[Mapbender-commits] r1775 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Mon Oct 29 11:53:50 EDT 2007
Author: christoph
Date: 2007-10-29 11:53:50 -0400 (Mon, 29 Oct 2007)
New Revision: 1775
trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php
display wfs info and geom type
Modified: trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php
--- trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php 2007-10-29 15:40:43 UTC (rev 1774)
+++ trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php 2007-10-29 15:53:50 UTC (rev 1775)
@@ -1,333 +1,417 @@
-<?php
-# $Id: mod_wfs_gazetteer_ajax.php 1307 2007-05-09 10:06:24Z christoph $
-# maintained by http://www.mapbender.org/index.php/User:Verena Diewald
-# http://www.mapbender.org/index.php/WFS_gazetteer
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-session_start();
-$gui_id = $_SESSION["mb_user_gui"];
-$target = $_REQUEST["target"];
-$e_id_css = $_REQUEST["e_id_css"];
-require_once("../../conf/mapbender.conf");
-$con = db_connect($DBSERVER,$OWNER,$PW);
-db_select_db($DB,$con);
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<meta http-equiv="Content-Type" content="text/html; charset='<?php echo CHARSET;?>'">
-<title>mod_wfs_gazetteer</title>
-<?php
-include '../include/dyn_css.php';
-<script type="text/javascript">
-<?php
- echo "var targetString = '" . $target . "';";
- echo "var wfsConfIdString = '" . $wfsConfIdString . "';";
-var targetArray = targetString.split(",");
-var global_wfsConfObj;
-var global_selectedWfsConfId;
-var point_px = 10;
-var resultGeom = null;
-var cw_fillcolor = "#cc33cc";
-parent.mb_registerInitFunctions("window.frames['"+this.name+"'].initModWfsGazetteer()");
-function removeChildNodes(node) {
- while (node.childNodes.length > 0) {
- var childNode = node.firstChild;
- node.removeChild(childNode);
- * removes whitespaces and endlines before and after a string
-function trimString (str) {
- return str.replace(/^\s+|\s+|\n+$/g, '');
-function appendStyles() {
- var styleObj;
- var rule = global_wfsConfObj[global_selectedWfsConfId].g_style + global_wfsConfObj[global_selectedWfsConfId].g_res_style;
- if (parent.ie) {
- var styleSheetObj=document.createStyleSheet();
- styleObj=styleSheetObj.owningElement || styleSheetObj.ownerNode;
- styleObj.setAttribute("type","text/css");
- ruleArray = rule.split("}");
- for (var i=0; i < ruleArray.length - 1; i++) {
- var currentRule = trimString(ruleArray[i]);
- var nameValueArray = currentRule.split("{");
- var name = nameValueArray[0];
- var value = nameValueArray[1];
- styleSheetObj.addRule(name,value);
- else {
- styleObj=document.createElement("style");
- document.getElementsByTagName("head")[0].appendChild(styleObj);
- styleObj.appendChild(document.createTextNode(rule+"\n"));
-function initModWfsGazetteer() {
- parent.mb_ajax_json("../php/mod_wfs_gazetteer_server.php", {command:"getWfsConf",wfsConfIdString:wfsConfIdString}, function(json, status) {
- global_wfsConfObj = json;
- var wfsCount = 0;
- for (var wfsConfId in global_wfsConfObj) {
- global_selectedWfsConfId = wfsConfId;
- if (typeof(global_wfsConfObj[wfsConfId] != 'function')) {
- wfsCount++;
- if (wfsCount === 0) {
- var e = parent.Mb_exception("no wfs conf id available.");
- else if (wfsCount === 1) {
- appendStyles();
- appendWfsForm();
- else {
- appendWfsConfSelectBox();
-function appendWfsConfSelectBox() {
- var selectNode = document.createElement("select");
- selectNode.name = "wfs_conf_sel";
- selectNode.setAttribute("onchange", "global_selectedWfsConfId = this.value;appendStyles();appendWfsForm()");
- var isSelected = false;
- var optionNode = document.createElement("option");
