[Mapbender-commits] r1744 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Fri Oct 26 06:23:44 EDT 2007
Author: christoph
Date: 2007-10-26 06:23:44 -0400 (Fri, 26 Oct 2007)
New Revision: 1744
Added:
trunk/mapbender/http/classes/class_keyword.php
initial commit
Added: trunk/mapbender/http/classes/class_keyword.php
--- trunk/mapbender/http/classes/class_keyword.php (rev 0)
+++ trunk/mapbender/http/classes/class_keyword.php 2007-10-26 10:23:44 UTC (rev 1744)
@@ -0,0 +1,371 @@
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/class_administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+$con = db_connect(DBSERVER,OWNER,PW);
+db_select_db(DB,$con);
+ * class to handle keywords for services
+class Mapbender_keyword{
+ private $service;
+ private $serviceId;
+ * Constructor of the keyword-class
+ * set the service to: wms, layer, wfs, featuretype
+ * @param string service
+ * @param integer id the id of the service
+ function __construct($service,$serviceId){
+ $this->service = $service;
+ $this->serviceId = $serviceId;
+ if ($this->service == "layer"){
+ $this->table = 'layer_keyword';
+ $this->serviceIdColumn = 'fkey_layer_id';
+ //example for wms
+ else if ($this->service == "wms"){
+ $this->table = 'wms_keyword';
+ $this->serviceIdColumn = 'fkey_wms_id';
+ //example for featuretype
+ else if ($this->service == "featuretype"){
+ $this->table = 'wfs_featuretype_keyword';
+ $this->serviceIdColumn = 'fkey_featuretype_id';
+ * selects a keyword
+ * @param integer the keyword_id
+ * @return string the name of the selected keyword
+ function get($keywordId){
+ global $con;
+ $sql = "SELECT keyword FROM keyword WHERE keyword_id = $1";
+ $v = array($keywordId);
+ $t = array('i');
+ $res = db_prep_query($sql,$v,$t);
+ if($row = db_fetch_array($res)){
+ return $row['keyword'];
+ else{
+ return false;
+ /* selects keywords of layer
+ * @param integer the layer_id
+ * @return array keywords
+ function getLayerKeywords(){
+ global $con;
+ $sql = "SELECT keyword FROM keyword, layer_keyword, layer " .
+ "WHERE keyword.keyword_id = layer_keyword.fkey_keyword_id " .
+ "AND layer_keyword.fkey_layer_id = layer.layer_id " .
+ "AND layer.layer_id = $1";
+ $v = array($this->serviceId);
+ $t = array('i');
+ $keywordList = "";
+ $separator = "";
+ while($row = db_fetch_array($res)){
+ if($keywordList != ""){
+ $separator = ",";
+ $keywordList .= $separator.$row["keyword"];
+ return $keywordList;
+ /* selects keywords of featuretype
+ * @param integer the featuretype_id
+ function getFeaturetypeKeywords(){
+ global $con;
+ $sql = "SELECT keyword FROM keyword, wfs_featuretype_keyword, wfs_featuretype " .
+ "WHERE keyword.keyword_id = wfs_featuretype_keyword.fkey_keyword_id " .
+ "AND wfs_featuretype_keyword.fkey_featuretype_id = wfs_featuretype.featuretype_id " .
