[Mapbender-commits] r1751 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Fri Oct 26 07:33:58 EDT 2007
Author: christoph
Date: 2007-10-26 07:33:57 -0400 (Fri, 26 Oct 2007)
New Revision: 1751
trunk/mapbender/http/javascripts/mod_insertLayerPreviewIntoDb.php
latest version, let's see if it's usable at all
Modified: trunk/mapbender/http/javascripts/mod_insertLayerPreviewIntoDb.php
--- trunk/mapbender/http/javascripts/mod_insertLayerPreviewIntoDb.php 2007-10-26 11:28:39 UTC (rev 1750)
+++ trunk/mapbender/http/javascripts/mod_insertLayerPreviewIntoDb.php 2007-10-26 11:33:57 UTC (rev 1751)
@@ -1,5 +1,5 @@
<?php
-#$Id: mod_insertWmcIntoDb.php 359 2006-10-09 16:41:18Z christoph $
+#$Id: mod_insertLayerPreviewIntoDb.php 915 2007-09-19 13:57:27Z baudson $
#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
# Copyright (C) 2002 CCGIS
@@ -18,41 +18,48 @@
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
session_start();
-include("../../conf/mapbender.conf");
+include(dirname(__FILE__)."/../../conf/mapbender.conf");
+include(dirname(__FILE__)."/../../conf/geoportal.conf");
require_once(dirname(__FILE__)."/../classes/class_administration.php");
+require_once(dirname(__FILE__)."/../classes/class_connector.php");
+require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
+function savePreview($fileName, $fileContent) {
+ if (strlen($fileContent) > 0) {
+ $fileMapImg = fopen("..".LAYER_PREVIEW_URL."/".$fileName, 'w+');
+ if ($fileMapImg) {
+ rewind($fileMapImg);
+ $bytesWritten = fwrite($fileMapImg, $fileContent);
+ if ($bytesWritten) {
+ fflush($fileMapImg);
+ ftruncate($fileMapImg, ftell($fileMapImg));
+ fclose($fileMapImg);
+ return true;
+ $e = new mb_exception("..".LAYER_PREVIEW_URL."/".$fileName.": 0 bytes written.");
+ return false;
+ $e = new mb_exception("..".LAYER_PREVIEW_URL."/".$fileName.": could not open.");
+ return false;
+ $e = new mb_exception($fileName.": no file content.");
+ return false;
$gui_id = $_REQUEST["gui_id"];
$con = db_connect($DBSERVER,$OWNER,$PW);
db_select_db(DB,$con);
-function escByteA($binData) {
- $search = array();
- $replace = array();
- array_push($search, chr(92));
- array_push($replace, '\\134');
- array_push($search, chr(0));
- array_push($replace, '\\000');
- array_push($search, chr(39));
- array_push($replace, '\\047');
- array_push($search, chr(13));
- array_push($replace, '\\015');
- array_push($search, chr(10));
- array_push($replace, '\\012');
- $binData = preg_replace($search, $replace, $binData);
- return $binData;
if ($_POST["data"]) {
$d = explode("____", $_POST["data"]);
$mapurl = $d[0];
$legendurl = $d[1];
- $mapurl = mb_eregi_replace("(&width=)[0-9]+($|[^0-9])", "\\1200\\2", $mapurl);
- $mapurl = mb_eregi_replace("(&height=)[0-9]+($|[^0-9])", "\\1200\\2", $mapurl);
+ $mapurl = eregi_replace("(&width=)[0-9]+($|[^0-9])", "\\1".LAYER_PREVIEW_WIDTH."\\2", $mapurl);
+ $mapurl = eregi_replace("(&height=)[0-9]+($|[^0-9])", "\\1".LAYER_PREVIEW_HEIGHT."\\2", $mapurl);
$adm = new administration();
$layer_id = $_SESSION['layer_preview'];
@@ -60,9 +67,19 @@
echo "<script>alert('Could not find wms: ".$wms_getmap."');</script>";
else {
- $map_img = file_get_contents($mapurl);
- $legend_img = file_get_contents($legendurl);
+ session_write_close();
+ $con1 = new connector($mapurl);
+ $fileNameMap = $layer_id."_layer_map_preview.png";
+ $fileContentMap = $con1->file;
