/landmap/mosaics/spot/orthospot17_233.ecw', 'orthospot17_233.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14461, 824, 91, '0', '/landmap/mosaics/spot/orthospot17_234.ecw', 'orthospot17_234.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14462, 824, 92, '0', '/landmap/mosaics/spot/orthospot17_235.ecw', 'orthospot17_235.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14463, 824, 93, '0', '/landmap/mosaics/spot/orthospot17_236.ecw', 'orthospot17_236.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14464, 824, 94, '0', '/landmap/mosaics/spot/orthospot17_237.ecw', 'orthospot17_237.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14465, 824, 95, '0', '/landmap/mosaics/spot/orthospot17_238.ecw', 'orthospot17_238.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14466, 824, 96, '0', '/landmap/mosaics/spot/orthospot17_239.ecw', 'orthospot17_239.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14467, 824, 97, '0', '/landmap/mosaics/spot/orthospot17_240.ecw', 'orthospot17_240.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14468, 824, 98, '0', '/landmap/mosaics/spot/orthospot18_229.ecw', 'orthospot18_229.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14469, 824, 99, '0', '/landmap/mosaics/spot/orthospot18_231.ecw', 'orthospot18_231.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14470, 824, 100, '0', '/landmap/mosaics/spot/orthospot18_232.ecw', 'orthospot18_232.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14471, 824, 101, '0', '/landmap/mosaics/spot/orthospot18_233.ecw', 'orthospot18_233.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14472, 824, 102, '0', '/landmap/mosaics/spot/orthospot18_234.ecw', 'orthospot18_234.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14473, 824, 103, '0', '/landmap/mosaics/spot/orthospot18_235.ecw', 'orthospot18_235.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14474, 824, 104, '0', '/landmap/mosaics/spot/orthospot18_236.ecw', 'orthospot18_236.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14475, 824, 105, '0', '/landmap/mosaics/spot/orthospot18_237.ecw', 'orthospot18_237.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14476, 824, 106, '0', '/landmap/mosaics/spot/orthospot18_238.ecw', 'orthospot18_238.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14477, 824, 107, '0', '/landmap/mosaics/spot/orthospot25_237.ecw', 'orthospot25_237.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14478, 824, 108, '0', '/landmap/mosaics/spot/orthospot25_238.ecw', 'orthospot25_238.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14479, 824, 109, '0', '/landmap/mosaics/spot/orthospot25_241.ecw', 'orthospot25_241.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14480, 824, 110, '0', '/landmap/mosaics/spot/orthospot25_242.ecw', 'orthospot25_242.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14481, 824, 111, '0', '/landmap/mosaics/spot/orthospot25_243.ecw', 'orthospot25_243.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14482, 824, 112, '0', '/landmap/mosaics/spot/orthospot25_244.ecw', 'orthospot25_244.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14483, 824, 113, '0', '/landmap/mosaics/spot/orthospot25_245.ecw', 'orthospot25_245.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14484, 824, 114, '0', '/landmap/mosaics/spot/orthospot25_247.ecw', 'orthospot25_247.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14485, 824, 115, '0', '/landmap/mosaics/spot/orthospot25_248.ecw', 'orthospot25_248.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14486, 824, 116, '0', '/landmap/mosaics/spot/orthospot26_239.ecw', 'orthospot26_239.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14487, 824, 117, '0', '/landmap/mosaics/spot/orthospot26_240.ecw', 'orthospot26_240.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14488, 824, 118, '0', '/landmap/mosaics/spot/orthospot26_241.ecw', 'orthospot26_241.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14489, 824, 119, '0', '/landmap/mosaics/spot/orthospot26_242.ecw', 'orthospot26_242.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14490, 824, 120, '0', '/landmap/mosaics/spot/orthospot26_243.ecw', 'orthospot26_243.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14491, 824, 121, '0', '/landmap/mosaics/spot/orthospot26_244.ecw', 'orthospot26_244.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14492, 824, 122, '0', '/landmap/mosaics/spot/orthospot26_245.ecw', 'orthospot26_245.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14493, 824, 123, '0', '/landmap/mosaics/spot/orthospot26_246.ecw', 'orthospot26_246.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14494, 824, 124, '0', '/landmap/mosaics/spot/orthospot26_247.ecw', 'orthospot26_247.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14495, 824, 125, '0', '/landmap/mosaics/spot/orthospot26_248.ecw', 'orthospot26_248.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14496, 824, 126, '0', '/landmap/mosaics/spot/orthospot28_246.ecw', 'orthospot28_246.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14497, 824, 127, '0', '/landmap/mosaics/spot/orthospot28_247.ecw', 'orthospot28_247.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14498, 824, 128, '0', '/landmap/mosaics/spot/orthospot29_239.ecw', 'orthospot29_239.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14499, 824, 129, '0', '/landmap/mosaics/spot/orthospot29_240.ecw', 'orthospot29_240.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14500, 824, 130, '0', '/landmap/mosaics/spot/orthospot29_241.ecw', 'orthospot29_241.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14501, 824, 131, '0', '/landmap/mosaics/spot/orthospot29_242.ecw', 'orthospot29_242.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14502, 824, 132, '0', '/landmap/mosaics/spot/orthospot29_243.ecw', 'orthospot29_243.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14503, 824, 133, '0', '/landmap/mosaics/spot/orthospot29_244.ecw', 'orthospot29_244.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14504, 824, 134, '0', '/landmap/mosaics/spot/orthospot29_245.ecw', 'orthospot29_245.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14505, 824, 135, '0', '/landmap/mosaics/spot/orthospot30_242.ecw', 'orthospot30_242.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14506, 824, 136, '0', '/landmap/mosaics/spot/orthospot30_243.ecw', 'orthospot30_243.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14507, 824, 137, '0', '/landmap/mosaics/spot/orthospot30_245.ecw', 'orthospot30_245.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14508, 824, 138, '0', '/landmap/mosaics/spot/orthospot30_246.ecw', 'orthospot30_246.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14509, 824, 139, '0', '/landmap/mosaics/spot/orthospot30_247.ecw', 'orthospot30_247.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14510, 824, 140, '0', '/landmap/mosaics/spot/orthospot32_246.ecw', 'orthospot32_246.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14511, 824, 141, '0', '/landmap/mosaics/spot/orthospot32_247.ecw', 'orthospot32_247.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14512, 824, 142, '0', '/landmap/mosaics/spot/orthospot33_243.ecw', 'orthospot33_243.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14513, 824, 143, '0', '/landmap/mosaics/spot/orthospot33_244.ecw', 'orthospot33_244.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14514, 824, 144, '0', '/landmap/mosaics/spot/orthospot33_245.ecw', 'orthospot33_245.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14515, 824, 145, '0', '/landmap/mosaics/spot/orthospot34_243.ecw', 'orthospot34_243.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14516, 824, 146, '0', '/landmap/mosaics/spot/orthospot34_244.ecw', 'orthospot34_244.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14517, 824, 147, '0', '/landmap/mosaics/spot/orthospot34_245.ecw', 'orthospot34_245.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14518, 824, 148, '0', '/landmap/mosaics/spot/orthospot34_246.ecw', 'orthospot34_246.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14519, 824, 149, '0', '/landmap/mosaics/spot/orthospot34_247.ecw', 'orthospot34_247.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14520, 824, 150, '0', '/landmap/orthospot/UK_Orthospot/mosaics.ecw', 'mosaics.ecw', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14525, 827, 0, '', '', 'Test Imagery', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14526, 827, 1, '0', 'dlwc_landsat_2000_mosaic', 'NSW Landsat 2000 Mosaic', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14527, 828, 0, '', '', 'IDERIOJA', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14528, 828, 1, '0', 'ortofoto', 'Ortofoto', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14529, 828, 2, '0', 'Cuadricula', 'Cuadricula 5k', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14530, 828, 3, '0', 'Nucleos', 'Nucleos Urbanos', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14531, 828, 4, '0', 'Rios', 'Rios', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14532, 828, 5, '0', 'municipios', 'Terminos Municipales', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14533, 828, 6, '0', 'Carreteras', 'Carreteras', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14534, 829, 0, '', '', 'at_etm7_lambert', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14535, 829, 1, '0', '0', 'etm7_lambert', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14550, 831, 0, '', 'DELI', 'MNDNR Data Deli WMS Server', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14551, 831, 1, '0', 'L380000020906', '1:100k Digital Raster Graphic - Collars Removed', 0, 0, 125000, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14552, 831, 2, '0', 'L380000030906', '1:24k Digital Raster Graphic - Collars Removed', 0, 0, 30000, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14553, 831, 3, '0', 'L380000010906', '1:250k Digital Raster Graphic - Collars Removed', 0, 0, 499999, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14554, 831, 4, '0', 'L390002440906', 'GAP Land Cover - Image', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14555, 831, 5, '0', 'L390002400906', 'Public Waters Inventory Maps', 0, 0, 100000, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14556, 831, 6, '0', 'L370000050906', 'USGS Digital Orthophoto Quad (DOQ) - 3 meter', 0, 0, 100000, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14557, 832, 0, '', '', 'ArcIMS MapService', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14558, 832, 1, '0', 'overview', 'Wetland Overview', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14559, 832, 2, '0', 'wetlands_low', 'Wetlands Low Res', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14560, 832, 3, '0', 'wetlands', 'Wetlands High Res', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14561, 833, 0, '', '', 'encdirect', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14562, 833, 1, '0', '4', 'ENCNAMES_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14563, 833, 2, '0', 'LAND', 'LAND', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14564, 833, 3, '0', 'QUALITY OF DATA(M_QUAL)', 'QUALITY OF DATA', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14565, 833, 4, '0', 'NAVIGATIONAL SYSTEM OF MARKS(M_NSYS)', 'NAVIGATIONAL SYSTEM OF MARKS', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14566, 833, 5, '0', 'HORIZONTAL DATUM OF DATA(M_SDAT)', 'HORIZONTAL DATUM OF DATA', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14567, 833, 6, '0', 'NAUTICAL PUBLICATION INFORMATION(M_NPUB)', 'NAUTICAL PUBLICATION INFORMATION', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14568, 833, 7, '0', 'COMPLIATION OF SCALE DATA(M_CSCL)', 'COMPLIATION OF SCALE DATA', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14569, 833, 8, '0', 'COVERAGE(M_COVR)', 'COVERAGE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14570, 833, 9, '0', 'ACCURACY(M_ACCY)', 'ACCURACY', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14571, 833, 10, '0', 'LAND AREA(LNDARE)', 'LAND AREA_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14572, 833, 11, '0', 'DEPTH AREA(DEPARE)', 'DEPTH AREA_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14573, 833, 12, '0', 'ICE AREA(ICEARE)', 'ICE AREA', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14574, 833, 13, '0', 'HARBOR FACILITY_POLYGON(HRBFAC)', 'HARBOR FACILITY_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14575, 833, 14, '0', 'SEA AREA(SEAARE)', 'SEA AREA_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14576, 833, 15, '0', 'PYLONS_polygon(PYLONS)', 'PYLONS_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14577, 833, 16, '0', 'SEABED AREA_polygon(SBDARE)', 'SEABED AREA_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14578, 833, 17, '0', 'PONTOON(PONTON)', 'PONTOON_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14579, 833, 18, '0', 'WEED, KELP(WEDKLP)', 'WEED, KELP_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14580, 833, 19, '0', 'OFFSHORE PRODUCTION AREA(OSPARE)', 'OFFSHORE PRODUCTION AREA', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14581, 833, 20, '0', 'VEGATATION(VEGATN)', 'VEGATATION_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14582, 833, 21, '0', 'TWO_WAY ROUTE PART(TWRTPT)', 'TWO_WAY ROUTE PART', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14583, 833, 22, '0', 'SWEPTH AREA(SWPARE)', 'SWEPTH AREA', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14584, 833, 23, '0', 'SEA PLANE LANDING AREA(SLPARE)', 'SEA PLANE LANDING AREA_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14585, 833, 24, '0', 'WATER TURBULENCE(WATTUR)', 'WATER TURBULENCE_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14586, 833, 25, '0', 'SLOPING GROUND(SLOGRD)', 'SLOPING GROUND_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14587, 833, 26, '0', 'PRODUCTION AREA(PRDARE)', 'PRODUCTION AREA_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14588, 833, 27, '0', 'RUNWAY(RUNWAY)', 'RUNWAY_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14589, 833, 28, '0', 'RECOMMENDED TRACK(RECTRC)', 'RECOMMENDED TRACK_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14590, 833, 29, '0', 'RAPIDS(RAPIDS)', 'RAPIDS_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14591, 833, 30, '0', 'MILITARY PRACTICE AREA(MIPARE)', 'MILITARY PRACTICE AREA_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14592, 833, 31, '0', 'PRECAUTIONARY AREA_polygon(PRCARE)', 'PRECAUTIONARY AREA_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14593, 833, 32, '0', 'PILOT BOARDING AREA(PILBOP)', 'PILOT BOARDING AREA_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14594, 833, 33, '0', 'OFFSHORE PLATFORM(OFSPLF)', 'OFFSHORE PLATFORM_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14595, 833, 34, '0', 'LOCAL MAGNETIC ANOMALY(LOCMAG)', 'LOCAL MAGNETIC ANOMALY_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14596, 833, 35, '0', 'LOCK BASIN(LOKBSN)', 'LOCK BASIN', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14597, 833, 36, '0', 'MOORING FACILITY(MORFAC)', 'MOORING FACILITY_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14598, 833, 37, '0', 'GATE(GATCON)', 'GATE_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14599, 833, 38, '0', 'HARBOR AREA(HRBARE)', 'HARBOR AREA', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14600, 833, 39, '0', 'GRIDIRON(GRIDRN)', 'GRIDIRON_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14601, 833, 40, '0', 'LOG POND(LOGPON)', 'LOG POND_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14602, 833, 41, '0', 'LANDMARK(LNDMRK)', 'LANDMARK_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14603, 833, 42, '0', 'FERRY ROUTE(FERYRT)', 'FERRY ROUTE_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14604, 833, 43, '0', 'HULK_polygon(HULKES)', 'HULK_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14605, 833, 44, '0', 'FISH FACILITY(FSHFAC)', 'FISH FACILITY_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14606, 833, 45, '0', 'FLOATING DOCK_polygon(FLODOC)', 'FLOATING DOCK_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14607, 833, 46, '0', 'RIVERS(RIVERS)', 'RIVERS_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14608, 833, 47, '0', 'UNSURVEYED AREA(UNSARE)', 'UNSURVEYED AREA', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14609, 833, 48, '0', 'LAKE(LAKARE)', 'LAKE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14610, 833, 49, '0', 'SHORELINE CONSTRUCTION(SLCONS)', 'SHORELINE CONSTRUCTION_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14611, 833, 50, '0', 'TRAFFIC SEPARATION ZONE(TSEZNE)', 'TRAFFIC SEPARATION ZONE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14612, 833, 51, '0', 'OBSTRUCTION(OBSTRN)', 'OBSTRUCTION_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14613, 833, 52, '0', 'TRAFFIC SEPARATION SCHEME LANE PART(TSSLPT)', 'TRAFFIC SEPARATION SCHEME LANE PART', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14614, 833, 53, '0', 'LAND REGION(LNDRGN)', 'LAND REGION_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14615, 833, 54, '0', 'WRECKS_polygon(WRECKS)', 'WRECKS_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14616, 833, 55, '0', 'MARINE FARM, CULTURE(MARCUL)', 'MARINE FARM, CULTURE_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14617, 833, 56, '0', 'INSHORE TRAFFIC ZONE(ISTZNE)', 'INSHORE TRAFFIC ZONE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14618, 833, 57, '0', 'DEEP WATER ROUTE PART(DWRTPT)', 'DEEP WATER ROUTE PART', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14619, 833, 58, '0', 'DREDGED AREA(DRGARE)', 'DREDGED AREA', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14620, 833, 59, '0', 'DUMPING GROUND(DMPGRD)', 'DUMPING GROUND_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14621, 833, 60, '0', 'FAIRWAY_polygon(FAIRWY)', 'FAIRWAY', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14622, 833, 61, '0', 'ANCHOR BERTH(ACHBRT)', 'ANCHOR BERTH_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14623, 833, 62, '0', 'DRY DOCK(DRYDOC)', 'DRY DOCK', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14624, 833, 63, '0', 'RESTRICTED AREA(RESARE)', 'RESTRICTED AREA', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14625, 833, 64, '0', 'DOCK AREA(DOCARE)', 'DOCK AREA', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14626, 833, 65, '0', 'DIKE(DYKON)', 'DIKE_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14627, 833, 66, '0', 'BERTHS(BERTHS)', 'BERTHS_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14628, 833, 67, '0', 'DAM(DAMCON)', 'DAM_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14629, 833, 68, '0', 'ANCHORAGE AREA(ACHARE)', 'ANCHORAGE AREA_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14630, 833, 69, '0', 'CANALS(CANALS)', 'CANALS_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14631, 833, 70, '0', 'CAUSEWAY(CAUSWY)', 'CAUSEWAY_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14632, 833, 71, '0', 'CABLE AREA(CBLARE)', 'CABLE AREA', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14633, 833, 72, '0', 'BUILT-UP AREA(BUAARE)', 'BUILT-UP AREA_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14634, 833, 73, '0', 'SILO, TANK(SILTNK)', 'SILO, TANK_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14635, 833, 74, '0', 'FORTIFIED STRUCTURE(FORSTC)', 'FORTIFIED STRUCTURE_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14636, 833, 75, '0', 'TUNNEL(TUNNEL)', 'TUNNEL_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14637, 833, 76, '0', 'CONVEYOR(CONVYR)', 'CONVEYOR_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14638, 833, 77, '0', 'BUILDING(BUISGL)', 'BUILDING_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14639, 833, 78, '0', 'CRANES(CRANES)', 'CRANES_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14640, 833, 79, '0', 'ADMINISTRATION AREA_polygon(ADMARE)', 'ADMINISTRATION AREA', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14641, 833, 80, '0', 'AIRARE(AIRARE)', 'AIRPORT_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14642, 833, 81, '0', 'TRAFFIC SEPARATION SCHEME BOUNDARY(TSSBND)', 'TRAFFIC SEPARATION SCHEME BOUNDARY', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14643, 833, 82, '0', 'CAUTION AREA(CTNARE)', 'CAUTION AREA_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14644, 833, 83, '0', 'BRIDGE_polygon(BRIDGE)', 'BRIDGE_polygon', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14645, 833, 84, '0', 'SLOPE_TOPLINE(SLOTOP', 'SLOPE TOPLINE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14646, 833, 85, '0', 'WATER FALL_line(WATFAL)', 'WATER FALL_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14647, 833, 86, '0', 'SHORELINE CONSTRUCTION_line(SLCONS)', 'SHORELINE CONSTRUCTION_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14648, 833, 87, '0', 'RIVERS_line(RIVERS)', 'RIVERS_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14649, 833, 88, '0', 'SUBMARINE_ON LAND PIPELINE_line(PIPSOL)', 'SUBMARINE_ON LAND