[Mapbender-commits] r2331 - in branches/nimix_dev: conf http/classes http/css http/frames http/javascripts http/php http/sld/classes http/tools owsproxy/http resources/db/mysql/iso resources/db/mysql/utf8 resources/db/postgresql/iso resources/db/postgresql/utf8 resources/db/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Apr 2 04:09:26 EDT 2008
Author: nimix
Date: 2008-04-02 04:09:18 -0400 (Wed, 02 Apr 2008)
New Revision: 2331
Added:
   branches/nimix_dev/http/javascripts/mod_switchLocale_noreload.php
Removed:
   branches/nimix_dev/http/tools/mapFiler.php
   branches/nimix_dev/conf/digitize_default.conf
   branches/nimix_dev/http/classes/class_stripRequest.php
   branches/nimix_dev/http/css/popup.css
   branches/nimix_dev/http/frames/index.php
   branches/nimix_dev/http/javascripts/geometry.js
   branches/nimix_dev/http/javascripts/mod_digitize_tab.php
   branches/nimix_dev/http/javascripts/mod_wfs_gazetteer_client.php
   branches/nimix_dev/http/php/mod_forgottenPassword.php
   branches/nimix_dev/http/sld/classes/StyledLayerDescriptor.php
   branches/nimix_dev/owsproxy/http/index.php
   branches/nimix_dev/resources/db/mysql/iso/mysql_data.sql
   branches/nimix_dev/resources/db/mysql/utf8/mysql_data.sql
   branches/nimix_dev/resources/db/postgresql/iso/pgsql_data.sql
   branches/nimix_dev/resources/db/postgresql/utf8/pgsql_data.sql
   branches/nimix_dev/resources/db/update/mod_switchLocale_noreload.sql
   branches/nimix_dev/resources/db/update/update_guis_iso.sql
   branches/nimix_dev/resources/db/update/update_guis_utf8.sql
   branches/nimix_dev/resources/db/update/update_mysql_db.sql
merge 2.5 changes
Modified: branches/nimix_dev/conf/digitize_default.conf
--- branches/nimix_dev/conf/digitize_default.conf	2008-04-02 07:59:47 UTC (rev 2330)
+++ branches/nimix_dev/conf/digitize_default.conf	2008-04-02 08:09:18 UTC (rev 2331)
@@ -1,194 +1,20 @@
-// Messages
-var language = (function () {
-		function constructorFunction(){
-			this.de = "de";
-			this.en = "en";
-		return new constructorFunction();
-var selectedLanguage = language.en;
+// * List of buttons for digitizing within the tabulator 'Digitize'.
+// * Set the first 1 in row to 0 to disable digitizing for a certain
+//   kind of digitizing (e.g. point, line, or polygon)
+// * Do not change the ID (first entry)!!
-var messageDescriptionPolygon = [];
-messageDescriptionPolygon[language.de] = "Polygon";
-messageDescriptionPolygon[language.en] = "polygon";
+addButtonDig("Point", 1, "point_off.png", "", "", 0, 0);
+addButtonDig("Line", 1, "line_off.png", "", "", 25, 0);
+addButtonDig("Polygon", 1, "polygon_off.png", "", "", 50, 0);
+addButtonDig("dragBasePoint", 1, "move_node_off.png", "", "", 75, 0);
+addButtonDig("setBasePoint", 1, "new_node_off.png", "", "", 100, 0);
+addButtonDig("delBasePoint", 1, "delete_node_off.png", "", "", 125, 0);
+addButtonDig("clear", 1, "del_off.png", "", "", 150, 0);
-var messageDescriptionLine = [];
-messageDescriptionLine[language.de] = "Linie";
-messageDescriptionLine[language.en] = "line";
-var messageDescriptionPoint = [];
-messageDescriptionPoint[language.de] = "Punkt";
-messageDescriptionPoint[language.en] = "point";
-var messageErrorNotAnInteger = [];
-messageErrorNotAnInteger[language.de] = "Kein Integer-Wert.";
-messageErrorNotAnInteger[language.en] = "Not an integer value.";
-var messageErrorNotAFloat = [];
-messageErrorNotAFloat[language.de] = "Kein Double-Wert.";
-messageErrorNotAFloat[language.en] = "Not a double value.";
-var messageErrorFieldIsEmpty = [];
-messageErrorFieldIsEmpty[language.de] = "Das Feld darf nicht leer sein.";
-messageErrorFieldIsEmpty[language.en] = "This field may not be empty.";
-var messageErrorFormEvaluation = [];
-messageErrorFormEvaluation[language.de] = "Fehler bei der Formularauswertung.";
-messageErrorFormEvaluation[language.en] = "Failure during form evaluation.";
-var messageErrorWfsWrite = [];
-messageErrorWfsWrite[language.de] = "Ein Fehler ist aufgetreten.";
-messageErrorWfsWrite[language.en] = "An error occured.";
-var messageSuccessWfsWrite = [];
-messageSuccessWfsWrite[language.de] = "Aktion erfolgreich beendet.";
-messageSuccessWfsWrite[language.en] = "Success.";
-var messageConfirmDeleteGeomFromDb = [];
-messageConfirmDeleteGeomFromDb[language.de] = "Geometrie in der Datenbank löschen?";
-messageConfirmDeleteGeomFromDb[language.en] = "Delete geometry from database?";
-var messageConfirmDeleteAllGeomFromList = [];
-messageConfirmDeleteAllGeomFromList[language.de] = "Soll die Geometrieliste wirklich geleert werden?";
-messageConfirmDeleteAllGeomFromList[language.en] = "Clear list of geometries?";
-var messageSelectAnOption = [];
-messageSelectAnOption[language.de] = "Bitte treffen Sie eine Auswahl.";
-messageSelectAnOption[language.en] = "Please select an entry.";
-var buttonLabelSaveGeometry = [];
-buttonLabelSaveGeometry[language.de] = "Speichern";
-buttonLabelSaveGeometry[language.en] = "Save";
-var buttonLabelUpdateGeometry = [];
-buttonLabelUpdateGeometry[language.de] = "Aktualisieren";
-buttonLabelUpdateGeometry[language.en] = "Update";
-var buttonLabelDeleteGeometry = [];
-buttonLabelDeleteGeometry[language.de] = "Löschen";
-buttonLabelDeleteGeometry[language.en] = "Delete";
-var buttonLabelAbort = [];
-buttonLabelAbort[language.de] = "Abbrechen";
-buttonLabelAbort[language.en] = "Abort";
-var errorMessageEpsgMismatch = [];
-errorMessageEpsgMismatch[language.de] = "Schwerwiegender Fehler: ungleiche EPSGs. ";
-errorMessageEpsgMismatch[language.en] = "Fatal error: EPSG mismatch. ";
-var errorMessageNoGeometrySelected = [];
-errorMessageNoGeometrySelected[language.de] = "Keine Geometrie ausgewählt!";
-errorMessageNoGeometrySelected[language.en] = "No geometry selected!";
-var buttonLabelPointOff = [];
-buttonLabelPointOff[language.de] = "Punkt hinzufügen";
-buttonLabelPointOff[language.en] = "add point";
-var buttonLabelPointOn = [];
-buttonLabelPointOn[language.de] = "Editieren abbrechen";
-buttonLabelPointOn[language.en] = "cancel editing";
-var buttonLabelLineOff = [];
-buttonLabelLineOff[language.de] = "Linie hinzufügen";
-buttonLabelLineOff[language.en] = "add line";
-var buttonLabelLineOn = [];
-buttonLabelLineOn[language.de] = "Linie abschliessen";
-buttonLabelLineOn[language.en] = "finish line";
-var buttonLabelPolygonOff = [];
-buttonLabelPolygonOff[language.de] = "Polygon hinzufügen";
-buttonLabelPolygonOff[language.en] = "add polygon";
-var buttonLabelPolygonOn = [];
-buttonLabelPolygonOn[language.de] = "Polygon schliessen";
-buttonLabelPolygonOn[language.en] = "close polygon";
-var buttonLabelMoveBasepointOff = [];
-buttonLabelMoveBasepointOff[language.de] = "Stützpunkt verschieben";
-buttonLabelMoveBasepointOff[language.en] = "move basepoint";
-var buttonLabelMoveBasepointOn = [];
-buttonLabelMoveBasepointOn[language.de] = "Stützpunkt verschieben";
-buttonLabelMoveBasepointOn[language.en] = "move basepoint";
-var buttonLabelInsertBasepointOff = [];
-buttonLabelInsertBasepointOff[language.de] = "Stützpunkt einfügen";
-buttonLabelInsertBasepointOff[language.en] = "Insert basepoint";
-var buttonLabelInsertBasepointOn = [];
-buttonLabelInsertBasepointOn[language.de] = "Stützpunkt einfügen";
-buttonLabelInsertBasepointOn[language.en] = "Insert basepoint";
-var buttonLabelDeleteBasepointOff = [];
-buttonLabelDeleteBasepointOff[language.de] = "Stützpunkt löschen";
-buttonLabelDeleteBasepointOff[language.en] = "Delete basepoint";
-var buttonLabelDeleteBasepointOn = [];
-buttonLabelDeleteBasepointOn[language.de] = "Stützpunkt löschen";
-buttonLabelDeleteBasepointOn[language.en] = "Delete basepoint";
-var buttonLabelClearListOff = [];
-buttonLabelClearListOff[language.de] = "Geometrieliste leeren";
-buttonLabelClearListOff[language.en] = "clear list of geometries";
-var buttonLabelClearListOn = [];
-buttonLabelClearListOn[language.de] = "Geometrieliste leeren";
-buttonLabelClearListOn[language.en] = "clear list of geometries";
-// Buttons
-function addButtonDig(id, isOn, src, titleOff, titleOn, x, y) {
-	buttonDig_id.push(id);
-	buttonDig_on.push(isOn);
-	buttonDig_src.push(src);
-	buttonDig_title_off.push(titleOff);
-	buttonDig_title_on.push(titleOn);
-	buttonDig_x.push(x);
-	buttonDig_y.push(y);
-var buttonDig_imgdir = "../img/button_digitize/";
-var buttonDig_id = [];
-var buttonDig_on = [];
-var buttonDig_src = [];
-var buttonDig_title_off = [];
-var buttonDig_title_on = [];
-var buttonDig_x = [];
-var buttonDig_y = [];
-//List of buttons for digitizing within the tabulator 'Digitize'. Set the first 1 in row to 0 to disable digitizing for a certain kind of digitizing (e.g. point, line, or polygon)
-addButtonDig("Point", 1, "point_off.png", buttonLabelPointOff[selectedLanguage], buttonLabelPointOn[selectedLanguage], 0, 0);
-addButtonDig("Line", 1, "line_off.png", buttonLabelLineOff[selectedLanguage], buttonLabelLineOn[selectedLanguage], 25, 0);
-addButtonDig("Polygon", 1, "polygon_off.png", buttonLabelPolygonOff[selectedLanguage], buttonLabelPolygonOn[selectedLanguage], 50, 0);
-addButtonDig("dragBasePoint", 1, "move_node_off.png", buttonLabelMoveBasepointOff[selectedLanguage], buttonLabelMoveBasepointOn[selectedLanguage], 75, 0);
-addButtonDig("setBasePoint", 1, "new_node_off.png", buttonLabelInsertBasepointOff[selectedLanguage], buttonLabelInsertBasepointOn[selectedLanguage], 100, 0);
-addButtonDig("delBasePoint", 1, "delete_node_off.png", buttonLabelDeleteBasepointOff[selectedLanguage], buttonLabelDeleteBasepointOn[selectedLanguage], 125, 0);
-addButtonDig("clear", 1, "del_off.png", buttonLabelClearListOff[selectedLanguage], buttonLabelClearListOn[selectedLanguage], 150, 0);
-//addButtonDig("combine", 1, "combine_off.png", "combine to multigeometry", "combine to multigeometry", 175, 0);
 var buttonDig_wfs_src = "geomInfo.png";
-var buttonDig_wfs_title = [];
-buttonDig_wfs_title[language.de] = "speichern / aktualisieren / löschen";
-buttonDig_wfs_title[language.en] = "save / update / delete";
 var buttonDig_remove_src = "geomRemove.png";
-var buttonDig_remove_title = [];
-buttonDig_remove_title[language.de] = "aus der Liste entfernen";
-buttonDig_remove_title[language.en] = "remove from workspace";
 var buttonDig_removeDb_src = "geomRemoveDb.png";
-var buttonDig_removeDb_title = [];
-buttonDig_removeDb_title[language.de] = "aus der Datenbank löschen";
-buttonDig_removeDb_title[language.en] = "remove from database";
-var closePolygon_title = "click the first basepoint to close the polygon";
 var dotDistance = 7;
 var geomList_x = 20;
 var geomList_y = 50;
@@ -207,15 +33,16 @@
 var measureTagName = "dependentDiv";
 var measureTagTarget = "";
-var measureTagLabelCurrent = [];
-measureTagLabelCurrent[language.de] = "Letztes Segment: ";
-measureTagLabelCurrent[language.en] = "Current: ";
-var measureTagLabelTotal = [];
-measureTagLabelTotal[language.de] = "Gesamtlänge: ";
-measureTagLabelTotal[language.en] = "Total: ";
-var measureTagStyle = {"position":"absolute", "top":"530px", "left":"250px", "width":"5000px", "height":"30px", "z-index":"100"}; //style is ignored when tag already exists
+//style is ignored when tag already exists
+var measureTagStyle = {
+	position:"absolute",
+	top:"530px",
+	left:"250px",
+	width:"5000px",
+	height:"30px",
+	zIndex:"1"
 var measureNumberOfDigits = 3;
 var showSaveButtonForExistingGeometries = false;
@@ -227,8 +54,4 @@
 var wfsWindowWidth = 400;
 var wfsWindowHeight = 300;
-var digitizeDefaultGeometryName = [];
-digitizeDefaultGeometryName[language.de] = "neu";
-digitizeDefaultGeometryName[language.en] = "new";
-var spatialRequestResultToDigitize = 1;
+var spatialRequestResultToDigitize = 1;
\ No newline at end of file
Modified: branches/nimix_dev/http/classes/class_stripRequest.php
--- branches/nimix_dev/http/classes/class_stripRequest.php	2008-04-02 07:59:47 UTC (rev 2330)
+++ branches/nimix_dev/http/classes/class_stripRequest.php	2008-04-02 08:09:18 UTC (rev 2331)
@@ -39,8 +39,8 @@
 			$tmp = explode("=", $patterns[$i]);
 			if(mb_strtoupper($tmp[0]) == mb_strtoupper($key)){
 				$replacement = mb_strtoupper($key) . "=" . $value;
-				$currentPattern = "/" . $patterns[$i] . "/";
-				$this->url = preg_replace($currentPattern, $replacement, $this->url);
+				$currentPattern = $patterns[$i];
+				$this->url = str_replace($currentPattern, $replacement, $this->url);
 				$exists = true;
Modified: branches/nimix_dev/http/css/popup.css
--- branches/nimix_dev/http/css/popup.css	2008-04-02 07:59:47 UTC (rev 2330)
+++ branches/nimix_dev/http/css/popup.css	2008-04-02 08:09:18 UTC (rev 2331)
@@ -8,10 +8,12 @@
     overflow:hidden;
     position: absolute;
-/*styles that can change*/
+	/*styles that can change*/
     background:#EEEEEE url(../img/info_on.gif) 8px 8px no-repeat;
     border: 1px solid #000;
     -moz-border-radius:10px;
+    /*border to client area (top right bottom left)*/
     padding: 30px 10px 5px 10px;
Modified: branches/nimix_dev/http/frames/index.php
--- branches/nimix_dev/http/frames/index.php	2008-04-02 07:59:47 UTC (rev 2330)
+++ branches/nimix_dev/http/frames/index.php	2008-04-02 08:09:18 UTC (rev 2331)
@@ -164,7 +164,7 @@
 </form>
 <?php
 #echo "<script type='text/javascript' src='../javascripts/map.php?gui_id=".$_REQUEST["gui_id"]."&zoomToLayer=".$_REQUEST["zoomToLayer"]."&portal_services=".$_REQUEST['portal_services']."&portal_services_wfs=".$_REQUEST['portal_services_wfs']."&layer_preview=".$_REQUEST['layer_preview']."&".strip_tags(SID)."&mb_myBBOX=".$_REQUEST["mb_myBBOX"]."'></script>";
-echo "<script type='text/javascript' src='../javascripts/map.php?gui_id=".$urlParameters."&mb_myBBOX=".$_REQUEST["mb_myBBOX"]."'></script>";
+echo "<script type='text/javascript' src='../javascripts/map.php?".$urlParameters."&mb_myBBOX=".$_REQUEST["mb_myBBOX"]."'></script>";
 </body>
 </html>
Modified: branches/nimix_dev/http/javascripts/geometry.js
--- branches/nimix_dev/http/javascripts/geometry.js	2008-04-02 07:59:47 UTC (rev 2330)
+++ branches/nimix_dev/http/javascripts/geometry.js	2008-04-02 08:09:18 UTC (rev 2331)
@@ -350,8 +350,11 @@
 																		this.addMember(geomType.line);
 																		this.get(-1).addGeometry();
 																		for (var m = 0; m < coordinates.length; m++) {
-																			var currentPoint = coordinates[m];
-																			this.getGeometry(-1,-1).addPointByCoordinates(currentPoint[0], currentPoint[1]);
+																			var currentLine = coordinates[m];
+																			for (var n = 0; n < currentLine.length; n++) {
+																				var currentPoint = currentLine[n];
+																				this.getGeometry(-1,-1).addPointByCoordinates(currentPoint[0], currentPoint[1]);
 																		this.getGeometry(-1,-1).setEpsg(featureEpsg);
 																		this.close();
Modified: branches/nimix_dev/http/javascripts/mod_digitize_tab.php
--- branches/nimix_dev/http/javascripts/mod_digitize_tab.php	2008-04-02 07:59:47 UTC (rev 2330)
+++ branches/nimix_dev/http/javascripts/mod_digitize_tab.php	2008-04-02 08:09:18 UTC (rev 2331)
@@ -34,10 +34,36 @@
 <?php
 $digitize_conf_filename = "digitize_default.conf";
 include '../include/dyn_css.php';
+<script language='JavaScript'>
+// Buttons
+function addButtonDig(id, isOn, src, titleOff, titleOn, x, y) {
+	buttonDig_id.push(id);
+	buttonDig_on.push(isOn);
+	buttonDig_src.push(src);
+	buttonDig_title_off.push(titleOff);
+	buttonDig_title_on.push(titleOn);
+	buttonDig_x.push(x);
+	buttonDig_y.push(y);
-echo "<script language='JavaScript'>";
+var buttonDig_imgdir = "../img/button_digitize/";
+var buttonDig_id = [];
+var buttonDig_on = [];
+var buttonDig_src = [];
+var buttonDig_title_off = [];
+var buttonDig_title_on = [];
+var buttonDig_x = [];
+var buttonDig_y = [];
+<?php
 echo "var mod_digitize_target = '".$e_target."';";
-include(dirname(__FILE__) . "/../../conf/" . $digitize_conf_filename);
+$digitizeConfFilenameAndPath = dirname(__FILE__) . "/../../conf/" . $digitize_conf_filename;
+if ($digitize_conf_filename && file_exists($digitizeConfFilenameAndPath)) {
+	include($digitizeConfFilenameAndPath);
 var wfsWindow;
@@ -469,6 +495,75 @@
+function updateButtons() {
+	for (var i = 0 ; i < buttonDig_id.length ; i ++) {
+		if (parseInt(buttonDig_on[i])==1) {
+			var currentButton = document.getElementById(buttonDig_id[i]);
+			var currentStatus = buttonDig_id[i].status;
+			var currentTitle = "";
+			switch (buttonDig_id[i]) {
+				case "Point":
+					if (currentStatus == 1) {
+						currentTitle = msgObj.buttonLabelPointOn;
+					else {
+						currentTitle = msgObj.buttonLabelPointOff;
+					break;
+				case "Line":
+						currentTitle = msgObj.buttonLabelLineOn;
+					else {
+						currentTitle = msgObj.buttonLabelLineOff;
+					break;
+				case "Polygon":
+						currentTitle = msgObj.buttonLabelPolygonOn;
+					else {
+						currentTitle = msgObj.buttonLabelPolygonOff;
+					break;
+				case "dragBasePoint":
+						currentTitle = msgObj.buttonLabelMoveBasepointOn;
+					else {
+						currentTitle = msgObj.buttonLabelMoveBasepointOff;
+					break;
+				case "setBasePoint":
+						currentTitle = msgObj.buttonLabelInsertBasepointOn;
+					else {
+						currentTitle = msgObj.buttonLabelInsertBasepointOff;
+					break;
+				case "delBasePoint":
+						currentTitle = msgObj.buttonLabelDeleteBasepointOn;
+					else {
+						currentTitle = msgObj.buttonLabelDeleteBasepointOff;
+					break;
+				case "clear":
+						currentTitle = msgObj.buttonLabelClearListOn;
+					else {
+						currentTitle = msgObj.buttonLabelClearListOff;
+					break;
+			currentButton.title = currentTitle;
 function initDigButton(ind, pos){
 	parent.mb_button[ind] = document.getElementById(buttonDig_id[pos]);
 	parent.mb_button[ind].img_over = buttonDig_imgdir + buttonDig_src[pos].replace(/_off/,"_over");
@@ -715,7 +810,7 @@
 								smPArray[smPArray.length] = "<div class='bp' style='top:"+(currentPointMap.y-2)+"px;left:"+(currentPointMap.x-2)+"px;z-index:"+digitizeTransactionalZIndex+";'";
 							if(k==0 && isPolygon && !isComplete){
-								smPArray[smPArray.length] = " title='"+closePolygon_title+"' ";
+								smPArray[smPArray.length] = " title='"+msgObj.closePolygon_title+"' ";
 							if(isMoveOrInsertOrDelete) {
 								smPArray[smPArray.length] = " onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].handleBasepoint(this,"+i+","+j+","+k+")' ;";
@@ -1419,6 +1514,7 @@
 function applyMessages() {
 	updateMeasureTag();
 	updateListOfGeometries();
+	updateButtons();
 	</script>
Copied: branches/nimix_dev/http/javascripts/mod_switchLocale_noreload.php (from rev 2330, branches/2.5/http/javascripts/mod_switchLocale_noreload.php)
--- branches/nimix_dev/http/javascripts/mod_switchLocale_noreload.php	                        (rev 0)
+++ branches/nimix_dev/http/javascripts/mod_switchLocale_noreload.php	2008-04-02 08:09:18 UTC (rev 2331)
@@ -0,0 +1,49 @@
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/localeSwitch
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+include(dirname(__FILE__) . "/../include/dyn_js.php");
+function validate_locale(){
+	var index = document.getElementById("language").selectedIndex;
+	var lang = document.getElementById("language").options[index].value;
+	mb_ajax_post("../php/mod_setLocale.php", {"lang":lang}, function(result, status) {
+		mapbender.locale = result;
+		localize();
+eventInit.register(function () {
+	var localeSelectNode = document.getElementById('language');
+	var languageArray = languages.split(",");
+	var selected = false;
+	for (var i = 0; i < languageArray.length; i++) {
+		if (languageArray[i] == '<?php echo $_SESSION["mb_lang"];?>') {
+			selected = true;
+		else {
+			selected = false;
+		var currentOption = new Option(languageArray[i], languageArray[i], selected, selected);
+		localeSelectNode.options[i] = currentOption;
Modified: branches/nimix_dev/http/javascripts/mod_wfs_gazetteer_client.php
--- branches/nimix_dev/http/javascripts/mod_wfs_gazetteer_client.php	2008-04-02 07:59:47 UTC (rev 2330)
+++ branches/nimix_dev/http/javascripts/mod_wfs_gazetteer_client.php	2008-04-02 08:09:18 UTC (rev 2331)
@@ -157,7 +157,7 @@
 		if (wfsCount === 0) {
-			var e = parent.Mb_exception("no wfs conf id available.");
+			var e = new parent.Mb_exception("no wfs conf id available.");
 		else if (wfsCount === 1) {
 			appendStyles();
Modified: branches/nimix_dev/http/php/mod_forgottenPassword.php
--- branches/nimix_dev/http/php/mod_forgottenPassword.php	2008-04-02 07:59:47 UTC (rev 2330)
+++ branches/nimix_dev/http/php/mod_forgottenPassword.php	2008-04-02 08:09:18 UTC (rev 2331)
@@ -66,7 +66,7 @@
 	if ($_POST["sendnew"]) {
 		if ($_POST["username"]) {
 			$id = $admin->getUserIdByUserName($_POST["username"]);
-			$user_id = $id[0];
+			$user_id = $id;
 			if ($user_id) {
