[Mapbender-commits] r1769 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Mon Oct 29 08:43:58 EDT 2007
Author: christoph
Date: 2007-10-29 08:43:58 -0400 (Mon, 29 Oct 2007)
New Revision: 1769
trunk/mapbender/http/javascripts/mod_loadwmc.php
imported from Geoportal
Modified: trunk/mapbender/http/javascripts/mod_loadwmc.php
--- trunk/mapbender/http/javascripts/mod_loadwmc.php 2007-10-29 12:41:26 UTC (rev 1768)
+++ trunk/mapbender/http/javascripts/mod_loadwmc.php 2007-10-29 12:43:58 UTC (rev 1769)
@@ -37,41 +37,79 @@
if($cnt > 1){
echo "alert('loadwmc: ID not unique!');";
+$e_id_css = "loadwmc";
+include("../include/dyn_js.php");
echo "mod_loadwmc_target = '".$e_target."';";
+// this may be added at a later stage
+if ($new_wmc == 1) {
+ include("../generate_defaultWmc.php");
+ $startup = true;
+ $e = new mb_notice("loadwmc: new wmc");
+else {
+ $startup = false;
+ $e = new mb_notice("loadwmc: old wmc");
+if ($gui_changed == 0) {
+ if ($_REQUEST['portal_services']) {
+ $e = new mb_notice("loadwmc: merging layers");
+ include("../merge_layers.php");
+ if ($_SESSION['GML']) {
+ $e = new mb_notice("loadwmc: merging bbox");
+ include("../merge_bbox.php");
function load_wmc_session() {
<?php
- if (isset($_SESSION['mb_wmc']) && !empty($_SESSION['mb_wmc'])) {
+ if (isset($_SESSION['mb_wmc'])) {
$wmc = new wmc();
if ($wmc->createObjFromWMC_xml($_SESSION['mb_wmc'])) {
+ $js = "";
if ($_SESSION['layer_preview']) {
+// echo "var e = new Mb_notice('mod_loadwmc: load_wmc_session: layer preview');";
$js = $wmc->createJsObjFromWMC("", $e_target, "load");
- else if ($_SESSION['startup'] == true) {
+ else if ($startup == true) {
+// echo "var e = new Mb_notice('mod_loadwmc: load_wmc_session: load new wmc');";
$js = $wmc->createJsObjFromWMC("", $e_target, "merge");
- $_SESSION['startup'] = false;
+ $startup = false;
else {
+// echo "var e = new Mb_notice('mod_loadwmc: load_wmc_session: load old wmc');";
echo $js;
+ else {
+ echo "var e = new Mb_notice('mod_loadwmc: load_wmc_session: error parsing wmc');";
+ else {
+ echo "var e = new Mb_warning('mod_loadwmc: load_wmc_session: no wmc set!');";
-//mb_registerInitFunctions('load_wmc_session()');
+try {if (loadFromSession) {}}catch(e) {loadFromSession = 0;}
+if (loadFromSession) {
+ mb_registerInitFunctions('load_wmc_session()');
var mod_loadwmc_img = new Image(); mod_loadwmc_img.src = "<?php echo $e_src; ?>";
-//var mod_loadwmc_img_over = new Image(); mod_loadwmc_img_over.src = "<?php echo preg_replace("/_off/","_over",$e_src); ?>";
+//var mod_loadwmc_img_over = new Image(); mod_loadwmc_img_over.src = "<?php echo preg_replace("/_off/","_over",$e_src); ?>";
+function mod_importWmc(id){
+ alert(id);
function mod_loadwmc(obj){
- windowWmc = window.open("../php/mb_listWMCs.php?<?php echo "e_id=".$e_id . "&" . SID;?>","displayWmc","width=500, height=600, scrollbars=yes, dependent=yes");
- //windowWmc.focus();
+ windowWmc = window.open("../php/mb_listWMCs.php?<?php echo SID;?>","displayWmc","width=500, height=600, scrollbars=yes, dependent=yes");
function mod_loadwmc_init(obj){
//document.getElementById("loadwmc").src = mod_zoom1_img_over.src;
More information about the Mapbender_commits
