[Mapbender-commits] r1773 - in trunk/mapbender/owsproxy/http: . classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Oct 29 10:24:32 EDT 2007
Author: christoph
Date: 2007-10-29 10:24:32 -0400 (Mon, 29 Oct 2007)
New Revision: 1773
Added:
   trunk/mapbender/owsproxy/http/classes/
   trunk/mapbender/owsproxy/http/classes/class_QueryHandler.php
   trunk/mapbender/owsproxy/http/index.php
imported from Geoportal
Added: trunk/mapbender/owsproxy/http/classes/class_QueryHandler.php
--- trunk/mapbender/owsproxy/http/classes/class_QueryHandler.php	                        (rev 0)
+++ trunk/mapbender/owsproxy/http/classes/class_QueryHandler.php	2007-10-29 14:24:32 UTC (rev 1773)
@@ -0,0 +1,159 @@
+<?php
+# $Id: $
+# http://www.mapbender.org/index.php/class_administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once("../../../http/classes/class_mb_exception.php");
+ * class to handle the querystring and the params
+class QueryHandler{
+	private $reqParams = array();
+	private $reqParamsToLower = array();
+	private $owsproxyServiceKey = 'wms';
+	private $owsproxyServiceId;
+	private $onlineResource;
+	 * Constructor of the QueryHandler
+	function __construct(){
+		$this->setRequestParams(array_keys($_REQUEST));
+		$notice = new mb_notice("const: querystring: ".$this->getQueryString());
+	 * set all query parameter-keys and -values to lowerCase
+	 * so that they could be handled caseinsensitive
+	 * set another array with original keys and values
+	 * @param string[] the keys of all query parameters
+	 * @return string[] an associative array with request parameters keys (tolowercase) and values (tolower)
+	function setRequestParams($keys){
+		for($i=0; $i<count($keys); $i++){
+			$this->reqParams[strtolower($keys[$i])] = $_REQUEST[$keys[$i]];
+			$this->reqParamsToLower[strtolower($keys[$i])] = $_REQUEST[$keys[$i]];
+			if($keys[$i] == $this->owsproxyServiceKey){
+				$this->owsproxyServiceId = $_REQUEST[$keys[$i]];
+				$notice = new mb_notice("owsId: ".$this->owsproxyServiceId);
+	 * checks is a request param is part of the original request
+	 * @param string request key
+	 * @return boolean true if it is part of original request
+	function isValidParam($key){
+		if($key == 'sid'){
+			return false;
+		else if($key == $this->owsproxyServiceKey){
+			return false;
+		else if($key == ini_get("session.name")){
+			return false;
+		else if($key == 'request' && $this->reqParams[$key] == 'external'){
+			return false;
+		else{
+			return true;
+	 * gets the request params
+	 * @return request params
+	function getRequestParams(){
+		return $this->reqParamsToLower;
+	 * modifies the layers
+	 function setParam($param,$value){
+		$mykeys = array_keys($this->reqParams);
+		for($i=0; $i<count($mykeys);$i++){
+			if(strtolower($mykeys[$i]) == strtolower($param)){
+				$this->reqParams[$mykeys[$i]] = $value;
+				$n = new mb_notice("QueryHandler: setParam: ".serialize($this->reqParams));
+	  * gets the original query string
+	  * @return string original query string
+	  function getQueryString(){
+		$cnt = 0;
+			if($this->isValidParam($mykeys[$i])){
+				if($cnt > 0){
+					$qstring .= "&";
+				$qstring .= $mykeys[$i]."=".rawurlencode(stripslashes($this->reqParams[$mykeys[$i]]));
+				$cnt++;
+		$notice = new mb_notice("getQueryString() : " . $qstring);
+		return $qstring;
+	   * gets the original request with url and query string
+	   * @return string request
+	   function getRequest(){
+	   		$req = $this->onlineResource.$this->getConjunctionCharacter($this->onlineResource).$this->getQueryString();