 				$upd=true;
Modified: branches/nimix_dev/http/sld/classes/StyledLayerDescriptor.php
--- branches/nimix_dev/http/sld/classes/StyledLayerDescriptor.php	2008-04-02 07:59:47 UTC (rev 2330)
+++ branches/nimix_dev/http/sld/classes/StyledLayerDescriptor.php	2008-04-02 08:09:18 UTC (rev 2331)
@@ -16,7 +16,7 @@
  * This file contains the class definitions for the sld-editor.
@@ -83,8 +83,8 @@
 	function generateXml($offset = "")
-		$temp = "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n";
-		$temp .= $offset."<StyledLayerDescriptor";
+		#$temp = "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n";
+		$temp = $offset."<StyledLayerDescriptor";
 		if ($this->version != "") $temp .= " version=\"".htmlspecialchars($this->version)."\"";
 		$temp .= " xsi:schemaLocation=\"http://www.opengis.net/sld StyledLayerDescriptor.xsd\"";
 		$temp .= " xmlns=\"http://www.opengis.net/sld\"";
@@ -208,5 +208,5 @@
 function __autoload($class_name) {
     require_once $class_name . '.php';
Deleted: branches/nimix_dev/http/tools/mapFiler.php
--- branches/nimix_dev/http/tools/mapFiler.php	2008-04-02 07:59:47 UTC (rev 2330)
+++ branches/nimix_dev/http/tools/mapFiler.php	2008-04-02 08:09:18 UTC (rev 2331)
@@ -1,126 +0,0 @@
-<html>
-  <head>
-    <title>MapFile</title>
-    <style></style>
-  <script type='text/javascript' >
-  function validate(){
-  	/*eventuell den Inhalt (Pfad) noch aufbereiten?
-	* Slash und Backslash -> win, linux usw.
-	document.form1.location.type = 'text';
-	document.form1.myLocation.value = document.form1.location.value;
-	document.form1.submit();
-  </script>
-  </head>
-  <body>
-  <form name='form1' action='<?php $PHP_SELF ?>' method='POST'>
-  <table>
-	<tr>
-		<td>Location:</td>
-		<td>
-			<input type='file' name='location' >
-			<input type='hidden' name='myLocation'>
-		</td>
-	</tr>
-	<tr>
-		<td>all files with the same extension:</td>
-		<td>
-		<input type='checkbox' name='dir'>
-		</td>
-	</tr>
-	<tr>
-		<td>Factor:</td>
-		<td><input type='text' name='factor' value='4'></td>
-	</tr>
-	<tr>
-		<td><input type='button' value="let's go" onclick='validate()'></td>
-		<td></td>
-	</tr>
-  </table>
-  <?php
-import_request_variables('PG');
-/*********PARAMS***************/
-$countSymbolsFiles = 0;
-$arraySymbolsFiles;
-function modify($myDir, $myFile){
-	global $factor;
-	$myContent = fopen($myDir."/".$myFile, "r") or die("Datei " . $myDir . " / ". $myFile ." konnte nicht zum Lesen geöffnet werden!");
-	$myNewContent = fopen($myDir."/".str_replace(".","_".$factor.".",$myFile), "w") or die("Datei " . $myDir . " / ". str_replace(".","_".$factor.".",$myFile) ." konnte nicht zum Schreiben geöffnet werden!");
-	fputs($myNewContent, "#Modified by MapbenderTools" . "\n");
-	fputs($myNewContent, "#Date: ". date("d.m.Y") . "\n");
-	fputs($myNewContent, "#Factor: ". $factor . "\n\n");
-	while(!feof($myContent)){
-		$myLine = fgets($myContent, 1024);
-		if(preg_match("/\bSIZE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
-			if(count($matches) <= 2){
-				fputs($myNewContent, str_replace($matches[1], multiplicate($matches[1]), $myLine));
-		else if(preg_match("/(.*OFFSET)\s*(\d+.?\d*)(\s*)(\d+.?\d*)(\s*)/i",$myLine,$matches)){
-			$myNewOFFSET=$matches[1] . " " .multiplicate($matches[2]) . " " . multiplicate($matches[4]).$matches[5];
-			fputs($myNewContent,$myNewOFFSET);
-		else if(preg_match("/\bMAXSIZE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
-		else if(preg_match("/\bMINSIZE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
-		else if(preg_match("/\bSYMBOLSCALE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
-			fputs($myNewContent, "# ". $myLine);
-		else if(preg_match("/\bSYMBOLSET\s*(.*)/i",$myLine,$matches)){ //noch nicht fertig
-			$arraySymbolFiles[$countSymbolsFiles] = str_replace("\"","",$matches[1]);
-			$countSymbolsFiles++;
-			fputs($myNewContent, $myLine);
-		#catch all
-		else{
-	fclose($myContent);
-	fclose($myNewContent);
-function multiplicate($x){
-	global $factor;
-	$x = floatval($x) * $factor;
-	return $x;
- if(isset($myLocation) && $myLocation != ""){
-	# what is to do...
-	$myFile = basename($myLocation);
-	$myDir = dirname($myLocation);
-	$suffix = strstr($myFile, ".");
-	if(!isset($dir)){
-		modify($myDir, $myFile);
-		echo "modified: " . $myDir . "/" . $myFile. "<br />";
-	else{
-		if($verz = opendir($myDir)){
-			while ($myFile = readdir ($verz)) {
-				if($myFile != ".." && $myFile != "." && is_file($myDir."/".$myFile) && strstr($myFile, $suffix)){
-			closedir($verz);
-  </form>
-  </body>
-</html>
Modified: branches/nimix_dev/owsproxy/http/index.php
--- branches/nimix_dev/owsproxy/http/index.php	2008-04-02 07:59:47 UTC (rev 2330)
+++ branches/nimix_dev/owsproxy/http/index.php	2008-04-02 08:09:18 UTC (rev 2331)
@@ -98,6 +98,10 @@
 			throwE("Permission denied");
 			die();
+		if($layers===""){
+			throwE("Permission denied");
+			die();
 		$query->setParam("layers",$layers);
 		$request = $query->getRequest();
 		getImage($request);
Modified: branches/nimix_dev/resources/db/mysql/iso/mysql_data.sql
--- branches/nimix_dev/resources/db/mysql/iso/mysql_data.sql	2008-04-02 07:59:47 UTC (rev 2330)
+++ branches/nimix_dev/resources/db/mysql/iso/mysql_data.sql	2008-04-02 08:09:18 UTC (rev 2331)
@@ -28,7 +28,7 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'metadata', 2, 1, 'shows informations about the wms and the requests of the gui', 'img', '../img/button_blink_red/metadata_off.png', 'onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_blink_red/metadata_over.png"'' onmouseout=''this.src="../img/button_blink_red/metadata_off.png"'' title="Show WMS infos"', 710, 60, 24, 24, 1, '', '', '', 'mod_displayObj.js', '', '', '', 'http://www.mapbender.org/index.php/Metadata');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredGui_filteredUser', 2, 1, 'Oberfläche mehreren Benutzer zuordnen ', 'a', '', 'href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ', 8, 535, 190, 25, 10, '', 'GUI mehreren Benutzern <br> zuordnen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredGui_filteredUser', 2, 1, 'Oberfl�che mehreren Benutzer zuordnen ', 'a', '', 'href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ', 8, 535, 190, 25, 10, '', 'GUI mehreren Benutzern <br> zuordnen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'overview', 2, 1, 'OverviewFrame', 'iframe', '../php/mod_mapOV.php?wms=0&sessionID', 'scrolling="no" frameborder=''0'' ', 15, 25, 150, 150, 2, '', '', 'iframe', '', 'mod_box1.js', 'mapframe1', '', 'http://www.mapbender.org/index.php/Overview');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'imprint', 2, 1, 'Information about the owner of the gui', 'iframe', '../html/tab_imprint.html', 'frameborder = "0" ', 1, 1, 1, 1, 5, 'visibility:hidden;', '', 'iframe', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'loadData', 2, 1, 'IFRAME, um Daten zu laden', 'iframe', '../html/mod_blank.html', 'frameborder = "0" ', 0, 0, 1, 1, 0, 'visibility:visible', '', 'iframe', '', '', '', '', NULL);
@@ -38,11 +38,11 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'legend', 2, 1, 'legend', 'iframe', '../javascripts/mod_legend.php?sessionID&e_id_css=legend', 'frameborder=''0''', 1, 1, 1, 1, 3, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'showLoggedUser', 2, 1, 'displays the logged admin', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, NULL, '', '', 'iframe', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'meetingPoint', 2, 1, 'create a meeting point', 'iframe', '../php/mod_meetingPoint.php?sessionID', 'frameborder = "0" ', 0, 0, NULL, NULL, 4, 'visibility:hidden;', '', 'iframe', '', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredGui_filteredGroup', 2, 1, 'Einzelner Oberfläche mehrere Gruppen zuordnen', 'a', '', 'href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ', 8, 605, 190, 25, 10, '', 'Einzelner GUI mehrere<br> Gruppen zuordnen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'AdminFrame', 2, 1, 'Bereich für Administrationsmodule', 'iframe', '', 'frameborder = "0"', 210, 25, 800, 800, 12, '', '', 'iframe', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredGui_filteredGroup', 2, 1, 'Einzelner Oberfl�che mehrere Gruppen zuordnen', 'a', '', 'href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ', 8, 605, 190, 25, 10, '', 'Einzelner GUI mehrere<br> Gruppen zuordnen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'AdminFrame', 2, 1, 'Bereich f�r Administrationsmodule', 'iframe', '', 'frameborder = "0"', 210, 25, 800, 800, 12, '', '', 'iframe', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'body', 1, 1, 'Navigation', 'body', '', 'onload=''mod_adminNavigation_init()''', NULL, NULL, NULL, NULL, NULL, '', '', '', 'mod_adminNavigation.js', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'headline_Configure_WMS_Access', 3, 1, 'Hintergrund WMS Zuordnung', 'div', '', '', 1, 175, 210, 63, 2, '', 'WMS Zuordnung', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'headline_GUI_Management', 3, 1, 'Oberflächenverwaltung', 'div', '', '', 1, 428, 210, 153, 2, '', 'GUI Verwaltung', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'headline_GUI_Management', 3, 1, 'Oberfl�chenverwaltung', 'div', '', '', 1, 428, 210, 153, 2, '', 'GUI Verwaltung', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'headline_Metadata', 3, 1, 'Metadateneditor Caption', 'div', '', '', 1, 252, 210, 63, 2, '', 'Metadaten', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'headline_WFS_Management', 3, 1, 'WFS Verwaltung', 'div', '', '', 1, 330, 210, 82, 2, '', 'WFS Verwaltung', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'body', 1, 1, 'body
@@ -108,7 +108,7 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'body', 1, 1, 'body (obligatory)', 'body', '', 'onload="init()"', NULL, NULL, NULL, NULL, NULL, '', '', '', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_australia', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''onmouseover=''this.src="../img/button_gray/logout_over.png"''onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'mapbender', 2, 1, 'Mapbender-Logo', 'div', '', 'onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"', 81, -19, 1, 1, 30, 'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;', '<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_australia', 'content', 2, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_australia', 'content', 2, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Beh�lter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfl�che. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuw�hlen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'showCoords_div', 2, 1, 'displays coodinates by onmouseover', 'img', '../img/button_gray/coords_off.png', 'onmouseover = "mb_regButton(''init_mod_showCoords_div'')" title="Coordinates" ', 450, 10, 24, 24, 1, '', '', '', 'mod_coords_div.php', '', 'mapframe1', 'dependendDiv', 'http://www.mapbender.org/index.php/ShowCoords_div');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_australia', 'body', 1, 1, 'obligatory body', 'body', '', '', 0, 0, NULL, NULL, NULL, '', '', 'body', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredGui_filteredUser', 2, 1, 'Allow several users access to one GUI ', 'a', '', 'href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ', 8, 535, 190, 25, 10, '', 'Allow several users access to <br> one GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
@@ -117,7 +117,7 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_europe', 'body', 1, 1, 'obligatory body', 'body', '', '', 0, 0, NULL, NULL, NULL, '', '', 'body', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'editGroup', 2, 1, 'edit group', 'a', '', 'href = "../php/mod_editGroup.php?sessionID" target = "AdminFrame" ', 10, 510, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT GROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'updateWMSs', 2, 1, 'edit the elements of the gui', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 10, 70, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'UPDATE WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/UpdateWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_europe', 'content', 2, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_europe', 'content', 2, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Beh�lter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfl�che. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuw�hlen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'rename_copy_Gui', 2, 1, 'rename and copy gui', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 10, 470, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'RENAME COPY GUI', 'a', '', '', '', 'AdminFrame', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredGroup_filteredGui', 2, 1, 'Allow one group access to several GUIs', 'a', '', 'href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ', 8, 570, 190, 25, 10, '', 'Allow one group access to <br> several GUIs', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_gdi_de', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''onmouseover=''this.src="../img/button_gray/logout_over.png"''onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 5, 5, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
@@ -128,7 +128,7 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'AdminFrame', 2, 1, 'Bereich f&uuml;r Administrationsmodule', 'iframe', '', 'frameborder = "0"', 200, 20, 800, 800, 0, '', '', 'iframe', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'body', 1, 1, 'Navigation', 'body', '', 'onload=''mod_adminNavigation_init()''', 0, 0, 180, 20, 0, '', '', '', 'mod_adminNavigation.js', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'newGui', 2, 1, 'create a new gui', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 10, 130, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;', 'NEW GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_gdi_de', 'content', 2, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_gdi_de', 'content', 2, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Beh�lter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfl�che. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuw�hlen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'AdminFrame', 2, 1, 'administration frame', 'iframe', '', 'frameborder = "0"', 210, 25, 1000, 800, 12, '', '', 'iframe', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'body', 1, 1, 'Navigation', 'body', '', 'onload=''mod_adminNavigation_init()''', NULL, NULL, NULL, NULL, NULL, '', '', '', 'mod_adminNavigation.js', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'filteredGui_filteredGroup', 2, 1, 'Allow several groups access to one GUI', 'a', '', 'href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ', 8, 605, 190, 25, 10, '', 'Allow several groups access <br> to one GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
@@ -152,13 +152,13 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'forward', 2, 1, 'History.forward()', 'img', '../img/button_blink_red/forward_off_disabled.png', 'onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" title="Forward"', 425, 60, 24, 24, 1, '', '', '', 'mod_forward.php', '', 'mapframe1,overview', '', 'http://www.mapbender.org/index.php/Forward');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'navFrame', 2, 1, 'navigation mapborder', 'div', '', '', 0, 0, 0, 0, 10, 'font-size:1px;', '<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ', 'div', 'mod_navFrame.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/NavFrame');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'pan1', 2, 1, 'pan', 'img', '../img/button_blink_red/pan_off.png', 'onmouseover = "mb_regButton(''init_mod_pan'')" title="Pan"', 260, 60, 24, 24, 1, '', '', '', 'mod_pan.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Pan');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_germany', 'content', 2, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_germany', 'content', 2, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Beh�lter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfl�che. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuw�hlen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'showLoggedUser', 2, 1, 'Logged User:', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, 1, 'background-color:lightgrey;', '', 'iframe', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'printPDF', 2, 1, 'start print GUI', 'img', '../img/button_blink_red/print_off.png', 'onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF_b.conf","printWin","width=180, height=200, resizable=yes ")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Print"', 555, 60, 24, 24, 1, '', '', '', '', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/Print');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'zoomFull', 2, 1, 'zoom to full extent button', 'img', '../img/button_blink_red/zoomFull_off.png', 'onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"  title="Display complete map"', 335, 60, 24, 24, 2, '', '', 'img', 'mod_zoomFull.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomFull');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'zoomOut1', 2, 1, 'zoomOut button', 'img', '../img/button_blink_red/zoomOut2_off.png', 'onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' title="Zoom out"', 235, 60, 24, 24, 1, '', '', '', 'mod_zoomOut1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ZoomOut');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'help1', 2, 1, 'button help', 'img', '../img/button_blink_red/help_off.png', 'onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")'' title="Help"', 790, 60, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/help');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_north_america', 'content', 2, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_north_america', 'content', 2, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Beh�lter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfl�che. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuw�hlen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'imprint', 2, 1, 'Information about the owner of the gui', 'iframe', '../html/tab_imprint.html', 'frameborder = "0" ', 1, 1, 1, 1, 5, 'visibility:hidden;', '', 'iframe', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'layout_back', 3, 1, 'layout, background for buttons', 'div', '', '', 360, 10, 51, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'layout_featureInfo', 3, 1, 'layout, background for FeatureInfo', 'div', '', '', 425, 10, 51, 26, 0, 'background-color:#414547;', '', 'div', '', '', '', '', NULL);