+ $success = savePreview($fileNameMap, $fileContentMap);
+ if (!$success) $fileNameMap = "";
+ $con2 = new connector($legendurl);
+ $fileNameLegend = $layer_id."_layer_legend_preview.png";
+ $fileContentLegend = $con2->file;
+ $success = savePreview($fileNameLegend, $fileContentLegend);
+ if (!$success) $fileNameLegend = "";
// $rlp_4326_box = array(6.10988942079081,48.987785376052,8.58790010810365,50.9273496139233);
$rlp_4326_box = array(6.05,48.9,8.6,50.96);
@@ -118,8 +135,11 @@
if ($new_miny < -90) $rlp_4326_box[1] = -90; else $rlp_4326_box[1] = $new_miny;
if ($new_maxy > 90) $rlp_4326_box[3] = 90; else $rlp_4326_box[3] = $new_maxy;
-// echo "<script>prompt('link', 'http://212.79.172.107/cgi-bin/mapserv?map=/data/umn/service_layer.map&VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=rlp,ows_layer&STYLES=&SRS=EPSG:4326&BBOX=".$rlp_4326_box[0].",".$rlp_4326_box[1].",".$rlp_4326_box[2].",".$rlp_4326_box[3]."&WIDTH=600&HEIGHT=600&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage&layer_id=".$extent_layer_id."');</script>";
- $extent_img = file_get_contents("http://212.79.172.107/cgi-bin/mapserv?map=/data/umn/service_layer.map&VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=rlp,ows_layer&STYLES=&SRS=EPSG:4326&BBOX=".$rlp_4326_box[0].",".$rlp_4326_box[1].",".$rlp_4326_box[2].",".$rlp_4326_box[3]."&WIDTH=120&HEIGHT=120&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage&layer_id=".$extent_layer_id);
+ $con3 = new connector(LAYER_EXTENT_URL."VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=rlp,ows_layer&STYLES=&SRS=EPSG:4326&BBOX=".$rlp_4326_box[0].",".$rlp_4326_box[1].",".$rlp_4326_box[2].",".$rlp_4326_box[3]."&WIDTH=120&HEIGHT=120&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage&layer_id=".$extent_layer_id);
+ $fileNameExtent = $layer_id."_layer_extent_preview.png";
+ $fileContentExtent = $con3->file;
+ $success = savePreview($fileNameExtent, $fileContentExtent);
+ if (!$success) $fileNameExtent = "";
$sql = "SELECT * FROM layer_preview WHERE fkey_layer_id = $1";
$v = array($layer_id);
@@ -127,17 +147,16 @@
$res = db_prep_query($sql, $v, $t);
$row = db_fetch_array($res);
if ($row['fkey_layer_id'] == $layer_id) {
- $sql = "UPDATE layer_preview SET layer_map_preview = $1, layer_extent_preview = $2, layer_legend_preview = $3 WHERE fkey_layer_id = $4";
- $v = array( escByteA($map_img), escByteA($extent_img), escByteA($legend_img), $layer_id);
+ $sql = "UPDATE layer_preview SET layer_map_preview_filename = $1, layer_extent_preview_filename = $2, layer_legend_preview_filename = $3 WHERE fkey_layer_id = $4";
+ $v = array($fileNameMap, $fileNameExtent, $fileNameLegend, $layer_id);
$t = array('s', 's', 's', 'i');
else {
- $sql = "INSERT INTO layer_preview (fkey_layer_id, layer_map_preview, layer_extent_preview, layer_legend_preview) VALUES ($1, $2, $3, $4)";
- $v = array($layer_id, escByteA($map_img), escByteA($extent_img), escByteA($legend_img));
+ $sql = "INSERT INTO layer_preview (fkey_layer_id, layer_map_preview_filename, layer_extent_preview_filename, layer_legend_preview_filename) VALUES ($1, $2, $3, $4)";
+ $v = array($layer_id, $fileNameMap, $fileNameExtent, $fileNameLegend);
$t = array('i', 's', 's', 's');
if (db_error()) {
echo "<script>alert(\"Error while saving layer preview: ".addslashes(db_error())."\");</script>";
More information about the Mapbender_commits
