[Mapbender-commits] r1754 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Oct 26 10:15:56 EDT 2007
Author: christoph
Date: 2007-10-26 10:15:56 -0400 (Fri, 26 Oct 2007)
New Revision: 1754
Added:
   trunk/mapbender/http/classes/class_monitor.php
   trunk/mapbender/http/php/mod_monitorCapabilities_main.php
   trunk/mapbender/http/php/mod_monitorCapabilities_read.php
   trunk/mapbender/http/php/mod_monitorCapabilities_write.php
checks if a wms that is reachable returns images or just error msgs
see http://trac.osgeo.org/mapbender/ticket/130
Added: trunk/mapbender/http/classes/class_monitor.php
--- trunk/mapbender/http/classes/class_monitor.php	                        (rev 0)
+++ trunk/mapbender/http/classes/class_monitor.php	2007-10-26 14:15:56 UTC (rev 1754)
@@ -0,0 +1,478 @@
+<?php
+# $Id: class_layer_monitor.php 791 2007-08-10 10:36:04Z baudson $
+# http://www.mapbender.org/index.php/
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../classes/class_wms.php");
+require_once(dirname(__FILE__)."/../classes/class_bbox.php");
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+define("MONITOR_DEFAULT_SCALE", 500000);
+define("MONITOR_IMG_WIDTH", 20);
+define("MONITOR_IMG_HEIGHT", 20);
+define("MB_RESOLUTION", 28.35);
+class Monitor {
+	 *  1 = reachable and in sync with db
+	 *  0 = reachable and out of sync with db
+	 * -1 = unreachable
+	 * -2 = monitoring in progress
+	var $result = -1;
+	 * 1  = the get map request DEFINITELY returns a valid map image
+	 * 0  = the WMS doesn't support XML error format. Who knows if the image is really a map?
+	 * -1 = the get map request doesn't return an image
+	var $returnsImage;
+	var $comment = "";
+	var $updated = "0";
+	var $supportsXMLException = false;
+	var $timestamp;
+	var $capabilitiesURL;
+	var $mapURL;
+	var $remoteXML;
+	var $localXML;
+	function __construct($wmsId, $uploadId, $autoUpdate) {
+		$this->wmsId = $wmsId;
+		$this->uploadId = $uploadId;
+		$this->autoUpdate = $autoUpdate;
+		$this->capabilitiesURL = $this->getUploadURL($this->wmsId, $this->uploadId);
+		set_time_limit(TIME_LIMIT);
+		$this->timestamp = time();
+		if ($this->capabilitiesURL) {
+			$remoteWms = new wms();
+			$remoteWms->createObjFromXML($this->capabilitiesURL);
+			$this->remoteXML = $remoteWms->wms_getcapabilities_doc;
+			$this->localXML = $this->getCapabilitiesDocByWMS($this->wmsId);
+			// service unreachable
+			if (!$this->remoteXML) {
+				$this->result = -1;
+				$this->comment = "Connection failed.";
+			 * service available;
+			 * no local copy of capabilities file,
+			 * so it has to be updated anyway
+			elseif (!$this->localXML) {
+				$this->result = 0;
+			 * check if local copy is different
+			 * to remote capabilties document
+			else {
+				 * compare to local capabilities document
+				// capabilities files match
+				if ($this->localXML == $this->remoteXML) {
+					$this->result = 1;
+					$this->comment = "WMS is stable.";
+				// capabilities files don't match
+				else {
+			 * if the WMS is available,
+			 * 1) get a map image
+			 * 2) update the local backup of the capabilities doc if necessary
+			if ($this->result != -1) {
+				$this->mapURL = $this->getMapRequest($this->wmsId);
+				if ($this->isImage($this->mapURL)) {
+					$this->returnsImage = 1;
+				else {
+					$this->returnsImage = -1;