- optionNode.value = wfsConfId;
- optionNode.innerHTML = global_wfsConfObj[wfsConfId].g_label;
- if (!isSelected) {
- optionNode.selected = true;
- isSelected = true;
- selectNode.appendChild(optionNode);
- var form = document.getElementById('selectWfsConfForm');
- form.appendChild(selectNode);
- appendStyles();
- appendWfsForm();
-function appendWfsForm() {
- var form = document.getElementById("wfsForm");
- removeChildNodes(form);
- var resultDiv = document.getElementById("res");
- removeChildNodes(resultDiv);
- var divContainer = document.createElement("div");
- divContainer.className = global_wfsConfObj[global_selectedWfsConfId].g_label_id;
- divContainer.innerHTML = global_wfsConfObj[global_selectedWfsConfId].g_label;
- form.appendChild(divContainer);
- var wfsConfElementArray = global_wfsConfObj[global_selectedWfsConfId].element;
- for (var i = 0; i < wfsConfElementArray.length; i++){
- var spanNode = document.createElement("span");
- spanNode.setAttribute("id", "ttttt");
- spanNode.className = wfsConfElementArray[i].f_label_id;
- spanNode.innerHTML = wfsConfElementArray[i].f_label;
- var inputNode = document.createElement("input");
- inputNode.type = "text";
- inputNode.className = wfsConfElementArray[i].f_style_id;
- inputNode.id = wfsConfElementArray[i].element_name;
- form.appendChild(spanNode);
- form.appendChild(inputNode);
- form.appendChild(document.createElement("br"));
- var submitButton = document.createElement("input");
- submitButton.type = "submit";
- submitButton.className = global_wfsConfObj[global_selectedWfsConfId].g_button_id;
- submitButton.value = global_wfsConfObj[global_selectedWfsConfId].g_button;
- form.appendChild(submitButton);
-function validate(){
- global_resultHighlight = new parent.Highlight(targetArray, "wfs_gazetteer_highlight", {"position":"absolute", "top":"0px", "left":"0px", "z-index":100}, 2);
- var filterParameterCount = getNumberOfFilterParameters();
- if(filterParameterCount == 0){
- return false;
- else{
- var andConditions = "";
- var el = global_wfsConfObj[global_selectedWfsConfId].element;
- for (var i = 0; i < el.length; i++) {
- if (el[i]['f_search'] == 1 && document.getElementById(el[i]['element_name']).value != '') {
- var a = new Array();
- a = document.getElementById(el[i]['element_name']).value.split(",");
- var orConditions = "";
- for (var j=0; j < a.length; j++) {
- orConditions += "<ogc:PropertyIsLike wildCard='*' singleChar='.' escape='!'>";
- orConditions += "<ogc:PropertyName>" + el[i]['element_name'] + "</ogc:PropertyName>";
- orConditions += "<ogc:Literal>*";
- if(el[i]['f_toupper'] == 1){
- orConditions += a[j].toUpperCase();
- else{
- orConditions += a[j];
- orConditions += "*</ogc:Literal>";
- orConditions += "</ogc:PropertyIsLike>";
- if(a.length > 1){
- andConditions += "<Or>" + orConditions + "</Or>";
- else {
- andConditions += orConditions;
- var u = global_wfsConfObj[global_selectedWfsConfId].wfs_getfeature + parent.mb_getConjunctionCharacter(global_wfsConfObj[global_selectedWfsConfId].wfs_getfeature);
- u += "REQUEST=getFeature&Typename="+global_wfsConfObj[global_selectedWfsConfId].featuretype_name+"&Version=1.0.0&service=WFS";
- u += "&filter=";
- if (filterParameterCount > 1) {
- andConditions = "<And>" + andConditions + "</And>";
- var filter = "<ogc:Filter xmlns:ogc='http://ogc.org' xmlns:gml='http://www.opengis.net/gml'>"+andConditions+"</ogc:Filter>";
- document.getElementById("res").innerHTML = "<table><tr><td><img src='../img/indicator_wheel.gif'></td><td>Searching...</td></tr></table>";
- var parameters = {command:"getSearchResults", "wfs_conf_id":global_selectedWfsConfId, "frame":this.name, "url":u, "filter":filter, "backlink":""};