@@ -198,12 +198,12 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'scalebar', 2, 1, 'scalebar', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_scalebar.php', '', 'mapframe1', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'scaleSelect', 2, 1, 'Scale-Selectbox', 'select', '', 'onchange=''mod_scaleSelect(this)''', 555, 25, 100, 20, 1, '', '<option value = ''''>Scale</option> <option value=''100''>1 : 100</option> <option value=''250''>1 : 250</option> <option value=''500''>1 : 500</option> <option value=''1000''>1 : 1000</option> <option value=''2500''>1 : 2500</option> <option value=''5000''>1 : 5000</option> <option value=''10000''>1 : 10000</option> <option value=''25000''>1 : 25000</option> <option value=''30000''>1 : 30000</option> <option value=''50000''>1 : 50000</option> <option value=''75000''>1 : 75000</option> <option value=''100000''>1 : 100000</option> <option value=''200000''>1 : 200000</option> <option value=''300000''>1 : 300000</option> <option value=''400000''>1 : 400000</option> <option value=''500000''>1 : 500000</option> <option value=''600000''>1 : 600000</option> <option value=''700000''>1 : 700000</option> <option value=''800000''>1 : 800000</option> <option value=''900000''>1 : 900000</option> <option value=''1000000''>1 : 1000000</option>', 'select', 'mod_scaleSel.php', '', 'mapframe1', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'scaleText', 2, 1, 'Scale-description field', 'form', '', 'onsubmit=''return mod_scaleText()''', 672, 25, 100, 30, 0, '', '<input type="text">', 'form', 'mod_scaleText.php', '', 'mapframe1', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'myGUIlist', 2, 1, 'go back to your GUI list', 'img', '../img/button_gray/home_off.png', 'onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zurück zur GUI Liste"', 150, 2, 24, 24, 1, '', '', 'img', 'mod_home.php', '', '', '', 'http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'myGUIlist', 2, 1, 'go back to your GUI list', 'img', '../img/button_gray/home_off.png', 'onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zur�ck zur GUI Liste"', 150, 2, 24, 24, 1, '', '', 'img', 'mod_home.php', '', '', '', 'http://www.mapbender.org/index.php/MyGUIlist');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'setBackground', 2, 0, 'switch background-wms', 'form', '', '', 15, 190, 0, 0, 1, '', '<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>', 'form', 'mod_setBackground.php', '', 'mapframe1', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'setBackground_all', 2, 0, 'switch all background-wms', 'form', '', '', 157, 190, 40, 20, 1, '', '<input type=''checkbox'' onclick=''mod_setBackground_all_init(this)''> <font face="Arial, sans-serif" size="2">all</font>', 'form', 'mod_setBackground_all.php', '', 'mapframe1', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'setBBOX', 2, 0, 'set Extent for mapframe and overviewframe', 'div', '', '', 0, 0, 0, 0, 0, '', '', 'div', 'mod_setBBOX1.php', '', 'mapframe1', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'setScaleHint', 1, 0, 'set scaleHint for mapframes', 'div', '', '', 1, 1, 1, 1, 0, 'visibility:hidden;', '', 'div', 'mod_scaleHint.php', '', 'mapframe1,100,10000000', '', NULL);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_worldwide', 'content', 2, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('wms_worldwide', 'content', 2, 1, 'text', 'div', '', '', 10, 50, 500, 30, 2, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'This GUI is an OGC service catalog container and does not provide a map user interface. Please use the  (<a href=''javascript:history.back()''>back</a>) link to select another GUI form your list or log off to log on using another account (identity).<br><br>Diese GUI ist ein OGC Service Katalog Beh�lter (Eimer, Container, nimm was Du meinst) und beinhaltet keine Kartenoberfl�che. Verwenden Sie diesen (<a href=''javascript:history.back()''>back</a>)  Verweis, um aus der Liste eine andere GUI auszuw�hlen oder melden Sie sich ab, um sich mit einer anderen Kennung anzumelden. ', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'treeConfGDE', 2, 0, 'configurable directory tree', 'iframe', '../php/mod_treefolderClient.php?sessionID', 'frameborder = "0" ', 0, 180, 250, 500, 0, 'visibility:visible', '', 'iframe', 'mod_treeConf.js', '', 'mapframe1', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'treeGDE_1', 2, 0, 'directory tree, checkbox for visible, checkbox for querylayer, no immediate refreshing, with nested layers', 'iframe', '../html/mod_sync_treefolder_1.html', 'frameborder = "0" ', 0, 180, 250, 500, 0, 'visibility:visible', '', 'iframe', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'wfs_gazetteer', 2, 0, 'gazetteer using wfs', 'iframe', '../php/mod_wfs_gazetteer.php?sessionID&color=255,0,255', 'frameborder = "0" ', -50, 490, 250, 300, 0, 'visibility:visible', '', 'iframe', '', '', 'mapframe1,overview', 'wfs', NULL);
@@ -217,7 +217,7 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'Gui_Group', 2, 1, 'allocate guis to groups', 'a', '', 'href = "../php/mod_gui_group.php?sessionID&e_id_css=Gui_Group" target = "AdminFrame" ', 10, 250, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI -> GROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'Gui_User', 2, 1, 'allocate a gui to user', 'a', '', 'href = "../php/mod_gui_user.php?sessionID&e_id_css=Gui_User" target = "AdminFrame" ', 10, 190, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'GUI -> USER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'User_Group', 2, 1, 'allocat user to groups', 'a', '', 'href = "../php/mod_user_group.php?sessionID&e_id_css=User_Group" target = "AdminFrame" ', 10, 430, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'USER -> GROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'myGUIlist', 2, 1, 'Zurück zur eigenen GUI Liste', 'img', '../img/button_gray/home_off.png', 'onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zurück zur GUI Liste"', 150, 2, 24, 24, 2, '', '', 'img', 'mod_home.php', '', '', '', 'http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'myGUIlist', 2, 1, 'Zur�ck zur eigenen GUI Liste', 'img', '../img/button_gray/home_off.png', 'onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zur�ck zur GUI Liste"', 150, 2, 24, 24, 2, '', '', 'img', 'mod_home.php', '', '', '', 'http://www.mapbender.org/index.php/MyGUIlist');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'editFilteredGroup', 2, 1, 'edit group of this admin', 'a', '', 'href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ', 10, 530, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT myGROUP', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'showLoggedUser', 2, 1, 'show logged in user', 'iframe', '../php/mod_showLoggedUser.php?sessionID', 'frameborder="0" scrolling=''no''', 1, 1, 200, 30, 1, 'background-color:lightgrey;', '', 'iframe', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'editFilteredUser', 2, 1, 'save, edit, delete user where this admin is owner', 'a', '', 'href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"', 10, 350, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'EDIT myUSER', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
@@ -245,7 +245,7 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'deleteGui', 2, 1, 'delete gui', 'a', '', 'href = "../php/mod_deleteGUI.php?sessionID" target = "AdminFrame" ', 10, 150, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'DELETE GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'deleteWMS', 2, 1, 'delete wms', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 10, 110, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'DELETE WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWMS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'highlightPOI', 2, 1, 'highlight 1 to n pois in your gui with a Symbol and a special text', 'div', '', '', 0, 0, NULL, NULL, NULL, '', '', 'div', 'mod_highlightPOI.php', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'exportGUI', 2, 1, 'Oberfläche (GUI) exportieren, SQL erzeugen', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 8, 300, 190, 20, 10, '', 'GUI exportieren (SQL)', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'exportGUI', 2, 1, 'Oberfl�che (GUI) exportieren, SQL erzeugen', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 8, 300, 190, 20, 10, '', 'GUI exportieren (SQL)', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'delete_filteredGui', 2, 1, 'delete guis of this admin', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 10, 790, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'DELETE myGUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'layout_linie', 3, 0, 'layout', 'div', '', '', 1, 70, 830, 1, 1, 'background-color:#799FEB;font-size:1px;', '', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'editElements', 2, 1, 'edit gui elements', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 10, 170, 200, 20, 0, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;', 'EDIT GUI-ELEMENTS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_Elements');
@@ -264,7 +264,7 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'logout', 2, 1, 'Logout', 'img', '../img/button_blink_red/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blink_red/logout_over.png"'' onmouseout=''this.src="../img/button_blink_red/logout_off.png"'' title="Logout"', 830, 60, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/Logout');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'treeGDE', 2, 1, 'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
 for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2', 'iframe', '../html/mod_treefolder2.php?sessionID', 'frameborder = \\"0\\" ', 10, 220, 200, 300, NULL, 'visibility:visible', '', 'iframe', '', '', 'mapframe1', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'editElements', 2, 1, 'Oberflächenelemente editieren', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 8, 260, 190, 20, 5, '', 'GUI-Elemente editieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'editElements', 2, 1, 'Oberfl�chenelemente editieren', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 8, 260, 190, 20, 5, '', 'GUI-Elemente editieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_Elements');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 660, 10, 24, 24, 1, '', '', '', '', '', '', '', 'http://www.mapbender.org/index.php/Logout');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui1', 'legend', 2, 1, 'legend', 'iframe', '../javascripts/mod_legend.php?sessionID&wms_legend = yes', 'frameborder=''0''', -59, 200, 180, 600, 3, '', '', 'iframe', '', '', 'mapframe1', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui', 'treeGDE', 2, 1, 'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
@@ -315,7 +315,7 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'loadWMS', 2, 1, 'Load Capabilities', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 8, 60, 190, 20, 5, '', 'Load Capabilities', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'CreateTreeGDE', 2, 1, 'TreeGDE set up', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 8, 280, 190, 20, 5, '', 'TreeGDE set up', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/ConfTreeGde');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'editFilteredGroup', 2, 1, 'Create and edit group', 'a', '', 'href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ', 8, 400, 190, 20, 10, '', 'Create and edit group', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_1d', 3, 1, 'Hintergrund Oberflächenverwaltung', 'div', '', '', 5, 217, 193, 126, 2, '', ' GUI-Verwaltung', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_1d', 3, 1, 'Hintergrund Oberfl�chenverwaltung', 'div', '', '', 5, 217, 193, 126, 2, '', ' GUI-Verwaltung', 'div', '', '', '', '', '');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'orphanWMS', 2, 1, 'display orphaned WMS', 'a', '', 'href = "../php/mod_orphanWMS.php?sessionID&&elementID=orphanWMS" target = "AdminFrame"', 10, 930, 200, 20, 5, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'ORPHAN WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/OrphanWMS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'layout_0', 3, 1, 'WMS Management border', 'div', '', '', 3, 35, 193, 90, 1, '', '', 'div', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'layout_1', 3, 1, 'WMS Management caption', 'div', '', '', 5, 37, 193, 86, 2, '', ' WMS Management', 'div', '', '', '', '', NULL);
@@ -458,7 +458,7 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'editGUI_WMS', 2, 1, 'WMS GUI Einstellungen', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 8, 180, 190, 20, 5, '', 'WMS GUI Einstellungen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_WMS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'loadWMSList', 2, 1, 'WMS in GUI einbinden', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 8, 160, 190, 20, 5, '', 'WMS in GUI einbinden', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'loadWMS', 2, 1, 'Capabilities hochladen', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 8, 60, 190, 20, 5, '', 'Capabilities hochladen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredUser_filteredGui', 2, 1, 'Einem Nutzer Zugriff auf mehrere Oberflächen erteilen', 'a', '', 'href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ', 8, 500, 190, 25, 10, '', 'Einem Nutzer Zugriff auf <br> mehrere GUIs erteilen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'filteredUser_filteredGui', 2, 1, 'Einem Nutzer Zugriff auf mehrere Oberfl�chen erteilen', 'a', '', 'href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ', 8, 500, 190, 25, 10, '', 'Einem Nutzer Zugriff auf <br> mehrere GUIs erteilen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/user');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_0', 3, 1, 'Hintergrund WMS Verwaltung Rahmen', 'div', '', '', 3, 35, 193, 90, 1, '', '', 'div', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_1', 3, 1, 'Hintergrund WMS Management', 'div', '', '', 5, 37, 193, 86, 2, '', ' WMS Verwaltung', 'div', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_1a', 3, 1, 'Hintergrund WMS Zuordnung Rahmen', 'div', '', '', 3, 135, 193, 70, 1, '', '', 'div', '', '', '', '', NULL);
@@ -469,18 +469,18 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_4', 3, 1, 'Hintergrund Benutzerzugriff erteilen Rahmen', 'div', '', '', 3, 475, 193, 200, 1, '', '', 'div', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'layout_5', 3, 1, 'Hintergrund Benutzerzugriff erteilen', 'div', '', '', 5, 477, 193, 196, 2, '', ' Benutzerzugriff erteilen', 'div', '', '', '', '', NULL);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'newGui', 2, 1, 'Create new GUI', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 8, 240, 110, 20, 5, '', 'Create new GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'delete_filteredGui', 2, 1, 'GUI löschen', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 10, 471, 200, 20, 5, '', 'GUI löschen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'editElements', 2, 1, 'Oberflächenelemente editieren', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 10, 491, 200, 25, 5, '', 'GUI editieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_Elements');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'editGUI_WMS', 2, 1, 'WMS GUI Einstellungen', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 10, 218, 200, 20, 5, '', 'WMS Einstellungen ändern', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'delete_filteredGui', 2, 1, 'GUI l�schen', 'a', '', 'href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ', 10, 471, 200, 20, 5, '', 'GUI l�schen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'editElements', 2, 1, 'Oberfl�chenelemente editieren', 'a', '', 'href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ', 10, 491, 200, 25, 5, '', 'GUI editieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'editGUI_WMS', 2, 1, 'WMS GUI Einstellungen', 'a', '', 'href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"', 10, 218, 200, 20, 5, '', 'WMS Einstellungen �ndern', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_GUI_WMS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'loadWMSList', 2, 1, 'WMS in GUI einbinden', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 10, 198, 200, 20, 5, '', 'WMS einbinden', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'loadWMS', 2, 1, 'Capabilities hochladen', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 10, 60, 200, 20, 5, '', 'WMS laden', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 180, 2, 24, 24, 2, '', '', 'img', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'myGUIlist', 2, 1, 'Zurück zur eigenen GUI Liste', 'img', '../img/button_gray/home_off.png', 'onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zurück zur GUI Liste"', 150, 2, 24, 24, 2, '', '', 'img', 'mod_home.php', '', '', '', 'http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'myGUIlist', 2, 1, 'Zur�ck zur eigenen GUI Liste', 'img', '../img/button_gray/home_off.png', 'onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zur�ck zur GUI Liste"', 150, 2, 24, 24, 2, '', '', 'img', 'mod_home.php', '', '', '', 'http://www.mapbender.org/index.php/MyGUIlist');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'newGui', 2, 1, 'GUI erzeugen', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 10, 451, 200, 20, 5, '', 'GUI erzeugen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin1', 'deleteWFS', 2, 1, 'delete WFS', 'a', '', 'href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ', 10, 890, 200, 20, NULL, 'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;', 'DELETE WFS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWFS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'loadWFS', 2, 1, 'WFS Capabilities in eine GUI laden', 'a', '', 'href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"', 10, 353, 200, 20, 5, '', 'WFS laden', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/LoadWFS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'orphanWMS', 2, 1, 'display orphaned WMS', 'a', '', 'href = "../php/mod_orphanWMS.php?sessionID"
-target = "AdminFrame"', 10, 120, 200, 20, 5, '', 'WMS ohne Zuordung löschen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/OrphanWMS');
+target = "AdminFrame"', 10, 120, 200, 20, 5, '', 'WMS ohne Zuordung l�schen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/OrphanWMS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'owsproxy', 2, 1, 'secure services', 'a', '', 'href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"', 10, 140, 200, 20, 10, '', 'OWSPROXY', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Owsproxy');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'rename_copy_Gui', 2, 1, 'GUI umbenennen/ kopieren', 'a', '', 'href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ', 10, 561, 200, 20, 10, '', 'GUI umbenennen/kopieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/RenameGUI');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'updateWMSs', 2, 1, 'Hochgeladene aktualisieren', 'a', '', 'href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"', 10, 80, 200, 20, 5, '', 'WMS aktualisieren', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/UpdateWMS');
@@ -496,7 +496,7 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'loadWMS', 2, 1, 'load Capabilities', 'a', '', 'href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"', 10, 60, 200, 20, 5, '', 'Load Capabilities', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'loadWMSList', 2, 1, 'assign WMS to a GUI', 'a', '', 'href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"', 10, 198, 200, 20, 5, '', 'Assign WMS to a GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'logout', 2, 1, 'Logout', 'img', '../img/button_gray/logout_off.png', 'onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"', 180, 2, 24, 24, 2, '', '', 'img', '', '', '', '', 'http://www.mapbender.org/index.php/logout');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'myGUIlist', 2, 1, 'back to GUI list', 'img', '../img/button_gray/home_off.png', 'onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zurück zur GUI Liste"', 150, 2, 24, 24, 2, '', '', 'img', 'mod_home.php', '', '', '', 'http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'myGUIlist', 2, 1, 'back to GUI list', 'img', '../img/button_gray/home_off.png', 'onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zur�ck zur GUI Liste"', 150, 2, 24, 24, 2, '', '', 'img', 'mod_home.php', '', '', '', 'http://www.mapbender.org/index.php/MyGUIlist');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'newGui', 2, 1, 'New GUI', 'a', '', 'href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ', 10, 451, 200, 20, 5, '', 'New GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'orphanWMS', 2, 1, 'Delete orphaned WMS', 'a', '', 'href = "../php/mod_orphanWMS.php?sessionID"
 target = "AdminFrame"', 10, 120, 200, 20, 5, '', 'Delete orphaned WMS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/OrphanWMS');