+				 * if the local backup of the capabilities document
+				 * is deprecated, update the local backup
+				if ($this->result == 0) {
+					$mywms = new wms();
+					 * if the capabilities document is valid,
+					 * update it OR mark it as "not up to date"
+					if ($mywms->createObjFromXML($this->capabilitiesURL)) {
+						if ($this->autoUpdate) {
+							$mywms->updateObjInDB($this->wmsId);
+							$this->updated = "1";
+							$this->comment = "WMS has been updated.";
+						else {
+							$this->comment = "WMS is not up to date.";
+					// capabilities document is invalid
+					else {
+						$this->comment = "Invalid getCapabilities request/document or service exception.";
+		else {
+			$this->comment = "Invalid upload URL.";
+		$e = new mb_notice("class_monitor: constructor: result = " . $this->result);
+		$e = new mb_notice("class_monitor: constructor: comment = " . $this->comment);
+		$e = new mb_notice("class_monitor: constructor: returnsImage = " . $this->returnsImage);
+	public function __toString() {
+		$str = "";
+		$str .= "wmsid: " . $this->wmsId . "\nupload_id: " . $this->uploadId . "\n";
+		$str .= "autoupdate: " . $this->autoUpdate . "\n";
+		$str .= "result: " . $this->result . "\ncomment: " . $this->comment . "\n";
+		$str .= "timestamp: " . $this->timestamp . " (".date("F j, Y, G:i:s", $this->timestamp).")\n";
+		$str .= "getCapabilities URL: " . $this->capabilitiesURL . "\nupdated: " . $this->updated . "\n\n";
+		$str .= "getMap URL: " . $this->mapURL . "\nis image: " . $this->returnsImage . "\n\n";
+		$str .= "-------------------------------------------------------------------\n";
+		$str .= "remote XML:\n\n" . $this->remoteXML . "\n\n";
+		$str .= "local XML:\n\n" . $this->localXML . "\n\n";
+		return (string) $str;
+	 * Update database
+	function updateInDB() {
+		$sql = "UPDATE mb_monitor SET updated = $1, status = $2, image = $3, status_comment = $4, upload_url = $5, timestamp_end = $6, map_url = $7 WHERE upload_id = $8 AND fkey_wms_id = $9";
+		$v = array($this->updated, $this->result, $this->returnsImage, $this->comment, $this->capabilitiesURL, $this->timestamp, $this->mapURL, $this->uploadId, $this->wmsId);
+		$t = array('s', 'i', 'i', 's', 's', 's', 's', 's', 'i');
+		$res = db_prep_query($sql,$v,$t);
+	 * Checks if the mapUrl returns an image or an exception
+	private function isImage($url) {
+		$headers = get_headers($url, 1);
+		$e = new mb_notice("class_monitor: isImage: map URL is " . $url);
+		$e = new mb_notice("class_monitor: isImage: Content-Type is " . $headers["Content-Type"]);
+		if (preg_match("/xml/", $headers["Content-Type"])) {
+			return false;
+		return true;
+	 * Returns the upload url of some WMS
+	private function getUploadURL($wmsId, $upload_id) {
+		$e = new mb_notice("class_monitor: getUploadURL: wms = " . $wmsId);
+		$e = new mb_notice("class_monitor: getUploadURL: upload_id = " . $upload_id);
+		$sql = "SELECT upload_url FROM mb_monitor WHERE fkey_wms_id = $1 AND upload_id = $2";
+		$v = array($wmsId, $upload_id);
+		$t = array('i', 'i');
+		$someArray = db_fetch_array($res);
+		$e = new mb_notice("class_monitor: getUploadURL: url = " . $someArray["upload_url"]);
+		return $someArray["upload_url"];
+	 * Returns the character that needs to be appended to
+	 * a given online resource, in order to append other GET
+	 * parameters.