- parent.mb_ajax_get("../php/mod_wfs_gazetteer_server.php", parameters, function (jsCode, status) {
- eval(jsCode);
- for (var i=0; i < parent.wms.length; i++) {
- for (var j=0; j < parent.wms[i].objLayer.length; j++) {
- var currentLayer = parent.wms[i].objLayer[j];
- var wms_id = parent.wms[i].wms_id;
- if (currentLayer.gui_layer_wfs_featuretype == global_selectedWfsConfId) {
- var layer_name = currentLayer.layer_name;
- parent.handleSelectedLayer_array(targetArray[0],[wms_id],[layer_name],'querylayer',1);
- parent.handleSelectedLayer_array(targetArray[0],[wms_id],[layer_name],'visible',1);
- var body = "";
- if (typeof(geom) == 'object') {
- resultGeom = geom; // set the global variable
- for (var i=0; i < geom.count(); i++) {
- body += "<div id='geom"+i+"'style='cursor:pointer;' ";
- if ((i % 2) === 0) {
- body += "class='even'";
- else {
- body += "class='uneven'";
- body += " onmouseover=\"setResult('over', this.id)\" ";
- body += " onmouseout=\"setResult('out', this.id)\" ";
- body += " onclick=\"setResult('click', this.id)\">";
- for (var j=0; j < geom.get(i).e.count(); j++) {
- body += geom.get(i).e.getValue(j) + " ";
- body += "</div>";
- else {
- body = "Kein Ergebnis.";
- document.getElementById('res').innerHTML = body;
- return false;
-function getNumberOfFilterParameters(){
- var cnt = 0;
- for (var i = 0; i < el.length; i++){
- if( el[i]['f_search'] == 1){
- if (document.getElementById(el[i]['element_name']).value != '') {
- cnt++;
- return cnt;
-* event -> {over || out || click}
-* geom -> commaseparated coordinates x1,y1,x2,y2 ...
-function setResult(event, id){
- var index = parseInt(id.slice(4));
- if (event == "over") {
- global_resultHighlight.add(resultGeom.get(index), cw_fillcolor);
- else if (event == "out"){
- global_resultHighlight.del(resultGeom.get(index), cw_fillcolor);
- else if (event == "click"){
- var bbox = resultGeom.get(index).getBBox();
- var buffer = new parent.Point(1,1);
- bbox[0] = bbox[0].minus(buffer);
- bbox[1] = bbox[1].plus(buffer);
- parent.mb_calculateExtent(targetArray[0], bbox[0].x, bbox[0].y, bbox[1].x, bbox[1].y);
- parent.zoom(targetArray[0], 'true', 1.0);
- return true;
-</script>
-</head>
-<body leftmargin='0' topmargin='10' bgcolor='#ffffff'>
-<form name='selectWfsConfForm' id='selectWfsConfForm'></form>
-<form name='wfsForm' id='wfsForm' onsubmit='return validate()'></form>
-<div name='res' id='res' style='width:180px'></div>
-</body>
+<?php
+# $Id: mod_wfs_gazetteer_client.php 1326 2007-10-29 10:52:03Z baudson $
+# maintained by http://www.mapbender.org/index.php/User:Verena Diewald
+# http://www.mapbender.org/index.php/WFS_gazetteer
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+session_start();
+$gui_id = $_SESSION["mb_user_gui"];
+$target = $_REQUEST["e_target"];
+$e_id_css = $_REQUEST["e_id_css"];
+require_once("../../conf/mapbender.conf");
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db($DB,$con);
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta http-equiv="Content-Type" content="text/html; charset='<?php echo CHARSET;?>'">
+<title>mod_wfs_gazetteer</title>
+<?php
+include '../include/dyn_css.php';
+<script type="text/javascript">
+<?php
+ echo "var targetString = '" . $target . "';";
+ echo "var wfsConfIdString = '" . $wfsConfIdString . "';";
+// Element var maxHighlightedPoints
+try{
+ if (maxHighlightedPoints){
+ maxHighlightedPoints = Number(maxHighlightedPoints);
+ if (isNaN(maxHighlightedPoints)) {
+ var e = new parent.Mb_warning("mod_wfs_gazetteer_client.php: Element var maxHighlightedPoints must be a number.");
+catch(e){
+ maxHighlightedPoints = 0;