@@ -506,11 +506,11 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'wfs_conf', 2, 1, 'Configure WFS', 'a', '', 'href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"', 10, 373, 200, 20, 5, '', 'Configure WFS', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Wfs_conf');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'help', 2, 1, 'button help', 'img', '../img/button_gray/help_off.png', 'onmouseover = "mb_regButton(''init_help'')" title="help"', 210, 2, 24, 24, 1, '', '', '', 'mod_help.php', '../extensions/wz_jsgraphics.js', '', 'jsGraphics', 'http://www.mapbender.org');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'CreateTreeGDE', 2, 1, 'Ordnerbaum konfigurieren', 'a', '', 'href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ', 10, 516, 200, 20, 5, '', 'Ordnerbaum konfigurieren', 'a', '', '', '', 'AdminFrame', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'deleteWMS', 2, 1, '!Vollständig löschen!', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 10, 100, 200, 20, 5, '', 'WMS löschen!', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'deleteWMS', 2, 1, '!Vollst�ndig l�schen!', 'a', '', 'href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ', 10, 100, 200, 20, 5, '', 'WMS l�schen!', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWMS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'exportGUI', 2, 1, 'GUI exportieren, SQL erzeugen', 'a', '', 'href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ', 10, 536, 200, 25, 10, 'x', 'GUI exportieren (SQL)', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'filteredWms_layer_topic', 2, 1, 'allocate topics to layers of wms of this user', 'a', '', 'href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ', 10, 295, 200, 20, 5, '', 'Allocate topics', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Topic_/_Category');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'filteredWms_layer_topic', 2, 1, 'allocate topics to layers of wms of this user', 'a', '', 'href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ', 10, 295, 200, 20, 5, '', 'Kategoriezuordnung', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Topic_/_Category');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'deleteWFS', 2, 1, 'WFS löschen', 'a', '', 'href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ', 10, 393, 200, 20, 5, '', 'WFS löschen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'deleteWFS', 2, 1, 'WFS l�schen', 'a', '', 'href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ', 10, 393, 200, 20, 5, '', 'WFS l�schen', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/DeleteWFS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_en_services', 'EditWMSMetadata', 2, 1, 'edit the metadata of wms', 'a', '', 'href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"', 10, 275, 200, 20, 5, '', 'WMS Metadata', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_WMS_Metadata');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin_de_services', 'EditWMSMetadata', 2, 1, 'edit the metadata of wms', 'a', '', 'href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"', 10, 275, 200, 20, 5, '', 'WMS Metadaten', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/Edit_WMS_Metadata');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('gui2', 'center1', 2, 1, 'Center button', 'img', '../img/button_blue/center_off.png', 'onmouseover = "mb_regButton(''init_gui1_center'')" title="Set map center"', 308, 40, 28, 28, 3, 'filter:Chroma(color=#C2CBCF);', '', '', 'mod_center1.php', '', 'mapframe1', '', 'http://www.mapbender.org/index.php/ReCenter');
@@ -2736,8 +2736,8 @@
 INSERT INTO keyword (keyword_id, keyword) VALUES (41, 'GIS');
 INSERT INTO keyword (keyword_id, keyword) VALUES (42, 'GDI NRW');
 INSERT INTO keyword (keyword_id, keyword) VALUES (43, 'NWSIB');
-INSERT INTO keyword (keyword_id, keyword) VALUES (44, 'klassifiziertes Straßennetz');
-INSERT INTO keyword (keyword_id, keyword) VALUES (45, 'Anweisung Straßeninformationsbank ASB');
+INSERT INTO keyword (keyword_id, keyword) VALUES (44, 'klassifiziertes Stra�ennetz');
+INSERT INTO keyword (keyword_id, keyword) VALUES (45, 'Anweisung Stra�eninformationsbank ASB');
 INSERT INTO keyword (keyword_id, keyword) VALUES (46, 'Netzknoten-Stationierungssystem');
 INSERT INTO keyword (keyword_id, keyword) VALUES (47, 'birds');
 INSERT INTO keyword (keyword_id, keyword) VALUES (48, 'distribution');
@@ -2937,7 +2937,7 @@
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10174, 640, 13, '0', 'huemapped_srtm', 'SRTM derived global elevation, 3 arc-second, hue mapped', 0, 90198, 0, '', '', ' An SRTM derived elevation dataset, where elevation is mapped to hue, resulting a color image');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10175, 640, 14, '0', 'srtmplus', 'Global 1km elevation, seamless SRTM land elevation and ocean depth', 0, 1002199, 0, '', '', ' 	The SRTM30 Plus dataset, a 30 arc-second seamless combination of GTOPO30, SRTM derived land elevation and UCSD Sandwell bathymetry data.  The default style is scaled to 8 bit, non-linear.  It is possible to request the elevation data in meters by the short_int tyle and requesting PNG format.  The resulting PNG file will be a unsigned 16 bit per pixel image. The values are then the elevation in meters.  Values are signed 16 bit integers, but PNG will present them as unsigned, any values larger than 32767 should be interpreted as negative numbers.  For elevation values in feet, request PNG format with the style feet_short_int.       ');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10176, 640, 15, '0', 'worldwind_dem', 'SRTM derived global elevation, 3 arc-second', 0, 90198, 0, '', '', ' 	A global elevation model, prepared from the 3 arc-second SRTM dataset by filling some of the problem areas. Prepared by the NASA Learning Technologies. 	The default style is scaled to 8 bit, non-linear. 	It is possible to request the elevation data in meters by the short_int tyle and requesting PNG format. The resulting PNG file will be a unsigned 16 bit per pixel image. The values are then the elevation in meters. 	Values are signed 16 bit integers, but PNG will present them as unsigned, leading to a few areas with very large values (65000+) 	For elevation values in feet, request PNG format with the style feet_short_int.       ');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19255, 828, 7, '0', 'Puntos_geodésicos', 'Puntos_geodésicos', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19255, 828, 7, '0', 'Puntos_geod�sicos', 'Puntos_geod�sicos', 1, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19176, 250, 0, '', 'Demis World Map', 'Demis World Map', 0, 0, 0, '', '', 'None');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2713, 250, 1, '0', 'Bathymetry', 'Bathymetry', 1, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (2714, 250, 2, '0', 'Countries', 'Countries', 1, 0, 0, '', '', '');
@@ -3120,17 +3120,17 @@
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19241, 789, 18, '0', 'tk10', 'TK 10', 0, 94, 4691, '', '', 'FREETK:MS:FREETK:');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19242, 789, 19, '18', 'tk10w', 'TK 10 - Gewaesser', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK10GEW');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19243, 789, 20, '18', 'tk10i', 'TK 10 - Hoehenlinien', 0, 0, 0, '', '', 'FREETK:MS:FREETK:RASTER TK10ISO');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19190, 328, 0, '', 'verfügbare Layer', 'verfügbare Layer', 0, 0, 0, '', '', 'Web Map Service auf Basis des Smallworld GIS');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19190, 328, 0, '', 'verf�gbare Layer', 'verf�gbare Layer', 0, 0, 0, '', '', 'Web Map Service auf Basis des Smallworld GIS');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3385, 328, 1, '0', 'Autobahn', 'Autobahn', 1, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3386, 328, 2, '0', 'Bundesstr.', 'Bundesstr.', 1, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3387, 328, 3, '0', 'Landesstr.', 'Landesstr.', 1, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3388, 328, 4, '0', 'Kreisstr.', 'Kreisstr.', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3393, 328, 5, '0', 'Aeste', 'Äste', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3393, 328, 5, '0', 'Aeste', '�ste', 1, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19191, 328, 6, '0', 'Netzknoten', 'Netzknoten', 1, 0, 68150, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19192, 328, 7, '0', 'Nullpunkte', 'Nullpunkte', 1, 0, 50110, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19193, 328, 8, '0', 'AS-Nummern', 'AS-Nummern', 1, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19194, 328, 9, '0', 'AS-Namen', 'AS-Namen', 1, 0, 68150, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19195, 328, 10, '0', 'Strassenbez.', 'Straßenbez.', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19195, 328, 10, '0', 'Strassenbez.', 'Stra�enbez.', 1, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19196, 328, 11, '0', 'Abschnittsnr.', 'Abschnittsnr.', 1, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3391, 328, 12, '0', 'Bauwerke', 'Bauwerke', 1, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19197, 328, 13, '12', 'Bauwerkslage', 'Bauwerkslage', 1, 0, 50110, '', '', '');
@@ -3138,10 +3138,10 @@
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19199, 328, 15, '0', 'Verwaltungsbezirke', 'Verwaltungsbezirke', 1, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19200, 328, 16, '15', 'Bundesland', 'Bundesland', 1, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19201, 328, 17, '15', 'Regierungsbezirke', 'Regierungsbezirke', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19202, 328, 18, '15', 'Kreise_/_kreisfreie_Staedte', 'Kreise / kreisfreie Städte', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19202, 328, 18, '15', 'Kreise_/_kreisfreie_Staedte', 'Kreise / kreisfreie St�dte', 1, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19203, 328, 19, '15', 'Gemeinden', 'Gemeinden', 1, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19204, 328, 20, '0', 'Rasterkarten', 'Rasterkarten', 0, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19205, 328, 21, '20', 'Strassenkarte', 'Straßenkarte', 0, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19205, 328, 21, '20', 'Strassenkarte', 'Stra�enkarte', 0, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7523, 584, 6, '0', 'OBBA_SQUARE', 'Ontario Breeding Bird Atlas 10 km Squares', 1, 0, 0, '', '', 'A sampling unit used by the Ontario Breeding Bird Atlas to collect breeding evidence data for all bird species within the Province of Ontario.  Squares are based upon the Universal Transverse Mercator (UTM) grid system, NAD83, and measure 10Km by 10Km except near UTM zone boundaries, where they are smaller.');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7524, 584, 7, '0', 'OBBA_REGION', 'Ontario Breeding Bird Atlas Administrative Regions', 1, 0, 0, '', '', 'An administrative unit that is used for local bird atlas co-ordination, which is based on bioregions and access.  Each region is assigned a Regional Coordinator who administers bird surveys within their region.');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7525, 584, 8, '0', 'OBBA_BLOCK', 'Ontario Breeding Bird Atlas 100 km Blocks', 1, 0, 0, '', '', 'A sampling unit used by the Ontario Breeding Bird Atlas to collect breeding evidence data for all bird species within the Province of Ontario.  Blocks are based upon the Universal Transverse Mercator (UTM) grid system, NAD83, and measure 100Km by 100Km except near UTM zone boundaries, where they are smaller.');
@@ -3149,9 +3149,9 @@
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7527, 584, 10, '0', 'BBS_PT', 'Breeding Bird Survey Route Start Points', 1, 0, 0, '', '', 'The Breeding Bird Survey, initiated in 1966, is one of the oldest surveys of breeding birds in North America. It is conducted primarily by volunteers, who follow a predetermined, roadside route each year at the height of the breeding season.  This layer portrays the start point for each BBS route in Canada.');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19228, 834, 0, '', 'DE_aerial02', 'DE_aerial02', 0, 0, 0, '', '', 'The Delaware 2002 Aerial Imagery Map Service serves statewide orthophotography as captured in 2002. The State of Delaware contracted with EarthData International to develop 0.25-meter resolution color infrared digital ortho-photos for the entire state. Map scale of the photography is approximately 1:2,400. Airphotos were taken in March and April, 2002, digitized and georeferenced to Delaware State Plane NAD83 meters. This data is available as an ArcIMS map service, a WMS map service, original 1-meter raw data files. ');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19246, 828, 0, '', 'CAPAS', 'CAPAS', 0, 0, 0, '', '', 'IDERIOJA Gobierno de La Rioja OGC WMS');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19247, 828, 1, '0', 'Elementos_hidrográficos', 'Elementos_hidrográficos', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19248, 828, 2, '0', 'Hojas_cartográficas_1-5000', 'Hojas_cartográficas_1-5000', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19249, 828, 3, '0', 'Manzanas_de_los_núcleos_urbanos', 'Manzanas_de_los_núcleos_urbanos', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19247, 828, 1, '0', 'Elementos_hidrogr�ficos', 'Elementos_hidrogr�ficos', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19248, 828, 2, '0', 'Hojas_cartogr�ficas_1-5000', 'Hojas_cartogr�ficas_1-5000', 1, 0, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19249, 828, 3, '0', 'Manzanas_de_los_n�cleos_urbanos', 'Manzanas_de_los_n�cleos_urbanos', 1, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10106, 634, 0, '', 'Location', 'Point locations', 0, 0, 0, '', '', 'This service provides approximate point locations for various     themes.   ');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10107, 634, 1, '0', 'city_austral', 'Australasian Cities', 0, 0, 0, '', '', '           Location of cities in the Australasian region.         ');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (10108, 634, 2, '0', 'capital_aus', 'Australian Capital Cities', 0, 0, 0, '', '', '           Location of capital cities in Australia.         ');
@@ -3216,7 +3216,7 @@
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19006, 893, 0, '', 'Germany', 'Germany', 0, 1, 0, '', '', 'Germany');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19007, 893, 1, '0', 'Topographie', 'topography', 0, 0, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Topographie,Landschaft');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (7519, 584, 2, '0', 'CBC_PT', 'Canadian Christmas Bird Count Locations', 1, 0, 0, '', '', 'A winter survey of bird populations conducted during the Christmas period - December 14 to January 5th inclusive.  More than 1800 counts are conducted each year across Canada, the United States and Latin America.  On a selected day within the count period, local birders count as many birds as possible within a 24 km (15 mile) diameter circle.  The Christmas Bird Count had long been organized on the continental scale by the New York-based National Audubon Society. In 2000, Audubon finalized an agreement with Bird Studies Canada that would see BSC partner with Audubon to coordinate CBCs in Canada.  This layer represents the centre point of all the Christmas Bird Counts conducted in Canada.  An accompanying layer (CBC_PY) contains the 24 km circles.');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19170, 908, 0, '', 'NRW', 'NRW', 0, 0, 140316, '', '', 'Nutzungsbedingungen: Sämtliche Rechte an diesem Produkt liegen beim Landesvermessungsamt NRW. Die Nutzung ist bis auf Widerruf kostenfrei. Der Nutzer muss sich vor jeder Nutzung beim Landesvermessungsamt NRW identifizieren und seine spezielle Nutzung mit Angabe des Verwendungszwecks und Umfang der Nutzung anmelden (Kontaktmöglichkeiten zum Landesvermessungsamt NRW siehe unten). Die Nutzung ist ausschließlich für Testzwecke und im Rahmen von GDI-Projekten zulässig; die Nutzung für kommerzielle Anwendungen ist ausdrücklich ausgeschlossen. Die mittelbare oder unmittelbare Weitergabe der Daten an Dritte ist auch in Verbindung mit weiteren Daten ohne ausdrückliche Genehmigung durch das Landesvermessungsamt NRW nicht zulässig. Der Nutzer ist verpflichtet, einen deutlichen Copyright-Hinweis auf das Landesvermessungsamt NRW als Dateneigentümer bei Visualisierungen jeder Art anzubringen.');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19170, 908, 0, '', 'NRW', 'NRW', 0, 0, 140316, '', '', 'Nutzungsbedingungen: S�mtliche Rechte an diesem Produkt liegen beim Landesvermessungsamt NRW. Die Nutzung ist bis auf Widerruf kostenfrei. Der Nutzer muss sich vor jeder Nutzung beim Landesvermessungsamt NRW identifizieren und seine spezielle Nutzung mit Angabe des Verwendungszwecks und Umfang der Nutzung anmelden (Kontaktm�glichkeiten zum Landesvermessungsamt NRW siehe unten). Die Nutzung ist ausschlie�lich f�r Testzwecke und im Rahmen von GDI-Projekten zul�ssig; die Nutzung f�r kommerzielle Anwendungen ist ausdr�cklich ausgeschlossen. Die mittelbare oder unmittelbare Weitergabe der Daten an Dritte ist auch in Verbindung mit weiteren Daten ohne ausdr�ckliche Genehmigung durch das Landesvermessungsamt NRW nicht zul�ssig. Der Nutzer ist verpflichtet, einen deutlichen Copyright-Hinweis auf das Landesvermessungsamt NRW als Dateneigent�mer bei Visualisierungen jeder Art anzubringen.');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19171, 908, 1, '0', 'Raster:TK100_KMF:Farbkombination', 'Farbkombination', 1, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19226, 789, 0, '', 'Topographische Karten', 'Topographische Karten', 0, 0, 0, '', '', 'SICAD Internet Suite V6.0A05 at http://www.landesvermessung.sachsen.de/sims/sicad-');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19008, 893, 2, '0', 'Grenze', 'border', 0, 750000, 0, 'http://www.mapbender.de/', 'http://www.mapbender.de/', 'Grenzen, border');
@@ -3385,17 +3385,17 @@
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14970, 844, 37, '0', 'coasts', 'coasts', 1, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14978, 844, 38, '0', 'contour_syn_precip', 'contour_syn_precip', 1, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (14990, 844, 39, '0', 'interstates', 'interstates', 1, 0, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19111, 902, 1, '0', 'kreis', 'Landkreise und kreisfreie Städte', 1, 25001, 0, '', '', 'Landkreise und kreisfreie Städte');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19111, 902, 1, '0', 'kreis', 'Landkreise und kreisfreie St�dte', 1, 25001, 0, '', '', 'Landkreise und kreisfreie St�dte');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19112, 902, 2, '0', 'wald', 'Wald', 0, 25001, 150000, '', '', 'Wald');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19113, 902, 3, '0', 'ozen', 'Oberzentren', 0, 25001, 2000000, '', '', 'Oberzentren, TYP = 0');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19114, 902, 4, '0', 'mzen', 'Mittelzentren', 0, 25001, 600000, '', '', 'Mittelzentren, TYP = 1');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19115, 902, 5, '0', 'uzen', 'Unterzentren', 0, 25001, 200000, '', '', 'Unterzentren, TYP = 2');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19116, 902, 6, '0', 'lwas', 'Flüsse und Kanäle', 0, 25001, 150000, '', '', 'Flüsse und Kanäle');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19116, 902, 6, '0', 'lwas', 'Fl�sse und Kan�le', 0, 25001, 150000, '', '', 'Fl�sse und Kan�le');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19117, 902, 7, '0', 'fwas', 'Seen', 0, 25001, 250001, '', '', 'Seen');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19118, 902, 8, '0', 'ebahn', 'Eisenbahnen', 0, 25001, 250001, '', '', 'Eisenbahnen');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19119, 902, 9, '0', 'kstr', 'Kreisstraßen', 0, 25001, 100000, '', '', 'Kreisstraßen');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19120, 902, 10, '0', 'lstr', 'Landesstraßen', 0, 25001, 250001, '', '', 'Landesstraßen');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19121, 902, 11, '0', 'bstr', 'Bundesstraßen', 0, 25001, 749999, '', '', 'Bundesstraßen');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19119, 902, 9, '0', 'kstr', 'Kreisstra�en', 0, 25001, 100000, '', '', 'Kreisstra�en');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19120, 902, 10, '0', 'lstr', 'Landesstra�en', 0, 25001, 250001, '', '', 'Landesstra�en');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19121, 902, 11, '0', 'bstr', 'Bundesstra�en', 0, 25001, 749999, '', '', 'Bundesstra�en');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19122, 902, 12, '0', 'astr', 'Autobahnen', 0, 25001, 0, '', '', 'Autobahnen');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19123, 902, 13, '0', 'nfwas', 'Namen der Seen', 0, 25001, 100000, '', '', 'Namen der Seen');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19124, 902, 14, '0', 'kfz', 'Kfz-Zeichen', 0, 2000000, 0, '', '', 'Kfz-Zeichen');
@@ -4330,21 +4330,21 @@
