[Mapbender-commits] r1740 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Oct 26 06:12:53 EDT 2007
Author: christoph
Date: 2007-10-26 06:12:53 -0400 (Fri, 26 Oct 2007)
New Revision: 1740
   trunk/mapbender/http/classes/class_bbox.php
new functions
more notices
more comments
Modified: trunk/mapbender/http/classes/class_bbox.php
--- trunk/mapbender/http/classes/class_bbox.php	2007-10-18 14:52:40 UTC (rev 1739)
+++ trunk/mapbender/http/classes/class_bbox.php	2007-10-26 10:12:53 UTC (rev 1740)
@@ -2,7 +2,7 @@
 # $Id$
 # http://www.mapbender.org/index.php/
 # Copyright (C) 2002 CCGIS
 # This program is free software; you can redistribute it and/or modify
 # it under the terms of the GNU General Public License as published by
 # the Free Software Foundation; either version 2, or (at your option)
@@ -23,25 +23,25 @@
 db_select_db(DB,$con);
- * A Mapbender_point is a 2-dimensional point with an EPSG.
+ * A Mapbender_point is a 2-dimensional point with an EPSG.
 class Mapbender_point {
 	var $x;
 	var $y;
 	var $epsg;
 	 * @constructor
-	function Mapbender_point($x, $y, $epsg) {
-		if ($x == null || $y == null || $epsg == null) {
-			$e = new mb_exception("Mapbender_point: constructor: some parameters are not set!");
+	function __construct($x, $y, $epsg) {
+		if (!$x || !$y || !$epsg) {
+			$e = new mb_exception("Mapbender_point: constructor: some parameters are not set (set (x: ".$x.", y: ".$y.", epsg:".$epsg.")!");
 		$this->x = $x;
 		$this->y = $y;
 		$this->epsg = $epsg;
 	 * computes a new point with the minimal coordinates of this point and $point
@@ -65,7 +65,7 @@
 			$e = new mb_exception("Mapbender_point: cannot process min with different EPSG codes");
 	 * computes a new point with the maximal coordinates of this point and $point
@@ -86,10 +86,10 @@
 			return new Mapbender_point($maxx, $maxy, $point1->epsg);
 		else {
-			$e = new mb_exception("Mapbender_point: cannot process max with different EPSG codes");
+			$e = new mb_exception("Mapbender_point: cannot process min with different EPSG codes");
 	function isWestOf($point) {
 		if ($this->x < $point->x) {
 			return true;
@@ -101,8 +101,35 @@
 			return true;
+	 * Addition
+	 * @param anotherPoint another Mapbender_point
+	function plus ($anotherPoint) {
+		return new Mapbender_point($this->x + $anotherPoint->x, $this->y + $anotherPoint->y, $this->epsg);
+	 * Subtraction
+	function minus ($anotherPoint) {
+		return $this->plus($anotherPoint->times(-1));
+	 * Scalar multiplication
+	 * @param aFloat a floating point number
+	function times ($aFloat) {
+		return new Mapbender_point($this->x * $aFloat, $this->y * $aFloat, $this->epsg);
 	 * transforms this point to another EPSG
 	function transform($toEpsg) {
@@ -118,10 +145,10 @@
 			$this->epsg = $point->epsg;
 		else {
-			$e = new mb_exception("Mapbender_point: transformCoordinates needs PostgreSQL");
+			$e = new mb_exception("transformCoordinates needs PostgreSQL");
 	function __toString() {
 		return (string) "(" . $this->x . "," . $this->y . "," . $this->epsg . ")";
@@ -134,26 +161,56 @@
 	var $min;
 	var $max;
 	var $epsg;
 	 * @constructor
-	function Mapbender_bbox($min, $max, $epsg) {
-		if ($min->isWestOf($max) && $min->isSouthOf($max)) {
-			if ($min->epsg == $max->epsg && $min->epsg == $epsg) {
-				$this->min = $min;
-				$this->max = $max;