+	   		$notice = new mb_notice("onlineResource:". $req);
+	   		return $req;
+	    * gets the conjunction character between url and query string
+	    function getConjunctionCharacter($url){
+			if(strpos($url,"?")){
+				if(strpos($url,"?") == strlen($url)){
+				$cchar = "";
+				}else if(strpos($url,"&") == strlen($url)){
+					$cchar = "";
+				}else{
+					$cchar = "&";
+			if(strpos($url,"?") === false){
+				$cchar = "?";
+			return $cchar;
+		function getOwsproxyServiceId(){
+			return $this->owsproxyServiceId;
+		function setOnlineResource($url){
+			$this->onlineResource = $url;
\ No newline at end of file
Modified: trunk/mapbender/owsproxy/http/index.php
--- trunk/mapbender/owsproxy/http/index.php	2007-10-29 13:12:49 UTC (rev 1772)
+++ trunk/mapbender/owsproxy/http/index.php	2007-10-29 14:24:32 UTC (rev 1773)
@@ -22,29 +22,33 @@
 require("../../http/classes/class_administration.php");
 require("../../http/classes/class_connector.php");
 require_once("../../http/classes/class_mb_exception.php");
+require("./classes/class_QueryHandler.php");
 /***** conf *****/
 $imageformats = array("image/png","image/gif","image/jpeg", "image/jpg");
-$mbkeys = array("sid",strtolower(ini_get("session.name")),"wms");
 /***** conf *****/
 $con = db_connect(DBSERVER,OWNER,PW);
 db_select_db(DB,$con);
+$postdata = $HTTP_RAW_POST_DATA;
-$reqParams = array();
-$myKeys = array_keys($_REQUEST);
-// create an associative array with request parameters (get)
-for($i=0; $i<count($myKeys); $i++){
-	$tmp[$i] = removeQM(strtolower($myKeys[$i]));
-	$$tmp[$i]  = $_REQUEST[$myKeys[$i]];
-	if(!in_array(removeQM(strtolower($myKeys[$i])),$mbkeys)){
-		$reqParams[removeQM(strtolower($myKeys[$i]))] = $_REQUEST[$myKeys[$i]];
+$owsproxyService = $_REQUEST['wms']; //ToDo: change this to 'service' in the apache url-rewriting
+$query = new QueryHandler();
+// an array with keys and values toLoserCase -> caseinsensitiv
+$reqParams = $query->getRequestParams();
+$notice = new mb_notice("owsproxy id:".$query->getOwsproxyServiceId());
 // check session
 session_id($_REQUEST["sid"]);
 session_start();
+if(!$_SESSION['mb_user_id']){
+	$notice = new mb_notice("Permission denied");
+	throwE("Permission denied");
+	die();
 //if($_SESSION['mb_user_ip'] != $_SERVER['REMOTE_ADDR']){
 //	throwE(array("No session data available.","Permission denied.","Please authenticate."));
@@ -52,42 +56,65 @@
 /*************  workflow ************/
-$n = new administration();
-switch (strtolower($request)) {
+$n = new administration();
+switch (strtolower($reqParams['request'])) {
 	case 'getcapabilities':
-		$arrayOnlineresources = checkWmsPermission($wms);
-		$or = $n->checkURL($arrayOnlineresources["wms_getcapabilities"]);
-		$or = completeURL($or);
-		getCapabilities($or);
+		$arrayOnlineresources = checkWmsPermission($query->getOwsproxyServiceId());
+		$query->setOnlineResource($arrayOnlineresources['wms_getcapabilities']);
+		$request = $query->getRequest();
+		getCapabilities($request);
 		break;
 	case 'getfeatureinfo':
-		$or = $n->checkURL($arrayOnlineresources["wms_getfeatureinfo"]);
-		getFeatureInfo($or);
+		$query->setOnlineResource($arrayOnlineresources['wms_getfeatureinfo']);
+		getFeatureInfo($request);
 		break;
 	case 'getmap':
-		$reqParams["layers"] = checkLayerPermission($arrayOnlineresources["wms_id"],$layers);
-		getMap($or);
+		$arrayOnlineresources = checkWmsPermission($owsproxyService);
+		$query->setOnlineResource($arrayOnlineresources['wms_getmap']);