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20099, 824, 791, '786', 'USA_SANDIEGOAIRPHOTO_02', 'sandiegoairphoto', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/usa/sandiegoairphoto.ecw', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20100, 824, 792, '786', 'USA_SANDIEGOAIRPHOTO_03', 'sandiegoairphoto', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/usa/sandiegoairphoto.jp2', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20101, 824, 793, '786', 'USA_SANDIEGOAIRPHOTO_LOSSLESS_01', 'sandiegoairphoto_lossless', 0, 0, 0, 'http://camber.mc.man.ac.uk/ecwp/ImageX.dll?dsinfo?layer=/sampleiws/images/usa/sandiegoairphoto_lossless.jp2', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19149, 905, 0, '', 'Brandenburg', 'DNM FÜK', 0, 50000, 0, '', '', 'Digitales Navigationsmodell Flurübersichtskarte der Brandenburger Landesvermessung');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19149, 905, 0, '', 'Brandenburg', 'DNM F�K', 0, 50000, 0, '', '', 'Digitales Navigationsmodell Flur�bersichtskarte der Brandenburger Landesvermessung');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19150, 905, 1, '0', 'flur', 'Flur', 1, 50000, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19151, 905, 2, '0', 'gema', 'Gemarkung', 1, 50000, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19152, 905, 3, '0', 'geme', 'Gemeinde', 1, 50000, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19153, 905, 4, '0', 'stadt', 'Kreisfreie Städte', 1, 50000, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19153, 905, 4, '0', 'stadt', 'Kreisfreie St�dte', 1, 50000, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19138, 904, 0, '', 'Brandenburg', 'DNM 250/2', 0, 25001, 0, '', '', '2. Generation des Digitalen Navigationsmodells 1:250.000 als topographische Basisnavigationsdaten der Brandenburger Landesvermessung');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19154, 905, 5, '0', 'kreis', 'Landkreise', 1, 50000, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3401, 329, 0, '', 'MUENSTER', 'Geobasisdaten Muenster', 0, 0, 0, '', '', 'Geobasisdaten Muenster');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3402, 329, 1, '0', 'splan', 'Stadtplan', 0, 2400, 2000000, '', '', 'Stadtplan');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19139, 904, 1, '0', 'kreis', 'Landkreise und kreisfreie Städte', 1, 200000, 0, '', '', 'Landkreise und kreisfreie Städte');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19139, 904, 1, '0', 'kreis', 'Landkreise und kreisfreie St�dte', 1, 200000, 0, '', '', 'Landkreise und kreisfreie St�dte');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3403, 329, 2, '0', 'luftb', 'Luftbilder', 0, 375, 3900, '', '', 'Luftbilder');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19140, 904, 2, '0', 'orte', 'Zentren', 0, 200000, 1000000, '', '', 'Zentren, TYP = 0');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19141, 904, 3, '0', 'korte', 'Orte', 0, 200000, 749999, '', '', 'Orte, TYP = 0');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3404, 329, 3, '0', 'dgk5dbr', 'DGK5', 0, 1, 3900, '', '', 'DGK5');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19142, 904, 4, '0', 'lwas', 'Flüsse und Kanäle', 0, 200000, 749999, '', '', 'Flüsse und Kanäle');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19142, 904, 4, '0', 'lwas', 'Fl�sse und Kan�le', 0, 200000, 749999, '', '', 'Fl�sse und Kan�le');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3405, 329, 4, '0', 'Stadtgrundkarte', 'Stadtgrundkarte', 0, 0, 0, '', '', 'Stadtgrundkarte');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19143, 904, 5, '0', 'fwas', 'Seen', 0, 200000, 749999, '', '', 'Seen');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3406, 329, 5, '4', 'flst', 'Flurstuecke', 0, 1, 2500, '', '', '');
@@ -4353,21 +4353,21 @@
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3407, 329, 6, '4', 'gebaeude', 'Gebaeude', 0, 1, 2500, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3408, 329, 7, '4', 'linien', 'Topographie', 0, 1, 2500, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (3409, 329, 8, '4', 'texte', 'Beschriftung', 0, 1, 2500, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19145, 904, 7, '0', 'lstr', 'Landesstraßen', 0, 200000, 400000, '', '', 'Landesstraßen');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19146, 904, 8, '0', 'bstr', 'Bundesstraßen', 0, 200000, 1000000, '', '', 'Bundesstraßen');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19145, 904, 7, '0', 'lstr', 'Landesstra�en', 0, 200000, 400000, '', '', 'Landesstra�en');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19146, 904, 8, '0', 'bstr', 'Bundesstra�en', 0, 200000, 1000000, '', '', 'Bundesstra�en');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19147, 904, 9, '0', 'astr', 'Autobahnen', 0, 200000, 0, '', '', 'Autobahnen');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19148, 904, 10, '0', 'kfz', 'Kfz-Zeichen', 0, 1000000, 0, '', '', 'Kfz-Zeichen');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19156, 906, 1, '0', 'berlin', 'Berliner Bezirke', 0, 50000, 1000000, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19157, 906, 2, '0', 'geme', 'Gemeinde', 1, 50000, 1000000, '', '', 'digitaliert aus DTK 1:100.000');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19158, 906, 3, '0', 'kamt', 'Amtsfreie Gemeinde', 1, 50000, 1000000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19159, 906, 4, '0', 'amt', 'Ämter', 1, 50000, 1000000, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19160, 906, 5, '0', 'stadt', 'Kreisfreie Städte', 1, 50000, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19159, 906, 4, '0', 'amt', '�mter', 1, 50000, 1000000, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19160, 906, 5, '0', 'stadt', 'Kreisfreie St�dte', 1, 50000, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19161, 906, 6, '0', 'kreis', 'Landkreise', 1, 50000, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19162, 906, 7, '0', 'land', 'Land', 0, 50000, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19163, 906, 8, '0', 'staat', 'Deutschland', 0, 50000, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19164, 906, 9, '0', 'ngeme', 'Namen der Gemeinden', 0, 50000, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19165, 906, 10, '0', 'nkamt', 'Namen der amtfreien Gemeinden', 0, 50000, 0, '', '', '');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19166, 906, 11, '0', 'namt', 'Namen der Ämter', 0, 50000, 0, '', '', '');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19166, 906, 11, '0', 'namt', 'Namen der �mter', 0, 50000, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19167, 906, 12, '0', 'nkreis', 'KFZ Kennzeichen der Kreise', 0, 50000, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19233, 706, 0, '', 'WA_Atlas_GN_WMS', 'WA_Atlas_GN_WMS', 0, 0, 0, '', '', 'WMS Map Server');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11542, 706, 1, '0', 'Australia Base Map', 'Australia Base Map', 0, 0, 0, '', '', '');
@@ -4377,17 +4377,17 @@
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11546, 706, 5, '0', 'State Geological Polygons', 'State Geological Polygons', 0, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (11547, 706, 6, '0', 'Beards Vegetation', 'Beards Vegetation', 0, 0, 0, '', '', '');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19125, 903, 0, '', 'Brandenburg', 'DNM 25', 0, 100, 50000, '', '', 'Digitales Navigationsmodell 1:25.000 als Basisnavigationsdaten der Brandenburger Landesvermessung');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19126, 903, 1, '0', 'land', 'Landkreise und kreisfreie Städte', 0, 100, 50000, '', '', 'digitalisiert und generalisiert aus DTK 1:100.000');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19126, 903, 1, '0', 'land', 'Landkreise und kreisfreie St�dte', 0, 100, 50000, '', '', 'digitalisiert und generalisiert aus DTK 1:100.000');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19127, 903, 2, '0', 'ort', 'Ortschaften', 1, 1000, 50000, '', '', 'digitaliert aus DTK 1:100.000');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19128, 903, 3, '0', 'wald', 'Waldflächen', 0, 1000, 50000, '', '', 'aus Basis-DLM');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19129, 903, 4, '0', 'gruen', 'Grünflächen', 0, 1000, 50000, '', '', 'Grünflächen aus Basis-DLM');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19130, 903, 5, '0', 'lwas', 'Flüsse und Kanäle', 0, 1000, 50000, '', '', 'aus Basis-DLM');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19128, 903, 3, '0', 'wald', 'Waldfl�chen', 0, 1000, 50000, '', '', 'aus Basis-DLM');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19129, 903, 4, '0', 'gruen', 'Gr�nfl�chen', 0, 1000, 50000, '', '', 'Gr�nfl�chen aus Basis-DLM');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19130, 903, 5, '0', 'lwas', 'Fl�sse und Kan�le', 0, 1000, 50000, '', '', 'aus Basis-DLM');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19131, 903, 6, '0', 'fwas', 'Seen, Teiche', 0, 1000, 50000, '', '', 'aus Basis-DLM');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19132, 903, 7, '0', 'kgrnz', 'Kreisgrenze', 0, 1000, 50000, '', '', 'generalisiert aus 1:100.000');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19133, 903, 8, '0', 'flug', 'Internationale Flughäfen', 0, 1000, 29999, '', '', 'aus Basis-DLM');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19133, 903, 8, '0', 'flug', 'Internationale Flugh�fen', 0, 1000, 29999, '', '', 'aus Basis-DLM');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19134, 903, 9, '0', 'ebahn', 'Eisenbahnverbindungen', 0, 1000, 50000, '', '', 'aus Basis-DLM');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19135, 903, 10, '0', 'str', 'Straßen', 0, 1000, 50000, '', '', 'aus Basis-DLM');
-INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19136, 903, 11, '0', 'haus', 'Gebäude', 0, 1000, 50000, '', '', 'aus Basis-DLM');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19135, 903, 10, '0', 'str', 'Stra�en', 0, 1000, 50000, '', '', 'aus Basis-DLM');
+INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19136, 903, 11, '0', 'haus', 'Geb�ude', 0, 1000, 50000, '', '', 'aus Basis-DLM');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (19137, 903, 12, '0', 'nfwas', 'Namen der Seen, Teiche', 0, 1000, 50000, '', '', 'aus Basis-DLM');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20102, 910, 0, '', 'IGME5000', 'IGME5000 preliminary release', 0, 0, 0, NULL, NULL, 'The 1 : 5 Million International Geological Map of Europe and Adjacent Areas (IGME 5000).');
 INSERT INTO layer (layer_id, fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, layer_queryable, layer_minscale, layer_maxscale, layer_dataurl, layer_metadataurl, layer_abstract) VALUES (20103, 910, 1, '0', 'la_igme_nations', 'Nations', 0, 0, 0, NULL, NULL, 'Nation Shapes of Europe');
@@ -7814,17 +7814,17 @@
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10175, 'default', 'Default Elevation Style, scaled to 8 bit using a non-linear function', '', '');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10175, 'short_int', 'short int elevation values when format is image/png, identical to default for jpeg', '', '');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10175, 'feet_short_int', 'short int elevation values in feet when format is image/png ', '', '');
-INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19247, 'Default', 'Default', 'http://wms.larioja.org/Legends/Elementos_hidrográficos_Default.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19247, 'Default', 'Default', 'http://wms.larioja.org/Legends/Elementos_hidrogr�ficos_Default.png', 'image/png');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10176, 'default', 'Default Elevation Style, scaled to 8 bit using a non-linear function', '', '');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10176, 'short_int', 'short int elevation values when format is image/png', '', '');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10176, 'feet_short_int', 'short int elevation values in feet when format is image/png', '', '');
-INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19248, 'Default', 'Default', 'http://wms.larioja.org/Legends/Hojas_cartográficas_1-5000_Default.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19248, 'Default', 'Default', 'http://wms.larioja.org/Legends/Hojas_cartogr�ficas_1-5000_Default.png', 'image/png');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10177, 'default', 'Default Elevation', '', '');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10177, 'short_int', 'short int signed elevation values when format is image/png or tiff', '', '');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10177, 'feet_short_int', 'short int elevation values in feet when format is image/png or image/tiff', '', '');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10177, 'real', 'DEM real numbers, in floating point format, meters, when used with image/tiff', '', '');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10177, 'feet_real', 'DEM in real numbers, in floating point format, feet, when used with image/tiff', '', '');
-INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19249, 'Default', 'Default', 'http://wms.larioja.org/Legends/Manzanas_de_los_núcleos_urbanos_Default.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19249, 'Default', 'Default', 'http://wms.larioja.org/Legends/Manzanas_de_los_n�cleos_urbanos_Default.png', 'image/png');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10178, 'default', 'Default Elevation', '', '');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10178, 'short_int', 'short int elevation values when format is image/png', '', '');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (10178, 'feet_short_int', 'short int elevation values in feet when format is image/png', '', '');
@@ -7924,7 +7924,7 @@
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19240, 'Feb', 'February', '', '');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19240, 'Mar', 'March', '', '');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19240, 'Apr', 'April', '', '');
-INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19255, 'Default', 'Default', 'http://wms.larioja.org/Legends/Puntos_geodésicos_Default.png', 'image/png');
+INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19255, 'Default', 'Default', 'http://wms.larioja.org/Legends/Puntos_geod�sicos_Default.png', 'image/png');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19256, 'Default', 'Default', 'http://wms.larioja.org/Legends/Tramos_de_carreteras_Default.png', 'image/png');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (19257, 'Default', 'Default', 'http://wms.larioja.org/Legends/Tramos_de_ferrocarril_Default.png', 'image/png');
 INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) VALUES (14843, 'Default', 'Default', 'http://maps1.intergraph.com/wms/world/Legends/GLOBEImage_Default.png', 'image/png');
@@ -8143,13 +8143,13 @@
 INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (3, 'boundaries', 'Grenzen');
 INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (4, 'climatologyMeteorologyAtmosphere', 'Wetterkunde');
 INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (5, 'economy', 'Wirtschaft');
-INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (6, 'elevation', 'Höhendaten');
+INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (6, 'elevation', 'H�hendaten');
 INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (7, 'environment', 'Umwelt');
 INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (8, 'geoscientificInformation', 'Geowissenschaft');
 INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (9, 'health', 'Gesundheit');
 INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (10, 'imageryBaseMapsEarthCover', 'Grundlagenkarten');
-INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (11, 'intelligenceMilitary', 'militärische Aufklärung');
-INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (12, 'inlandWaters', 'Binnengewässer');
+INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (11, 'intelligenceMilitary', 'milit�rische Aufkl�rung');
+INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (12, 'inlandWaters', 'Binnengew�sser');
 INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (13, 'location', 'Ortsinformationen');
 INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (14, 'oceans', 'Meereskunde');
 INSERT INTO md_topic_category (md_topic_category_id, md_topic_category_code_en, md_topic_category_code_de) VALUES (15, 'planningCadastre', 'Landnutzung/Planung/Kataster');
@@ -12370,7 +12370,7 @@
     <ScaleHint min="0.0498903" max="24.9451" />
     <Layer queryable="0" opaque="0" cascaded="0">
         <Name>land</Name>
-        <Title>Landkreise und kreisfreie Städte</Title>
+        <Title>Landkreise und kreisfreie St�dte</Title>
         <Abstract>digitalisiert und generalisiert aus DTK 1:100.000</Abstract>
         <SRS>EPSG:25833</SRS>
         <LatLonBoundingBox minx="11.2317" miny="51.3099" maxx="14.7656" maxy="53.5639" />
@@ -12390,7 +12390,7 @@
     </Layer>
         <Name>wald</Name>
-        <Title>Waldflächen</Title>
+        <Title>Waldfl�chen</Title>
         <Abstract>aus Basis-DLM</Abstract>
         <LatLonBoundingBox minx="11.2411" miny="51.3136" maxx="14.7667" maxy="53.5599" />
@@ -12400,8 +12400,8 @@
     </Layer>
         <Name>gruen</Name>
-        <Title>Grünflächen</Title>
-        <Abstract>Grünflächen aus Basis-DLM</Abstract>
+        <Title>Gr�nfl�chen</Title>
+        <Abstract>Gr�nfl�chen aus Basis-DLM</Abstract>
         <LatLonBoundingBox minx="11.2339" miny="51.3128" maxx="14.7662" maxy="53.5648" />
         <BoundingBox SRS="EPSG:25833"
@@ -12410,7 +12410,7 @@
     </Layer>
         <Name>lwas</Name>
-        <Title>Flüsse und Kanäle</Title>
+        <Title>Fl�sse und Kan�le</Title>
         <LatLonBoundingBox minx="11.253" miny="51.3161" maxx="14.7408" maxy="53.5563" />
@@ -12440,7 +12440,7 @@
     </Layer>
         <Name>flug</Name>
-        <Title>Internationale Flughäfen</Title>
+        <Title>Internationale Flugh�fen</Title>
         <LatLonBoundingBox minx="12.4667" miny="52.3476" maxx="13.562" maxy="52.5707" />
@@ -12460,7 +12460,7 @@
     </Layer>
         <Name>str</Name>
-        <Title>Straßen</Title>
+        <Title>Stra�en</Title>
         <LatLonBoundingBox minx="11.2382" miny="51.3129" maxx="14.7649" maxy="53.5635" />
@@ -12470,7 +12470,7 @@
     </Layer>
         <Name>haus</Name>
-        <Title>Gebäude</Title>
+        <Title>Geb�ude</Title>
         <LatLonBoundingBox minx="11.2386" miny="51.3159" maxx="14.7642" maxy="53.5646" />
@@ -12589,7 +12589,7 @@
 INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (828, '1.1.1', 'IDERIOJA Gobierno de La Rioja OGC WMS', 'IDERIOJA Gobierno de La Rioja OGC WMS', 'http://wms.larioja.org/request.asp', 'http://wms.larioja.org/request.asp', 'http://wms.larioja.org/request.asp', '', '', '<?xml version="1.0"?>
 <!DOCTYPE WMT_MS_Capabilities SYSTEM "http://wms.larioja.org/Capabilities/capabilities_1_1_1.dtd" [ <!ELEMENT VendorSpecificCapabilities EMPTY>]>