-				$this->epsg = $epsg;
+	function __construct($param0, $param1, $param2, $param3, $param4) {
+		// params are point, point, epsg
+		if (is_a($param0, "Mapbender_point") && is_a($param1, "Mapbender_point") && !$param3 && !$param4) {
+			$e = new mb_notice("Mapbender_bbox: constructor: point1, point2, epsg");
+			$min = $param0; // is a Mapbender_point
+			$max = $param1; // is a Mapbender_point
+			$epsg = $param2; // is an EPSG code like "EPSG:4326"
+			if ($min->isWestOf($max) && $min->isSouthOf($max)) {
+				if ($min->epsg == $max->epsg && $min->epsg == $epsg) {
+					$this->min = $min;
+					$this->max = $max;
+					$this->epsg = $epsg;
+				else {
+					$e = new mb_exception("Mapbender_bbox: constructor: EPSG mismatch!");
 			else {
-				$e = new mb_exception("Mapbender_bbox: EPSG mismatch!");
+				$e = new mb_exception("Mapbender_bbox: constructor: min (".$this->min.") is not southwest of max (".$this->max.")!");
+		// params are x1, y1, x2, xy, epsg
 		else {
-			$e = new mb_exception("Mapbender_bbox: min is not southwest of max!");
+			$e = new mb_notice("Mapbender_bbox: constructor: x1, y1, x2, y2, epsg");
+			$min = new Mapbender_point($param0, $param1, $param4);
+			$max = new Mapbender_point($param2, $param3, $param4);
+			$epsg = $param4; // is an EPSG code like "EPSG:4326"
+				else {
+			else {
 	 * Computes a new bounding box, bbox1 UNION bbox2
@@ -162,24 +219,27 @@
 			return array_pop($bboxArray);
 		elseif (count($bboxArray) >= 2) {
 			$bbox1 = array_pop($bboxArray);
 			$bbox2 = Mapbender_bbox::union($bboxArray);
 			if (!($bbox1 != null && $bbox1->isValid()) && !($bbox2 != null && $bbox2->isValid())) {
-				$e = new mb_notice("Mapbender_bbox: union: both parameters invalid!");
+				$e = new mb_exception("Mapbender_bbox: union: both parameters invalid!");
 				return null;
 			elseif (!($bbox1 != null && $bbox1->isValid()) && ($bbox2 != null && $bbox2->isValid())) {
-				$e = new mb_notice("Mapbender_bbox: union: first parameter invalid!");
+				$e = new mb_exception("Mapbender_bbox: union: first parameter invalid!");
 				return $bbox2;
 			elseif (($bbox1 != null && $bbox1->isValid()) && !($bbox2 != null && $bbox2->isValid())) {
-				$e = new mb_notice("Mapbender_bbox: union: second parameter invalid!");
+				$e = new mb_exception("Mapbender_bbox: union: second parameter invalid!");
 				return $bbox1;
 			else {
 				if ($bbox1->epsg == $bbox2->epsg) {
+					$e = new mb_notice("Mapbender_bbox: union: bbox1 is: " . $bbox1);
+					$e = new mb_notice("Mapbender_bbox: union: bbox2 is: " . $bbox2);
+					$e = new mb_notice("Mapbender_bbox: union: merging bbox1 and bbox2...");
 					return new Mapbender_bbox(Mapbender_point::min($bbox1->min, $bbox2->min), Mapbender_point::max($bbox1->max, $bbox2->max), $bbox1->epsg);
 				else {
@@ -192,9 +252,10 @@
 		return null;
 	 * transforms this bbox in another EPSG
+	 * @param toEpsg transform the bbox to this EPSG code, example: "EPSG:4326"
 		if ($this->isValid()) {
@@ -216,9 +277,9 @@
 		$e = new mb_exception("Mapbender_bbox: this is not a valid bbox!");
 		return false;
-		return (string) "[" . $this->min . $this->max . " " . $this->epsg . "]";
+		return (string) "[" . $this->min . $this->max . " " . $this->epsg . "]";
\ No newline at end of file
More information about the Mapbender_commits mailing list