+		$layers = checkLayerPermission($arrayOnlineresources['wms_id'],$reqParams['layers']);
+		$query->setParam("layers",$layers);
+		getImage($request);
+		break;
+	case 'getlegendgraphic':
+		$url = getLegendUrl($query->getOwsproxyServiceId());
+		getImage($url);
+		break;
 	case 'external':
-		getExternalRequest($wms);
+		getExternalRequest($query->getOwsproxyServiceId());
+		break;
+	case 'getfeature':
+		$arrayFeatures = array($reqParams['typename']);
+		$arrayOnlineresources = checkWfsPermission($query->getOwsproxyServiceId(), $arrayFeatures);
+		$query->setOnlineResource($arrayOnlineresources['wfs_getfeature']);
+		$request = stripslashes($request);
+		getFeature($request);
+		break;
+	// case wfs transaction (because of raw POST the request param is empty)
+	case '':
+		$arrayFeatures = getWfsFeaturesFromTransaction($HTTP_RAW_POST_DATA);
+		$query->setOnlineResource($arrayOnlineresources['wfs_transaction']);
+		doTransaction($request, $HTTP_RAW_POST_DATA);
+		break;
 	default:
 function throwE($e){
-	global $format, $imageformats;
-	echo $format."---";
-	if(in_array($format,$imageformats)){
+	global $reqParams, $imageformats;
+	if(in_array($reqParams['format'],$imageformats)){
 		throwImage($e);
 	else{
 		throwText($e);
 function throwImage($e){
 	global $width,$height;
 	$image = imagecreate($width,$height);
@@ -104,7 +131,8 @@
 	echo join(" ", $e);
 function responseImage($im){
-	global $format;
+	global $reqParams;
+	$format = $reqParams['format'];
 	if($format == 'image/png'){header("Content-Type: image/png");}
 	if($format == 'image/jpeg' || $format == 'image/jpg'){header("Content-Type: image/jpeg");}
 	if($format == 'image/gif'){header("Content-Type: image/gif");}
@@ -122,21 +150,20 @@
 	return $url;
-function removeQM($t){
-	if(strpos($t,"?") === 0){
-		$t = substr($t,1);
-	return $t;
-function getMap($or){
-	global $format, $width, $height;
-	if($format == 'image/png'){header("Content-Type: image/png");}
-	if($format == 'image/jpeg' || $format == 'image/jpg'){header("Content-Type: image/jpeg");}
-	if($format == 'image/gif'){header("Content-Type: image/gif");}
+ * fetch and returns an image to client
+ * @param string the original url of the image to send
+function getImage($or){
+	header("Content-Type: ".$reqParams['format']);
 	echo getDocumentContent($or);
  * fetchs and returns the content of the FeatureInfo Response
  * @param string the url of the FeatureInfoRequest
@@ -149,9 +176,125 @@
 	$content = getDocumentContent($url);
 	$content = matchUrls($content);
 	echo $content;
+ * fetchs and returns the content of WFS GetFeature response
+ * @param string the url of the GetFeature request
+ * @return echo the content of the GetFeature document
+function getFeature($url){
+	global $info_format;
+	header("Content-Type: ".$info_format);
+	$content = getDocumentContent($url);
+	$content = matchUrls($content);
+	echo $content;
+ * simulates a post request to host
+ * @param string host to send the request to
+ * @param string port of host to send the request to
+ * @param string method to send data (should be "POST")
+ * @param string path on host
+ * @param string data to send to host
+ * @return string hosts response
+function sendToHost($host,$port,$method,$path,$data){
+	$buf = '';
+    if (empty($method)) $method = 'POST';
+    $method = mb_strtoupper($method);
+    $fp = fsockopen($host, $port);
+    fputs($fp, "$method $path HTTP/1.1\r\n");
+    fputs($fp, "Host: $host\r\n");
+    fputs($fp,"Content-type: application/xml\r\n");
+    fputs($fp, "Content-length: " . strlen($data) . "\r\n");
