[Mapbender-commits] r1771 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Mon Oct 29 08:52:00 EDT 2007
Author: christoph
Date: 2007-10-29 08:52:00 -0400 (Mon, 29 Oct 2007)
New Revision: 1771
trunk/mapbender/http/php/mod_wfs_gazetteer_server.php
imported from Geoportal
Modified: trunk/mapbender/http/php/mod_wfs_gazetteer_server.php
--- trunk/mapbender/http/php/mod_wfs_gazetteer_server.php 2007-10-29 12:50:43 UTC (rev 1770)
+++ trunk/mapbender/http/php/mod_wfs_gazetteer_server.php 2007-10-29 12:52:00 UTC (rev 1771)
@@ -1,210 +1,171 @@
-<?php
-# $Id: mod_wfsrequest.php 1008 2007-01-16 11:26:56Z christoph $
-# http://www.mapbender.org/index.php/Administration
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-include(dirname(__FILE__)."/../classes/class_gml2.php");
-require_once(dirname(__FILE__)."/../extensions/JSON.php");
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-$con = db_connect($DBSERVER,$OWNER,$PW);
-db_select_db($DB,$con);
-$command = $_REQUEST["command"];
-function checkAccessConstraint($filter, $wfs_conf_id) {
- /* wfs_conf_element */
- $sql = "SELECT * FROM wfs_conf_element ";
- $sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
- $sql .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
- $sql .= "ORDER BY wfs_conf_element.f_respos";
- $v = array($wfs_conf_id);
- $t = array('i');
- $res = db_prep_query($sql,$v,$t);
- while($row = db_fetch_array($res)){
- if (!empty($row["f_auth_varname"])) {
- $auth_varname = $row["f_auth_varname"];
- $element_name = $row["element_name"];
- if (!empty($auth_varname)) {
- if (isValidVarName($auth_varname)) {
- $user = eval("return " . $auth_varname . ";");
- $pattern = "(<ogc:Filter[^>]*>)(.*)(</ogc:Filter>)";
- $replacement = "\\1<And>\\2<ogc:PropertyIsEqualTo><ogc:PropertyName>" . $element_name . "</ogc:PropertyName><ogc:Literal>" . $user . "</ogc:Literal></ogc:PropertyIsEqualTo></And>\\3";
- $filter = mb_eregi_replace($pattern, $replacement, $filter);
- return $filter;
-if ($command == "getWfsConf") {
- $wfsConfIdString = $_GET["wfsConfIdString"];
- if ($wfsConfIdString != "") {
- $wfsConfIdArray = mb_split(",", $wfsConfIdString);
- else {
- echo "please specify wfs conf id.";
- die();
- $sql = "SELECT * FROM wfs_conf ";
- $sql .= "JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
- $sql .= "WHERE wfs_conf.wfs_conf_id IN (";
- $v = array();
- $t = array();
- for ($i = 0; $i < count($wfsConfIdArray); $i++) {
- if ($i > 0) {$sql .= ", ";}
- $sql .= "$" . ($i+1);
- array_push($v, $wfsConfIdArray[$i]);
- array_push($t, 'i');
- $sql .= ")";
- $res = db_prep_query($sql, $v, $t);
- $obj = array();
- while ($row = db_fetch_array($res)) {
- $id = $row["wfs_conf_id"];
- $sql_conf_element = "SELECT * FROM wfs_conf_element ";
- $sql_conf_element .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
- $sql_conf_element .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
- $sql_conf_element .= "AND wfs_conf_element.f_search = 1 ORDER BY wfs_conf_element.f_pos";
- $v_conf_element = array($id);
- $t_conf_element = array('i');
- $res_conf_element = db_prep_query($sql_conf_element, $v_conf_element, $t_conf_element);
- $elementArray = array();
- while ($row_conf_element = db_fetch_array($res_conf_element)) {
- $currentElement = array("f_search" => $row_conf_element["f_search"],
- "f_style_id" => $row_conf_element["f_style_id"],
- "f_toupper" => $row_conf_element["f_toupper"],
- "f_label" => $row_conf_element["f_label"],
- "f_label_id" => $row_conf_element["f_label_id"],
- "element_name" => $row_conf_element["element_name"],
- "element_type" => $row_conf_element["element_type"]
- array_push($elementArray, $currentElement);
