[Mapbender-commits] r1701 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Tue Oct 2 09:00:38 EDT 2007
Author: christoph
Date: 2007-10-02 09:00:37 -0400 (Tue, 02 Oct 2007)
New Revision: 1701
Removed:
trunk/mapbender/http/classes/class_gml.php
obsolete version of gml class; use class_gml2.php instead
Deleted: trunk/mapbender/http/classes/class_gml.php
--- trunk/mapbender/http/classes/class_gml.php 2007-10-02 12:58:38 UTC (rev 1700)
+++ trunk/mapbender/http/classes/class_gml.php 2007-10-02 13:00:37 UTC (rev 1701)
@@ -1,356 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/class_gml.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-require_once(dirname(__FILE__)."/class_mb_exception.php");
-require_once(dirname(__FILE__)."/class_gmlMember.php");
-require_once(dirname(__FILE__)."/class_geomObj.php");
-require_once(dirname(__FILE__)."/class_geomColl.php");
-class gml{
- * Class variables:
- var $bbox = array();
- var $width;
- var $height;
- var $gml;
- var $lineColor = array(255, 0, 0);
- var $lineThickness = 3;
- var $textColor = array(0, 0, 0);
- var $cnt_gml;
- var $geomColl = array();
- var $pointSingle = array("GML:POINT");
- var $lineSingle = array("GML:LINESTRING");
- var $polygonSingle = array("GML:POLYGON");
- var $multi = array("GML:MULTIPOINT", "GML:MULTILINESTRING", "GML:MULTIPOLYGON");
- var $tagList = array();
- function setImageWidth($w) {
- $this->width = $w;
- function setImageHeight($h) {
- $this->height = $h;
- function setLineThickness($t) {
- $this->lineThickness = $t;
- function setLineColor($c) {
- $this->lineColor = $c;
- function setTextColor($c) {
- $this->textColor = $c;
- function setBBox($gmlIndex, $b) {
- $this->bbox[$gmlIndex] = explode(",", $b);
- function gml() {
- $this->cnt_gml = -1;
- $this->linethickness = 1;
- function addGmlList($gmlString, $separator) {
- $gmlArray = explode($separator, $gmlString);
- $this->addGml($gmlArray);
- function addGml($gmlArray){
- for ($i=0; $i<count($gmlArray); $i++) {
- $this->cnt_gml++;
- $this->gml[$this->cnt_gml] = $gmlArray[$i];
- #parseBbox will calculate a bbox that delivers
- #some output for testing.
- #uncomment the following line if there is no bbox
- #and you want to test png output
- #otherwise, you have to set a bbox with setBbox
- #$this->parseBbox($i, $gmlArray[$i]);
- $this->geomColl[$this->cnt_gml] = new geomColl();
- $this->parseGml($i);
- function getBBox($i) {
- return $this->bbox[$i];
- function getGml($i) {
- return $this->gml[$i];
- function getAllGeomColl(){
- return $this->geomColl;
- function getGeomColl($gmlIndex){
- return $this->geomColl[$gmlIndex];
- function parseGml($index){
- $data = preg_replace("/&/", "&", $this->gml[$index]);
- $this->tagList = array_merge($this->multi, $this->pointSingle, $this->lineSingle, $this->polygonSingle);
- $parser = xml_parser_create();
- xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
- xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
- xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
- xml_parse_into_struct($parser,$data,$values,$tags);
- $code = xml_get_error_code ($parser);
- if ($code) {
- $line = xml_get_current_line_number($parser);
- $mb_exception = new mb_exception(xml_error_string($code) . " in line " . $line);
- xml_parser_free($parser);
- $item = -1;
- $cnt_el = 1;
- $geom = false;
- $foundGeom = false;
- $typeset=false;
- $member=false;
- foreach ($values as $element) {
- if(mb_strtoupper($element['tag']) == mb_strtoupper("gml:featureMember") && $element['type'] == "open"){
- $member = true;
- if (in_array(mb_strtoupper($element['tag']),$this->tagList) && $element['type'] == "open" && $member==true && $geom==false && $typeset==false) {
- $this->geomColl[$index]->addGeometryMember($element['tag']);
- $typeset=true;
- if(in_array(mb_strtoupper($element['tag']),$this->pointSingle) && $element['type'] == "open" && $typeset==true){
- $foundGeom = true;
- $geom = true;
- $this->geomColl[$index]->addPoint();
- if(in_array(mb_strtoupper($element['tag']),$this->lineSingle) && $element['type'] == "open" && $typeset==true){
- $geom = true;
- $this->geomColl[$index]->addLine();
- if(in_array(mb_strtoupper($element['tag']),$this->polygonSingle) && $element['type'] == "open" && $typeset==true){
- $geom = true;
- $this->geomColl[$index]->addPolygon();
- if(mb_strtoupper($element['tag']) == mb_strtoupper("gml:coordinates") && $geom == true){
- $myGeom = $this->prepareCoordinates($element['value']);
- $coord = explode(",",$myGeom);
- for($i=0;$i<count($coord)-1; $i += 2){
- $coordinates = array($coord[$i], $coord[$i+1]);
- $this->geomColl[$index]->addCoordinates($coordinates);
- if(mb_strtoupper($element['tag']) == mb_strtoupper("label")){