+	 * Possible characters: "?", "&", ""
+	private function mb_getConjunctionCharacter($onlineresource){
+		// index of character ? in online resource
+		$indexOfChar = mb_strpos($onlineresource,"?");
+		if($indexOfChar) {
+			// no conjunction character needed
+			if($indexOfChar == mb_strlen($onlineresource)-1){
+				return "";
+			else if (mb_substr($onlineresource, mb_strlen($onlineresource)-1) == "&") {
+				return "";
+			else{
+				return "&";
+		return "?";
+	 * retrieves all information necessary to build a map request,
+	 * concatenates them and returns a valid get map request
+	private function getMapRequest($wmsId) {
+		// get map (wms_getmap)
+		// version (wms_version)
+		$sql = "SELECT wms_getmap, wms_version FROM wms WHERE wms_id = $1";
+		$res = db_prep_query($sql, array($wmsId), array('i'));
+		$row = db_fetch_array($res);
+		$getmap = $row["wms_getmap"];
+		$version = $row["wms_version"];
+		//map format
+		$sql = "SELECT * FROM wms_format WHERE data_type = 'map' AND fkey_wms_id = $1";
+		$mapFormat = "";
+		while ($row = db_fetch_array($res)) {
+			$mapFormat = urlencode($row["data_format"]);
+			if (preg_match("/png/", $mapFormat) || preg_match("/gif/", $mapFormat) || preg_match("/jp.{1}g/", $mapFormat)) {
+				break;
+		// layers (all layers)
+		$sql = "SELECT layer_name FROM layer WHERE fkey_wms_id = $1 AND layer_parent <> '' AND layer_pos > 0";
+		$layerArray = array();
+			array_push($layerArray, urlencode($row["layer_name"]));
+		$layerList = implode(",", $layerArray);
+		// srs (layer_epsg: epsg)
+		// bbox (layer_epsg: minx, miny, maxx, maxy)
+		$sql = "SELECT epsg, minx, miny, maxx, maxy ";
+		$sql .= "FROM layer_epsg, (SELECT fkey_wms_id, layer_id FROM layer WHERE fkey_wms_id = $1 AND layer_parent = '' AND layer_pos = 0) AS l ";
+		$sql .= "WHERE l.layer_id = layer_epsg.fkey_layer_id AND l.fkey_wms_id = $1";
+		$bboxArray = array();
+			array_push($bboxArray, new Mapbender_bbox($row["minx"], $row["miny"], $row["maxx"], $row["maxy"], $row["epsg"]));
+		// get a bbox in a preferably non WGS84 epsg to use the scalehints
+		for ($i=0; $i < count($bboxArray); $i++) {
+			$bbox = $bboxArray[$i];
+			if ($bboxArray[$i]->epsg != "EPSG:4326") {
+				break;
+		 * transform to 31466 if is 4326
+		 * TODO: extend to other EPSG apart from 31466
+		if ($bbox->epsg == "EPSG:4326") {
+			$bbox->transform("EPSG:31466");
+		 * get map and check if result is image
+		// check if this WMS supports exception type XML
+		$sql = "SELECT data_format FROM wms_format WHERE fkey_wms_id = $1 AND data_type = 'exception'";
+		$v = array($wmsId);
+		$t = array('i');
+			$exceptionFormat = $row["data_format"];
+			// set the exception type to xml (if possible)
+			if (preg_match('/xml/', $exceptionFormat)) {
+				$this->supportsXMLException = true;
+				break;
+		// correct bbox according to scale
+		$scale = $this->getScaleForWMS($wmsId);
+		$bbox = $this->getBBoxInScale($bbox, $scale);
+		return $this->concatenateMapRequest($getmap, $version, $mapFormat, $layerList, $bbox, MONITOR_IMG_WIDTH, MONITOR_IMG_HEIGHT, $exceptionFormat);
+	 * updates a given BBox according to a given scale
+	 * @param bbox
+	 * @param scale
+	private function getBBoxInScale($bbox, $scale) {
+		$e = new mb_notice("class_monitor: getMapRequest: old bbox = " . $bbox);
+		$e = new mb_notice("class_monitor: getMapRequest: old bbox = " . $bbox->min->x . "," . $bbox->min->y . "," . $bbox->max->x . "," . $bbox->max->y);
+		$e = new mb_notice("class_monitor: getMapRequest: scale = " . $scale);
+		if ($scale) {
+			$center = $bbox->min->plus($bbox->max)->times(0.5);
+			$e = new mb_notice("class_monitor: getMapRequest: center = " . $center);
+			 * TODO: this formula should have documentation
+			$offset =  MONITOR_IMG_WIDTH / (MB_RESOLUTION * 100 * 2) * $scale;
+			$offsetPoint = new Mapbender_point($offset, $offset, $bbox->epsg);
+			$min = $center->minus($offsetPoint);
+			$max = $center->plus($offsetPoint);
+			$bbox->min = $min;
+			$bbox->max = $max;
+			$e = new mb_notice("class_monitor: getMapRequest: new bbox = " . $bbox);