 <WMT_MS_Capabilities version="1.1.1"><Service><Name>OGC:WMS</Name><!--Human-readable title for pick lists--><Title>IDERIOJA Gobierno de La Rioja OGC WMS</Title><!--Narrative description providing additional information--><Abstract>IDERIOJA Gobierno de La Rioja OGC WMS</Abstract><KeywordList><Keyword>WMS</Keyword><Keyword>OGC</Keyword><Keyword> La Rioja</Keyword><Keyword>Cartografia</Keyword><Keyword> Mapas </Keyword></KeywordList><!--Top-level address of service or service provider--><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://www.larioja.org" xlink:type="simple"/><ContactInformation><ContactPersonPrimary><ContactPerson>Gonzalo López García</ContactPerson><ContactOrganization>Consejería de Turismo, Medio Ambiente y Política Territorial</ContactOrganization></ContactPersonPrimary><ContactPosition>Jefe de Sección de Sistemas de Información Geográfica y Cartografía</ContactPosition><ContactAddress><AddressType>postal</AddressType><Address>Prado Viejo, 62 bis</Address><City>Logroño</City><StateOrProvince>La Rioja</StateOrProvince><PostCode>26071</PostCode><Country></Country></ContactAddress><ContactVoiceTelephone></ContactVoiceTelephone><ContactElectronicMailAddress></ContactElectronicMailAddress></ContactInformation><Fees>none</Fees><AccessConstraints>none</AccessConstraints></Service><Capability><Request><GetCapabilities><Format>application/vnd.ogc.wms_xml</Format><DCPType><HTTP><Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms.larioja.org/request.asp" xlink:type="simple"/></Get></HTTP></DCPType></GetCapabilities><GetMap><Format>image/png</Format><Format>image/jpeg</Format><DCPType><HTTP><Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms.larioja.org/request.asp" xlink:type="simple"/></Get></HTTP></DCPType></GetMap><GetFeatureInfo><Format>text/html</Format><DCPType><HTTP><Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms.larioja.org/request.asp" xlink:type="simple"/></Get></HTTP></DCPType></GetFeatureInfo></Request><Exception><Format>application/vnd.ogc.se_inimage</Format><Format>application/vnd.ogc.se_xml</Format></Exception><Layer><Title>CAPAS</Title><SRS>EPSG:4326</SRS><SRS>EPSG:23030</SRS><SRS>EPSG:25830</SRS><LatLonBoundingBox minx="-3.2623" miny="41.8509" maxx="-1.5416" maxy="42.7473"/><!--BoundingBox is inheritable, we define at root, inherited by all--><BoundingBox SRS="EPSG:23030" minx="478621.4999" miny="4634401.5" maxx="619671.5001" maxy="4733511.3584"/><BoundingBox SRS="EPSG:25830" minx="478517.3309" miny="4634188.7848" maxx="619566.8081" maxy="4733298.3072"/><BoundingBox SRS="EPSG:4326" minx="-3.2623" miny="41.8509" maxx="-1.5416" maxy="42.7473"/><Layer queryable="1" opaque="0" noSubsets="0"><Name>Elementos_hidrográficos</Name><Title>Elementos_hidrográficos</Title><Style><Name>Default</Name><Title>Default</Title><LegendURL width="20" height="15"><Format>image/png</Format><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms.larioja.org/Legends/Elementos_hidrográficos_Default.png" xlink:type="simple"/></LegendURL></Style></Layer><Layer queryable="1" opaque="0" noSubsets="0"><Name>Hojas_cartográficas_1-5000</Name><Title>Hojas_cartográficas_1-5000</Title><Style><Name>Default</Name><Title>Default</Title><LegendURL width="20" height="15"><Format>image/png</Format><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms.larioja.org/Legends/Hojas_cartográficas_1-5000_Default.png" xlink:type="simple"/></LegendURL></Style></Layer><Layer queryable="1" opaque="0" noSubsets="0"><Name>Manzanas_de_los_núcleos_urbanos</Name><Title>Manzanas_de_los_núcleos_urbanos</Title><Style><Name>Default</Name><Title>Default</Title><LegendURL width="20" height="15"><Format>image/png</Format><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms.larioja.org/Legends/Manzanas_de_los_núcleos_urbanos_Default.png" xlink:type="simple"/></LegendURL></Style></Layer><Layer queryable="1" opaque="0" noSubsets="0"><Name>Masas_de_agua</Name><Title>Masas_de_agua</Title><Style><Name>Default</Name><Title>Default</Title><LegendURL width="20" height="15"><Format>image/png</Format><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms.larioja.org/Legends/Masas_de_agua_Default.png" xlink:type="simple"/></LegendURL></Style></Layer><Layer queryable="1" opaque="0" noSubsets="0"><Name>Municipios</Name><Title>Municipios</Title><Style><Name>Default</Name><Title>Default</Title><LegendURL width="20" height="15"><Format>image/png</Format><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms.larioja.org/Legends/Municipios_Default.png" xlink:type="simple"/></LegendURL></Style></Layer><Layer queryable="0" opaque="0" noSubsets="0"><Name>Ortofoto_2004</Name><Title>Ortofoto_2004</Title><Style><Name>Default</Name><Title>Default</Title><LegendURL width="20" height="15"><Format>image/png</Format><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms.larioja.org/Legends/Ortofoto_2004_Default.png" xlink:type="simple"/></LegendURL></Style></Layer><Layer queryable="1" opaque="0" noSubsets="0"><Name>Puntos_geodésicos</Name><Title>Puntos_geodésicos</Title><Style><Name>Default</Name><Title>Default</Title><LegendURL width="20" height="15"><Format>image/png</Format><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms.larioja.org/Legends/Puntos_geodésicos_Default.png" xlink:type="simple"/></LegendURL></Style></Layer><Layer queryable="1" opaque="0" noSubsets="0"><Name>Tramos_de_carreteras</Name><Title>Tramos_de_carreteras</Title><Style><Name>Default</Name><Title>Default</Title><LegendURL width="20" height="15"><Format>image/png</Format><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms.larioja.org/Legends/Tramos_de_carreteras_Default.png" xlink:type="simple"/></LegendURL></Style></Layer><Layer queryable="1" opaque="0" noSubsets="0"><Name>Tramos_de_ferrocarril</Name><Title>Tramos_de_ferrocarril</Title><Style><Name>Default</Name><Title>Default</Title><LegendURL width="20" height="15"><Format>image/png</Format><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://wms.larioja.org/Legends/Tramos_de_ferrocarril_Default.png" xlink:type="simple"/></LegendURL></Style></Layer></Layer></Capability></WMT_MS_Capabilities>
-', NULL, 'http://wms.larioja.org/request.asp?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1', 'none', 'none', 'Gonzalo López García', 'Jefe de Sección de Sistemas de Información Geográfica y Cartografía', 'Consejería de Turismo, Medio Ambiente y Política Territorial', 'Prado Viejo, 62 bis', 'Logroño', 'La Rioja', '26071', '', '', '', '', NULL, 1, 1173698127);
+', NULL, 'http://wms.larioja.org/request.asp?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1', 'none', 'none', 'Gonzalo L�pez Garc�a', 'Jefe de Secci�n de Sistemas de Informaci�n Geogr�fica y Cartograf�a', 'Consejer�a de Turismo, Medio Ambiente y Pol�tica Territorial', 'Prado Viejo, 62 bis', 'Logro�o', 'La Rioja', '26071', '', '', '', '', NULL, 1, 1173698127);
 INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (86, '1.1.1', 'World Map', 'World Map in WGS84 Reference System', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/world/world_map.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/world/world_map.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/world/world_map.map&', 'http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/world/world_map.map&', '', '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
 <!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengeospatial.net/wms/1.1.1/WMS_MS_Capabilities.dtd"
@@ -12753,8 +12753,8 @@
 		<Abstract>Web Map Service auf Basis des Smallworld GIS</Abstract>
 		<KeywordList>
 			<Keyword>NWSIB</Keyword>
-			<Keyword>klassifiziertes Straßennetz</Keyword>
-			<Keyword>Anweisung Straßeninformationsbank ASB</Keyword>
+			<Keyword>klassifiziertes Stra�ennetz</Keyword>
+			<Keyword>Anweisung Stra�eninformationsbank ASB</Keyword>
 			<Keyword>Netzknoten-Stationierungssystem</Keyword>
 		</KeywordList>
 		<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.gis-consult.de"/>
@@ -12763,7 +12763,7 @@
 				<ContactPerson>Christian Vogt</ContactPerson>
 				<ContactOrganization>GIS Consult GmbH</ContactOrganization>
-			<ContactPosition>Geschäftsführer</ContactPosition>
+			<ContactPosition>Gesch�ftsf�hrer</ContactPosition>
 			<ContactAddress>
 				<Address>Schultenbusch 3</Address>
@@ -12777,7 +12777,7 @@
 			<ContactElectronicMailAddress>vogt at gis-consult.de</ContactElectronicMailAddress>
 		<Fees>none</Fees>
-		<AccessConstraints>Die Straßendaten wurden freundlicherweise vom Landesbetrieb Straßenbau NRW zur Verfügung gestellt. Es handelt sich hierbei um einen unvollständigen Datenauszug, der nicht dem aktuellen Stand der NWSIB entspricht.</AccessConstraints>
+		<AccessConstraints>Die Stra�endaten wurden freundlicherweise vom Landesbetrieb Stra�enbau NRW zur Verf�gung gestellt. Es handelt sich hierbei um einen unvollst�ndigen Datenauszug, der nicht dem aktuellen Stand der NWSIB entspricht.</AccessConstraints>
 	</Service>
 	<Capability>
 		<Request>
@@ -12826,7 +12826,7 @@
 		</Exception>
 		<Layer queryable="0">
-			<Title>verfügbare Layer</Title>
+			<Title>verf�gbare Layer</Title>
 			<SRS>EPSG:31466 EPSG:31467 EPSG:31468 EPSG:31469 EPSG:4326</SRS>
 			<LatLonBoundingBox minx="5.65296386" miny="50.31247805" maxx="9.61606634" maxy="52.54258946"/>
 			<BoundingBox SRS="EPSG:31466" minx="2475321.110" miny="5575227.309" maxx="2745328.607" maxy="5829431.962" resx="1" resy="1"/>
@@ -12852,7 +12852,7 @@
 			</Layer>
 			<Layer queryable="1" opaque="0">
 				<Name>Aeste</Name>
-				<Title>Äste</Title>
+				<Title>�ste</Title>
 			</Layer>
 				<Name>Netzknoten</Name>
@@ -12875,7 +12875,7 @@
 			</Layer>
 				<Name>Strassenbez.</Name>
-				<Title>Straßenbez.</Title>
+				<Title>Stra�enbez.</Title>
 			</Layer>
 				<Name>Abschnittsnr.</Name>
@@ -12908,7 +12908,7 @@
 				</Layer>
 					<Name>Kreise_/_kreisfreie_Staedte</Name>
-					<Title>Kreise / kreisfreie Städte</Title>
+					<Title>Kreise / kreisfreie St�dte</Title>
 				</Layer>
 					<Name>Gemeinden</Name>
@@ -12919,12 +12919,12 @@
 				<Title>Rasterkarten</Title>
 				<Layer queryable="0" opaque="1">
 					<Name>Strassenkarte</Name>
-					<Title>Straßenkarte</Title>
+					<Title>Stra�enkarte</Title>
 				</Layer>
 			</Layer>
 		</Layer>
 	</Capability>
-</WMT_MS_Capabilities>', NULL, 'http://services.gis-consult.de/NWSIB-online/GCGisService?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0', 'none', 'Die Straßendaten wurden freundlicherweise vom Landesbetrieb Straßenbau NRW zur Verfügung gestellt. Es handelt sich hierbei um einen unvollständigen Datenauszug, der nicht dem aktuellen Stand der NWSIB entspricht.', 'Christian Vogt', 'Geschäftsführer', 'GIS Consult GmbH', 'Schultenbusch 3', 'Haltern am See', 'D', '45721', 'Germany', '+49 2364 9218-31', '+49 2364 9218-72', 'vogt at gis-consult.de', NULL, 1, 1173698122);
+</WMT_MS_Capabilities>', NULL, 'http://services.gis-consult.de/NWSIB-online/GCGisService?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0', 'none', 'Die Stra�endaten wurden freundlicherweise vom Landesbetrieb Stra�enbau NRW zur Verf�gung gestellt. Es handelt sich hierbei um einen unvollst�ndigen Datenauszug, der nicht dem aktuellen Stand der NWSIB entspricht.', 'Christian Vogt', 'Gesch�ftsf�hrer', 'GIS Consult GmbH', 'Schultenbusch 3', 'Haltern am See', 'D', '45721', 'Germany', '+49 2364 9218-31', '+49 2364 9218-72', 'vogt at gis-consult.de', NULL, 1, 1173698122);
 INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (671, '1.1.0', 'Wasserschutzgebiete NRW', 'This is an OGC compliant MapService served By ESRI. The engine used to serve this MapService is ArcIMS', 'http://www.gis2.nrw.de/wmsconnector/wms/wsg?', 'http://www.gis2.nrw.de/wmsconnector/wms/wsg?', 'http://www.gis2.nrw.de/wmsconnector/wms/wsg?', '', '', '<?xml version="1.0" encoding="UTF-8"?>
 <!DOCTYPE WMT_MS_Capabilities SYSTEM "http://www.gis2.nrw.de/wmsconnector/schema/wms/1.1.0/capabilities_1_1_0.dtd" [
 <!-- Vendor-specific elements are defined here if needed. -->
@@ -14672,11 +14672,11 @@
 <Service>
-  <Title>SÅ?ubfurt</Title>
-  <Abstract>SÅ?ubfurter Mental Map Survey 2000 - 2002.</Abstract>
+  <Title>S�?ubfurt</Title>
+  <Abstract>S�?ubfurter Mental Map Survey 2000 - 2002.</Abstract>
         <KeywordList>
-          <Keyword>SÅ?ubfurt</Keyword>
-          <Keyword> SÅ?ubice</Keyword>
+          <Keyword>S�?ubfurt</Keyword>
+          <Keyword> S�?ubice</Keyword>
           <Keyword> Frankfurt (Oder)</Keyword>
           <Keyword> topophilia</Keyword>
           <Keyword> mental maps</Keyword>
@@ -14783,7 +14783,7 @@
   <UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0"/>
   <Layer>
     <Name>SLUBFURT</Name>
     <SRS>EPSG:25832</SRS>
@@ -14800,8 +14800,8 @@
     <ScaleHint min="0.0623629" max="31.1814" />
     <Layer queryable="0" opaque="1" cascaded="0">
         <Name>slubfurtmap</Name>
-        <Title>SÅ?ubfurt City Map</Title>
-        <Abstract>SÅ?ubfurter City Map</Abstract>
+        <Title>S�?ubfurt City Map</Title>
+        <Abstract>S�?ubfurter City Map</Abstract>
@@ -14817,7 +14817,7 @@
         <Name>Mentalscape</Name>
         <Title>Mentalscape</Title>
-        <Abstract>SÅ?ubfurter Mental Map Survey 2000 - 2002: mentalscape</Abstract>
+        <Abstract>S�?ubfurter Mental Map Survey 2000 - 2002: mentalscape</Abstract>
@@ -17013,7 +17013,7 @@
 <WMT_MS_Capabilities  version="1.1.1" updateSequence="1.1.0"><Service><Name>OGC:WMS</Name><Title>WMS-Thueringen</Title><Abstract>wms reference implementation</Abstract><KeywordList><Keyword>deegree</Keyword><Keyword>wms</Keyword></KeywordList><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.webmap-test.thueringen.de/deegreewms"/><ContactInformation><ContactPersonPrimary><ContactPerson>F. Engel</ContactPerson><ContactOrganization>Geoinformationszentrum</ContactOrganization></ContactPersonPrimary><ContactPosition>Consultant</ContactPosition><ContactAddress><AddressType/><Address>Hohenwindenstrasse 13a</Address><City>Erfurt</City><StateOrProvince>Thueringen</StateOrProvince><PostCode>99096</PostCode><Country/></ContactAddress><ContactElectronicMailAddress>f.engel at tlverma.thueringen.de</ContactElectronicMailAddress></ContactInformation><Fees>none</Fees><AccessConstraints>none</AccessConstraints></Service><Capability><Request><GetCapabilities><Format>application/vnd.ogc.wms_xml</Format><DCPType><HTTP><Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.webmap-test.thueringen.de/deegreewms/wms?"/></Get></HTTP></DCPType></GetCapabilities><GetMap><Format>image/png</Format><Format>image/jpeg</Format><Format>image/tif</Format><Format>image/svg+xml</Format><Format>image/bmp</Format><Format>image/gif</Format><Format>image/jpg</Format><DCPType><HTTP><Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.webmap-test.thueringen.de/deegreewms/wms?"/></Get><Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.webmap-test.thueringen.de/deegreewms/wms?"/></Post></HTTP></DCPType></GetMap><GetFeatureInfo><Format>text/html</Format><Format>application/vnd.ogc.gml</Format><Format>text/plain</Format><DCPType><HTTP><Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.webmap-test.thueringen.de/deegreewms/wms?"/></Get></HTTP></DCPType></GetFeatureInfo></Request><Exception><Format>application/vnd.ogc.se_xml</Format><Format>application/vnd.ogc.se_inimage</Format><Format>application/vnd.ogc.se_blank</Format></Exception><Layer queryable="0" cascaded="0" opaque="0" noSubsets="0"><Title>TKVV</Title><Abstract>the top-level-layer of the deegree demo-CD</Abstract><KeywordList><Keyword>deegree</Keyword><Keyword>demo-CD</Keyword><Keyword>layer</Keyword></KeywordList><SRS>EPSG:31468</SRS><LatLonBoundingBox minx="-180.0" miny="-90.0" maxx="180.0" maxy="90.0"/><BoundingBox SRS="EPSG:31468" minx="4500038.056252609" miny="-1.0000959949100513E7" maxx="4500018.656164683" maxy="1.000096364770234E7"/><ScaleHint max="100.0" min="0.1"/><Layer queryable="0" opaque="0" noSubsets="0"><Name>Thueringer_Orthofotos</Name><Title>Thueringer_Orthofotos</Title><Abstract>cascaded WMS layers remote WFS and remote WCS examples</Abstract><LatLonBoundingBox minx="-180.0" miny="-90.0" maxx="180.0" maxy="90.0"/><Style><Name>default:Thueringer_Orthofotos</Name><Title>default:Thueringer_Orthofotos</Title><LegendURL width="20" height="20"><Format>image/png</Format><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.webmap-test.thueringen.de/deegreewms/legend/default_Thueringer_Orthofotos.png"/></LegendURL></Style><ScaleHint max="1.7976931348623157E308" min="0.0"/><Layer queryable="0" opaque="0" noSubsets="0" fixedWidth="0" fixedHeight="0"><Name>Orthophotos_TH-2m</Name><Title>Orthophotos_TH-2m</Title><LatLonBoundingBox minx="-180.0" miny="-90.0" maxx="180.0" maxy="90.0"/><Style><Name>default:Orthophotos_TH-2m</Name><Title>default:Orthophotos_TH-2m</Title><LegendURL width="20" height="20"><Format>image/png</Format><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.webmap-test.thueringen.de/deegreewms/legend/default_Orthophotos_TH-2m.png"/></LegendURL></Style><ScaleHint max="1.7976931348623157E308" min="0.0"/></Layer></Layer><Layer queryable="0" opaque="0" noSubsets="0"><Name>TK50</Name><Title>TK50</Title><Abstract>cascaded WMS layers remote WFS and remote WCS examples</Abstract><LatLonBoundingBox minx="-180.0" miny="-90.0" maxx="180.0" maxy="90.0"/><Style><Name>default:TK50</Name><Title>default:TK50</Title><LegendURL width="20" height="20"><Format>image/png</Format><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.webmap-test.thueringen.de/deegreewms/legend/default_TK50.png"/></LegendURL></Style><ScaleHint max="1.7976931348623157E308" min="0.0"/><Layer queryable="0" opaque="0" noSubsets="0" fixedWidth="0" fixedHeight="0"><Name>Top.Karte_50_gesamt</Name><Title>Top.Karte_50_gesamt</Title><LatLonBoundingBox minx="-180.0" miny="-90.0" maxx="180.0" maxy="90.0"/><Style><Name>default:Top.Karte_50_gesamt</Name><Title>default:Top.Karte_50_gesamt</Title><LegendURL width="20" height="20"><Format>image/png</Format><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.webmap-test.thueringen.de/deegreewms/legend/default_Top.Karte_50_gesamt.png"/></LegendURL></Style><ScaleHint max="1.7976931348623157E308" min="0.0"/></Layer><Layer queryable="0" opaque="0" noSubsets="0" fixedWidth="0" fixedHeight="0"><Name>Grundriss</Name><Title>Grundriss</Title><LatLonBoundingBox minx="-180.0" miny="-90.0" maxx="180.0" maxy="90.0"/><Style><Name>default:Grundriss</Name><Title>default:Grundriss</Title><LegendURL width="20" height="20"><Format>image/png</Format><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.webmap-test.thueringen.de/deegreewms/legend/default_Grundriss.png"/></LegendURL></Style><ScaleHint max="1.7976931348623157E308" min="0.0"/></Layer><Layer queryable="0" opaque="0" noSubsets="0" fixedWidth="0" fixedHeight="0"><Name>Gewaesser</Name><Title>Gewaesser</Title><LatLonBoundingBox minx="-180.0" miny="-90.0" maxx="180.0" maxy="90.0"/><Style><Name>default:Gewaesser</Name><Title>default:Gewaesser</Title><LegendURL width="20" height="20"><Format>image/png</Format><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.webmap-test.thueringen.de/deegreewms/legend/default_Gewaesser.png"/></LegendURL></Style><ScaleHint max="1.7976931348623157E308" min="0.0"/></Layer><Layer queryable="0" opaque="0" noSubsets="0" fixedWidth="0" fixedHeight="0"><Name>Hoehenschichten</Name><Title>Hoehenschichten</Title><LatLonBoundingBox minx="-180.0" miny="-90.0" maxx="180.0" maxy="90.0"/><Style><Name>default:Hoehenschichten</Name><Title>default:Hoehenschichten</Title><LegendURL width="20" height="20"><Format>image/png</Format><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.webmap-test.thueringen.de/deegreewms/legend/default_Hoehenschichten.png"/></LegendURL></Style><ScaleHint max="1.7976931348623157E308" min="0.0"/></Layer><Layer queryable="0" opaque="0" noSubsets="0" fixedWidth="0" fixedHeight="0"><Name>Strassen</Name><Title>Strassen</Title><LatLonBoundingBox minx="-180.0" miny="-90.0" maxx="180.0" maxy="90.0"/><Style><Name>default:Strassen</Name><Title>default:Strassen</Title><LegendURL width="20" height="20"><Format>image/png</Format><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.webmap-test.thueringen.de/deegreewms/legend/default_Strassen.png"/></LegendURL></Style><ScaleHint max="1.7976931348623157E308" min="0.0"/></Layer><Layer queryable="0" opaque="0" noSubsets="0" fixedWidth="0" fixedHeight="0"><Name>Wald</Name><Title>Wald</Title><LatLonBoundingBox minx="-180.0" miny="-90.0" maxx="180.0" maxy="90.0"/><Style><Name>default:Wald</Name><Title>default:Wald</Title><LegendURL width="20" height="20"><Format>image/png</Format><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://www.webmap-test.thueringen.de/deegreewms/legend/default_Wald.png"/></LegendURL></Style><ScaleHint max="1.7976931348623157E308" min="0.0"/></Layer></Layer></Layer></Capability></WMT_MS_Capabilities>', NULL, 'http://www.webmap-test.thueringen.de/deegreewms/wms?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1', 'none', 'none', 'F. Engel', 'Consultant', 'Geoinformationszentrum', 'Hohenwindenstrasse 13a', 'Erfurt', 'Thueringen', '99096', '', '', '', 'f.engel at tlverma.thueringen.de', NULL, 1, 1173698125);
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (908, '1.1.0', 'NRW: TK100 Farbe', 'Nutzungsbedingungen: Sämtliche Rechte an diesem Produkt liegen beim Landesvermessungsamt NRW. Die Nutzung ist bis auf Widerruf kostenfrei. Der Nutzer muss sich vor jeder Nutzung beim Landesvermessungsamt NRW identifizieren und seine spezielle Nutzung mit Angabe des Verwendungszwecks und Umfang der Nutzung anmelden (Kontaktmöglichkeiten zum Landesvermessungsamt NRW siehe unten). Die Nutzung ist ausschließlich für Testzwecke und im Rahmen von GDI-Projekten zulässig; die Nutzung für kommerzielle Anwendungen ist ausdrücklich ausgeschlossen. Die mittelbare oder unmittelbare Weitergabe der Daten an Dritte ist auch in Verbindung mit weiteren Daten ohne ausdrückliche Genehmigung durch das Landesvermessungsamt NRW nicht zulässig. Der Nutzer ist verpflichtet, einen deutlichen Copyright-Hinweis auf das Landesvermessungsamt NRW als Dateneigentümer bei Visualisierungen jeder Art anzubringen.', 'http://www.geoserver.nrw.de:80/GeoOgcWms1.3/servlet/TK100', 'http://www.geoserver.nrw.de:80/GeoOgcWms1.3/servlet/TK100', 'http://www.geoserver.nrw.de:80/GeoOgcWms1.3/servlet/TK100', '', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (908, '1.1.0', 'NRW: TK100 Farbe', 'Nutzungsbedingungen: S�mtliche Rechte an diesem Produkt liegen beim Landesvermessungsamt NRW. Die Nutzung ist bis auf Widerruf kostenfrei. Der Nutzer muss sich vor jeder Nutzung beim Landesvermessungsamt NRW identifizieren und seine spezielle Nutzung mit Angabe des Verwendungszwecks und Umfang der Nutzung anmelden (Kontaktm�glichkeiten zum Landesvermessungsamt NRW siehe unten). Die Nutzung ist ausschlie�lich f�r Testzwecke und im Rahmen von GDI-Projekten zul�ssig; die Nutzung f�r kommerzielle Anwendungen ist ausdr�cklich ausgeschlossen. Die mittelbare oder unmittelbare Weitergabe der Daten an Dritte ist auch in Verbindung mit weiteren Daten ohne ausdr�ckliche Genehmigung durch das Landesvermessungsamt NRW nicht zul�ssig. Der Nutzer ist verpflichtet, einen deutlichen Copyright-Hinweis auf das Landesvermessungsamt NRW als Dateneigent�mer bei Visualisierungen jeder Art anzubringen.', 'http://www.geoserver.nrw.de:80/GeoOgcWms1.3/servlet/TK100', 'http://www.geoserver.nrw.de:80/GeoOgcWms1.3/servlet/TK100', 'http://www.geoserver.nrw.de:80/GeoOgcWms1.3/servlet/TK100', '', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