- $sql_feature_type = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1 AND featuretype_id = $2";
- $v_feature_type = array($row["fkey_wfs_id"], $row["fkey_featuretype_id"]);
- $t_feature_type = array("i", "i");
- $res_feature_type = db_prep_query($sql_feature_type, $v_feature_type, $t_feature_type);
- if($row_feature_type = db_fetch_array($res_feature_type)){
- $featuretype_name = $row_feature_type["featuretype_name"];
- $featuretype_srs = $row_feature_type["featuretype_srs"];
- $currentRow = array("g_label" => $row["g_label"],
- "g_label_id" => $row["g_label_id"],
- "g_style" => $row["g_style"],
- "g_button" => $row["g_button"],
- "g_button_id" => $row["g_button_id"],
- "g_buffer" => $row["g_buffer"],
- "g_res_style" => $row["g_res_style"],
- "g_use_wzgraphics" => $row["g_use_wzgraphics"],
- "wfs_id" => $row["fkey_wfs_id"],
- "featuretype_id" => $row["fkey_featuretype_id"],
- "featuretype_name" => $featuretype_name,
- "featuretype_id" => $featuretype_srs,
- "wfs_getfeature" => $row["wfs_getfeature"],
- "element" => $elementArray
- $obj[$id] = $currentRow;
- $json = new Services_JSON();
- $output = $json->encode($obj);
- echo $output;
-else if ($command == "getSearchResults") {
- $wfs_conf_id = $_REQUEST["wfs_conf_id"];
- $backlink = $_REQUEST["backlink"];
- $frame = $_REQUEST["frame"];
- $filter = $_REQUEST["filter"];
- $url = $_REQUEST["url"];
- /* wfs_conf */
- $sql = "SELECT * FROM wfs_conf JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
- $sql .= "WHERE wfs_conf.wfs_conf_id = $1";
- $t = array('i');
- if ($row = db_fetch_array($res)) {
- $g_res_style = $row["g_res_style"];
- else {
- die("wfs_conf " . $wfs_conf_id . "data not available");
- $sql .= "AND wfs_conf_element.f_show = 1 ORDER BY wfs_conf_element.f_respos;";
- $t = array('i');
- $col = array();
- array_push($col, $row["element_name"]);
- if (count($col) == 0) {
- die("wfs_conf_element data not available");
- // append authorisation condition to filter
- $filter = checkAccessConstraint($filter, $wfs_conf_id);
- $admin = new administration();
- $req = urldecode($url).urlencode($admin->char_decode(stripslashes($filter)));
- $mygml = new gml2();
- $mygml->parsegml($req);
- // generates JavaScript code that will add a geometry array containing
- // all the result geometries and their attributes (wfs_conf_elements)
- $js = "";
- if ($mygml->getMemberCount() > 0) {
- $js .= $mygml->exportGeometriesToJS(true);
- for ($i = 0; $i < $mygml->getMemberCount(); $i++) {
- for ($j = 0; $j < count($col); $j++){
- $js .= "geom.get(".$i.").e.setElement('".$j."', '".$mygml->getValueBySeparatedKey($i, $col[$j]) . "');\n";
- echo $js;
-else {
- echo "please enter a valid command.";
+<?php
+# $Id: mod_wfs_gazetteer_server.php 1190 2007-10-18 10:38:38Z baudson $
+# http://www.mapbender.org/index.php/Administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+session_start();
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+include(dirname(__FILE__)."/../classes/class_gml2.php");
+require_once(dirname(__FILE__)."/../extensions/JSON.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+require_once(dirname(__FILE__)."/../classes/class_wfs_conf.php");
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db($DB,$con);
+$command = $_REQUEST["command"];
+ * checks if a variable name is valid.
+ * Currently a valid name would be sth. like $_SESSION["mb_user_id"]
+ * TODO: this function is also in mod_wfs_result!! Maybe merge someday.
+function isValidVarName ($varname) {
+ if (preg_match("/[\$]{1}_[a-z]+\[\"[a-z_]+\"\]/i", $varname) != 0) {
+ return true;
+ return false;
+ * If access to the WFS conf is restricted, modify the filter.