+			$e = new mb_notice("class_monitor: getMapRequest: new bbox = " . $bbox->min->x . "," . $bbox->min->y . "," . $bbox->max->x . "," . $bbox->max->y);
+		return $bbox;
+	 * Returns an online resource representing a get map request
+	private function concatenateMapRequest(	$getmap, $wmsVersion, $mapFormat, $layerList,
+							$bbox, $width, $height, $exceptionFormat) {
+		 * getMap URL
+		$mapRequest = $getmap;
+		$mapRequest .= $this->mb_getConjunctionCharacter($getmap);
+		 * WMS version
+		if ($wmsVersion == "1.0.0") {
+			$mapRequest .= "WMTVER=" . $wmsVersion . "&REQUEST=map&";
+		else {
+			$mapRequest .= "VERSION=" . $wmsVersion . "&REQUEST=GetMap&SERVICE=WMS&";
+		 * Layer list
+		$mapRequest .= "LAYERS=" . $layerList . "&";
+		 * Format
+		 $mapRequest .= "FORMAT=" . $mapFormat . "&";
+		 * SRS and BBox
+		$mapRequest .= "SRS=" . $bbox->epsg . "&";
+		$mapRequest .= "BBOX=" . $bbox->min->x . "," . $bbox->min->y . "," . $bbox->max->x . "," . $bbox->max->y . "&";
+		 * Width and height
+		$mapRequest .= "WIDTH=" . $width . "&";
+		$mapRequest .= "HEIGHT=" . $height . "&";
+		 * BGColor
+		$mapRequest .= "BGCOLOR=0xffffff&";
+		 * Transparency
+		if (preg_match("/png/", $mapFormat) || preg_match("/gif/", $mapFormat)) {
+			$mapRequest .= "TRANSPARENT=TRUE&";
+		 * Exception format
+		$mapRequest .= "EXCEPTIONS=" . $exceptionFormat . "&";
+//		return urlencode($mapRequest);
+		return $mapRequest;
+	 * Checks if the given WMS has ScaleHints. If yes, a scale is selected and returned.
+	private function getScaleForWMS($wmsId) {
+		// get the scalehints
+		$sql = "SELECT layer_minscale, layer_maxscale FROM layer WHERE fkey_wms_id = $1 AND layer_pos = 0 AND layer_parent = '' AND layer_minscale <> layer_maxscale LIMIT 1";
+		$t = array('i');
+		$scaleHintArray = db_fetch_array($res);
+		 *  determine the scalehint
+		// if a scalehint exists
+		if ($scaleHintArray) {
+			// if upper boundary
+			if ($scaleHintArray["layer_minscale"] < $scaleHintArray["layer_maxscale"]) {
+				// TODO: find a better algorithm with a less obscure scale
+				$scaleHint = round($scaleHintArray["layer_maxscale"] - $scaleHintArray["layer_minscale"]) / 2;
+			// if lower boundary
+			else {
+				if ($scaleHintArray["layer_minscale"] < MONITOR_DEFAULT_SCALE) {
+					$scaleHint = MONITOR_DEFAULT_SCALE;
+				else {
+					$scaleHint = $scaleHintArray["layer_minscale"] + 1000;
+		// otherwise, use a default value
+		else {
+		return $scaleHint;
+	 * Returns the local backup of the given WMS' capabilities document
+	private function getCapabilitiesDocByWMS($wmsId) {
+		$sql = "SELECT wms_getcapabilities_doc FROM wms WHERE wms_id = $1";
+		$t = array('i');
+		return $someArray["wms_getcapabilities_doc"];
\ No newline at end of file
Modified: trunk/mapbender/http/php/mod_monitorCapabilities_main.php
--- trunk/mapbender/http/php/mod_monitorCapabilities_main.php	2007-10-26 13:59:20 UTC (rev 1753)
+++ trunk/mapbender/http/php/mod_monitorCapabilities_main.php	2007-10-26 14:15:56 UTC (rev 1754)
@@ -1,5 +1,5 @@
 <?php
-# $Id: mod_monitorCapabilities.php 371 2006-05-31 12:45:24Z christoph $
+# $Id: mod_monitorCapabilities_main.php 1240 2007-10-24 09:27:00Z baudson $
 # http://www.mapbender.org/index.php/Monitor_Capabilities
@@ -32,8 +32,8 @@
 function getConjunctionCharacter($onlineresource){
-	if(mb_strpos($onlineresource, "?")) {
-		$lastChar = mb_substr($onlineresource,mb_strlen($onlineresource)-1, 1);
+	if(strstr($onlineresource, "?")) {
+		$lastChar = substr($onlineresource,strlen($onlineresource)-1, 1);
 		if ($lastChar == "?" || $lastChar == "&") {return "";}
 		else{return "&";}
@@ -53,10 +53,10 @@
 	//command line
 	$p1 = $_SERVER["argv"][1];
 	$p2 = $_SERVER["argv"][2];
-	if (mb_substr($p1, 0,5) == "user:") {
-		$user = mb_substr($p1, 5);
-		if (mb_substr($p2, 0,4) == "gui:") {
-			$gui = mb_substr($p2, 4);
+	if (substr($p1, 0,5) == "user:") {
+		$user = substr($p1, 5);
+		if (substr($p2, 0,4) == "gui:") {
+			$gui = substr($p2, 4);
@@ -66,24 +66,39 @@
 $userid = $admin->getUserIdByUserName($user);
+ * if the current user is a valid user...