PIPELINE_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14650, 833, 89, '0', 'OVERHEAD PIPELINE(PIPOHD)', 'OVERHEAD PIPELINE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14651, 833, 90, '0', 'OBSTRUCTION_line(OBSTRN)', 'OBSTRUCTION_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14652, 833, 91, '0', 'NAVIGATION LINE(NAVLNE)', 'NAVIGATION LINE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14653, 833, 92, '0', 'LAND ELEVATION_line(LNDELV)', 'LAND ELEVATION_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14654, 833, 93, '0', 'ROAD_line(ROADWY)', 'ROAD_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14655, 833, 94, '0', 'FENCE LINE_line(FNCLNE)', 'FENCE LINE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14656, 833, 95, '0', 'OIL BARRIER_line(OILBAR)', 'OIL BARRIER', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14657, 833, 96, '0', 'FERRY ROUTE_line(FERYRT)', 'FERRY ROUTE_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14658, 833, 97, '0', 'DIKE_line(DYKCON)', 'DIKE_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14659, 833, 98, '0', 'SAND WAVES_line(SNDWAV)', 'SAND WAVES_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14660, 833, 99, '0', 'RECOMMENDED TRACK_line(RECTRC)', 'RECOMMENDED TRACK_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14661, 833, 100, '0', 'DEPTH AREA_line(DEPARE)', 'DEPTH AREA_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14662, 833, 101, '0', '1', 'WATER TURBULENCE_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14663, 833, 102, '0', 'DEPTH CONTOUR(DEPCNT)', 'DEPTH CONTOUR', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14664, 833, 103, '0', 'CONVEYOR_line(CONVYR)', 'CONVEYOR_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14665, 833, 104, '0', 'DAM_line(DAMCON)', 'DAM_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14666, 833, 105, '0', 'COASTLINE(COALNE)', 'COASTLINE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14667, 833, 106, '0', 'LAND AREA_line(LNDAARE)', 'LAND AREA_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14668, 833, 107, '0', 'FISH FACILITY_line(FSHFAC)', 'FISH FACILITY_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14669, 833, 108, '0', 'MOORING FACILITY_line(MORFAC)', 'MOORING FACILITY_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14670, 833, 109, '0', 'GATE_line(GATCON)', 'GATE_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14671, 833, 110, '0', 'TUNNEL_line(TUNNEL)', 'TUNNEL_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14672, 833, 111, '0', 'SUBMARINE CABLE(CLBSUB)', 'SUBMARINE CABLE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14673, 833, 112, '0', 'SLOPE TOPLINE_line(SLOTOP)', 'SLOPE TOPLINE_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14674, 833, 113, '0', 'RAILWAY_line(RAILWY)', 'RAILWAY', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14675, 833, 114, '0', 'TRAFFIC SEPARATION LINE(TSELNE)', 'TRAFFIC SEPARATION LINE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14676, 833, 115, '0', 'VEGATATION_line(VEGATN)', 'VEGATATION_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14677, 833, 116, '0', 'OVERHEAD CABLE(CBLOHD)', 'OVERHEAD CABLE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14678, 833, 117, '0', 'PONTOON_line(PONTON)', 'PONTOON_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14679, 833, 118, '0', 'CANALS_line(CANALS)', 'CANALS_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14680, 833, 119, '0', 'RECOMMENDED ROUTE CENTERLINE_line(RCRTCL)', 'RECOMMENDED ROUTE CENTERLINE_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14681, 833, 120, '0', 'BRIDGE_line(BRIDGE)', 'BRIDGE_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14682, 833, 121, '0', 'WRECKS_point(WRECKS)', 'WRECKS_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14683, 833, 122, '0', 'WEED, KELP_point(WEDKLP)', 'WEED, KELP_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14684, 833, 123, '0', 'WATER TURBULENCE_point(WATTUR)', 'WATER TURBULENCE_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14685, 833, 124, '0', 'ROCK AWASH, UNDERWATER_POINT(UWTROC)', 'ROCK AWASH, UNDERWATER', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14686, 833, 125, '0', 'TOPMARK_point(TOPMAR)', 'TOPMARK', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14687, 833, 126, '0', 'SHORELINE CONSTRUCTION_point(SLCONS)', 'SHORELINE CONSTRUCTION_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14688, 833, 127, '0', 'SILO, TANK_point(SILTNK)', 'SILO, TANK_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14689, 833, 128, '0', 'SEA AREA_point(SEAARE)', 'SEA AREA_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14690, 833, 129, '0', 'SEABED AREA_point(SBDARE)', 'SEABED AREA_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14691, 833, 130, '0', 'RADAR TRANSPONDER BEACON_POINT(RTPBCN)', 'RADAR TRANSPONDER BEACON', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14692, 833, 131, '0', 'RESCUE STATION_POINT(RCSTA)', 'RESCUE STATION', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14693, 833, 132, '0', 'PYLONS_point(PYLONS)', 'PYLONS_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14694, 833, 133, '0', 'PILE_point(PILPNT)', 'PILE', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14695, 833, 134, '0', 'OFFSHORE PLATFORM_point(OFSPLF_point)', 'OFFSHORE PLATFORM_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14696, 833, 135, '0', 'MOORING FACILITY_point(MORFAC_point)', 'MOORING FACILITY_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14697, 833, 136, '0', 'LAND REGION_point(LNDRGN_point)', 'LAND REGION_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14698, 833, 137, '0', 'LANDMARK_point(LNDMARK)', 'LANDMARK_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14699, 833, 138, '0', 'LAND AREA_point(LNDARE)', 'LAND AREA_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14700, 833, 139, '0', 'FOGSIG_point(FOGSIG)', 'FOG SIGNAL', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14701, 833, 140, '0', 'DAYMARK_point(DAYMAR)', 'DAYMARK', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14702, 833, 141, '0', 'CAUTION AREA_point(CNTARE)', 'CAUTION AREA_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14703, 833, 142, '0', 'COASTGUARD STATION_point(CGUSTA)', 'COASTGUARD STATION', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14704, 833, 143, '0', 'BUILDING_point(BUISGL)', 'BUILDING_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14705, 833, 144, '0', 'BUILT-UP AREA_point(BUAARE)', 'BUILT-UP AREA_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14706, 833, 145, '0', 'INSTALLATION(BOYINB)', 'INSTALLATION BUOY', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14707, 833, 146, '0', 'SPECIAL PURPOSE BUOY_point(BOYSPP)', 'SPECIAL PURPOSE BUOY', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14708, 833, 147, '0', 'SAFE WATER BUOY(BOYSAW)', 'SAFE WATER BUOY', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14709, 833, 148, '0', 'LATERAL BUOY_point(BOYLAT)', 'LATERAL BUOY', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14710, 833, 149, '0', 'SPECIAL PURPOSE BEACON_point(BCNSPP)', 'SPECIAL PURPOSE BEACON', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14711, 833, 150, '0', 'SAFE WATER BEACON_point(BCNSAW)', 'SAFE WATER BEACON', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14712, 833, 151, '0', 'LATERAL BEACON_point(BCNLAT)', 'LATERAL BEACON', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14713, 833, 152, '0', 'LAND ELEVATION_point(LNDELV)', 'LAND ELEVATION_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14714, 833, 153, '0', 'ANCHOR BERTH_point(ACHBRT)', 'ANCHOR BERTH_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14715, 833, 154, '0', 'ANCHORAGE AREA_point(ANCARE)', 'ANCHORAGE AREA_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14716, 833, 155, '0', 'AIRPORT_point(AIRARE)', 'AIRPORT_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14717, 833, 156, '0', 'ISOLATED DANGER BEACON(BCNISD)', 'ISOLATED DANGER BEACON', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14718, 833, 157, '0', 'BERTHS_point(BERTHS)', 'BERTHS_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14719, 833, 158, '0', 'CARDINAL BUOY_point(BOYCAR)', 'CARDINAL BUOY', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14720, 833, 159, '0', 'ISOLATED DANGER BUOY_point(BOYISD)', 'ISOLATED DANGER BUOY', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14721, 833, 160, '0', 'CRANES_point(CRANES)', 'CRANES_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14722, 833, 161, '0', 'CONTROL POINT(CTRPNT)', 'CONTROL POINT', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14723, 833, 162, '0', 'CURRENT_point(CURENT)', 'CURRENT', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14724, 833, 163, '0', 'DAM_point(DAMCON)', 'DAM_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14725, 833, 164, '0', 'DISTANCE MARK_point(DISMAR)', 'DISTANCE MARK', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14726, 833, 165, '0', 'DUMPING GROUND_point(DMPGRD)', 'DUMPING GROUND_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14727, 833, 166, '0', 'FORTIFIED STRUCTURE_point(FORSTC)', 'FORTIFIED STRUCTURE_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14728, 833, 167, '0', 'FISH FACILITY_point(FSHFAC)', 'FISH FACILITY_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14729, 833, 168, '0', 'GATE_point(GATCON)', 'GATE_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14730, 833, 169, '0', 'HARBOR FACILITY_point(HRBFAC)', 'HARBOR FACILITY_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14731, 833, 170, '0', 'LOCAL MAGNETIC ANOMALY_point(LOCMAG)', 'LOCAL MAGNETIC ANOMALY_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14732, 833, 171, '0', 'LOG POND_point(LOGPON)', 'LOG POND_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14733, 833, 172, '0', 'MAGNETIC VARIATION_point(MAGVAR)', 'MAGNETIC VARIATION_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14734, 833, 173, '0', 'PILOT BOARDING POINT_point(PILBOP)', 'PILOT BOARDING POINT_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14735, 833, 174, '0', 'SUBMARINE_ON LAND PIPELINE_point(PISOL)', 'SUBMARINE_ON LAND PIPELINE_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14736, 833, 175, '0', 'PRODUCTION AREA_point(PRDARE)', 'PRODUCTION AREA_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14737, 833, 176, '0', 'RADIO CALLING IN POINT_point(RDOCAL)', 'RADIO CALLING IN POINT_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14738, 833, 177, '0', 'RETRO REFLECTOR_point(RETRFL)', 'RETRO REFLECTOR', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14739, 833, 178, '0', 'WARNING SIGNAL STATION_point(SISTAW)', 'WARNING SIGNAL STATION', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14740, 833, 179, '0', 'TRAFFIC SIGNAL STATION_point(SISTAT)', 'TRAFFIC SIGNAL STATION', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14741, 833, 180, '0', 'SLOPING GROUND_point(SLOGRD)', 'SLOPING GROUND_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14742, 833, 181, '0', 'SMALL CRAFT FACILITY_point(SMCFAC)', 'SMALL CRAFT FACILITY_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14743, 833, 182, '0', 'SAND WAVES_point(SNDWAV)', 'SAND WAVES_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14744, 833, 183, '0', 'SEA PLANE LANDING AREA_point(SPLARE)', 'SEA PLANE LANDING AREA_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14745, 833, 184, '0', 'SPRING_point(SPRING)', 'SPRING', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14746, 833, 185, '0', 'TIDAL STREAM_point(TS_FEB)', 'TIDAL STREAM_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14747, 833, 186, '0', 'SEABED AREA_line(SBDARE)', 'SEABED AREA_line', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14748, 833, 187, '0', 'TUNNEL_point(TUNNEL)', 'TUNNEL_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14749, 833, 188, '0', 'VEGATATION_point(VEGATN)', 'VEGATATION_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14750, 833, 189, '0', 'WATER FALL', 'WATER FALL_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14751, 833, 190, '0', 'RADIO STATION(RDOSTA)', 'RADIO STATION', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14752, 833, 191, '0', 'OBSTRUCTION_point(OBSTRN)', 'OBSTRUCTION_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14753, 833, 192, '0', 'LIGHTS_point(LIGHTS)', 'LIGHTS', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14754, 833, 193, '0', 'LIGHT FLOAT_point(LITFLT)', 'LIGHT FLOAT', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14755, 833, 194, '0', 'HULK_point(HULKES)', 'HULKES_point', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14756, 833, 195, '0', 'SOUNDINGS', 'SOUNDINGS', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14757, 833, 196, '0', '0', 'ENC INDEX', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14758, 834, 0, '', '', 'DE_aerial02', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14759, 834, 1, '0', 'ortho2002', '2002 Aerial Imagery', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14800, 836, 0, '', '', 'NDOP', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14801, 836, 1, '0', 'States', 'State Boundaries', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14802, 836, 2, '0', 'Projects', 'NDOP Projects', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14803, 837, 0, '', '', 'U.S. Geological Survey', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14804, 837, 1, '0', 'DOQ', 'USGS Digital Ortho-Quadrangles', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14805, 837, 2, '0', 'DRG', 'USGS Raster Graphics (Topo Maps)', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14806, 837, 3, '0', 'UrbanArea', 'USGS Urban Areas Ortho-Imagery', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14842, 840, 0, '', '', 'World', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14843, 840, 1, '0', 'GLOBEImage', 'GlobeImage', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14844, 840, 2, '0', 'ADMIN', 'Admin', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14845, 840, 3, '0', 'COUNTRY', ' Country', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14846, 840, 4, '0', 'Lakes', ' Lakes', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14847, 840, 5, '0', 'RAILWAY', ' Railway', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14848, 840, 6, '0', 'WorldGridLines', ' World Grid Lines', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14849, 840, 7, '0', 'OCEAN_TEXT', ' Ocean Label', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14850, 840, 8, '0', 'CAPITALS', ' Capitals', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14851, 841, 0, '', 'ICEDSWMS', 'ICEDS (Integrated CEOS European Data Server) WMS', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14852, 841, 1, '0', 'GRID', 'MAPDRESSING GRID', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14853, 841, 2, '0', 'lights', 'DMSP/NOAA human settlements night lights of the wo', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14854, 841, 3, '2', 'lights_1', 'DMSP/NOAA human settlements night lights (300 arcs', 0, 44999930, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14855, 841, 4, '2', 'lights_2', 'DMSP/NOAA human settlements night lights (30 arcse', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14856, 841, 5, '0', 'landsat5', 'LANDSAT 5 mosaic for Africa and Europe', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14857, 841, 6, '5', 'landsat_1', 'LANDSAT 5 mosaic for Africa and Europe (100 arscse', 0, 9000006, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14858, 841, 7, '5', 'landsat_2', 'LANDSAT 5 mosaic for Africa and Europe (10 arscsec', 0, 3000002, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14859, 841, 8, '5', 'landsat_3', 'LANDSAT 5 mosaic for Africa and Europe (1 arscsec.', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14860, 841, 9, '0', 'srtm', 'Hillshaded SRTM3 mosaic', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14861, 841, 10, '9', 'srtm3_1', 'Hillshaded SRTM3 mosaic (180 arscsec. level)', 0, 20000000, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14862, 841, 11, '9', 'srtm3_2', 'Hillshaded SRTM3 mosaic (30 arscsec. level)', 0, 1700000, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14863, 841, 12, '9', 'srtm3_3', 'Hillshaded SRTM3 mosaic (3 arscsec. level)', 0, 0, 1700000, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14864, 841, 13, '0', 'srtm30', 'Hillshaded SRTM30 mosaic', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14865, 841, 14, '13', 'srtm30_1', 'Hillshaded SRTM30 mosaic (300 arscsec. level)', 0, 20000000, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14866, 841, 15, '13', 'srtm30_2', 'Hillshaded SRTM30 mosaic (30 arscsec. level)', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14867, 841, 16, '0', 'bluemarble', 'Global MODIS Blue Marble', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14868, 841, 17, '16', 'bluemarble_1', 'Global MODIS Blue Marble (300 arcsec. level)', 0, 11999988, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14869, 841, 18, '16', 'bluemarble_2', 'Global MODIS Blue Marble (30 arcsec. level)', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14870, 841, 19, '0', 'globe', 'Cascaded data from GLOBE', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14871, 841, 20, '19', 'rivers', 'Cascaded Rivers from GLOBE', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14872, 841, 21, '19', 'coastlines', 'Cascaded Coastlines from GLOBE', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14873, 841, 22, '0', 'demis', 'Cascaded data from Demis', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14874, 841, 23, '22', 'bathymetry', 'Cascaded Bathymetry from Demis', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14875, 841, 24, '0', 'onearth', 'Cascaded data from OnEarth', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14876, 841, 25, '24', 'landsat7', 'Cascaded Landsat7 from OnEarth', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14877, 841, 26, '24', 'terra', 'Cascaded daily MODIS Terra from OnEarth', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14878, 841, 27, '24', 'aqua', 'Cascaded daily MODIS Aqua from OnEarth', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14879, 841, 28, '0', 'metarweather', 'Cascaded World Hourly METAR Weather Reports from C', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14880, 841, 29, '0', 'noaa', 'Cascaded NOAA World Natural Hazards data', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14881, 841, 30, '29', 'earthquakes', 'Cascaded NOAA Significant Earthquakes', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14882, 841, 31, '29', 'tsunamievents', 'Cascaded NOAA Tsunami Events', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14883, 841, 32, '29', 'volcanoes', 'Cascaded NOAA Volcanoes', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14884, 841, 33, '29', 'plateboundaries', 'Cascaded NOAA Plate Boundaries', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14885, 841, 34, '29', 'countries', 'Cascaded NOAA Countries', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14886, 841, 35, '29', 'cities', 'Cascaded NOAA Cities', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14887, 841, 36, '0', 'sigafrique', 'Cascaded SIGAFRIQUE data', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14888, 841, 37, '36', 'geofault10', 'Cascaded geologic faults 10 m', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14889, 841, 38, '36', 'geoform10', 'Cascaded geologic formations 10 m', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14890, 841, 39, '36', 'towns', 'Cascaded towns', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14891, 841, 40, '36', 'mainrivers', 'Cascaded main water courses and inland water bodie', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14892, 841, 41, '36', 'water', 'Cascaded water courses', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14893, 841, 42, '36', 'railway', 'Cascaded railway network', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14894, 842, 0, '', 'Tsunami_Disaster_Map', 'Tsunami_Diasaster_Data', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14895, 842, 1, '0', 'Satellite_Imagery', 'Satellite_Imagery', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14896, 842, 2, '1', 'GAEL_WORLD_MARCH', 'ENVISAT MERIS mosaic', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14897, 842, 3, '1', 'srtm_tiles', 'SRTM 90m DEM - unclassified', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14898, 842, 4, '1', 'thai-LandsatTrue', 'Landsat Mosaic of Thailand', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14899, 842, 5, '1', 'sri_landsat', 'Landsat Mosaic of Sri Lanka', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14900, 842, 6, '0', 'Physical_Geography', 'Physical_Geography', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14901, 842, 7, '6', 'GTOPO30:Foundation', 'Global 30 