+ var e = new parent.Mb_warning("mod_wfs_gazetteer_client.php: Element var maxHighlightedPoints is not set, see 'edit element vars'.");
+var targetArray = targetString.split(",");
+var global_wfsConfObj;
+var global_selectedWfsConfId;
+var point_px = 10;
+var resultGeom = null;
+var cw_fillcolor = "#cc33cc";
+//parent.mb_registerInitFunctions("window.frames['"+this.name+"'].initModWfsGazetteer()");
+function openwindow(Adresse) {
+ Fenster1 = window.open(Adresse, "Informationen", "width=500,height=500,left=100,top=100,scrollbars=yes,resizable=no");
+ Fenster1.focus();
+function appendWfsConf(newWfsConfIdString) {
+ // merge with existing wfs conf ids
+ wfsConfIdString += "," + newWfsConfIdString;
+ // rebuild form
+ initModWfsGazetteer();
+function removeChildNodes(node) {
+ while (node.childNodes.length > 0) {
+ var childNode = node.firstChild;
+ node.removeChild(childNode);
+ * removes whitespaces and endlines before and after a string
+function trimString (str) {
+ return str.replace(/^\s+|\s+|\n+$/g, '');
+function appendStyles() {
+ var styleObj;
+ var rule = global_wfsConfObj[global_selectedWfsConfId].g_style + global_wfsConfObj[global_selectedWfsConfId].g_res_style;
+ if (parent.ie) {
+ var styleSheetObj=document.createStyleSheet();
+ styleObj=styleSheetObj.owningElement || styleSheetObj.ownerNode;
+ styleObj.setAttribute("type","text/css");
+ ruleArray = rule.split("}");
+ for (var i=0; i < ruleArray.length - 1; i++) {
+ var currentRule = trimString(ruleArray[i]);
+ var nameValueArray = currentRule.split("{");
+ var name = nameValueArray[0];
+ var value = nameValueArray[1];
+ styleSheetObj.addRule(name,value);
+ else {
+ styleObj=document.createElement("style");
+ document.getElementsByTagName("head")[0].appendChild(styleObj);
+ styleObj.appendChild(document.createTextNode(rule+"\n"));
+function initModWfsGazetteer() {
+ // empty nodes
+ var nodesToEmpty = ["selectWfsConfForm", "wfsForm", "res"];
+ while (nodesToEmpty.length > 0) {
+ var currentId = nodesToEmpty.pop();
+ var currentNode = document.getElementById(currentId);
+ removeChildNodes(currentNode);
+ parent.mb_ajax_json("../php/mod_wfs_gazetteer_server.php", {command:"getWfsConf",wfsConfIdString:wfsConfIdString}, function(json, status) {
+ global_wfsConfObj = json;
+ var wfsCount = 0;
+ for (var wfsConfId in global_wfsConfObj) {
+ global_selectedWfsConfId = wfsConfId;
+ if (typeof(global_wfsConfObj[wfsConfId] != 'function')) {
+ wfsCount++;
+ if (wfsCount === 0) {
+ var e = parent.Mb_exception("no wfs conf id available.");
+ else if (wfsCount === 1) {
+ appendStyles();
+ appendWfsForm();
+ setWfsInfo();
+ else {
+ appendWfsConfSelectBox();
+ setWfsInfo();
+ parent.mb_setWmcExtensionData({"wfsConfIdString":wfsConfIdString});
+function setWfsInfo() {
+ var bulbNode = document.getElementById("wfsInfo");
+ // append bulb image
+ removeChildNodes(bulbNode);
+ var imgNode = document.createElement("img");
+ imgNode.id = "wfsInfoImg";
+ imgNode.src = "../img/button_digitize/geomInfo.png";
+ imgNode.border = 0;
+ bulbNode.appendChild(imgNode);
+ bulbNode.href = "javascript:openwindow('../x_geoportal/mod_featuretypeMetadata.php?wfs_conf_id=" + global_selectedWfsConfId.toString() + "');";
+ // set wfsGeomType image
+ var wfsGeomTypeNode = document.getElementById("wfsGeomType");
+ var wfsGeomType = "";
+ for (var i=0; i < global_wfsConfObj[global_selectedWfsConfId].element.length; i++) {
+ if (parseInt(global_wfsConfObj[global_selectedWfsConfId].element[i].f_geom)) {
+ wfsGeomType = global_wfsConfObj[global_selectedWfsConfId].element[i].element_type;
+ if (wfsGeomType.match(/Point/)) {
+ wfsGeomTypeNode.src = "../img/button_digitize/point_off.png";
+ wfsGeomTypeNode.style.visibility = 'visible';