 if ($userid) {
 	$ownguis = $admin->getGuisByOwner($userid,true);
+	 * if monitoring is restricted to a single GUI...
 	if ($gui) {
+		// ... abort if the GUI doesn't exist
 		if (!$admin->guiExists($gui)) {
 			echo "GUI " . $gui . " doesn't exist.\n"; die();
+		// ... add the GUI to the array of GUIs that will be monitored
 		elseif (in_array($gui, $ownguis)) {
 			$ownguis = array($gui);
+		// ... abort if the GUI is not owned by the current user
 		else {
 			echo "User " . $user . " is not owner of GUI " . $gui . ".\n"; die();
+ * if current user is not a valid user, abort
 else {
 	echo $user . " is not a valid username.\n";	die();
+ * Array of WMS IDs. These are the WMS that the user owns.
 $wms_id_own = $admin->getWmsByOwnGuis($ownguis);
 // initialise monitoring processes
@@ -131,10 +146,10 @@
 for ($k=0; $k<count($wms_id_own); $k++) {
 	if (intval(AUTO_UPDATE)) {
-		$exec = PHP_PATH . "php mod_monitorCapabilities_write.php ".$wms_id_own[$k]." ".$time." 1 > ../tmp/output_".$time."_".$wms_id_own[$k].".txt &";
+		$exec = PHP_PATH . "php5 mod_monitorCapabilities_write.php ".$wms_id_own[$k]." ".$time." 1 > ../tmp/output_".$time."_".$wms_id_own[$k].".txt &";
 	else {
-		$exec = PHP_PATH . "php mod_monitorCapabilities_write.php ".$wms_id_own[$k]." ".$time." 0 > ../tmp/output_".$time."_".$wms_id_own[$k].".txt &";
+		$exec = PHP_PATH . "php5 mod_monitorCapabilities_write.php ".$wms_id_own[$k]." ".$time." 0 > ../tmp/output_".$time."_".$wms_id_own[$k].".txt &";
 	exec($exec);
@@ -169,7 +184,7 @@
 	if ($status[$i] == -2 && intval(time())-intval($timestamp_begin[$i]) > intval(TIME_LIMIT)) {
 		$comment[$i] = "Monitoring process timed out.";
 		$status[$i] = -1;
-		$new_sql = "UPDATE mb_monitor SET status = '-1', status_comment = 'Monitoring process timed out.', timestamp_end = $1 WHERE fkey_wms_id = $2 AND upload_id = $3";
+		$new_sql = "UPDATE mb_monitor SET status = '-1', isImage = '-1', status_comment = 'Monitoring process timed out.', timestamp_end = $1 WHERE fkey_wms_id = $2 AND upload_id = $3";
 		$new_v = array((intval($upload_id[$i])+intval(TIME_LIMIT)), $wms_id[$i], $time);
 		$new_t = array('s', 'i', 's');
 		$new_res = db_prep_query($new_sql,$new_v,$new_t);
@@ -186,7 +201,7 @@
 if ($body) {
 	$error_msg = "";
 	if ($admin->getEmailByUserId($userid)) {
-		$admin->sendEmail(MAILADMIN, MAILADMINNAME, $admin->getEmailByUserId($userid), $user, "WMS monitor report " . date("F j, Y, G:i:s", $time), utf8_decode($body), &$error_msg);
+//		$admin->sendEmail(MAILADMIN, MAILADMINNAME, $admin->getEmailByUserId($userid), $user, "WMS monitor report " . date("F j, Y, G:i:s", $time), utf8_decode($body), &$error_msg);
 	else {
 		$error_msg = "Email address of user '" . $admin->getUserNameByUserId($userid) . "' unknown!\n";
Modified: trunk/mapbender/http/php/mod_monitorCapabilities_read.php
--- trunk/mapbender/http/php/mod_monitorCapabilities_read.php	2007-10-26 13:59:20 UTC (rev 1753)
+++ trunk/mapbender/http/php/mod_monitorCapabilities_read.php	2007-10-26 14:15:56 UTC (rev 1754)
@@ -1,6 +1,6 @@
 <?php
-# $Id: mod_monitorCapabilities_read.php 76 2006-08-15 12:25:34Z heuser $