Second Elevations', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14902, 842, 8, '6', 'RELIEF:Foundation', 'Two Minute Shaded Relief', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14903, 842, 9, '6', 'Bathymetry', 'Bathymetry', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14904, 842, 10, '6', 'Topography', 'Topography', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14905, 842, 11, '6', 'Hillshading', 'Hillshading', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14906, 842, 12, '6', 'CONTOURL_ELEV_1M:Foundation', 'Elevation Contours', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14907, 842, 13, '0', 'Disaster_Info', 'Disaster_Info', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14908, 842, 14, '13', 'locations', 'Disaster Point Locations', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14909, 842, 15, '13', 'faults', 'Fault Lines', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14910, 842, 16, '13', 'Wave_Heights', 'Wave Heights', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14911, 842, 17, '13', 'earthquakes', 'Recent Earthquakes', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14912, 842, 18, '13', 'epicenter', 'Epicenter of the Earthquake', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14913, 842, 19, '0', 'Political', 'Political', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14914, 842, 20, '19', 'World_WMS-WorldGen', 'World Countries', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14915, 842, 21, '19', 'Coastlines', 'Coastlines', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14916, 842, 22, '19', 'Borders', 'Borders', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14917, 842, 23, '19', 'oceans', 'World Oceans Labels', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14918, 842, 24, '19', 'Cities', 'World Cities', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14919, 842, 25, '0', 'Affected_Country_Statistics', 'Affected_Country_Statistics', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14920, 842, 26, '25', 'gdp', 'Gross Domestic Product (GDP)', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14921, 842, 27, '25', 'gdpper', 'Gross Domestic Product (GDP) per capita', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14922, 842, 28, '25', 'extdebt', 'External Debt', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14923, 842, 29, '25', 'density', 'Population Density (per sq. km)', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14924, 842, 30, '25', 'population', '2004 Population', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14925, 842, 31, '25', 'deaths', 'Total Deaths Per Country', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14926, 842, 32, '25', 'SriLanka_deaths', 'Sri Lanka Total Deaths by Region', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14927, 842, 33, '25', 'SriLanka_injured', 'Sri Lanka Total injuries by Region', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14928, 842, 34, '25', 'SriLanka_missing', 'Sri Lanka Total missing persons by Region', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14929, 842, 35, '25', 'SriLanka_displaced', 'Sri Lanka Total Displaced Population by Region', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14930, 842, 36, '25', 'SriLanka_camps', 'Sri Lanka Total camps by Region', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14931, 842, 37, '0', 'Infrastructure', 'Infrastructure', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14932, 842, 38, '37', 'BUILTUPA_POP_1M:Foundation', 'Built-Up Areas', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14933, 842, 39, '37', 'ROADL_TRANS_1M:Foundation', 'Roads', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14934, 843, 0, '', '', 'hazards', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14935, 843, 1, '0', 'Ambient Population 2002 (per 30 arc seconds)', 'Ambient Population 2002 (per 30 arc seconds)', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14936, 843, 2, '0', 'Elevation/Bathymetry', 'Elevation/Bathymetry', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14937, 843, 3, '0', 'Continents', 'Continents', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14938, 843, 4, '0', 'Lakes', 'Lakes', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14939, 843, 5, '0', 'Rivers', 'Rivers', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14940, 843, 6, '0', 'Countries', 'Countries', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14941, 843, 7, '0', 'States', 'States', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14942, 843, 8, '0', 'Cities', 'Cities', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14943, 843, 9, '0', 'Plate Boundaries', 'Plate Boundaries', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14944, 843, 10, '0', 'Volcanoes', 'Volcanoes', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14945, 843, 11, '0', 'Tsunami Events with runups', 'Tsunami Events with runups', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14946, 843, 12, '0', 'Tsunami Events with slides', 'Tsunami Events with slides', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14947, 843, 13, '0', 'Tsunami Events', 'Tsunami Events', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14948, 843, 14, '0', 'Tsunami Runups', 'Tsunami Runups', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14949, 843, 15, '0', 'Significant Earthquakes with slides', 'Significant Earthquakes with slides', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14950, 843, 16, '0', 'Significant Earthquakes', 'Significant Earthquakes', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14951, 844, 0, '', '', 'CustomWeather Map Server', 0, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14952, 844, 1, '0', 'cite:BasicPolygons', 'cite:BasicPolygons', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14953, 844, 2, '0', 'cite:Bridges', 'cite:Bridges', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14954, 844, 3, '0', 'cite:BuildingCenters', 'cite:BuildingCenters', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14955, 844, 4, '0', 'cite:Buildings', 'cite:Buildings', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14956, 844, 5, '0', 'cite:DividedRoutes', 'cite:DividedRoutes', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14957, 844, 6, '0', 'cite:Forests', 'cite:Forests', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14958, 844, 7, '0', 'cite:Lakes', 'cite:Lakes', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14959, 844, 8, '0', 'cite:MapNeatline', 'cite:MapNeatline', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14960, 844, 9, '0', 'cite:NamedPlaces', 'cite:NamedPlaces', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14961, 844, 10, '0', 'cite:Ponds', 'cite:Ponds', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14962, 844, 11, '0', 'cite:RoadSegments', 'cite:RoadSegments', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14963, 844, 12, '0', 'cite:Streams', 'cite:Streams', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14964, 844, 13, '0', 'airport_delay', 'airport_delay', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14965, 844, 14, '0', 'anim', 'anim', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14966, 844, 15, '0', 'au_radar', 'au_radar', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14967, 844, 16, '0', 'au_radar_stations', 'au_radar_stations', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14968, 844, 17, '0', 'base', 'base', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14969, 844, 18, '0', 'borders', 'borders', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14970, 844, 19, '0', 'coasts', 'coasts', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14971, 844, 20, '0', 'conditions', 'conditions', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14972, 844, 21, '0', 'contour_fire_danger', 'contour_fire_danger', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14973, 844, 22, '0', 'contour_high', 'contour_high', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14974, 844, 23, '0', 'contour_jet_stream', 'contour_jet_stream', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14975, 844, 24, '0', 'contour_low', 'contour_low', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14976, 844, 25, '0', 'contour_precip', 'contour_precip', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14977, 844, 26, '0', 'contour_pressure', 'contour_pressure', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14978, 844, 27, '0', 'contour_syn_precip', 'contour_syn_precip', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14979, 844, 28, '0', 'conus_ir_satellite_4km', 'conus_ir_satellite_4km', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14980, 844, 29, '0', 'counties', 'counties', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14981, 844, 30, '0', 'earthquakes', 'earthquakes', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14982, 844, 31, '0', 'eqc', 'eqc', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14983, 844, 32, '0', 'forecasts', 'forecasts', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14984, 844, 33, '0', 'frontlines', 'frontlines', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14985, 844, 34, '0', 'future_lightning', 'future_lightning', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14986, 844, 35, '0', 'gazetteer', 'gazetteer', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14987, 844, 36, '0', 'geom', 'geom', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14988, 844, 37, '0', 'global_ir_satellite_10km', 'global_ir_satellite_10km', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14989, 844, 38, '0', 'hurricanes', 'hurricanes', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14990, 844, 39, '0', 'interstates', 'interstates', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14991, 844, 40, '0', 'jetstream', 'jetstream', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14992, 844, 41, '0', 'label', 'label', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14993, 844, 42, '0', 'land_sea_mask', 'land_sea_mask', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14994, 844, 43, '0', 'legend', 'legend', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14995, 844, 44, '0', 'lightning', 'lightning', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14996, 844, 45, '0', 'maple', 'maple', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14997, 844, 46, '0', 'maple_raster', 'maple_raster', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14998, 844, 47, '0', 'marine_zones', 'marine_zones', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14999, 844, 48, '0', 'pacus_ir_satellite_4km', 'pacus_ir_satellite_4km', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15000, 844, 49, '0', 'post_borders', 'post_borders', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15001, 844, 50, '0', 'radar', 'radar', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15002, 844, 51, '0', 'radar_mask', 'radar_mask', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15003, 844, 52, '0', 'rivers', 'rivers', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15004, 844, 53, '0', 'severe_warnings', 'severe_warnings', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15005, 844, 54, '0', 'severe_watches', 'severe_watches', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15006, 844, 55, '0', 'state_borders', 'state_borders', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15007, 844, 56, '0', 'storm_track', 'storm_track', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15008, 844, 57, '0', 'template', 'template', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15009, 844, 58, '0', 'wide_conus_ir_satellite_4km', 'wide_conus_ir_satellite_4km', 1, 0, 0, '', NULL, NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15010, 844, 59, '0', 'zones', 'zones', 1, 0, 0, '', NULL, NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19188, 624, 9, '0', '13', 'Beschriftung Fliessgewaesser', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19189, 624, 10, '0', '18', 'Beschriftung Einzugsgebiete', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19214, 786, 1, '0', 'bw', 'Graustufen', 0, 0, 0, '', '', 'bw');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19215, 786, 3, '1', 'ortho_pan06', 'Sachsen 2005/06', 0, 1, 9999, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19216, 786, 4, '1', 'ortho_flut', 'Flut 2002', 0, 1, 20000, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19217, 786, 5, '0', 'ir', 'Farbe (infrarot)', 0, 0, 0, '', '', 'ir');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19220, 786, 6, '5', 'ortho_cir06', 'Sachsen 2005/06', 0, 1, 9999, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19221, 786, 7, '0', 'c', 'Farbe (RGB)', 0, 0, 0, '', '', 'c');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19223, 786, 8, '7', 'ortho_color', 'Mittelsachsen 2002', 0, 1, 20000, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19225, 786, 9, '7', 'ortho_rgb06_lowres', 'Sachsen 2005/06 LowRes', 0, 9999, 1000000, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19227, 786, 10, '7', 'ortho_rgb06', 'Sachsen 2005/06', 0, 1, 9999, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14270, 789, 4, '2', 'tk100i', 'TK 100 - Hoehenlinien', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK100ISO');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14271, 789, 5, '2', 'tk100v', 'TK 100 - Vegetation', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK100VEG');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14269, 789, 6, '2', 'tk100g', 'TK 100 - Grundriss', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK100GRU');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14267, 789, 7, '2', 'tk100s', 'TK 100 - Schriften', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK100SCHR');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14272, 789, 8, '0', 'tk50', 'TK 50', 0, 9382, 23456, '', '', 'FREETK:MS:FREETK:');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14273, 789, 9, '8', 'tk50w', 'TK 50 - Gewaesser', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK50GEW');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14275, 789, 10, '8', 'tk50i', 'TK 50 - Hoehenlinien', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK50ISO');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14276, 789, 11, '8', 'tk50v', 'TK 50 - Vegetation', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK50VEG');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14274, 789, 12, '8', 'tk50g', 'TK 50 - Grundriss', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK50GRU');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19235, 789, 13, '0', 'tk25', 'TK 25', 0, 4691, 9382, '', '', 'FREETK:MS:FREETK:');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19236, 789, 14, '13', 'tk25w', 'TK 25 - Gewaesser', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK25GEW');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19237, 789, 15, '13', 'tk25i', 'TK 25 - Hoehenlinien', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK25ISO');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19238, 789, 16, '13', 'tk25v', 'TK 25 - Vegetation', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK25VEG');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19239, 789, 17, '13', 'tk25g', 'TK 25 - Grundriss', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK25GRU');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19241, 789, 18, '0', 'tk10', 'TK 10', 0, 94, 4691, '', '', 'FREETK:MS:FREETK:');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19242, 789, 19, '18', 'tk10w', 'TK 10 - Gewaesser', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK10GEW');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19243, 789, 20, '18', 'tk10i', 'TK 10 - Hoehenlinien', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK10ISO');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19190, 328, 0, '', 'verfügbare Layer', 'verfügbare Layer', 0, 0, 0, '', '', 'Web Map Service auf Basis des Smallworld GIS');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3385, 328, 1, '0', 'Autobahn', 'Autobahn', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3386, 328, 2, '0', 'Bundesstr.', 'Bundesstr.', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3387, 328, 3, '0', 'Landesstr.', 'Landesstr.', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3388, 328, 4, '0', 'Kreisstr.', 'Kreisstr.', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3393, 328, 5, '0', 'Aeste', 'Äste', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19191, 328, 6, '0', 'Netzknoten', 'Netzknoten', 1, 0, 68150, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19192, 328, 7, '0', 'Nullpunkte', 'Nullpunkte', 1, 0, 50110, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19193, 328, 8, '0', 'AS-Nummern', 'AS-Nummern', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19194, 328, 9, '0', 'AS-Namen', 'AS-Namen', 1, 0, 68150, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19195, 328, 10, '0', 'Strassenbez.', 'Straßenbez.', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19196, 328, 11, '0', 'Abschnittsnr.', 'Abschnittsnr.', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3391, 328, 12, '0', 'Bauwerke', 'Bauwerke', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19197, 328, 13, '12', 'Bauwerkslage', 'Bauwerkslage', 1, 0, 50110, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19198, 328, 14, '12', 'Bauwerksnr.', 'Bauwerksnr.', 1, 0, 50110, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19199, 328, 15, '0', 'Verwaltungsbezirke', 'Verwaltungsbezirke', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19200, 328, 16, '15', 'Bundesland', 'Bundesland', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19201, 328, 17, '15', 'Regierungsbezirke', 'Regierungsbezirke', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19202, 328, 18, '15', 'Kreise_/_kreisfreie_Staedte', 'Kreise / kreisfreie Städte', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19203, 328, 19, '15', 'Gemeinden', 'Gemeinden', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19204, 328, 20, '0', 'Rasterkarten', 'Rasterkarten', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19205, 328, 21, '20', 'Strassenkarte', 'Straßenkarte', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7523, 584, 6, '0', 'OBBA_SQUARE', 'Ontario Breeding Bird Atlas 10 km Squares', 1, 0, 0, '', '', 'A sampling unit used by the Ontario Breeding Bird Atlas to collect breeding evidence data for all bird species within the Province of Ontario.  Squares are based upon the Universal Transverse Mercator (UTM) grid system, NAD83, and measure 10Km by 10Km except near UTM zone boundaries, where they are smaller.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7524, 584, 7, '0', 'OBBA_REGION', 'Ontario Breeding Bird Atlas Administrative Regions', 1, 0, 0, '', '', 'An administrative unit that is used for local bird atlas co-ordination, which is based on bioregions and access.  Each region is assigned a Regional Coordinator who administers bird surveys within their region.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7525, 584, 8, '0', 'OBBA_BLOCK', 'Ontario Breeding Bird Atlas 100 km Blocks', 1, 0, 0, '', '', 'A sampling unit used by the Ontario Breeding Bird Atlas to collect breeding evidence data for all bird species within the Province of Ontario.  Blocks are based upon the Universal Transverse Mercator (UTM) grid system, NAD83, and measure 100Km by 100Km except near UTM zone boundaries, where they are smaller.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7526, 584, 9, '0', 'OWLS', 'Nocturnal Owl Survey Locations', 1, 0, 0, '', '', 'A volunteer-based program that monitors the abundance of owl species across Canada by means of broadcast surveys.  Ontario survey locations are currently available through this service.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7527, 584, 10, '0', 'BBS_PT', 'Breeding Bird Survey Route Start Points', 1, 0, 0, '', '', 'The Breeding Bird Survey, initiated in 1966, is one of the oldest surveys of breeding birds in North America. It is conducted primarily by volunteers, who follow a predetermined, roadside route each year at the height of the breeding season.  This layer portrays the start point for each BBS route in Canada.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19228, 834, 0, '', 'DE_aerial02', 'DE_aerial02', 0, 0, 0, '', '', 'The Delaware 2002 Aerial Imagery Map Service serves statewide orthophotography as captured in 2002. The State of Delaware contracted with EarthData International to develop 0.25-meter resolution color infrared digital ortho-photos for the entire state. Map scale of the photography is approximately 1:2,400. Airphotos were taken in March and April, 2002, digitized and georeferenced to Delaware State Plane NAD83 meters. This data is available as an ArcIMS map service, a WMS map service, original 1-meter raw data files. ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19246, 828, 0, '', 'CAPAS', 'CAPAS', 0, 0, 0, '', '', 'IDERIOJA Gobierno de La Rioja OGC WMS');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19247, 828, 1, '0', 'Elementos_hidrográficos', 'Elementos_hidrográficos', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19248, 828, 2, '0', 'Hojas_cartográficas_1-5000', 'Hojas_cartográficas_1-5000', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19249, 828, 3, '0', 'Manzanas_de_los_núcleos_urbanos', 'Manzanas_de_los_núcleos_urbanos', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10106, 634, 0, '', 'Location', 'Point locations', 0, 0, 0, '', '', 'This service provides approximate point locations for various     themes.   ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10107, 634, 1, '0', 'city_austral', 'Australasian Cities', 0, 0, 0, '', '', '           Location of cities in the Australasian region.         ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10108, 634, 2, '0', 'capital_aus', 'Australian Capital Cities', 0, 0, 0, '', '', '           Location of capital cities in Australia.         ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10109, 634, 3, '0', 'town_aus', '           Some Australian towns         ', 0, 0, 0, '', '', '           Location of some towns in Australia.         ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10110, 634, 4, '0', 'wastewet', '           Wastewater artificial wetlands listed as important wetlands           in Australia         ', 0, 0, 0, '', '', '           Location of artificial wetlands that are comprised primarily of           waste water as listed in "A Directory of Important Wetlands in           Australia Database".         ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14364, 800, 2, '0', 'doq', '1991 doqs', 0, 802, 0, '', 'http://www.lmic.state.mn.us/chouse/metadata/doq.html', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14366, 800, 3, '0', 'metro', '2004 metro area NGA', 0, 241, 0, '', 'http://mcmcweb.er.usgs.gov/catalog/metadata/Minneapolis-StPaul_2004.html', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19222, 800, 4, '0', 'bw1997', '1997 Met Council BW', 0, 481, 0, '', 'http://www.datafinder.org/metadata/orthos1997.htm', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19224, 800, 5, '0', 'bw2000', '2000 Met Council BW', 0, 481, 0, '', 'http://www.datafinder.org/metadata/orthos2000.htm', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19229, 640, 4, '0', 'srtm_mag', 'SRTM reflectance magnitude, 30m', 0, 20044, 0, '', '', '   This is the radar reflectance image produced by the SRTM mission. It is the best available snapshot of the surface of the earth, being the highest resolution image collected in the shortest ammount of time, with near-global 30m coverage collected during an 11-day Endeavour mission, in February of 2000. Five basic bands are available as WMS styles, ss1, ss2, ss3 and ss4 being SRTM image subswath averages, the "all" style being an average of the four subswath composites. The "default" style is derived from the "all" band, using an arbitrary color map to make more detail visible. The subswath composites also available as WMS bands, band 0 correspoinding to ss1, 1 to "ss2", 2 to "ss3", 3 to "ss4" and 5 to "all". A radar image has little in common with a visual image, depending mostly on the material and orientation of the object. Areas with low detail such as lakes and sand tend to have no reflection, and very steep terrain can obscure certain areas from the side look ing SRTM instrument, both fenomena generating voids in the SRTM reflectance image. Urban areas tend to have stronger reflectance. The banding artifacts still visible in the images are the result of the combination of data from multiple orbits or are intrinsic to the SRTM instrument.       ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19230, 640, 5, '0', 'daily_terra_721', 'Daily composite of MODIS-TERRA 721 pseudocolor', 0, 250550, 0, '', '', ' 	Daily generated mosaic of TERRA images released by the MODIS Rapid Response System. 	Updates every day, at about 1200Z, with images taken during the previous day. 	Maximum resolution is 8 arcseconds per pixel. The WMS "time" dimension can be used to retrieve past data.         The 721 band mapping is used to identify burnt and flooded areas.       ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19231, 640, 6, '0', 'daily_aqua_721', 'Daily composite of MODIS-AQUA 721 pseudocolor', 0, 250550, 0, '', '', ' 	Daily generated mosaic of the AQUA images released by the MODIS Rapid Response System. 	Updates every day, at about 1200Z, with images taken during the previous day. 	Maximum resolution is 8 arcseconds per pixel. The WMS "time" dimension can be used to retrieve past data.         The 721 band mapping is used to identify burnt and flooded areas.       ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19232, 640, 7, '0', 'daily_terra_ndvi', 'Daily composite of MODIS-TERRA images, NDVI processing', 0, 250550, 0, '', '', ' 	Daily generated mosaic of TERRA images released by the MODIS Rapid Response System. 	Updates every day, at about 1200Z, with images taken during the previous day. 	Maximum resolution is 8 arcseconds per pixel. The WMS "time" dimension can be used to retrieve past data.         The Normalized Difference Vegetation Index (NDVI) is strongly correlated with the plant density and state.       ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19234, 640, 8, '0', 'daily_aqua_ndvi', 'Daily composite of MODIS-AQUA images, NDVI processing', 0, 250550, 0, '', '', ' 	Daily generated mosaic of the AQUA images released by the MODIS Rapid Response System. 	Updates every day, at about 1200Z, with images taken during the previous day. 	Maximum resolution is 8 arcseconds per pixel. The WMS "time" dimension can be used to retrieve past data.         The Normalized Difference Vegetation Index (NDVI) is strongly correlated with the plant density and state.       ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10171, 640, 9, '0', 'daily_terra', 'Daily composite of MODIS-TERRA images', 0, 250550, 0, '', '', ' 	Daily generated mosaic of TERRA images released by the MODIS Rapid Response System. 	Updates every day, at about 1200Z, with images taken during the previous day. 	Maximum resolution is 8 arcseconds per pixel. The WMS "time" dimension can be used to retrieve past data.       ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10177, 640, 16, '0', 'us_ned', 'United States elevation, 30m', 0, 40088, 0, '', '', '         Continental United States elevation, produced from the USGS National Elevation.         The default style is scaled to 8 bit from the orginal floating point data.       ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10370, 648, 1, '0', 'hangneigung', 'Hangneigung', 1, 200, 374944, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10371, 648, 2, '0', 'Fliessgewaesser', 'Fliessgewaesser', 1, 200, 374944, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19218, 792, 0, '', 'TKVV', 'TKVV', 0, 200, 200440, '', '', 'wms reference implementation');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14288, 792, 1, '0', 'Thueringer_Orthofotos', 'Thueringer_Orthofotos', 0, 0, 0, '', '', 'cascaded WMS layers remote WFS and remote WCS examples');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14289, 792, 2, '1', 'Orthophotos_TH-2m', 'Orthophotos_TH-2m', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14290, 792, 3, '0', 'TK50', 'TK50', 0, 0, 0, '', '', 'cascaded WMS layers remote WFS and remote WCS examples');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14291, 792, 4, '3', 'Top.Karte_50_gesamt', 'Top.Karte_50_gesamt', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14292, 792, 5, '3', 'Grundriss', 'Grundriss', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14293, 792, 6, '3', 'Gewaesser', 'Gewaesser', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14294, 792, 7, '3', 'Hoehenschichten', 'Hoehenschichten', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14295, 792, 8, '3', 'Strassen', 'Strassen', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14296, 792, 9, '3', 'Wald', 'Wald', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14759, 834, 1, '0', 'ortho2002', '2002 Aerial Imagery', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10178, 640, 17, '0', 'us_elevation', 'Digital Elevation Map of the United States, DTED dataset, 3 second resolution, grayscale', 0, 90198, 0, '', '', ' 	DTED Level 3 US elevation.  The default style is scaled to 8 bit. 	It is possible to request the elevation data in meters by the short_int tyle and requesting PNG format. The resulting PNG file will be a unsigned 16 bit per pixel image. The values are elevation in meters, zero clipped (no negative values).       ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19206, 670, 0, '', 'waldtyp', 'waldtyp', 1, 0, 0, '', '', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10989, 670, 1, '0', 'Waldtyp_50', 'Waldtyp_50', 0, 37494, 187472, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15735, 854, 0, '', 'wesseling_stadtkarte', 'Stadtkarte', 0, 0, 0, '', '', NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15736, 854, 1, '0', 'Nutzung', 'Nutzung', 0, 0, 0, '', '', NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15737, 854, 2, '1', 'wes_dsk_patch1', 'wes_dsk_patch1', 0, 0, 0, '', '', NULL);
@@ -4095,52 +3268,19 @@
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15753, 854, 18, '17', 'wes_dsk_strnamen_umn_1_t', 'wes_dsk_strnamen_umn_1_t', 0, 0, 0, '', '', NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15754, 854, 19, '17', 'wes_dsk_strnamen_umn_2_t', 'wes_dsk_strnamen_umn_2_t', 0, 0, 4000, '', '', NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15755, 854, 20, '0', 'wes_dsk_patch', 'wes_dsk_patch', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19172, 909, 0, '', 'germany_wfs_myedit', 'MyEdit Elements', 0, 1, 0, '', '', 'germany_wfs_places');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19173, 909, 1, '0', 'my_polygons', 'my polygons', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19174, 909, 2, '0', 'my_lines', 'my lines', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19175, 909, 3, '0', 'my_points', 'my points', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10990, 670, 2, '0', 'Waldtyp_Real', 'Waldtyp_Real', 0, 37494, 187472, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19219, 640, 0, '', 'OnEarth Web Map Server', 'OnEarth Web Map Server', 0, 0, 0, '', '', 'WMS Server maintained by JPL, worldwide satellite imagery.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19250, 828, 4, '0', 'Masas_de_agua', 'Masas_de_agua', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19252, 828, 5, '0', 'Municipios', 'Municipios', 1, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15337, 407, 0, '', 'Mapbender', 'Mapbender User', 0, 1, 0, '', '', 'Mapbender User Overview (Mapbender User/Postgis)');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19254, 828, 6, '0', 'Ortofoto_2004', 'Ortofoto_2004', 0, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15338, 407, 1, '0', 'Mapbender_User', 'Mapbender User', 0, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Mapbender');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15339, 407, 2, '0', 'Mapbender_Names', 'Mapbender Info', 1, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Mapbender');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19172, 909, 0, '', 'germany_wfs_myedit', 'MyEdit Elements', 0, 1, 0, '', '', 'This is the demo WMS for the Mapbender digitize test-gui.');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18068, 859, 0, '', '', 'Geobasisdaten', 0, 0, 0, '', '', NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18069, 859, 1, '0', '1', 'Digitale Orthophotos', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18119, 866, 0, '', '', 'hochwasser', 1, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18120, 866, 1, '0', '8', 'rhein-hq100-odeich', 1, 200, 749888, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18121, 866, 2, '0', '9', 'rhein-hq100-mdeich', 1, 200, 749888, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18122, 866, 3, '0', '6', 'rhein-hq200-odeich', 1, 200, 749888, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18123, 866, 4, '0', '7', 'rhein-hq200-mdeich', 1, 200, 749888, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18124, 866, 5, '0', '4', 'rhein-hq500-odeich', 1, 200, 749888, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18125, 866, 6, '0', '5', 'rhein-hq500-mdeich', 1, 200, 749888, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18126, 866, 7, '0', '0', 'vereinf_Verfahren', 1, 200, 374944, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18127, 866, 8, '0', '1', 'Sonstige_UESG', 1, 200, 374944, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18128, 866, 9, '0', '2', 'Historische_UESG', 1, 200, 374944, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18129, 866, 10, '0', '3', 'neuere_Berechnungsverfahren', 1, 200, 374944, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18130, 866, 11, '0', '18', 'Seen', 1, 200, 374944, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18131, 866, 12, '0', '19', 'Talsperre', 1, 200, 374944, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18132, 867, 0, '', '', 'stobo', 1, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18133, 867, 1, '0', 'Bleibelastung der Ackerboeden in mg pro kg', 'Bleibelastung der Ackerboeden in mg pro kg', 1, 22497, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18134, 867, 2, '0', 'Cadmiumbelastung der Ackerboeden in mg pro kg', 'Cadmiumbelastung der Ackerboeden in mg pro kg', 1, 22497, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18135, 867, 3, '0', 'Zinkbelastung der Ackerboeden in mg pro kg', 'Zinkbelastung der Ackerboeden in mg pro kg', 1, 22497, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18136, 867, 4, '0', 'Bleibelastung der Gartenboeden in mg pro kg', 'Bleibelastung der Gartenboeden in mg pro kg', 1, 22497, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18137, 867, 5, '0', 'Cadmiumbelastung der Gartenboeden in mg pro kg', 'Cadmiumbelastung der Gartenboeden in mg pro kg', 1, 22497, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18138, 867, 6, '0', 'Zinkbelastung der Gartenboeden in mg pro kg', 'Zinkbelastung der Gartenboeden in mg pro kg', 1, 22497, 74989, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18139, 867, 7, '0', 'Bleibelastung der Gruenlandboeden in mg pro kg', 'Bleibelastung der Gruenlandboeden in mg pro kg', 1, 22497, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18140, 867, 8, '0', 'Cadmiumbelastung der Gruenlandboeden in mg pro kg', 'Cadmiumbelastung der Gruenlandboeden in mg pro kg', 1, 22497, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18141, 867, 9, '0', 'Zinkbelastung der Gruenlandboeden in mg pro kg', 'Zinkbelastung der Gruenlandboeden in mg pro kg', 1, 22497, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18142, 867, 10, '0', 'Probenahmenstandorte in NRW differenziert nach Nutzungen', 'Probenahmenstandorte in NRW differenziert nach Nutzungen', 1, 22497, 0, '', '', NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18143, 868, 0, '', '', 'Gelaendemodell', 0, 0, 0, '', '', NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18144, 868, 1, '0', 'DGM50', 'DGM50', 0, 26075, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18145, 869, 0, '', '', 'linfos', 1, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18146, 869, 1, '0', '51', 'Vegetationstypen', 1, 0, 150214, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18147, 869, 2, '0', '49', 'Vegetationsaufnahmen', 1, 0, 150214, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18148, 869, 3, '0', '45', 'Naturraeumliche Haupteinheiten', 1, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18149, 869, 4, '0', '43', 'Landschaftsschutzgebiete', 1, 0, 150214, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18150, 869, 5, '0', '42', 'Stand der Landschaftsplanung', 1, 0, 150214, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18151, 869, 6, '0', '32', 'FFH-Gebiete', 1, 0, 150214, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18152, 869, 7, '0', '31', 'Vogelschutzgebiete', 1, 0, 150214, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18153, 869, 8, '0', '28', 'Biotoptypen', 1, 0, 150214, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18154, 869, 9, '0', '3', 'Biotopkataster', 1, 0, 150214, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18155, 869, 10, '0', '1', 'Naturschutzgebiete', 1, 0, 150214, '', '', NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18159, 871, 0, '', 'MUENSTER', 'Geobasisdaten Muenster', 0, 0, 0, '', '', NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18160, 871, 1, '0', 'splan', 'Stadtplan', 0, 2400, 2000000, '', '', NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18161, 871, 2, '0', 'luftb', 'Luftbilder', 0, 375, 3900, '', '', NULL);
@@ -4150,71 +3290,21 @@
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18165, 871, 6, '4', 'gebaeude', 'Gebaeude', 0, 1, 2500, '', '', NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18166, 871, 7, '4', 'linien', 'Topographie', 0, 1, 2500, '', '', NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18167, 871, 8, '4', 'texte', 'Beschriftung', 0, 1, 2500, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18168, 872, 0, '', '', 'WV_WMS', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18169, 872, 1, '0', 'rheinplus', 'rheinplus', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18170, 872, 2, '0', 'uesgobwup', 'uesgobwup', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18171, 872, 3, '0', 'uesgmorsbach', 'uesgmorsbach', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18172, 872, 4, '0', 'klaerwerkseinzugsgebiete', 'klaerwerkseinzugsgebiete', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18173, 872, 5, '0', 'entwaesserungssystem', 'entwaesserungssystem', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18174, 872, 6, '0', 'gezgross', 'gezgross', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18175, 872, 7, '0', 'gezklein', 'gezklein', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18176, 872, 8, '0', 'ueberleitungsgebiete', 'ueberleitungsgebiete', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18177, 872, 9, '0', 'verbandsgebiet', 'verbandsgebiet', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18178, 872, 10, '0', 'gsg5', 'gsg5', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18179, 872, 11, '0', 'gsg3', 'gsg3', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18180, 872, 12, '0', 'gsg1', 'gsg1', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18181, 872, 13, '0', 'gewaesser', 'gewaesser', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18182, 872, 14, '0', 'verrohrungen', 'verrohrungen', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18183, 872, 15, '0', 'verlaufaenderungen', 'verlaufaenderungen', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18184, 872, 16, '0', 'gewaesserbeschriftung', 'gewaesserbeschriftung', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18185, 872, 17, '0', 'talsperren', 'talsperren', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18186, 872, 18, '0', 'sammler', 'sammler', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18187, 872, 19, '0', 'stationierung', 'stationierung', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18188, 872, 20, '0', 'fotos_am_gewaesser', 'fotos_am_gewaesser', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18189, 872, 21, '0', 'limnologie', 'limnologie', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18190, 872, 22, '0', 'niederschlagsstationen', 'niederschlagsstationen', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18191, 872, 23, '0', 'pegel', 'pegel', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18192, 872, 24, '0', 'wehre', 'wehre', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18193, 872, 25, '0', 'fischaufstiege', 'fischaufstiege', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18194, 872, 26, '0', 'hrb', 'hrb', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18195, 872, 27, '0', 'regenbeckenwv', 'regenbeckenwv', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18196, 872, 28, '0', 'klaerwerke', 'klaerwerke', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18205, 881, 0, '', 'Gebietsgliederung', 'Gebietsgliederung', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18206, 881, 1, '0', 'Stadtbezirke', 'Stadtbezirke', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18207, 881, 2, '1', 'stadtbezirke_pl', 'stadtbezirke_pl', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18208, 881, 