+ function checkAccessConstraint($filter, $wfs_conf_id) {
+ /* wfs_conf_element */
+ $sql = "SELECT * FROM wfs_conf_element ";
+ $sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
+ $sql .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
+ $sql .= "ORDER BY wfs_conf_element.f_respos";
+ $v = array($wfs_conf_id);
+ $t = array('i');
+ $res = db_prep_query($sql,$v,$t);
+ while($row = db_fetch_array($res)){
+ if (!empty($row["f_auth_varname"])) {
+ $auth_varname = $row["f_auth_varname"];
+ $element_name = $row["element_name"];
+ if (!empty($auth_varname)) {
+ if (isValidVarName($auth_varname)) {
+ $user = eval("return " . $auth_varname . ";");
+ if ($user) {
+ $pattern = "(<ogc:Filter[^>]*>)(.*)(</ogc:Filter>)";
+ $replacement = "\\1<And>\\2<ogc:PropertyIsEqualTo><ogc:PropertyName>" . $element_name . "</ogc:PropertyName><ogc:Literal>" . $user . "</ogc:Literal></ogc:PropertyIsEqualTo></And>\\3";
+ $filter = mb_eregi_replace($pattern, $replacement, $filter);
+ else {
+ $e = new mb_exception("mod_wfs_gazetteer_server: checkAccessConstraint: invalid value of variable containing user information!");
+ else {
+ $e = new mb_exception("mod_wfs_gazetteer_server: checkAccessConstraint: var name is not valid! (" . $auth_varname . ")");
+ return $filter;
+if ($command == "getWfsConf") {
+ $wfsConfIdString = $_GET["wfsConfIdString"];
+ if ($wfsConfIdString != "") {
+ //array_keys(array_flip()) produces an array with unique entries
+ $wfsConfIdArray = array_keys(array_flip(mb_split(",", $wfsConfIdString)));
+ else {
+ echo "please specify wfs conf id.";
+ die();
+ $obj = new WfsConf($wfsConfIdArray);
+ $json = new Services_JSON();
+ $output = $json->encode($obj->confArray);
+ echo $output;
+else if ($command == "getSearchResults") {
+ $wfs_conf_id = $_REQUEST["wfs_conf_id"];
+ $backlink = $_REQUEST["backlink"];
+ $frame = $_REQUEST["frame"];
+ $filter = $_REQUEST["filter"];
+ $url = $_REQUEST["url"];
+ /* wfs_conf */
+ $sql = "SELECT * FROM wfs_conf JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
+ $sql .= "WHERE wfs_conf.wfs_conf_id = $1";
+ $t = array('i');
+ if ($row = db_fetch_array($res)) {
+ $g_res_style = $row["g_res_style"];
+ else {
+ die("wfs_conf " . $wfs_conf_id . "data not available");
+ $sql .= "AND wfs_conf_element.f_show = 1 ORDER BY wfs_conf_element.f_respos;";
+ $t = array('i');
+ $col = array();
+ while ($row = db_fetch_array($res)) {
+ array_push($col, $row["element_name"]);
+ if (count($col) == 0) {
+ die("wfs_conf_element data not available");
+ // append authorisation condition to filter
+ $filter = checkAccessConstraint($filter, $wfs_conf_id);
+ $admin = new administration();
+ $req = urldecode($url).urlencode($admin->char_decode(stripslashes($filter)));
+ $mygml = new gml2();
+ $mygml->parsegml($req);
+ // generates JavaScript code that will add a geometry array containing
+ // all the result geometries and their attributes (wfs_conf_elements)
+ $js = "";
+ if ($mygml->getMemberCount() > 0) {
+ $js .= $mygml->exportGeometriesToJS(true);
+ for ($i = 0; $i < $mygml->getMemberCount(); $i++) {
+ for ($j = 0; $j < count($col); $j++){
+ $js .= "geom.get(".$i.").e.setElement('".$j."', '".$mygml->getValueBySeparatedKey($i, $col[$j]) . "');\n";
+ echo $js;
+else {
+ echo "please enter a valid command.";
\ No newline at end of file
More information about the Mapbender_commits