+# $Id: mod_monitorCapabilities_read.php 1283 2007-10-25 15:20:25Z baudson $
@@ -87,7 +87,7 @@
 		$avg_response_time[$wms[$i]] = round(db_result($res,0,1)-db_result($res,0,0), 1);
-	$sql = "SELECT status, status_comment, timestamp_begin, timestamp_end, upload_url, updated FROM mb_monitor ";
+	$sql = "SELECT status, status_comment, timestamp_begin, timestamp_end, upload_url, updated, image, map_url FROM mb_monitor ";
 	$sql .= "WHERE upload_id = $1 AND fkey_wms_id = $2 ORDER BY status, status_comment, timestamp_end, fkey_wms_id";
 	$v = array($upload_id[$wms[$i]], $wms_id[$wms[$i]]);
 	$t = array('s', 'i');
@@ -99,6 +99,8 @@
 	$timestamp_end[$wms[$i]] = db_result($res,0,"timestamp_end");
 	$upload_url[$wms[$i]] = db_result($res,0,"upload_url");
 	$updated[$wms[$i]] = db_result($res,0,"updated");
+	$mapurl[$wms[$i]] = db_result($res,0,"map_url");
+	$image[$wms[$i]] = db_result($res,0,"image");
  	if ($status[$wms[$i]] == -2 && intval(time())-intval($timestamp_begin[$wms[$i]]) > intval(TIME_LIMIT)) {
 		$comment[$wms[$i]] = "Monitoring process timed out.";
@@ -147,6 +149,10 @@
 		$newArray = $upload_id;
 		arsort($newArray);
+	elseif ($_GET['image'] == "last") {
+		$newArray = $image;
+		arsort($newArray);
@@ -158,6 +164,7 @@
 $str .= "<table cellpadding=10 cellspacing=0 border=0>";
 $str .= "<tr bgcolor='#dddddd'><th></th><th align='left'><a href='".$PHP_SELF."?sortby=wms'>wms</a></th>";
 $str .= "<th align='left' colspan = 2><a href='".$PHP_SELF."?sortby=status'>current status</a></th>";
+$str .= "<th align='left'><a href='".$PHP_SELF."?sortby=image'>image</a></th>";
 $str .= "<th align='left'><a href='".$PHP_SELF."?sortby=avgresp'>avg. response time</a></th>";
 $str .= "<th align='left'><a href='".$PHP_SELF."?sortby=avail'>overall availability</a></th><th></th></tr>";
@@ -179,6 +186,27 @@
 	$str .= "\n\t\t\t<td valign='top'><b>" . $wms_id[$k] . "</b><br>" . $admin->getWmsTitleByWmsId($wms_id[$k]) . "</td>";
 	$str .= "\n\t\t\t<td valign='top'><a href='".$upload_url[$k]."' target=_blank><img title='Connect to service' border=0 src = '../img/trafficlights/". $img. "'></a></td>";
 	$str .= "\n\t\t\t<td valign='top'>" . $comment[$k] . "<br><div style='font-size:12'>".date("F j, Y, G:i:s", $upload_id[$k])."</div></td>";
+	$str .= "\n\t\t\t<td valign='top'>";
+	$str .= "<table bgcolor='black' border=1 cellspacing=1 cellpadding=0><tr><td height=20 width=20 align=center valign=middle bgcolor='";
+	if ($image[$k] == -1) {
+		$str .= "red";
+	elseif ($image[$k] == 0) {
+		$str .= "yellow";
+	elseif ($image[$k] == 1) {
+		$str .= "green";
+	if ($image[$k] != -1) {
+		$str .= "'><a href='".$mapurl[$k]."'>o</a></td></tr></table></td>";
+	else {
+		$str .= "'><a href='".$mapurl[$k]."'>x</a></td></tr></table></td>";
 	$str .= "\n\t\t\t<td valign='top' align = 'left'>";
 	if ($avg_response_time[$k] == NULL) {
 		$str .= "n/a";
Modified: trunk/mapbender/http/php/mod_monitorCapabilities_write.php
--- trunk/mapbender/http/php/mod_monitorCapabilities_write.php	2007-10-26 13:59:20 UTC (rev 1753)
+++ trunk/mapbender/http/php/mod_monitorCapabilities_write.php	2007-10-26 14:15:56 UTC (rev 1754)
@@ -1,5 +1,5 @@
 <?php
-# $Id: mod_monitorCapabilities_write.php 76 2006-08-15 12:25:34Z heuser $
