[Mapbender-commits] r1709 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Fri Oct 5 07:47:02 EDT 2007
Author: verenadiewald
Date: 2007-10-05 07:47:02 -0400 (Fri, 05 Oct 2007)
New Revision: 1709
trunk/mapbender/http/javascripts/map_obj.js
new functions for gui layer style handling
Modified: trunk/mapbender/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js 2007-10-05 11:44:22 UTC (rev 1708)
+++ trunk/mapbender/http/javascripts/map_obj.js 2007-10-05 11:47:02 UTC (rev 1709)
@@ -244,6 +244,7 @@
return visibleLayers;
* get the actual style of all visible layers
@@ -256,7 +257,7 @@
var styles = [];
if(layers){
for(i = 0; i < layers.length; i++){
- var style = this.getStyleByLayerName(layers[i]);
+ var style = this.getCurrentStyleByLayerName(layers[i]);
if(!style){
style = '';
@@ -268,6 +269,21 @@
+ * check if layer is parentLayer
+ * @param layername
+ * @return the parent value of the given layer
+ * @type integer
+wms_const.prototype.checkLayerParentByLayerName = function(layername){
+ for(var i=0; i< this.objLayer.length; i++){
+ if(this.objLayer[i].layer_name == layername){
+ return this.objLayer[i].layer_parent;
* get the title of the current layer
* @param layername
@@ -283,7 +299,7 @@
- * get the style of the layer
+ * get the current style of the layer
* @param layername
* @return the stylename of the given layer
@@ -292,12 +308,44 @@
wms_const.prototype.getCurrentStyleByLayerName = function(layername){
- return this.objLayer[i].gui_layer_style;
+ if(this.objLayer[i].gui_layer_style==''){
+ return false;
+ else{
+ return this.objLayer[i].gui_layer_style;
+ * get the legendurl of the gui layer style
+ * @param stylename
+ * @return the legendurl of the given style
+ * @type string
+wms_const.prototype.getLegendUrlByGuiLayerStyle = function(layername,guiLayerStyle){
+ if(this.objLayer[i].layer_style.length==0){
+ return false;
+ for(var k=0; k< this.objLayer[i].layer_style.length; k++){
+ if(this.objLayer[i].layer_style[k]["name"]==guiLayerStyle){
+ if(this.objLayer[i].layer_style[k]["legendurl"]!=''){
+ return this.objLayer[i].layer_style[k]["legendurl"];
+ else {
+ return false;
* get all querylayers
* @return array of layernames
More information about the Mapbender_commits