+ else if (wfsGeomType.match(/Line/)) {
+ wfsGeomTypeNode.src = "../img/button_digitize/line_off.png";
+ else if (wfsGeomType.match(/Polygon/)) {
+ wfsGeomTypeNode.src = "../img/button_digitize/polygon_off.png";
+ else {
+ var e = new Mb_exception("WFS gazetteer: geometry type unknown.");
+function appendWfsConfSelectBox() {
+ var selectNode = document.createElement("select");
+ selectNode.name = "wfs_conf_sel";
+ selectNode.setAttribute("onchange", "global_selectedWfsConfId = this.value;setWfsInfo();appendStyles();appendWfsForm()");
+ var isSelected = false;
+ var optionNode = document.createElement("option");
+ optionNode.value = wfsConfId;
+ optionNode.innerHTML = global_wfsConfObj[wfsConfId].g_label;
+ if (!isSelected) {
+ optionNode.selected = true;
+ isSelected = true;
+ selectNode.appendChild(optionNode);
+ var form = document.getElementById('selectWfsConfForm');
+ form.appendChild(selectNode);
+ appendStyles();
+ appendWfsForm();
+function appendWfsForm() {
+ var form = document.getElementById("wfsForm");
+ removeChildNodes(form);
+ var resultDiv = document.getElementById("res");
+ removeChildNodes(resultDiv);
+ var divContainer = document.createElement("div");
+ divContainer.className = global_wfsConfObj[global_selectedWfsConfId].g_label_id;
+ divContainer.innerHTML = global_wfsConfObj[global_selectedWfsConfId].g_label;
+ form.appendChild(divContainer);
+ var wfsConfElementArray = global_wfsConfObj[global_selectedWfsConfId].element;
+ for (var i = 0; i < wfsConfElementArray.length; i++){
+ if (parseInt(wfsConfElementArray[i].f_search)) {
+ var spanNode = document.createElement("span");
+ spanNode.setAttribute("id", "ttttt");
+ spanNode.className = wfsConfElementArray[i].f_label_id;
+ spanNode.innerHTML = wfsConfElementArray[i].f_label;
+ var inputNode = document.createElement("input");
+ inputNode.type = "text";
+ inputNode.className = wfsConfElementArray[i].f_style_id;
+ inputNode.id = wfsConfElementArray[i].element_name;
+ form.appendChild(spanNode);
+ form.appendChild(inputNode);
+ form.appendChild(document.createElement("br"));
+ var submitButton = document.createElement("input");
+ submitButton.type = "submit";
+ submitButton.className = global_wfsConfObj[global_selectedWfsConfId].g_button_id;
+ submitButton.value = global_wfsConfObj[global_selectedWfsConfId].g_button;
+ form.appendChild(submitButton);
+function validate(){
+ global_resultHighlight = new parent.Highlight(targetArray, "wfs_gazetteer_highlight", {"position":"absolute", "top":"0px", "left":"0px", "z-index":100}, 2);
+ var filterParameterCount = getNumberOfFilterParameters();
+ if(filterParameterCount == 0){
+ return false;
+ else{
+ var andConditions = "";
+ var el = global_wfsConfObj[global_selectedWfsConfId].element;
+ for (var i = 0; i < el.length; i++) {
+ if (el[i]['f_search'] == 1 && document.getElementById(el[i]['element_name']).value != '') {
+ var a = new Array();
+ a = document.getElementById(el[i]['element_name']).value.split(",");
+ var orConditions = "";
+ for (var j=0; j < a.length; j++) {
+ orConditions += "<ogc:PropertyIsLike wildCard='*' singleChar='.' escape='!'>";
+ orConditions += "<ogc:PropertyName>" + el[i]['element_name'] + "</ogc:PropertyName>";
+ orConditions += "<ogc:Literal>*";
+ if(el[i]['f_toupper'] == 1){
+ orConditions += a[j].toUpperCase();
+ else{
+ orConditions += a[j];
+ orConditions += "*</ogc:Literal>";
+ orConditions += "</ogc:PropertyIsLike>";
+ if(a.length > 1){
+ andConditions += "<Or>" + orConditions + "</Or>";
+ else {
+ andConditions += orConditions;
+ var u = global_wfsConfObj[global_selectedWfsConfId].wfs_getfeature + parent.mb_getConjunctionCharacter(global_wfsConfObj[global_selectedWfsConfId].wfs_getfeature);