3, '1', 'stadtbezirke_t', 'stadtbezirke_t', 0, 0, 300000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18209, 881, 4, '0', 'Statistische_Bezirke', 'Statistische_Bezirke', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18210, 881, 5, '4', 'statist_bez_pl', 'statist_bez_pl', 0, 0, 300000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18211, 881, 6, '4', 'statist_bez_t', 'statist_bez_t', 0, 0, 300000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18212, 881, 7, '0', 'Verkehrszellen', 'Verkehrszellen', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18213, 881, 8, '7', 'verkehrszellen_pl', 'verkehrszellen_pl', 0, 0, 300000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18214, 881, 9, '7', 'verkehrszellen_t', 'verkehrszellen_t', 0, 0, 300000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18215, 881, 10, '0', 'Baubloecke', 'Baubloecke', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18216, 881, 11, '10', 'baubloecke_pl', 'baubloecke_pl', 0, 0, 100000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18217, 881, 12, '10', 'baubloecke_t', 'baubloecke_t', 0, 0, 100000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18218, 882, 0, '', 'Wahlen', 'Wahlen', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18219, 882, 1, '0', 'HINTERGRUNDKARTE', 'HINTERGRUNDKARTE', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18220, 882, 2, '1', 'stadtplan_grau_zoomst_1', 'stadtplan_grau_zoomst_1', 0, 135001, 300000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18221, 882, 3, '1', 'stadtplan_zoom3_01', '02_stadtplan', 0, 20001, 135000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18222, 882, 4, '1', 'stadtplan_zoom3_02', '03_stadtplan', 0, 12001, 20000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18223, 882, 5, '1', 'stadtplan_zoom3_03', '04_stadtplan', 0, 2751, 12000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18224, 882, 6, '1', 'dgk5_liste', 'Deutsche Grundkarte', 0, 0, 2750, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18225, 882, 7, '0', 'stadtplan_72dpi', 'stadtplan_uebersicht', 0, 300000, 1000000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18226, 882, 8, '0', 'Stadtbezirke', 'Stadtbezirke', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18227, 882, 9, '8', 'stadtbezirke_pl', 'stadtbezirke_pl', 0, 0, 300000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18228, 882, 10, '8', 'stadtbezirke_t', 'stadtbezirke_t', 0, 0, 300000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18229, 882, 11, '0', 'Wahlbezirke', 'Wahlbezirke', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18230, 882, 12, '11', 'wahlbezirke_pl', 'wahlbezirke_pl', 0, 0, 300000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18231, 882, 13, '11', 'wahlbezirke_t', 'wahlbezirke_t', 0, 0, 300000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18232, 882, 14, '0', 'Stimmbezirke', 'Stimmbezirke', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18233, 882, 15, '14', 'stimmbezirke_pl', 'stimmbezirke_pl', 0, 0, 300000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18234, 882, 16, '14', 'stimmbezirke_t', 'stimmbezirke_t', 0, 0, 300000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18235, 883, 0, '', '', 'Luftbilder', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18236, 883, 1, '0', '1', '$_nav_uebersicht', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18237, 883, 2, '0', '2', 'Stadtplan', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18238, 883, 3, '0', '5', 'Luftbilder 1999', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18239, 883, 4, '0', '8', 'Flurstuecksstruktur', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18240, 883, 5, '0', '9', 'Texte', 0, 0, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10153, 637, 0, '', 'Bathymetry', 'MapServer WMS Demo', 0, 50000, 0, '', '', 'This is a UMN WMS MapServer demonstration application for global elevation data.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10154, 637, 1, '0', 'etopo2', 'etopo2', 0, 50000, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10155, 637, 2, '0', 'ecbathy', 'ecbathy', 0, 50000, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10156, 637, 3, '0', 'gom', 'gom', 0, 50000, 2000000, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10157, 637, 4, '0', 'bbay', 'bbay', 0, 50000, 1000000, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10158, 637, 5, '0', 'gomctr', 'gomctr', 0, 50000, 749999, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10159, 637, 6, '0', 'world_line_simp', 'world_line_simp', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10160, 637, 7, '0', 'world_line', 'world_line', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19211, 637, 8, '0', 'alvin', 'alvin', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14109, 767, 6, '0', 'Edges', 'Edges', 1, 0, 0, '', '', 'Slubfurter Mental Map Survey 2000 - 2002: Edges are the linear elements not used or considered as paths by the observer. They are boundaries between two phases, linear breaks in continuity (eg. highways, shores, railroad lines, edges of built up areas, walls).(Lynch 1960: The Image of the City) ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14110, 767, 7, '0', 'Nodes', 'Nodes', 1, 0, 0, '', '', 'Slubfurter Mental Map Survey 2000 - 2002: Nodes are points, the strategic spots in a city into which an observer can enter, and which are the intensive foci to and from which he is traveling (e.g. intersections, street corner, play grounds, railway stations, core areas or polarizing center of districts, etc.). (Lynch 1960: The Image of the City)');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19207, 671, 0, '', 'wsg', 'wsg', 1, 0, 0, '', '', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10992, 671, 1, '0', 'Trinkwasser Zone 1 punktfoermig', 'Trinkwasser Zone 1 punktfoermig', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10993, 671, 2, '0', 'Trinkwasserschutzgebiete', 'Trinkwasserschutzgebiete', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14111, 767, 8, '0', 'Landmarks', 'Landmarks', 1, 0, 0, '', '', 'Slubfurter Mental Map Survey 2000 - 2002: Landmarks are another type of point reference, but in this case the observer does not enter within them, they are external (eg. distinctive reference points such as a building or a tower, a sign, a store, a statue, a natural feature in the landscape such as a mountain or even a tree). (Lynch 1960: The Image of the City)');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18248, 885, 2, '1', 'Autobahnen', 'Autobahnen', 0, 0, 0, '', '', NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18253, 885, 7, '6', 'NKAutobahnen', 'Netzknoten, Autobahnen', 0, 0, 0, '', '', NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18258, 885, 12, '11', 'NPAutobahnen', 'Nullpunkte, Autobahnen', 0, 0, 0, '', '', NULL);
@@ -4224,53 +3314,22 @@
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18270, 885, 24, '22', 'mZstOrtBundesstrassen', 'Zst-Orte Bundesstrassen', 0, 0, 0, '', '', NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18271, 885, 25, '22', 'mZstOrtLandesstrassen', 'Zst-Orte Landesstrassen', 0, 0, 0, '', '', NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18272, 885, 26, '22', 'mZstOrtKreisstrassen', 'Zst-Orte Kreisstrassen', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18274, 887, 0, '', '', 'BK50', 1, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18275, 887, 1, '0', 'bk50', 'bk50', 1, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19125, 903, 0, '', 'Brandenburg', 'DNM 25', 0, 100, 50000, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19173, 909, 1, '0', 'my_polygons', 'my polygons', 1, 0, 0, '', '', 'polygon');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14112, 767, 9, '0', 'CityWall', 'CityWall', 1, 0, 0, '', '', 'Slubfurter Stadtmauer:http://www.art.artpp.net/slubfurt/d/city/p1de_vita.html');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19174, 909, 2, '0', 'my_lines', 'my lines', 1, 0, 0, '', '', 'line, Linie');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19175, 909, 3, '0', 'my_points', 'my points', 1, 0, 0, '', '', 'point,Punkt,poi');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14113, 767, 10, '0', 'HotSpots', 'HotSpots', 1, 0, 0, '', '', 'Slubfurter Mental Map Survey 2000 - 2002: Nearest Neighbor Hierarchical Clustering - First Order; For each identified cluster a Standard Deviational Ellipse is calculated. Typically, one standard deviation will cover more than 50% of the cases, one and a half standard deviations will cover more than 90% of the cases, and two standard deviations will cover more than 99% of the cases, although the exact percentage will depend on the distribution (Levine, 2002).');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19006, 893, 0, '', 'Germany', 'Germany', 0, 1, 0, '', '', 'Germany');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19126, 903, 1, '0', 'land', 'Landkreise und kreisfreie Städte', 0, 100, 50000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19127, 903, 2, '0', 'ort', 'Ortschaften', 1, 1000, 50000, '', '', NULL);
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19007, 893, 1, '0', 'Topographie', 'topography', 0, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Topographie,Landschaft');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19079, 899, 0, '', 'infoprix', 'Infoprix', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19080, 899, 1, '0', 'Ajouter_un_Marche', 'Ajouter_un_Marche', 1, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19081, 899, 2, '0', 'Weltlaender', 'Etats', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19082, 899, 3, '0', 'Departmt', 'Departements', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19083, 899, 4, '0', 'Sousprefneu', 'Sous Prefectures', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19084, 899, 5, '0', 'rivlc', 'Rivieres et lacs', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19085, 899, 6, '0', 'Route2', 'Voies de communication', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19086, 899, 7, '0', 'localits', 'Localités', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19087, 899, 8, '0', 'Villes', 'Villes', 0, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19088, 899, 9, '0', 'Maerkte1', 'Marches', 1, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19089, 899, 10, '0', 'Nouveaux-Marches', 'Nouveaux-Marches', 1, 0, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19128, 903, 3, '0', 'wald', 'Waldflächen', 0, 1000, 50000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19129, 903, 4, '0', 'gruen', 'Grünflächen', 0, 1000, 50000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19146, 904, 8, '0', 'bstr', 'Bundesstraßen', 0, 200000, 1000000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19147, 904, 9, '0', 'astr', 'Autobahnen', 0, 200000, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19148, 904, 10, '0', 'kfz', 'Kfz-Zeichen', 0, 1000000, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19149, 905, 0, '', 'Brandenburg', 'DNM FÜK', 0, 50000, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19150, 905, 1, '0', 'flur', 'Flur', 1, 50000, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19151, 905, 2, '0', 'gema', 'Gemarkung', 1, 50000, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19152, 905, 3, '0', 'geme', 'Gemeinde', 1, 50000, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19153, 905, 4, '0', 'stadt', 'Kreisfreie Städte', 1, 50000, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19154, 905, 5, '0', 'kreis', 'Landkreise', 1, 50000, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19155, 906, 0, '', 'Brandenburg', 'DNM VG', 0, 50000, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19156, 906, 1, '0', 'berlin', 'Berliner Bezirke', 0, 50000, 1000000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19157, 906, 2, '0', 'geme', 'Gemeinde', 1, 50000, 1000000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19158, 906, 3, '0', 'kamt', 'Amtsfreie Gemeinde', 1, 50000, 1000000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19159, 906, 4, '0', 'amt', 'Ämter', 1, 50000, 1000000, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19160, 906, 5, '0', 'stadt', 'Kreisfreie Städte', 1, 50000, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19161, 906, 6, '0', 'kreis', 'Landkreise', 1, 50000, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19162, 906, 7, '0', 'land', 'Land', 0, 50000, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19163, 906, 8, '0', 'staat', 'Deutschland', 0, 50000, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19164, 906, 9, '0', 'ngeme', 'Namen der Gemeinden', 0, 50000, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19165, 906, 10, '0', 'nkamt', 'Namen der amtfreien Gemeinden', 0, 50000, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19166, 906, 11, '0', 'namt', 'Namen der Ämter', 0, 50000, 0, '', '', NULL);
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19167, 906, 12, '0', 'nkreis', 'KFZ Kennzeichen der Kreise', 0, 50000, 0, '', '', NULL);
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7519, 584, 2, '0', 'CBC_PT', 'Canadian Christmas Bird Count Locations', 1, 0, 0, '', '', 'A winter survey of bird populations conducted during the Christmas period - December 14 to January 5th inclusive.  More than 1800 counts are conducted each year across Canada, the United States and Latin America.  On a selected day within the count period, local birders count as many birds as possible within a 24 km (15 mile) diameter circle.  The Christmas Bird Count had long been organized on the continental scale by the New York-based National Audubon Society. In 2000, Audubon finalized an agreement with Bird Studies Canada that would see BSC partner with Audubon to coordinate CBCs in Canada.  This layer represents the centre point of all the Christmas Bird Counts conducted in Canada.  An accompanying layer (CBC_PY) contains the 24 km circles.');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19170, 908, 0, '', 'NRW', 'NRW', 0, 0, 140316, '', '', 'Nutzungsbedingungen: Sämtliche Rechte an diesem Produkt liegen beim Landesvermessungsamt NRW. Die Nutzung ist bis auf Widerruf kostenfrei. Der Nutzer muss sich vor jeder Nutzung beim Landesvermessungsamt NRW identifizieren und seine spezielle Nutzung mit Angabe des Verwendungszwecks und Umfang der Nutzung anmelden (Kontaktmöglichkeiten zum Landesvermessungsamt NRW siehe unten). Die Nutzung ist ausschließlich für Testzwecke und im Rahmen von GDI-Projekten zulässig; die Nutzung für kommerzielle Anwendungen ist ausdrücklich ausgeschlossen. Die mittelbare oder unmittelbare Weitergabe der Daten an Dritte ist auch in Verbindung mit weiteren Daten ohne ausdrückliche Genehmigung durch das Landesvermessungsamt NRW nicht zulässig. Der Nutzer ist verpflichtet, einen deutlichen Copyright-Hinweis auf das Landesvermessungsamt NRW als Dateneigentümer bei Visualisierungen jeder Art anzubringen.');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19171, 908, 1, '0', 'Raster:TK100_KMF:Farbkombination', 'Farbkombination', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19226, 789, 0, '', 'Topographische Karten', 'Topographische Karten', 0, 0, 0, '', '', 'SICAD Internet Suite V6.0A05 at http://www.landesvermessung.sachsen.de/sims/sicad-');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19008, 893, 2, '0', 'Grenze', 'border', 0, 750000, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Grenzen, border');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14266, 789, 2, '0', 'tk100', 'TK 100', 0, 23457, 117283, '', '', 'FREETK:MS:FREETK:');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19009, 893, 3, '0', 'Bundeslaender', 'federal states', 0, 750000, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Laender');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19010, 893, 4, '0', 'Staedte', 'places', 0, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Staedte in der BRD');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14268, 789, 3, '2', 'tk100w', 'TK 100 - Gewaesser', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK100GEW');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19011, 893, 5, '0', 'Postleitzahlbereiche', 'postcode areas', 1, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Postleitzahl,PLZ,postcode');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19012, 893, 6, '0', 'Bahnlinien', 'railroad lines', 0, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'railroad,Bahn,DB');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19013, 893, 7, '0', 'Fluesse', 'rivers', 0, 0, 1250000, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'river');
@@ -4279,43 +3338,1171 @@
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19016, 893, 10, '0', 'Postleitzahlbereichname', 'postcode areas (names)', 0, 0, 350000, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'PLZ');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19017, 893, 11, '0', 'Staedtenamen', 'places (names)', 0, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'city');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19018, 893, 12, '0', 'Bundeslaendernamen', 'federal states (names)', 0, 1000000, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Bundesland');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10179, 640, 18, '0', 'us_colordem', 'Digital Elevation Map of the United States, DTED dataset, 3 second resolution, hue mapped', 0, 90198, 0, '', '', ' 	The DTED Level 3 US elevation, mapped to a color image using the full spectrum. 	This result is not achievable by using SLD, so it is presented as a different layer.       ');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19251, 832, 0, '', 'ArcIMS MapService', 'ArcIMS MapService', 0, 0, 0, '', '', 'This is an OGC compliant MapService served by the USGS Technology Applications Team (TAT) from the USGS''s Fort Collins Science Center');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14558, 832, 1, '0', 'overview', 'Wetland Overview', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10415, 655, 0, '', 'SEACOOS Remotely-Sensed Imagery', 'SEACOOS Remotely-Sensed Imagery', 0, 0, 0, '', '', 'The SouthEast Atlantic Coastal Ocean Observing System (SEACOOS) is a regional partnership that has initiated an integrated coastal ocean observing system for a four-state region of the southeast U.S.  SEACOOS brings together many organizations witha vested interest in improved oceanographic information and in building an Integrated Ocean Observing System (IOOS). The IOOS seeks to address the needs and concerns of the larger coastal community.  SEACOOS endeavors to significantly increase the quantity and quality of environmental information that is needed to address critical scientific problems and societal issues including:  commercial, military, and recreational maritime operations; K-16 and public education; safety; weather prediction; public health related to waste disposal and harmful algal blooms; shore erosion; and fisheries management.    To accomplish this, SEACOOS uses observing systems that operate at the sub-regional level, collecting real-time information using buoys and other automated coastal sensors every few minutes.  It combines these data with real-time downlinks of satellite images that cover the region in a synoptic manner several times a day.  The founding institutions are research universities within the region, while members include state and federal agencies. The Institute for Marine Remote Sensing (IMaRS) of the College of Marine Science at the University of South Florida, and the Rosenstiel School of Marine and Atmospheric Sciences (RSMAS) of the University of Miami operate the satellite ground stations and generate the various satellite data products consumed by SEACOOS users.  The University of North Carolina at Chapel Hill, the University of South Florida, and the University of Miami produce the model output with hindcasting and forecasting capabilities..  A current list of partners and affiliates can be found at http://www.seacoos.org.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14559, 832, 2, '0', 'wetlands_low', 'Wetlands Low Res', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14560, 832, 3, '0', 'wetlands', 'Wetlands High Res', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19258, 655, 1, '0', 'etopo2_bathy_relief', 'TBA', 0, 0, 0, '', '', 'TBA');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19259, 655, 2, '0', 'etopo2_bathy_contour', 'TBA', 0, 0, 0, '', '', 'TBA');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10416, 655, 3, '0', 'modis_ergb_low', 'MODIS Enhanced RGB, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', 'An enhanced true color image of the upper ocean waters and coastal zones, estimated from the ocean color measurements collected by the MODerate Resolution Imaging Spectroradiometers aboard NASA''s polar orbiting Terra and Aqua satellites. The red, green, and blue channels are provided by the water-leaving radiance data at 1km resolution, namely 555nm (R), 490nm (G), 443nm (B). This layer is provided by the USF Institute for Marine Remote Sensing, http://imars.usf.edu.