[Mapbender-commits] r1782 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Wed Oct 31 04:24:30 EDT 2007
Author: christoph
Date: 2007-10-31 04:24:30 -0400 (Wed, 31 Oct 2007)
New Revision: 1782
Added:
trunk/mapbender/http/javascripts/mod_renderGML.php
new module that renders the GML in the session variable
$_SESSION["GML"]
on start-up
Added: trunk/mapbender/http/javascripts/mod_renderGML.php
--- trunk/mapbender/http/javascripts/mod_renderGML.php (rev 0)
+++ trunk/mapbender/http/javascripts/mod_renderGML.php 2007-10-31 08:24:30 UTC (rev 1782)
@@ -0,0 +1,64 @@
+<?php
+# http://www.mapbender.org/index.php/Monitor_Capabilities
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../../conf/geoportal.conf");
+require_once(dirname(__FILE__)."/../classes/class_gml2.php");
+require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
+$gui_id = $_SESSION["mb_user_gui"];
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db(DB,$con);
+$sql = "SELECT e_target FROM gui_element WHERE e_id = 'renderGML' AND fkey_gui_id = $1 LIMIT 1";
+$v = array($gui_id);
+$t = array('s');
+$res = db_prep_query($sql, $v, $t);
+$row = db_fetch_array($res);
+$e_target = explode(",",$row[0]);
+$gml_string = $_SESSION["GML"];
+if ($gml_string) {
+ $gml = new gml2();
+ $gml->parse_xml($gml_string);
+ $bbox = $gml->bbox;
+ echo "mb_registerInitFunctions('highlight_init()');\n";
+ echo "function highlight_init() {\n";
+ echo "var mf = new Array(";
+ for ($i=0; $i<count($e_target); $i++) {
+ if ($i>0) echo ", ";
+ echo "'".$e_target[$i]."'";
+ echo ");\n";
+ echo "hl = new Highlight(mf, 'GML_rendering', {'position':'absolute', 'top':'0px', 'left':'0px', 'z-index':" . GML_HIGHLIGHT_Z_INDEX . "});\n";
+ echo $gml->exportMemberToJS(0, false);
+ echo "hl.add(q);\n";
+ echo "mb_registerSubFunctions('hl.paint()');\n";
+ echo "}\n";
+ $e = new mb_notice("renderGML: GML: " . $_SESSION["GML"] . "; EPSG: " . $_SESSION["epsg"] . "; BBOX: " . implode(", ", $bbox));
+ $_SESSION["GML"] = NULL;
+ $e = new mb_notice("renderGML: deleting GML...");
+else {
+ $e = new mb_notice("renderGML: no GML.");
\ No newline at end of file
More information about the Mapbender_commits
