[Mapbender-commits] r1233 - trunk/mapbender/http/html
    svn_mapbender at osgeo.org
    Fri Mar 16 11:04:10 EDT 2007
Author: nimix
Date: 2007-03-16 11:04:10 -0400 (Fri, 16 Mar 2007)
New Revision: 1233
   trunk/mapbender/http/html/mod_treefolder2.php
disable selection if wmsbuttons = false
Modified: trunk/mapbender/http/html/mod_treefolder2.php
--- trunk/mapbender/http/html/mod_treefolder2.php	2007-03-16 14:44:51 UTC (rev 1232)
+++ trunk/mapbender/http/html/mod_treefolder2.php	2007-03-16 15:04:10 UTC (rev 1233)
@@ -94,6 +94,16 @@
 //var menu_layer_switch = ['menu_zoom', ['Zjjj ', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow("../php/mod_layerMetadata.php?id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid);',,'info.png']];
 //var menu_info_switch = ['menu_zoom', ['Zmn ', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow("../php/mod_layerMetadata.php?id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid);',,'info.png']];
+parent.mb_registerloadWmsSubFunctions("window.frames['treeGDE'].reloadTree();");
+parent.mb_registerInitFunctions("window.frames['treeGDE'].loadTree();");
+if(showstatus=='true'||alerterror=='true'){
+	parent.mb_registerSubFunctions("window.frames['treeGDE'].init_mapcheck();");
+	init_mapcheck();
+parent.mb_registerSubFunctions("window.frames['treeGDE'].updateScale();");
+if(wmsbuttons != "true")
+	jst_highlight = false;
 function select(i,ii,iii){
 	//ignore if selected
 	if(selectedMap==i && selectedWMS==ii && selectedLayer==iii)return;
@@ -196,14 +206,6 @@
-parent.mb_registerloadWmsSubFunctions("window.frames['treeGDE'].reloadTree();");
-parent.mb_registerInitFunctions("window.frames['treeGDE'].loadTree();");
-if(showstatus=='true'||alerterror=='true'){
-	parent.mb_registerSubFunctions("window.frames['treeGDE'].init_mapcheck();");
-	init_mapcheck();
-parent.mb_registerSubFunctions("window.frames['treeGDE'].updateScale();");
 function imgerror(){
 	var map=parent.getMapObjIndexByName(mod_treeGDE_map);
 	var wms=Number(this.id.substr(4));
More information about the Mapbender_commits