 <!-- The DTD (Document Type Definition) given here must correspond to the version number declared in the WMT_MS_Capabilities element below. -->
   "http://www.geoserver.nrw.de/wmt/xml/capabilities_1_1_0.dtd"
@@ -17032,7 +17032,7 @@
   <!-- Human-readable title for pick lists -->
   <Title>NRW: TK100 Farbe</Title>
   <!-- Narrative description providing additional information -->
-      <Abstract>Nutzungsbedingungen: Sämtliche Rechte an diesem Produkt liegen beim Landesvermessungsamt NRW. Die Nutzung ist bis auf Widerruf kostenfrei. Der Nutzer muss sich vor jeder Nutzung beim Landesvermessungsamt NRW identifizieren und seine spezielle Nutzung mit Angabe des Verwendungszwecks und Umfang der Nutzung anmelden (Kontaktmöglichkeiten zum Landesvermessungsamt NRW siehe unten). Die Nutzung ist ausschließlich für Testzwecke und im Rahmen von GDI-Projekten zulässig; die Nutzung für kommerzielle Anwendungen ist ausdrücklich ausgeschlossen. Die mittelbare oder unmittelbare Weitergabe der Daten an Dritte ist auch in Verbindung mit weiteren Daten ohne ausdrückliche Genehmigung durch das Landesvermessungsamt NRW nicht zulässig. Der Nutzer ist verpflichtet, einen deutlichen Copyright-Hinweis auf das Landesvermessungsamt NRW als Dateneigentümer bei Visualisierungen jeder Art anzubringen.</Abstract>
+      <Abstract>Nutzungsbedingungen: S�mtliche Rechte an diesem Produkt liegen beim Landesvermessungsamt NRW. Die Nutzung ist bis auf Widerruf kostenfrei. Der Nutzer muss sich vor jeder Nutzung beim Landesvermessungsamt NRW identifizieren und seine spezielle Nutzung mit Angabe des Verwendungszwecks und Umfang der Nutzung anmelden (Kontaktm�glichkeiten zum Landesvermessungsamt NRW siehe unten). Die Nutzung ist ausschlie�lich f�r Testzwecke und im Rahmen von GDI-Projekten zul�ssig; die Nutzung f�r kommerzielle Anwendungen ist ausdr�cklich ausgeschlossen. Die mittelbare oder unmittelbare Weitergabe der Daten an Dritte ist auch in Verbindung mit weiteren Daten ohne ausdr�ckliche Genehmigung durch das Landesvermessungsamt NRW nicht zul�ssig. Der Nutzer ist verpflichtet, einen deutlichen Copyright-Hinweis auf das Landesvermessungsamt NRW als Dateneigent�mer bei Visualisierungen jeder Art anzubringen.</Abstract>
       <!-- Top-level web address of service or service provider.  See also OnlineResource
   elements under <DCPType>. -->
@@ -19170,8 +19170,8 @@
     <ScaleHint min="12.4731" max="1746.16" />
     <Layer queryable="1" opaque="0" cascaded="0">
         <Name>kreis</Name>
-        <Abstract>Landkreise und kreisfreie Städte</Abstract>
+        <Abstract>Landkreise und kreisfreie St�dte</Abstract>
@@ -19220,8 +19220,8 @@
     </Layer>
         <Name>lwas</Name>
-        <Abstract>Flüsse und Kanäle</Abstract>
+        <Abstract>Fl�sse und Kan�le</Abstract>
         <LatLonBoundingBox minx="11.2394" miny="51.3212" maxx="14.7654" maxy="53.5254" />
@@ -19250,8 +19250,8 @@
     </Layer>
         <Name>kstr</Name>
-        <Title>Kreisstraßen</Title>
-        <Abstract>Kreisstraßen</Abstract>
+        <Title>Kreisstra�en</Title>
+        <Abstract>Kreisstra�en</Abstract>
         <LatLonBoundingBox minx="11.2393" miny="51.3127" maxx="14.7641" maxy="53.5593" />
@@ -19260,8 +19260,8 @@
     </Layer>
         <Name>lstr</Name>
-        <Title>Landesstraßen</Title>
-        <Abstract>Landesstraßen</Abstract>
+        <Title>Landesstra�en</Title>
+        <Abstract>Landesstra�en</Abstract>
         <LatLonBoundingBox minx="11.3238" miny="51.3172" maxx="14.7548" maxy="53.5632" />
@@ -19270,8 +19270,8 @@
     </Layer>
         <Name>bstr</Name>
-        <Title>Bundesstraßen</Title>
-        <Abstract>Bundesstraßen</Abstract>
+        <Title>Bundesstra�en</Title>
+        <Abstract>Bundesstra�en</Abstract>
         <LatLonBoundingBox minx="11.2459" miny="51.3585" maxx="14.7403" maxy="53.4965" />
@@ -20882,7 +20882,7 @@
 </Capability>
 ', NULL, 'http://terraservice.net/ogccapabilities.ashx?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1', 'none', 'none', 'Tom Barclay', 'Researcher', 'Microsoft', '455 Market Street, Suite 1690', 'San Francisco', 'CA', '94105', 'USA', '+1 415 778 8223', '+1 425 706 7329', 'tbarclay at microsoft.com', NULL, 1, 1173698130);
-INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (905, '1.1.0', 'DNM FÜK', 'Digitales Navigationsmodell Flurübersichtskarte der Brandenburger Landesvermessung', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMFUEK.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMFUEK.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMFUEK.map&', '', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
+INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (905, '1.1.0', 'DNM F�K', 'Digitales Navigationsmodell Flur�bersichtskarte der Brandenburger Landesvermessung', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMFUEK.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMFUEK.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMFUEK.map&', '', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
 <!DOCTYPE WMT_MS_Capabilities SYSTEM "http://www.digitalearth.gov/wmt/xml/capabilities_1_1_0.dtd"
@@ -20894,8 +20894,8 @@
 <Service>
-  <Title>DNM FÜK</Title>
-  <Abstract>Digitales Navigationsmodell Flurübersichtskarte der Brandenburger Landesvermessung</Abstract>
+  <Title>DNM F�K</Title>
+  <Abstract>Digitales Navigationsmodell Flur�bersichtskarte der Brandenburger Landesvermessung</Abstract>
   <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&amp;map=wms/DNMFUEK.map&amp;"/>
         <KeywordList>
           <Keyword>DNM</Keyword>
@@ -20953,7 +20953,7 @@
   <VendorSpecificCapabilities />
   <Layer>
     <Name>Brandenburg</Name>
     <LatLonBoundingBox minx="10.8594" miny="51.1966" maxx="15.0908" maxy="53.6627" />
@@ -20988,7 +20988,7 @@
     </Layer>
         <Name>stadt</Name>
-        <Title>Kreisfreie Städte</Title>
+        <Title>Kreisfreie St�dte</Title>
         <LatLonBoundingBox minx="12.3551" miny="51.6655" maxx="14.607" maxy="52.5623" />
@@ -21087,8 +21087,8 @@
         <Name>kreis</Name>
@@ -21117,8 +21117,8 @@
     </Layer>
         <Name>lwas</Name>
         <LatLonBoundingBox minx="11.3337" miny="51.3295" maxx="14.6826" maxy="53.4539" />
@@ -21147,8 +21147,8 @@
     </Layer>
         <Name>lstr</Name>
         <LatLonBoundingBox minx="11.3234" miny="51.318" maxx="14.7561" maxy="53.5644" />
@@ -21157,8 +21157,8 @@
     </Layer>
         <Name>bstr</Name>
         <LatLonBoundingBox minx="11.2485" miny="51.3577" maxx="14.747" maxy="53.4523" />
@@ -21212,7 +21212,7 @@
     <ContactAddress>
         <AddressType></AddressType>
         <Address>Albersloher Weg 33</Address>
-        <City>Münster</City>
+        <City>M�nster</City>
         <StateOrProvince></StateOrProvince>
         <PostCode>48155</PostCode>
         <Country>Germany</Country>
@@ -21358,7 +21358,7 @@
   </Layer>
 </Capability>
-', NULL, 'http://geo.stadt-muenster.de/cgi-bin/geobasis?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0', 'none', 'none', 'Norbert Dephoff', '', 'Vermessungs- und Katasteramt', 'Albersloher Weg 33', 'Münster', '', '48155', 'Germany', '', '', 'dephoffn at stadt-muenster.de', NULL, 1, 1173698462);
+', NULL, 'http://geo.stadt-muenster.de/cgi-bin/geobasis?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0', 'none', 'none', 'Norbert Dephoff', '', 'Vermessungs- und Katasteramt', 'Albersloher Weg 33', 'M�nster', '', '48155', 'Germany', '', '', 'dephoffn at stadt-muenster.de', NULL, 1, 1173698462);
 INSERT INTO wms (wms_id, wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, wms_getfeatureinfo, wms_getlegendurl, wms_filter, wms_getcapabilities_doc, wms_owsproxy, wms_upload_url, fees, accessconstraints, contactperson, contactposition, contactorganization, address, city, stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, wms_mb_getcapabilies_doc, wms_owner, wms_timestamp) VALUES (906, '1.1.0', 'DNM VG', 'Digitales Navigationsmodell Verwaltungsgrenzen als Basisnavigationsdaten der Brandenburger Landesvermessung', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMVG.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMVG.map&', 'http://geoservice.geobasis-bb.de/cgi-bin/proxy?USER_ID=GAST12345678&map=wms/DNMVG.map&', '', NULL, '<?xml version=''1.0'' encoding="ISO-8859-1" standalone="no" ?>
@@ -21466,7 +21466,7 @@
     </Layer>
         <Name>amt</Name>
-        <Title>Ämter</Title>
+        <Title>�mter</Title>
         <LatLonBoundingBox minx="11.2423" miny="51.3099" maxx="14.7656" maxy="53.4443" />
@@ -21475,7 +21475,7 @@
     </Layer>
         <Name>stadt</Name>
@@ -21529,7 +21529,7 @@
     </Layer>
         <Name>namt</Name>
-        <Title>Namen der Ämter</Title>
+        <Title>Namen der �mter</Title>
@@ -22895,5 +22895,308 @@
 INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (706, 'EPSG:4326');
 INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (903, 'EPSG:25833');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui','switchLocale_noreload',8,1,'changes the locale without reloading the client','Set language','div','','frameborder=''0''',696,14,50,30,5,'','<form id=''form_switch_locale'' name=''form_switch_locale'' target=''parent''>
+<select id=''language'' name=''language'' onchange=''validate_locale()''>
+</select>
+</form>
+','div','mod_switchLocale_noreload.php','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'switchLocale_noreload', 'languages', 'de,en,bg,gr,nl,it,es', '' ,'var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_closetag, e_js_file) VALUES('gui1', 'popup', 6, 1, 'popup replacement', 'div', 'div', 'popup.js');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Pan', 'Ausschnitt verschieben');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Display complete map', 'gesamte Karte anzeigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom in', 'In die Karte hineinzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom out', 'Aus der Karte herauszoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Back', 'Zurück');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Forward', 'Nach vorne');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Coordinates', 'Koordinaten anzeigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom by rectangle', 'Ausschnitt wählen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Redraw', 'Neu laden oder Tastatur: Leertaste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Query', 'Datenabfrage');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Logout', 'Abmelden');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'WMS preferences', 'WMS Einstellungen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS from filtered list', 'WMS von gefilteter Liste hinzufügen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set map center', 'Kartenmittelpunkt setzen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Help', 'Hilfe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Show WMS infos', 'Anzeige von WMS Informationen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Save workspace as web map context document', 'Ansicht als Web Map Context Dokument speichern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Resize Mapsize', 'Bildschirmgröße anpassen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Rubber', 'Skizze löschen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Get Area', 'Fläche berechnen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Close Polygon', 'Polygon schliessen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Move back to your GUI list', 'Zurück zur GUI Liste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Legend', 'Legende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Print', 'Druck');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Imprint', 'Impressum');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Maps', 'Karten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Search', 'Suche');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Meetingpoint', 'Treffpunkt');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Metadatasearch', 'Metadatensuche');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS', 'WMS hinzufügen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS from List', 'WMS aus Liste hinzufügen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Change Projection', 'Projektion ändern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Digitize', 'Digitalisierung');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Overview', 'Übersichtskarte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Drag Mapsize', 'Karte vergrößern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Mapframe', 'Kartenfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Navigation Frame', 'Navigationsfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scale Select', 'Auswahl des Maßstabes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scale Text', 'Maßstab per Texteingabe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scalebar', 'Maßstabsleiste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set Background', 'Hintegrundkarte auswählen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom to Coordinates', 'Zu den Koordinaten zoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Change Password', 'Passwort ändern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Load a web map context document', 'laden eines Web Map Context Dokumentes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de ', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Pan', 'Премести областта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Display complete map', 'Покажи цялата карта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom in', 'Покажи картата в по-едър мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom out', 'Покажи картата в по-дребен мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Back', 'Назад');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Forward', 'Напред');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Coordinates', 'Координати');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom by rectangle', 'Увеличи картата в избраната област');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Redraw', 'Пречертай или от клавиатурата: празен интервал');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Query', 'Зявка към данните');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Logout', 'Изход на потребител');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'WMS preferences', 'WMS настройки');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS from filtered list', 'Добави WMS от избран списък');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Set map center', 'Постави център на карта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Help', 'Помощ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Show WMS infos', 'Покажи WMS информация');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Save workspace as web map context document', 'Запази работния документ като Web Map Context документ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Resize Mapsize', 'Напасни големината на картата');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Rubber', 'Изтрий');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Get Area', 'Изчисли площ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Close Polygon', 'Затвори полигон');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Move back to your GUI list', 'Назад към списъка с интерфейси (GUI)');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Legend', 'Легенда');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Print', 'Печат');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Imprint', 'Авторско каре');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Maps', 'Карти');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Search', 'Търсене');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Meetingpoint', 'Място на среща');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Metadatasearch', 'Търсене по метаданни');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS', 'Добави WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS from List', 'Добави WMS от списък');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Info', 'Информация');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Change Projection', 'Промени проекция');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Copyright', 'Авторско право');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Digitize', 'Дигитализиране');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Overview','Обзорна карта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Drag Mapsize', 'Промени размера на картата');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Mapframe', 'Рамка на картата');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Navigation Frame', 'Навигационна рамка');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scale Select', 'Избор на мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scale Text', 'Въведи мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scalebar', 'Мащабна скала');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Set Background', 'Избери фоново изображение');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom to Coordinates', 'Покажи картата около посочените координати');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Change Password', 'Промени парола');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Load a web map context document', 'Зареди Web Map Context документ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Logo', 'Фирмен знак');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Measure distance', 'Измери разстояние');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Pan', 'Μετακίνηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Display complete map', 'Επίδειξη Πλήρους Χάρτη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom in', 'Zoom In');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom out', 'Zoom Out');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Back', 'Πίσω');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Forward', 'Πρόσθια');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Coordinates', 'Συντεταγμένες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom by rectangle', 'Ζουμ από ορθογώνιο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Redraw', 'Απόσυρση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Query', 'Μέτρηση Εμβαδού');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Logout', 'Αποσύνδεση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'WMS preferences', 'Αλλάξτε τη διάταξη των WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS from filtered list', 'Πρόσθεση WMS από το φιλτραρισμένο κατάλογο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Set map center', 'Το καθορισμένο Κέντρο Χαρτών');