+ u += "REQUEST=getFeature&Typename="+global_wfsConfObj[global_selectedWfsConfId].featuretype_name+"&Version=1.0.0&service=WFS";
+ u += "&filter=";
+ if (filterParameterCount > 1) {
+ andConditions = "<And>" + andConditions + "</And>";
+ var filter = "<ogc:Filter xmlns:ogc='http://ogc.org' xmlns:gml='http://www.opengis.net/gml'>"+andConditions+"</ogc:Filter>";
+ document.getElementById("res").innerHTML = "<table><tr><td><img src='../img/indicator_wheel.gif'></td><td>Searching...</td></tr></table>";
+ var parameters = {command:"getSearchResults", "wfs_conf_id":global_selectedWfsConfId, "frame":this.name, "url":u, "filter":filter, "backlink":""};
+ parent.mb_ajax_get("../php/mod_wfs_gazetteer_server.php", parameters, function (jsCode, status) {
+ document.getElementById("res").innerHTML = "<table><tr><td>Arranging search results...</td></tr></table>";
+ eval(jsCode);
+ for (var i=0; i < parent.wms.length; i++) {
+ for (var j=0; j < parent.wms[i].objLayer.length; j++) {
+ var currentLayer = parent.wms[i].objLayer[j];
+ var wms_id = parent.wms[i].wms_id;
+ if (currentLayer.gui_layer_wfs_featuretype == global_selectedWfsConfId) {
+ var layer_name = currentLayer.layer_name;
+ parent.handleSelectedLayer_array(targetArray[0],[wms_id],[layer_name],'querylayer',1);
+ parent.handleSelectedLayer_array(targetArray[0],[wms_id],[layer_name],'visible',1);
+ var body = "";
+ if (typeof(geom) == 'object') {
+ resultGeom = geom; // set the global variable
+ for (var i=0; i < geom.count(); i++) {
+ body += "<div id='geom"+i+"'style='cursor:pointer;' ";
+ if ((i % 2) === 0) {
+ body += "class='even'";
+ else {
+ body += "class='uneven'";
+ body += " onmouseover=\"setResult('over', this.id)\" ";
+ body += " onmouseout=\"setResult('out', this.id)\" ";
+ body += " onclick=\"setResult('click', this.id)\">";
+ for (var j=0; j < geom.get(i).e.count(); j++) {
+ body += geom.get(i).e.getValue(j) + " ";
+ body += "</div>";
+ else {
+ body = "Kein Ergebnis.";
+ document.getElementById('res').innerHTML = body;
+ return false;
+function getNumberOfFilterParameters(){
+ var cnt = 0;
+ for (var i = 0; i < el.length; i++){
+ if( el[i]['f_search'] == 1){
+ if (document.getElementById(el[i]['element_name']).value != '') {
+ cnt++;
+ return cnt;
+* event -> {over || out || click}
+* geom -> commaseparated coordinates x1,y1,x2,y2 ...
+function setResult(event, id){
+ var index = parseInt(id.slice(4));
+ var currentGeom = resultGeom.get(index);
+ if (maxHighlightedPoints > 0 && currentGeom.getTotalPointCount() > maxHighlightedPoints) {
+ currentGeom = currentGeom.getBBox4();
+ if (event == "over") {
+ global_resultHighlight.add(currentGeom, cw_fillcolor);
+ else if (event == "out"){
+ global_resultHighlight.del(currentGeom, cw_fillcolor);
+ else if (event == "click"){
+ var bbox = currentGeom.getBBox();
+ var buffer = new parent.Point(global_wfsConfObj[global_selectedWfsConfId].g_buffer,global_wfsConfObj[global_selectedWfsConfId].g_buffer);
+ bbox[0] = bbox[0].minus(buffer);
+ bbox[1] = bbox[1].plus(buffer);
+ parent.mb_calculateExtent(targetArray[0], bbox[0].x, bbox[0].y, bbox[1].x, bbox[1].y);
+ parent.zoom(targetArray[0], 'true', 1.0);
+ return true;
+</script>
+</head>
+<body leftmargin='0' topmargin='10' bgcolor='#ffffff'>
+<form name='selectWfsConfForm' id='selectWfsConfForm'></form>
+<img src = "" name='wfsGeomType' id='wfsGeomType'>
+<a name='wfsInfo' id='wfsInfo'/>
+<form name='wfsForm' id='wfsForm' onsubmit='return validate()'></form>
+<div name='res' id='res' style='width:180px'></div>
+</body>
</html>
\ No newline at end of file
More information about the Mapbender_commits