+# $Id: mod_monitorCapabilities_write.php 1235 2007-10-23 15:42:55Z baudson $
@@ -16,113 +16,26 @@
-//require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-require_once(dirname(__FILE__)."/../classes/class_wms.php");
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
 session_start();
-import_request_variables("PG");
-$con = db_connect($DBSERVER,$OWNER,$PW);
-db_select_db(DB,$con);
+require_once(dirname(__FILE__)."/../classes/class_monitor.php");
+ * incoming parameters from command line
 if ($_SERVER["argc"] != 4) {
 	echo "Insufficient arguments! Monitoring aborted.";
 	die();
 $wmsId = $_SERVER["argv"][1];
-$upload_id = $_SERVER["argv"][2];
-$auto_update = intval($_SERVER["argv"][3]);
+$uploadId = $_SERVER["argv"][2];
+$autoUpdate = intval($_SERVER["argv"][3]);
-// get the uploadURL
-$sql = "SELECT upload_url FROM mb_monitor WHERE fkey_wms_id = $1 AND upload_id = $2";
-$v = array($wmsId, $upload_id);
-$t = array('i', 's');
-$res = db_prep_query($sql,$v,$t);
-$someArray = db_fetch_row($res);
-$myURL = $someArray[0];
+$monitor = new Monitor($wmsId, $uploadId, $autoUpdate);
-// get the capabilities doc
-$sql = "SELECT wms_getcapabilities_doc FROM wms WHERE wms_id = $1";
-$v = array($wmsId);
-$t = array('i');
-$capabilities_doc = $someArray[0];
+echo $monitor;
-$comment = "";
-$updated = "0";
-$result = -1;
-set_time_limit(TIME_LIMIT);
-if ($myURL) {
-	$remoteWms = new wms();
-	$remoteWms->createObjFromXML($myURL);
-	$now = time();
-	$remoteXml = $remoteWms->wms_getcapabilities_doc;
-	// compare the capabilities XML documents
-	$localXml = $capabilities_doc;
-	if (!$remoteXml) {
-		$result = -1;
-		$comment = "Connection failed.";
-	elseif (!$localXml) {
-		$result = 0;
-	else {
-		if ($localXml == $remoteXml) {
-			$result = 1;
-			$comment = "WMS is stable.";
-		else {
-			$result = 0;
-	if ($result == 0) {
-		$mywms = new wms();
-		if ($mywms->createObjFromXML($myURL)) {
-			if ($auto_update) {
-				$mywms->updateObjInDB($wmsId);
-				$updated = "1";
-				$comment = "WMS has been updated.";
-			else {
-				$comment = "WMS is not up to date.";
-		else {
-			$result = -1;
-			$comment = "Invalid getCapabilities request/document or service exception.";
-else {
-	$result = -1;
-	$comment = "Invalid upload URL.";
-	$now = time();
-echo "wmsid: " . $wmsId . "\nupload_id: " . $upload_id . "\n";
-echo "autoupdate: " . $auto_update . "\n";
-echo "result: " . $result . "\ncomment: " . $comment . "\n";
-echo "timestamp: " . $now . " (".date("F j, Y, G:i:s",$now).")\n";
-echo "getCapabilities URL: " . $myURL . "\nupdated: " . $updated . "\n\n";
-echo "-------------------------------------------------------------------\n";
-echo "remote XML:\n\n" . $remoteXml . "\n\n";
-echo "local XML:\n\n" . $localXml . "\n\n";
-$sql = "UPDATE mb_monitor SET updated = $1, status = $2, status_comment = $3, upload_url = $4, timestamp_end = $5 WHERE upload_id = $6 AND fkey_wms_id = $7";
-$v = array($updated, $result, $comment, $myURL, $now, $upload_id, $wmsId);
-$t = array('s', 's', 's', 's', 's', 's', 'i');
+$monitor->updateInDB();
More information about the Mapbender_commits mailing list