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10417, 655, 4, '0', 'modis_rgb_composite_low', 'MODIS Low Resolution RGB Composite, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', 'The approximate true color of the upper ocean waters, estimated from the ocean color measurements collected by the MODerate Resolution Imaging Spectroradiometers aboard NASA''s polar orbiting Terra and Aqua satellites. Red, green, and blue channels are combined to represent what your eye would see in the ocean from this vantage point in space. The image, at approximately 1km resolution, uses radiance data at 678nm, 551nm, and 443nm as the red, green, blue channels, respectively.  The composite image is created by superimposing the most recent four passes with the latest pass drawn on top.  These data are made available by the USF Institute for Marine Remote Sensing, http://imars.usf.edu.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19256, 828, 8, '0', 'Tramos_de_carreteras', 'Tramos_de_carreteras', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19257, 828, 9, '0', 'Tramos_de_ferrocarril', 'Tramos_de_ferrocarril', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10418, 655, 5, '0', 'modis_rgb_low', 'MODIS Low Resolution RGB, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', 'The approximate true color of the upper ocean waters, estimated from the ocean color measurements collected by the MODerate Resolution Imaging Spectroradiometers aboard NASA''s polar orbiting Terra and Aqua satellites. Red, green, and blue channels are combined to represent what your eye would see in the ocean from this vantage point in space. The image, at approximately 1km resolution, uses radiance data at 678nm, 551nm, and 443nm as the red, green, blue channels, respectively. These data are made available by the USF Institute for Marine Remote Sensing, http://imars.usf.edu.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10419, 655, 6, '0', 'modis_rgb_hi_chesapeake_bay', 'MODIS High Resolution RGB, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', 'The approximate true color of the upper ocean waters, coastal zones, and land areas estimated from color measurements collected by the MODerate Resolution Imaging Spectroradiometers aboard NASA''s polar orbiting Terra and Aqua satellites. Red, green, and blue channels are combined to represent what your eye would see in the ocean from this vantage point in space. The image, at approximately 250m resolution, uses radiance data at 645nm, 555nm, 469nm as the red, green, and blue channels, respectively. This layer is available for select coastal locations and is provided by USF Institute for Marine Remote Sensing, http://imars.usf.edu.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10420, 655, 7, '0', 'modis_rgb_hi_florida_bay', 'MODIS High Resolution RGB, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', 'The approximate true color of the upper ocean waters, coastal zones, and land areas estimated from color measurements collected by the MODerate Resolution Imaging Spectroradiometers aboard NASA''s polar orbiting Terra and Aqua satellites. Red, green, and blue channels are combined to represent what your eye would see in the ocean from this vantage point in space. The image, at approximately 250m resolution, uses radiance data at 645nm, 555nm, 469nm as the red, green, and blue channels, respectively. This layer is available for select coastal locations and is provided by USF Institute for Marine Remote Sensing, http://imars.usf.edu.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10421, 655, 8, '0', 'modis_rgb_hi_miss_plume', 'MODIS High Resolution RGB, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', 'The approximate true color of the upper ocean waters, coastal zones, and land areas estimated from color measurements collected by the MODerate Resolution Imaging Spectroradiometers aboard NASA''s polar orbiting Terra and Aqua satellites. Red, green, and blue channels are combined to represent what your eye would see in the ocean from this vantage point in space. The image, at approximately 250m resolution, uses radiance data at 645nm, 555nm, 469nm as the red, green, and blue channels, respectively. This layer is available for select coastal locations and is provided by USF Institute for Marine Remote Sensing, http://imars.usf.edu.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10422, 655, 9, '0', 'modis_rgb_hi_suwannee_river', 'MODIS High Resolution RGB, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', 'The approximate true color of the upper ocean waters, coastal zones, and land areas estimated from color measurements collected by the MODerate Resolution Imaging Spectroradiometers aboard NASA''s polar orbiting Terra and Aqua satellites. Red, green, and blue channels are combined to represent what your eye would see in the ocean from this vantage point in space. The image, at approximately 250m resolution, uses radiance data at 645nm, 555nm, 469nm as the red, green, and blue channels, respectively. This layer is available for select coastal locations and is provided by USF Institute for Marine Remote Sensing, http://imars.usf.edu.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10423, 655, 10, '0', 'modis_rgb_hi_tampa_bay', 'MODIS High Resolution RGB, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', 'The approximate true color of the upper ocean waters, coastal zones, and land areas estimated from color measurements collected by the MODerate Resolution Imaging Spectroradiometers aboard NASA''s polar orbiting Terra and Aqua satellites. Red, green, and blue channels are combined to represent what your eye would see in the ocean from this vantage point in space. The image, at approximately 250m resolution, uses radiance data at 645nm, 555nm, 469nm as the red, green, and blue channels, respectively. This layer is available for select coastal locations and is provided by USF Institute for Marine Remote Sensing, http://imars.usf.edu.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10424, 655, 11, '0', 'oi_sst', 'Optimally Interpolated SST, courtesy USF Ocean Circulation Group (http://ocg6.marine.usf.edu/)', 0, 0, 0, '', '', 'This layer is an operational, cloud-free, satellite SST product for the SEACOOS domain. Using Optimal Interpolation (OI) three types of satellite sea surface temperature (SST) data are merged to produce a cloud-free satellite SST field. Input data come from NOAA and NASA satellites and are compiled and processed daily by the USF Ocean Circulation Group, http://ocg6.marine.usf.edu. DISPLAY NOTE : A land mask cover should be placed over this layer.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10425, 655, 12, '0', 'modis_sst', 'MODIS SST, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', 'This SST layer is estimated from infrared measurements collected by the Advanced Very High Resolution Radiometer aboard NOAA''s series of polar orbiting satellites. Energy levels at the top of the atmosphere in the 10 - 11 micron range are fit statistically to in-water SST measurements to allow 1km resolution SST estimates to be made. These data are made available by the USF Institute for Marine Remote Sensing, http://imars.usf.edu. DISPLAY NOTE : A land mask cover should be placed over this layer.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19260, 840, 0, '', 'World', 'World', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10426, 655, 13, '0', 'avhrr_sst', 'AVHRR SST, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', 'This SST layer is derived from infrared measurements collected by the MODerate Resolution Imaging Spectroradiometers aboard NASA''s polar orbiting Terra and Aqua satellites. Energy levels at the top of the atmosphere in the 10-11 micron range (daytime) and 3-4 micron range (nighttime) are fit statistically to in-water SST measurements to allow 1km resolution SST estimates to be made. The resolution and accuracy of MODIS data are among the best available to Earth scientists today. These data are made available by the USF Institute for Marine Remote Sensing, http://imars.usf.edu.  DISPLAY NOTE : A land mask cover should be placed over this layer.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10427, 655, 14, '0', 'modis_chl', 'MODIS Chl-A, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', 'TBA DISPLAY NOTE : A land mask cover should be placed over this layer.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19261, 883, 0, '', 'Luftbilder', 'Luftbilder', 0, 0, 0, '', '', 'SICAD/SD Internet Map Services V5.1 at http://192.168.252.12:80-Luftbilder');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14843, 840, 1, '0', 'GLOBEImage', 'GlobeImage', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10428, 655, 15, '0', 'jpl_sea_surface_height_composite', 'TBA', 0, 0, 0, '', '', 'TBA');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10429, 655, 16, '0', 'tamu_level_III', 'Texas Mesonet Radar, courtesy Texas A and M University (http://mesonet.tamu.edu/)', 0, 0, 0, '', '', 'The Texas Mesonet is a network of meteorological monitoring instruments, broadly dispersed across the State, and reporting to a common point for display of the data in near-real-time.  The data are archived and available to the public and the academic community for research and analysis.  The goal of this site is to provide a demonstration of the potential and capabilities of a Mesoscale (medium scale) monitoring network to the potential users:  The Citizens of Texas, the academic community, Emergency Planners and Managers, the Public Utilities, and anyone else who will find this data useful.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14851, 841, 0, '', 'ICEDSWMS', 'ICEDS (Integrated CEOS European Data Server) WMS', 0, 0, 0, '', '', 'Integrated CEOS European Data Server (ICEDS) Web Map Service, maintained by the Geomatic Engineering Dept at UCL');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14852, 841, 1, '0', 'GRID', 'MAPDRESSING GRID', 0, 0, 0, '', '', 'MAPDRESSING GRID');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14856, 841, 2, '0', 'landsat5', 'LANDSAT 5 mosaic for Africa and Europe', 0, 0, 0, '', '', 'LANDSAT 5 mosaic for Africa and Europe produced and kindly provided by Dr. Nevin Bryant (JPL)');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10430, 655, 17, '0', 'tamu_usrad', 'Texas Mesonet Radar, courtesy Texas A and M University (http://mesonet.tamu.edu/)', 0, 0, 0, '', '', 'The Texas Mesonet is a network of meteorological monitoring instruments, broadly dispersed across the State, and reporting to a common point for display of the data in near-real-time.  The data are archived and available to the public and the academic community for research and analysis.  The goal of this site is to provide a demonstration of the potential and capabilities of a Mesoscale (medium scale) monitoring network to the potential users:  The Citizens of Texas, the academic community, Emergency Planners and Managers, the Public Utilities, and anyone else who will find this data useful.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19262, 841, 3, '2', 'landsat_1_01', 'LANDSAT 5 mosaic for Africa and Europe (100 arscsec. level)', 0, 0, 0, '', '', 'LANDSAT 5 mosaic for Africa and Europe produced and kindly provided by Dr. Nevin Bryant (JPL). Data resolution is a resampled version of the original dataset (100 arcsec.)');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19264, 841, 4, '2', 'landsat_2_01', 'LANDSAT 5 mosaic for Africa and Europe (10 arscsec. level)', 0, 0, 0, '', '', 'LANDSAT 5 mosaic for Africa and Europe produced and kindly provided by Dr. Nevin Bryant (JPL). Data resolution is a resampled version of the original dataset (10 arcsec.)');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19265, 841, 5, '2', 'landsat_3_01', 'LANDSAT 5 mosaic for Africa and Europe (1 arscsec. level)', 0, 0, 0, '', '', 'LANDSAT 5 mosaic for Africa and Europe produced and kindly provided by Dr. Nevin Bryant (JPL). Data resolution of 1 arcsec. per pixel');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10431, 655, 18, '0', 'surface_currents_radar', 'Surface currents (Radar) (EXPERIMENTAL), courtesy SEACOOS', 0, 0, 0, '', '', 'TBA');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19266, 841, 6, '0', 'landsat', 'Landsat 5 for Northamerica, Europe and Africa', 0, 0, 0, '', '', 'LANDSAT 5 mosaic for Northamerica, Europe and Africa');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19267, 841, 7, '6', 'landsat_1_02', 'LANDSAT 5 for Northamerica, Europe and Africa', 0, 0, 0, '', '', 'LANDSAT 5 mosaic for Northamerica, Europe and Africa');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10432, 655, 19, '0', 'depth_averaged_currents', 'Depth-averaged currents (EXPERIMENTAL), courtesy University of North Carolina, Chapel Hill', 0, 0, 0, '', '', 'TBA');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19268, 841, 8, '6', 'landsat_2_02', 'LANDSAT 5 for Northamerica, Europe and Africa', 0, 0, 0, '', '', 'LANDSAT 5 mosaic for Northamerica, Europe and Africa');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19269, 841, 9, '6', 'landsat_3_02', 'LANDSAT 5 for Northamerica, Europe and Africa', 0, 0, 0, '', '', 'LANDSAT 5 mosaic for Northamerica, Europe and Africa');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14860, 841, 10, '0', 'srtm', 'Hillshaded SRTM3 mosaic', 0, 0, 0, '', '', 'Hillshaded SRTM3 mosaic with the sea masked by the NOAA GSHHS global shorelines dataset');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10433, 655, 20, '0', 'sea_surface_elevation', 'Sea surface elevation (EXPERIMENTAL), courtesy University of North Carolina, Chapel Hill', 0, 0, 0, '', '', 'TBA');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14844, 840, 2, '0', 'ADMIN', 'Admin', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14845, 840, 3, '0', 'COUNTRY', ' Country', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14846, 840, 4, '0', 'Lakes', ' Lakes', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14847, 840, 5, '0', 'RAILWAY', ' Railway', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19263, 887, 0, '', 'BK50', 'BK50', 1, 0, 0, '', '', 'WMS Map Server');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14848, 840, 6, '0', 'WorldGridLines', ' World Grid Lines', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14849, 840, 7, '0', 'OCEAN_TEXT', ' Ocean Label', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14850, 840, 8, '0', 'CAPITALS', ' Capitals', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18275, 887, 1, '0', 'bk50', 'bk50', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18236, 883, 1, '0', '1', '$_nav_uebersicht', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18237, 883, 2, '0', '2', 'Stadtplan ', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18238, 883, 3, '0', '5', 'Luftbilder 1999', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18239, 883, 4, '0', '8', 'Flurstuecksstruktur', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18240, 883, 5, '0', '9', 'Texte', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14861, 841, 11, '10', 'srtm3_1', 'Hillshaded SRTM3 mosaic (180 arscsec. level)', 0, 0, 0, '', '', 'Hillshaded SRTM3 mosaic with the sea masked by the NOAA GSHHS global shorelines dataset. Data resolution is a resampled version of the original dataset (180 arcsec.)');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14862, 841, 12, '10', 'srtm3_2', 'Hillshaded SRTM3 mosaic (30 arscsec. level)', 0, 1700000, 0, '', '', 'Hillshaded SRTM3 mosaic with the sea masked by the NOAA GSHHS global shorelines dataset. Data resolution is a resampled version of the original dataset (30 arcsec.)');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14863, 841, 13, '10', 'srtm3_3', 'Hillshaded SRTM3 mosaic (3 arscsec. level)', 0, 0, 1699999, '', '', 'Hillshaded SRTM3 mosaic with the sea masked by the NOAA GSHHS global shorelines dataset. Data resolution of 3 arcsec. per pixel');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14864, 841, 14, '0', 'srtm30', 'Hillshaded SRTM30 mosaic', 0, 0, 0, '', '', 'Hillshaded SRTM30 mosaic combined with GTOPO30 data');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14865, 841, 15, '14', 'srtm30_1', 'Hillshaded SRTM30 mosaic (300 arscsec. level)', 0, 0, 0, '', '', 'Hillshaded SRTM30 mosaic combined with GTOPO30 data. Data resolution is a resampled version of the original dataset (300 arcsec.)');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14866, 841, 16, '14', 'srtm30_2', 'Hillshaded SRTM30 mosaic (30 arscsec. level)', 0, 0, 0, '', '', 'Hillshaded SRTM30 mosaic combined with GTOPO30 data. Data resolution of 30 arcsec. per pixel');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19275, 841, 17, '0', 'srtm3_v2', 'Hillshaded SRTM3 mosaic (Version 2)', 0, 0, 0, '', '', 'Hillshaded SRTM3 Version 2 mosaic with waterbodies masked by SRTM Water Bodies Mask');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19277, 841, 18, '17', 'srtm3_v2_0', 'Hillshaded SRTM3 mosaic (180 arscsec. level)', 0, 0, 0, '', '', 'Hillshaded SRTM3 Version 2 mosaic with waterbodies makes by SRTM Water Bodies Mask dataset. Data resolution is a resampled version of the original dataset (180 arcsec.)');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19278, 841, 19, '17', 'srtm3_v2_1', 'Hillshaded SRTM3 mosaic (30 arscsec. level)', 0, 0, 0, '', '', 'Hillshaded SRTM3 Version 2 mosaic with waterbodies masked by SRTM Water Bodies Mask. Data resolution is a resampled version of the original dataset (30 arcsec.)');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19279, 841, 20, '17', 'srtm3_v2_2', 'Hillshaded SRTM3 mosaic (30 arscsec. level)', 0, 1999999, 0, '', '', 'Hillshaded SRTM3 Version 2 mosaic with waterbodies masked by SRTM Water Bodies Mask. Data resolution is a resampled version of the original dataset (30 arcsec.)');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19280, 841, 21, '17', 'srtm3_v2_3', 'Hillshaded SRTM3 Version 2 mosaic (3 arscsec. level)', 0, 0, 1999999, '', '', 'Hillshaded SRTM3 Version 2 mosaic with waterbodies masked by SRTM Water Bodies Mask. Data resolution of 3 arcsec. per pixel');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19281, 841, 22, '0', 'srtm3_v1', 'Hillshaded SRTM3 mosaic (Version 1)', 0, 0, 0, '', '', 'Hillshaded SRTM3 Version 1 mosaic with waterbodies masked by SRTM Water Bodies Mask');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19282, 841, 23, '22', 'srtm3_v1_0', 'Hillshaded SRTM3 mosaic (180 arscsec. level)', 0, 0, 0, '', '', 'Hillshaded SRTM3 Version 1 mosaic with waterbodies makes by SRTM Water Bodies Mask dataset. Data resolution is a resampled version of the original dataset (180 arcsec.)');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19284, 841, 24, '22', 'srtm3_v1_1', 'Hillshaded SRTM3 mosaic (30 arscsec. level)', 0, 0, 0, '', '', 'Hillshaded SRTM3 Version 1 mosaic with waterbodies masked by SRTM Water Bodies Mask. Data resolution is a resampled version of the original dataset (30 arcsec.)');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19286, 841, 25, '22', 'srtm3_v1_2', 'Hillshaded SRTM3 mosaic (30 arscsec. level)', 0, 1999999, 0, '', '', 'Hillshaded SRTM3 Version 2 mosaic with waterbodies masked by SRTM Water Bodies Mask. Data resolution is a resampled version of the original dataset (30 arcsec.)');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19287, 841, 26, '22', 'srtm3_v1_3', 'Hillshaded SRTM3 Version 1 mosaic (3 arscsec. level)', 0, 0, 1999999, '', '', 'Hillshaded SRTM3 Version 1 mosaic with waterbodies masked by SRTM Water Bodies Mask. Data resolution of 3 arcsec. per pixel');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14867, 841, 27, '0', 'bluemarble', 'Global MODIS Blue Marble', 0, 0, 0, '', '', 'Global MODIS Blue Marble');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14868, 841, 28, '27', 'bluemarble_1', 'Global MODIS Blue Marble (300 arcsec. level)', 0, 0, 0, '', '', 'Global MODIS Blue Marble. Data resolution of 300 arcsec. per pixel');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14869, 841, 29, '27', 'bluemarble_2', 'Global MODIS Blue Marble (30 arcsec. level)', 0, 0, 0, '', '', 'Global MODIS Blue Marble. Data resolution of 30 arcsec. per pixel');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19289, 841, 30, '0', 'ciesin_pop', 'Cascaded population data from CIESIN', 0, 0, 0, '', '', 'ciesin_pop');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19291, 841, 31, '30', 'gpw1990', 'Gridded Population of the World , v3 beta: Pop Density 1990', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14870, 841, 32, '0', 'globe', 'Cascaded data from GLOBE', 0, 0, 0, '', '', 'globe');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14871, 841, 33, '32', 'rivers', 'Cascaded Rivers from GLOBE', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14872, 841, 34, '32', 'coastlines', 'Cascaded Coastlines from GLOBE', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14873, 841, 35, '0', 'demis', 'Cascaded data from Demis', 0, 0, 0, '', '', 'demis');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10434, 655, 21, '0', 'opaque_legend_background', 'Opaque legend background', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10435, 655, 22, '0', 'modis_chl_legend_full_range', 'MODIS Chl-A Legend, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10436, 655, 23, '0', 'sst_legend_full_range', 'SST Legend, courtesy USF Institute for Marine Remote Sensing (http://imars.usf.edu/)', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10437, 655, 24, '0', 'tamu_level_III_legend_full_range', 'Texas Mesonet Radar Legend, courtesy Texas A and M University (http://mesonet.tamu.edu/)', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19270, 869, 0, '', 'linfos', 'linfos', 1, 0, 0, '', '', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19271, 866, 0, '', 'hochwasser', 'hochwasser', 1, 0, 0, '', '', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10438, 655, 25, '0', 'current_velocity_legend', 'Current velocity legend', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19272, 867, 0, '', 'stobo', 'stobo', 1, 0, 0, '', '', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19110, 902, 0, '', 'Brandenburg', 'DNM 100/2', 0, 25001, 0, '', '', '2. Generation des Digitalen Navigationsmodells 1:100.000 als topographische Basisnavigationsdaten der Brandenburger Landesvermessung');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19273, 843, 0, '', 'hazards', 'hazards', 0, 0, 0, '', '', 'WMS Map Server');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19274, 837, 0, '', 'U.S. Geological Survey', 'U.S. Geological Survey', 0, 0, 0, '', '', 'WMT Map Server maintained by Microsoft Corporation.  