[Mapbender-commits] r1757 - trunk/mapbender/http/frames
svn_mapbender at osgeo.org
Fri Oct 26 10:59:11 EDT 2007
Author: christoph
Date: 2007-10-26 10:59:11 -0400 (Fri, 26 Oct 2007)
New Revision: 1757
trunk/mapbender/http/frames/index.php
re-added sessionId to modules (not sure if actually necessary)
left in some get-parameters from Geoportal that could be used in Mapbender, like portal_services, layer_preview. These entries are commented by #
Modified: trunk/mapbender/http/frames/index.php
--- trunk/mapbender/http/frames/index.php 2007-10-26 14:35:47 UTC (rev 1756)
+++ trunk/mapbender/http/frames/index.php 2007-10-26 14:59:11 UTC (rev 1757)
@@ -1,5 +1,5 @@
<?php
-#$Id$
+# $Id$
# http://www.mapbender.org/index.php/index.php
# Copyright (C) 2002 CCGIS
@@ -21,14 +21,21 @@
session_start();
mb_internal_encoding("UTF-8");
-require("../php/mb_validateSession.php");
-require_once("../classes/class_locale.php");
-require_once("../../conf/mapbender.conf");
+require(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
+require_once(dirname(__FILE__)."/../classes/class_locale.php");
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+#$e = new mb_notice("index.php: arguments: GML: " . $_SESSION["GML"]);
+#$e = new mb_notice("index.php: arguments: Zoom to layer: " . $_REQUEST["zoomToLayer"]);
+#$e = new mb_notice("index.php: arguments: portal_services: " . $_REQUEST["portal_services"]);
+#$e = new mb_notice("index.php: arguments: portal_services_wfs: " . $_REQUEST["portal_services_wfs"]);
+#$e = new mb_notice("index.php: arguments: layer_preview: " . $_REQUEST["layer_preview"]);
$con = db_connect(DBSERVER,OWNER,PW);
db_select_db(DB,$con);
-$pattern = '/sessionID/';
+$pattern = "/sessionID/";
$_SESSION["mb_user_gui"] = $_REQUEST["gui_id"];
@@ -83,6 +90,7 @@
<script type='text/javascript' src="../javascripts/map_obj.js"></script>
<script type='text/javascript' src="../javascripts/wfs_obj.js"></script>
<?php
+//echo "<script type='text/javascript' src='../javascripts/map.php?gui_id=".$_REQUEST["gui_id"]."&zoomToLayer=".$_REQUEST["zoomToLayer"]."&portal_services=".$_REQUEST['portal_services']."&portal_services_wfs=".$_REQUEST['portal_services_wfs']."&layer_preview=".$_REQUEST['layer_preview']."&".strip_tags(SID)."&mb_myBBOX=".$_REQUEST["mb_myBBOX"]."'></script>";
echo "<script type='text/javascript' src='../javascripts/map.php?gui_id=".$_REQUEST["gui_id"]."&".strip_tags(SID)."&mb_myBBOX=".$_REQUEST["mb_myBBOX"]."'></script>";
echo "<script type='text/javascript' src='../php/mod_createJSObjFromDB.php?". strip_tags (SID)."'></script>";
@@ -96,7 +104,7 @@
$cnt = 0;
while($row = db_fetch_array($res)){
if($row["e_mb_mod"] != ""){
- echo "<script type='text/javascript' src='../javascripts/".trim($row["e_mb_mod"])."?gui_id=".$_REQUEST["gui_id"]."'></script> ";
+ echo "<script type='text/javascript' src='../javascripts/".trim($row["e_mb_mod"])."?gui_id=".$_REQUEST["gui_id"]."&". strip_tags (SID)."'></script> ";
$cnt++;
More information about the Mapbender_commits
