[Mapbender-commits] r1759 - trunk/mapbender/http/classes
    svn_mapbender at osgeo.org
    Fri Oct 26 11:17:16 EDT 2007
Author: christoph
Date: 2007-10-26 11:17:16 -0400 (Fri, 26 Oct 2007)
New Revision: 1759
Added:
   trunk/mapbender/http/classes/class_layer_monitor.php
* new table layer monitor: counts how often a layer has been loaded from a WMC
* overview extent is now in WMC
* other Mapbender specific data stored in WMC, like wfs_conf_ids
Added: trunk/mapbender/http/classes/class_layer_monitor.php
--- trunk/mapbender/http/classes/class_layer_monitor.php	                        (rev 0)
+++ trunk/mapbender/http/classes/class_layer_monitor.php	2007-10-26 15:17:16 UTC (rev 1759)
@@ -0,0 +1,55 @@
+<?php
+# $Id: class_layer_monitor.php 791 2007-08-10 10:36:04Z baudson $
+# http://www.mapbender.org/index.php/
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+class Layer_load_count {
+	function __construct () {
+	 * increments the load count in table "layer_load_count" for
+	 * each layer in the WMC document by one.
+	function increment($layer_id) {
+		//check if an entry exists for the current layer id
+		$sql = "SELECT load_count FROM layer_load_count WHERE fkey_layer_id = $1";
+		$v = array($layer_id);
+		$t = array('i');
+		$res = db_prep_query($sql, $v, $t);
+		$row = db_fetch_array($res);
+		//if yes, increment the load counter
+		if ($row) {
+			$currentCount = $row["load_count"];
+			$sql = "UPDATE layer_load_count SET load_count = $1 WHERE fkey_layer_id = $2";
+			$v = array(intval($currentCount + 1), $layer_id);
+			$t = array('i', 'i');
+		//if no, insert a new row with current layer id and load_count = 1
+		else {
+			$sql = "INSERT INTO layer_load_count (fkey_layer_id, load_count) VALUES ($1, 1)";
+			$t = array('i');
\ No newline at end of file
More information about the Mapbender_commits
