[Mapbender-commits] r1777 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Oct 30 05:49:56 EDT 2007
Author: verenadiewald
Date: 2007-10-30 05:49:56 -0400 (Tue, 30 Oct 2007)
New Revision: 1777
   trunk/mapbender/http/php/mod_editGuiWms.php
added style handling for each layer
Modified: trunk/mapbender/http/php/mod_editGuiWms.php
--- trunk/mapbender/http/php/mod_editGuiWms.php	2007-10-29 16:01:09 UTC (rev 1776)
+++ trunk/mapbender/http/php/mod_editGuiWms.php	2007-10-30 09:49:56 UTC (rev 1777)
@@ -19,6 +19,7 @@
 session_start();
 require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
 $con = db_connect(DBSERVER,OWNER,PW);
 db_select_db(DB,$con);
 import_request_variables("PG");
@@ -426,6 +427,7 @@
 $gui_layer_minscale = array();
 $gui_layer_maxscale = array();
 $gui_layer_priority = array();
+$gui_layer_style = array();
 $gui_layer_wfs_featuretype = array();
 $layer_id = array();
 $layer_parent = array();
@@ -443,6 +445,7 @@
 	array_push($gui_layer_minscale, $row["gui_layer_minscale"]);
 	array_push($gui_layer_maxscale, $row["gui_layer_maxscale"]);
 	array_push($gui_layer_priority, $row["gui_layer_priority"]);
+	array_push($gui_layer_style, $row["gui_layer_style"]);
 	array_push($gui_layer_wfs_featuretype, $row["gui_layer_wfs_featuretype"]);
 	array_push($layer_id, $row["layer_id"]);
 	array_push($layer_parent, $row["layer_parent"]);
@@ -462,7 +465,8 @@
 while($row = db_fetch_array($res_le)){
    $epsg[$cnt_le] = $row["epsg"];
    $cnt_le++;
 echo "<div style='position:absolute;left:590px; top:180px;' ><input type='button' style='width:100px;height:100px;background-color:#0066cc' value='save' onclick='checkBoxValue()'></div>";
 echo "<table class='table_top'>";
@@ -572,6 +576,7 @@
                 echo "<td>" . toImage('info_default') . "</td>";
                 echo "<td>" . toImage('minScale 1:') . "</td>";
                 echo "<td>" . toImage('maxScale 1:') . "</td>";
+                echo "<td>" . toImage('Style') . "</td>";
                 echo "<td>" . toImage('Prio') . "</td>";
                 echo "<td>" . toImage('setWFS') . "</td>";
         echo "</tr>";
@@ -586,7 +591,21 @@
 echo "<nobr><input type='button' class='button_on_off' value='off' onclick='setLayer(\"querylayer\",false)'>&nbsp;";
 echo "<input type='button' class='button_on_off' value='on' onclick='setLayer(\"querylayer\",true)'></nobr>";
 echo "</td><td></td><td></td><td></td></tr>";
 for($i=0; $i<count($layer_id); $i++){
+#layer_styles
+$sql_styles = "SELECT * FROM layer_style WHERE  fkey_layer_id = $1";
+$v = array($layer_id[$i]);
+$t = array('i');
+$res_styles = db_prep_query($sql_styles,$v,$t);
+$cnt_styles= 0;
+$style = array();
+while($row = db_fetch_array($res_styles)){
+   $style[$cnt_styles] = $row["name"];
+   $cnt_styles++;
  echo "<tr align='center'>";
   echo "<td><input type='text' size='1' name='L_".$layer_id[$i]."___layer_nr' disabled value='".$i."'></td>";
   echo "<td style='background:lightgrey'><input type='text' size='2' name='L_".$layer_id[$i]."___layer_id' value='".$layer_id[$i]."' readonly></td>";
@@ -618,7 +637,21 @@
   echo "<td><input name='L_".$layer_id[$i]."___gui_layer_minscale' type='text' size='5' value='".$gui_layer_minscale[$i]."'></td>";
   echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_maxscale' type='text' size='5' value='".$gui_layer_maxscale[$i]."'></td>";
+  echo "<td>\n";
+  echo "<select class='mySelect' name='L_".$layer_id[$i]."___gui_layer_style'>\n";
+  	   echo "<option value=''";
+  	   if(count($style) ==0){ echo "selected";}
+  	   echo ">---</option>\n";
+  for($j=0;$j<count($style); $j++){
+       echo "<option value='".$style[$j]."'";
+       if($style[$j] == $gui_layer_style[$i]){ echo "selected";}
+       echo ">".$style[$j]."</option>\n";
+  echo "</select></td>\n";
   echo "<td><select class='select_short' name='L_".$layer_id[$i]."___gui_layer_priority'>";
   for($j=0; $j<count($gui_layer_priority); $j++){
      echo "<option value='".$j."'";
More information about the Mapbender_commits mailing list