+    fputs($fp, "Connection: close\r\n\r\n");
+    if ($method == 'POST') fputs($fp, $data);
+    while (!feof($fp)) $buf .= fgets($fp,4096);
+    fclose($fp);
+    return $buf;
+ * get wfs featurenames that are touched by a tansaction request defined in XML $data
+ * @param string XML that contains the tansaction request
+ * @return array array of touched feature names
+function getWfsFeaturesFromTransaction($data){
+	$features = array();
+	$values = NULL;
+	$tags = NULL;
+	$parser = xml_parser_create();
+	xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
+	xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
+	xml_parse_into_struct($parser,$data,$values,$tags);
+	$code = xml_get_error_code ($parser);
+	if ($code) {
+		$line = xml_get_current_line_number($parser);
+		$col = xml_get_current_column_number($parser);
+		$mb_exception = new mb_exception("OWSPROXY invalid Tansaction XML: ".xml_error_string($code) .  " in line " . $line. " at character ". $col);
+		die();
+	xml_parser_free($parser);
+	$insert = false;
+	$insertlevel = 0;
+	foreach ($values as $element) {
+		//features touched by insert
+		if(strtoupper($element[tag]) == "WFS:INSERT" && $element[type] == "open"){
+			$insert = true;
+			$insertlevel = $element[level];
+		if($insert && $element[level] == $insertlevel + 1 && $element[type] == "open"){
+			array_push($features, $element[tag]);
+		if(strtoupper($element[tag]) == "WFS:INSERT" && $element[type] == "close"){
+			$insert = false;
+		//updated features
+		if(strtoupper($element[tag]) == "WFS:UPDATE" && $element[type] == "open"){
+			array_push($features, $element[attributes]["typeName"]);
+		//deleted features
+		if(strtoupper($element[tag]) == "WFS:DELETE" && $element[type] == "open"){
+	return $features;
+ * sends the data of WFS Transaction and echos the response
+ *  @param string url to send the WFS Transaction to
+ *  @param string WFS Transaction data
+function doTransaction($url, $data){
+	$arURL = parse_url($url);
+	$host = $arURL["host"];
+	$port = $arURL["port"];
+	if($port == '') $port = 80;
+	$path = $arURL["path"];
+	$method = "POST";
+	$result = sendToHost($host,$port,$method,html_entity_decode($path),$data);
+	//delete header from result
+	$result = mb_eregi_replace("^[^<]*", "", $result);
+	$result = mb_eregi_replace("[^>]*$", "", $result);
+	echo $result;
 function matchUrls($content){
 	if(!session_is_registered("owsproxyUrls")){
 		$_SESSION["owsproxyUrls"] = array();
@@ -167,10 +310,11 @@
 		$content = str_replace($req,$extReq,$content);
 	return $content;
 function setExternalRequest($id){
-	global $sid;
-	$extReq = OWSPROXY ."/". $sid ."/".$id."?request=external";
+	global $reqParams,$query;
+	$extReq = OWSPROXY ."/". $reqParams['sid'] ."/".$id."?request=external";
 	return $extReq;
 function getExternalRequest($id){
@@ -195,7 +339,7 @@
 function removeOWSGetParams($query_string){
-	$r = preg_replace("/\.\*request=external&/","",$query_string);
+	$r = preg_replace("/.*request=external&/","",$query_string);
 	return $r;
@@ -236,9 +380,55 @@
 	$r = str_replace($t,$new,$arrayOnlineresources["wms_getcapabilities_doc"]);
 	header("Content-Type: application/xml");
 	echo $r;
+ * gets the original url of the requested legend graphic
+ * @param string owsproxy md5
+ * @return string url to legend graphic
+function getLegendUrl($wms){
+	//get wms id
+	$sql = "SELECT * FROM wms WHERE wms_owsproxy = $1";
+	$v = array($wms);
+	$t = array("s");
+	$res = db_prep_query($sql, $v, $t);
+	if($row = db_fetch_array($res))
