[Mapbender-commits] r2357 - trunk/build
svn_mapbender at osgeo.org
Mon Apr 7 09:11:20 EDT 2008
Author: christoph
Date: 2008-04-07 09:11:20 -0400 (Mon, 07 Apr 2008)
New Revision: 2357
trunk/build/build.sh
fixed bug in jsdoc
set correct mime type for html files
Modified: trunk/build/build.sh
--- trunk/build/build.sh 2008-04-07 12:50:26 UTC (rev 2356)
+++ trunk/build/build.sh 2008-04-07 13:11:20 UTC (rev 2357)
@@ -26,8 +26,8 @@
# path to "extension" folder in Mapbender
EXT_PATH="http/extensions"
-# array of javascript files for JSDoc
-JSDOC_F=("$JS_PATH/geometry.js" "$JS_PATH/point.js" "$JS_PATH/map.js" "$JS_PATH/map_obj.js" "$EXT_PATH/wz_jsgraphics.js")
+# string containing javascript files for JSDoc
+JSDOC_F="$JS_PATH/geometry.js $JS_PATH/point.js $JS_PATH/map.js $JS_PATH/map_obj.js $EXT_PATH/wz_jsgraphics.js"
# array of javascript files for JSMin
JSMIN_F=("$JS_PATH/geometry.js" "$JS_PATH/point.js" "$JS_PATH/map.js" "$JS_PATH/map_obj.js" "$EXT_PATH/jquery.js" "$EXT_PATH/wz_jsgraphics.js")
@@ -50,11 +50,7 @@
#compile JSDoc
echo "compiling JSDoc ..."
-for name in ${JSDOC_F[@]}
-do
- echo "extracting doc from $FOLDER/$name"
- perl $JSDOC_PATH/jsdoc.pl $FOLDER/$name
-done
+perl $JSDOC_PATH/jsdoc.pl $FOLDER/$JSDOC_F
#move JSDoc to folder
mkdir $FOLDER/documents 2>/dev/null
@@ -65,10 +61,12 @@
#check in JSDOC
echo "committing JSDoc ..."
svn add -q $FOLDER/documents/
-# to do: set property svn:mime-type text/html for all html files
-# cannot be set for folder, we have to do a for loop over all files
-# this doesn't work:
-# svn propset svn:mime-type text/html $FOLDER/documents/*.html
+# set property svn:mime-type text/html for all html files
+for file in `dir -d $FOLDER/documents/jsdoc/*.html`
+do
+ svn propset svn:mime-type text/html $file 2>/dev/null
+done
svn commit -q -m updated_documentation --username $2 --password $3 $FOLDER/documents/
#compile PHPDoc
More information about the Mapbender_commits