+ "AND wfs_featuretype.featuretype_id = $1";
+ $t = array('i');
+ $separator = "";
+ $separator = ",";
+ * Checks whether the keyword exist in the table keywords
+ * @param string the keyword
+ * @return integer the ID of the keyword
+ function exists($keyword){
+ global $con;
+ $sql = "SELECT keyword_id FROM keyword WHERE keyword = $1";
+ $v = array($keyword);
+ $t = array('s');
+ return $row['keyword_id'];
+ else{
+ return false;
+ * Inserts a new keyword in the parent table keyword
+ * Check first, if the keyword exists
+ * @return integer the id of the new keyword
+ function insert($keyword){
+ global $con;
+ if ($this->exists($keyword)){
+ return false;
+ else{
+ $sql = "INSERT INTO keyword (keyword) VALUES ($1)";
+ $t = array('s');
+ $id_sql = "SELECT keyword_id FROM keyword WHERE keyword = $1";
+ $id_v = array($keyword);
+ $id_t = array('s');
+ $id_res = db_prep_query($id_sql,$id_v,$id_t);
+ if($row = db_fetch_array($id_res)){
+ else{
+ return false;
+ * Deletes the entry in the parent table keyword
+ function delete($keywordId){
+ global $con;
+ $sql = "DELETE FROM keyword WHERE keyword_id = $1";
+ $t = array('i');
+ else{
+ return false;
+ * Inserts a new keyword-constraint in the crosstabulation
+ * @return integer the id of the new keyword-constraint
+ function allocate($keywordId){
+ global $con;
+ $sql = "INSERT INTO ".$this->table." (".$this->serviceIdColumn.", fkey_keyword_id) VALUES ($1,$2)";
+ $v = array($this->serviceId, $keywordId);
+ $t = array('i','i');
+ return $row['fkey_keyword_id'];
+ else{
+ return false;
+ * Checks whether the keyword exist in the crosstabulation layer_keywords
+ * @return true or false
+ function isAllocated($keywordId){
+ global $con;
+ $sql = "SELECT ".$this->serviceIdColumn." FROM ".$this->table." WHERE fkey_keyword_id = $1";
+ $t = array('i');
+ return true;
+ else{
+ return false;
+ * Deletes the entry in the crosstabulation (relation)
+ * @return integer the id of the keyword
+ function remove($keywordId){
+ global $con;
+ $sql = "DELETE FROM ".$this->table." WHERE ".$this->serviceIdColumn." = $1 AND fkey_keyword_id = $2";
+ if($res!=FALSE){
+ return true;
+ else{
+ return false;
+ * Deletes all entries of service in the crosstabulation (relation)
+ * @param
+ * @return
+ function removeAll(){
+ global $con;
+ $sql = "DELETE FROM ".$this->table." WHERE ".$this->serviceIdColumn." = $1";
+ $t = array('i');
+ if($res!=FALSE){
+ return true;
+ else{
+ return false;
+ * Deletes the keyword if it has no entry in one of the crosstabs
+ * @TODO check if the keyword exists in every crosstab (wms, layer, wfs, feturetype) !!!
+ function orphaned(){
+ global $con;
+ $sql = "DELETE FROM keyword WHERE NOT EXISTS (SELECT fkey_keyword_id FROM layer_keyword WHERE keyword.keyword_id = layer_keyword.fkey_keyword_id);";
+ //$sql .= " AND NOT EXISTS (SELECT fkey_keyword_id FROM wms_keyword WHERE keyword.keyword_id = wms_keyword.fkey_keyword_id);";
+ $res = db_prep_query($sql);
+ if($res!=FALSE){
+ return true;
+ else{
+ return false;
+ * add a new keyword.
+ * @param string the new keyword
+ function add($keyword){
+ // if the keyword exists add a new entry in the crosstab
+ if ($keywordId = $this->exists($keyword)){
+ $this->allocate($keywordId);
+ // if it doesn´t exist create a new entry in the keyword table and add a new entry in the crosstab
+ else{
+ $keywordId = $this->insert($keyword);
+ * add list of keywords to a service
+ * @param string[] keywords an array of keywords
+ function addList($keywords){
+ foreach ($keywords as $keyword){
+ else{
+ * replaces the keywords of a service
+ * @param string keywords an array of keywords
+ function replaceList($keywords){
+ // remove all entries in the crosstable for the current service
+ $this->removeAll();
+ // check for each keyword of the array if it exists
+ // check if the keyword is allocated
+ else{
+ $keywordIdNew = $this->insert($keyword);
+ $this->allocate($keywordIdNew);
+ // if a keyword exists, that has no constraint delete it
+ $this->orphaned();
+//$x = new Mapbender_keyword("layer",20840);
+//echo $x->replaceList(array(test1,test2));
More information about the Mapbender_commits