+INSERT INTO translations (locale, msgid, msgstr) VALUES  ('gr', 'Help', 'Βοήθεια');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Save workspace as web map context document', 'Ansicht als Web Map Context Dokument speichern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Rubber', 'Το λάστιχο- Τρίφτης');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Close Polygon', 'Το Κλειστό Πολύγωνο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ( 'gr', 'Move back to your GUI list', 'Παρουσίαση του GUI Καταλόγου');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Print', 'Εκτύπωση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Maps', ' Χάρτες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS', 'Πρόσθεση WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS from List', 'Πρόσθεση WMS από τον κατάλογο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Navigation Frame', 'Navigationsfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Load a web map context document', 'laden eines Web Map Context Dokumentes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Measure distance', 'Μέτρηση Απόστασης');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Meetingpoint', 'Σημείο Συνάντησης');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Info', 'Πληροφορίες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Digitize', 'Ψηφιοποίηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Change Projection', 'Αλλαγή Προβολής');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Set Background', 'Επιλογή Φόντου');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Overview', 'Προεπισκόπιση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Change Password', 'Αλλαγή Συνθηματικού');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scalebar', 'Κανόνας Κλίμακας');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr ', 'Logo', 'Λογότυπο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom to Coordinates', 'Εστίαση σε Συντεταγμένες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scale Text', 'Κείμενο Κλίμακας');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Show WMS infos', 'Προβολή WMS πληροφοριών');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Legend', 'Λεζάντα');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Search', 'Αναζήτηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Resize Mapsize', 'Αλλαγή Μεγέθους Χάρτη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Drag Mapsize', 'Αλλαγή Μεγέθους Χάρτη με Ολίσθηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Mapframe', 'Πλαίσιο Χάρτη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Get Area', 'Προβολή Περιοχής');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Imprint', 'Αποτύπωση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scale Select', 'Επιλογή Κλίμακας');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Metadatasearch', 'Αναζήτηση στα Metadata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Pan', 'Selectie verschuiven');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Display complete map', 'Hele kaart tonen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom in', 'Inzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom out', 'Uitzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Back', 'Terug');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Forward', 'Voorwaarts');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Coordinates', 'Koordinaten tonen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom by rectangle', 'Zoom rechthoek-selectie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Redraw', 'Opfrissen of toetsenbord : spatiebalk');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Query', 'Data opvragen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Logout', 'Afmelden');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'WMS preferences', 'WMS instellingen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS from filtered list', 'WMS van gefilterte lijst toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set map center', 'Kaartmiddelpunt aangeven');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Help', 'Help');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Show WMS infos', 'Tonen van WMS Informatie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Save workspace as web map context document', 'zicht als Web map context dokument bewaren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Resize Mapsize', 'beeldschermgrote aanpassen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Rubber', 'schets verwerpen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Get Area', 'oppervlakte berekenen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Close Polygon', 'Polygoon sluiten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Move back to your GUI list', 'Terug naar GUI lijst');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Legend', 'Legende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Print', 'Drukken');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Imprint', 'Impressum');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Maps', 'Kaarten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Search', 'Zoek');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Meetingpoint', 'Trefpunt');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Metadatasearch', 'Zoeken naar Metadata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS', 'WMS toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS from List', 'WMS uit lijst toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Info', 'Informatie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Change Projection', 'Projektie veranderen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Digitize', 'Digitaliseren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Overview', 'overzichtskaart');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Drag Mapsize', 'Kaart vergroten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Mapframe', 'Kaartvenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Navigation Frame', 'Navigeervenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scale Select', 'Schaal selecteren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scale Text', 'Schaal via tekstingave');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scalebar', 'Schaalbalk');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set Background', 'Achtergrond selecteren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom to Coordinates', 'Naar koordinaten zoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Change Password', 'Paswoord wijzigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Load a web map context document', 'Laad een Web Map Context Dokument');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Measure distance', 'Meet afstand');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Pan', 'Sposta dettaglio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Display complete map', 'Mostra tutta la mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom in', 'Ingrandisci');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom out', 'Riduci');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Back', 'Indietro');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Forward', 'Avanti');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Coordinates', 'Mostra coordinate');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom by rectangle', 'Seleziona dettaglio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Redraw', 'Ridisegna oppure, da tastiera: spazio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Query', 'Interroga');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Logout', 'Logout');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'WMS preferences', 'Impostazioni WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS from filtered list', 'Aggiungi un WMS da una lista filtrata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set map center', 'Fissa il centro della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Help', 'Aiuto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Show WMS infos', 'Mostra informazioni sul WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Save workspace as web map context document', 'Salva vista come documento di Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Resize Mapsize', 'Adatta la dimensione della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Rubber', 'Cancella bozza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Get Area', 'Calcola area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Close Polygon', 'Chiudi poligono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Move back to your GUI list', 'Torna alla lista delle GUI');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Legend', 'Legenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Print', 'Stampa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Imprint', 'Colophon');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Maps', 'Mappe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Search', 'Cerca');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Meetingpoint', 'Punti di incontro');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Metadatasearch', 'Ricerca metadati');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS', 'Aggiungi WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS from List', 'Aggiungi WMS da lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Change Projection', 'Cambia proiezione');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Digitize', 'Digitalizza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Overview', 'Mappa di insieme');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Drag Mapsize', 'Cambia dimensione mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Mapframe', 'Quadro della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Navigation Frame', 'Quadro di navigazione');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scale Select', 'Scelta della scala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scale Text', 'Scala dei testi');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scalebar', 'Scala di riferimento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set Background', 'Seleziona mappa di sfondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom to Coordinates', 'Ingrandisci alle coordinate');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Change Password', 'Cambia password');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Load a web map context document', 'Carica un documento Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Measure distance', 'Misura distanza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Pan', 'Desplazamiento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Display complete map', 'Desplazamiento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom in', 'Zoom +');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom out', 'Zoom -');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Back', 'Zoom previo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Forward', 'Zoom siguiente');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Coordinates', 'Mostrar coordenadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom by rectangle', 'Zoom rectángulo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Redraw', 'Refrescar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Query', 'Busqueda de datos');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Logout', 'Terminar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'WMS preferences', 'Ajuste WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS from filtered list', 'Anadir WMS desde lista filtrada');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set map center', 'Centrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Help', 'Ayuda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Show WMS infos', 'Mostrar información sobre WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Save workspace as web map context document', 'Guardar vista como fichero Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Resize Mapsize', 'Modificar el tamano de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Rubber', 'Borrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Get Area', 'Calcular area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Close Polygon', 'Cerrar polígono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Move back to your GUI list', 'Volver a la lista WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Legend', 'Leyenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Print', 'Imprimir');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Imprint', 'Aviso legal');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Maps', 'Mapas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Search', 'Busqueda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Meetingpoint', 'Lugar de reunión');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Metadatasearch', 'Búsqueda de datos meta');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS', 'Añadir WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS from List', 'Añadir WMS desde lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Info', 'Informacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Change Projection', 'Cambiar projecto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Digitize', 'Digitalización');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Overview', 'Mapa de visión general');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Drag Mapsize', 'Ampilar vista de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Mapframe', 'Ventana de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Navigation Frame', 'Ventana de navigacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scale Select', 'Selecionar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scale Text', 'Teclar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scalebar', 'Fraja de escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set Background', 'Poner el fondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom to Coordinates', 'Zoom en coordenadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Change Password', 'Cambiar clave');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Load a web map context document', 'Cargar un documento de Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Measure distance', 'Medir distancias');
 SET FOREIGN_KEY_CHECKS=1;
Modified: branches/nimix_dev/resources/db/mysql/utf8/mysql_data.sql
--- branches/nimix_dev/resources/db/mysql/utf8/mysql_data.sql	2008-04-02 07:59:47 UTC (rev 2330)
+++ branches/nimix_dev/resources/db/mysql/utf8/mysql_data.sql	2008-04-02 08:09:18 UTC (rev 2331)
@@ -1,4 +1,4 @@
 -- mysql data utf8
 -- Mapbender (Version: 2.4.2)
@@ -22903,4 +22903,308 @@
+</select>
+</form>
Modified: branches/nimix_dev/resources/db/postgresql/iso/pgsql_data.sql
--- branches/nimix_dev/resources/db/postgresql/iso/pgsql_data.sql	2008-04-02 07:59:47 UTC (rev 2330)
+++ branches/nimix_dev/resources/db/postgresql/iso/pgsql_data.sql	2008-04-02 08:09:18 UTC (rev 2331)
@@ -1,4 +1,4 @@
 -- postgresql data iso
@@ -22894,6 +22894,309 @@
 INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (906, 'EPSG:25833');
+</select>
+</form>
 UPDATE pg_catalog.pg_class SET reltriggers = (SELECT pg_catalog.count(*) FROM pg_catalog.pg_trigger where pg_class.oid = tgrelid) ;
Modified: branches/nimix_dev/resources/db/postgresql/utf8/pgsql_data.sql
--- branches/nimix_dev/resources/db/postgresql/utf8/pgsql_data.sql	2008-04-02 07:59:47 UTC (rev 2330)
+++ branches/nimix_dev/resources/db/postgresql/utf8/pgsql_data.sql	2008-04-02 08:09:18 UTC (rev 2331)
@@ -22998,7 +22998,309 @@
+</select>
+</form>
\ No newline at end of file
Modified: branches/nimix_dev/resources/db/update/mod_switchLocale_noreload.sql
--- branches/nimix_dev/resources/db/update/mod_switchLocale_noreload.sql	2008-04-02 07:59:47 UTC (rev 2330)
+++ branches/nimix_dev/resources/db/update/mod_switchLocale_noreload.sql	2008-04-02 08:09:18 UTC (rev 2331)
@@ -1,2 +1,6 @@
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui','switchLocale_noreload',8,1,'changes the locale without reloading the client','Set language','iframe','../php/mod_switchLocale_noreload.php','frameborder=''0''',720,14,50,30,5,'','','iframe','','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'switchLocale_noreload', 'languages', 'de,en,bg,gr,nl,it,es', '' ,'php_var');
+</select>
+</form>
Modified: branches/nimix_dev/resources/db/update/update_guis_iso.sql
--- branches/nimix_dev/resources/db/update/update_guis_iso.sql	2008-04-02 07:59:47 UTC (rev 2330)
+++ branches/nimix_dev/resources/db/update/update_guis_iso.sql	2008-04-02 08:09:18 UTC (rev 2331)
@@ -848,7 +848,15 @@
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+</select>
+</form>
Modified: branches/nimix_dev/resources/db/update/update_guis_utf8.sql
--- branches/nimix_dev/resources/db/update/update_guis_utf8.sql	2008-04-02 07:59:47 UTC (rev 2330)
+++ branches/nimix_dev/resources/db/update/update_guis_utf8.sql	2008-04-02 08:09:18 UTC (rev 2331)
@@ -817,8 +817,15 @@
+</select>
+</form>
Modified: branches/nimix_dev/resources/db/update/update_mysql_db.sql
--- branches/nimix_dev/resources/db/update/update_mysql_db.sql	2008-04-02 07:59:47 UTC (rev 2330)
+++ branches/nimix_dev/resources/db/update/update_mysql_db.sql	2008-04-02 08:09:18 UTC (rev 2331)
@@ -138,55 +138,251 @@
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Pan', 'Премести областта');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Display complete map', 'Покажи цялата карта');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Zoom in', 'Покажи картата в по-едър мащаб');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Zoom out', 'Покажи картата в по-дребен мащаб');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Back', 'Назад');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Forward', 'Напред');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Coordinates', 'Координати');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Zoom by rectangle', 'Увеличи картата в избраната област');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Redraw', 'Пречертай или от клавиатурата: празен интервал');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Query', 'Зявка към данните');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Logout', 'Изход на потребител');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'WMS preferences', 'WMS настройки');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Adding WMS from filtered list', 'Добави WMS от избран списък');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Set map center', 'Постави център на карта');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Help', 'Помощ');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Show WMS infos', 'Покажи WMS информация');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Save workspace as web map context document', 'Запази работния документ като Web Map Context документ');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Resize Mapsize', 'Напасни големината на картата');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Rubber', 'Изтрий');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Get Area', 'Изчисли площ');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Close Polygon', 'Затвори полигон');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Move back to your GUI list', 'Назад към списъка с интерфейси (GUI)');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Legend', 'Легенда');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Print', 'Печат');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Imprint', 'Авторско каре');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Maps', 'Карти');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Search', 'Търсене');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Meetingpoint', 'Място на среща');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Metadatasearch', 'Търсене по метаданни');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Adding WMS', 'Добави WMS');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Adding WMS from List', 'Добави WMS от списък');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Info', 'Информация');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Change Projection', 'Промени проекция');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Copyright', 'Авторско право');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Digitize', 'Дигитализиране');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Overview','Обзорна карта');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Drag Mapsize', 'Промени размера на картата');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Mapframe', 'Рамка на картата');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Navigation Frame', 'Навигационна рамка');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Scale Select', 'Избор на мащаб');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Scale Text', 'Въведи мащаб');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Scalebar', 'Мащабна скала');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Set Background', 'Избери фоново изображение');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Zoom to Coordinates', 'Покажи картата около посочените координати');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Change Password', 'Промени парола');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Load a web map context document', 'Зареди Web Map Context документ');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Logo', 'Фирмен знак');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('bga', 'Measure distance', 'Измери разстояние');
 -- new table gui_kml
More information about the Mapbender_commits mailing list