Data returned provided by US Geological Survey.  Contact: tbarclay at microsoft.com or gylee at usgs.gov.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18146, 869, 1, '0', '51', 'Vegetationstypen', 1, 0, 150214, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14935, 843, 1, '0', 'Ambient Population 2002 (per 30 arc seconds)', 'Ambient Population 2002 (per 30 arc seconds)', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14936, 843, 2, '0', 'Elevation/Bathymetry', 'Elevation/Bathymetry', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10439, 655, 26, '0', 'water_level_legend', 'Elevation legend', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18147, 869, 2, '0', '49', 'Vegetationsaufnahmen', 1, 0, 150214, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18133, 867, 1, '0', 'Bleibelastung der Ackerboeden in mg pro kg', 'Bleibelastung der Ackerboeden in mg pro kg', 1, 22497, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18120, 866, 1, '0', '8', 'rhein-hq100-odeich', 1, 200, 749888, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19276, 844, 0, '', 'CustomWeather Map Server', 'CustomWeather Map Server', 0, 0, 0, '', '', 'CustomWeather WMS Map Server.  Contact: info at customweather.com.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14937, 843, 3, '0', 'Continents', 'Continents', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18148, 869, 3, '0', '45', 'Naturraeumliche Haupteinheiten', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18134, 867, 2, '0', 'Cadmiumbelastung der Ackerboeden in mg pro kg', 'Cadmiumbelastung der Ackerboeden in mg pro kg', 1, 22497, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14804, 837, 1, '0', 'DOQ', 'USGS Digital Ortho-Quadrangles', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18121, 866, 2, '0', '9', 'rhein-hq100-mdeich', 1, 200, 749888, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14938, 843, 4, '0', 'Lakes', 'Lakes', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18135, 867, 3, '0', 'Zinkbelastung der Ackerboeden in mg pro kg', 'Zinkbelastung der Ackerboeden in mg pro kg', 1, 22497, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18149, 869, 4, '0', '43', 'Landschaftsschutzgebiete', 1, 0, 150214, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18150, 869, 5, '0', '42', 'Stand der Landschaftsplanung', 1, 0, 150214, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18151, 869, 6, '0', '32', 'FFH-Gebiete', 1, 0, 150214, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18152, 869, 7, '0', '31', 'Vogelschutzgebiete', 1, 0, 150214, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18153, 869, 8, '0', '28', 'Biotoptypen', 1, 0, 150214, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18154, 869, 9, '0', '3', 'Biotopkataster', 1, 0, 150214, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18155, 869, 10, '0', '1', 'Naturschutzgebiete', 1, 0, 150214, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15004, 844, 1, '0', 'severe_warnings', 'severe_warnings', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14965, 844, 2, '0', 'anim', 'anim', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14967, 844, 3, '0', 'au_radar_stations', 'au_radar_stations', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14971, 844, 4, '0', 'conditions', 'conditions', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15005, 844, 5, '0', 'severe_watches', 'severe_watches', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14998, 844, 6, '0', 'marine_zones', 'marine_zones', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19285, 844, 7, '0', 'synoptic_weather', 'synoptic_weather', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14968, 844, 8, '0', 'base', 'base', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14993, 844, 9, '0', 'land_sea_mask', 'land_sea_mask', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15002, 844, 10, '0', 'radar_mask', 'radar_mask', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19288, 844, 11, '0', 'world_borders', 'world_borders', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19290, 844, 12, '0', 'fire_zones', 'fire_zones', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19292, 844, 13, '0', 'coasts_lakes', 'coasts_lakes', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14981, 844, 14, '0', 'earthquakes', 'earthquakes', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14964, 844, 15, '0', 'airport_delay', 'airport_delay', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14995, 844, 16, '0', 'lightning', 'lightning', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14988, 844, 17, '0', 'global_ir_satellite_10km', 'global_ir_satellite_10km', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14984, 844, 18, '0', 'frontlines', 'frontlines', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19293, 844, 19, '0', 'openwms', 'openwms', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14973, 844, 20, '0', 'contour_high', 'contour_high', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14972, 844, 21, '0', 'contour_fire_danger', 'contour_fire_danger', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14994, 844, 22, '0', 'legend', 'legend', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14969, 844, 23, '0', 'borders', 'borders', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14997, 844, 24, '0', 'maple_raster', 'maple_raster', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14980, 844, 25, '0', 'counties', 'counties', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15010, 844, 26, '0', 'zones', 'zones', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14976, 844, 27, '0', 'contour_precip', 'contour_precip', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14983, 844, 28, '0', 'forecasts', 'forecasts', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14977, 844, 29, '0', 'contour_pressure', 'contour_pressure', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19295, 844, 30, '0', 'hurricane', 'hurricane', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19296, 844, 31, '0', 'nhe_exp', 'nhe_exp', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19297, 844, 32, '0', 'high_seas', 'high_seas', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14974, 844, 33, '0', 'contour_jet_stream', 'contour_jet_stream', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15006, 844, 34, '0', 'state_borders', 'state_borders', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15001, 844, 35, '0', 'radar', 'radar', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14966, 844, 36, '0', 'au_radar', 'au_radar', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14970, 844, 37, '0', 'coasts', 'coasts', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14978, 844, 38, '0', 'contour_syn_precip', 'contour_syn_precip', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14990, 844, 39, '0', 'interstates', 'interstates', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19111, 902, 1, '0', 'kreis', 'Landkreise und kreisfreie Städte', 1, 25001, 0, '', '', 'Landkreise und kreisfreie Städte');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19112, 902, 2, '0', 'wald', 'Wald', 0, 25001, 150000, '', '', 'Wald');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19113, 902, 3, '0', 'ozen', 'Oberzentren', 0, 25001, 2000000, '', '', 'Oberzentren, TYP = 0');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19114, 902, 4, '0', 'mzen', 'Mittelzentren', 0, 25001, 600000, '', '', 'Mittelzentren, TYP = 1');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19115, 902, 5, '0', 'uzen', 'Unterzentren', 0, 25001, 200000, '', '', 'Unterzentren, TYP = 2');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19116, 902, 6, '0', 'lwas', 'Flüsse und Kanäle', 0, 25001, 150000, '', '', 'Flüsse und Kanäle');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19117, 902, 7, '0', 'fwas', 'Seen', 0, 25001, 250001, '', '', 'Seen');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19118, 902, 8, '0', 'ebahn', 'Eisenbahnen', 0, 25001, 250001, '', '', 'Eisenbahnen');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19119, 902, 9, '0', 'kstr', 'Kreisstraßen', 0, 25001, 100000, '', '', 'Kreisstraßen');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19120, 902, 10, '0', 'lstr', 'Landesstraßen', 0, 25001, 250001, '', '', 'Landesstraßen');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19121, 902, 11, '0', 'bstr', 'Bundesstraßen', 0, 25001, 749999, '', '', 'Bundesstraßen');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19122, 902, 12, '0', 'astr', 'Autobahnen', 0, 25001, 0, '', '', 'Autobahnen');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19123, 902, 13, '0', 'nfwas', 'Namen der Seen', 0, 25001, 100000, '', '', 'Namen der Seen');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19124, 902, 14, '0', 'kfz', 'Kfz-Zeichen', 0, 2000000, 0, '', '', 'Kfz-Zeichen');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14939, 843, 5, '0', 'Rivers', 'Rivers', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14940, 843, 6, '0', 'Countries', 'Countries', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14941, 843, 7, '0', 'States', 'States', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14942, 843, 8, '0', 'Cities', 'Cities', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14943, 843, 9, '0', 'Plate Boundaries', 'Plate Boundaries', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19283, 843, 10, '0', 'DART Buoys', 'DART Buoys', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14944, 843, 11, '0', 'Volcanoes', 'Volcanoes', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14945, 843, 12, '0', 'Tsunami Events with runups', 'Tsunami Events with runups', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14946, 843, 13, '0', 'Tsunami Events with slides', 'Tsunami Events with slides', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14947, 843, 14, '0', 'Tsunami Events', 'Tsunami Events', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14948, 843, 15, '0', 'Tsunami Runups', 'Tsunami Runups', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14949, 843, 16, '0', 'Significant Earthquakes with slides', 'Significant Earthquakes with slides', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14950, 843, 17, '0', 'Significant Earthquakes', 'Significant Earthquakes', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18136, 867, 4, '0', 'Bleibelastung der Gartenboeden in mg pro kg', 'Bleibelastung der Gartenboeden in mg pro kg', 1, 22497, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18137, 867, 5, '0', 'Cadmiumbelastung der Gartenboeden in mg pro kg', 'Cadmiumbelastung der Gartenboeden in mg pro kg', 1, 22497, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18138, 867, 6, '0', 'Zinkbelastung der Gartenboeden in mg pro kg', 'Zinkbelastung der Gartenboeden in mg pro kg', 1, 22497, 74989, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18139, 867, 7, '0', 'Bleibelastung der Gruenlandboeden in mg pro kg', 'Bleibelastung der Gruenlandboeden in mg pro kg', 1, 22497, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18140, 867, 8, '0', 'Cadmiumbelastung der Gruenlandboeden in mg pro kg', 'Cadmiumbelastung der Gruenlandboeden in mg pro kg', 1, 22497, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18141, 867, 9, '0', 'Zinkbelastung der Gruenlandboeden in mg pro kg', 'Zinkbelastung der Gruenlandboeden in mg pro kg', 1, 22497, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18142, 867, 10, '0', 'Probenahmenstandorte in NRW differenziert nach Nutzungen', 'Probenahmenstandorte in NRW differenziert nach Nutzungen', 1, 22497, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18122, 866, 3, '0', '6', 'rhein-hq200-odeich', 1, 200, 749888, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18123, 866, 4, '0', '7', 'rhein-hq200-mdeich', 1, 200, 749888, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18124, 866, 5, '0', '4', 'rhein-hq500-odeich', 1, 200, 749888, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18125, 866, 6, '0', '5', 'rhein-hq500-mdeich', 1, 200, 749888, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18126, 866, 7, '0', '0', 'vereinf_Verfahren', 1, 200, 374944, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18127, 866, 8, '0', '1', 'Sonstige_UESG', 1, 200, 374944, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18128, 866, 9, '0', '2', 'Historische_UESG', 1, 200, 374944, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18129, 866, 10, '0', '3', 'neuere_Berechnungsverfahren', 1, 200, 374944, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18130, 866, 11, '0', '18', 'Seen', 1, 200, 374944, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18131, 866, 12, '0', '19', 'Talsperre', 1, 200, 374944, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14805, 837, 2, '0', 'DRG', 'USGS Raster Graphics (Topo Maps)', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14894, 842, 0, '', 'Tsunami_Disaster_Map', 'Tsunami_Diasaster_Data', 0, 0, 0, '', '', 'This WMS server contains data used in http://www.mapsherpa.com/tsunami/. Much of the reference data is cascaded from other WMS servers.  Before using this data in your live application, please consult the metadata url for each layer to check to see if you can legally use the data in your application.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14895, 842, 1, '0', 'Satellite_Imagery', 'Satellite_Imagery', 0, 0, 0, '', '', 'Satellite_Imagery');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14896, 842, 2, '1', 'GAEL_WORLD_MARCH', 'ENVISAT MERIS mosaic', 0, 0, 0, '', 'http://mapserv2.esrin.esa.it/ionicweb/map/GAEL_WORLD_MARCH?', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14897, 842, 3, '1', 'srtm_tiles', 'SRTM 90m DEM - unclassified', 0, 0, 0, '', 'http://gisweb.ciat.cgiar.org/sig/90m_data_tropics.htm', 'Hole-filled seamless SRTM data V1, 2004, International Centre for Tropical Agriculture (CIAT). Processed by the Laboratory for Applied Geomatics and GIS Science (LAGGISS), University of Ottawa.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14898, 842, 4, '1', 'thai-LandsatTrue', 'Landsat Mosaic of Thailand', 1, 0, 0, '', 'http://203.159.10.13/cgi-bin/mapserv?map=/var/www/html/gms/thaiwms.map', 'Landsat Mosaic of Thailand. Provided by the Asian Institute of Technology (AIT), Pathumthani, Thailand.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14806, 837, 3, '0', 'UrbanArea', 'USGS Urban Areas Ortho-Imagery', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14899, 842, 5, '1', 'sri_landsat', 'Landsat Mosaic of Sri Lanka', 0, 0, 0, '', 'https://zulu.ssc.nasa.gov/mrsid/docs/GeoCover_circa_2000_Product_Description.pdf', 'Landsat ETM+ image of Sri Lanka, obtained from https://zulu.ssc.nasa.gov/mrsid/mrsid.pl.  Processed by the Laboratory for Applied Geomatics and GIS Science (LAGGISS), University of Ottawa.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14900, 842, 6, '0', 'Physical_Geography', 'Physical_Geography', 0, 0, 0, '', '', 'Physical_Geography');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14901, 842, 7, '6', 'GTOPO30:Foundation', 'Global 30 Second Elevations', 1, 0, 0, '', 'http://ceoware2.ccrs.nrcan.gc.ca/cubewerx/cubeserv/cubeserv.cgi?', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14902, 842, 8, '6', 'RELIEF:Foundation', 'Two Minute Shaded Relief', 1, 0, 0, '', 'http://ceoware2.ccrs.nrcan.gc.ca/cubewerx/cubeserv/cubeserv.cgi?', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14903, 842, 9, '6', 'Bathymetry', 'Bathymetry', 0, 0, 0, '', 'http://www.ngdc.noaa.gov/mgg/fliers/01mgg04.html', '2-Minute Gridded Global Relief Data (ETOPO2), obtained from NOAA');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14904, 842, 10, '6', 'Topography', 'Topography', 0, 0, 0, '', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&?', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14905, 842, 11, '6', 'Hillshading', 'Hillshading', 0, 0, 0, '', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&?', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14906, 842, 12, '6', 'CONTOURL_ELEV_1M:Foundation', 'Elevation Contours', 1, 0, 0, '', 'http://ceoware2.ccrs.nrcan.gc.ca/cubewerx/cubeserv/cubeserv.cgi?', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14907, 842, 13, '0', 'Disaster_Info', 'Disaster_Info', 0, 0, 0, '', '', 'Disaster_Info');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14908, 842, 14, '13', 'locations', 'Disaster Point Locations', 1, 0, 0, '', 'N/A', 'Click points of interest for Disaster_Information about that location.