[Mapbender-commits] r1667 - trunk/mapbender/resources/db/mysql
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Sep 10 03:53:18 EDT 2007
Author: sven
Date: 2007-09-10 03:53:18 -0400 (Mon, 10 Sep 2007)
New Revision: 1667
   trunk/mapbender/resources/db/mysql/mysql_schema.sql
change column data_format in wms_format: set length from 50 to 100
Modified: trunk/mapbender/resources/db/mysql/mysql_schema.sql
--- trunk/mapbender/resources/db/mysql/mysql_schema.sql	2007-09-10 07:52:13 UTC (rev 1666)
+++ trunk/mapbender/resources/db/mysql/mysql_schema.sql	2007-09-10 07:53:18 UTC (rev 1667)
@@ -495,7 +495,7 @@
 CREATE TABLE wms_format (
   fkey_wms_id int(11) NOT NULL default '0',
   data_type varchar(50) NOT NULL default '',
-  data_format varchar(50) NOT NULL default '',
+  data_format varchar(100) NOT NULL default '',
   KEY wms_index (fkey_wms_id)
 ) TYPE=InnoDB;
More information about the Mapbender_commits mailing list
