[Mapbender-commits] r2322 - branches/2.5/http/sld/classes
svn_mapbender at osgeo.org
Tue Apr 1 11:33:28 EDT 2008
Author: astrid_emde
Date: 2008-04-01 11:33:28 -0400 (Tue, 01 Apr 2008)
New Revision: 2322
branches/2.5/http/sld/classes/StyledLayerDescriptor.php
xml header commented out
Modified: branches/2.5/http/sld/classes/StyledLayerDescriptor.php
--- branches/2.5/http/sld/classes/StyledLayerDescriptor.php 2008-04-01 15:31:51 UTC (rev 2321)
+++ branches/2.5/http/sld/classes/StyledLayerDescriptor.php 2008-04-01 15:33:28 UTC (rev 2322)
@@ -16,7 +16,7 @@
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
* This file contains the class definitions for the sld-editor.
@@ -83,8 +83,8 @@
function generateXml($offset = "")
- $temp = "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n";
- $temp .= $offset."<StyledLayerDescriptor";
+ #$temp = "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n";
+ $temp = $offset."<StyledLayerDescriptor";
if ($this->version != "") $temp .= " version=\"".htmlspecialchars($this->version)."\"";
$temp .= " xsi:schemaLocation=\"http://www.opengis.net/sld StyledLayerDescriptor.xsd\"";
$temp .= " xmlns=\"http://www.opengis.net/sld\"";
@@ -208,5 +208,5 @@
function __autoload($class_name) {
require_once $class_name . '.php';
\ No newline at end of file
More information about the Mapbender_commits