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14874, 841, 36, '35', 'bathymetry', 'Cascaded Bathymetry from Demis', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14875, 841, 37, '0', 'onearth', 'Cascaded data from OnEarth', 0, 0, 0, '', '', 'onearth');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14876, 841, 38, '37', 'landsat7', 'Cascaded Landsat7 from OnEarth', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19294, 841, 39, '37', 'srtm_amp', 'Cascaded colourised SRTM amplitude mosaic from OnEarth', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14877, 841, 40, '37', 'terra', 'Cascaded daily MODIS Terra from OnEarth', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14878, 841, 41, '37', 'aqua', 'Cascaded daily MODIS Aqua from OnEarth', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14853, 841, 42, '0', 'lights', 'DMSP/NOAA human settlements night lights of the world', 0, 0, 0, '', '', 'Defense Metereological Satellite Program (DMSP)/NOAA - human settlements nightime lights. The brigthness is related to the average DN values for the year. The human settlements are the stable lights minus the identified gas flares');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14854, 841, 43, '42', 'lights_1', 'DMSP/NOAA human settlements night lights (300 arcsec. level)', 0, 0, 0, '', '', 'Defense Metereological Satellite Program (DMSP)/NOAA - human settlements nightime lights. The brigthness is related to the average DN values for the year. The human settlements are the stable lights minus the identified gas flares. Data resolution is a resampled version of the original dowloaded dataset (300 arcsec.)');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14855, 841, 44, '42', 'lights_2', 'DMSP/NOAA human settlements night lights (30 arcsec. level)', 0, 0, 0, '', '', 'Defense Metereological Satellite Program (DMSP)/NOAA - human settlements nightime lights. The brigthness is related to the average DN values for the year. The human settlements are the stable lights minus the identified gas flares. Data resolution corresponds to the original dowloaded dataset resolution (30 arcsec.)');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19298, 841, 45, '0', 'usgs_aster', 'Footprints of pre-processed USGS ASTER DEMs', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19299, 841, 46, '0', 'swbd', 'Water bodies detected from SRTM amplitudes', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14879, 841, 47, '0', 'metarweather', 'Cascaded World Hourly METAR Weather Reports from Compusult', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14880, 841, 48, '0', 'noaa', 'Cascaded NOAA World Natural Hazards data', 0, 0, 0, '', '', 'noaa');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14881, 841, 49, '48', 'earthquakes', 'Cascaded NOAA Significant Earthquakes', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14882, 841, 50, '48', 'tsunamievents', 'Cascaded NOAA Tsunami Events', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14883, 841, 51, '48', 'volcanoes', 'Cascaded NOAA Volcanoes', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14884, 841, 52, '48', 'plateboundaries', 'Cascaded NOAA Plate Boundaries', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14885, 841, 53, '48', 'countries', 'Cascaded NOAA Countries', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14886, 841, 54, '48', 'cities', 'Cascaded NOAA Cities', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14887, 841, 55, '0', 'sigafrique', 'Cascaded SIGAFRIQUE data', 0, 0, 0, '', '', 'sigafrique');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14888, 841, 56, '55', 'geofault10', 'Cascaded geologic faults 10 m', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14889, 841, 57, '55', 'geoform10', 'Cascaded geologic formations 10 m', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14890, 841, 58, '55', 'towns', 'Cascaded towns', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14891, 841, 59, '55', 'mainrivers', 'Cascaded main water courses and inland water bodies', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14892, 841, 60, '55', 'water', 'Cascaded water courses', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14909, 842, 15, '13', 'faults', 'Fault Lines', 0, 0, 0, '', 'http://www.colorado.edu/geography/foote/maps/assign/hotspots/hotspots.html', 'Boundary lines between major world tectonic plates.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14910, 842, 16, '13', 'Wave_Heights', 'Wave Heights', 1, 0, 0, '', 'http://www.drs.dpri.kyoto-u.ac.jp/sumatra/index-e.html', 'Surveyed Wave Heights collected by Asian Research Group.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14911, 842, 17, '13', 'earthquakes', 'Recent Earthquakes', 1, 0, 0, '', 'http://earthquake.usgs.gov/recenteqsww/Maps/10/95_5.html', 'List of earthquakes of various magnitudes in the Indian Ocean region.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14912, 842, 18, '13', 'epicenter', 'Epicenter of the Earthquake', 1, 0, 0, '', 'http://earthquake.usgs.gov/recenteqsww/Maps/10/95_5.html', 'Epicenter of the earthquake - 9.0M, 2004/12/26 00:58:53 UTC');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18218, 882, 0, '', 'Wahlen', 'Wahlen', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18219, 882, 1, '0', 'HINTERGRUNDKARTE', 'HINTERGRUNDKARTE', 0, 0, 0, '', '', 'HINTERGRUNDKARTE');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14913, 842, 19, '0', 'Political', 'Political', 0, 0, 0, '', '', 'Political');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14914, 842, 20, '19', 'World_WMS-WorldGen', 'World Countries', 1, 0, 0, '', 'http://dev1.dmsolutions.ca/cgi-bin/mswms_world?', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18220, 882, 2, '1', 'stadtplan_grau_zoomst_1', 'stadtplan_grau_zoomst_1', 0, 135001, 300000, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18221, 882, 3, '1', 'stadtplan_zoom3_01', '02_stadtplan', 0, 20001, 135000, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14915, 842, 21, '19', 'Coastlines', 'Coastlines', 0, 0, 0, '', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&?', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14916, 842, 22, '19', 'Borders', 'Borders', 0, 0, 0, '', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&?', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18222, 882, 4, '1', 'stadtplan_zoom3_02', '03_stadtplan', 0, 12001, 20000, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14917, 842, 23, '19', 'oceans', 'World Oceans Labels', 0, 0, 0, '', 'N/A', 'Ocean labels for visual purpose only.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18223, 882, 5, '1', 'stadtplan_zoom3_03', '04_stadtplan', 0, 2751, 12000, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14918, 842, 24, '19', 'Cities', 'World Cities', 0, 0, 0, '', 'http://www2.demis.nl/wms/wms.asp?wms=WorldMap&?', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14919, 842, 25, '0', 'Affected_Country_Statistics', 'Affected_Country_Statistics', 0, 0, 0, '', '', 'Affected_Country_Statistics');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18224, 882, 6, '1', 'dgk5_liste', 'Deutsche Grundkarte', 0, 0, 2750, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14920, 842, 26, '25', 'gdp', 'Gross Domestic Product (GDP)', 1, 0, 0, '', 'Country Stats: http://www.cia.gov/cia/publications/factbook/', 'Classified layer of countries affected by the tsunami.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18225, 882, 7, '0', 'stadtplan_72dpi', 'stadtplan_uebersicht', 0, 300000, 1000000, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14921, 842, 27, '25', 'gdpper', 'Gross Domestic Product (GDP) per capita', 1, 0, 0, '', 'Country Stats: http://www.cia.gov/cia/publications/factbook/', 'Classified layer of countries affected by the tsunami.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18226, 882, 8, '0', 'Stadtbezirke', 'Stadtbezirke', 0, 0, 0, '', '', 'Stadtbezirke');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14922, 842, 28, '25', 'extdebt', 'External Debt', 1, 0, 0, '', 'Country Stats: http://www.cia.gov/cia/publications/factbook/', 'Classified layer of countries affected by the tsunami.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18227, 882, 9, '8', 'stadtbezirke_pl', 'stadtbezirke_pl', 0, 0, 300000, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14923, 842, 29, '25', 'density', 'Population Density (per sq. km)', 1, 0, 0, '', 'Country Stats: http://www.cia.gov/cia/publications/factbook/', 'Classified layer of countries affected by the tsunami.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14924, 842, 30, '25', 'population', '2004 Population', 1, 0, 0, '', 'Country Stats: http://www.cia.gov/cia/publications/factbook/', 'Classified layer of countries affected by the tsunami.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14925, 842, 31, '25', 'deaths', 'Total Deaths Per Country', 1, 0, 0, '', 'Country Stats: http://www.cia.gov/cia/publications/factbook/geos/in.html. Death Toll: http://www.cnn.com/2004/WORLD/asiapcf/12/28/tsunami.deaths/index.html', 'Classified layer of countries affected by the tsunami.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14926, 842, 32, '25', 'SriLanka_deaths', 'Sri Lanka Total Deaths by Region', 1, 0, 0, '', 'http://www.cnosrilanka.org/', 'Total reported deaths as a result of the tsunami in each region.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14927, 842, 33, '25', 'SriLanka_injured', 'Sri Lanka Total injuries by Region', 1, 0, 0, '', 'http://www.cnosrilanka.org/', 'Number of population that were physically injured as a result of the tsunami.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14928, 842, 34, '25', 'SriLanka_missing', 'Sri Lanka Total missing persons by Region', 1, 0, 0, '', 'http://www.cnosrilanka.org/', 'Population curently missing in each region.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14929, 842, 35, '25', 'SriLanka_displaced', 'Sri Lanka Total Displaced Population by Region', 1, 0, 0, '', 'http://www.cnosrilanka.org/', 'Population displaced from their homes by the effects of the tsunami.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14930, 842, 36, '25', 'SriLanka_camps', 'Sri Lanka Total camps by Region', 1, 0, 0, '', 'http://www.cnosrilanka.org/', 'Number of temporary relief camps to shelter those displaced by the tsunami');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14931, 842, 37, '0', 'Infrastructure', 'Infrastructure', 0, 0, 0, '', '', 'Infrastructure');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14932, 842, 38, '37', 'BUILTUPA_POP_1M:Foundation', 'Built-Up Areas', 1, 0, 0, '', 'http://ceoware2.ccrs.nrcan.gc.ca/cubewerx/cubeserv/cubeserv.cgi?', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14933, 842, 39, '37', 'ROADL_TRANS_1M:Foundation', 'Roads', 1, 0, 0, '', 'http://ceoware2.ccrs.nrcan.gc.ca/cubewerx/cubeserv/cubeserv.cgi?', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18228, 882, 10, '8', 'stadtbezirke_t', 'stadtbezirke_t', 0, 0, 300000, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18229, 882, 11, '0', 'Wahlbezirke', 'Wahlbezirke', 0, 0, 0, '', '', 'Wahlbezirke');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18230, 882, 12, '11', 'wahlbezirke_pl', 'wahlbezirke_pl', 0, 0, 300000, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18231, 882, 13, '11', 'wahlbezirke_t', 'wahlbezirke_t', 0, 0, 300000, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18232, 882, 14, '0', 'Stimmbezirke', 'Stimmbezirke', 0, 0, 0, '', '', 'Stimmbezirke');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18233, 882, 15, '14', 'stimmbezirke_pl', 'stimmbezirke_pl', 0, 0, 300000, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (18234, 882, 16, '14', 'stimmbezirke_t', 'stimmbezirke_t', 0, 0, 300000, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14999, 844, 40, '0', 'pacus_ir_satellite_4km', 'pacus_ir_satellite_4km', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14986, 844, 41, '0', 'gazetteer', 'gazetteer', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15000, 844, 42, '0', 'post_borders', 'post_borders', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14985, 844, 43, '0', 'future_lightning', 'future_lightning', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14987, 844, 44, '0', 'geom', 'geom', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14975, 844, 45, '0', 'contour_low', 'contour_low', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14989, 844, 46, '0', 'hurricanes', 'hurricanes', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15003, 844, 47, '0', 'rivers', 'rivers', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14992, 844, 48, '0', 'label', 'label', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14979, 844, 49, '0', 'conus_ir_satellite_4km', 'conus_ir_satellite_4km', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19300, 844, 50, '0', 'country_borders', 'country_borders', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19301, 844, 51, '0', 'radar_edited', 'radar_edited', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14996, 844, 52, '0', 'maple', 'maple', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15007, 844, 53, '0', 'storm_track', 'storm_track', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (15009, 844, 54, '0', 'wide_conus_ir_satellite_4km', 'wide_conus_ir_satellite_4km', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14982, 844, 55, '0', 'eqc', 'eqc', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14893, 841, 61, '55', 'railway', 'Cascaded railway network', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19302, 841, 62, '0', 'aster1', 'Hillshaded ASTER 1 arc sec DEM for the Three Gorges Area, China', 0, 0, 0, '', '', 'Hillshaded ASTER 1 arc sec DEM for the Three Gorges Area, China');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19303, 841, 63, '62', 'threegorges_1', 'Hillshaded ASTER 1 mosaic (10 arscsec. level)', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19304, 841, 64, '62', 'threegorges_2', 'Hillshaded ASTER 1 mosaic (1 arscsec. level)', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19305, 841, 65, '0', 'srtm_v3', 'Hillshaded ASTER 1 arc sec DEM for the Three Gorges Area, China', 0, 0, 0, '', '', 'Hillshaded ASTER 1 arc sec DEM for the Three Gorges Area, China');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19306, 841, 66, '65', 'srtm_v3_1', 'Hillshaded SRTM Version 3 ', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19307, 841, 67, '65', 'srtm_v3_2', 'Hillshaded ASTER 1 mosaic (1 arscsec. level)', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19308, 824, 0, '', 'Images', 'Images', 0, 0, 0, '', '', 'Image Web Server');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19309, 824, 1, '0', 'AUSTRALIA_PARRAMATTA', 'parramatta', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/secure/australia/parramatta.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19310, 824, 2, '0', 'GEODETIC_USADEMO', 'USADemo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/secure/geodetic/USADemo.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19311, 824, 3, '0', 'GEODETIC_WORLDGEODEMO', 'WorldGeoDemo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/secure/geodetic/WorldGeoDemo.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19312, 824, 4, '0', 'USA_1METERCALIF', '1metercalif', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/secure/usa/1metercalif.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19313, 824, 5, '0', 'USA_SANDIEGO1M_BW', 'Sandiego1m_bw', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/secure/usa/Sandiego1m_bw.jp2', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19314, 824, 6, '0', 'USA_SANDIEGO1M_NULL', 'Sandiego1m_null', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/secure/usa/Sandiego1m_null.jp2', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19315, 824, 7, '0', 'USA_SANDIEGO3I', 'sandiego3i', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/secure/usa/sandiego3i.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19316, 824, 8, '0', 'USA_SANDIEGOAIRPHOTO', 'sandiegoairphoto', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/secure/usa/sandiegoairphoto.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19317, 824, 9, '0', 'USA_SANDIEGOAIRPHOTO_01', 'sandiegoairphoto', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/secure/usa/sandiegoairphoto.jp2', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19318, 824, 10, '0', 'USA_SANDIEGOAIRPHOTO_LOSSLESS', 'sandiegoairphoto_lossless', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/secure/usa/sandiegoairphoto_lossless.jp2', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19319, 824, 11, '0', 'AUSTRALIA_PARRAMATTA_01', 'parramatta', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/australia/parramatta.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19320, 824, 12, '0', 'elevation', 'elevation', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19321, 824, 13, '12', 'HILLSHADE_HS', 'hs', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/elevation/hillshade/hs.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19322, 824, 14, '12', 'HILLSHADE_HS2', 'hs2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/elevation/hillshade/hs2.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19323, 824, 15, '12', 'HILLSHADE_HS3', 'hs3', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/elevation/hillshade/hs3.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19324, 824, 16, '12', 'GEODETIC_HS', 'hs', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/elevation/hillshade/geodetic/hs.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19325, 824, 17, '12', 'HILLSHADE_HS_01', 'hs', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/hillshade/hs.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19326, 824, 18, '12', 'HILLSHADE_HS2_01', 'hs2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/hillshade/hs2.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19327, 824, 19, '12', 'HILLSHADE_HS3_01', 'hs3', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/hillshade/hs3.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19328, 824, 20, '12', 'GEODETIC_HS_01', 'hs', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/hillshade/geodetic/hs.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19329, 824, 21, '0', 'geodetic', 'geodetic', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19330, 824, 22, '21', 'GEODETIC_USADEMO_01', 'USADemo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/geodetic/USADemo.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19331, 824, 23, '21', 'GEODETIC_WORLDGEODEMO_01', 'WorldGeoDemo', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/geodetic/WorldGeoDemo.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19332, 824, 24, '0', 'optical', 'optical', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19333, 824, 25, '24', 'ECW_ORTHOLANDSAT5_201_23', 'ortholandsat5_201_23', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_201_23.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19334, 824, 26, '24', 'ECW_ORTHOLANDSAT5_201_24', 'ortholandsat5_201_24', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_201_24.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19335, 824, 27, '24', 'ECW_ORTHOLANDSAT5_202_22', 'ortholandsat5_202_22', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_202_22.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19336, 824, 28, '24', 'ECW_ORTHOLANDSAT5_202_23', 'ortholandsat5_202_23', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_202_23.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19337, 824, 29, '24', 'ECW_ORTHOLANDSAT5_202_24', 'ortholandsat5_202_24', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_202_24.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19338, 824, 30, '24', 'ECW_ORTHOLANDSAT5_202_25', 'ortholandsat5_202_25', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_202_25.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19339, 824, 31, '24', 'ECW_ORTHOLANDSAT5_203_22', 'ortholandsat5_203_22', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_203_22.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19340, 824, 32, '24', 'ECW_ORTHOLANDSAT5_203_23', 'ortholandsat5_203_23', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_203_23.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19341, 824, 33, '24', 'ECW_ORTHOLANDSAT5_203_24', 'ortholandsat5_203_24', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_203_24.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19342, 824, 34, '24', 'ECW_ORTHOLANDSAT5_203_25', 'ortholandsat5_203_25', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_203_25.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19343, 824, 35, '24', 'ECW_ORTHOLANDSAT5_204_20Q1', 'ortholandsat5_204_20q1', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_204_20q1.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19344, 824, 36, '24', 'ECW_ORTHOLANDSAT5_204_20Q3', 'ortholandsat5_204_20q3', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_204_20q3.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19345, 824, 37, '24', 'ECW_ORTHOLANDSAT5_204_21', 'ortholandsat5_204_21', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_204_21.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19346, 824, 38, '24', 'ECW_ORTHOLANDSAT5_204_22', 'ortholandsat5_204_22', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_204_22.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19347, 824, 39, '24', 'ECW_ORTHOLANDSAT5_204_23', 'ortholandsat5_204_23', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_204_23.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19348, 824, 40, '24', 'ECW_ORTHOLANDSAT5_204_24', 'ortholandsat5_204_24', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_204_24.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19349, 824, 41, '24', 'ECW_ORTHOLANDSAT5_204_25', 'ortholandsat5_204_25', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_204_25.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19350, 824, 42, '24', 'ECW_ORTHOLANDSAT5_205_18Q1', 'ortholandsat5_205_18q1', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_205_18q1.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19351, 824, 43, '24', 'ECW_ORTHOLANDSAT5_205_18Q2', 'ortholandsat5_205_18q2', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_205_18q2.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19352, 824, 44, '24', 'ECW_ORTHOLANDSAT5_205_20', 'ortholandsat5_205_20', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_205_20.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19353, 824, 45, '24', 'ECW_ORTHOLANDSAT5_205_21', 'ortholandsat5_205_21', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_205_21.ecw', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19354, 824, 46, '24', 'ECW_ORTHOLANDSAT5_205_22', 'ortholandsat5_205_22', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/optical/landsat5/ecw/ortholandsat5_205_22.ecw', '', '');