- $this->geomColl[$index]->addLabel($element['value']);
- if ($foundGeom == true && $geom == false && mb_substr($element['tag'], 0, 4) != "gml:" && isset($element['value'])) {
- $this->geomColl[$index]->addAttribute($element['tag'], $element['value']);
- if((in_array(mb_strtoupper($element['tag']),$this->pointSingle)
- || in_array(mb_strtoupper($element['tag']),$this->lineSingle)
- || in_array(mb_strtoupper($element['tag']),$this->polygonSingle))
- && $element['type'] == "close"){
- $geom = false;
- if(mb_strtoupper($element['tag']) == mb_strtoupper("gml:featureMember") && $element['type'] == "close"){
- $member = false;
- $typeset=false;
- // if there is no bbox given by setbbox, this funtion finds lowest and highest x- & y-coordinates
- // and sets the bbox according to these values
- // if found it very useful for testing the png output, but now it may be obsolete
- function parseBbox($gmlIndex, $gml){
- $data = preg_replace("/&/", "&", $gml);
- if ($code) {
- $boundingbox = false;
- $cnt_member = false;
- $min_x = "";
- $min_y = "";
- $max_x = "";
- $max_y = "";
- $cnt_member=true;
- || in_array(mb_strtoupper($element['tag']),$this->polygonSingle)) && $element['type'] == "open"){
- $boundingbox=true;
- if(mb_strtoupper($element['tag']) == mb_strtoupper("gml:coordinates") && $boundingbox == true){
- if ($coord[$i] < $min_x || !$min_x) {
- $min_x = $coord[$i];
- if ($coord[$i] > $max_x || !$max_x) {
- $max_x = $coord[$i];
- if ($coord[$i+1] < $min_y || !$min_y) {
- $min_y = $coord[$i+1];
- if ($coord[$i+1] > $max_y || !$max_y) {
- $max_y = $coord[$i+1];
- || in_array(mb_strtoupper($element['tag']),$this->polygonSingle)) && $element['type'] == "close"){
- $cnt_member=false;
- $this->bbox[$gmlIndex][0] = $min_x;
- $this->bbox[$gmlIndex][1] = $min_y;
- $this->bbox[$gmlIndex][2] = $max_x;
- $this->bbox[$gmlIndex][3] = $max_y;
- function prepareCoordinates($strCoords){
- $ret = preg_replace("/\s/i", ",", trim($strCoords));
- return $ret;
- function png ($gmlIndex, $label){
- $image = imagecreate($this->width,$this->height);
- $transparent = ImageColorAllocate($image,255,255,255);
- ImageFilledRectangle($image,0,0,$this->width,$this->height,$transparent);
- ImageColorTransparent ($image , $transparent);
- $line = imagecolorallocate($image, $this->lineColor[0], $this->lineColor[1], $this->lineColor[2]);
- if($this->lineColor != $this->textColor){
- $text = imagecolorallocate($image, $this->textColor[0], $this->textColor[1], $this->textColor[2]);
- } else{
- $text = $line;
- imagesetthickness($image, $this->lineThickness);
- $image = $this->geomColl[$gmlIndex]->addToPng($image, $this->bbox[$gmlIndex], $this->width, $this->height, $line, $text, $label);
- return $image;
- function gml2JavaObj($gmlIndex) {
- $javaObjStr = "";
- $javaObjStr .= $this->geomColl[$gmlIndex]->getJavaObjStr($this->bbox[$gmlIndex], $this->width, $this->height);
- return $javaObjStr;
-#so far, this class has only been tested with gmls generated by UMN map server
-#load gml files like this
-#$data[0] = implode("", file("fluesse.xml"));
-#$data[1] = implode("", file("staedte.xml"));
-#$data[2] = implode("", file("plz.xml"));
-#initiate gml object like this
-#$D = new gml();
-#$D->parseGml();
-#you can add gml objects by passing a string of gmls...
-#$separator = "___";
-#$list = $data[0] . $separator . $data[1] . $separator . $data[2];
-#$D->addGmlList($list, $separator);
-# .. or alternatively by passing an array of gmls
-#$D->addGml($data);
-#print_r($D->getBBox(0));
-# you have to set a bbox for each gml
-# if no bbox is set, png output will not work
-#$D->setBBox(0, "3399409.885263,5566197.180021,3410613.307859,5573006.265254");
-#you can set the parameters for graphical output like this
-#$D->setImageWidth(640);
-#$D->setImageHeight(480);
-#$D->setLineThickness(1);
-#$D->setLineColor(array(125, 40, 25));
-#retrieve all geometries of all gmls like this
-#$data = $D->getAllGeomColl();
-#this is the way to get a single feature member
-#$data = $D->getGeomColl(2)->getMember(3)->getGeomObj(2);
-#if you want the data structure of a single gml, try this
-#$data = $D->getGeomColl(1);
-#this is how the data structure looks like (view source)
-#print_r($data);
-# if your gmls have points, you can add labels
-# from the attributes of the gml for png output
-#$data = $D->getGeomColl(2);
-#$member = $data->getMember(0);
-#$keys = $member->getAllAttributeKeys();
-#header("Content-type: image/png");
-#imagepng($D->png(2, $keys[3]));
-#alternatively, you can display the png without labels
-#imagepng($D->png(0, ""));
-#imagepng($D->png(1, ""));
-#check the subclasses for further documentation
\ No newline at end of file
More information about the Mapbender_commits