+		$wmsid = $row["wms_id"];
+	else{
+		throwE(array("No wms data available."));
+		die();
+	//get the url
+	$sql = "SELECT layer_style.legendurl ";
+	$sql .= "FROM layer_style JOIN layer ";
+	$sql .= "ON layer_style.fkey_layer_id = layer.layer_id ";
+	$sql .= "WHERE layer.layer_name = $2 AND layer.fkey_wms_id = $1 ";
+	$sql .= "AND layer_style.name = $3 AND layer_style.legendurlformat = $4";
+	$v = array($wmsid, $reqParams['layer'], $reqParams['style'], $reqParams['format']);
+	$t = array("i", "s", "s", "s");
+		return $row["legendurl"];
+	else{
+		throwE(array("No legend available."));
+		die();
+ * validated access permission on requested wms
+ * @param string OWSPROXY md5
+ * @return array array with detailed information about requested wms
 function checkWmsPermission($wms){
-	global $con, $n;
+	global $con, $n;
 	$myguis = $n->getGuisByPermission($_SESSION["mb_user_id"],true);
 	$mywms = $n->getWmsByOwnGuis($myguis);
@@ -263,10 +453,77 @@
 		throwE(array("Permission denied."," -> ".$service["wms_id"], implode(",", $mywms)));
 		die();
-	return $service;
+	return $service;
+ * validates the access permission by getting the appropriate wfs_conf
+ * to each feature requested and check the wfs_conf permission
+ * @param array array of requested featuretype names
+ * @return array array with detailed information on reqested wfs
+function checkWfsPermission($wfsOws, $features){
+	global $con, $n;
+	$myconfs = $n->getWfsConfByPermission($_SESSION["mb_user_id"]);
+	//check if we know the features requested
+	if(count($features) == 0){
+		throwE(array("No wfs_feature data available."));
+		die();
+	//get wfs
+	$sql = "SELECT * FROM wfs WHERE wfs_owsproxy = $1";
+	$v = array($wfsOws);
+	$t = array("s");
+	$service = array();
+	if($row = db_fetch_array($res)){
+		$service["wfs_id"] = $row["wfs_id"];
+		$service["wfs_getcapabilities"] = $row["wfs_getcapabilities"];
+		$service["wfs_getfeature"] = $row["wfs_getfeature"];
+		$service["wfs_describefeaturetype"] = $row["wfs_describefeaturetype"];
+		$service["wfs_transaction"] = $row["wfs_transaction"];
+		$service["wfs_getcapabilities_doc"] = $row["wfs_getcapabilities_doc"];
+	else{
+		throwE(array("No wfs data available."));
+		die();
+	foreach($features as $feature){
+		//get appropriate wfs_conf
+		$sql = "SELECT wfs_conf.wfs_conf_id FROM wfs_conf ";
+		$sql.= "JOIN wfs_featuretype ";
+		$sql.= "ON wfs_featuretype.featuretype_id = wfs_conf.fkey_featuretype_id ";
+		$sql.= "WHERE wfs_featuretype.featuretype_name = $2 ";
+		$sql.= "AND wfs_featuretype.fkey_wfs_id = $1";
+		$v = array($service["wfs_id"], $feature);
+		$t = array("i","s");
+		if(!($row = db_fetch_array($res))){
+			$notice = new mb_notice("Permissioncheck failed no wfs conf for wfs ".$service["wfs_id"]." with feturetype ".$feature);
+			throwE(array("No wfs_conf data for featuretype ".$feature));
+			die();
+		$conf_id = $row["wfs_conf_id"];
+		//check permission
+		if(!in_array($conf_id, $myconfs)){
+			$notice = new mb_notice("Permissioncheck failed:".$conf_id." not in ".implode(",", $myconfs));
+			throwE(array("Permission denied."," -> ".$conf_id, implode(",", $myconfs)));
+			die();
+	return $service;
 function checkLayerPermission($wms_id,$l){
-	global $n;
+	global $n, $owsproxyService;
+//	$notice = new mb_notice("owsproxy: checkLayerpermission: wms: ".$wms_id.", layer: ".$l);
 	$myl = split(",",$l);
 	$r = array();
 	foreach($myl as $mysl){
@@ -281,6 +538,4 @@
 	$d = new connector($url);
 	return $d->file;
More information about the Mapbender_commits mailing list
